#!/bin/sh
# This script will populate the root directory with libs from the sysroot.
# (C) 2007 Yann E. MORIN
# Licensed under the GPL v2
set -e
# Use the tools discovered by crosstool-NG's ./configure:
install="install"
grep="grep"
sed="sed"
awk="awk"
# Detect where the toolchain is:
CT_PREFIX_DIR="$(cd "$(dirname "$0")/.."; pwd)"
CT_GCC="${0%-populate}-gcc"
CT_READELF="${0%-populate}-readelf"
CT_CFG_PREFIX_DIR="$("${CT_GCC}" -v 2>&1            \
                     |tr ' ' '\n'                   \
                     |"${grep}" -E -- '--prefix='   \
                     |cut -d = -f 2-
CT_CFG_SYSROOT_DIR="$("${CT_GCC}" -v 2>&1                   \
                      |tr ' ' '\n'                          \
                      |"${grep}" -E -- '--with-sysroot='    \
                      |cut -d = -f 2-
CT_SYSROOT_DIR="$(printf "${CT_CFG_SYSROOT_DIR}\n"                              \
                  |"${sed}" -r -e "s:^${CT_CFG_PREFIX_DIR}:${CT_PREFIX_DIR}:;"  \
                  |"${sed}" -r -e 's,/+,/,g;'                                   \
myname=$(basename "$0")
doHelp() {
    cat <<_EOF_
NAME
    $myname - populate the target root file system
SYNOPSIS
    $myname OPTIONS -s source_root -d destination_root
DESCRIPTION
    This script will 'populate' your target root file system 'source_root'
    with libraries from the toolchain (eg. libc.so...), storing the result
    into 'dst_dir'.
OPTIONS
    -s src_dir
        Use 'src_dir' as the un-populated (source) root directory.
    -d dst_dir
        Use 'dst_dir' as the place to put the populated root directory.
        See the -f and -m options, below, on the required (non-)existence
        of this directory.
    -r sysroot_dir
        Use 'sysroot_dir' as the sysroot instead of the toolchain default.
    -l name1[:name2[...]]
        Always add the specified shared library/ies name1, name2... from the
        toolchain (in the sysroot). Actual library names are searched as
        follows (where 'name' is replaced with the given name) in the
        sysroot directory:
          - libname.so
          - name.so
          - name
        If the file is found, then the SONAME of the library is used, and the
        library is copied with that name. If the library was not found, this
        yields an error (unless -f was given).
    -L file
        Read 'file' for a list of shared libraries to always add from the
        toolchain. The file should contain one library name per line; text
        after a # is ignored until the end of the line; spaces are ignored;
        empty lines are ignored. Libraries are searched for as with -l.
    -f  Force execution: if destination directory already exists, it will be
        removed first; if a specified library (above) was not found, continue.
        Note: if using -m and the destination directory already exists, it
        is *not* removed, see below.
    -m  Merge the source root directory with the destination root directory.
        If the latter does not exist, it is created, and -m is ignored.
        If the destination root directory exists, then the content of the
        source root directory is copied in there, and the result is populated
        as usual.
        It can be useful if constructing a rootfs incrementally from many
        smaller source root directories, or if your destination root directory
        is an NFS export that your target mounts as / (and you don't want to
        re-run exportfs -av everytime). USE WITH CARE!
    -v  Be verbose. By default, populate is absolutely silent.
_EOF_
CT_ROOT_SRC_DIR=
CT_ROOT_DST_DIR=
CT_LIB_LIST=
CT_LIB_FILE=
CT_MERGE=
CT_FORCE=
CT_PRINTF=:
OPTIND=1
while getopts ":s:d:r:l:L:fmvh" CT_OPT; do
    case "${CT_OPT}" in
        s)  CT_ROOT_SRC_DIR="${OPTARG}";;
        d)  CT_ROOT_DST_DIR="${OPTARG}";;
        r)  CT_SYSROOT_DIR="${OPTARG}";;
        l)  CT_LIB_LIST="${CT_LIB_LIST}:${OPTARG}";;
        L)  CT_LIB_FILE="${OPTARG}";;
        f)  CT_FORCE=y;;
        m)  CT_MERGE=y;;
        v)  CT_PRINTF=printf;;
        h)  doHelp
            exit 0
        :)  printf "$myname: '-${OPTARG}' takes exactly one argument.\n"
            exit 1
        ?)  printf "$myname: unknown option '-${OPTARG}'.\n"
            exit 1
# Sanity checks
if [ -z "${CT_ROOT_SRC_DIR}" -o -z "${CT_ROOT_DST_DIR}" ]; then
    doHelp
    exit 1
if [ ! -d "${CT_ROOT_SRC_DIR}" ]; then
    printf "$myname: '${CT_ROOT_SRC_DIR}': no such file or directory\n"
    exit 1
if [ ! -d "${CT_SYSROOT_DIR}" ]; then
    printf "$myname: '${CT_SYSROOT_DIR}': no such file or directory\n"
    exit 1
# If the dest dir does not exist, all is well
# If merging, we accept an existing dest directory
# If forcing and not merging, we remove an exiting dest directory
# If not forcing and not merging, we do not accept an exiting dest directory
if [ -d "${CT_ROOT_DST_DIR}" ]; then
    case "${CT_FORCE}:${CT_MERGE}" in
        *:y)    ;;
        y:)     rm -rf "${CT_ROOT_DST_DIR}";;
        :)      printf "$myname: '${CT_ROOT_DST_DIR}': already exists\n"
                exit 1
src_inode=$(ls -1id "${CT_ROOT_SRC_DIR}/." |${awk} '{ print $1 }')
dst_inode=$(ls -1id "${CT_ROOT_DST_DIR}/." 2>/dev/null |${awk} '{ print $1 }')
if [ "${src_inode}" -eq "$((dst_inode+0))" ]; then
    printf "$myname: source and destination are the same!\n"
    exit 1
# Check existence of the forced libraries file
if [ -n "${CT_LIB_FILE}" -a ! \( -f "${CT_LIB_FILE}" -a -r "${CT_LIB_FILE}" \) ]; then
    printf "$myname: forced libraries file '${CT_LIB_FILE}' not found!\n"
    exit 1
# Create the working copy, no issue if already existing
mkdir -p "${CT_ROOT_DST_DIR}"
# Make all path absolute
CT_ROOT_SRC_DIR=$(cd "${CT_ROOT_SRC_DIR}"; pwd)
CT_ROOT_DST_DIR=$(cd "${CT_ROOT_DST_DIR}"; pwd)
CT_SYSROOT_DIR=$(cd "${CT_SYSROOT_DIR}"; pwd)
# Populate the destination directory with files from the source directory
cp -a . "${CT_ROOT_DST_DIR}"
cd - >/dev/null
# A function do search for a library
# Usage: do_add_lib libname
# returns: 0 if library was found and added, !0 otherwise
do_add_lib() {
    local libname="$1"
    local true_libname
    local dir
    local mode
    for dir in lib usr/lib usr/lib/gconv; do
        if [ -e "${dir}/${libname}" ]; then
            ${CT_PRINTF} "    already present\n"
            return 0
        ${CT_PRINTF} "    trying in '%s'" "${dir}"
        libfile="${CT_SYSROOT_DIR}/${dir}/${libname}"
        ${CT_PRINTF} ": '%s'\n" "${libfile}"
        if [ -e "${libfile}" ]; then
            mkdir -p "${dir}"
            true_libname=$("${CT_READELF}" -d "${libfile}"          \
                           |"${grep}" "Library soname:"             \
                           |"${sed}" -r -e 's,.+\[(.+)\] *$,\1,;'   \
            case "${libfile}" in
                */ld*)  mode=0755;;
                *)      mode=0644;;
            ${CT_PRINTF} "      installing as '%s/%s', mode='%s'\n" "${dir}" "${true_libname}" "${mode}"
            ${install} -m "${mode}" "${libfile}" "${dir}/${true_libname}"
            do_resolve_deps "${dir}/${true_libname}"
            return 0
    return 1
# A function to resolve all NEEDED entries for the given file, relative
# to the working directory (eg. dst_dir)
# Usage: do_resolve_deps some/where/some/file
# Returns: 0, meaning all dependencies were found
# If not all dependencies could be found, exists with error code 1
# (unless forced)
do_resolve_deps() {
    local file="${1}"
    local libname
    for libname in $("${CT_READELF}" -d "${file}"                           \
                     |"${grep}" -E '\(NEEDED\)[[:space:]]+Shared library:'  \
                    ); do
        [ -n "${libname}" ] || continue
        ${CT_PRINTF} "Searching for '%s' needed by '%s'\n" "${libname}" "${file}"
        if ! do_add_lib "${libname}"; then
            printf "$myname: library '${libname}' not found!\n"
            [ "${CT_FORCE}" = "y" ] || exit 1
# We'll work in the copied rootfs
# First of, copy the forced libraries into the working copy
lib_list=
if [ -n "${CT_LIB_FILE}" ]; then
    lib_list=$("${sed}" -r -e ':loop; s/#.*//;'         \
                           -e 's/[[:space:]]+//g;'      \
                           -e 's/([^:])$/\1:/;'         \
                           -e '/$/N; s/\n//; tloop;'    \
                        "${CT_LIB_FILE}"
CT_LIB_LIST=$(printf "${CT_LIB_LIST}:${lib_list}\n"         \
              |"${sed}" -r -e 's/^:+//; s/:+$//; s/:+/ /g;' \
if [ -n "${CT_LIB_LIST}" ]; then
    for name in ${CT_LIB_LIST}; do
        [ -z "${name}" ] && continue
        found=0
        for libname in "lib${name}.so" "${name}.so" "${name}"; do
            ${CT_PRINTF} "Searching for forced library '%s'\n" "${libname}"
            if do_add_lib "${libname}"; then
                found=1
                break
        if [ ${found} -eq 0 ]; then
# Create a temporary place where to store... temp files.
rand="$( dd if=/dev/urandom bs=1024 count=1 2>/dev/null \
         |md5sum                                        \
         |${awk} '{ print $1; }'
CT_TMP_DIR="${TMPDIR:-/tmp}/populate-${rand}-${$}"
( umask 0077; mkdir "${CT_TMP_DIR}" ) || { printf "Could not create temporary directory\n"; exit 1; }
trap "rm -rf ${CT_TMP_DIR}" EXIT
# List all ELF (executables|shared objects)...
find . -type f -exec file {} \;                                             \
|"${grep}" -E ': ELF [[:digit:]]+-bit (L|M)SB +(executable|shared object),' \
|cut -d ":" -f 1                                                            \
>"${CT_TMP_DIR}/files.list"
# ... and use that list to find missing dependencies
while read file; do
    do_resolve_deps "${file}"
done <"${CT_TMP_DIR}/files.list"
rm -rf "${CT_TMP_DIR}"
trap - EXIT
# OK, we're done. Back off.
cd - >/dev/null
