// Copyright 2020-2021 Beken
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
//     http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
#include <common/bk_include.h>
#include <components/ate.h>
#include <os/mem.h>
#include <driver/flash.h>
#include <os/os.h>
#include "bk_pm_model.h"
#include "flash_driver.h"
#include "flash_hal.h"
#include "sys_driver.h"
#include "driver/flash_partition.h"
#include <modules/chip_support.h>
#include "flash_bypass.h"
#include "mb_ipc_cmd.h"
#if CONFIG_FLASH_QUAD_ENABLE
extern UINT8 flash_get_line_mode(void);
extern void flash_set_line_mode(UINT8 mode);
#ifdef CONFIG_FREERTOS_SMP
#include "spinlock.h"
static volatile spinlock_t flash_spin_lock = SPIN_LOCK_INIT;
#endif // CONFIG_FREERTOS_SMP
	flash_hal_t hal;
	uint32_t flash_id;
	const flash_config_t *flash_cfg;
} flash_driver_t;
#define FLASH_GET_PROTECT_CFG(cfg) ((cfg) & FLASH_STATUS_REG_PROTECT_MASK)
#define FLASH_GET_CMP_CFG(cfg)     (((cfg) >> FLASH_STATUS_REG_PROTECT_OFFSET) & FLASH_STATUS_REG_PROTECT_MASK)
#define FLASH_RETURN_ON_DRIVER_NOT_INIT() do {\
	if (!s_flash_is_init) {\
		return BK_ERR_FLASH_NOT_INIT;\
} while(0)
#define FLASH_RETURN_ON_WRITE_ADDR_OUT_OF_RANGE(addr, len) do {\
	if ((addr >= s_flash.flash_cfg->flash_size) ||\
		(len > s_flash.flash_cfg->flash_size) ||\
		((addr + len) > s_flash.flash_cfg->flash_size)) {\
		FLASH_LOGW("write error[addr:0x%x len:0x%x]\r\n", addr, len);\
		return BK_ERR_FLASH_ADDR_OUT_OF_RANGE;\
} while(0)
#define FLASH_CPU_MASTER		0
#define FLASH_CPU_SLAVE1		1
static const flash_config_t flash_config[] = {
	/* flash_id, status_reg_size, flash_size,    line_mode,           cmp_post, protect_post, protect_mask, protect_all, protect_none, protect_half, unprotect_last_block. quad_en_post, quad_en_val, coutinuous_read_mode_bits_val, mode_sel*/
	{0x1C7016,   1,               FLASH_SIZE_4M, FLASH_LINE_MODE_FOUR, 0,        2,            0x1F,         0x1F,        0x00,         0x16,         0x01B,                9,            1,           0xA5,                          0x02}, //en_25qh32b
	{0x1C7015,   1,               FLASH_SIZE_2M, FLASH_LINE_MODE_FOUR, 0,        2,            0x1F,         0x1F,        0x00,         0x0d,         0x0d,                 9,            1,           0xA5,                          0x02}, //en_25qh16b
	{0x0B4014,   2,               FLASH_SIZE_1M, FLASH_LINE_MODE_FOUR, 14,       2,            0x1F,         0x1F,        0x00,         0x0C,         0x101,                9,            1,           0xA0,                          0x02}, //xtx_25f08b
	{0x0B4015,   2,               FLASH_SIZE_2M, FLASH_LINE_MODE_FOUR, 14,       2,            0x1F,         0x1F,        0x00,         0x0D,         0x101,                9,            1,           0xA0,                          0x02}, //xtx_25f16b
	{0x0B4016,   2,               FLASH_SIZE_4M, FLASH_LINE_MODE_FOUR, 14,      2,            0x1F,         0x1F,        0x00,         0x0E,         0x101,                9,           1,            0xA0,                          0x02}, //xtx_25f32b
	{0x0B4017,   2,               FLASH_SIZE_8M, FLASH_LINE_MODE_FOUR, 14,       2,            0x1F,         0x05,        0x00,         0x0E,         0x109,                9,            1,           0xA0,                          0x02}, //xtx_25f64b
	{0x0B6017,   2,               FLASH_SIZE_8M, FLASH_LINE_MODE_FOUR,  0,	    2,            0x0F,         0x0F,        0x00,         0x0A,         0x00E,                9,            1,           0xA0,                          0x02}, //xt_25q64d
	{0x0B6018,   2,               FLASH_SIZE_16M, FLASH_LINE_MODE_FOUR,  0,	    2,            0x0F,         0x0F,        0x00,         0x0A,         0x00E,                9,            1,           0xA0,                          0x02}, //xt_25q128d
	{0x0E4016,   2,               FLASH_SIZE_4M, FLASH_LINE_MODE_FOUR, 14,       2,            0x1F,         0x1F,        0x00,         0x0E,         0x101,                9,            1,           0xA0,                          0x02}, //xtx_FT25H32
	{0x1C4116,   1,               FLASH_SIZE_4M, FLASH_LINE_MODE_FOUR, 0,        2,            0x1F,         0x1F,        0x00,         0x0E,         0x00E,                9,            1,           0xA0,                          0x02}, //en_25qe32a(not support 4 line)
	{0x5E5018,   1,               FLASH_SIZE_16M, FLASH_LINE_MODE_FOUR, 0, 	    2,            0x0F,         0x0F,        0x00,         0x0A,         0x00E,                9,            1,           0xA0,                          0x02}, //zb_25lq128c
	{0xC84015,   2,               FLASH_SIZE_2M, FLASH_LINE_MODE_FOUR, 14,       2,            0x1F,         0x1F,        0x00,         0x0D,         0x101,                9,            1,           0xA0,                          0x02}, //gd_25q16c
	{0xC84017,   1,               FLASH_SIZE_8M, FLASH_LINE_MODE_FOUR, 14,       2,            0x1F,         0x1F,        0x00,         0x0D,         0x101,                9,            1,           0xA0,                          0x02}, //gd_25q16c
	{0xC84016,   2,               FLASH_SIZE_4M, FLASH_LINE_MODE_FOUR, 14,      2,            0x1F,         0x1F,        0x00,         0x0E,         0x00E,                9,            1,           0xA0,                          0x02}, //gd_25q32c
	{0xC86018,   2,               FLASH_SIZE_16M,FLASH_LINE_MODE_FOUR, 0,       2,            0x0F,         0x0F,        0x00,         0x0A,         0x00E,                9,            1,           0xA0,                          0x02}, //gd_25lq128e
	{0xC86515,   2,               FLASH_SIZE_2M, FLASH_LINE_MODE_FOUR, 14,       2,            0x1F,         0x1F,        0x00,         0x0D,         0x101,                9,            1,           0xA0,                          0x02}, //gd_25w16e
	{0xC86516,   2,               FLASH_SIZE_4M, FLASH_LINE_MODE_FOUR, 14,      2,            0x1F,         0x1F,        0x00,         0x0E,         0x00E,                9,            1,           0xA0,                          0x02}, //gd_25wq32e
	{0xEF4016,   2,               FLASH_SIZE_4M, FLASH_LINE_MODE_FOUR, 14,       2,            0x1F,         0x1F,        0x00,         0x00,         0x101,                9,            1,           0xA0,                          0x02}, //w_25q32(bfj)
	{0x204118,	 2, 			  FLASH_SIZE_16M,FLASH_LINE_MODE_FOUR, 0,		2,			  0x0F, 		0x0F,		 0x00,		   0x0A,		 0x00E, 			   9,			 1, 		  0xA0, 						 0x02}, //xm_25qu128c
	{0x204016,   2,               FLASH_SIZE_4M, FLASH_LINE_MODE_FOUR, 14,       2,            0x1F,         0x1F,        0x00,         0x0E,         0x101,                9,            1,           0xA0,                          0x02}, //xmc_25qh32b
	{0xC22315,   1,               FLASH_SIZE_2M, FLASH_LINE_MODE_FOUR, 0,        2,            0x0F,         0x0F,        0x00,         0x0A,         0x00E,                6,            1,           0xA5,                          0x02}, //mx_25v16b
	{0xEB6015,   2,               FLASH_SIZE_2M, FLASH_LINE_MODE_FOUR, 14,       2,            0x1F,         0x1F,        0x00,         0x0D,         0x101,                9,            1,           0xA0,                          0x02}, //zg_th25q16b
	{0xC86517,	 2, 			  FLASH_SIZE_8M, FLASH_LINE_MODE_FOUR, 14,		2,			  0x1F, 		0x1F,		 0x00,		   0x0E,		 0x00E, 			   9,			 1, 		  0xA0, 						 0x02}, //gd_25Q32E
	{0x000000,   2,               FLASH_SIZE_4M, FLASH_LINE_MODE_TWO, 0,        2,            0x1F,         0x00,        0x00,         0x00,         0x000,                0,            0,           0x00,                          0x02}, //default
static flash_driver_t s_flash = {0};
static bool s_flash_is_init = false;
static beken_mutex_t s_flash_mutex = NULL;
static PM_STATUS flash_ps_status;
static flash_ps_callback_t s_flash_ps_suspend_cb = NULL;
static flash_ps_callback_t s_flash_ps_resume_cb = NULL;
#if (CONFIG_SOC_BK7256XX)
static uint32_t s_hold_low_speed_status = 0;
#define FLASH_MAX_WAIT_CB_CNT (4)
static flash_wait_callback_t s_flash_wait_cb[FLASH_MAX_WAIT_CB_CNT] = {NULL};
static volatile flash_op_status_t s_flash_op_status = 0;
static inline uint32_t flash_enter_critical()
	uint32_t flags = rtos_disable_int();
	spin_lock(&flash_spin_lock);
	return flags;
static inline void flash_exit_critical(uint32_t flags)
	spin_unlock(&flash_spin_lock);
	rtos_enable_int(flags);
#if CONFIG_FLASH_MB && (CONFIG_CPU_CNT > 1)
#include <driver/mailbox_channel.h>
#if CONFIG_CACHE_ENABLE
#include "cache.h"
enum
	IPC_ERASE_COMPLETE = 0,
	IPC_ERASE_REQ,
	IPC_ERASE_ACK,
enum
	IPC_FLASH_OP_COMPLETE = 0,
	IPC_FLASH_OP_REQ,
	IPC_FLASH_OP_ACK,
enum
	IPC_FLASH_OP_START = 0,
	IPC_FLASH_OP_END,
#if CONFIG_SYS_CPU0
#include <driver/aon_rtc.h>
static volatile uint32_t flash_erase_ipc_state = IPC_ERASE_COMPLETE;
#define FLASH_WAIT_ACK_TIMEOUT 5000
#if 1  // new design of flash operation notification.
static bk_err_t send_flash_op_state(uint8_t state)
	uint64_t us_start = 0;
	uint64_t us_end = 0;
	flash_erase_ipc_state = IPC_FLASH_OP_REQ;
	mb_chnl_cmd_t  cmd_buf;
	cmd_buf.hdr.data = 0; /* clear hdr. */
	cmd_buf.hdr.cmd  = state;
	cmd_buf.param1 = flash_erase_ipc_state;
	bk_err_t   ret_val = mb_chnl_write(MB_CHNL_FLASH, &cmd_buf);
	if(ret_val != BK_OK)
		return ret_val;
#if CONFIG_AON_RTC
	us_start = bk_aon_rtc_get_us();
	for(int i = 0; i < 2000; i++)
		if(flash_erase_ipc_state == IPC_FLASH_OP_ACK)
#if CONFIG_AON_RTC
		us_end = bk_aon_rtc_get_us();
		// wait ack time should not be more than 5 ms
		if((us_end - us_start) > FLASH_WAIT_ACK_TIMEOUT)
			return BK_FAIL;
	return BK_OK;
extern int mb_ipc_cpu_is_power_on(u32 cpu_id);
bk_err_t send_flash_op_prepare(void)			// CPU0 notify CPU1 before flash operation
	bk_err_t   ret_val = BK_OK;
	#if (CONFIG_CPU_CNT > 1)
	if( !mb_ipc_cpu_is_power_on(1) )  // cpu1 power off!
		return BK_OK;
	ret_val = send_flash_op_state(IPC_FLASH_OP_START);
	return ret_val;
bk_err_t send_flash_op_finish(void)			// CPU0 notify CPU1 after flash operation
		return BK_OK;
	ret_val = send_flash_op_state(IPC_FLASH_OP_END);
	return ret_val;
static bk_err_t send_pause_cmd(uint8_t log_chnl)
	cmd_buf.hdr.cmd  = 1;
	flash_erase_ipc_state = IPC_ERASE_REQ;
	cmd_buf.param1 = (u32)&flash_erase_ipc_state;
	return mb_chnl_write(log_chnl, &cmd_buf);
static bk_err_t send_flash_op_prepare(void)			//CPU0 notify CPU1 before flash operation
	send_pause_cmd(MB_CHNL_FLASH);
		flush_dcache((void *)&flash_erase_ipc_state, 4);
		if(flash_erase_ipc_state == IPC_ERASE_ACK)
		//wait ack time should not be more than 5 ms
			return BK_FAIL;
	return BK_OK;
static bk_err_t send_flash_op_finish(void)			//CPU0 notify CPU1 after flash operation
	return BK_OK;
#if CONFIG_SYS_CPU1
extern void lcd_hal_rgb_int_enable(bool is_sof_en, bool is_eof_en);
__attribute__((section(".iram"))) static void mb_flash_ipc_rx_isr(void *chn_param, mb_chnl_cmd_t *cmd_buf)
	volatile uint32_t * stat_addr = (volatile uint32_t *)cmd_buf->param1;
	flush_dcache((void *)stat_addr, 4);
	//only puase cpu1 when flash erasing
	if(*(stat_addr) == IPC_ERASE_REQ)
		bk_flash_set_operate_status(FLASH_OP_BUSY);
		*(stat_addr) = IPC_ERASE_ACK;
#if CONFIG_LCD
        lcd_hal_rgb_int_enable(0, 0);
		while(*(stat_addr) != IPC_ERASE_COMPLETE)
#if CONFIG_LCD
        lcd_hal_rgb_int_enable(0, 1);
		bk_flash_set_operate_status(FLASH_OP_IDLE);
static bk_err_t mb_flash_ipc_init(void)
	bk_err_t ret_code = mb_chnl_open(MB_CHNL_FLASH, NULL);
	if(ret_code != BK_OK)
		return ret_code;
#if CONFIG_SYS_CPU1
	// call chnl driver to register isr callback;
	mb_chnl_ctrl(MB_CHNL_FLASH, MB_CHNL_SET_RX_ISR, (void *)mb_flash_ipc_rx_isr);
	return ret_code;
static void mb_flash_ipc_deinit(void)
	mb_chnl_close(MB_CHNL_FLASH);
bk_err_t bk_flash_register_wait_cb(flash_wait_callback_t wait_cb)
	uint32_t i = 0;
	for(i = 0; i < FLASH_MAX_WAIT_CB_CNT; i++)
		if(s_flash_wait_cb[i] == NULL)
			s_flash_wait_cb[i] = wait_cb;
	if(i == FLASH_MAX_WAIT_CB_CNT)
		FLASH_LOGE("cb is full\r\n");
		return BK_ERR_FLASH_WAIT_CB_FULL;
	return BK_OK;
bk_err_t bk_flash_unregister_wait_cb(flash_wait_callback_t wait_cb)
	uint32_t i = 0;
		if(s_flash_wait_cb[i] == wait_cb)
			s_flash_wait_cb[i] = NULL;
		FLASH_LOGE("cb isn't registered\r\n");
		return BK_ERR_FLASH_WAIT_CB_NOT_REGISTER;
	return BK_OK;
__attribute__((section(".itcm_sec_code"))) void flash_waiting_cb(void)
	uint32_t i = 0;
		if(s_flash_wait_cb[i])
			s_flash_wait_cb[i]();
static UINT32 flash_ps_suspend(UINT32 ps_level)
	PM_STATUS *flash_ps_status_ptr = &flash_ps_status;
	switch (ps_level) {
	case NORMAL_PS:
	case LOWVOL_PS:
	case DEEP_PS:
	case IDLE_PS:
		if (s_flash_ps_suspend_cb) {
			s_flash_ps_suspend_cb();
		if (FLASH_LINE_MODE_FOUR == bk_flash_get_line_mode())
			bk_flash_set_line_mode(FLASH_LINE_MODE_TWO);
		flash_ps_status_ptr->bits.unconditional_ps_sleeped = 1;
		flash_ps_status_ptr->bits.normal_ps_sleeped = 1;
		flash_ps_status_ptr->bits.lowvol_ps_sleeped = 1;
		flash_ps_status_ptr->bits.deep_ps_sleeped = 1;
static UINT32 flash_ps_resume(UINT32 ps_level)
	switch (ps_level) {
	case NORMAL_PS:
	case LOWVOL_PS:
	case DEEP_PS:
	case IDLE_PS:
			bk_flash_set_line_mode(FLASH_LINE_MODE_FOUR);
		if (s_flash_ps_resume_cb) {
			s_flash_ps_resume_cb();
		flash_ps_status_ptr->bits.unconditional_ps_sleeped = 0;
		flash_ps_status_ptr->bits.normal_ps_sleeped = 0;
		flash_ps_status_ptr->bits.lowvol_ps_sleeped = 0;
		flash_ps_status_ptr->bits.deep_ps_sleeped = 0;
static PM_STATUS flash_ps_get_status(UINT32 flag)
	return flash_ps_status;
static DEV_PM_OPS_S flash_ps_ops = {
	.pm_init = NULL,
	.pm_deinit = NULL,
	.suspend = flash_ps_suspend,
	.resume = flash_ps_resume,
	.status = flash_ps_get_status,
	.get_sleep_time = NULL,
static void flash_init_common(void)
	int ret = rtos_init_mutex(&s_flash_mutex);
	BK_ASSERT(kNoErr == ret); /* ASSERT VERIFIED */
static void flash_deinit_common(void)
	int ret = rtos_deinit_mutex(&s_flash_mutex);
static void flash_get_current_config(void)
	bool cfg_success = false;
	for (uint32_t i = 0; i < (ARRAY_SIZE(flash_config) - 1); i++) {
		if (s_flash.flash_id == flash_config[i].flash_id) {
			s_flash.flash_cfg = &flash_config[i];
			cfg_success = true;
	if (!cfg_success) {
		s_flash.flash_cfg = &flash_config[ARRAY_SIZE(flash_config) - 1];
		for(int i = 0; i < 10; i++) {
			FLASH_LOGE("This flash is not identified, choose default config\r\n");
static uint32_t flash_get_protect_cfg(flash_protect_type_t type)
	switch (type) {
	case FLASH_PROTECT_NONE:
		return FLASH_GET_PROTECT_CFG(s_flash.flash_cfg->protect_none);
	case FLASH_PROTECT_ALL:
		return FLASH_GET_PROTECT_CFG(s_flash.flash_cfg->protect_all);
	case FLASH_PROTECT_HALF:
		return FLASH_GET_PROTECT_CFG(s_flash.flash_cfg->protect_half);
	case FLASH_UNPROTECT_LAST_BLOCK:
		return FLASH_GET_PROTECT_CFG(s_flash.flash_cfg->unprotect_last_block);
static void flash_set_protect_cfg(uint32_t *status_reg_val, uint32_t new_protect_cfg)
	*status_reg_val &= ~(s_flash.flash_cfg->protect_mask << s_flash.flash_cfg->protect_post);
	*status_reg_val |= ((new_protect_cfg & s_flash.flash_cfg->protect_mask) << s_flash.flash_cfg->protect_post);
static uint32_t flash_get_cmp_cfg(flash_protect_type_t type)
	switch (type) {
		return FLASH_GET_CMP_CFG(s_flash.flash_cfg->protect_none);
		return FLASH_GET_CMP_CFG(s_flash.flash_cfg->protect_all);
		return FLASH_GET_CMP_CFG(s_flash.flash_cfg->protect_half);
		return FLASH_GET_CMP_CFG(s_flash.flash_cfg->unprotect_last_block);
static void flash_set_cmp_cfg(uint32_t *status_reg_val, uint32_t new_cmp_cfg)
	*status_reg_val &= ~(FLASH_CMP_MASK << s_flash.flash_cfg->cmp_post);
	*status_reg_val |= ((new_cmp_cfg & FLASH_CMP_MASK) << s_flash.flash_cfg->cmp_post);
static bool flash_is_need_update_status_reg(uint32_t protect_cfg, uint32_t cmp_cfg, uint32_t status_reg_val)
	uint32_t cur_protect_val_in_status_reg = (status_reg_val >> s_flash.flash_cfg->protect_post) & s_flash.flash_cfg->protect_mask;
	uint32_t cur_cmp_val_in_status_reg = (status_reg_val >> s_flash.flash_cfg->cmp_post) & FLASH_CMP_MASK;
	if (cur_protect_val_in_status_reg != protect_cfg ||
		cur_cmp_val_in_status_reg != cmp_cfg) {
		return true;
		return false;
static void flash_set_protect_type(flash_protect_type_t type)
	uint32_t protect_cfg = flash_get_protect_cfg(type);
	uint32_t cmp_cfg = flash_get_cmp_cfg(type);
	uint32_t status_reg = flash_hal_read_status_reg(&s_flash.hal, s_flash.flash_cfg->status_reg_size);
	if (flash_is_need_update_status_reg(protect_cfg, cmp_cfg, status_reg)) {
		flash_set_protect_cfg(&status_reg, protect_cfg);
		flash_set_cmp_cfg(&status_reg, cmp_cfg);
		//FLASH_LOGD("write status reg:%x, status_reg_size:%d\r\n", status_reg, s_flash.flash_cfg->status_reg_size);
		flash_hal_write_status_reg(&s_flash.hal, s_flash.flash_cfg->status_reg_size, status_reg);
static void flash_set_qe(void)
	uint32_t status_reg;
	flash_hal_wait_op_done(&s_flash.hal);
	if (status_reg & (s_flash.flash_cfg->quad_en_val << s_flash.flash_cfg->quad_en_post)) {
	status_reg |= s_flash.flash_cfg->quad_en_val << s_flash.flash_cfg->quad_en_post;
static void flash_set_qwfr(void)
	flash_hal_set_mode(&s_flash.hal, s_flash.flash_cfg->mode_sel);
static void flash_read_common(uint8_t *buffer, uint32_t address, uint32_t len)
	uint32_t addr = address & (~FLASH_ADDRESS_MASK);
	uint32_t buf[FLASH_BUFFER_LEN] = {0};
	uint8_t *pb = (uint8_t *)&buf[0];
	if (len == 0) {
	while (len) {
		uint32_t int_level = flash_enter_critical();
		flash_hal_set_op_cmd_read(&s_flash.hal, addr);
		addr += FLASH_BYTES_CNT;
		for (uint32_t i = 0; i < FLASH_BUFFER_LEN; i++) {
			buf[i] = flash_hal_read_data(&s_flash.hal);
		flash_exit_critical(int_level);
		for (uint32_t i = address % FLASH_BYTES_CNT; i < FLASH_BYTES_CNT; i++) {
			*buffer++ = pb[i];
			address++;
			len--;
			if (len == 0) {
static void flash_read_word_common(uint32_t *buffer, uint32_t address, uint32_t len)
	//nt8_t *pb = (uint8_t *)&buf[0];
	uint32_t *pb = (uint32_t *)&buf[0];
	if (len == 0) {
	while (len) {
		for (uint32_t i = address % (FLASH_BYTES_CNT/4); i < (FLASH_BYTES_CNT/4); i++) {
			*buffer++ = pb[i];
			address++;
			len--;
			if (len == 0) {
//extern part_flag update_part_flag;
bool flash_is_area_write_disable(uint32_t addr)
	uint32_t firmware_area_end_address = 0;
	bk_logic_partition_t * flash_pt = NULL;
	flash_pt = bk_flash_partition_get_info(BK_PARTITION_BOOTLOADER);
	if(!flash_pt)
		FLASH_LOGE("get partition ota fail\r\n");
		return true;
	firmware_area_end_address = flash_pt->partition_start_addr + flash_pt->partition_length;
	if (addr < firmware_area_end_address) {
		FLASH_LOGE("valid write/erase start address = 0x%x, but current address = 0x%x.\r\n", firmware_area_end_address, addr);
		BK_ASSERT(addr >= firmware_area_end_address);
		return true;
	return false;
static bk_err_t flash_write_common(const uint8_t *buffer, uint32_t address, uint32_t len)
	uint32_t buf[FLASH_BUFFER_LEN];
	FLASH_RETURN_ON_WRITE_ADDR_OUT_OF_RANGE(addr, len);
	while (len) {
		os_memset(pb, 0xFF, FLASH_BYTES_CNT);
			pb[i] = *buffer++;
			address++;
			len--;
			if (len == 0) {
			flash_hal_write_data(&s_flash.hal, buf[i]);
		flash_hal_set_op_cmd_write(&s_flash.hal, addr);
	return BK_OK;
void flash_lock(void)
	if (s_flash_mutex)
		rtos_lock_mutex(&s_flash_mutex);
void flash_unlock(void)
	if (s_flash_mutex)
		rtos_unlock_mutex(&s_flash_mutex);
#if defined(CONFIG_SECURITY_OTA) && !defined(CONFIG_TFM_FWU)
static bk_err_t vote_flash_set_line_mode(flash_line_mode_t line_mode)
	flash_hal_clear_qwfr(&s_flash.hal);
#if CONFIG_SOC_BK7236XX
	sys_drv_set_sys2flsh_2wire(0);
	if (FLASH_LINE_MODE_TWO == line_mode) {
		flash_hal_set_dual_mode(&s_flash.hal);
	} else if (FLASH_LINE_MODE_FOUR == line_mode) {
		flash_hal_set_quad_m_value(&s_flash.hal, s_flash.flash_cfg->coutinuous_read_mode_bits_val);
		if (1 == s_flash.flash_cfg->quad_en_val) {
			flash_set_qe();
		flash_set_qwfr();
	sys_drv_set_sys2flsh_2wire(1);
	return BK_OK;
bk_err_t bk_flash_set_line_mode(flash_line_mode_t line_mode)
#if CONFIG_SYS_CPU1 && CONFIG_MAILBOX
		return vote_flash_set_line_mode(line_mode);
		FLASH_RETURN_ON_DRIVER_NOT_INIT();
#define FLASH_USER_CPU		FLASH_CPU_SLAVE1
		u32 send_line_mode = ((FLASH_USER_CPU) << 16) + (u32)line_mode;
		uint32_t ret_line_mode = ipc_vote_flash_line_mode(send_line_mode);
		uint32_t retry = 0;
		uint32_t ret = BK_OK;
		while(ret_line_mode != line_mode){
			if(retry > 3){
				FLASH_LOGE("%s retry 3 times fail\r\n", __func__);
				ret = BK_FAIL;
			retry++;
	return BK_OK;
bk_err_t bk_flash_driver_init(void)
	if (s_flash_is_init) {
		return BK_OK;
	bk_err_t ret_code = mb_flash_ipc_init();
		return ret_code;
	extern bk_err_t bk_flash_svr_init(void);
	int ret_val = bk_flash_svr_init();
		BK_LOGE("Flash", "flash svr create failed %d.\r\n", ret_val);
#if CONFIG_FLASH_ORIGIN_API
	if (FLASH_LINE_MODE_FOUR == flash_get_line_mode())
	os_memset(&s_flash, 0, sizeof(s_flash));
	flash_hal_init(&s_flash.hal);
	s_flash.flash_id = flash_hal_get_id(&s_flash.hal);
	FLASH_LOGI("id=0x%x\r\n", s_flash.flash_id);
	flash_get_current_config();
	flash_set_protect_type(FLASH_UNPROTECT_LAST_BLOCK);
#if (0 == CONFIG_JTAG)
	flash_hal_disable_cpu_data_wr(&s_flash.hal);
	bk_flash_set_line_mode(s_flash.flash_cfg->line_mode);
	flash_hal_set_default_clk(&s_flash.hal);
	#if CONFIG_ATE_TEST
	bk_flash_clk_switch(FLASH_SPEED_LOW, 0);
	bk_flash_clk_switch(FLASH_SPEED_HIGH, 0);
#if (CONFIG_SOC_BK7236XX)
	if((s_flash.flash_id >> FLASH_ManuFacID_POSI) == FLASH_ManuFacID_GD) {
		if((1 != sys_drv_flash_get_clk_sel()) || (1 != sys_drv_flash_get_clk_div())) {
			sys_drv_flash_set_clk_div(1); // dpll div 6 = 80M
			sys_drv_flash_cksel(1);
		if((1 != sys_drv_flash_get_clk_sel()) || (3 != sys_drv_flash_get_clk_div())) {
			sys_drv_flash_set_clk_div(3); // dpll div 10 = 48M
	flash_init_common();
	s_flash_is_init = true;
	return BK_OK;
bk_err_t bk_flash_driver_deinit(void)
		return BK_OK;
	mb_flash_ipc_deinit();
	flash_deinit_common();
	return BK_OK;
static bk_err_t flash_erase_block(uint32_t address, int type)
#if CONFIG_FLASH_MB && CONFIG_SYS_CPU0 && (CONFIG_CPU_CNT > 1)
	int ret = BK_OK;
	uint32_t erase_addr = address & FLASH_ERASE_SECTOR_MASK;
	flash_ps_suspend(NORMAL_PS);
	if (erase_addr >= s_flash.flash_cfg->flash_size) {
		FLASH_LOGW("erase error:invalid address 0x%x\r\n", erase_addr);
	if (flash_is_area_write_disable(address)) {
//CPU0 notfify CPU1 when operate flash, to fix LCD display issue while erasing
	ret = send_flash_op_prepare();
	if(ret != BK_OK)
		FLASH_LOGD("erase req failed, ret = 0x%x\n", ret );
	flash_hal_erase_block(&s_flash.hal, erase_addr, type);
	ret = send_flash_op_finish();
	if(ret != BK_OK)
		FLASH_LOGD("erase op_finish ret = 0x%x\n", ret );
	flash_ps_resume(NORMAL_PS);
	return BK_OK;
bk_err_t bk_flash_erase_sector(uint32_t address)
	return flash_erase_block(address, FLASH_OP_CMD_SE);
bk_err_t bk_flash_erase_32k(uint32_t address)
	return flash_erase_block(address, FLASH_OP_CMD_BE1);
bk_err_t bk_flash_erase_block(uint32_t address)
	return flash_erase_block(address, FLASH_OP_CMD_BE2);
bk_err_t bk_flash_read_bytes(uint32_t address, uint8_t *user_buf, uint32_t size)
	if (address >= s_flash.flash_cfg->flash_size) {
		FLASH_LOGW("read error:invalid address 0x%x\r\n", address);
	flash_read_common(user_buf, address, size);
	return BK_OK;
bk_err_t bk_flash_read_word(uint32_t address, uint32_t *user_buf, uint32_t size)
	flash_read_word_common(user_buf, address, size);
	return BK_OK;
bk_err_t bk_flash_write_bytes(uint32_t address, const uint8_t *user_buf, uint32_t size)
		FLASH_LOGW("write error:invalid address 0x%x\r\n", address);
	flash_write_common(user_buf, address, size);
	return BK_OK;
uint32_t bk_flash_get_id(void)
	return s_flash.flash_id;
flash_line_mode_t bk_flash_get_line_mode(void)
	return s_flash.flash_cfg->line_mode;
bk_err_t bk_flash_set_clk_dpll(void)
	sys_drv_flash_set_dpll();
	flash_hal_set_clk_dpll(&s_flash.hal);
	return BK_OK;
bk_err_t bk_flash_set_clk_dco(void)
	sys_drv_flash_set_dco();
	bool ate_enabled = ate_is_enabled();
	flash_hal_set_clk_dco(&s_flash.hal, ate_enabled);
	return BK_OK;
bk_err_t bk_flash_set_clk(flash_clk_src_t flash_src_clk, uint8_t flash_dpll_div)
	if ((FLASH_CLK_DPLL == flash_src_clk) && (flash_dpll_div == 0)) {
		FLASH_LOGE("flash 120M clock not support.\r\n");
		return BK_FAIL;
	if (FLASH_CLK_APLL == flash_src_clk) {
		FLASH_LOGE("flash apll clock not support.\r\n");
		return BK_FAIL;
	if((sys_drv_flash_get_clk_sel() == flash_src_clk) && (sys_drv_flash_get_clk_div() == flash_dpll_div)) {
		return BK_OK;
	if (FLASH_CLK_DPLL == flash_src_clk) {
		sys_drv_flash_set_clk_div(flash_dpll_div);
	sys_drv_flash_cksel(flash_src_clk);
	return BK_OK;
bk_err_t bk_flash_clk_switch(uint32_t flash_speed_type, uint32_t modules)
	int chip_id = 0;
	switch (flash_speed_type) {
		case FLASH_SPEED_LOW:
			s_hold_low_speed_status |= modules;
			FLASH_LOGD("%s: set low, 0x%x 0x%x\r\n", __func__, s_hold_low_speed_status, modules);
			if (s_hold_low_speed_status) {
				bk_flash_set_clk(FLASH_CLK_XTAL, FLASH_DPLL_DIV_VALUE_TEN);
		case FLASH_SPEED_HIGH:
			s_hold_low_speed_status &= ~(modules);
			FLASH_LOGD("%s: clear low bit, 0x%x 0x%x\r\n", __func__, s_hold_low_speed_status, modules);
			if (0 == s_hold_low_speed_status) {
				chip_id = bk_get_hardware_chip_id_version();
				//chipC version with GD flash switch to 80M for peformance
				if ((chip_id == CHIP_VERSION_C) && ((s_flash.flash_id >> FLASH_ManuFacID_POSI) == FLASH_ManuFacID_GD)) {
					bk_flash_set_clk(FLASH_CLK_DPLL, FLASH_DPLL_DIV_VALUE_SIX);
					bk_flash_set_clk(FLASH_CLK_DPLL, FLASH_DPLL_DIV_VALUE_TEN);
	return BK_OK;
bk_err_t bk_flash_write_enable(void)
	flash_hal_write_enable(&s_flash.hal);
	return BK_OK;
bk_err_t bk_flash_write_disable(void)
	flash_hal_write_disable(&s_flash.hal);
	return BK_OK;
uint16_t bk_flash_read_status_reg(void)
	uint16_t sr_data = flash_hal_read_status_reg(&s_flash.hal, s_flash.flash_cfg->status_reg_size);
	return sr_data;
bk_err_t bk_flash_write_status_reg(uint16_t status_reg_data)
	flash_hal_write_status_reg(&s_flash.hal, s_flash.flash_cfg->status_reg_size, status_reg_data);
	return BK_OK;
flash_protect_type_t bk_flash_get_protect_type(void)
	uint32_t type = 0;
	uint16_t protect_value = 0;
	protect_value = flash_hal_get_protect_value(&s_flash.hal, s_flash.flash_cfg->status_reg_size,
												s_flash.flash_cfg->protect_post, s_flash.flash_cfg->protect_mask,
	if (protect_value == s_flash.flash_cfg->protect_all)
		type = FLASH_PROTECT_ALL;
	else if (protect_value == s_flash.flash_cfg->protect_none)
		type = FLASH_PROTECT_NONE;
	else if (protect_value == s_flash.flash_cfg->protect_half)
		type = FLASH_PROTECT_HALF;
	else if (protect_value == s_flash.flash_cfg->unprotect_last_block)
		type = FLASH_UNPROTECT_LAST_BLOCK;
		type = -1;
	return type;
bk_err_t bk_flash_set_protect_type(flash_protect_type_t type)
    int ret = BK_OK;
    if (type == FLASH_PROTECT_NONE)
        if(ret != BK_OK)
	flash_set_protect_type(type);
    if (type != FLASH_PROTECT_NONE)
        if(ret != BK_OK)
	return BK_OK;
/* This API is not used in bk7256xx */
void flash_ps_pm_init(void)
	bk_flash_set_clk_dco();
	bk_flash_get_id();
	flash_ps_status_ptr->bits.unconditional_ps_support = 1;
	flash_ps_status_ptr->bits.unconditional_ps_suspend_allow = 1;
	flash_ps_status_ptr->bits.unconditional_ps_resume_allow = 1;
	flash_ps_status_ptr->bits.normal_ps_support = 1;
	flash_ps_status_ptr->bits.normal_ps_suspend_allow = 1;
	flash_ps_status_ptr->bits.normal_ps_resume_allow = 1;
	flash_ps_status_ptr->bits.lowvol_ps_support = 1;
	flash_ps_status_ptr->bits.lowvol_ps_suspend_allow = 1;
	flash_ps_status_ptr->bits.lowvol_ps_resume_allow = 1;
	flash_ps_status_ptr->bits.deep_ps_support = 1;
	flash_ps_status_ptr->bits.deep_ps_suspend_allow = 1;
	flash_ps_status_ptr->bits.deep_ps_resume_allow = 1;
	dev_pm_register(PM_ID_FLASH, "flash", &flash_ps_ops);
bool bk_flash_is_driver_inited()
	return s_flash_is_init;
uint32_t bk_flash_get_current_total_size(void)
	return s_flash.flash_cfg->flash_size;
bk_err_t bk_flash_register_ps_suspend_callback(flash_ps_callback_t ps_suspend_cb)
	s_flash_ps_suspend_cb = ps_suspend_cb;
	return BK_OK;
bk_err_t bk_flash_register_ps_resume_callback(flash_ps_callback_t ps_resume_cb)
	s_flash_ps_resume_cb = ps_resume_cb;
	return BK_OK;
__attribute__((section(".iram"))) bk_err_t bk_flash_enter_deep_sleep(void)
	int ret = 0;
	uint8_t op_code = FLASH_CMD_ENTER_DEEP_PWR_DW;
	// flash need to change 2 line when do flash operate except read
	// need to recover 4 line, please do it manually
	//if (FLASH_LINE_MODE_FOUR == bk_flash_get_line_mode())
	//	bk_flash_set_line_mode(FLASH_LINE_MODE_TWO);
	ret = flash_bypass_op_write(&op_code, NULL, 0);
	if(ret == 0)// success
		// delay T_dp: 3us
		//for(volatile int j=0; j<500; j++);
		return BK_OK;
	return BK_FAIL;
__attribute__((section(".iram"))) bk_err_t bk_flash_exit_deep_sleep(void)
	int ret = 0;
	uint8_t op_code = FLASH_CMD_EXIT_DEEP_PWR_DW;
		// delay T_res1: 20us
		return BK_OK;
	return BK_FAIL;
#define FLASH_OPERATE_SIZE_AND_OFFSET    (4096)
bk_err_t bk_spec_flash_write_bytes(bk_partition_t partition, const uint8_t *user_buf, uint32_t size,uint32_t offset)
	bk_logic_partition_t *bk_ptr = NULL;
	u8 *save_flashdata_buff  = NULL;
	flash_protect_type_t protect_type;
	bk_ptr = bk_flash_partition_get_info(partition);
	if((size + offset) > FLASH_OPERATE_SIZE_AND_OFFSET)
		return BK_FAIL;
	save_flashdata_buff= os_malloc(bk_ptr->partition_length);
	if(save_flashdata_buff == NULL)
		os_printf("save_flashdata_buff malloc err\r\n");
		return BK_FAIL;
	bk_flash_read_bytes((bk_ptr->partition_start_addr),(uint8_t *)save_flashdata_buff, bk_ptr->partition_length);
	protect_type = bk_flash_get_protect_type();
	bk_flash_set_protect_type(FLASH_PROTECT_NONE);
	bk_flash_erase_sector(bk_ptr->partition_start_addr);
	os_memcpy((save_flashdata_buff + offset), user_buf, size);
	bk_flash_write_bytes(bk_ptr->partition_start_addr ,(uint8_t *)save_flashdata_buff, bk_ptr->partition_length);
    	bk_flash_set_protect_type(protect_type);
	os_free(save_flashdata_buff);
	return BK_OK;
__attribute__((section(".itcm_sec_code"))) bk_err_t bk_flash_set_operate_status(flash_op_status_t status)
	s_flash_op_status = status;
	return BK_OK;
__attribute__((section(".itcm_sec_code"))) flash_op_status_t bk_flash_get_operate_status(void)
	return s_flash_op_status;
#if CONFIG_SECURITY_OTA
uint32_t flash_get_excute_enable()
	return flash_hal_read_offset_enable(&s_flash.hal);
#include "partitions.h"
#include "_ota.h"
#include "cache.h"
#if CONFIG_INT_WDT
#include <driver/wdt.h>
#include "bk_wdt.h"
static inline bool is_64k_aligned(uint32_t addr)
	return ((addr & (KB(64) - 1)) == 0);
static inline bool is_32k_aligned(uint32_t addr)
	return ((addr & (KB(32) - 1)) == 0);
/*make sure wdt is closed!*/
bk_err_t bk_flash_erase_fast(uint32_t erase_off, uint32_t len)
	uint32_t erase_size = 0;
	int erase_remain = len;
	while (erase_remain > 0) {
		if ((erase_remain >= KB(64)) && is_64k_aligned(erase_off)) {
			FLASH_LOGD("64k erase: off=%x remain=%x\r\n", erase_off, erase_remain);
			bk_flash_erase_block(erase_off);
			erase_size = KB(64);
		} else if ((erase_remain >= KB(32)) && is_32k_aligned(erase_off)) {
			FLASH_LOGD("32k erase: off=%x remain=%x\r\n", erase_off, erase_remain);
			bk_flash_erase_32k(erase_off);
			erase_size = KB(32);
			FLASH_LOGD("4k erase: off=%x remain=%x\r\n", erase_off, erase_remain);
			bk_flash_erase_sector(erase_off);
			erase_size = KB(4);
		erase_off += erase_size;
		erase_remain -= erase_size;
	return BK_OK;
void bk_flash_xip_erase(void)
	uint32_t update_id = flash_get_excute_enable() ^ 1;
	uint32_t erase_addr;
	if (update_id  == 0) {
		erase_addr = CONFIG_PRIMARY_ALL_PHY_PARTITION_OFFSET;
		erase_addr = CONFIG_SECONDARY_ALL_PHY_PARTITION_OFFSET;
	uint32_t erase_size = CONFIG_PRIMARY_ALL_PHY_PARTITION_SIZE;
#if CONFIG_INT_WDT
	extern bk_err_t bk_wdt_stop(void);
	extern bk_err_t bk_wdt_start(uint32_t timeout_ms);
	bk_wdt_stop();
	bk_flash_erase_fast(erase_addr,erase_size);
#if CONFIG_INT_WDT
	bk_wdt_start(CONFIG_INT_WDT_PERIOD_MS);
#if CONFIG_DIRECT_XIP
	uint32_t magic_offset = CEIL_ALIGN_34(erase_addr + erase_size - 4096);
	uint32_t status = XIP_SET;
	const uint8_t * value = (const uint8_t *)&(status);
	bk_flash_write_bytes(magic_offset,value,sizeof(value));
static void *flash_memcpy(void *d, const void *s, size_t n)
        /* attempt word-sized copying only if buffers have identical alignment */
        unsigned char *d_byte = (unsigned char *)d;
        const unsigned char *s_byte = (const unsigned char *)s;
        const uint32_t mask = sizeof(uint32_t) - 1;
        if ((((uint32_t)d ^ (uint32_t)s_byte) & mask) == 0) {
                /* do byte-sized copying until word-aligned or finished */
                while (((uint32_t)d_byte) & mask) {
                        if (n == 0) {
                                return d;
                        *(d_byte++) = *(s_byte++);
                        n--;
                /* do word-sized copying as long as possible */
                uint32_t *d_word = (uint32_t *)d_byte;
                const uint32_t *s_word = (const uint32_t *)s_byte;
                while (n >= sizeof(uint32_t)) {
                        *(d_word++) = *(s_word++);
                        n -= sizeof(uint32_t);
                d_byte = (unsigned char *)d_word;
                s_byte = (unsigned char *)s_word;
        /* do byte-sized copying until finished */
        while (n > 0) {
                n--;
        return d;
static void bk_flash_write_cbus(uint32_t address, const uint8_t *user_buf, uint32_t size)
	flash_hal_enable_cpu_data_wr(&s_flash.hal);
	flash_memcpy((char*)(0x02000000+address), (const char*)user_buf,size);
void bk_flash_xip_write_cbus(uint32_t off, const void *src, uint32_t len)
	uint32_t line_mode = bk_flash_get_line_mode();
	bk_flash_set_line_mode(2);
	uint32_t fa_off = FLASH_PHY2VIRTUAL(CEIL_ALIGN_34(CONFIG_PRIMARY_ALL_PHY_PARTITION_OFFSET));
	uint32_t int_status =  rtos_disable_int();
    enable_dcache(0);
    uint32_t write_addr = (fa_off+off);
    write_addr |= 1 << 24;
    bk_flash_write_cbus(write_addr,src,len);
    enable_dcache(1);
	rtos_enable_int(int_status);
	bk_flash_set_line_mode(line_mode);
void bk_flash_xip_write_dbus(uint32_t off, const void *src, uint32_t len)
	uint32_t update_id = (flash_get_excute_enable() ^ 1);
	uint32_t fa_addr;
		fa_addr = CONFIG_PRIMARY_ALL_PHY_PARTITION_OFFSET;
		fa_addr = CONFIG_SECONDARY_ALL_PHY_PARTITION_OFFSET;
	uint32_t addr = fa_addr + off;
	bk_flash_write_bytes(addr, src, len);
void bk_flash_xip_update(uint32_t off, const void *src, uint32_t len)
#if CONFIG_OTA_ENCRYPTED
	bk_flash_xip_write_dbus(off, src, len);
	bk_flash_xip_write_cbus(off, src, len);
#endif //  CONFIG_SECURITY_OTA && !CONFIG_TFM_FWU
