   text	   code	 rodata	   data	    bss	    dec	    hex	filename
    543	    532	     11	      0	      0	    543	    21f	startup_bk7236.c.obj (ex armino/cmsis/libcmsis.a)
    264	    264	      0	      0	      0	    264	    108	system_bk7236xx.c.obj (ex armino/cmsis/libcmsis.a)
    807	    796	     11	      0	      0	    807	    327	armino/cmsis/libcmsis.a
   2799	   1540	   1259	      0	     80	   2879	    b3f	trap_base.c.obj (ex armino/cm33/libcm33.a)
   1269	    852	    417	      0	     16	   1285	    505	mpu.c.obj (ex armino/cm33/libcm33.a)
    174	    174	      0	      0	      0	    174	     ae	arm.c.obj (ex armino/cm33/libcm33.a)
    350	    350	      0	      0	    256	    606	    25e	arch_interrupt.c.obj (ex armino/cm33/libcm33.a)
    266	    266	      0	      0	      0	    266	    10a	cache.c.obj (ex armino/cm33/libcm33.a)
    635	    392	    243	      0	      0	    635	    27b	stack_base.c.obj (ex armino/cm33/libcm33.a)
   5493	   3574	   1919	      0	    352	   5845	   16d5	armino/cm33/libcm33.a
    710	    268	    442	      0	      8	    718	    2ce	reset_reason.c.obj (ex armino/driver/libdriver.a)
    650	    650	      0	      0	      0	    650	    28a	sys_driver.c.obj (ex armino/driver/libdriver.a)
    388	    340	     48	      4	     13	    405	    195	wdt_driver.c.obj (ex armino/driver/libdriver.a)
    108	    108	      0	      0	      0	    108	     6c	aon_pmu_driver.c.obj (ex armino/driver/libdriver.a)
   4145	   3620	    525	     25	    445	   4615	   1207	gpio_driver_base.c.obj (ex armino/driver/libdriver.a)
   2846	   2212	    634	      0	     68	   2914	    b62	aon_rtc_driver_64bit.c.obj (ex armino/driver/libdriver.a)
    630	    600	     30	      0	     48	    678	    2a6	amp_res_lock.c.obj (ex armino/driver/libdriver.a)
   1510	   1304	    206	      0	      4	   1514	    5ea	gpio_driver.c.obj (ex armino/driver/libdriver.a)
    810	    810	      0	      0	      1	    811	    32b	sys_ps_driver.c.obj (ex armino/driver/libdriver.a)
    452	    452	      0	      0	      0	    452	    1c4	sys_int_driver.c.obj (ex armino/driver/libdriver.a)
   1022	   1022	      0	      0	      0	   1022	    3fe	sys_clock_driver.c.obj (ex armino/driver/libdriver.a)
    376	    120	    256	      0	      0	    376	    178	interrupt_base.c.obj (ex armino/driver/libdriver.a)
   1868	   1800	     68	      0	     33	   1901	    76d	timer_driver.c.obj (ex armino/driver/libdriver.a)
   1205	   1134	     71	      0	    104	   1309	    51d	mb_ipc_cmd.c.obj (ex armino/driver/libdriver.a)
    188	    188	      0	      0	      0	    188	     bc	mb_chnl_buff.c.obj (ex armino/driver/libdriver.a)
      6	      6	      0	      0	      0	      6	      6	interrupt.c.obj (ex armino/driver/libdriver.a)
   5438	   5180	    258	      0	    285	   5723	   165b	dma_driver.c.obj (ex armino/driver/libdriver.a)
   1347	   1332	     15	      0	    649	   1996	    7cc	mailbox_channel.c.obj (ex armino/driver/libdriver.a)
    312	    312	      0	      0	    111	    423	    1a7	mbox0_adapter.c.obj (ex armino/driver/libdriver.a)
    316	    316	      0	      0	     25	    341	    155	mbox0_drv.c.obj (ex armino/driver/libdriver.a)
   6818	   6482	    336	    120	     93	   7031	   1b77	uart_driver.c.obj (ex armino/driver/libdriver.a)
   4649	   4526	    123	      0	      0	   4649	   1229	printf.c.obj (ex armino/driver/libdriver.a)
   3189	   2896	    293	     36	     46	   3271	    cc7	adc_driver.c.obj (ex armino/driver/libdriver.a)
    261	    124	    137	      0	     16	    277	    115	adc_statis.c.obj (ex armino/driver/libdriver.a)
   2242	   1650	    592	      8	     27	   2277	    8e5	pwr_clk.c.obj (ex armino/driver/libdriver.a)
   5211	   4620	    591	      0	    225	   5436	   153c	pwm_driver.c.obj (ex armino/driver/libdriver.a)
   8261	   7724	    537	      0	    304	   8565	   2175	i2s_driver_v1_1.c.obj (ex armino/driver/libdriver.a)
    248	    248	      0	      0	     13	    261	    105	trng_driver.c.obj (ex armino/driver/libdriver.a)
   4181	   3046	   1135	     24	     54	   4259	   10a3	flash_driver.c.obj (ex armino/driver/libdriver.a)
    409	    320	     89	      0	      0	    409	    199	flash_partition.c.obj (ex armino/driver/libdriver.a)
    562	    562	      0	      0	      0	    562	    232	audio_ring_buff.c.obj (ex armino/driver/libdriver.a)
   1402	   1296	    106	     29	    136	   1567	    61f	touch_driver_v1_1.c.obj (ex armino/driver/libdriver.a)
   4921	   4064	    857	    528	      8	   5457	   1551	otp_driver_v1_1.c.obj (ex armino/driver/libdriver.a)
    122	    122	      0	      0	      0	    122	     7a	spinlock.c.obj (ex armino/driver/libdriver.a)
   1680	   1632	     48	     12	     21	   1713	    6b1	ckmn_driver.c.obj (ex armino/driver/libdriver.a)
   1460	   1460	      0	      0	    148	   1608	    648	scr_driver_v1_26.c.obj (ex armino/driver/libdriver.a)
   1562	   1562	      0	      0	      0	   1562	    61a	sys_wifi_driver.c.obj (ex armino/driver/libdriver.a)
   1060	   1060	      0	      0	      0	   1060	    424	sys_audio_driver.c.obj (ex armino/driver/libdriver.a)
    572	    572	      0	      0	      0	    572	    23c	sys_touch_driver.c.obj (ex armino/driver/libdriver.a)
    570	    570	      0	    420	      0	    990	    3de	drv_model.c.obj (ex armino/driver/libdriver.a)
   2537	   1998	    539	      0	      2	   2539	    9eb	flash_bypass.c.obj (ex armino/driver/libdriver.a)
    746	    538	    208	      0	      0	    746	    2ea	driver.c.obj (ex armino/driver/libdriver.a)
    418	    418	      0	      0	      0	    418	    1a2	sys_bt_driver.c.obj (ex armino/driver/libdriver.a)
      4	      4	      0	      0	      0	      4	      4	dd.c.obj (ex armino/driver/libdriver.a)
    232	    232	      0	      0	      9	    241	     f1	efuse_driver.c.obj (ex armino/driver/libdriver.a)
    757	    644	    113	      0	     13	    770	    302	qspi_driver.c.obj (ex armino/driver/libdriver.a)
    166	     92	     74	      0	      8	    174	     ae	qspi_statis.c.obj (ex armino/driver/libdriver.a)
   1246	   1216	     30	      6	     65	   1317	    525	jpeg_driver.c.obj (ex armino/driver/libdriver.a)
   1899	   1754	    145	      4	     29	   1932	    78c	sdmadc_driver.c.obj (ex armino/driver/libdriver.a)
    668	    668	      0	      0	      0	    668	    29c	sys_video_driver.c.obj (ex armino/driver/libdriver.a)
   6322	   5844	    478	     96	     51	   6469	   1945	spi_driver.c.obj (ex armino/driver/libdriver.a)
    454	    200	    254	      0	     64	    518	    206	spi_statis.c.obj (ex armino/driver/libdriver.a)
     78	     38	     40	      0	      0	     78	     4e	sys_driver_common.c.obj (ex armino/driver/libdriver.a)
    878	    668	    210	      0	     12	    890	    37a	rosc_calib.c.obj (ex armino/driver/libdriver.a)
  90112	  80624	   9488	   1312	   3138	  94562	  17162	armino/driver/libdriver.a
   1307	    926	    381	      0	     48	   1355	    54b	system_main.c.obj (ex armino/bk_startup/libbk_startup.a)
     14	     14	      0	      0	      0	     14	      e	rtos_init.c.obj (ex armino/bk_startup/libbk_startup.a)
   1321	    940	    381	      0	     48	   1369	    559	armino/bk_startup/libbk_startup.a
    993	    928	     65	      1	     74	   1068	    42c	printf.c.obj (ex armino/bk_system/libbk_system.a)
     86	     86	      0	      0	      0	     86	     56	delay.c.obj (ex armino/bk_system/libbk_system.a)
     80	     80	      0	      0	      0	     80	     50	tick.c.obj (ex armino/bk_system/libbk_system.a)
    100	     52	     48	      0	      0	    100	     64	bk_system_at.c.obj (ex armino/bk_system/libbk_system.a)
    107	     78	     29	      0	      0	    107	     6b	reboot.c.obj (ex armino/bk_system/libbk_system.a)
    162	    162	      0	      1	      1	    164	     a4	printf_base.c.obj (ex armino/bk_system/libbk_system.a)
    606	    380	    226	      7	      1	    614	    266	mac.c.obj (ex armino/bk_system/libbk_system.a)
   2134	   1766	    368	      9	     76	   2219	    8ab	armino/bk_system/libbk_system.a
   5002	   4690	    312	     77	  14949	  20028	   4e3c	shell_task.c.obj (ex armino/bk_cli/libbk_cli.a)
   1092	   1048	     44	   1152	    368	   2612	    a34	shell_uart.c.obj (ex armino/bk_cli/libbk_cli.a)
    266	    242	     24	     40	      0	    306	    132	shell_mailbox_ipc.c.obj (ex armino/bk_cli/libbk_cli.a)
   3687	   2872	    815	      2	     17	   3706	    e7a	cli_main.c.obj (ex armino/bk_cli/libbk_cli.a)
   1184	    612	    572	      0	     13	   1197	    4ad	cli_rpc.c.obj (ex armino/bk_cli/libbk_cli.a)
  10358	   5900	   4458	      0	     16	  10374	   2886	cli_wifi.c.obj (ex armino/bk_cli/libbk_cli.a)
   2063	   1184	    879	      0	      0	   2063	    80f	cli_netif.c.obj (ex armino/bk_cli/libbk_cli.a)
   2050	   1212	    838	      0	     16	   2066	    812	cli_pwr.c.obj (ex armino/bk_cli/libbk_cli.a)
    747	    136	    611	      0	      0	    747	    2eb	cli_phy.c.obj (ex armino/bk_cli/libbk_cli.a)
     41	     12	     29	      0	      0	     41	     29	cli_iperf.c.obj (ex armino/bk_cli/libbk_cli.a)
   4825	   3012	   1813	      0	     36	   4861	   12fd	cli_i2s.c.obj (ex armino/bk_cli/libbk_cli.a)
   2006	   1620	    386	      0	     13	   2019	    7e3	cli_scr.c.obj (ex armino/bk_cli/libbk_cli.a)
     38	     12	     26	      0	      0	     38	     26	cli_ble.c.obj (ex armino/bk_cli/libbk_cli.a)
   1119	    820	    299	      0	      0	   1119	    45f	cli_event.c.obj (ex armino/bk_cli/libbk_cli.a)
  34478	  23372	  11106	   1271	  15428	  51177	   c7e9	armino/bk_cli/libbk_cli.a
    600	    456	    144	      0	    284	    884	    374	at_server.c.obj (ex armino/at_server/libat_server.a)
   1703	   1568	    135	      5	    528	   2236	    8bc	at_task.c.obj (ex armino/at_server/libat_server.a)
    258	    190	     68	      0	      0	    258	    102	atsvr_core.c.obj (ex armino/at_server/libat_server.a)
    495	    348	    147	      0	      0	    495	    1ef	atsvr_port.c.obj (ex armino/at_server/libat_server.a)
   2674	   1574	   1100	      0	     12	   2686	    a7e	_at_server.c.obj (ex armino/at_server/libat_server.a)
    942	    620	    322	      0	      0	    942	    3ae	_atsvr_func.c.obj (ex armino/at_server/libat_server.a)
   6672	   4756	   1916	      5	    824	   7501	   1d4d	armino/at_server/libat_server.a
   6889	   5476	   1413	    861	    173	   7923	   1ef3	pm.c.obj (ex armino/bk_pm/libbk_pm.a)
    120	     82	     38	      0	      0	    120	     78	pm_misc.c.obj (ex armino/bk_pm/libbk_pm.a)
    104	    104	      0	      0	    240	    344	    158	pm_model.c.obj (ex armino/bk_pm/libbk_pm.a)
    182	    148	     34	      0	      8	    190	     be	low_vol.c.obj (ex armino/bk_pm/libbk_pm.a)
   7295	   5810	   1485	    861	    421	   8577	   2181	armino/bk_pm/libbk_pm.a
  11672	   8138	   3534	      0	      4	  11676	   2d9c	mqtt_client.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
    506	    390	    116	      0	      0	    506	    1fa	mqtt_adapter.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
    650	    552	     98	      0	      0	    650	    28a	utils_list.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
    553	    384	    169	      0	     12	    565	    235	device.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
    874	    472	    402	     36	      4	    914	    392	guider.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
    822	    822	      0	      0	      4	    826	    33a	MQTTPacket.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
    314	    314	      0	      0	      0	    314	    13a	MQTTSerializePublish.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
    206	    206	      0	      0	      0	    206	     ce	MQTTUnsubscribeClient.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
   3155	   1996	   1159	      0	     60	   3215	    c8f	mqtt_test.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
    558	    546	     12	      0	      0	    558	    22e	MQTTConnectClient.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
    208	    208	      0	      0	      0	    208	     d0	MQTTDeserializePublish.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
    286	    286	      0	      0	      0	    286	    11e	MQTTSubscribeClient.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
      4	      4	      0	      0	      0	      4	      4	ca.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
    192	     80	    112	      0	      0	    192	     c0	report.c.obj (ex armino/ali_mqtt/libali_mqtt.a)
  20000	  14398	   5602	     36	     84	  20120	   4e98	armino/ali_mqtt/libali_mqtt.a
   2187	   2158	     29	      0	      0	   2187	    88b	interrupts.c.obj (ex armino/bk7236/libbk7236.a)
   6249	   6098	    151	      1	      0	   6250	   186a	sys_hal.c.obj (ex armino/bk7236/libbk7236.a)
   3764	   3600	    164	      0	      8	   3772	    ebc	sys_pm_hal.c.obj (ex armino/bk7236/libbk7236.a)
    416	    416	      0	      0	      0	    416	    1a0	aon_pmu_hal.c.obj (ex armino/bk7236/libbk7236.a)
   1452	   1452	      0	      0	      1	   1453	    5ad	i2s_hal.c.obj (ex armino/bk7236/libbk7236.a)
   2004	   2004	      0	      0	      0	   2004	    7d4	scr_hal.c.obj (ex armino/bk7236/libbk7236.a)
    160	     32	    128	      0	      0	    160	     a0	jpeg_ll.c.obj (ex armino/bk7236/libbk7236.a)
     32	     32	      0	    109	      0	    141	     8d	mpu_cfg.c.obj (ex armino/bk7236/libbk7236.a)
     52	     52	      0	      0	      0	     52	     34	timer_hal.c.obj (ex armino/bk7236/libbk7236.a)
  16316	  15844	    472	    110	      9	  16435	   4033	armino/bk7236/libbk7236.a
    752	    752	      0	      0	      0	    752	    2f0	timer_hal.c.obj (ex armino/common/libcommon.a)
   2530	   1840	    690	      0	      4	   2534	    9e6	gpio_hal.c.obj (ex armino/common/libcommon.a)
   1220	   1124	     96	      0	      0	   1220	    4c4	mbox0_hal.c.obj (ex armino/common/libcommon.a)
    592	    592	      0	      0	      0	    592	    250	aon_rtc_hal_64bit.c.obj (ex armino/common/libcommon.a)
    472	    472	      0	      0	      0	    472	    1d8	uart_hal.c.obj (ex armino/common/libcommon.a)
    386	    386	      0	      0	      0	    386	    182	adc_hal.c.obj (ex armino/common/libcommon.a)
   9116	   9116	      0	      0	      0	   9116	   239c	pwm_hal_v1px.c.obj (ex armino/common/libcommon.a)
    448	    448	      0	      0	      0	    448	    1c0	ckmn_hal.c.obj (ex armino/common/libcommon.a)
    376	    328	     48	      0	      0	    376	    178	efuse_hal.c.obj (ex armino/common/libcommon.a)
   1457	   1418	     39	      0	      4	   1461	    5b5	qspi_hal.c.obj (ex armino/common/libcommon.a)
    406	    406	      0	      0	      0	    406	    196	jpeg_hal.c.obj (ex armino/common/libcommon.a)
    152	    152	      0	      0	      0	    152	     98	sdmadc_hal.c.obj (ex armino/common/libcommon.a)
    764	    654	    110	      0	      0	    764	    2fc	spi_hal.c.obj (ex armino/common/libcommon.a)
    527	    490	     37	      0	      0	    527	    20f	dma_hal.c.obj (ex armino/common/libcommon.a)
    176	    172	      4	      0	      0	    176	     b0	wdt_hal.c.obj (ex armino/common/libcommon.a)
    202	    202	      0	      0	      0	    202	     ca	flash_hal.c.obj (ex armino/common/libcommon.a)
     72	     72	      0	      0	      0	     72	     48	trng_hal.c.obj (ex armino/common/libcommon.a)
    173	    148	     25	      0	      0	    173	     ad	otp_hal.c.obj (ex armino/common/libcommon.a)
  19821	  18772	   1049	      0	      8	  19829	   4d75	armino/common/libcommon.a
   4777	   4134	    643	   4796	      9	   9582	   256e	rtos_pub.c.obj (ex armino/bk_rtos/libbk_rtos.a)
   1623	    888	    735	      0	      0	   1623	    657	rtos_debug.c.obj (ex armino/bk_rtos/libbk_rtos.a)
    575	    384	    191	      0	      0	    575	    23f	mem_arch.c.obj (ex armino/bk_rtos/libbk_rtos.a)
    200	    190	     10	      0	      0	    200	     c8	str_arch.c.obj (ex armino/bk_rtos/libbk_rtos.a)
    581	    428	    153	      0	      0	    581	    245	platform_stub.c.obj (ex armino/bk_rtos/libbk_rtos.a)
   7756	   6024	   1732	   4796	      9	  12561	   3111	armino/bk_rtos/libbk_rtos.a
   4836	   4298	    538	      0	      0	   4836	   12e4	queue.c.obj (ex armino/os_source/libos_source.a)
  10578	   9596	    982	      4	    384	  10966	   2ad6	tasks.c.obj (ex armino/os_source/libos_source.a)
   2194	   1862	    332	      0	    332	   2526	    9de	timers.c.obj (ex armino/os_source/libos_source.a)
   2665	   2192	    473	      0	     60	   2725	    aa5	heap_4.c.obj (ex armino/os_source/libos_source.a)
   2146	   1494	    652	      4	     28	   2178	    882	port.c.obj (ex armino/os_source/libos_source.a)
    304	    304	      0	      0	      0	    304	    130	portasm.c.obj (ex armino/os_source/libos_source.a)
    132	    132	      0	      0	      0	    132	     84	list.c.obj (ex armino/os_source/libos_source.a)
  22855	  19878	   2977	      8	    804	  23667	   5c73	armino/os_source/libos_source.a
   4898	   2426	   2472	      0	    328	   5226	   146a	cm_backtrace.c.obj (ex armino/coredump/libcoredump.a)
   4898	   2426	   2472	      0	    328	   5226	   146a	armino/coredump/libcoredump.a
    343	    232	    111	      0	      0	    343	    157	log.c.obj (ex armino/bk_log/libbk_log.a)
    343	    232	    111	      0	      0	    343	    157	armino/bk_log/libbk_log.a
    116	    116	      0	      0	      1	    117	     75	ate.c.obj (ex armino/bk_ate/libbk_ate.a)
    116	    116	      0	      0	      1	    117	     75	armino/bk_ate/libbk_ate.a
    812	    812	      0	      0	      0	    812	    32c	command_line.c.obj (ex armino/uart_debug/libuart_debug.a)
    812	    812	      0	      0	      0	    812	    32c	armino/uart_debug/libuart_debug.a
   3133	   2374	    759	      0	      0	   3133	    c3d	wifi_api_wrapper.c.obj (ex armino/bk_wifi/libbk_wifi.a)
   2265	   2050	    215	   1348	      4	   3617	    e21	bk_wifi_adapter.c.obj (ex armino/bk_wifi/libbk_wifi.a)
   7906	   3732	   4174	      0	    177	   8083	   1f93	wifi_at.c.obj (ex armino/bk_wifi/libbk_wifi.a)
    148	    148	      0	      0	      0	    148	     94	net_param.c.obj (ex armino/bk_wifi/libbk_wifi.a)
  13452	   8304	   5148	   1348	    181	  14981	   3a85	armino/bk_wifi/libbk_wifi.a
   3140	   2706	    434	    224	     40	   3404	    d4c	net.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    416	    416	      0	      0	      0	    416	    1a0	netifapi.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   8426	   8042	    384	      0	    648	   9074	   2372	sockets.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    595	    588	      7	      0	     16	    611	    263	tcpip.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    290	    290	      0	      0	      0	    290	    122	def.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   2232	   2218	     14	      0	    586	   2818	    b02	dns.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    492	    492	      0	      0	      0	    492	    1ec	inet_chksum.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   6013	   5212	    801	      0	     99	   6112	   17e0	dhcp.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   2857	   2628	    229	      0	    302	   3159	    c57	etharp.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    578	    570	      8	      0	     16	    594	    252	ip4_addr.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   1494	   1494	      0	      0	      6	   1500	    5dc	ip4.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   1528	   1528	      0	      0	     16	   1544	    608	mem.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    744	    242	    502	      0	    612	   1356	    54c	memp.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   1792	   1514	    278	      0	     93	   1885	    75d	netif.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   2408	   2004	    404	      0	      5	   2413	    96d	pbuf.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    726	    726	      0	      0	      4	    730	    2da	raw.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   1543	    892	    651	      0	    556	   2099	    833	stats.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   5499	   4750	    749	      6	     35	   5540	   15a4	tcp.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    556	    496	     60	      0	     12	    568	    238	timeouts.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    556	    468	     88	      0	      0	    556	    22c	wlanif.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    649	    646	      3	      0	      4	    653	    28d	sys_arch.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   3987	   2830	   1157	      0	      8	   3995	    f9b	api_lib.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   4141	   4104	     37	      0	      0	   4141	   102d	api_msg.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    505	     60	    445	      0	      0	    505	    1f9	err.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    665	    406	    259	      0	      0	    665	    299	netbuf.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    568	    568	      0	      0	    297	    865	    361	netdb.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   2863	   2728	    135	      4	    228	   3095	    c17	dhcp-server.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   1285	    904	    381	      0	     18	   1303	    517	ping.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
     46	     46	      0	      0	      0	     46	     2e	init.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   1950	   1384	    566	      0	      8	   1958	    7a6	igmp.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   1655	   1628	     27	      0	      6	   1661	    67d	ip4_frag.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
     34	     34	      0	      0	      0	     34	     22	sys.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   5522	   5496	     26	      0	     64	   5586	   15d2	tcp_in.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   4010	   3938	     72	      0	      0	   4010	    faa	tcp_out.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
   2312	   1764	    548	      2	      4	   2318	    90e	udp.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    304	    292	     12	      0	      0	    304	    130	ethernet.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    132	    120	     12	      0	      5	    137	     89	dhcp-server-main.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
    612	    612	      0	      0	      0	    612	    264	icmp.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
      0	      0	      0	      0	     24	     24	     18	ip.c.obj (ex armino/lwip_intf_v2_1/liblwip_intf_v2_1.a)
  73125	  64836	   8289	    236	   3712	  77073	  12d11	armino/lwip_intf_v2_1/liblwip_intf_v2_1.a
    541	    504	     37	      0	     65	    606	    25e	bk_netif.c.obj (ex armino/bk_netif/libbk_netif.a)
    174	     72	    102	      0	      0	    174	     ae	bk_at_netif.c.obj (ex armino/bk_netif/libbk_netif.a)
    715	    576	    139	      0	     65	    780	    30c	armino/bk_netif/libbk_netif.a
    371	    298	     73	      0	      0	    371	    173	bk_init.c.obj (ex armino/bk_init/libbk_init.a)
    493	    290	    203	      0	     16	    509	    1fd	components_init.c.obj (ex armino/bk_init/libbk_init.a)
    864	    588	    276	      0	     16	    880	    370	armino/bk_init/libbk_init.a
  47875	    466	  47409	      0	      0	  47875	   bb03	conv_utf8.c.obj (ex armino/utf8/libutf8.a)
  47875	    466	  47409	      0	      0	  47875	   bb03	armino/utf8/libutf8.a
    681	    516	    165	      0	     12	    693	    2b5	bk_sensor.c.obj (ex armino/temp_detect/libtemp_detect.a)
   2171	   1762	    409	      0	    136	   2307	    903	temp_detect.c.obj (ex armino/temp_detect/libtemp_detect.a)
    939	    778	    161	      0	     36	    975	    3cf	volt_detect.c.obj (ex armino/temp_detect/libtemp_detect.a)
   3791	   3056	    735	      0	    184	   3975	    f87	armino/temp_detect/libtemp_detect.a
    520	    392	    128	      0	      0	    520	    208	lite-log.c.obj (ex armino/http/libhttp.a)
   7171	   5090	   2081	      9	     36	   7216	   1c30	utils_httpc.c.obj (ex armino/http/libhttp.a)
   2024	   1372	    652	      0	      0	   2024	    7e8	utils_net.c.obj (ex armino/http/libhttp.a)
    128	    128	      0	      0	      0	    128	     80	utils_timer.c.obj (ex armino/http/libhttp.a)
   9843	   6982	   2861	      9	     36	   9888	   26a0	armino/http/libhttp.a
     64	     64	      0	      0	      0	     64	     40	bk_feature.c.obj (ex armino/bk_common/libbk_common.a)
     64	     64	      0	      0	      0	     64	     40	armino/bk_common/libbk_common.a
    530	    300	    230	      0	      1	    531	    213	bt_main.c.obj (ex armino/bk_bluetooth/libbk_bluetooth.a)
   2427	   2008	    419	    384	      0	   2811	    afb	bluetooth.c.obj (ex armino/bk_bluetooth/libbk_bluetooth.a)
   2957	   2308	    649	    384	      1	   3342	    d0e	armino/bk_bluetooth/libbk_bluetooth.a
     80	     80	      0	      0	      0	     80	     50	lib_adapter.c.obj (ex armino/bk_adapter/libbk_adapter.a)
     80	     80	      0	      0	      0	     80	     50	armino/bk_adapter/libbk_adapter.a
    348	    284	     64	      0	      5	    353	    161	controller_init.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1276	   1276	      0	      0	      4	   1280	    500	bluetooth_osi_wrapper.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   2711	   2566	    145	      6	      0	   2717	    a9d	common_utils.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1049	   1034	     15	      0	     64	   1113	    459	rf_xvr.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   4759	   3490	   1269	     26	     22	   4807	   12c7	ble_main.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   2774	   2242	    532	     12	   1219	   4005	    fa5	uart_ble.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1354	   1010	    344	     16	     28	   1398	    576	uart_controller_only.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1985	   1838	    147	      0	     32	   2017	    7e1	llc.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   9745	   8224	   1521	      1	     32	   9778	   2632	lld_con.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   4449	   3808	    641	      0	     32	   4481	   1181	lld_sync.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   2590	   2036	    554	      0	    976	   3566	    dee	llm.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   7677	   7144	    533	      0	      0	   7677	   1dfd	llm_scan.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    418	    396	     22	      0	      8	    426	    1aa	sch_alarm.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1076	    744	    332	      0	     37	   1113	    459	hci.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    156	    156	      0	      0	      8	    164	     a4	hci_fc.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   2552	   2326	    226	      0	     36	   2588	    a1c	hci_tl.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1158	    734	    424	      0	      0	   1158	    486	common_list.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1081	    988	     93	      0	     48	   1129	    469	h4tl.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1244	   1040	    204	      0	      0	   1244	    4dc	kernel_mem.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    227	    198	     29	      0	      0	    227	     e3	kernel_msg.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1038	    850	    188	      0	     12	   1050	    41a	kernel_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    259	    234	     25	      0	      0	    259	    103	kernel_timer.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1115	    968	    147	      0	  13582	  14697	   3969	rwip.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   4483	   3662	    821	      0	    264	   4747	   128b	rwip_driver.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    428	    428	      0	      0	     12	    440	    1b8	ble_aes.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    574	    468	    106	      0	     24	    598	    256	common_djob.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    906	    844	     62	      0	     20	    926	    39e	common_time.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   6835	   4328	   2507	      0	      8	   6843	   1abb	ecc_p256.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    443	    340	    103	      0	     32	    475	    1db	kernel_event.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    104	    104	      0	      0	      0	    104	     68	kernel_queue.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
     94	     84	     10	      0	      0	     94	     5e	rwble.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1697	   1668	     29	      0	      0	   1697	    6a1	llc_dl_upd.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    811	    598	    213	      0	      0	    811	    32b	llc_hci.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    820	    754	     66	      0	      0	    820	    334	llc_le_ping.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1611	    996	    615	      0	      0	   1611	    64b	llc_llcp.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   2160	   2160	      0	      0	      0	   2160	    870	llc_past.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   3157	   3010	    147	      0	      0	   3157	    c55	llc_phy_upd.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    224	    224	      0	      0	      0	    224	     e0	llc_pwr.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    280	     36	    244	      0	      8	    288	    120	llc_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    955	    904	     51	      0	      0	    955	    3bb	llc_ver_exch.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   4111	   3224	    887	      0	     77	   4188	   105c	lld.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
  11971	   9980	   1991	      0	     32	  12003	   2ee3	lld_adv.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   5793	   5046	    747	      0	      4	   5797	   16a5	lld_init.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   5035	   3944	   1091	      0	     32	   5067	   13cb	lld_per_adv.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   9126	   7948	   1178	      0	      8	   9134	   23ae	lld_scan.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   3278	   2400	    878	      0	      5	   3283	    cd3	lld_test.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   9051	   8476	    575	      0	      0	   9051	   235b	llm_adv.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    418	    262	    156	      0	      1	    419	    1a3	llm_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1287	   1242	     45	      0	      0	   1287	    507	llm_test.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    441	    416	     25	      0	      0	    441	    1b9	ble_aes_rpa.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1951	   1684	    267	      0	     24	   1975	    7b7	sch_arb.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1314	   1250	     64	      0	      9	   1323	    52b	sch_plan.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   2284	   1486	    798	      0	    260	   2544	    9f0	sch_prog.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    705	    588	    117	      0	     88	    793	    319	sch_slice.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1151	    912	    239	      0	   3128	   4279	   10b7	hci_packet_parser.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    383	    360	     23	      0	      0	    383	    17f	ble_util.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    953	    828	    125	      0	    344	   1297	    511	ble_util_buf.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1228	   1144	     84	      0	      0	   1228	    4cc	llc_chmap_upd.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    883	    830	     53	      0	      0	    883	    373	llc_clk_acc.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   4362	   4088	    274	      0	      0	   4362	   110a	llc_con_upd.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1049	    918	    131	      0	      0	   1049	    419	llc_disconnect.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   3644	   3504	    140	      0	      0	   3644	    e3c	llc_encrypt.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   1051	   1018	     33	      0	      0	   1051	    41b	llc_feat_exch.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   4149	   3394	    755	      0	      0	   4149	   1035	llm_hci.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   2820	   2604	    216	      0	      0	   2820	    b04	llm_init.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
   5332	   3328	   2004	      0	      0	   5332	   14d4	hci_msg.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
     48	     48	      0	      0	      0	     48	     30	dbg.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
    102	    102	      0	      0	     44	    146	     92	kernel.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a)
 160543	 135218	  25325	     61	  20569	 181173	  2c3b5	/home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbluetooth_controller_controller_only.a
    464	    464	      0	      0	     24	    488	    1e8	bk_phy_if.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
     64	     64	      0	      0	      1	     65	     41	bk7011_cal.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
  26487	  22582	   3905	     27	    506	  27020	   698c	bk7236_cal.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
  21241	  16198	   5043	     58	    227	  21526	   5416	manual_cal_bk7236.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
    388	    388	      0	      0	      0	    388	    184	rc_driver.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
   1911	   1504	    407	      0	      8	   1919	    77f	la_driver.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
    154	    154	      0	      0	      0	    154	     9a	nv_parameters.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
    429	    404	     25	      0	     24	    453	    1c5	rf_cntrl.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
   1684	   1300	    384	      8	     28	   1720	    6b8	tx_evm.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
   2781	   2128	    653	      0	     32	   2813	    afd	cmd_rx_sensitivity.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
    956	    956	      0	      0	      0	    956	    3bc	bk_cal_common.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
   3648	   2960	    688	      0	     68	   3716	    e84	rx_sensitivity.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
   6237	   4240	   1997	      8	     12	   6257	   1871	cmd_evm.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
   1516	   1452	     64	      0	      1	   1517	    5ed	mac_phy_bypass.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a)
  67960	  54794	  13166	    101	    931	  68992	  10d80	/home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libbk_phy.a
   1952	   1220	    732	      0	      8	   1960	    7a8	tuya_app_main.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    700	    700	      0	      0	      8	    708	    2c4	tal_uart.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    870	    582	    288	      0	      8	    878	    36e	lv_port_disp.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    399	    290	    109	      0	      0	    399	    18f	lv_log.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1405	   1364	     41	      0	      0	   1405	    57d	lv_color.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1516	   1516	      0	      0	      0	   1516	    5ec	lv_style_gen.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1606	    952	    654	      0	      0	   1606	    646	lv_style.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1892	   1360	    532	      0	      4	   1896	    768	lv_timer.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2297	   2012	    285	      0	      0	   2297	    8f9	lv_anim.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    203	     64	    139	      0	      0	    203	     cb	lv_st7735.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    168	    168	      0	      0	      0	    168	     a8	lv_tick.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   7216	   5474	   1742	      0	      0	   7216	   1c30	lv_display.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
  10164	  10148	     16	      0	      0	  10164	   27b4	lv_theme_default.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    322	    322	      0	      0	      0	    322	    142	lv_theme.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1291	   1008	    283	      0	      0	   1291	    50b	lv_sysmon.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    866	    586	    280	      0	      0	    866	    362	lv_tileview.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   5313	   4540	    773	      0	      0	   5313	   14c1	lv_buttonmatrix.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1352	   1086	    266	      0	      0	   1352	    548	lv_checkbox.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    313	    268	     45	      0	      0	    313	    139	lv_win.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    412	    284	    128	      0	      0	    412	    19c	lv_list.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   6757	   6132	    625	      0	      0	   6757	   1a65	lv_scale.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   5083	   4224	    859	      0	      0	   5083	   13db	lv_image.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   6402	   5530	    872	      0	      0	   6402	   1902	lv_table.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   6284	   5530	    754	      0	      0	   6284	   188c	lv_label.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1419	   1060	    359	      0	      0	   1419	    58b	lv_switch.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1684	   1288	    396	      0	      0	   1684	    694	lv_led.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3189	   2792	    397	      0	      0	   3189	    c75	lv_bar.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   4103	   3094	   1009	      0	      0	   4103	   1007	lv_menu.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    274	    230	     44	      0	      0	    274	    112	lv_spinner.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2609	   2364	    245	      0	      0	   2609	    a31	lv_slider.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1085	    552	    533	      0	      0	   1085	    43d	lv_calendar_header_arrow.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2564	   1894	    670	      0	      0	   2564	    a04	lv_calendar.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1216	    494	    722	      0	      0	   1216	    4c0	lv_calendar_header_dropdown.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   8085	   6756	   1329	      0	      4	   8089	   1f99	lv_textarea.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   9433	   8300	   1133	      0	      0	   9433	   24d9	lv_chart.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   4053	   3598	    455	      0	      0	   4053	    fd5	lv_roller.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   5899	   5038	    861	      0	      0	   5899	   170b	lv_dropdown.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2439	   1940	    499	      0	      0	   2439	    987	lv_spinbox.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1890	   1546	    344	      0	      0	   1890	    762	lv_tabview.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2483	   1238	   1245	     80	      0	   2563	    a03	lv_keyboard.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1519	   1090	    429	      0	      0	   1519	    5ef	lv_line.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1702	   1026	    676	      0	      0	   1702	    6a6	lv_msgbox.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   5859	   5110	    749	      0	      0	   5859	   16e3	lv_arc.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2286	   1672	    614	      0	      0	   2286	    8ee	lv_obj_event.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2555	   2136	    419	      0	      0	   2555	    9fb	lv_group.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3642	   2942	    700	      0	      0	   3642	    e3a	lv_obj_tree.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   5406	   4956	    450	      0	      0	   5406	   151e	lv_obj_style.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   7759	   7120	    639	      0	      0	   7759	   1e4f	lv_obj_pos.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   4092	   3700	    392	      0	      0	   4092	    ffc	lv_obj.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1742	   1742	      0	      0	      0	   1742	    6ce	lv_obj_style_gen.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   5058	   4540	    518	      0	      0	   5058	   13c2	lv_refr.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   4776	   4560	    216	      0	      0	   4776	   12a8	lv_obj_scroll.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    431	    248	    183	      0	      0	    431	    1af	lv_mem.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1109	    810	    299	      0	  65536	  66645	  10455	lv_mem_core_builtin.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    974	    974	      0	      0	      0	    974	    3ce	lv_string_builtin.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   5993	   3348	   2645	      0	      0	   5993	   1769	lv_tlsf.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    545	    364	    181	      0	    500	   1045	    415	lv_init.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   6916	   6122	    794	      0	      0	   6916	   1b04	lv_indev.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3172	   3172	      0	      0	      0	   3172	    c64	lv_indev_scroll.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    608	    608	      0	      0	      0	    608	    260	lv_ll.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2124	   2124	      0	      0	      0	   2124	    84c	lv_area.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2255	   1868	    387	      0	      0	   2255	    8cf	lv_fs.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    180	    180	      0	      0	      0	    180	     b4	lv_async.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1414	    976	    438	      0	      0	   1414	    586	lv_math.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2319	   2078	    241	      0	      0	   2319	    90f	lv_text.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2806	   1156	   1650	      0	      0	   2806	    af6	lv_event.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    458	    240	    218	      0	      0	    458	    1ca	lv_utils.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1139	    898	    241	      0	      0	   1139	    473	lv_lcd_generic_mipi.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    400	    200	    200	      0	      0	    400	    190	lv_draw_mask.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    362	    232	    130	      0	      0	    362	    16a	lv_draw_line.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1903	   1514	    389	      0	      0	   1903	    76f	lv_draw_image.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1449	   1154	    295	      0	      0	   1449	    5a9	lv_image_decoder.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1928	   1508	    420	      0	      0	   1928	    788	lv_draw.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3961	   2912	   1049	      0	      0	   3961	    f79	lv_draw_buf.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    337	    334	      3	      0	      0	    337	    151	lv_draw_sw.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   4292	   4098	    194	      0	      0	   4292	   10c4	lv_draw_sw_mask.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2675	   2448	    227	      0	      0	   2675	    a73	lv_draw_label.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1226	   1098	    128	      0	      0	   1226	    4ca	lv_draw_arc.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1999	   1754	    245	      0	      0	   1999	    7cf	lv_draw_rect.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    420	    204	    216	      0	      0	    420	    1a4	lv_layout.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3348	   3348	      0	      0	      0	   3348	    d14	lv_theme_mono.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2186	   2186	      0	      0	      0	   2186	    88a	lv_theme_simple.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   4836	   3784	   1052	      0	      0	   4836	   12e4	lv_observer.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    789	    542	    247	      0	      0	    789	    315	lv_font.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   5972	   5180	    792	      0	      0	   5972	   1754	lv_span.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1727	   1116	    611	      0	      0	   1727	    6bf	lv_cache_entry.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1929	   1432	    497	      0	      0	   1929	    789	lv_cache.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    918	    584	    334	      0	      0	    918	    396	lv_image_cache.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    909	    554	    355	      0	      0	    909	    38d	lv_image_header_cache.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1151	    852	    299	      0	      0	   1151	    47f	lv_array.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1918	   1612	    306	      0	      0	   1918	    77e	lv_rb.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1279	    928	    351	      0	      0	   1279	    4ff	lv_iter.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    805	    552	    253	      0	      0	    805	    325	lv_draw_sw_gradient.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3050	   2824	    226	      0	      0	   3050	    bea	lv_grid.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2419	   1758	    661	      0	      0	   2419	    973	lv_circle_buf.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    532	    318	    214	      0	     20	    552	    228	lvgl_test.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    465	    340	    125	      0	      1	    466	    1d2	app_key.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1063	    912	    151	     36	      0	   1099	    44b	dp_process.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    273	    254	     19	      0	      6	    279	    117	app_led.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    284	    284	      0	      0	      0	    284	    11c	lv_color_op.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1166	    344	    822	      0	      0	   1166	    48e	lv_palette.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
  13637	      0	  13637	      0	      0	  13637	   3545	lv_font_montserrat_14.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1363	   1116	    247	      0	      0	   1363	    553	lv_font_fmt_txt.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
     97	     52	     45	      0	      0	     97	     61	lv_button.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2245	   2100	    145	      0	      0	   2245	    8c5	lv_obj_draw.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    699	    484	    215	      0	      0	    699	    2bb	lv_obj_class.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2002	   2002	      0	      0	      0	   2002	    7d2	lv_sprintf_builtin.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    294	    294	      0	      0	      0	    294	    126	lv_draw_sw_letter.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1477	   1306	    171	      0	      0	   1477	    5c5	lv_draw_sw_arc.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    366	    366	      0	      0	      0	    366	    16e	lv_draw_sw_mask_rect.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2682	   2396	    286	      0	      0	   2682	    a7a	lv_draw_sw_img.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    882	    882	      0	      0	      0	    882	    372	lv_draw_sw_triangle.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1252	   1100	    152	      0	      0	   1252	    4e4	lv_draw_sw_fill.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3054	   2868	    186	      0	      0	   3054	    bee	lv_flex.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
      2	      2	      0	      0	      0	      2	      2	lv_os.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3141	   2294	    847	      0	      0	   3141	    c45	lv_bin_decoder.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   2480	   1856	    624	      0	      0	   2480	    9b0	lv_cache_lru_rb.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1565	   1532	     33	      0	      0	   1565	    61d	lv_draw_sw_line.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
    884	    708	    176	      0	      0	    884	    374	lv_draw_sw_blend.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   4441	   4190	    251	      0	      0	   4441	   1159	lv_draw_sw_blend_to_i1.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   5099	   4786	    313	      0	      0	   5099	   13eb	lv_draw_sw_blend_to_rgb565.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3768	   3538	    230	      0	      0	   3768	    eb8	lv_draw_sw_blend_to_rgb888.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   4334	   4100	    234	      0	      0	   4334	   10ee	lv_draw_sw_blend_to_argb8888.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3076	   2854	    222	      0	      0	   3076	    c04	lv_draw_sw_blend_to_l8.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3662	   3436	    226	      0	      0	   3662	    e4e	lv_draw_sw_blend_to_al88.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   1278	   1278	      0	      0	      0	   1278	    4fe	lv_draw_sw_border.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3478	   3312	    166	      0	      0	   3478	    d96	lv_draw_sw_box_shadow.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
   3322	   3026	    296	      0	      0	   3322	    cfa	lv_draw_sw_transform.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a)
 324598	 262342	  62256	    116	  66095	 390809	  5f699	/home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos_demo_quickstart_lvgl.a
   1868	   1700	    168	      0	    100	   1968	    7b0	tal_time_serivce.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2216	   1800	    416	      0	      0	   2216	    8a8	tuya_ws_db.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   6964	   6924	     40	     12	     23	   6999	   1b57	ty_cJSON.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2110	   1496	    614	      0	    104	   2214	    8a6	uni_network.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   7334	   5840	   1494	      0	    436	   7770	   1e5a	mqc_app.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   7484	   6408	   1076	     52	      0	   7536	   1d70	tuya_svc_mqtt_client.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    422	    380	     42	     28	      5	    455	    1c7	tuya_svc_wired.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    384	    348	     36	      0	      0	    384	    180	tuya_transport.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    130	    130	      0	      0	      0	    130	     82	tal_wired.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1100	   1100	      0	      0	      0	   1100	    44c	tal_network.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   3681	   3050	    631	      1	      1	   3683	    e63	tuya_iot_com_api.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    132	     92	     40	      0	      4	    136	     88	tuya_iot_api_pre_handle.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2659	   2282	    377	     88	      8	   2755	    ac3	tal_wifi.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
  10130	   8062	   2068	      0	    148	  10278	   2826	tuya_svc_upgrade.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   5701	   4402	   1299	      0	      9	   5710	   164e	tuya_svc_devos.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   4448	   3380	   1068	      0	      0	   4448	   1160	ws_db_gw.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   6009	   5054	    955	      4	   3709	   9722	   25fa	tuya_devos_utils.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    356	    290	     66	      0	      4	    360	    168	tuya_devos.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   3671	   2508	   1163	      0	      4	   3675	    e5b	tuya_devos_health.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1130	   1010	    120	      0	      4	   1134	    46e	tuya_devos_reset.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2519	   2038	    481	      4	     33	   2556	    9fc	tuya_svc_devos_daemons.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    212	    212	      0	      0	      0	    212	     d4	tal_flash.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
     60	     60	      0	      0	      0	     60	     3c	tal_watchdog.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
  10867	   7920	   2947	      0	     60	  10927	   2aaf	ap_netcfg.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    305	    254	     51	      0	      0	    305	    131	ap_pbkdf2.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1390	   1128	    262	     32	      5	   1427	    593	netcfg_module.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    259	    196	     63	      0	      4	    263	    107	user_netcfg.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   3274	   2788	    486	      4	      4	   3282	    cd2	wifi_netcfg_frame_transporter.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1744	   1468	    276	      0	      8	   1752	    6d8	wifi_netcfg_frame_sniffer.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   4410	   3460	    950	     28	     16	   4454	   1166	tuya_wifi_link.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   3922	   2776	   1146	      4	     32	   3958	    f76	tuya_wifi_connect.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    677	    508	    169	      1	     11	    689	    2b1	tuya_wifi_status.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   3480	   2630	    850	      4	     32	   3516	    dbc	tuya_wifi_reset.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   9572	   7254	   2318	      4	      8	   9584	   2570	tuya_wifi_protect.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   4853	   3758	   1095	      1	     16	   4870	   1306	tuya_wifi_netcfg.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    335	    288	     47	      0	      8	    343	    157	tal_system.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1938	   1376	    562	      0	     16	   1954	    7a2	tal_thread.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    316	    316	      0	      0	      0	    316	    13c	tal_template.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1184	    832	    352	      0	     21	   1205	    4b5	tal_sleep.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2033	   1864	    169	      0	      4	   2037	    7f5	tal_log.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1407	   1220	    187	      0	     40	   1447	    5a7	tal_sw_timer.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    728	    504	    224	      0	      0	    728	    2d8	tuya_uf_db.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1606	   1272	    334	      0	     40	   1646	    66e	tuya_svc_netmgr_linkage.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    471	    372	     99	      0	      4	    475	    1db	tuya_svc_netmgr_daemon.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    291	    284	      7	      0	      0	    291	    123	tuya_svc_netmgr.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1146	   1146	      0	      0	      0	   1146	    47a	tal_symmetry.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    948	    948	      0	      0	      0	    948	    3b4	tal_hash.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    294	    294	      0	      0	      0	    294	    126	mbedtls_hash.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
  10047	   6258	   3789	      2	     32	  10081	   2761	httpc.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    219	    202	     17	      0	      4	    223	     df	uni_random.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1224	   1190	     34	      0	      1	   1225	    4c9	mix_method.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1088	     64	   1024	      0	      0	   1088	    440	crc32i.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2782	   2776	      6	      0	      0	   2782	    ade	tuya_lib_mqtt.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    682	    642	     40	      0	      8	    690	    2b2	kv_storge.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1754	   1362	    392	      0	     36	   1790	    6fe	simple_flash_app.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
  11274	   9842	   1432	      0	      4	  11278	   2c0e	simple_flash.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
  20973	  15634	   5339	     84	     12	  21069	   524d	iot_httpc.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   5820	   4258	   1562	      0	     56	   5876	   16f4	tuya_cert_manager.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1009	    744	    265	      0	      0	   1009	    3f1	cipher_wrapper.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   3779	   3084	    695	      0	     16	   3795	    ed3	com_protocol.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   3257	   2128	   1129	      4	    148	   3409	    d51	tuya_svc_online_log.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1031	    772	    259	      0	     12	   1043	    413	svc_netcfg_qrcode.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1639	   1440	    199	     28	     32	   1699	    6a3	tuya_register_center.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   4724	   3334	   1390	     29	   3272	   8025	   1f59	tuya_tls.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   9336	   6954	   2382	      0	    256	   9592	   2578	tuya_svc_timer_task.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   4074	   3628	    446	      0	    216	   4290	   10c2	log_seq.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1686	   1276	    410	      0	     28	   1714	    6b2	tuya_svc_mqtt_direct.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    665	    572	     93	      0	      0	    665	    299	tuya_iot_internal_api.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1645	   1200	    445	    156	      0	   1801	    709	tal_wifi_reconnet.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2581	   2384	    197	      4	     16	   2601	    a29	tal_wifi_mgnt.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   4348	   4348	      0	      0	   8748	  13096	   3328	aes.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    838	    838	      0	      0	      0	    838	    346	ecdh.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
     46	     46	      0	     16	      0	     62	     3e	threading.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   4100	   4100	      0	      0	      0	   4100	   1004	ssl_msg.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
     50	     50	      0	      8	      0	     58	     3a	platform.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    998	    998	      0	      0	      0	    998	    3e6	entropy.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    794	    784	     10	      0	      0	    794	    31a	pkcs5.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1302	   1302	      0	      0	      0	   1302	    516	ctr_drbg.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   8013	   7916	     97	     69	      0	   8082	   1f92	ssl_tls.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1448	   1330	    118	      0	      0	   1448	    5a8	md.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1084	   1084	      0	      0	      0	   1084	    43c	asn1parse.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2656	   2656	      0	      0	      4	   2660	    a64	cipher.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   8008	   7622	    386	      0	     18	   8026	   1f5a	ecp.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   9797	   9108	    689	      0	      0	   9797	   2645	bignum.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1390	   1390	      0	      0	      0	   1390	    56e	constant_time.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   3896	   3516	    380	      0	      0	   3896	    f38	pkparse.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   9116	   6856	   2260	      0	      0	   9116	   239c	x509_crt.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    790	    790	      0	      0	      4	    794	    31a	uf_file.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    438	    340	     98	      0	      0	    438	    1b6	tal_x509.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1953	   1672	    281	      0	      0	   1953	    7a1	http_inf.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2788	   2184	    604	      0	      0	   2788	    ae4	simple_flash_protected.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    158	    122	     36	      0	      0	    158	     9e	svc_online_log_mqtt.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    875	    848	     27	      0	      0	    875	    36b	pk.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   6546	   6546	      0	      0	      0	   6546	   1992	rsa.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   3366	    266	   3100	      0	    144	   3510	    db6	ssl_ciphersuites.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    962	    962	      0	      0	      0	    962	    3c2	chacha20.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1332	   1048	    284	      0	      0	   1332	    534	pk_wrap.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2062	    410	   1652	      0	    116	   2178	    882	cipher_wrap.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2242	   2160	     82	      0	      0	   2242	    8c2	x509.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1592	   1592	      0	      0	      0	   1592	    638	ccm.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   5157	    938	   4219	      0	      0	   5157	   1425	oid.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1375	   1268	    107	      0	      0	   1375	    55f	pem.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1000	   1000	      0	      0	      0	   1000	    3e8	pkcs12.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1855	   1446	    409	      0	     36	   1891	    763	uf_flash_file_app.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1410	   1410	      0	      0	      0	   1410	    582	ecdsa.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1366	   1366	      0	      0	      0	   1366	    556	asn1write.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1124	   1124	      0	      0	      0	   1124	    464	poly1305.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   5305	   4980	    325	      0	      0	   5305	   14b9	uf_flash_file.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1714	   1616	     98	      0	     28	   1742	    6ce	base_event.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    218	    120	     98	      0	      4	    222	     de	tuya_base_utilities.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    609	    488	    121	      0	      8	    617	    269	tal_workq_service.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    821	    594	    227	      0	      0	    821	    335	tls_transporter.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    390	    260	    130	      1	      4	    395	    18b	tuya_upgrade_main.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1801	   1340	    461	      0	     48	   1849	    739	tuya_svc_schema_upgrade.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   3885	   3044	    841	      0	     44	   3929	    f59	multi_section_upgrade.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1120	    828	    292	      0	      0	   1120	    460	tuya_svc_upgrade_http.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    931	    696	    235	      0	      0	    931	    3a3	tuya_devos_mqc.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1704	   1480	    224	      0	     28	   1732	    6c4	tuya_svc_devos_activate.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    746	    508	    238	      0	      0	    746	    2ea	tuya_svc_devos_activate_ext_module.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    832	    586	    246	      0	      0	    832	    340	tuya_svc_devos_activate_token.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    586	    400	    186	      0	      0	    586	    24a	tuya_svc_devos_activate_meta.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1117	    772	    345	      0	      4	   1121	    461	tuya_devos_stride.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2088	   1408	    680	      0	     36	   2124	    84c	tuya_devos_localkey_update.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    803	    756	     47	      0	      0	    803	    323	tal_workqueue.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
      4	      4	      0	     28	      0	     32	     20	tuya_svc_netmgr_linkage_virtual.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    162	    162	      0	      0	      0	    162	     a2	mbedtls_symmetry.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    228	    228	      0	      0	      0	    228	     e4	uni_log.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
     72	     72	      0	      0	      0	     72	     48	crc_16.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
     80	     80	      0	      0	      0	     80	     50	uni_base64.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    773	    638	    135	      0	     12	    785	    311	ty_meta_report.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
      4	      4	      0	      0	      0	      4	      4	svc_online_log_http.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   4366	   3324	   1042	      0	      4	   4370	   1112	astro_timer.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1038	    876	    162	      0	      0	   1038	    40e	tcp_transporter.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    413	    412	      1	      0	      0	    413	    19d	hkdf.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2644	   2388	    256	      0	      0	   2644	    a54	sha256.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    564	    564	      0	      0	      0	    564	    234	base64.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
  37706	   5286	  32420	     28	      0	  37734	   9366	ecp_curves.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
     62	     62	      0	      0	      0	     62	     3e	entropy_poll.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2306	   2306	      0	      0	      0	   2306	    902	md5.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   3808	   3786	     22	      0	      0	   3808	    ee0	ssl_cli.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   4132	   4132	      0	      0	      0	   4132	   1024	sha1.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
     20	     20	      0	      4	      0	     24	     18	platform_util.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1221	    728	    493	      0	      0	   1221	    4c5	wifi_ap_activate.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    140	    120	     20	      0	      0	    140	     8c	svc_online_log_db.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   2132	   2004	    128	      0	      0	   2132	    854	gcm.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   4270	   3630	    640	      0	      0	   4270	   10ae	sha512.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
    784	    784	      0	      0	      0	    784	    310	chachapoly.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
   1591	   1536	     55	      0	      0	   1591	    637	rsa_alt_helpers.c.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a)
 408924	 307624	 101300	    728	  18360	 428012	  687ec	/home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/libs/libtuyaos.a
   text	   code	 rodata	   data	    bss	    dec	    hex	filename
    853	    778	     75	      0	      0	    853	    355	co_list.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   4542	   3850	    692	      0	     33	   4575	   11df	ps.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   4460	   3772	    688	      0	   2628	   7088	   1bb0	vif_mgmt.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2233	   1906	    327	      0	    199	   2432	    980	td.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1441	   1392	     49	      0	     80	   1521	    5f1	txl_cfm.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   5265	   4754	    511	      2	    392	   5659	   161b	txl_cntrl.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
     44	      4	     40	      0	      0	     44	     2c	tx_swdesc.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   3572	   3184	    388	    412	     46	   4030	    fbe	rwnx.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    943	    742	    201	      0	      0	    943	    3af	tpc.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2679	   2378	    301	      0	     44	   2723	    aa3	scan.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2103	   1864	    239	      0	     33	   2136	    858	rxl_cntrl.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   8970	   6002	   2968	      0	      5	   8975	   230f	hal_machw.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   4889	   4656	    233	      0	      0	   4889	   1319	me_utils.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   4084	   3786	    298	      0	      0	   4084	    ff4	me_mgmtframe.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2521	   2192	    329	      0	    112	   2633	    a49	me_strategy.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    526	    430	     96	      0	    396	    922	    39a	me.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   5612	   5218	    394	      0	   3296	   8908	   22cc	scanu.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   7584	   7064	    520	      0	   5128	  12712	   31a8	rxu_cntrl.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   3642	   3276	    366	      0	    844	   4486	   1186	bam.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2549	   2380	    169	      0	     16	   2565	    a05	apm.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   4369	   3880	    489	      0	     36	   4405	   1135	txu_cntrl.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2711	   2510	    201	      0	    643	   3354	    d1a	twt.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
  13277	  11260	   2017	      0	    472	  13749	   35b5	rc.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   3283	   2814	    469	      0	  17728	  21011	   5213	rxl_hwdesc.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    558	    484	     74	      0	      8	    566	    236	crm.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
  10832	   8456	   2376	      0	     53	  10885	   2a85	phy_karst_bk7236.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2168	   1628	    540	    128	      0	   2296	    8f8	bk_wifi_phy_api.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
  16700	  13816	   2884	     11	    248	  16959	   423f	wifi_v2.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    919	    716	    203	      0	      0	    919	    397	wifi_api_wrapper_internal.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
     58	     58	      0	      0	      0	     58	     3a	sa_ap.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    502	    388	    114	      4	      4	    510	    1fe	sa_station.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    177	    124	     53	      0	      0	    177	     b1	wifi_init.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1182	    868	    314	      0	      0	   1182	    49e	wifi_rw.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    823	    660	    163	      0	      0	    823	    337	wifi_netif.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    980	    980	      0	      4	    805	   1789	    6fd	lsig_monitor.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    658	    632	     26	      8	      4	    670	    29e	bk_workqueue.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1367	   1072	    295	   1099	    648	   3114	    c2a	rw_ieee80211.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   4857	   4440	    417	      4	    105	   4966	   1366	rw_msg_rx.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   5079	   4892	    187	      0	      1	   5080	   13d8	rw_msg_tx.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   3267	   2696	    571	      0	     33	   3300	    ce4	rw_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1597	   1490	    107	      0	      0	   1597	    63d	rwnx_rx.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2933	   2374	    559	      0	      0	   2933	    b75	rwnx_tx.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   3026	   2786	    240	      0	      0	   3026	    bd2	rwnx_txq.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    867	    844	     23	      0	      0	    867	    363	rwnx_utils.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    456	    404	     52	      0	      4	    460	    1cc	skbuff.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2802	   2380	    422	    140	      0	   2942	    b7e	rwnx_params.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    390	    352	     38	      0	      0	    390	    186	sk_intf.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   4739	   3798	    941	      4	     52	   4795	   12bb	main_none.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1745	   1548	    197	      0	      0	   1745	    6d1	ap_config.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2478	   2458	     20	      0	      0	   2478	    9ae	ap_drv_ops.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   7459	   7204	    255	      0	      0	   7459	   1d23	hostapd.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2761	   2652	    109	      0	      0	   2761	    ac9	hw_features.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
     58	     58	      0	      0	      0	     58	     3a	ieee802_11_auth.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   3878	   3468	    410	      0	      0	   3878	    f26	sta_info.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    158	    158	      0	      0	      0	    158	     9e	utils.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
  13043	  11562	   1481	      0	      0	  13043	   32f3	wpa_auth.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1220	   1220	      0	      0	      0	   1220	    4c4	hw_features_common.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
  10578	   5832	   4746	      4	      0	  10582	   2956	ieee802_11_common.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   7467	   6894	    573	      0	      0	   7467	   1d2b	wpa_common.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1609	   1502	    107	      0	     20	   1629	    65d	wpa_psk_cache.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   4211	   1984	   2227	      0	      0	   4211	   1073	driver_common.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1311	   1104	    207	     16	      0	   1327	    52f	l2_packet_none.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
  10203	   9928	    275	      0	      1	  10204	   27dc	wpa.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   3838	   3634	    204	      4	    129	   3971	    f83	common.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2980	   2742	    238	      0	     84	   3064	    bf8	eloop.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    378	    368	     10	      0	      0	    378	    17a	os_none.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    737	    702	     35	      0	      0	    737	    2e1	wpabuf.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   5924	   5234	    690	      0	      8	   5932	   172c	ctrl_iface.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   9292	   9046	    246	      0	      0	   9292	   244c	events.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    835	    772	     63	      4	     20	    859	    35b	main_supplicant.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2024	   1806	    218	      0	     17	   2041	    7f9	notify.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2780	   2422	    358	      0	      0	   2780	    adc	wmm_ac.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   7330	   5906	   1424	      0	      0	   7330	   1ca2	wpa_scan.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
  16349	  15644	    705	      0	      0	  16349	   3fdd	wpa_supplicant.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2616	   2336	    280	      0	      0	   2616	    a38	wpas_glue.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1248	   1138	    110	      0	      0	   1248	    4e0	dragonfly.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   9498	   9118	    380	      0	      0	   9498	   251a	sae.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   5945	   4734	   1211	      0	      8	   5953	   1741	hostapd_intf.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    475	    436	     39	      0	    129	    604	    25c	mac.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1668	   1632	     36	      0	      0	   1668	    684	mac_ie.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    563	    364	    199	      0	      4	    567	    237	trace.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1647	   1544	    103	      0	      0	   1647	    66f	dbg_print.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    434	    302	    132	      0	      0	    434	    1b2	dbg_assert.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    812	    518	    294	      4	      0	    816	    330	ke_event.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    366	    284	     82	      0	      0	    366	    16e	ke_msg.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1218	   1028	    190	      0	      0	   1218	    4c2	ke_timer.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1531	   1290	    241	      0	     48	   1579	    62b	macif_fhost.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
  11519	   9972	   1547	      0	    696	  12215	   2fb7	mcc.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
  22824	  18706	   4118	      0	    480	  23304	   5b08	mm.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   3057	   2642	    415	      0	     28	   3085	    c0d	mm_bcn.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1211	    950	    261	      0	      8	   1219	    4c3	mm_timer.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1615	   1028	    587	      0	      2	   1617	    651	scan_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    627	    408	    219	      0	     23	    650	    28a	hal_mib.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    502	    392	    110	      0	      2	    504	    1f8	twt_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1438	   1270	    168	     12	      0	   1450	    5aa	fake_socket.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
      6	      6	      0	      0	      0	      6	      6	signal.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    880	    870	     10	      0	      0	    880	    370	ap_list.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2418	   2418	      0	      0	      0	   2418	    972	drv_callbacks.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   7349	   7226	    123	      0	      0	   7349	   1cb5	ieee802_11.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    624	    596	     28	      0	      0	    624	    270	ieee802_11_shared.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    989	    932	     57	      0	      0	    989	    3dd	ieee802_11_vht.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   4437	   2620	   1817	      0	      0	   4437	   1155	ieee802_1x.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1687	   1510	    177	      0	      0	   1687	    697	pmksa_cache_auth.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    516	    516	      0	      0	      0	    516	    204	wmm.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   9718	   7724	   1994	      0	      0	   9718	   25f6	driver_beken.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2406	   2230	    176	      0	      0	   2406	    966	pmksa_cache.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    325	    224	    101	      4	      8	    337	    151	wpa_debug.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   3696	   3492	    204	      0	      0	   3696	    e70	bss.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
  16996	   9998	   6998	      0	      0	  16996	   4264	config.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    946	    808	    138	      0	      0	    946	    3b2	config_none.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1396	   1340	     56	      0	      0	   1396	    574	op_classes.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   3142	   3136	      6	      0	      0	   3142	    c46	dfs.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1897	   1674	    223	      0	   2280	   4177	   1051	sta_mgmt.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2459	   2216	    243	      0	    288	   2747	    abb	txl_frame.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   7265	   6212	   1053	      0	   1488	   8753	   2231	txl_he.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    752	    752	      0	      0	      0	    752	    2f0	mfp.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2269	   1444	    825	      0	      0	   2269	    8dd	mfp_bip.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
     68	     56	     12	      0	      0	     68	     44	llc.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   9463	   7734	   1729	      0	      0	   9463	   24f7	wifi_wpa_cmd.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    152	     96	     56	      0	      0	    152	     98	phy.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    301	    260	     41	     10	     12	    323	    143	wifi_config.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    332	    286	     46	      0	     40	    372	    174	rwnx_td.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2228	   1284	    944	      0	      5	   2233	    8b9	rwm_proto.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1128	   1110	     18	      0	      0	   1128	    468	ieee802_11_ht.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1353	   1244	    109	      0	      0	   1353	    549	wpa_auth_glue.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1470	   1430	     40	      0	      0	   1470	    5be	wpa_auth_ie.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
      8	      0	      8	      0	      0	      8	      8	drivers.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    924	    924	      0	      0	      0	    924	    39c	wpa_ie.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1064	     40	   1024	      0	      0	   1064	    428	crc32.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   3242	   3130	    112	      0	      0	   3242	    caa	sme.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   2565	   1656	    909	      0	      8	   2573	    a0d	dbg.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1391	    898	    493	      0	      0	   1391	    56f	ke_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   9830	   6954	   2876	      0	      2	   9832	   2668	mm_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    343	    312	     31	      0	      0	    343	    157	txl_buffer.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   6157	   5418	    739	      0	   3788	   9945	   26d9	txl_agg.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
  10296	   8740	   1556	      0	    132	  10428	   28bc	sm.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   5297	   4252	   1045	      0	      2	   5299	   14b3	sm_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    463	    450	     13	      0	      0	    463	    1cf	me_mic.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   4077	   3324	    753	      0	      2	   4079	    fef	me_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1287	    868	    419	      0	      2	   1289	    509	scanu_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1710	   1500	    210	      0	     26	   1736	    6c8	bam_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1804	   1264	    540	      0	      2	   1806	    70e	apm_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    985	    784	    201	      0	      2	    987	    3db	ftm_task.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    153	    112	     41	      0	      0	    153	     99	dma.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
     16	     16	      0	      0	      0	     16	     10	wifi_wpa.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    116	    116	      0	      0	      0	    116	     74	ap_mlme.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   4856	   4792	     64	      0	      0	   4856	   12f8	beacon.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1603	   1562	     41	      0	      0	   1603	    643	ieee802_11_he.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    252	    252	      0	      0	      0	    252	     fc	tkip_countermeasures.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    993	    566	    427	      0	    256	   1249	    4e1	ocv.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
    615	    594	     21	      0	      0	    615	    267	bssid_ignore.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1060	     36	   1024	      0	      0	   1060	    424	co_math.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
   1201	   1152	     49	      0	     96	   1297	    511	ftm.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
     52	     52	      0	      0	      0	     52	     34	ddrv.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
     58	     58	      0	      0	      0	     58	     3a	ke_queue.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
      0	      0	      0	      0	    256	    256	    100	txl_buffer_shared.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
      0	      0	      0	      0	    320	    320	    140	scan_shared.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
      0	      0	      0	      0	    200	    200	     c8	scanu_shared.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
      0	      0	      0	      0	     28	     28	     1c	ke_env.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
      0	      0	      0	      0	   3424	   3424	    d60	txl_frame_shared.c.obj (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a)
 501635	 423636	  77999	   1874	  48470	 551979	  86c2b	/home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/t3_os/armino/components/bk_libs/bk7236/libs/libwifi.a
     16	     16	      0	      0	      0	     16	     10	lib_a-atoi.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     16	     16	      0	      0	      0	     16	     10	lib_a-atol.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     16	     16	      0	      0	      0	     16	     10	lib_a-atoll.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    728	    728	      0	      0	      0	    728	    2d8	lib_a-findfp.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    132	    132	      0	      0	      0	    132	     84	lib_a-fwalk.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     40	     40	      0	      0	      9	     49	     31	lib_a-lock.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    176	    176	      0	      0	      0	    176	     b0	lib_a-sscanf.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
   4411	   4316	     95	      0	      0	   4411	   113b	lib_a-strtod.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    112	    112	      0	      0	      0	    112	     70	lib_a-strtok_r.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    376	    376	      0	      0	      0	    376	    178	lib_a-strtol.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    400	    400	      0	      0	      0	    400	    190	lib_a-strtoll.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    328	    328	      0	      0	      0	    328	    148	lib_a-strtoul.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     36	     36	      0	      0	      0	     36	     24	lib_a-vprintf.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    148	    148	      0	      0	      0	    148	     94	lib_a-vsscanf.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    220	    220	      0	      0	      0	    220	     dc	lib_a-fclose.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     18	      4	     14	      2	      0	     20	     14	lib_a-lnumeric.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    152	    140	     12	    364	      4	    520	    208	lib_a-locale.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     20	     20	      0	      0	      0	     20	     14	lib_a-localeconv.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    153	    152	      1	      0	      0	    153	     99	lib_a-mbrtowc.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     64	     64	      0	      0	      0	     64	     40	lib_a-mbtowc_r.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
   3139	   2720	    419	      0	      0	   3139	    c43	lib_a-mprec.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    428	    428	      0	      0	      0	    428	    1ac	lib_a-strtoull.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
   6022	   5988	     34	      0	      0	   6022	   1786	lib_a-svfiscanf.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    452	    452	      0	      0	      0	    452	    1c4	lib_a-ungetc.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
   7338	   7240	     98	      0	      0	   7338	   1caa	lib_a-vfprintf.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     48	     48	      0	      0	      0	     48	     30	lib_a-wctomb_r.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    320	    320	      0	      0	      0	    320	    140	lib_a-makebuf.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
   3855	   3776	     79	      0	      0	   3855	    f0f	lib_a-vfiprintf.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    380	    380	      0	      0	      0	    380	    17c	lib_a-fputwc.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    192	    192	      0	      0	      0	    192	     c0	lib_a-wbuf.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    136	    136	      0	      0	      0	    136	     88	lib_a-wcrtomb.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    257	      0	    257	      0	      0	    257	    101	lib_a-ctype_.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    536	    536	      0	      0	      0	    536	    218	lib_a-fflush.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
      4	      0	      4	   1068	      0	   1072	    430	lib_a-impure.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     96	     96	      0	      0	      0	     96	     60	lib_a-memcmp.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    248	    248	      0	      0	      0	    248	     f8	lib_a-memmove.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    164	    164	      0	      0	      0	    164	     a4	lib_a-memset.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
   1580	   1580	      0	      0	      0	   1580	    62c	lib_a-qsort.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     76	     76	      0	      0	      0	     76	     4c	lib_a-rand.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    148	    148	      0	      0	      0	    148	     94	lib_a-stdio.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     76	     76	      0	      0	      0	     76	     4c	lib_a-strcasecmp.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     64	     64	      0	      0	      0	     64	     40	lib_a-strcat.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    204	    204	      0	      0	      0	    204	     cc	lib_a-strchr.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    188	    188	      0	      0	      0	    188	     bc	lib_a-strcpy.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     92	     92	      0	      0	      0	     92	     5c	lib_a-strlen-stub.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     88	     88	      0	      0	      0	     88	     58	lib_a-strncasecmp.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     92	     92	      0	      0	      0	     92	     5c	lib_a-strncat.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    120	    120	      0	      0	      0	    120	     78	lib_a-strncmp.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    100	    100	      0	      0	      0	    100	     64	lib_a-strncpy.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     36	     36	      0	      0	      0	     36	     24	lib_a-strrchr.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
   1080	   1080	      0	      0	      0	   1080	    438	lib_a-strstr.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     16	     16	      0	      0	      0	     16	     10	lib_a-strtok.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
   5995	   5956	     39	      0	      0	   5995	   176b	lib_a-svfscanf.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     44	     44	      0	      0	      0	     44	     2c	lib_a-writer.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     36	     36	      0	      0	      0	     36	     24	lib_a-closer.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     12	     12	      0	      0	      0	     12	      c	lib_a-errno.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
   2094	   1684	    410	      0	      0	   2094	    82e	lib_a-gdtoa-gethex.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    492	    492	      0	      0	      0	    492	    1ec	lib_a-gdtoa-hexnan.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
      8	      8	      0	      0	      0	      8	      8	lib_a-iswspace.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     24	     24	      0	      0	      0	     24	     18	lib_a-iswspace_l.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     44	     44	      0	      0	      0	     44	     2c	lib_a-lseekr.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     44	     44	      0	      0	      0	     44	     2c	lib_a-readr.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     16	     16	      0	      0	      0	     16	     10	lib_a-s_nan.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    144	    144	      0	      0	      0	    144	     90	lib_a-sccl.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     12	     12	      0	      0	      0	     12	      c	lib_a-sf_nan.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     36	     36	      0	      0	      0	     36	     24	lib_a-strnlen.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    212	    212	      0	      0	      0	    212	     d4	lib_a-wsetup.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    108	    108	      0	      0	      0	    108	     6c	lib_a-callocr.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
   4374	   4232	    142	      0	      0	   4374	   1116	lib_a-dtoa.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    128	    128	      0	      0	      0	    128	     80	lib_a-memchr-stub.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    112	    112	      0	      0	      0	    112	     70	lib_a-s_frexp.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     44	     44	      0	      0	      0	     44	     2c	lib_a-fstatr.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
    756	    756	      0	      0	      0	    756	    2f4	lib_a-fvwrite.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
     36	     36	      0	      0	      0	     36	     24	lib_a-isattyr.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a)
  49908	  48304	   1604	   1434	     13	  51355	   c89b	/home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libc.a
    380	    380	      0	      0	      0	    380	    17c	tkl_flash.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    468	    448	     20	    588	      0	   1056	    420	tkl_gpio.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    408	    408	      0	      0	     16	    424	    1a8	tkl_spi.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    709	    376	    333	      4	      4	    717	    2cd	tkl_uart.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
   1159	   1056	    103	      4	   1164	   2327	    917	tkl_ota.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    998	    998	      0	     16	      0	   1014	    3f6	encrypt.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
     36	      8	     28	      0	      0	     36	     24	tkl_init_wired.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    156	      8	    148	      0	      0	    156	     9c	tkl_init_network.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    128	      8	    120	      0	      0	    128	     80	tkl_init_wifi.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
     52	     16	     36	      0	      0	     52	     34	tkl_init_common.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    184	      8	    176	      0	      0	    184	     b8	tkl_init_system.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    680	    680	      0	      0	      0	    680	    2a8	tuya_queue.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    434	    434	      0	      0	      0	    434	    1b2	tuya_ringbuf.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
     78	     78	      0	      0	      0	     78	     4e	tuya_list.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    202	    202	      0	      0	      0	    202	     ca	tuya_smartpointer.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    672	    672	      0	      0	      0	    672	    2a0	tuya_tools.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
     36	     36	      0	      0	      0	     36	     24	tkl_wired.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
   2151	   1822	    329	      0	     16	   2167	    877	tkl_network.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    455	    304	    151	      0	     32	    487	    1e7	tkl_sleep.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    764	    536	    228	      0	      4	    768	    300	tkl_wakeup.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
   3258	   2346	    912	      0	      5	   3263	    cbf	cli_tuya_test.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    252	    120	    132	      0	      0	    252	     fc	tkl_memory.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    232	    182	     50	      0	      1	    233	     e9	tkl_system.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    362	    280	     82	      0	     12	    374	    176	tkl_hci.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    118	    118	      0	      0	      0	    118	     76	tkl_mutex.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
     28	     28	      0	      0	      0	     28	     1c	tkl_output.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    142	    142	      0	      0	      0	    142	     8e	tkl_thread.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    129	     92	     37	      0	      0	    129	     81	tkl_watchdog.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
   5595	   4404	   1191	     40	     25	   5660	   161c	tkl_wifi.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    176	    176	      0	      0	      0	    176	     b0	tkl_semaphore.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
    212	    212	      0	      0	      0	    212	     d4	tkl_queue.c.obj (ex armino/tuyaos_adapter/libtuyaos_adapter.a)
  20654	  16578	   4076	    652	   1279	  22585	   5839	armino/tuyaos_adapter/libtuyaos_adapter.a
    488	    488	      0	      0	      0	    488	    1e8	aes-omac1.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    264	    264	      0	      0	      0	    264	    108	aes-unwrap.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    212	    212	      0	      0	      0	    212	     d4	aes-wrap.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    200	    200	      0	      0	      0	    200	     c8	sha1-prf.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    241	    240	      1	      0	      0	    241	     f1	sha256-kdf.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    276	    276	      0	      0	      0	    276	    114	sha256-prf.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    264	    264	      0	      0	      0	    264	    108	sha384-prf.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    276	    276	      0	      0	      0	    276	    114	sha512-prf.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    241	    240	      1	      0	      0	    241	     f1	sha384-kdf.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    241	    240	      1	      0	      0	    241	     f1	sha512-kdf.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
   1092	   1056	     36	      0	      0	   1092	    444	aes-internal-dec.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    916	    880	     36	      0	      0	    916	    394	aes-internal-enc.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
   2990	    676	   2314	      0	      0	   2990	    bae	aes-internal.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    272	    272	      0	      0	      0	    272	    110	md5.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    184	    184	      0	      0	      0	    184	     b8	rc4.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    304	    304	      0	      0	      0	    304	    130	sha1-pbkdf2.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
    296	    296	      0	      0	      0	    296	    128	sha1.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
   2116	   2116	      0	      0	      0	   2116	    844	md5-internal.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
   4122	   4120	      2	      0	      0	   4122	   101a	sha1-internal.c.obj (ex armino/wpa_supplicant/libwpa_supplicant.a)
  14995	  12604	   2391	      0	      0	  14995	   3a93	armino/wpa_supplicant/libwpa_supplicant.a
   3014	   2810	    204	      0	      0	   3014	    bc6	crypto_wolfssl.c.obj (ex armino/wolfssl/libwolfssl.a)
  19327	  17534	   1793	      0	      0	  19327	   4b7f	ecc.c.obj (ex armino/wolfssl/libwolfssl.a)
   1142	   1130	     12	      0	      0	   1142	    476	hmac.c.obj (ex armino/wolfssl/libwolfssl.a)
   2276	   2276	      0	      0	      0	   2276	    8e4	md5.c.obj (ex armino/wolfssl/libwolfssl.a)
   2396	   1904	    492	      0	      0	   2396	    95c	random.c.obj (ex armino/wolfssl/libwolfssl.a)
   4168	   4168	      0	      0	      0	   4168	   1048	sha.c.obj (ex armino/wolfssl/libwolfssl.a)
   1842	   1552	    290	      0	      0	   1842	    732	sha256.c.obj (ex armino/wolfssl/libwolfssl.a)
  10319	   9622	    697	      0	      0	  10319	   284f	sha512.c.obj (ex armino/wolfssl/libwolfssl.a)
  17909	  16312	   1597	      0	      0	  17909	   45f5	tfm.c.obj (ex armino/wolfssl/libwolfssl.a)
    332	    324	      8	      0	      0	    332	    14c	wolfmath.c.obj (ex armino/wolfssl/libwolfssl.a)
  62725	  57632	   5093	      0	      0	  62725	   f505	armino/wolfssl/libwolfssl.a
   2487	   1946	    541	      0	     17	   2504	    9c8	event.c.obj (ex armino/bk_event/libbk_event.a)
   2487	   1946	    541	      0	     17	   2504	    9c8	armino/bk_event/libbk_event.a
    138	     84	     54	      0	      0	    138	     8a	app_main.c.obj (ex armino/main/libmain.a)
    138	     84	     54	      0	      0	    138	     8a	armino/main/libmain.a
   4831	   3348	   1483	     28	     16	   4875	   130b	iperf.c.obj (ex armino/iperf/libiperf.a)
   4831	   3348	   1483	     28	     16	   4875	   130b	armino/iperf/libiperf.a
    784	     52	    732	      0	      0	    784	    310	vnd_cal.c.obj (ex armino/vnd_cal/libvnd_cal.a)
    784	     52	    732	      0	      0	    784	    310	armino/vnd_cal/libvnd_cal.a
    256	    256	      0	      0	      0	    256	    100	lib_a-s_ceil.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libm.a)
    256	    256	      0	      0	      0	    256	    100	/home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libm.a
     16	     16	      0	      0	      0	     16	     10	close.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libnosys.a)
     16	     16	      0	      0	      0	     16	     10	fstat.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libnosys.a)
     16	     16	      0	      0	      0	     16	     10	isatty.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libnosys.a)
     16	     16	      0	      0	      0	     16	     10	lseek.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libnosys.a)
     16	     16	      0	      0	      0	     16	     10	read.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libnosys.a)
     16	     16	      0	      0	      0	     16	     10	write.o (ex /home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libnosys.a)
     96	     96	      0	      0	      0	     96	     60	/home/share/samba/T3_TuyaOS-3.8.30/software/TuyaOS/vendor/T3/toolchain/gcc-arm-none-eabi-10.3-2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v8-m.main+fp/hard/libnosys.a
    276	      0	    276	      0	      0	    276	    114	vnd_flash.c.obj (ex armino/vnd_flash/libvnd_flash.a)
    276	      0	    276	      0	      0	    276	    114	armino/vnd_flash/libvnd_flash.a
    122	     70	     52	      0	      0	    122	     7a	bk_rf_adapter.c.obj (ex armino/bk_phy/libbk_phy.a)
   1668	    808	    860	      0	      0	   1668	    684	bk_phy_adapter.c.obj (ex armino/bk_phy/libbk_phy.a)
   1790	    878	    912	      0	      0	   1790	    6fe	armino/bk_phy/libbk_phy.a
