# Doxyfile 1.9.4
# This file describes the settings to be used by the documentation system
# doxygen (www.doxygen.org) for a project.
# All text after a double hash (##) is considered a comment and is placed in
# front of the TAG it is preceding.
# All text after a single hash (#) is considered a comment and will be ignored.
# The format is:
# TAG = value [value, ...]
# For lists, items can also be appended using:
# TAG += value [value, ...]
# Values that contain spaces should be placed between quotes (\" \").
# Project related configuration options
# This tag specifies the encoding used for all characters in the configuration
# file that follow. The default is UTF-8 which is also the encoding used for all
# text before the first occurrence of this tag. Doxygen uses libiconv (or the
# iconv built into libc) for the transcoding. See
# https://www.gnu.org/software/libiconv/ for the list of possible encodings.
# The default value is: UTF-8.
DOXYFILE_ENCODING      = UTF-8
# The PROJECT_NAME tag is a single word (or a sequence of words surrounded by
# double-quotes, unless you are using Doxywizard) that should identify the
# project for which the documentation is generated. This name is used in the
# title of most generated pages and in a few other places.
# The default value is: My Project.
PROJECT_NAME           = "TuyaOS"
# The PROJECT_NUMBER tag can be used to enter a project or revision number. This
# could be handy for archiving the generated documentation or if some version
# control system is used.
PROJECT_NUMBER         =
# Using the PROJECT_BRIEF tag one can provide an optional one line description
# for a project that appears at the top of each page and should give viewer a
# quick idea about the purpose of the project. Keep the description short.
PROJECT_BRIEF          =
# With the PROJECT_LOGO tag one can specify a logo or an icon that is included
# in the documentation. The maximum height of the logo should not exceed 55
# pixels and the maximum width should not exceed 200 pixels. Doxygen will copy
# the logo to the output directory.
PROJECT_LOGO           =
# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute) path
# into which the generated documentation will be written. If a relative path is
# entered, it will be relative to the location where doxygen was started. If
# left blank the current directory will be used.
OUTPUT_DIRECTORY       =
# If the CREATE_SUBDIRS tag is set to YES then doxygen will create 4096 sub-
# directories (in 2 levels) under the output directory of each output format and
# will distribute the generated files over these directories. Enabling this
# option can be useful when feeding doxygen a huge amount of source files, where
# putting all generated files in the same directory would otherwise causes
# performance problems for the file system.
# The default value is: NO.
CREATE_SUBDIRS         = YES
# If the ALLOW_UNICODE_NAMES tag is set to YES, doxygen will allow non-ASCII
# characters to appear in the names of generated files. If set to NO, non-ASCII
# characters will be escaped, for example _xE3_x81_x84 will be used for Unicode
# U+3044.
ALLOW_UNICODE_NAMES    = NO
# The OUTPUT_LANGUAGE tag is used to specify the language in which all
# documentation generated by doxygen is written. Doxygen will use this
# information to generate all constant output in the proper language.
# Possible values are: Afrikaans, Arabic, Armenian, Brazilian, Catalan, Chinese,
# Chinese-Traditional, Croatian, Czech, Danish, Dutch, English (United States),
# Esperanto, Farsi (Persian), Finnish, French, German, Greek, Hungarian,
# Indonesian, Italian, Japanese, Japanese-en (Japanese with English messages),
# Korean, Korean-en (Korean with English messages), Latvian, Lithuanian,
# Macedonian, Norwegian, Persian (Farsi), Polish, Portuguese, Romanian, Russian,
# Serbian, Serbian-Cyrillic, Slovak, Slovene, Spanish, Swedish, Turkish,
# Ukrainian and Vietnamese.
# The default value is: English.
OUTPUT_LANGUAGE        = Chinese
# If the BRIEF_MEMBER_DESC tag is set to YES, doxygen will include brief member
# descriptions after the members that are listed in the file and class
# documentation (similar to Javadoc). Set to NO to disable this.
# The default value is: YES.
BRIEF_MEMBER_DESC      = YES
# If the REPEAT_BRIEF tag is set to YES, doxygen will prepend the brief
# description of a member or function before the detailed description
# Note: If both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
# brief descriptions will be completely suppressed.
REPEAT_BRIEF           = YES
# This tag implements a quasi-intelligent brief description abbreviator that is
# used to form the text in various listings. Each string in this list, if found
# as the leading text of the brief description, will be stripped from the text
# and the result, after processing the whole list, is used as the annotated
# text. Otherwise, the brief description is used as-is. If left blank, the
# following values are used ($name is automatically replaced with the name of
# the entity):The $name class, The $name widget, The $name file, is, provides,
# specifies, contains, represents, a, an and the.
ABBREVIATE_BRIEF       = "The $name class" \
                         "The $name widget" \
                         "The $name file" \
                         is \
                         provides \
                         specifies \
                         contains \
                         represents \
                         a \
                         an \
                         the
# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
# doxygen will generate a detailed section even if there is only a brief
# description.
ALWAYS_DETAILED_SEC    = NO
# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all
# inherited members of a class in the documentation of that class as if those
# members were ordinary class members. Constructors, destructors and assignment
# operators of the base classes will not be shown.
INLINE_INHERITED_MEMB  = NO
# If the FULL_PATH_NAMES tag is set to YES, doxygen will prepend the full path
# before files name in the file list and in the header files. If set to NO the
# shortest path that makes the file name unique will be used
FULL_PATH_NAMES        = YES
# The STRIP_FROM_PATH tag can be used to strip a user-defined part of the path.
# Stripping is only done if one of the specified strings matches the left-hand
# part of the path. The tag can be used to show relative paths in the file list.
# If left blank the directory from which doxygen is run is used as the path to
# strip.
# Note that you can specify absolute paths here, but also relative paths, which
# will be relative from the directory where doxygen is started.
# This tag requires that the tag FULL_PATH_NAMES is set to YES.
STRIP_FROM_PATH        =
# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of the
# path mentioned in the documentation of a class, which tells the reader which
# header file to include in order to use a class. If left blank only the name of
# the header file containing the class definition is used. Otherwise one should
# specify the list of include paths that are normally passed to the compiler
# using the -I flag.
STRIP_FROM_INC_PATH    =
# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter (but
# less readable) file names. This can be useful is your file systems doesn't
# support long names like on DOS, Mac, or CD-ROM.
SHORT_NAMES            = NO
# If the JAVADOC_AUTOBRIEF tag is set to YES then doxygen will interpret the
# first line (until the first dot) of a Javadoc-style comment as the brief
# description. If set to NO, the Javadoc-style will behave just like regular Qt-
# style comments (thus requiring an explicit @brief command for a brief
# description.)
JAVADOC_AUTOBRIEF      = NO
# If the JAVADOC_BANNER tag is set to YES then doxygen will interpret a line
# such as
# as being the beginning of a Javadoc-style comment "banner". If set to NO, the
# Javadoc-style will behave just like regular comments and it will not be
# interpreted by doxygen.
JAVADOC_BANNER         = NO
# If the QT_AUTOBRIEF tag is set to YES then doxygen will interpret the first
# line (until the first dot) of a Qt-style comment as the brief description. If
# set to NO, the Qt-style will behave just like regular Qt-style comments (thus
# requiring an explicit \brief command for a brief description.)
QT_AUTOBRIEF           = NO
# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make doxygen treat a
# multi-line C++ special comment block (i.e. a block of //! or /// comments) as
# a brief description. This used to be the default behavior. The new default is
# to treat a multi-line C++ comment block as a detailed description. Set this
# tag to YES if you prefer the old behavior instead.
# Note that setting this tag to YES also means that rational rose comments are
# not recognized any more.
MULTILINE_CPP_IS_BRIEF = NO
# By default Python docstrings are displayed as preformatted text and doxygen's
# special commands cannot be used. By setting PYTHON_DOCSTRING to NO the
# doxygen's special commands can be used and the contents of the docstring
# documentation blocks is shown as doxygen documentation.
PYTHON_DOCSTRING       = YES
# If the INHERIT_DOCS tag is set to YES then an undocumented member inherits the
# documentation from any documented member that it re-implements.
INHERIT_DOCS           = YES
# If the SEPARATE_MEMBER_PAGES tag is set to YES then doxygen will produce a new
# page for each member. If set to NO, the documentation of a member will be part
# of the file/class/namespace that contains it.
SEPARATE_MEMBER_PAGES  = NO
# The TAB_SIZE tag can be used to set the number of spaces in a tab. Doxygen
# uses this value to replace tabs by spaces in code fragments.
# Minimum value: 1, maximum value: 16, default value: 4.
TAB_SIZE               = 4
# This tag can be used to specify a number of aliases that act as commands in
# the documentation. An alias has the form:
# name=value
# For example adding
# "sideeffect=@par Side Effects:^^"
# will allow you to put the command \sideeffect (or @sideeffect) in the
# documentation, which will result in a user-defined paragraph with heading
# "Side Effects:". Note that you cannot put \n's in the value part of an alias
# to insert newlines (in the resulting output). You can put ^^ in the value part
# of an alias to insert a newline as if a physical newline was in the original
# file. When you need a literal { or } or , in the value part of an alias you
# have to escape them by means of a backslash (\), this can lead to conflicts
# with the commands \{ and \} for these it is advised to use the version @{ and
# @} or use a double escape (\\{ and \\})
ALIASES                =
# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
# only. Doxygen will then generate output that is more tailored for C. For
# instance, some of the names that are used will be different. The list of all
# members will be omitted, etc.
OPTIMIZE_OUTPUT_FOR_C  = YES
# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java or
# Python sources only. Doxygen will then generate output that is more tailored
# for that language. For instance, namespaces will be presented as packages,
# qualified scopes will look different, etc.
OPTIMIZE_OUTPUT_JAVA   = NO
# Set the OPTIMIZE_FOR_FORTRAN tag to YES if your project consists of Fortran
# sources. Doxygen will then generate output that is tailored for Fortran.
OPTIMIZE_FOR_FORTRAN   = NO
# Set the OPTIMIZE_OUTPUT_VHDL tag to YES if your project consists of VHDL
# sources. Doxygen will then generate output that is tailored for VHDL.
OPTIMIZE_OUTPUT_VHDL   = NO
# Set the OPTIMIZE_OUTPUT_SLICE tag to YES if your project consists of Slice
# sources only. Doxygen will then generate output that is more tailored for that
# language. For instance, namespaces will be presented as modules, types will be
# separated into more groups, etc.
OPTIMIZE_OUTPUT_SLICE  = YES
# Doxygen selects the parser to use depending on the extension of the files it
# parses. With this tag you can assign which parser to use for a given
# extension. Doxygen has a built-in mapping, but you can override or extend it
# using this tag. The format is ext=language, where ext is a file extension, and
# language is one of the parsers supported by doxygen: IDL, Java, JavaScript,
# Csharp (C#), C, C++, Lex, D, PHP, md (Markdown), Objective-C, Python, Slice,
# VHDL, Fortran (fixed format Fortran: FortranFixed, free formatted Fortran:
# FortranFree, unknown formatted Fortran: Fortran. In the later case the parser
# tries to guess whether the code is fixed or free formatted code, this is the
# default for Fortran type files). For instance to make doxygen treat .inc files
# as Fortran files (default is PHP), and .f files as C (default is Fortran),
# use: inc=Fortran f=C.
# Note: For files without extension you can use no_extension as a placeholder.
# Note that for custom extensions you also need to set FILE_PATTERNS otherwise
# the files are not read by doxygen. When specifying no_extension you should add
# * to the FILE_PATTERNS.
# Note see also the list of default file extension mappings.
EXTENSION_MAPPING      =
# If the MARKDOWN_SUPPORT tag is enabled then doxygen pre-processes all comments
# according to the Markdown format, which allows for more readable
# documentation. See https://daringfireball.net/projects/markdown/ for details.
# The output of markdown processing is further processed by doxygen, so you can
# mix doxygen, HTML, and XML commands with Markdown formatting. Disable only in
# case of backward compatibilities issues.
MARKDOWN_SUPPORT       = YES
# When the TOC_INCLUDE_HEADINGS tag is set to a non-zero value, all headings up
# to that level are automatically included in the table of contents, even if
# they do not have an id attribute.
# Note: This feature currently applies only to Markdown headings.
# Minimum value: 0, maximum value: 99, default value: 5.
# This tag requires that the tag MARKDOWN_SUPPORT is set to YES.
TOC_INCLUDE_HEADINGS   = 5
# When enabled doxygen tries to link words that correspond to documented
# classes, or namespaces to their corresponding documentation. Such a link can
# be prevented in individual cases by putting a % sign in front of the word or
# globally by setting AUTOLINK_SUPPORT to NO.
AUTOLINK_SUPPORT       = YES
# If you use STL classes (i.e. std::string, std::vector, etc.) but do not want
# to include (a tag file for) the STL sources as input, then you should set this
# tag to YES in order to let doxygen match functions declarations and
# definitions whose arguments contain STL classes (e.g. func(std::string);
# versus func(std::string) {}). This also make the inheritance and collaboration
# diagrams that involve STL classes more complete and accurate.
BUILTIN_STL_SUPPORT    = NO
# If you use Microsoft's C++/CLI language, you should set this option to YES to
# enable parsing support.
CPP_CLI_SUPPORT        = NO
# Set the SIP_SUPPORT tag to YES if your project consists of sip (see:
# https://www.riverbankcomputing.com/software/sip/intro) sources only. Doxygen
# will parse them like normal C++ but will assume all classes use public instead
# of private inheritance when no explicit protection keyword is present.
SIP_SUPPORT            = NO
# For Microsoft's IDL there are propget and propput attributes to indicate
# getter and setter methods for a property. Setting this option to YES will make
# doxygen to replace the get and set methods by a property in the documentation.
# This will only work if the methods are indeed getting or setting a simple
# type. If this is not the case, or you want to show the methods anyway, you
# should set this option to NO.
IDL_PROPERTY_SUPPORT   = YES
# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
# tag is set to YES then doxygen will reuse the documentation of the first
# member in the group (if any) for the other members of the group. By default
# all members of a group must be documented explicitly.
DISTRIBUTE_GROUP_DOC   = NO
# If one adds a struct or class to a group and this option is enabled, then also
# any nested class or struct is added to the same group. By default this option
# is disabled and one has to add nested compounds explicitly via \ingroup.
GROUP_NESTED_COMPOUNDS = NO
# Set the SUBGROUPING tag to YES to allow class member groups of the same type
# (for instance a group of public functions) to be put as a subgroup of that
# type (e.g. under the Public Functions section). Set it to NO to prevent
# subgrouping. Alternatively, this can be done per class using the
# \nosubgrouping command.
SUBGROUPING            = YES
# When the INLINE_GROUPED_CLASSES tag is set to YES, classes, structs and unions
# are shown inside the group in which they are included (e.g. using \ingroup)
# instead of on a separate page (for HTML and Man pages) or section (for LaTeX
# and RTF).
# Note that this feature does not work in combination with
# SEPARATE_MEMBER_PAGES.
INLINE_GROUPED_CLASSES = NO
# When the INLINE_SIMPLE_STRUCTS tag is set to YES, structs, classes, and unions
# with only public data fields or simple typedef fields will be shown inline in
# the documentation of the scope in which they are defined (i.e. file,
# namespace, or group documentation), provided this scope is documented. If set
# to NO, structs, classes, and unions are shown on a separate page (for HTML and
# Man pages) or section (for LaTeX and RTF).
INLINE_SIMPLE_STRUCTS  = NO
# When TYPEDEF_HIDES_STRUCT tag is enabled, a typedef of a struct, union, or
# enum is documented as struct, union, or enum with the name of the typedef. So
# typedef struct TypeS {} TypeT, will appear in the documentation as a struct
# with name TypeT. When disabled the typedef will appear as a member of a file,
# namespace, or class. And the struct will be named TypeS. This can typically be
# useful for C code in case the coding convention dictates that all compound
# types are typedef'ed and only the typedef is referenced, never the tag name.
TYPEDEF_HIDES_STRUCT   = NO
# The size of the symbol lookup cache can be set using LOOKUP_CACHE_SIZE. This
# cache is used to resolve symbols given their name and scope. Since this can be
# an expensive process and often the same symbol appears multiple times in the
# code, doxygen keeps a cache of pre-resolved symbols. If the cache is too small
# doxygen will become slower. If the cache is too large, memory is wasted. The
# cache size is given by this formula: 2^(16+LOOKUP_CACHE_SIZE). The valid range
# is 0..9, the default is 0, corresponding to a cache size of 2^16=65536
# symbols. At the end of a run doxygen will report the cache usage and suggest
# the optimal cache size from a speed point of view.
# Minimum value: 0, maximum value: 9, default value: 0.
LOOKUP_CACHE_SIZE      = 0
# The NUM_PROC_THREADS specifies the number threads doxygen is allowed to use
# during processing. When set to 0 doxygen will based this on the number of
# cores available in the system. You can set it explicitly to a value larger
# than 0 to get more control over the balance between CPU load and processing
# speed. At this moment only the input processing can be done using multiple
# threads. Since this is still an experimental feature the default is set to 1,
# which effectively disables parallel processing. Please report any issues you
# encounter. Generating dot graphs in parallel is controlled by the
# DOT_NUM_THREADS setting.
# Minimum value: 0, maximum value: 32, default value: 1.
NUM_PROC_THREADS       = 1
# Build related configuration options
# If the EXTRACT_ALL tag is set to YES, doxygen will assume all entities in
# documentation are documented, even if no documentation was available. Private
# class members and static file members will be hidden unless the
# EXTRACT_PRIVATE respectively EXTRACT_STATIC tags are set to YES.
# Note: This will also disable the warnings about undocumented members that are
# normally produced when WARNINGS is set to YES.
EXTRACT_ALL            = NO
# If the EXTRACT_PRIVATE tag is set to YES, all private members of a class will
# be included in the documentation.
EXTRACT_PRIVATE        = NO
# If the EXTRACT_PRIV_VIRTUAL tag is set to YES, documented private virtual
# methods of a class will be included in the documentation.
EXTRACT_PRIV_VIRTUAL   = NO
# If the EXTRACT_PACKAGE tag is set to YES, all members with package or internal
# scope will be included in the documentation.
EXTRACT_PACKAGE        = NO
# If the EXTRACT_STATIC tag is set to YES, all static members of a file will be
# included in the documentation.
EXTRACT_STATIC         = NO
# If the EXTRACT_LOCAL_CLASSES tag is set to YES, classes (and structs) defined
# locally in source files will be included in the documentation. If set to NO,
# only classes defined in header files are included. Does not have any effect
# for Java sources.
EXTRACT_LOCAL_CLASSES  = YES
# This flag is only useful for Objective-C code. If set to YES, local methods,
# which are defined in the implementation section but not in the interface are
# included in the documentation. If set to NO, only methods in the interface are
# included.
EXTRACT_LOCAL_METHODS  = NO
# If this flag is set to YES, the members of anonymous namespaces will be
# extracted and appear in the documentation as a namespace called
# 'anonymous_namespace{file}', where file will be replaced with the base name of
# the file that contains the anonymous namespace. By default anonymous namespace
# are hidden.
EXTRACT_ANON_NSPACES   = NO
# If this flag is set to YES, the name of an unnamed parameter in a declaration
# will be determined by the corresponding definition. By default unnamed
# parameters remain unnamed in the output.
RESOLVE_UNNAMED_PARAMS = YES
# If the HIDE_UNDOC_MEMBERS tag is set to YES, doxygen will hide all
# undocumented members inside documented classes or files. If set to NO these
# members will be included in the various overviews, but no documentation
# section is generated. This option has no effect if EXTRACT_ALL is enabled.
HIDE_UNDOC_MEMBERS     = NO
# If the HIDE_UNDOC_CLASSES tag is set to YES, doxygen will hide all
# undocumented classes that are normally visible in the class hierarchy. If set
# to NO, these classes will be included in the various overviews. This option
# has no effect if EXTRACT_ALL is enabled.
HIDE_UNDOC_CLASSES     = NO
# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, doxygen will hide all friend
# declarations. If set to NO, these declarations will be included in the
# documentation.
HIDE_FRIEND_COMPOUNDS  = NO
# If the HIDE_IN_BODY_DOCS tag is set to YES, doxygen will hide any
# documentation blocks found inside the body of a function. If set to NO, these
# blocks will be appended to the function's detailed documentation block.
HIDE_IN_BODY_DOCS      = NO
# The INTERNAL_DOCS tag determines if documentation that is typed after a
# \internal command is included. If the tag is set to NO then the documentation
# will be excluded. Set it to YES to include the internal documentation.
INTERNAL_DOCS          = NO
# With the correct setting of option CASE_SENSE_NAMES doxygen will better be
# able to match the capabilities of the underlying filesystem. In case the
# filesystem is case sensitive (i.e. it supports files in the same directory
# whose names only differ in casing), the option must be set to YES to properly
# deal with such files in case they appear in the input. For filesystems that
# are not case sensitive the option should be be set to NO to properly deal with
# output files written for symbols that only differ in casing, such as for two
# classes, one named CLASS and the other named Class, and to also support
# references to files without having to specify the exact matching casing. On
# Windows (including Cygwin) and MacOS, users should typically set this option
# to NO, whereas on Linux or other Unix flavors it should typically be set to
# YES.
# The default value is: system dependent.
CASE_SENSE_NAMES       = YES
# If the HIDE_SCOPE_NAMES tag is set to NO then doxygen will show members with
# their full class and namespace scopes in the documentation. If set to YES, the
# scope will be hidden.
HIDE_SCOPE_NAMES       = NO
# If the HIDE_COMPOUND_REFERENCE tag is set to NO (default) then doxygen will
# append additional text to a page's title, such as Class Reference. If set to
# YES the compound reference will be hidden.
HIDE_COMPOUND_REFERENCE= NO
# If the SHOW_HEADERFILE tag is set to YES then the documentation for a class
# will show which file needs to be included to use the class.
SHOW_HEADERFILE        = YES
# If the SHOW_INCLUDE_FILES tag is set to YES then doxygen will put a list of
# the files that are included by a file in the documentation of that file.
SHOW_INCLUDE_FILES     = YES
# If the SHOW_GROUPED_MEMB_INC tag is set to YES then Doxygen will add for each
# grouped member an include statement to the documentation, telling the reader
# which file to include in order to use the member.
SHOW_GROUPED_MEMB_INC  = NO
# If the FORCE_LOCAL_INCLUDES tag is set to YES then doxygen will list include
# files with double quotes in the documentation rather than with sharp brackets.
FORCE_LOCAL_INCLUDES   = NO
# If the INLINE_INFO tag is set to YES then a tag [inline] is inserted in the
# documentation for inline members.
INLINE_INFO            = YES
# If the SORT_MEMBER_DOCS tag is set to YES then doxygen will sort the
# (detailed) documentation of file and class members alphabetically by member
# name. If set to NO, the members will appear in declaration order.
SORT_MEMBER_DOCS       = YES
# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the brief
# descriptions of file, namespace and class members alphabetically by member
# name. If set to NO, the members will appear in declaration order. Note that
# this will also influence the order of the classes in the class list.
SORT_BRIEF_DOCS        = YES
# If the SORT_MEMBERS_CTORS_1ST tag is set to YES then doxygen will sort the
# (brief and detailed) documentation of class members so that constructors and
# destructors are listed first. If set to NO the constructors will appear in the
# respective orders defined by SORT_BRIEF_DOCS and SORT_MEMBER_DOCS.
# Note: If SORT_BRIEF_DOCS is set to NO this option is ignored for sorting brief
# member documentation.
# Note: If SORT_MEMBER_DOCS is set to NO this option is ignored for sorting
# detailed member documentation.
SORT_MEMBERS_CTORS_1ST = YES
# If the SORT_GROUP_NAMES tag is set to YES then doxygen will sort the hierarchy
# of group names into alphabetical order. If set to NO the group names will
# appear in their defined order.
SORT_GROUP_NAMES       = YES
# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be sorted by
# fully-qualified names, including namespaces. If set to NO, the class list will
# be sorted only by class name, not including the namespace part.
# Note: This option is not very useful if HIDE_SCOPE_NAMES is set to YES.
# Note: This option applies only to the class list, not to the alphabetical
# list.
SORT_BY_SCOPE_NAME     = YES
# If the STRICT_PROTO_MATCHING option is enabled and doxygen fails to do proper
# type resolution of all parameters of a function it will reject a match between
# the prototype and the implementation of a member function even if there is
# only one candidate or it is obvious which candidate to choose by doing a
# simple string match. By disabling STRICT_PROTO_MATCHING doxygen will still
# accept a match between prototype and implementation in such cases.
STRICT_PROTO_MATCHING  = NO
# The GENERATE_TODOLIST tag can be used to enable (YES) or disable (NO) the todo
# list. This list is created by putting \todo commands in the documentation.
GENERATE_TODOLIST      = YES
# The GENERATE_TESTLIST tag can be used to enable (YES) or disable (NO) the test
# list. This list is created by putting \test commands in the documentation.
GENERATE_TESTLIST      = NO
# The GENERATE_BUGLIST tag can be used to enable (YES) or disable (NO) the bug
# list. This list is created by putting \bug commands in the documentation.
GENERATE_BUGLIST       = YES
# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or disable (NO)
# the deprecated list. This list is created by putting \deprecated commands in
GENERATE_DEPRECATEDLIST= NO
# The ENABLED_SECTIONS tag can be used to enable conditional documentation
# sections, marked by \if <section_label> ... \endif and \cond <section_label>
# ... \endcond blocks.
ENABLED_SECTIONS       =
# The MAX_INITIALIZER_LINES tag determines the maximum number of lines that the
# initial value of a variable or macro / define can have for it to appear in the
# documentation. If the initializer consists of more lines than specified here
# it will be hidden. Use a value of 0 to hide initializers completely. The
# appearance of the value of individual variables and macros / defines can be
# controlled using \showinitializer or \hideinitializer command in the
# documentation regardless of this setting.
# Minimum value: 0, maximum value: 10000, default value: 30.
MAX_INITIALIZER_LINES  = 30
# Set the SHOW_USED_FILES tag to NO to disable the list of files generated at
# the bottom of the documentation of classes and structs. If set to YES, the
# list will mention the files that were used to generate the documentation.
SHOW_USED_FILES        = YES
# Set the SHOW_FILES tag to NO to disable the generation of the Files page. This
# will remove the Files entry from the Quick Index and from the Folder Tree View
# (if specified).
SHOW_FILES             = YES
# Set the SHOW_NAMESPACES tag to NO to disable the generation of the Namespaces
# page. This will remove the Namespaces entry from the Quick Index and from the
# Folder Tree View (if specified).
SHOW_NAMESPACES        = YES
# The FILE_VERSION_FILTER tag can be used to specify a program or script that
# doxygen should invoke to get the current version for each file (typically from
# the version control system). Doxygen will invoke the program by executing (via
# popen()) the command command input-file, where command is the value of the
# FILE_VERSION_FILTER tag, and input-file is the name of an input file provided
# by doxygen. Whatever the program writes to standard output is used as the file
# version. For an example see the documentation.
FILE_VERSION_FILTER    =
# The LAYOUT_FILE tag can be used to specify a layout file which will be parsed
# by doxygen. The layout file controls the global structure of the generated
# output files in an output format independent way. To create the layout file
# that represents doxygen's defaults, run doxygen with the -l option. You can
# optionally specify a file name after the option, if omitted DoxygenLayout.xml
# will be used as the name of the layout file. See also section "Changing the
# layout of pages" for information.
# Note that if you run doxygen from a directory containing a file called
# DoxygenLayout.xml, doxygen will parse it automatically even if the LAYOUT_FILE
# tag is left empty.
LAYOUT_FILE            =
# The CITE_BIB_FILES tag can be used to specify one or more bib files containing
# the reference definitions. This must be a list of .bib files. The .bib
# extension is automatically appended if omitted. This requires the bibtex tool
# to be installed. See also https://en.wikipedia.org/wiki/BibTeX for more info.
# For LaTeX the style of the bibliography can be controlled using
# LATEX_BIB_STYLE. To use this feature you need bibtex and perl available in the
# search path. See also \cite for info how to create references.
CITE_BIB_FILES         =
# Configuration options related to warning and progress messages
# The QUIET tag can be used to turn on/off the messages that are generated to
# standard output by doxygen. If QUIET is set to YES this implies that the
# messages are off.
QUIET                  = NO
# The WARNINGS tag can be used to turn on/off the warning messages that are
# generated to standard error (stderr) by doxygen. If WARNINGS is set to YES
# this implies that the warnings are on.
# Tip: Turn warnings on while writing the documentation.
WARNINGS               = YES
# If the WARN_IF_UNDOCUMENTED tag is set to YES then doxygen will generate
# warnings for undocumented members. If EXTRACT_ALL is set to YES then this flag
# will automatically be disabled.
WARN_IF_UNDOCUMENTED   = YES
# If the WARN_IF_DOC_ERROR tag is set to YES, doxygen will generate warnings for
# potential errors in the documentation, such as documenting some parameters in
# a documented function twice, or documenting parameters that don't exist or
# using markup commands wrongly.
WARN_IF_DOC_ERROR      = YES
# If WARN_IF_INCOMPLETE_DOC is set to YES, doxygen will warn about incomplete
# function parameter documentation. If set to NO, doxygen will accept that some
# parameters have no documentation without warning.
WARN_IF_INCOMPLETE_DOC = YES
# This WARN_NO_PARAMDOC option can be enabled to get warnings for functions that
# are documented, but have no documentation for their parameters or return
# value. If set to NO, doxygen will only warn about wrong parameter
# documentation, but not about the absence of documentation. If EXTRACT_ALL is
# set to YES then this flag will automatically be disabled. See also
# WARN_IF_INCOMPLETE_DOC
WARN_NO_PARAMDOC       = NO
# If the WARN_AS_ERROR tag is set to YES then doxygen will immediately stop when
# a warning is encountered. If the WARN_AS_ERROR tag is set to FAIL_ON_WARNINGS
# then doxygen will continue running as if WARN_AS_ERROR tag is set to NO, but
# at the end of the doxygen process doxygen will return with a non-zero status.
# Possible values are: NO, YES and FAIL_ON_WARNINGS.
WARN_AS_ERROR          = NO
# The WARN_FORMAT tag determines the format of the warning messages that doxygen
# can produce. The string should contain the $file, $line, and $text tags, which
# will be replaced by the file and line number from which the warning originated
# and the warning text. Optionally the format may contain $version, which will
# be replaced by the version of the file (if it could be obtained via
# FILE_VERSION_FILTER)
# The default value is: $file:$line: $text.
WARN_FORMAT            = "$file:$line: $text"
# The WARN_LOGFILE tag can be used to specify a file to which warning and error
# messages should be written. If left blank the output is written to standard
# error (stderr). In case the file specified cannot be opened for writing the
# warning and error messages are written to standard error. When as file - is
# specified the warning and error messages are written to standard output
# (stdout).
WARN_LOGFILE           =
# Configuration options related to the input files
# The INPUT tag is used to specify the files and/or directories that contain
# documented source files. You may enter file names like myfile.cpp or
# directories like /usr/src/myproject. Separate the files or directories with
# spaces. See also FILE_PATTERNS and EXTENSION_MAPPING
# Note: If this tag is empty the current directory is searched.
INPUT = README.md
INPUT += ./include
INPUT += ./docs/"TuyaOS 介绍.md"
INPUT += ./docs/初始化(Wi-Fi).md
INPUT += ./docs/重置(Wi-Fi).md
INPUT += ./docs/初始化(Wired).md
INPUT += ./docs/重置(Wired).md
INPUT += ./docs/Wi-Fi配网.md
INPUT += ./docs/qrcode绑定.md
INPUT += ./docs/局域网.md
#INPUT += ./docs/涂鸦局域网协议.md
INPUT += ./docs/蓝牙.md
INPUT += ./docs/KV-DB.md
INPUT += ./docs/文件系统.md
INPUT += ./docs/DP.md
INPUT += ./docs/OTA.md
INPUT += ./docs/ffc.md
INPUT += ./docs/定时任务.md
INPUT += ./docs/在线日志.md
INPUT += ./docs/网络.md
INPUT += ./docs/http文件下载.md
INPUT += ./docs/http协议.md
#INPUT += ./docs/产测.md
INPUT += ./docs/安全.md
INPUT += ./docs/事件.md
INPUT += ./docs/内存管理.md
INPUT += ./docs/日志服务.md
INPUT += ./docs/定时队列服务.md
INPUT += ./docs/工作队列.md
INPUT += ./docs/工作队列服务.md
INPUT += ./docs/register.md
INPUT += ./docs/tkl_adc.md
INPUT += ./docs/tkl_dac.md
INPUT += ./docs/tkl_gpio.md
INPUT += ./docs/tkl_i2c.md
INPUT += ./docs/tkl_i2s.md
INPUT += ./docs/tkl_pinmux.md
INPUT += ./docs/tkl_pwm.md
INPUT += ./docs/tkl_spi.md
INPUT += ./docs/tkl_timer.md
INPUT += ./docs/tkl_uart.md
INPUT += ./docs/tkl_wakeup.md
USE_MDFILE_AS_MAINPAGE = README.md
# This tag can be used to specify the character encoding of the source files
# that doxygen parses. Internally doxygen uses the UTF-8 encoding. Doxygen uses
# libiconv (or the iconv built into libc) for the transcoding. See the libiconv
# documentation (see:
# https://www.gnu.org/software/libiconv/) for the list of possible encodings.
INPUT_ENCODING         = UTF-8
# If the value of the INPUT tag contains directories, you can use the
# FILE_PATTERNS tag to specify one or more wildcard patterns (like *.cpp and
# *.h) to filter out the source-files in the directories.
# Note that for custom extensions or not directly supported extensions you also
# need to set EXTENSION_MAPPING for the extension otherwise the files are not
# read by doxygen.
# Note the list of default checked file patterns might differ from the list of
# default file extension mappings.
# If left blank the following patterns are tested:*.c, *.cc, *.cxx, *.cpp,
# *.c++, *.java, *.ii, *.ixx, *.ipp, *.i++, *.inl, *.idl, *.ddl, *.odl, *.h,
# *.hh, *.hxx, *.hpp, *.h++, *.l, *.cs, *.d, *.php, *.php4, *.php5, *.phtml,
# *.inc, *.m, *.markdown, *.md, *.mm, *.dox (to be provided as doxygen C
# comment), *.py, *.pyw, *.f90, *.f95, *.f03, *.f08, *.f18, *.f, *.for, *.vhd,
# *.vhdl, *.ucf, *.qsf and *.ice.
FILE_PATTERNS          = *.h *.md
# The RECURSIVE tag can be used to specify whether or not subdirectories should
# be searched for input files as well.
RECURSIVE              = YES
# The EXCLUDE tag can be used to specify files and/or directories that should be
# excluded from the INPUT source files. This way you can easily exclude a
# subdirectory from a directory tree whose root is specified with the INPUT tag.
# Note that relative paths are relative to the directory from which doxygen is
# run.
EXCLUDE                =
# The EXCLUDE_SYMLINKS tag can be used to select whether or not files or
# directories that are symbolic links (a Unix file system feature) are excluded
# from the input.
EXCLUDE_SYMLINKS       = YES
# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
# certain files from those directories.
# Note that the wildcards are matched against the file with absolute path, so to
# exclude all test directories for example use the pattern */test/*
EXCLUDE_PATTERNS       = */mbedtls/*
# The EXCLUDE_SYMBOLS tag can be used to specify one or more symbol names
# (namespaces, classes, functions, etc.) that should be excluded from the
# output. The symbol name can be a fully qualified name, a word, or if the
# wildcard * is used, a substring. Examples: ANamespace, AClass,
# ANamespace::AClass, ANamespace::*Test
# exclude all test directories use the pattern */test/*
EXCLUDE_SYMBOLS        =
# The EXAMPLE_PATH tag can be used to specify one or more files or directories
# that contain example code fragments that are included (see the \include
# command).
EXAMPLE_PATH           =
# If the value of the EXAMPLE_PATH tag contains directories, you can use the
# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp and
# *.h) to filter out the source-files in the directories. If left blank all
# files are included.
EXAMPLE_PATTERNS       =
# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
# searched for input files to be used with the \include or \dontinclude commands
# irrespective of the value of the RECURSIVE tag.
EXAMPLE_RECURSIVE      = NO
# The IMAGE_PATH tag can be used to specify one or more files or directories
# that contain images that are to be included in the documentation (see the
# \image command).
IMAGE_PATH             =
# The INPUT_FILTER tag can be used to specify a program that doxygen should
# invoke to filter for each input file. Doxygen will invoke the filter program
# by executing (via popen()) the command:
# <filter> <input-file>
# where <filter> is the value of the INPUT_FILTER tag, and <input-file> is the
# name of an input file. Doxygen will then use the output that the filter
# program writes to standard output. If FILTER_PATTERNS is specified, this tag
# will be ignored.
# Note that the filter must not add or remove lines; it is applied before the
# code is scanned, but not when the output code is generated. If lines are added
# or removed, the anchors will not be placed correctly.
# properly processed by doxygen.
INPUT_FILTER           =
# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
# basis. Doxygen will compare the file name with each pattern and apply the
# filter if there is a match. The filters are a list of the form: pattern=filter
# (like *.cpp=my_cpp_filter). See INPUT_FILTER for further information on how
# filters are used. If the FILTER_PATTERNS tag is empty or if none of the
# patterns match the file name, INPUT_FILTER is applied.
FILTER_PATTERNS        =
# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
# INPUT_FILTER) will also be used to filter the input files that are used for
# producing the source files to browse (i.e. when SOURCE_BROWSER is set to YES).
FILTER_SOURCE_FILES    = NO
# The FILTER_SOURCE_PATTERNS tag can be used to specify source filters per file
# pattern. A pattern will override the setting for FILTER_PATTERN (if any) and
# it is also possible to disable source filtering for a specific pattern using
# *.ext= (so without naming a filter).
# This tag requires that the tag FILTER_SOURCE_FILES is set to YES.
FILTER_SOURCE_PATTERNS =
# If the USE_MDFILE_AS_MAINPAGE tag refers to the name of a markdown file that
# is part of the input, its contents will be placed on the main page
# (index.html). This can be useful if you have a project on for instance GitHub
# and want to reuse the introduction page also for the doxygen output.
# USE_MDFILE_AS_MAINPAGE =
# Configuration options related to source browsing
# If the SOURCE_BROWSER tag is set to YES then a list of source files will be
# generated. Documented entities will be cross-referenced with these sources.
# Note: To get rid of all source code in the generated output, make sure that
# also VERBATIM_HEADERS is set to NO.
SOURCE_BROWSER         = NO
# Setting the INLINE_SOURCES tag to YES will include the body of functions,
# classes and enums directly into the documentation.
INLINE_SOURCES         = NO
# Setting the STRIP_CODE_COMMENTS tag to YES will instruct doxygen to hide any
# special comment blocks from generated source code fragments. Normal C, C++ and
# Fortran comments will always remain visible.
STRIP_CODE_COMMENTS    = YES
# If the REFERENCED_BY_RELATION tag is set to YES then for each documented
# entity all documented functions referencing it will be listed.
REFERENCED_BY_RELATION = YES
# If the REFERENCES_RELATION tag is set to YES then for each documented function
# all documented entities called/used by that function will be listed.
REFERENCES_RELATION    = YES
# If the REFERENCES_LINK_SOURCE tag is set to YES and SOURCE_BROWSER tag is set
# to YES then the hyperlinks from functions in REFERENCES_RELATION and
# REFERENCED_BY_RELATION lists will link to the source code. Otherwise they will
# link to the documentation.
REFERENCES_LINK_SOURCE = YES
# If SOURCE_TOOLTIPS is enabled (the default) then hovering a hyperlink in the
# source code will show a tooltip with additional information such as prototype,
# brief description and links to the definition and documentation. Since this
# will make the HTML file larger and loading of large files a bit slower, you
# can opt to disable this feature.
# This tag requires that the tag SOURCE_BROWSER is set to YES.
SOURCE_TOOLTIPS        = YES
# If the USE_HTAGS tag is set to YES then the references to source code will
# point to the HTML generated by the htags(1) tool instead of doxygen built-in
# source browser. The htags tool is part of GNU's global source tagging system
# (see https://www.gnu.org/software/global/global.html). You will need version
# 4.8.6 or higher.
# To use it do the following:
# - Install the latest version of global
# - Enable SOURCE_BROWSER and USE_HTAGS in the configuration file
# - Make sure the INPUT points to the root of the source tree
# - Run doxygen as normal
# Doxygen will invoke htags (and that will in turn invoke gtags), so these
# tools must be available from the command line (i.e. in the search path).
# The result: instead of the source browser generated by doxygen, the links to
# source code will now point to the output of htags.
USE_HTAGS              = NO
# If the VERBATIM_HEADERS tag is set the YES then doxygen will generate a
# verbatim copy of the header file for each class for which an include is
# specified. Set to NO to disable this.
# See also: Section \class.
VERBATIM_HEADERS       = YES
# Configuration options related to the alphabetical class index
# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index of all
# compounds will be generated. Enable this if the project contains a lot of
# classes, structs, unions or interfaces.
ALPHABETICAL_INDEX     = YES
# In case all classes in a project start with a common prefix, all classes will
# be put under the same header in the alphabetical index. The IGNORE_PREFIX tag
# can be used to specify a prefix (or a list of prefixes) that should be ignored
# while generating the index headers.
# This tag requires that the tag ALPHABETICAL_INDEX is set to YES.
IGNORE_PREFIX          =
# Configuration options related to the HTML output
# If the GENERATE_HTML tag is set to YES, doxygen will generate HTML output
GENERATE_HTML          = YES
# The HTML_OUTPUT tag is used to specify where the HTML docs will be put. If a
# relative path is entered the value of OUTPUT_DIRECTORY will be put in front of
# it.
# The default directory is: html.
# This tag requires that the tag GENERATE_HTML is set to YES.
HTML_OUTPUT            = output/docs
# The HTML_FILE_EXTENSION tag can be used to specify the file extension for each
# generated HTML page (for example: .htm, .php, .asp).
# The default value is: .html.
HTML_FILE_EXTENSION    = .html
# The HTML_HEADER tag can be used to specify a user-defined HTML header file for
# each generated HTML page. If the tag is left blank doxygen will generate a
# standard header.
# To get valid HTML the header file that includes any scripts and style sheets
# that doxygen needs, which is dependent on the configuration options used (e.g.
# the setting GENERATE_TREEVIEW). It is highly recommended to start with a
# default header using
# doxygen -w html new_header.html new_footer.html new_stylesheet.css
# YourConfigFile
# and then modify the file new_header.html. See also section "Doxygen usage"
# for information on how to generate the default header that doxygen normally
# uses.
# Note: The header is subject to change so you typically have to regenerate the
# default header when upgrading to a newer version of doxygen. For a description
# of the possible markers and block names see the documentation.
GENERATE_TREEVIEW = YES
DISABLE_INDEX = YES
HTML_HEADER            =
# The HTML_FOOTER tag can be used to specify a user-defined HTML footer for each
# generated HTML page. If the tag is left blank doxygen will generate a standard
# footer. See HTML_HEADER for more information on how to generate a default
# footer and what special commands can be used inside the footer. See also
# section "Doxygen usage" for information on how to generate the default footer
# that doxygen normally uses.
HTML_FOOTER            =
# The HTML_STYLESHEET tag can be used to specify a user-defined cascading style
# sheet that is used by each HTML page. It can be used to fine-tune the look of
# the HTML output. If left blank doxygen will generate a default style sheet.
# See also section "Doxygen usage" for information on how to generate the style
# sheet that doxygen normally uses.
# Note: It is recommended to use HTML_EXTRA_STYLESHEET instead of this tag, as
# it is more robust and this tag (HTML_STYLESHEET) will in the future become
# obsolete.
HTML_STYLESHEET        =
# The HTML_EXTRA_STYLESHEET tag can be used to specify additional user-defined
# cascading style sheets that are included after the standard style sheets
# created by doxygen. Using this option one can overrule certain style aspects.
# This is preferred over using HTML_STYLESHEET since it does not replace the
# standard style sheet and is therefore more robust against future updates.
# Doxygen will copy the style sheet files to the output directory.
# Note: The order of the extra style sheet files is of importance (e.g. the last
# style sheet in the list overrules the setting of the previous ones in the
# list). For an example see the documentation.
HTML_EXTRA_STYLESHEET  =
# The HTML_EXTRA_FILES tag can be used to specify one or more extra images or
# other source files which should be copied to the HTML output directory. Note
# that these files will be copied to the base HTML output directory. Use the
# $relpath^ marker in the HTML_HEADER and/or HTML_FOOTER files to load these
# files. In the HTML_STYLESHEET file, use the file name only. Also note that the
# files will be copied as-is; there are no commands or markers available.
HTML_EXTRA_FILES       =
# The HTML_COLORSTYLE_HUE tag controls the color of the HTML output. Doxygen
# will adjust the colors in the style sheet and background images according to
# this color. Hue is specified as an angle on a color-wheel, see
# https://en.wikipedia.org/wiki/Hue for more information. For instance the value
# 0 represents red, 60 is yellow, 120 is green, 180 is cyan, 240 is blue, 300
# purple, and 360 is red again.
# Minimum value: 0, maximum value: 359, default value: 220.
HTML_COLORSTYLE_HUE    = 220
# The HTML_COLORSTYLE_SAT tag controls the purity (or saturation) of the colors
# in the HTML output. For a value of 0 the output will use gray-scales only. A
# value of 255 will produce the most vivid colors.
# Minimum value: 0, maximum value: 255, default value: 100.
HTML_COLORSTYLE_SAT    = 100
# The HTML_COLORSTYLE_GAMMA tag controls the gamma correction applied to the
# luminance component of the colors in the HTML output. Values below 100
# gradually make the output lighter, whereas values above 100 make the output
# darker. The value divided by 100 is the actual gamma applied, so 80 represents
# a gamma of 0.8, The value 220 represents a gamma of 2.2, and 100 does not
# change the gamma.
# Minimum value: 40, maximum value: 240, default value: 80.
HTML_COLORSTYLE_GAMMA  = 80
# If the HTML_TIMESTAMP tag is set to YES then the footer of each generated HTML
# page will contain the date and time when the page was generated. Setting this
# to YES can help to show when doxygen was last run and thus if the
# documentation is up to date.
HTML_TIMESTAMP         = NO
# If the HTML_DYNAMIC_MENUS tag is set to YES then the generated HTML
# documentation will contain a main index with vertical navigation menus that
# are dynamically created via JavaScript. If disabled, the navigation index will
# consists of multiple levels of tabs that are statically embedded in every HTML
# page. Disable this option to support browsers that do not have JavaScript,
# like the Qt help browser.
HTML_DYNAMIC_MENUS     = YES
# If the HTML_DYNAMIC_SECTIONS tag is set to YES then the generated HTML
# documentation will contain sections that can be hidden and shown after the
# page has loaded.
HTML_DYNAMIC_SECTIONS  = NO
# With HTML_INDEX_NUM_ENTRIES one can control the preferred number of entries
# shown in the various tree structured indices initially; the user can expand
# and collapse entries dynamically later on. Doxygen will expand the tree to
# such a level that at most the specified number of entries are visible (unless
# a fully collapsed tree already exceeds this amount). So setting the number of
# entries 1 will produce a full collapsed tree by default. 0 is a special value
# representing an infinite number of entries and will result in a full expanded
# tree by default.
# Minimum value: 0, maximum value: 9999, default value: 100.
HTML_INDEX_NUM_ENTRIES = 100
# If the GENERATE_DOCSET tag is set to YES, additional index files will be
# generated that can be used as input for Apple's Xcode 3 integrated development
# environment (see:
# https://developer.apple.com/xcode/), introduced with OSX 10.5 (Leopard). To
# create a documentation set, doxygen will generate a Makefile in the HTML
# output directory. Running make will produce the docset in that directory and
# running make install will install the docset in
# ~/Library/Developer/Shared/Documentation/DocSets so that Xcode will find it at
# startup. See https://developer.apple.com/library/archive/featuredarticles/Doxy
# genXcode/_index.html for more information.
GENERATE_DOCSET        = NO
# This tag determines the name of the docset feed. A documentation feed provides
# an umbrella under which multiple documentation sets from a single provider
# (such as a company or product suite) can be grouped.
# The default value is: Doxygen generated docs.
# This tag requires that the tag GENERATE_DOCSET is set to YES.
DOCSET_FEEDNAME        = "Doxygen generated docs"
# This tag determines the URL of the docset feed. A documentation feed provides
DOCSET_FEEDURL         =
# This tag specifies a string that should uniquely identify the documentation
# set bundle. This should be a reverse domain-name style string, e.g.
# com.mycompany.MyDocSet. Doxygen will append .docset to the name.
# The default value is: org.doxygen.Project.
DOCSET_BUNDLE_ID       = org.doxygen.Project
# The DOCSET_PUBLISHER_ID tag specifies a string that should uniquely identify
# the documentation publisher. This should be a reverse domain-name style
# string, e.g. com.mycompany.MyDocSet.documentation.
# The default value is: org.doxygen.Publisher.
DOCSET_PUBLISHER_ID    = org.doxygen.Publisher
# The DOCSET_PUBLISHER_NAME tag identifies the documentation publisher.
# The default value is: Publisher.
DOCSET_PUBLISHER_NAME  = Publisher
# If the GENERATE_HTMLHELP tag is set to YES then doxygen generates three
# additional HTML index files: index.hhp, index.hhc, and index.hhk. The
# index.hhp is a project file that can be read by Microsoft's HTML Help Workshop
# on Windows. In the beginning of 2021 Microsoft took the original page, with
# a.o. the download links, offline the HTML help workshop was already many years
# in maintenance mode). You can download the HTML help workshop from the web
# archives at Installation executable (see:
# http://web.archive.org/web/20160201063255/http://download.microsoft.com/downlo
# ad/0/A/9/0A939EF6-E31C-430F-A3DF-DFAE7960D564/htmlhelp.exe).
# The HTML Help Workshop contains a compiler that can convert all HTML output
# generated by doxygen into a single compiled HTML file (.chm). Compiled HTML
# files are now used as the Windows 98 help format, and will replace the old
# Windows help format (.hlp) on all Windows platforms in the future. Compressed
# HTML files also contain an index, a table of contents, and you can search for
# words in the documentation. The HTML workshop also contains a viewer for
# compressed HTML files.
GENERATE_HTMLHELP      = NO
# The CHM_FILE tag can be used to specify the file name of the resulting .chm
# file. You can add a path in front of the file if the result should not be
# written to the html output directory.
# This tag requires that the tag GENERATE_HTMLHELP is set to YES.
CHM_FILE               =
# The HHC_LOCATION tag can be used to specify the location (absolute path
# including file name) of the HTML help compiler (hhc.exe). If non-empty,
# doxygen will try to run the HTML help compiler on the generated index.hhp.
# The file has to be specified with full path.
HHC_LOCATION           =
# The GENERATE_CHI flag controls if a separate .chi index file is generated
# (YES) or that it should be included in the main .chm file (NO).
GENERATE_CHI           = NO
# The CHM_INDEX_ENCODING is used to encode HtmlHelp index (hhk), content (hhc)
# and project file content.
CHM_INDEX_ENCODING     =
# The BINARY_TOC flag controls whether a binary table of contents is generated
# (YES) or a normal table of contents (NO) in the .chm file. Furthermore it
# enables the Previous and Next buttons.
BINARY_TOC             = NO
# The TOC_EXPAND flag can be set to YES to add extra items for group members to
# the table of contents of the HTML help documentation and to the tree view.
TOC_EXPAND             = NO
# If the GENERATE_QHP tag is set to YES and both QHP_NAMESPACE and
# QHP_VIRTUAL_FOLDER are set, an additional index file will be generated that
# can be used as input for Qt's qhelpgenerator to generate a Qt Compressed Help
# (.qch) of the generated HTML documentation.
GENERATE_QHP           = NO
# If the QHG_LOCATION tag is specified, the QCH_FILE tag can be used to specify
# the file name of the resulting .qch file. The path specified is relative to
# the HTML output folder.
# This tag requires that the tag GENERATE_QHP is set to YES.
QCH_FILE               =
# The QHP_NAMESPACE tag specifies the namespace to use when generating Qt Help
# Project output. For more information please see Qt Help Project / Namespace
# (see:
# https://doc.qt.io/archives/qt-4.8/qthelpproject.html#namespace).
QHP_NAMESPACE          = org.doxygen.Project
# The QHP_VIRTUAL_FOLDER tag specifies the namespace to use when generating Qt
# Help Project output. For more information please see Qt Help Project / Virtual
# Folders (see:
# https://doc.qt.io/archives/qt-4.8/qthelpproject.html#virtual-folders).
# The default value is: doc.
QHP_VIRTUAL_FOLDER     = doc
# If the QHP_CUST_FILTER_NAME tag is set, it specifies the name of a custom
# filter to add. For more information please see Qt Help Project / Custom
# Filters (see:
# https://doc.qt.io/archives/qt-4.8/qthelpproject.html#custom-filters).
QHP_CUST_FILTER_NAME   =
# The QHP_CUST_FILTER_ATTRS tag specifies the list of the attributes of the
# custom filter to add. For more information please see Qt Help Project / Custom
# Filters (see:
QHP_CUST_FILTER_ATTRS  =
# The QHP_SECT_FILTER_ATTRS tag specifies the list of the attributes this
# project's filter section matches. Qt Help Project / Filter Attributes (see:
# https://doc.qt.io/archives/qt-4.8/qthelpproject.html#filter-attributes).
QHP_SECT_FILTER_ATTRS  =
# The QHG_LOCATION tag can be used to specify the location (absolute path
# including file name) of Qt's qhelpgenerator. If non-empty doxygen will try to
# run qhelpgenerator on the generated .qhp file.
QHG_LOCATION           =
# If the GENERATE_ECLIPSEHELP tag is set to YES, additional index files will be
# generated, together with the HTML files, they form an Eclipse help plugin. To
# install this plugin and make it available under the help contents menu in
# Eclipse, the contents of the directory containing the HTML and XML files needs
# to be copied into the plugins directory of eclipse. The name of the directory
# within the plugins directory should be the same as the ECLIPSE_DOC_ID value.
# After copying Eclipse needs to be restarted before the help appears.
GENERATE_ECLIPSEHELP   = NO
# A unique identifier for the Eclipse help plugin. When installing the plugin
# the directory name containing the HTML and XML files should also have this
# name. Each documentation set should have its own identifier.
# This tag requires that the tag GENERATE_ECLIPSEHELP is set to YES.
ECLIPSE_DOC_ID         = org.doxygen.Project
# If you want full control over the layout of the generated HTML pages it might
# be necessary to disable the index and replace it with your own. The
# DISABLE_INDEX tag can be used to turn on/off the condensed index (tabs) at top
# of each HTML page. A value of NO enables the index and the value YES disables
# it. Since the tabs in the index contain the same information as the navigation
# tree, you can set this option to YES if you also set GENERATE_TREEVIEW to YES.
DISABLE_INDEX          = NO
# The GENERATE_TREEVIEW tag is used to specify whether a tree-like index
# structure should be generated to display hierarchical information. If the tag
# value is set to YES, a side panel will be generated containing a tree-like
# index structure (just like the one that is generated for HTML Help). For this
# to work a browser that supports JavaScript, DHTML, CSS and frames is required
# (i.e. any modern browser). Windows users are probably better off using the
# HTML help feature. Via custom style sheets (see HTML_EXTRA_STYLESHEET) one can
# further fine tune the look of the index (see "Fine-tuning the output"). As an
# example, the default style sheet generated by doxygen has an example that
# shows how to put an image at the root of the tree instead of the PROJECT_NAME.
# Since the tree basically has the same information as the tab index, you could
# consider setting DISABLE_INDEX to YES when enabling this option.
GENERATE_TREEVIEW      = NO
# When both GENERATE_TREEVIEW and DISABLE_INDEX are set to YES, then the
# FULL_SIDEBAR option determines if the side bar is limited to only the treeview
# area (value NO) or if it should extend to the full height of the window (value
# YES). Setting this to YES gives a layout similar to
# https://docs.readthedocs.io with more room for contents, but less room for the
# project logo, title, and description. If either GENERATE_TREEVIEW or
# DISABLE_INDEX is set to NO, this option has no effect.
FULL_SIDEBAR           = NO
# The ENUM_VALUES_PER_LINE tag can be used to set the number of enum values that
# doxygen will group on one line in the generated HTML documentation.
# Note that a value of 0 will completely suppress the enum values from appearing
# in the overview section.
# Minimum value: 0, maximum value: 20, default value: 4.
ENUM_VALUES_PER_LINE   = 4
# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be used
# to set the initial width (in pixels) of the frame in which the tree is shown.
# Minimum value: 0, maximum value: 1500, default value: 250.
TREEVIEW_WIDTH         = 250
# If the EXT_LINKS_IN_WINDOW option is set to YES, doxygen will open links to
# external symbols imported via tag files in a separate window.
EXT_LINKS_IN_WINDOW    = NO
# If the OBFUSCATE_EMAILS tag is set to YES, doxygen will obfuscate email
# addresses.
OBFUSCATE_EMAILS       = YES
# If the HTML_FORMULA_FORMAT option is set to svg, doxygen will use the pdf2svg
# tool (see https://github.com/dawbarton/pdf2svg) or inkscape (see
# https://inkscape.org) to generate formulas as SVG images instead of PNGs for
# the HTML output. These images will generally look nicer at scaled resolutions.
# Possible values are: png (the default) and svg (looks nicer but requires the
# pdf2svg or inkscape tool).
# The default value is: png.
HTML_FORMULA_FORMAT    = png
# Use this tag to change the font size of LaTeX formulas included as images in
# the HTML documentation. When you change the font size after a successful
# doxygen run you need to manually remove any form_*.png images from the HTML
# output directory to force them to be regenerated.
# Minimum value: 8, maximum value: 50, default value: 10.
FORMULA_FONTSIZE       = 10
# Use the FORMULA_TRANSPARENT tag to determine whether or not the images
# generated for formulas are transparent PNGs. Transparent PNGs are not
# supported properly for IE 6.0, but are supported on all modern browsers.
# Note that when changing this option you need to delete any form_*.png files in
# the HTML output directory before the changes have effect.
FORMULA_TRANSPARENT    = YES
# The FORMULA_MACROFILE can contain LaTeX \newcommand and \renewcommand commands
# to create new LaTeX commands to be used in formulas as building blocks. See
# the section "Including formulas" for details.
FORMULA_MACROFILE      =
# Enable the USE_MATHJAX option to render LaTeX formulas using MathJax (see
# https://www.mathjax.org) which uses client side JavaScript for the rendering
# instead of using pre-rendered bitmaps. Use this if you do not have LaTeX
# installed or if you want to formulas look prettier in the HTML output. When
# enabled you may also need to install MathJax separately and configure the path
# to it using the MATHJAX_RELPATH option.
# The default value is: NO.
USE_MATHJAX            = NO
# With MATHJAX_VERSION it is possible to specify the MathJax version to be used.
# Note that the different versions of MathJax have different requirements with
# regards to the different settings, so it is possible that also other MathJax
# settings have to be changed when switching between the different MathJax
# versions.
# Possible values are: MathJax_2 and MathJax_3.
# The default value is: MathJax_2.
# This tag requires that the tag USE_MATHJAX is set to YES.
MATHJAX_VERSION        = MathJax_2
# When MathJax is enabled you can set the default output format to be used for
# the MathJax output. For more details about the output format see MathJax
# version 2 (see:
# http://docs.mathjax.org/en/v2.7-latest/output.html) and MathJax version 3
# (see:
# http://docs.mathjax.org/en/latest/web/components/output.html).
# Possible values are: HTML-CSS (which is slower, but has the best
# compatibility. This is the name for Mathjax version 2, for MathJax version 3
# this will be translated into chtml), NativeMML (i.e. MathML. Only supported
# for NathJax 2. For MathJax version 3 chtml will be used instead.), chtml (This
# is the name for Mathjax version 3, for MathJax version 2 this will be
# translated into HTML-CSS) and SVG.
# The default value is: HTML-CSS.
MATHJAX_FORMAT         = HTML-CSS
# When MathJax is enabled you need to specify the location relative to the HTML
# output directory using the MATHJAX_RELPATH option. The destination directory
# should contain the MathJax.js script. For instance, if the mathjax directory
# is located at the same level as the HTML output directory, then
# MATHJAX_RELPATH should be ../mathjax. The default value points to the MathJax
# Content Delivery Network so you can quickly see the result without installing
# MathJax. However, it is strongly recommended to install a local copy of
# MathJax from https://www.mathjax.org before deployment. The default value is:
# - in case of MathJax version 2: https://cdn.jsdelivr.net/npm/mathjax@2
# - in case of MathJax version 3: https://cdn.jsdelivr.net/npm/mathjax@3
MATHJAX_RELPATH        =
# The MATHJAX_EXTENSIONS tag can be used to specify one or more MathJax
# extension names that should be enabled during MathJax rendering. For example
# for MathJax version 2 (see https://docs.mathjax.org/en/v2.7-latest/tex.html
# #tex-and-latex-extensions):
# MATHJAX_EXTENSIONS = TeX/AMSmath TeX/AMSsymbols
# For example for MathJax version 3 (see
# http://docs.mathjax.org/en/latest/input/tex/extensions/index.html):
# MATHJAX_EXTENSIONS = ams
# The MATHJAX_CODEFILE tag can be used to specify a file with javascript pieces
# of code that will be used on startup of the MathJax code. See the MathJax site
# (see:
# http://docs.mathjax.org/en/v2.7-latest/output.html) for more details. For an
# example see the documentation.
MATHJAX_CODEFILE       =
# When the SEARCHENGINE tag is enabled doxygen will generate a search box for
# the HTML output. The underlying search engine uses javascript and DHTML and
# should work on any modern browser. Note that when using HTML help
# (GENERATE_HTMLHELP), Qt help (GENERATE_QHP), or docsets (GENERATE_DOCSET)
# there is already a search function so this one should typically be disabled.
# For large projects the javascript based search engine can be slow, then
# enabling SERVER_BASED_SEARCH may provide a better solution. It is possible to
# search using the keyboard; to jump to the search box use <access key> + S
# (what the <access key> is depends on the OS and browser, but it is typically
# <CTRL>, <ALT>/<option>, or both). Inside the search box use the <cursor down
# key> to jump into the search results window, the results can be navigated
# using the <cursor keys>. Press <Enter> to select an item or <escape> to cancel
# the search. The filter options can be selected when the cursor is inside the
# search box by pressing <Shift>+<cursor down>. Also here use the <cursor keys>
# to select a filter and <Enter> or <escape> to activate or cancel the filter
# option.
# The default value is: YES.
SEARCHENGINE           = YES
# When the SERVER_BASED_SEARCH tag is enabled the search engine will be
# implemented using a web server instead of a web client using JavaScript. There
# are two flavors of web server based searching depending on the EXTERNAL_SEARCH
# setting. When disabled, doxygen will generate a PHP script for searching and
# an index file used by the script. When EXTERNAL_SEARCH is enabled the indexing
# and searching needs to be provided by external tools. See the section
# "External Indexing and Searching" for details.
# This tag requires that the tag SEARCHENGINE is set to YES.
SERVER_BASED_SEARCH    = NO
# When EXTERNAL_SEARCH tag is enabled doxygen will no longer generate the PHP
# script for searching. Instead the search results are written to an XML file
# which needs to be processed by an external indexer. Doxygen will invoke an
# external search engine pointed to by the SEARCHENGINE_URL option to obtain the
# search results.
# Doxygen ships with an example indexer (doxyindexer) and search engine
# (doxysearch.cgi) which are based on the open source search engine library
# Xapian (see:
# https://xapian.org/).
# See the section "External Indexing and Searching" for details.
EXTERNAL_SEARCH        = NO
# The SEARCHENGINE_URL should point to a search engine hosted by a web server
# which will return the search results when EXTERNAL_SEARCH is enabled.
# Xapian (see:
# https://xapian.org/). See the section "External Indexing and Searching" for
# details.
SEARCHENGINE_URL       =
# When SERVER_BASED_SEARCH and EXTERNAL_SEARCH are both enabled the unindexed
# search data is written to a file for indexing by an external tool. With the
# SEARCHDATA_FILE tag the name of this file can be specified.
# The default file is: searchdata.xml.
SEARCHDATA_FILE        = searchdata.xml
# EXTERNAL_SEARCH_ID tag can be used as an identifier for the project. This is
# useful in combination with EXTRA_SEARCH_MAPPINGS to search through multiple
# projects and redirect the results back to the right project.
EXTERNAL_SEARCH_ID     =
# The EXTRA_SEARCH_MAPPINGS tag can be used to enable searching through doxygen
# projects other than the one defined by this configuration file, but that are
# all added to the same external search index. Each project needs to have a
# unique id set via EXTERNAL_SEARCH_ID. The search mapping then maps the id of
# to a relative location where the documentation can be found. The format is:
# EXTRA_SEARCH_MAPPINGS = tagname1=loc1 tagname2=loc2 ...
# Configuration options related to the LaTeX output
# If the GENERATE_LATEX tag is set to YES, doxygen will generate LaTeX output.
GENERATE_LATEX         = NO
# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put. If a
# it.
# The default directory is: latex.
# This tag requires that the tag GENERATE_LATEX is set to YES.
LATEX_OUTPUT           = latex
# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
# invoked.
# Note that when not enabling USE_PDFLATEX the default is latex when enabling
# USE_PDFLATEX the default is pdflatex and when in the later case latex is
# chosen this is overwritten by pdflatex. For specific output languages the
# default can have been set differently, this depends on the implementation of
# the output language.
LATEX_CMD_NAME         =
# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to generate
# index for LaTeX.
# Note: This tag is used in the Makefile / make.bat.
# See also: LATEX_MAKEINDEX_CMD for the part in the generated output file
# (.tex).
# The default file is: makeindex.
MAKEINDEX_CMD_NAME     = makeindex
# The LATEX_MAKEINDEX_CMD tag can be used to specify the command name to
# generate index for LaTeX. In case there is no backslash (\) as first character
# it will be automatically added in the LaTeX code.
# Note: This tag is used in the generated output file (.tex).
# See also: MAKEINDEX_CMD_NAME for the part in the Makefile / make.bat.
# The default value is: makeindex.
LATEX_MAKEINDEX_CMD    = makeindex
# If the COMPACT_LATEX tag is set to YES, doxygen generates more compact LaTeX
# documents. This may be useful for small projects and may help to save some
# trees in general.
COMPACT_LATEX          = NO
# The PAPER_TYPE tag can be used to set the paper type that is used by the
# printer.
# Possible values are: a4 (210 x 297 mm), letter (8.5 x 11 inches), legal (8.5 x
# 14 inches) and executive (7.25 x 10.5 inches).
# The default value is: a4.
PAPER_TYPE             = a4
# The EXTRA_PACKAGES tag can be used to specify one or more LaTeX package names
# that should be included in the LaTeX output. The package can be specified just
# by its name or with the correct syntax as to be used with the LaTeX
# \usepackage command. To get the times font for instance you can specify :
# EXTRA_PACKAGES=times or EXTRA_PACKAGES={times}
# To use the option intlimits with the amsmath package you can specify:
# EXTRA_PACKAGES=[intlimits]{amsmath}
# If left blank no extra packages will be included.
EXTRA_PACKAGES         =
# The LATEX_HEADER tag can be used to specify a user-defined LaTeX header for
# the generated LaTeX document. The header should contain everything until the
# first chapter. If it is left blank doxygen will generate a standard header. It
# is highly recommended to start with a default header using
# doxygen -w latex new_header.tex new_footer.tex new_stylesheet.sty
# and then modify the file new_header.tex. See also section "Doxygen usage" for
# information on how to generate the default header that doxygen normally uses.
# Note: Only use a user-defined header if you know what you are doing!
# default header when upgrading to a newer version of doxygen. The following
# commands have a special meaning inside the header (and footer): For a
# description of the possible markers and block names see the documentation.
LATEX_HEADER           =
# The LATEX_FOOTER tag can be used to specify a user-defined LaTeX footer for
# the generated LaTeX document. The footer should contain everything after the
# last chapter. If it is left blank doxygen will generate a standard footer. See
# LATEX_HEADER for more information on how to generate a default footer and what
# special commands can be used inside the footer. See also section "Doxygen
# usage" for information on how to generate the default footer that doxygen
# normally uses. Note: Only use a user-defined footer if you know what you are
# doing!
LATEX_FOOTER           =
# The LATEX_EXTRA_STYLESHEET tag can be used to specify additional user-defined
# LaTeX style sheets that are included after the standard style sheets created
# by doxygen. Using this option one can overrule certain style aspects. Doxygen
# will copy the style sheet files to the output directory.
# list).
LATEX_EXTRA_STYLESHEET =
# The LATEX_EXTRA_FILES tag can be used to specify one or more extra images or
# other source files which should be copied to the LATEX_OUTPUT output
# directory. Note that the files will be copied as-is; there are no commands or
# markers available.
LATEX_EXTRA_FILES      =
# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated is
# prepared for conversion to PDF (using ps2pdf or pdflatex). The PDF file will
# contain links (just like the HTML output) instead of page references. This
# makes the output suitable for online browsing using a PDF viewer.
PDF_HYPERLINKS         = YES
# If the USE_PDFLATEX tag is set to YES, doxygen will use the engine as
# specified with LATEX_CMD_NAME to generate the PDF file directly from the LaTeX
# files. Set this option to YES, to get a higher quality PDF documentation.
# See also section LATEX_CMD_NAME for selecting the engine.
USE_PDFLATEX           = YES
# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \batchmode
# command to the generated LaTeX files. This will instruct LaTeX to keep running
# if errors occur, instead of asking the user for help.
LATEX_BATCHMODE        = NO
# If the LATEX_HIDE_INDICES tag is set to YES then doxygen will not include the
# index chapters (such as File Index, Compound Index, etc.) in the output.
LATEX_HIDE_INDICES     = NO
# The LATEX_BIB_STYLE tag can be used to specify the style to use for the
# bibliography, e.g. plainnat, or ieeetr. See
# https://en.wikipedia.org/wiki/BibTeX and \cite for more info.
# The default value is: plain.
LATEX_BIB_STYLE        = plain
# If the LATEX_TIMESTAMP tag is set to YES then the footer of each generated
# to NO can help when comparing the output of multiple runs.
LATEX_TIMESTAMP        = NO
# The LATEX_EMOJI_DIRECTORY tag is used to specify the (relative or absolute)
# path from which the emoji images will be read. If a relative path is entered,
# it will be relative to the LATEX_OUTPUT directory. If left blank the
# LATEX_OUTPUT directory will be used.
LATEX_EMOJI_DIRECTORY  =
# Configuration options related to the RTF output
# If the GENERATE_RTF tag is set to YES, doxygen will generate RTF output. The
# RTF output is optimized for Word 97 and may not look too pretty with other RTF
# readers/editors.
GENERATE_RTF           = NO
# The RTF_OUTPUT tag is used to specify where the RTF docs will be put. If a
# it.
# The default directory is: rtf.
# This tag requires that the tag GENERATE_RTF is set to YES.
RTF_OUTPUT             = rtf
# If the COMPACT_RTF tag is set to YES, doxygen generates more compact RTF
# trees in general.
COMPACT_RTF            = NO
# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated will
# contain hyperlink fields. The RTF file will contain links (just like the HTML
# output) instead of page references. This makes the output suitable for online
# browsing using Word or some other Word compatible readers that support those
# fields.
# Note: WordPad (write) and others do not support links.
RTF_HYPERLINKS         = NO
# Load stylesheet definitions from file. Syntax is similar to doxygen's
# configuration file, i.e. a series of assignments. You only have to provide
# replacements, missing definitions are set to their default value.
# default style sheet that doxygen normally uses.
RTF_STYLESHEET_FILE    =
# Set optional variables used in the generation of an RTF document. Syntax is
# similar to doxygen's configuration file. A template extensions file can be
# generated using doxygen -e rtf extensionFile.
RTF_EXTENSIONS_FILE    =
# Configuration options related to the man page output
# If the GENERATE_MAN tag is set to YES, doxygen will generate man pages for
# classes and files.
GENERATE_MAN           = NO
# The MAN_OUTPUT tag is used to specify where the man pages will be put. If a
# it. A directory man3 will be created inside the directory specified by
# MAN_OUTPUT.
# The default directory is: man.
# This tag requires that the tag GENERATE_MAN is set to YES.
MAN_OUTPUT             = man
# The MAN_EXTENSION tag determines the extension that is added to the generated
# man pages. In case the manual section does not start with a number, the number
# 3 is prepended. The dot (.) at the beginning of the MAN_EXTENSION tag is
# optional.
# The default value is: .3.
MAN_EXTENSION          = .3
# The MAN_SUBDIR tag determines the name of the directory created within
# MAN_OUTPUT in which the man pages are placed. If defaults to man followed by
# MAN_EXTENSION with the initial . removed.
MAN_SUBDIR             =
# If the MAN_LINKS tag is set to YES and doxygen generates man output, then it
# will generate one additional man file for each entity documented in the real
# man page(s). These additional files only source the real man page, but without
# them the man command would be unable to find the correct page.
MAN_LINKS              = NO
# Configuration options related to the XML output
# If the GENERATE_XML tag is set to YES, doxygen will generate an XML file that
# captures the structure of the code including all documentation.
GENERATE_XML           = NO
# The XML_OUTPUT tag is used to specify where the XML pages will be put. If a
# it.
# The default directory is: xml.
# This tag requires that the tag GENERATE_XML is set to YES.
XML_OUTPUT             = xml
# If the XML_PROGRAMLISTING tag is set to YES, doxygen will dump the program
# listings (including syntax highlighting and cross-referencing information) to
# the XML output. Note that enabling this will significantly increase the size
# of the XML output.
XML_PROGRAMLISTING     = YES
# If the XML_NS_MEMB_FILE_SCOPE tag is set to YES, doxygen will include
# namespace members in file scope as well, matching the HTML output.
XML_NS_MEMB_FILE_SCOPE = NO
# Configuration options related to the DOCBOOK output
# If the GENERATE_DOCBOOK tag is set to YES, doxygen will generate Docbook files
# that can be used to generate PDF.
GENERATE_DOCBOOK       = NO
# The DOCBOOK_OUTPUT tag is used to specify where the Docbook pages will be put.
# If a relative path is entered the value of OUTPUT_DIRECTORY will be put in
# front of it.
# The default directory is: docbook.
# This tag requires that the tag GENERATE_DOCBOOK is set to YES.
DOCBOOK_OUTPUT         = docbook
# Configuration options for the AutoGen Definitions output
# If the GENERATE_AUTOGEN_DEF tag is set to YES, doxygen will generate an
# AutoGen Definitions (see http://autogen.sourceforge.net/) file that captures
# the structure of the code including all documentation. Note that this feature
# is still experimental and incomplete at the moment.
GENERATE_AUTOGEN_DEF   = NO
# Configuration options related to the Perl module output
# If the GENERATE_PERLMOD tag is set to YES, doxygen will generate a Perl module
# file that captures the structure of the code including all documentation.
# Note that this feature is still experimental and incomplete at the moment.
GENERATE_PERLMOD       = NO
# If the PERLMOD_LATEX tag is set to YES, doxygen will generate the necessary
# Makefile rules, Perl scripts and LaTeX code to be able to generate PDF and DVI
# output from the Perl module output.
# This tag requires that the tag GENERATE_PERLMOD is set to YES.
PERLMOD_LATEX          = NO
# If the PERLMOD_PRETTY tag is set to YES, the Perl module output will be nicely
# formatted so it can be parsed by a human reader. This is useful if you want to
# understand what is going on. On the other hand, if this tag is set to NO, the
# size of the Perl module output will be much smaller and Perl will parse it
# just the same.
PERLMOD_PRETTY         = YES
# The names of the make variables in the generated doxyrules.make file are
# prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX. This is useful
# so different doxyrules.make files included by the same Makefile don't
# overwrite each other's variables.
PERLMOD_MAKEVAR_PREFIX =
# Configuration options related to the preprocessor
# If the ENABLE_PREPROCESSING tag is set to YES, doxygen will evaluate all
# C-preprocessor directives found in the sources and include files.
ENABLE_PREPROCESSING   = YES
# If the MACRO_EXPANSION tag is set to YES, doxygen will expand all macro names
# in the source code. If set to NO, only conditional compilation will be
# performed. Macro expansion can be done in a controlled way by setting
# EXPAND_ONLY_PREDEF to YES.
# This tag requires that the tag ENABLE_PREPROCESSING is set to YES.
MACRO_EXPANSION        = YES
# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES then
# the macro expansion is limited to the macros specified with the PREDEFINED and
# EXPAND_AS_DEFINED tags.
EXPAND_ONLY_PREDEF     = NO
# If the SEARCH_INCLUDES tag is set to YES, the include files in the
# INCLUDE_PATH will be searched if a #include is found.
SEARCH_INCLUDES        = YES
# The INCLUDE_PATH tag can be used to specify one or more directories that
# contain include files that are not input files but should be processed by the
# preprocessor.
# This tag requires that the tag SEARCH_INCLUDES is set to YES.
INCLUDE_PATH           = ./include
# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
# patterns (like *.h and *.hpp) to filter out the header-files in the
# directories. If left blank, the patterns specified with FILE_PATTERNS will be
# used.
INCLUDE_FILE_PATTERNS  =
# The PREDEFINED tag can be used to specify one or more macro names that are
# defined before the preprocessor is started (similar to the -D option of e.g.
# gcc). The argument of the tag is a list of macros of the form: name or
# name=definition (no spaces). If the definition and the "=" are omitted, "=1"
# is assumed. To prevent a macro definition from being undefined via #undef or
# recursively expanded use the := operator instead of the = operator.
PREDEFINED             =
# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then this
# tag can be used to specify a list of macro names that should be expanded. The
# macro definition that is found in the sources will be used. Use the PREDEFINED
# tag if you want to use a different macro definition that overrules the
# definition found in the source code.
EXPAND_AS_DEFINED      =
# If the SKIP_FUNCTION_MACROS tag is set to YES then doxygen's preprocessor will
# remove all references to function-like macros that are alone on a line, have
# an all uppercase name, and do not end with a semicolon. Such function macros
# are typically used for boiler-plate code, and will confuse the parser if not
# removed.
SKIP_FUNCTION_MACROS   = YES
# Configuration options related to external references
# The TAGFILES tag can be used to specify one or more tag files. For each tag
# file the location of the external documentation should be added. The format of
# a tag file without this location is as follows:
# TAGFILES = file1 file2 ...
# Adding location for the tag files is done as follows:
# TAGFILES = file1=loc1 "file2 = loc2" ...
# where loc1 and loc2 can be relative or absolute paths or URLs. See the
# section "Linking to external documentation" for more information about the use
# of tag files.
# Note: Each tag file must have a unique name (where the name does NOT include
# the path). If a tag file is not located in the directory in which doxygen is
# run, you must also specify the path to the tagfile here.
TAGFILES               =
# When a file name is specified after GENERATE_TAGFILE, doxygen will create a
# tag file that is based on the input files it reads. See section "Linking to
# external documentation" for more information about the usage of tag files.
GENERATE_TAGFILE       =
# If the ALLEXTERNALS tag is set to YES, all external class will be listed in
# the class index. If set to NO, only the inherited external classes will be
# listed.
ALLEXTERNALS           = NO
# If the EXTERNAL_GROUPS tag is set to YES, all external groups will be listed
# in the modules index. If set to NO, only the current project's groups will be
# listed.
EXTERNAL_GROUPS        = YES
# If the EXTERNAL_PAGES tag is set to YES, all external pages will be listed in
# the related pages index. If set to NO, only the current project's pages will
# be listed.
EXTERNAL_PAGES         = YES
# Configuration options related to the dot tool
# You can include diagrams made with dia in doxygen documentation. Doxygen will
# then run dia to produce the diagram and insert it in the documentation. The
# DIA_PATH tag allows you to specify the directory where the dia binary resides.
# If left empty dia is assumed to be found in the default search path.
DIA_PATH               =
# If set to YES the inheritance and collaboration graphs will hide inheritance
# and usage relations if the target is undocumented or is not a class.
HIDE_UNDOC_RELATIONS   = YES
# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
# available from the path. This tool is part of Graphviz (see:
# http://www.graphviz.org/), a graph visualization toolkit from AT&T and Lucent
# Bell Labs. The other options in this section have no effect if this option is
# set to NO
HAVE_DOT               = YES
# The DOT_NUM_THREADS specifies the number of dot invocations doxygen is allowed
# to run in parallel. When set to 0 doxygen will base this on the number of
# processors available in the system. You can set it explicitly to a value
# larger than 0 to get control over the balance between CPU load and processing
# speed.
# Minimum value: 0, maximum value: 32, default value: 0.
# This tag requires that the tag HAVE_DOT is set to YES.
DOT_NUM_THREADS        = 0
# When you want a differently looking font in the dot files that doxygen
# generates you can specify the font name using DOT_FONTNAME. You need to make
# sure dot is able to find the font, which can be done by putting it in a
# standard location or by setting the DOTFONTPATH environment variable or by
# setting DOT_FONTPATH to the directory containing the font.
# The default value is: Helvetica.
DOT_FONTNAME           = Helvetica
# The DOT_FONTSIZE tag can be used to set the size (in points) of the font of
# dot graphs.
# Minimum value: 4, maximum value: 24, default value: 10.
DOT_FONTSIZE           = 10
# By default doxygen will tell dot to use the default font as specified with
# DOT_FONTNAME. If you specify a different font using DOT_FONTNAME you can set
# the path where dot can find it using this tag.
DOT_FONTPATH           =
# If the CLASS_GRAPH tag is set to YES (or GRAPH) then doxygen will generate a
# graph for each documented class showing the direct and indirect inheritance
# relations. In case HAVE_DOT is set as well dot will be used to draw the graph,
# otherwise the built-in generator will be used. If the CLASS_GRAPH tag is set
# to TEXT the direct and indirect inheritance relations will be shown as texts /
# links.
# Possible values are: NO, YES, TEXT and GRAPH.
CLASS_GRAPH            = NO
# If the COLLABORATION_GRAPH tag is set to YES then doxygen will generate a
# graph for each documented class showing the direct and indirect implementation
# dependencies (inheritance, containment, and class references variables) of the
# class with other documented classes.
COLLABORATION_GRAPH    = YES
# If the GROUP_GRAPHS tag is set to YES then doxygen will generate a graph for
# groups, showing the direct groups dependencies.
GROUP_GRAPHS           = YES
# If the UML_LOOK tag is set to YES, doxygen will generate inheritance and
# collaboration diagrams in a style similar to the OMG's Unified Modeling
# Language.
UML_LOOK               = NO
# If the UML_LOOK tag is enabled, the fields and methods are shown inside the
# class node. If there are many fields or methods and many nodes the graph may
# become too big to be useful. The UML_LIMIT_NUM_FIELDS threshold limits the
# number of items for each type to make the size more manageable. Set this to 0
# for no limit. Note that the threshold may be exceeded by 50% before the limit
# is enforced. So when you set the threshold to 10, up to 15 fields may appear,
# but if the number exceeds 15, the total amount of fields shown is limited to
# 10.
# Minimum value: 0, maximum value: 100, default value: 10.
# This tag requires that the tag UML_LOOK is set to YES.
UML_LIMIT_NUM_FIELDS   = 10
# If the DOT_UML_DETAILS tag is set to NO, doxygen will show attributes and
# methods without types and arguments in the UML graphs. If the DOT_UML_DETAILS
# tag is set to YES, doxygen will add type and arguments for attributes and
# methods in the UML graphs. If the DOT_UML_DETAILS tag is set to NONE, doxygen
# will not generate fields with class member information in the UML graphs. The
# class diagrams will look similar to the default class diagrams but using UML
# notation for the relationships.
# Possible values are: NO, YES and NONE.
DOT_UML_DETAILS        = NO
# The DOT_WRAP_THRESHOLD tag can be used to set the maximum number of characters
# to display on a single line. If the actual line length exceeds this threshold
# significantly it will wrapped across multiple lines. Some heuristics are apply
# to avoid ugly line breaks.
# Minimum value: 0, maximum value: 1000, default value: 17.
DOT_WRAP_THRESHOLD     = 17
# If the TEMPLATE_RELATIONS tag is set to YES then the inheritance and
# collaboration graphs will show the relations between templates and their
# instances.
TEMPLATE_RELATIONS     = NO
# If the INCLUDE_GRAPH, ENABLE_PREPROCESSING and SEARCH_INCLUDES tags are set to
# YES then doxygen will generate a graph for each documented file showing the
# direct and indirect include dependencies of the file with other documented
# files.
INCLUDE_GRAPH          = YES
# If the INCLUDED_BY_GRAPH, ENABLE_PREPROCESSING and SEARCH_INCLUDES tags are
# set to YES then doxygen will generate a graph for each documented file showing
# the direct and indirect include dependencies of the file with other documented
# files.
INCLUDED_BY_GRAPH      = YES
# If the CALL_GRAPH tag is set to YES then doxygen will generate a call
# dependency graph for every global function or class method.
# Note that enabling this option will significantly increase the time of a run.
# So in most cases it will be better to enable call graphs for selected
# functions only using the \callgraph command. Disabling a call graph can be
# accomplished by means of the command \hidecallgraph.
CALL_GRAPH             = YES
# If the CALLER_GRAPH tag is set to YES then doxygen will generate a caller
# So in most cases it will be better to enable caller graphs for selected
# functions only using the \callergraph command. Disabling a caller graph can be
# accomplished by means of the command \hidecallergraph.
CALLER_GRAPH           = YES
# If the GRAPHICAL_HIERARCHY tag is set to YES then doxygen will graphical
# hierarchy of all classes instead of a textual one.
GRAPHICAL_HIERARCHY    = YES
# If the DIRECTORY_GRAPH tag is set to YES then doxygen will show the
# dependencies a directory has on other directories in a graphical way. The
# dependency relations are determined by the #include relations between the
# files in the directories.
DIRECTORY_GRAPH        = YES
# The DIR_GRAPH_MAX_DEPTH tag can be used to limit the maximum number of levels
# of child directories generated in directory dependency graphs by dot.
# Minimum value: 1, maximum value: 25, default value: 1.
# This tag requires that the tag DIRECTORY_GRAPH is set to YES.
DIR_GRAPH_MAX_DEPTH    = 25
# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
# generated by dot. For an explanation of the image formats see the section
# output formats in the documentation of the dot tool (Graphviz (see:
# http://www.graphviz.org/)).
# Note: If you choose svg you need to set HTML_FILE_EXTENSION to xhtml in order
# to make the SVG files visible in IE 9+ (other browsers do not have this
# requirement).
# Possible values are: png, jpg, gif, svg, png:gd, png:gd:gd, png:cairo,
# png:cairo:gd, png:cairo:cairo, png:cairo:gdiplus, png:gdiplus and
# png:gdiplus:gdiplus.
DOT_IMAGE_FORMAT       = png
# If DOT_IMAGE_FORMAT is set to svg, then this option can be set to YES to
# enable generation of interactive SVG images that allow zooming and panning.
# Note that this requires a modern browser other than Internet Explorer. Tested
# and working are Firefox, Chrome, Safari, and Opera.
# Note: For IE 9+ you need to set HTML_FILE_EXTENSION to xhtml in order to make
# the SVG files visible. Older versions of IE do not have SVG support.
INTERACTIVE_SVG        = NO
# The DOT_PATH tag can be used to specify the path where the dot tool can be
# found. If left blank, it is assumed the dot tool can be found in the path.
DOT_PATH               =
# The DOTFILE_DIRS tag can be used to specify one or more directories that
# contain dot files that are included in the documentation (see the \dotfile
# command).
DOTFILE_DIRS           =
# The MSCFILE_DIRS tag can be used to specify one or more directories that
# contain msc files that are included in the documentation (see the \mscfile
# command).
MSCFILE_DIRS           =
# The DIAFILE_DIRS tag can be used to specify one or more directories that
# contain dia files that are included in the documentation (see the \diafile
# command).
DIAFILE_DIRS           =
# When using plantuml, the PLANTUML_JAR_PATH tag should be used to specify the
# path where java can find the plantuml.jar file or to the filename of jar file
# to be used. If left blank, it is assumed PlantUML is not used or called during
# a preprocessing step. Doxygen will generate a warning when it encounters a
# \startuml command in this case and will not generate output for the diagram.
PLANTUML_JAR_PATH      =
# When using plantuml, the PLANTUML_CFG_FILE tag can be used to specify a
# configuration file for plantuml.
PLANTUML_CFG_FILE      =
# When using plantuml, the specified paths are searched for files specified by
# the !include statement in a plantuml block.
PLANTUML_INCLUDE_PATH  = .
# The DOT_GRAPH_MAX_NODES tag can be used to set the maximum number of nodes
# that will be shown in the graph. If the number of nodes in a graph becomes
# larger than this value, doxygen will truncate the graph, which is visualized
# by representing a node as a red box. Note that doxygen if the number of direct
# children of the root node in a graph is already larger than
# DOT_GRAPH_MAX_NODES then the graph will not be shown at all. Also note that
# the size of a graph can be further restricted by MAX_DOT_GRAPH_DEPTH.
# Minimum value: 0, maximum value: 10000, default value: 50.
DOT_GRAPH_MAX_NODES    = 50
# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the graphs
# generated by dot. A depth value of 3 means that only nodes reachable from the
# root by following a path via at most 3 edges will be shown. Nodes that lay
# further from the root node will be omitted. Note that setting this option to 1
# or 2 may greatly reduce the computation time needed for large code bases. Also
# note that the size of a graph can be further restricted by
# DOT_GRAPH_MAX_NODES. Using a depth of 0 means no depth restriction.
# Minimum value: 0, maximum value: 1000, default value: 0.
MAX_DOT_GRAPH_DEPTH    = 0
# Set the DOT_TRANSPARENT tag to YES to generate images with a transparent
# background. This is disabled by default, because dot on Windows does not seem
# to support this out of the box.
# Warning: Depending on the platform used, enabling this option may lead to
# badly anti-aliased labels on the edges of a graph (i.e. they become hard to
# read).
DOT_TRANSPARENT        = NO
# Set the DOT_MULTI_TARGETS tag to YES to allow dot to generate multiple output
# files in one run (i.e. multiple -o and -T options on the command line). This
# makes dot run faster, but since only newer versions of dot (>1.8.10) support
# this, this feature is disabled by default.
DOT_MULTI_TARGETS      = NO
# If the GENERATE_LEGEND tag is set to YES doxygen will generate a legend page
# explaining the meaning of the various boxes and arrows in the dot generated
# graphs.
# Note: This tag requires that UML_LOOK isn't set, i.e. the doxygen internal
# graphical representation for inheritance and collaboration diagrams is used.
GENERATE_LEGEND        = YES
# If the DOT_CLEANUP tag is set to YES, doxygen will remove the intermediate
# files that are used to generate the various graphs.
# Note: This setting is not only used for dot files but also for msc temporary
# files.
DOT_CLEANUP            = YES
