# Automatically generated file; DO NOT EDIT.
# NationalChip Voice Signal Process Configuration
# CONFIG_GX8010NRE is not set
CONFIG_GX8008B=y
CONFIG_MCU_ARCH="csky"
CONFIG_MCU_TYPE="ck802"
CONFIG_MCU_LINK_SCRIPT="arch/soc/gx8008b/link.ld"
CONFIG_SOC_MODEL="gx8008b"
CONFIG_SOC_SRAM_SIZE_KB=1536
CONFIG_BOARD_VENDOR="nationalchip"
CONFIG_BOARD_MODEL="leo_mini_gx8008c_wukong_prime_1_4v"
CONFIG_SYS_CONFIG_NAME="leo_mini_gx8008c_wukong_prime_1_4v"
# CONFIG_BOARD_SUPPORT_MULTIBOOT is not set
CONFIG_BOARD_MIC_NUM=4
CONFIG_BOARD_LED_NUM=1
# CONFIG_BOARD_HAS_MUTE_BTN is not set
CONFIG_BOARD_SUPPORT_ANALOG_VAD_WAKEUP=y
# CONFIG_BOARD_VENDOR_AIROUTER is not set
# CONFIG_BOARD_VENDOR_AISPEECH is not set
# CONFIG_BOARD_VENDOR_AOVEISE is not set
# CONFIG_BOARD_VENDOR_BAIDU is not set
# CONFIG_BOARD_VENDOR_BENEWTECH is not set
# CONFIG_BOARD_VENDOR_BOTHLENT is not set
# CONFIG_BOARD_VENDOR_BTSTEREO is not set
# CONFIG_BOARD_VENDOR_BYTEDANCE is not set
# CONFIG_BOARD_VENDOR_COCHEER is not set
# CONFIG_BOARD_VENDOR_CYLAN is not set
# CONFIG_BOARD_VENDOR_DANGBEI is not set
# CONFIG_BOARD_VENDOR_DONGDONG is not set
# CONFIG_BOARD_VENDOR_EST is not set
# CONFIG_BOARD_VENDOR_GLOBALPAT is not set
# CONFIG_BOARD_VENDOR_GOERTEK is not set
# CONFIG_BOARD_VENDOR_GUANGDIAN is not set
# CONFIG_BOARD_VENDOR_HAOZO is not set
# CONFIG_BOARD_VENDOR_HICHIPS is not set
# CONFIG_BOARD_VENDOR_HIKVISION is not set
# CONFIG_BOARD_VENDOR_HORN is not set
# CONFIG_BOARD_VENDOR_ICAROOM is not set
# CONFIG_BOARD_VENDOR_IFLYTEK is not set
# CONFIG_BOARD_VENDOR_JD is not set
# CONFIG_BOARD_VENDOR_JIARENZHINENG is not set
# CONFIG_BOARD_VENDOR_JMGO is not set
# CONFIG_BOARD_VENDOR_KEJIA is not set
# CONFIG_BOARD_VENDOR_LIANGBA is not set
# CONFIG_BOARD_VENDOR_MEITONG_360 is not set
# CONFIG_BOARD_VENDOR_MERRY_USB_HEADSET is not set
# CONFIG_BOARD_VENDOR_MKTECH is not set
CONFIG_BOARD_VENDOR_NATIONALCHIP=y
# CONFIG_BOARD_VENDOR_NEWLAND is not set
# CONFIG_BOARD_VENDOR_POROS is not set
# CONFIG_BOARD_VENDOR_POWER_STRONIC is not set
# CONFIG_BOARD_VENDOR_QIANAN_USB_HEADSET is not set
# CONFIG_BOARD_VENDOR_QINQI is not set
# CONFIG_BOARD_VENDOR_RAYLEIGHLABS is not set
# CONFIG_BOARD_VENDOR_ROKID is not set
# CONFIG_BOARD_VENDOR_SHENGHAN is not set
# CONFIG_BOARD_VENDOR_SKYWORTH_INSTITUTE is not set
# CONFIG_BOARD_VENDOR_SKYWORTH is not set
# CONFIG_BOARD_VENDOR_SZHKLT is not set
# CONFIG_BOARD_VENDOR_UGREEN is not set
# CONFIG_BOARD_VENDOR_XIAOHI is not set
# CONFIG_BOARD_VENDOR_XIMALAYA is not set
# CONFIG_BOARD_VENDOR_ZIMI is not set
# CONFIG_BOARD_GX8008B_DEV_V1 is not set
# CONFIG_BOARD_GX8008B_UAC_1V is not set
# CONFIG_BOARD_GX8008C_ACM_BOARD_1_0V is not set
# CONFIG_BOARD_GX8008C_ALEXA_BOARD_2_0V is not set
# CONFIG_BOARD_GX8008C_BK3266_CONFERENCE_1V is not set
# CONFIG_BOARD_GX8008C_CARKIT_1V is not set
# CONFIG_BOARD_GX8008C_CONFERENCE_SYSTEM_2V is not set
# CONFIG_BOARD_GX8008C_DMIC_TEST_1V is not set
# CONFIG_BOARD_GX8008C_JL_WIRELESS_MIC_1V is not set
# CONFIG_BOARD_GX8008C_MICROSOFT_MONO_USB_MICROPHONE_1V is not set
# CONFIG_BOARD_GX8008C_SMART_SWITCH_1V is not set
# CONFIG_BOARD_GX8008C_USB_MICROPHONE_1V is not set
CONFIG_BOARD_GX8008C_WUKONG_PRIME_1_4V=y
# CONFIG_BOARD_GX8008C_WUKONG_PRIME_1V is not set
# CONFIG_BOARD_GX8008C_WUKONG_ZERO_DEV_1V is not set
# CONFIG_BOARD_GX8008C_ZENCHANT_AC892X_1V is not set
# CONFIG_BOARD_HAS_I2S_REF is not set
CONFIG_BOARD_HAS_I2S_OUT=y
# CONFIG_BOARD_HAS_I2C0 is not set
# CONFIG_BOARD_HAS_I2C1 is not set
CONFIG_BOARD_HAS_UART0=y
CONFIG_BOARD_HAS_UART1=y
# CONFIG_BOARD_HAS_DSP_UART is not set
# CONFIG_BOARD_HAS_SPI1 is not set
CONFIG_BOARD_AIN_CHANNEL_0=0
CONFIG_BOARD_AIN_CHANNEL_1=1
CONFIG_BOARD_AIN_CHANNEL_2=2
CONFIG_BOARD_AIN_CHANNEL_3=3
CONFIG_BOARD_REF_CHANNEL_0=3
CONFIG_BOARD_REF_CHANNEL_1=3
CONFIG_BOARD_AMIC_GAIN=24
CONFIG_BOARD_HAS_I2S_OUT_16K=y
# CONFIG_BOARD_HAS_LED_G is not set
# CONFIG_BOARD_HAS_LED_B is not set
CONFIG_BOARD_AMIC_REF_GAIN=0
CONFIG_BOARD_GX8008C_WUKONG_PRIME_1_4_0V=y
# Board Options:
# Part of Options depend PIN`s Function
# some options may be conflict             -WATCH OUT!-
# Select what you want
# CONFIG_BOARD_ENABLE_SPK is not set
# Does not support Red LED lights
CONFIG_BOARD_HAS_AMIC=y
# CONFIG_BOARD_HAS_DMIC is not set
# CONFIG_BOARD_HAS_NO_MIC is not set
CONFIG_BOARD_HAS_AMIC_REF=y
# CONFIG_BOARD_HAS_DMIC_REF is not set
# CONFIG_BOARD_HAS_I2S_S_REF is not set
# CONFIG_BOARD_HAS_I2S_M_REF is not set
CONFIG_BOARD_DIGITAL_VAD=y
# CONFIG_BOARD_ANALOG_VAD is not set
# Frequence settings
CONFIG_XTAL_FREQUENCE_12M=y
# CONFIG_XTAL_FREQUENCE_12_288M is not set
# CONFIG_XTAL_FREQUENCE_24_576M is not set
CONFIG_PLL_FREQUENCE_1200M=y
# CONFIG_PLL_FREQUENCE_600M is not set
# CONFIG_PLL_FREQUENCE_408M is not set
# CONFIG_PLL_FREQUENCE_300M is not set
CONFIG_AUDIO_FREQUENCE_761_856M=y
# CONFIG_MCU_FREQUENCE_50M is not set
# CONFIG_MCU_FREQUENCE_100M is not set
CONFIG_MCU_FREQUENCE_150M=y
# CONFIG_DSP_FREQUENCE_50M is not set
# CONFIG_DSP_FREQUENCE_100M is not set
# CONFIG_DSP_FREQUENCE_150M is not set
# CONFIG_DSP_FREQUENCE_200M is not set
# CONFIG_DSP_FREQUENCE_300M is not set
CONFIG_DSP_FREQUENCE_400M=y
# CONFIG_DSP_FREQUENCE_516M is not set
# CONFIG_SRAM_FREQUENCE_50M is not set
# CONFIG_SRAM_FREQUENCE_100M is not set
# CONFIG_SRAM_FREQUENCE_150M is not set
CONFIG_SRAM_FREQUENCE_300M=y
# CONFIG_FLASH_FREQUENCE_37_5M is not set
# CONFIG_FLASH_FREQUENCE_50M is not set
CONFIG_FLASH_FREQUENCE_75M=y
# MCU settings
CONFIG_MCU_ENABLE_PRINTF=y
CONFIG_MCU_ENABLE_UART_PRINTF=y
# CONFIG_MCU_ENABLE_USB_PRINTF is not set
# CONFIG_MCU_ENABLE_DEBUG is not set
# CONFIG_MCU_ENABLE_TTYACM_THROUGH_USB is not set
# CONFIG_MCU_BUILD_SCHEMA_DEBUG is not set
# CONFIG_MCU_BUILD_SCHEMA_RELEASE is not set
# CONFIG_MCU_BUILD_SCHEMA_OPTIMIZED_SPEED is not set
CONFIG_MCU_BUILD_SCHEMA_OPTIMIZED_SIZE=y
CONFIG_MCU_ENABLE_SPI_DMA_FOR_FLASH=y
# CONFIG_MCU_ENABLE_SPI_NOR_USE_4K_SECTORS is not set
# CONFIG_MCU_FLASH_SPI_DUAL is not set
CONFIG_MCU_FLASH_SPI_QUAD=y
# CONFIG_MCU_FLASH_SPI_AUTO is not set
# CONFIG_MCU_ENABLE_EASY_FLASH is not set
# CONFIG_MCU_ENABLE_EASY_LOGGER is not set
CONFIG_MCU_MAIN_STACK_SIZE=3
# CONFIG_MCU_ENABLE_STACK_MONITORING is not set
CONFIG_MCU_BOOT_ENABLE_INIT_BOARD=y
CONFIG_MCU_BOOT_ENABLE_SPIFLASH_LOADER=y
# CONFIG_MCU_ENABLE_SPL_INTC is not set
# CONFIG_MCU_ENABLE_BOOT_TOOL is not set
CONFIG_MCU_ENABLE_XIP=y
CONFIG_MCU_DEFAULT_TEXT_IN_SRAM=y
# CONFIG_MCU_DEFAULT_TEXT_IN_FLASH is not set
CONFIG_MCU_UDC_ENABLED=y
CONFIG_MCU_UDC_WORK_IN_FULL_SPEED=y
CONFIG_MCU_UDC_ENABLE_CLOCK_SYNC_BY_SOF=y
# CONFIG_MCU_UDC_ENABLE_UAC2 is not set
# CONFIG_MCU_UDC_UAC2_ENABLE_PLAYBACK is not set
# CONFIG_MCU_UDC_UAC2_ENABLE_CAPTURE is not set
CONFIG_MCU_UDC_UAC2_CAPTURE_CHANNEL=4
CONFIG_MCU_UDC_UAC2_CAPTURE_TERMINAL_TYPE=0x201
CONFIG_MCU_UDC_ENABLE_UAC1=y
# CONFIG_MCU_UDC_UAC1_ENABLE_PLAYBACK is not set
CONFIG_MCU_UDC_UAC1_ENABLE_CAPTURE=y
# CONFIG_MCU_UDC_ENABLE_HID is not set
# CONFIG_MCU_UDC_HID_PROTOCOL_KEYBOARD is not set
# CONFIG_MCU_UDC_HID_PROTOCOL_NONE is not set
# CONFIG_MCU_UDC_HID_PROTOCOL_TEAMS is not set
# CONFIG_MCU_UDC_HID_PROTOCOL_HUACHUANGSHIXUN is not set
# CONFIG_MCU_UDC_HID_PROTOCOL_GENERIC_VOLUME_CONTROL is not set
# CONFIG_MCU_UDC_HID_PROTOCOL_GENERIC_VOLUME_CONTROL_WITH_OTA is not set
# CONFIG_MCU_UDC_HID_ENABLE_DOWNSTREAM is not set
# CONFIG_MCU_UDC_ENABLE_GS is not set
# CONFIG_MCU_UDC_ENABLE_MS is not set
# CONFIG_MCU_UDC_ENABLE_NAKED_IN_CONFIG1 is not set
# CONFIG_MCU_UDC_ENABLE_NAKED_IN_CONFIG2 is not set
# CONFIG_MCU_UDC_ENABLE_LS is not set
# CONFIG_MCU_ENABLE_ARCLIB is not set
# CONFIG_MCU_ENABLE_MULTI_BUTTON is not set
# DSP settings
CONFIG_DSP_TOOLCHAIN_PATH="~/xtensa"
CONFIG_GXHifi4_170719A_G1708=y
# CONFIG_GXHifi4_220409A_RI2108_XC is not set
# CONFIG_DSP_BUILD_SCHEMA_DEBUG is not set
# CONFIG_DSP_BUILD_SCHEMA_RELEASE is not set
CONFIG_DSP_BUILD_SCHEMA_OPTIMIZED=y
# CONFIG_DSP_BUILD_SCHEMA_CUSTOMIZED is not set
CONFIG_DSP_EXTRA_COMPILE_FLAGS=""
CONFIG_DSP_SRAM_SIZE_KB=1290
CONFIG_DSP_ARCH="xtensa"
CONFIG_DSP_TYPE="hifi4"
CONFIG_DSP_LSP="min-rt"
CONFIG_DSP_LSP_XIP="min-rt-xip"
CONFIG_DSP_LSP_DDR="min-rt-ddr"
CONFIG_DSP_PTCM_BASE=0x00900000
CONFIG_DSP_PTCM_SIZE=65536
CONFIG_DSP_DTCM_BASE=0x00910000
CONFIG_DSP_DTCM_SIZE=65536
CONFIG_ENCRYPTION_KEY_NATIONALCHIP=y
# CONFIG_ENCRYPTION_KEY_CHIPGUIDE is not set
# CONFIG_DSP_ENABLE_EXCEPTION_HANDLER is not set
# CONFIG_DSP_ENABLE_PROCESS_CYCLE_STATISTIC is not set
# CONFIG_DSP_ENABLE_HEAP_MEMORY_MONITOR is not set
# CONFIG_DSP_ENABLE_PRINTF is not set
CONFIG_DSP_ENABLE_WAITI=y
CONFIG_DSP_ENABLE_XIP=y
CONFIG_DSP_XIP_SIZE_KB=1024
# VSP I/O Buffer settings
# Channel settings:
CONFIG_MIC_ARRAY_MIC_NUM=2
CONFIG_VSP_REF_NUM=1
CONFIG_VSP_RX_NUM=0
CONFIG_VSP_SPK_NUM=1
CONFIG_VSP_OUT_NUM=4
CONFIG_VSP_OUT_INTERLACED=y
CONFIG_VSP_OUT_INTERLACED_NUM=4
# Frame settings:
# CONFIG_VSP_SAMPLE_RATE_8K is not set
CONFIG_VSP_SAMPLE_RATE_16K=y
# CONFIG_VSP_SAMPLE_RATE_48K is not set
# CONFIG_VSP_FRAME_LENGTH_2MS is not set
# CONFIG_VSP_FRAME_LENGTH_3MS is not set
# CONFIG_VSP_FRAME_LENGTH_4MS is not set
CONFIG_VSP_FRAME_LENGTH_10MS=y
# CONFIG_VSP_FRAME_LENGTH_16MS is not set
CONFIG_VSP_FRAME_BIT_16=y
# CONFIG_VSP_FRAME_BIT_24 is not set
# Context settings:
CONFIG_VSP_FRAME_NUM_PER_CONTEXT=4
CONFIG_VSP_CONTEXT_GAP=4
# Command Queue settings (The command is sent from mcu to cpu):
CONFIG_VSP_COMMAND_NUMBER=0
CONFIG_VSP_COMMAND_GAP=0
CONFIG_VSP_COMMAND_DATA_SIZE=0
# DDR Buffer settings:
CONFIG_VSP_DDR_FRAME_NUM_PER_CHANNEL=120
CONFIG_VSP_DDR_CONTEXT_NUM=30
CONFIG_VSP_DDR_TEMP_BUFFER_SIZE=0
CONFIG_VSP_BUFFER_HAS_SRAM_MIC=y
CONFIG_VSP_BUFFER_HAS_SRAM_REF=y
CONFIG_VSP_BUFFER_HAS_SRAM_CTX=y
# SRAM Buffer settings:
CONFIG_VSP_SRAM_FRAME_NUM_PER_CHANNEL=80
CONFIG_VSP_SRAM_CONTEXT_NUM=4
# VSP Workmode settings
CONFIG_VSP_INIT_WORKMODE_UAC=y
# CONFIG_VSP_HAS_UPGRADE_MODE is not set
# --- GX8008 ---
CONFIG_VSP_HAS_UAC_MODE=y
CONFIG_VSP_UAC_PROGRAM_STANDARD=y
# CONFIG_VSP_UAC_PROGRAM_POROS is not set
CONFIG_VSP_UAC_VERSION_1=y
# CONFIG_VSP_UAC_VERSION_2 is not set
CONFIG_VSP_UAC_NAME_IN_WINDOWS="NationalChip UAC1.0"
CONFIG_VSP_UAC_MANUFACTURER_NAME="NationalChip"
CONFIG_VSP_UAC_PRODUCT_NAME="NationalChip UAC Dongle"
CONFIG_VSP_UAC_SERIAL_NUMBER="88156088"
CONFIG_MCU_USB_VID=0x1d6b
CONFIG_MCU_USB_PID=0xa4a7
# CONFIG_VSP_UAC_MODE_ENABLE_SEND_HID is not set
CONFIG_VSP_UAC_MODE_ENABLE_CAPTURE=y
# CONFIG_VSP_UAC_MODE_CAPTURE_SAMPLE_RATE_8K is not set
CONFIG_VSP_UAC_MODE_CAPTURE_SAMPLE_RATE_16K=y
# CONFIG_VSP_UAC_MODE_CAPTURE_SAMPLE_RATE_32K is not set
# CONFIG_VSP_UAC_MODE_CAPTURE_SAMPLE_RATE_48K is not set
# CONFIG_VSP_UAC_MODE_CAPTURE_SAMPLE_RATE_64K is not set
# CONFIG_VSP_UAC_MODE_CAPTURE_SAMPLE_RATE_80K is not set
# CONFIG_VSP_UAC_MODE_CAPTURE_SAMPLE_RATE_96K is not set
CONFIG_MCU_UDC_UAC2_CAPTURE_TERMINAL_TYPE_201=y
# CONFIG_MCU_UDC_UAC2_CAPTURE_TERMINAL_TYPE_205 is not set
# CONFIG_MCU_UDC_UAC2_CAPTURE_TERMINAL_TYPE_405 is not set
# CONFIG_VSP_UAC_CAPTURE_ADVANCED_CONTROL is not set
# CONFIG_VSP_UAC_MODE_ENABLE_PLAYBACK is not set
CONFIG_VSP_UAC_MODE_ENABLE_AUDIO_OUT=y
CONFIG_VSP_UAC_MODE_AUDIO_OUT_SOURCE_FROM_SPK=y
# CONFIG_VSP_UAC_MODE_AUDIO_OUT_SOURCE_FROM_OUTPUT is not set
# CONFIG_VSP_UAC_MODE_AUDIO_OUT_SOURCE_FROM_MIC is not set
# CONFIG_VSP_UAC_MODE_AUDIO_OUT_SOURCE_FROM_NULL is not set
# CONFIG_VSP_UAC_MODE_AUDIO_OUT_SAMPLE_RATE_8K is not set
CONFIG_VSP_UAC_MODE_AUDIO_OUT_SAMPLE_RATE_16K=y
# CONFIG_VSP_UAC_MODE_AUDIO_OUT_SAMPLE_RATE_32K is not set
# CONFIG_VSP_UAC_MODE_AUDIO_OUT_SAMPLE_RATE_48K is not set
CONFIG_VSP_UAC_MODE_AUDIO_OUT_CHANNEL_TYPE_MONO=y
# CONFIG_VSP_UAC_MODE_AUDIO_OUT_CHANNEL_TYPE_STEREO is not set
CONFIG_VSP_UAC_WORKS_ON_SRAM=y
# CONFIG_VSP_UAC_WORKS_ON_DDR is not set
# CONFIG_VSP_UAC_WORKS_ON_LINUX is not set
# CONFIG_VSP_UAC_WITHOUT_DSP is not set
CONFIG_VSP_UAC_CONTEXT_OFFSET_BETWEEN_MIC_AND_REF=1
# CONFIG_VSP_UAC_ENABLE_UAC_LED is not set
# CONFIG_VSP_UAC_USING_GADGET_SERIAL is not set
# CONFIG_VSP_UAC_MODE_ENABLE_AGC is not set
# CONFIG_VSP_UAC_MODE_ENABLE_MASS_STORAGE is not set
# CONFIG_VSP_HAS_PLC_MODE is not set
# CONFIG_VSP_HAS_CODEC_MODE is not set
# CONFIG_VSP_HAS_FACTORY_MODE is not set
# CONFIG_VSP_HAS_OTP_MODE is not set
# VSP Basic Functions settings
# CONFIG_VSP_HAS_TTS_PLAYER is not set
# CONFIG_VSP_LED_RING_PLAYER_ENABLE is not set
# CONFIG_VSP_UART_MESSAGE_UNENABLE is not set
# CONFIG_VSP_UART_MESSAGE_ENABLE_V1_0 is not set
CONFIG_VSP_UART_MESSAGE_ENABLE_V2_0=y
# CONFIG_VSP_VOICE_PLAYER_ENABLE is not set
CONFIG_VSP_PLC_ENABLE_SYS_EVENT=y
# CONFIG_VSP_I2SIN_SLAVE_PLAYER_ENABLE is not set
# CONFIG_VSP_AGC_FUNCTION_ENABLE is not set
# CONFIG_VSP_STANDBY_FUNCTION_ENABLE is not set
# CONFIG_VSP_PDU_FUNCTION_ENABLE is not set
# CONFIG_VSP_CACHE_WAKEUP_AUDIO_ENABLE is not set
# CONFIG_VSP_IR_COMMUNICATION_FUNCTION_ENABLE is not set
# VSP Customize Functions Settings
CONFIG_VSP_CUSTOMIZE_FUNCTION_TUYA_AIOT=y
# CONFIG_VSP_CUSTOMIZE_FUNCTION_NULL is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_BLUETOOTH_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_BLUETOOTH_V2_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_SIMULATOR_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_SIMULATOR_V2_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_COMPATIBLE_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_ARC_HB1688_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_BK7251_8008C_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_8008C_BK3266_CONFERENCE_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_CONFERENCE_V2_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_CONFERENCE_V3_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_CODEC_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_ONESHORT_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_UART_RECORD_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_I2C_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_FILL_SPK_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_JL_WIRELESS_MIC_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_WEI_MAI_TONG_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_HID_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_DOA_LED_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_KOKI_DOA is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_ACM_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_SPI_CODEC_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_SPI_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_LED_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_XIP_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_PDU_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_EASY_LOGGER_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_SWEEPER_LED_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_SRP_BUTTON_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_IR_COMMUNICATION_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_VOICE_PLAY_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_VOICE_PLAY_DEMO_V2_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_GPIO_SIMULATION_UART_DEMO_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_SED_DEMO is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_KEJIA_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_COCHEER_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_DANGBEI_F1_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_HICHIPS_K7338_AC6925B_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_POWERSTRONIC_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_ZIMI_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_HAIER_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_DONGDONG_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_HUACHUANGSHIXUN_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_ROKID_KRAIL_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_ROKID_IHANGER_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_BANG_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_AOPU_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_BYTEDANCE_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_AOPU_BATH_HEATER_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_ZENCHANT_MASSAGE_CHAIR_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_GUANGDIAN_CONFERENCE_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_QINQI_V1_0 is not set
# CONFIG_VSP_CUSTOMIZE_FUNCTION_NATIONALCHIP_ALEXA_HOOK_V1_0 is not set
# Customize Functions Setting
CONFIG_VSP_VPA_EXT_BUFFER_SIZE=1
# CONFIG_VSP_VPA_AISPEECH_BIN is not set
# CONFIG_VSP_VPA_AISPEECH_LIB is not set
# CONFIG_VSP_VPA_ALANGO_LIB is not set
# CONFIG_VSP_VPA_ALANGO_SRP_LIB is not set
# CONFIG_VSP_VPA_ALANGO_VCP is not set
# CONFIG_VSP_VPA_ARACH is not set
# CONFIG_VSP_VPA_BYPASS_BIN is not set
# CONFIG_VSP_VPA_BYPASS is not set
# CONFIG_VSP_VPA_EXAMPLE_LIB is not set
# CONFIG_VSP_VPA_EXAMPLE is not set
# CONFIG_VSP_VPA_FACTORY is not set
# CONFIG_VSP_VPA_HEFEI_SANEN is not set
# CONFIG_VSP_VPA_HORIZON_BIN is not set
# CONFIG_VSP_VPA_HORIZON_LIB is not set
# CONFIG_VSP_VPA_HORIZON_VOIP_LIB is not set
# CONFIG_VSP_VPA_IFLYTEK is not set
# CONFIG_VPA_OLAB_ALEXA is not set
# CONFIG_VSP_VPA_OLAB_KOKI is not set
# CONFIG_VSP_VPA_OLAB_NN is not set
# CONFIG_VPA_OLAB_OP_NNN is not set
CONFIG_VPA_OLAB_OP=y
# CONFIG_VPA_OLAB_STONE is not set
# CONFIG_VPA_OLAB_TIGER is not set
# CONFIG_VSP_VPA_OLAB_WWE is not set
# CONFIG_VSP_VPA_OWL is not set
# CONFIG_VSP_VPA_PULAO is not set
# CONFIG_VSP_VPA_QDREAMER_VOIP_LIB is not set
# CONFIG_VSP_VPA_ROKID_LIB is not set
# CONFIG_VSP_VPA_SANEN_VOIP_LIB is not set
# CONFIG_VSP_VPA_SED is not set
# CONFIG_VSP_VPA_SOUNDAI_LIB is not set
# CONFIG_VSP_VPA_TEMPLATE_BIN is not set
# CONFIG_VSP_VPA_TEMPLATE_LIB is not set
# CONFIG_VSP_VPA_TEMPLATE is not set
# CONFIG_VSP_VPA_XIP_EXAMPLE is not set
CONFIG_VSP_VPA_COPY_OUTPUT_CHANNEL_TO_SPK=y
CONFIG_VSP_VPA_COPY_OUTPUT_CHANNEL_TO_SPK_INDEX_L=0
CONFIG_PREFIX_CHAR_LENGTH=8
CONFIG_VPA_AEC_REF_DELAY_TIME_MS=0
CONFIG_VPA_AGC_TX_TARGETLEVELDBFS=3
CONFIG_VPA_AGC_TX_COMPRESSIONGAINDB=10
CONFIG_ICA_V2=y
CONFIG_OUT_BEAM_NUM=0
CONFIG_ICA_FFT_LENGTH=1024
CONFIG_ICA_DR_FILTER_LENGTH=1
CONFIG_ICA_SKIP_FRE_BINS=1
# CONFIG_ENABLE_ICA_CHANNEL_CHOOSE is not set
CONFIG_ENABLE_ICA_CUT_MEMORY=y
# Olab OP Settings
CONFIG_VSP_VPA_OLAB_OP_ENABLE_LOGFBANK=y
# VMA Settings
CONFIG_VSP_VPA_OLAB_OP_MICROPHONE_DISTANCE=32
# AEC Settings
CONFIG_VSP_VPA_OLAB_OP_ENABLE_AEC=y
CONFIG_VSP_VPA_OLAB_OP_AEC_FILTER_LENGTH=2048
CONFIG_VSP_VPA_OLAB_OP_AEC_FLOATING_POINT=y
# CONFIG_VSP_VPA_OLAB_OP_AEC_FIXED_POINT is not set
CONFIG_VSP_VPA_OLAB_OP_AEC_TALKING_MODE_ENABLE=y
CONFIG_VSP_VPA_OLAB_OP_AEC_TALKING_MODE_POST_PROCESS=y
# CONFIG_VSP_VPA_OLAB_OP_AEC_TALKING_MODE_NNAEC is not set
CONFIG_VSP_VPA_OLAB_OP_AEC_TALKING_MODE_POST_PROCESS_NORMAL=y
# CONFIG_VSP_VPA_OLAB_OP_AEC_TALKING_MODE_POST_PROCESS_WORSE_SPEAKER is not set
CONFIG_VSP_VPA_OLAB_OP_ACTIVE_DEFAULT_AEC_MODE_NORMAL=y
# CONFIG_VSP_VPA_OLAB_OP_ACTIVE_DEFAULT_AEC_MODE_TALKING is not set
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_RESAMPLE is not set
CONFIG_VSP_VPA_OLAB_OP_ENABLE_VAD=y
CONFIG_VSP_VPA_OLAB_OP_VAD_LATENCY=3
CONFIG_VSP_VPA_OLAB_OP_VAD_TIMEOUT=2
CONFIG_VSP_VPA_OLAB_OP_CTC_VAD_TIMEOUT_THRESHOLD=600
CONFIG_VSP_VPA_OLAB_OP_ENABLE_AGC=y
CONFIG_VSP_VPA_OLAB_OP_ENABLE_AGC_FOR_ASR=y
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_AGC_FOR_TALKING is not set
CONFIG_VSP_VPA_OLAB_OP_ENABLE_DENOISE=y
CONFIG_VSP_VPA_OLAB_OP_USE_WEBRTC_DENOISE=y
# CONFIG_VSP_VPA_OLAB_OP_USE_SPEEXDSP_DENOISE is not set
# CONFIG_VSP_VPA_OLAB_OP_USE_IMCRA_DENOISE is not set
CONFIG_VSP_VPA_OLAB_OP_ENABLE_OUTPUT0_DENOISE=y
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_MIC_DENOISE is not set
CONFIG_ACIIVE_MODEL_WEBRTC_DENOISE_LEVEL=2
CONFIG_TALKING_MODEL_WEBRTC_DENOISE_LEVEL=2
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_RNNOISE is not set
# Speech Array Enhance Algorithm Settings
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_DOA is not set
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_DEREVERB is not set
CONFIG_VSP_VPA_OLAB_OP_VSA=y
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_BEAMFORMING is not set
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_DUET is not set
CONFIG_VSP_VPA_OLAB_OP_ENABLE_ICA=y
# ICA Settings
# CONFIG_ENABLE_PREEMP_BEFORE_ICA is not set
# CONFIG_ENABLE_NORMAL_ICA_WHEN_AEC is not set
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_PHONE_HEADSET is not set
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_COPY_REF_TO_DECTET_KWS is not set
CONFIG_VSP_VPA_OLAB_OP_ENABLE_COPY_MIC_REF_TO_OUTPUT=y
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_EQUALIZER is not set
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_OUTPUT_ADPCM_ENCODE is not set
CONFIG_VSP_VPA_OLAB_OP_ENABLE_ENCODER=y
CONFIG_VSP_VPA_OLAB_OP_ENABLE_ENCODER_OPUS=y
# CONFIG_VSP_VPA_OLAB_OP_ENABLE_ENCODER_SPEEX is not set
CONFIG_VSP_VPA_OLAB_OP_OPUS_ENCODER_FROM_OUTPUT_CHANNEL=y
# CONFIG_VSP_VPA_OLAB_OP_OPUS_ENCODER_FROM_MIC_CHANNEL is not set
CONFIG_VSP_VPA_OLAB_OP_OPUS_ENCODER_OUTPUT_NUMBER=1
# CONFIG_VSP_VPA_OLAB_OP_ENCODER_VBR is not set
CONFIG_VSP_VPA_OLAB_OP_ENCODER_FRAME_SIZE=20
CONFIG_VSP_VPA_OLAB_OP_ENCODER_COMPLEXITY=4
CONFIG_VSP_VPA_OLAB_OP_ENCODER_BITRATE=16000
# CONFIG_ENABLE_VSP_VPA_MIC0_DELAY_IN_OUTPUT is not set
# VUI Settings
CONFIG_VPA_ENABLE_KEYWORD_RECOGNITION=y
CONFIG_KWS_SNPU_BUFFER_SIZE=6664
CONFIG_KWS_MODEL_FEATURES_DIM_PER_FRAME=40
CONFIG_KWS_MODEL_INPUT_STRIDE_LENGTH=4
CONFIG_KWS_MODEL_INPUT_WIN_LENGTH=13
CONFIG_KWS_MODEL_OUTPUT_LENGTH=1
CONFIG_HIFI4_NNLIB_V2=y
# CONFIG_VPA_ENABLE_CTC_DECODER is not set
# CONFIG_VPA_ENABLE_CTC_AND_BEAMSEARCH_DECODER is not set
# CONFIG_VPA_ENABLE_BEAMSEARCH_DECODER is not set
CONFIG_VPA_ENABLE_MAX_DECODER=y
# CONFIG_VPA_ENABLE_USER_DECODER is not set
# CONFIG_VPA_KWS_360_SWEEPING_ROBOT is not set
# CONFIG_VPA_KWS_XIAO_YOU_XIAO_YOU_AIR_CONDITIONER is not set
# CONFIG_VPA_KWS_ANKER_AUDIO is not set
# CONFIG_VPA_KWS_NI_HAO_XIAO_AO_AUPU_BATHROOM_HEATER is not set
# CONFIG_VPA_KWS_NI_HAO_XIAO_AO_AUPU_DRYING_RACK is not set
# CONFIG_VPA_KWS_XIAOBAOXIAOBAO is not set
# CONFIG_VPA_SED_KWS_EBL_KWS is not set
# CONFIG_VPA_KWS_ELECTRIC_FAN is not set
# CONFIG_VPA_KWS_GD_MEET_ENGLISH is not set
# CONFIG_VPA_KWS_GD_MEET is not set
# CONFIG_VPA_KWS_GENERAL_KWS is not set
# CONFIG_VPA_KWS_HANGSHENG_CAR is not set
# CONFIG_VPA_KWS_BUNKWS_HELLO_KUKA is not set
CONFIG_VPA_KWS_HEY_TUYA=y
# CONFIG_VPA_KWS_HIKIVISION_CAMERA is not set
# CONFIG_VPA_KWS_HI_XIAO_JING_YU is not set
# CONFIG_VPA_KWS_HUIKAIDA_EN_BATHROOM_FAN is not set
# CONFIG_VPA_KWS_JOMOO_DRYING_RACK is not set
# CONFIG_VPA_KWS_KUSAI_ROBOT is not set
# CONFIG_VPA_KWS_SWEEPER is not set
# CONFIG_VPA_KWS_SWEEPER_V2 is not set
# CONFIG_VPA_KWS_TUYA is not set
# CONFIG_VPA_KWS_XIAO_DU_XIAO_DU is not set
# CONFIG_VPA_KWS_XIAO_HE_XIAO_HE is not set
# CONFIG_VPA_KWS_XIAO_K_XIAO_K is not set
# CONFIG_VPA_KWS_XIAO_LAN_XIAO_LAN is not set
# CONFIG_VPA_KWS_XIAO_T_XIAO_T is not set
# CONFIG_VPA_KWS_XIAO_WEI_XIAO_WEI is not set
# CONFIG_VPA_KWS_XIAO_YA_XIAO_YA is not set
# CONFIG_VPA_KWS_YUEER_SPEAKER is not set
# CONFIG_VPA_KWS_ZENCHANT_IREST is not set
# CONFIG_VPA_KWS_ZENCHANT_MASSAGE_CHAIR is not set
# CONFIG_VPA_KWS_ZENCHANT_MUSI_MASSAGE_CHAIR is not set
CONFIG_VPA_KWS_HEY_TUYA_V0DOT1DOT0_2025_0819=y
CONFIG_KWS_MODEL_DECODER_STRIDE_LENGTH=1
CONFIG_KWS_MODEL_DECODER_WIN_LENGTH=38
# Model Param Setting:
# Kws List Settings
CONFIG_KEYWORD_ENABLE_HEY_TUYA=y
CONFIG_KEYWORD_HEY_TUYA_THRESHOLD=925
CONFIG_KEYWORD_HEY_TUYA_MODEL_IDX=0
CONFIG_KEYWORD_HEY_TUYA_VALUE=100
# CONFIG_VPA_ENABLE_BIONIC is not set
# CONFIG_VPA_ENABLE_DELAY_TO_DECODE is not set
CONFIG_VPA_WAIT_FEW_CTX_AFTER_KWS_ACTIVATION=0
CONFIG_KWS_MAX_DECODER_WIN_LENGTH=10
CONFIG_MODEL_ACTIVATION_NUMBERS=1
CONFIG_VPA_KWS_BATCH_NUM=3
CONFIG_VPA_KWS_ENABLE_MIC_PREEM=y
# CONFIG_VPA_ENABLE_ONLY_PRINTF_SCORE_WITHOUT_ACTIVATE is not set
CONFIG_VPA_ADJUST_THRESHOLD_IN_AEC=0
# CONFIG_VPA_ENABLE_EXPORT_KWS_VIA_OUTPUT0 is not set
# CONFIG_VPA_ENABLE_ROCK is not set
# CONFIG_VPA_ENABLE_ALEXA_AFE is not set
# CONFIG_VPA_ENABLE_SENSORY is not set
# CONFIG_VPA_ENABLE_DENOISE is not set
CONFIG_VPA_ENABLE_NNVAD=y
CONFIG_NNVAD_SNPU_BUFFER_SIZE=2240
CONFIG_NNVAD_MODEL_FEATURES_DIM_PER_FRAME=40
CONFIG_NNVAD_MODEL_INPUT_STRIDE_LENGTH=4
CONFIG_NNVAD_MODEL_INPUT_WIN_LENGTH=13
CONFIG_NNVAD_MODEL_OUTPUT_LENGTH=1
CONFIG_NNVAD_MODEL_USE_REF=y
CONFIG_NNVAD_THRESHOLD=600
CONFIG_VPA_NNVAD_MODEL_GENERAL_VAD=y
# CONFIG_VPA_NNVAD_MODEL_GENERAL_VAD_V0_2_2_20250529 is not set
# CONFIG_VPA_NNVAD_MODEL_GENERAL_VAD_V0_2_3_20250526 is not set
# CONFIG_VPA_NNVAD_MODEL_GENERAL_VAD_V0_2_4_20250604 is not set
# CONFIG_VPA_NNVAD_MODEL_GENERAL_VAD_V0_2_5_20250722 is not set
CONFIG_VPA_NNVAD_MODEL_GENERAL_VAD_VV0_2_9_20251131=y
CONFIG_VPA_NNVAD_BATCH_NUMBER=1
CONFIG_VSP_SOFTWARE_VERSION="3.0.6"
CONFIG_VSP_PROJECT_NAME="heytuya"
