# Automatically generated file. DO NOT EDIT.
# Beken IoT Development Framework (BEKEN-ARMINO) Project Configuration
# SOC_CONFIG
# CONFIG_SOC_BK7231N is not set
# CONFIG_SOC_BK7236 is not set
# CONFIG_SOC_BK7234 is not set
# CONFIG_SOC_BK7236_CP1 is not set
# CONFIG_SOC_BK723L is not set
# CONFIG_SOC_BK7239 is not set
# CONFIG_SOC_BK7239_CP1 is not set
# CONFIG_SOC_BK7286 is not set
# CONFIG_SOC_BK7286_CP1 is not set
CONFIG_SOC_BK7258=y
# CONFIG_SOC_BK7258_CP1 is not set
# CONFIG_SOC_BK7258_CP2 is not set
# CONFIG_SOC_BK7256 is not set
# CONFIG_SOC_BK7256_CP1 is not set
# CONFIG_SOC_BK7235 is not set
# CONFIG_SOC_BK7235_CP1 is not set
# CONFIG_SOC_BK7235M is not set
# CONFIG_SYS_CPU0 is not set
CONFIG_SYS_CPU1=y
# CONFIG_SYS_CPU2 is not set
CONFIG_CPU_CNT=3
CONFIG_SOC_STR="bk7258_cp1"
CONFIG_SOC_ARCH="cm33"
# CONFIG_SOC_BK7256XX is not set
CONFIG_SOC_BK7236XX=y
# CONFIG_SOC_SMP is not set
# CONFIG_SOC_BK7236_SMP is not set
# CONFIG_SOC_BK7236_SMP_TEMP is not set
# CONFIG_SOC_BK7239XX is not set
# CONFIG_SOC_BK7239_SMP is not set
# CONFIG_SOC_BK7239_SMP_TEMP is not set
# CONFIG_SOC_BK7286XX is not set
# CONFIG_SOC_BK7286_FPGA is not set
# CONFIG_SOC_BK7286_SMP is not set
# CONFIG_SOC_BK7286_SMP_TEMP is not set
# end of SOC_CONFIG
# ARMINO Configuration
# Common Configuration
# Compile/Build
CONFIG_TOOLCHAIN_PATH="../../toolchain/gcc-arm-none-eabi-10.3-2021.10/bin"
CONFIG_TOOLCHAIN_PREFIX="arm-none-eabi-"
CONFIG_OBJDUMP=y
# end of Compile/Build
# Debug
# CONFIG_ASSERT_IGNORE is not set
# CONFIG_ASSERT_HALT is not set
CONFIG_ASSERT_REBOOT=y
# CONFIG_JTAG is not set
# end of Debug
# end of Common Configuration
# Features Configuration
CONFIG_NO_HOSTED=y
# CONFIG_SEMI_HOSTED is not set
# CONFIG_FULLY_HOSTED is not set
# CONFIG_WIFI_SENSOR is not set
# CONFIG_BLUETOOTH is not set
# end of Features Configuration
# Modules Configuration
# Components Configuration
# Adc_key
# CONFIG_ADC_KEY is not set
# end of Adc_key
# Ali_mqtt
# end of Ali_mqtt
# App
# CONFIG_DEMO_TEST is not set
# CONFIG_FTPD_UPGRADE is not set
# CONFIG_OTA_TFTP is not set
# CONFIG_SECURITY_OTA is not set
# end of App
# At
# CONFIG_AT_CMD is not set
# end of At
# At_server
# CONFIG_AT is not set
# end of At_server
# Modules::Bk_airkiss
# end of Modules::Bk_airkiss
# Bk_ate
# CONFIG_ATE is not set
# Modify Ate Config
# CONFIG_ATE_TEST is not set
CONFIG_ATE_CPU2_ADDRESS=0x2809FFF7
CONFIG_ATE_CPU2_VALUE=0x4332
# end of Modify Ate Config
# end of Bk_ate
# Demos::Bluetooth
# Bk_cli
# Modify Cli Config
CONFIG_CLI=y
# CONFIG_CLI_USER_CONFIG is not set
# CONFIG_CLI_CODE_SIZE_OPTIMIZE_ENABLE is not set
# CONFIG_BKREG is not set
CONFIG_MAX_COMMANDS=128
# CONFIG_TCP_SERVER_TEST is not set
# CONFIG_AIRKISS_TEST is not set
# CONFIG_WIFI_RAW_TX_TEST is not set
# CONFIG_WIFI_CLI_RAW_LINK_ENABLE is not set
# CONFIG_CONNECT_THROUGH_PSK_OR_SAE_PASSWORD is not set
# CONFIG_VFS_TEST is not set
# CONFIG_I2C1_TEST is not set
# CONFIG_I2C2_TEST is not set
# CONFIG_UART_TEST is not set
# CONFIG_SPI_TEST is not set
# CONFIG_PERI_TEST is not set
# CONFIG_RF_OTA_TEST is not set
CONFIG_SHELL_ASYNCLOG=y
CONFIG_DYM_LOG_MEM_MAX=0x2000
# CONFIG_UART_RING_BUFF is not set
# CONFIG_TOUCH_TEST is not set
# CONFIG_SBC_TEST is not set
CONFIG_AUDIO=y
# CONFIG_PSRAM_TEST is not set
# CONFIG_DVP_CAMERA_TEST is not set
CONFIG_INTERRUPT_TEST=y
CONFIG_AON_PMU_TEST=y
CONFIG_SDMADC_TEST=y
# CONFIG_PM_TEST is not set
# CONFIG_VIDEO_TRANSFER_DEMO is not set
# CONFIG_PUF_TEST is not set
# CONFIG_EFUSE is not set
CONFIG_ICU=y
# CONFIG_SECURITYIP is not set
# CONFIG_KEYVALUE is not set
# CONFIG_IDLE_UART_OUT_TEST is not set
# CONFIG_COMPONENTS_WPA2_ENTERPRISE is not set
# CONFIG_COMPONENTS_WPA_TWT_TEST is not set
# CONFIG_COMPONENTS_WFA_CA is not set
# CONFIG_ENABLE_WIFI_DEFAULT_CONNECT is not set
# CONFIG_RTC_TIMER_PRECISION_TEST is not set
# CONFIG_RTC_TIMER_PRECISION_TEST_BY_GPIO is not set
# CONFIG_RWNX_PROTO_DEBUG is not set
# CONFIG_AUDIO_TEST is not set
# end of Modify Cli Config
# end of Bk_cli
# modules::uart_debug
# end of modules::uart_debug
# Httpc
# CONFIG_HTTPC is not set
# end of Httpc
# Https
# CONFIG_HTTPS is not set
# end of Https
# Bk_libs
# CONFIG_MCU_PS is not set
# CONFIG_DEEP_PS is not set
CONFIG_TICK_CALI=y
# CONFIG_STA_PS is not set
# end of Bk_libs
# Mcu_4g_modem
# CONFIG_BK_MODEM is not set
# end of Mcu_4g_modem
# Bk_netif
# end of Bk_netif
# Bk_Phy
# CONFIG_PHY_LOG_ENABLE is not set
# end of Bk_Phy
# PM
# CONFIG_PM_ENABLE is not set
# CONFIG_PM_SUPER_DEEP_SLEEP is not set
# end of PM
# Bk_rtos
CONFIG_CUSTOMIZE_HEAP_SIZE=163840
# CONFIG_SIZE_OPTIMIZE is not set
# Modify FreeRTOS Config
CONFIG_FREERTOS=y
# CONFIG_FREERTOS_USE_QUEUE_SETS is not set
# CONFIG_MEM_MGMT is not set
# CONFIG_FREERTOS_V9 is not set
CONFIG_FREERTOS_V10=y
# CONFIG_FREERTOS_SMP is not set
# CONFIG_FREERTOS_POSIX is not set
# CONFIG_FREERTOS_TRACE is not set
# CONFIG_TASK_STACK_IN_PSRAM is not set
# CONFIG_QUEUE_IN_PSRAM is not set
CONFIG_FREERTOS_USE_TICKLESS_IDLE=0
CONFIG_FREERTOS_USE_RECURSIVE_MUTEXES=y
CONFIG_FREERTOS_TICK_RATE_HZ=500
# end of Modify FreeRTOS Config
# Modify LITEOS_M Config
# CONFIG_LITEOS_M is not set
# CONFIG_LITEOS_M_V3 is not set
# end of Modify LITEOS_M Config
# Modify NON_OS Config
# CONFIG_NON_OS is not set
# end of Modify NON_OS Config
# Modify Memory Debug Config
# CONFIG_MALLOC_STATIS is not set
CONFIG_MEM_DEBUG=y
CONFIG_MEM_DEBUG_FUNC_NAME=y
CONFIG_MEM_DEBUG_FUNC_NAME_LEN=16
CONFIG_MEM_DEBUG_TASK_NAME=y
CONFIG_MEM_DEBUG_TASK_NAME_LEN=8
# end of Modify Memory Debug Config
# end of Bk_rtos
# Bk_startup
CONFIG_APP_MAIN_TASK_PRIO=4
CONFIG_APP_MAIN_TASK_STACK_SIZE=4096
# CONFIG_MATTER_START is not set
# end of Bk_startup
# BK_system
# Mac Config
# CONFIG_BASE_MAC_FROM_EFUSE is not set
# CONFIG_BASE_MAC_FROM_RF_OTP_FLASH is not set
CONFIG_NEW_MAC_POLICY=y
# CONFIG_BASE_MAC_FROM_OTP1 is not set
CONFIG_RANDOM_MAC_ADDR=y
CONFIG_BK_MAC_ADDR_CHECK=y
CONFIG_CUS_MAC_MASK=0
# end of Mac Config
# Print Config
# CONFIG_SYS_PRINT_DEV_UART is not set
CONFIG_SYS_PRINT_DEV_MAILBOX=y
# CONFIG_SYS_PRINT_DEV_NULL is not set
CONFIG_FWD_CMD_TO_CPUx=y
# CONFIG_SMP_SYNC_PRINTF is not set
# end of Print Config
# end of BK_system
# Bk_usb
CONFIG_USB=y
CONFIG_USB_VBAT_CONTROL_GPIO_ID=5
# Modify USB Mailbox
# CONFIG_USB_MAILBOX is not set
# CONFIG_USB_MAILBOX_MASTER is not set
# CONFIG_USB_MAILBOX_SLAVE is not set
# CONFIG_USB_MAILBOX_MASTER_CPU1_TO_CPU2 is not set
# CONFIG_USB_MAILBOX_SLAVE_CPU2_TO_CPU1 is not set
# CONFIG_USB_MAILBOX_MASTER_CPU1_TO_CPU0 is not set
# CONFIG_USB_MAILBOX_SLAVE_CPU0_TO_CPU1 is not set
# end of Modify USB Mailbox
# Modify Usb Config
# CONFIG_MUSB_FDRC is not set
CONFIG_MUSB_MHDRC=y
# CONFIG_SYNOPSYS_DWC2_USB_IP is not set
# CONFIG_MENTOR_USB is not set
CONFIG_CHERRY_USB=y
CONFIG_USB_HOST=y
# CONFIG_USB_DEVICE is not set
# CONFIG_USB1_PORT is not set
CONFIG_USB2_PORT=y
CONFIG_TASK_USB_PRIO=5
# CONFIG_USB_DMA_ENABLE is not set
CONFIG_USB_HUB=y
# CONFIG_USB_MSD is not set
# CONFIG_USB_UPC is not set
# CONFIG_USB_HID is not set
CONFIG_USB_CDC=y
CONFIG_USB_UVC=y
CONFIG_USB_UAC=y
# Modify Usb Uac Config
CONFIG_USB_UAC_MIC=y
CONFIG_USB_UAC_SPEAKER=y
# end of Modify Usb Uac Config
# CONFIG_USB_CHARGE is not set
# CONFIG_USBH_SERIAL_CH340 is not set
# end of Modify Usb Config
# Modify USB Demo Config
CONFIG_UVC_UAC_DEMO=y
CONFIG_UVC_UAC_DEMO_DEBUG=y
# end of Modify USB Demo Config
# Modify Dsp Config
# CONFIG_DSP is not set
CONFIG_DSP_SRC_ADD=0x130000
# end of Modify Dsp Config
# CONFIG_STANDARD_DUALSTREAM is not set
CONFIG_UVC_DUAL_DEVICE=1
CONFIG_USB_CDC_MODEM=y
# end of Bk_usb
# Bk_vfs
CONFIG_VFS=y
CONFIG_VFS_MAX_FD_NUM=20
# end of Bk_vfs
# Bk_websocket
# end of Bk_websocket
# Bk_Wifi
# CONFIG_WIFI_ENABLE is not set
CONFIG_WIFI_TX_RAW_ENABLE=y
CONFIG_RWNX_MEM_STATS=y
# CONFIG_WIFI_PS_DISABLE is not set
CONFIG_WIFI_AUTO_COUNTRY_CODE=y
CONFIG_WIFI_SCAN_COUNTRY_CODE=y
CONFIG_MSDU_RESV_HEAD_LENGTH=96
CONFIG_MSDU_RESV_TAIL_LENGTH=16
CONFIG_TASK_RECONNECT_PRIO=4
# CONFIG_AP_MONITOR_COEXIST is not set
# CONFIG_WIFI_FAST_CONNECT is not set
# CONFIG_WFA_CERT is not set
# CONFIG_LESS_MEMERY_IN_RWNX is not set
# CONFIG_AP_STATYPE_LIMIT is not set
# CONFIG_TCP_PROTECT_EN is not set
# CONFIG_AP_TX_TIM is not set
# CONFIG_RECEIVE_BCMC_IN_DTIM10 is not set
# CONFIG_NOT_CHECK_SSID_CHANGE is not set
CONFIG_NET_PARAM=y
# CONFIG_DEAUTH_BEFORE_CONNECT is not set
# CONFIG_IMPROVE_HE_TB_ENABLE is not set
# CONFIG_CLOSE_COEXIST_CSA is not set
CONFIG_SCAN_SPEED_LEVEL=3
# CONFIG_NETWORK_FOUND_EVENT_ENABLE is not set
# CONFIG_POWER_TABLE is not set
CONFIG_PM_V2=y
CONFIG_WIFI_KMSG_TASK_PRIO=3
CONFIG_WIFI_KMSG_TASK_STACK_SIZE=4096
CONFIG_WIFI_CORE_TASK_PRIO=2
CONFIG_WIFI_CORE_TASK_STACK_SIZE=2048
CONFIG_RWNX_QOS_MSDU=y
# CONFIG_WPA_TWT_TEST is not set
CONFIG_RWNX_TD=y
CONFIG_BK_MEM_DYNA_APPLY_EN=y
# CONFIG_P2P is not set
# CONFIG_P2P_GO is not set
# CONFIG_TX_BUFING is not set
# CONFIG_AP_PS is not set
# CONFIG_UAPSD is not set
# CONFIG_USE_P2P_PS is not set
# CONFIG_AP_PROBEREQ_CB is not set
CONFIG_MAC_SFRAME_SOFTWARE_RETRY=y
# CONFIG_WIFI_FTM is not set
CONFIG_WIFI_MAC_SUPPORT_STAS_MAX_NUM=2
CONFIG_MAC_SHORT_RETRY=240
CONFIG_MAC_LONG_RETRY=240
# end of Bk_Wifi
# Cmsis
CONFIG_CMSIS=y
# Modify Cmsis Config
# CONFIG_DEFAULT_CMSIS_START is not set
CONFIG_DCACHE=y
CONFIG_ICACHE=y
# end of Modify Cmsis Config
# end of Cmsis
# decompress
# CONFIG_LZMA1900 is not set
# CONFIG_LZMA2301 is not set
# end of decompress
# Coredump
CONFIG_CM_BACKTRACE=y
# end of Coredump
# Demos::Os
# CONFIG_OS_THREAD_DEMO is not set
# CONFIG_OS_QUEUE_DEMO is not set
# CONFIG_OS_SEM_DEMO is not set
# CONFIG_OS_MUTEX_DEMO is not set
# CONFIG_OS_TIMER_DEMO is not set
# CONFIG_OS_SMP_BLINKY_DEMO is not set
# CONFIG_OS_SMP_AFFINITY_DEMO is not set
# CONFIG_OS_SMP_DEEP_LV_DEMO is not set
# end of Demos::Os
# Demos::Peripheral::Touch
# end of Demos::Peripheral::Touch
# Demos::Net::Iperf
# end of Demos::Net::Iperf
# Easy_flash
# CONFIG_EASY_FLASH is not set
# end of Easy_flash
# GCov
# CONFIG_GCOV is not set
# end of GCov
# flashdb
# CONFIG_FLASHDB is not set
# end of flashdb
# Http
# CONFIG_HTTP_OTA_WITH_BLE is not set
# CONFIG_LITE_LOG_ENABLED is not set
# end of Http
# RTP
# CONFIG_RTP is not set
# end of RTP
# json
# CONFIG_CJSON_USE is not set
# end of json
# CONFIG_BUTTON is not set
# Key_Handle
# CONFIG_COMPONENTS_TX_BUFING is not set
# end of Key_Handle
# Littlefs
CONFIG_LITTLEFS=y
# end of Littlefs
# Lwip_intf_v2_1
# CONFIG_IPV6 is not set
# CONFIG_WIFI_FAST_DHCP is not set
# CONFIG_STA_USE_STATIC_IP is not set
CONFIG_MQTT_ACK_NOW=y
# CONFIG_LWIP_TCP_SACK_OUT is not set
# CONFIG_IP_FORWARD is not set
# CONFIG_IP_FORWARD_ALLOW_TX_ON_RX_NETIF is not set
# CONFIG_IP_NAPT is not set
# CONFIG_WIFI_REAPETER is not set
# CONFIG_BRIDGE is not set
# CONFIG_LWIP_PPP_SUPPORT is not set
# Memory Config
CONFIG_LWIP_UDP_RECVMBOX_SIZE=24
CONFIG_LWIP_MEM_SIZE=51200
CONFIG_LWIP_MEM_MAX_RX_SIZE=38400
CONFIG_LWIP_MEM_MAX_TX_SIZE=42666
CONFIG_LWIP_TCP_MSS=1460
CONFIG_LWIP_TCP_SND_BUF=29200
CONFIG_LWIP_TCP_WND=29200
CONFIG_LWIP_MEMP_NUM_NETBUF=32
CONFIG_LWIP_PBUF_POOL_SIZE=10
CONFIG_LWIP_TCP_SND_QUEUELEN=40
CONFIG_LWIP_MEMP_NUM_TCP_SEG=80
# end of Memory Config
# end of Lwip_intf_v2_1
# Mbedtls
# CONFIG_MBEDTLS is not set
# end of Mbedtls
# MICROPYTHON CONFIG
# CONFIG_MICROPYTHON is not set
# end of MICROPYTHON CONFIG
# Openssl
# CONFIG_OPENSSL is not set
CONFIG_OPENSSL_ERROR_STACK=y
# CONFIG_OPENSSL_DEBUG is not set
# CONFIG_OPENSSL_ASSERT_DO_NOTHING is not set
CONFIG_OPENSSL_ASSERT_EXIT=y
# end of Openssl
# Ota
# CONFIG_HTTP_AB_PARTITION is not set
# CONFIG_OTA_UPDATE_DEFAULT_PARTITION is not set
# CONFIG_OTA_UPDATE_B_PARTITION is not set
# CONFIG_OTA_EVADE_METHOD is not set
# CONFIG_OTA_HTTPS is not set
# CONFIG_OTA_HASH_FUNCTION is not set
# CONFIG_OTA_DEBUG_LOG_OPEN is not set
# CONFIG_OTA_POSITION_INDEPENDENT_AB is not set
CONFIG_OTA_TEST=y
# CONFIG_VALIDATE_BEFORE_REBOOT is not set
# CONFIG_OTA_UPDATE_PUBKEY is not set
# CONFIG_OTA_CONFIRM_UPDATE is not set
# end of Ota
# Part_table
CONFIG_FLASH_PARTITION_USER=y
# end of Part_table
# PSA Mbedtls
# CONFIG_PSA_MBEDTLS is not set
# end of PSA Mbedtls
# Saradc_intf
# CONFIG_SARADC_CALI is not set
# end of Saradc_intf
# Security
# CONFIG_SECURITY is not set
# end of Security
# sensor_detect
# CONFIG_TEMP_DETECT is not set
# CONFIG_SDMADC_TEMP is not set
# CONFIG_VOLT_DETECT is not set
# end of sensor_detect
# TFM Mbedtls
# CONFIG_MBEDTLS_ACCELERATOR is not set
# CONFIG_TE200_TEST is not set
# end of TFM Mbedtls
# User_driver
CONFIG_FLASH_SIZE_4M=y
# end of User_driver
# utf8
CONFIG_USE_CONV_UTF8=y
# end of utf8
# Webclient
# CONFIG_WEBCLIENT is not set
# end of Webclient
# modules::wolfssl
# CONFIG_WOLFSSL_BEKEN is not set
# end of modules::wolfssl
# modules::wpa_supplicant-2.10
# CONFIG_WLAN_FAST_CONNECT_WITHOUT_SCAN is not set
# CONFIG_WLAN_FAST_CONNECT_DEAUTH_FIRST is not set
# CONFIG_WLAN_FAST_CONNECT_WPA3 is not set
CONFIG_FAST_CONNECT_INFO_ENC_METHOD=1
CONFIG_WPA_AUTH_TIMEOUT=2
# CONFIG_WIFI_ROAMING is not set
# CONFIG_BK_SUPPLICANT_OPTIMIZE_CONNECTION is not set
# end of modules::wpa_supplicant-2.10
# draw blend
# bk peripheral
# RGB LCD
CONFIG_LCD_ILI9488=y
CONFIG_LCD_GC9503_BOE=y
CONFIG_LCD_T50P181CQ=y
CONFIG_LCD_TUYA_COMMON_RGB=y
# CONFIG_LCD_GC9503V is not set
CONFIG_LCD_H050IWV=y
CONFIG_LCD_HX8282=y
CONFIG_LCD_MD0430R=y
CONFIG_LCD_MD0700R=y
# CONFIG_LCD_NT35512 is not set
# CONFIG_LCD_NT35510 is not set
CONFIG_LCD_ST7282=y
CONFIG_LCD_ST7701S_LY=y
CONFIG_LCD_ST7701S=y
CONFIG_LCD_ST7701SN=y
CONFIG_LCD_AML01=y
# end of RGB LCD
# MCU LCD
CONFIG_LCD_NT35510_MCU=y
CONFIG_LCD_ST7796S=y
# CONFIG_LCD_ST7789V is not set
# end of MCU LCD
# QSPI LCD
# end of QSPI LCD
# SPI LCD
# CONFIG_LCD_SPI_ST7796U is not set
# end of SPI LCD
# DVP Camera
# TP
CONFIG_TP_GT911=y
CONFIG_TP_GT1151=y
# CONFIG_TP_FT6336 is not set
# CONFIG_TP_HY4633 is not set
# end of TP
# end of bk peripheral
# CLI TEST
# CONFIG_IDF_TEST is not set
# end of CLI TEST
# Display Service
CONFIG_MEDIA_DISPLAY_SERVICE=y
# CONFIG_LCD_SPI_DISPLAY is not set
# end of Display Service
# Freetype
CONFIG_FREETYPE=y
# end of Freetype
# Lvgl
CONFIG_LVGL=y
CONFIG_LVGL_V8=y
# CONFIG_LVGL_V9 is not set
CONFIG_LV_COLOR_DEPTH=16
# CONFIG_LVGL_SRAM_MAPPING is not set
# CONFIG_LV_COLOR_SCREEN_TRANSP is not set
# CONFIG_LV_FONT_MONTSERRAT_8 is not set
# CONFIG_LV_FONT_MONTSERRAT_16 is not set
# CONFIG_LV_FONT_MONTSERRAT_12 is not set
# CONFIG_LV_FONT_MONTSERRAT_18 is not set
# CONFIG_LV_FONT_MONTSERRAT_20 is not set
# CONFIG_LV_FONT_MONTSERRAT_22 is not set
CONFIG_LV_FONT_MONTSERRAT_24=y
# CONFIG_LV_FONT_MONTSERRAT_26 is not set
# CONFIG_LV_FONT_MONTSERRAT_28 is not set
# CONFIG_LV_FONT_MONTSERRAT_30 is not set
# CONFIG_LV_FONT_MONTSERRAT_32 is not set
# CONFIG_LV_FONT_MONTSERRAT_34 is not set
# CONFIG_LV_FONT_MONTSERRAT_36 is not set
# CONFIG_LV_FONT_MONTSERRAT_38 is not set
# CONFIG_LV_FONT_MONTSERRAT_40 is not set
# CONFIG_LV_FONT_MONTSERRAT_42 is not set
# CONFIG_LV_FONT_MONTSERRAT_44 is not set
# CONFIG_LV_FONT_MONTSERRAT_46 is not set
# CONFIG_LV_FONT_MONTSERRAT_48 is not set
# CONFIG_LV_USE_PERF_MONITOR is not set
# CONFIG_LVGL_USE_PSRAM is not set
CONFIG_LVGL_USE_DIRECT_MODE=y
# CONFIG_LV_ATTRIBUTE_FAST_MEM is not set
CONFIG_LVGL_TASK_PRIORITY=5
# CONFIG_LVGL_TASK_SLEEP_TIME_CUSTOMIZE is not set
# CONFIG_LV_COLOR_16_SWAP is not set
# CONFIG_LV_ATTRIBUTE_FAST_MEM_L2 is not set
# CONFIG_LV_CODE_LOAD_PSRAM is not set
# end of Lvgl
# Media
CONFIG_MEDIA=y
CONFIG_WIFI_TRANSFER=y
# CONFIG_LCD_FLASH_JPEG_DISPLAY is not set
CONFIG_LCD_DMA2D_BLEND=y
# CONFIG_BLEND_USE_GUI is not set
# CONFIG_BLEND_GUI_OUTPUT_888 is not set
CONFIG_LCD_FONT_BLEND=y
# CONFIG_FACE_DETECTION is not set
CONFIG_IMAGE_STORAGE=y
# CONFIG_EXTENTED_PSRAM_LAYOUT is not set
CONFIG_TRANSFER_TASK_STACK_SIZE=1536
CONFIG_MEDIA_MAJOR_THREAD_STACK_SIZE=3584
CONFIG_LCD_MEDIA=y
CONFIG_LCD_ROTATE=y
CONFIG_LCD_HW_PFC=y
CONFIG_LCD_HW_DECODE=y
CONFIG_LCD_SW_DECODE=y
# end of Media
# Media Unit Test
CONFIG_MEDIA_UNIT_TEST=y
# end of Media Unit Test
# Media Utils
CONFIG_MEDIA_IPC=y
CONFIG_PSRAM_MEM_SLAB_USER_SIZE=102400
CONFIG_PSRAM_MEM_SLAB_AUDIO_SIZE=102400
CONFIG_PSRAM_MEM_SLAB_ENCODE_SIZE=1433600
CONFIG_PSRAM_MEM_SLAB_DISPLAY_SIZE=5701632
# end of Media Utils
# Media
CONFIG_MEDIA_MAJOR=y
# CONFIG_MEDIA_APP is not set
# CONFIG_MEDIA_MINOR is not set
CONFIG_MEDIA_UI_TASK_STACK_SIZE=4096
CONFIG_USB_TRANSFER=y
# CONFIG_JPEG_YUV_MIX is not set
CONFIG_TRANS_APP_TASK_SIZE=1024
# CONFIG_SW_ROTATE_TO_YUYV_AND_DMA2D_TO_YUYV_NOT_RGB888 is not set
# CONFIG_LCD_AUTO_FILL_FULL is not set
CONFIG_MEDIA_SCALE=y
CONFIG_MEDIA_PIPELINE=y
# CONFIG_AUD_INTF_TEST is not set
# CONFIG_AUD_TRAS_USE_SRAM is not set
CONFIG_AUD_TRAS_USE_PSRAM=y
# CONFIG_AUD_TRAS_DAC_PA_CTRL is not set
CONFIG_AUD_RING_BUFF_SAFE_INTERVAL=4
# CONFIG_MEDIA_BT_AUDIO is not set
# CONFIG_SOFTWARE_DECODE_SRAM_MAPPING is not set
# CONFIG_DMIC_DUAL_NC_ALGRITHMS_OPEN is not set
# end of Media
# Wifi Transfer
# CONFIG_MEDIA_DROP_STRATEGY_ENABLE is not set
# end of Wifi Transfer
# Asdf
# CONFIG_ASDF_AUTO_TEST is not set
# end of Asdf
# Asdf::Audio_streams::Fatfs_stream
# end of Asdf::Audio_streams::Fatfs_stream
# Asdf::Audio_streams::Onboard_mic_stream
# end of Asdf::Audio_streams::Onboard_mic_stream
# Asdf::Audio_streams::Onboard_speaker_stream
# end of Asdf::Audio_streams::Onboard_speaker_stream
# Asdf::Audio_streams::raw_stream
# end of Asdf::Audio_streams::raw_stream
# CODEC
CONFIG_VIDEO_DTCM=y
# CONFIG_VIDEO_ITCM is not set
# CONFIG_VIDEO_DTCM_ALL is not set
# end of CODEC
# legacy_App
# end of legacy_App
# Demos::Media::Audio::Aud_intf
# Modify Aud Intf Config
# CONFIG_AUD_INTF is not set
# end of Modify Aud Intf Config
# Modify Aud Trasfer Config
# CONFIG_AUDIO_TRANSFER is not set
CONFIG_AUDIO_INTF_TASK_SIZE=1536
# end of Modify Aud Trasfer Config
# end of Demos::Media::Audio::Aud_intf
# Demos::Media::Dma2d
# CONFIG_DMA2D_TEST is not set
# end of Demos::Media::Dma2d
# Demos::Media::Doorbell
# end of Demos::Media::Doorbell
# Demos::Media::rott
# CONFIG_HW_ROTT_TEST is not set
# end of Demos::Media::rott
# Demos::Media::Video
CONFIG_JPEGDEC_SW=y
# CONFIG_JPEGDEC_LIBJPEG is not set
# CONFIG_SPIDMA is not set
# end of Demos::Media::Video
# Bk_thirdparty::Wanson
# CONFIG_WANSON_ASR is not set
# end of Bk_thirdparty::Wanson
# Bk_thirdparty::aac_decoder
# CONFIG_AAC_DECODER is not set
# end of Bk_thirdparty::aac_decoder
# Bk_thirdparty::agora-iot-sdk
# CONFIG_AGORA_IOT_SDK is not set
# end of Bk_thirdparty::agora-iot-sdk
# cs2p2p
# CONFIG_CS2_P2P_SERVER is not set
# CONFIG_CS2_P2P_CLIENT is not set
# CONFIG_CS2_P2P_TEST is not set
CONFIG_CS2_TX_BUFFER_THD=5120
# CONFIG_CS2_MALLOC_USE_PSRAM is not set
# CONFIG_CS2_DEBUG_LIB is not set
# end of cs2p2p
# Bk_thirdparty::JPEG software encoder
# CONFIG_JPEG_SW_ENCODER is not set
# end of Bk_thirdparty::JPEG software encoder
# end of Components Configuration
# Middleware Configuration
# Arch::Riscv
CONFIG_CPU_FREQ_HZ=120000000
# CONFIG_ARCH_RISCV is not set
# CONFIG_DUMP_ENABLE is not set
CONFIG_MEMDUMP_ALL=y
# CONFIG_CACHE_ENABLE is not set
# end of Arch::Riscv
# Arch::Cm33
CONFIG_ARCH_CM33=y
# Modify Arch Cm33 Config
# CONFIG_FPGA is not set
CONFIG_MPU=y
# CONFIG_ARCH_INT_STATIS is not set
CONFIG_SYSTICK_32K=y
# end of Modify Arch Cm33 Config
# end of Arch::Cm33
# Arch::Arm9
# CONFIG_ARCH_ARM9 is not set
# end of Arch::Arm9
# Compal
# CONFIG_COMMON_IO is not set
# end of Compal
# Driver
# device
CONFIG_DEVICE_MAX_NAME_LEN=32
# CONFIG_DM is not set
# end of device
# Watchdog
# CONFIG_INT_WDT is not set
CONFIG_INT_WDT_PERIOD_MS=1000
# CONFIG_TASK_WDT is not set
CONFIG_TASK_WDT_PERIOD_MS=60000
# CONFIG_NMI_WDT_EN is not set
# end of Watchdog
# AON_Watchdog
# CONFIG_AON_WDT is not set
# CONFIG_INT_AON_WDT is not set
CONFIG_INT_AON_WDT_PERIOD_MS=1000
# end of AON_Watchdog
# UART
CONFIG_UART1=y
# CONFIG_UART1_FLOW_CTRL is not set
CONFIG_UART2=y
CONFIG_UART3=y
CONFIG_UART_PRINT_PORT=1
CONFIG_UART_ATE_PRINT_PORT=0
CONFIG_UART_ATE_PORT=1
CONFIG_PRINTF_BUF_SIZE=256
# CONFIG_BACKGROUND_PRINT is not set
CONFIG_KFIFO_SIZE=128
# CONFIG_UART_STATIS is not set
CONFIG_UART_LOW_VOLTAGE_SUPPORT=y
CONFIG_UART_ERR_INTERRUPT=y
# CONFIG_UART_RX_DMA is not set
CONFIG_UART_RX_DMA_KFIFO_SIZE=512
# CONFIG_UART_PM_CB_SUPPORT is not set
# end of UART
# TRNG
# CONFIG_TRNG_SUPPORT is not set
CONFIG_TRNG_PM_CB_SUPPORT=y
# end of TRNG
# SDIO_HOST
# CONFIG_SDIO_HOST is not set
CONFIG_SDIO_HOST_DEFAULT_CLOCK_FREQ=7
CONFIG_SDIO_HOST_CLR_WRITE_INT=y
# end of SDIO_HOST
# SDCARD
# CONFIG_SDCARD is not set
CONFIG_SDCARD_DEFAULT_CLOCK_FREQ=11
# CONFIG_SDCARD_CHECK_INSERTION_EN is not set
# CONFIG_SDCARD_BUSWIDTH_4LINE is not set
# CONFIG_SDCARD_DEBUG_SUPPORT is not set
# end of SDCARD
# FATFS
CONFIG_FATFS=y
# CONFIG_FATFS_SDCARD is not set
# end of FATFS
# SDIO
# CONFIG_SDIO is not set
CONFIG_SDIO_V2P0=y
# CONFIG_SDIO_GDMA_EN is not set
# CONFIG_SDIO_PM_CB_SUPPORT is not set
# end of SDIO
# SPI
CONFIG_SPI_DMA=y
CONFIG_SPI_STATIS=y
CONFIG_SPI_SUPPORT_TX_FIFO_WR_READY=y
# CONFIG_SPI_MST_FLASH is not set
# CONFIG_SPI_MST_PSRAM is not set
# CONFIG_SPI_PM_CB_SUPPORT is not set
CONFIG_SPI=y
# CONFIG_SPI_BYTE_INTERVAL is not set
# end of SPI
# QSPI
CONFIG_QSPI=y
CONFIG_QSPI_STATIS=y
CONFIG_QSPI_FLASH_GD=y
# end of QSPI
# AON_RTC
# CONFIG_AON_RTC is not set
# CONFIG_AON_RTC_64BIT is not set
CONFIG_AON_RTC_MANY_USERS=y
# CONFIG_AON_RTC_TEST is not set
# CONFIG_AON_RTC_DEBUG is not set
# CONFIG_AON_RTC_KEEP_TIME_SUPPORT is not set
# CONFIG_RTC_ANA_WAKEUP_SUPPORT is not set
# CONFIG_AON_RTC_DYNAMIC_CLOCK_SUPPORT is not set
# end of AON_RTC
# GPIO
# CONFIG_GPIO_WAKEUP_SUPPORT is not set
CONFIG_GPIO_DYNAMIC_WAKEUP_SOURCE_MAX_CNT=4
CONFIG_CONFIG_GPIO_WAKEUP_ID=22
CONFIG_CONFIG_GPIO_WAKEUP_INT_TYPE=0
# CONFIG_GPIO_SIMULATE_UART_WRITE is not set
CONFIG_GPIO_DEFAULT_SET_SUPPORT=y
# CONFIG_GPIO_ANA_WAKEUP_SUPPORT is not set
# CONFIG_GPIO_RETENTION_SUPPORT is not set
CONFIG_GPIO_RETENTION_DISPOSABLE=y
CONFIG_USR_GPIO_CFG_EN=y
# end of GPIO
# AON_PMU
CONFIG_AON_PMU=y
# end of AON_PMU
# GENERAL_DMA
CONFIG_GENERAL_DMA=y
CONFIG_GDMA_HW_V2PX=y
# CONFIG_GDMA_HW_V1PX is not set
CONFIG_DMA_LOGIC_CHAN_CNT=8
CONFIG_DMA_LOGIC_CHAN_ID_MIN=4
# end of GENERAL_DMA
# TOUCH
# CONFIG_TOUCH is not set
# CONFIG_TOUCH_INTERNAL_SERIAL_CAP is not set
# CONFIG_TOUCH_PM_SUPPORT is not set
# end of TOUCH
# SBC
# CONFIG_SBC is not set
# end of SBC
# JPEG_ENC
CONFIG_JPEGENC_HW=y
# end of JPEG_ENC
# JPEG_DEC
CONFIG_JPEGDEC_HW=y
CONFIG_JPEGDEC_HW_SUPPORT_DRI=y
# CONFIG_JPEGDEC_HW_SUPPORT_FFD9_CHECK is not set
# end of JPEG_DEC
# PSRAM
CONFIG_PSRAM=y
CONFIG_PSRAM_AS_SYS_MEMORY=y
# CONFIG_USE_PSRAM_HEAP_AT_SRAM_OOM is not set
CONFIG_PSRAM_HEAP_BASE=0x60a00000
CONFIG_PSRAM_HEAP_CPU0_BASE_ADDER=0x60700000
CONFIG_PSRAM_HEAP_SIZE=0x600000
CONFIG_PSRAM_WRITE_THROUGH=y
# CONFIG_PSRAM_CALIBRATE is not set
# end of PSRAM
# CALENDAR
# CONFIG_CALENDAR is not set
# end of CALENDAR
# SYS_CTRL
# CONFIG_SYS_REDUCE_NORMAL_POWER is not set
# CONFIG_XTAL_FREQ_40M is not set
CONFIG_XTAL_FREQ_26M=y
CONFIG_XTAL_FREQ=26000000
CONFIG_DCO_FREQ=120000000
CONFIG_SYSTEM_CTRL=y
CONFIG_HAL_DEBUG_SYS=y
# CONFIG_POWER_CLOCK_RF is not set
CONFIG_SYSTEM_CLOCK=y
# CONFIG_ROSC_TEST_MODE is not set
CONFIG_DEFAULT_LPO_SRC=2
# CONFIG_CPU0_SUB_POWER_DOMAIN_ENA is not set
# CONFIG_LDO_SELF_LOW_POWER_MODE_ENA is not set
# end of SYS_CTRL
# PHY
# CONFIG_PTA is not set
CONFIG_MAC_PHY_BYPASS=y
# end of PHY
# I2S
# CONFIG_I2S is not set
# end of I2S
# I2C
CONFIG_I2C=y
CONFIG_I2C_SUPPORT_ID_BITS=2
# CONFIG_FM_I2C is not set
CONFIG_SIM_I2C=y
# CONFIG_I2C_PM_CB_SUPPORT is not set
CONFIG_SIM_I2C_HW_BOARD_V3=y
# end of I2C
# AUDIO
CONFIG_AUDIO_ADC=y
# CONFIG_AUDIO_DMIC is not set
# CONFIG_AUDIO_DTMF is not set
CONFIG_AUDIO_DAC=y
CONFIG_AUDIO_RING_BUFF=y
# end of AUDIO
# PWM
# CONFIG_PWM is not set
# CONFIG_PWM_V0P0 is not set
CONFIG_PWM_V1PX=y
# CONFIG_PWM_HAS_TWO_INT is not set
# CONFIG_PWM_PM_CB_SUPPORT is not set
# CONFIG_PWM_PHASE_SHIFT is not set
# end of PWM
# ICU
# CONFIG_ICU_GPIO is not set
# end of ICU
# Interrupt
# CONFIG_ISR_REG_DISABLE is not set
# end of Interrupt
# TIMER
CONFIG_TIMER=y
CONFIG_TIMER_COUNTER=y
CONFIG_TIMER_SUPPORT_ID_BITS=56
CONFIG_TIMER_US=y
# CONFIG_TIMER_PM_CB_SUPPORT is not set
# end of TIMER
# SARADC
# CONFIG_SARADC is not set
# CONFIG_SARADC_NEED_FLUSH is not set
CONFIG_SARADC_RANGE_DIVIDE=y
CONFIG_ADC_BUF_SIZE=32
# end of SARADC
# FLASH
CONFIG_FLASH=y
# CONFIG_FLASH_QUAD_ENABLE is not set
# CONFIG_FLASH_SRC_CLK_60M is not set
# CONFIG_FLASH_ORIGIN_API is not set
CONFIG_FLASH_MB=y
# end of FLASH
# H264_CONFIG
CONFIG_H264=y
CONFIG_H264_QUALITY_LEVEL=0
CONFIG_H264_GOP_START_IDR_FRAME=y
# CONFIG_H264_ADD_SELF_DEFINE_SEI is not set
CONFIG_H264_P_FRAME_CNT=15
# end of H264_CONFIG
# SDMADC
CONFIG_SDMADC=y
# end of SDMADC
# PWR_CLK
# CONFIG_EXTERN_32K is not set
# CONFIG_MEM_AUTO_POWER_DISABLE is not set
# CONFIG_CP1_AUTO_POWER_DISABLE is not set
# CONFIG_CPU_DEFAULT_FREQ_60M is not set
# CONFIG_RESERVE_1K_SRAM_UNINITIAL is not set
CONFIG_LPO_SRC_26M32K=y
# CONFIG_BUCK_ENABLE is not set
# CONFIG_BAKP_POWER_DOMAIN_DISABLE is not set
# CONFIG_BAKP_POWER_DOMAIN_PM_CONTROL is not set
# CONFIG_AHBP_POWER_DOMAIN_LV_DISABLE is not set
# CONFIG_PSRAM_POWER_DOMAIN_LV_DISABLE is not set
# CONFIG_DCO_CLK_ENABLE is not set
# CONFIG_EXTERN_32K_PIN_MULT is not set
# CONFIG_VBSPBUFLP1V_ENABLE is not set
# CONFIG_SMP_CPU1_DISABLE is not set
# CONFIG_LPO_MP_A_FORCE_USE_EXT32K is not set
# CONFIG_ROSC_CALIB_SW is not set
CONFIG_ROSC_COMPENSATION=y
CONFIG_LP_VOL=0x6
CONFIG_DIGLDO_LOW_VOLTAGE_ENABLE=y
# end of PWR_CLK
# VAULT
# CONFIG_VAULT_SUPPORT is not set
# end of VAULT
# OTP
# CONFIG_OTP is not set
# CONFIG_OTP_V1 is not set
# CONFIG_PHY_RFCALI_TO_OTP is not set
# CONFIG_OTP_SLEEP is not set
# end of OTP
# FFT
# CONFIG_FFT is not set
# end of FFT
# HW_ROTATE
CONFIG_HW_ROTATE_PFC=y
# end of HW_ROTATE
# YUV_BUF
CONFIG_YUV_BUF=y
# end of YUV_BUF
# LCD
CONFIG_LCD=y
# CONFIG_LCD_QSPI is not set
# CONFIG_LCD_POWER_GPIO_CTRL is not set
# CONFIG_LCD_BACKLIGHT_GPIO_CTRL is not set
# end of LCD
# IRDA
# CONFIG_SUPPORT_IRDA is not set
# end of IRDA
# CAMERA
CONFIG_DVP_CAMERA=y
CONFIG_DVP_CAMERA_I2C_ID=1
CONFIG_CAMERA_POWER_GPIO_CTRL=y
CONFIG_CAMERA_CTRL_POWER_GPIO_ID=56
CONFIG_ENCODE_BUF_DYNAMIC=y
CONFIG_UVC_CHECK_BULK_JPEG_HEADER=y
CONFIG_UVC_MAX_PACKET_CNT=16
CONFIG_JPEG_FRAME_SIZE=153600
CONFIG_H264_FRAME_SIZE=65536
CONFIG_JPEG_FRAME_CHECK_LENGTH=1024
# end of CAMERA
# RESET_REASON
# CONFIG_RESET_REASON is not set
CONFIG_RESET_REASON_TEST=y
# end of RESET_REASON
# EFUSE
# end of EFUSE
# MAILBOX
CONFIG_MAILBOX=y
CONFIG_MAILBOX_V2_0=y
# end of MAILBOX
# TP
CONFIG_TP=y
# end of TP
# DMA2D
CONFIG_DMA2D=y
# end of DMA2D
# SOFTWARE_SUPPORT_CHIP
# CONFIG_CHIP_SUPPORT is not set
# end of SOFTWARE_SUPPORT_CHIP
# ETH
# CONFIG_ETH is not set
CONFIG_ETH_PIN_GROUP0=y
# CONFIG_ETH_PIN_GROUP1 is not set
# CONFIG_ETH_PTP is not set
# CONFIG_ETH_VLAN is not set
# CONFIG_ETH_LPI is not set
# CONFIG_ETH_EEE is not set
# CONFIG_ETH_REGISTER_CALLBACKS is not set
# CONFIG_ETH_TSO is not set
CONFIG_ETH_CSUM_OFFLOAD=y
# CONFIG_ETH_PM_CB_SUPPORT is not set
CONFIG_PHY_SMSC=y
# CONFIG_PHY_MICREL_KSZ90X1 is not set
# CONFIG_PHY_REALTEK is not set
# end of ETH
# CKMN
# CONFIG_CKMN is not set
# end of CKMN
# HW_SCALE
CONFIG_HW_SCALE=y
# end of HW_SCALE
# LIN
# CONFIG_LIN is not set
# end of LIN
# SCR
# CONFIG_SCR is not set
# end of SCR
# JPEG_DEC
# end of JPEG_DEC
# SLCD
# CONFIG_SLCD is not set
# end of SLCD
# end of Driver
# bk7258
CONFIG_ITCM_SIZE=0x4000
CONFIG_DTCM_SIZE=0x4000
CONFIG_CPU0_SPE_RAM_SIZE=0x50800
CONFIG_CPU0_NSPE_RAM_SIZE=0x40000
CONFIG_CPU1_APP_RAM_SIZE=0x4F800
CONFIG_CPU2_APP_RAM_SIZE=0x00000
# CONFIG_ANA_REG_WRITE_POLL_REG_B is not set
# CONFIG_PM_HAL_DEBUG is not set
# CONFIG_PM_HAL_CTRL is not set
CONFIG_TZ=y
CONFIG_SPE=1
# CONFIG_RX_OPTIMIZE is not set
# CONFIG_BT_REUSE_MEDIA_MEMORY is not set
# end of bk7258
# Boards::Bk7256::Vnd_flash
CONFIG_OVERRIDE_FLASH_PARTITION=y
# end of Boards::Bk7256::Vnd_flash
# end of Middleware Configuration
# Projects Configuration
# Properties Configuration
# Extra Modules Configuration
# TUYA_SDK
# CONFIG_TUYA_OS_ADAPTER is not set
# CONFIG_TUYA_APP_SOURCES is not set
# CONFIG_TUYA_COMPONENTS is not set
CONFIG_CPU_INDEX=1
CONFIG_TUYA_LCD=y
# TUYA LCD Driver
CONFIG_TUYA_ST7701S=y
CONFIG_TUYA_ST7701SN=y
CONFIG_LCD_SPI_GC9A01=y
# end of TUYA LCD Driver
# TUYA LCD Type
CONFIG_TUYA_LCD_RGB565=y
# CONFIG_TUYA_LCD_RGB888 is not set
# end of TUYA LCD Type
# CONFIG_TUYA_LOG_OPTIMIZATION is not set
CONFIG_TUYA_GPIO_MAP=y
# CONFIG_TUYA_PAGE_TILEVIEW is not set
# CONFIG_TUYA_TEST_CLI is not set
CONFIG_VND_CAL_VERSION=1
CONFIG_ENABLE_TUYA_LVGL_TEST_DEMO=0
# CONFIG_TUYA_ENABLE_QSPI_FLASH is not set
CONFIG_TUYA_QSPI_FLASH_TYPE="gd25q127c"
# CONFIG_USE_PRIVATE_HELIX is not set
# CONFIG_SPI0_REMAP_PIN is not set
# end of TUYA_SDK
# end of Extra Modules Configuration
# end of Modules Configuration
# end of ARMINO Configuration
# TUYA_APP
# CONFIG_TUYA_APP_PARAM1 is not set
# CONFIG_TUYA_APP_PARAM2 is not set
# CONFIG_SUPPORTED_IMAGE_MAX_720P is not set
# end of TUYA_APP
