tuya_iot_config.h
Copyright(C),2018-2020, 涂鸦科技 www.tuya.comm
/* AUTO-GENERATED FILE. DO NOT MODIFY !!!
* This config file is automatically generated by tuya cross-build system.
* It should not be modified by hand.
#ifndef TUYA_IOT_CONFIG_H
#define TUYA_IOT_CONFIG_H
/* default definitons */
#define SYSTEM_SMALL_MEMORY_BEGIN       0       /*small memory systems begin */
#define SYSTEM_REALTEK8710_1M           1
#define SYSTEM_REALTEK8710_2M           2
#define SYSTEM_NON_OS					3		/*no operating system*/
#define SYSTEM_FREERTOS                 98
#define SYSTEM_SMALL_MEMORY_END         99      /*small memory systems end */
#define SYSTEM_LINUX                    100
#define SYSTEM_LITEOS                   120
#define TLS_DISABLE                     0       /* disable tls function */
#define TLS_TUYA_PSK_ONLY               2       /* only enable ciper 0xAE */
#define TLS_TUYA_ECC_PSK                3       /* enable ciper 0xAE && 0xC027 */
#define TLS_TUYA_ECC_ONLY               4       /* only enable ciper 0xC027 */
#define TLS_TUYA_ECC_ONLY_NOSTRIP       5       /* only enable ciper 0xC027, but enable most of mbed-tls configs */
#define TLS_TUYA_ECC_CLIENT_AUTH        6       /* TLS Client Authentication and Server Authentication mode */
#define TUYA_SL_0           0       /* security level 0,Applies to: Resource-constrained devices;Feature: Can only access Tuya Cloud */
#define TUYA_SL_1           1       /* security level 1,Applies to: Resource-constrained devices;Feature: One-way authentication */
#define TUYA_SL_2           2       /* security level 2,Applies to: Resource-rich equipment;Feature: Two-way authentication */
#define TUYA_SL_3           3       /* security level 3,Applies to: Resource-rich equipment;Feature: Two-way authentication,Devices use security chips to protect sensitive information */
#define TUYA_MODIFY_MBEDTLS             1
#define TUYA_OPERATOR_DISABLE           0x0
#define TUYA_OPERATOR_CUCC              0x01
#define TUYA_OPERATOR_CTCC              0x02
#define TUYA_OPERATOR_CMCC              0x04
#define TUYA_OPERATOR_CMCC_ANDLINK      0x08
#define TUYA_OPERATOR_ALL               (TUYA_OPERATOR_CUCC | TUYA_OPERATOR_CTCC | TUYA_OPERATOR_CMCC)
#define TUYA_LAN_V31              0x1
#define TUYA_LAN_V32              0x2
#define TUYA_LAN_V33              0x4
#define TUYA_LAN_V35              0x8
#define TUYA_LAN_ALL              (TUYA_LAN_V31 | TUYA_LAN_V32 | TUYA_LAN_V33 | TUYA_LAN_V35)
#define TUYA_MQ_V21               0x1
#define TUYA_MQ_V22               0x2
#define TUYA_MQ_V23               0x4
#define TUYA_MQ_ALL               (TUYA_MQ_V21 | TUYA_MQ_V22 | TUYA_MQ_V23)
/* custom settings */
