ignore_user_input
[01-01 18:12:37:597 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007.
[01-01 18:12:37:597 TUYA D][tuya_z3.c:28002] Time zone is not synchronized
[01-01 18:12:39:579 TUYA W][subdev_core.c:467] module is not init
[01-01 18:12:40:612 TUYA D][af-main-common.c:931] Nodeid:0xfffc, clusterId:0x001f, SUCCESS: tx 0.
[01-01 18:12:43:909 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 9035eafffe76a5ba
[01-01 18:12:43:909 TUYA D][tuya_zigbee_api.c:410] dev_id: 9035eafffe76a5ba, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:12:43:909 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:12:43:934 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle.
WRITE ERR: ep 01 clus 0000 attr 0011 not supported
WRITE: clus 0000 attr 0011 FAIL 86
[01-01 18:12:43:958 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle.
[01-01 18:12:44:10 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 403059fffe6528aa
[01-01 18:12:44:10 TUYA D][tuya_zigbee_api.c:410] dev_id: 403059fffe6528aa, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:12:44:10 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:12:44:110 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 6cfd22fffe14e1a7
[01-01 18:12:44:110 TUYA D][tuya_zigbee_api.c:410] dev_id: 6cfd22fffe14e1a7, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:12:44:110 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:12:48:884 TUYA D][af-main-common.c:909] ERROR: tx 66, Nodeid:0x84fc, clusterId:0x0000, num:0.
[01-01 18:12:48:884 TUYA D][tuya_z3_api_tmp.c:5194]  enable tx power change 60s.
[01-01 18:12:48:975 TUYA D][af-main-common.c:909] ERROR: tx 66, Nodeid:0xd63a, clusterId:0x0000, num:0.
[01-01 18:12:48:975 TUYA D][tuya_z3_api_tmp.c:5194]  enable tx power change 60s.
[01-01 18:12:48:975 TUYA D][callback-stub.c:1221] NOTE: add new dev:0xd63a send status, num = 2.
[01-01 18:12:48:975 TUYA D][callback-stub.c:1348] Send FindNodeId: 0xd63a.
[01-01 18:12:49:1 TUYA D][callback-stub.c:2766] NodeId:0x0, LastHopRssi:0, LastHopLqi:255.
[01-01 18:12:49:1 TUYA D][callback-stub.c:2729] dev:6cfd22fffe14e1a7 address respon.
[01-01 18:12:49:1 TUYA D][device-table-tracking.c:51] ROUTE REPAIR SERVICE RETURN RESULT: status=4
[01-01 18:12:49:579 TUYA W][subdev_core.c:467] module is not init
[01-01 18:12:59:581 TUYA W][subdev_core.c:467] module is not init
[01-01 18:13:00:216 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 9035eafffe76a5ba
[01-01 18:13:00:216 TUYA D][tuya_zigbee_api.c:410] dev_id: 9035eafffe76a5ba, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:00:216 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:00:254 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle.
[01-01 18:13:00:278 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle.
[01-01 18:13:00:316 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 403059fffe6528aa
[01-01 18:13:00:317 TUYA D][tuya_zigbee_api.c:410] dev_id: 403059fffe6528aa, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:00:317 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:00:417 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 6cfd22fffe14e1a7
[01-01 18:13:00:417 TUYA D][tuya_zigbee_api.c:410] dev_id: 6cfd22fffe14e1a7, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:00:417 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:02:980 TUYA D][callback-stub.c:2766] NodeId:0x0, LastHopRssi:0, LastHopLqi:255.
[01-01 18:13:02:980 TUYA D][device-table-discovery.c:1295] ZDOMessageReceived node id:0x0000 ,cluster:0x8038 
[01-01 18:13:02:980 TUYA D][device-table-discovery.c:1356] Untracked ZDO 8038
[01-01 18:13:02:980 TUYA D][ias-zone-client.c:624] Incoming ZDO, Cluster: 0x8038
[01-01 18:13:05:186 TUYA D][af-main-common.c:909] ERROR: tx 66, Nodeid:0x84fc, clusterId:0x0000, num:0.
[01-01 18:13:05:186 TUYA D][tuya_z3_api_tmp.c:5194]  enable tx power change 60s.
[01-01 18:13:05:288 TUYA D][af-main-common.c:909] ERROR: tx 66, Nodeid:0xd63a, clusterId:0x0000, num:0.
[01-01 18:13:05:288 TUYA D][tuya_z3_api_tmp.c:5194]  enable tx power change 60s.
[01-01 18:13:09:581 TUYA W][subdev_core.c:467] module is not init
[01-01 18:13:11:957 TUYA D][device-table-discovery.c:1213] TC Join Callback 84fc , decision: 3, status: 0
[01-01 18:13:11:957 TUYA D][device-table-discovery.c:1221] ****** newNodeEui64  403059fffe6528aa  STANDARD_SECURITY_SECURED_REJOIN ******
[01-01 18:13:11:957 TUYA D][device-table-discovery.c:1256] new device line 1256
[01-01 18:13:11:957 TUYA D][device-table-discovery.c:994] NewDeviceJoinHandler, node: 0x84fc, eui64:403059fffe6528aa
[01-01 18:13:11:957 TUYA D][callback-stub.c:1975] [emberAfPluginDeviceTableFreshCallback:1975].
[01-01 18:13:11:957 TUYA D][tuya_z3_api_tmp.c:1337]  Dev:403059fffe6528aa, tuya_z3_DeviceRejoinCb.
[01-01 18:13:11:957 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1013.
[01-01 18:13:11:957 TUYA D][tuya_z3_api_tmp.c:5194]  enable tx power change 60s.
[01-01 18:13:11:957 TUYA D][dev_table_tmp.c:55] NOTE: add new dev:403059fffe6528aa rejoin table tmp num:1.
Trust Center Join Handler: status = secured rejoin, decision = no action (03), shortid 0x84FC
[01-01 18:13:11:957 TUYA W][subdev_core.c:379] module is not init
[01-01 18:13:11:957 TUYA E][subdev_sdk_api.c:725] dev 403059fffe6528aa not exit
[01-01 18:13:11:957 TUYA D][tuya_gw_z3_user.c:229] z3 user device found, dev_id: 403059fffe6528aa
[01-01 18:13:11:958 TUYA D][tuya_z3.c:24775] user device: 403059fffe6528aa, need_sync: 1
[01-01 18:13:12:676 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007.
[01-01 18:13:12:676 TUYA D][tuya_z3.c:28002] Time zone is not synchronized
[01-01 18:13:13:677 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007.
[01-01 18:13:13:677 TUYA D][tuya_z3.c:28002] Time zone is not synchronized
[01-01 18:13:14:679 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007.
[01-01 18:13:14:679 TUYA D][tuya_z3.c:28002] Time zone is not synchronized
[01-01 18:13:15:681 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007.
[01-01 18:13:15:681 TUYA D][tuya_z3.c:28002] Time zone is not synchronized
[01-01 18:13:16:524 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 9035eafffe76a5ba
[01-01 18:13:16:524 TUYA D][tuya_zigbee_api.c:410] dev_id: 9035eafffe76a5ba, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:16:524 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:16:562 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle.
[01-01 18:13:16:585 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle.
[01-01 18:13:16:624 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 403059fffe6528aa
[01-01 18:13:16:625 TUYA D][tuya_zigbee_api.c:410] dev_id: 403059fffe6528aa, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:16:625 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:16:626 TUYA D][dev_table_tmp.c:75] Del dev rejoin 403059fffe6528aa table tmp.
[01-01 18:13:16:689 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007.
[01-01 18:13:16:689 TUYA D][tuya_z3.c:28002] Time zone is not synchronized
[01-01 18:13:16:725 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 6cfd22fffe14e1a7
[01-01 18:13:16:725 TUYA D][tuya_zigbee_api.c:410] dev_id: 6cfd22fffe14e1a7, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:16:726 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:17:698 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007.
[01-01 18:13:17:698 TUYA D][tuya_z3.c:28002] Time zone is not synchronized
[01-01 18:13:18:699 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007.
[01-01 18:13:18:699 TUYA D][tuya_z3.c:28002] Time zone is not synchronized
[01-01 18:13:19:591 TUYA W][subdev_core.c:467] module is not init
[01-01 18:13:19:701 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007.
[01-01 18:13:19:701 TUYA D][tuya_z3.c:28002] Time zone is not synchronized
[01-01 18:13:20:702 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007.
[01-01 18:13:20:702 TUYA D][tuya_z3.c:28002] Time zone is not synchronized
[01-01 18:13:21:491 TUYA D][af-main-common.c:909] ERROR: tx 66, Nodeid:0x84fc, clusterId:0x0000, num:0.
[01-01 18:13:21:491 TUYA D][tuya_z3_api_tmp.c:5194]  enable tx power change 60s.
[01-01 18:13:21:592 TUYA D][af-main-common.c:909] ERROR: tx 66, Nodeid:0xd63a, clusterId:0x0000, num:0.
[01-01 18:13:21:592 TUYA D][tuya_z3_api_tmp.c:5194]  enable tx power change 60s.
[01-01 18:13:21:704 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007.
[01-01 18:13:21:704 TUYA D][tuya_z3.c:28002] Time zone is not synchronized
[01-01 18:13:29:600 TUYA W][subdev_core.c:467] module is not init
[01-01 18:13:32:831 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 9035eafffe76a5ba
[01-01 18:13:32:831 TUYA D][tuya_zigbee_api.c:410] dev_id: 9035eafffe76a5ba, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:32:831 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:32:869 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle.
[01-01 18:13:32:893 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle.
[01-01 18:13:32:931 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 403059fffe6528aa
[01-01 18:13:32:931 TUYA D][tuya_zigbee_api.c:410] dev_id: 403059fffe6528aa, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:32:931 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:33:31 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 6cfd22fffe14e1a7
[01-01 18:13:33:31 TUYA D][tuya_zigbee_api.c:410] dev_id: 6cfd22fffe14e1a7, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:33:31 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:37:799 TUYA D][af-main-common.c:909] ERROR: tx 66, Nodeid:0x84fc, clusterId:0x0000, num:0.
[01-01 18:13:37:799 TUYA D][tuya_z3_api_tmp.c:5194]  enable tx power change 60s.
[01-01 18:13:37:900 TUYA D][af-main-common.c:909] ERROR: tx 66, Nodeid:0xd63a, clusterId:0x0000, num:0.
[01-01 18:13:37:900 TUYA D][tuya_z3_api_tmp.c:5194]  enable tx power change 60s.
[01-01 18:13:39:608 TUYA W][subdev_core.c:467] module is not init
[01-01 18:13:49:140 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 9035eafffe76a5ba
[01-01 18:13:49:141 TUYA D][tuya_zigbee_api.c:410] dev_id: 9035eafffe76a5ba, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:49:141 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:49:168 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle.
[01-01 18:13:49:192 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle.
[01-01 18:13:49:241 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 403059fffe6528aa
[01-01 18:13:49:241 TUYA D][tuya_zigbee_api.c:410] dev_id: 403059fffe6528aa, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:49:241 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:49:341 TUYA D][tuya_zigbee_api.c:389] send zcl to device: 6cfd22fffe14e1a7
[01-01 18:13:49:341 TUYA D][tuya_zigbee_api.c:410] dev_id: 6cfd22fffe14e1a7, profile_id: 0x0104, cluster_id: 0x0000
[01-01 18:13:49:341 TUYA D][tuya_zigbee_api.c:413] src_ep[0x01] dst_ep[0x01] grp_id[0x0000] cmd_type[0x01] msg_len[4] cmd_id[0x02]
[01-01 18:13:49:611 TUYA W][subdev_core.c:467] module is not init
[01-01 18:13:54:111 TUYA D][af-main-common.c:909] ERROR: tx 66, Nodeid:0x84fc, clusterId:0x0000, num:0.
[01-01 18:13:54:111 TUYA D][tuya_z3_api_tmp.c:5194]  enable tx power change 60s.
[01-01 18:13:54:213 TUYA D][af-main-common.c:909] ERROR: tx 66, Nodeid:0xd63a, clusterId:0x0000, num:0.
[01-01 18:13:54:213 TUYA D][tuya_z3_api_tmp.c:5194]  enable tx power change 60s.
