    Phyplus Microelectronics Limited confidential and proprietary.
    All rights reserved.
    IMPORTANT: All rights of this software belong to Phyplus Microelectronics
    Limited ("Phyplus"). Your use of this Software is limited to those
    specific rights granted under  the terms of the business contract, the
    confidential agreement, the non-disclosure agreement and any other forms
    of agreements as a customer or a partner of Phyplus. You may not use this
    Software unless you agree to abide by the terms of these agreements.
    You acknowledge that the Software may not be modified, copied,
    distributed or disclosed unless embedded on a Phyplus Bluetooth Low Energy
    (BLE) integrated circuit, either as a product or is integrated into your
    products.  Other than for the aforementioned purposes, you may not use,
    reproduce, copy, prepare derivative works of, modify, distribute, perform,
    display or sell this Software and/or its documentation for any purposes.
    YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
    PROVIDED AS IS WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
    INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
    NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
    PHYPLUS OR ITS SUBSIDIARIES BE LIABLE OR OBLIGATED UNDER CONTRACT,
    NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
    LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
    INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
    OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
    OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
    (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
    @file   adc.c
    @brief  Contains all functions support for adc driver
    @version  0.0
    @date   18. Oct. 2017
    @author qing.han
#include "error.h"
#include "gpio.h"
#include "pwrmgr.h"
#include "clock.h"
#include "adc.h"
#include "log.h"
#include "jump_function.h"
#include "version.h"
#define    GET_IRQ_STATUS         (AP_ADCC->intr_status & 0x0003ffff)
#define    MAX_ADC_SAMPLE_SIZE     32
#define    ENABLE_ADC_COMPARE_INT       AP_ADCC->intr_mask |= 0x0003fc00
#define    MASK_ADC_COMPARE_INT         AP_ADCC->intr_mask &= 0xfffc03ff
static uint32_t adc_compare_enable_flag = 0;
static uint32_t adc_compare_filter_counter = 0;
static bool mAdc_init_flg = FALSE;
static adc_Ctx_t mAdc_Ctx =
    .enable = FALSE,
    .all_channel = 0x00,
    .chs_en_shadow = 0x00,
    .continue_mode = FALSE,
    .evt_handler = NULL
static uint8_t  adc_cal_read_flag = 0;
static uint16_t adc_cal_postive = 0x0fff;
static uint16_t adc_cal_negtive = 0x0fff;
gpio_pin_e s_pinmap[ADC_CH_NUM] =
    GPIO_DUMMY, //ADC_CH0 =0,
    GPIO_DUMMY, //ADC_CH1 =1,
    P11, //ADC_CH1N =2,
    P23, //ADC_CH1P =3,  ADC_CH1DIFF = 3,
    P24, //ADC_CH2N =4,
    P14, //ADC_CH2P =5,  ADC_CH2DIFF = 5,
    P15, //ADC_CH3N =6,
    P20, //ADC_CH3P =7,  ADC_CH3DIFF = 7,
    GPIO_DUMMY,  //ADC_CH_VOICE =8,
static bool high_threshold_flag = FALSE;
bool adc_get_high_threshold_flag(void)
    return high_threshold_flag;
void adc_set_high_threshold_flag(bool flag)
    high_threshold_flag = flag;
static void set_sampling_resolution(adc_CH_t channel, bool is_high_resolution,bool is_differential_mode)
    uint8_t aio = 0;
    uint8_t diff_aio = 0;
    switch(channel)
    case ADC_CH1N_P11:
        aio = 0;
        diff_aio = 1;
    case ADC_CH1P_P23:
        aio = 1;
        diff_aio = 0;
    case ADC_CH2N_P24:
        aio = 2;
        diff_aio = 3;
    case ADC_CH2P_P14:
        aio = 3;
        diff_aio = 2;
    case ADC_CH3N_P15:
        aio = 4;
        diff_aio = 7;
    case ADC_CH3P_P20:
        aio = 7;
        diff_aio = 4;
    if(is_high_resolution)
        if(is_differential_mode)
            subWriteReg(&(AP_AON->PMCTL2_1),(diff_aio+8),(diff_aio+8),0);
            subWriteReg(&(AP_AON->PMCTL2_1),diff_aio,diff_aio,1);
        subWriteReg(&(AP_AON->PMCTL2_1),(aio+8),(aio+8),0);
        subWriteReg(&(AP_AON->PMCTL2_1),aio,aio,1);
            subWriteReg(&(AP_AON->PMCTL2_1),(diff_aio+8),(diff_aio+8),1);
            subWriteReg(&(AP_AON->PMCTL2_1),diff_aio,diff_aio,0);
        subWriteReg(&(AP_AON->PMCTL2_1),(aio+8),(aio+8),1);
        subWriteReg(&(AP_AON->PMCTL2_1),aio,aio,0);
static void set_sampling_resolution_auto(uint8_t channel, uint8_t is_high_resolution,uint8_t is_differential_mode)
    uint8_t i_channel;
    adc_CH_t a_channel;
    AP_AON->PMCTL2_1 = 0x00;
    for(i_channel =2; i_channel<(ADC_CH_NUM-1); i_channel++)
        if(channel & BIT(i_channel))
            a_channel = (adc_CH_t)i_channel;
            set_sampling_resolution(a_channel,
                                    (is_high_resolution & BIT(i_channel)),
                                    (is_differential_mode & BIT(i_channel)));
static void set_differential_mode(void)
    subWriteReg(&( AP_PCRM->ANA_CTL),8,8,0);
    subWriteReg(&( AP_PCRM->ANA_CTL),11,11,0);
static void disable_analog_pin(adc_CH_t channel)
    int index = (int)channel;
    gpio_pin_e pin = s_pinmap[index];
    if(pin == GPIO_DUMMY)
    hal_gpio_cfg_analog_io(pin,Bit_DISABLE);
    hal_gpio_pin_init(pin,GPIO_INPUT);       //ie=0,oen=1 set to imput
    hal_gpio_pull_set(pin,GPIO_FLOATING);    //
void clear_adcc_cfg(void)
    mAdc_Ctx.all_channel = 0x00;
    mAdc_Ctx.chs_en_shadow = 0x00;
    mAdc_Ctx.continue_mode = FALSE;
    memset(&mAdc_Ctx, 0, sizeof(mAdc_Ctx));
/////////////// adc ////////////////////////////
    @fn          hal_ADC_IRQHandler
    @brief       This function process for adc interrupt
    input parameters
    @param       None.
    output parameters
    @param       None.
    @return      None.
void __attribute__((used)) hal_ADC_IRQHandler(void)
    int ch,status,ch2,n;
    uint16_t adc_data[(MAX_ADC_SAMPLE_SIZE-2)<<1];
    status = GET_IRQ_STATUS;
    MASK_ADC_INT;
    if(status == mAdc_Ctx.all_channel)
        for (ch = 2; ch <= ADC_CH9; ch++)
            if (status & BIT(ch))
                AP_ADCC->intr_mask &= ~BIT(ch);
                for (n = 0; n < (MAX_ADC_SAMPLE_SIZE-2); n++)
                    adc_data[n<<1] = (uint16_t)(read_reg(ADC_CH_BASE + (ch * 0x80) + ((n+2) * 4))&0xfff);
                    adc_data[(n<<1)+1] = (uint16_t)((read_reg(ADC_CH_BASE + (ch * 0x80) + ((n+2) * 4))>>16)&0xfff);
                AP_ADCC->intr_clear = BIT(ch);
                if(mAdc_Ctx.enable == FALSE)
                ch2=(ch%2)?(ch-1):(ch+1);
                if (mAdc_Ctx.evt_handler[ch2])
                    adc_Evt_t evt;
                    evt.type = HAL_ADC_EVT_DATA;
                    evt.ch = (adc_CH_t)ch2;
                    evt.data = adc_data;
                    evt.size = (MAX_ADC_SAMPLE_SIZE-2)<<1;
                    mAdc_Ctx.evt_handler[ch2](&evt);
                AP_ADCC->intr_mask |= BIT(ch);
        if(mAdc_Ctx.continue_mode == FALSE)
            hal_poilling_adc_stop();
    ENABLE_ADC_INT;
static void adc_wakeup_hdl(void)
    NVIC_SetPriority((IRQn_Type)ADCC_IRQn, IRQ_PRIO_HAL);
    @fn          hal_adc_init
    @brief       This function process for adc initial
    input parameters
    @param       ADC_MODE_e mode: adc sample mode select;1:SAM_MANNUAL(mannual mode),0:SAM_AUTO(auto mode)
                ADC_CH_e adc_pin: adc pin select;ADC_CH0~ADC_CH7 and ADC_CH_VOICE
                ADC_SEMODE_e semode: signle-ended mode negative side enable; 1:SINGLE_END(single-ended mode) 0:DIFF(Differentail mode)
                IO_CONTROL_e amplitude: input signal amplitude, 0:BELOW_1V,1:UP_1V
    output parameters
    @param       None.
    @return      None.
void hal_adc_init(void)
    mAdc_init_flg = TRUE;
    hal_pwrmgr_register(MOD_ADCC,NULL,adc_wakeup_hdl);
    clear_adcc_cfg();
int hal_adc_clock_config(adc_CLOCK_SEL_t clk)
    if(!mAdc_init_flg)
        return PPlus_ERR_NOT_REGISTED;
    subWriteReg(0x4000F000 + 0x7c,2,1,clk);
    return PPlus_SUCCESS;
int hal_adc_compare_start(void)
    if(!mAdc_init_flg)
    mAdc_Ctx.enable = TRUE;
    hal_pwrmgr_lock(MOD_ADCC);
    JUMP_FUNCTION(ADCC_IRQ_HANDLER)                  =   (uint32_t)&hal_ADC_compare_IRQHandler;
    //ENABLE_ADC;
    AP_PCRM->ANA_CTL |= BIT(3);
    AP_PCRM->ANA_CTL |= BIT(0);//new
    //ADC_IRQ_ENABLE;
    NVIC_EnableIRQ((IRQn_Type)ADCC_IRQn);
    //ENABLE_ADC_INT;
    AP_ADCC->intr_mask = 0x1ff;
    //disableSleep();
int hal_adc_start(uint8_t adc_mode)
    uint8_t     all_channel2 = (((mAdc_Ctx.chs_en_shadow&0x80)>>1)|\
                                ((mAdc_Ctx.chs_en_shadow&0x40)<<1)|\
                                ((mAdc_Ctx.chs_en_shadow&0x20)>>1)|\
                                ((mAdc_Ctx.chs_en_shadow&0x10)<<1)|\
                                ((mAdc_Ctx.chs_en_shadow&0x08)>>1)|\
                                ((mAdc_Ctx.chs_en_shadow&0x04)<<1));
    if(!mAdc_init_flg)
    CLEAR_ADC_INT_ALL;
    if( adc_mode == POLLING_MODE )
        JUMP_FUNCTION(ADCC_IRQ_HANDLER)                  =   0;
    else if(adc_mode == INTERRUPT_MODE)
        JUMP_FUNCTION(ADCC_IRQ_HANDLER)                  =   (uint32_t)&hal_ADC_IRQHandler;
    for(int i=2; i<=7; i++)
        if(all_channel2 & (BIT(i)))
            switch (i)
            case ADC_CH1N_P11:
                AP_PCRM->ADC_CTL1 |= BIT(20);
            case ADC_CH1P_P23:
                AP_PCRM->ADC_CTL1 |= BIT(4);
            case ADC_CH2N_P24:
                AP_PCRM->ADC_CTL2 |= BIT(20);
            case ADC_CH2P_P14:
                AP_PCRM->ADC_CTL2 |= BIT(4);
            case ADC_CH3N_P15:
                AP_PCRM->ADC_CTL3 |= BIT(20);
            case ADC_CH3P_P20:
                AP_PCRM->ADC_CTL3 |= BIT(4);
    //ENABLE_ADC;
    //ADC_IRQ_ENABLE;
    if( adc_mode == INTERRUPT_MODE || adc_mode == CCOMPARE_MODE)
        NVIC_DisableIRQ((IRQn_Type)ADCC_IRQn);
    //ENABLE_ADC_INT;
    //disableSleep();
int hal_adc_config_channel(adc_Cfg_t cfg, adc_Hdl_t evt_handler)
    uint8_t i;
    uint8_t chn_sel,evt_index;
    gpio_pin_e pin,pin_neg;
    if(!mAdc_init_flg)
    if(mAdc_Ctx.enable)
        return PPlus_ERR_BUSY;
    if(evt_handler == NULL)
        return PPlus_ERR_INVALID_PARAM;
    if(cfg.channel & BIT(0)/*||channel == ADC_CH1*/ )
        return PPlus_ERR_NOT_SUPPORTED;
    if((!cfg.channel & BIT(1))&&(cfg.is_differential_mode && (cfg.channel & BIT(1))))
    if(cfg.is_differential_mode != 0)
        if((cfg.is_differential_mode != 0x80) && (cfg.is_differential_mode != 0x20) && (cfg.is_differential_mode != 0x08))
    mAdc_Ctx.continue_mode = cfg.is_continue_mode;
    mAdc_Ctx.all_channel = cfg.channel & 0x03;
    for(i=2; i<8; i++)
        if(cfg.channel & BIT(i))
            if(i%2)
                mAdc_Ctx.all_channel |= BIT(i-1);
                mAdc_Ctx.all_channel |= BIT(i+1);
    mAdc_Ctx.chs_en_shadow = mAdc_Ctx.all_channel;
    if((AP_PCR->SW_CLK & BIT(MOD_ADCC)) == 0)
        hal_clk_gate_enable(MOD_ADCC);
    //CLK_1P28M_ENABLE;
    AP_PCRM->CLKSEL |= BIT(6);
    //ENABLE_XTAL_OUTPUT;         //enable xtal 16M output,generate the 32M dll clock
    AP_PCRM->CLKHF_CTL0 |= BIT(18);
    //ENABLE_DLL;                  //enable DLL
    AP_PCRM->CLKHF_CTL1 |= BIT(7);
    //ADC_DBLE_CLOCK_DISABLE;      //disable double 32M clock,we are now use 32M clock,should enable bit<13>, diable bit<21>
    subWriteReg(0x4000F044,21,20,1);    // dig_clk_32M_sel, use dbl_b_32M
    //subWriteReg(0x4000F044,21,20,3);
    //ADC_CLOCK_ENABLE;            //adc clock enbale,always use clk_32M
    AP_PCRM->CLKHF_CTL1 |= BIT(13);
    //subWriteReg(0x4000f07c,4,4,1);    //set adc mode,1:mannual,0:auto mode
    AP_PCRM->ADC_CTL4 |= BIT(4);
    AP_PCRM->ADC_CTL4 |= BIT(0);
    set_sampling_resolution_auto(cfg.channel, cfg.is_high_resolution,cfg.is_differential_mode);
    AP_PCRM->ADC_CTL0 &= ~BIT(20);
    AP_PCRM->ADC_CTL0 &= ~BIT(4);
    AP_PCRM->ADC_CTL1 &= ~BIT(20);
    AP_PCRM->ADC_CTL1 &= ~BIT(4);
    AP_PCRM->ADC_CTL2 &= ~BIT(20);
    AP_PCRM->ADC_CTL2 &= ~BIT(4);
    AP_PCRM->ADC_CTL3 &= ~BIT(20);
    AP_PCRM->ADC_CTL3 &= ~BIT(4);
    AP_PCRM->ANA_CTL &= ~BIT(23);//disable micbias
    if(cfg.is_differential_mode == 0)
        AP_PCRM->ADC_CTL4 &= ~BIT(4); //enable auto mode
        for(i=2; i<8; i++)
                gpio_pin_e pin = s_pinmap[i];
                hal_gpio_ds_control(pin, Bit_ENABLE);
                hal_gpio_cfg_analog_io(pin, Bit_ENABLE);
                switch (i)
                case 0:
                    AP_PCRM->ADC_CTL0 |= BIT(20);
                case 1:
                    AP_PCRM->ADC_CTL0 |= BIT(4);
                case 2:
                case 3:
                case 4:
                case 5:
                case 6:
                case 7:
                mAdc_Ctx.evt_handler[i] = evt_handler;
        switch(cfg.is_differential_mode)
        case 0x80:
            pin = P20;
            pin_neg = P15;
            chn_sel = 0x04;
            evt_index = 7;
        case 0x20:
            pin = P14;
            pin_neg = P24;
            chn_sel = 0x03;
            evt_index = 5;
        case 0x08:
            pin = P23;
            pin_neg = P11;
            chn_sel = 0x02;
            evt_index = 3;
        case 0x02:
            pin = P18;
            pin_neg = P25;
            chn_sel = 0x01;
            evt_index = 1;
            *(volatile int*)(0x4000F020) = 0x0060;
        subWriteReg(0x4000f048,7,5,chn_sel);
        set_differential_mode();
        //LOG("%d %d %x\n",pin,pin_neg,*(volatile int*)0x40003800);
        hal_gpio_pull_set(pin_neg,GPIO_FLOATING);
        hal_gpio_cfg_analog_io(pin,Bit_ENABLE);
        hal_gpio_cfg_analog_io(pin_neg,Bit_ENABLE);
        mAdc_Ctx.all_channel = (cfg.is_differential_mode >> 1);
        mAdc_Ctx.evt_handler[evt_index] = evt_handler;
int hal_adc_stop(void)
    int i;
    if(!mAdc_init_flg)
    //MASK_ADC_INT;
    ADC_INIT_TOUT(to);
    AP_ADCC->intr_clear = 0x1FF;
    //DISABLE_ADC;
    AP_PCRM->ANA_CTL &= ~BIT(3);
    //ADC_CLOCK_DISABLE;
    // AP_PCRM->CLKHF_CTL1 &= ~BIT(13);
    for(i =0; i< ADC_CH_NUM; i++)
        if(all_channel2 & BIT(i))
            disable_analog_pin((adc_CH_t)i);
    AP_PCRM->ANA_CTL &= ~BIT(0);//Power down analog LDO
    hal_clk_reset(MOD_ADCC);
    hal_clk_gate_disable(MOD_ADCC);
    clear_adcc_cfg();
    //enableSleep();
    hal_pwrmgr_unlock(MOD_ADCC);
int hal_poilling_adc_stop(void)
    int i;
    if(!mAdc_init_flg)
    //MASK_ADC_INT;
    ADC_INIT_TOUT(to);
    //DISABLE_ADC;
        if(mAdc_Ctx.evt_handler[i])
    clear_adcc_cfg();
    //enableSleep();
    NVIC_ClearPendingIRQ((IRQn_Type)ADCC_IRQn);
    @fn          hal_adc_value
    @brief       This function process for get adc value
    input parameters
    @param       ADC_CH_e adc_pin: adc pin select;ADC_CH0~ADC_CH7 and ADC_CH_VOICE
    output parameters
    @param       None.
    @return      ADC value
static void hal_adc_load_calibration_value(void)
    if(adc_cal_read_flag==FALSE)
        adc_cal_read_flag = TRUE;
        adc_cal_negtive = read_reg(0x11001000)&0x0fff;
        adc_cal_postive = (read_reg(0x11001000)>>16)&0x0fff;
        LOG("AD_CAL[%x %x]\n",adc_cal_negtive,adc_cal_postive);
        if((adc_cal_negtive < 0x733) || (adc_cal_negtive > 0x8cc) || (adc_cal_postive < 0x733) || (adc_cal_postive > 0x8cc))
            adc_cal_negtive = 0xfff;
            adc_cal_postive = 0xfff;
            LOG("->AD_CAL[%x %x]\n",adc_cal_negtive,adc_cal_postive);
#if(SDK_VER_CHIP==__DEF_CHIP_QFN32__)
const unsigned int adc_Lambda[ADC_CH_NUM] =
    0, //ADC_CH0 =0,
    0, //ADC_CH1 =1,
    4519602,//P11
    4308639,//P23
    4263287,//P24
    4482718,//P14
    4180401,//P15
    4072069,//P20
    0,//GPIO_DUMMY,  //ADC_CH_VOICE =8,
#elif(SDK_VER_CHIP == __DEF_CHIP_TSOP16__)
    0, //ADC_CH0 =0,
    0, //ADC_CH1 =1,
    4488156,//P11
    4308639,//P23,
    4263287,//P24,
    4467981,//P14
    4142931,//P15
    4054721,//P20
double hal_adc_value_cal(adc_CH_t ch,uint16_t* buf, uint32_t size, uint8_t high_resol, uint8_t diff_mode)
    uint32_t i;
    int adc_sum = 0;
    volatile double result = 0.0;
    for (i = 0; i < size; i++)
        adc_sum += (buf[i]&0xfff);
    hal_adc_load_calibration_value();
    result = ((double)adc_sum)/size;
//	LOG("AD_CAL[%x %x]\n",adc_cal_negtive,adc_cal_postive);
    //LOG("adc_sum:%10d %10d ",adc_sum,adc_sum/(MAX_ADC_SAMPLE_SIZE-3));
    if((adc_cal_postive!=0xfff)&&(adc_cal_negtive!=0xfff))
        double delta = ((int)(adc_cal_postive-adc_cal_negtive))/2.0;
        if(ch&0x01)
            result = (diff_mode) ? ((result-2048-delta)*2/(adc_cal_postive+adc_cal_negtive))
                     : ((result-delta) /(adc_cal_postive+adc_cal_negtive));
                     : ((result+delta) /(adc_cal_postive+adc_cal_negtive));
        result = (diff_mode) ? (double)(result / 2048 -1) : (double)(result /4096);
    if(high_resol == TRUE)
        result *= 0.8;
        result = (double)result *(double)adc_Lambda[ch]*0.8/1000000;
    return result;
void hal_adc_value_read(adc_CH_t ch)
    volatile uint16_t status;
    uint8_t ch2;
    while(!(status & BIT(ch2)))
    AP_ADCC->intr_mask &= ~BIT(ch2);
    for (uint8_t n = 0; n < (MAX_ADC_SAMPLE_SIZE-2); n++)
        adc_data[n<<1] = (uint16_t)(read_reg(ADC_CH_BASE + (ch2 * 0x80) + ((n+2) * 4))&0xfff);
        adc_data[(n<<1)+1] = (uint16_t)((read_reg(ADC_CH_BASE + (ch2 * 0x80) + ((n+2) * 4))>>16)&0xfff);
    AP_ADCC->intr_clear = BIT(ch2);
    if (mAdc_Ctx.evt_handler[ch])
        adc_Evt_t evt;
        evt.ch = (adc_CH_t)ch;
        mAdc_Ctx.evt_handler[ch](&evt);
    AP_ADCC->intr_mask |= BIT(ch2);
int hal_adc_deinit(void)
    mAdc_Ctx.enable = FALSE;
    return hal_pwrmgr_unregister(MOD_ADCC);
    input parameters
    @param       None.
    output parameters
    @param       None.
    @return      None.
static void __attribute__((used)) hal_ADC_compare_IRQHandler(void)
    volatile int ch,status,ch2,n;
    volatile int status2;
    status =  (AP_ADCC->intr_status & 0x0003ffff);
    MASK_ADC_COMPARE_INT;
    //AP_ADCC->intr_clear = status;
    status2 =  (AP_ADCC->intr_status & 0x0003ffff);
    MASK_ADC_INT;
    if(status & 0x3FC00)
        for(n=10; n<17; n++)
            if(((status & 0x3FC00) & (1<<n)))//((status & 0x3FF) & (1<<(n-10)))
                AP_ADCC->intr_clear =  BIT(n);
                adc_compare_cb((n-10),status);
        AP_ADCC->intr_clear =  0x3FC00;
    if(status2 == mAdc_Ctx.all_channel)
            if (status2 & BIT(ch))
                    adc_Evt_t evt;
            hal_adc_stop();
    //ENABLE_ADC_INT;
    // ENABLE_ADC_COMPARE_INT;
    AP_ADCC->intr_mask |=  (adc_compare_enable_flag<<10)|0x3ff;
static void adc_compare_cb(uint16_t ch,uint32_t status)
    int32_t delay;
    uint16_t threshold_low,threshold_high;
    bool compare_flag = FALSE;
    uint32_t adc_one_sample_value;
    uint16_t adc_v1,adc_v2;
    if((ch >= ADC_CH1N_P11) && (ch <=ADC_CH3P_P20))
        LOG("compare int:%d 0x%x 0x%x\n",ch,status,AP_ADCC->compare_cfg[ch]);
        adc_one_sample_value = read_reg(ADC_CH_BASE + (ch * 0x80) + 0x4);
        adc_v1 = (uint16_t)(adc_one_sample_value&0xfff);
        adc_v2 = (uint16_t)((adc_one_sample_value>>16)&0xfff);
        threshold_high = AP_ADCC->compare_cfg[ch] & 0xFFF;
        threshold_low = (AP_ADCC->compare_cfg[ch] & 0xFFF000)>>12;
        if(AP_ADCC->compare_cfg[ch] & 0x80000000)//high
            if((adc_v1 > threshold_high) || (adc_v2 > threshold_high))
                compare_flag = TRUE;
            if((adc_v1 < threshold_low) || (adc_v2 < threshold_low))
        if(compare_flag == TRUE)
            LOG("+adc compare int:%d reg:0x%x value:0x%x 0x%x 0x%x l:0x%x h:0x%x\n",ch,AP_ADCC->compare_cfg[ch],adc_one_sample_value,adc_v1,adc_v2,threshold_low,threshold_high);
            adc_compare_filter_counter++;
            LOG("-adc compare int:%d reg:0x%x value:0x%x 0x%x 0x%x l:0x%x h:0x%x\n",ch,AP_ADCC->compare_cfg[ch],adc_one_sample_value,adc_v1,adc_v2,threshold_low,threshold_high);
        if(adc_compare_filter_counter > ADC_COMPARE_FILTER_MAX_TIME)
            LOG("adc compare ind:%d,0x%x\n",ch,(AP_ADCC->compare_cfg[ch] & 0x80000000));
            if((AP_ADCC->compare_cfg[ch] & 0x80000000) == 0)//enable high threhold
                adc_set_high_threshold_flag(TRUE);
        subWriteReg(&(AP_ADCC->compare_cfg[ch]),30,30,0);//compare disable
        delay=5;
        while(delay--);
        subWriteReg(&(AP_ADCC->compare_cfg[ch]),30,30,1);//compare enable
        delay=5;
        while(delay--);
        subWriteReg(&(AP_ADCC->compare_reset),ch,ch,1);
        delay=5;
        while(delay--);
        subWriteReg(&(AP_ADCC->compare_reset),ch,ch,0);
        delay=5;
        while(delay--);
        LOG("compare err:%d\n",ch);
int hal_adc_comppare_reset(adc_CH_t ch)
    int delay=10;
    int i=0;
        i = (ch%2)?(ch-1):(ch+1);
        subWriteReg(&(AP_ADCC->compare_reset),i,i,1);
        while(delay--);
        //LOG("0x4005001c:0x%x\n",*(volatile int*)(0x4005001c));
        subWriteReg(&(AP_ADCC->compare_reset),i,i,0);
        delay=10;
        while(delay--);
int hal_adc_compare_enable(adc_CH_t ch,uint32_t flag,uint32_t th_high,uint32_t th_low)
    int i=0;
        AP_ADCC->compare_cfg[i] = 0;
        subWriteReg(&(AP_ADCC->compare_cfg[i]),23,12,th_high);//low
        subWriteReg(&(AP_ADCC->compare_cfg[i]),11,0,th_low);
        if(flag == 0)//low threshold value
            subWriteReg(&(AP_ADCC->compare_cfg[i]),31,31,0);
        else//high threshold value
            subWriteReg(&(AP_ADCC->compare_cfg[i]),31,31,1);
        subWriteReg(&(AP_ADCC->intr_mask),(i+10),(i+10),0);
        subWriteReg(&(AP_ADCC->compare_cfg[i]),30,30,1);
        adc_compare_enable_flag |= (1<<i);
        LOG("adc_compare_enable_flag:0x%x\n",adc_compare_enable_flag);
        LOG("i:%d\n",i);
        LOG("compare reg:0x%x\n",AP_ADCC->compare_cfg[i]);
