Ingenic-uc1_1 login:
Ingenic-uc1_1 login: root
Jan  1 00:00:15 login[60]: root login on 'console'
[root@Ingenic-uc1_1:~]# cd system/bin/
[root@Ingenic-uc1_1:bin]#
[root@Ingenic-uc1_1:bin]# rm test_aec_record.pcm
[root@Ingenic-uc1_1:bin]# ifconfig wlan0 192.168.176.1
touch /var/lib/misc/udhcpd.leases
udhcpd -fS /etc/udhcpd.conf &[root@Ingenic-uc1_1:bin]# touch /var/lib/misc/udhcpd.leases
[root@Ingenic-uc1_1:bin]# udhcpd -fS /etc/udhcpd.conf &
[root@Ingenic-uc1_1:bin]# udhcpd (v1.22.1) started
[root@Ingenic-uc1_1:bin]# ./tuyaos_demo_ipc -m 1 -r ./  -c ./ &
[root@Ingenic-uc1_1:bin]# [main, 654] Sep  9 2025,16:07:15 token[] raw_path[./] cfg_path[.//tuya_device_cfg.json]
detect auto test enviroment, load config from .//tuya_device_cfg.json
buffer is {
        "pid":"kpkmmc1w6wqfxhdo",
        "uuid": "uuid5f82e0aa8891be2b",
        "authkey": "kPA8rcFWz6iNEfTTNAyFmNNgjjGInHhv",
        "storage": "./",
        "media_path": "./",
        "sd_path": "/tmp/",
        "upgrade_file": "/tmp/upgrade.file",
        "app_version": "1.2.3"
s_ipc_pid: kpkmmc1w6wqfxhdo
s_ipc_uuid: uuid5f82e0aa8891be2b
s_ipc_authkey: kPA8rcFWz6iNEfTTNAyFmNNgjjGInHhv
s_ipc_storage: ./
s_raw_path: ./
s_ipc_sd_path: /tmp/
s_ipc_upgrade_file: /tmp/upgrade.file
s_app_version: 1.2.3
SDK Version:< TuyaOS V:6.2.8 BS:40.00_PT:2.3_LAN:3.5_CAD:1.0.5_CD:1.0.0 >
< BUILD AT:2025_02_21_11_26_21 BY ci_manage FOR tuyaos-ipc AT T23_uclibc >
IOT DEFS < WIFI_GW:1 DEBUG:0 KV_FILE:0 LITTLE_END:1 SL:1 OPERATING_SYSTEM:100 RELIABLE_TRANSFER:0 >
MODE:1  LINK_TYPE:1 IP_MODE_TYPE:0
[01-01 00:00:00 ty I][fc73][tal_thread.c:185] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[01-01 00:00:00 ty I][fc73][tal_thread.c:185] thread_create name:wq_system,stackDepth:6144,totalstackDepth:10240,priority:3
[01-01 00:00:00 ty I][fc73][tal_thread.c:185] thread_create name:wq_highpri,stackDepth:5120,totalstackDepth:15360,priority:4
71, wifi_status_event_cb: WiFi : first_stat=0
[01-01 00:00:00 ty I][fc73][tal_thread.c:185] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:16896,priority:5
[01-01 00:00:00 ty I][fc73][mqc_app.c:490] mqc app init ...
[01-01 00:00:00 ty I][fc73][kv_storge.c:45] Init Kvs With File:./
[01-01 00:00:00 ty N][fc73][tuya_tls.c:876] uni_random_init...
[01-01 00:00:00 ty N][fc73][tuya_tls.c:303] tuya_tls_rand_init ok!
[01-01 00:00:00 ty N][fc73][tuya_svc_devos.c:338] gw_cntl->gw_wsm.stat:2
898, tkl_gen_set_country_code: wifi_type=1, set country CN
ERROR: 454, tkl_wifi_set_country_code: set country code failed
[01-01 00:00:00 ty E][fc73][tuya_wifi_connect.c:257] ret:-1
[01-01 00:00:00 ty E][fc73][base_event.c:153] ret:-1
[01-01 00:00:00 ty D][fc73][tuya_ipc_media_adapter.c:101] media adapter init success. avaliable_res_size:5000
[01-01 00:00:00 ty D][fc73][tuya_ipc_media_adapter.c:511] insert media info node success! device:[0] channel:[0]
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:0 Enable:1
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:813] video_bitrate 1536, video_fps 25
[01-01 00:00:00 ty D][fc73][tuya_ring_buffer.c:649] Init Ring Buffer. ch0st0tr0 bitrate:1536 fps:25
[01-01 00:00:00 ty D][fc73][tuya_ring_buffer.c:672] Ring buffer malloc 1966080 bytes for ch0st0tr0, max frame size 294912
[01-01 00:00:00 ty I][fc73][tuya_ring_buffer.c:694] Init Ring Buffer success: ch0st0tr0 size:1966080 nodes:250
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:821] init ring buffer success. channel:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:1 Enable:1
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:813] video_bitrate 512, video_fps 25
[01-01 00:00:00 ty D][fc73][tuya_ring_buffer.c:649] Init Ring Buffer. ch0st0tr1 bitrate:512 fps:25
[01-01 00:00:00 ty D][fc73][tuya_ring_buffer.c:672] Ring buffer malloc 655360 bytes for ch0st0tr1, max frame size 98304
[01-01 00:00:00 ty I][fc73][tuya_ring_buffer.c:694] Init Ring Buffer success: ch0st0tr1 size:655360 nodes:250
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:821] init ring buffer success. channel:1
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:2 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:3 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:4 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:5 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:6 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:7 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:8 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:9 Enable:1
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:804] audio_sample 16000, audio_databits 16, audio_fps 25
[01-01 00:00:00 ty D][fc73][tuya_ring_buffer.c:649] Init Ring Buffer. ch0st0tr9 bitrate:250 fps:25
[01-01 00:00:00 ty D][fc73][tuya_ring_buffer.c:672] Ring buffer malloc 320000 bytes for ch0st0tr9, max frame size 48000
[01-01 00:00:00 ty I][fc73][tuya_ring_buffer.c:694] Init Ring Buffer success: ch0st0tr9 size:320000 nodes:250
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:821] init ring buffer success. channel:9
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:10 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:11 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:12 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:13 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:14 Enable:0
[01-01 00:00:00 ty D][fc73][ty_sdk_media_callback.c:795] init ring buffer Channel:0 Stream:15 Enable:0
[01-01 00:00:00 ty D][fc73][simplekv.c:1137] read key:gw_bi isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][fc73][simplekv.c:1168] find key:1 gw_bi
[01-01 00:00:00 ty D][fc73][simplekv.c:1194] key:gw_bi find value.Len:272
[01-01 00:00:00 ty D][fc73][tuya_ws_db.c:711] sync to protected len[258]
[01-01 00:00:00 ty D][fc73][ws_db_gw.c:148] gw_bi read ret:0
[01-01 00:00:00 ty D][fc73][tuya_wifi_link.c:901] tuya wifi link init mthd:0,wifi start mode:0, enable_station_ap:0
[01-01 00:00:00 ty D][fc73][simplekv.c:1137] read key:gw_wsm isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][fc73][simplekv.c:1168] find key:2 gw_wsm
[01-01 00:00:00 ty D][fc73][simplekv.c:1194] key:gw_wsm find value.Len:224
[01-01 00:00:00 ty D][fc73][tuya_ws_db.c:711] sync to protected len[215]
[01-01 00:00:00 ty D][fc73][ws_db_gw.c:259] gw_wsm read ret:0
[01-01 00:00:00 ty N][fc73][tuya_wifi_link.c:85] start wifi link params validate, nc_tp:4 md:4
[01-01 00:00:00 ty N][fc73][tuya_wifi_link.c:107] gw_wsm.nc_tp:4
[01-01 00:00:00 ty N][fc73][tuya_wifi_link.c:108] gw_wsm.md:4
[01-01 00:00:00 ty N][fc73][tuya_svc_devos.c:563] Last reset reason: 7
[01-01 00:00:00 ty D][fc73][simplekv.c:1137] read key:gw_di isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][fc73][simplekv.c:1168] find key:3 gw_di
[01-01 00:00:00 ty D][fc73][simplekv.c:1194] key:gw_di find value.Len:704
[01-01 00:00:00 ty D][fc73][ws_db_gw.c:376] gw_di read ret:0
[01-01 00:00:00 ty D][fc73][simplekv.c:1137] read key:is_stride isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][fc73][simplekv.c:1168] find key:7 is_stride
[01-01 00:00:00 ty D][fc73][simplekv.c:1194] key:is_stride find value.Len:16
[01-01 00:00:00 ty D][fc73][tuya_devos_stride.c:55] stride from flash: 0.
[01-01 00:00:00 ty D][fc73][tuya_devos_stride.c:83] ver no change.
[01-01 00:00:00 ty N][fc73][tuya_svc_devos.c:395] gw_cntl->gw_if.abi:0 input:0
[01-01 00:00:00 ty N][fc73][tuya_svc_devos.c:396] gw_cntl->gw_if.product_key:kpkmmc1w6wqfxhdo, input:kpkmmc1w6wqfxhdo
[01-01 00:00:00 ty N][fc73][tuya_svc_devos.c:397] gw_cntl->gw_if.tp:0, input:0
[01-01 00:00:00 ty D][fc73][simplekv.c:1137] read key:e1mtcgtk isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][fc73][simplekv.c:1168] find key:8 e1mtcgtk
[01-01 00:00:00 ty D][fc73][simplekv.c:1194] key:e1mtcgtk find value.Len:3536
[01-01 00:00:00 ty D][fc73][ws_db_gw.c:535] schema e1mtcgtk read success
[01-01 00:00:00 ty D][fc73][tuya_devos_utils.c:1169] create dev_cntl Success
[01-01 00:00:00 ty N][fc73][tuya_svc_devos.c:596] enter success_proc
424, tkl_gen_get_mac: WIFI GET MAC success , MAC:fc:23:cd:14:d1:48
227, tkl_wifi_get_mac: GET MAC success, MAC:fc:23:cd:14:d1:48
[01-01 00:00:00 ty N][fc73][tuya_svc_devos.c:599] serial_no:fc23cd14d148
[01-01 00:00:00 ty D][fc73][tuya_svc_upgrade.c:1369] tuya svc upgrade init success!
[01-01 00:00:00 ty D][fc73][simplekv.c:1137] read key:kv.meta.report isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][fc73][simplekv.c:1168] find key:16 kv.meta.report
[01-01 00:00:00 ty D][fc73][simplekv.c:1194] key:kv.meta.report find value.Len:64
[01-01 00:00:00 ty D][fc73][ty_meta_report.c:111] meta in kv {"metas":{"secureVersion":"1.0.0","timerCapability":1}}
[01-01 00:00:00 ty D][fc73][mqc_app.c:109] mq_pro:300 cnt:3
[01-01 00:00:00 ty D][fc73][mqc_app.c:109] mq_pro:302 cnt:4
[01-01 00:00:00 ty D][fc73][mqc_app.c:109] mq_pro:304 cnt:5
[01-01 00:00:00 ty D][fc73][mqc_app.c:109] mq_pro:307 cnt:6
[01-01 00:00:00 ty D][fc73][mqc_app.c:109] mq_pro:308 cnt:7
[01-01 00:00:00 ty D][fc73][mqc_app.c:109] mq_pro:312 cnt:8
[01-01 00:00:00 ty D][fc73][tuya_ipc_mqtt_subscribe.c:292] iot_register_extra_mqt_cb done
[01-01 00:00:00 ty D][fc73][tuya_ipc_hardware_info.c:252] traversal over
[01-01 00:00:00 ty E][fc73][tuya_ipc_hardware_info.c:173] NO sensor info. Please check if you need.
[01-01 00:00:00 ty D][fc73][tuya_ipc_hardware_info.c:115] not found device wifi info
[01-01 00:00:00 ty D][fc73][tuya_ipc_hardware_info.c:355] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":1,\"webrtc\":2,\"cloudRule\":7,\"p2p\":611,\"security_ability\":30,\"video_num\":2,\"sdk_version\":\"6.2.8\"},\"hardware\":{\"toolchain\":\"T23_uclibc\",\"cpu\":{\"model\":\"Pike\",\"bogomips\":\"1185.38\",\"name\":\"Ingenic Xburst V0.0  FPU V0.0\"}}
[01-01 00:00:00 ty D][fc73][simplekv.c:1137] read key:func_restrict isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][fc73][simplekv.c:1165] no key find
[01-01 00:00:00 ty D][fc73][simplekv.c:1207] __read_kv_raw fail. -3
[01-01 00:00:00 ty D][fc73][simplekv.c:1246] __read_kv_with_decode fail. -3
[01-01 00:00:00 ty D][cdf4][tuya_svc_devos.c:854] state change from 0 to 3
[01-01 00:00:00 ty D][fc73][tuya_iot_wifi_api.c:452] register wifi network monitor. interval:1
[01-01 00:00:00 ty D][fc73][main.c:390] tuya ipc sdk start is complete
[01-01 00:00:00 ty I][fc73][tal_thread.c:185] thread_create name:md_proc,stackDepth:524288,totalstackDepth:541184,priority:3
[01-01 00:00:00 ty D][20e4][tal_thread.c:209] Thread:md_proc Exec Start. Set to Running Stat 0x7520e4e0
253, tkl_wifi_set_work_mode: WIFI SET work mode success, set mode :station mode
[01-01 00:00:01 ty D][cdf4][tuya_wifi_reset.c:596] reset init mthd:0, short timer:0 long timer:0
[01-01 00:00:01 ty D][cdf4][tuya_wifi_netcfg.c:437] do proxy actived work,mode:2,stat:2,nc_tp:4
[01-01 00:00:01 ty N][cdf4][tuya_svc_devos.c:246] __devos_init_evt success
[01-01 00:00:01 ty N][cdf4][tuya_svc_devos.c:75] already bind
[01-01 00:00:01 ty E][cdf4][tuya_ipc_sdk_init.c:377] gw status changed to [3], but not notify
[01-01 00:00:01 ty I][cdf4][mqc_app.c:526] mqc app start ...
[01-01 00:00:01 ty D][cdf4][mqc_app.c:573] MQTT Protocol URL:m6.tuyacn.com:8886 Port:8883
[01-01 00:00:01 ty I][cdf4][tal_thread.c:185] thread_create name:mqtt_thread,stackDepth:9216,totalstackDepth:550400,priority:4
[01-01 00:00:01 ty D][cdf4][mqc_app.c:617] mqtt send topic:smart/device/out/6c9108853826b21b49bvi8
[01-01 00:00:01 ty D][cdf4][mqc_app.c:619] mqtt-media send topic:d/m/o/6c9108853826b21b49bvi8
[01-01 00:00:01 ty N][cdf4][tuya_svc_mqtt_client.c:175] [mqtts://m6.tuyacn.com:8886] mqtt state change 0 -> 1
[01-01 00:00:01 ty D][cdf4][mqc_app.c:109] mq_pro:64 cnt:9
[01-01 00:00:01 ty D][cdf4][mqc_app.c:109] mq_pro:19 cnt:10
[01-01 00:00:01 ty D][cdf4][mqc_app.c:109] mq_pro:22 cnt:11
[01-01 00:00:01 ty D][cdf4][mqc_app.c:109] mq_pro:55 cnt:12
[01-01 00:00:01 ty D][cdf4][simplekv.c:1137] read key:timer_full_key isFuzzy:0 skipCnt:0
[01-01 00:00:01 ty D][cdf4][simplekv.c:1165] no key find
[01-01 00:00:01 ty D][cdf4][simplekv.c:1207] __read_kv_raw fail. -3
[01-01 00:00:01 ty D][cdf4][simplekv.c:1246] __read_kv_with_decode fail. -3
[01-01 00:00:01 ty E][cdf4][tuya_svc_timer_task.c:1376] read timer_full_key failed
[01-01 00:00:01 ty D][cdf4][simplekv.c:1137] read key:timer_arr isFuzzy:0 skipCnt:0
[01-01 00:00:01 ty D][cdf4][tuya_svc_timer_task.c:429] no timer
[01-01 00:00:01 ty D][cdf4][tuya_svc_timer_task.c:1480] --- timer_cnt = 0
[01-01 00:00:01 ty D][cdf4][mqc_app.c:109] mq_pro:15 cnt:13
[01-01 00:00:01 ty D][cdf4][tuya_svc_upgrade.c:1396] upgrade active success
[01-01 00:00:01 ty D][cdf4][tuya_svc_online_log.c:204] mqtt log topic init log/realtime/6c9108853826b21b49bvi8
[01-01 00:00:01 ty D][cdf4][tuya_svc_online_log.c:205] mqtt log topic init log/runstat/6c9108853826b21b49bvi8
[01-01 00:00:01 ty D][cdf4][tuya_svc_online_log.c:314] svc online log active success
[01-01 00:00:01 ty D][cdf4][mqc_app.c:109] mq_pro:11 cnt:14
[01-01 00:00:01 ty D][cdf4][mqc_app.c:109] mq_pro:41 cnt:15
[01-01 00:00:01 ty D][cdf4][mqc_app.c:109] mq_pro:27 cnt:16
[01-01 08:00:01 ty D][cdf4][tuya_devos_log_upd.c:1168] not set cb, will not rept meta
[01-01 08:00:01 ty D][cdf4][simplekv.c:1137] read key:wf_pt isFuzzy:0 skipCnt:0
[01-01 08:00:01 ty D][cdf4][simplekv.c:1165] no key find
[01-01 08:00:01 ty D][cdf4][simplekv.c:1207] __read_kv_raw fail. -3
[01-01 08:00:01 ty D][cdf4][simplekv.c:1246] __read_kv_with_decode fail. -3
[01-01 08:00:01 ty D][cdf4][wf_protect.c:1624] wifi protect ap info init
[01-01 08:00:01 ty D][cdf4][ty_meta_report.c:184] need_report 0 mode 0
[01-01 08:00:01 ty D][cdf4][tuya_wifi_connect.c:319] __wifi_net_conn.
[01-01 08:00:01 ty D][a0e4][tal_thread.c:209] Thread:mqtt_thread Exec Start. Set to Running Stat 0x74a0e4e0
[01-01 08:00:01 ty N][a0e4][tuya_svc_mqtt_client.c:1193] mqtt_thread paused
[01-01 08:00:01 ty N][a0e4][tuya_svc_mqtt_client.c:656] mqtt close
[01-01 08:00:01 ty D][cdf4][tuya_wifi_connect.c:217] status:5,mode:2
[01-01 08:00:01 ty D][cdf4][tuya_wifi_connect.c:321] __wifi_net_conn, enable_station_ap:0
[01-01 08:00:01 ty D][cdf4][tuya_wifi_connect.c:339] start wf connect, ssid:CMCC-C96J, pwd:G5fe2G2a
[01-01 08:00:01 ty D][cdf4][tal_wifi_reconnet.c:92] wifi auto reconn ssid CMCC-C96J
[01-01 08:00:01 ty D][cdf4][ty_sdk_status_callback.c:86] status chaged: group[2] status[22]
593, tkl_gen_station_connect: WiFi : connect to ap
Successfully initialized wpa_supplicant
nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory)
killall: udhcpc: no process killed
1109, priv_set_ipv6_linklocal_addr: ll addr: fe80::fe23:cdff:fe14:d148
udhcpc (v1.22.1) started
ifconfig: socket: Address family not supported by protocol
killall: udhcpc6: no process killed
[01-01 08:00:02 ty D][cdf4][tuya_wifi_connect.c:350] wf connect success!
/bin/sh: /usr/bin/udhcpc6: not found
[01-01 08:00:02 ty N][cdf4][tuya_wifi_status.c:167] cur stat:5  0x4ddbcc -->>
[01-01 08:00:02 ty N][cdf4][tuya_wifi_status.c:169] wifi netstat changed to:5  -->>
[01-01 08:00:02 ty N][cdf4][tuya_wifi_status.c:173] report wifi netstat[5] to callback  -->>
[01-01 08:00:02 ty D][cdf4][ty_sdk_status_callback.c:86] status chaged: group[2] status[20]
[01-01 08:00:02 ty D][cdf4][ty_sdk_status_callback.c:93] status ignore. cb is null.
Sending discover...
Sending discover...
Sending select for 192.168.1.171...
Lease of 192.168.1.171 obtained, lease time 86400
deleting routers
adding dns 211.136.192.6
adding dns 120.196.165.24
[01-01 08:00:06 ty D][4df4][ty_sdk_status_callback.c:86] status chaged: group[2] status[21]
[01-01 08:00:06 ty D][4df4][ty_sdk_status_callback.c:93] status ignore. cb is null.
[01-01 08:00:06 ty N][cdf4][tal_wifi_reconnet.c:249] wifi status changed to 0, stat: 1
[01-01 08:00:06 ty D][cdf4][tuya_svc_devos.c:864] set netcfgstat, stage:2, status:0
[01-01 08:00:06 ty D][cdf4][tuya_ble_svc.c:1665] ble get conn stat:4
[01-01 08:00:06 ty D][cdf4][tuya_wifi_link.c:305] stat:6
[01-01 08:00:06 ty D][cdf4][tuya_svc_netmgr_linkage.c:120] link[2][1] is_up[1] active_link[2][1] status[0]
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886
[01-01 08:00:06 ty D][4df4][ty_meta_report.c:184] need_report 0 mode 0
[01-01 08:00:06 ty N][4df4][tuya_svc_devos_daemons.c:306] Main Module: v1.0.0 (1.2.3)
[01-01 08:00:06 ty N][cdf4][tuya_wifi_status.c:167] cur stat:6  0x4ddbcc -->>
[01-01 08:00:06 ty N][cdf4][tuya_wifi_status.c:169] wifi netstat changed to:6  -->>
[01-01 08:00:06 ty N][cdf4][tuya_wifi_status.c:173] report wifi netstat[6] to callback  -->>
[01-01 08:00:06 ty I][cdf4][tal_thread.c:185] thread_create name:lan_sock_loop,stackDepth:4096,totalstackDepth:554496,priority:3
[01-01 08:00:06 ty D][cdf4][tuya_lan_sock.c:312] init sock loop success
[01-01 08:00:06 ty D][cdf4][tuya_wifi_link.c:221] reg wifi lan enable
[01-01 08:00:06 ty D][cdf4][tuya_svc_lan.c:2401] lan init success
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:848] mqtt client type:2 ip:192.168.1.171
[01-01 08:00:06 ty D][a0e4][tcp_transporter.c:37] dns mode by ip 2
[01-01 08:00:06 ty D][a0e4][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1
640, tkl_gen_get_bssid: WiFi Get AP BSSID 88:6e:dd:e8:c9:6a
[01-01 08:00:06 ty E][cdf4][tuya_wifi_connect.c:106] wf_get_connected_ap_info fails 0 (nil)
[01-01 08:00:06 ty D][cdf4][tal_wifi_reconnet.c:266] wifi connected in check
[01-01 08:00:06 ty D][20e4][tal_thread.c:209] Thread:lan_sock_loop Exec Start. Set to Running Stat 0x7420e4e0
[01-01 08:00:06 ty D][a0e4][uni_network.c:257] use dynamic dns ip:8.153.104.55 for domain:m6.tuyacn.com
[01-01 08:00:06 ty D][a0e4][uni_network.c:184] cache dns [m6.tuyacn.com]<->[8.153.104.55]
[01-01 08:00:06 ty D][a0e4][tcp_transporter.c:44] DNS parse type:2
[01-01 08:00:06 ty D][a0e4][tcp_transporter.c:85] bind  port:2674 ok
[01-01 08:00:06 ty D][a0e4][tuya_tls.c:979] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1
[01-01 08:00:06 ty D][a0e4][tuya_tls.c:988] TUYA_TLS Begin Connect m6.tuyacn.com:8886
[01-01 08:00:06 ty D][a0e4][tuya_tls.c:738] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED
[01-01 08:00:06 ty D][a0e4][tuya_tls.c:751] load tuya cert.
[01-01 08:00:06 ty D][a0e4][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com
[01-01 08:00:06 ty D][a0e4][tuya_cert_manager.c:236] tuya public url
[01-01 08:00:06 ty D][a0e4][tuya_cert_manager.c:1100] parse crt <0> len <540> ret <0>
[01-01 08:00:06 ty D][a0e4][tuya_tls.c:1077] socket fd is set. set to inner send/recv to handshake
[01-01 08:00:06 ty D][a0e4][tuya_tls.c:711] mbedtls_cert_pkey_free.
[01-01 08:00:06 ty D][a0e4][tuya_tls.c:1139] handshake finish for m6.tuyacn.com. set send/recv to user set
[01-01 08:00:06 ty D][a0e4][tuya_tls.c:1145] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:883] setup mqtt transporter success
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:175] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:908] send mqtt connect success
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:175] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:938] mqtt connect success
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:175] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 4
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:977] mqtt topics cnt 1
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:991] send mqtt subscribe success
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:175] [mqtts://m6.tuyacn.com:8886] mqtt state change 4 -> 5
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:1016] mqtt subscribe success
[01-01 08:00:06 ty N][a0e4][tuya_svc_mqtt_client.c:175] [mqtts://m6.tuyacn.com:8886] mqtt state change 5 -> 6
[01-01 08:00:06 ty D][cdf4][mqc_app.c:418] mqtt connect success
[01-01 08:00:06 ty N][cdf4][tuya_wifi_status.c:167] cur stat:7  0x4ddbcc -->>
[01-01 08:00:06 ty N][cdf4][tuya_wifi_status.c:169] wifi netstat changed to:7  -->>
[01-01 08:00:06 ty N][cdf4][tuya_wifi_status.c:173] report wifi netstat[7] to callback  -->>
[01-01 08:00:06 ty D][cdf4][ty_sdk_status_callback.c:86] status chaged: group[4] status[40]
[01-01 08:00:06 ty I][cdf4][ty_sdk_status_callback.c:59] online: network status MQTT connected
[01-01 08:00:06 ty D][cdf4][smart_frame.c:2497] sync chan:1
[01-01 08:00:06 ty D][cdf4][tuya_ipc_moto_mqtt.c:69] book topic start
[01-01 08:00:06 ty D][cdf4][tuya_ipc_moto_mqtt.c:75] book topic done, ret:0
[01-01 08:00:06 ty D][cdf4][tuya_ipc_sdk_info.c:354] ipc sdk info: mqstat change to :1
[01-01 08:00:06 ty D][cdf4][mqc_app.c:800] Send MQTT Msg.P:65 N:28575 Q:1 Data:{"reqType":"ipcFunctionRestrictReq","data":{"devId":"6c9108853826b21b49bvi8","action":0,"functions":[]}}
[01-01 08:00:06 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 3
[01-01 08:00:06 ty D][fc73][main.c:691] tuya_ipc_sdk_mqtt_online_proc is start run
[01-01 08:00:06 ty D][fc73][tuya_ipc_sdk_info.c:147] no service time now, force sync
[01-01 08:00:06 ty D][fc73][iot_httpc.c:973] Post Data: {"devId":"6c9108853826b21b49bvi8","lastFetchTime":"0","t":6}
[01-01 08:00:06 ty D][fc73][iot_httpc.c:985] Post URL: https://a6.tuyacn.com/d.json?a=tuya.device.timer.count&devId=6c9108853826b21b49bvi8&et=3&t=6&v=4.2&sign=a22dfaeec97fef1d07af6b43f55a5e7c
[01-01 08:00:06 ty D][fc73][httpc.c:623] Connect: a6.tuyacn.com Port: 443  -->>
[01-01 08:00:06 ty D][fc73][tcp_transporter.c:37] dns mode by ip 2
[01-01 08:00:06 ty D][fc73][uni_network.c:230] unw_gethostbyname a6.tuyacn.com, prio 1
[01-01 08:00:06 ty D][fc73][uni_network.c:257] use dynamic dns ip:47.116.198.59 for domain:a6.tuyacn.com
[01-01 08:00:06 ty D][fc73][uni_network.c:184] cache dns [a6.tuyacn.com]<->[47.116.198.59]
[01-01 08:00:06 ty D][fc73][tcp_transporter.c:44] DNS parse type:2
[01-01 08:00:06 ty D][fc73][tcp_transporter.c:85] bind  port:0 ok
[01-01 08:00:07 ty D][fc73][tuya_tls.c:979] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1
[01-01 08:00:07 ty D][fc73][tuya_tls.c:988] TUYA_TLS Begin Connect a6.tuyacn.com:443
[01-01 08:00:07 ty D][fc73][tuya_tls.c:738] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED
[01-01 08:00:07 ty D][fc73][tuya_tls.c:751] load tuya cert.
[01-01 08:00:07 ty D][fc73][tuya_cert_manager.c:213] p_url:a6.tuyacn.com, rcs.urlx:h6.iot-dns.com
[01-01 08:00:07 ty D][fc73][tuya_cert_manager.c:236] tuya public url
[01-01 08:00:07 ty D][fc73][tuya_cert_manager.c:1100] parse crt <0> len <540> ret <0>
[01-01 08:00:07 ty D][fc73][tuya_tls.c:1077] socket fd is set. set to inner send/recv to handshake
[01-01 08:00:07 ty D][cdf4][tuya_lan_sock.c:331] reg post queue 8
[01-01 08:00:07 ty D][cdf4][tuya_lan_sock.c:331] reg post queue 9
[01-01 08:00:07 ty D][cdf4][tuya_svc_lan.c:988] udp ip: 192.168.1.171
[01-01 08:00:07 ty D][fc73][tuya_tls.c:711] mbedtls_cert_pkey_free.
[01-01 08:00:07 ty D][fc73][tuya_tls.c:1139] handshake finish for a6.tuyacn.com. set send/recv to user set
[01-01 08:00:07 ty D][fc73][tuya_tls.c:1145] TUYA_TLS Success Connect a6.tuyacn.com:443 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
[01-01 08:00:07 ty D][fc73][httpc.c:625] Connect: a6.tuyacn.com Port: 443  --<< ,r:0
[01-01 08:00:07 ty D][fc73][iot_httpc.c:619] Decode Rev:{"result":{"code":"200","count":0,"devId":"6c9108853826b21b49bvi8","lastFetchTime":0},"t":1757407548,"success":true}
[09-09 16:45:48 ty D][fc73][tls_transporter.c:93] tls transporter close socket fd:7
[09-09 16:45:48 ty D][fc73][tcp_transporter.c:183] tcp transporter close socket fd:7
[09-09 16:45:48 ty D][fc73][tls_transporter.c:101] tls transporter close tls handler:0x9e3b60
[09-[   60.933602] cgu_vpu can not set to 416000000, will change!!!
09 16:45:48 ty D][fc73][tuya_tls.c:1221] TUYA_TLS Disconnect ENT[   60.947131] [sc3336p_probe,1369] default_boot=1
ER
[09-09 16:45:48 ty D][fc73][tuya_tls.c:1246] TUYA_TLS Disconnect Success
[09-09 16:45:48 ty D][fc73][tuya_tls.c:941] tuya_tls_connect_destroy.
[09-09 16:45:48 ty D][fc73][tuya_ipc_sdk_info.c:130] ipc get service time 1757407548 28800
[09-09 16:45:48 ty D][fc73][tuya_ipc_sdk_info.c:161] got service time 1757407548 28800
create av task!!!
SAMPLE_VENC_1080P_INIT################
[sample_system_init, 253]sample_system_init start
[   61.012883] -----sc3336p_detect: 849 ret = 0, v = 0x9c
[   61.018721] -----sc3336p_detect: 857 ret = 0, v = 0x41
[   61.024074] sc3336p chip found @ 0x30 (i2c0)
[   61.028492] sensor driver version H20250206a
[09-09 16:45:48 ty D][cdf4][simplekv.c:1137] read key:em_sys_env isFuzzy:0 skipCnt:0
[09-09 16:45:48 ty D][cdf4][simplekv.c:1168] find key:4 em_sys_env
[09-09 16:45:48 ty D][cdf4][simplekv.c:1194] key:em_sys_env find value.Len:32
[09-09 16:45:48 ty D][cdf4][tuya_svc_online_log.c:160] load env success T23_uclibc
[09-09 16:45:48 ty D][cdf4][tuya_svc_online_log.c:163] env T23_uclibc same. need not to update
[09-09 16:45:48 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1130414197 1 UDP 1694498815 120.235.186.91 3273 typ srflx\r\n"}},"protocol":302,"t":1757407548}
[09-09 16:45:48 ty D][a0e4][tuya_ipc_mqtt_subscribe.c:213] recv mq: protocol 302
[09-09 16:45:48 ty E][4df4][tuya_ipc_mqtt_subscribe.c:143] mqtt subscribe not inited
[09-09 16:45:48 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:905595773 1 UDP 16777215 47.103.17.244 62907 typ relay\r\n"}},"protocol":302,"t":1757407548}
[09-09 16:45:48 ty D][a0e4][tuya_ipc_mqtt_subscribe.c:213] recv mq: p[   61.485191] sc3336p stream on
rotocol 302
[09-09 16:45:48 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":""}},"protocol":302,"t":1757407548}
[09-09 16:45:48 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"dps":{"208":null}},"protocol":5,"t":1757407548}
[09-09 16:45:48 ty D][a0e4][sf_mqc_cb.c:11] Rev DP Cmd
[09-09 16:45:48 ty D][cdf4][smart_frame.c:1180] Rev Cmd 1, data:0x9ecd28
[09-09 16:45:48 ty D][cdf4][smart_frame.c:1180] Rev Cmd 1, data:0x9bddf0
[09-09 16:45:48 ty D][cdf4][smart_frame.c:1180] Rev Cmd 1, data:0x9ed690
[sample_system_init, 321]ImpSystemInit success
[SAMPLE_VENC_1080P_INIT, 199]IMP_System_Init##############
sample_framesource_init################
sample_encoder_init################
i264e[info]: profile High, level 5.0
i264e[info]: profile High, level 3.0
Bind FrameSource channel################
sample_framesource_streamon################
[09-09 16:45:48 ty D][cdf4][smart_frame.c:1180] Rev Cmd 1, data:0x9ecb88
[09-09 16:45:48 ty D][20e4][tuya_lan_sock.c:127] reg lan sock 8,read:0x53a6a8
sample_framesource_streamon&&&&&&&&&&&&&&&&&&&
[09-09 16:45:48 ty I][fc73][tal_thread.c:185] thread_create name:video_main,stackDepth:524288,totalstackDepth:1078784,priority:3
[09-09 16:45:48 ty I][fc73][tal_thread.c:185] thread_create name:video_main,stackDepth:524288,totalstackDepth:1603072,priority:3
[09-09 16:45:48 ty I][fc73][tal_thread.c:185] thread_create name:audio_main,stackDepth:524288,totalstackDepth:2127360,priority:3
[09-09 16:45:48 ty D][fc73][simplekv.c:1137] read key:media_log_info isFuzzy:0 skipCnt:0
[09-09 16:45:48 ty D][fc73][simplekv.c:1168] find key:12 media_log_info
[09-09 16:45:48 ty D][fc73][simplekv.c:1194] key:media_log_info find value.Len:96
[09-09 16:45:48 ty D][fc73][tuya_imm_service_log.c:493] LOAD log server: level[2],server[/av/moto/log]
[09-09 16:45:48 ty I][fc73][tuya_imm_service_log.c:338] use mqtt uploader
[09-09 16:45:48 ty I][fc73][tuya_imm_service_log.c:372] init uploader[0] OK.
[09-09 16:45:48 ty D][fc73][tuya_ipc_mqtt_subscribe.c:84] __mqtt_subscribe_init
[09-09 16:45:48 ty D][fc73][tuya_imm_service_log.c:605] send mqtt msg to topic[/av/moto/log/d/6c9108853826b21b49bvi8][{"header":{"from":"6c9108853826b21b49bvi8","type":"getLogToken","tid":"11d5b5363859156335a3fdba70f93b27"}}]
[09-09 16:45:48 ty D][fc73][mqc_app.c:1001] Send MQTT Msg.P:312 N:28576 Q:0
[09-09 16:45:48 ty D][fc73][tuya_svc_mqtt_client.c:421] packet id: 4
[09-09 16:45:48 ty D][3214][tal_thread.c:209] Thread:video_main Exec Start. Set to Running Stat 0x6c3214e0
__video_main######################
get_video_stream####################
[09-09 16:45:48 ty D][b214][tal_thread.c:209] Thread:video_main Exec Start. Set to Running Stat 0x6bb214e0
[09-09 16:45:48 ty D][3214][tal_thread.c:209] Thread:audio_main Exec Start. Set to Running Stat 0x6b3214e0
Audio In GetPubAttr samplerate : 16000
Audio In GetPubAttr      bitwidth : 16
Audio In GetPubAttr     soundmode : 1
Audio In GetPubAttr        frmNum : 40
Audio In GetPubAttr     numPerFrm : 320
Audio In GetPubAttr        chnCnt : 1
[09-09 16:45:48 ty I][fc73][tuya_imm_service_log.c:665] init ok
[09-09 16:45:48 ty D][fc73][tuya_ipc_media_stream.c:65] P2P API Version: 244.3.4.120
[09-09 16:45:48 ty D][fc73][tuya_ipc_media_stream.c:362] gw actived
tuya liteos uv
[09-09 16:45:48 ty D][fc73][simplekv.c:1137] read key:tuya_seed isFuzzy:0 skipCnt:0
[09-09 16:45:48 ty D][fc73][simplekv.c:1168] find key:0 tuya_seed
[09-09 16:45:48 ty D][fc73][simplekv.c:1194] key:tuya_seed find value.Len:80
[09-09 16:45:48 ty D][fc73][simplekv.c:370] write key:tuya_seed And Value Len:80
[09-09 16:45:48 ty D][fc73][simplekv.c:388] 0 key same AND size old 148 >= new 80
[09-09 16:45:48 ty D][fc73][simplekv.c:416] find 0 available space
[09-09 16:45:48 ty D][fc73][simplekv.c:453] reuse available space 28700
[09-09 16:45:48 ty D][fc73][simplekv.c:208] update crc 3157362433
[09-09 16:45:48 ty D][fc73][simplekv.c:357] write head to normal file success
[09-09 16:45:48 ty D][fc73][simplekv.c:493] write success
[09-09 16:45:48 ty D][3214][tuya_ring_buffer.c:780] ch0st0tr0 open with type 1
[09-09 16:45:48 ty D][cdf4][smart_frame.c:1180] Rev Cmd 1, data:0xa2d398
[09-09 16:45:49 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"protocol":312,"pv":"2.3","t":1757407549,"data":{"header":{"type":"setLogToken","to":"6c9108853826b21b49bvi8","tid":"11d5b5363859156335a3fdba70f93b27"},"msg":{"mode":"log","log":{"level":2,"size":1024,"interval":60,"topic":"/av/moto/log","api":"thing.m.rtc.log","tcp":{"domain":"wework-9-cn.stream.iot-11.com","address":"47.101.63.221","port":9093,"key":"6e9d446e4a2d2cdc"}}}}}
[09-09 16:45:49 ty D][a0e4][tuya_ipc_mqtt_subscribe.c:213] recv mq: protocol 312
[09-09 16:45:49 ty D][fc73][simplekv.c:1137] read key:tuya_seed isFuzzy:0 skipCnt:0
[09-09 16:45:49 ty D][fc73][simplekv.c:1168] find key:0 tuya_seed
[09-09 16:45:49 ty D][fc73][simplekv.c:1194] key:tuya_seed find value.Len:80
[09-09 16:45:49 ty D][fc73][simplekv.c:370] write key:tuya_seed And Value Len:80
[09-09 16:45:49 ty D][fc73][simplekv.c:388] 0 key same AND size old 148 >= new 80
[09-09 16:45:49 ty D][fc73][simplekv.c:416] find 0 available space
[09-09 16:45:49 ty D][fc73][simplekv.c:453] reuse available space 28700
[09-09 16:45:49 ty D][fc73][simplekv.c:208] update crc 1471444289
[09-09 16:45:49 ty D][4df4][tuya_imm_service_log.c:454] server info is same
[09-09 16:45:49 ty D][4df4][tuya_imm_service_log.c:587] Set log server:[/av/moto/log]
[09-09 16:45:49 ty D][fc73][simplekv.c:357] write head to normal file success
[09-09 16:45:49 ty D][fc73][simplekv.c:493] write success
[09-09 16:45:49 ty D][fc73][simplekv.c:208] update crc 1043437646
[09-09 16:45:49 ty I][fc73][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436348429,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_init","l":"6c9108853826b21b49bvi8","mcn":6,"msn":5,"k":611}
[09-09 16:45:49 ty I][fc73][tal_thread.c:185] thread_create name:tuya_p2p_listen_task,stackDepth:131072,totalstackDepth:2258432,priority:2
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5019] video codec[18] fps[25] gop[25]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5020] height[1296] width[2304] bitrate[1536]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5020] height[360] width[640] bitrate[512]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5031] video codec[18] fps[25] gop[25]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5032] height[1296] width[2304] bitrate[1536]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5032] height[360] width[640] bitrate[512]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5031] video codec[0] fps[0] gop[0]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5032] height[0] width[0] bitrate[0]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5034] audio codec[129] sample[3]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5035] databits[1] channel[0]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5040] videoNum[2]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5260] p2p max_client_num[5]
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5279] need speaker audio codec[129] sample[3] databits[1] channel[0] def_live_mode[0]
Audio In GetChnParam usrFrmDepth : 40
warn: shm_init,53shm init already
Audio In GetVol   vol : 60
[09-09 16:45:49 ty D][a374][tal_thread.c:209] Thread:tuya_p2p_listen Exec Start. Set to Running Stat 0x6aa374e0
[09-09 16:45:49 ty D][a374][tuya_ipc_p2p_wrapper.c:17] listen task start
[09-09 16:45:49 ty D][b014][simplekv.c:1137] read key:tuya_seed isFuzzy:0 skipCnt:0
[09-09 16:45:49 ty D][b014][simplekv.c:1168] find key:0 tuya_seed
[09-09 16:45:49 ty D][b014][simplekv.c:1194] key:tuya_seed find value.Len:80
[09-09 16:45:49 ty D][b014][simplekv.c:370] write key:tuya_seed And Value Len:80
[09-09 16:45:49 ty D][b014][simplekv.c:388] 0 key same AND size old 148 >= new 80
[09-09 16:45:49 ty D][b014][simplekv.c:416] find 0 available space
[09-09 16:45:49 ty D][b014][simplekv.c:453] reuse available space 28700
[09-09 16:45:49 ty D][b014][simplekv.c:208] update crc 854257580
[09-09 16:45:49 ty D][cdf4][smart_frame.c:2412] Start To Sync Dev:6c9108853826b21b49bvi8, dp_rept_chan:1
[09-09 16:45:49 ty D][cdf4][smart_frame.c:2802] Pack local dp, reset_flow_ctl:1,dpnum:45.
[09-09 16:45:49 ty D][cdf4][smart_frame.c:2888] Nothing To Pack
[09-09 16:45:49 ty D][cdf4][smart_frame.c:2437] OUT IS NULL
[09-09 16:45:49 ty D][cdf4][smart_frame.c:2488] Sync Finish
[09-09 16:45:49 ty D][b014][simplekv.c:357] write head to normal file success
[09-09 16:45:49 ty D][b014][simplekv.c:493] write success
[09-09 16:45:49 ty D][fc73][simplekv.c:1137] read key:p2p_pwd isFuzzy:0 skipCnt:0
[09-09 16:45:49 ty D][fc73][simplekv.c:1168] find key:9 p2p_pwd
[09-09 16:45:49 ty D][fc73][simplekv.c:1194] key:p2p_pwd find value.Len:16
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p_common.c:308] check p2p auth update or not
[09-09 16:45:49 ty D][fc73][simplekv.c:1137] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[09-09 16:45:49 ty D][fc73][simplekv.c:1168] find key:13 p2p_auth_info
[09-09 16:45:49 ty D][fc73][simplekv.c:1194] key:p2p_auth_info find value.Len:32
[09-09 16:45:49 ty D][fc73][simplekv.c:1137] read key:p2p_type isFuzzy:0 skipCnt:0
[09-09 16:45:49 ty D][fc73][simplekv.c:1168] find key:14 p2p_type
[09-09 16:45:49 ty D][fc73][simplekv.c:1194] key:p2p_type find value.Len:16
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p_common.c:371] no need update p2p_auth_info from service
[09-09 16:45:49 ty D][fc73][tuya_ipc_media_adapter.c:542] attach media info success! device:[0] channel:[0] cb:[0x53ee5c]
[09-09 16:45:49 ty I][fc73][tal_thread.c:185] thread_create name:p2p_media_recv,stackDepth:65536,totalstackDepth:2323968,priority:3
[09-09 16:45:49 ty I][fc73][tal_thread.c:185] thread_create name:p2p_session_detect,stackDepth:65536,totalstackDepth:2389504,priority:3
[09-09 16:45:49 ty I][fc73][tal_thread.c:185] thread_create name:p2p_media_send,stackDepth:65536,totalstackDepth:2455040,priority:3
[09-09 16:45:49 ty I][fc73][tal_thread.c:185] thread_create name:p2p_cmd_recv,stackDepth:65536,totalstackDepth:2520576,priority:3
[09-09 16:45:49 ty I][fc73][tal_thread.c:185] thread_create name:p2p_cmd_send,stackDepth:65536,totalstackDepth:2586112,priority:3
[09-09 16:45:49 ty D][fc73][tuya_ipc_p2p.c:5384] P2P init success
[09-09 16:45:49 ty D][fc73][tuya_ipc_webrtc.c:1833] begin___
[09-09 16:45:49 ty D][fc73][tuya_ipc_media_adapter.c:542] attach media info success! device:[0] channel:[0] cb:[0x5a5184]
[09-09 16:45:49 ty D][fc73][tuya_ipc_webrtc.c:1781] webrtc playback start_id 5
[09-09 16:45:49 ty E][fc73][tuya_ipc_streamer.c:1623] tstream init start
Audio In GetGain    gain : 31
[09-09 16:45:49 ty D][fc73][tuya_ipc_packager.c:72] get packager instance
[09-09 16:45:49 ty D][a374][tal_thread.c:209] Thread:p2p_media_send Exec Start. Set to Running Stat 0x68a374e0
[09-09 16:45:49 ty D][a374][tuya_ipc_p2p.c:4574] into p2p video send
[09-09 16:45:49 ty D][a374][tuya_ipc_p2p.c:4581] media send proc alive [0]
[09-09 16:45:49 ty D][2374][tal_thread.c:209] Thread:p2p_session_det Exec Start. Set to Running Stat 0x692374e0
[09-09 16:45:49 ty D][2374][tuya_ipc_p2p.c:4919] Begin to session detect
[09-09 16:45:49 ty D][a374][tal_thread.c:209] Thread:p2p_media_recv Exec Start. Set to Running Stat 0x69a374e0
[09-09 16:45:49 ty D][a374][tuya_ipc_p2p.c:2430] media recv proc alive [0]
[09-09 16:45:49 ty D][20e4][tuya_lan_sock.c:127] reg lan sock 9,read:0x537e4c
[09-09 16:45:49 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","is_pre":0,"moto_id":"","p2p_skill":1635,"path":"mqtt","security_level":3,"sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"offer"},"msg":{"log":{"api":"thing.m.rtc.log","interval":60,"level":2,"size":1024,"tcp":{"address":"47.101.63.221","domain":"wework-9-cn.stream.iot-11.com","key":"6e9d446e4a2d2cdc","port":9093},"topic":"/av/moto/log"},"preconnect":true,"sdp":"v=0\r\no=- 1757407548 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9108853826b21b49bvi817574075484NXzBpr3\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:xuIF\r\na=ice-pwd:q0wEF3MQweOxTn76uoKutgGc\r\na=ice-options:trickle\r\na=aes-key:764a526b484e79564f4a764b78484652\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay17466220669
[09-09 16:45:49 ty D][a0e4][tuya_ipc_mqtt_subscribe.c:213] recv mq: protocol 302
[09-09 16:45:49 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:252120008 1 UDP 2130706431 fe80::500f:20ff:fe66:bac5 41836 typ host\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:49 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:2065400564 1 UDP 2130706431 192.168.1.17 41836 typ host\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:49 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:249241073 1 UDP 2130706431 2409:8a55:8c1:52c0:500f:20ff:fe66:bac5 41836 typ host\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:50 ty D][a0e4][tuya_ipc_mqtt_subscribe.c:213] recv mq: protocol 302
[09-09 16:45:50 ty D][4df4][tuya_svc_mqtt_client.c:421] packet id: 5
[09-09 16:45:50 ty D][b014][simplekv.c:1137] read key:tuya_seed isFuzzy:0 skipCnt:0
[09-09 16:45:50 ty D][b014][simplekv.c:1168] find key:0 tuya_seed
[09-09 16:45:50 ty D][fc73][tuya_ipc_packager.c:81] get packager instance done
[09-09 16:45:50 ty D][a374][tal_thread.c:209] Thread:p2p_cmd_send Exec Start. Set to Running Stat 0x67a374e0
[09-09 16:45:50 ty D][2374][tal_thread.c:209] Thread:p2p_cmd_recv Exec Start. Set to Running Stat 0x682374e0
[09-09 16:45:50 ty D][2374][tuya_ipc_p2p.c:4230] session cmd recv proc alive [0] num[0]
[09-09 16:45:50 ty D][a374][tuya_ipc_p2p.c:4311] session cmd send proc alive [0] num[0]
[09-09 16:45:50 ty D][b014][simplekv.c:1194] key:tuya_seed find value.Len:80
[09-09 16:45:50 ty D][fc73][simplekv.c:1137] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[09-09 16:45:50 ty D][fc73][simplekv.c:1168] find key:15 cloud_enc_key
[09-09 16:45:50 ty D][fc73][simplekv.c:1194] key:cloud_enc_key find value.Len:32
[09-09 16:45:50 ty D][fc73][tuya_ipc_media_adapter.c:154] alloc resource success: user handle [0xa419e0][0 KB], user num [1] res[5000]
[09-09 16:45:50 ty I][fc73][tal_thread.c:185] thread_create name:streamer,stackDepth:8192,totalstackDepth:2594304,priority:3
[09-09 16:45:50 ty E][fc73][tuya_ipc_streamer.c:1695] tstream init done
[09-09 16:45:50 ty D][fc73][tuya_ipc_streamer.c:1591] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":2,\"sampleRate\":90000,\"profileId\":\"\",\"width\":2304,\"height\":1296},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":16000,\"dataBit\":16,\"channels\":1}]
[09-09 16:45:50 ty D][fc73][tuya_ipc_media_adapter.c:542] attach media info success! device:[0] channel:[0] cb:[0x5eae3c]
[09-09 16:45:50 ty D][fc73][tuya_tmm_link.c:707] add encoder(0)
[09-09 16:45:50 ty D][fc73][tuya_tmm_link.c:707] add encoder(1)
[09-09 16:45:50 ty D][fc73][tuya_tmm_link.c:746] add encoder(9)
[09-09 16:45:50 ty D][fc73][tuya_tmm_link.c:945] tmm skill --:{"producerStr":{"v":[{"cT":2,"sR":90000,"pId":1,"w":2304,"h":1296,"sT":2},{"cT":2,"sR":90000,"pId":1,"w":640,"h":360,"sT":4}],"a":[{"cT":101,"sR":16000,"dB":16,"ch":0,"sT":1}]},"consumerStr":{"v":[],"a":[{"cT":101,"sR":16000,"dB":16}]}}
[09-09 16:45:50 ty D][fc73][tuya_tmm_link.c:953] TMM uninit dev list
[09-09 16:45:50 ty D][fc73][ty_sdk_media_callback.c:759] media stream init result is 0
[09-09 16:45:50 ty D][fc73][tuya_ipc_event.c:1931] init with max:1
[09-09 16:45:50 ty I][fc73][tal_thread.c:185] thread_create name:event,stackDepth:131072,totalstackDepth:2725376,priority:3
[09-09 16:45:50 ty D][fc73][main.c:716] event module init result is 0
[09-09 16:45:50 ty D][fc73][ty_sdk_sd_card.c:265] s_sd_mount_path =
[09-09 16:45:50 ty D][fc73][main.c:567] Init Stream_Storage SD:/tmp/
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:1808935521 1 UDP 2130706431 2409:8a55:8c1:52c0:908:c958:b0ef:a8f 41836 typ host\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:357666007 1 UDP 1694498815 120.235.186.91 3266 typ srflx\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:872146317 1 UDP 16777215 47.103.17.244 53736 typ relay\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":""}},"protocol":302,"t":1757407549}
[09-09 16:45:50 ty D][fc73][tuya_ipc_stream_storage.c:1242] Init tuya_ipc_ss_init
[09-09 16:45:50 ty D][fc73][tuya_ipc_stream_storage.c:1316] Init stream_storage.base_path:/tmp/ v:2 a:101, max event per day 500, max during 600
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:304] stream_enable:1 1 0
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:305] fps:25
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:306] gop:25
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:307] bitrate:1536 kbps
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:308] video_main_width:2304
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:309] video_main_height:1296
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:310] video_freq:90000
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:311] video_codec:2
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:313] audio_codec:101
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:314] audio_sample:16000
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:315] audio_databits:16
[09-09 16:45:50 ty D][fc73][tuya_ipc_ss_util.c:316] audio_channel:0
[09-09 16:45:50 ty D][fc73][tuya_ipc_media_adapter.c:542] attach media info success! device:[0] channel:[0] cb:[0x51de34]
[09-09 16:45:50 ty D][fc73][tuya_ipc_stream_storage.c:1352] gw actived
[09-09 16:45:50 ty D][1574][tal_thread.c:209] Thread:streamer Exec Start. Set to Running Stat 0x671574e0
[09-09 16:45:50 ty D][1574][tuya_ipc_streamer.c:1403] __thread_streaming thread start
[09-09 16:45:50 ty D][9574][tal_thread.c:209] Thread:event Exec Start. Set to Running Stat 0x669574e0
[09-09 16:45:50 ty D][9574][tuya_ipc_event.c:1191] gw actived
[09-09 16:45:50 ty D][b014][simplekv.c:370] write key:tuya_seed And Value Len:80
[09-09 16:45:50 ty D][b014][simplekv.c:388] 0 key same AND size old 148 >= new 80
[09-09 16:45:50 ty D][3214][tuya_ring_buffer.c:780] ch0st0tr9 open with type 1
[09-09 16:45:50 ty D][b014][simplekv.c:416] find 0 available space
[09-09 16:45:50 ty D][b014][simplekv.c:453] reuse available space 28700
[09-09 16:45:50 ty D][b014][simplekv.c:208] update crc 815660073
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","is_pre":1,"moto_id":"","p2p_skill":1635,"path":"mqtt","security_level":3,"sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"offer"},"msg":{"log":{"api":"thing.m.rtc.log","interval":60,"level":2,"size":1024,"tcp":{"address":"47.101.63.221","domain":"wework-9-cn.stream.iot-11.com","key":"6e9d446e4a2d2cdc","port":9093},"topic":"/av/moto/log"},"preconnect":true,"sdp":"v=0\r\no=- 1757407548 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9108853826b21b49bvi81757407548LaA34kjv\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:UC3d\r\na=ice-pwd:jVfbumfvxI109D5AkTairSkv\r\na=ice-options:trickle\r\na=aes-key:6475434d4e7178466361425873415830\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay1746622066937sx1YA\r\n","tcp_token":{"credential":"hVjDYgJS+0YzpLdkEI2FA7aLZIw=","do
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1324465740 1 UDP 2130706431 fe80::500f:20ff:fe66:bac5 44628 typ host\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1560030202 1 UDP 2130706431 192.168.1.17 44628 typ host\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:725876156 1 UDP 2130706431 2409:8a55:8c1:52c0:500f:20ff:fe66:bac5 44628 typ host\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1038635519 1 UDP 2130706431 2409:8a55:8c1:52c0:908:c958:b0ef:a8f 44628 typ host\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1130414197 1 UDP 1694498815 120.235.186.91 3273 typ srflx\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:905595773 1 UDP 16777215 47.103.17.244 62907 typ relay\r\n"}},"protocol":302,"t":1757407549}
[09-09 16:45:50 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":""}},"protocol":302,"t":1757407549}
[09-09 16:45:51 ty D][a0e4][tuya_ipc_mqtt_subscribe.c:213] recv mq: protocol 302
[09-09 16:45:51 ty D][a0e4][mqc_app.c:1383] custom async cb op_ret: 0
[09-09 16:45:51 ty D][b014][simplekv.c:357] write head to normal file success
[09-09 16:45:51 ty D][b014][simplekv.c:493] write success
[09-09 16:45:51 ty D][b014][simplekv.c:1137] read key:tuya_seed isFuzzy:0 skipCnt:0
[09-09 16:45:51 ty D][b014][simplekv.c:1168] find key:0 tuya_seed
[09-09 16:45:51 ty D][b014][simplekv.c:1194] key:tuya_seed find value.Len:80
[09-09 16:45:51 ty D][4df4][mqc_app.c:1445] pub finish:0
[09-09 16:45:51 ty D][4df4][simplekv.c:1137] read key:e1mtcgtk_ver isFuzzy:0 skipCnt:0
[09-09 16:45:51 ty D][4df4][simplekv.c:1165] no key find
[09-09 16:45:51 ty D][4df4][simplekv.c:1207] __read_kv_raw fail. -3
[09-09 16:45:51 ty D][4df4][simplekv.c:1246] __read_kv_with_decode fail. -3
[09-09 16:45:51 ty D][4df4][tuya_svc_schema_upgrade.c:218] schema[e1mtcgtk] not updated since activated
[09-09 16:45:51 ty D][20e4][tuya_svc_lan.c:1763] new client connect. nums:1 cfd:24 ip:0xc0a80111
[09-09 16:45:51 ty D][20e4][tuya_lan_sock.c:331] reg post queue 24
[09-09 16:45:51 ty D][20e4][tuya_lan_sock.c:127] reg lan sock 24,read:0x539eb8
[09-09 16:45:51 ty D][20e4][tuya_svc_lan.c:1697] fd:24, wk_stat = 2, type = 3
[09-09 16:45:51 ty D][9574][simplekv.c:1137] read key:event_spec_info isFuzzy:0 skipCnt:0
[09-09 16:45:51 ty D][9574][simplekv.c:1168] find key:18 event_spec_info
[09-09 16:45:51 ty D][9574][simplekv.c:1194] key:event_spec_info find value.Len:3168
[09-09 16:45:51 ty E][9574][tuya_ipc_event.c:259] get type array cnt:93
[09-09 16:45:51 ty D][fc73][simplekv.c:1137] read key:md5_encrypt_key isFuzzy:0 skipCnt:0
[09-09 16:45:51 ty D][fc73][simplekv.c:1168] find key:17 md5_encrypt_key
[09-09 16:45:51 ty D][fc73][simplekv.c:1194] key:md5_encrypt_key find value.Len:144
[09-09 16:45:51 ty D][fc73][tuya_ipc_ss_encrypt.c:145] read buf:{"md5_value":"MTAwYjMyMTI0ODc4NzcxY2RiYzEzZjgzMzVhMDQxZjk=","md5_len":32,"encrypt_key_value":"NGI0NTI0ZWM1Y2Q2NGZiOA==","encrypt_key_len":16 }
[09-09 16:45:51 ty D][fc73][tuya_ipc_ss_encrypt.c:187] read buf:{"md5_value":"MTAwYjMyMTI0ODc4NzcxY2RiYzEzZjgzMzVhMDQxZjk=","md5_len":32,"encrypt_key_value":"NGI0NTI0ZWM1Y2Q2NGZiOA==","encrypt_key_len":16 }
[09-09 16:45:51 ty D][fc73][tuya_ipc_ss_encrypt.c:197] gw base read success
[09-09 16:45:51 ty D][fc73][tuya_ipc_ss_encrypt.c:250] encrypt key 4b4524ec5cd64fb8 len 16 and md5 check pass
[09-09 16:45:51 ty D][fc73][tuya_ipc_ss_encrypt.c:499] use current encrypt key
[09-09 16:45:51 ty D][fc73][tuya_ipc_ss_encrypt.c:292] get_gw_uuid uuid5f82e0aa8891be2b
[09-09 16:45:51 ty D][fc73][tuya_ipc_ss_encrypt.c:533] encrypt_mode 0 security_level 3
[09-09 16:45:51 ty E][fc73][tuya_ipc_stream_storage.c:1432] disable aov local storage,stor_format:0,aov_on:0
[09-09 16:45:51 ty D][fc73][tuya_ipc_stream_storage.c:1436]  to start disk monitor
[09-09 16:45:51 ty I][fc73][tal_thread.c:185] thread_create name:disk_monitor,stackDepth:8192,totalstackDepth:2733568,priority:3
[09-09 16:45:51 ty D][fc73][tuya_ipc_stream_storage.c:1472] stream storage task init success
[09-09 16:45:51 ty D][fc73][main.c:722] local storage init result is 0
[09-09 16:45:51 ty D][fc73][tuya_ipc_video_msg.c:623] init video msg begin
[09-09 16:45:51 ty D][fc73][tuya_ring_buffer.c:780] ch0st0tr0 open with type 0
[09-09 16:45:51 ty D][fc73][tuya_ring_buffer.c:780] ch0st0tr9 open with type 0
[09-09 16:45:51 ty I][fc73][tal_thread.c:185] thread_create name:video_msg,stackDepth:131072,totalstackDepth:2864640,priority:3
[09-09 16:45:51 ty D][fc73][tuya_ipc_media_adapter.c:542] attach media info success! device:[0] channel:[0] cb:[0x5db5ec]
[09-09 16:45:51 ty D][fc73][tuya_ipc_video_msg.c:724] init video msg success
[09-09 16:45:51 ty D][fc73][main.c:728] door bell init result is 0
[09-09 16:45:51 ty D][fc73][tuya_ipc_rule.c:2542] tuya_ipc_rule_init begin
[09-09 16:45:51 ty D][fc73][tuya_ipc_media_upload.c:622] tuya_ipc_media_upload_init begin
[09-09 16:45:51 ty I][fc73][tal_thread.c:185] thread_create name:media_upload_func,stackDepth:32768,totalstackDepth:2897408,priority:3
[09-09 16:45:51 ty D][fc73][tuya_ipc_media_upload.c:649] tuya_ipc_media_upload_init success
[09-09 16:45:51 ty D][fc73][tuya_ipc_media_gateway.c:2807] media gateway init begin
[09-09 16:45:51 ty D][fc73][tuya_ipc_media_gateway.c:2847] media gateway seize 315392 memory for send buffer
[09-09 16:45:51 ty D][fc73][tuya_ipc_media_gateway.c:2863] media gateway seize 8192 memory for recv buffer
[09-09 16:45:51 ty I][fc73][tal_thread.c:185] thread_create name:media_gateway_func,stackDepth:16384,totalstackDepth:2913792,priority:3
[09-09 16:45:51 ty D][fc73][tuya_ipc_media_gateway.c:2881] media gateway init success
[09-09 16:45:51 ty I][fc73][tal_thread.c:185] thread_create name:rule_func,stackDepth:32768,totalstackDepth:2946560,priority:3
[09-09 16:45:51 ty D][fc73][tuya_ipc_rule.c:2613] tuya_ipc_rule_init success
[09-09 16:45:51 ty D][fc73][main.c:733] cloud rule init result is 0
[09-09 16:45:51 ty D][fc73][tuya_ipc_cloud_storage.c:2045] init ipc cloud storage begin
[09-09 16:45:51 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","is_pre":0,"moto_id":"","p2p_skill":1635,"path":"mqtt","security_level":3,"sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"offer"},"msg":{"log":{"api":"thing.m.rtc.log","interval":60,"level":2,"size":1024,"tcp":{"address":"47.101.63.221","domain":"wework-9-cn.stream.iot-11.com","key":"6e9d446e4a2d2cdc","port":9093},"topic":"/av/moto/log"},"preconnect":true,"sdp":"v=0\r\no=- 1757407548 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9108853826b21b49bvi817574075484NXzBpr3\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:xuIF\r\na=ice-pwd:q0wEF3MQweOxTn76uoKutgGc\r\na=ice-options:trickle\r\na=aes-key:764a526b484e79564f4a764b78484652\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay17466220669
[09-09 16:45:51 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:252120008 1 UDP 2130706431 fe80::500f:20ff:fe66:bac5 41836 typ host\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:51 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:2065400564 1 UDP 2130706431 192.168.1.17 41836 typ host\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:51 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:249241073 1 UDP 2130706431 2409:8a55:8c1:52c0:500f:20ff:fe66:bac5 41836 typ host\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:51 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:1808935521 1 UDP 2130706431 2409:8a55:8c1:52c0:908:c958:b0ef:a8f 41836 typ host\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:51 ty D][20e4][tuya_svc_lan.c:1697] fd:24, wk_stat = 2, type = 5
[09-09 16:45:51 ty D][20e4][tuya_svc_lan.c:1281] hmac randB lo 32 <0xa67588>
23 97 8b 10 44 5c 74 e6 d6 d0 b2 2b e5 e0 25 bc 61 c0 7c 61 34 b3 47 89 1b a9 eb 78 76 fc 23 9b
[09-09 16:45:51 ty D][20e4][tuya_svc_lan.c:1282] hmac randB in 32 <0xa67560>
[09-09 16:45:51 ty D][20e4][tuya_svc_lan.c:1697] fd:24, wk_stat = 2, type = 16
[09-09 16:45:51 ty D][20e4][smart_frame.c:2802] Pack local dp, reset_flow_ctl:0,dpnum:45.
[09-09 16:45:51 ty D][20e4][smart_frame.c:2888] Nothing To Pack
[09-09 16:45:51 ty D][20e4][tuya_svc_lan.c:1365] nothing to report
[09-09 16:45:51 ty D][4df4][tuya_svc_mqtt_client.c:421] packet id: 6
[09-09 16:45:51 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436350493,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_create","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"h":0,"lk":611,"rk":1635,"c":"kcp","ice":[{"urls":"stun:47.103.17.244:3478"},{"credential":"UDhzF5iXfENDQEnTLs636b4xvew=","ttl":36000,"urls":"turn:47.103.17.244:3478","username":"1757443071:6c9108853826b21b49bvi8"}],"tcp":{"credential":"UDhzF5iXfENDQEnTLs636b4xvew=","domain":"wework-6-cn.stream.iot-11.com","sessionId":"6c9108853826b21b49bvi81757407548Uz4jTvr4","urls":["tcp4:106.15.73.202:1443"],"username":"1757443071:6c9108853826b21b49bvi8"}}
[09-09 16:45:51 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:45:51 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436351175,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_state","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":1,"as":2,"h":1,"e":0,"ex":0,"d":683}
[09-09 16:45:51 ty D][1574][tal_thread.c:209] Thread:disk_monitor Exec Start. Set to Running Stat 0x661574e0
[09-09 16:45:51 ty D][1574][tuya_ipc_stream_storage.c:948] SD task begin___
[09-09 16:45:51 ty D][1574][tuya_ipc_stream_storage.c:957] report sd status 0 -> 5
[09-09 16:45:51 ty D][fc73][tuya_ipc_cloud_storage_common.c:96] read buf:{"md5_value":"MTAwYjMyMTI0ODc4NzcxY2RiYzEzZjgzMzVhMDQxZjk=","md5_len":32,"encrypt_key_value":"NGI0NTI0ZWM1Y2Q2NGZiOA==","encrypt_key_len":16 }
[09-09 16:45:52 ty D][fc73][simplekv.c:1137] read key:md5_encrypt_key isFuzzy:0 skipCnt:0
[09-09 16:45:52 ty D][fc73][simplekv.c:1168] find key:17 md5_encrypt_key
[09-09 16:45:52 ty D][fc73][simplekv.c:1194] key:md5_encrypt_key find value.Len:144
[09-09 16:45:52 ty D][fc73][tuya_ipc_cloud_storage_common.c:138] read buf:{"md5_value":"MTAwYjMyMTI0ODc4NzcxY2RiYzEzZjgzMzVhMDQxZjk=","md5_len":32,"encrypt_key_value":"NGI0NTI0ZWM1Y2Q2NGZiOA==","encrypt_key_len":16 }
[09-09 16:45:52 ty D][fc73][tuya_ipc_cloud_storage_common.c:148] gw base read success
[09-09 16:45:52 ty D][fc73][tuya_ipc_cloud_storage_common.c:201] encrypt key and md5 check pass
[09-09 16:45:52 ty D][fc73][tuya_ipc_cloud_storage.c:1906] use current encrypt key
[09-09 16:45:52 ty I][fc73][tal_thread.c:185] thread_create name:cloud_storage0,stackDepth:65536,totalstackDepth:3012096,priority:3
[09-09 16:45:52 ty D][fc73][tuya_ipc_media_adapter.c:542] attach media info success! device:[0] channel:[0] cb:[0x4f05a4]
[09-09 16:45:52 ty D][fc73][tuya_ipc_dev_manager.c:287] handler cloud storage init event
[09-09 16:45:52 ty D][fc73][tuya_ipc_cloud_storage.c:2089] init cloud storage success
[09-09 16:45:52 ty D][fc73][main.c:619] Set pre-record time to [2], [success]
[09-09 16:45:52 ty D][1574][tal_thread.c:209] Thread:media_upload_fu Exec Start. Set to Running Stat 0x651574e0
[09-09 16:45:52 ty D][9574][tal_thread.c:209] Thread:video_msg Exec Start. Set to Running Stat 0x659574e0
[09-09 16:45:52 ty D][1094][tal_thread.c:209] Thread:rule_func Exec Start. Set to Running Stat 0x641094e0
[09-09 16:45:52 ty D][1094][simplekv.c:1137] read key:dynamic_rule isFuzzy:0 skipCnt:0
[09-09 16:45:52 ty D][1094][simplekv.c:1168] find key:19 dynamic_rule
[09-09 16:45:52 ty D][1094][simplekv.c:1194] key:dynamic_rule find value.Len:16
[09-09 16:45:52 ty D][1094][tuya_ipc_rule.c:1091] local rule size: 0
[09-09 16:45:52 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:357666007 1 UDP 1694498815 120.235.186.91 3266 typ srflx\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:52 ty D][a0e4][tuya_ipc_mqtt_subscribe.c:213] recv mq: protocol 302
[09-09 16:45:52 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":"a=candidate:872146317 1 UDP 16777215 47.103.17.244 53736 typ relay\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:52 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","to":"6c9108853826b21b49bvi8","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","type":"candidate"},"msg":{"candidate":""}},"protocol":302,"t":1757407551}
[09-09 16:45:52 ty D][1574][smart_frame.c:3982] rept chan:3
[09-09 16:45:52 ty D][1574][smart_frame.c:418] dp<110> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:1
[09-09 16:45:52 ty D][1574][smart_frame.c:438] dp_cntl value:0, dp_data value:5
[09-09 16:45:52 ty D][1574][smart_frame.c:544] is_need_update:1, is_dp_passive:0, pv_stat:2, uling_cnt:0
[09-09 16:45:52 ty D][1574][smart_frame.c:2549] dp rept_type:0, data:{"110":5}
[09-09 16:45:52 ty D][1574][mqc_app.c:800] Send MQTT Msg.P:4 N:28578 Q:1 Data:{"dps":{"110":5}}
[09-09 16:45:52 ty D][1574][tuya_svc_mqtt_client.c:421] packet id: 7
[09-09 16:45:52 ty E][1574][tuya_ipc_stream_storage.c:441] storage not inited
[09-09 16:45:52 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:45:52 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:45:52 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28579 Q:0
[09-09 16:45:52 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 8
[09-09 16:45:52 ty D][cdf4][com_protocol.c:758] To:0 src:{"dps":{"110":5}} pro:4 num:28578
[09-09 16:45:52 ty D][cdf4][com_protocol.c:773] After Pack:{"protocol":4,"t":1757407552,"data":{"dps":{"110":5}}} offset:54
[09-09 16:45:52 ty D][cdf4][tuya_svc_lan.c:1067] Prepare To Send Lan:{"dps":{"110":5}}, msg_len:17, out_len:69
[09-09 16:45:52 ty D][ae14][mqc_app.c:800] Send MQTT Msg.P:302 N:28577 Q:0 Data:{"header":{"from":"6c9108853826b21b49bvi8","to":"ay1746622066937sx1YA","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","moto_id":"","type":"answer","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","is_pre":0,"p2p_skill":611,"security_level":3,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 1757436351 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9108853826b21b49bvi817574075484NXzBpr3\r\nm=application 9 tuya 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:dlhJ\r\na=ice-pwd:VwP4fLGqM0ROSGRHOpLsQ13x\r\na=ice-options:trickle\r\na=aes-key:764a526b484e79564f4a764b78484652\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 3\r\na=ssrc:0 cname:6c9108853826b21b49bvi8\r\n","preconnect":true,"token":[{"urls":"stun:47.103.17.244:3478"},{"credential":"UDhzF5iXfENDQEnTLs636b4xvew=","ttl":36000,"urls":"turn:47.103.17.244:3478","username":"1757443071:6c9108853826
[09-09 16:45:52 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436351183,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:252120008 1 UDP 2130706431 fe80::500f:20ff:fe66:bac5 41836 typ host\r\n","d":691}
[09-09 16:45:52 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436351850,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:2065400564 1 UDP 2130706431 192.168.1.17 41836 typ host\r\n","d":1358}
[09-09 16:45:52 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:45:52 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436351851,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:249241073 1 UDP 2130706431 2409:8a55:8c1:52c0:500f:20ff:fe66:bac5 41836 typ host\r\n","d":1359}
[09-09 16:45:52 ty E][b214][tuya_imm_service_log.c:104] DROP LOG, total_len:1092, max_len:1024
[09-09 16:45:52 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436351852,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1808935521 1 UDP 2130706431 2409:8a55:8c1:52c0:908:c958:b0ef:a8f 41836 typ host\r\n","d":1360}
[09-09 16:45:52 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436352184,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:357666007 1 UDP 1694498815 120.235.186.91 3266 typ srflx\r\n","d":1692}
[09-09 16:45:52 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436352185,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:872146317 1 UDP 16777215 47.103.17.244 53736 typ relay\r\n","d":1693}
[09-09 16:45:52 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436352186,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"","d":1694}
[09-09 16:45:52 ty D][20e4][tuya_svc_lan.c:1697] fd:24, wk_stat = 2, type = 7
[09-09 16:45:52 ty D][20e4][tuya_svc_lan.c:1161] JSON string:{"data":{"devId":"6c9108853826b21b49bvi8","dps":{"208":null},"t":1757407551,"uid":"ay1746622066937sx1YA"},"protocol":5,"t":1757407551}
[09-09 16:45:52 ty D][20e4][tuya_svc_lan.c:1186] Rev TP CMD. Send to User,Lan Ver 3.5
[09-09 16:45:52 ty D][fc73][main.c:739] cloud storage init result is 0
[09-09 16:45:52 ty I][fc73][ty_sdk_dp_handler.c:200] curr sleep_mode:0
[09-09 16:45:52 ty D][cdf4][smart_frame.c:1180] Rev Cmd 0, data:0xa41eb8
[09-09 16:45:52 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","is_pre":1,"moto_id":"","p2p_skill":1635,"path":"mqtt","security_level":3,"sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"offer"},"msg":{"log":{"api":"thing.m.rtc.log","interval":60,"level":2,"size":1024,"tcp":{"address":"47.101.63.221","domain":"wework-9-cn.stream.iot-11.com","key":"6e9d446e4a2d2cdc","port":9093},"topic":"/av/moto/log"},"preconnect":true,"sdp":"v=0\r\no=- 1757407548 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9108853826b21b49bvi81757407548LaA34kjv\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:UC3d\r\na=ice-pwd:jVfbumfvxI109D5AkTairSkv\r\na=ice-options:trickle\r\na=aes-key:6475434d4e7178466361425873415830\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay1746622066937sx1YA\r\n","tcp_token":{"credential":"hVjDYgJS+0YzpLdkEI2FA7aLZIw=","do
[09-09 16:45:52 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1324465740 1 UDP 2130706431 fe80::500f:20ff:fe66:bac5 44628 typ host\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:52 ty D][9094][tal_thread.c:209] Thread:cloud_storage0 Exec Start. Set to Running Stat 0x639094e0
[09-09 16:45:52 ty D][9094][tuya_ipc_cloud_storage.c:1425] [] cloud storage task start
[09-09 16:45:52 ty D][9094][tal_thread.c:209] Thread:media_gateway_f Exec Start. Set to Running Stat 0x649094e0
[09-09 16:45:53 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:45:53 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:45:53 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28580 Q:0
[09-09 16:45:53 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 9
[09-09 16:45:53 ty D][9094][tuya_ring_buffer.c:780] ch0st0tr0 open with type 0
[09-09 16:45:53 ty D][9094][tuya_ring_buffer.c:780] ch0st0tr9 open with type 0
[09-09 16:45:53 ty D][9094][tuya_ipc_cloud_storage.c:1449] rule_store_mode:2
[09-09 16:45:53 ty D][9094][iot_httpc.c:973] Post Data: {"type":"MediaStor","t":1757407553}
[09-09 16:45:53 ty D][9094][iot_httpc.c:985] Post URL: https://a6.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c9108853826b21b49bvi8&et=3&t=1757407553&v=3.0&sign=8bd9074e04dc6186a6928cd9750589fa
[09-09 16:45:53 ty D][fc73][smart_frame.c:3982] rept chan:3
[09-09 16:45:53 ty D][fc73][smart_frame.c:418] dp<105> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0
[09-09 16:45:53 ty D][fc73][smart_frame.c:422] dp_cntl bool:0, dp_data bool:0
[09-09 16:45:53 ty D][fc73][smart_frame.c:544] is_need_update:1, is_dp_passive:0, pv_stat:2, uling_cnt:0
[09-09 16:45:53 ty D][fc73][smart_frame.c:2549] dp rept_type:0, data:{"105":false}
[09-09 16:45:53 ty D][fc73][mqc_app.c:800] Send MQTT Msg.P:4 N:28581 Q:1 Data:{"dps":{"105":false}}
[09-09 16:45:53 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1560030202 1 UDP 2130706431 192.168.1.17 44628 typ host\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:53 ty D][a0e4][tuya_ipc_mqtt_subscribe.c:213] recv mq: protocol 302
[09-09 16:45:53 ty D][cdf4][com_protocol.c:758] To:0 src:{"dps":{"105":false}} pro:4 num:28581
[09-09 16:45:53 ty D][cdf4][com_protocol.c:773] After Pack:{"protocol":4,"t":1757407553,"data":{"dps":{"105":false}}} offset:58
[09-09 16:45:53 ty D][cdf4][tuya_svc_lan.c:1067] Prepare To Send Lan:{"dps":{"105":false}}, msg_len:21, out_len:73
[09-09 16:45:53 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:45:53 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436352192,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_tcp_state","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":0,"d":1700,"th":{"tconn":0,"tresp":0,"tcomp":0}}
[09-09 16:45:53 ty E][b214][tuya_imm_service_log.c:104] DROP LOG, total_len:1295, max_len:1024
[09-09 16:45:53 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436352527,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_ice_state","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":0,"d":2035,"ih":{"ha":true,"hlc":false,"hlh":false,"hls":false,"hlr":false,"hrc":true,"hrh":true,"hrs":true,"hrr":true}}
[09-09 16:45:53 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436352529,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_local","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1399903401 1 UDP 2130706431 192.168.1.171 50458 typ host\r\n","d":2037}
[09-09 16:45:53 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436352861,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_ice_state","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":1,"d":2369,"ih":{"ha":true,"hlc":true,"hlh":true,"hls":false,"hlr":false,"hrc":true,"hrh":true,"hrs":true,"hrr":true}}
[09-09 16:45:53 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28582 Q:0
[09-09 16:45:53 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 11
[09-09 16:45:53 ty D][fc73][tuya_svc_mqtt_client.c:421] packet id: 10
[09-09 16:45:53 ty I][fc73][ty_sdk_dp_handler.c:220] curr light_on_off:0
[09-09 16:45:53 ty D][fc73][smart_frame.c:418] dp<101> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0
[09-09 16:45:53 ty D][fc73][smart_frame.c:2549] dp rept_type:0, data:{"101":false}
[09-09 16:45:53 ty D][cdf4][com_protocol.c:758] To:0 src:{"dps":{"101":false}} pro:4 num:28584
[09-09 16:45:53 ty D][cdf4][com_protocol.c:773] After Pack:{"protocol":4,"t":1757407553,"data":{"dps":{"101":false}}} offset:58
[09-09 16:45:53 ty D][cdf4][tuya_svc_lan.c:1067] Prepare To Send Lan:{"dps":{"101":false}}, msg_len:21, out_len:73
[09-09 16:45:53 ty D][9094][httpc.c:623] Connect: a6.tuyacn.com Port: 443  -->>
[09-09 16:45:53 ty D][9094][tcp_transporter.c:37] dns mode by ip 2
[09-09 16:45:53 ty D][9094][uni_network.c:230] unw_gethostbyname a6.tuyacn.com, prio 1
[09-09 16:45:53 ty D][9094][uni_network.c:246] use dynamic dns ip:47.116.198.59 for domain:a6.tuyacn.com
[09-09 16:45:53 ty D][9094][tcp_transporter.c:44] DNS parse type:2
[09-09 16:45:53 ty D][9094][tcp_transporter.c:85] bind  port:0 ok
[09-09 16:45:53 ty D][ae14][mqc_app.c:800] Send MQTT Msg.P:302 N:28583 Q:0 Data:{"header":{"from":"6c9108853826b21b49bvi8","to":"ay1746622066937sx1YA","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","moto_id":"","type":"candidate","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","path":"mqtt"},"msg":{"candidate":"a=candidate:1399903401 1 UDP 2130706431 192.168.1.171 50458 typ host\r\n"}}
[09-09 16:45:53 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:725876156 1 UDP 2130706431 2409:8a55:8c1:52c0:500f:20ff:fe66:bac5 44628 typ host\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:53 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1038635519 1 UDP 2130706431 2409:8a55:8c1:52c0:908:c958:b0ef:a8f 44628 typ host\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:53 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1130414197 1 UDP 1694498815 120.235.186.91 3273 typ srflx\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:53 ty D][fc73][mqc_app.c:800] Send MQTT Msg.P:4 N:28584 Q:1 Data:{"dps":{"101":false}}
[09-09 16:45:53 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28585 Q:0
[09-09 16:45:53 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436352881,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_local","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1436326476 1 UDP 1694498815 120.235.186.91 3284 typ srflx\r\n","d":2389}
[09-09 16:45:53 ty D][9094][tuya_tls.c:979] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1
[09-09 16:45:53 ty D][9094][tuya_tls.c:988] TUYA_TLS Begin Connect a6.tuyacn.com:443
[09-09 16:45:53 ty D][9094][tuya_tls.c:738] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED
[09-09 16:45:53 ty D][9094][tuya_tls.c:751] load tuya cert.
[09-09 16:45:53 ty D][9094][tuya_cert_manager.c:213] p_url:a6.tuyacn.com, rcs.urlx:h6.iot-dns.com
[09-09 16:45:53 ty D][9094][tuya_cert_manager.c:236] tuya public url
[09-09 16:45:53 ty D][fc73][tuya_svc_mqtt_client.c:421] packet id: 12
[09-09 16:45:53 ty I][fc73][ty_sdk_dp_handler.c:240] curr flip_on_off:0
[09-09 16:45:53 ty D][fc73][smart_frame.c:418] dp<103> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0
[09-09 16:45:53 ty D][fc73][smart_frame.c:2549] dp rept_type:0, data:{"103":false}
[09-09 16:45:53 ty D][cdf4][com_protocol.c:758] To:0 src:{"dps":{"103":false}} pro:4 num:28587
[09-09 16:45:53 ty D][cdf4][com_protocol.c:773] After Pack:{"protocol":4,"t":1757407553,"data":{"dps":{"103":false}}} offset:58
[09-09 16:45:53 ty D][cdf4][tuya_svc_lan.c:1067] Prepare To Send Lan:{"dps":{"103":false}}, msg_len:21, out_len:73
[09-09 16:45:53 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 13
[09-09 16:45:53 ty D][ae14][mqc_app.c:800] Send MQTT Msg.P:302 N:28586 Q:0 Data:{"header":{"from":"6c9108853826b21b49bvi8","to":"ay1746622066937sx1YA","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","moto_id":"","type":"candidate","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","path":"mqtt"},"msg":{"candidate":"a=candidate:1436326476 1 UDP 1694498815 120.235.186.91 3284 typ srflx\r\n"}}
[09-09 16:45:53 ty D][9094][tuya_cert_manager.c:1100] parse crt <0> len <540> ret <0>
[09-09 16:45:53 ty D][9094][tuya_tls.c:1077] socket fd is set. set to inner send/recv to handshake
[09-09 16:45:53 ty D][fc73][mqc_app.c:800] Send MQTT Msg.P:4 N:28587 Q:1 Data:{"dps":{"103":false}}
[09-09 16:45:53 ty E][fc73][tuya_svc_mqtt_client.c:404] can't find free mqmde
[09-09 16:45:53 ty E][fc73][mqc_app.c:821] mqc_pub_async err:-1
[09-09 16:45:53 ty E][fc73][smart_frame.c:2642] mqtt async send err:-1
[09-09 16:45:53 ty D][fc73][smart_frame.c:2497] sync chan:3
[09-09 16:45:53 ty E][fc73][smart_frame.c:4014] dp_report err:-1
[09-09 16:45:53 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:905595773 1 UDP 16777215 47.103.17.244 62907 typ relay\r\n"}},"protocol":302,"t":1757407551}
[09-09 16:45:54 ty D][a0e4][tuya_ipc_mqtt_subscribe.c:213] recv mq: protocol 302
[09-09 16:45:54 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":""}},"protocol":302,"t":1757407551}
[09-09 16:45:54 ty D][a0e4][mqc_app.c:1383] custom async cb op_ret: 0
[09-09 16:45:54 ty D][4df4][mqc_app.c:1445] pub finish:0
[09-09 16:45:54 ty I][fc73][ty_sdk_dp_handler.c:260] curr watermark_on_off:0
[09-09 16:45:54 ty D][fc73][smart_frame.c:3982] rept chan:3
[09-09 16:45:54 ty D][fc73][smart_frame.c:418] dp<104> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0
[09-09 16:45:54 ty D][fc73][smart_frame.c:422] dp_cntl bool:0, dp_data bool:0
[09-09 16:45:54 ty D][fc73][smart_frame.c:544] is_need_update:1, is_dp_passive:0, pv_stat:2, uling_cnt:0
[09-09 16:45:54 ty D][fc73][smart_frame.c:2549] dp rept_type:0, data:{"104":false}
[09-09 16:45:54 ty D][fc73][mqc_app.c:800] Send MQTT Msg.P:4 N:28588 Q:1 Data:{"dps":{"104":false}}
[09-09 16:45:54 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436353305,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_ice_state","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":2,"d":2813,"ih":{"ha":true,"hlc":true,"hlh":true,"hls":true,"hlr":false,"hrc":true,"hrh":true,"hrs":true,"hrr":true}}
[09-09 16:45:54 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:45:54 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:45:54 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28589 Q:0
[09-09 16:45:54 ty D][cdf4][com_protocol.c:758] To:0 src:{"dps":{"104":false}} pro:4 num:28588
[09-09 16:45:54 ty D][cdf4][com_protocol.c:773] After Pack:{"protocol":4,"t":1757407554,"data":{"dps":{"104":false}}} offset:58
[09-09 16:45:54 ty D][cdf4][tuya_svc_lan.c:1067] Prepare To Send Lan:{"dps":{"104":false}}, msg_len:21, out_len:73
[09-09 16:45:54 ty D][ae14][mqc_app.c:800] Send MQTT Msg.P:302 N:28590 Q:0 Data:{"header":{"from":"6c9108853826b21b49bvi8","to":"ay1746622066937sx1YA","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","moto_id":"","type":"candidate","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","path":"mqtt"},"msg":{"candidate":""}}
[09-09 16:45:54 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:45:54 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436353557,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_state","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":3,"as":2,"h":1,"e":0,"ex":0,"d":3065}
[09-09 16:45:54 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436353560,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_add","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","ca":"","st":"new_session","e":0,"ex":0,"d":3068,"th":{"tconn":1757436353229,"tresp":0,"tcomp":0},"ih":{"ha":true,"hlc":true,"hlh":true,"hls":true,"hlr":false,"hrc":true,"hrh":true,"hrs":true,"hrr":true}}
[09-09 16:45:54 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436353894,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_create","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"h":0,"lk":611,"rk":1635,"c":"kcp","ice":[{"urls":"stun:47.103.2.131:3478"},{"credential":"hVjDYgJS+0YzpLdkEI2FA7aLZIw=","ttl":36000,"urls":"turn:47.103.17.244:3478","username":"1757443548:6c9108853826b21b49bvi8"}],"tcp":{"credential":"hVjDYgJS+0YzpLdkEI2FA7aLZIw=","domain":"wework-5-cn.stream.iot-11.com","sessionId":"6c9108853826b21b49bvi81757443548XZ2RSjvk","urls":["tcp4:47.100.110.61:1443"],"username":"1757443548:6c9108853826b21b49bvi8"}}
[09-09 16:45:54 ty D][a0e4][smart_frame.c:2102] msg_data:{"dps":{"110":5}}, mqtt async dp cb:0
[09-09 16:45:54 ty D][a0e4][smart_frame.c:216] set short dp rate rule, dpID:110, curr_t:1757407554, rept_cnt:1.
[09-09 16:45:54 ty D][a0e4][smart_frame.c:224] set long dp rate rule, dpID:110, curr_t:1757407554, rept_cnt:0.
[09-09 16:45:54 ty D][a0e4][smart_frame.c:233] set all dp rate rule, dpID:110, curr_t:1757407554, rept_cnt:0.
[09-09 16:45:54 ty D][a0e4][smart_frame.c:2102] msg_data:{"dps":{"105":false}}, mqtt async dp cb:0
[09-09 16:45:54 ty D][a0e4][smart_frame.c:216] set short dp rate rule, dpID:105, curr_t:1757407554, rept_cnt:1.
[09-09 16:45:54 ty D][a0e4][smart_frame.c:224] set long dp rate rule, dpID:105, curr_t:1757407554, rept_cnt:0.
[09-09 16:45:54 ty D][a0e4][smart_frame.c:233] set all dp rate rule, dpID:105, curr_t:1757407554, rept_cnt:0.
[09-09 16:45:54 ty D][a0e4][smart_frame.c:2102] msg_data:{"dps":{"101":false}}, mqtt async dp cb:0
[09-09 16:45:54 ty D][a0e4][smart_frame.c:216] set short dp rate rule, dpID:101, curr_t:1757407554, rept_cnt:1.
[09-09 16:45:54 ty D][a0e4][smart_frame.c:224] set long dp rate rule, dpID:101, curr_t:1757407554, rept_cnt:0.
[09-09 16:45:54 ty D][a0e4][smart_frame.c:233] set all dp rate rule, dpID:101, curr_t:1757407554, rept_cnt:0.
[09-09 16:45:54 ty D][a374][tuya_ipc_p2p.c:5130] __p2p_deal_with_listen, session[65537]
[09-09 16:45:54 ty E][a374][tuya_imm_service_log.c:104] DROP LOG, total_len:1093, max_len:1024
[09-09 16:45:54 ty D][a374][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:45:54 ty D][9094][tuya_tls.c:711] mbedtls_cert_pkey_free.
[09-09 16:45:54 ty D][9094][tuya_tls.c:1139] handshake finish for a6.tuyacn.com. set send/recv to user set
[09-09 16:45:54 ty D][9094][tuya_tls.c:1145] TUYA_TLS Success Connect a6.tuyacn.com:443 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
[09-09 16:45:54 ty D][9094][httpc.c:625] Connect: a6.tuyacn.com Port: 443  --<< ,r:0
[09-09 16:45:54 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 14
[09-09 16:45:54 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28591 Q:0
[09-09 16:45:54 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 15
[09-09 16:45:54 ty D][fc73][tuya_svc_mqtt_client.c:421] packet id: 16
[09-09 16:45:54 ty I][fc73][ty_sdk_dp_handler.c:281] curr watermark_on_off:0
[09-09 16:45:54 ty E][fc73][smart_frame.c:587] devid:NULL dparr[0]:107 not find
[09-09 16:45:54 ty D][fc73][smart_frame.c:646] no vaild dp to rept
[09-09 16:45:54 ty D][fc73][smart_frame.c:3995] dp compose null, ret:-3585
[09-09 16:45:54 ty I][fc73][ty_sdk_dp_handler.c:302] curr IPC_APP_get_night_mode:
[09-09 16:45:54 ty E][fc73][smart_frame.c:323] enum check err:723 3
[09-09 16:45:54 ty D][4df4][tuya_svc_mqtt_client.c:421] packet id: 17
[09-09 16:45:54 ty D][fc73][smart_frame.c:601] obj dp rept filtered:108
[09-09 16:45:54 ty I][fc73][ty_sdk_dp_handler.c:324] curr alarm_on_off:0
[09-09 16:45:54 ty D][fc73][smart_frame.c:418] dp<134> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0
[09-09 16:45:54 ty D][fc73][smart_frame.c:2549] dp rept_type:0, data:{"134":false}
[09-09 16:45:54 ty D][fc73][mqc_app.c:800] Send MQTT Msg.P:4 N:28592 Q:1 Data:{"dps":{"134":false}}
[09-09 16:45:54 ty D][fc73][tuya_svc_mqtt_client.c:421] packet id: 18
[09-09 16:45:54 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","is_pre":1,"moto_id":"","p2p_skill":1635,"path":"mqtt","security_level":3,"sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"offer"},"msg":{"log":{"api":"thing.m.rtc.log","interval":60,"level":2,"size":1024,"tcp":{"address":"47.101.63.221","domain":"wework-9-cn.stream.iot-11.com","key":"6e9d446e4a2d2cdc","port":9093},"topic":"/av/moto/log"},"preconnect":true,"sdp":"v=0\r\no=- 1757407548 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9108853826b21b49bvi81757407548LaA34kjv\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:UC3d\r\na=ice-pwd:jVfbumfvxI109D5AkTairSkv\r\na=ice-options:trickle\r\na=aes-key:6475434d4e7178466361425873415830\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay1746622066937sx1YA\r\n","tcp_token":{"credential":"hVjDYgJS+0YzpLdkEI2FA7aLZIw=","do
[09-09 16:45:54 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1324465740 1 UDP 2130706431 fe80::500f:20ff:fe66:bac5 44628 typ host\r\n"}},"protocol":302,"t":1757407554}
[09-09 16:45:54 ty D][cdf4][com_protocol.c:758] To:0 src:{"dps":{"134":false}} pro:4 num:28592
[09-09 16:45:54 ty D][cdf4][com_protocol.c:773] After Pack:{"protocol":4,"t":1757407554,"data":{"dps":{"134":false}}} offset:58
[09-09 16:45:54 ty D][cdf4][tuya_svc_lan.c:1067] Prepare To Send Lan:{"dps":{"134":false}}, msg_len:21, out_len:73
[09-09 16:45:54 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436353906,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_state","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":1,"as":0,"h":0,"e":0,"ex":0,"d":13}
[09-09 16:45:54 ty D][9094][iot_httpc.c:619] Decode Rev:{"result":{"errorCode":"CAMERA_STORAGE_ORDER_NOT_EXISTED"},"t":1757407555,"success":true}
[09-09 16:45:55 ty D][9094][tls_transporter.c:93] tls transporter close socket fd:27
[09-09 16:45:55 ty D][9094][tcp_transporter.c:183] tcp transporter close socket fd:27
[09-09 16:45:55 ty D][9094][tls_transporter.c:101] tls transporter close tls handler:0xa88708
[09-09 16:45:55 ty D][9094][tuya_tls.c:1221] TUYA_TLS Disconnect ENTER
[09-09 16:45:55 ty D][9094][tuya_tls.c:1246] TUYA_TLS Disconnect Success
[09-09 16:45:55 ty D][9094][tuya_tls.c:941] tuya_tls_connect_destroy.
[09-09 16:45:55 ty E][9094][cloud_operation.c:537] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED
[09-09 16:45:55 ty D][9094][tuya_ipc_cloud_storage.c:254] order expire or remote server error
[09-09 16:45:55 ty D][a0e4][tuya_ipc_mqtt_subscribe.c:213] recv mq: protocol 302
[09-09 16:45:55 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1560030202 1 UDP 2130706431 192.168.1.17 44628 typ host\r\n"}},"protocol":302,"t":1757407554}
[09-09 16:45:55 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:725876156 1 UDP 2130706431 2409:8a55:8c1:52c0:500f:20ff:fe66:bac5 44628 typ host\r\n"}},"protocol":302,"t":1757407554}
[09-09 16:45:55 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436354247,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1324465740 1 UDP 2130706431 fe80::500f:20ff:fe66:bac5 44628 typ host\r\n","d":354}
[09-09 16:45:55 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436354579,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1560030202 1 UDP 2130706431 192.168.1.17 44628 typ host\r\n","d":687}
[09-09 16:45:55 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:45:55 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436354580,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:725876156 1 UDP 2130706431 2409:8a55:8c1:52c0:500f:20ff:fe66:bac5 44628 typ host\r\n","d":687}
[09-09 16:45:55 ty I][fc73][ty_sdk_dp_handler.c:345] curr alarm_sensitivity:
[09-09 16:45:55 ty D][fc73][smart_frame.c:3982] rept chan:3
[09-09 16:45:55 ty E][fc73][smart_frame.c:323] enum check err:723 3
[09-09 16:45:55 ty D][fc73][smart_frame.c:601] obj dp rept filtered:106
[09-09 16:45:55 ty D][fc73][smart_frame.c:646] no vaild dp to rept
[09-09 16:45:55 ty D][fc73][smart_frame.c:3995] dp compose null, ret:-3585
[09-09 16:45:55 ty I][fc73][ty_sdk_dp_handler.c:365] curr alarm_on_off:0
[09-09 16:45:55 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:45:55 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:45:55 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28594 Q:0
[09-09 16:45:55 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 19
[09-09 16:45:55 ty D][ae14][mqc_app.c:800] Send MQTT Msg.P:302 N:28593 Q:0 Data:{"header":{"from":"6c9108853826b21b49bvi8","to":"ay1746622066937sx1YA","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","moto_id":"","type":"answer","trace_id":"","is_pre":1,"p2p_skill":611,"security_level":3,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 1757436354 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9108853826b21b49bvi81757407548LaA34kjv\r\nm=application 9 tuya 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:tp7q\r\na=ice-pwd:Zztn6lxPz97jHplFE3DScyvE\r\na=ice-options:trickle\r\na=aes-key:6475434d4e7178466361425873415830\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 3\r\na=ssrc:0 cname:6c9108853826b21b49bvi8\r\n","preconnect":true,"token":[{"urls":"stun:47.103.2.131:3478"},{"credential":"hVjDYgJS+0YzpLdkEI2FA7aLZIw=","ttl":36000,"urls":"turn:47.103.17.244:3478","username":"1757443548:6c9108853826b21b49bvi8"}],"tcp_token":{"credential":"hVjDYgJS+0YzpLdkEI2FA7aLZIw=","do
[09-09 16:45:55 ty E][fc73][smart_frame.c:587] devid:NULL dparr[0]:168 not find
[09-09 16:45:55 ty E][fc73][smart_frame.c:587] devid:NULL dparr[0]:169 not find
[09-09 16:45:55 ty I][fc73][ty_sdk_dp_handler.c:489] curr sd_status:1
[09-09 16:45:55 ty D][fc73][smart_frame.c:418] dp<110> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:1
[09-09 16:45:55 ty D][fc73][smart_frame.c:438] dp_cntl value:5, dp_data value:1
[09-09 16:45:55 ty D][fc73][smart_frame.c:544] is_need_update:1, is_dp_passive:0, pv_stat:2, uling_cnt:0
[09-09 16:45:55 ty D][fc73][smart_frame.c:2549] dp rept_type:0, data:{"110":1}
[09-09 16:45:55 ty D][cdf4][com_protocol.c:758] To:0 src:{"dps":{"110":1}} pro:4 num:28595
[09-09 16:45:55 ty D][cdf4][com_protocol.c:773] After Pack:{"protocol":4,"t":1757407555,"data":{"dps":{"110":1}}} offset:54
[09-09 16:45:55 ty D][cdf4][tuya_svc_lan.c:1067] Prepare To Send Lan:{"dps":{"110":1}}, msg_len:17, out_len:69
[09-09 16:45:55 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436354580,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1038635519 1 UDP 2130706431 2409:8a55:8c1:52c0:908:c958:b0ef:a8f 44628 typ host\r\n","d":691}
[09-09 16:45:55 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436354918,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1130414197 1 UDP 1694498815 120.235.186.91 3273 typ srflx\r\n","d":1025}
[09-09 16:45:55 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436354919,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:905595773 1 UDP 16777215 47.103.17.244 62907 typ relay\r\n","d":1026}
[09-09 16:45:55 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1038635519 1 UDP 2130706431 2409:8a55:8c1:52c0:908:c958:b0ef:a8f 44628 typ host\r\n"}},"protocol":302,"t":1757407554}
[09-09 16:45:55 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1130414197 1 UDP 1694498815 120.235.186.91 3273 typ srflx\r\n"}},"protocol":302,"t":1757407554}
[09-09 16:45:55 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:905595773 1 UDP 16777215 47.103.17.244 62907 typ relay\r\n"}},"protocol":302,"t":1757407554}
[09-09 16:45:56 ty D][a0e4][tuya_ipc_mqtt_subscribe.c:213] recv mq: protocol 302
[09-09 16:45:56 ty D][a0e4][mqc_app.c:371] Rev MQTT:{"data":{"header":{"from":"ay1746622066937sx1YA","moto_id":"","path":"mqtt","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","to":"6c9108853826b21b49bvi8","trace_id":"","type":"candidate"},"msg":{"candidate":""}},"protocol":302,"t":1757407554}
[09-09 16:45:56 ty D][a0e4][smart_frame.c:2102] msg_data:{"dps":{"104":false}}, mqtt async dp cb:0
[09-09 16:45:56 ty D][a0e4][smart_frame.c:216] set short dp rate rule, dpID:104, curr_t:1757407556, rept_cnt:1.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:224] set long dp rate rule, dpID:104, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:233] set all dp rate rule, dpID:104, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty D][a0e4][mqc_app.c:1383] custom async cb op_ret: 0
[09-09 16:45:56 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:45:56 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:45:56 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28596 Q:0
[09-09 16:45:56 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:45:56 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436354920,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"","d":1027}
[09-09 16:45:56 ty D][fc73][mqc_app.c:800] Send MQTT Msg.P:4 N:28595 Q:1 Data:{"dps":{"110":1}}
[09-09 16:45:56 ty D][4df4][mqc_app.c:1445] pub finish:0
[09-09 16:45:56 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 20
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2412] Start To Sync Dev:6c9108853826b21b49bvi8, dp_rept_chan:3
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2802] Pack local dp, reset_flow_ctl:1,dpnum:45.
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2828] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:103.
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2822] dpid:110, is_lan:0, p_dp_ctl->pv_stat:2, p_dp_ctl->uling_cnt:1
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2822] dpid:134, is_lan:0, p_dp_ctl->pv_stat:2, p_dp_ctl->uling_cnt:1
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2933] dp time:NULL
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2938] final pack:{"103":false}
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2429] need another sync
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2497] sync chan:3
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2549] dp rept_type:0, data:{"103":false}
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2567] rept form:sync
[09-09 16:45:56 ty D][cdf4][mqc_app.c:800] Send MQTT Msg.P:4 N:28597 Q:1 Data:{"dps":{"103":false},"type":"sync"}
[09-09 16:45:56 ty D][fc73][tuya_svc_mqtt_client.c:421] packet id: 21
[09-09 16:45:56 ty I][fc73][ty_sdk_dp_handler.c:505] curr sd total:128000000 used:32000000 empty:96000000
[09-09 16:45:56 ty D][fc73][smart_frame.c:3982] rept chan:3
[09-09 16:45:56 ty D][fc73][smart_frame.c:418] dp<109> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:2
[09-09 16:45:56 ty D][fc73][smart_frame.c:544] is_need_update:1, is_dp_passive:0, pv_stat:2, uling_cnt:0
[09-09 16:45:56 ty D][4df4][tuya_svc_mqtt_client.c:421] packet id: 22
[09-09 16:45:56 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 23
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2449] dp sync rslt:0x0, 0x0
[09-09 16:45:56 ty D][cdf4][smart_frame.c:2488] Sync Finish
[09-09 16:45:56 ty D][fc73][smart_frame.c:2549] dp rept_type:0, data:{"109":"128000000|32000000|96000000"}
[09-09 16:45:56 ty D][fc73][mqc_app.c:800] Send MQTT Msg.P:4 N:28598 Q:1 Data:{"dps":{"109":"128000000|32000000|96000000"}}
[09-09 16:45:56 ty D][fc73][tuya_svc_mqtt_client.c:421] packet id: 24
[09-09 16:45:56 ty D][cdf4][com_protocol.c:758] To:0 src:{"dps":{"109":"128000000|32000000|96000000"}} pro:4 num:28598
[09-09 16:45:56 ty D][cdf4][com_protocol.c:773] After Pack:{"protocol":4,"t":1757407556,"data":{"dps":{"109":"128000000|32000000|96000000"}}} offset:82
[09-09 16:45:56 ty D][cdf4][tuya_svc_lan.c:1067] Prepare To Send Lan:{"dps":{"109":"128000000|32000000|96000000"}}, msg_len:45, out_len:97
[09-09 16:45:56 ty D][a0e4][smart_frame.c:2102] msg_data:{"dps":{"134":false}}, mqtt async dp cb:0
[09-09 16:45:56 ty D][a0e4][smart_frame.c:216] set short dp rate rule, dpID:134, curr_t:1757407556, rept_cnt:1.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:224] set long dp rate rule, dpID:134, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:233] set all dp rate rule, dpID:134, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:2102] msg_data:{"dps":{"110":1}}, mqtt async dp cb:0
[09-09 16:45:56 ty D][a0e4][smart_frame.c:216] set short dp rate rule, dpID:110, curr_t:1757407556, rept_cnt:2.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:224] set long dp rate rule, dpID:110, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:233] set all dp rate rule, dpID:110, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436355273,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_tcp_state","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":0,"d":1380,"th":{"tconn":0,"tresp":0,"tcomp":0}}
[09-09 16:45:56 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436355602,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_ice_state","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":0,"d":1709,"ih":{"ha":true,"hlc":false,"hlh":false,"hls":false,"hlr":false,"hrc":true,"hrh":true,"hrs":true,"hrr":true}}
[09-09 16:45:56 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436355604,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_local","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1105800676 1 UDP 2130706431 192.168.1.171 42317 typ host\r\n","d":1711}
[09-09 16:45:56 ty D][fc73][smart_frame.c:418] dp<150> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0
[09-09 16:45:56 ty D][fc73][smart_frame.c:422] dp_cntl bool:0, dp_data bool:0
[09-09 16:45:56 ty D][fc73][smart_frame.c:2549] dp rept_type:0, data:{"150":false}
[09-09 16:45:56 ty D][fc73][mqc_app.c:800] Send MQTT Msg.P:4 N:28599 Q:1 Data:{"dps":{"150":false}}
[09-09 16:45:56 ty D][fc73][tuya_svc_mqtt_client.c:421] packet id: 25
[09-09 16:45:56 ty D][cdf4][com_protocol.c:758] To:0 src:{"dps":{"150":false}} pro:4 num:28599
[09-09 16:45:56 ty D][cdf4][com_protocol.c:773] After Pack:{"protocol":4,"t":1757407556,"data":{"dps":{"150":false}}} offset:58
[09-09 16:45:56 ty D][cdf4][tuya_svc_lan.c:1067] Prepare To Send Lan:{"dps":{"150":false}}, msg_len:21, out_len:73
[09-09 16:45:56 ty D][a0e4][smart_frame.c:2102] msg_data:{"dps":{"103":false},"type":"sync"}, mqtt async dp cb:0
[09-09 16:45:56 ty D][a0e4][smart_frame.c:216] set short dp rate rule, dpID:103, curr_t:1757407556, rept_cnt:1.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:224] set long dp rate rule, dpID:103, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:233] set all dp rate rule, dpID:103, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:2102] msg_data:{"dps":{"109":"128000000|32000000|96000000"}}, mqtt async dp cb:0
[09-09 16:45:56 ty D][a0e4][smart_frame.c:216] set short dp rate rule, dpID:109, curr_t:1757407556, rept_cnt:1.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:224] set long dp rate rule, dpID:109, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:233] set all dp rate rule, dpID:109, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:2102] msg_data:{"dps":{"150":false}}, mqtt async dp cb:0
[09-09 16:45:56 ty D][a0e4][smart_frame.c:216] set short dp rate rule, dpID:150, curr_t:1757407556, rept_cnt:1.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:224] set long dp rate rule, dpID:150, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty D][a0e4][smart_frame.c:233] set all dp rate rule, dpID:150, curr_t:1757407556, rept_cnt:0.
[09-09 16:45:56 ty D][ae14][mqc_app.c:800] Send MQTT Msg.P:302 N:28600 Q:0 Data:{"header":{"from":"6c9108853826b21b49bvi8","to":"ay1746622066937sx1YA","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1105800676 1 UDP 2130706431 192.168.1.171 42317 typ host\r\n"}}
[09-09 16:45:56 ty D][4df4][tuya_svc_mqtt_client.c:421] packet id: 26
[09-09 16:45:56 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28601 Q:0
[09-09 16:45:56 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 27
[09-09 16:45:56 ty D][fc73][smart_frame.c:418] dp<151> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:3
[09-09 16:45:56 ty D][fc73][smart_frame.c:2549] dp rept_type:0, data:{"151":"1"}
[09-09 16:45:56 ty D][fc73][mqc_app.c:800] Send MQTT Msg.P:4 N:28602 Q:1 Data:{"dps":{"151":"1"}}
[09-09 16:45:56 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436355609,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_ice_state","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":1,"d":1716,"ih":{"ha":true,"hlc":true,"hlh":true,"hls":false,"hlr":false,"hrc":true,"hrh":true,"hrs":true,"hrr":true}}
[09-09 16:45:56 ty D][cdf4][com_protocol.c:758] To:0 src:{"dps":{"151":"1"}} pro:4 num:28602
[09-09 16:45:56 ty D][cdf4][com_protocol.c:773] After Pack:{"protocol":4,"t":1757407556,"data":{"dps":{"151":"1"}}} offset:56
[09-09 16:45:56 ty D][cdf4][tuya_svc_lan.c:1067] Prepare To Send Lan:{"dps":{"151":"1"}}, msg_len:19, out_len:71
[09-09 16:45:56 ty D][fc73][tuya_svc_mqtt_client.c:421] packet id: 28
[09-09 16:45:56 ty D][fc73][smart_frame.c:418] dp<117> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:1
[09-09 16:45:56 ty D][fc73][smart_frame.c:438] dp_cntl value:0, dp_data value:0
[09-09 16:45:56 ty D][fc73][smart_frame.c:2549] dp rept_type:0, data:{"117":0}
[09-09 16:45:56 ty D][cdf4][com_protocol.c:758] To:0 src:{"dps":{"117":0}} pro:4 num:28603
[09-09 16:45:56 ty D][cdf4][com_protocol.c:773] After Pack:{"protocol":4,"t":1757407556,"data":{"dps":{"117":0}}} offset:54
[09-09 16:45:56 ty D][cdf4][tuya_svc_lan.c:1067] Prepare To Send Lan:{"dps":{"117":0}}, msg_len:17, out_len:69
[09-09 16:45:56 ty D][fc73][mqc_app.c:800] Send MQTT Msg.P:4 N:28603 Q:1 Data:{"dps":{"117":0}}
[09-09 16:45:56 ty D][fc73][tuya_svc_mqtt_client.c:421] packet id: 29
[09-09 16:45:56 ty I][fc73][ty_sdk_dp_handler.c:920] curr blub_on_off:0
[09-09 16:45:57 ty D][fc73][smart_frame.c:3982] rept chan:3
[09-09 16:45:57 ty E][fc73][smart_frame.c:587] devid:NULL dparr[0]:138 not find
[09-09 16:45:57 ty D][fc73][smart_frame.c:646] no vaild dp to rept
[09-09 16:45:57 ty D][fc73][smart_frame.c:3995] dp compose null, ret:-3585
[09-09 16:45:57 ty I][fc73][ty_sdk_dp_callback.c:154] current power mode:701
[09-09 16:45:57 ty E][fc73][smart_frame.c:587] devid:NULL dparr[0]:146 not find
[09-09 16:45:57 ty I][fc73][ty_sdk_dp_callback.c:156] current battery percent:80
[09-09 16:45:57 ty E][fc73][smart_frame.c:587] devid:NULL dparr[0]:145 not find
[09-09 16:45:57 ty D][fc73][iot_httpc.c:973] Post Data: {"skill":"{\"v\":2,\"sdk_version\":\"6.2.8\",\"channel_num\":1,\"cloudGW\":3,\"cloudStorage\":1,\"doorbellStorage\":1,\"localStorage\":69509,\"webrtc\":115,\"p2p\":611,\"max_p2p_sessions\":5,\"video_num\":2,\"videos\":[{\"streamType\":2,\"codecType\":2,\"sampleRate\":90000,\"profileId\":\"\",\"width\":2304,\"height\":1296},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":16000,\"dataBit\":16,\"channels\":1}],\"security_ability\":30,\"cloudRule\":7}","t":1757407557}
[09-09 16:45:57 ty D][fc73][iot_httpc.c:985] Post URL: https://a6.tuyacn.com/d.json?a=tuya.device.skill.update&devId=6c9108853826b21b49bvi8&et=3&t=1757407557&v=1.0&sign=656485fb57081a5d227bb098293bdea4
[09-09 16:45:57 ty D][a374][tuya_ipc_p2p.c:4405] compare passwd
[09-09 16:45:57 ty D][a374][tuya_ipc_p2p.c:4426] auth success
[09-09 16:45:57 ty D][a374][tuya_ipc_p2p.c:608] __p2p_get_idle_session begin
[09-09 16:45:57 ty D][a374][tuya_ipc_p2p.c:619] create p2p sessions. cur online session num = 1
[09-09 16:45:57 ty D][a374][tuya_ipc_media_adapter.c:154] alloc resource success: user handle [0xaa07e8][1000 KB], user num [2] res[4000]
[09-09 16:45:57 ty D][a374][tuya_ipc_p2p.c:4473] session:[0] malloc video send buffer success
[09-09 16:45:57 ty D][a374][tuya_ipc_p2p.c:4520] session:[0] malloc audio send buffer success
[09-09 16:45:57 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436355960,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_local","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1827158867 1 UDP 16777215 47.103.17.244 63200 typ relay\r\n","d":5468}
[09-09 16:45:57 ty D][a0e4][mqc_app.c:1383] custom async cb op_ret: 0
[09-09 16:45:57 ty D][a0e4][smart_frame.c:2102] msg_data:{"dps":{"151":"1"}}, mqtt async dp cb:0
[09-09 16:45:57 ty D][a0e4][smart_frame.c:216] set short dp rate rule, dpID:151, curr_t:1757407557, rept_cnt:1.
[09-09 16:45:57 ty D][a0e4][smart_frame.c:224] set long dp rate rule, dpID:151, curr_t:1757407557, rept_cnt:0.
[09-09 16:45:57 ty D][a0e4][smart_frame.c:233] set all dp rate rule, dpID:151, curr_t:1757407557, rept_cnt:0.
[09-09 16:45:57 ty D][a0e4][smart_frame.c:2102] msg_data:{"dps":{"117":0}}, mqtt async dp cb:0
[09-09 16:45:57 ty D][a0e4][smart_frame.c:216] set short dp rate rule, dpID:117, curr_t:1757407557, rept_cnt:1.
[09-09 16:45:57 ty D][a0e4][smart_frame.c:224] set long dp rate rule, dpID:117, curr_t:1757407557, rept_cnt:0.
[09-09 16:45:57 ty D][a0e4][smart_frame.c:233] set all dp rate rule, dpID:117, curr_t:1757407557, rept_cnt:0.
[09-09 16:45:57 ty D][ae14][mqc_app.c:800] Send MQTT Msg.P:302 N:28604 Q:0 Data:{"header":{"from":"6c9108853826b21b49bvi8","to":"ay1746622066937sx1YA","sessionid":"6c9108853826b21b49bvi817574075484NXzBpr3","moto_id":"","type":"candidate","trace_id":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","path":"mqtt"},"msg":{"candidate":"a=candidate:1827158867 1 UDP 16777215 47.103.17.244 63200 typ relay\r\n"}}
[09-09 16:45:57 ty D][4df4][mqc_app.c:1445] pub finish:0
[09-09 16:45:57 ty D][4df4][iot_httpc.c:973] Post Data: {"devId":"6c9108853826b21b49bvi8","t":1757407557}
[09-09 16:45:57 ty D][4df4][iot_httpc.c:985] Post URL: https://a6.tuyacn.com/d.json?a=thing.ipc.dynamic.rule.get&devId=6c9108853826b21b49bvi8&et=3&t=1757407557&v=1.0&sign=df4f677dc1453f0b4197127534766608
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:3110] recv session[65537] high cmd[10] low cmd[0] len[4] req_id[0]
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:3110] recv session[65537] high cmd[2] low cmd[0] len[4] req_id[39]
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:3110] recv session[65537] high cmd[9] low cmd[0] len[8] req_id[327721]
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:3942] set video clarity session[65537]chn[0] op[4] clarity[1]
[09-09 16:45:57 ty D][2374][ty_sdk_media_callback.c:276] p2p rev event cb=[34]
[09-09 16:45:57 ty D][2374][ty_sdk_media_callback.c:534] set clarity:1
[09-09 16:45:57 ty D][2374][ty_sdk_media_callback.c:537] set clarity:1 OK
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:3944] ipc chan 0 clarity 1
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:3110] recv session[65537] high cmd[6] low cmd[0] len[8] req_id[327720]
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:3327] CTRL VIDEO session[65537] chn[0] op[0]
[09-09 16:45:57 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436356295,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_local","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:811145762 1 UDP 1694498815 120.235.186.91 3289 typ srflx\r\n","d":2402}
[09-09 16:45:57 ty D][fc73][httpc.c:623] Connect: a6.tuyacn.com Port: 443  -->>
[09-09 16:45:57 ty D][fc73][tcp_transporter.c:37] dns mode by ip 2
[09-09 16:45:57 ty D][fc73][uni_network.c:230] unw_gethostbyname a6.tuyacn.com, prio 1
[09-09 16:45:57 ty D][fc73][uni_network.c:246] use dynamic dns ip:47.116.198.59 for domain:a6.tuyacn.com
[09-09 16:45:57 ty D][fc73][tcp_transporter.c:44] DNS parse type:2
[09-09 16:45:57 ty D][fc73][tcp_transporter.c:85] bind  port:0 ok
[09-09 16:45:57 ty D][ae14][mqc_app.c:800] Send MQTT Msg.P:302 N:28605 Q:0 Data:{"header":{"from":"6c9108853826b21b49bvi8","to":"ay1746622066937sx1YA","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:811145762 1 UDP 1694498815 120.235.186.91 3289 typ srflx\r\n"}}
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:1805] session[65537]video video_start wait_concurr_idle
[09-09 16:45:57 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:45:57 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:45:57 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28606 Q:0
[09-09 16:45:57 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 30
[09-09 16:45:57 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:45:57 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436356660,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:252120008 1 UDP 2130706431 fe80::500f:20ff:fe66:bac5 41836 typ host\r\n","d":6168}
[09-09 16:45:57 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436356663,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:2065400564 1 UDP 2130706431 192.168.1.17 41836 typ host\r\n","d":6171}
[09-09 16:45:57 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436356996,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:249241073 1 UDP 2130706431 2409:8a55:8c1:52c0:500f:20ff:fe66:bac5 41836 typ host\r\n","d":6504}
[09-09 16:45:57 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28607 Q:0
[09-09 16:45:57 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 31
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:5094] session[65537] concurr idle[2][2]
[09-09 16:45:57 ty D][2374][ty_sdk_media_callback.c:276] p2p rev event cb=[30]
[09-09 16:45:57 ty D][2374][ty_sdk_media_callback.c:283] chn[0] video start
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:1817] session[65537] video start success
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:3110] recv session[65537] high cmd[6] low cmd[4] len[8] req_id[327722]
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:3327] CTRL VIDEO session[65537] chn[0] op[4]
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:1864] session[65537] send audio start to dev
[09-09 16:45:57 ty D][2374][ty_sdk_media_callback.c:276] p2p rev event cb=[32]
[09-09 16:45:57 ty D][2374][ty_sdk_media_callback.c:295] chn[0] audio start
[09-09 16:45:57 ty D][2374][tuya_ipc_p2p.c:1871] session:[65537] audio start success
[09-09 16:45:57 ty D][4df4][httpc.c:623] Connect: a6.tuyacn.com Port: 443  -->>
[09-09 16:45:57 ty D][4df4][tcp_transporter.c:37] dns mode by ip 2
[09-09 16:45:57 ty D][4df4][uni_network.c:230] unw_gethostbyname a6.tuyacn.com, prio 1
[09-09 16:45:57 ty D][4df4][uni_network.c:246] use dynamic dns ip:47.116.198.59 for domain:a6.tuyacn.com
[09-09 16:45:57 ty D][4df4][tcp_transporter.c:44] DNS parse type:2
[09-09 16:45:57 ty D][fc73][tuya_tls.c:979] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1
[09-09 16:45:57 ty D][fc73][tuya_tls.c:988] TUYA_TLS Begin Connect a6.tuyacn.com:443
[09-09 16:45:57 ty D][fc73][tuya_tls.c:738] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED
[09-09 16:45:57 ty D][fc73][tuya_tls.c:751] load tuya cert.
[09-09 16:45:57 ty D][fc73][tuya_cert_manager.c:213] p_url:a6.tuyacn.com, rcs.urlx:h6.iot-dns.com
[09-09 16:45:57 ty D][fc73][tuya_cert_manager.c:236] tuya public url
[09-09 16:45:57 ty D][fc73][tuya_cert_manager.c:1100] parse crt <0> len <540> ret <0>
[09-09 16:45:57 ty D][fc73][tuya_tls.c:1077] socket fd is set. set to inner send/recv to handshake
[09-09 16:45:57 ty D][a374][tuya_ring_buffer.c:780] ch0st0tr0 open with type 0
[09-09 16:45:57 ty E][a374][tuya_ipc_p2p.c:4629] session[65537] open_stream video success
[09-09 16:45:57 ty D][a374][tuya_ring_buffer.c:780] ch0st0tr9 open with type 0
[09-09 16:45:57 ty E][a374][tuya_ipc_p2p.c:4648] session[65537] open_stream audio success
[09-09 16:45:57 ty D][a374][tuya_ring_buffer.c:1065] get latest audio frame success, node 107 seq_no 357 ch0st0tr9
[09-09 16:45:57 ty D][4df4][tcp_transporter.c:85] bind  port:0 ok
[09-09 16:45:57 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436356996,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1808935521 1 UDP 2130706431 2409:8a55:8c1:52c0:908:c958:b0ef:a8f 41836 typ host\r\n","d":6504}
[09-09 16:45:57 ty D][a374][tuya_ipc_p2p.c:2369] session send video cnt [1] ring[0]
[09-09 16:45:57 ty D][a374][tuya_ipc_p2p.c:2378] session send audio cnt [1]
[09-09 16:45:57 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436357135,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_ice_state","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":2,"d":3242,"ih":{"ha":true,"hlc":true,"hlh":true,"hls":true,"hlr":false,"hrc":true,"hrh":true,"hrs":true,"hrr":true}}
[09-09 16:45:57 ty D][ae14][mqc_app.c:800] Send MQTT Msg.P:302 N:28608 Q:0 Data:{"header":{"from":"6c9108853826b21b49bvi8","to":"ay1746622066937sx1YA","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":""}}
[09-09 16:45:57 ty D][4df4][tuya_tls.c:979] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1
[09-09 16:45:57 ty D][4df4][tuya_tls.c:988] TUYA_TLS Begin Connect a6.tuyacn.com:443
[09-09 16:45:57 ty D][4df4][tuya_tls.c:738] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED
[09-09 16:45:57 ty D][4df4][tuya_tls.c:751] load tuya cert.
[09-09 16:45:57 ty D][4df4][tuya_cert_manager.c:213] p_url:a6.tuyacn.com, rcs.urlx:h6.iot-dns.com
[09-09 16:45:57 ty D][4df4][tuya_cert_manager.c:236] tuya public url
[09-09 16:45:57 ty D][4df4][tuya_cert_manager.c:1100] parse crt <0> len <540> ret <0>
[09-09 16:45:57 ty D][4df4][tuya_tls.c:1077] socket fd is set. set to inner send/recv to handshake
[09-09 16:45:57 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436357167,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_tcp_state","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":1,"d":6675,"th":{"tconn":1757436353229,"tresp":1757436356292,"tcomp":1757436357058}}
[09-09 16:45:58 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28609 Q:0
[09-09 16:45:58 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 32
[09-09 16:45:58 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:45:58 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436357170,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_state","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":3,"as":0,"h":0,"e":0,"ex":0,"d":3277}
[09-09 16:45:58 ty D][cdf4][smart_frame.c:2412] Start To Sync Dev:6c9108853826b21b49bvi8, dp_rept_chan:3
[09-09 16:45:58 ty D][cdf4][smart_frame.c:2802] Pack local dp, reset_flow_ctl:1,dpnum:45.
[09-09 16:45:58 ty D][cdf4][smart_frame.c:2888] Nothing To Pack
[09-09 16:45:58 ty D][cdf4][smart_frame.c:2437] OUT IS NULL
[09-09 16:45:58 ty D][cdf4][smart_frame.c:2488] Sync Finish
[09-09 16:45:58 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436357724,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_local","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1994453975 1 UDP 16777215 47.103.17.244 54721 typ relay\r\n","d":3831}
[09-09 16:45:58 ty D][ae14][mqc_app.c:800] Send MQTT Msg.P:302 N:28610 Q:0 Data:{"header":{"from":"6c9108853826b21b49bvi8","to":"ay1746622066937sx1YA","sessionid":"6c9108853826b21b49bvi81757407548LaA34kjv","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1994453975 1 UDP 16777215 47.103.17.244 54721 typ relay\r\n"}}
[09-09 16:45:58 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436358061,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_tcp_state","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":1,"d":4168,"th":{"tconn":1757436357085,"tresp":1757436357738,"tcomp":1757436358061}}
[09-09 16:45:58 ty D][fc73][tuya_tls.c:711] mbedtls_cert_pkey_free.
[09-09 16:45:58 ty D][fc73][tuya_tls.c:1139] handshake finish for a6.tuyacn.com. set send/recv to user set
[09-09 16:45:58 ty D][fc73][tuya_tls.c:1145] TUYA_TLS Success Connect a6.tuyacn.com:443 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
[09-09 16:45:58 ty D][fc73][httpc.c:625] Connect: a6.tuyacn.com Port: 443  --<< ,r:0
[09-09 16:45:58 ty D][4df4][tuya_tls.c:711] mbedtls_cert_pkey_free.
[09-09 16:45:58 ty D][4df4][tuya_tls.c:1139] handshake finish for a6.tuyacn.com. set send/recv to user set
[09-09 16:45:58 ty D][4df4][tuya_tls.c:1145] TUYA_TLS Success Connect a6.tuyacn.com:443 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
[09-09 16:45:58 ty D][4df4][httpc.c:625] Connect: a6.tuyacn.com Port: 443  --<< ,r:0
[09-09 16:45:59 ty D][fc73][iot_httpc.c:619] Decode Rev:{"t":1757407559,"success":true}
[09-09 16:45:59 ty D][fc73][tls_transporter.c:93] tls transporter close socket fd:32
[09-09 16:45:59 ty D][fc73][tcp_transporter.c:183] tcp transporter close socket fd:32
[09-09 16:45:59 ty D][fc73][tls_transporter.c:101] tls transporter close tls handler:0xac9770
[09-09 16:45:59 ty D][fc73][tuya_tls.c:1221] TUYA_TLS Disconnect ENTER
[09-09 16:45:59 ty D][fc73][tuya_tls.c:1246] TUYA_TLS Disconnect Success
[09-09 16:45:59 ty D][fc73][tuya_tls.c:941] tuya_tls_connect_destroy.
[09-09 16:45:59 ty D][fc73][tuya_ipc_skill.c:335] upload data: {\"v\":2,\"sdk_version\":\"6.2.8\",\"channel_num\":1,\"cloudGW\":3,\"cloudStorage\":1,\"doorbellStorage\":1,\"localStorage\":69509,\"webrtc\":115,\"p2p\":611,\"max_p2p_sessions\":5,\"video_num\":2,\"videos\":[{\"streamType\":2,\"codecType\":2,\"sampleRate\":90000,\"profileId\":\"\",\"width\":2304,\"height\":1296},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":16000,\"dataBit\":16,\"channels\":1}],\"security_ability\":30,\"cloudRule\":7}
[09-09 16:45:59 ty D][fc73][tuya_ipc_skill.c:357] upload data: {"producerStr":{"v":[{"cT":2,"sR":90000,"pId":1,"w":2304,"h":1296,"sT":2},{"cT":2,"sR":90000,"pId":1,"w":640,"h":360,"sT":4}],"a":[{"cT":101,"sR":16000,"dB":16,"ch":0,"sT":1}]},"consumerStr":{"v":[],"a":[{"cT":101,"sR":16000,"dB":16}]}}
[09-09 16:45:59 ty D][fc73][iot_httpc.c:973] Post Data: {"producerStr":{"v":[{"cT":2,"sR":90000,"pId":1,"w":2304,"h":1296,"sT":2},{"cT":2,"sR":90000,"pId":1,"w":640,"h":360,"sT":4}],"a":[{"cT":101,"sR":16000,"dB":16,"ch":0,"sT":1}]},"consumerStr":{"v":[],"a":[{"cT":101,"sR":16000,"dB":16}]},"t":1757407559}
[09-09 16:45:59 ty D][fc73][iot_httpc.c:985] Post URL: https://a6.tuyacn.com/d.json?a=tuya.device.skill.multimedia.update&devId=6c9108853826b21b49bvi8&et=3&t=1757407559&v=1.0&sign=7762bd01dddfb56161bd70e22dcbb7d6
[09-09 16:45:59 ty D][fc73][httpc.c:623] Connect: a6.tuyacn.com Port: 443  -->>
[09-09 16:45:59 ty D][fc73][tcp_transporter.c:37] dns mode by ip 2
[09-09 16:45:59 ty D][fc73][uni_network.c:230] unw_gethostbyname a6.tuyacn.com, prio 1
[09-09 16:45:59 ty D][fc73][uni_network.c:246] use dynamic dns ip:47.116.198.59 for domain:a6.tuyacn.com
[09-09 16:45:59 ty D][fc73][tcp_transporter.c:44] DNS parse type:2
[09-09 16:45:59 ty D][fc73][tcp_transporter.c:85] bind  port:0 ok
[09-09 16:45:59 ty D][4df4][iot_httpc.c:619] Decode Rev:{"result":[],"t":1757407559,"success":true}
[09-09 16:45:59 ty D][4df4][tls_transporter.c:93] tls transporter close socket fd:31
[09-09 16:45:59 ty D][4df4][tcp_transporter.c:183] tcp transporter close socket fd:31
[09-09 16:45:59 ty D][4df4][tls_transporter.c:101] tls transporter close tls handler:0xacb9b8
[09-09 16:45:59 ty D][4df4][tuya_tls.c:1221] TUYA_TLS Disconnect ENTER
[09-09 16:45:59 ty D][4df4][tuya_tls.c:1246] TUYA_TLS Disconnect Success
[09-09 16:45:59 ty D][4df4][tuya_tls.c:941] tuya_tls_connect_destroy.
[09-09 16:45:59 ty D][4df4][tuya_ipc_rule.c:1222] rule size: 0
[09-09 16:45:59 ty D][4df4][simplekv.c:1137] read key:dynamic_rule isFuzzy:0 skipCnt:0
[09-09 16:45:59 ty D][4df4][simplekv.c:1168] find key:19 dynamic_rule
[09-09 16:45:59 ty D][4df4][simplekv.c:1194] key:dynamic_rule find value.Len:16
[09-09 16:45:59 ty D][4df4][tuya_ipc_rule.c:1156] rules not change, no need save
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436358346,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:357666007 1 UDP 1694498815 120.235.186.91 3266 typ srflx\r\n","d":7854}
[09-09 16:45:59 ty D][fc73][tuya_tls.c:979] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1
[09-09 16:45:59 ty D][fc73][tuya_tls.c:988] TUYA_TLS Begin Connect a6.tuyacn.com:443
[09-09 16:45:59 ty D][fc73][tuya_tls.c:738] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED
[09-09 16:45:59 ty D][fc73][tuya_tls.c:751] load tuya cert.
[09-09 16:45:59 ty D][fc73][tuya_cert_manager.c:213] p_url:a6.tuyacn.com, rcs.urlx:h6.iot-dns.com
[09-09 16:45:59 ty D][fc73][tuya_cert_manager.c:236] tuya public url
[09-09 16:45:59 ty D][fc73][tuya_cert_manager.c:1100] parse crt <0> len <540> ret <0>
[09-09 16:45:59 ty D][fc73][tuya_tls.c:1077] socket fd is set. set to inner send/recv to handshake
[09-09 16:45:59 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:45:59 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:45:59 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28611 Q:0
[09-09 16:45:59 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 33
[09-09 16:45:59 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436358352,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:872146317 1 UDP 16777215 47.103.17.244 53736 typ relay\r\n","d":7860}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436358686,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"","d":8194}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436358686,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1324465740 1 UDP 2130706431 fe80::500f:20ff:fe66:bac5 44628 typ host\r\n","d":4794}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436358687,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1560030202 1 UDP 2130706431 192.168.1.17 44628 typ host\r\n","d":4794}
[09-09 16:45:59 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28612 Q:0
[09-09 16:45:59 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 35
[09-09 16:45:59 ty D][1094][tuya_ipc_rule.c:2494] next_update_time: 1757409208
[09-09 16:45:59 ty D][4df4][tuya_svc_mqtt_client.c:421] packet id: 34
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436358688,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:725876156 1 UDP 2130706431 2409:8a55:8c1:52c0:500f:20ff:fe66:bac5 44628 typ host\r\n","d":4795}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436358696,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1038635519 1 UDP 2130706431 2409:8a55:8c1:52c0:908:c958:b0ef:a8f 44628 typ host\r\n","d":4803}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436358696,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1130414197 1 UDP 1694498815 120.235.186.91 3273 typ srflx\r\n","d":4804}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436358698,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:905595773 1 UDP 16777215 47.103.17.244 62907 typ relay\r\n","d":4805}
[09-09 16:45:59 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28613 Q:0
[09-09 16:45:59 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 36
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436358698,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"","d":4805}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436359032,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":8540,"channels":[[0,152,236,152,236,1944,10920,6161,6137,5466,3405,5466],[1,397537,0,391313,0,621376,308,6522,6511,-1,-1,7382],[2,69488,0,65168,0,62648,176,6642,6592,-1,-1,7382],[6,2572,0,-132,0,22536,0,3400,688,-1,-1,-1]]}
[09-09 16:45:59 ty D][a0e4][mqc_app.c:1383] custom async cb op_ret: 0
[09-09 16:45:59 ty D][fc73][tuya_tls.c:711] mbedtls_cert_pkey_free.
[09-09 16:45:59 ty D][fc73][tuya_tls.c:1139] handshake finish for a6.tuyacn.com. set send/recv to user set
[09-09 16:45:59 ty D][fc73][tuya_tls.c:1145] TUYA_TLS Success Connect a6.tuyacn.com:443 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
[09-09 16:45:59 ty D][fc73][httpc.c:625] Connect: a6.tuyacn.com Port: 443  --<< ,r:0
[09-09 16:45:59 ty D][4df4][mqc_app.c:1445] pub finish:0
[09-09 16:45:59 ty D][4df4][iot_httpc.c:973] Post Data: {"type":"[\"timezone\",\"rateRule\",\"seniorAbility\"]","t":1757407559}
[09-09 16:45:59 ty D][4df4][iot_httpc.c:985] Post URL: https://a6.tuyacn.com/d.json?a=tuya.device.dynamic.config.get&devId=6c9108853826b21b49bvi8&et=3&t=1757407559&v=2.0&sign=bc13abe10c14805462ddff3b3dbdbe89
[09-09 16:45:59 ty D][2374][tuya_ipc_p2p.c:4987] session detect run
[09-09 16:45:59 ty D][2374][tuya_ipc_p2p.c:4965] session[65537] detect WaitCnt[0] SendCnt[108] RecvCnt[0]
[09-09 16:45:59 ty D][4df4][httpc.c:623] Connect: a6.tuyacn.com Port: 443  -->>
[09-09 16:45:59 ty D][4df4][tcp_transporter.c:37] dns mode by ip 2
[09-09 16:45:59 ty D][4df4][uni_network.c:230] unw_gethostbyname a6.tuyacn.com, prio 1
[09-09 16:45:59 ty D][4df4][uni_network.c:246] use dynamic dns ip:47.116.198.59 for domain:a6.tuyacn.com
[09-09 16:45:59 ty D][4df4][tcp_transporter.c:44] DNS parse type:2
[09-09 16:45:59 ty D][4df4][tcp_transporter.c:85] bind  port:0 ok
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436359217,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1324465740 1 UDP 2130706431 fe80::500f:20ff:fe66:bac5 44628 typ host\r\n","d":5324}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436359224,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1560030202 1 UDP 2130706431 192.168.1.17 44628 typ host\r\n","d":5331}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436359226,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:725876156 1 UDP 2130706431 2409:8a55:8c1:52c0:500f:20ff:fe66:bac5 44628 typ host\r\n","d":5333}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436359229,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1038635519 1 UDP 2130706431 2409:8a55:8c1:52c0:908:c958:b0ef:a8f 44628 typ host\r\n","d":5336}
[09-09 16:45:59 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28614 Q:0
[09-09 16:45:59 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 37
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436359233,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:1130414197 1 UDP 1694498815 120.235.186.91 3273 typ srflx\r\n","d":5340}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436359239,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"a=candidate:905595773 1 UDP 16777215 47.103.17.244 62907 typ relay\r\n","d":5346}
[09-09 16:45:59 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436359240,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_candidate_remote","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"c":"","d":5347}
[09-09 16:46:00 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:46:00 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:46:00 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28615 Q:0
[09-09 16:46:00 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 38
[09-09 16:46:00 ty D][4df4][tuya_tls.c:979] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1
[09-09 16:46:00 ty D][4df4][tuya_tls.c:988] TUYA_TLS Begin Connect a6.tuyacn.com:443
[09-09 16:46:00 ty D][4df4][tuya_tls.c:738] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED
[09-09 16:46:00 ty D][4df4][tuya_tls.c:751] load tuya cert.
[09-09 16:46:00 ty D][4df4][tuya_cert_manager.c:213] p_url:a6.tuyacn.com, rcs.urlx:h6.iot-dns.com
[09-09 16:46:00 ty D][4df4][tuya_cert_manager.c:236] tuya public url
[09-09 16:46:00 ty D][4df4][tuya_cert_manager.c:1100] parse crt <0> len <540> ret <0>
[09-09 16:46:00 ty D][4df4][tuya_tls.c:1077] socket fd is set. set to inner send/recv to handshake
[09-09 16:46:00 ty D][fc73][iot_httpc.c:619] Decode Rev:{"result":true,"t":1757407560,"success":true}
[09-09 16:46:00 ty D][fc73][tls_transporter.c:93] tls transporter close socket fd:32
[09-09 16:46:00 ty D][fc73][tcp_transporter.c:183] tcp transporter close socket fd:32
[09-09 16:46:00 ty D][fc73][tls_transporter.c:101] tls transporter close tls handler:0xb125c0
[09-09 16:46:00 ty D][fc73][tuya_tls.c:1221] TUYA_TLS Disconnect ENTER
[09-09 16:46:00 ty D][fc73][tuya_tls.c:1246] TUYA_TLS Disconnect Success
[09-09 16:46:00 ty D][fc73][tuya_tls.c:941] tuya_tls_connect_destroy.
[09-09 16:46:00 ty D][fc73][tuya_ipc_skill.c:367] upload finish
[09-09 16:46:00 ty D][fc73][main.c:750] tuya_ipc_sdk_mqtt_online_proc is end run
[09-09 16:46:00 ty D][4df4][tuya_tls.c:711] mbedtls_cert_pkey_free.
[09-09 16:46:00 ty D][4df4][tuya_tls.c:1139] handshake finish for a6.tuyacn.com. set send/recv to user set
[09-09 16:46:00 ty D][4df4][tuya_tls.c:1145] TUYA_TLS Success Connect a6.tuyacn.com:443 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
[09-09 16:46:00 ty D][4df4][httpc.c:625] Connect: a6.tuyacn.com Port: 443  --<< ,r:0
[09-09 16:46:00 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436359422,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_tcp_state","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"a":2,"d":5529,"th":{"tconn":1757436357085,"tresp":1757436357738,"tcomp":1757436358061}}
[09-09 16:46:00 ty D][4df4][iot_httpc.c:619] Decode Rev:{"result":{"seniorAbility":{},"timezone":{"config":{},"time":1757407560,"validTime":1800}},"t":1757407560,"success":true}
[09-09 16:46:00 ty D][4df4][tls_transporter.c:93] tls transporter close socket fd:31
[09-09 16:46:00 ty D][4df4][tcp_transporter.c:183] tcp transporter close socket fd:31
[09-09 16:46:00 ty D][4df4][tls_transporter.c:101] tls transporter close tls handler:0xacb9b8
[09-09 16:46:00 ty D][4df4][tuya_tls.c:1221] TUYA_TLS Disconnect ENTER
[09-09 16:46:00 ty D][4df4][tuya_tls.c:1246] TUYA_TLS Disconnect Success
[09-09 16:46:00 ty D][4df4][tuya_tls.c:941] tuya_tls_connect_destroy.
[09-09 16:46:00 ty D][4df4][tuya_devos_utils.c:106] reset dp rate rule finish.
[09-09 16:46:00 ty D][4df4][iot_httpc.c:2243] NO ackId
[09-09 16:46:00 ty D][4df4][iot_httpc.c:973] Post Data: {"data":"7","t":1757407560}
[09-09 16:46:00 ty D][4df4][iot_httpc.c:985] Post URL: https://a6.tuyacn.com/d.json?a=atop.online.debug.log&devId=6c9108853826b21b49bvi8&et=3&t=1757407560&sign=17706e52db3cd9a9993c3ec949fe1137
[09-09 16:46:00 ty D][4df4][httpc.c:623] Connect: a6.tuyacn.com Port: 443  -->>
[09-09 16:46:00 ty D][4df4][tcp_transporter.c:37] dns mode by ip 2
[09-09 16:46:00 ty D][4df4][uni_network.c:230] unw_gethostbyname a6.tuyacn.com, prio 1
[09-09 16:46:00 ty D][4df4][uni_network.c:246] use dynamic dns ip:47.116.198.59 for domain:a6.tuyacn.com
[09-09 16:46:00 ty D][4df4][tcp_transporter.c:44] DNS parse type:2
[09-09 16:46:00 ty D][4df4][tcp_transporter.c:85] bind  port:0 ok
[09-09 16:46:00 ty D][a374][tuya_ipc_p2p.c:2430] media recv proc alive [2000]
[09-09 16:46:00 ty D][4df4][iot_httpc.c:619] Decode Rev:{"result":true,"t":1757407561,"success":true}
[09-09 16:46:01 ty D][4df4][tls_transporter.c:93] tls transporter close socket fd:31
[09-09 16:46:01 ty D][4df4][tcp_transporter.c:183] tcp transporter close socket fd:31
[09-09 16:46:01 ty D][4df4][tls_transporter.c:101] tls transporter close tls handler:0xb125c0
[09-09 16:46:01 ty D][4df4][tuya_tls.c:1221] TUYA_TLS Disconnect ENTER
[09-09 16:46:01 ty D][4df4][tuya_tls.c:1246] TUYA_TLS Disconnect Success
[09-09 16:46:01 ty D][4df4][tuya_tls.c:941] tuya_tls_connect_destroy.
[09-09 16:46:01 ty D][4df4][tuya_svc_devos_daemons.c:57] put rst log finish
[09-09 16:46:01 ty D][a374][tuya_ipc_p2p.c:4581] media send proc alive [2000]
[09-09 16:46:01 ty D][4df4][tuya_svc_mqtt_client.c:421] packet id: 39
[09-09 16:46:01 ty D][a0e4][mqc_app.c:1383] custom async cb op_ret: 0
[09-09 16:46:01 ty D][4df4][mqc_app.c:1445] pub finish:0
[09-09 16:46:01 ty D][4df4][iot_httpc.c:973] Post Data: {"subId":null,"t":1757407561}
[09-09 16:46:01 ty D][4df4][iot_httpc.c:985] Post URL: https://a6.tuyacn.com/d.json?a=tuya.device.upgrade.silent.get&devId=6c9108853826b21b49bvi8&et=3&t=1757407561&v=4.4&sign=be32de8b6c0b0bf9de2403fe8c299e88
[09-09 16:46:01 ty D][4df4][httpc.c:623] Connect: a6.tuyacn.com Port: 443  -->>
[09-09 16:46:01 ty D][4df4][tcp_transporter.c:37] dns mode by ip 2
[09-09 16:46:01 ty D][4df4][uni_network.c:230] unw_gethostbyname a6.tuyacn.com, prio 1
[09-09 16:46:01 ty D][4df4][uni_network.c:246] use dynamic dns ip:47.116.198.59 for domain:a6.tuyacn.com
[09-09 16:46:01 ty D][4df4][tcp_transporter.c:44] DNS parse type:2
[09-09 16:46:01 ty D][4df4][tcp_transporter.c:85] bind  port:0 ok
[09-09 16:46:01 ty D][4df4][tuya_tls.c:979] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1
[09-09 16:46:01 ty D][4df4][tuya_tls.c:988] TUYA_TLS Begin Connect a6.tuyacn.com:443
[09-09 16:46:01 ty D][4df4][tuya_tls.c:738] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED
[09-09 16:46:01 ty D][4df4][tuya_tls.c:751] load tuya cert.
[09-09 16:46:01 ty D][4df4][tuya_cert_manager.c:213] p_url:a6.tuyacn.com, rcs.urlx:h6.iot-dns.com
[09-09 16:46:01 ty D][4df4][tuya_cert_manager.c:236] tuya public url
[09-09 16:46:01 ty D][4df4][tuya_cert_manager.c:1100] parse crt <0> len <540> ret <0>
[09-09 16:46:01 ty D][4df4][tuya_tls.c:1077] socket fd is set. set to inner send/recv to handshake
[09-09 16:46:01 ty D][4df4][tuya_tls.c:711] mbedtls_cert_pkey_free.
[09-09 16:46:01 ty D][4df4][tuya_tls.c:1139] handshake finish for a6.tuyacn.com. set send/recv to user set
[09-09 16:46:01 ty D][4df4][tuya_tls.c:1145] TUYA_TLS Success Connect a6.tuyacn.com:443 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
[09-09 16:46:01 ty D][4df4][httpc.c:625] Connect: a6.tuyacn.com Port: 443  --<< ,r:0
[09-09 16:46:01 ty D][4df4][iot_httpc.c:619] Decode Rev:{"t":1757407561,"success":true}
[09-09 16:46:01 ty E][4df4][tuya_svc_upgrade.c:885] result null
[09-09 16:46:01 ty D][4df4][tuya_svc_upgrade.c:966] silent get firmware fail
[09-09 16:46:01 ty D][4df4][tuya_svc_upgrade.c:473] next detect timer: 21600s
[09-09 16:46:02 ty D][2374][tuya_ipc_p2p.c:3110] recv session[65537] high cmd[8] low cmd[0] len[8] req_id[43]
[09-09 16:46:02 ty D][2374][ty_sdk_media_callback.c:276] p2p rev event cb=[1]
[09-09 16:46:02 ty D][2374][ty_sdk_media_callback.c:306] enbale audio speaker
Audio Out GetPubAttr samplerate:16000
Audio Out GetPubAttr   bitwidth:16
Audio Out GetPubAttr  soundmode:1
Audio Out GetPubAttr    frmNum:20
Audio Out GetPubAttr  numPerFrm:640
Audio Out GetPubAttr    chnCnt:1
warn: shm_init,53shm init already
Audio Out GetVol    vol:80
Audio Out GetGain       gain : 31
[09-09 16:46:02 ty D][2374][tuya_ipc_media_adapter.c:618] speak event start success by user handle [0xaa07e8]
[09-09 16:46:02 ty D][2374][tuya_ipc_p2p.c:2613] speak start success!
[09-09 16:46:03 ty D][a374][tuya_ipc_p2p.c:2359] session recv audio cnt [1]
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939098]
####################### Write data: 320,recive data :320
Play: TotalNum 20, FreeNum 20, BusyNum 0
Play: TotalNum 20, FreeNum 19, BusyNum 1
Play: TotalNum 20, FreeNum 18, BusyNum 2
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939109]
Play: TotalNum 20, FreeNum 17, BusyNum 3
Play: TotalNum 20, FreeNum 16, BusyNum 4
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939142]
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939143]
Play: TotalNum 20, FreeNum 15, BusyNum 5
Play: TotalNum 20, FreeNum 14, BusyNum 6
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939183]
Play: TotalNum 20, FreeNum 13, BusyNum 7
Play: TotalNum 20, FreeNum 12, BusyNum 8
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939226]
Play: TotalNum 20, FreeNum 11, BusyNum 9
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939227]
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939263]
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939307]
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939308]
[09-09 16:46:03 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436362512,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":8619,"channels":[[6,2204,0,2204,0,0,0,-1,348,-1,-1,-1]]}
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939343]
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939388]
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939389]
[09-09 16:46:03 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939422]
Play: TotalNum 20, FreeNum 10, BusyNum 10
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939462]
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939503]
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939504]
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939544]
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939586]
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939626]
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939667]
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939668]
Play: TotalNum 20, FreeNum 9, BusyNum 11
Play: TotalNum 20, FreeNum 8, BusyNum 12
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939705]
[09-09 16:46:04 ty D][a374][tuya_ipc_p2p.c:2378] session send audio cnt [301]
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939744]
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939785]
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939824]
[09-09 16:46:04 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939825]
[09-09 16:46:05 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:46:05 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:46:05 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28616 Q:0
[09-09 16:46:05 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 40
[09-09 16:46:05 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:46:05 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436364035,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":13543,"channels":[[0,180,264,180,264,2080,11056,6161,6137,5466,3405,5466],[1,1046665,0,1044857,0,1450416,1804,6522,6511,-1,-1,7382],[2,238736,27456,234416,41536,281592,52088,6642,6592,11399,11022,7382],[6,2572,0,-132,0,92712,0,3400,688,-1,-1,-1]]}
[09-09 16:46:05 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939825]
[09-09 16:46:05 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939870]
[09-09 16:46:05 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939903]
[09-09 16:46:05 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939953]
[09-09 16:46:05 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939954]
[09-09 16:46:05 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765939989]
[09-09 16:46:05 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940023]
[09-09 16:46:05 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940065]
[09-09 16:46:05 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940066]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940066]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940104]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940146]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940147]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940184]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940226]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940265]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940306]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940345]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940382]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940383]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940422]
[09-09 16:46:06 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940463]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940463]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940504]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940548]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940549]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940584]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940627]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940663]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940708]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940751]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940784]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940827]
[09-09 16:46:07 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940864]
[09-09 16:46:08 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940865]
[09-09 16:46:08 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940911]
[09-09 16:46:08 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940912]
[09-09 16:46:08 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940946]
[09-09 16:46:08 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765940985]
[09-09 16:46:08 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941027]
[09-09 16:46:08 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941028]
[09-09 16:46:08 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941063]
[09-09 16:46:08 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941103]
[09-09 16:46:08 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436367512,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":13619,"channels":[[6,2204,0,2204,0,0,0,-1,348,-1,-1,-1]]}
[09-09 16:46:09 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941144]
[09-09 16:46:09 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941182]
[09-09 16:46:09 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941222]
[09-09 16:46:09 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941266]
[09-09 16:46:09 ty D][4df4][simplekv.c:1137] read key:e1mtcgtk_ver isFuzzy:0 skipCnt:0
[09-09 16:46:09 ty D][4df4][simplekv.c:1165] no key find
[09-09 16:46:09 ty D][4df4][simplekv.c:1207] __read_kv_raw fail. -3
[09-09 16:46:09 ty D][4df4][simplekv.c:1246] __read_kv_with_decode fail. -3
[09-09 16:46:09 ty D][4df4][tuya_svc_upgrade_http.c:125] schema get:{"schemaId":"e1mtcgtk","version":""}
[09-09 16:46:09 ty D][4df4][iot_httpc.c:973] Post Data: {"schemaId":"e1mtcgtk","version":"","t":1757407569}
[09-09 16:46:09 ty D][4df4][iot_httpc.c:985] Post URL: https://a6.tuyacn.com/d.json?a=tuya.device.schema.newest.get&devId=6c9108853826b21b49bvi8&et=3&t=1757407569&v=1.1&sign=6c0780e9bbd22fd9f03c9a1e2e5913f5
[09-09 16:46:09 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941267]
[09-09 16:46:09 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941308]
[09-09 16:46:09 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941309]
[09-09 16:46:09 ty D][4df4][httpc.c:623] Connect: a6.tuyacn.com Port: 443  -->>
[09-09 16:46:09 ty D][4df4][tcp_transporter.c:37] dns mode by ip 2
[09-09 16:46:09 ty D][4df4][uni_network.c:230] unw_gethostbyname a6.tuyacn.com, prio 1
[09-09 16:46:09 ty D][4df4][uni_network.c:246] use dynamic dns ip:47.116.198.59 for domain:a6.tuyacn.com
[09-09 16:46:09 ty D][4df4][tcp_transporter.c:44] DNS parse type:2
[09-09 16:46:09 ty D][4df4][tcp_transporter.c:85] bind  port:0 ok
[09-09 16:46:09 ty D][4df4][tuya_tls.c:979] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1
[09-09 16:46:09 ty D][4df4][tuya_tls.c:988] TUYA_TLS Begin Connect a6.tuyacn.com:443
[09-09 16:46:09 ty D][4df4][tuya_tls.c:738] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED
[09-09 16:46:09 ty D][4df4][tuya_tls.c:751] load tuya cert.
[09-09 16:46:09 ty D][4df4][tuya_cert_manager.c:213] p_url:a6.tuyacn.com, rcs.urlx:h6.iot-dns.com
[09-09 16:46:09 ty D][4df4][tuya_cert_manager.c:236] tuya public url
[09-09 16:46:09 ty D][4df4][tuya_cert_manager.c:1100] parse crt <0> len <540> ret <0>
[09-09 16:46:09 ty D][4df4][tuya_tls.c:1077] socket fd is set. set to inner send/recv to handshake
[09-09 16:46:09 ty E][a374][tuya_ipc_p2p.c:4777] no audio or video data count = [1000]
[09-09 16:46:09 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941344]
[09-09 16:46:09 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941345]
[09-09 16:46:09 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941386]
[09-09 16:46:09 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941428]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941428]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941464]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941465]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941506]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941507]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941547]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941584]
[09-09 16:46:10 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436369036,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":18544,"channels":[[0,180,264,180,264,2080,11056,6161,6137,5466,3405,5466],[1,1722122,0,1715370,0,2167504,3476,6522,6511,-1,-1,7382],[2,407296,89056,404416,103136,470988,128792,6642,6592,11399,11022,7382],[6,2572,0,-132,0,162888,0,3400,688,-1,-1,-1]]}
[09-09 16:46:10 ty D][2374][tuya_ipc_p2p.c:4987] session detect run
[09-09 16:46:10 ty D][2374][tuya_ipc_p2p.c:4965] session[65537] detect WaitCnt[0] SendCnt[608] RecvCnt[254]
[09-09 16:46:10 ty D][a374][tuya_ipc_p2p.c:2378] session send audio cnt [601]
[09-09 16:46:10 ty D][4df4][tuya_tls.c:711] mbedtls_cert_pkey_free.
[09-09 16:46:10 ty D][4df4][tuya_tls.c:1139] handshake finish for a6.tuyacn.com. set send/recv to user set
[09-09 16:46:10 ty D][4df4][tuya_tls.c:1145] TUYA_TLS Success Connect a6.tuyacn.com:443 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
[09-09 16:46:10 ty D][4df4][httpc.c:625] Connect: a6.tuyacn.com Port: 443  --<< ,r:0
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941585]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941626]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941627]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941663]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941664]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941705]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941706]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941744]
[09-09 16:46:10 ty D][4df4][iot_httpc.c:619] Decode Rev:{"result":{"schema":"","schemaId":"e1mtcgtk"},"t":1757407570,"success":true}
[09-09 16:46:10 ty D][4df4][tls_transporter.c:93] tls transporter close socket fd:33
[09-09 16:46:10 ty D][4df4][tcp_transporter.c:183] tcp transporter close socket fd:33
[09-09 16:46:10 ty D][4df4][tls_transporter.c:101] tls transporter close tls handler:0xacb9b8
[09-09 16:46:10 ty D][4df4][tuya_tls.c:1221] TUYA_TLS Disconnect ENTER
[09-09 16:46:10 ty D][4df4][tuya_tls.c:1246] TUYA_TLS Disconnect Success
[09-09 16:46:10 ty D][4df4][tuya_tls.c:941] tuya_tls_connect_destroy.
[09-09 16:46:10 ty D][4df4][tuya_svc_upgrade_http.c:133] schema get result:{"schema":"","schemaId":"e1mtcgtk"}
[09-09 16:46:10 ty D][4df4][tuya_svc_schema_upgrade.c:131] schema[e1mtcgtk] ver not update
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941789]
[09-09 16:46:10 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941790]
[09-09 16:46:11 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941790]
[09-09 16:46:11 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941825]
[09-09 16:46:11 ty D][a374][tuya_ipc_p2p.c:4311] session cmd send proc alive [2000] num[1]
[09-09 16:46:11 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941864]
[09-09 16:46:11 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941903]
[09-09 16:46:11 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941949]
[09-09 16:46:11 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941950]
[09-09 16:46:11 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765941988]
[09-09 16:46:11 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942023]
[09-09 16:46:11 ty D][a374][tuya_ipc_p2p.c:2359] session recv audio cnt [301]
[09-09 16:46:11 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942063]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942064]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942106]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942107]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942143]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942144]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942184]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942226]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942227]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942263]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942306]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942307]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942344]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942345]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942385]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942386]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942423]
[09-09 16:46:12 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942424]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942424]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942466]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942467]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942506]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942544]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942584]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942585]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942624]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942674]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942675]
[09-09 16:46:13 ty D][a374][tuya_ipc_p2p.c:4581] media send proc alive [4000]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942703]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942745]
[09-09 16:46:13 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436372513,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":18621,"channels":[[6,2204,0,2204,0,0,0,-1,348,-1,-1,-1]]}
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942784]
[09-09 16:46:13 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942826]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942826]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942827]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942864]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942903]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942944]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765942989]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943023]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943069]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943103]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943144]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943145]
[09-09 16:46:14 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943183]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943227]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943228]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943270]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943304]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943345]
[09-09 16:46:15 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:46:15 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:46:15 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28617 Q:0
[09-09 16:46:15 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 41
[09-09 16:46:15 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:46:15 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436374040,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":23548,"channels":[[0,180,264,180,264,2080,11056,6161,6137,5466,3405,5466],[1,2352693,0,2333797,0,2842668,5148,6522,6511,-1,-1,7382],[2,577232,151008,571472,160512,660928,200448,6642,6592,11399,11022,7382],[6,2572,0,-132,0,233064,0,3400,688,-1,-1,-1]]}
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943346]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943383]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943425]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943426]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943464]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943506]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943507]
[09-09 16:46:15 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943547]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943583]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943625]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943628]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943665]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943666]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943704]
[09-09 16:46:16 ty D][a374][tuya_ipc_p2p.c:2378] session send audio cnt [901]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943705]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943749]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943783]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943784]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943831]
[09-09 16:46:16 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943832]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943832]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943863]
[09-09 16:46:17 ty D][4df4][tuya_svc_schema_upgrade.c:170] next schema get slot 58462.
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943908]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943909]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943947]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765943987]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944023]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944024]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944064]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944065]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944104]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944106]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944143]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944188]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944189]
[09-09 16:46:17 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944226]
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944226]
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944263]
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944304]
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944305]
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944349]
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944385]
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944423]
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944465]
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944508]
[09-09 16:46:18 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436377517,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":23624,"channels":[[6,2204,0,2204,0,0,0,-1,348,-1,-1,-1]]}
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944543]
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944583]
[09-09 16:46:18 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944625]
[09-09 16:46:19 ty D][2374][tuya_ipc_p2p.c:4230] session cmd recv proc alive [2000] num[1]
[09-09 16:46:19 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944625]
[09-09 16:46:19 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944663]
[09-09 16:46:19 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944708]
[09-09 16:46:19 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944709]
[09-09 16:46:19 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944744]
[09-09 16:46:19 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944790]
[09-09 16:46:19 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944823]
[09-09 16:46:19 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944824]
[09-09 16:46:19 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944866]
[09-09 16:46:19 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944867]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944905]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944948]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944949]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944992]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765944993]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945024]
[09-09 16:46:20 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436379045,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":28553,"channels":[[0,180,264,180,264,2080,11056,6161,6137,5466,3405,5466],[1,3078505,0,3066473,0,3635788,6732,6522,6511,-1,-1,7382],[2,747168,210496,745008,224576,854688,296708,6642,6592,11399,11022,7382],[6,2572,0,-132,0,300316,0,3400,688,-1,-1,-1]]}
[09-09 16:46:20 ty D][a374][tuya_ipc_p2p.c:2359] session recv audio cnt [601]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945064]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945065]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945106]
[09-09 16:46:20 ty D][2374][tuya_ipc_p2p.c:4987] session detect run
[09-09 16:46:20 ty D][2374][tuya_ipc_p2p.c:4965] session[65537] detect WaitCnt[0] SendCnt[1116] RecvCnt[609]
[09-09 16:46:20 ty E][a374][tuya_ipc_p2p.c:4777] no audio or video data count = [2000]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945142]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945143]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945185]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945222]
[09-09 16:46:20 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945266]
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945266]
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945267]
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945303]
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945304]
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945347]
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945385]
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945423]
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945463]
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945508]
####################### Write data: 320,recive data :320
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945509]
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945543]
Play: TotalNum 20, FreeNum 20, BusyNum 0
Play: TotalNum 20, FreeNum 19, BusyNum 1
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945585]
Play: TotalNum 20, FreeNum 18, BusyNum 2
Play: TotalNum 20, FreeNum 17, BusyNum 3
[09-09 16:46:21 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945623]
Play: TotalNum 20, FreeNum 16, BusyNum 4
Play: TotalNum 20, FreeNum 15, BusyNum 5
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945667]
Play: TotalNum 20, FreeNum 14, BusyNum 6
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945668]
Play: TotalNum 20, FreeNum 13, BusyNum 7
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945703]
Play: TotalNum 20, FreeNum 12, BusyNum 8
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945704]
Play: TotalNum 20, FreeNum 11, BusyNum 9
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945745]
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945746]
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945783]
[09-09 16:46:22 ty D][a374][tuya_ipc_p2p.c:2378] session send audio cnt [1201]
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945824]
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945867]
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945868]
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945903]
[09-09 16:46:22 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945942]
[09-09 16:46:23 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945942]
[09-09 16:46:23 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765945982]
[09-09 16:46:23 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946026]
[09-09 16:46:23 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946066]
[09-09 16:46:23 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946102]
[09-09 16:46:23 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946148]
[09-09 16:46:23 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946182]
[09-09 16:46:23 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436382517,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":28624,"channels":[[6,2204,0,2204,0,0,0,-1,348,-1,-1,-1]]}
[09-09 16:46:23 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946226]
[09-09 16:46:23 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946227]
[09-09 16:46:23 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946263]
[09-09 16:46:23 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946306]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946306]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946347]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946383]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946426]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946467]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946503]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946548]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946582]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946622]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946665]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946666]
[09-09 16:46:24 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946703]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946703]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946748]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946749]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946783]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946825]
[09-09 16:46:25 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:46:25 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:46:25 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28618 Q:0
[09-09 16:46:25 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 42
[09-09 16:46:25 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:46:25 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436384047,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":33555,"channels":[[0,180,264,180,264,2080,11056,6161,6137,5466,3405,5466],[1,3696894,0,3684222,0,4295728,8360,6522,6511,-1,-1,7382],[2,917104,274208,915664,288288,1045700,375980,6642,6592,11399,11022,7382],[6,2572,0,-132,0,370492,0,3400,688,-1,-1,-1]]}
[09-09 16:46:25 ty D][a374][tuya_ipc_p2p.c:4581] media send proc alive [6000]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946863]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946903]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946947]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946948]
Play: TotalNum 20, FreeNum 10, BusyNum 10
Play: TotalNum 20, FreeNum 9, BusyNum 11
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765946984]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765947027]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765947063]
[09-09 16:46:25 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765947064]
[09-09 16:46:26 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765947064]
[09-09 16:46:26 ty I][a374][ty_sdk_media_callback.c:653] Rev Audio. size:[320] audio_codec:[101] audio_sample:[16000] audio_databits:[16] audio_channel:[0] p_audio_frame->pts:[0]  p_audio_frame->timestamp:[765947107]
[09-09 16:46:26 ty D][2374][tuya_ipc_p2p.c:3110] recv session[65537] high cmd[8] low cmd[0] len[8] req_id[0]
[09-09 16:46:26 ty D][2374][ty_sdk_media_callback.c:276] p2p rev event cb=[2]
[09-09 16:46:26 ty D][2374][ty_sdk_media_callback.c:312] disable audio speaker
[09-09 16:46:27 ty D][2374][tuya_ipc_media_adapter.c:659] speak event stop success by user handle [0xaa07e8]
[09-09 16:46:27 ty D][2374][tuya_ipc_p2p.c:2645] speak stop success!
[09-09 16:46:27 ty D][a374][tuya_ipc_media_adapter.c:793] speak is idle, or user handle is not match! speak is already started by:[(nil)], now handle is:[0xaa07e8]
[09-09 16:46:28 ty D][a374][tuya_ipc_p2p.c:2378] session send audio cnt [1501]
[09-09 16:46:28 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436387519,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":33626,"channels":[[6,2204,0,2204,0,0,0,-1,348,-1,-1,-1]]}
[09-09 16:46:30 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436389050,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":38558,"channels":[[0,208,292,208,292,2216,11192,6161,6137,5466,3405,5466],[1,4376790,0,4368790,0,5033904,9988,6522,6511,-1,-1,7382],[2,1087040,284064,1082000,298144,1236552,389944,6642,6592,11399,11022,7382],[6,2572,0,-132,0,437744,0,3400,688,-1,-1,-1]]}
[09-09 16:46:30 ty D][2374][tuya_ipc_p2p.c:4987] session detect run
[09-09 16:46:30 ty D][2374][tuya_ipc_p2p.c:4965] session[65537] detect WaitCnt[0] SendCnt[1621] RecvCnt[807]
[09-09 16:46:31 ty D][a374][tuya_ipc_p2p.c:2430] media recv proc alive [4000]
[09-09 16:46:31 ty E][a374][tuya_ipc_p2p.c:4777] no audio or video data count = [3000]
[09-09 16:46:31 ty D][a374][tuya_ipc_p2p.c:4311] session cmd send proc alive [4000] num[1]
[09-09 16:46:33 ty D][b214][tuya_imm_service_log.c:755] trigger upload timer....
[09-09 16:46:33 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436392523,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"","s":"6c9108853826b21b49bvi81757407548LaA34kjv","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":38630,"channels":[[6,2204,0,2204,0,0,0,-1,348,-1,-1,-1]]}
[09-09 16:46:33 ty D][cdf4][tuya_imm_service_log.c:405] upload timer trigger....
[09-09 16:46:33 ty D][cdf4][tuya_imm_service_log.c:428] start send.
[09-09 16:46:33 ty D][cdf4][mqc_app.c:1001] Send MQTT Msg.P:312 N:28619 Q:0
[09-09 16:46:33 ty D][cdf4][tuya_svc_mqtt_client.c:421] packet id: 43
[09-09 16:46:34 ty D][a374][tuya_ipc_p2p.c:2378] session send audio cnt [1801]
[09-09 16:46:35 ty I][b214][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":1757436394050,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_stats","tid":"72d24eab-bcb8-477f-a3ad-21ed313c040f_6c9108853826b21b49bvi8_1757407548622","s":"6c9108853826b21b49bvi817574075484NXzBpr3","l":"6c9108853826b21b49bvi8","r":"ay1746622066937sx1YA","o":1,"d":43558,"channels":[[0,208,292,208,292,2216,11192,6161,6137,5466,3405,5466],[1,5033657,0,5029705,0,5734204,11748,6522,6511,-1,-1,7382],[2,1256976,284064,1254096,298144,1425392,391880,6642,6592,11399,11022,7382],[6,2572,0,-132,0,510844,0,3400,688,-1,-1,-1]]}
[09-09 16:46:37 ty D][a374][tuya_ipc_p2p.c:4581] media send proc alive [8000]
