[BEGIN] 2022/11/9 15:57:58 # ./home_ctrl_demo +++++++hc_proc start home control 3.4.2 build Nov 9 2022 14:42:44 start config: { "pid": "g5bp3qdpx6zgivbx", "uuid": "tuya317602374863261e", "authkey": "0ocqCmeLUYv54oInGBLr0oJwnuAWxbha", "storage_path": "/data/nand-2/JD/TUYA_JD/", "sw_ver": "10.1.5", "log_level": 4, "tuya": { "center_ctrl": { "img_path": "/tmp", "img_size": { "width": 0, "height": 0 } }, "fake": { } }, "user": [{ "tp": 10 }] } [01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /data/nand-2/JD/TUYA_JD/ [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/data/nand-2/JD/TUYA_JD/ [01-01 18:12:15 TUYA D][simplekv.c:945] path:/data/nand-2/JD/TUYA_JD/ [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£¢US¾򽸹kRꡝ [01-01 18:12:15 TUYA D][simplekv.c:1012] both file exist [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512 [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success [01-01 18:12:15 TUYA D][simplekv.c:1055] read from normal file [01-01 18:12:15 TUYA D][simplekv.c:765] curr db is V2. No need to upgrade [01-01 18:12:15 TUYA D][simplekv.c:555] head check success [01-01 18:12:15 TUYA D][simplekv.c:658] read and check head success [01-01 18:12:15 TUYA D][simplekv.c:1075] read from normal file success [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2360] [ty_rcd] udb_mng inited. [01-01 18:12:15 TUYA D][rcd_file.c:2377] [ty_rcd] db_enc_file_nm:/data/nand-2/JD/TUYA_JD//rcdDb/tyRcdEncKey.rdb rcd encrypt key 16 9d 8a 55 33 1f 4b bc d9 93 9b e9 bb 11 3b e0 22 [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:gw_pool_fast0,stackDepth:8192,totalstackDepth:12288,priority:4 [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:gw_pool_fast0 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][thread_pool.c:160] get thread id:0x5f9c [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:gw_pool_nor0,stackDepth:8192,totalstackDepth:20480,priority:3 [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:gw_pool_nor0 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][thread_pool.c:160] get thread id:0x5f9d [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:gw_pool_nor1,stackDepth:8192,totalstackDepth:28672,priority:3 [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:gw_pool_nor1 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][thread_pool.c:160] get thread id:0x5f9e [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:gw_pool_tmp0,stackDepth:8192,totalstackDepth:36864,priority:2 [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:gw_pool_tmp0 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][thread_pool_temp.c:275] create temp 0 in 0x18c04760 [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:gw_pool_tmp1,stackDepth:8192,totalstackDepth:45056,priority:2 [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:gw_pool_tmp1 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][thread_pool_temp.c:275] create temp 1 in 0x18c04730 [01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:1 idx:0 md:1 name:thr_pool_idle [01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 1 thr_pool_idle ret:0x18c04b90 [01-01 18:12:15 TUYA D][thread_pool_temp.c:358] not cycle thread [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ... [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:49152,priority:4 [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2 [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success [01-01 18:12:15 TUYA D][log_seq.c:894] read m:1 f:0 l:0 [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:54272,priority:3 [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][user_iot_intf.c:271] tuya_iot_init success [01-01 18:12:15 TUYA N][uni_log.c:197] SetLogManageAttr 4 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:192 [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0 [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success! [01-01 18:12:15 TUYA N][tuya_iot_sdk_api.c:509] gw is enabled [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:2 gw_di [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_di find value.Len:432 [01-01 18:12:15 TUYA D][ws_db_gw.c:515] gw_di read success [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:0000039kxz isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:8 0000039kxz [01-01 18:12:15 TUYA D][simplekv.c:1280] key:0000039kxz find value.Len:464 [01-01 18:12:15 TUYA D][ws_db_gw.c:699] schema 0000039kxz read success [01-01 18:12:15 TUYA D][subdev_sto_rcd.c:995] schema value is ok [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_alarm_flag isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:192 [01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:1 name:async_task [01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 2 async_task ret:0x18c050c0 [01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:2 idx:1 md:2 name:reli_http [01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 2 reli_http ret:0x18c050e0 [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/gw_cm_kv.rdb, need_backup:1, enable_encrypt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [gw_cm_kv] from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/gw_cm_kv_s.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2462] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [gw_cm_kv_s] from normal file success. [01-01 18:12:15 TUYA D][lan_dev_base.c:169] lan_dev_base_set_cap 8000, add 10 [01-01 18:12:15 TUYA D][gw_mgr.c:384] set client num 32 [01-01 18:12:15 TUYA D][gw_mgr.c:390] ignore SIGPIPE [01-01 18:12:15 TUYA D][tuya_weather_api.c:88] tuya_weather_init start [01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:3 name:svc_weather [01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 2 svc_weather ret:0x18c050c0 [01-01 18:12:15 TUYA D][tuya_weather_api.c:95] tuya_weather_init success [01-01 18:12:15 TUYA D][tuya_strategy_code.c:38] register code: enum cnt:1 [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:img_sevice_http,stackDepth:10240,totalstackDepth:64512,priority:2 [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:img_sevice_http Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:2 idx:1 md:4 name:ctrl_center [01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 2 ctrl_center ret:0x18c050e0 [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/ctrl_prod_std.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2462] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:28 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [ctrl_prod_std] from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/ctrl_product.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2462] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:28 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [ctrl_product] from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/ctrl_dev.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2462] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:31 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [ctrl_dev] from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/ctrl_room.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2462] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:15 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [ctrl_room] from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/ctrl_sensor_rule.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2462] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [ctrl_sensor_rule] from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/ctrl_schema.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2462] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:28 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [ctrl_schema] from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/ctrl_group.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [ctrl_group] from normal file success. [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:38 cnt:3 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:2 cnt:4 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:903 cnt:5 [01-01 18:12:15 TUYA D][svc_img.c:980] id name path is:/tmp/ctrl_dev_img/ [01-01 18:12:15 TUYA D][svc_img.c:995] id name list path is:/tmp/ctrl_dev_img/ [01-01 18:12:15 TUYA D][tuya_ctrl_init.c:52] start load config [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :pgiwlla1, dp_num : 5 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: pgiwlla1 category: wk dp_num: 5 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :mccp891b, dp_num : 8 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: mccp891b category: cjkg dp_num: 8 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :6anyh3ns, dp_num : 2 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: 6anyh3ns category: kg dp_num: 2 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :lbw2xxbw, dp_num : 1 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: lbw2xxbw category: kg dp_num: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :omqmddem, dp_num : 1 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: omqmddem category: kg dp_num: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :cavqhl2o, dp_num : 8 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: cavqhl2o category: cjkg dp_num: 8 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :4vobcgd3, dp_num : 7 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: 4vobcgd3 category: cl dp_num: 7 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :jgnltart, dp_num : 4 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: jgnltart category: kg dp_num: 4 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :20gwadww, dp_num : 2 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: 20gwadww category: kg dp_num: 2 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :0xxg9eop, dp_num : 7 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: 0xxg9eop category: xfj dp_num: 7 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :oamfizw6, dp_num : 5 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: oamfizw6 category: kt dp_num: 5 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :jswkk5se, dp_num : 4 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: jswkk5se category: cjkg dp_num: 4 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :fpygckga, dp_num : 6 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: fpygckga category: wk dp_num: 6 [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:476] pid: gub1jpldjidfjcl1 not dp [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :gub1jpldjidfjcl1, dp_num : 0 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: gub1jpldjidfjcl1 category: dgnzk dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :tlcuiaof, dp_num : 9 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: tlcuiaof category: kt dp_num: 9 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :9il6mpa2, dp_num : 6 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: 9il6mpa2 category: cl dp_num: 6 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :3lbtuxgp, dp_num : 15 [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: 3lbtuxgp category: dj dp_num: 15 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :xykg6fbg, dp_num : 3 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: xykg6fbg category: xfj dp_num: 3 [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:476] pid: g5bp3qdpx6zgivbx not dp [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :g5bp3qdpx6zgivbx, dp_num : 0 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: g5bp3qdpx6zgivbx category: dgnzk dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :nxlzauei, dp_num : 3 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: nxlzauei category: kg dp_num: 3 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :oligtw8v, dp_num : 2 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: oligtw8v category: cjkg dp_num: 2 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :swhwv3k3, dp_num : 7 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: swhwv3k3 category: cl dp_num: 7 [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:476] pid: viftmwpt not dp [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :viftmwpt, dp_num : 0 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: viftmwpt category: jzq dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :jlfmanzq, dp_num : 10 [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: jlfmanzq category: jtmspro dp_num: 10 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :qhvxrokpuu6uqvfb, dp_num : 1 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:347] json parse maxlen: 255. [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: qhvxrokpuu6uqvfb category: wg2 dp_num: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :d1xabwgg, dp_num : 2 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: d1xabwgg category: kg dp_num: 2 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :nnvwptvh, dp_num : 3 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: nnvwptvh category: kg dp_num: 3 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:496] pid :hzadjhkl, dp_num : 14 [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_prod_std.c:113] not process type: Raw [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:513] add pid: hzadjhkl category: cjkg dp_num: 14 [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:29,udb->rcd_valid_cnt:28 [01-01 18:12:15 TUYA E][rcd_file.c:2902] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA E][tuya_ctrl_storage.c:109] call tuya_rcd_entry_read_next(first, TY_PROD_STD_FILE_NAME, &p_data, &data_len) return -10100 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:575] pid: 6anyh3ns switch_dp: 2 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:575] pid: lbw2xxbw switch_dp: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:575] pid: omqmddem switch_dp: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:575] pid: jgnltart switch_dp: 4 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:575] pid: 20gwadww switch_dp: 2 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:575] pid: 3lbtuxgp switch_dp: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:575] pid: nxlzauei switch_dp: 3 [01-01 18:12:15 TUYA D][tuya_ctrl_prod_std.c:575] pid: nnvwptvh switch_dp: 3 [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:29,udb->rcd_valid_cnt:28 [01-01 18:12:15 TUYA E][rcd_file.c:2952] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA E][tuya_ctrl_storage.c:372] call tuya_rcd_entry_read_next_with_key(first, TY_CTRL_PRODUCT_FILE_NAME, &p_key, &p_data, &data_len) return -10100 [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"mode","property":{"range":["auto","manual"],"type":"enum"},"id":2,"type":"obj"},{"mode":"rw","code":"temp_set","property":{"unit":"℃","min":11,"max":35,"scale":0,"step":1,"type":"value"},"id":16,"type":"obj"},{"mode":"ro","code":"temp_current","property":{"unit":"℃","min":0,"max":50,"scale":0,"step":1,"type":"value"},"id":24,"type":"obj"},{"mode":"rw","code":"countdown_set","property":{"range":["cancel","1h","2h","3h","4h","5h","6h","7h","8h","9h","10h","11h","12h","13h","14h","15h","16h","17h","18h","19h","20h","21h","22h","23h","24h"],"type":"enum"},"id":41,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[pgiwlla1] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"scene_1","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":1,"type":"obj"},{"mode":"rw","code":"scene_2","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":2,"type":"obj"},{"mode":"rw","code":"scene_3","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":3,"type":"obj"},{"mode":"rw","code":"scene_4","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":4,"type":"obj"},{"mode":"rw","code":"switch_1","property":{"type":"bool"},"id":19,"type":"obj"},{"mode":"rw","code":"switch_2","property":{"type":"bool"},"id":20,"type":"obj"},{"mode":"rw","code":"switch_3","property":{"type":"bool"},"id":21,"type":"obj"},{"mode":"rw","code":"switch_4","property":{"type":"bool"},"id":22,"type":"obj"},{"mode":"rw","code":"change_1","property":{"range":["switch","scene"],"type":"enum"},"id":101,"type":"obj"},{"mode":"rw","code":"change_2","property":{"range":["switc [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[mccp891b] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch_1","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"switch_2","property":{"type":"bool"},"id":2,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[6anyh3ns] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch_1","property":{"type":"bool"},"id":1,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[lbw2xxbw] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch_1","property":{"type":"bool"},"id":1,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[omqmddem] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"scene_1","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":1,"type":"obj"},{"mode":"rw","code":"scene_2","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":2,"type":"obj"},{"mode":"rw","code":"scene_3","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":3,"type":"obj"},{"mode":"rw","code":"scene_4","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":4,"type":"obj"},{"mode":"rw","code":"switch_1","property":{"type":"bool"},"id":19,"type":"obj"},{"mode":"rw","code":"switch_2","property":{"type":"bool"},"id":20,"type":"obj"},{"mode":"rw","code":"switch_3","property":{"type":"bool"},"id":21,"type":"obj"},{"mode":"rw","code":"switch_4","property":{"type":"bool"},"id":22,"type":"obj"},{"mode":"rw","code":"change_1","property":{"range":["switch","scene"],"type":"enum"},"id":101,"type":"obj"},{"mode":"rw","code":"change_2","property":{"range":["switc [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[cavqhl2o] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"control","property":{"range":["open","stop","close"],"type":"enum"},"id":1,"type":"obj"},{"mode":"rw","code":"percent_control","property":{"unit":"%","min":0,"max":100,"scale":0,"step":1,"type":"value"},"id":2,"type":"obj"},{"mode":"ro","code":"percent_state","property":{"unit":"%","min":0,"max":100,"scale":0,"step":1,"type":"value"},"id":3,"type":"obj"},{"mode":"rw","code":"control_back","property":{"type":"bool"},"id":5,"type":"obj"},{"mode":"ro","code":"fault","property":{"label":["motor_fault"],"type":"bitmap","maxlen":1},"id":10,"type":"obj"},{"mode":"ro","code":"time_total","property":{"unit":"ms","min":0,"max":120000,"scale":0,"step":1,"type":"value"},"id":11,"type":"obj"}] [01-01 18:12:15 TUYA W][tuya_ctrl_schema_mgr.c:243] __parse_dp_property, dp_id:10, json type:bitmap is not support [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[4vobcgd3] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch_1","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"switch_2","property":{"type":"bool"},"id":2,"type":"obj"},{"mode":"rw","code":"switch_3","property":{"type":"bool"},"id":3,"type":"obj"},{"mode":"rw","code":"switch_4","property":{"type":"bool"},"id":4,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[jgnltart] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch_1","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"switch_2","property":{"type":"bool"},"id":2,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[20gwadww] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"mode","property":{"range":["auto","manual"],"type":"enum"},"id":2,"type":"obj"},{"mode":"ro","code":"temp_indoor","property":{"unit":"℃","min":0,"max":50,"scale":0,"step":1,"type":"value"},"id":9,"type":"obj"},{"mode":"rw","code":"fan_speed_enum","property":{"range":["low","mid","high","sleep"],"type":"enum"},"id":12,"type":"obj"},{"mode":"rw","code":"filter_reset","property":{"type":"bool"},"id":13,"type":"obj"},{"mode":"rw","code":"countdown_set","property":{"range":["cancel","1h","2h","3h","4h","5h","6h"],"type":"enum"},"id":16,"type":"obj"},{"mode":"rw","code":"exhaust_fan_speed","property":{"range":["off","low","mid","high"],"type":"enum"},"id":27,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[0xxg9eop] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"temp_set","property":{"unit":"℃","min":16,"max":30,"scale":0,"step":1,"type":"value"},"id":2,"type":"obj"},{"mode":"rw","code":"mode","property":{"range":["auto","cold","hot","wet","wind"],"type":"enum"},"id":4,"type":"obj"},{"mode":"rw","code":"fan_speed_enum","property":{"range":["auto","low","middle","high"],"type":"enum"},"id":5,"type":"obj"},{"mode":"rw","code":"countdown_set","property":{"range":["cancel","1h","2h","3h","4h","5h","6h","7h","8h","9h","10h","11h","12h","13h","14h","15h","16h","17h","18h","19h","20h","21h","22h","23h","24h"],"type":"enum"},"id":20,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[oamfizw6] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"scene_1","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":1,"type":"obj"},{"mode":"rw","code":"scene_2","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":2,"type":"obj"},{"mode":"rw","code":"scene_3","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":3,"type":"obj"},{"mode":"rw","code":"scene_4","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":4,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[jswkk5se] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"mode","property":{"range":["auto","manual"],"type":"enum"},"id":2,"type":"obj"},{"mode":"rw","code":"temp_set","property":{"unit":"℃","min":11,"max":35,"scale":0,"step":1,"type":"value"},"id":16,"type":"obj"},{"mode":"rw","code":"capacity_set","property":{"range":["2000W","3000W","5000W"],"type":"enum"},"id":21,"type":"obj"},{"mode":"ro","code":"temp_current","property":{"unit":"℃","min":0,"max":50,"scale":0,"step":1,"type":"value"},"id":24,"type":"obj"},{"mode":"rw","code":"countdown_set","property":{"range":["cancel","1h","2h","3h","4h","5h","6h"],"type":"enum"},"id":41,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[fpygckga] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"ro","code":"up_channel","id":1,"type":"raw"},{"mode":"wr","code":"down_channel","id":2,"type":"raw"},{"mode":"rw","code":"switch_1","property":{"type":"bool"},"id":16,"type":"obj"},{"mode":"rw","code":"switch_2","property":{"type":"bool"},"id":17,"type":"obj"},{"mode":"rw","code":"voice_vol","property":{"min":0,"max":100,"scale":0,"step":1,"type":"value"},"id":203,"type":"obj"},{"mode":"rw","code":"voice_mic","property":{"type":"bool"},"id":204,"type":"obj"},{"mode":"rw","code":"voice_play","property":{"type":"bool"},"id":205,"type":"obj"},{"mode":"rw","code":"voice_bt_play","property":{"type":"bool"},"id":206,"type":"obj"},{"mode":"rw","code":"voice_alarm_clock","property":{"type":"string","maxlen":255},"id":207,"type":"obj"},{"mode":"rw","code":"voice_ctrl_group","property":{"type":"string","maxlen":3072},"id":208,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:219] json parse maxlen: 255. [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:219] json parse maxlen: 3072. [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[gub1jpldjidfjcl1] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"temp_set","property":{"unit":"℃","min":16,"max":30,"scale":0,"step":1,"type":"value"},"id":2,"type":"obj"},{"mode":"ro","code":"temp_current","property":{"unit":"℃","min":0,"max":55,"scale":0,"step":1,"type":"value"},"id":3,"type":"obj"},{"mode":"rw","code":"mode","property":{"range":["auto","cold","hot","wet","wind"],"type":"enum"},"id":4,"type":"obj"},{"mode":"rw","code":"fan_speed_enum","property":{"range":["sleep","strong","low","middle","high"],"type":"enum"},"id":5,"type":"obj"},{"mode":"rw","code":"windshake","property":{"range":["horizontal","vertical"],"type":"enum"},"id":15,"type":"obj"},{"mode":"rw","code":"countdown_set","property":{"range":["cancel","1h","2h","3h","4h","5h","6h"],"type":"enum"},"id":20,"type":"obj"},{"mode":"rw","code":"gear_vertical","property":{"range":["off","vane_1","vane_2","vane_3","vane_4","vane_ [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[tlcuiaof] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"control","property":{"range":["open","stop","close","continue"],"type":"enum"},"id":1,"type":"obj"},{"mode":"rw","code":"percent_control","property":{"unit":"%","min":0,"max":100,"scale":0,"step":1,"type":"value"},"id":2,"type":"obj"},{"mode":"ro","code":"percent_state","property":{"unit":"%","min":0,"max":100,"scale":0,"step":1,"type":"value"},"id":3,"type":"obj"},{"mode":"rw","code":"control_back","property":{"range":["forward","back"],"type":"enum"},"id":5,"type":"obj"},{"mode":"ro","code":"fault","property":{"label":["motor_fault"],"type":"bitmap","maxlen":1},"id":12,"type":"obj"},{"mode":"rw","code":"border","property":{"range":["border_angle"],"type":"enum"},"id":16,"type":"obj"},{"mode":"rw","code":"angle_horizontal","property":{"unit":"","min":0,"max":100,"scale":0,"step":1,"type":"value"},"id":21,"type":"obj"},{"mode":"rw","code":"remote","property":{"range":["clear","study"],"type":"enum"},"id":101,"ty [01-01 18:12:15 TUYA W][tuya_ctrl_schema_mgr.c:243] __parse_dp_property, dp_id:12, json type:bitmap is not support [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[9il6mpa2] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch_led","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"work_mode","property":{"range":["white","colour","scene","music"],"type":"enum"},"id":2,"type":"obj"},{"mode":"rw","code":"bright_value","property":{"min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":3,"type":"obj"},{"mode":"rw","code":"temp_value","property":{"min":0,"max":1000,"scale":0,"step":1,"type":"value"},"id":4,"type":"obj"},{"mode":"rw","code":"colour_data","property":{"type":"string","maxlen":255},"id":5,"type":"obj"},{"mode":"rw","code":"scene_data","property":{"type":"string","maxlen":255},"id":6,"type":"obj"},{"mode":"rw","code":"countdown","property":{"unit":"s","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":7,"type":"obj"},{"mode":"wr","code":"music_data","property":{"type":"string","maxlen":255},"id":8,"type":"obj"},{"mode":"wr","code":"control_data","property":{"type":"string","maxlen":255},"i [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:219] json parse maxlen: 255. [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:219] json parse maxlen: 255. [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:219] json parse maxlen: 255. [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:219] json parse maxlen: 255. [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[3lbtuxgp] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"countdown_set","property":{"range":["cancel","1h","2h","3h","4h","5h","6h","7h","8h","9h","10h","11h","12h","13h","14h","15h","16h","17h","18h","19h","20h","21h","22h","23h","24h"],"type":"enum"},"id":16,"type":"obj"},{"mode":"rw","code":"exhaust_fan_speed","property":{"range":["off","low","mid","high"],"type":"enum"},"id":27,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[xykg6fbg] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"voice_vol","property":{"min":0,"max":100,"scale":0,"step":1,"type":"value"},"id":203,"type":"obj"},{"mode":"rw","code":"voice_mic","property":{"type":"bool"},"id":204,"type":"obj"},{"mode":"rw","code":"voice_play","property":{"type":"bool"},"id":205,"type":"obj"},{"mode":"rw","code":"voice_bt_play","property":{"type":"bool"},"id":206,"type":"obj"},{"mode":"rw","code":"voice_alarm_clock","property":{"type":"string","maxlen":255},"id":207,"type":"obj"},{"mode":"rw","code":"voice_ctrl_group","property":{"type":"string","maxlen":3072},"id":208,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:219] json parse maxlen: 255. [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:219] json parse maxlen: 3072. [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[g5bp3qdpx6zgivbx] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch_1","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"switch_2","property":{"type":"bool"},"id":2,"type":"obj"},{"mode":"rw","code":"switch_3","property":{"type":"bool"},"id":3,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[nxlzauei] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"scene_1","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":1,"type":"obj"},{"mode":"rw","code":"scene_2","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":2,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[oligtw8v] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"control","property":{"range":["open","stop","close"],"type":"enum"},"id":1,"type":"obj"},{"mode":"rw","code":"percent_control","property":{"unit":"%","min":0,"max":100,"scale":0,"step":1,"type":"value"},"id":2,"type":"obj"},{"mode":"ro","code":"percent_state","property":{"unit":"%","min":0,"max":100,"scale":0,"step":1,"type":"value"},"id":3,"type":"obj"},{"mode":"rw","code":"control_back","property":{"range":["forward","back"],"type":"enum"},"id":5,"type":"obj"},{"mode":"ro","code":"work_state","property":{"range":["opening","closing"],"type":"enum"},"id":7,"type":"obj"},{"mode":"ro","code":"time_total","property":{"unit":"ms","min":0,"max":120000,"scale":0,"step":1,"type":"value"},"id":10,"type":"obj"},{"mode":"ro","code":"fault","property":{"label":["motor_fault"],"type":"bitmap","maxlen":1},"id":12,"type":"obj"}] [01-01 18:12:15 TUYA W][tuya_ctrl_schema_mgr.c:243] __parse_dp_property, dp_id:12, json type:bitmap is not support [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[swhwv3k3] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"ro","code":"up_channel","id":1,"type":"raw"},{"mode":"wr","code":"down_channel","id":2,"type":"raw"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[viftmwpt] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"ro","code":"unlock_fingerprint","property":{"unit":"","min":0,"max":999,"scale":0,"step":1,"type":"value"},"trigger":"direct","id":1,"type":"obj"},{"mode":"ro","code":"unlock_password","property":{"min":0,"max":999,"scale":0,"step":1,"type":"value"},"trigger":"direct","id":2,"type":"obj"},{"mode":"ro","code":"unlock_temporary","property":{"min":0,"max":999,"scale":0,"step":1,"type":"value"},"trigger":"direct","id":3,"type":"obj"},{"mode":"ro","code":"unlock_dynamic","property":{"min":0,"max":999,"scale":0,"step":1,"type":"value"},"trigger":"direct","id":4,"type":"obj"},{"mode":"ro","code":"unlock_card","property":{"min":0,"max":999,"scale":0,"step":1,"type":"value"},"trigger":"direct","id":5,"type":"obj"},{"mode":"ro","code":"open_close","property":{"type":"bool"},"id":8,"type":"obj"},{"mode":"ro","code":"alarm_lock","property":{"range":["wrong_finger","wrong_password","wrong_card","wrong_face","tongue_bad","too_hot","tongu [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:219] json parse maxlen: 255. [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[jlfmanzq] to schema map success [01-01 18:12:15":"ro","code":"master_information","property":{"type":"string","maxlen":255},"id":33,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:219] json parse maxlen: 255. [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[qhvxrokpuu6uqvfb] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch_1","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"countdown_1","property":{"unit":"s","min":0,"max":43200,"scale":0,"step":1,"type":"value"},"id":7,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[d1xabwgg] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"rw","code":"switch_1","property":{"type":"bool"},"id":1,"type":"obj"},{"mode":"rw","code":"switch_2","property":{"type":"bool"},"id":2,"type":"obj"},{"mode":"rw","code":"switch_3","property":{"type":"bool"},"id":3,"type":"obj"}] [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[nnvwptvh] to schema map success [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:480] storage get schema data: [{"mode":"ro","code":"scene_1","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":1,"type":"obj"},{"mode":"ro","code":"scene_2","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":2,"type":"obj"},{"mode":"ro","code":"scene_3","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":3,"type":"obj"},{"mode":"ro","code":"scene_4","property":{"range":["scene"],"type":"enum"},"trigger":"direct","id":4,"type":"obj"},{"mode":"rw","code":"scene_id_group_id","id":17,"type":"raw"},{"mode":"rw","code":"mode_1","property":{"range":["switch_1","scene_1"],"type":"enum"},"id":18,"type":"obj"},{"mode":"rw","code":"mode_2","property":{"range":["switch_2","scene_2"],"type":"enum"},"id":19,"type":"obj"},{"mode":"rw","code":"mode_3","property":{"range":["switch_3","scene_3"],"type":"enum"},"id":20,"type":"obj"},{"mode":"rw","code":"mode_4","property":{"range":["switch_4","scene_4"],"type":"enum"},"id":21,"t [01-01 18:12:15 TUYA D][tuya_ctrl_schema_mgr.c:343] put pid[hzadjhkl] to schema map success [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:29,udb->rcd_valid_cnt:28 [01-01 18:12:15 TUYA E][rcd_file.c:2952] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA E][tuya_ctrl_storage.c:469] ret:-10100 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c532d9717845ff9f6lmen name: Smart pid: d1xabwgg comm: 6ce31c8d4213fd9ea3n3rd pv: 2.2 sub: 1 node: 000d6ffffe67e2ca icon_path: /tmp//ctrl_dev_img/CE9C187646394B0A5D3B1C0A16F4F437.png dev_num: 0 SEQ: 25. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6ce31c8d4213fd9ea3n3rd name: Linux无网关中控 pid: g5bp3qdpx6zgivbx comm: 6ce31c8d4213fd9ea3n3rd pv: 2.2 sub: 0 node: icon_path: /tmp//ctrl_dev_img/CF314D2F624EAAA13944C5836F3156EE.png dev_num: 1 SEQ: 0. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c8d86100ac2212db3dqj5 name: 4路多功能面板 pid: hzadjhkl comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: a4c138b0118f0c28 icon_path: /tmp//ctrl_dev_img/D5190CB46622DE60480C2B7607355784.png dev_num: 2 SEQ: 24. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c4eca7a6857459e05iy4h name: 智能窗帘电机Zigbee pid: swhwv3k3 comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 9035eafffe51b775 icon_path: /tmp//ctrl_dev_img/3E639AF5B5924001BC988FD4C3B22891.png dev_num: 3 SEQ: 23. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c27a15bd59ee5bdf4upda name: ZigBee梦幻帘 pid: 9il6mpa2 comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: a4c138ee9b2e7659 icon_path: /tmp//ctrl_dev_img/7535B336890BF7520F3789BEBE98AB2B.png dev_num: 4 SEQ: 22. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 1, dp_name : 开关 1 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 2, dp_name : 开关 2 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c3bf2671c859434dcqwy2 name: 2路智能开关面板-V2 2 pid: 6anyh3ns comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: b4e3f9fffe0917b1 icon_path: /tmp//ctrl_dev_img/D69D26B5EF826064F7504AF7812E30C0.png dev_num: 5 SEQ: 21. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6cf6379b475d474da28m3g name: 2路智能情景面板 pid: oligtw8v comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 04cd15fffea027f7 icon_path: /tmp//ctrl_dev_img/36D4C6A2D254D230808DD6BC9D3822D1.png dev_num: 6 SEQ: 20. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c3828df4c0b927f0fgmvk name: 智能温控面板(液晶屏) pid: viftmwpt comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: e0798dfffeb20216 icon_path: /tmp//ctrl_dev_img/27787C5D1B57EEBF4759CB8D49E8E508.png dev_num: 7 SEQ: 0. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c2529f04b3e2f53efovgd name: 空调控制面板 pid: oamfizw6 comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: e0798dfffeb20216-v-0100 icon_path: /tmp//ctrl_dev_img/9DE74D1CAA4D1CA988C170C28A6611E9.png dev_num: 8 SEQ: 19. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6ca4e06c90ca9be915zkfk name: SMARTLIGHT pid: 3lbtuxgp comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: a4c138e4b50c46a2 icon_path: /tmp//ctrl_dev_img/6C7852B5B36A2FFD61D31297AE353E6D.png dev_num: 9 SEQ: 18. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6cb5dc73d1285dd5ddiv3h name: 新风控制面板 pid: xykg6fbg comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: e0798dfffeb20216-v-0200 icon_path: /tmp//ctrl_dev_img/0A02B28467A8F72E07B16B17BC67191F.png dev_num: 10 SEQ: 17. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c99344ae1ee6e93cameee name: 地暖控制面板 pid: pgiwlla1 comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: e0798dfffeb20216-v-0300 icon_path: /tmp//ctrl_dev_img/9E0DC2F17451D8F9801E80739A9AD1C5.png dev_num: 11 SEQ: 16. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c5915544f98d4ae7cqsfd name: 奥科ZigBee开合帘 pid: 4vobcgd3 comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 540f57fffef9cd90 icon_path: /tmp//ctrl_dev_img/9E47D42AEFAA0633C1A62EFDC2AEFDF2.png dev_num: 12 SEQ: 15. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 1, dp_name : 开关 1 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 2, dp_name : 开关 2 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 3, dp_name : 开关 3 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6cd4638122441b052e4sxq name: 3路智能开关面板 2 pid: nxlzauei comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: bc33acfffef46c8f icon_path: /tmp//ctrl_dev_img/FC7C435DF2D9BF91A65FD0E994EF0368.png dev_num: 13 SEQ: 14. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 20, dp_name : 开关2 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 21, dp_name : 开关3 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c87ffeca8ddda70bfkyce name: 多功能面板-V2 pid: cavqhl2o comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 8cf681fffe9104e0 icon_path: /tmp//ctrl_dev_img/B12D80002A5E4164814C9B69254037FD.png dev_num: 14 SEQ: 13. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 1, dp_name : 开关 1 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 2, dp_name : 开关 2 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 3, dp_name : 开关 3 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 4, dp_name : 开关 4 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6cd5fc133a10b9492f2mjr name: 4路智能开关面板 pid: jgnltart comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 8cf681fffeca6716 icon_path: /tmp//ctrl_dev_img/FA40C8045031985F47767E93B8578027.png dev_num: 15 SEQ: 12. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c7662830c8c8544076lcq name: 4路智能情景面板-V2 pid: jswkk5se comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: b4e3f9fffe35a4b6 icon_path: /tmp//ctrl_dev_img/18A75991F890EB67FCA62A78FCA6E482.png dev_num: 16 SEQ: 11. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6cc30800d40ef47493t6a9 name: 1路智能开关面板-V2 11 pid: omqmddem comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 9035eafffe04b552 icon_path: /tmp//ctrl_dev_img/6CCDEBA825187927EFD5E3B3EF6A1530.png dev_num: 17 SEQ: 10. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 1, dp_name : 开关 1 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 2, dp_name : 开关 2 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c15cfcf1a96b57237suji name: 2路智能开关面板 pid: 20gwadww comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 588e81fffed38069 icon_path: /tmp//ctrl_dev_img/E11866F409A4BF596969354245A04546.png dev_num: 18 SEQ: 9. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 1, dp_name : 开关 1 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 2, dp_name : 开关 2 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 3, dp_name : 开关 3 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6cf669ac11164156b6obee name: 3路智能开关面板 pid: nxlzauei comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 8cf681fffef1aded icon_path: /tmp//ctrl_dev_img/FC7C435DF2D9BF91A65FD0E994EF0368.png dev_num: 19 SEQ: 8. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6cd3c4e6a2e5a8b893qqni name: 1路智能开关 pid: omqmddem comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 04cd15fffefad906 icon_path: /tmp//ctrl_dev_img/6CCDEBA825187927EFD5E3B3EF6A1530.png dev_num: 20 SEQ: 7. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c234dbaf596f2bc18h3be name: 网关开关 pid: lbw2xxbw comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 04cd15fffe976a5e icon_path: /tmp//ctrl_dev_img/8B0679748A433EA12B1F8C1ECE9172BF.png dev_num: 21 SEQ: 6. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 1, dp_name : 开关 1 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 2, dp_name : 开关 2 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6ce7e76b6dd5ae2cc7gofr name: 2路智能开关面板-V2 pid: 6anyh3ns comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 8cf681fffeca66e8 icon_path: /tmp//ctrl_dev_img/D69D26B5EF826064F7504AF7812E30C0.png dev_num: 22 SEQ: 5. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 1, dp_name : 开关 1 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 2, dp_name : 开关 2 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:80] init dev dp name info, dp_id : 3, dp_name : 开关 3 [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6c4a21a4359ea3d811u4dw name: 3路智能开关面板-V2 pid: nnvwptvh comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 1 node: 04cd15fffef82576 icon_path: /tmp//ctrl_dev_img/88157B8AD315F0825A09D32F262F3FE7.png dev_num: 23 SEQ: 4. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6cd4e4d52a86777441iaxt name: 网关 pid: qhvxrokpuu6uqvfb comm: 6cd4e4d52a86777441iaxt pv: 2.2 sub: 0 node: icon_path: /tmp//ctrl_dev_img/48F868F4076712B7807F62544278BFA9.png dev_num: 24 SEQ: 0. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: 6cd4cfefaccf115ed42vof name: 4寸智能中控-L pid: gub1jpldjidfjcl1 comm: 6cd4cfefaccf115ed42vof pv: 2.2 sub: 0 node: icon_path: /tmp//ctrl_dev_img/C9EBED89C2AA18D802D6CBE0B55F9753.png dev_num: 25 SEQ: 0. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: vdevo160645218918419 name: 新版标准zigbee门锁 pid: jlfmanzq comm: vdevo160645218918419 pv: 2.0 sub: 0 node: icon_path: /tmp//ctrl_dev_img/ACC2E4ED93AC103BBE20D7BF65CFDB72.png dev_num: 26 SEQ: 0. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: vdevo160307051406239 name: 全屋情景复用开关(参考)-vdevo pid: mccp891b comm: vdevo160307051406239 pv: 2.0 sub: 0 node: icon_path: /tmp//ctrl_dev_img/AC3F0466D229F5D607DD174C38864B33.png dev_num: 27 SEQ: 3. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: vdevo159963120231012 name: 新风控制面板 pid: 0xxg9eop comm: vdevo159963120231012 pv: 2.0 sub: 0 node: icon_path: /tmp//ctrl_dev_img/CAA935B4930ED59AF7E4BB589C1C62A7.png dev_num: 28 SEQ: 2. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: vdevo159963275037036 name: Zigbee温控器 pid: fpygckga comm: vdevo159963275037036 pv: 2.0 sub: 0 node: icon_path: /tmp//ctrl_dev_img/3C5BC26EAA895089939BAC0CA1427328.png dev_num: 29 SEQ: 1. [01-01 18:12:15 TUYA D][tuya_ctrl_dev.c:111] add devId: vdevo159962420219648 name: 标准公版空调 pid: tlcuiaof comm: vdevo159962420219648 pv: 2.0 sub: 0 node: icon_path: /tmp//ctrl_dev_img/9F5BC1C216638B98EA8EBF059302143A.png dev_num: 30 SEQ: 0. [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:32,udb->rcd_valid_cnt:31 [01-01 18:12:15 TUYA E][rcd_file.c:2902] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA E][tuya_ctrl_storage.c:280] call tuya_rcd_entry_read_next(first, TY_CTRL_DEV_FILE_NAME, &p_data, &data_len) return -10100 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 14045775 name: 客厅 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 14045776 name: 过道 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 14045777 name: 次卧 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 14045778 name: 餐厅 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 14045779 name: 厨房 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 14045780 name: 书房 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 25171483 name: 阳台 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 25171485 name: 房间1 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 25171486 name: 房间3 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 25171487 name: 房间5 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 25171547 name: 房间6 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 25172442 name: 儿童房 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 25172443 name: 衣帽间 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 25172445 name: 房间2 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_room.c:199] add room id: 25172446 name: 房间4 dev_num: 0 group_num: 0 [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:16,udb->rcd_valid_cnt:15 [01-01 18:12:15 TUYA E][rcd_file.c:2902] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA E][tuya_ctrl_storage.c:326] call tuya_rcd_entry_read_next(first, TY_CTRL_ROOM_FILE_NAME, &p_data, &data_len) return -10100 [01-01 18:12:15 TUYA D][tuya_ctrl_ability.c:40] init dev rule success [01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:5 name:tuya_ctrl_resend [01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 2 tuya_ctrl_resend ret:0x18c050c0 [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:ir_lib_sevice_http,stackDepth:10240,totalstackDepth:74752,priority:2 [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:ir_lib_sevice_h Exec Start. Set to Running Stat [01-01 18:12:15 TUYA E][tuya_local_ir_control.c:128] mkdir ir lib /tmpir_code error! ret = -1 [01-01 18:12:15 TUYA E][tuya_ctrl_ir.c:473] call tuya_ir_center_service_register("ir_code", tuya_ir_code_handle) return -1 [01-01 18:12:15 TUYA E][tuya_ctrl_init.c:104] call tuya_ctrl_ir_init(db_path) return -1 [01-01 18:12:15 TUYA D][tuya_scene_switch_mgr.c:1067] LOCK IN mutex __g_scene_switch_mgr.mutex, 0x7fb777c478. [01-01 18:12:15 TUYA D][tuya_scene_switch_mgr.c:1067] LOCK OUT mutex __g_scene_switch_mgr.mutex, 0x7fb777c478. [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:903 cnt:6 [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/scene_switch_mgr.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [scene_switch_mgr] from normal file success. [01-01 18:12:15 TUYA D][tuya_scene_switch_mgr.c:124] __rcd_create SUCCESSFULLY: scene_switch_mgr. [01-01 18:12:15 TUYA I][two_level_nesting_map.c:203] two_level_nesting_map_create SUCCESSFULLY: 0x18c2ec50: (nil). [01-01 18:12:15 TUYA D][tuya_scene_switch_mgr.c:886] ====== start sync from rcd ====== [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:1,udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA E][rcd_file.c:1478] [ty_rcd] not FOUND no key rcd_info.cur_valid_rcd_pos:-1,rcd_cnt:0 [01-01 18:12:15 TUYA E][rcd_file.c:1551] __read_kv_raw fail. -10107 [01-01 18:12:15 TUYA D][tuya_scene_switch_mgr.c:187] __rcd_read_next_with_key FAILED: rt -10107. [01-01 18:12:15 TUYA D][tuya_scene_switch_mgr.c:890] ====== end sync from rcd ====== [01-01 18:12:15 TUYA I][tuya_scene_switch_mgr.c:900] __tuya_scene_switch_mgr_init SUCCESSFULLY. [01-01 18:12:15 TUYA D][tuya_scene_switch_mgr.c:1083] UNLOCK IN mutex __g_scene_switch_mgr.mutex, 0x7fb777c478. [01-01 18:12:15 TUYA D][tuya_scene_switch_mgr.c:1083] UNLOCK OUT mutex __g_scene_switch_mgr.mutex, 0x7fb777c478. [01-01 18:12:15 TUYA I][tuya_scene_switch_mgr.c:1085] tuya_scene_switch_mgr_init SUCCESSFULLY. [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/ctrl_sensor_rule.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2462] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [ctrl_sensor_rule] from normal file success. [01-01 18:12:15 TUYA D][tuya_ctrl_dp_log.c:799] get sensor rule: { "deviceType": 1, "categoryList": ["sos", "sj", "mcs", "rqbj", "pir", "wsdcg"] } [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:2,udb->rcd_valid_cnt:1 [01-01 18:12:15 TUYA E][rcd_file.c:2902] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA E][tuya_ctrl_dp_log.c:788] call __tuya_sensor_rcd_entry_read_next(first, TY_CTRL_SENSOR_RULE_NAME, &p_data, &data_len) return -10100 [01-01 18:12:15 TUYA D][tuya_ctrl_center_api.c:1208] dev_ability user set shortcut:0, media:0 [01-01 18:12:15 TUYA D][tuya_ctrl_center_api.c:1247] dev_ability set success shortcut:2, media:1, dp_type: standard, category is kg,cz,dj,cl,kt,lyj,wk,pir,mcs,sj,wsdcg,rqbj,sos,dgnbj,xfj,pc,xxj,jsq,rs,tgkg,kj,ir_air,ir_stb,ir_tv,ir_network_box,ir_fan,ir_diy [01-01 18:12:15 TUYA D][tuya_iot_scene_init.c:33] tuya scence init [01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:2 idx:1 md:6 name:iot_scene [01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 2 iot_scene ret:0x18c050e0 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:401 cnt:7 [01-01 18:12:15 TUYA D][svc_img.c:980] id name path is:/tmp/scene_img/ [01-01 18:12:15 TUYA D][svc_img.c:995] id name list path is:/tmp/scene_img/ [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/tm_sto_data.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [tm_sto_data] from normal file success. [01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:7 name:tm_sto_data [01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 2 tm_sto_data ret:0x18c050c0 [01-01 18:12:15 TUYA D][tuya_iot_scene_data.c:67] tuya_scene_rcd_data_init [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/scene_sto.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2462] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [scene_sto] from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/scene_data.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2462] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [scene_data] from normal file success. [01-01 18:12:15 TUYA D][tuya_iot_scene_sto.c:207] read all scene num:1 [01-01 18:12:15 TUYA D][tuya_iot_scene_sto.c:55] rcd read qlNHIB28HGNRZ94c read success [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:122] scene name:4路 1:开启, item num:4. [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:246] scene->lan_status:1. [01-01 18:12:15 TUYA D][tuya_iot_scene_sto.c:142] read all scene data num:1 [01-01 18:12:15 TUYA D][tuya_iot_scene_sto.c:168] get scene data: {"id":"qlNHIB28HGNRZ94c","frequency":0,"icon_path":"/tmp//scene_img/423C8888EE43AEBA5A5B8AEA6C79074E.png","is_hide":false } [01-01 18:12:15 TUYA D][tuya_iot_scene_data.c:31] __add_scene_data_to_list_unlock:4路 1:开启, id:qlNHIB28HGNRZ94c, frequency:0 [01-01 18:12:15 TUYA D][tuya_iot_scene_init.c:44] tuya scence init success [01-01 18:12:15 TUYA D][tuya_home_ctrl_dev.c:2551] tuya_home_ctrl_dev_init SUCCESSFULLY. [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: all_info_sync [01-01 18:12:15 TUYA D][tuya_ctrl_center_api.c:1182] ability_rule_category_add clkg,ywbj success, now is kg,cz,dj,cl,kt,lyj,wk,pir,mcs,sj,wsdcg,rqbj,sos,dgnbj,xfj,pc,xxj,jsq,rs,tgkg,kj,ir_air,ir_stb,ir_tv,ir_network_box,ir_fan,ir_diy,clkg,ywbj [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: dev_shortcut_report [01-01 18:12:15 TUYA D][tuya_iot_sdk_api.c:662] register gw app callback [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: dev_online_update [01-01 18:12:15 TUYA D][tuya_gw_z3_user.c:161] z3 user dev num: 2 [01-01 18:12:15 TUYA D][tuya_gw_z3_user.c:180] index[1], manufacture name: TUYATEC-nPGIPl5D, model id: TS0001 [01-01 18:12:15 TUYA D][tuya_gw_z3_user.c:180] index[2], manufacture name: TUYATEC-1xAC7DHQ, model id: TZ3000 [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: dev_dp_name_update [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1758] Last reset reason: 255 [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: cc_dev_change [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: dev_name_update [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:192 [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: dev_icon_path_update [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0 [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: scene_change [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: scene_name_update [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:6 tls_ca_cnt [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: scene_icon_path_update [01-01 18:12:15 TUYA D][simplekv.c:1280] key:tls_ca_cnt find value.Len:16 [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: cc_ir_code_get [01-01 18:12:15 TUYA D][tuya_tls.c:319] tls_ca_cnt:2 and parse:2 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:4 tls_ca0 [01-01 18:12:15 TUYA D][simplekv.c:1280] key:tls_ca0 find value.Len:1376 [01-01 18:12:15 TUYA D][tuya_tls.c:349] Parse DER tls_ca0:1028 success [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca1 isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:5 tls_ca1 [01-01 18:12:15 TUYA D][simplekv.c:1280] key:tls_ca1 find value.Len:2688 [01-01 18:12:15 TUYA D][tuya_tls.c:349] Parse DER tls_ca1:2002 success [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1122] serial_no:null [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:80 [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1153] gw_cntl.gw_wsm.stat:2 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:2 gw_di [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_di find value.Len:432 [01-01 18:12:15 TUYA D][ws_db_gw.c:515] gw_di read success [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1212] gw_cntl.gw_if.abi:1 input:1 [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1213] gw_cntl.gw_if.product_key:g5bp3qdpx6zgivbx, input:g5bp3qdpx6zgivbx [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1214] gw_cntl.gw_if.tp:0, input:0 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:9 gw_ai [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:560 [01-01 18:12:15 TUYA D][ws_db_gw.c:640] gw_ai read success [01-01 18:12:15 TUYA D][uni_network.c:417] set_dns_region:1 [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[42.192.30.165] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:8883]<->[42.192.31.85] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1327] attach count changed [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:0000039kxz isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:8 0000039kxz [01-01 18:12:15 TUYA D][simplekv.c:1280] key:0000039kxz find value.Len:464 [01-01 18:12:15 TUYA D][ws_db_gw.c:699] schema 0000039kxz read success [01-01 18:12:15 TUYA D][tuya_devos_utils.c:873] create dev_cntl Success [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1780] enter success_proc [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600 [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:76288,priority:5 [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_alarm_flag isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:192 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_alarm_flag isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [01-01 18:12:15 TUYA D][home_security_inner_api.c:33] wd_common_read fails gw_alarm_flag -6 [01-01 18:12:15 TUYA D][subdev_mgr.c:41] gw_subdev_init [01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:2 idx:1 md:8 name:subdev_mod [01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 2 subdev_mod ret:0x18c050e0 [01-01 18:12:15 TUYA D][subdev_core.c:106] subdev_core_init [01-01 18:12:15 TUYA I][subdev_hb_ol.c:232] subdev_hb_ol_init [01-01 18:12:15 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15 TUYA E][gw_kv_db.c:116] rcd_entry_kv_read fails lp_off_dev -6 [01-01 18:12:15 TUYA D][subdev_hb_ol.c:1485] gw_kv_db_read lp_off_dev, maybe not exist [01-01 18:12:15 TUYA D][subdev_upgrade.c:171] subdev_upgrade_init [01-01 18:12:15 TUYA D][gw_http_report_meta.c:161] gw_http_report_meta pvu {\"pvu\":1} [01-01 18:12:15 TUYA D][gw_reli_http_report.c:287] gw_reli_http_report_data 0x7fb74c4c80 0x18c3ec10 [01-01 18:12:15 TUYA D][subdev_bind.c:1541] Begin Load Devices [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/sub_dev_ddi_s.rdb, need_backup:1, enable_encrypt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2462] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [sub_dev_ddi_s] from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/sub_dev_schm.rdb, need_backup:1, enable_encrypt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [sub_dev_schm] from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/s_dev_schm_ver.rdb, need_backup:1, enable_encrypt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [s_dev_schm_ver] from normal file success. [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:ddi- isFuzzy:1 skipCnt:1 [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15 TUYA D][subdev_sto_rcd.c:147] ddi fuzzy read -6. maybe not exist [01-01 18:12:15 TUYA D][subdev_sto_rcd.c:224] old plain db not exist [01-01 18:12:15 TUYA D][subdev_sto_rcd.c:592] num is 1 [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:2,udb->rcd_valid_cnt:1 [01-01 18:12:15 TUYA E][rcd_file.c:2952] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA D][subdev_sto_rcd.c:639] rcd_entry_read_next_with_key fail -10100. [01-01 18:12:15 TUYA D][subdev_sto_rcd.c:671] Index:0 devId:000d6ffffe67e2ca [01-01 18:12:15 TUYA D][subdev_bind.c:1454] devId:000d6ffffe67e2ca [01-01 18:12:15 TUYA D][subdev_sto_rcd.c:794] rcd read 0000004qsd read success [01-01 18:12:15 TUYA D][tuya_devos_utils.c:873] create dev_cntl Success [01-01 18:12:15 TUYA D][subdev_core.c:279] create bind node 000d6ffffe67e2ca [01-01 18:12:15 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:000d6ffffe67e2ca,p_rcd_info:0x18c59c68 [01-01 18:12:15 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:11,p_rcd_info->crc32:4239278697,len:416 key:000d6ffffe67e2ca. [01-01 18:12:15 TUYA D][subdev_bind.c:1545] Load Devices Finish [01-01 18:12:15 TUYA D][gw_engr_init.c:593] gw_engineer_init_pre [01-01 18:12:15 TUYA D][util_engr.c:331] config_path:/data/nand-2/JD/TUYA_JD/,fs_storge_path:/data/nand-2/JD/TUYA_JD/ [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:8 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:9 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:10 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:11 [01-01 18:12:15 TUYA D][tuya_iot_base_api.c:270] register wired network monitor. interval:1 [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:lpc_task,stackDepth:3072,totalstackDepth:79360,priority:3 [01-01 18:12:15:649 TUYA D][uni_thread.c:250] Thread:lpc_task Exec Start. Set to Running Stat [01-01 18:12:15:649 TUYA D][app_agent.c:1365] Setup TCP Server On Port:6668 [01-01 18:12:15:650 TUYA D][subdev_mgr.c:127] gw_subdev_lansrv_enable [01-01 18:12:15:650 TUYA I][tuya_iot_sdk_api.c:438] tuya iot sdk start [01-01 18:12:15:651 TUYA D][tuya_devos_netlink.c:343] gw_wsm stat:2 [01-01 18:12:15:651 TUYA I][uni_thread.c:228] thread_create name:heartbeat,stackDepth:4096,totalstackDepth:83456,priority:3 [01-01 18:12:15:652 TUYA D][uni_thread.c:250] Thread:heartbeat Exec Start. Set to Running Stat [01-01 18:12:15:653 TUYA D][subdev_hb_ol.c:813] start hb process... [01-01 18:12:15:654 TUYA D][tuya_home_ctrl_event.c:163] register SUCCESSFULLY: 0x7fb73cc768. [01-01 18:12:15:654 TUYA I][tuya_iot_sdk_api.c:119] device active stat update, status: 3 home_on_bind_change [65] :home_on_bind_change 1 [01-01 18:12:15:655 TUYA D][tuya_cloud.c:188] gw active stat callback, registered: 3 home_on_gw_change [60] :home_on_gw_change 3 [01-01 18:12:15:656 TUYA D][tuya_home_ctrl_event.c:135] register SUCCESSFULLY: 0x7fb73cc850. [01-01 18:12:15:657 TUYA D][simplekv.c:1211] read key:cls_key_cnt isFuzzy:0 skipCnt:0 [01-01 18:12:15:658 TUYA D][simplekv.c:1251] find key:13 cls_key_cnt [01-01 18:12:15:659 TUYA D][simplekv.c:1280] key:cls_key_cnt find value.Len:32 [01-01 18:12:15:659 TUYA D][simplekv.c:1211] read key:cls_lck_key_a isFuzzy:0 skipCnt:0 [01-01 18:12:15:660 TUYA D][simplekv.c:1251] find key:14 cls_lck_key_a [01-01 18:12:15:660 TUYA D][simplekv.c:1280] key:cls_lck_key_a find value.Len:96 [01-01 18:12:15:661 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:9 name:lan_dev [01-01 18:12:15:662 TUYA D][thread_pool.c:437] get thread 2 lan_dev ret:0x18c050c0 [01-01 18:12:15:662 TUYA I][uni_thread.c:228] thread_create name:lan_nsvr,stackDepth:4096,totalstackDepth:87552,priority:4 [01-01 18:12:15:663 TUYA D][uni_thread.c:250] Thread:lan_nsvr Exec Start. Set to Running Stat [01-01 18:12:15:664 TUYA D][lan_net_svr.c:132] begint to execute __lan_task_cb [01-01 18:12:15:665 TUYA D][lan_dev_base.c:494] __try_load_lan_cluster_seqno [01-01 18:12:15:665 TUYA D][simplekv.c:1211] read key:lan_cls_seq isFuzzy:0 skipCnt:0 [01-01 18:12:15:666 TUYA D][simplekv.c:1251] find key:3 lan_cls_seq [01-01 18:12:15:666 TUYA D][simplekv.c:1280] key:lan_cls_seq find value.Len:32 [01-01 18:12:15:667 TUYA D][simplekv.c:1211] read key:lan_cls_seq isFuzzy:0 skipCnt:0 [01-01 18:12:15:668 TUYA D][simplekv.c:1251] find key:3 lan_cls_seq [01-01 18:12:15:668 TUYA D][simplekv.c:1280] key:lan_cls_seq find value.Len:32 [01-01 18:12:15:669 TUYA D][simplekv.c:374] write key:lan_cls_seq And Value Len:32 [01-01 18:12:15:669 TUYA D][simplekv.c:397] 3 key same AND size old 436 >= new 32 [01-01 18:12:15:670 TUYA D][simplekv.c:430] find 3 available space [01-01 18:12:15:670 TUYA D][simplekv.c:474] reuse available space 29544 [01-01 18:12:15:671 TUYA D][simplekv.c:203] update crc 3116383058 [01-01 18:12:15:693 TUYA D][simplekv.c:359] write head to normal file success [01-01 18:12:15:694 TUYA D][simplekv.c:520] write success [01-01 18:12:15:694 TUYA D][base_rpc_com.c:339] rpc handler create success [01-01 18:12:15:695 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0 [01-01 18:12:15:695 TUYA D][simplekv.c:1251] find key:9 gw_ai [01-01 18:12:15:696 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:560 [01-01 18:12:15:697 TUYA D][lan_rpc.c:267] read localkey success [01-01 18:12:15:697 TUYA I][uni_thread.c:228] thread_create name:lan_rpc,stackDepth:4096,totalstackDepth:91648,priority:4 [01-01 18:12:15:698 TUYA D][uni_thread.c:250] Thread:lan_rpc Exec Start. Set to Running Stat [01-01 18:12:15:699 TUYA D][lan_cluster_master_core.c:1381] cluster change status from 0 to 0 [01-01 18:12:15:699 TUYA N][lan_cluster_master_core.c:1393] cluster change status cb new out st 0 master [] ip[0] [01-01 18:12:15:702 TUYA D][lan_cluster_master_core.c:1445] __init_cls_node_list inited[0] [01-01 18:12:15:702 TUYA N][lan_rpc.c:233] lan rpc node is empty [01-01 18:12:15:703 TUYA I][uni_thread.c:228] thread_create name:lan_msg_send,stackDepth:4096,totalstackDepth:95744,priority:4 [01-01 18:12:15:704 TUYA D][uni_thread.c:250] Thread:lan_msg_send Exec Start. Set to Running Stat [01-01 18:12:15:705 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0 [01-01 18:12:15:705 TUYA D][simplekv.c:1251] find key:9 gw_ai [01-01 18:12:15:706 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:560 [01-01 18:12:15:707 TUYA D][lan_dev_base.c:482] read localkey success [01-01 18:12:15:707 TUYA D][lan_rpc.c:274] lan_rpc_session_key_set key: 35 64 37 64 [01-01 18:12:15:708 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_SUBSCRIBE [01-01 18:12:15:708 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_PUBLISH [01-01 18:12:15:709 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_PUSH [01-01 18:12:15:710 TUYA D][lan_pub_sub_mq.c:508] lan_pub_sub_mq_init OK [01-01 18:12:15:710 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_SYNC_DP_RPT_REQ [01-01 18:12:15:711 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_SYNC_DP_RPT [01-01 18:12:15:712 TUYA D][thread_pool.c:399] thread type:2 idx:1 md:10 name:lan_dp_rpt_ch [01-01 18:12:15:712 TUYA D][thread_pool.c:437] get thread 2 lan_dp_rpt_ch ret:0x18c050e0 [01-01 18:12:15:713 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_PUSH [01-01 18:12:15:714 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_SUBSCRIBE [01-01 18:12:15:715 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_PUBLISH [01-01 18:12:15:715 TUYA D][lan_pub_sub_mq_center.c:514] lan_pub_sub_mq_center_init OK [01-01 18:12:15:716 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_SYNC_DP_RPT_REQ [01-01 18:12:15:717 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_SYNC_DP_RPT [01-01 18:12:15:717 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:11 name:lan_dp_rpt_sy [01-01 18:12:15:718 TUYA D][thread_pool.c:437] get thread 2 lan_dp_rpt_sy ret:0x18c050c0 [01-01 18:12:15:719 TUYA D][gw_kv_db.c:120] gw_kv_db_read dev_cls_info [01-01 18:12:15:719 TUYA D][lan_cluster_multi_home_common.c:619] read home info: [{"id":"6cd4e4d52a86777441iaxt","st":1,"cap":1,"seq":240}] [01-01 18:12:15:721 TUYA D][lan_cluster_multi_home_common.c:111] add dev 6cd4e4d52a86777441iaxt. home cap 1. home st 1 SAME [01-01 18:12:15:722 TUYA D][scene_linkage_storage.c:380] scene_linkage_storage_init [01-01 18:12:15:722 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/linkage_0.rdb, need_backup:1, enable_encrypt:0 [01-01 18:12:15:723 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15:724 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15:725 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15:725 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15:726 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:2 [01-01 18:12:15:726 TUYA D][rcd_file.c:2621] [ty_rcd] init [linkage_0] from normal file success. [01-01 18:12:15:727 TUYA D][scene_linkage_storage.c:251] get meta From db 0 0 0. [01-01 18:12:15:728 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-2/JD/TUYA_JD//rcdDb/linkage_1.rdb, need_backup:1, enable_encrypt:0 [01-01 18:12:15:729 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15:729 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file [01-01 18:12:15:730 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15:731 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success [01-01 18:12:15:731 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:2 [01-01 18:12:15:732 TUYA D][rcd_file.c:2621] [ty_rcd] init [linkage_1] from normal file success. [01-01 18:12:15:733 TUYA D][scene_linkage_storage.c:251] get meta From db 0 0 0. [01-01 18:12:15:733 TUYA D][simplekv.c:1211] read key:scene_unit isFuzzy:0 skipCnt:0 [01-01 18:12:15:734 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15:734 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15:735 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [01-01 18:12:15:735 TUYA D][simplekv.c:1211] read key:scn_lnk_ttl_cnt isFuzzy:0 skipCnt:0 [01-01 18:12:15:736 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15:737 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15:737 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [01-01 18:12:15:738 TUYA D][simplekv.c:1211] read key:lanlnk_ttl_cnt isFuzzy:0 skipCnt:0 [01-01 18:12:15:738 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15:739 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15:739 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [01-01 18:12:15:740 TUYA D][scene_linkage_rule_exe.c:363] set vid 6ce31c8d4213fd9ea3n3rd [01-01 18:12:15:741 TUYA D][thread_pool.c:399] thread type:2 idx:1 md:12 name:lkg_rule_exe [01-01 18:12:15:741 TUYA D][thread_pool.c:437] get thread 2 lkg_rule_exe ret:0x18c050e0 [01-01 18:12:15:742 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:13 name:lkg_rule_up [01-01 18:12:15:743 TUYA D][thread_pool.c:437] get thread 2 lkg_rule_up ret:0x18c050c0 [01-01 18:12:15:743 TUYA D][scene_linkage_rule_sync.c:295] scene_linkage_rule_sync_init [01-01 18:12:15:744 TUYA D][scene_linkage_scene_name.c:345] remove all name [01-01 18:12:15:745 TUYA D][scene_linkage_scene_name.c:350] name list is empty [01-01 18:12:15:745 TUYA D][scene_linkage_rule_exe.c:896] scene_linkage_rule_delete_all, rule_type[0] [01-01 18:12:15:746 TUYA D][scene_linkage_rule_sync.c:496] read __get_real_count_from_nvram rule_type:0 real_cnt:0 [01-01 18:12:15:747 TUYA D][scene_linkage_rule_exe.c:839] __rule_delete_all, rule_type[0] [01-01 18:12:15:748 TUYA D][scene_linkage_rule_exe.c:842] no record now [01-01 18:12:15:748 TUYA D][scene_linkage_rule_sync.c:507] No rules. [01-01 18:12:15:749 TUYA D][scene_linkage_rule_sync.c:515] no need upload takeover result [01-01 18:12:15:749 TUYA I][scene_linkage_scene_name.c:499] scene_linkage_name_id_update_notify [01-01 18:12:15:750 TUYA D][scene_linkage_rule_exe.c:896] scene_linkage_rule_delete_all, rule_type[1] [01-01 18:12:15:751 TUYA D][scene_linkage_rule_sync.c:496] read __get_real_count_from_nvram rule_type:1 real_cnt:0 [01-01 18:12:15:752 TUYA D][scene_linkage_rule_sync.c:507] No rules. [01-01 18:12:15:752 TUYA D][scene_linkage_rule_sync.c:515] no need upload takeover result [01-01 18:12:15:753 TUYA D][scene_linkage_rule_exe.c:839] __rule_delete_all, rule_type[1] [01-01 18:12:15:754 TUYA D][scene_linkage_rule_exe.c:842] no record now [01-01 18:12:15:754 TUYA I][scene_linkage_scene_name.c:499] scene_linkage_name_id_update_notify [01-01 18:12:15:755 TUYA D][scene_linkage_rule_sync.c:1941] scene_linkage_update_from_server linkage_type:0 delaymS:24000 [01-01 18:12:15:756 TUYA D][mqc_app.c:144] mq_pro:49 cnt:12 [01-01 18:12:15:756 TUYA D][mqc_app.c:144] mq_pro:403 cnt:13 [01-01 18:12:15:757 TUYA D][thread_pool.c:399] thread type:2 idx:1 md:14 name:sce_lnk_log_upload [01-01 18:12:15:758 TUYA D][thread_pool.c:437] get thread 2 sce_lnk_log_upload ret:0x18c050e0 [01-01 18:12:15:758 TUYA D][scene_linkage_offline_exe_cntl.c:463] scene_linkage_offline_exe_cntl_init [01-01 18:12:15:759 TUYA D][scene_linkage_offline_exe_cntl.c:194] no old db [01-01 18:12:15:760 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15:760 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [01-01 18:12:15:761 TUYA E][gw_kv_db.c:116] rcd_entry_kv_read fails sl_eoc_is_stop -6 [01-01 18:12:15:761 TUYA D][scene_linkage_offline_exe_cntl.c:117] is_stop not exist [01-01 18:12:15:762 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15:763 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [01-01 18:12:15:763 TUYA E][gw_kv_db.c:116] rcd_entry_kv_read fails sl_eoc_is_enable -6 [01-01 18:12:15:764 TUYA D][scene_linkage_offline_exe_cntl.c:126] is_enable not exist [01-01 18:12:15:765 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15:765 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [01-01 18:12:15:766 TUYA E][gw_kv_db.c:116] rcd_entry_kv_read fails sl_eoc_off_dura -6 [01-01 18:12:15:767 TUYA D][scene_linkage_offline_exe_cntl.c:135] offline_dura not exist [01-01 18:12:15:767 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15:768 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [01-01 18:12:15:768 TUYA E][gw_kv_db.c:116] rcd_entry_kv_read fails sl_eoc_cur_dura -6 [01-01 18:12:15:769 TUYA D][scene_linkage_offline_exe_cntl.c:144] cur_dura not exist [01-01 18:12:15:770 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15:770 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [01-01 18:12:15:771 TUYA E][gw_kv_db.c:116] rcd_entry_kv_read fails sl_eoc_deadline_s -6 [01-01 18:12:15:772 TUYA D][scene_linkage_offline_exe_cntl.c:153] deadline_s not exist [01-01 18:12:15:772 TUYA D][scene_linkage_offline_exe_cntl.c:158] is_enable: 0, is_stop: 0, cur_dura: 0, off_dura: 0, dl_s: 0 [01-01 18:12:15:773 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:15 name:lnk_offline_exe_cntl [01-01 18:12:15:774 TUYA D][thread_pool.c:437] get thread 2 lnk_offline_exe_cntl ret:0x18c050c0 [01-01 18:12:15:775 TUYA D][scene_linkage_offline_exe_cntl.c:489] scene_linkage_offline_exe_cntl_init success [01-01 18:12:15:776 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_DP_REPORT [01-01 18:12:15:776 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_DP_REPORT [01-01 18:12:15:777 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_LINKAGE [01-01 18:12:15:778 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_LINKAGE [01-01 18:12:15:778 TUYA I][mqc_app.c:387] mqc app start ... [01-01 18:12:15:779 TUYA D][mqc_app.c:459] MQTT Protocol URL:m2.tuyacn.com:8883 Port:8883 [01-01 18:12:15:780 TUYA D][mqc_app.c:473] TLS disable [01-01 18:12:15:780 TUYA D][mqc_app.c:308] TLS Mode:4 [01-01 18:12:15:780 TUYA D][mqtt_client.c:291] subcribe_topic:smart/device/in/6ce31c8d4213fd9ea3n3rd, client_id:6ce31c8d4213fd9ea3n3rd, user_name:6ce31c8d4213fd9ea3n3rd, passwd:804b82caadaad539 [01-01 18:12:15:782 TUYA D][mqtt_client.c:322] domain<0> m2.tuyacn.com:8883 HAVE PORT [01-01 18:12:15:783 TUYA D][mqtt_client.c:325] PARSE m2.tuyacn.com:8883 [01-01 18:12:15:783 TUYA D][mqtt_client.c:353] wakeup_domain_tbl<0> m2.tuyacn.com:1883 HAVE PORT [01-01 18:12:15:784 TUYA D][mqtt_client.c:356] PARSE m2.tuyacn.com:1883 [01-01 18:12:15:784 TUYA D][mqc_app.c:520] mqtt send topic:smart/device/out/6ce31c8d4213fd9ea3n3rd [01-01 18:12:15:785 TUYA D][mqc_app.c:522] mqtt-media send topic:d/m/o/6ce31c8d4213fd9ea3n3rd [01-01 18:12:15:786 TUYA I][uni_thread.c:228] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:99840,priority:4 [01-01 18:12:15:787 TUYA D][mqc_app.c:144] mq_pro:64 cnt:14 [01-01 18:12:15:787 TUYA D][mqc_app.c:144] mq_pro:22 cnt:15 [01-01 18:12:15:788 TUYA D][mqc_app.c:144] mq_pro:55 cnt:16 [01-01 18:12:15:788 TUYA D][uni_thread.c:250] Thread:mq_cntl_task Exec Start. Set to Running Stat [01-01 18:12:15:789 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0 [01-01 18:12:15:790 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15:790 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15:791 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [01-01 18:12:15:791 TUYA D][tuya_svc_timer_task.c:146] no timer [01-01 18:12:15:792 TUYA D][mqc_app.c:144] mq_pro:13 cnt:17 [01-01 18:12:15:792 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyacn.com, prio 2 [01-01 18:12:15:793 TUYA D][mqc_app.c:144] mq_pro:15 cnt:18 [01-01 18:12:15:793 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.30.165 for domain:m2.tuyacn.com [01-01 18:12:15:794 TUYA D][mqtt_client.c:1406] select mqtt host:m2.tuyacn.com [01-01 18:12:15:795 TUYA N][mqtt_client.c:1427] mqtt get serve ip success [01-01 18:12:15:795 TUYA D][tuya_svc_upgrade.c:826] upgrade active success [01-01 18:12:15:796 TUYA D][mqtt_client.c:932] serverIP 717233829 port:8883 [01-01 18:12:15:796 TUYA D][svc_online_log.c:217] mqtt log topic init log/realtime/6ce31c8d4213fd9ea3n3rd [01-01 18:12:15:797 TUYA D][svc_online_log.c:219] mqtt log topic init log/runstat/6ce31c8d4213fd9ea3n3rd [01-01 18:12:15:798 TUYA E][mqtt_client.c:1442] mqtt connect fail. retry_cnt:0 ret:-2310 errno:-16 [01-01 18:12:15:799 TUYA D][svc_online_log.c:317] svc online log active success [01-01 08:00:00:800 TUYA D][thread_pool.c:399] thread type:2 idx:1 md:16 name:grp_mod [01-01 08:00:00:800 TUYA D][thread_pool.c:437] get thread 2 grp_mod ret:0x18c050e0 [01-01 08:00:00:801 TUYA D][group_scene.c:54] current path set: /data/nand-2/JD/TUYA_JD/ [01-01 08:00:00:801 TUYA D][group_scene_serve.c:2730] start group scene serve [01-01 08:00:00:802 TUYA D][group_scene_serve.c:671] =====__group_scene_save_init===== [01-01 08:00:00:803 TUYA D][group_scene_serve.c:699] group scene flag file: /data/nand-2/JD/TUYA_JD/grp_sce_flag_file. [01-01 08:00:00:804 TUYA D][group_scene_serve.c:700] group scene file: /data/nand-2/JD/TUYA_JD/grp_sce_save_file. [01-01 08:00:00:804 TUYA D][group_scene_serve.c:701] group scene back file: /data/nand-2/JD/TUYA_JD/grp_sce_save_bak_file. [01-01 08:00:00:806 TUYA D][simplekv.c:1211] read key:grp_sce_list isFuzzy:0 skipCnt:0 [01-01 08:00:00:806 TUYA D][simplekv.c:1247] no key find [01-01 08:00:00:807 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 08:00:00:807 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [01-01 08:00:00:808 TUYA E][group_scene_serve.c:647] read grp_sce_list err. -6 [01-01 08:00:00:808 TUYA D][group_scene_serve.c:729] No old group scene flag file. [01-01 08:00:00:809 TUYA I][uni_thread.c:228] thread_create name:grp_sce,stackDepth:4096,totalstackDepth:103936,priority:3 [01-01 08:00:00:810 TUYA D][group_scene_serve.c:2756] end group scene serve [01-01 08:00:00:810 TUYA D][uni_thread.c:250] Thread:grp_sce Exec Start. Set to Running Stat [01-01 08:00:00:811 TUYA D][mqc_app.c:144] mq_pro:204 cnt:19 [01-01 08:00:00:812 TUYA D][mqc_app.c:144] mq_pro:206 cnt:20 [01-01 08:00:00:812 TUYA D][mqc_app.c:144] mq_pro:202 cnt:21 [01-01 08:00:00:813 TUYA D][scene_linkage.c:55] the scene linkage is inited [01-01 08:00:00:813 TUYA D][home_security.c:2408] Init home security start, Ver:1.0.1. [01-01 08:00:00:814 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:17 name:home_sec [01-01 08:00:00:814 TUYA D][thread_pool.c:437] get thread 2 home_sec ret:0x18c050c0 [01-01 08:00:00:815 TUYA D][simplekv.c:1211] read key:home_secu isFuzzy:0 skipCnt:0 [01-01 08:00:00:816 TUYA D][simplekv.c:1247] no key find [01-01 08:00:00:816 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 08:00:00:817 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [01-01 08:00:00:817 TUYA E][tuya_ws_db.c:326] kvs_read fails home_secu -6 [01-01 08:00:00:818 TUYA W][ws_db_home_security.c:61] home_secu read null. [01-01 08:00:00:818 TUYA E][home_security.c:2453] wd_gw_home_security_if_read error,ret:-6. [01-01 08:00:00:819 TUYA D][home_security.c:2460] security_mode:0, enable_def_time:60. [01-01 08:00:00:820 TUYA D][simplekv.c:1211] read key:delay_time_list isFuzzy:0 skipCnt:0 [01-01 08:00:00:821 TUYA D][simplekv.c:1251] find key:11 delay_time_list [01-01 08:00:00:821 TUYA D][simplekv.c:1280] key:delay_time_list find value.Len:48 [01-01 08:00:00:822 TUYA D][home_security.c:2464] delay_json_str:{"1":{"enable":0},"2":{"enable":30}}. [01-01 08:00:00:823 TUYA E][home_security.c:1017] mode_delay_json is error.. [01-01 08:00:00:823 TUYA E][home_security.c:1039] Enable def time:60. [01-01 08:00:00:824 TUYA W][home_security.c:2481] gw_home_security_if_cb is null. [01-01 08:00:00:824 TUYA D][simplekv.c:1211] read key:ignore_list isFuzzy:0 skipCnt:0 [01-01 08:00:00:825 TUYA D][simplekv.c:1247] no key find [01-01 08:00:00:825 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 08:00:00:826 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [01-01 08:00:00:826 TUYA E][home_security.c:862] read ignore_list err. -6 [01-01 08:00:00:827 TUYA D][lan_pub_sub_mq.c:636] add_sub_service [LAN_SECURITY] [01-01 08:00:00:828 TUYA D][lan_pub_sub_mq.c:672] add_publish_service [LAN_SECURITY] [01-01 08:00:00:828 TUYA D][lan_pub_sub_mq_api.c:120] add topic:[LAN_SECURITY] [01-01 08:00:00:829 TUYA D][lan_security_pub_sub.c:232] lan_security_pub_sub_init OK [01-01 08:00:00:830 TUYA D][mqc_app.c:144] mq_pro:701 cnt:22 [01-01 08:00:00:830 TUYA D][home_security.c:2511] Init home security end. [01-01 08:00:00:831 TUYA D][subdev_mgr.c:94] gw_subdev_active [01-01 08:00:00:831 TUYA D][mqc_app.c:144] mq_pro:8 cnt:23 [01-01 08:00:00:832 TUYA D][mqc_app.c:144] mq_pro:102 cnt:24 [01-01 08:00:00:832 TUYA D][mqc_app.c:144] mq_pro:200 cnt:25 [01-01 08:00:00:833 TUYA D][mqc_app.c:144] mq_pro:33 cnt:26 [01-01 08:00:00:833 TUYA D][mqc_app.c:144] mq_pro:28 cnt:27 [01-01 08:00:00:833 TUYA D][subdev_upgrade.c:186] subdev_upgrade_active [01-01 08:00:00:834 TUYA D][subdev_group_upgrade.c:264] subdev_group_upgrade_active [01-01 08:00:00:835 TUYA D][mqc_app.c:144] mq_pro:73 cnt:28 [01-01 08:00:00:835 TUYA D][subdev_query_cloud.c:165] subdev_query_cloud_init flag 0 [01-01 08:00:00:836 TUYA I][uni_thread.c:228] thread_create name:lpc_con,stackDepth:4096,totalstackDepth:108032,priority:4 [01-01 08:00:00:837 TUYA D][uni_thread.c:250] Thread:lpc_con Exec Start. Set to Running Stat [01-01 08:00:00:837 TUYA D][thread_pool.c:399] thread type:2 idx:1 md:18 name:lan_pro_c [01-01 08:00:00:838 TUYA D][thread_pool.c:437] get thread 2 lan_pro_c ret:0x18c050e0 [01-01 08:00:00:839 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:19 name:ty_lan_dev [01-01 08:00:00:839 TUYA D][thread_pool.c:437] get thread 2 ty_lan_dev ret:0x18c050c0 [01-01 08:00:00:840 TUYA D][simplekv.c:1211] read key:lan_nd_attr isFuzzy:0 skipCnt:0 [01-01 08:00:00:841 TUYA D][simplekv.c:1251] find key:12 lan_nd_attr [01-01 08:00:00:841 TUYA D][simplekv.c:1280] key:lan_nd_attr find value.Len:80 [01-01 08:00:00:842 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_DEV_LIST_QR [01-01 08:00:00:843 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_DEV_LIST_QR [01-01 08:00:00:843 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_DEV_LIST_QR_RSP [01-01 08:00:00:844 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_DEV_LIST_QR_RSP [01-01 08:00:00:845 TUYA D][lan_pub_sub_mq.c:636] add_sub_service [LAN_DEV_LIST_SYNC] [01-01 08:00:00:846 TUYA D][lan_pub_sub_mq.c:672] add_publish_service [LAN_DEV_LIST_SYNC] [01-01 08:00:00:846 TUYA D][lan_pub_sub_mq_api.c:120] add topic:[LAN_DEV_LIST_SYNC] [01-01 08:00:00:847 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_DP_QUERY [01-01 08:00:00:848 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_DP_QUERY [01-01 08:00:00:848 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_DP_QUERY_RSP [01-01 08:00:00:849 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_DP_QUERY_RSP [01-01 08:00:00:850 TUYA D][lan_pub_sub_mq.c:636] add_sub_service [LAN_DP_UP] [01-01 08:00:00:850 TUYA D][lan_pub_sub_mq.c:672] add_publish_service [LAN_DP_UP] [01-01 08:00:00:851 TUYA D][lan_pub_sub_mq_api.c:120] add topic:[LAN_DP_UP] [01-01 08:00:00:852 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_CNTL_SEND [01-01 08:00:00:852 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_CNTL_SEND [01-01 08:00:00:853 TUYA E][gw_mgr.c:557] Macro GW_MAJOR_SDK_INFO or GW_MINOR_SDK_INFO is not defined [01-01 08:00:00:854 TUYA I][gw_mgr.c:627] Dont't Upload Sdk Version [01-01 08:00:00:855 TUYA D][tuya_lan_dp_up.c:165] watch dev:,vdevo159962420219648,vdevo159963275037036,vdevo159963120231012,vdevo160307051406239,vdevo160645218918419,6cd4cfefaccf115ed42vof,6cd4e4d52a86777441iaxt, [01-01 08:00:00:856 TUYA D][lan_pub_sub_mq.c:765] topic sub_param_set [LAN_DP_UP] [01-01 08:00:01:646 TUYA D][rcd_file.c:548] [ty_rcd]__flush_timer_cb start [01-01 08:00:01:647 TUYA D][thread_pool_temp.c:721] temp run add 0x18c04770 0x7fb74ce2ac 18c50e70 [01-01 08:00:01:647 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74ce2ac 18c50e70 [01-01 08:00:01:648 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74ce2ac 18c50e70 in thread 18c04760 BEGIN [01-01 08:00:01:649 TUYA D][rcd_file.c:533] [ty_rcd] __rcd_db_flush start. [01-01 08:00:01:657 TUYA D][rcd_file.c:538] [ty_rcd] __rcd_db_flush end. [01-01 08:00:01:657 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [01-01 08:00:01:658 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [01-01 08:00:01:658 TUYA D][thread_pool_temp.c:147] put thread 0x18c04770 [01-01 08:00:01:659 TUYA D][thread_pool_temp.c:155] temp thread total:2 used:0 [01-01 08:00:01:659 TUYA D][tuya_iot_base_api.c:249] wired netstat changed to:1 -->> [01-01 08:00:01:660 TUYA D][tuya_iot_sdk_api.c:183] base nw stat: 1 [01-01 08:00:01:661 TUYA D][tuya_iot_base_api.c:256] wired netstat changed to:1 <<-- [01-01 08:00:01:799 TUYA N][mqtt_client.c:1628] mqtt close [01-01 08:00:01:799 TUYA N][mqtt_client.c:783] close mqtt -->> [01-01 08:00:01:800 TUYA N][mqtt_client.c:829] close mqtt <<-- [01-01 08:00:01:800 TUYA D][mqtt_client.c:1644] mqtt fail_cnt:1, sleeptime:1492 ms [01-01 08:00:01:861 TUYA D][lan_pub_sub_mq.c:311] try to check sub topic [01-01 08:00:01:861 TUYA D][lan_pub_sub_mq.c:314] cur st is:0. not check [01-01 08:00:03:293 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyacn.com, prio 2 [01-01 08:00:03:665 TUYA D][lpc_db_manager.c:114] add dev:6cd4e4d52a86777441iaxt, ip:102.18.168.192, overtime:127424, active:2 [01-01 08:00:03:667 TUYA D][lan_cluster_multi_home_common.c:131] dev 6cd4e4d52a86777441iaxt [SAME] lan seq chgn 240 to 164. up 1 [01-01 08:00:03:668 TUYA D][lan_cluster_master_core.c:1367] node [6cd4e4d52a86777441iaxt]report. st[0] [01-01 08:00:03:668 TUYA D][lan_dev_base_master.c:1078] __lan_node_change_single_cb node 6cd4e4d52a86777441iaxt st:0 [01-01 08:00:03:669 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6cd4e4d52a86777441iaxt [01-01 08:00:03:670 TUYA D][lan_msg_seqno.c:153] __init is False [01-01 08:00:03:670 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:03:671 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6cd4e4d52a86777441iaxt pos:0 [01-01 08:00:03:672 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6cd4e4d52a86777441iaxt st:0 [01-01 08:00:03:673 TUYA D][lan_dp_report_sync_master.c:329] node 6cd4e4d52a86777441iaxt not found omit [01-01 08:00:03:674 TUYA I][lan_cluster_master_core.c:1082] node [6cd4e4d52a86777441iaxt] ip[c0a81266] [5010] [164]join. hash map len=1 [01-01 08:00:05:655 TUYA D][lpc_db_manager.c:114] add dev:6ce31c8d4213fd9ea3n3rd, ip:101.18.168.192, overtime:127426, active:2 [01-01 08:00:05:705 TUYA I][lan_cluster_master_core.c:850] __timer_proc_master_wait. send_cnt[0] [01-01 08:00:05:706 TUYA D][lan_cluster_master_confirm.c:240] Create UDP Socket To Broadcast master confirm [01-01 08:00:05:847 TUYA D][lpc_db_manager.c:294] db_key:6ce31c8d4213fd9ea3n3rd, node[id:6ce31c8d4213fd9ea3n3rd, ip:192.168.18.101, overtime:127426, localkey:, pv:3.4, active:2, need_connect:0, is_connect:0, is_new_ver:0] [01-01 08:00:05:849 TUYA D][lpc_db_manager.c:294] db_key:6cd4e4d52a86777441iaxt, node[id:6cd4e4d52a86777441iaxt, ip:192.168.18.102, overtime:127424, localkey:, pv:3.4, active:2, need_connect:0, is_connect:0, is_new_ver:0] [01-01 08:00:08:310 TUYA D][uni_network.c:365] use system dns ip 42.192.31.85 for domain m2.tuyacn.com [01-01 08:00:08:310 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com]<->[42.192.31.85] [01-01 08:00:08:311 TUYA D][mqtt_client.c:1406] select mqtt host:m2.tuyacn.com [01-01 08:00:08:311 TUYA N][mqtt_client.c:1427] mqtt get serve ip success [01-01 08:00:08:312 TUYA D][mqtt_client.c:932] serverIP 717234005 port:8883 [01-01 08:00:08:337 TUYA D][mqtt_client.c:957] mqtt over TLS is enabled. Host:m2.tuyacn.com Port:8883 [01-01 08:00:08:337 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:08:338 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect m2.tuyacn.com:8883 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:08:339 TUYA D][tuya_tls.c:1373] load tuya cert. [01-01 08:00:08:340 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [01-01 08:00:08:341 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [01-01 08:00:08:341 TUYA D][tuya_iot_com_api.c:259] tuya public url [01-01 08:00:08:342 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [01-01 08:00:08:596 TUYA D][tuya_tls.c:1533] handshake finish for m2.tuyacn.com. set send/recv to user set [01-01 08:00:08:596 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect m2.tuyacn.com:8883 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:08:597 TUYA N][mqtt_client.c:1465] mqtt create success, begin to connect [01-01 08:00:08:598 TUYA D][mqc_app.c:308] TLS Mode:4 [01-01 08:00:08:630 TUYA D][mqtt_client.c:1347] cnt 1 [01-01 08:00:08:663 TUYA D][mqtt_client.c:1047] mqtt subscribe success [01-01 08:00:08:664 TUYA D][mqc_app.c:732] mqtt connect success [01-01 08:00:08:665 TUYA D][tuya_weather_api.c:34] weather mqtt connect [01-01 08:00:08:665 TUYA D][tuya_weather_data_handle.c:212] tuya_weather_all_data_sync delay 5 ms [01-01 08:00:08:666 TUYA D][tuya_ctrl_mqc.c:708] mqtt connect [01-01 08:00:08:666 TUYA D][tuya_ctrl_mqc.c:469] unsubscribe topic cnt:6 [01-01 08:00:08:669 TUYA D][tuya_ctrl_mqc.c:482] unsubscribe topic[0]:smart/mb/in/6ce31c8d4213fd9ea3n3rd. [01-01 08:00:08:669 TUYA D][tuya_ctrl_mqc.c:482] unsubscribe topic[1]:smart/mb/in/6cd4e4d52a86777441iaxt. [01-01 08:00:08:670 TUYA D][tuya_ctrl_mqc.c:482] unsubscribe topic[2]:smart/mb/in/vdevo160307051406239. [01-01 08:00:08:671 TUYA D][tuya_ctrl_mqc.c:482] unsubscribe topic[3]:smart/mb/in/vdevo159963120231012. [01-01 08:00:08:672 TUYA D][tuya_ctrl_mqc.c:482] unsubscribe topic[4]:smart/mb/in/vdevo159963275037036. [01-01 08:00:08:673 TUYA D][tuya_ctrl_mqc.c:482] unsubscribe topic[5]:smart/mb/in/vdevo159962420219648. [01-01 08:00:08:673 TUYA D][tuya_ctrl_sync.c:226] sync delay: 100 ms [01-01 08:00:08:674 TUYA E][tuya_ctrl_sync.c:228] call gw_thread_pool_start_tm_msg(ctrl_mgr.thr_hdl, ctrl_mgr.tmm_sync, delay, TIMER_ONCE) return -2 [01-01 08:00:08:675 TUYA E][tuya_ctrl_mqc.c:713] call tuya_ctrl_sync_all_info(TY_MQ_CONN_SYNC_DELAY_TM) return -2 [01-01 08:00:08:676 TUYA E][base_event.c:155] ret:-2 [01-01 08:00:08:676 TUYA D][tuya_iot_scene_event.c:88] mqtt connect [01-01 08:00:08:677 TUYA D][tuya_tm_sto_rcd.c:458] mqtt connect [01-01 08:00:08:677 TUYA D][scene_linkage_rule_sync.c:1941] scene_linkage_update_from_server linkage_type:0 delaymS:373000 [01-01 08:00:08:678 TUYA D][scene_linkage_lan_master.c:328] lan_scene_linkage_on_mqtt_online 1 [01-01 08:00:08:679 TUYA D][lan_dev_base_master.c:378] lan_scene_linkage_on_mqtt_online 1 [01-01 08:00:08:680 TUYA D][iot_httpc.c:946] Post Data: {"codes":["w.temp","w.humidity","w.windLevel","w.windSpeed","w.windDir","w.aqi","w.pm25","w.so2","c.city","w.conditionNum","w.thigh","w.thigh"],"t":8} [01-01 08:00:08:681 TUYA D][thread_pool_temp.c:721] temp run add 0x18c33fd0 0x7fb74c5f50 0 [01-01 08:00:08:682 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74c5f50 0 [01-01 08:00:08:683 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.public.data.get&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=8&v=1.0&sign=c6deae02de0c308ae52e0c687175b01a [01-01 08:00:08:684 TUYA I][subdev_inner_api.c:277] gw_subdev_on_mq_con connected [01-01 08:00:08:685 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74c5f50 0 in thread 18c04760 BEGIN [01-01 08:00:08:685 TUYA I][subdev_bind.c:1715] sync dev list delay_ms: 3000 [01-01 08:00:08:686 TUYA D][tuya_iot_base_api.c:249] wired netstat changed to:2 -->> [01-01 08:00:08:687 TUYA D][tuya_iot_sdk_api.c:183] base nw stat: 2 [01-01 08:00:08:687 TUYA D][tuya_iot_base_api.c:256] wired netstat changed to:2 <<-- [01-01 08:00:08:688 TUYA D][thread_pool_temp.c:738] temp run add delay 0x7fa40107a0 0x7fb74ed764 0 13 [01-01 08:00:08:689 TUYA W][home_security.c:2401] Home security have init.. [01-01 08:00:08:689 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [01-01 08:00:08:690 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [01-01 08:00:08:691 TUYA D][mqc_app.c:879] Send MQTT Msg.P:23 N:6244 Q:0 Data:{"reqType":"netMode","data":{"netMode":"wired"}} [01-01 08:00:08:692 TUYA D][iot_httpc.c:946] Post Data: {"devId":"6ce31c8d4213fd9ea3n3rd","t":8} [01-01 08:00:08:692 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.cache.mark.publish&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=8&v=1.0&sign=11cea277ae86c79553982f6ebfbdf963 [01-01 08:00:08:694 TUYA I][gw_info_report.c:460] same lan ip, skip meta report [01-01 08:00:08:694 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [01-01 08:00:08:695 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [01-01 08:00:08:696 TUYA D][thread_pool_temp.c:721] temp run add 0x7f8c000b90 0x7fb74d5810 8c000990 [01-01 08:00:08:696 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74d5810 8c000990 [01-01 08:00:08:697 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74d5810 8c000990 in thread 18c04730 BEGIN [01-01 08:00:08:698 TUYA D][user_iot_intf.c:32] online stat: 1 [01-01 08:00:08:698 TUYA D][lan_cluster_multi_home_common.c:696] delay 26 to sync dev cls info [01-01 08:00:08:699 TUYA I][gw_info_report.c:306] post_data:{"value":{"compiler":"ci_manage@tuya.com","compile_time":1665148550,"gw_sdk_name":"ty_integrated_sdk","gw_sdk_ver":"3.4.2-beta.8","gw_baseline":[{"local_linkage":[{"support":true},{"version":"3.1.6-beta.7"}]},{"lan_linkage":[{"support":true},{"version":"3.1.6-beta.7"}]},{"voice_scene":[{"support":false},{"version":null}]},{"engi_mode":[{"support":true},{"version":null}]},{"fault_transfer":[{"support":false},{"version":null}]},{"security":[{"support":true},{"version":null}]},{"pull_local_logs":[{"support":false},{"version":null}]}]},"type":1} [01-01 08:00:08:704 TUYA D][scene_linkage_offline_exe_cntl.c:451] scene_linkage_offline_exe_cntl_mq_online_handle [01-01 08:00:08:705 TUYA D][mqc_app.c:879] Send MQTT Msg.P:65 N:6245 Q:1 Data:{"reqType": "linkageOfflineCntlStatusRep","isStop": false} [01-01 08:00:08:706 TUYA D][iot_httpc.c:946] Post Data: {"value":{"compiler":"ci_manage@tuya.com","compile_time":1665148550,"gw_sdk_name":"ty_integrated_sdk","gw_sdk_ver":"3.4.2-beta.8","gw_baseline":[{"local_linkage":[{"support":true},{"version":"3.1.6-beta.7"}]},{"lan_linkage":[{"support":true},{"version":"3.1.6-beta.7"}]},{"voice_scene":[{"support":false},{"version":null}]},{"engi_mode":[{"support":true},{"version":null}]},{"fault_transfer":[{"support":false},{"version":null}]},{"security":[{"support":true},{"version":null}]},{"pull_local_logs":[{"support":false},{"version":null}]}]},"type":1,"t":8} [01-01 08:00:08:711 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.properties.report&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=8&v=1.0&sign=23db9dc4b1f332d5a232f5c99ecc9a44 [01-01 08:00:08:712 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [01-01 08:00:08:712 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [01-01 08:00:08:828 TUYA D][iot_httpc.c:946] Post Data: {"versions":"[{\"otaChannel\":0,\"protocolVer\":\"2.2\",\"devAttribute\":6,\"sdkFullVer\":\"TuyaOS2.3.5_ty_integrated_sdk_3.4.2-beta.8_linux_rockchip_rk3308_release_0.0.8\",\"baselineVer\":\"40.00\",\"softVer\":\"3.4.2\",\"cadVer\":\"1.0.4\",\"cdVer\":\"1.0.0\"}]","t":8} [01-01 08:00:08:830 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.versions.update&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=8&v=4.1&sign=942036e95f3e05b88f018a71f5b71cfb [01-01 08:00:08:832 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [01-01 08:00:08:832 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [01-01 08:00:08:990 TUYA I][subdev_hb_ol.c:465] {"online":["000d6ffffe67e2ca"],"offline":[]} [01-01 08:00:08:991 TUYA D][mqc_app.c:879] Send MQTT Msg.P:25 N:6246 Q:1 Data:{"online":["000d6ffffe67e2ca"],"offline":[]} [01-01 08:00:09:61 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0 [01-01 08:00:09:62 TUYA D][simplekv.c:1251] find key:10 em_sys_env [01-01 08:00:09:62 TUYA D][simplekv.c:1280] key:em_sys_env find value.Len:32 [01-01 08:00:09:63 TUYA D][svc_online_log.c:173] load env success em_sys_env [01-01 08:00:09:63 TUYA D][svc_online_log.c:176] env em_sys_env same. need not to update [01-01 08:00:09:680 TUYA D][tuya_iot_scene_sync.c:216] __tmm_scene_sync_cb [01-01 08:00:09:680 TUYA D][iot_httpc.c:946] Post Data: {"t":9} [01-01 08:00:09:681 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.screen.linkage.rule.all&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=9&v=1.0&sign=53bc2f49d2cc3fc7281b0893ca006aa3 [01-01 08:00:09:682 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [01-01 08:00:09:683 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [01-01 08:00:10:1 TUYA W][tuya_z3.c:31701] Zigbee COO ver is not get. [01-01 08:00:10:633 TUYA D][gw_async_task.c:231] gw_async_task_exe 0x7fb74d8270 (nil) [01-01 08:00:11:688 TUYA D][thread_pool_temp.c:721] temp run add 0x18c33fd0 0x7fb750ca28 18c3ed40 [01-01 08:00:11:688 TUYA D][thread_pool_temp.c:627] temp run 0x7fb750ca28 18c3ed40 [01-01 08:00:13:720 TUYA D][uni_network.c:365] use system dns ip 42.192.31.36 for domain a2.tuyacn.com [01-01 08:00:13:720 TUYA D][uni_network.c:268] cache dns [a2.tuyacn.com]<->[42.192.31.36] [01-01 08:00:13:721 TUYA D][uni_network.c:365] use system dns ip 42.192.31.36 for domain a2.tuyacn.com [01-01 08:00:13:722 TUYA D][uni_network.c:268] cache dns [a2.tuyacn.com]<->[42.192.31.36] [01-01 08:00:13:723 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [01-01 08:00:13:723 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [01-01 08:00:13:730 TUYA D][uni_network.c:365] use system dns ip 42.192.31.36 for domain a2.tuyacn.com [01-01 08:00:13:730 TUYA D][uni_network.c:268] cache dns [a2.tuyacn.com]<->[42.192.31.36] [01-01 08:00:13:731 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [01-01 08:00:13:751 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [01-01 08:00:13:751 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:13:752 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [01-01 08:00:13:752 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:13:753 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:13:754 TUYA D][tuya_tls.c:1373] load tuya cert. [01-01 08:00:13:754 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:13:755 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [01-01 08:00:13:756 TUYA D][tuya_tls.c:1373] load tuya cert. [01-01 08:00:13:756 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [01-01 08:00:13:757 TUYA D][tuya_iot_com_api.c:259] tuya public url [01-01 08:00:13:758 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [01-01 08:00:13:758 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:13:759 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [01-01 08:00:13:760 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [01-01 08:00:13:760 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:13:761 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [01-01 08:00:13:762 TUYA D][tuya_tls.c:1373] load tuya cert. [01-01 08:00:13:762 TUYA D][tuya_iot_com_api.c:259] tuya public url [01-01 08:00:13:763 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [01-01 08:00:13:763 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [01-01 08:00:13:764 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [01-01 08:00:13:765 TUYA D][tuya_iot_com_api.c:259] tuya public url [01-01 08:00:13:765 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [01-01 08:00:13:840 TUYA D][uni_network.c:365] use system dns ip 42.192.31.36 for domain a2.tuyacn.com [01-01 08:00:13:840 TUYA D][uni_network.c:268] cache dns [a2.tuyacn.com]<->[42.192.31.36] [01-01 08:00:13:841 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [01-01 08:00:13:864 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [01-01 08:00:13:865 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:13:865 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:13:866 TUYA D][tuya_tls.c:1373] load tuya cert. [01-01 08:00:13:867 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [01-01 08:00:13:867 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [01-01 08:00:13:868 TUYA D][tuya_iot_com_api.c:259] tuya public url [01-01 08:00:13:869 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [01-01 08:00:14:58 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [01-01 08:00:14:58 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:14:63 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [01-01 08:00:14:64 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:14:70 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [01-01 08:00:14:71 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:14:144 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1667980693,"success":true} [11-09 15:58:13:0 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:13:1 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:13:11 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:13:11 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:13:16 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"cacheDevs":[]},"protocol":102,"s":1716229,"t":1667980693} [11-09 15:58:13:16 TUYA D][subdev_mq.c:94] Rev Device Wakeup Cmd [11-09 15:58:13:17 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1667980693,"success":true} [11-09 15:58:13:18 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:13:18 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:13:19 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:13:19 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:13:20 TUYA D][thread_pool_temp.c:218] num:2 to exe [11-09 15:58:13:20 TUYA D][thread_pool_temp.c:201] run temp 0x7fb750ca28 18c3ed40 in thread 18c04760 BEGIN [11-09 15:58:13:21 TUYA D][iot_httpc.c:946] Post Data: {"t":1667980693} [11-09 15:58:13:22 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.sub.list&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980693&v=2.0&sign=4ddf9b3119b41cacb6b09178b966d94f [11-09 15:58:13:23 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:13:24 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:13:24 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:13:25 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:13:55 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"data":{"c.city":"福州","w.temp":23,"w.humidity":64,"w.windLevel":3,"w.windSpeed":"4.4","w.windDir":"NW","w.aqi":29,"w.pm25":13,"w.so2":4,"w.conditionNum":"142"},"expiration":30},"t":1667980693,"success":true} [11-09 15:58:13:57 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:13:57 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:13:58 TUYA W][tuya_weather_data_handle.c:107] tuya_weather_data_parse_unlock :w.thigh is not exist [11-09 15:58:13:59 TUYA W][tuya_weather_data_handle.c:107] tuya_weather_data_parse_unlock :w.thigh is not exist [11-09 15:58:13:60 TUYA D][tuya_weather_data_handle.c:168] weather_sync rt :0, sync_time_left :1800000 [11-09 15:58:13:60 TUYA D][tuya_weather_data_handle.c:212] tuya_weather_all_data_sync delay 1800000 ms [11-09 15:58:13:61 TUYA D][tuya_tm_sto_rcd.c:397] read all timer storage data num:0 [11-09 15:58:13:62 TUYA D][scene_linkage_rule_sync.c:1853] report_ability [11-09 15:58:13:62 TUYA D][thread_pool_temp.c:721] temp run add 0x7fa400eca0 0x7fb74b1848 0 [11-09 15:58:13:63 TUYA I][uni_thread.c:228] thread_create name:gw_pool_tmp2,stackDepth:8192,totalstackDepth:116224,priority:2 [11-09 15:58:13:64 TUYA D][uni_thread.c:250] Thread:gw_pool_tmp2 Exec Start. Set to Running Stat [11-09 15:58:13:65 TUYA D][thread_pool_temp.c:275] create temp 2 in 0x7f9400e840 [11-09 15:58:13:66 TUYA D][thread_pool_temp.c:133] temp thread expand:3 [11-09 15:58:13:66 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74b1848 0 [11-09 15:58:13:67 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74b1848 0 in thread 9400e840 BEGIN [11-09 15:58:13:67 TUYA D][gw_async_task.c:112] node 0x7fb74d8270 (nil) use thr 0 [11-09 15:58:13:68 TUYA D][thread_pool_temp.c:721] temp run add 0x18c04980 0x7fb7537e20 88000990 [11-09 15:58:13:69 TUYA I][scene_linkage_http_intf.c:239] post_data: {"gwId":"6ce31c8d4213fd9ea3n3rd","abilityProperty":{"condType":[7,13],"actionType":["dpStep","deviceGroupDpIssue"],"unSupportActionType":["irIssue","irIssueVii"],"condStrategyType":[1],"mqttAck":true}} [11-09 15:58:13:71 TUYA D][iot_httpc.c:946] Post Data: {"gwId":"6ce31c8d4213fd9ea3n3rd","abilityProperty":{"condType":[7,13],"actionType":["dpStep","deviceGroupDpIssue"],"unSupportActionType":["irIssue","irIssueVii"],"condStrategyType":[1],"mqttAck":true},"t":1667980693} [11-09 15:58:13:73 TUYA I][uni_thread.c:228] thread_create name:gw_pool_tmp3,stackDepth:8192,totalstackDepth:124416,priority:2 [11-09 15:58:13:74 TUYA D][uni_thread.c:250] Thread:gw_pool_tmp3 Exec Start. Set to Running Stat [11-09 15:58:13:75 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.linkage.ability&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980693&v=1.0&sign=3106b46faf7681330f9dd4c6a974f65c [11-09 15:58:13:76 TUYA D][thread_pool_temp.c:275] create temp 3 in 0x7f9400e320 [11-09 15:58:13:77 TUYA D][thread_pool_temp.c:133] temp thread expand:4 [11-09 15:58:13:77 TUYA D][thread_pool_temp.c:627] temp run 0x7fb7537e20 88000990 [11-09 15:58:13:78 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:13:79 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:13:79 TUYA D][thread_pool_temp.c:201] run temp 0x7fb7537e20 88000990 in thread 9400e320 BEGIN [11-09 15:58:13:80 TUYA D][gw_async_task.c:53] call cb 0x7fb74d8270 (nil), idx 0 [11-09 15:58:13:81 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:13:81 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:13:82 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:13:83 TUYA I][lan_cluster_master_core.c:850] __timer_proc_master_wait. send_cnt[1] [11-09 15:58:13:84 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:13:85 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:13:85 TUYA D][iot_httpc.c:946] Post Data: {"metas":"{\"pvu\":1}","t":1667980693} [11-09 15:58:13:86 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:13:86 TUYA D][thread_pool_temp.c:721] temp run add 0x7fa4010a00 0x7fb74dffcc 0 [11-09 15:58:13:87 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.meta.save&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980693&v=1.0&sign=05476690079ce54c7985574e32205dc3 [11-09 15:58:13:88 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:13:89 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:13:90 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:13:90 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:13:91 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:13:92 TUYA I][uni_thread.c:228] thread_create name:gw_pool_tmp4,stackDepth:8192,totalstackDepth:132608,priority:2 [11-09 15:58:13:93 TUYA D][uni_thread.c:250] Thread:gw_pool_tmp4 Exec Start. Set to Running Stat [11-09 15:58:13:93 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:13:94 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:13:94 TUYA D][thread_pool_temp.c:275] create temp 4 in 0x7f9400e2c0 [11-09 15:58:13:95 TUYA D][thread_pool_temp.c:133] temp thread expand:5 [11-09 15:58:13:96 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74dffcc 0 [11-09 15:58:13:96 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:13:97 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74dffcc 0 in thread 9400e2c0 BEGIN [11-09 15:58:13:98 TUYA D][iot_httpc.c:946] Post Data: {"devId":"6ce31c8d4213fd9ea3n3rd","t":1667980693} [11-09 15:58:13:99 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.h.s.boot.config.get&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980693&v=3.0&sign=ff486f71e1c49ad3864e6110966d0daf [11-09 15:58:13:100 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:13:101 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:13:101 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:13:102 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:13:114 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:13:114 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:13:115 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:13:116 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:13:117 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:13:117 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:13:118 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:13:118 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:13:123 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:13:123 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:13:124 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:13:125 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:13:125 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:13:126 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:13:126 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:13:127 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:13:138 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:13:138 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:13:139 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:13:140 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:13:141 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:13:141 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:13:142 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:13:142 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:13:145 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1667980693,"success":true} [11-09 15:58:13:145 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:13:146 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:13:146 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0 [11-09 15:58:13:147 TUYA D][simplekv.c:1251] find key:2 gw_di [11-09 15:58:13:147 TUYA D][simplekv.c:1280] key:gw_di find value.Len:432 [11-09 15:58:13:148 TUYA D][simplekv.c:374] write key:gw_di And Value Len:416 [11-09 15:58:13:148 TUYA D][simplekv.c:397] 2 key same AND size old 468 >= new 416 [11-09 15:58:13:149 TUYA D][simplekv.c:430] find 2 available space [11-09 15:58:13:150 TUYA D][simplekv.c:474] reuse available space 29076 [11-09 15:58:13:150 TUYA D][simplekv.c:203] update crc 4276988698 [11-09 15:58:13:155 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:13:155 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:13:159 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:13:160 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:13:171 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:13:171 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:13:174 TUYA D][simplekv.c:359] write head to normal file success [11-09 15:58:13:174 TUYA D][simplekv.c:520] write success [11-09 15:58:13:175 TUYA D][ws_db_gw.c:430] gw_di write success [11-09 15:58:13:221 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:13:221 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:13:268 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1667980693,"success":true} [11-09 15:58:13:268 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"nodes":["000d6ffffe67e2ca"]},"t":1667980693,"success":true} [11-09 15:58:13:269 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:13:270 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:13:270 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"abilityProperty":"{\"condType\":[7,13],\"actionType\":[\"dpStep\",\"deviceGroupDpIssue\"],\"unSupportActionType\":[\"irIssue\",\"irIssueVii\"],\"condStrategyType\":[1],\"mqttAck\":true}","gwId":"6ce31c8d4213fd9ea3n3rd"},"t":1667980693,"success":true} [11-09 15:58:13:273 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:13:273 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:13:274 TUYA D][gw_http_report_meta.c:119] meta rpt {"metas":"{\"pvu\":1}"} ret 0 cnt 0 [11-09 15:58:13:274 TUYA D][subdev_bind.c:1151] dev_num:1 [11-09 15:58:13:275 TUYA D][subdev_bind.c:1153] dev_list_bind:["000d6ffffe67e2ca"]. [11-09 15:58:13:275 TUYA D][subdev_sigmesh.c:1383] dev_num:1 [11-09 15:58:13:276 TUYA D][gw_async_task.c:93] no msg to rpt [11-09 15:58:13:276 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:13:277 TUYA D][thread_pool_temp.c:204] thread 9400e320 END [11-09 15:58:13:278 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:13:278 TUYA D][thread_pool_temp.c:147] put thread 0x18c04980 [11-09 15:58:13:279 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:4 [11-09 15:58:13:279 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:13:280 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:13:280 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:13:281 TUYA D][thread_pool_temp.c:147] put thread 0x18c33fd0 [11-09 15:58:13:281 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:3 [11-09 15:58:13:282 TUYA D][thread_pool_temp.c:204] thread 9400e840 END [11-09 15:58:13:283 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:13:283 TUYA D][thread_pool_temp.c:147] put thread 0x7fa400eca0 [11-09 15:58:13:284 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:2 [11-09 15:58:13:294 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"delayTimes":{"1":{"enable":0},"2":{"enable":30}}},"t":1667980693,"success":true} [11-09 15:58:13:295 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:13:296 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:13:296 TUYA D][home_security.c:1424] home security delay_time: {"1":{"enable":0},"2":{"enable":30}}, cmd_from = 0. [11-09 15:58:13:297 TUYA D][home_security.c:889] Save delay time list: {"1":{"enable":0},"2":{"enable":30}}. [11-09 15:58:13:298 TUYA D][simplekv.c:1211] read key:delay_time_list isFuzzy:0 skipCnt:0 [11-09 15:58:13:298 TUYA D][simplekv.c:1251] find key:11 delay_time_list [11-09 15:58:13:299 TUYA D][simplekv.c:1280] key:delay_time_list find value.Len:48 [11-09 15:58:13:300 TUYA D][home_security.c:788] isNeedPullTime:1. [11-09 15:58:13:300 TUYA D][thread_pool_temp.c:204] thread 9400e2c0 END [11-09 15:58:13:301 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:13:301 TUYA D][thread_pool_temp.c:147] put thread 0x7fa4010a00 [11-09 15:58:13:302 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:1 [11-09 15:58:13:548 TUYA D][uni_network.c:365] use system dns ip 42.192.31.36 for domain a2.tuyacn.com [11-09 15:58:13:549 TUYA D][uni_network.c:268] cache dns [a2.tuyacn.com]<->[42.192.31.36] [11-09 15:58:13:549 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:13:576 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:13:576 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:13:577 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:13:578 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:13:579 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:13:579 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:13:580 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:13:580 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:13:624 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:13:625 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:13:626 TUYA D][http_inf.c:403] NEW HTTP Session https://a2.tuyacn.com:443. [11-09 15:58:13:738 TUYA D][thread_pool_temp.c:721] temp run add 0x18c33fd0 0x7fb750b7bc 18c50d00 [11-09 15:58:13:739 TUYA D][thread_pool_temp.c:627] temp run 0x7fb750b7bc 18c50d00 [11-09 15:58:13:739 TUYA D][thread_pool_temp.c:201] run temp 0x7fb750b7bc 18c50d00 in thread 18c04760 BEGIN [11-09 15:58:13:740 TUYA D][subdev_bind.c:529] sub device bind start [11-09 15:58:13:741 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:13:741 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:13:742 TUYA D][thread_pool_temp.c:147] put thread 0x18c33fd0 [11-09 15:58:13:742 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:1 [11-09 15:58:13:778 TUYA D][iot_httpc.c:601] Decode Rev:{"result":[{"matchType":1,"offGwSync":false,"outOfWork":0,"ownerId":"6231002","offGwSyncSuccess":false,"id":"qlNHIB28HGNRZ94c","runtimeEnv":"prod","newLocalScene":true,"coverIcon":"https://images.tuyacn.com/smart/rule/glyphicons/label.png","commonField":"{\"revise\":\"deviceGroupDpIssue\",\"gwId\":\"6cefafa55d118a8a7aatxd\"}","name":"4路 1:开启","containDeviceDelete":false,"actions":[{"offGwSync":false,"actionExecutor":"dpIssue","orderNum":1,"enabled":true,"executorProperty":{"1":true},"attribute":0,"id":"uAbCRirbsJEUcAdkhai3","ruleId":"qlNHIB28HGNRZ94c","actionStrategy":"edge","extraProperty":{"gid":"1","gwId":"6c4fb71f22990fe000dcdp","sid":"1"},"entityId":"6c77807db9ea34126dpzov","devDelMark":false,"status":true},{"offGwSync":false,"actionExecutor":"dpIssue","orderNum":2,"enabled":true,"executorProperty":{"2":false},"attribute":0,"id":"o3kafl9VSVnEZtGuA08Z","ruleId":"qlNHIB28HGNRZ94c","actionStrategy":"edge","extraProperty":{"gid":"1","gwId":"6c4 [11-09 15:58:14:0 TUYA D][tuya_iot_scene_sync.c:177] scene num:1 [11-09 15:58:14:0 TUYA D][tuya_iot_scene_sync.c:191] scene: 4路 1:开启 change, del old first [11-09 15:58:14:1 TUYA D][tuya_iot_scene_sto.c:55] rcd read qlNHIB28HGNRZ94c read success [11-09 15:58:14:1 TUYA D][tuya_iot_scene_parse.c:122] scene name:4路 1:开启, item num:4. [11-09 15:58:14:2 TUYA D][tuya_iot_scene_parse.c:246] scene->lan_status:1. [11-09 15:58:14:4 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:qlNHIB28HGNRZ94c,p_rcd_info:0x18c4b900 [11-09 15:58:14:5 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:9,p_rcd_info->crc32:2320487611,len:2224 key:qlNHIB28HGNRZ94c. [11-09 15:58:14:6 TUYA D][tuya_iot_scene_sto.c:36] rcd write qlNHIB28HGNRZ94c success [11-09 15:58:14:6 TUYA D][tuya_iot_scene_sync.c:202] storage scene sync begin. [11-09 15:58:14:7 TUYA D][tuya_iot_scene_sync.c:227] scene sync type: 3 [11-09 15:58:14:7 TUYA N][svc_img.c:688] id name url frist one build list:scene_img tuya_home_control_all_info_sync_event [69] :tuya_home_control_all_info_sync_event 3 [11-09 15:58:14:8 TUYA D][svc_file.c:344] file name--:423C8888EE43AEBA5A5B8AEA6C79074E.png [11-09 15:58:14:9 TUYA D][tuya_home_control_sync.c:35] recv scene sync event [11-09 15:58:14:10 TUYA D][svc_file.c:352] file path--:/tmp/scene_img/423C8888EE43AEBA5A5B8AEA6C79074E.png [11-09 15:58:14:11 TUYA D][smart_frame.c:2112] Start To Sync Dev:6ce31c8d4213fd9ea3n3rd, dp_rept_chan:1 [11-09 15:58:14:12 TUYA D][svc_file.c:434] p_name file:. [11-09 15:58:14:12 TUYA D][svc_file.c:434] p_name file:.. [11-09 15:58:14:12 TUYA D][svc_file.c:434] p_name file:423C8888EE43AEBA5A5B8AEA6C79074E.png [11-09 15:58:14:13 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:6. [11-09 15:58:14:14 TUYA E][svc_file.c:473] tuya_hal_dir_read err:/tmp/scene_img/ [11-09 15:58:14:14 TUYA D][smart_frame.c:2517] Nothing To Pack [11-09 15:58:14:15 TUYA E][svc_img.c:713] tuya_dir_file_delete_for_url err:-1 [11-09 15:58:14:16 TUYA D][smart_frame.c:2112] Start To Sync Dev:000d6ffffe67e2ca, dp_rept_chan:1 [11-09 15:58:14:16 TUYA D][tuya_iot_scene_img_sync.c:125] img cb url: https://images.tuyacn.com/smart/rule/glyphicons/label.png path: /tmp/scene_img/423C8888EE43AEBA5A5B8AEA6C79074E.png [11-09 15:58:14:18 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:2. [11-09 15:58:14:18 TUYA D][smart_frame.c:2517] Nothing To Pack [11-09 15:58:14:19 TUYA D][smart_frame.c:2164] Sync Finish [11-09 15:58:14:19 TUYA D][tuya_iot_scene_img_sync.c:95] scene id:qlNHIB28HGNRZ94c, name:4路 1:开启,icon_path:/tmp/scene_img/423C8888EE43AEBA5A5B8AEA6C79074E.png. [11-09 15:58:14:21 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:qlNHIB28HGNRZ94c,p_rcd_info:0x18c4e308 [11-09 15:58:14:22 TUYA D][iot_httpc.c:946] Post Data: {"data":"255","t":1667980694} [11-09 15:58:14:22 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:3,p_rcd_info->crc32:2324019059,len:128 key:qlNHIB28HGNRZ94c. [11-09 15:58:14:23 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=atop.online.debug.log&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980694&sign=0409332a830a21916a0b517b9f7f7de3 [11-09 15:58:14:25 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:14:25 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:14:26 TUYA D][tuya_iot_scene_img_sync.c:65] publish scene id:qlNHIB28HGNRZ94c path:/tmp/scene_img/423C8888EE43AEBA5A5B8AEA6C79074E.png [11-09 15:58:14:27 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:14:28 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:14:28 TUYA D][tuya_home_ctrl_event.c:375] icon path update: scene qlNHIB28HGNRZ94c, icon_path /tmp/scene_img/423C8888EE43AEBA5A5B8AEA6C79074E.png. [11-09 15:58:14:29 TUYA D][tuya_iot_scene_img_sync.c:130] scene sync type: 3 tuya_home_control_all_info_sync_event [69] :tuya_home_control_all_info_sync_event 3 [11-09 15:58:14:31 TUYA D][tuya_home_control_sync.c:35] recv scene sync event [11-09 15:58:14:45 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0 [11-09 15:58:14:45 TUYA D][mqc_app.c:1537] pub finish:0 [11-09 15:58:14:46 TUYA D][log_seq.c:793] upolad: mqtt | 3.4.2 | 01-01 00:00:01 | erc:0 | [20:-2310]/mqtt | 3.4.2 | 01-01 00:00:01 | erc:0 | [20:-2310] [11-09 15:58:14:59 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:14:60 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:14:60 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:14:61 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:14:62 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:14:63 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:14:63 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:14:64 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:14:102 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:14:103 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:14:183 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1667980694,"success":true} [11-09 15:58:14:183 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:14:184 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:14:184 TUYA D][tuya_devos_entry.c:406] put rst log finish [11-09 15:58:14:185 TUYA D][iot_httpc.c:946] Post Data: {"type":"[\"timezone\",\"rateRule\"]","t":1667980694} [11-09 15:58:14:186 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.get&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980694&v=2.0&sign=543852b71df58e9e4280a09ea54bb859 [11-09 15:58:14:187 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:14:188 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:14:188 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:14:189 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:14:215 TUYA D][thread_pool_temp.c:204] thread 18c04730 END [11-09 15:58:14:216 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:14:216 TUYA D][thread_pool_temp.c:147] put thread 0x7f8c000b90 [11-09 15:58:14:217 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:58:14:243 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:14:244 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:14:245 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:14:246 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:14:246 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:14:247 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:14:247 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:14:248 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:14:292 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:14:292 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:14:388 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"timezone":{"validTime":1800,"time":1667980694,"config":{}}},"t":1667980694,"success":true} [11-09 15:58:14:389 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:14:390 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:14:390 TUYA D][iot_httpc.c:3173] dynamic cfg post data:{"type":"[\"timezone\",\"rateRule\"]","t":1667980694}, ret:0. [11-09 15:58:14:391 TUYA D][tuya_devos_utils.c:205] set dp rate_rule:{"timezone":{"validTime":1800,"time":1667980694,"config":{}}}. [11-09 15:58:14:392 TUYA D][tuya_devos_utils.c:94] reset dp rate rule finish. [11-09 15:58:14:393 TUYA D][iot_httpc.c:2171] NO ackId [11-09 15:58:14:393 TUYA D][simplekv.c:1211] read key:0000039kxz_ver isFuzzy:0 skipCnt:0 [11-09 15:58:14:394 TUYA D][simplekv.c:1247] no key find [11-09 15:58:14:394 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [11-09 15:58:14:395 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [11-09 15:58:14:395 TUYA D][tuya_svc_schema_upgrade.c:223] schema[0000039kxz] not updated since activated [11-09 15:58:14:490 TUYA D][gw_reli_http_report.c:94] no msg to rpt [11-09 15:58:14:785 TUYA I][lan_cluster_master_core.c:850] __timer_proc_master_wait. send_cnt[2] [11-09 15:58:14:867 TUYA D][iot_httpc.c:946] Post Data: {"subId":null,"t":1667980694} [11-09 15:58:14:867 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upgrade.silent.get&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980694&v=4.4&sign=86dd2dce1379b8486916210bba2f7b02 [11-09 15:58:14:869 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:14:869 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:14:870 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:14:871 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:14:900 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:14:901 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:14:901 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:14:902 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:14:903 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:14:904 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:14:904 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:14:905 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:14:956 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:14:956 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:15:8 TUYA D][rcd_file.c:548] [ty_rcd]__flush_timer_cb start [11-09 15:58:15:9 TUYA D][thread_pool_temp.c:721] temp run add 0x18c04770 0x7fb74ce2ac 18c4ae40 [11-09 15:58:15:9 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74ce2ac 18c4ae40 [11-09 15:58:15:10 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74ce2ac 18c4ae40 in thread 18c04760 BEGIN [11-09 15:58:15:11 TUYA D][rcd_file.c:533] [ty_rcd] __rcd_db_flush start. [11-09 15:58:15:21 TUYA D][rcd_file.c:538] [ty_rcd] __rcd_db_flush end. [11-09 15:58:15:21 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:15:21 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:15:22 TUYA D][thread_pool_temp.c:147] put thread 0x18c04770 [11-09 15:58:15:22 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:58:15:30 TUYA D][rcd_file.c:548] [ty_rcd]__flush_timer_cb start [11-09 15:58:15:31 TUYA D][thread_pool_temp.c:721] temp run add 0x18c04770 0x7fb74ce2ac 18c4d980 [11-09 15:58:15:32 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74ce2ac 18c4d980 [11-09 15:58:15:33 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74ce2ac 18c4d980 in thread 18c04760 BEGIN [11-09 15:58:15:33 TUYA D][rcd_file.c:533] [ty_rcd] __rcd_db_flush start. [11-09 15:58:15:43 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1667980695,"success":true} [11-09 15:58:15:44 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:15:44 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:15:45 TUYA E][tuya_svc_upgrade.c:436] result null [11-09 15:58:15:45 TUYA D][tuya_svc_upgrade.c:511] silent get firmware fail [11-09 15:58:15:46 TUYA D][tuya_svc_upgrade.c:205] next detect timer: 21600s [11-09 15:58:15:46 TUYA N][tuya_svc_timer_task.c:801] Update Timer from cloud [11-09 15:58:15:47 TUYA D][iot_httpc.c:946] Post Data: {"devId":"6ce31c8d4213fd9ea3n3rd","lastFetchTime":"0","t":1667980695} [11-09 15:58:15:48 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.timer.count&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980695&v=4.2&sign=50aec882cfec4325209e5f5cf0ee1008 [11-09 15:58:15:49 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:15:50 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:15:51 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:15:51 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:15:77 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:15:77 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:15:78 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:15:79 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:15:80 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:15:80 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:15:81 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:15:81 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:15:87 TUYA D][rcd_file.c:538] [ty_rcd] __rcd_db_flush end. [11-09 15:58:15:87 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:15:88 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:15:88 TUYA D][thread_pool_temp.c:147] put thread 0x18c04770 [11-09 15:58:15:89 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:58:15:145 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:15:145 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:15:213 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"devId":"6ce31c8d4213fd9ea3n3rd","code":"200","count":0,"lastFetchTime":0},"t":1667980695,"success":true} [11-09 15:58:15:214 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:15:214 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:15:215 TUYA D][tuya_svc_timer_task.c:456] time eq skip:0 [11-09 15:58:17:760 TUYA D][thread_pool_temp.c:738] temp run add delay 0x7fa40107a0 0x7fb74ecd1c 0 0 [11-09 15:58:17:760 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74ecd1c 0 [11-09 15:58:17:761 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74ecd1c 0 in thread 18c04760 BEGIN [11-09 15:58:17:762 TUYA D][iot_httpc.c:946] Post Data: {"typeAttribute":8,"t":1667980697} [11-09 15:58:17:762 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.local.group.relation.get&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980697&v=1.0&sign=ae73bbd25a6c988bc2e9414bc9c6bb73 [11-09 15:58:17:764 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:17:764 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:17:765 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:17:766 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:17:788 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:17:789 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:17:789 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:17:790 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:17:791 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:17:792 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:17:792 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:17:793 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:17:828 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:17:829 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:17:889 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{},"t":1667980698,"success":true} [11-09 15:58:18:0 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:18:0 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:18:1 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:18:1 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:18:2 TUYA D][thread_pool_temp.c:147] put thread 0x7fa40107a0 [11-09 15:58:18:2 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:58:19:118 TUYA D][http_inf.c:284] HTTP Session https://a2.tuyacn.com:443 timeout. [11-09 15:58:19:119 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:19:119 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:19:330 TUYA W][tuya_z3.c:31701] Zigbee COO ver is not get. [11-09 15:58:19:904 TUYA I][lan_cluster_master_core.c:850] __timer_proc_master_wait. send_cnt[3] [11-09 15:58:19:905 TUYA D][lan_cluster_master_core.c:1381] cluster change status from 0 to 1 [11-09 15:58:19:905 TUYA N][lan_cluster_master_core.c:1393] cluster change status cb new out st 1 master [6ce31c8d4213fd9ea3n3rd] ip[0] [11-09 15:58:19:906 TUYA D][lan_pub_sub_mq.c:243] sub all topic at local [11-09 15:58:19:907 TUYA D][lan_pub_sub_mq_center.c:144] add topic[LAN_DP_UP] suber[local] [11-09 15:58:19:908 TUYA D][lan_pub_sub_mq_center.c:144] add topic[LAN_DEV_LIST_SYNC] suber[local] [11-09 15:58:19:908 TUYA D][lan_pub_sub_mq_center.c:144] add topic[LAN_SECURITY] suber[local] [11-09 15:58:19:909 TUYA I][uni_thread.c:228] thread_create name:lan_key_exch,stackDepth:4096,totalstackDepth:136704,priority:4 [11-09 15:58:19:910 TUYA D][scene_linkage_lan_master.c:350] __cluster_state_change -> 1 [11-09 15:58:19:911 TUYA D][scene_linkage_rule_sync.c:1941] scene_linkage_update_from_server linkage_type:1 delaymS:60000 [11-09 15:58:19:912 TUYA D][uni_thread.c:250] Thread:lan_key_exch Exec Start. Set to Running Stat [11-09 15:58:19:912 TUYA D][tuya_lan_dev_list_core.c:342] lan_cluste st 1 [11-09 15:58:19:913 TUYA I][lpc_con_core.c:252] tuya_lan_pro_client_connet_del_all_peer_node [11-09 15:58:19:914 TUYA D][tuya_lan_dev_localkey.c:518] add node 6cd4e4d52a86777441iaxt [11-09 15:58:19:914 TUYA D][tuya_lan_dev_list_cache.c:207] dev list add cache 6ce31c8d4213fd9ea3n3rd [11-09 15:58:19:915 TUYA D][tuya_ctrl_lan_manage.c:81] dev:6ce31c8d4213fd9ea3n3rd lan avail:1 [11-09 15:58:19:916 TUYA D][tuya_ctrl_online.c:430] recv id: 6c532d9717845ff9f6lmen tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:19:917 TUYA D][tuya_ctrl_online.c:430] recv id: 6ce31c8d4213fd9ea3n3rd tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:1 [11-09 15:58:19:918 TUYA D][thread_pool_temp.c:721] temp run add 0x7fa4011cd0 0x7fb7534f94 a4013080 [11-09 15:58:19:919 TUYA D][thread_pool_temp.c:627] temp run 0x7fb7534f94 a4013080 [11-09 15:58:19:920 TUYA D][tuya_ctrl_online.c:387] publish id:6ce31c8d4213fd9ea3n3rd online:1 [11-09 15:58:19:920 TUYA D][tuya_home_ctrl_event.c:282] event oneline devid : 6ce31c8d4213fd9ea3n3rd, online state : 1 [11-09 15:58:19:921 TUYA D][thread_pool_temp.c:201] run temp 0x7fb7534f94 a4013080 in thread 18c04760 BEGIN [11-09 15:58:19:922 TUYA E][tuya_lan_dp_query.c:502] my dev cntl Not Find [11-09 15:58:19:923 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:19:923 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:19:924 TUYA D][thread_pool_temp.c:147] put thread 0x7fa4011cd0 [11-09 15:58:19:924 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:58:19:925 TUYA D][tuya_home_ctrl_event.c:284] FINISH CALL cb 1 in total. [11-09 15:58:19:926 TUYA I][tuya_home_ctrl_dev.c:2257] hashmap_get FAILED: rt -2. [11-09 15:58:19:926 TUYA E][tuya_home_ctrl_dev.c:2295] _tuya_home_ctrl_dev_online_update_event FAILED: dev_id 6ce31c8d4213fd9ea3n3rd, online_stat 1. [11-09 15:58:20:509 TUYA D][subdev_upgrade_schema.c:720] start schema update subdev. [11-09 15:58:20:509 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [11-09 15:58:20:510 TUYA D][subdev_sto_rcd.c:790] rcd_entry_kv_read fails 0000004qsd -6 [11-09 15:58:20:510 TUYA W][subdev_upgrade_schema.c:447] schema[0000004qsd] not updated since activated [11-09 15:58:20:511 TUYA D][subdev_upgrade_schema.c:731] schema update dev get. [11-09 15:58:20:512 TUYA D][subdev_upgrade_schema.c:764] end schema update subdev:1. [11-09 15:58:20:873 TUYA D][thread_pool_temp.c:417] check delay task num=1 [11-09 15:58:20:874 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74ed764 0 [11-09 15:58:20:875 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74ed764 0 in thread 18c04760 BEGIN [11-09 15:58:20:875 TUYA D][iot_httpc.c:946] Post Data: {"typeAttribute":0,"t":1667980700} [11-09 15:58:20:876 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.local.group.relation.get&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980700&v=1.0&sign=7b8a48ea53c4512395efa01937f03ef2 [11-09 15:58:20:878 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:20:878 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:20:879 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:20:880 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:20:904 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:20:904 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:20:905 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:20:906 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:20:906 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:20:907 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:20:907 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:20:908 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:20:914 TUYA D][thread_pool_temp.c:721] temp run add 0x7fa4010e30 0x7fb7528790 0 [11-09 15:58:20:915 TUYA D][thread_pool_temp.c:627] temp run 0x7fb7528790 0 [11-09 15:58:20:915 TUYA D][thread_pool_temp.c:201] run temp 0x7fb7528790 0 in thread 18c04730 BEGIN [11-09 15:58:20:916 TUYA D][iot_httpc.c:946] Post Data: {"devIds":["6cd4e4d52a86777441iaxt"],"t":1667980700} [11-09 15:58:20:917 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.lan.node.sync&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980700&v=2.0&sign=12102e739eb872bb4da853ef664ada69 [11-09 15:58:20:918 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:20:919 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:20:920 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:20:920 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:20:947 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:20:947 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:20:948 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:20:949 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:20:950 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:20:951 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:20:952 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:20:952 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:20:953 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:20:953 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:21:4 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:21:5 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:21:7 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{},"t":1667980701,"success":true} [11-09 15:58:21:8 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:21:8 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:21:9 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:21:9 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:21:10 TUYA D][thread_pool_temp.c:147] put thread 0x7fa40107a0 [11-09 15:58:21:10 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:1 [11-09 15:58:21:80 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"fail":[],"nodes":[{"devId":"6cd4e4d52a86777441iaxt","cadVersion":"1.0.4","localKey":"6578801940797883"}],"success":["6cd4e4d52a86777441iaxt"]},"t":1667980701,"success":true} [11-09 15:58:21:82 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:21:82 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:21:83 TUYA D][tuya_lan_dev_localkey.c:320] node 6cd4e4d52a86777441iaxt is get lc key ok [11-09 15:58:21:84 TUYA D][simplekv.c:1211] read key:lan_nd_attr isFuzzy:0 skipCnt:0 [11-09 15:58:21:84 TUYA D][simplekv.c:1251] find key:12 lan_nd_attr [11-09 15:58:21:85 TUYA D][simplekv.c:1280] key:lan_nd_attr find value.Len:80 [11-09 15:58:21:85 TUYA D][tuya_lan_dev_localkey.c:89] __localkey_get_rsp [11-09 15:58:21:86 TUYA D][tuya_lan_dev_localkey.c:113] __localkey_get_rsp num=1 [11-09 15:58:21:86 TUYA D][tuya_lan_dev_list_core.c:568] local key get cb 1 [11-09 15:58:21:87 TUYA D][thread_pool_temp.c:204] thread 18c04730 END [11-09 15:58:21:88 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:21:88 TUYA D][thread_pool_temp.c:147] put thread 0x7fa4010e30 [11-09 15:58:21:89 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:58:21:89 TUYA D][tuya_lan_dev_list_core.c:546] local key set 6cd4e4d52a86777441iaxt [11-09 15:58:21:90 TUYA D][lpc_db_manager.c:215] dev:6cd4e4d52a86777441iaxt, updata localkey from to 6578801940797883 [11-09 15:58:21:91 TUYA I][lpc_con_core.c:207] tuya_lan_pro_client_connet_del_peer_node id:6cd4e4d52a86777441iaxt [11-09 15:58:21:92 TUYA D][lpc_con_core.c:238] id 6cd4e4d52a86777441iaxt not exist [11-09 15:58:21:92 TUYA D][lpc_db_manager.c:223] dev:6cd4e4d52a86777441iaxt, updata is_new_ver from 0 to 1 [11-09 15:58:21:93 TUYA D][lpc_db_manager.c:230] dev:6cd4e4d52a86777441iaxt, updata need_connect from 0 to 1 [11-09 15:58:21:94 TUYA D][tuya_lan_dev_list_core.c:491] dev st change from pro 6cd4e4d52a86777441iaxt 3 DISCON [11-09 15:58:21:95 TUYA I][lpc_con_core.c:185] tuya_lan_pro_client_connet_add_peer_node id:6cd4e4d52a86777441iaxt [11-09 15:58:21:96 TUYA D][tuya_lan_dev_list_core.c:466] dev st change 6cd4e4d52a86777441iaxt 5 CON_ERR [11-09 15:58:24:18 TUYA D][lpc_tcp.c:82] connect IP:192.168.18.102 Port:6668 [11-09 15:58:24:19 TUYA D][lpc_tcp.c:181] id:6cd4e4d52a86777441iaxt change state from init(0) to connectting(1) [11-09 15:58:24:20 TUYA D][lpc_tcp.c:184] key_exch_connecting :6cd4e4d52a86777441iaxt [11-09 15:58:24:22 TUYA D][lpc_key_exch.c:116] send_randA_msg [11-09 15:58:24:22 TUYA D][lpc_tcp.c:463] id:6cd4e4d52a86777441iaxt change state from connectting(1) to key exching(7) [11-09 15:58:24:29 TUYA D][lpc_tcp.c:315] id 6cd4e4d52a86777441iaxt KEY_EXCH read [11-09 15:58:24:29 TUYA D][lpc_tuya_lan_frame.c:646] id:6cd4e4d52a86777441iaxt Process Data. Type:4 [11-09 15:58:24:30 TUYA D][lpc_tuya_lan_frame.c:439] lan ver over 3.4 [11-09 15:58:24:31 TUYA D][lpc_protocol_processor.c:113] id:6cd4e4d52a86777441iaxt Process Data. Type:4 Len:48 ret:0 [11-09 15:58:24:32 TUYA D][lpc_db_manager.c:253] dev:6cd4e4d52a86777441iaxt, session_key from 0 0 0 0 to 3d a8 5f bb [11-09 15:58:24:33 TUYA D][lpc_db_manager.c:237] dev:6cd4e4d52a86777441iaxt, updata is_connect from 0 to 1 [11-09 15:58:24:34 TUYA D][lpc_db_manager.c:244] dev:6cd4e4d52a86777441iaxt, updata fd from 0 to 33 [11-09 15:58:24:34 TUYA D][tuya_lan_dev_list_core.c:491] dev st change from pro 6cd4e4d52a86777441iaxt 2 CON [11-09 15:58:24:35 TUYA D][lpc_tcp.c:342] id:6cd4e4d52a86777441iaxt change state from key exching(7) to exching(2) [11-09 15:58:24:36 TUYA D][tuya_lan_dev_list_core.c:466] dev st change 6cd4e4d52a86777441iaxt 3 CON_OK [11-09 15:58:24:912 TUYA D][lan_cluster_master_core.c:1367] node [6cd4e4d52a86777441iaxt]report. st[1] [11-09 15:58:24:912 TUYA D][lan_dev_base_master.c:1078] __lan_node_change_single_cb node 6cd4e4d52a86777441iaxt st:1 [11-09 15:58:24:913 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6cd4e4d52a86777441iaxt [11-09 15:58:24:914 TUYA D][lan_msg_reliable_trans_master.c:636] id 6cd4e4d52a86777441iaxt already add [11-09 15:58:24:915 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6cd4e4d52a86777441iaxt st:1 [11-09 15:58:24:916 TUYA D][lan_dp_report_sync_master.c:329] node 6cd4e4d52a86777441iaxt not found omit [11-09 15:58:24:916 TUYA I][lan_cluster_master_core.c:972] node [6cd4e4d52a86777441iaxt] joined [11-09 15:58:24:917 TUYA I][lan_cluster_master_core.c:1330] node report. total num[1] report num[1] [11-09 15:58:24:918 TUYA D][lan_cluster_node_info.c:122] __cluster_node_info_change_cb num = 1 6cd4e4d52a86777441iaxt,[11-09 15:58:24:919 TUYA D][lan_cluster_node_info.c:126] [11-09 15:58:24:919 TUYA D][lan_dev_base_master.c:449] node report num[1] [11-09 15:58:29:335 TUYA W][tuya_z3.c:31701] Zigbee COO ver is not get. [11-09 15:58:29:834 TUYA D][subdev_hb_ol.c:826] start heartbeat qeury process... [11-09 15:58:33:176 TUYA I][lan_rpc.c:529] lan_rpc_recv result 192, ip -> c0a81266, port 6608 [11-09 15:58:33:177 TUYA D][lan_rpc.c:534] session_key 35 64 37 64 [11-09 15:58:33:177 TUYA D][lan_rpc.c:571] session_key 00 00 00 00 [11-09 15:58:33:178 TUYA D][base_rpc_com.c:429] Rev From Key:192.168.18.102 Len:192 [11-09 15:58:33:179 TUYA E][base_rpc_com.c:520] hmac check error recv:0f dc 24 d6. calc:f3 58 eb f6 [11-09 15:58:33:889 TUYA D][lan_cluster_multi_home_common.c:530] try sync cloud need 1 [11-09 15:58:33:889 TUYA D][thread_pool_temp.c:721] temp run add 0x7fa4005070 0x7fb75147b8 0 [11-09 15:58:33:890 TUYA D][thread_pool_temp.c:627] temp run 0x7fb75147b8 0 [11-09 15:58:33:890 TUYA D][thread_pool_temp.c:201] run temp 0x7fb75147b8 0 in thread 18c04760 BEGIN [11-09 15:58:33:891 TUYA D][lan_cluster_multi_home_common.c:423] __thread_sync_cloud [11-09 15:58:33:892 TUYA D][iot_httpc.c:946] Post Data: {"devIds":["6cd4e4d52a86777441iaxt"],"t":1667980713} [11-09 15:58:33:893 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.lan.node.sync&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980713&v=2.0&sign=744475f8f99fd5ce327c78528c1b18f3 [11-09 15:58:33:894 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:33:895 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:33:895 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:33:896 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:33:995 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:33:995 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:33:996 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:33:997 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:33:998 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:33:998 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:33:999 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:33:999 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:34:41 TUYA D][tuya_lan_dev_list_core.c:315] check_lan_dev_chgn [11-09 15:58:34:41 TUYA D][tuya_lan_dev_list_core.c:278] node st 6cd4e4d52a86777441iaxt 3 [11-09 15:58:34:42 TUYA D][tuya_lan_dev_list_core.c:282] add cache node 6cd4e4d52a86777441iaxt [11-09 15:58:34:43 TUYA D][tuya_lan_dev_list_cache.c:207] dev list add cache 6cd4e4d52a86777441iaxt [11-09 15:58:34:43 TUYA D][tuya_ctrl_lan_manage.c:81] dev:6cd4e4d52a86777441iaxt lan avail:1 [11-09 15:58:34:44 TUYA D][tuya_ctrl_online.c:430] recv id: 6c8d86100ac2212db3dqj5 tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:45 TUYA D][tuya_ctrl_online.c:430] recv id: 6c4eca7a6857459e05iy4h tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:46 TUYA D][tuya_ctrl_online.c:430] recv id: 6c27a15bd59ee5bdf4upda tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:48 TUYA D][tuya_ctrl_online.c:430] recv id: 6c3bf2671c859434dcqwy2 tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:49 TUYA D][tuya_ctrl_online.c:430] recv id: 6cf6379b475d474da28m3g tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:50 TUYA D][tuya_ctrl_online.c:430] recv id: 6c3828df4c0b927f0fgmvk tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:51 TUYA D][tuya_ctrl_online.c:430] recv id: 6c2529f04b3e2f53efovgd tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:52 TUYA D][tuya_ctrl_online.c:430] recv id: 6ca4e06c90ca9be915zkfk tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:54 TUYA D][tuya_ctrl_online.c:430] recv id: 6cb5dc73d1285dd5ddiv3h tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:55 TUYA D][tuya_ctrl_online.c:430] recv id: 6c99344ae1ee6e93cameee tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:56 TUYA D][tuya_ctrl_online.c:430] recv id: 6c5915544f98d4ae7cqsfd tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:57 TUYA D][tuya_ctrl_online.c:430] recv id: 6cd4638122441b052e4sxq tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:59 TUYA D][tuya_ctrl_online.c:430] recv id: 6c87ffeca8ddda70bfkyce tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:60 TUYA D][tuya_ctrl_online.c:430] recv id: 6cd5fc133a10b9492f2mjr tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:61 TUYA D][tuya_ctrl_online.c:430] recv id: 6c7662830c8c8544076lcq tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:62 TUYA D][tuya_ctrl_online.c:430] recv id: 6cc30800d40ef47493t6a9 tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:63 TUYA D][tuya_ctrl_online.c:430] recv id: 6c15cfcf1a96b57237suji tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:65 TUYA D][tuya_ctrl_online.c:430] recv id: 6cf669ac11164156b6obee tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:66 TUYA D][tuya_ctrl_online.c:430] recv id: 6cd3c4e6a2e5a8b893qqni tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:67 TUYA D][tuya_ctrl_online.c:430] recv id: 6c234dbaf596f2bc18h3be tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:68 TUYA D][tuya_ctrl_online.c:430] recv id: 6ce7e76b6dd5ae2cc7gofr tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:69 TUYA D][tuya_ctrl_online.c:430] recv id: 6c4a21a4359ea3d811u4dw tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:0 [11-09 15:58:34:71 TUYA D][tuya_ctrl_online.c:430] recv id: 6cd4e4d52a86777441iaxt tp:0 src:3 online stat: 1, old_st:0, new_st:0x1, old_online:0, new_online:1 [11-09 15:58:34:72 TUYA D][tuya_lan_dp_query.c:568] dp_query id[6cd4e4d52a86777441iaxt] cid[] state[1] [11-09 15:58:34:73 TUYA D][tuya_lan_dp_query.c:297] lan dp query in_master src:local dst:6cd4e4d52a86777441iaxt [11-09 15:58:34:73 TUYA D][tuya_ctrl_online.c:387] publish id:6cd4e4d52a86777441iaxt online:1 [11-09 15:58:34:74 TUYA D][tuya_home_ctrl_event.c:282] event oneline devid : 6cd4e4d52a86777441iaxt, online state : 1 [11-09 15:58:34:75 TUYA D][tuya_home_ctrl_event.c:284] FINISH CALL cb 1 in total. [11-09 15:58:34:76 TUYA I][tuya_home_ctrl_dev.c:2257] hashmap_get FAILED: rt -2. [11-09 15:58:34:76 TUYA E][tuya_home_ctrl_dev.c:2295] _tuya_home_ctrl_dev_online_update_event FAILED: dev_id 6cd4e4d52a86777441iaxt, online_stat 1. [11-09 15:58:34:100 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:34:100 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:34:162 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"fail":[],"nodes":[{"devId":"6cd4e4d52a86777441iaxt","cadVersion":"1.0.4","localKey":"6578801940797883"}],"success":["6cd4e4d52a86777441iaxt"]},"t":1667980714,"success":true} [11-09 15:58:34:164 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:34:164 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:34:165 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:34:165 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:34:166 TUYA D][thread_pool_temp.c:147] put thread 0x7fa4005070 [11-09 15:58:34:166 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:58:34:510 TUYA I][lan_rpc.c:529] lan_rpc_recv result 192, ip -> c0a81266, port 6608 [11-09 15:58:34:510 TUYA D][lan_rpc.c:534] session_key 35 64 37 64 [11-09 15:58:34:511 TUYA D][lan_rpc.c:571] session_key 00 00 00 00 [11-09 15:58:34:511 TUYA D][base_rpc_com.c:429] Rev From Key:192.168.18.102 Len:192 [11-09 15:58:34:512 TUYA E][base_rpc_com.c:520] hmac check error recv:07 e6 0b 55. calc:f5 52 c0 d9 [11-09 15:58:34:528 TUYA D][simplekv.c:1211] read key:0000039kxz_ver isFuzzy:0 skipCnt:0 [11-09 15:58:34:528 TUYA D][simplekv.c:1247] no key find [11-09 15:58:34:528 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [11-09 15:58:34:529 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [11-09 15:58:34:530 TUYA D][tuya_svc_upgrade_http.c:125] schema get:{"schemaId":"0000039kxz","version":""} [11-09 15:58:34:531 TUYA D][iot_httpc.c:946] Post Data: {"schemaId":"0000039kxz","version":"","t":1667980714} [11-09 15:58:34:531 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.schema.newest.get&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980714&v=1.1&sign=0df73ffa3026549e77156372eaec6eeb [11-09 15:58:34:533 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:34:533 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:34:534 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:34:535 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:34:548 TUYA D][lan_pub_sub_mq_center.c:245] push topic:[LAN_DEV_LIST_SYNC] [{"list":"6ce31c8d4213fd9ea3n3rd,6cd4e4d52a86777441iaxt"}] [11-09 15:58:34:549 TUYA D][lan_pub_sub_mq.c:122] recv push topic:LAN_DEV_LIST_SYNC content:{"list":"6ce31c8d4213fd9ea3n3rd,6cd4e4d52a86777441iaxt"} src_id:6ce31c8d4213fd9ea3n3rd [11-09 15:58:34:550 TUYA D][lan_pub_sub_mq.c:150] my pub topic. so omit [11-09 15:58:34:551 TUYA D][lan_pub_sub_mq.c:708] publish topic[LAN_DEV_LIST_SYNC], [{"list":"6ce31c8d4213fd9ea3n3rd,6cd4e4d52a86777441iaxt"}], 0 [11-09 15:58:34:552 TUYA D][lan_pub_sub_mq_api.c:154] topic publish:[{"list":"6ce31c8d4213fd9ea3n3rd,6cd4e4d52a86777441iaxt"}] [11-09 15:58:34:595 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:34:595 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:34:596 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:34:597 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:34:598 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:34:598 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:34:599 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:34:599 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:34:640 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:34:640 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:34:716 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"schema":"","schemaId":"0000039kxz"},"t":1667980714,"success":true} [11-09 15:58:34:718 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:34:718 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:34:718 TUYA D][tuya_svc_upgrade_http.c:133] schema get result:{"schema":"","schemaId":"0000039kxz"} [11-09 15:58:34:719 TUYA D][tuya_svc_schema_upgrade.c:130] schema[0000039kxz] ver not update [11-09 15:58:35:512 TUYA I][lan_rpc.c:529] lan_rpc_recv result 192, ip -> c0a81266, port 6608 [11-09 15:58:35:513 TUYA D][lan_rpc.c:534] session_key 35 64 37 64 [11-09 15:58:35:513 TUYA D][lan_rpc.c:571] session_key 00 00 00 00 [11-09 15:58:35:514 TUYA D][base_rpc_com.c:429] Rev From Key:192.168.18.102 Len:192 [11-09 15:58:35:515 TUYA E][base_rpc_com.c:520] hmac check error recv:48 15 f5 ca. calc:cf cf 0d 3d [11-09 15:58:37:83 TUYA D][tuya_lan_dp_query.c:257] do query node 6cd4e4d52a86777441iaxt [11-09 15:58:37:83 TUYA D][thread_pool_temp.c:721] temp run add 0x7fa4011cd0 0x7fb75342c8 a40204d0 [11-09 15:58:37:84 TUYA D][thread_pool_temp.c:627] temp run 0x7fb75342c8 a40204d0 [11-09 15:58:37:85 TUYA D][thread_pool_temp.c:201] run temp 0x7fb75342c8 a40204d0 in thread 18c04760 BEGIN [11-09 15:58:37:85 TUYA D][tuya_lan_dp_query.c:195] do_query_by_pro :6cd4e4d52a86777441iaxt [11-09 15:58:37:86 TUYA D][tuya_lan_dp_query.c:220] cid is NULL [11-09 15:58:37:87 TUYA D][lpc_cmd.c:253] query_json:{}, query_cmd:16 [11-09 15:58:37:87 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:37:88 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:37:88 TUYA D][thread_pool_temp.c:147] put thread 0x7fa4011cd0 [11-09 15:58:37:89 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:58:37:92 TUYA D][lpc_tuya_lan_frame.c:646] id:6cd4e4d52a86777441iaxt Process Data. Type:16 [11-09 15:58:37:93 TUYA D][lpc_tuya_lan_frame.c:439] lan ver over 3.4 [11-09 15:58:37:93 TUYA D][lpc_protocol_processor.c:113] id:6cd4e4d52a86777441iaxt Process Data. Type:16 Len:0 ret:1 [11-09 15:58:37:512 TUYA I][lan_rpc.c:529] lan_rpc_recv result 192, ip -> c0a81266, port 6608 [11-09 15:58:37:512 TUYA D][lan_rpc.c:534] session_key 35 64 37 64 [11-09 15:58:37:513 TUYA D][lan_rpc.c:571] session_key 00 00 00 00 [11-09 15:58:37:513 TUYA D][base_rpc_com.c:429] Rev From Key:192.168.18.102 Len:192 [11-09 15:58:37:514 TUYA E][base_rpc_com.c:520] hmac check error recv:bc dd 3f ab. calc:f7 fa ee 5f [11-09 15:58:38:86 TUYA D][tuya_lan_dp_query.c:275] no query node [11-09 15:58:39:341 TUYA W][tuya_z3.c:31701] Zigbee COO ver is not get. [11-09 15:58:40:548 TUYA I][lan_rpc.c:529] lan_rpc_recv result 192, ip -> c0a81266, port 6608 [11-09 15:58:40:549 TUYA D][lan_rpc.c:534] session_key 35 64 37 64 [11-09 15:58:40:549 TUYA D][lan_rpc.c:571] session_key 00 00 00 00 [11-09 15:58:40:550 TUYA D][base_rpc_com.c:429] Rev From Key:192.168.18.102 Len:192 [11-09 15:58:40:551 TUYA E][base_rpc_com.c:520] hmac check error recv:a8 87 fb c9. calc:4d a0 d7 8c [11-09 15:58:40:721 TUYA D][subdev_upgrade_schema.c:389] start schema get subdev. [11-09 15:58:40:722 TUYA D][subdev_upgrade_schema.c:405] dev id:000d6ffffe67e2ca check schema update. [11-09 15:58:40:723 TUYA D][subdev_upgrade_schema.c:114] start dev update, schema:0000004qsd. [11-09 15:58:40:723 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [11-09 15:58:40:724 TUYA D][subdev_sto_rcd.c:790] rcd_entry_kv_read fails 0000004qsd -6 [11-09 15:58:40:725 TUYA D][tuya_svc_upgrade_http.c:125] schema get:{"schemaId":"0000004qsd","version":"","nodeId":"000d6ffffe67e2ca"} [11-09 15:58:40:726 TUYA D][iot_httpc.c:946] Post Data: {"schemaId":"0000004qsd","version":"","nodeId":"000d6ffffe67e2ca","t":1667980720} [11-09 15:58:40:727 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.schema.newest.get&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980720&v=1.1&sign=26549245801375e10ce21382f9d4e9d5 [11-09 15:58:40:728 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:40:729 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:40:730 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:40:730 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:40:856 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:40:856 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:40:857 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:40:858 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:40:858 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:40:859 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:40:859 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:40:860 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:40:967 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:40:967 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:41:70 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"schema":"","schemaId":"0000004qsd"},"t":1667980721,"success":true} [11-09 15:58:41:71 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:41:71 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:41:71 TUYA D][tuya_svc_upgrade_http.c:133] schema get result:{"schema":"","schemaId":"0000004qsd"} [11-09 15:58:41:72 TUYA D][subdev_upgrade_schema.c:225] schema[0000004qsd] ver not update [11-09 15:58:41:73 TUYA D][subdev_upgrade_schema.c:254] end dev update, eAction:0. [11-09 15:58:41:73 TUYA D][subdev_upgrade_schema.c:427] end schema get subdev, eAction:0, is_got_new:0. [11-09 15:58:42:921 TUYA D][thread_pool_temp.c:721] temp run add 0x7fa40060a0 0x7fb749f1f4 0 [11-09 15:58:42:922 TUYA D][thread_pool_temp.c:627] temp run 0x7fb749f1f4 0 [11-09 15:58:42:922 TUYA D][thread_pool_temp.c:201] run temp 0x7fb749f1f4 0 in thread 18c04760 BEGIN [11-09 15:58:42:923 TUYA D][lan_dev_base_master.c:547] node report node_num 1. [11-09 15:58:42:924 TUYA D][iot_httpc.c:946] Post Data: {"devIds": ["6cd4e4d52a86777441iaxt"],"t":1667980722} [11-09 15:58:42:924 TUYA D][iot_httpc.c:958] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.lan.node.report&devId=6ce31c8d4213fd9ea3n3rd&et=1&t=1667980722&v=1.0&sign=dba75f614fd0a15dd03058355003322f [11-09 15:58:42:926 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443 -->> [11-09 15:58:42:927 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 2 [11-09 15:58:42:927 TUYA D][uni_network.c:353] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [11-09 15:58:42:928 TUYA D][httpc.c:476] ----got ipaddr:42,192,31,36 [11-09 15:58:42:963 TUYA D][httpc.c:817] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [11-09 15:58:42:964 TUYA D][tuya_tls.c:1259] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [11-09 15:58:42:964 TUYA D][tuya_tls.c:1302] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [11-09 15:58:42:965 TUYA D][tuya_tls.c:1373] load tuya cert. [11-09 15:58:42:966 TUYA D][tuya_tls.c:1378] parse crt <0> len <1028> ret <0> [11-09 15:58:42:967 TUYA D][tuya_tls.c:1378] parse crt <1> len <2002> ret <0> [11-09 15:58:42:967 TUYA D][tuya_iot_com_api.c:259] tuya public url [11-09 15:58:42:968 TUYA D][tuya_tls.c:1488] socket fd is set. set to inner send/recv to handshake [11-09 15:58:43:17 TUYA D][tuya_tls.c:1533] handshake finish for a2.tuyacn.com. set send/recv to user set [11-09 15:58:43:18 TUYA D][tuya_tls.c:1548] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [11-09 15:58:43:104 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"success":["6ce31c8d4213fd9ea3n3rd","6cd4e4d52a86777441iaxt"],"fail":[],"keyMap":{"6ce31c8d4213fd9ea3n3rd":"5d7d84f58a7ea2ee","6cd4e4d52a86777441iaxt":"6578801940797883"}},"t":1667980723,"success":true} [11-09 15:58:43:106 TUYA D][tuya_tls.c:1628] TUYA_TLS Disconnect ENTER [11-09 15:58:43:106 TUYA D][tuya_tls.c:1683] TUYA_TLS Disconnect Success [11-09 15:58:43:107 TUYA I][lan_key_exch_nodeA.c:282] lan_key_exch_add_peer_node id:6cd4e4d52a86777441iaxt [11-09 15:58:43:108 TUYA D][lan_cluster_master_core.c:1239] __on_node_ack num[2]. hash map len=1 [11-09 15:58:43:108 TUYA I][lan_cluster_master_core.c:1274] node [6cd4e4d52a86777441iaxt] acked [11-09 15:58:43:109 TUYA D][lan_rpc.c:205] lan_rpc_node_key_set id:6cd4e4d52a86777441iaxt key: 36 35 37 38 [11-09 15:58:43:110 TUYA D][lan_msg_reliable_trans_master.c:237] lan_msg_set_recv_seq id:6cd4e4d52a86777441iaxt seq:0 [11-09 15:58:43:111 TUYA D][simplekv.c:1348] delete key:cls_local_key isFuzzy:0 [11-09 15:58:43:111 TUYA D][simplekv.c:1354] cnt:15 delete bit arr len:1 [11-09 15:58:43:112 TUYA D][simplekv.c:1395] key:cls_local_key not find [11-09 15:58:43:112 TUYA D][simplekv.c:1211] read key:cls_key_cnt isFuzzy:0 skipCnt:0 [11-09 15:58:43:113 TUYA D][simplekv.c:1251] find key:13 cls_key_cnt [11-09 15:58:43:114 TUYA D][simplekv.c:1280] key:cls_key_cnt find value.Len:32 [11-09 15:58:43:114 TUYA D][simplekv.c:1211] read key:cls_lck_key_a isFuzzy:0 skipCnt:0 [11-09 15:58:43:115 TUYA D][simplekv.c:1251] find key:14 cls_lck_key_a [11-09 15:58:43:116 TUYA D][simplekv.c:1280] key:cls_lck_key_a find value.Len:96 [11-09 15:58:43:116 TUYA D][simplekv.c:1211] read key:cls_key_cnt isFuzzy:0 skipCnt:0 [11-09 15:58:43:117 TUYA D][simplekv.c:1251] find key:13 cls_key_cnt [11-09 15:58:43:117 TUYA D][simplekv.c:1280] key:cls_key_cnt find value.Len:32 [11-09 15:58:43:118 TUYA D][simplekv.c:1211] read key:cls_lck_key_a isFuzzy:0 skipCnt:0 [11-09 15:58:43:119 TUYA D][simplekv.c:1251] find key:14 cls_lck_key_a [11-09 15:58:43:119 TUYA D][simplekv.c:1280] key:cls_lck_key_a find value.Len:96 [11-09 15:58:43:120 TUYA D][simplekv.c:1211] read key:cls_key_cnt isFuzzy:0 skipCnt:0 [11-09 15:58:43:120 TUYA D][simplekv.c:1251] find key:13 cls_key_cnt [11-09 15:58:43:121 TUYA D][simplekv.c:1280] key:cls_key_cnt find value.Len:32 [11-09 15:58:43:122 TUYA D][simplekv.c:1211] read key:cls_lck_key_a isFuzzy:0 skipCnt:0 [11-09 15:58:43:122 TUYA D][simplekv.c:1251] find key:14 cls_lck_key_a [11-09 15:58:43:123 TUYA D][simplekv.c:1280] key:cls_lck_key_a find value.Len:96 [11-09 15:58:43:124 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:43:124 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:43:125 TUYA D][thread_pool_temp.c:147] put thread 0x7fa40060a0 [11-09 15:58:43:125 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:58:43:913 TUYA D][lan_key_exch_nodeA.c:464] doing num:0 [11-09 15:58:43:914 TUYA D][lan_key_exch_nodeA.c:163] connect IP:c0a81266 Port:6682 [11-09 15:58:43:914 TUYA D][lan_key_exch_nodeA.c:508] key_exch_connecting :6cd4e4d52a86777441iaxt [11-09 15:58:43:915 TUYA D][lan_key_exch_nodeA.c:581] listen peer num:1 [11-09 15:58:43:917 TUYA D][lan_key_exch_base.c:125] __send_frame,type:3,ret_code:0,data_len:16 [11-09 15:58:43:917 TUYA D][lan_key_exch_nodeA.c:746] id 6cd4e4d52a86777441iaxt st KEY_NODEA_ST_EXCHING [11-09 15:58:43:918 TUYA D][lan_key_exch_nodeA.c:464] doing num:1 [11-09 15:58:43:918 TUYA D][lan_key_exch_nodeA.c:581] listen peer num:1 [11-09 15:58:43:923 TUYA D][lan_key_exch_nodeA.c:695] id 6cd4e4d52a86777441iaxt read [11-09 15:58:43:924 TUYA D][lan_key_exch_base.c:310] tuya_hal_net_recv,len:94 [11-09 15:58:43:924 TUYA D][lan_key_exch_base.c:338] tuya_hal_net_recv,type:4 [11-09 15:58:43:925 TUYA D][lan_key_exch_base.c:125] __send_frame,type:5,ret_code:0,data_len:32 [11-09 15:58:43:926 TUYA D][lan_key_exch_nodeA.c:715] id 6cd4e4d52a86777441iaxt st:2 [11-09 15:58:43:938 TUYA D][lan_key_exch_nodeA.c:695] id 6cd4e4d52a86777441iaxt read [11-09 15:58:43:938 TUYA D][lan_rpc.c:205] lan_rpc_node_key_set id:6cd4e4d52a86777441iaxt key: f6 fc 78 46 [11-09 15:58:43:939 TUYA D][lan_msg_reliable_trans_master.c:237] lan_msg_set_recv_seq id:6cd4e4d52a86777441iaxt seq:0 [11-09 15:58:43:940 TUYA D][lan_key_exch_nodeA.c:621] id 6cd4e4d52a86777441iaxt exch finish ret:0 old_st:2 new_st:4 [11-09 15:58:43:941 TUYA D][lan_key_exch_nodeA.c:464] doing num:0 [11-09 15:58:43:941 TUYA D][lan_key_exch_nodeA.c:584] no peer hc_show_all [1493] :===========================hc_show_all============================ [11-09 15:58:46:987 TUYA I][tuya_ctrl_center_api.c:269] dev 6ce31c8d4213fd9ea3n3rd (name Linux无网关中控) should not be shown on screen. [11-09 15:58:46:988 TUYA I][tuya_ctrl_center_api.c:269] dev 6c3828df4c0b927f0fgmvk (name 智能温控面板(液晶屏)) should not be shown on screen. [11-09 15:58:46:989 TUYA I][tuya_ctrl_center_api.c:269] dev 6cd4e4d52a86777441iaxt (name 网关) should not be shown on screen. [11-09 15:58:46:990 TUYA I][tuya_ctrl_center_api.c:269] dev 6cd4cfefaccf115ed42vof (name 4寸智能中控-L) should not be shown on screen. [11-09 15:58:46:991 TUYA I][tuya_ctrl_center_api.c:269] dev vdevo160645218918419 (name 新版标准zigbee门锁) should not be shown on screen. [11-09 15:58:46:992 TUYA D][tuya_ctrl_center_api.c:280] > get brief [0] dev_id vdevo159962420219648 name 标准公版空调, SEQ 0. [11-09 15:58:46:993 TUYA D][tuya_ctrl_center_api.c:280] > get brief [1] dev_id vdevo159963275037036 name Zigbee温控器, SEQ 1. [11-09 15:58:46:994 TUYA D][tuya_ctrl_center_api.c:280] > get brief [2] dev_id vdevo159963120231012 name 新风控制面板, SEQ 2. [11-09 15:58:46:995 TUYA D][tuya_ctrl_center_api.c:280] > get brief [3] dev_id vdevo160307051406239 name 全屋情景复用开关(参考)-vdevo, SEQ 3. [11-09 15:58:46:996 TUYA D][tuya_ctrl_center_api.c:280] > get brief [4] dev_id 6c4a21a4359ea3d811u4dw name 3路智能开关面板-V2, SEQ 4. [11-09 15:58:46:997 TUYA D][tuya_ctrl_center_api.c:280] > get brief [5] dev_id 6ce7e76b6dd5ae2cc7gofr name 2路智能开关面板-V2, SEQ 5. [11-09 15:58:46:999 TUYA D][tuya_ctrl_center_api.c:280] > get brief [6] dev_id 6c234dbaf596f2bc18h3be name 网关开关, SEQ 6. [11-09 15:58:47:0 TUYA D][tuya_ctrl_center_api.c:280] > get brief [7] dev_id 6cd3c4e6a2e5a8b893qqni name 1路智能开关, SEQ 7. [11-09 15:58:47:1 TUYA D][tuya_ctrl_center_api.c:280] > get brief [8] dev_id 6cf669ac11164156b6obee name 3路智能开关面板, SEQ 8. [11-09 15:58:47:2 TUYA D][tuya_ctrl_center_api.c:280] > get brief [9] dev_id 6c15cfcf1a96b57237suji name 2路智能开关面板, SEQ 9. [11-09 15:58:47:3 TUYA D][tuya_ctrl_center_api.c:280] > get brief [10] dev_id 6cc30800d40ef47493t6a9 name 1路智能开关面板-V2 11, SEQ 10. [11-09 15:58:47:4 TUYA D][tuya_ctrl_center_api.c:280] > get brief [11] dev_id 6c7662830c8c8544076lcq name 4路智能情景面板-V2, SEQ 11. [11-09 15:58:47:5 TUYA D][tuya_ctrl_center_api.c:280] > get brief [12] dev_id 6cd5fc133a10b9492f2mjr name 4路智能开关面板, SEQ 12. [11-09 15:58:47:6 TUYA D][tuya_ctrl_center_api.c:280] > get brief [13] dev_id 6c87ffeca8ddda70bfkyce name 多功能面板-V2, SEQ 13. [11-09 15:58:47:7 TUYA D][tuya_ctrl_center_api.c:280] > get brief [14] dev_id 6cd4638122441b052e4sxq name 3路智能开关面板 2, SEQ 14. [11-09 15:58:47:8 TUYA D][tuya_ctrl_center_api.c:280] > get brief [15] dev_id 6c5915544f98d4ae7cqsfd name 奥科ZigBee开合帘, SEQ 15. [11-09 15:58:47:9 TUYA D][tuya_ctrl_center_api.c:280] > get brief [16] dev_id 6c99344ae1ee6e93cameee name 地暖控制面板, SEQ 16. [11-09 15:58:47:10 TUYA D][tuya_ctrl_center_api.c:280] > get brief [17] dev_id 6cb5dc73d1285dd5ddiv3h name 新风控制面板, SEQ 17. [11-09 15:58:47:11 TUYA D][tuya_ctrl_center_api.c:280] > get brief [18] dev_id 6ca4e06c90ca9be915zkfk name SMARTLIGHT, SEQ 18. [11-09 15:58:47:12 TUYA D][tuya_ctrl_center_api.c:280] > get brief [19] dev_id 6c2529f04b3e2f53efovgd name 空调控制面板, SEQ 19. [11-09 15:58:47:13 TUYA D][tuya_ctrl_center_api.c:280] > get brief [20] dev_id 6cf6379b475d474da28m3g name 2路智能情景面板, SEQ 20. [11-09 15:58:47:14 TUYA D][tuya_ctrl_center_api.c:280] > get brief [21] dev_id 6c3bf2671c859434dcqwy2 name 2路智能开关面板-V2 2, SEQ 21. [11-09 15:58:47:15 TUYA D][tuya_ctrl_center_api.c:280] > get brief [22] dev_id 6c27a15bd59ee5bdf4upda name ZigBee梦幻帘, SEQ 22. [11-09 15:58:47:16 TUYA D][tuya_ctrl_center_api.c:280] > get brief [23] dev_id 6c4eca7a6857459e05iy4h name 智能窗帘电机Zigbee, SEQ 23. [11-09 15:58:47:17 TUYA D][tuya_ctrl_center_api.c:280] > get brief [24] dev_id 6c8d86100ac2212db3dqj5 name 4路多功能面板, SEQ 24. [11-09 15:58:47:18 TUYA D][tuya_ctrl_center_api.c:280] > get brief [25] dev_id 6c532d9717845ff9f6lmen name Smart, SEQ 25. [11-09 15:58:47:19 TUYA D][tuya_ctrl_center_api.c:301] tuya_get_dev_brief_info_list SUCCESSFULLY: dev cnt 26. hc_show_all [1497] :tuya_get_dev_brief_info_list ret:0 count:26 [11-09 15:58:47:21 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[0] 0x18c42c00. [11-09 15:58:47:22 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:22 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:23 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-vdevo159962420219648, cb 0x7fb75c56e4. [11-09 15:58:47:23 TUYA D][tuya_base_event.c:28] subscribe: dp-vdevo159962420219648 [11-09 15:58:47:24 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-vdevo159962420219648, cb 0x7fb75c6374. [11-09 15:58:47:25 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-vdevo159962420219648 [11-09 15:58:47:26 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id vdevo159962420219648, handle 0x18c42c00, ref_cnt 1. [11-09 15:58:47:27 TUYA D][home_control.c:1434] ============================标准公版空调/vdevo159962420219648/kt============================== [11-09 15:58:47:28 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:28 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch, mode 0, type 0: [11-09 15:58:47:29 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:30 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code temp_set, mode 0, type 1: [11-09 15:58:47:30 TUYA D][tuya_home_ctrl_common_show.c:34] int min:16, max:30, step:1, scale:0, value:0 [11-09 15:58:47:31 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code mode, mode 0, type 3: [11-09 15:58:47:32 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 5 enums: [11-09 15:58:47:32 TUYA D][tuya_home_ctrl_common_show.c:43] auto [11-09 15:58:47:33 TUYA D][tuya_home_ctrl_common_show.c:43] cold [11-09 15:58:47:34 TUYA D][tuya_home_ctrl_common_show.c:43] hot [11-09 15:58:47:34 TUYA D][tuya_home_ctrl_common_show.c:43] wet [11-09 15:58:47:35 TUYA D][tuya_home_ctrl_common_show.c:43] wind [11-09 15:58:47:35 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code fan_speed_enum, mode 0, type 3: [11-09 15:58:47:36 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 5 enums: [11-09 15:58:47:37 TUYA D][tuya_home_ctrl_common_show.c:43] sleep [11-09 15:58:47:37 TUYA D][tuya_home_ctrl_common_show.c:43] strong [11-09 15:58:47:38 TUYA D][tuya_home_ctrl_common_show.c:43] low [11-09 15:58:47:38 TUYA D][tuya_home_ctrl_common_show.c:43] middle [11-09 15:58:47:39 TUYA D][tuya_home_ctrl_common_show.c:43] high [11-09 15:58:47:40 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code windshake, mode 0, type 3: [11-09 15:58:47:40 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:41 TUYA D][tuya_home_ctrl_common_show.c:43] horizontal [11-09 15:58:47:42 TUYA D][tuya_home_ctrl_common_show.c:43] vertical [11-09 15:58:47:42 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code countdown_set, mode 0, type 3: [11-09 15:58:47:43 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 7 enums: [11-09 15:58:47:44 TUYA D][tuya_home_ctrl_common_show.c:43] cancel [11-09 15:58:47:44 TUYA D][tuya_home_ctrl_common_show.c:43] 1h [11-09 15:58:47:45 TUYA D][tuya_home_ctrl_common_show.c:43] 2h [11-09 15:58:47:45 TUYA D][tuya_home_ctrl_common_show.c:43] 3h [11-09 15:58:47:46 TUYA D][tuya_home_ctrl_common_show.c:43] 4h [11-09 15:58:47:46 TUYA D][tuya_home_ctrl_common_show.c:43] 5h [11-09 15:58:47:47 TUYA D][tuya_home_ctrl_common_show.c:43] 6h [11-09 15:58:47:48 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code gear_vertical, mode 0, type 3: [11-09 15:58:47:48 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 6 enums: [11-09 15:58:47:49 TUYA D][tuya_home_ctrl_common_show.c:43] off [11-09 15:58:47:50 TUYA D][tuya_home_ctrl_common_show.c:43] vane_1 [11-09 15:58:47:50 TUYA D][tuya_home_ctrl_common_show.c:43] vane_2 [11-09 15:58:47:51 TUYA D][tuya_home_ctrl_common_show.c:43] vane_3 [11-09 15:58:47:51 TUYA D][tuya_home_ctrl_common_show.c:43] vane_4 [11-09 15:58:47:52 TUYA D][tuya_home_ctrl_common_show.c:43] vane_5 [11-09 15:58:47:53 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code gear_horizontal, mode 0, type 3: [11-09 15:58:47:53 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 6 enums: [11-09 15:58:47:54 TUYA D][tuya_home_ctrl_common_show.c:43] off [11-09 15:58:47:55 TUYA D][tuya_home_ctrl_common_show.c:43] vane_1 [11-09 15:58:47:55 TUYA D][tuya_home_ctrl_common_show.c:43] vane_2 [11-09 15:58:47:56 TUYA D][tuya_home_ctrl_common_show.c:43] vane_3 [11-09 15:58:47:56 TUYA D][tuya_home_ctrl_common_show.c:43] vane_4 [11-09 15:58:47:57 TUYA D][tuya_home_ctrl_common_show.c:43] vane_5 [11-09 15:58:47:57 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code temp_current, mode 2, type 1: [11-09 15:58:47:58 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:55, step:1, scale:0, value:0 [11-09 15:58:47:59 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[1] 0x18c3fc80. [11-09 15:58:47:60 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:60 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:61 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-vdevo159963275037036, cb 0x7fb75c56e4. [11-09 15:58:47:62 TUYA D][tuya_base_event.c:28] subscribe: dp-vdevo159963275037036 [11-09 15:58:47:62 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-vdevo159963275037036, cb 0x7fb75c6374. [11-09 15:58:47:63 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-vdevo159963275037036 [11-09 15:58:47:64 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id vdevo159963275037036, handle 0x18c3fc80, ref_cnt 1. [11-09 15:58:47:65 TUYA D][home_control.c:1434] ============================Zigbee温控器/vdevo159963275037036/wk============================== [11-09 15:58:47:66 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:67 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch, mode 0, type 0: [11-09 15:58:47:67 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:68 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code mode, mode 0, type 3: [11-09 15:58:47:69 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:69 TUYA D][tuya_home_ctrl_common_show.c:43] auto [11-09 15:58:47:70 TUYA D][tuya_home_ctrl_common_show.c:43] manual [11-09 15:58:47:70 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code temp_set, mode 0, type 1: [11-09 15:58:47:71 TUYA D][tuya_home_ctrl_common_show.c:34] int min:11, max:35, step:1, scale:0, value:0 [11-09 15:58:47:72 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code capacity_set, mode 0, type 3: [11-09 15:58:47:73 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 3 enums: [11-09 15:58:47:74 TUYA D][tuya_home_ctrl_common_show.c:43] 2000W [11-09 15:58:47:74 TUYA D][tuya_home_ctrl_common_show.c:43] 3000W [11-09 15:58:47:75 TUYA D][tuya_home_ctrl_common_show.c:43] 5000W [11-09 15:58:47:75 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code countdown, mode 0, type 3: [11-09 15:58:47:76 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 7 enums: [11-09 15:58:47:77 TUYA D][tuya_home_ctrl_common_show.c:43] cancel [11-09 15:58:47:77 TUYA D][tuya_home_ctrl_common_show.c:43] 1h [11-09 15:58:47:78 TUYA D][tuya_home_ctrl_common_show.c:43] 2h [11-09 15:58:47:78 TUYA D][tuya_home_ctrl_common_show.c:43] 3h [11-09 15:58:47:79 TUYA D][tuya_home_ctrl_common_show.c:43] 4h [11-09 15:58:47:79 TUYA D][tuya_home_ctrl_common_show.c:43] 5h [11-09 15:58:47:80 TUYA D][tuya_home_ctrl_common_show.c:43] 6h [11-09 15:58:47:81 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code temp_current, mode 2, type 1: [11-09 15:58:47:81 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:50, step:1, scale:0, value:0 [11-09 15:58:47:82 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[2] 0x18c55c20. [11-09 15:58:47:83 TUYA D][subdev_upgrade_schema.c:389] start schema get subdev. [11-09 15:58:47:83 TUYA D][subdev_upgrade_schema.c:427] end schema get subdev, eAction:1, is_got_new:0. [11-09 15:58:47:84 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:85 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:85 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-vdevo159963120231012, cb 0x7fb75c56e4. [11-09 15:58:47:86 TUYA D][tuya_base_event.c:28] subscribe: dp-vdevo159963120231012 [11-09 15:58:47:87 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-vdevo159963120231012, cb 0x7fb75c6374. [11-09 15:58:47:88 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-vdevo159963120231012 [11-09 15:58:47:89 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id vdevo159963120231012, handle 0x18c55c20, ref_cnt 1. [11-09 15:58:47:90 TUYA D][home_control.c:1434] ============================新风控制面板/vdevo159963120231012/xfj============================== [11-09 15:58:47:91 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:91 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch, mode 0, type 0: [11-09 15:58:47:92 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:93 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code mode, mode 0, type 3: [11-09 15:58:47:93 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:94 TUYA D][tuya_home_ctrl_common_show.c:43] auto [11-09 15:58:47:94 TUYA D][tuya_home_ctrl_common_show.c:43] manual [11-09 15:58:47:95 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code fan_speed_enum, mode 0, type 3: [11-09 15:58:47:96 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 4 enums: [11-09 15:58:47:97 TUYA D][tuya_home_ctrl_common_show.c:43] low [11-09 15:58:47:97 TUYA D][tuya_home_ctrl_common_show.c:43] mid [11-09 15:58:47:98 TUYA D][tuya_home_ctrl_common_show.c:43] high [11-09 15:58:47:98 TUYA D][tuya_home_ctrl_common_show.c:43] sleep [11-09 15:58:47:99 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code filter_reset, mode 0, type 0: [11-09 15:58:47:100 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:100 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code countdown_set, mode 0, type 3: [11-09 15:58:47:101 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 7 enums: [11-09 15:58:47:102 TUYA D][tuya_home_ctrl_common_show.c:43] cancel [11-09 15:58:47:102 TUYA D][tuya_home_ctrl_common_show.c:43] 1h [11-09 15:58:47:103 TUYA D][tuya_home_ctrl_common_show.c:43] 2h [11-09 15:58:47:103 TUYA D][tuya_home_ctrl_common_show.c:43] 3h [11-09 15:58:47:104 TUYA D][tuya_home_ctrl_common_show.c:43] 4h [11-09 15:58:47:104 TUYA D][tuya_home_ctrl_common_show.c:43] 5h [11-09 15:58:47:105 TUYA D][tuya_home_ctrl_common_show.c:43] 6h [11-09 15:58:47:105 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code exhaust_fan_speed, mode 0, type 3: [11-09 15:58:47:106 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 4 enums: [11-09 15:58:47:107 TUYA D][tuya_home_ctrl_common_show.c:43] off [11-09 15:58:47:108 TUYA D][tuya_home_ctrl_common_show.c:43] low [11-09 15:58:47:108 TUYA D][tuya_home_ctrl_common_show.c:43] mid [11-09 15:58:47:109 TUYA D][tuya_home_ctrl_common_show.c:43] high [11-09 15:58:47:109 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code temp_indoor, mode 2, type 1: [11-09 15:58:47:110 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:50, step:1, scale:0, value:0 [11-09 15:58:47:111 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[3] 0x18c62cf0. [11-09 15:58:47:112 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:112 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:113 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-vdevo160307051406239, cb 0x7fb75c56e4. [11-09 15:58:47:114 TUYA D][tuya_base_event.c:28] subscribe: dp-vdevo160307051406239 [11-09 15:58:47:114 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-vdevo160307051406239, cb 0x7fb75c6374. [11-09 15:58:47:115 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-vdevo160307051406239 [11-09 15:58:47:116 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id vdevo160307051406239, handle 0x18c62cf0, ref_cnt 1. [11-09 15:58:47:117 TUYA D][home_control.c:1434] ============================全屋情景复用开关(参考)-vdevo/vdevo160307051406239/cjkg============================== [11-09 15:58:47:118 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:119 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_1, mode 0, type 3: [11-09 15:58:47:119 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:120 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:121 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_2, mode 0, type 3: [11-09 15:58:47:122 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:122 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:123 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_3, mode 0, type 3: [11-09 15:58:47:124 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:124 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:125 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_4, mode 0, type 3: [11-09 15:58:47:126 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:126 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:127 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:128 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:128 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_2, mode 0, type 0: [11-09 15:58:47:129 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:129 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_3, mode 0, type 0: [11-09 15:58:47:130 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:131 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_4, mode 0, type 0: [11-09 15:58:47:131 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:132 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[4] 0x18c63d80. [11-09 15:58:47:133 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 3 [11-09 15:58:47:134 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c4a21a4359ea3d811u4dw, cb 0x7fb75c56e4. [11-09 15:58:47:134 TUYA D][tuya_base_event.c:28] subscribe: dp-6c4a21a4359ea3d811u4dw [11-09 15:58:47:135 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c4a21a4359ea3d811u4dw, cb 0x7fb75c6374. [11-09 15:58:47:136 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c4a21a4359ea3d811u4dw [11-09 15:58:47:137 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c4a21a4359ea3d811u4dw, handle 0x18c63d80, ref_cnt 1. [11-09 15:58:47:138 TUYA D][home_control.c:1434] ============================3路智能开关面板-V2/6c4a21a4359ea3d811u4dw/kg============================== [11-09 15:58:47:139 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 3 hc_show_dev [1438] :!!!!!!!0(3):switch_1/开关 1!!!!!!! hc_show_dev [1438] :!!!!!!!1(3):switch_2/开关 2!!!!!!! hc_show_dev [1438] :!!!!!!!2(3):switch_3/开关 3!!!!!!! [11-09 15:58:47:141 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:142 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:143 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_2, mode 0, type 0: [11-09 15:58:47:143 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:144 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_3, mode 0, type 0: [11-09 15:58:47:145 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:145 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[5] 0x18c63d00. [11-09 15:58:47:146 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 2 [11-09 15:58:47:147 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6ce7e76b6dd5ae2cc7gofr, cb 0x7fb75c56e4. [11-09 15:58:47:148 TUYA D][tuya_base_event.c:28] subscribe: dp-6ce7e76b6dd5ae2cc7gofr [11-09 15:58:47:148 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6ce7e76b6dd5ae2cc7gofr, cb 0x7fb75c6374. [11-09 15:58:47:149 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6ce7e76b6dd5ae2cc7gofr [11-09 15:58:47:150 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6ce7e76b6dd5ae2cc7gofr, handle 0x18c63d00, ref_cnt 1. [11-09 15:58:47:151 TUYA D][home_control.c:1434] ============================2路智能开关面板-V2/6ce7e76b6dd5ae2cc7gofr/kg============================== [11-09 15:58:47:152 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 2 hc_show_dev [1438] :!!!!!!!0(2):switch_1/开关 1!!!!!!! hc_show_dev [1438] :!!!!!!!1(2):switch_2/开关 2!!!!!!! [11-09 15:58:47:154 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:155 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:156 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_2, mode 0, type 0: [11-09 15:58:47:156 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:157 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[6] 0x18c63ce0. [11-09 15:58:47:158 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:158 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:159 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c234dbaf596f2bc18h3be, cb 0x7fb75c56e4. [11-09 15:58:47:160 TUYA D][tuya_base_event.c:28] subscribe: dp-6c234dbaf596f2bc18h3be [11-09 15:58:47:160 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c234dbaf596f2bc18h3be, cb 0x7fb75c6374. [11-09 15:58:47:161 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c234dbaf596f2bc18h3be [11-09 15:58:47:162 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c234dbaf596f2bc18h3be, handle 0x18c63ce0, ref_cnt 1. [11-09 15:58:47:163 TUYA D][home_control.c:1434] ============================网关开关/6c234dbaf596f2bc18h3be/kg============================== [11-09 15:58:47:164 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:165 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:165 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:166 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[7] 0x18c63d20. [11-09 15:58:47:167 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:167 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:168 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6cd3c4e6a2e5a8b893qqni, cb 0x7fb75c56e4. [11-09 15:58:47:169 TUYA D][tuya_base_event.c:28] subscribe: dp-6cd3c4e6a2e5a8b893qqni [11-09 15:58:47:169 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6cd3c4e6a2e5a8b893qqni, cb 0x7fb75c6374. [11-09 15:58:47:170 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6cd3c4e6a2e5a8b893qqni [11-09 15:58:47:171 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6cd3c4e6a2e5a8b893qqni, handle 0x18c63d20, ref_cnt 1. [11-09 15:58:47:172 TUYA D][home_control.c:1434] ============================1路智能开关/6cd3c4e6a2e5a8b893qqni/kg============================== [11-09 15:58:47:173 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:174 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:175 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:175 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[8] 0x18c63c80. [11-09 15:58:47:176 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 3 [11-09 15:58:47:177 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6cf669ac11164156b6obee, cb 0x7fb75c56e4. [11-09 15:58:47:178 TUYA D][tuya_base_event.c:28] subscribe: dp-6cf669ac11164156b6obee [11-09 15:58:47:178 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6cf669ac11164156b6obee, cb 0x7fb75c6374. [11-09 15:58:47:179 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6cf669ac11164156b6obee [11-09 15:58:47:180 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6cf669ac11164156b6obee, handle 0x18c63c80, ref_cnt 1. [11-09 15:58:47:181 TUYA D][home_control.c:1434] ============================3路智能开关面板/6cf669ac11164156b6obee/kg============================== [11-09 15:58:47:182 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 3 hc_show_dev [1438] :!!!!!!!0(3):switch_1/开关 1!!!!!!! hc_show_dev [1438] :!!!!!!!1(3):switch_2/开关 2!!!!!!! hc_show_dev [1438] :!!!!!!!2(3):switch_3/开关 3!!!!!!! [11-09 15:58:47:185 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:185 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:186 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_2, mode 0, type 0: [11-09 15:58:47:187 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:187 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_3, mode 0, type 0: [11-09 15:58:47:188 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:188 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[9] 0x18c63c00. [11-09 15:58:47:189 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 2 [11-09 15:58:47:190 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c15cfcf1a96b57237suji, cb 0x7fb75c56e4. [11-09 15:58:47:191 TUYA D][tuya_base_event.c:28] subscribe: dp-6c15cfcf1a96b57237suji [11-09 15:58:47:192 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c15cfcf1a96b57237suji, cb 0x7fb75c6374. [11-09 15:58:47:193 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c15cfcf1a96b57237suji [11-09 15:58:47:193 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c15cfcf1a96b57237suji, handle 0x18c63c00, ref_cnt 1. [11-09 15:58:47:194 TUYA D][home_control.c:1434] ============================2路智能开关面板/6c15cfcf1a96b57237suji/kg============================== [11-09 15:58:47:196 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 2 hc_show_dev [1438] :!!!!!!!0(2):switch_1/开关 1!!!!!!! hc_show_dev [1438] :!!!!!!!1(2):switch_2/开关 2!!!!!!! [11-09 15:58:47:197 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:198 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:199 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_2, mode 0, type 0: [11-09 15:58:47:199 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:200 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[10] 0x18c63be0. [11-09 15:58:47:201 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:201 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:202 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6cc30800d40ef47493t6a9, cb 0x7fb75c56e4. [11-09 15:58:47:203 TUYA D][tuya_base_event.c:28] subscribe: dp-6cc30800d40ef47493t6a9 [11-09 15:58:47:203 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6cc30800d40ef47493t6a9, cb 0x7fb75c6374. [11-09 15:58:47:204 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6cc30800d40ef47493t6a9 [11-09 15:58:47:205 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6cc30800d40ef47493t6a9, handle 0x18c63be0, ref_cnt 1. [11-09 15:58:47:206 TUYA D][home_control.c:1434] ============================1路智能开关面板-V2 11/6cc30800d40ef47493t6a9/kg============================== [11-09 15:58:47:207 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:208 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:209 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:209 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[11] 0x18c63c20. [11-09 15:58:47:210 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:210 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:211 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c7662830c8c8544076lcq, cb 0x7fb75c56e4. [11-09 15:58:47:212 TUYA D][tuya_base_event.c:28] subscribe: dp-6c7662830c8c8544076lcq [11-09 15:58:47:213 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c7662830c8c8544076lcq, cb 0x7fb75c6374. [11-09 15:58:47:214 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c7662830c8c8544076lcq [11-09 15:58:47:214 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c7662830c8c8544076lcq, handle 0x18c63c20, ref_cnt 1. [11-09 15:58:47:215 TUYA D][home_control.c:1434] ============================4路智能情景面板-V2/6c7662830c8c8544076lcq/cjkg============================== [11-09 15:58:47:217 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:217 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_1, mode 0, type 3: [11-09 15:58:47:218 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:219 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:219 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_2, mode 0, type 3: [11-09 15:58:47:220 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:221 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:221 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_3, mode 0, type 3: [11-09 15:58:47:222 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:223 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:223 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_4, mode 0, type 3: [11-09 15:58:47:224 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:225 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:225 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[12] 0x18c66960. [11-09 15:58:47:226 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 4 [11-09 15:58:47:227 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6cd5fc133a10b9492f2mjr, cb 0x7fb75c56e4. [11-09 15:58:47:228 TUYA D][tuya_base_event.c:28] subscribe: dp-6cd5fc133a10b9492f2mjr [11-09 15:58:47:228 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6cd5fc133a10b9492f2mjr, cb 0x7fb75c6374. [11-09 15:58:47:229 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6cd5fc133a10b9492f2mjr [11-09 15:58:47:230 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6cd5fc133a10b9492f2mjr, handle 0x18c66960, ref_cnt 1. [11-09 15:58:47:231 TUYA D][home_control.c:1434] ============================4路智能开关面板/6cd5fc133a10b9492f2mjr/kg============================== [11-09 15:58:47:232 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 4 hc_show_dev [1438] :!!!!!!!0(4):switch_1/开关 1!!!!!!! hc_show_dev [1438] :!!!!!!!1(4):switch_2/开关 2!!!!!!! hc_show_dev [1438] :!!!!!!!2(4):switch_3/开关 3!!!!!!! hc_show_dev [1438] :!!!!!!!3(4):switch_4/开关 4!!!!!!! [11-09 15:58:47:235 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:236 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:237 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_2, mode 0, type 0: [11-09 15:58:47:237 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:238 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_3, mode 0, type 0: [11-09 15:58:47:239 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:239 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_4, mode 0, type 0: [11-09 15:58:47:240 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:240 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[13] 0x18c66980. [11-09 15:58:47:241 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 2 [11-09 15:58:47:242 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c87ffeca8ddda70bfkyce, cb 0x7fb75c56e4. [11-09 15:58:47:243 TUYA D][tuya_base_event.c:28] subscribe: dp-6c87ffeca8ddda70bfkyce [11-09 15:58:47:244 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c87ffeca8ddda70bfkyce, cb 0x7fb75c6374. [11-09 15:58:47:245 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c87ffeca8ddda70bfkyce [11-09 15:58:47:245 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c87ffeca8ddda70bfkyce, handle 0x18c66980, ref_cnt 1. [11-09 15:58:47:246 TUYA D][home_control.c:1434] ============================多功能面板-V2/6c87ffeca8ddda70bfkyce/cjkg============================== [11-09 15:58:47:247 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 2 hc_show_dev [1438] :!!!!!!!0(2):switch_2/开关2!!!!!!! hc_show_dev [1438] :!!!!!!!1(2):switch_3/开关3!!!!!!! [11-09 15:58:47:249 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_1, mode 0, type 3: [11-09 15:58:47:250 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:251 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:251 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_2, mode 0, type 3: [11-09 15:58:47:252 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:253 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:253 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_3, mode 0, type 3: [11-09 15:58:47:254 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:255 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:255 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_4, mode 0, type 3: [11-09 15:58:47:256 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:257 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:257 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:258 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:259 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_2, mode 0, type 0: [11-09 15:58:47:259 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:260 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_3, mode 0, type 0: [11-09 15:58:47:261 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:261 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_4, mode 0, type 0: [11-09 15:58:47:262 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:262 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[14] 0x18c67d10. [11-09 15:58:47:263 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 3 [11-09 15:58:47:264 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6cd4638122441b052e4sxq, cb 0x7fb75c56e4. [11-09 15:58:47:265 TUYA D][tuya_base_event.c:28] subscribe: dp-6cd4638122441b052e4sxq [11-09 15:58:47:266 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6cd4638122441b052e4sxq, cb 0x7fb75c6374. [11-09 15:58:47:267 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6cd4638122441b052e4sxq [11-09 15:58:47:267 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6cd4638122441b052e4sxq, handle 0x18c67d10, ref_cnt 1. [11-09 15:58:47:268 TUYA D][home_control.c:1434] ============================3路智能开关面板 2/6cd4638122441b052e4sxq/kg============================== [11-09 15:58:47:270 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 3 hc_show_dev [1438] :!!!!!!!0(3):switch_1/开关 1!!!!!!! hc_show_dev [1438] :!!!!!!!1(3):switch_2/开关 2!!!!!!! hc_show_dev [1438] :!!!!!!!2(3):switch_3/开关 3!!!!!!! [11-09 15:58:47:272 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:273 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:273 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_2, mode 0, type 0: [11-09 15:58:47:274 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:275 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_3, mode 0, type 0: [11-09 15:58:47:275 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:276 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[15] 0x18c67d30. [11-09 15:58:47:277 TUYA E][tuya_ctrl_center_api.c:96] strategy convert error: -6 [11-09 15:58:47:277 TUYA W][tuya_home_ctrl_dev.c:306] dp type 10 not matched, do nothing. [11-09 15:58:47:278 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:278 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:279 TUYA E][tuya_ctrl_center_api.c:977] unknown type:10 [11-09 15:58:47:279 TUYA W][tuya_ctrl_center_api.c:1032] dev_id:6c5915544f98d4ae7cqsfd dp_id: 10 prop_tp:10 mode:2 get value err [11-09 15:58:47:280 TUYA W][tuya_home_ctrl_dev.c:594] custom dp type 10 not matched, do nothing. [11-09 15:58:47:281 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c5915544f98d4ae7cqsfd, cb 0x7fb75c56e4. [11-09 15:58:47:282 TUYA D][tuya_base_event.c:28] subscribe: dp-6c5915544f98d4ae7cqsfd [11-09 15:58:47:283 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c5915544f98d4ae7cqsfd, cb 0x7fb75c6374. [11-09 15:58:47:284 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c5915544f98d4ae7cqsfd [11-09 15:58:47:285 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c5915544f98d4ae7cqsfd, handle 0x18c67d30, ref_cnt 1. [11-09 15:58:47:286 TUYA D][home_control.c:1434] ============================奥科ZigBee开合帘/6c5915544f98d4ae7cqsfd/cl============================== [11-09 15:58:47:287 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:287 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code control_back, mode 0, type 0: [11-09 15:58:47:288 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:289 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code control, mode 1, type 3: [11-09 15:58:47:289 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 3 enums: [11-09 15:58:47:290 TUYA D][tuya_home_ctrl_common_show.c:43] open [11-09 15:58:47:291 TUYA D][tuya_home_ctrl_common_show.c:43] stop [11-09 15:58:47:291 TUYA D][tuya_home_ctrl_common_show.c:43] close [11-09 15:58:47:292 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code percent_control, mode 0, type 1: [11-09 15:58:47:293 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:100, step:1, scale:0, value:0 [11-09 15:58:47:293 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code control_back, mode 1, type 0: [11-09 15:58:47:294 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:295 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code percent_state, mode 2, type 1: [11-09 15:58:47:295 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:100, step:1, scale:0, value:0 [11-09 15:58:47:296 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code time_total, mode 2, type 1: [11-09 15:58:47:297 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:120000, step:1, scale:0, value:0 [11-09 15:58:47:298 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code fault, mode 2, type 10: [11-09 15:58:47:299 TUYA E][tuya_home_ctrl_dev.c:2107] do not support show value, dp_type:10 [11-09 15:58:47:299 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[16] 0x18c693b0. [11-09 15:58:47:300 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:301 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:301 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c99344ae1ee6e93cameee, cb 0x7fb75c56e4. [11-09 15:58:47:302 TUYA D][tuya_base_event.c:28] subscribe: dp-6c99344ae1ee6e93cameee [11-09 15:58:47:303 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c99344ae1ee6e93cameee, cb 0x7fb75c6374. [11-09 15:58:47:304 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c99344ae1ee6e93cameee [11-09 15:58:47:304 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c99344ae1ee6e93cameee, handle 0x18c693b0, ref_cnt 1. [11-09 15:58:47:306 TUYA D][home_control.c:1434] ============================地暖控制面板/6c99344ae1ee6e93cameee/wk============================== [11-09 15:58:47:307 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:307 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch, mode 0, type 0: [11-09 15:58:47:308 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:308 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code mode, mode 0, type 3: [11-09 15:58:47:309 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:310 TUYA D][tuya_home_ctrl_common_show.c:43] auto [11-09 15:58:47:310 TUYA D][tuya_home_ctrl_common_show.c:43] manual [11-09 15:58:47:311 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code temp_set, mode 0, type 1: [11-09 15:58:47:312 TUYA D][tuya_home_ctrl_common_show.c:34] int min:11, max:35, step:1, scale:0, value:0 [11-09 15:58:47:313 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code countdown, mode 0, type 3: [11-09 15:58:47:313 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 25 enums: [11-09 15:58:47:314 TUYA D][tuya_home_ctrl_common_show.c:43] cancel [11-09 15:58:47:315 TUYA D][tuya_home_ctrl_common_show.c:43] 1h [11-09 15:58:47:315 TUYA D][tuya_home_ctrl_common_show.c:43] 2h [11-09 15:58:47:316 TUYA D][tuya_home_ctrl_common_show.c:43] 3h [11-09 15:58:47:316 TUYA D][tuya_home_ctrl_common_show.c:43] 4h [11-09 15:58:47:317 TUYA D][tuya_home_ctrl_common_show.c:43] 5h [11-09 15:58:47:317 TUYA D][tuya_home_ctrl_common_show.c:43] 6h [11-09 15:58:47:318 TUYA D][tuya_home_ctrl_common_show.c:43] 7h [11-09 15:58:47:319 TUYA D][tuya_home_ctrl_common_show.c:43] 8h [11-09 15:58:47:319 TUYA D][tuya_home_ctrl_common_show.c:43] 9h [11-09 15:58:47:320 TUYA D][tuya_home_ctrl_common_show.c:43] 10h [11-09 15:58:47:320 TUYA D][tuya_home_ctrl_common_show.c:43] 11h [11-09 15:58:47:321 TUYA D][tuya_home_ctrl_common_show.c:43] 12h [11-09 15:58:47:321 TUYA D][tuya_home_ctrl_common_show.c:43] 13h [11-09 15:58:47:322 TUYA D][tuya_home_ctrl_common_show.c:43] 14h [11-09 15:58:47:322 TUYA D][tuya_home_ctrl_common_show.c:43] 15h [11-09 15:58:47:323 TUYA D][tuya_home_ctrl_common_show.c:43] 16h [11-09 15:58:47:324 TUYA D][tuya_home_ctrl_common_show.c:43] 17h [11-09 15:58:47:324 TUYA D][tuya_home_ctrl_common_show.c:43] 18h [11-09 15:58:47:325 TUYA D][tuya_home_ctrl_common_show.c:43] 19h [11-09 15:58:47:325 TUYA D][tuya_home_ctrl_common_show.c:43] 20h [11-09 15:58:47:326 TUYA D][tuya_home_ctrl_common_show.c:43] 21h [11-09 15:58:47:326 TUYA D][tuya_home_ctrl_common_show.c:43] 22h [11-09 15:58:47:327 TUYA D][tuya_home_ctrl_common_show.c:43] 23h [11-09 15:58:47:328 TUYA D][tuya_home_ctrl_common_show.c:43] 24h [11-09 15:58:47:328 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code temp_current, mode 2, type 1: [11-09 15:58:47:329 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:50, step:1, scale:0, value:0 [11-09 15:58:47:330 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[17] 0x18c6a900. [11-09 15:58:47:331 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:331 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:332 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6cb5dc73d1285dd5ddiv3h, cb 0x7fb75c56e4. [11-09 15:58:47:332 TUYA D][tuya_base_event.c:28] subscribe: dp-6cb5dc73d1285dd5ddiv3h [11-09 15:58:47:333 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6cb5dc73d1285dd5ddiv3h, cb 0x7fb75c6374. [11-09 15:58:47:334 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6cb5dc73d1285dd5ddiv3h [11-09 15:58:47:335 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6cb5dc73d1285dd5ddiv3h, handle 0x18c6a900, ref_cnt 1. [11-09 15:58:47:336 TUYA D][home_control.c:1434] ============================新风控制面板/6cb5dc73d1285dd5ddiv3h/xfj============================== [11-09 15:58:47:337 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:338 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch, mode 0, type 0: [11-09 15:58:47:338 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:339 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code countdown_set, mode 0, type 3: [11-09 15:58:47:340 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 7 enums: [11-09 15:58:47:340 TUYA D][tuya_home_ctrl_common_show.c:43] cancel [11-09 15:58:47:341 TUYA D][tuya_home_ctrl_common_show.c:43] 1h [11-09 15:58:47:341 TUYA D][tuya_home_ctrl_common_show.c:43] 2h [11-09 15:58:47:342 TUYA D][tuya_home_ctrl_common_show.c:43] 3h [11-09 15:58:47:343 TUYA D][tuya_home_ctrl_common_show.c:43] 4h [11-09 15:58:47:343 TUYA D][tuya_home_ctrl_common_show.c:43] 5h [11-09 15:58:47:344 TUYA D][tuya_home_ctrl_common_show.c:43] 6h [11-09 15:58:47:344 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code exhaust_fan_speed, mode 0, type 3: [11-09 15:58:47:345 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 4 enums: [11-09 15:58:47:346 TUYA D][tuya_home_ctrl_common_show.c:43] off [11-09 15:58:47:346 TUYA D][tuya_home_ctrl_common_show.c:43] low [11-09 15:58:47:347 TUYA D][tuya_home_ctrl_common_show.c:43] mid [11-09 15:58:47:347 TUYA D][tuya_home_ctrl_common_show.c:43] high [11-09 15:58:47:348 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[18] 0x18c6b740. [11-09 15:58:47:349 TUYA E][tuya_ctrl_center_api.c:78] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:349 TUYA E][tuya_ctrl_center_api.c:78] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:350 TUYA E][tuya_ctrl_center_api.c:78] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:351 TUYA E][tuya_ctrl_center_api.c:78] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:352 TUYA E][tuya_ctrl_center_api.c:78] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:353 TUYA E][tuya_ctrl_center_api.c:78] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:353 TUYA D][dpcode_strategy.c:56] str: len:0 [11-09 15:58:47:354 TUYA D][dpcode_strategy.c:59] strlen:0 is wrong [11-09 15:58:47:354 TUYA W][tuya_std_dp_light_transform.c:197] light scene mode : is not found [11-09 15:58:47:355 TUYA W][tuya_home_ctrl_light_dp.c:188] light_dp_generate_scene_mode is not found [11-09 15:58:47:356 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:357 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:357 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:358 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:359 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:360 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:360 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:361 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:362 TUYA E][tuya_ctrl_center_api.c:977] unknown type:10 [11-09 15:58:47:362 TUYA W][tuya_ctrl_center_api.c:1032] dev_id:6ca4e06c90ca9be915zkfk dp_id: 30 prop_tp:10 mode:0 get value err [11-09 15:58:47:363 TUYA E][tuya_ctrl_center_api.c:977] unknown type:10 [11-09 15:58:47:364 TUYA W][tuya_ctrl_center_api.c:1032] dev_id:6ca4e06c90ca9be915zkfk dp_id: 31 prop_tp:10 mode:0 get value err [11-09 15:58:47:365 TUYA E][tuya_ctrl_center_api.c:977] unknown type:10 [11-09 15:58:47:365 TUYA W][tuya_ctrl_center_api.c:1032] dev_id:6ca4e06c90ca9be915zkfk dp_id: 32 prop_tp:10 mode:0 get value err [11-09 15:58:47:366 TUYA E][tuya_ctrl_center_api.c:977] unknown type:10 [11-09 15:58:47:367 TUYA W][tuya_ctrl_center_api.c:1032] dev_id:6ca4e06c90ca9be915zkfk dp_id: 33 prop_tp:10 mode:0 get value err [11-09 15:58:47:368 TUYA E][tuya_ctrl_center_api.c:977] unknown type:10 [11-09 15:58:47:368 TUYA W][tuya_ctrl_center_api.c:1032] dev_id:6ca4e06c90ca9be915zkfk dp_id: 35 prop_tp:10 mode:0 get value err [11-09 15:58:47:369 TUYA E][tuya_ctrl_center_api.c:977] unknown type:10 [11-09 15:58:47:370 TUYA W][tuya_ctrl_center_api.c:1032] dev_id:6ca4e06c90ca9be915zkfk dp_id: 209 prop_tp:10 mode:0 get value err [11-09 15:58:47:371 TUYA E][tuya_ctrl_center_api.c:977] unknown type:10 [11-09 15:58:47:371 TUYA W][tuya_ctrl_center_api.c:1032] dev_id:6ca4e06c90ca9be915zkfk dp_id: 210 prop_tp:10 mode:0 get value err [11-09 15:58:47:372 TUYA W][tuya_home_ctrl_dev.c:594] custom dp type 10 not matched, do nothing. [11-09 15:58:47:373 TUYA W][tuya_home_ctrl_dev.c:594] custom dp type 10 not matched, do nothing. [11-09 15:58:47:374 TUYA W][tuya_home_ctrl_dev.c:594] custom dp type 10 not matched, do nothing. [11-09 15:58:47:374 TUYA W][tuya_home_ctrl_dev.c:594] custom dp type 10 not matched, do nothing. [11-09 15:58:47:375 TUYA W][tuya_home_ctrl_dev.c:594] custom dp type 10 not matched, do nothing. [11-09 15:58:47:376 TUYA W][tuya_home_ctrl_dev.c:594] custom dp type 10 not matched, do nothing. [11-09 15:58:47:377 TUYA W][tuya_home_ctrl_dev.c:594] custom dp type 10 not matched, do nothing. [11-09 15:58:47:378 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6ca4e06c90ca9be915zkfk, cb 0x7fb75c56e4. [11-09 15:58:47:378 TUYA D][tuya_base_event.c:28] subscribe: dp-6ca4e06c90ca9be915zkfk [11-09 15:58:47:379 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6ca4e06c90ca9be915zkfk, cb 0x7fb75c6374. [11-09 15:58:47:380 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6ca4e06c90ca9be915zkfk [11-09 15:58:47:381 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6ca4e06c90ca9be915zkfk, handle 0x18c6b740, ref_cnt 1. [11-09 15:58:47:382 TUYA D][home_control.c:1434] ============================SMARTLIGHT/6ca4e06c90ca9be915zkfk/dj============================== [11-09 15:58:47:383 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:384 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:385 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:385 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:386 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:387 TUYA E][tuya_ctrl_center_api.c:811] id:6ca4e06c90ca9be915zkfk not find dev dp: 0 [11-09 15:58:47:388 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:388 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_led, mode 0, type 0: [11-09 15:58:47:389 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:390 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code work_mode, mode 0, type 3: [11-09 15:58:47:390 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 4 enums: [11-09 15:58:47:391 TUYA D][tuya_home_ctrl_common_show.c:43] white [11-09 15:58:47:392 TUYA D][tuya_home_ctrl_common_show.c:43] colour [11-09 15:58:47:392 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:393 TUYA D][tuya_home_ctrl_common_show.c:43] music [11-09 15:58:47:393 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code home_ctrl_light_bright, mode 0, type 1: [11-09 15:58:47:394 TUYA D][tuya_home_ctrl_common_show.c:34] int min:1, max:100, step:1, scale:0, value:0 [11-09 15:58:47:395 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code home_ctrl_light_temp, mode 0, type 1: [11-09 15:58:47:396 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:100, step:1, scale:0, value:1 [11-09 15:58:47:397 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code home_ctrl_light_colour, mode 0, type 101: [11-09 15:58:47:397 TUYA D][tuya_home_ctrl_light_dp.c:404] color:h:0,s:0,v:100 [11-09 15:58:47:398 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code home_ctrl_light_scene, mode 0, type 102: [11-09 15:58:47:399 TUYA D][tuya_home_ctrl_light_dp.c:425] scene:0 [11-09 15:58:47:399 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code countdown_1, mode 0, type 1: [11-09 15:58:47:400 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:86400, step:1, scale:0, value:0 [11-09 15:58:47:401 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code music_data, mode 0, type 2: [11-09 15:58:47:402 TUYA D][tuya_home_ctrl_common_show.c:37] str: [11-09 15:58:47:402 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code control_data, mode 0, type 2: [11-09 15:58:47:403 TUYA D][tuya_home_ctrl_common_show.c:37] str: [11-09 15:58:47:404 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code , mode 0, type 0: [11-09 15:58:47:404 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:405 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code , mode 0, type 0: [11-09 15:58:47:406 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:406 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code , mode 0, type 0: [11-09 15:58:47:407 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:407 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code , mode 0, type 0: [11-09 15:58:47:408 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:408 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code , mode 0, type 0: [11-09 15:58:47:409 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:410 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code , mode 0, type 0: [11-09 15:58:47:410 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:411 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[19] 0x18c6c930. [11-09 15:58:47:412 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:412 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:413 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c2529f04b3e2f53efovgd, cb 0x7fb75c56e4. [11-09 15:58:47:414 TUYA D][tuya_base_event.c:28] subscribe: dp-6c2529f04b3e2f53efovgd [11-09 15:58:47:414 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c2529f04b3e2f53efovgd, cb 0x7fb75c6374. [11-09 15:58:47:415 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c2529f04b3e2f53efovgd [11-09 15:58:47:416 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c2529f04b3e2f53efovgd, handle 0x18c6c930, ref_cnt 1. [11-09 15:58:47:417 TUYA D][home_control.c:1434] ============================空调控制面板/6c2529f04b3e2f53efovgd/kt============================== [11-09 15:58:47:418 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:419 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch, mode 0, type 0: [11-09 15:58:47:420 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:420 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code temp_set, mode 0, type 1: [11-09 15:58:47:421 TUYA D][tuya_home_ctrl_common_show.c:34] int min:16, max:30, step:1, scale:0, value:0 [11-09 15:58:47:422 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code mode, mode 0, type 3: [11-09 15:58:47:422 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 5 enums: [11-09 15:58:47:423 TUYA D][tuya_home_ctrl_common_show.c:43] auto [11-09 15:58:47:424 TUYA D][tuya_home_ctrl_common_show.c:43] cold [11-09 15:58:47:424 TUYA D][tuya_home_ctrl_common_show.c:43] hot [11-09 15:58:47:425 TUYA D][tuya_home_ctrl_common_show.c:43] wet [11-09 15:58:47:425 TUYA D][tuya_home_ctrl_common_show.c:43] wind [11-09 15:58:47:426 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code fan_speed_enum, mode 0, type 3: [11-09 15:58:47:427 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 4 enums: [11-09 15:58:47:427 TUYA D][tuya_home_ctrl_common_show.c:43] auto [11-09 15:58:47:428 TUYA D][tuya_home_ctrl_common_show.c:43] low [11-09 15:58:47:429 TUYA D][tuya_home_ctrl_common_show.c:43] middle [11-09 15:58:47:429 TUYA D][tuya_home_ctrl_common_show.c:43] high [11-09 15:58:47:430 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code countdown_set, mode 0, type 3: [11-09 15:58:47:430 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 7 enums: [11-09 15:58:47:431 TUYA D][tuya_home_ctrl_common_show.c:43] cancel [11-09 15:58:47:432 TUYA D][tuya_home_ctrl_common_show.c:43] 1h [11-09 15:58:47:432 TUYA D][tuya_home_ctrl_common_show.c:43] 2h [11-09 15:58:47:433 TUYA D][tuya_home_ctrl_common_show.c:43] 3h [11-09 15:58:47:433 TUYA D][tuya_home_ctrl_common_show.c:43] 4h [11-09 15:58:47:434 TUYA D][tuya_home_ctrl_common_show.c:43] 5h [11-09 15:58:47:435 TUYA D][tuya_home_ctrl_common_show.c:43] 6h [11-09 15:58:47:435 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[20] 0x18c6e180. [11-09 15:58:47:436 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:436 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:437 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6cf6379b475d474da28m3g, cb 0x7fb75c56e4. [11-09 15:58:47:438 TUYA D][tuya_base_event.c:28] subscribe: dp-6cf6379b475d474da28m3g [11-09 15:58:47:438 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6cf6379b475d474da28m3g, cb 0x7fb75c6374. [11-09 15:58:47:440 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6cf6379b475d474da28m3g [11-09 15:58:47:440 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6cf6379b475d474da28m3g, handle 0x18c6e180, ref_cnt 1. [11-09 15:58:47:441 TUYA D][home_control.c:1434] ============================2路智能情景面板/6cf6379b475d474da28m3g/cjkg============================== [11-09 15:58:47:442 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:443 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_1, mode 0, type 3: [11-09 15:58:47:444 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:444 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:445 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_2, mode 0, type 3: [11-09 15:58:47:446 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:447 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:447 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[21] 0x18c6dc00. [11-09 15:58:47:448 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 2 [11-09 15:58:47:449 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c3bf2671c859434dcqwy2, cb 0x7fb75c56e4. [11-09 15:58:47:450 TUYA D][tuya_base_event.c:28] subscribe: dp-6c3bf2671c859434dcqwy2 [11-09 15:58:47:450 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c3bf2671c859434dcqwy2 [11-09 15:58:47:451 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c3bf2671c859434dcqwy2, cb 0x7fb75c6374. [11-09 15:58:47:452 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c3bf2671c859434dcqwy2, handle 0x18c6dc00, ref_cnt 1. [11-09 15:58:47:453 TUYA D][home_control.c:1434] ============================2路智能开关面板-V2 2/6c3bf2671c859434dcqwy2/kg============================== [11-09 15:58:47:454 TUYA D][tuya_ctrl_center_api.c:837] tuya_get_dev_dp_name_list success, dev cnt is 2 hc_show_dev [1438] :!!!!!!!0(2):switch_1/开关 1!!!!!!! hc_show_dev [1438] :!!!!!!!1(2):switch_2/开关 2!!!!!!! [11-09 15:58:47:456 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:457 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:457 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_2, mode 0, type 0: [11-09 15:58:47:458 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:459 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[22] 0x18c6e110. [11-09 15:58:47:459 TUYA E][tuya_ctrl_center_api.c:96] strategy convert error: -6 [11-09 15:58:47:460 TUYA W][tuya_home_ctrl_dev.c:306] dp type 10 not matched, do nothing. [11-09 15:58:47:461 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:461 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:462 TUYA E][tuya_ctrl_center_api.c:977] unknown type:10 [11-09 15:58:47:462 TUYA W][tuya_ctrl_center_api.c:1032] dev_id:6c27a15bd59ee5bdf4upda dp_id: 12 prop_tp:10 mode:2 get value err [11-09 15:58:47:463 TUYA W][tuya_home_ctrl_dev.c:594] custom dp type 10 not matched, do nothing. [11-09 15:58:47:464 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c27a15bd59ee5bdf4upda, cb 0x7fb75c56e4. [11-09 15:58:47:465 TUYA D][tuya_base_event.c:28] subscribe: dp-6c27a15bd59ee5bdf4upda [11-09 15:58:47:466 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c27a15bd59ee5bdf4upda, cb 0x7fb75c6374. [11-09 15:58:47:467 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c27a15bd59ee5bdf4upda [11-09 15:58:47:467 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c27a15bd59ee5bdf4upda, handle 0x18c6e110, ref_cnt 1. [11-09 15:58:47:468 TUYA D][home_control.c:1434] ============================ZigBee梦幻帘/6c27a15bd59ee5bdf4upda/cl============================== [11-09 15:58:47:470 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:470 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code control, mode 0, type 3: [11-09 15:58:47:471 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 4 enums: [11-09 15:58:47:472 TUYA D][tuya_home_ctrl_common_show.c:43] open [11-09 15:58:47:472 TUYA D][tuya_home_ctrl_common_show.c:43] stop [11-09 15:58:47:473 TUYA D][tuya_home_ctrl_common_show.c:43] close [11-09 15:58:47:473 TUYA D][tuya_home_ctrl_common_show.c:43] continue [11-09 15:58:47:474 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code percent_control, mode 0, type 1: [11-09 15:58:47:475 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:100, step:1, scale:0, value:0 [11-09 15:58:47:475 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code control_back_mode, mode 0, type 3: [11-09 15:58:47:476 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:477 TUYA D][tuya_home_ctrl_common_show.c:43] forward [11-09 15:58:47:478 TUYA D][tuya_home_ctrl_common_show.c:43] back [11-09 15:58:47:478 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code angle_horizontal, mode 0, type 1: [11-09 15:58:47:479 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:100, step:1, scale:0, value:0 [11-09 15:58:47:480 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code percent_state, mode 2, type 1: [11-09 15:58:47:481 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:100, step:1, scale:0, value:0 [11-09 15:58:47:481 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code fault, mode 2, type 10: [11-09 15:58:47:482 TUYA E][tuya_home_ctrl_dev.c:2107] do not support show value, dp_type:10 [11-09 15:58:47:483 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[23] 0x18c6ee70. [11-09 15:58:47:484 TUYA E][tuya_ctrl_center_api.c:96] strategy convert error: -6 [11-09 15:58:47:484 TUYA W][tuya_home_ctrl_dev.c:306] dp type 10 not matched, do nothing. [11-09 15:58:47:485 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:485 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:486 TUYA E][tuya_ctrl_center_api.c:977] unknown type:10 [11-09 15:58:47:486 TUYA W][tuya_ctrl_center_api.c:1032] dev_id:6c4eca7a6857459e05iy4h dp_id: 12 prop_tp:10 mode:2 get value err [11-09 15:58:47:487 TUYA W][tuya_home_ctrl_dev.c:594] custom dp type 10 not matched, do nothing. [11-09 15:58:47:488 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c4eca7a6857459e05iy4h, cb 0x7fb75c56e4. [11-09 15:58:47:489 TUYA D][tuya_base_event.c:28] subscribe: dp-6c4eca7a6857459e05iy4h [11-09 15:58:47:490 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c4eca7a6857459e05iy4h [11-09 15:58:47:491 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c4eca7a6857459e05iy4h, cb 0x7fb75c6374. [11-09 15:58:47:492 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c4eca7a6857459e05iy4h, handle 0x18c6ee70, ref_cnt 1. [11-09 15:58:47:493 TUYA D][home_control.c:1434] ============================智能窗帘电机Zigbee/6c4eca7a6857459e05iy4h/cl============================== [11-09 15:58:47:494 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:494 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code control, mode 0, type 3: [11-09 15:58:47:495 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 3 enums: [11-09 15:58:47:496 TUYA D][tuya_home_ctrl_common_show.c:43] open [11-09 15:58:47:496 TUYA D][tuya_home_ctrl_common_show.c:43] stop [11-09 15:58:47:497 TUYA D][tuya_home_ctrl_common_show.c:43] close [11-09 15:58:47:498 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code percent_control, mode 0, type 1: [11-09 15:58:47:498 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:100, step:1, scale:0, value:0 [11-09 15:58:47:499 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code control_back_mode, mode 0, type 3: [11-09 15:58:47:500 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:501 TUYA D][tuya_home_ctrl_common_show.c:43] forward [11-09 15:58:47:501 TUYA D][tuya_home_ctrl_common_show.c:43] back [11-09 15:58:47:502 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code percent_state, mode 2, type 1: [11-09 15:58:47:503 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:100, step:1, scale:0, value:0 [11-09 15:58:47:503 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code work_state, mode 2, type 3: [11-09 15:58:47:504 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:505 TUYA D][tuya_home_ctrl_common_show.c:43] opening [11-09 15:58:47:505 TUYA D][tuya_home_ctrl_common_show.c:43] closing [11-09 15:58:47:506 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code time_total, mode 2, type 1: [11-09 15:58:47:507 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:120000, step:1, scale:0, value:0 [11-09 15:58:47:508 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code fault, mode 2, type 10: [11-09 15:58:47:508 TUYA E][tuya_home_ctrl_dev.c:2107] do not support show value, dp_type:10 [11-09 15:58:47:509 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[24] 0x18c708e0. [11-09 15:58:47:510 TUYA E][tuya_ctrl_center_api.c:78] id:6c8d86100ac2212db3dqj5 not find dev dp: 0 [11-09 15:58:47:511 TUYA E][tuya_ctrl_center_api.c:811] id:6c8d86100ac2212db3dqj5 not find dev dp: 0 [11-09 15:58:47:511 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:512 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:512 TUYA E][tuya_ctrl_center_api.c:977] unknown type:10 [11-09 15:58:47:513 TUYA W][tuya_ctrl_center_api.c:1032] dev_id:6c8d86100ac2212db3dqj5 dp_id: 17 prop_tp:10 mode:0 get value err [11-09 15:58:47:514 TUYA W][tuya_home_ctrl_dev.c:594] custom dp type 10 not matched, do nothing. [11-09 15:58:47:515 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c8d86100ac2212db3dqj5, cb 0x7fb75c56e4. [11-09 15:58:47:516 TUYA D][tuya_base_event.c:28] subscribe: dp-6c8d86100ac2212db3dqj5 [11-09 15:58:47:516 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c8d86100ac2212db3dqj5 [11-09 15:58:47:517 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c8d86100ac2212db3dqj5, cb 0x7fb75c6374. [11-09 15:58:47:518 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c8d86100ac2212db3dqj5, handle 0x18c708e0, ref_cnt 1. [11-09 15:58:47:519 TUYA D][home_control.c:1434] ============================4路多功能面板/6c8d86100ac2212db3dqj5/cjkg============================== [11-09 15:58:47:520 TUYA E][tuya_ctrl_center_api.c:811] id:6c8d86100ac2212db3dqj5 not find dev dp: 0 [11-09 15:58:47:521 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:522 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code mode_1, mode 0, type 3: [11-09 15:58:47:522 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:523 TUYA D][tuya_home_ctrl_common_show.c:43] switch_1 [11-09 15:58:47:524 TUYA D][tuya_home_ctrl_common_show.c:43] scene_1 [11-09 15:58:47:524 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code mode_2, mode 0, type 3: [11-09 15:58:47:525 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:526 TUYA D][tuya_home_ctrl_common_show.c:43] switch_2 [11-09 15:58:47:526 TUYA D][tuya_home_ctrl_common_show.c:43] scene_2 [11-09 15:58:47:527 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code mode_3, mode 0, type 3: [11-09 15:58:47:528 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:528 TUYA D][tuya_home_ctrl_common_show.c:43] switch_3 [11-09 15:58:47:529 TUYA D][tuya_home_ctrl_common_show.c:43] scene_3 [11-09 15:58:47:529 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code mode_4, mode 0, type 3: [11-09 15:58:47:530 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:531 TUYA D][tuya_home_ctrl_common_show.c:43] switch_4 [11-09 15:58:47:532 TUYA D][tuya_home_ctrl_common_show.c:43] scene_4 [11-09 15:58:47:532 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:533 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:533 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_2, mode 0, type 0: [11-09 15:58:47:534 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:535 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_3, mode 0, type 0: [11-09 15:58:47:535 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:536 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_4, mode 0, type 0: [11-09 15:58:47:537 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:537 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code light_mode, mode 0, type 3: [11-09 15:58:47:538 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 3 enums: [11-09 15:58:47:539 TUYA D][tuya_home_ctrl_common_show.c:43] none [11-09 15:58:47:539 TUYA D][tuya_home_ctrl_common_show.c:43] relay [11-09 15:58:47:540 TUYA D][tuya_home_ctrl_common_show.c:43] pos [11-09 15:58:47:540 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_1, mode 2, type 3: [11-09 15:58:47:541 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:542 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:542 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_2, mode 2, type 3: [11-09 15:58:47:543 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:544 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:544 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_3, mode 2, type 3: [11-09 15:58:47:545 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:546 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:546 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code scene_4, mode 2, type 3: [11-09 15:58:47:547 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:548 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:548 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code , mode 0, type 0: [11-09 15:58:47:549 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:550 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[25] 0x18c72460. [11-09 15:58:47:550 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:551 TUYA E][tuya_home_ctrl_dev.c:790] ret:-6 [11-09 15:58:47:551 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name dp-6c532d9717845ff9f6lmen, cb 0x7fb75c56e4. [11-09 15:58:47:552 TUYA D][tuya_base_event.c:28] subscribe: dp-6c532d9717845ff9f6lmen [11-09 15:58:47:553 TUYA D][tuya_base_event.c:28] subscribe: cst_dp-6c532d9717845ff9f6lmen [11-09 15:58:47:554 TUYA D][tuya_home_ctrl_dev.c:1705] tuya_subscribe SUCCESSFULLY: name cst_dp-6c532d9717845ff9f6lmen, cb 0x7fb75c6374. [11-09 15:58:47:555 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c532d9717845ff9f6lmen, handle 0x18c72460, ref_cnt 1. [11-09 15:58:47:556 TUYA D][home_control.c:1434] ============================Smart/6c532d9717845ff9f6lmen/kg============================== [11-09 15:58:47:557 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:557 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code switch_1, mode 0, type 0: [11-09 15:58:47:558 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:559 TUYA D][tuya_home_ctrl_dev.c:3248] DP: dp_code countdown_1, mode 0, type 1: [11-09 15:58:47:559 TUYA D][tuya_home_ctrl_common_show.c:34] int min:0, max:43200, step:1, scale:0, value:0 [11-09 15:58:47:560 TUYA I][tuya_home_ctrl_dev.c:1835] ADD dev_des_pool[26] 0x18c723f0. [11-09 15:58:47:561 TUYA I][tuya_home_ctrl_dev.c:2625] Dev added SUCCESSFULLY: dev_id 6c8d86100ac2212db3dqj5, handle 0x18c723f0, ref_cnt 2. [11-09 15:58:47:562 TUYA D][home_control.c:1468] ============================6c8d86100ac2212db3dqj5============================== [11-09 15:58:47:563 TUYA E][tuya_ctrl_center_api.c:811] id:6c8d86100ac2212db3dqj5 not find dev dp: 0 [11-09 15:58:47:564 TUYA E][tuya_ctrl_center_api.c:830] not find dp name [11-09 15:58:47:564 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 1, mode 2, type 3: [11-09 15:58:47:565 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:566 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:566 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 2, mode 2, type 3: [11-09 15:58:47:567 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:568 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:568 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 3, mode 2, type 3: [11-09 15:58:47:569 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:570 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:570 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 4, mode 2, type 3: [11-09 15:58:47:571 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 1 enums: [11-09 15:58:47:572 TUYA D][tuya_home_ctrl_common_show.c:43] scene [11-09 15:58:47:572 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 17, mode 0, type 10: [11-09 15:58:47:573 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 18, mode 0, type 3: [11-09 15:58:47:574 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:575 TUYA D][tuya_home_ctrl_common_show.c:43] switch_1 [11-09 15:58:47:575 TUYA D][tuya_home_ctrl_common_show.c:43] scene_1 [11-09 15:58:47:576 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 19, mode 0, type 3: [11-09 15:58:47:577 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:577 TUYA D][tuya_home_ctrl_common_show.c:43] switch_2 [11-09 15:58:47:578 TUYA D][tuya_home_ctrl_common_show.c:43] scene_2 [11-09 15:58:47:578 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 20, mode 0, type 3: [11-09 15:58:47:579 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:580 TUYA D][tuya_home_ctrl_common_show.c:43] switch_3 [11-09 15:58:47:580 TUYA D][tuya_home_ctrl_common_show.c:43] scene_3 [11-09 15:58:47:581 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 21, mode 0, type 3: [11-09 15:58:47:582 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 2 enums: [11-09 15:58:47:583 TUYA D][tuya_home_ctrl_common_show.c:43] switch_4 [11-09 15:58:47:583 TUYA D][tuya_home_ctrl_common_show.c:43] scene_4 [11-09 15:58:47:584 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 24, mode 0, type 0: [11-09 15:58:47:584 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:585 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 25, mode 0, type 0: [11-09 15:58:47:586 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:586 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 26, mode 0, type 0: [11-09 15:58:47:587 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:587 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 27, mode 0, type 0: [11-09 15:58:47:588 TUYA D][tuya_home_ctrl_common_show.c:29] bool:0 [11-09 15:58:47:589 TUYA D][tuya_home_ctrl_dev.c:3262] CUSTOM DP: dp_id 37, mode 0, type 3: [11-09 15:58:47:589 TUYA D][tuya_home_ctrl_common_show.c:40] enum:, support total 3 enums: [11-09 15:58:47:590 TUYA D][tuya_home_ctrl_common_show.c:43] none [11-09 15:58:47:591 TUYA D][tuya_home_ctrl_common_show.c:43] relay [11-09 15:58:47:591 TUYA D][tuya_home_ctrl_common_show.c:43] pos [11-09 15:58:49:347 TUYA W][tuya_z3.c:31701] Zigbee COO ver is not get. [11-09 15:58:50:948 TUYA D][lan_cluster_master_confirm.c:294] Create UDP Socket To send master confirm [11-09 15:58:53:86 TUYA D][tuya_svc_schema_upgrade.c:170] next schema get slot 67957. [11-09 15:58:59:352 TUYA W][tuya_z3.c:31701] Zigbee COO ver is not get. [11-09 15:58:59:824 TUYA D][rcd_file.c:602] [ty_rcd]backup timer called. send to message queue to proc.-->> [11-09 15:58:59:824 TUYA D][thread_pool_temp.c:721] temp run add 0x18c04770 0x7fb74ce080 18c50e70 [11-09 15:58:59:825 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74ce080 18c50e70 [11-09 15:58:59:826 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74ce080 18c50e70 in thread 18c04760 BEGIN [11-09 15:58:59:826 TUYA D][rcd_file.c:483] [ty_rcd] db backup start [11-09 15:58:59:828 TUYA D][rcd_file.c:507] [ty_rcd]backup normal file to bak success [11-09 15:58:59:828 TUYA D][rcd_file.c:510] [ty_rcd] db backup end [11-09 15:58:59:829 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:58:59:829 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:58:59:830 TUYA D][thread_pool_temp.c:147] put thread 0x18c04770 [11-09 15:58:59:830 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:58:59:907 TUYA D][lan_cluster_multi_home_master.c:195] home mst info dump my_st 0 LAN_MAX. cur time 127461 [11-09 15:58:59:908 TUYA D][lan_cluster_multi_home_master.c:198] LAN Mst 6ce31c8d4213fd9ea3n3rd 0 [11-09 15:59:07:852 TUYA D][mqtt_client.c:203] mqtt_ping -->> [11-09 15:59:07:853 TUYA D][mqtt_client.c:221] mqtt_ping <<-- [11-09 15:59:07:993 TUYA D][mqtt_client.c:1239] ping respond. update fail_cnt:0 [11-09 15:59:09:120 TUYA I][lan_rpc.c:529] lan_rpc_recv result 192, ip -> c0a81266, port 6608 [11-09 15:59:09:121 TUYA D][lan_rpc.c:534] session_key 35 64 37 64 [11-09 15:59:09:121 TUYA D][lan_rpc.c:571] session_key f6 fc 78 46 [11-09 15:59:09:122 TUYA D][base_rpc_com.c:429] Rev From Key:192.168.18.102 Len:192 [11-09 15:59:09:123 TUYA D][base_rpc_com.c:775] msg type 0, seqno 1945 [11-09 15:59:09:123 TUYA D][rpc_udp.c:209] rpc aes decrypt equest [11-09 15:59:09:123 TUYA D][rpc_udp.c:233] request seqno 1945 - > {"json_rpc":"2.0","id":1944,"method":"LAN_SUBSCRIBE","params":{"param":"{\"topic\":\"LAN_SECURITY\" }","seq":402}} [11-09 15:59:09:125 TUYA I][lan_simple_mq.c:149] recv rpc name=[LAN_SUBSCRIBE] param=[{"topic":"LAN_SECURITY" }] seq[402] ip[c0a81266] st[1] [11-09 15:59:09:126 TUYA D][lan_msg_reliable_trans_master.c:207] lan_msg_get_recv_seq id:6cd4e4d52a86777441iaxt seq:0 [11-09 15:59:09:127 TUYA D][lan_msg_reliable_trans_master.c:237] lan_msg_set_recv_seq id:6cd4e4d52a86777441iaxt seq:402 [11-09 15:59:09:128 TUYA D][lan_pub_sub_mq_center.c:226] recv sub topic:LAN_SECURITY id:6cd4e4d52a86777441iaxt [11-09 15:59:09:129 TUYA D][lan_pub_sub_mq_center.c:144] add topic[LAN_SECURITY] suber[6cd4e4d52a86777441iaxt] [11-09 15:59:09:130 TUYA D][rpc_udp.c:281] response seqno 1945 - > {"json_rpc":"2.0","id":0,"result":{"param":0}} [11-09 15:59:09:130 TUYA D][rpc_udp.c:289] rpc aes encrypt result [11-09 15:59:09:131 TUYA D][rpc_udp.c:117] tuya_hal_net_send ip -> 192.168.18.102 [11-09 15:59:09:358 TUYA W][tuya_z3.c:31701] Zigbee COO ver is not get. home_on_gw_change [60] :home_on_gw_change 4 [11-09 15:59:10:656 TUYA I][lan_rpc.c:529] lan_rpc_recv result 192, ip -> c0a81266, port 6608 [11-09 15:59:10:656 TUYA D][lan_rpc.c:534] session_key 35 64 37 64 [11-09 15:59:10:657 TUYA D][lan_rpc.c:571] session_key f6 fc 78 46 [11-09 15:59:10:657 TUYA D][base_rpc_com.c:429] Rev From Key:192.168.18.102 Len:192 [11-09 15:59:10:658 TUYA D][base_rpc_com.c:775] msg type 0, seqno 1946 [11-09 15:59:10:659 TUYA D][rpc_udp.c:209] rpc aes decrypt equest [11-09 15:59:10:659 TUYA D][rpc_udp.c:233] request seqno 1946 - > {"json_rpc":"2.0","id":1945,"method":"LAN_SUBSCRIBE","params":{"param":"{\"topic\":\"LAN_SECURITY\" }","seq":402}} [11-09 15:59:10:661 TUYA I][lan_simple_mq.c:149] recv rpc name=[LAN_SUBSCRIBE] param=[{"topic":"LAN_SECURITY" }] seq[402] ip[c0a81266] st[1] [11-09 15:59:10:662 TUYA D][lan_msg_reliable_trans_master.c:207] lan_msg_get_recv_seq id:6cd4e4d52a86777441iaxt seq:402 [11-09 15:59:10:663 TUYA I][lan_simple_mq.c:199] msg from normal node already handled. seq_cur[402] [11-09 15:59:10:664 TUYA D][rpc_udp.c:281] response seqno 1946 - > {"json_rpc":"2.0","id":0,"result":{"param":0}} [11-09 15:59:10:664 TUYA D][rpc_udp.c:289] rpc aes encrypt result [11-09 15:59:10:665 TUYA D][rpc_udp.c:117] tuya_hal_net_send ip -> 192.168.18.102 [11-09 15:59:11:695 TUYA I][lan_rpc.c:529] lan_rpc_recv result 192, ip -> c0a81266, port 6608 [11-09 15:59:11:695 TUYA D][lan_rpc.c:534] session_key 35 64 37 64 [11-09 15:59:11:696 TUYA D][lan_rpc.c:571] session_key f6 fc 78 46 [11-09 15:59:11:696 TUYA D][base_rpc_com.c:429] Rev From Key:192.168.18.102 Len:192 [11-09 15:59:11:697 TUYA D][base_rpc_com.c:775] msg type 0, seqno 1947 [11-09 15:59:11:698 TUYA D][rpc_udp.c:209] rpc aes decrypt equest [11-09 15:59:11:698 TUYA D][rpc_udp.c:233] request seqno 1947 - > {"json_rpc":"2.0","id":1946,"method":"LAN_SUBSCRIBE","params":{"param":"{\"topic\":\"LAN_SECURITY\" }","seq":402}} [11-09 15:59:11:700 TUYA I][lan_simple_mq.c:149] recv rpc name=[LAN_SUBSCRIBE] param=[{"topic":"LAN_SECURITY" }] seq[402] ip[c0a81266] st[1] [11-09 15:59:11:701 TUYA D][lan_msg_reliable_trans_master.c:207] lan_msg_get_recv_seq id:6cd4e4d52a86777441iaxt seq:402 [11-09 15:59:11:702 TUYA I][lan_simple_mq.c:199] msg from normal node already handled. seq_cur[402] [11-09 15:59:11:703 TUYA D][rpc_udp.c:281] response seqno 1947 - > {"json_rpc":"2.0","id":0,"result":{"param":0}} [11-09 15:59:11:703 TUYA D][rpc_udp.c:289] rpc aes encrypt result [11-09 15:59:11:704 TUYA D][rpc_udp.c:117] tuya_hal_net_send ip -> 192.168.18.102 [11-09 15:59:13:625 TUYA I][lan_rpc.c:529] lan_rpc_recv result 192, ip -> c0a81266, port 6608 [11-09 15:59:13:626 TUYA D][lan_rpc.c:534] session_key 35 64 37 64 [11-09 15:59:13:626 TUYA D][lan_rpc.c:571] session_key f6 fc 78 46 [11-09 15:59:13:627 TUYA D][base_rpc_com.c:429] Rev From Key:192.168.18.102 Len:192 [11-09 15:59:13:628 TUYA D][base_rpc_com.c:775] msg type 0, seqno 1948 [11-09 15:59:13:628 TUYA D][rpc_udp.c:209] rpc aes decrypt equest [11-09 15:59:13:628 TUYA D][rpc_udp.c:233] request seqno 1948 - > {"json_rpc":"2.0","id":1947,"method":"LAN_SUBSCRIBE","params":{"param":"{\"topic\":\"LAN_SECURITY\" }","seq":402}} [11-09 15:59:13:630 TUYA I][lan_simple_mq.c:149] recv rpc name=[LAN_SUBSCRIBE] param=[{"topic":"LAN_SECURITY" }] seq[402] ip[c0a81266] st[1] [11-09 15:59:13:631 TUYA D][lan_msg_reliable_trans_master.c:207] lan_msg_get_recv_seq id:6cd4e4d52a86777441iaxt seq:402 [11-09 15:59:13:632 TUYA I][lan_simple_mq.c:199] msg from normal node already handled. seq_cur[402] [11-09 15:59:13:633 TUYA D][rpc_udp.c:281] response seqno 1948 - > {"json_rpc":"2.0","id":0,"result":{"param":0}} [11-09 15:59:13:633 TUYA D][rpc_udp.c:289] rpc aes encrypt result [11-09 15:59:13:634 TUYA D][rpc_udp.c:117] tuya_hal_net_send ip -> 192.168.18.102 [11-09 15:59:14:120 TUYA D][rcd_file.c:602] [ty_rcd]backup timer called. send to message queue to proc.-->> [11-09 15:59:14:121 TUYA D][thread_pool_temp.c:721] temp run add 0x18c04770 0x7fb74ce080 18c4ae40 [11-09 15:59:14:121 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74ce080 18c4ae40 [11-09 15:59:14:122 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74ce080 18c4ae40 in thread 18c04760 BEGIN [11-09 15:59:14:123 TUYA D][rcd_file.c:483] [ty_rcd] db backup start [11-09 15:59:14:125 TUYA D][rcd_file.c:507] [ty_rcd]backup normal file to bak success [11-09 15:59:14:125 TUYA D][rcd_file.c:510] [ty_rcd] db backup end [11-09 15:59:14:126 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:59:14:126 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:59:14:127 TUYA D][thread_pool_temp.c:147] put thread 0x18c04770 [11-09 15:59:14:127 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:59:14:132 TUYA D][rcd_file.c:602] [ty_rcd]backup timer called. send to message queue to proc.-->> [11-09 15:59:14:133 TUYA D][thread_pool_temp.c:721] temp run add 0x18c04770 0x7fb74ce080 18c4d980 [11-09 15:59:14:133 TUYA D][thread_pool_temp.c:627] temp run 0x7fb74ce080 18c4d980 [11-09 15:59:14:134 TUYA D][thread_pool_temp.c:201] run temp 0x7fb74ce080 18c4d980 in thread 18c04760 BEGIN [11-09 15:59:14:135 TUYA D][rcd_file.c:483] [ty_rcd] db backup start [11-09 15:59:14:136 TUYA D][rcd_file.c:507] [ty_rcd]backup normal file to bak success [11-09 15:59:14:136 TUYA D][rcd_file.c:510] [ty_rcd] db backup end [11-09 15:59:14:137 TUYA D][thread_pool_temp.c:204] thread 18c04760 END [11-09 15:59:14:137 TUYA N][uni_msg_queue.c:286] last_cb:0x7fb74dab34 [11-09 15:59:14:138 TUYA D][thread_pool_temp.c:147] put thread 0x18c04770 [11-09 15:59:14:138 TUYA D][thread_pool_temp.c:155] temp thread total:5 used:0 [11-09 15:59:14:977 TUYA D][lan_cluster_ka_master.c:272] node 6cd4e4d52a86777441iaxt send cnt 1. seq 9, cur seq 11, ka time 127472, cur_time 127476 ^C [END] 2022/11/9 16:00:35
