diff --git a/t3_os/armino/middleware/driver/pwm/v1px/pwm_driver.c b/t3_os/armino/middleware/driver/pwm/v1px/pwm_driver.c index ee0f10fe..7a9d5c06 100755 --- a/t3_os/armino/middleware/driver/pwm/v1px/pwm_driver.c +++ b/t3_os/armino/middleware/driver/pwm/v1px/pwm_driver.c @@ -208,6 +208,7 @@ static void pwm_chan_init_common(pwm_chan_t sw_ch) { pwm_id_t id; pwm_ch_t hw_ch; + uint32_t soft_reset = 0; pwm_sw_ch_to_hw_id_ch(sw_ch, &id, &hw_ch); s_pwm[id].chan_init_bits |= BIT(hw_ch); @@ -225,6 +226,10 @@ static void pwm_chan_init_common(pwm_chan_t sw_ch) } pwm_chan_init_gpio(sw_ch); + soft_reset = pwm_hal_get_cg_reset_soft_reset(&s_pwm[id].hal); + if (0 == soft_reset) { + pwm_hal_set_cg_reset_soft_reset(&s_pwm[id].hal, 1); + } } static void pwm_chan_deinit_common(pwm_chan_t sw_ch) @@ -546,6 +551,7 @@ bk_err_t bk_pwm_init(pwm_chan_t sw_ch, const pwm_init_config_t *config) pwm_sw_ch_to_hw_id_ch(sw_ch, &id, &hw_ch); PWM_RETURN_ON_INVALID_CHAN(hw_ch); + PWM_PM_CHECK_RESTORE(id); if (!pwm_driver_duty_is_valid(config->period_cycle, config->duty_cycle, config->duty2_cycle, config->duty3_cycle)) @@ -730,6 +736,7 @@ bk_err_t bk_pwm_set_period_duty(pwm_chan_t sw_ch, pwm_period_duty_config_t *conf config->duty2_cycle, config->duty3_cycle)) return BK_ERR_PWM_PERIOD_DUTY; + PWM_PM_CHECK_RESTORE(id); pwm_hal_set_new_config_way(&s_pwm[id].hal, hw_ch, 1); /* duty ratio is 0% */ @@ -1101,21 +1108,24 @@ static void pwm_group_init_with_any_channel(const pwm_group_init_config_t *confi { pwm_id_t id1, id2; pwm_ch_t hw_ch1, hw_ch2; - pwm_period_duty_config_t pwm_config; + pwm_period_duty_config_t pwm_config = {0}; pwm_sw_ch_to_hw_id_ch(config->chan1, &id1, &hw_ch1); pwm_sw_ch_to_hw_id_ch(config->chan2, &id2, &hw_ch2); + pwm_config.psc = 0; pwm_config.period_cycle = config->period_cycle; pwm_config.duty_cycle = config->chan1_duty_cycle; pwm_config.duty2_cycle = 0; pwm_config.duty3_cycle = 0; + pwm_hal_set_new_config_way(&s_pwm[id1].hal, hw_ch1, 0); pwm_set_channel_config(config->chan1, &pwm_config); pwm_hal_set_flip_mode(&s_pwm[id1].hal, hw_ch1, 3); pwm_hal_set_init_signal_high(&s_pwm[id1].hal, hw_ch1); pwm_config.duty_cycle = config->chan1_duty_cycle + dead_cycle; pwm_config.duty2_cycle = config->chan2_duty_cycle + pwm_config.duty_cycle; + pwm_hal_set_new_config_way(&s_pwm[id2].hal, hw_ch2, 0); pwm_set_channel_config(config->chan2, &pwm_config); pwm_hal_set_flip_mode(&s_pwm[id2].hal, hw_ch2, 1); pwm_hal_set_init_signal_low(&s_pwm[id2].hal, hw_ch2); @@ -1127,6 +1137,8 @@ bk_err_t bk_pwm_group_init(const pwm_group_init_config_t *config, pwm_group_t *g { PWM_RETURN_ON_NOT_INIT(); BK_RETURN_ON_NULL(group); + PWM_PM_CHECK_RESTORE(PWM_ID_0); + PWM_PM_CHECK_RESTORE(PWM_ID_1); uint32_t dead_cycle = 0; int ret; @@ -1139,13 +1151,17 @@ bk_err_t bk_pwm_group_init(const pwm_group_init_config_t *config, pwm_group_t *g return ret; } - dead_cycle = (config->period_cycle - config->chan1_duty_cycle - config->chan2_duty_cycle) >> 1; + pwm_chan_init_common(config->chan1); pwm_chan_init_common(config->chan2); if (pwm_chan_is_default_group(config->chan1, config->chan2)) { PWM_LOGI("use hardware default group\r\n"); - pwm_group_output_mode_config(config, 25, dead_cycle); + if (dead_cycle >= 0x400) { + PWM_LOGE("pwm_group_validate_dead_cycle, dead_cycle:%d\r\n", dead_cycle); + return BK_ERR_PWM_GROUP_DUTY; + } + pwm_group_output_mode_config(config, 0, dead_cycle); } else { PWM_LOGI("configure channels into group mode manually\r\n"); pwm_group_init_with_any_channel(config, dead_cycle); @@ -1231,6 +1247,8 @@ bk_err_t bk_pwm_group_set_config(pwm_group_t group, const pwm_group_config_t *co if (!pwm_group_is_existed(group)) { return BK_ERR_PWM_GROUP_NOT_EXIST; } + PWM_PM_CHECK_RESTORE(PWM_ID_0); + PWM_PM_CHECK_RESTORE(PWM_ID_1); pwm_id_t id1, id2; pwm_ch_t hw_ch1, hw_ch2; diff --git a/t3_os/tuya_app/config/bk7236/config b/t3_os/tuya_app/config/bk7236/config index 47efe157..7439434e 100644 --- a/t3_os/tuya_app/config/bk7236/config +++ b/t3_os/tuya_app/config/bk7236/config @@ -64,3 +64,5 @@ CONFIG_FLASH_BYPASS_OTP_OPERATION=y CONFIG_SPI_DMA=y # CONFIG_SPI_ETH=y + +CONFIG_PWM_PM_CB_SUPPORT=y
