ifdef COMPILE_INCLUDE
CFLAGS += -I $(COMPILE_INCLUDE)
endif
ifdef COMPILE_LIB
export LD_LIBRARY_PATH=$(COMPILE_LIB)
endif
LINKFLAGS =
ifeq ($(CONFIG_OPERATING_SYSTEM), 100) 
LINKFLAGS += -lpthread -lm
endif
ifdef PRJ_LINKS
LINKFLAGS += $(PRJ_LINKS)
endif
 中间编译过程输出已经忽略
AR -rcs /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/lib/libserver.a /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/app/app_mf.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/app/app_test.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/app/app_tuya_cloud.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/app/app_tuya_lan_server.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/app/app_tuya_mcu.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/bsp/bsp_tcp_log.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/bsp/bsp_uart.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/common/common_autoload.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/common/common_console.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/common/common_log.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/common/common_storage.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/tuya_device.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/vendor/driver/driver_console.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/vendor/driver/driver_log.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/vendor/fjson/fjson.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/vendor/kvflash/kv_cache.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/vendor/kvflash/kv_flash.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/vendor/kvflash/kv_port.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/vendor/tools/tools_monitor.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/vendor/tools/tools_timer.c.o /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/.objs/static/apps/server/src/vendor/tuya/tuya_mcu.c.o
/root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/lib/libserver.a build done.
AR -rcs /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/lib/libtuyaapp_components.a 
AR -rcs /root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/lib/libtuyaapp_drivers.a 
/root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/lib/libtuyaapp_components.a build done.
/root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/output/T1_server/lib/libtuyaapp_drivers.a build done.
====== build app(server) begin =======
# 开始编译app
apps/server
APP_BIN_NAME=server
APP_VERSION=1.0.2
TARGET_PLATFORM=T1
APP_PATH=../../../apps/server
USER_CMD=
Start Compile
system:Linux
Removing TUYA APP Common and Components Objs
Deleting Debug/apps/server/src
Deleting Debug/apps/server/src/app
Deleting Debug/apps/server/src/bsp
Deleting Debug/apps/server/src/common
Deleting Debug/apps/server/src/vendor
Deleting Debug/apps/server/src/vendor/driver
Deleting Debug/apps/server/src/vendor/fjson
Deleting Debug/apps/server/src/vendor/kvflash
Deleting Debug/apps/server/src/vendor/tools
Deleting Debug/apps/server/src/vendor/tuya
/root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/vendor/T1/T1_os
not is ci build
make[1]: warning: -j0 forced in submake: resetting jobserver mode.
make[1]: Entering directory '/root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/vendor/T1/T1_os'
fatal: not a git repository (or any of the parent directories): .git
make[2]: Entering directory '/root/tuya/wifi-server/T1-CHL_TuyaOS-3.11.11/software/TuyaOS/vendor/T1/T1_os'
echo prerequirement0
prerequirement0
Build server
echo prerequirement1
prerequirement1
mkdir -p Debug
echo prerequirement2
prerequirement2
#-rm -rf Debug/./T1/driver/entry/boot_handlers.O Debug/./T1/driver/entry/boot_vectors.O Debug/./T1/os/FreeRTOSv9.0.0/FreeRTOS/Source/portable/Keil/ARM968es/port.marm.o Debug/./T1/os/FreeRTOSv9.0.0/FreeRTOS/Source/croutine.o Debug/./T1/os/FreeRTOSv9.0.0/FreeRTOS/Source/event_groups.o Debug/./T1/os/FreeRTOSv9.0.0/FreeRTOS/Source/list.o Debug/./T1/os/FreeRTOSv9.0.0/FreeRTOS/Source/portable/MemMang/heap_4.o Debug/./T1/os/FreeRTOSv9.0.0/FreeRTOS/Source/queue.o Debug/./T1/os/FreeRTOSv9.0.0/FreeRTOS/Source/tasks.o Debug/./T1/os/FreeRTOSv9.0.0/FreeRTOS/Source/timers.o Debug/./T1/os/FreeRTOSv9.0.0/rtos_pub.o Debug/./T1/os/mem_arch.o Debug/./T1/os/platform_stub.o Debug/./T1/os/str_arch.o Debug/libtuya.a
CC ../../../apps/server/src/tuya_device.c
CC ../../../apps/server/src/app/app_tuya_cloud.c
