#!/bin/bash
# $Id: ncurses-config.in,v 1.36 2017/12/09 22:45:44 tom Exp $
# Copyright (c) 2006-2015,2017 Free Software Foundation, Inc.                #
# Permission is hereby granted, free of charge, to any person obtaining a    #
# copy of this software and associated documentation files (the "Software"), #
# to deal in the Software without restriction, including without limitation  #
# the rights to use, copy, modify, merge, publish, distribute, distribute    #
# with modifications, sublicense, and/or sell copies of the Software, and to #
# permit persons to whom the Software is furnished to do so, subject to the  #
# following conditions:                                                      #
# The above copyright notice and this permission notice shall be included in #
# all copies or substantial portions of the Software.                        #
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR #
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,   #
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL    #
# THE ABOVE COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER      #
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING    #
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER        #
# DEALINGS IN THE SOFTWARE.                                                  #
# Except as contained in this notice, the name(s) of the above copyright     #
# holders shall not be used in advertising or otherwise to promote the sale, #
# use or other dealings in this Software without prior written               #
# authorization.                                                             #
# Author: Thomas E. Dickey, 2006-on
LANG=C;		export LANG
LANGUAGE=C;	export LANGUAGE
LC_ALL=C;	export LC_ALL
LC_CTYPE=C;	export LC_CTYPE
prefix="/usr"
exec_prefix="${prefix}"
bindir="${exec_prefix}/bin"
includedir="${prefix}/include"
libdir="${exec_prefix}/lib"
datarootdir="${prefix}/share"
datadir="${datarootdir}"
mandir="${datarootdir}/man"
THIS="ncurses"
TINFO_LIB="ncurses"
RPATH_LIST="${libdir}"
includesubdir="${prefix}/include/${THIS}"
# Ensure that RPATH_LIST contains only absolute pathnames, if it is nonempty.
# We cannot filter it out within the build-process since the variable is used
# in some special cases of installation using a relative path.
if test -n "$RPATH_LIST"
then
	save_IFS="$IFS"
	IFS=':'
	filtered=
	for item in $RPATH_LIST
	do
		case "$item" in
			test -n "$filtered" && filtered="${filtered}:"
			filtered="${filtered}${item}"
	IFS="$save_IFS"
	# if the result is empty, there is little we can do to fix it
	RPATH_LIST="$filtered"
# with --disable-overwrite, we installed into a subdirectory, but transformed
# the headers to include like this:
#	<ncurses/curses.h>
if test xyes = xno ; then
	case $includedir in
	$prefix/include/ncurses)
		includedir=`echo "$includedir" | sed -e 's,/[^/]*$,,'`
test $# = 0 && exec /bin/bash $0 --error
while test $# -gt 0; do
	case "$1" in
	# basic configuration
	--prefix)
		echo "$prefix"
	--exec-prefix)
		echo "$exec_prefix"
	# compile/link
	--cflags)
		INCS=" -D_GNU_SOURCE"
		if test "xyes" = xno ; then
			INCS="$INCS -I${includesubdir}"
		if test "${includedir}" != /usr/include ; then
			INCS="$INCS -I${includedir}"
		sed -e 's,^[ ]*,,' -e 's, [ ]*, ,g' -e 's,[ ]*$,,' <<-ENDECHO
			$INCS
ENDECHO
	--libs)
		if test "$libdir" = /usr/lib
		then
			LIBDIR=
			LIBDIR=-L$libdir
		if test ncurses = ncurses ; then
			$LIBDIR  -l${THIS}
ENDECHO
			$LIBDIR  -l${THIS} -l${TINFO_LIB}
ENDECHO
	# identification
	--version)
		echo "6.1.20180129"
	--abi-version)
		echo "6"
	--mouse-version)
		echo "2"
	# locations
	--bindir)
		echo "${bindir}"
	--datadir)
		echo "${datadir}"
	--includedir)
		INCS=
			INCS="${includesubdir}"
		elif test "${includedir}" != /usr/include ; then
			INCS="${includedir}"
		echo $INCS
	--libdir)
		echo "${libdir}"
	--mandir)
		echo "${mandir}"
	--terminfo)
		echo "/usr/share/terminfo"
	--terminfo-dirs)
	--termpath)
		echo "/etc/termcap:/usr/share/misc/termcap"
	# general info
	--help)
		cat <<ENDHELP
Usage: `basename $0` [options]
Options:
  --prefix           echos the package-prefix of ${THIS}
  --exec-prefix      echos the executable-prefix of ${THIS}
  --cflags           echos the C compiler flags needed to compile with ${THIS}
  --libs             echos the libraries needed to link with ${THIS}
  --version          echos the release+patchdate version of ${THIS}
  --abi-version      echos the ABI version of ${THIS}
  --mouse-version    echos the mouse-interface version of ${THIS}
  --bindir           echos the directory containing ${THIS} programs
  --datadir          echos the directory containing ${THIS} data
  --includedir       echos the directory containing ${THIS} header files
  --libdir           echos the directory containing ${THIS} libraries
  --mandir           echos the directory containing ${THIS} manpages
  --terminfo         echos the \$TERMINFO terminfo database path
  --terminfo-dirs    echos the \$TERMINFO_DIRS directory list
  --termpath         echos the \$TERMPATH termcap list
  --help             prints this message
ENDHELP
	--error|*)
		/bin/bash $0 --help 1>&2
		exit 1
	shift
# vi:ts=4 sw=4
# vile:shmode
