[2025-07-17 22:46:17.998]# RECV ASCII> sysPortSetPrint ok!info: ty build envir info: buildEnvir start! info: key module build success!!! ledM=>info: LedM_SetFlashAction: first act=846fec, next=36108 info: cbSetLedLevel called! id=1,val=0 relayM=>info: relayBuildEnvir: cbs=221412 info: load params from flash info: buildEnvir done! info: ty build envir end info: mesh_state:1 info: cbOnMeshStateChanged: state=1 info: cbOnRadarResetRecvState called! [2025-07-17 22:46:24.563]# RECV ASCII> info: there is people now! relayM=>info: relayOpen: stag1. grpid=0,relayId=0 relayM=>info: relayOpen: stag2 relayM=>info: relayOpen: stag3 info: cbOpenRelay!!! called! relayId = 0 relayM=>info: relayOpen: stag4. cbs=360e4, getElapsed=d049 relayM=>info: relayOpen: done info: switchLight: grp addr = c1a0. onOff = 1 info: send enum value: dp=101,val=0 [2025-07-17 22:46:28.764]# RECV ASCII> info: app_mesh_data_recv called! opcode=0xc9d007 info: cbOnMeshWritePackReceived called! info: onRecvDPWriteReq: dp=103, type=2 01 67 02 00 00 00 06 info: DP_ID_MOVE_SENSITIVITY: moveSensitivity=6 info: cbOnRadarSend called! size=6 58 61 01 06 C0 00 [2025-07-17 22:46:29.029]# RECV ASCII> info: save cxt param ok! [2025-07-17 22:46:29.528]# RECV ASCII> info: app_mesh_data_recv called! opcode=0xc9d007 info: cbOnMeshWritePackReceived called! info: onRecvDPWriteReq: dp=104, type=2 01 68 02 00 00 00 06 info: DP_ID_MICRO_SENSITIVITY: microSensitivity=6 info: cbOnRadarSend called! size=6 58 62 01 06 C1 00 [2025-07-17 22:46:29.799]# RECV ASCII> info: save cxt param ok! [2025-07-17 22:46:30.354]# RECV ASCII> info: app_mesh_data_recv called! opcode=0xc9d007 info: cbOnMeshWritePackReceived called! info: onRecvDPWriteReq: dp=107, type=2 01 6B 02 00 00 00 00 info: DP_ID_MOVE_DETECT_NEAREST_DISTANCE: moveDetectNearestDistance=0 info: cbOnRadarSend called! size=7 58 63 02 00 00 BD 00 [2025-07-17 22:46:30.997]# RECV ASCII> info: app_mesh_data_recv called! opcode=0xc9d007 info: cbOnMeshWritePackReceived called! info: onRecvDPWriteReq: dp=108, type=2 01 6C 02 00 00 01 90 info: DP_ID_MOVE_DETECT_FARTHEST_DISTANCE: moveDetectFarthestDistance=400 info: cbOnRadarSend called! size=7 58 64 02 90 01 4F 01 [2025-07-17 22:46:31.670]# RECV ASCII> info: app_mesh_data_recv called! opcode=0xc9d007 info: cbOnMeshWritePackReceived called! info: onRecvDPWriteReq: dp=110, type=2 01 6E 02 00 00 00 00 info: DP_ID_MICRO_DETECT_FARTHEST_DISTANCE: microDetectFarthestDistance=0 info: cbOnRadarSend called! size=7 58 66 02 00 00 C0 00 [2025-07-17 22:46:32.390]# RECV ASCII> info: app_mesh_data_recv called! opcode=0xc9d007 info: cbOnMeshWritePackReceived called! info: onRecvDPWriteReq: dp=109, type=2 01 6D 02 00 00 00 0A info: DP_ID_MICRO_DETECT_NEAREST_DISTANCE: microDetectNearestDistance=10 info: cbOnRadarSend called! size=7 58 65 02 0A 00 C9 00 [2025-07-17 22:47:02.999]# RECV ASCII> info: app_mesh_data_recv called! opcode=0x8201 info: cbOnMeshDataReceived: opcode=8201 [2025-07-17 22:47:08.684]# RECV ASCII> info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=110 info: DP_ID_MICRO_DETECT_FARTHEST_DISTANCE: val=0 info: after=>>>>>>>>>>> dpId=110, dpType=2, outSize=4 00 00 00 00 info: app_mesh_vendor_get_recv called33333! info: dp_id=110, dp_type=2, dp_len=4 00 00 00 00 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDP [2025-07-17 22:47:09.208]# RECV ASCII> Values: dpId=111 info: app_mesh_vendor_get_recv called33333! info: dp_id=111, dp_type=2, dp_len=4 00 00 00 00 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=101 info: after=>>>>>>>>>>> dpId=101, dpType=4, outSize=1 00 info: app_mesh_vendor_get_recv called33333! info: dp_id=101, dp_type=4, dp_len=1 00 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: [2025-07-17 22:47:09.740]# RECV ASCII> app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=112 info: app_mesh_vendor_get_recv called33333! info: dp_id=112, dp_type=4, dp_len=1 00 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=113 info: app_mesh_vendor_get_recv called33333! info: dp_id=113, dp_type=4, dp_len=1 00 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv [2025-07-17 22:47:10.240]# RECV ASCII> called22222! info: cbOnGetDPValues: dpId=102 info: DP_ID_EXIT_DELAY: val=28 info: after=>>>>>>>>>>> dpId=102, dpType=2, outSize=4 00 00 00 1C info: app_mesh_vendor_get_recv called33333! info: dp_id=102, dp_type=2, dp_len=4 00 00 00 1C info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=103 info: DP_ID_MOVE_SENSITIVITY: val=6 info: after=>>>>>>>>>>> dpId=103, dpType=2, o [2025-07-17 22:47:10.772]# RECV ASCII> utSize=4 00 00 00 06 info: app_mesh_vendor_get_recv called33333! info: dp_id=103, dp_type=2, dp_len=4 00 00 00 06 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=114 info: app_mesh_vendor_get_recv called33333! info: dp_id=114, dp_type=2, dp_len=4 00 00 00 06 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPV [2025-07-17 22:47:11.302]# RECV ASCII> alues: dpId=115 info: app_mesh_vendor_get_recv called33333! info: dp_id=115, dp_type=2, dp_len=4 00 00 00 06 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=104 info: DP_ID_MICRO_SENSITIVITY: val=6 info: after=>>>>>>>>>>> dpId=104, dpType=2, outSize=4 00 00 00 06 info: app_mesh_vendor_get_recv called33333! info: dp_id=104, dp_type=2, dp_len=4 00 00 00 06 info: app_mesh_vendor_get_recv called! [2025-07-17 22:47:11.833]# RECV ASCII> info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=116 info: app_mesh_vendor_get_recv called33333! info: dp_id=116, dp_type=2, dp_len=4 00 00 00 06 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=105 info: DP_ID_LIGHT_SENSITIVITY: val=195 info: after=>>>>>>>>>>> dpId=105, dpType=2, outSize=4 00 00 00 C3 info: app_mesh_vendor_get_recv c [2025-07-17 22:47:12.347]# RECV ASCII> alled33333! info: dp_id=105, dp_type=2, dp_len=4 00 00 00 C3 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=106 info: app_mesh_vendor_get_recv called33333! info: dp_id=106, dp_type=2, dp_len=4 00 00 00 C3 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=117 info: DP_ID_LINK_LI [2025-07-17 22:47:12.879]# RECV ASCII> GHT_SENSOR: val=0 info: after=>>>>>>>>>>> dpId=117, dpType=2, outSize=4 00 00 00 00 info: app_mesh_vendor_get_recv called33333! info: dp_id=117, dp_type=2, dp_len=4 00 00 00 00 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=107 info: DP_ID_MOVE_DETECT_NEAREST_DISTANCE: val=0 info: after=>>>>>>>>>>> dpId=107, dpType=2, outSize=4 00 00 00 00 info: app_mesh_vendor_get_recv called33333! info: dp_id=107 [2025-07-17 22:47:13.374]# RECV ASCII> , dp_type=2, dp_len=4 00 00 00 00 info: app_mesh_vendor_get_recv called! info: app_mesh_vendor_get_recv called11111! info: app_mesh_vendor_get_recv called22222! info: cbOnGetDPValues: dpId=108 info: DP_ID_MOVE_DETECT_FARTHEST_DISTANCE: val=400 info: afé­‹ysPortSetPrint ok!info: ty build envir info: buildEnvir start! info: key module build success!!! ledM=>info: LedM_SetFlashAction: first act=846fec, next=36108 info: cbSetLedLevel called [2025-07-17 22:47:13.672]# RECV ASCII> ! id=1,val=0 relayM=>info: relayBuildEnvir: cbs=221412 info: load params from flash info: buildEnvir done! info: ty build envir end info: mesh_state:1 info: cbOnMeshStateChanged: state=1 info: cbOnRadarResetRecvState called! [2025-07-17 22:47:59.145]# RECV ASCII> info: there is people now! relayM=>info: relayOpen: stag1. grpid=0,relayId=0 relayM=>info: relayOpen: stag2 relayM=>info: relayOpen: stag3 info: cbOpenRelay!!! called! relayId = 0 relayM=>info: relayOpen: stag4. cbs=360e4, getElapsed=d049 relayM=>info: relayOpen: done info: switchLight: grp addr = c1a0. onOff = 1 info: send enum value: dp=101,val=0
