U-Boot 2013.07-H20241023a (Mar 28 2025 - 18:27:22)
apll_freq = 1200000000 
mpll_freq = 1200000000 
vpll_freq = 1188000000
sdram init start
DDR clk rate 600000000
80000e4c 00000000 00000000
DDR soft training ...
sdram init Finished
image entry point: 0x80100000
Board: PRJ007 (Ingenic XBurst PRJ007  SoC)
DRAM:  64 MiB
Top of RAM usable for U-Boot at: 84000000
Reserving 452k for U-Boot at: 83f8c000
Reserving 32784k for malloc() at: 81f88000
Reserving 32 Bytes for Board Info at: 81f87fe0
Reserving 124 Bytes for Global Data at: 81f87f64
Reserving 128k for boot params() at: 81f67f64
Stack Pointer at: 81f67f48
Now running in RAM - U-Boot at: 83f8c000
serial_initialize done
mem_malloc_init done
MMC PWR EN
MMC:   MSC: 0
SF: Detected GD25Q128C, flash size: 16MB, manufacturer id: c8
In:    serial
Out:   serial
Err:   serial
Net:   Jz4775-9161
Interface:  MMC
  Device 0: Vendor: Man 00006f Snr 00013601 Rev: 10.10 Prod: IST3T
            Type: Removable Hard Disk
            Capacity: 119305.0 MB = 116.5 GB (244336640 x 512)
Filesystem: FAT32 ""
reading t32_cfgupdate
t32_cfgupdate not found
Hit any key to stop autoboot:  0 
--->probe spend 6 ms
SF: 2621440 bytes @ 0x40000 Read: OK
--->read spend 842 ms
## Booting kernel from Legacy Image at 80600000 ...
   Image Name:   Linux-3.10.14__isvp_goat_1.0__
   Image Type:   MIPS Linux Kernel Image (lzma compressed)
   Data Size:    1645201 Bytes = 1.6 MiB
   Load Address: 80010000
   Entry Point:  80385bf0
   Verifying Checksum ... OK
   Uncompressing lzma Kernel Image ... OK
Starting kernel ...
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.14__isvp_goat_1.0__ (cxl@cxl-virtual-machine) (gcc version 5.4.0 (Ingenic r3.3.7-gcc540 Fix: forbid mxu2 division into delay slot . 2024.10-18) ) #3 PREEMPT Fri Mar 28 18:30:44 CST 2025
[    0.000000] Ingenic Kernel-3.10 version H20240927a
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU0 RESET ERROR PC:801C2760
[    0.000000] [<801c2760>] __delay+0x0/0x10
[    0.000000] CPU0 revision is: 00d00100 (Ingenic Xburst)
[    0.000000] FPU revision is: 00b70000
[    0.000000] CCLK:1200MHz L2CLK:600Mhz H0CLK:200MHz H2CLK:200Mhz PCLK:100Mhz
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 00497000 @ 00010000 (usable)
[    0.000000]  memory: 00039000 @ 004a7000 (usable after init)
[    0.000000] User-defined physical RAM map:
[    0.000000]  memory: 02e00000 @ 00000000 (usable)
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x02dfffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x02dfffff]
[    0.000000] cma: CMA: reserved 8 MiB at 02400000
[    0.000000] Primary instruction cache 32kB, 8-way, VIPT, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 8-way, VIPT, no aliases, linesize 32 bytes
[    0.000000] pls check processor_id[0x00d00100],sc_jz not support!
[    0.000000] MIPS secondary cache 128kB, 8-way, linesize 32 bytes.
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 11684
[    0.000000] Kernel command line: console=ttyS1,115200n8 mem=46M@0x0 rmem=18M@0x2E00000 init=/linuxrc rootfstype=squashfs root=/dev/mtdblock2 rw mtdparts=sfc0_nor:256k(boot),2048k(kernel),2048k(root),512k(cfg),-(appfs)
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 33048k/47104k available (3574k kernel code, 14056k reserved, 1124k data, 228k init, 0k highmem, 8192K cma-reserved)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:358
[    0.000000] clockevents_config_and_register success.
[   12.267397] Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256)
[   12.355185] pid_max: default: 32768 minimum: 301
[   12.360084] Mount-cache hash table entries: 512
[   12.365126] Initializing cgroup subsys debug
[   12.369390] Initializing cgroup subsys freezer
[   12.375980] regulator-dummy: no parameters
[   12.380413] NET: Registered protocol family 16
[   12.395970] bio: create slab <bio-0> at 0
[   12.401758] jz-dma jz-dma: JZ SoC DMA initialized
[   12.406832] usbcore: registered new interface driver usbfs
[   12.412354] usbcore: registered new interface driver hub
[   12.417858] usbcore: registered new device driver usb
[   12.423078]  (null): set:249  hold:250 dev=100000000 h=500 l=500
[   12.429174] i2c i2c-0: i2c0 register ok.
[   12.434807] Switching to clocksource jz_clocksource
[   12.440267] NET: Registered protocol family 2
[   12.444734] cfg80211: Calling CRDA to update world regulatory domain
[   12.451664] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[   12.458581] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[   12.465074] TCP: Hash tables configured (established 512 bind 512)
[   12.471362] TCP: reno registered
[   12.474557] UDP hash table entries: 256 (order: 0, 4096 bytes)
[   12.480506] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[   12.487057] NET: Registered protocol family 1
[   12.491774] RPC: Registered named UNIX socket transport module.
[   12.497708] RPC: Registered udp transport module.
[   12.502544] RPC: Registered tcp transport module.
[   12.507243] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   12.514101] cpu_clk rate is 1200000000
[   12.522523] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   12.529210] jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
[   12.535159] msgmni has been set to 80
[   12.540148] io scheduler noop registered
[   12.544085] io scheduler cfq registered (default)
[   12.549181] vpu_node_num: 1radix0 probe success
[   12.553900] vpu_node_num: 2helix0 success
[   12.559021] jz-uart.1: ttyS1 at MMIO 0x10031000 (irq = 58) is a gate_uart1
[   12.567269] console [ttyS1] enabled, bootconsole disabled
[   12.578529] jz-uart.2: ttyS2 at MMIO 0x10032000 (irq = 57) is a gate_uart2
[   12.588924] brd: module loaded
[   12.593822] loop: module loaded
[   12.597576] zram: Created 2 device(s) ...
[   12.601899] logger: created 256K log 'log_main'
[   12.607198] jz TCU driver register completed
[   12.612029] JZ-SFC,Use SFC Standard Mode
[   12.616092] JZ-SFC,Use SFC PIO Mode
[   12.620604] jz-sfc jz-sfc.0: Found Supported nor device, BE = 32K, id = c84018, name = GD25Q127C
[   12.629780] jz-sfc jz-sfc.0: nor flash now use standard mode!
[   12.635728] jz-sfc jz-sfc.0: nor flash now use 3bytes mode!
[   12.641528] 5 cmdlinepart partitions found on MTD device sfc0_nor
[   12.647835] Creating 5 MTD partitions on "sfc0_nor":
[   12.652988] 0x000000000000-0x000000040000 : "boot"
[   12.658513] 0x000000040000-0x000000240000 : "kernel"
[   12.664184] 0x000000240000-0x000000440000 : "root"
[   12.669572] 0x000000440000-0x0000004c0000 : "cfg"
[   12.674958] 0x0000004c0000-0x000001000000 : "appfs"
[   12.680630] jz-sfc jz-sfc.0: SPI NOR MTD LOAD OK
[   12.685476] tun: Universal TUN/TAP device driver, 1.6
[   12.690755] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[   12.697262] usbcore: registered new interface driver zd1201
[   12.703140] jz-dwc2 jz-dwc2: div clk gate get error
[   12.708208] DWC IN OTG MODE
[   12.711784] dwc2 dwc2: Keep PHY ON
[   12.715306] dwc2 dwc2: Using Buffer DMA mode
[   12.719750] dwc2 dwc2: Core Release: 3.00a
[   12.724025] dwc2 dwc2: DesignWare USB2.0 High-Speed Host Controller
[   12.730544] dwc2 dwc2: new USB bus registered, assigned bus number 1
[   12.738266] hub 1-0:1.0: USB hub found
[   12.742230] hub 1-0:1.0: 1 port detected
[   12.746419] dwc2 dwc2: DWC2 Host Initialized
[   12.752413] mmc0: Unknown controller version (5). You may experience problems.
[   12.760112] mmc0: no vqmmc regulator found
[   12.764358] mmc0: no vmmc regulator found
[   12.819807] mmc0: SDHCI controller on ingenic-msc [jz-sdhci.0] using ADMA
[   12.826856] dwc2 dwc2: ID PIN CHANGED!
[   12.831060] sdhci: Secure Digital Host Controller Interface driver
[   12.839516] sdhci: Copyright(c) Pierre Ossman
[   12.849496] TCP: cubic registered
[   12.853100] NET: Registered protocol family 17
[   12.862195] soc_vpu probe success,version:1.0.0-03203fd46d
[   12.872296] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   12.888050] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[   12.895878] Freeing unused kernel memory: 228K (804a7000 - 804e0000)
[   12.929212] mmc0: new high speed SDXC card at address b369
[   12.935436] mmcblk0: mmc0:b369 IST3T 116 GiB 
[   12.947627]  mmcblk0: p1
MDEV:mmcblk0p1
ACTION:add
[   13.690402] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
MDEV:mmcblk0
ACTION:add
mdev ignore mmcblk0
mdev is ok......
net.core.wmem_max = 26214400
net.core.wmem_default = 26214400
Ingenic-uc1_1 login: [   14.330819] [atbm_log]:atbm_usb_module_init 0
[   14.338418] [atbm_log]:platform_init(253)
[   14.345139] [atbm_log]:SVN_VER=34074,DPLL_CLOCK=2,BUILD_TIME=2025-04-01_20:18:44
[   14.353284] usbcore: registered new interface driver atbm_wlan
[   14.799732] usb 1-1: new high-speed USB device number 2 using dwc2
[   15.013787] [atbm_log]:atbm_usb_probe : idVendor[7a] idProduct[8890] 
[   15.023000] [atbm_log]:reset wifi_chip_probe!
[   15.027518] [atbm_log]:Probe called -1 v1
[   15.031774] [atbm_log]:not CONFIG_USE_DMA_ADDR_BUFFER
[   15.037152] [atbm_log]:CONFIG_TX_NO_CONFIRM
[   15.041595] [atbm_log]:ble_spin_lock init 
[   15.045842] [atbm_log]:Allocated hw_priv @ 82094ee0
[   15.051310] [atbm_log]: wait_event_interruptible from  send_prbresp_wq
[   15.058134] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (82094ee0)
[   15.064988] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (82094ee0)
[   15.071876] [atbm_log]:atbm_get_chiptype, chipver=0xa3, g_wifi_chip_type[14]
[   15.079172] [atbm_log]:atbm_before_load_firmware++
[   15.084210] [atbm_log]:+++++++++++++++++1.1v++++++++++++++++++
[   15.090263] [atbm_log]:===================~_~====================
[   15.096976] [atbm_log]:atbm_start_load_firmware++
[   15.101861] fwhdr->flags 34353678 sram_addr 9012000
[   15.106910] [atbm_log]:
[   15.106910] ======>>> load WIFI BLE COMB firmware <<<======
[   15.106910] 
[   15.116740] [atbm_log]:START DOWNLOAD ICCM=========
[   15.121798] [atbm_log]:atbm_load_firmware_generic: addr 10000: len 28000
[   15.252026] [atbm_log]:START DOWNLOAD DCCM=========
[   15.257087] [atbm_log]:atbm_load_firmware_generic: addr 800000: len a000
[   15.295139] [atbm_log]:START DOWNLOAD SRAM=========
[   15.300214] [atbm_log]:atbm_load_firmware_generic: addr 9012000: len 4000
[   15.319546] [atbm_log]:atbm_after_load_firmware++
[   15.324443] [atbm_log]:usb:try to flush rx....
[   15.419759] [atbm_log]:flush rx[-145][0]
[   15.423826] [atbm_log]:ARES_A:after_load_firmware
[   15.428888] [atbm_log]:0x1610102c=0x40a0e
[   15.433411] [atbm_log]:0x1610102c=0x10a0f
[   15.437612] [atbm_log]:0x16101000=0x8000e08
[   15.442318] [atbm_log]:set_block_size=256
[   15.446492] [atbm_log]:firmwareCap f1a9
[   15.450481] [atbm_log]:firmwareCap2 1185
[   15.454540] [atbm_log]:wsm_caps.firmwareCap 1185f1a9 0
[   15.459687] [atbm_log]:apollo wifi WSM init done.
[   15.459687]    Input buffers: 25 x 1648 bytes
[   15.459687]    Hardware: 7.0
[   15.459687]    WSM firmware [=MODEM=RF=Ares_AX Apr 22 2024 14:36:14], ver: 19963, build: 4221, api: 1060, cap: 0x1185F1A9 Config[30008]  expection 9001fdc, ep0 cmd addr 0 NumOfStations[8] NumOfInterfaces[3]
[   15.491207] [atbm_log]:EFUSE(8)                              [0]
[   15.495082] [atbm_log]:EFUSE(I)                                      [0]
[   15.499061] [atbm_log]:EFUSE(B)                      [0]
[   15.502860] [atbm_log]:CAPABILITIES_ATBM_PRIVATE_IE  [0]
[   15.508354] [atbm_log]:CAPABILITIES_NVR_IPC  [0]
[   15.513140] [atbm_log]:CAPABILITIES_NO_CONFIRM  [1]
[   15.518186] [atbm_log]:CAPABILITIES_SDIO_PATCH  [0]
[   15.523240] [atbm_log]:CAPABILITIES_NO_BACKOFF  [1]
[   15.528284] [atbm_log]:CAPABILITIES_CFO  [0]
[   15.532707] [atbm_log]:CAPABILITIES_AGC  [1]
[   15.537123] [atbm_log]:CAPABILITIES_TXCAL  [1]
[   15.541727] [atbm_log]:CAPABILITIES_MONITOR  [0]
[   15.546503] [atbm_log]:CAPABILITIES_CUSTOM  [0]
[   15.551195] [atbm_log]:CAPABILITIES_SMARTCONFIG  [0]
[   15.556330] [atbm_log]:CAPABILITIES_ETF  [1]
[   15.560754] [atbm_log]:CAPABILITIES_LMAC_RATECTL  [1]
[   15.565981] [atbm_log]:CAPABILITIES_LMAC_TPC  [1]
[   15.570854] [atbm_log]:CAPABILITIES_LMAC_TEMPC  [1]
[   15.575900] [atbm_log]:CAPABILITIES_CTS_BUG  [1]
[   15.580682] [atbm_log]:CAPABILITIES_USE_IPC  [0]
[   15.585457] [atbm_log]:CAPABILITIES_OUTER_PA  [0]
[   15.590331] [atbm_log]:CAPABILITIES_POWER_CONSUMPTION  [0]
[   15.596006] [atbm_log]:CAPABILITIES_RSSI_DECIDE_TXPOWER  [0]
[   15.601869] [atbm_log]:CAPABILITIES_RTS_LONG_DURATION  [1]
[   15.607546] [atbm_log]:CAPABILITIES_TX_CFO_PPM_CORRECTION  [1]
[   15.613588] [atbm_log]:CAPABILITIES_NOISE_SET_DCXO  [0]
[   15.618996] [atbm_log]:CAPABILITIES_CFO_DCXO_CORRECTION  [1]
[   15.624858] [atbm_log]:CAPABILITIES_HW_CHECKSUM  [0]
[   15.630002] [atbm_log]:CAPABILITIES_SINGLE_CHANNEL_MULTI_RX  [0]
[   15.636218] [atbm_log]:EX_CAPABILITIES_TWO_CHIP_ONE_SOC  [0]
[   15.642082] [atbm_log]:EX_CAPABILITIES_MANUAL_SET_AC  [0]
[   15.647668] [atbm_log]:EX_CAPABILITIES_LMAC_BW_CONTROL  [1]
[   15.653442] [atbm_log]:EX_CAPABILITIES_SUPPORT_TWO_ANTENNA  [0]
[   15.659567] [atbm_log]:EX_CAPABILITIES_ENABLE_STA_REMAIN_ON_CHANNEL  [1]
[   15.666510] [atbm_log]:EX_CAPABILITIES_ENABLE_PS  [1]
[   15.671743] [atbm_log]:EX_CAPABILITIES_TX_REQUEST_FIFO_LINK  [0]
[   15.677958] [atbm_log]:EX_CAPABILITIES_DRIVER_PHY_REG_INIT  [0]
[   15.684092] [atbm_log]:EX_CAPABILITIES_DRIVER_PROCESS_BA  [0]
[   15.690044] [atbm_log]:EX_CAPABILITIES_DRIVER_PHY_REG_INIT  [0]
[   15.696169] [atbm_log]:EX_CAPABILITIES_DRIVER_PROCESS_BA[1]
[   15.701943] [atbm_log]:CONFIG_PRODUCT_TEST_USE_FEATURE_ID [1]
[   15.707887] [atbm_log]:CONFIG_PRODUCT_TEST_USE_GOLDEN_LED [1]
[   15.713949] [atbm_log]:mdelay wait wsm_startup_done  !!
[   15.719739] [atbm_log]:wsm_generic_confirm:status(2)
[   15.724920] [atbm_log]:<WARNING> wsm_write_mib fail !!! mibId=4132
[   15.731631] [atbm_log]:efuse data is [0x11,0x55,0x2,0x3e,0x3b,0x10,0x0,0x0,0x60:0x56:0xee:0x16:0x81:0x2]
[   15.741629] [atbm_log]:apollo wifi : can't open /data/.mac.info
[   15.748264] [atbm_log]:enable sg
[   15.754233] [atbm_log]:[wlan0] has been disabled
[   15.773723] [atbm_log]:ble start
[   15.779675] [atbm_log]:[phy0-ble_recv] start
[   15.784310] [atbm_log]:ble subscribe
[   15.788187] [atbm_log]:[phy0-ble_xmit] start
[   15.792981] [atbm_log]:ble_platform_probe(81b19700)
[   15.800759] [atbm_log]:is registered as 'phy0'
[   15.805401] [atbm_log]:apollo wifi : can't open /tmp/atbm_txpwer_dcxo_cfg.txt
[   15.812916] [atbm_log]:apollo wifi : can't open /tmp/set_rate_power.txt
[   15.820027] [atbm_log]:apollo wifi : can't open /tmp/set_rate_power_5g.txt
[   15.827331] [atbm_log]:open_auto_cfo:ppm_buf:cfo 1 0 , buf_len:8 
[   15.833864] [atbm_log]:get chip id [34][0][0] 
[   15.838465] [atbm_log]:current chiptype 6132-BU 
[   15.843278] [atbm_log]:[atbm_wtd]:set wtd_probe = 1
[   18.383392] [atbm_log]:atbm_setup_mac:addr(6056ee168102)
[   18.389125] [atbm_log]:3 !!! atbm_vif_setup_params: enabling priv
[   18.419730] [atbm_log]:[STA] Interface ID:0 of type:2 added
[   18.425680] [atbm_log]:atbm_set_uapsd_param:uapsdFlags(0)
[   18.432028] [atbm_log]:atbm_set_uapsd_param:uapsdFlags(0)
[   18.438024] [atbm_log]:atbm_set_uapsd_param:uapsdFlags(0)
[   18.444053] [atbm_log]:atbm_set_uapsd_param:uapsdFlags(0)
[   18.450035] [atbm_log]:atbm_set_uapsd_param:uapsdFlags(0)
start_param
clk_name=mpll isp_clk=200000000
--nrvbs 2 --sboot=0 --fps=30
[   18.717273] @@@@ tx-isp-probe ok (version H20241022a), compiler date: Oct 22 2024 17:27:33 @@@@@
[   18.922629] dma dma0chan24: Channel 24 have been requested.(phy id 7,type 0x06 desc a2403000)
[   18.934488] dma dma0chan25: Channel 25 have been requested.(phy id 6,type 0x06 desc a2404000)
[   18.944078] dma dma0chan26: Channel 26 have been requested.(phy id 5,type 0x04 desc a2405000)
[   18.959155] the codec_type = 0 !!!!!
[   18.979774] @@@@@ inner codec power up@@@@@@
[   19.259766] @@@@ audio driver ok(version H20240815a) @@@@@
[   19.296616] <TNPU> tnna_clk=1200MHz, v0_clk=600MHz, default=600MHz
[   19.308972] <TNPU> Successful insmod, version=0x10200.
[1970-01-01 00:00:10:203] tag[INFO] module[PRODUCT_CONFIG]          func[product_config_init]                 line[480]   product config default file create success,cost:35 ms
[1970-01-01 00:00:10:204] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[58]    work_mode_->valueint:1
[1970-01-01 00:00:10:204] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[71]    essid_:sonsii
[1970-01-01 00:00:10:204] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[138]   mac_:0C:F0:B4:B8:DC:DA
[1970-01-01 00:00:10:205] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[151]   strlen(str):5 nic_name_:wlan0
[1970-01-01 00:00:10:205] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[177]   bind_:0
[1970-01-01 00:00:10:205] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[187]   token_:
[1970-01-01 00:00:10:206] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[58]    work_mode_->valueint:1
[1970-01-01 00:00:10:207] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[71]    essid_:sonsii
[1970-01-01 00:00:10:207] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[138]   mac_:0C:F0:B4:7C:34:D5
[1970-01-01 00:00:10:207] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[151]   strlen(str):5 nic_name_:wlan0
[1970-01-01 00:00:10:207] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[177]   bind_:0
[1970-01-01 00:00:10:207] tag[INFO] module[PRODUCT_NET_INFO]        func[product_net_info_get_first]          line[187]   token_:
[1970-01-01 00:00:10:207] tag[INFO] module[PRODUCT_CONFIG]          func[product_config_init]                 line[500]   product config user file load success,cost:2 ms
[1970-01-01 00:00:10:216] tag[INFO] module[PRODUCT_CONFIG]          func[product_config_init]                 line[535]   PRODUCT_CONFIG init success
[1970-01-01 00:00:10:216] tag[INFO] module[MAIN]                    func[product_config_set]                  line[287]   firmware_version:V1.0.13
mcu uart init....
[1970-01-01 00:00:10:226] tag[INFO] module[MCU_UART]                func[uart_init]                           line[1173]  ===================uart init ===================
[1970-01-01 00:00:10:243] tag[DEBG] module[COMPORT_INIT]            func[comport_open]                        line[55]    Open /dev/ttyS2 successfully.
[1970-01-01 00:00:10:444] tag[DEBG] module[COMPORT_INIT]            func[comport_init]                        line[217]   Comport Init Successfully......
[1970-01-01 00:00:10:444] tag[INFO] module[MCU_UART]                func[uart_init]                           line[1224]   uart init ===================success!
[1970-01-01 00:00:10:444] tag[INFO] module[MCU_UART]                func[mcu_uart_init]                       line[1293]  create uart receive thread...ok
[1970-01-01 00:00:10:445] tag[INFO] module[MCU_UART]                func[mcu_uart_init]                       line[1302]  create heart beat thread...ok
[1970-01-01 00:00:10:445] tag[INFO] module[MCU_UART]                func[mcu_uart_init]                       line[1311]  create upgrade thread...ok
[1970-01-01 00:00:10:445] tag[INFO] module[TIMEZONE]                func[timezone_init]                       line[135]   timezone_str_:GMT+8
[1969-12-31 16:00:10:446] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[1969-12-31 16:00:10:447] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
[1969-12-31 16:00:10:447] tag[INFO] module[SYSTEM_TIME]             func[_system_time_init_from_file]         line[235]   time_str:20210807 23:15:22
[1969-12-31 16:00:10:448] tag[INFO] module[SYSTEM_TIME]             func[_system_time_init_from_file]         line[264]   year:2021,month:08,day:07,hour:23,minute:15,second:22
[2021-08-07 23:15:22:000] tag[DEBG] module[UTIL_TIME]               func[util_local_time_set]                 line[23]    set local time:2021-08-07 23:15:22
[2021-08-07 23:15:22:000] tag[INFO] module[SYSTEM_TIME]             func[system_time_init]                    line[366]   SYSTEM_TIME init success
[2021-08-07 23:15:22:000] tag[INFO] module[ALARM_MNG]               func[alarm_mng_init]                      line[233]   ALARM_MNG init success
[2021-08-07 23:15:22:000] tag[INFO] module[UTIL_MEDIA_BUFF]         func[util_media_buff_create]              line[199]   chn:0,block_num:4,block_size:524288
[2021-08-07 23:15:22:004] tag[INFO] module[STREAM_BUFF_INIT]        func[stream_buff_init]                    line[129]   video_info->resolution_size_ :5; width:1920;height:1080
[2021-08-07 23:15:22:005] tag[INFO] module[UTIL_MEDIA_BUFF]         func[util_media_buff_set_attr]            line[176]   height_:1080
width_:1920
channel_:0
framerate_:15
stream_format_:5
codec_type_:0
audio_bit_:0
audio_sample_:0
[2021-08-07 23:15:22:005] tag[INFO] module[UTIL_MEDIA_BUFF]         func[util_media_buff_create]              line[199]   chn:1,block_num:2,block_size:262144
[2021-08-07 23:15:22:006] tag[INFO] module[STREAM_BUFF_INIT]        func[stream_buff_init]                    line[129]   video_info->resolution_size_ :1; width:640;height:360
[2021-08-07 23:15:22:006] tag[INFO] module[UTIL_MEDIA_BUFF]         func[util_media_buff_set_attr]            line[176]   height_:360
width_:640
channel_:1
framerate_:15
stream_format_:1
codec_type_:0
audio_bit_:0
audio_sample_:0
[2021-08-07 23:15:22:006] tag[INFO] module[STREAM_BUFF_INIT]        func[stream_buff_init]                    line[154]   STREAM_BUFF_INIT init success
[2021-08-07 23:15:22:006] tag[DEBG] module[VIDEO_INIT]              func[video_init]                          line[4516]  video [0] stream info:
enable_:1
video_encode_:0
resolution_size_:5
framerate_:15
bitrate_:1352000
gop_:20
bitrate_control_:2
osd_format_:0
osd_font_color_:0xffff
osd_edge_color_:0x8000
[2021-08-07 23:15:22:007] tag[DEBG] module[VIDEO_INIT]              func[video_init]                          line[4516]  video [1] stream info:
enable_:1
video_encode_:0
resolution_size_:1
framerate_:15
bitrate_:1
gop_:20
bitrate_control_:2
osd_format_:0
[2021-08-07 23:15:22:007] tag[DEBG] module[NET_MNG]                 func[net_notify_func_register]            line[737]   name:system_time
55aa030000010104
[2021-08-07 23:15:22:338] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:15:22:338] tag[INFO] module[   23.135397] set sensor mclk(0) gpio
[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:15:22:338] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:15:22:338] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
[2021-08-07 23:15:22:499] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[2021-08-07 23:15:22:499] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
55aa030000010104
[2021-08-07 23:15:22:538] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:15:22:539] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:15:22:539] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:15:22:539] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
[   23.360238] -----cv2003_detect: 1057 ret = 0, v = 0x20
[   23.366079] -----cv2003_detect: 1065 ret = 0, v = 0x03
[   23.371417] ===================================================
[   23.377544] Template version is V20241105a
[   23.381794] Sensor driver version is CVSENS.CV2003MP.songsii.V01.20250110
[   23.388818] Sensor name is cv2003
[   23.392254] Sensor chip found @ 0x36 (gate_i2c0)
[   23.397030] Sensor video interface is 0
[   23.401006] Sensor default boot is [0-->1920x1080@(30/1)fps]
[   23.406860] ===================================================
[   23.413401]  Create framechan0 OK! 
[   23.422508]  Create framechan1 OK! 
[   23.428296]  Create framechan2 OK! 
[   23.449786] ************************************************* 
[   23.455836] *********  ISP  Compiler: Oct 22 2024, 17:27:26   *********** 
[   23.463056] ************************************************* 
[   23.473722] [ISP][tisp_all_reset, 234]: isp all reset !!!
[   23.488505] [ISP][lib_tisp_get_isp_memory_space, 950]: width is 1920 
[   23.550642] [ISP][lib_tisp_set_isp_memory_space, 970]: vinum is 0
[2021-08-07 23:15:22:889] tag[INFO] module[MCU_UART]                func[mcu_uart_night_vision_status]        line[557]   mcu_uart_night_vision_status.
[2021-08-07 23:15:22:889] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(12), max length(196) ............
[2021-08-07 23:15:22:889] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
[2021-08-07 23:15:22:889] tag[INFO] module[MCU_UART]                func[mcu_uart_night_vision_status]        line[567]   UART_MSG_DPID_CONTROL DPID:0x90, status:0x0
[2021-08-07 23:15:22:890] tag[INFO] module[MCU_UART]                func[mcu_uart_ring_lamp_ctrl]             line[515]   mcu_uart_ring_lamp_ctrl.
[2021-08-07 23:15:22:890] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(12), max length(196) ............
[2021-08-07 23:15:22:890] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
[2021-08-07 23:15:22:890] tag[INFO] module[MCU_UART]                func[mcu_uart_ring_lamp_ctrl]             line[525]   UART_MSG_DPID_CONTROL DPID:0x8d, emoji:0x1
[2021-08-07 23:15:22:899] tag[DEBG] module[GPIO_CMD]                func[gpio_cmd_write]                      line[181]   gpioB8 write 1
[2021-08-07 23:15:22:900] tag[DEBG] module[GPIO_CMD]                func[gpio_cmd_write]                      line[181]   gpioB13 write 0
[2021-08-07 23:15:22:903] tag[DEBG] module[GPIO_CMD]                func[gpio_cmd_write]                      line[181]   gpioB14 write 1
55aa030700059004000100a3
[2021-08-07 23:15:22:938] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(12) success!
[2021-08-07 23:15:22:938] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:15:22:938] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x07, len:5
[2021-08-07 23:15:22:938] tag[INFO] module[MCU_UART]                func[process_message]                     line[842]   UART_MSG_STATUS_REPORT.
[2021-08-07 23:15:22:938] tag[ERRR] module[MCU_UART]                func[dispatch_dpid_msg]                   line[805]   invalid dpid:90
[2021-08-07 23:15:23:104] tag[DEBG] module[GPIO_CMD]                func[gpio_cmd_write]                      line[181]   gpioB13 write 0
[2021-08-07 23:15:2[   23.854854] Allocated 2 buffers!
3:104] tag[DEBG] module[GPIO_CMD]                func[gpio_cmd_write]                      line[181]   gpioB14 write 0
[2021-08-07 23:15:23:10[   23.873309] Allocated 2 buffers!
4] tag[ERRR] module[VIDEO_INIT]              func[isp_mode_set]                        line[4305]  IMP_ISP_Tuning_SetHVFLIP fail,hvflip:0
[2021-08-07 23:15:23:108] tag[DEBG] module[VIDEO_INIT]              func[_isp_init]                           line[3980]  video init result:0
[2021-08-07 23:15:23:108] tag[DEBG] module[VIDEO_INIT]              func[_isp_init]                           line[3989]  imp system init success
[2021-08-07 23:15:23:109] tag[DEBG] module[VIDEO_INIT]              func[_framesource_init]                   line[3715]  _framesource_init success
[2021-08-07 23:15:23:109] tag[DEBG] module[VIDEO_INIT]              func[_group_init]                         line[3589]  group init start
[2021-08-07 23:15:23:110] tag[DEBG] module[VIDEO_INIT]              func[_group_init]                         line[3613]  group init success
i265e[info]: Main profile, Level-4 (Main tier)
i265e[info]: Main profile, Level-2.1 (Main tier)
[2021-08-07 23:15:23:134] tag[DEBG] module[VIDEO_INIT]              func[_osd_init]                           line[2543]  stream_index:0,time_rgn_handle:0
[2021-08-07 23:15:23:134] tag[DEBG] module[VIDEO_INIT]              func[_osd_init]                           line[2543]  stream_index:1,time_rgn_handle:1
[2021-08-07 23:15:23:135] tag[DEBG] module[VIDEO_INIT]              func[_osd_init]                           line[2804]  _osd_init success
55aa030700058d04000101a1
[2021-08-07 23:15:23:147] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(12) success!
[2021-08-07 23:15:23:147] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:15:23:147] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x07, len:5
[2021-08-07 23:15:23:147] tag[INFO] module[MCU_UART]                func[process_message]                     line[842]   UART_MSG_STATUS_REPORT.
[2021-08-07 23:15:23:147] tag[INFO] module[MCU_UART]                func[dispatch_dpid_msg]                   line[801]   MSG_DPID_TYPE_RING_LAMP:0x1
[2021-08-07 23:15:23:164] tag[DEBG] module[VIDEO_INIT]              func[_framesource_on]                     line[1534]  _framesource_on success
[2021-08-07 23:15:23:164] tag[DEBG] module[VIDEO_INIT]              func[video_init]                          line[4644]  VIDEO_INIT init success
[2021-08-07 23:15:23:166] tag[DEBG] module[SNAP_INIT]               func[snap_init]                           line[510]   SNAP_INIT init success
[2021-08-07 23:15:23:166] tag[DEBG] module[AUDIO_INIT]              func[_ai_init]                            line[1202]  ai attr:
samplerate:16000
bitwidth:16
soundmode:1
frmNum:20
numPerFrm:320
chnCnt:1
[2021-08-07 23:15:23:241] tag[DEBG] module[AUDIO_INIT]              func[_ai_init]                            line[1237]  ai chn param:
usrFrmDepth:20
aecChn:0
warn: shm_init,53shm init already
[2021-08-07 23:15:23:242] tag[DEBG] module[AUDIO_INIT]              func[_ai_init]                            line[1264]  ai_vol:80
[2021-08-07 23:15:23:301] tag[DEBG] module[AUDIO_INIT]              func[_ai_init]                            line[1283]  ai_gain:28
aec version: v2.1.201201 in webrtc_profile.ini and v2.1.231101 in aec lib.
PATH:AEC_PATH is empty,normal audio library
[2021-08-07 23:15:23:592] tag[DEBG] module[AUDIO_INIT]              func[_ai_init]                            line[1335]  _ai_init success
[2021-08-07 23:15:23:599] tag[DEBG] module[AUDIO_INIT]              func[_aenc_init]                          line[1116]  _aenc_init success
[2021-08-07 23:15:23:599] tag[DEBG] module[AUDIO_INIT]              func[_adec_init]                          line[1055]  _adec_init success
[2021-08-07 23:15:23:601] tag[INFO] module[AUDIO_INIT]              func[turn_on_spk]                         line[94]    spk_power_pin level : 0
[2021-08-07 23:15:23:601] tag[DEBG] module[GPIO_CMD]                func[gpio_cmd_write]                      line[181]   gpioB31 write 1
[2021-08-07 23:15:23:601] tag[DEBG] module[AUDIO_INIT]              func[_ao_init]                            line[820]   ao attr:
samplerate:8000
bitwidth:16
soundmode:1
frmNum:20
numPerFrm:320
chnCnt:1
[2021-08-07 23:15:23:682] tag[DEBG] module[AUDIO_INIT]              func[_ao_init]                            line[870]   ao_gain:23
[2021-08-07 23:15:23:682] tag[DEBG] module[AUDIO_INIT]              func[_ao_init]                            line[928]   _ao_init success
[2021-08-07 23:15:23:682] tag[INFO] module[AUDIO_INIT]              func[audio_init]                          line[1897]  AUDIO_INIT init success
[2021-08-07 23:15:23:682] tag[INFO] module[IR_CUT]                  func[ircut_init]                          line[433]   IR_CUT init success
[2021-08-07 23:15:23:683] tag[INFO] module[MISC]                    func[misc_key_init]                       line[318]   start init key
[2021-08-07 23:15:23:683] tag[INFO] module[MISC]                    func[misc_key_init]                       line[332]   init key success
[2021-08-07 23:15:23:683] tag[INFO] module[MCU_UART]                func[mcu_uart_ring_lamp_ctrl]             line[515]   mcu_uart_ring_lamp_ctrl.
[2021-08-07 23:15:23:683] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(12), max length(196) ............
[2021-08-07 23:15:23:683] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
[2021-08-07 23:15:23:683] tag[INFO] module[MCU_UART]                func[mcu_uart_ring_lamp_ctrl]             line[525]   UART_MSG_DPID_CONTROL DPID:0x8d, emoji:0x1
[2021-08-07 23:15:23:683] tag[INFO] module[MCU_UART]                func[mcu_uart_set_laser_pointer]          line[494]   mcu_uart_set_laser_pointer.
[2021-08-07 23:15:23:684] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(12), max length(196) ............
[2021-08-07 23:15:23:684] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
[2021-08-07 23:15:23:684] tag[INFO] module[MCU_UART]                func[mcu_uart_set_laser_pointer]          line[504]   UART_MSG_DPID_CONTROL DPID:0x86, speed:0x0
[2021-08-07 23:15:23:684] tag[INFO] module[MCU_UART]                func[mcu_uart_set_move_speed]             line[473]   mcu_uart_set_move_speed.
[2021-08-07 23:15:23:684] tag[INFO] module[MCU_UART]                func[mcu_uart_set_move_speed]             line[483]   UART_MSG_DPID_CONTROL DPID:0x8c, speed:0x32
[2021-08-07 23:15:23:684] tag[DEBG] module[MISC]                    func[misc_init]                           line[499]   MISC init success
[2021-08-07 23:15:23:685] tag[DEBG] module[QRCODE]                  func[qrcode_init]                         line[628]   QRCODE init start
[2021-08-07 23:15:23:696] tag[INFO] module[MISC]                    func[key_event_listener]                  line[192]   Start read key event
[2021-08-07 23:15:23:719] tag[INFO] module[PROMPT_TONE]             func[prompt_tone_init]                    line[491]   PROMPT_TONE init success
[2021-08-07 23:15:23:719] tag[INFO] module[QRCODE]                  func[qrcode_init]                         line[682]   QRCODE init success
[2021-08-07 23:15:23:720] tag[INFO] module[PLATFORM_TY]             func[platform_init]                       line[1762]  sdk init start>>>>>>>>>>>>
[2021-08-07 23:15:23:720] tag[DEBG] module[ALARM_MNG]               func[alarm_mng_func_register]             line[169]   cb:0x45c6e0
[2021-08-07 23:15:23:727] tag[DEBG] module[VIDEO_INIT]              func[framesource_depth_set]               line[4076]  cur_depth:0,depth:1
[2021-08-07 23:15:23:727] tag[DEBG] module[PROMPT_TONE]             func[_prompt_tone_thread]                 line[183]   adec_format:2,play_item_type:41
[2021-08-07 23:15:23:738] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(12) success!
[2021-08-07 23:15:23:738] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:15:24:070] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x07, len:5
[2021-08-07 23:15:24:070] tag[INFO] module[MCU_UART]                func[process_message]                     line[842]   UART_MSG_STATUS_REPORT.
[2021-08-07 23:15:24:070] tag[INFO] module[MCU_UART]                func[dispatch_dpid_msg]                   line[801]   MSG_DPID_TYPE_RING_LAMP:0x1
[2021-08-07 23:15:23:766] tag[DEBG] module[QRCODE]                  func[_qrcode_thread]                      line[454]   yuv data buff malloc success!!!
[2021-08-07 23:15:23:788] tag[WARN] module[PLATFORM_TY]             func[platform_init]                       line[1826]  udid:uuida4c86e451c399c33,key:AmER9q1SPBjfkErpGgyqLjNHTsuRrCQp
[2021-08-07 23:15:24:073] tag[INFO] module[PLATFORM_TY]             func[platform_init]                       line[1847]  firmware version str:V1.0.13
[2021-08-07 23:15:24:073] tag[INFO] module[PLATFORM_TY]             func[platform_init]                       line[1849]  firmware version :1.0.13
SDK Version:< TuyaOS V:6.2.6 BS:40.00_PT:2.3_LAN:3.5_CAD:1.0.5_CD:1.0.0 >
< BUILD AT:2025_04_03_11_22_47 BY dandi.guo FOR tuyaos-ipc AT T32_uclibc_r3.3.7 >
IOT DEFS < WIFI_GW:1 DEBUG:0 KV_FILE:0 LITTLE_END:1 SL:1 OPERATING_SYSTEM:100 RELIABLE_TRANSFER:0 >
MODE:1  LINK_TYPE:5 IP_MODE_TYPE:0
[01-01 00:00:00 ty I][1e80][tal_thread.c:185] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[01-01 00:00:00 ty I][1e80][tal_thread.c:185] thread_create name:wq_system,stackDepth:6144,totalstackDepth:10240,priority:3
[01-01 00:00:00 ty I][1e80][tal_thread.c:185] thread_create name:wq_highpri,stackDepth:5120,totalstackDepth:15360,priority:4
tkl_wifi_init-173  called
[01-01 00:00:00 ty I][1e80][tal_thread.c:185] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:16896,priority:5
[01-01 00:00:00 ty I][1e80][mqc_app.c:490] mqc app init ...
[01-01 00:00:00 ty E][1e80][log_seq.c:861] open err
[01-01 00:00:00 ty I][1e80][kv_storge.c:45] Init Kvs With File:/mnt/config/
55aa0307000586040001009955aa030700058c04000132d1
[2021-08-07 23:15:24:271] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(24) success!
[2021-08-07 23:15:24:740] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:15:24:740] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x07, len:5
[2021-08-07 23:15:24:741] tag[INFO] module[MCU_UART]                func[process_message]                     line[842]   UART_MSG_STATUS_REPORT.
[2021-08-07 23:15:24:741] tag[INFO] module[MCU_UART]                func[dispatch_dpid_msg]                   line[797]   MSG_DPID_TYPE_LASER_POINTER:0x0
[2021-08-07 23:15:24:741] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x07, len:5
[2021-08-07 23:15:24:741] tag[ERRR] module[MCU_UART]                func[dispatch_dpid_msg]                   line[805]   invalid dpid:8C
WIFI mode[0] Get IP failed
wifi_status_event_cb-155 set wf event[2]
[01-01 00:00:00 ty N][1e80][tuya_tls.c:876] uni_random_init...
[01-01 00:00:00 ty N][1e80][tuya_tls.c:303] tuya_tls_rand_init ok!
[01-01 00:00:00 ty N][1e80][tuya_svc_devos.c:338] gw_cntl->gw_wsm.stat:0
[01-01 00:00:00 ty D][1e80][tuya_ipc_media_adapter.c:101] media adapter init success. avaliable_res_size:5000
[01-01 00:00:00 ty D][1e80][tuya_ipc_media_adapter.c:511] insert media info node success! device:[0] channel:[0]
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:0 Enable:1
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:717] video_bitrate 768, video_fps 15
[01-01 00:00:00 ty D][1e80][tuya_ring_buffer.c:649] Init Ring Buffer. ch0st0tr0 bitrate:768 fps:15
[01-01 00:00:00 ty D][1e80][tuya_ring_buffer.c:672] Ring buffer malloc 589824 bytes for ch0st0tr0, max frame size 147456
[01-01 00:00:00 ty I][1e80][tuya_ring_buffer.c:694] Init Ring Buffer success: ch0st0tr0 size:589824 nodes:90
[01-01 00:00:00 ty T][1e80][tuya_ring_buffer.c:148] ch0st0tr0 release ref count: 0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:725] init ring buffer success. channel:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:1 Enable:1
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:717] video_bitrate 256, video_fps 15
[01-01 00:00:00 ty D][1e80][tuya_ring_buffer.c:649] Init Ring Buffer. ch0st0tr1 bitrate:256 fps:15
[01-01 00:00:00 ty D][1e80][tuya_ring_buffer.c:672] Ring buffer malloc 196608 bytes for ch0st0tr1, max frame size 49152
[01-01 00:00:00 ty I][1e80][tuya_ring_buffer.c:694] Init Ring Buffer success: ch0st0tr1 size:196608 nodes:90
[01-01 00:00:00 ty T][1e80][tuya_ring_buffer.c:148] ch0st0tr1 release ref count: 0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:725] init ring buffer success. channel:1
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:2 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:3 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:4 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:5 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:6 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:7 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:8 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:9 Enable:1
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:708] audio_sample 16000, audio_databits 16, audio_fps 25
[01-01 00:00:00 ty D][1e80][tuya_ring_buffer.c:649] Init Ring Buffer. ch0st0tr9 bitrate:250 fps:25
[01-01 00:00:00 ty D][1e80][tuya_ring_buffer.c:672] Ring buffer malloc 192000 bytes for ch0st0tr9, max frame size 48000
[01-01 00:00:00 ty I][1e80][tuya_ring_buffer.c:694] Init Ring Buffer success: ch0st0tr9 size:192000 nodes:150
[01-01 00:00:00 ty T][1e80][tuya_ring_buffer.c:148] ch0st0tr9 release ref count: 0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:725] init ring buffer success. channel:9
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:10 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:11 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:12 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:13 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:14 Enable:0
[01-01 00:00:00 ty D][1e80][ty_sdk_media_callback.c:699] init ring buffer Channel:0 Stream:15 Enable:0
[01-01 00:00:00 ty D][1e80][simplekv.c:1133] read key:gw_bi isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][1e80][simplekv.c:1164] find key:1 gw_bi
[01-01 00:00:00 ty D][1e80][simplekv.c:1190] key:gw_bi find value.Len:224
[01-01 00:00:00 ty D][1e80][tuya_ws_db.c:667] sync to protected len[223]
[01-01 00:00:00 ty D][1e80][ws_db_gw.c:148] gw_bi read ret:0
[01-01 00:00:00 ty D][1e80][tuya_wifi_link.c:901] tuya wifi link init mthd:0,wifi start mode:0, enable_station_ap:0
[01-01 00:00:01 ty D][1e80][simplekv.c:1133] read key:gw_wsm isFuzzy:0 skipCnt:0
[01-01 00:00:01 ty D][1e80][simplekv.c:1164] find key:2 gw_wsm
[01-01 00:00:01 ty D][1e80][simplekv.c:1190] key:gw_wsm find value.Len:192
[01-01 00:00:01 ty D][1e80][tuya_ws_db.c:667] sync to protected len[188]
[01-01 00:00:01 ty D][1e80][ws_db_gw.c:259] gw_wsm read ret:0
[01-01 00:00:01 ty N][1e80][tuya_wifi_link.c:85] start wifi link params validate, nc_tp:2 md:0
[01-01 00:00:01 ty N][1e80][tuya_wifi_link.c:107] gw_wsm.nc_tp:2
[01-01 00:00:01 ty N][1e80][tuya_wifi_link.c:108] gw_wsm.md:0
[01-01 00:00:01 ty D][1e80][tuya_bt_link.c:294] bt init...
[01-01 00:00:01 ty D][1e80][tuya_svc_netmgr_linkage.c:86] link[3] is registered [2]
[01-01 00:00:01 ty D][1e80][tuya_ble_svc.c:2325] get_wifi_list eanbled
[01-01 00:00:01 ty D][1e80][tuya_ble_svc.c:2331] get_netcfg_stat eanbled
[01-01 00:00:01 ty D][1e80][tuya_ble_svc.c:2335] get_dev_log eanbled
[01-01 00:00:01 ty D][1e80][tuya_ble_svc.c:2341] get_ap_name eanbled
[01-01 00:00:01 ty D][1e80][simplekv.c:1133] read key:wf_start_md isFuzzy:0 skipCnt:0
[01-01 00:00:01 ty D][1e80][simplekv.c:1161] no key find
[01-01 00:00:01 ty D][1e80][simplekv.c:1203] __read_kv_raw fail. -3
[01-01 00:00:01 ty D][1e80][simplekv.c:1242] __read_kv_with_decode fail. -3
[01-01 00:00:01 ty E][1e80][tuya_wifi_reset.c:675] read wf start mode err:-6
[01-01 00:00:01 ty D][1e80][tuya_wifi_reset.c:712] <__gw_upd_nc_type> wf start mode change:-6, 0->0
[01-01 00:00:01 ty N][1e80][tuya_svc_devos.c:563] Last reset reason: 7
[01-01 00:00:01 ty D][1e80][simplekv.c:1133] read key:gw_di isFuzzy:0 skipCnt:0
[01-01 00:00:01 ty D][1e80][simplekv.c:1164] find key:3 gw_di
[01-01 00:00:01 ty D][1e80][simplekv.c:1190] key:gw_di find value.Len:672
[01-01 00:00:01 ty D][1e80][ws_db_gw.c:376] gw_di read ret:0
[01-01 00:00:01 ty D][1e80][simplekv.c:1133] read key:is_stride isFuzzy:0 skipCnt:0
[01-01 00:00:01 ty D][1e80][tuya_devos_stride.c:55] stride from flash: 0.
[01-01 00:00:01 ty D][1e80][tuya_devos_stride.c:62] no actived, no upgrade:0
[01-01 00:00:01 ty N][1e80][tuya_svc_devos.c:395] gw_cntl->gw_if.abi:0 input:0
[01-01 00:00:01 ty N][1e80][tuya_svc_devos.c:396] gw_cntl->gw_if.product_key:jtpzscc43s2fzaff, input:jtpzscc43s2fzaff
[01-01 00:00:01 ty N][1e80][tuya_svc_devos.c:397] gw_cntl->gw_if.tp:0, input:0
[01-01 00:00:01 ty N][1e80][tuya_svc_devos.c:596] enter success_proc
WIFI Get MAC 00-00-00-00-00-00
[01-01 00:00:01 ty N][1e80][tuya_svc_devos.c:599] serial_no:000000000000
[01-01 00:00:01 ty D][1e80][tuya_svc_upgrade.c:1369] tuya svc upgrade init success!
[01-01 00:00:01 ty D][1e80][simplekv.c:1133] read key:kv.meta.report isFuzzy:0 skipCnt:0
[01-01 00:00:01 ty D][1e80][ty_meta_report.c:111] meta in kv {"metas":{}}
[01-01 00:00:01 ty D][1e80][mqc_app.c:109] mq_pro:300 cnt:3
[01-01 00:00:01 ty D][1e80][mqc_app.c:109] mq_pro:302 cnt:4
[01-01 00:00:01 ty D][1e80][mqc_app.c:109] mq_pro:304 cnt:5
[01-01 00:00:01 ty D][1e80][mqc_app.c:109] mq_pro:307 cnt:6
[01-01 00:00:01 ty D][1e80][mqc_app.c:109] mq_pro:308 cnt:7
[01-01 00:00:01 ty D][1e80][mqc_app.c:109] mq_pro:312 cnt:8
[01-01 00:00:01 ty D][1e80][tuya_ipc_mqtt_subscribe.c:292] iot_register_extra_mqt_cb done
[01-01 00:00:01 ty T][1e80][tuya_ring_buffer.c:127] ch0st0tr0 get ref count: 1
[01-01 00:00:01 ty T][1e80][tuya_ring_buffer.c:148] ch0st0tr0 release ref count: 0
[01-01 00:00:01 ty T][1e80][tuya_ring_buffer.c:127] ch0st0tr1 get ref count: 1
[01-01 00:00:01 ty T][1e80][tuya_ring_buffer.c:148] ch0st0tr1 release ref count: 0
[01-01 00:00:01 ty D][1e80][tuya_ipc_hardware_info.c:252] traversal over
[01-01 00:00:01 ty E][1e80][tuya_ipc_hardware_info.c:173] NO sensor info. Please check if you need.
[01-01 00:00:01 ty D][1e80][tuya_ipc_hardware_info.c:115] not found device wifi info
[01-01 00:00:01 ty D][1e80][tuya_ipc_hardware_info.c:355] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":1,\"webrtc\":2,\"p2p\":611,\"security_ability\":30,\"video_num\":2,\"sdk_version\":\"6.2.6\"},\"hardware\":{\"toolchain\":\"T32_uclibc_r3.3.7\",\"cpu\":{\"model\":\"Goat\",\"bogomips\":\"1196.85\",\"name\":\"Ingenic Xburst V0.0  FPU V0.0\"}}
[01-01 00:00:01 ty D][1e80][tuya_ipc_sdk_init.c:426] debug ability:2
[01-01 00:00:01 ty D][1e80][tuya_iot_wifi_api.c:452] register wifi network monitor. interval:1
[01-01 00:00:01 ty D][1e80][platform_ty.c:1549] tuya ipc sdk start is complete
[01-01 00:00:01 ty D][ee84][tuya_svc_devos.c:854] state change from 0 to 1
[01-01 00:00:01 ty D][ee84][ty_sdk_status_callback.c:103] status chaged: group[1] status[9]
[01-01 00:00:01 ty D][ee84][ty_sdk_status_callback.c:39] __on_netcfg_start, netcfg start. You can start your own netcfg task now.
[01-01 00:00:01 ty D][ee84][simplekv.c:1133] read key:wf_start_md isFuzzy:0 skipCnt:0
[01-01 00:00:01 ty D][ee84][simplekv.c:1161] no key find
[01-01 00:00:01 ty D][ee84][simplekv.c:1203] __read_kv_raw fail. -3
[01-01 00:00:01 ty D][ee84][simplekv.c:1242] __read_kv_with_decode fail. -3
[01-01 00:00:01 ty E][ee84][tuya_wifi_reset.c:675] read wf start mode err:-6
[01-01 00:00:01 ty D][ee84][tuya_wifi_reset.c:712] <__gw_upd_nc_type> wf start mode change:-6, 0->0
[01-01 00:00:01 ty D][ee84][simplekv.c:1133] read key:kv.ccode.avtive isFuzzy:0 skipCnt:0
[01-01 00:00:01 ty D][ee84][simplekv.c:[   26.477778] [atbm_log]:ioctl:cmd[SIOCGIWNWID][0x8b03] not support
1161] no key find
Set Country Code:0 
Exec Cmd:ifconfig wlan0 up 
Exec Cmd:iwconfig wlan0 mode Managed 
WIFI Set Mode 2
[01-01 00:00:01 ty D][ee84][tuya_wifi_reset.c:596] reset init mthd:0, short timer:0 long timer:0
[   26.542182] [atbm_log]:ioctl:cmd[SIOCGIWNICKN][0x8b1d] not support
[   26.579837] [atbm_log]:ioctl:cmd[SIOCGIWSENS][0x8b09] not support
WIFI Get Mode [Managed] 2
[01-01 00:00:01 ty D][ee84][tuya_wifi_netcfg.c:437] do proxy actived work,mode:2,stat:0,nc_tp:2
[01-01 00:00:01 ty D][ee84][tuya_wifi_netcfg.c:734] nc_tp:2, md:0
WIFI Set Mode 2
[01-01 00:00:01 ty D][ee84][netcfg_module.c:133] type:0x10002,is_set:0
[01-01 00:00:01 ty D][ee84][netcfg_module.c:133] type:0x10100,is_set:0
[01-01 00:00:01 ty D][ee84][netcfg_module.c:133] type:0x10002,is_set:1
[   26.762603] [atbm_log]:ioctl:cmd[SIOCGIWNWID][0x8b03] not support
[   26.817524] [atbm_log]:ioctl:cmd[SIOCGIWNICKN][0x8b1d] not support
[   26.854674] [atbm_log]:ioctl:cmd[SIOCGIWSENS][0x8b09] not support
[01-01 00:00:02 ty D][ee84][tuya_wifi_link.c:140] get work mode:2
[01-01 00:00:02 ty D][ee84][tuya_wifi_link.c:147] start ap netcfg, wk_md:3
WIFI Set Mode 3
[01-01 00:00:02 ty E][ee84][tuya_wifi_link.c:151] wf_wk_mode_set error:-1
[01-01 00:00:02 ty E][ee84][netcfg_module.c:136] ret:-1
[01-01 00:00:02 ty D][ee84][netcfg_module.c:133] type:0x10002,is_set:0
[01-01 00:00:02 ty D][ee84][netcfg_module.c:133] type:0x10100,is_set:0
[   26.992619] [atbm_log]:ioctl:cmd[SIOCGIWNWID][0x8b03] not support
[   27.047469] [atbm_log]:ioctl:cmd[SIOCGIWNICKN][0x8b1d] not support
[   27.086139] [atbm_log]:ioctl:cmd[SIOCGIWSENS][0x8b09] not support
[01-01 00:00:02 ty N][ee84][tuya_wifi_status.c:167] cur stat:2  0x4c3644 -->>
[01-01 00:00:02 ty N][ee84][tuya_wifi_status.c:169] wifi netstat changed to:2  -->>
[01-01 00:00:02 ty N][ee84][tuya_wifi_status.c:173] report wifi netstat[2] to callback  -->>
[01-01 00:00:02 ty E][ee84][tuya_ipc_sdk_init.c:345] wf nw status changed to [2], but not notify
[01-01 00:00:02 ty D][ee84][netcfg_module.c:338] netcfg module start type:0x10100
[01-01 00:00:02 ty N][ee84][tuya_wifi_reset.c:438] timer stated, short timer:0x0, long timer:0x0
[01-01 00:00:02 ty D][ee84][tuya_wifi_netcfg.c:815] nc_tp:2, md:0
[01-01 00:00:02 ty N][ee84][tuya_bt_link.c:62] bt startup attr:ff
[01-01 00:00:02 ty D][ee84][tuya_bt_link.c:77] bt link open
[01-01 00:00:02 ty N][ee84][tuya_ble_svc.c:1199] upd product_id type:0 jtpzscc43s2fzaff
[01-01 00:00:02 ty D][ee84][simplekv.c:1133] read key:bt_encrpt_v2 isFuzzy:0 skipCnt:0
[01-01 00:00:02 ty D][ee84][simplekv.c:1161] no key find
[01-01 00:00:02 ty D][ee84][simplekv.c:1203] __read_kv_raw fail. -3
[01-01 00:00:02 ty D][ee84][simplekv.c:1242] __read_kv_with_decode fail. -3
[01-01 00:00:02 ty D][ee84][tuya_ble_cryption.c:491] read encrpt flag from flash: 0.
==================tkl_ble_gap_callback_register=================
==================tkl_ble_gatt_callback_register=================
==================tkl_ble_stack_init=================
[01-01 00:00:02 ty D][ee84][tuya_ble_svc.c:1115] rev ble event 1
[01-01 00:00:02 ty D][ee84][tuya_ble_svc.c:1768] set ble serv stat:0, curr:0
[tkl_ble_stack_init:1537] role:3 
==================tkl_ble_gatts_service_add=================
[tkl_ble_gatts_service_add:2041] p_service->svc_num:0x1 
[tkl_ble_gatts_service_add:2042] p_service->p_service->handle:0xffff 
[tkl_ble_gatts_service_add:2043] p_service->p_service->svc_uuid:0 
[tkl_ble_gatts_service_add:2044] p_service->p_service->type:0x2800 
[tkl_ble_gatts_service_add:2045] p_service->p_service->char_num:0x3 
register gatt service, num: 1
[tkl_ble_gatts_service_add:2055] i=0,  p_service_param->svc_uuid.uuid_type:0 
[tkl_ble_gatts_service_add:2056] i=0,  p_service_param->handle:0xffff 
[tkl_ble_gatts_service_add:2057] i=0,  p_service_param->type:0x2800 
[tkl_ble_gatts_service_add:2058] i=0,  p_service_param->svc_uuid.uuid.uuid16:0xfd50 
[tkl_ble_gatts_service_add:2059] i=0,  p_service_param->char_num:0x3 
[tkl_ble_gatts_service_add:2061] i=0,  p_service_param->p_char[0].char_uuid.uuid_type:0x2 
[tkl_ble_gatts_service_add:2062] i=0,  p_service_param->p_char[0].char_uuid.uuid128:0xb942d0 
[tkl_ble_gatts_service_add:2063] i=0,  p_service_param->p_char[0].handle:0xffff 
[tkl_ble_gatts_service_add:2064] i=0,  p_service_param->p_char[0].permission:0x6 
[tkl_ble_gatts_service_add:2065] i=0,  p_service_param->p_char[0].property:0xc 
[tkl_ble_gatts_service_add:2066] i=0,  p_service_param->p_char[0].value_len:0xf4 
[tkl_ble_gatts_service_add:2061] i=0,  p_service_param->p_char[1].char_uuid.uuid_type:0x2 
[tkl_ble_gatts_service_add:2062] i=0,  p_service_param->p_char[1].char_uuid.uuid128:0xb942ec 
[tkl_ble_gatts_service_add:2063] i=0,  p_service_param->p_char[1].handle:0xffff 
[tkl_ble_gatts_service_add:2064] i=0,  p_service_param->p_char[1].permission:0x6 
[tkl_ble_gatts_service_add:2065] i=0,  p_service_param->p_char[1].property:0x10 
[tkl_ble_gatts_service_add:2066] i=0,  p_service_param->p_char[1].value_len:0xf4 
[tkl_ble_gatts_service_add:2061] i=0,  p_service_param->p_char[2].char_uuid.uuid_type:0x2 
[tkl_ble_gatts_service_add:2062] i=0,  p_service_param->p_char[2].char_uuid.uuid128:0xb94308 
[tkl_ble_gatts_service_add:2063] i=0,  p_service_param->p_char[2].handle:0xffff 
[tkl_ble_gatts_service_add:2064] i=0,  p_service_param->p_char[2].permission:0x2 
[tkl_ble_gatts_service_add:2065] i=0,  p_service_param->p_char[2].property:0x2 
[tkl_ble_gatts_service_add:2066] i=0,  p_service_param->p_char[2].value_len:0xf4 
[tkl_ble_gatts_service_add:2085] i=0,  p_service_param->type:0x2800 
--- tuya_conn_handle :fd50
str_uuid_buf:00000001-0000-1001-8001-00805f9b07d0 
p_service_param->p_char[0].handle:1
str_uuid_buf:00000002-0000-1001-8001-00805f9b07d0 
p_service_param->p_char[1].handle:2
str_[   27.486962] [atbm_log]:ioctl_open(80cbf100)(81b19700)
uuid_buf:00000003-0000-1001-8001-00805f9b07d0 
p_service_param->p_char[2].handle:3
[01-01 00:00:02 ty D][ee84][tuya_ble_svc.c:1626] start ble monitor
[01-01 00:00:02 ty N][ee84][tuya_ble_svc.c:1294] ty bt sdk init success finish
[01-01 00:00:02 ty D][ee84][tuya_ble_netcfg.c:153] net_cfg sub session created
[01-01 00:00:02 ty D][ee84][tuya_ble_svc.c:2298] get_wifi_list sub [   27.525566] [atbm_log]:atbm_ioctl_ble_start
session created
[01-01 00:00:02 ty D][ee84][tuya_ble_svc.c:2302] get_netcfg_stat sub session created
[01-01 00:00:02 ty D][ee84][tuya_ble_svc.c:2306] get_dev_log sub session created
[01-01 00:00:02 ty D][ee84][tuya_ble_svc.c:2310] get_ap_name sub session created
==================tkl_ble_gap_adv_start=================
lib_ble_main_init
======>>atbm_ble_start>>>
nimble_port_init++
os_mempool_module_init
msys block_count:20
ble_npl_eventq_main
acl block_count:40
nimble_host_task
FD_CLOEXEC set
ble_coexist_start--
ble_hs_sync:333
hif_ioctl_loop
get_command_func
ble_hs_hci_cmd_tx:352
===========ble_hci_sync_ok
ble_smart_cfg_startup!11
[ATBM lOG]set default tx power(0)
[01-01 00:00:02 ty N][ee84][tuya_svc_devos.c:246] __devos_init_evt success
[01-01 00:00:02 ty D][ee84][netcfg_module.c:116] start 0x10100 ret:0
[01-01 00:00:02 ty D][ee84][netcfg_module.c:338] netcfg module start type:0x10002
[01-01 00:00:02 ty D][ee84][tuya_ble_svc.c:244] upd adv para, send conn_req beacon.
[01-01 00:00:02 ty D][ee84][tuya_ble_svc.c:115] adv_data 31 <0x12329e1>
02 01 06 03 02 50 fd 17 16 50 fd 43 04 00 10 6a 74 70 7a 73 63 63 34 33 73 32 66 7a 61 66 66 
[01-01 00:00:02 ty D][ee84][tuya_ble_svc.c:115] rsp_data 31 <0x1232a01>
17 ff d0 07 00 00 04 21 e1 0f 16 2d 0b b3 ba 65 28 ce 77 19 9c 09 5f eb 06 09 54 55 59 41 5f 
[01-01 00:00:02 ty D][ee84][tuya_ble_svc.c:1665] ble get conn stat:4
==================tkl_ble_gap_adv_stop=================
==================tkl_ble_gap_adv_rsp_data_set=================
[tkl_ble_gap_adv_rsp_data_set:1773] 0x2 0x1 0x6 0x3 0x2 0x50 0xfd 0x17 0x16 0x50 0xfd 0x43 0x4 0 0x10 0x6a 0x74 0x70 0x7a 0x73 0x63 0x63 0x34 0x33 0x73 0x32 0x66 0x7a 0x61 0x66 0x66 
error lib_ble_main_init already!
[01-01 00:00:02 ty N][ee84][tuya_ble_svc.c:1381] ble adv updated
[01-01 00:00:02 ty D][ee84][ap_netcfg.c:1464] ap cfg start:65538
[01-01 00:00:02 ty E][ee84][ap_netcfg.c:1338] get ip fail:-1
[01-01 00:00:02 ty E][ee84][ap_netcfg.c:1469] ap_nw_cfg_start err:-6
[01-01 00:00:02 ty D][ee84][netcfg_module.c:116] start 0x10002 ret:-6
pub addr 60:56:ee:16:81:03
Ingenic-uc1_1 login: [2021-08-07 23:15:30:419] tag[INFO] module[PROMPT_TONE]             func[_prompt_tone_thread]                 line[364]   _prompt_tone_thread exit
[2021-08-07 23:15:37:500] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[2021-08-07 23:15:37:500] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
55aa030000010104
[2021-08-07 23:15:37:538] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:15:37:538] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:15:37:539] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:15:37:539] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
root
Aug  7 23:15:40 login[71]: root login on 'console'
[root@Ingenic-uc1_1:~]# [2021-08-07 23:15:52:500] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[2021-08-07 23:15:52:500] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
55aa030000010104
[2021-08-07 23:15:52:538] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:15:52:538] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:15:52:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:15:52:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
[2021-08-07 23:16:07:501] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[2021-08-07 23:16:07:501] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
55aa030000010104
[2021-08-07 23:16:07:538] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:16:07:538] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:16:07:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:16:07:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
ble_slave_gap_event->type=0
connection established; status=0 connection, handle=1
[ble_gap_event:107]send event type:4 (TKL_BLE_GAP_EVT_CONNECT)
[ble_gap_event:108]gap_evt.conn_handle :64848
gf:TAL_BLE_EVT_PERIPHERAL_CONNECT, result :0
[01-01 00:00:47 ty D][e574][tuya_ble_svc.c:1115] rev ble event 4
[01-01 00:00:47 ty N][e574][tuya_ble_svc.c:746] Ble Connected
[01-01 00:00:47 ty N][e574][tuya_ble_data_handler.c:69] ble reset sn
[01-01 00:00:47 ty N][e574][tuya_ble_svc.c:1659] ble set conn stat:1
[01-01 00:00:47 ty D][e574][tuya_ble_svc.c:1152] conn monitor timer started
ble_slave_gap_event->type=15
mtu update event; conn_handle=1 cid=4 mtu=247
ble_slave_gap_event->type=4
connection update request
[ble_gap_event:147]send event type:8 (TKL_BLE_GAP_EVT_CONN_PARAM_REQ)
[ble_gap_event:148]gap_evt.conn_handle :28420
ble_slave_gap_event->type=3
connection updated; status=0  conn_itvl=6 conn_latency=3 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[ble_gap_event:131]send event type:9 (TKL_BLE_GAP_EVT_CONN_PARAM_UPDATE)
[ble_gap_event:132]gap_evt.conn_handle :1
connection updated; status=0  conn_itvl=24 conn_latency=3 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2021-08-07 23:16:22:501] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[2021-08-07 23:16:22:502] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
55aa030000010104
[2021-08-07 23:16:22:538] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:16:22:538] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:16:22:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:16:22:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
[ble_svc_gatt_access:224] ble_uuid_u16(ctxt->chr->uuid) >> uuid:0
[ble_svc_gatt_access:225] ctxt->chr->flags:0xc
max_data_len=1024 
Len=20 
att=0x0 0x1 0x2 0x3 0x4 0x5 0x6 0x7 0x8 0x9 0x0 0x1 0x2 0x3 0x4 0x5 0x6 0x7 0x8 0x9 
[ble_svc_gatt_access:259]send gatt event type:7 (TKL_BLE_GATT_EVT_WRITE_REQ)
[ble_svc_gatt_access:260]event.gatt_event.write_report.char_handle :1
gf:p_event->ble_event.write_report.peer.char_handle[0] = 1
gf:ble_peripheral_info.char_handle[TAL_COMMON_WRITE_CHAR_INDEX] = 1
[01-01 00:00:59 ty D][e574][tuya_ble_svc.c:1115] rev ble event 14
[01-01 00:00:59 ty D][e574][tuya_ble_svc.c:1076] Dev Rev BT Package
[01-01 00:00:59 ty D][e574][tuya_ble_svc.c:115] bt_rev_raw 20 <0x62e56868>
00 01 02 03 04 05 06 07 08 09 00 01 02 03 04 05 06 07 08 09 
[01-01 00:00:59 ty D][e574][tuya_ble_data_handler.c:142] recive sub_pkg desc:3, no:1, pack_len:1, total_len:1
[01-01 00:00:59 ty E][e574][tuya_ble_data_handler.c:672] ty_ble_rx_proc version not compatibility!
[2021-08-07 23:16:37:502] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[2021-08-07 23:16:37:502] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
55aa030000010104
[2021-08-07 23:16:37:538] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:16:37:538] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:16:37:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:16:37:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
[01-01 00:01:17 ty D][ee84][tuya_ble_svc.c:1145] device no permit to connect, disconect!!
==================tkl_ble_gap_disconnect=================
[2021-08-07 23:16:52:502] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[2021-08-07 23:16:52:503] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
55aa030000010104
[2021-08-07 23:16:52:540] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:16:52:540] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:16:52:540] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:16:52:540] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
disconnect; reason=0x213 
[ble_gap_event:119]send event type:5 (TKL_BLE_GAP_EVT_DISCONNECT)
[ble_gap_event:120]gap_evt.conn_handle :64848
[01-01 00:01:31 ty D][e574][tuya_ble_svc.c:1115] rev ble event 6
[01-01 00:01:31 ty N][e574][tuya_ble_svc.c:774] Ble Disonnected
[01-01 00:01:31 ty N][e574][tuya_ble_data_handler.c:69] ble reset sn
[01-01 00:01:31 ty N][e574][tuya_ble_data_handler.c:83] ble clear pair rand
[01-01 00:01:31 ty N][e574][tuya_ble_svc.c:1659] ble set conn stat:0
[01-01 00:01:31 ty D][ee84][tuya_ble_svc.c:244] upd adv para, send conn_req beacon.
[01-01 00:01:31 ty D][ee84][tuya_ble_svc.c:115] adv_data 31 <0x12329e1>
[01-01 00:01:31 ty D][ee84][tuya_ble_svc.c:115] rsp_data 31 <0x1232a01>
[01-01 00:01:31 ty D][ee84][tuya_ble_svc.c:1665] ble get conn stat:0
[01-01 00:01:31 ty N][ee84][tuya_ble_svc.c:1381] ble adv updated
[01-01 00:01:36 ty D][e574][tuya_ble_svc.c:1115] rev ble event 4
[01-01 00:01:36 ty N][e574][tuya_ble_svc.c:746] Ble Connected
[01-01 00:01:36 ty N][e574][tuya_ble_data_handler.c:69] ble reset sn
[01-01 00:01:36 ty N][e574][tuya_ble_svc.c:1659] ble set conn stat:1
[01-01 00:01:36 ty D][e574][tuya_ble_svc.c:1152] conn monitor timer started
max_data_len=1024 
Len=20 
[01-01 00:01:42 ty D][e574][tuya_ble_svc.c:1115] rev ble event 14
[01-01 00:01:42 ty D][e574][tuya_ble_svc.c:1076] Dev Rev BT Package
[01-01 00:01:42 ty D][e574][tuya_ble_svc.c:115] bt_rev_raw 20 <0x62e56868>
[01-01 00:01:42 ty D][e574][tuya_ble_data_handler.c:142] recive sub_pkg desc:3, no:1, pack_len:1, total_len:1
[01-01 00:01:42 ty E][e574][tuya_ble_data_handler.c:672] ty_ble_rx_proc version not compatibility!
[2021-08-07 23:17:07:503] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[2021-08-07 23:17:07:503] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
55aa030000010104
[2021-08-07 23:17:07:537] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:17:07:538] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:17:07:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:17:07:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
[2021-08-07 23:17:22:503] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[2021-08-07 23:17:22:503] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
55aa030000010104
[2021-08-07 23:17:22:537] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:17:22:538] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:17:22:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:17:22:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
[01-01 00:02:00 ty D][6e84][simplekv.c:129] <__tmm_backup_work> backup file start...time: 133, MsTime: 206
[01-01 00:02:00 ty D][6e84][simplekv.c:241] backup normal file to bak success
[01-01 00:02:00 ty D][6e84][simplekv.c:132] <__tmm_backup_work> backup file end...time: 133, MsTime: 255
[01-01 00:02:06 ty D][ee84][tuya_ble_svc.c:1145] device no permit to connect, disconect!!
[2021-08-07 23:17:37:504] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[2021-08-07 23:17:37:504] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
55aa030000010104
[2021-08-07 23:17:37:537] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:17:37:538] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:17:37:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:17:37:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
[2021-08-07 23:17:52:504] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[21]    send command length(8), max length(196) ............
[2021-08-07 23:17:52:505] tag[DEBG] module[COMPORT_SWAP]            func[comport_send]                        line[68]    serial message is send success
55aa030000010104
[2021-08-07 23:17:52:537] tag[INFO] module[COMPORT_SWAP]            func[comport_recv]                        line[133]   reading serial response length(128),receive len(8) success!
[2021-08-07 23:17:52:537] tag[INFO] module[MCU_UART]                func[dispatch_message]                    line[915]   dispatch message.
[2021-08-07 23:17:52:537] tag[INFO] module[MCU_UART]                func[process_message]                     line[821]   msg cmd:0x00, len:1
[2021-08-07 23:17:52:538] tag[INFO] module[MCU_UART]                func[process_message]                     line[839]   Heart Beat Rsp...
