# ./alp_cam [00:00:21:079] [MAIN] [main, 116]:app start time:21079 ms rk_param_init g_ini_path_ is /userdata/doorbell.ini g_section_num is 4 section_name is tuyap2p tuyap2p:product_key = rdabfdahazz2lmcr tuyap2p:uuid = uuidd7c88a1bf61fe179 tuyap2p:auth_key = aP0SRTH5hQhJ2sVYWNOPTtqMpVIPWlhd section_name is appsetting appsetting:ipc_flip = 0 appsetting:timestamp_osd = 1 appsetting:night_mode = 0 appsetting:sd_record_onoff = 1 appsetting:sd_record_mode = 1 appsetting:sd_record_stream = 0 appsetting:sd_record_length = 10 appsetting:human_filter_enable = 0 appsetting:md_enable = 0 appsetting:md_nareas = 1 appsetting:md_area_state = 1 appsetting:md_area0 = 0,0,5000,0,5000,5000,0,5000 appsetting:md_area1 = 5000,0,10000,0,10000,5000,5000,5000 appsetting:md_area2 = 0,5000,5000,5000,5000,10000,0,10000 appsetting:tuya_pir_on_off = 2 appsetting:siren_enable = 0 appsetting:audio_volume = 100 appsetting:max_awake_time = 10 appsetting:antiflicker_mode = 0 appsetting:antiflicker_freq = 50 appsetting:indicator_light_enable = 1 appsetting:plan_num = 0 appsetting:plan_time = 0,0,0,0,0,0,0,0,0 appsetting:usb_plugin_pwron = 0 section_name is board board:sensor_inversion = 1 board:d2n_threshold = 123 board:n2d_threshold = 195 section_name is feature feature:devicetype = IPC feature:batterycam = Dormant feature:microphone = Yes,AEC feature:speaker = TuneVol feature:daynight = Yes feature:resolutions = HD+SD feature:md-capabilities = Sensitivity,VisibleZone feature:cap-ai = { "hw_ai":[{"type":"bd", "flags":1}] } feature:recordconf = res feature:rotatevideo = Yes feature:gps = No feature:g-sensor = No feature:doublelight = No feature:alarmlight = No feature:pir = Yes feature:eventset = [20, 2] feature:extinstructions = [ "status-led","close-device","alarmtone","close-plan","ai-switch" ] rockit log path (null), log_size = 0, can use export rt_log_path=, export rt_log_size= change log_file = (nil) RTVersion 00:00:21-093 {dump :064} --------------------------------------------------------- RTVersion 00:00:21-093 {dump :065} rockit version: git-4fdf752e Tue Apr 23 08:45:16 2024 +0800 RTVersion 00:00:21-093 {dump :066} rockit building: built- 2024-04-30 15:39:40 RTVersion 00:00:21-093 {dump :067} --------------------------------------------------------- (null) 00:00:21-094 {log_level_init :207} please use echo name=level > /tmp/rt_log_level set log level name: all cmpi mb sys vdec venc rgn vpss vgs tde avs wbc vo vi ai ao aenc adec log_level: 0 1 2 3 4 5 6 rockit default level 4, can use export rt_log_level=x, x=0,1,2,3,4,5,6 change (null) 00:00:21-094 {read_log_level :098} text is all=1 (null) 00:00:21-094 {read_log_level :100} module is all, log_level is 1 (null) 00:00:21-100 {monitor_log_level :149} #Start monitor_log_level thread, arg:(nil) RKViChn 00:00:21-105 {prepareRuntime :355} --------------------------------------------------------- RKViChn 00:00:21-105 {prepareRuntime :357} vi version: 1.21, name:vvi RKViChn 00:00:21-106 {prepareRuntime :358} rockit-ko version: vmpi:c9b2a2018416 RKViChn 00:00:21-106 {prepareRuntime :359} rockit-ko building: -2024-02-01-14:27:20 RKViChn 00:00:21-106 {prepareRuntime :360} --------------------------------------------------------- RKViChn 00:00:21-106 {prepareRuntime :379} mb pool create success, MBCnt= 3 rv1106/media/rv1106_media.cpp1493]bind chn 1, 21117ms RKViChn 00:00:21-122 {RKVIChannel :286} mb pool creat success, MBCnt:2 get rk_cam_hdr value: 0x0 get rk_color_mode value: 0x801434 get rk_iqbin_addr value: 0x810040 get rk_iqbin_size value: 0x3732c mmap iq ok rkaiq log level ff1 XCORE:K:rk_aiq_init_lib, ISP HW ver: 32 ************************** VERSION INFOS ************************** version release date: 2023-10-23 AIQ: AIQ v5.0x4.1 ************************ VERSION INFOS END ************************ =====day mode======= XCORE:K:rk_aiq_uapi_sysctl_preInit_scene: main_scene: normal, sub_scene: day XCORE:K:rk_aiq_uapi_sysctl_preInit_tb_info: magic a, is_pre_aiq : 0, is_start_once : 0, prd_type : 1, kernel status 0 XCORE:K:tbinfo: prd_type: 1 is_pre_aiq 0 is_start_once: 0 iq_bin_mode: 0 rtt_share_addr: (nil) rv1106/media/rv1106_media.cpp179]Enter >>>>>> timestamp = 21130 AEC:E:GAIN OUT OF RANGE: lasttime-gain: 0.000000-0.000000 ANR:E:enter!! IPCSERVER:K:cid[0] Process path:/tmp/UNIX.domain0, sockfd:40 XCORE:K:cid[0] rk_aiq_uapi_sysctl_init success. iq: XCORE:K:cid[0] _set_fast_aewb_as_init: ffwb:1.619048,1.000000,1.000000,1.816850 XCORE:K:cid[0] _set_fast_aewb_as_init: ffexp:0.009995,2.171875,1.000000 XCORE:K:cid[0] rk_aiq_uapi_sysctl_prepare success. mode:0 CAMHW:K:cid[0] start success. isGroup:0, isOnline:1, isMultiIsp:0, init_ens:0x0 XCORE:K:cid[0] rk_aiq_uapi_sysctl_start success. aiq startget rk_cam_mirror_flip value: 0x3 rv1106/media/rv1106_media.cpp1452]set mirror:1 flip:1 Aiq:36 ms rv1106/media/rv1106_media.cpp1325]Enter >>>> rv1106/media/rv1106_media.cpp1329]Start >>>> rv1106/media/rv1106_media.cpp106]getVenc0DataThread start,timestamp:21163 mpp[113]: mpp_enc_cfg: mpp_enc_cfg_get_s32 failed to set h265:strg_intra_smth_disable to -1530005988 Jan 1 00:00:21 mpp[113]: mpp_enc_cfg: mpp_enc_cfg_get_s32 failed to set h265:strg_intra_smth_disable to -1530005988 mpp[113]: mpp_chan: chan_id 0 is already valid Jan 1 00:00:21 mpp[113]: mpp_chan: chan_id 0 is already valid rv1106/media/rv1106_media.cpp142]VENC0 1st frame seq:0, pts:111604 devMng/netWork.cpp124]=====set wifi STA, MAC is: 98:03:cf:bc:0f:4c, len:17 rv1106/media/rv1106_media.cpp1257]RK_MPI_AMIX_SetControl() LoobackMode Mode2 success. LOG (rkaudio_preprocess_init(): ,117), out_size is 256 LOG (skv_preprocess_state_init(): ,612), BEAMFORM-RELEASE-VERSION-FOR-DOA 2.0,RELEASE DATE 2023-08-21 LOG (skv_preprocess_state_init(): ,623), This Beamform version is only used for 2 microphones! rv1106/media/rv1106_media.cpp211]VENC1 drop frame, 1st frame seq:316, expect seq:6 The wifi is hi3861l rv1106/media/rv1106_media.cpp147]VENC0 drop frame, seq:316, pre_seq:100 [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_up][l:216],net device up success [src/hisi_tools/vlinktest/vlink_hichannel_main.c][hisi_main][l:1186],hi_channel_init is ok! [src/hisi_tools/vlinktest/vlink_hichannel_main.c][hisi_main][l:1192],hi_channel_init open ok rk_wifi_state_callback state: 12, ts:21288ms RK_WIFI_State_OPEN [00:00:21:288] [TKL_WIFI] [tkl_wifi_station_set_status, 689]:g_sta_status = 0 [src/hisi_tools/vlinktest/vlink_hichannel_main.c][vlink_hi_channel_set_mac][l:662],vlink_hi_channel_set_mac======mac_addr:98:03:cf:bc:0f:4c rv1106/media/rv1106_media.cpp818]save_aenc_thread start [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_mac][l:267],net device set mac success [src/hisi_tools/vlinktest/vlink_hichannel_cmd.c][vlink_hi_channel_cmd_getall_info][l:598],vlink_hi_channel_cmd_getall_info-------sendcmdbuf-[14]-[00]-[00]- [src/hisi_tools/vlinktest/vlink_hichannel_cmd.c][vlink_hi_channel_cmd_getall_info][l:603],vlink_hi_channel_cmd_getall_info--send ok [src/hisi_tools/vlinktest/hichannel_host.c][hi_channel_host_thread][l:78],hi_channel_host_thread:1c,284,300,16 [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_link_rec_cb][l:808],sample_link_rec_cb:--start-- [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_link_rec_cb][l:812],sample_link_rec_cb:msg_data-[{ "cmd": "88", "ssid": "alpsentek_vip", "version": "1.0.2", "channel": "9", "status": "CONNECTED", "ip": "192.168.102.109", "gw": "192.168.102.1", "nm": "255.255.255.0", "dns1": "202.96.134.133", "dns2": "223.5.5.5", "wakeEvent": "NoneWakeEvent", "wifiRTC": "3315859743" }]-[284]-- [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_link_rec_cb][l:1074],:wakeEvent-[NoneWakeEvent]-- [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_link_rec_cb][l:1080],:wifiRTC-[3315859743]-- devMng/devMng.cpp418]eventStr:NoneWakeEvent devMng/devMng.cpp428]rtcTimeStr: 3315859743, rtc_time:3315859743, sys_ts:21362 devMng/devMng.cpp431]rtc time error. devMng/devMng.cpp326]eventStr :NoneWakeEvent devMng/devMng.cpp159]check_obj start devMng/devMng.cpp469]getWakeEvent done [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_ip][l:305],cmd: ifconfig wlan0 192.168.102.109 netmask 255.255.255.0 [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_ip][l:318],cmd: ifconfig wlan0 up [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_ip][l:323],net device set ip success route: SIOCDELRT: No such process [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_ip][l:329],cmd: route del default dev wlan0 [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_ip][l:337],cmd: route add default gw 192.168.102.1 [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_ip][l:342],net device set route success [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_ip][l:345],cmd: route add default gw 192.168.102.1 [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_ip][l:354],cmd: echo nameserver 202.96.134.133 >> /etc/resolv.conf [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_ip][l:363],cmd: echo nameserver 223.5.5.5 >> /etc/resolv.conf [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_wlan_init_ip][l:368],net device set dns success rk_wifi_state_callback state: 7, ts:21498ms [00:00:21:498] [TKL_WIFI] [tkl_wifi_station_set_status, 689]:g_sta_status = 0 RK_WIFI_State_CONNECTED rk_wifi_state_callback state: 18, ts:21499ms [00:00:21:499] [TKL_WIFI] [tkl_wifi_station_set_status, 689]:g_sta_status = 5 devMng/netWork.cpp69] DHCP OK 18 [src/hisi_tools/vlinktest/hichannel_host.c][hi_channel_host_thread][l:78],hi_channel_host_thread:1c,48,64,16 [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_link_rec_cb][l:808],sample_link_rec_cb:--start-- [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_link_rec_cb][l:812],sample_link_rec_cb:msg_data-[{ "cmd": "17", "charge": 0, "capacity": 17 }]-[48]-- [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_link_rec_cb][l:970],:battry info is chagre 0 [src/hisi_tools/vlinktest/vlink_hichannel_main.c][sample_link_rec_cb][l:976],:battry info capacity 17 devMng/devMng.cpp486]CDevMng start time:24170 Could not open /sys/class/gpio/gpio4/direction devMng/devMng.cpp507]CDevMng end time:24171 [00:00:24:171] [APX_TUYA] [tuya_sdk_init, 16]:storage_path: /userdata/, prd_key:rdabfdahazz2lmcr, uuid:uuidd7c88a1bf61fe179, authkey:aP0SRTH5hQhJ2sVYWNOPTtqMpVIPWlhd, app_ver:1.0.1. [src/hisi_tools/vlinktest/vlink_hichannel_cmd.c][vlink_hi_channel_cmd_setpir_info][l:472],vlink_hi_channel_cmd_setpir_info-------pJson[{ "pir_sens": 2 }]--- [src/hisi_tools/vlinktest/vlink_hichannel_cmd.c][vlink_hi_channel_cmd_setpir_info][l:484],vlink_hi_channel_cmd_setpir_info-------sendcmdbuf-[11]-[00]-[12]- [src/hisi_tools/vlinktest/vlink_hichannel_cmd.c][vlink_hi_channel_cmd_setpir_info][l:495],vlink_hi_channel_cmd_setpir_info--send ok [src/hisi_tools/vlinktest/vlink_hichannel_cmd.c][vlink_hi_channel_cmd_set_antibreak][l:512],vlink_hi_channel_cmd_set_antibreak:pJson[{ "antibreak_enable": 0 }]--- [src/hisi_tools/vlinktest/vlink_hichannel_cmd.c][vlink_hi_channel_cmd_set_antibreak][l:519],vlink_hi_channel_cmd_set_antibreak:sendcmdbuf-[23]-[00]-[1A]- [src/hisi_tools/vlinktest/vlink_hichannel_cmd.c][vlink_hi_channel_cmd_set_antibreak][l:527],vlink_hi_channel_cmd_set_antibreak:send ok [00:00:24:177] [APX_TUYA] [tuya_sdk_init, 17]:SDK Version:< TuyaOS V:6.2.4 BS:40.00_PT:2.3_LAN:3.5_CAD:1.0.5_CD:1.0.0 > < BUILD AT:2024_11_06_17_34_41 BY ci_manage FOR tuyaos-ipc AT rv1106 > IOT DEFS < WIFI_GW:1 DEBUG:0 KV_FILE:0 LITTLE_END:1 SL:1 OPERATING_SYSTEM:100 RELIABLE_TRANSFER:0 > devMng/devMng.cpp165]check_obj end devMng/devMng.cpp348]set wakeup event:NoneWakeEvent, ts:24190 [01-01 00:00:00 ty I][f600][tal_thread.c:185] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [01-01 00:00:00 ty I][f600][tal_thread.c:185] thread_create name:wq_system,stackDepth:6144,totalstackDepth:10240,priority:3 [01-01 00:00:00 ty I][f600][tal_thread.c:185] thread_create name:wq_highpri,stackDepth:5120,totalstackDepth:15360,priority:4 [01-01 00:00:00 ty I][f600][tal_thread.c:185] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:16896,priority:5 [01-01 00:00:00 ty I][f600][mqc_app.c:490] mqc app init ... [00:00:24:224] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:24:224] [TKL_WIFI] [wifi_status_event_cb, 59]:set wifi event[0] [01-01 00:00:00 ty I][f600][kv_storge.c:45] Init Kvs With File:/userdata/ [01-01 00:00:00 ty N][f600][tuya_tls.c:876] uni_random_init... [01-01 00:00:00 ty N][f600][tuya_tls.c:303] tuya_tls_rand_init ok! [01-01 00:00:00 ty N][f600][tuya_svc_devos.c:338] gw_cntl->gw_wsm.stat:2 [01-01 00:00:00 ty E][f600][tuya_wifi_connect.c:74] fast ap read fail:-6 [01-01 00:00:00 ty E][f600][tuya_wifi_connect.c:259] ret:-6 [01-01 00:00:00 ty E][f600][base_event.c:153] ret:-6 [01-01 00:00:00 ty D][f600][tuya_ipc_media_adapter.c:101] media adapter init success. avaliable_res_size:5000 [01-01 00:00:00 ty D][f600][tuya_ipc_media_adapter.c:511] insert media info node success! device:[0] channel:[0] init ring buffer Channel:0 Stream:0 Enable:1 video_bitrate 1024, video_fps 15 [01-01 00:00:00 ty D][f600][tuya_ring_buffer.c:637] Init Ring Buffer. ch0st0tr0 bitrate:1024 fps:15 [01-01 00:00:00 ty D][f600][tuya_ring_buffer.c:660] Ring buffer malloc 1310720 bytes for ch0st0tr0, max frame size 196608 [01-01 00:00:00 ty I][f600][tuya_ring_buffer.c:681] Init Ring Buffer success: ch0st0tr0 size:1310720 nodes:150 [01-01 00:00:00 ty T][f600][tuya_ring_buffer.c:147] ch0st0tr0 release ref count: 0 [01-01 00:00:00 ty T][f600][tuya_ring_buffer.c:126] ch0st0tr0 get ref count: 1 [01-01 00:00:00 ty D][f600][tuya_ring_buffer.c:767] ch0st0tr0 open with type 1 init ring buffer success. channel:0 init ring buffer Channel:0 Stream:1 Enable:0 init ring buffer Channel:0 Stream:2 Enable:0 init ring buffer Channel:0 Stream:3 Enable:0 init ring buffer Channel:0 Stream:4 Enable:0 init ring buffer Channel:0 Stream:5 Enable:0 init ring buffer Channel:0 Stream:6 Enable:0 init ring buffer Channel:0 Stream:7 Enable:0 init ring buffer Channel:0 Stream:8 Enable:0 init ring buffer Channel:0 Stream:9 Enable:1 audio_sample 8000, audio_databits 16, audio_fps 25 [01-01 00:00:00 ty D][f600][tuya_ring_buffer.c:637] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25 [01-01 00:00:00 ty D][f600][tuya_ring_buffer.c:660] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936 [01-01 00:00:00 ty I][f600][tuya_ring_buffer.c:681] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250 [01-01 00:00:00 ty T][f600][tuya_ring_buffer.c:147] ch0st0tr9 release ref count: 0 [01-01 00:00:00 ty T][f600][tuya_ring_buffer.c:126] ch0st0tr9 get ref count: 1 [01-01 00:00:00 ty D][f600][tuya_ring_buffer.c:767] ch0st0tr9 open with type 1 init ring buffer success. channel:9 init ring buffer Channel:0 Stream:10 Enable:0 init ring buffer Channel:0 Stream:11 Enable:0 init ring buffer Channel:0 Stream:12 Enable:0 init ring buffer Channel:0 Stream:13 Enable:0 init ring buffer Channel:0 Stream:14 Enable:0 init ring buffer Channel:0 Stream:15 Enable:0 [01-01 00:00:00 ty D][f600][simplekv.c:1133] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][f600][simplekv.c:1164] find key:1 gw_bi [01-01 00:00:00 ty D][f600][simplekv.c:1190] key:gw_bi find value.Len:272 [01-01 00:00:00 ty D][f600][tuya_ws_db.c:667] sync to protected len[258] [01-01 00:00:00 ty D][f600][ws_db_gw.c:148] gw_bi read ret:0 [01-01 00:00:00 ty D][f600][tuya_wifi_link.c:901] tuya wifi link init mthd:0,wifi start mode:0, enable_station_ap:0 [01-01 00:00:00 ty D][f600][simplekv.c:1133] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][f600][simplekv.c:1164] find key:2 gw_wsm [01-01 00:00:00 ty D][f600][simplekv.c:1190] key:gw_wsm find value.Len:240 [01-01 00:00:00 ty D][f600][tuya_ws_db.c:667] sync to protected len[235] [01-01 00:00:00 ty D][f600][ws_db_gw.c:259] gw_wsm read ret:0 [01-01 00:00:00 ty N][f600][tuya_wifi_link.c:85] start wifi link params validate, nc_tp:9 md:3 [01-01 00:00:00 ty N][f600][tuya_wifi_link.c:107] gw_wsm.nc_tp:9 [01-01 00:00:00 ty N][f600][tuya_wifi_link.c:108] gw_wsm.md:3 [01-01 00:00:00 ty D][f600][tuya_bt_link.c:294] bt init... [01-01 00:00:00 ty D][f600][tuya_svc_netmgr_linkage.c:86] link[3] is registered [2] [01-01 00:00:00 ty D][f600][tuya_ble_svc.c:2325] get_wifi_list eanbled [01-01 00:00:00 ty D][f600][tuya_ble_svc.c:2331] get_netcfg_stat eanbled [01-01 00:00:00 ty D][f600][tuya_ble_svc.c:2335] get_dev_log eanbled [01-01 00:00:00 ty D][f600][tuya_ble_svc.c:2341] get_ap_name eanbled [01-01 00:00:00 ty D][f600][simplekv.c:1133] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][f600][simplekv.c:1164] find key:2 gw_wsm [01-01 00:00:00 ty D][f600][simplekv.c:1190] key:gw_wsm find value.Len:240 [01-01 00:00:00 ty D][f600][tuya_ws_db.c:667] sync to protected len[235] [01-01 00:00:00 ty D][f600][ws_db_gw.c:259] gw_wsm read ret:0 [01-01 00:00:00 ty N][f600][tuya_svc_devos.c:563] Last reset reason: 7 [01-01 00:00:00 ty D][f600][simplekv.c:1133] read key:gw_di isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][f600][simplekv.c:1164] find key:3 gw_di [01-01 00:00:00 ty D][f600][simplekv.c:1190] key:gw_di find value.Len:704 [01-01 00:00:00 ty D][f600][ws_db_gw.c:376] gw_di read ret:0 [01-01 00:00:00 ty D][f600][simplekv.c:1133] read key:is_stride isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][f600][simplekv.c:1164] find key:8 is_stride [01-01 00:00:00 ty D][f600][simplekv.c:1190] key:is_stride find value.Len:16 [01-01 00:00:00 ty D][f600][tuya_devos_stride.c:55] stride from flash: 0. [01-01 00:00:00 ty D][f600][tuya_devos_stride.c:71] sw_ver:1.0.0->1.0.1 [01-01 00:00:00 ty D][f600][tuya_devos_stride.c:129] write stride to flash:0 [01-01 00:00:00 ty D][f600][simplekv.c:1133] read key:is_stride isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][f600][simplekv.c:1164] find key:8 is_stride [01-01 00:00:00 ty D][f600][simplekv.c:1190] key:is_stride find value.Len:16 [01-01 00:00:00 ty N][f600][tuya_svc_devos.c:395] gw_cntl->gw_if.abi:0 input:0 [01-01 00:00:00 ty N][f600][tuya_svc_devos.c:396] gw_cntl->gw_if.product_key:rdabfdahazz2lmcr, input:rdabfdahazz2lmcr [01-01 00:00:00 ty N][f600][tuya_svc_devos.c:397] gw_cntl->gw_if.tp:0, input:0 [01-01 00:00:00 ty D][f600][tuya_svc_devos.c:483] pv/lpv/bv/sw changed [01-01 00:00:00 ty D][f600][simplekv.c:1133] read key:000004vrk8 isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][f600][simplekv.c:1164] find key:9 000004vrk8 [01-01 00:00:00 ty D][f600][simplekv.c:1190] key:000004vrk8 find value.Len:1440 [01-01 00:00:00 ty D][f600][ws_db_gw.c:535] schema 000004vrk8 read success [01-01 00:00:00 ty D][f600][tuya_devos_utils.c:1169] create dev_cntl Success [01-01 00:00:00 ty N][f600][tuya_svc_devos.c:596] enter success_proc [00:00:24:282] [TKL_WIFI] [tkl_wifi_get_mac, 410]:WIFI Get MAC 98-03-CF-BC-0F-4C [01-01 00:00:00 ty N][f600][tuya_svc_devos.c:599] serial_no:9803cfbc0f4c [01-01 00:00:00 ty D][f600][tuya_svc_upgrade.c:1369] tuya svc upgrade init success! [01-01 00:00:00 ty D][f600][simplekv.c:1133] read key:kv.meta.report isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][f600][simplekv.c:1164] find key:17 kv.meta.report [01-01 00:00:00 ty D][f600][simplekv.c:1190] key:kv.meta.report find value.Len:96 [01-01 00:00:00 ty D][f600][ty_meta_report.c:111] meta in kv {"metas":{"btScyChannel":"{\"enable\":1,\"version\":\"1.0\"}","timerCapability":1}} [01-01 00:00:00 ty D][f600][mqc_app.c:109] mq_pro:300 cnt:3 [01-01 00:00:00 ty D][f600][mqc_app.c:109] mq_pro:302 cnt:4 [01-01 00:00:00 ty D][f600][mqc_app.c:109] mq_pro:304 cnt:5 [01-01 00:00:00 ty D][f600][mqc_app.c:109] mq_pro:307 cnt:6 [01-01 00:00:00 ty D][f600][mqc_app.c:109] mq_pro:308 cnt:7 [01-01 00:00:00 ty D][f600][mqc_app.c:109] mq_pro:312 cnt:8 [01-01 00:00:00 ty D][f600][tuya_ipc_mqtt_subscribe.c:292] iot_register_extra_mqt_cb done [01-01 00:00:00 ty T][f600][tuya_ring_buffer.c:126] ch0st0tr0 get ref count: 2 [01-01 00:00:00 ty T][f600][tuya_ring_buffer.c:147] ch0st0tr0 release ref count: 1 [01-01 00:00:00 ty D][f600][tuya_ipc_hardware_info.c:285] IS HARDware [01-01 00:00:00 ty D][f600][tuya_ipc_hardware_info.c:291] IS HARDware ok [01-01 00:00:00 ty D][f600][tuya_ipc_hardware_info.c:308] IS HARDware okok [01-01 00:00:00 ty D][f600][tuya_ipc_hardware_info.c:252] traversal over [01-01 00:00:00 ty E][f600][tuya_ipc_hardware_info.c:173] NO sensor info. Please check if you need. [01-01 00:00:00 ty D][f600][tuya_ipc_hardware_info.c:40] device can not found wifi device info [01-01 00:00:00 ty D][f600][tuya_ipc_hardware_info.c:355] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":1,\"webrtc\":2,\"p2p\":611,\"security_ability\":30,\"video_num\":1,\"sdk_version\":\"6.2.4\"},\"hardware\":{\"toolchain\":\"rv1106\",\"cpu\":{\"model\":\"ARMv7 Processor rev 5 (v7l)\",\"bogomips\":\"48.00\",\"name\":\"Rockchip (Device Tree)\"}} [01-01 00:00:00 ty D][b200][tuya_svc_devos.c:854] state change from 0 to 3 [01-01 00:00:00 ty D][b200][simplekv.c:1133] read key:kv.ccode.avtive isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][b200][simplekv.c:1161] no key find [01-01 00:00:00 ty D][b200][simplekv.c:1203] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][b200][simplekv.c:1242] __read_kv_with_decode fail. -3 Exec Cmd:ifconfig wlan0 up [01-01 00:00:00 ty D][f600][tuya_iot_wifi_api.c:452] register wifi network monitor. interval:1 [00:00:24:289] [MAIN] [main, 176]:end init iot time:24289 ms, wakeup event:12 rv1106/media/rv1106_media.cpp1238]Enter time: 24289 >>>> Thread(IotTuya) started [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:130227 type:1 pts:111604 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:0 data_size:130227 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:1 timestamp:98 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:44767 type:0 pts:178281 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:130227 data_size:44767 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:2 timestamp:99 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1975 type:0 pts:244960 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:174994 data_size:1975 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:3 timestamp:99 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4110 type:0 pts:311680 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:176969 data_size:4110 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:4 timestamp:100 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1726 type:0 pts:378281 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:181079 data_size:1726 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:5 timestamp:100 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4518 type:0 pts:445063 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:182805 data_size:4518 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:6 timestamp:100 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5985 type:0 pts:511727 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:187323 data_size:5985 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:7 timestamp:100 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2774 type:0 pts:578398 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:193308 data_size:2774 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:8 timestamp:100 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:8087 type:0 pts:645062 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:196082 data_size:8087 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:9 timestamp:100 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3907 type:0 pts:711734 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:204169 data_size:3907 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:10 timestamp:101 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6879 type:0 pts:778394 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:208076 data_size:6879 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:11 timestamp:101 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5496 type:0 pts:845069 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:214955 data_size:5496 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:12 timestamp:101 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:9009 type:0 pts:911724 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:220451 data_size:9009 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:13 timestamp:101 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7301 type:0 pts:978410 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:229460 data_size:7301 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:14 timestamp:101 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:8145 type:0 pts:1045059 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:236761 data_size:8145 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:15 timestamp:102 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:10152 type:0 pts:1111725 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:244906 data_size:10152 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:16 timestamp:103 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6530 type:0 pts:1178393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:255058 data_size:6530 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:17 timestamp:103 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5400 type:0 pts:1245068 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:261588 data_size:5400 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:18 timestamp:103 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6753 type:0 pts:1311727 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:266988 data_size:6753 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:19 timestamp:103 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4833 type:0 pts:1378393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:273741 data_size:4833 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:20 timestamp:104 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:8082 type:0 pts:1445064 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:278574 data_size:8082 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:21 timestamp:104 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3512 type:0 pts:1511725 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:286656 data_size:3512 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:22 timestamp:104 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4396 type:0 pts:1578392 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:290168 data_size:4396 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:23 timestamp:104 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5448 type:0 pts:1645062 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:294564 data_size:5448 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:24 timestamp:104 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7275 type:0 pts:1711726 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:300012 data_size:7275 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:25 timestamp:104 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4758 type:0 pts:1778393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:307287 data_size:4758 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:26 timestamp:105 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6432 type:0 pts:1845061 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:312045 data_size:6432 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:27 timestamp:105 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5480 type:0 pts:1911726 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:318477 data_size:5480 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:28 timestamp:105 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1894 type:0 pts:1978394 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:323957 data_size:1894 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:29 timestamp:105 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1649 type:0 pts:2045064 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:325851 data_size:1649 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:30 timestamp:105 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:44898 type:1 pts:2111726 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:327500 data_size:44898 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:31 timestamp:105 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1606 type:0 pts:2178393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:372398 data_size:1606 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:32 timestamp:106 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3123 type:0 pts:2245068 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:374004 data_size:3123 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:33 timestamp:106 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3078 type:0 pts:2311728 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:377127 data_size:3078 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:34 timestamp:106 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7035 type:0 pts:2378393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:380205 data_size:7035 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:35 timestamp:106 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3562 type:0 pts:2445062 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:387240 data_size:3562 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:36 timestamp:106 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6831 type:0 pts:2511727 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:390802 data_size:6831 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:37 timestamp:107 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3647 type:0 pts:2578394 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:397633 data_size:3647 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:38 timestamp:107 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5919 type:0 pts:2645063 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:401280 data_size:5919 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:39 timestamp:107 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2600 type:0 pts:2711726 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:407199 data_size:2600 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:40 timestamp:107 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2616 type:0 pts:2778394 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:409799 data_size:2616 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:41 timestamp:107 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1573 type:0 pts:2845062 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:412415 data_size:1573 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:42 timestamp:107 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2361 type:0 pts:2911727 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:413988 data_size:2361 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:43 timestamp:108 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2163 type:0 pts:2978393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:416349 data_size:2163 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:44 timestamp:108 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4675 type:0 pts:3045062 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:418512 data_size:4675 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:45 timestamp:108 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3569 type:0 pts:3111728 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:423187 data_size:3569 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:46 timestamp:108 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6380 type:0 pts:3178393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:426756 data_size:6380 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:47 timestamp:108 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4261 type:0 pts:3245063 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:433136 data_size:4261 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:48 timestamp:108 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7700 type:0 pts:3311727 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:437397 data_size:7700 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:49 timestamp:109 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7802 type:0 pts:3378393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:445097 data_size:7802 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:50 timestamp:109 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:9984 type:0 pts:3445060 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:452899 data_size:9984 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:51 timestamp:109 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7804 type:0 pts:3511728 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:462883 data_size:7804 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:52 timestamp:109 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6150 type:0 pts:3578393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:470687 data_size:6150 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:53 timestamp:109 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4584 type:0 pts:3645064 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:476837 data_size:4584 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:54 timestamp:109 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6963 type:0 pts:3711728 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:481421 data_size:6963 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:55 timestamp:110 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2898 type:0 pts:3778393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:488384 data_size:2898 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:56 timestamp:110 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5272 type:0 pts:3845062 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:491282 data_size:5272 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:57 timestamp:110 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4205 type:0 pts:3911726 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:496554 data_size:4205 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:58 timestamp:110 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4929 type:0 pts:3978393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:500759 data_size:4929 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:59 timestamp:110 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7003 type:0 pts:4045058 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:505688 data_size:7003 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:60 timestamp:110 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:44841 type:1 pts:4111723 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:512691 data_size:44841 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:61 timestamp:111 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1437 type:0 pts:4178393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:557532 data_size:1437 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:62 timestamp:111 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2095 type:0 pts:4245061 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:558969 data_size:2095 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:63 timestamp:111 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3127 type:0 pts:4311727 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:561064 data_size:3127 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:64 timestamp:111 [00:00:24:317] [TKL_WIFI] [tkl_wifi_set_work_mode, 466]:WIFI Set Mode 2 [01-01 00:00:00 ty D][b200][tuya_wifi_reset.c:596] reset init mthd:0, short timer:0 long timer:0 [01-01 00:00:00 ty D][b200][tuya_wifi_netcfg.c:437] do proxy actived work,mode:2,stat:2,nc_tp:9 [01-01 00:00:00 ty N][b200][tuya_bt_link.c:62] bt startup attr:ff [01-01 00:00:00 ty D][b200][tuya_bt_link.c:77] bt link open [01-01 00:00:00 ty N][b200][tuya_ble_svc.c:1199] upd product_id type:0 rdabfdahazz2lmcr [01-01 00:00:00 ty D][b200][simplekv.c:1133] read key:bt_encrpt_v2 isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][b200][simplekv.c:1164] find key:4 bt_encrpt_v2 [01-01 00:00:00 ty D][b200][simplekv.c:1190] key:bt_encrpt_v2 find value.Len:16 [01-01 00:00:00 ty D][b200][tuya_ble_cryption.c:491] read encrpt flag from flash: 1. [00:00:24:318] [TKL_BT] [tkl_ble_gap_callback_register, 156]: enter >>>>> [00:00:24:319] [TKL_BT] [tkl_ble_gatt_callback_register, 171]: enter >>>>> [00:00:24:319] [TKL_BT] [tkl_ble_stack_init, 94]:enter role = 3>>>>> [00:00:24:322] [APX_BLE] [ble_service_start, 314]:open uart device '/dev/ttyS5' ok. tkl_ble_gatts_service_add >>>>>> ble service num: 1 { .handle = 65535 svc_uuid = { uuid_type = 0 uuid.uuid16 = 0xFD50 type = 10240 char_num = 3 { .handle = 1 .char_uuid = { .uuid_type = 2 .uuid.uuid128 = {0xD0 0x7 0x9B 0x5F 0x80 0x0 0x1 0x80 0x1 0x10 0x0 0x0 0x1 0x0 0x0 0x0 } .property = 0xC .permission = 0x6 .value_len = 244 } { .handle = 2 .char_uuid = { .uuid_type = 2 .uuid.uuid128 = {0xD0 0x7 0x9B 0x5F 0x80 0x0 0x1 0x80 0x1 0x10 0x0 0x0 0x2 0x0 0x0 0x0 } .property = 0x10 .permission = 0x6 .value_len = 244 } { .handle = 3 .char_uuid = { .uuid_type = 2 .uuid.uuid128 = {0xD0 0x7 0x9B 0x5F 0x80 0x0 0x1 0x80 0x1 0x10 0x0 0x0 0x3 0x0 0x0 0x0 } .property = 0x2 .permission = 0x2 .value_len = 244 } } [01-01 00:00:00 ty D][b200][tuya_ble_svc.c:1115] rev ble event 1 [01-01 00:00:00 ty D][b200][tuya_ble_svc.c:1768] set ble serv stat:0, curr:0 [01-01 00:00:00 ty D][b200][tuya_ble_svc.c:1626] start ble monitor [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1162 type:0 pts:4378395 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:564191 data_size:1162 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:65 timestamp:125 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1686 type:0 pts:4445064 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:565353 data_size:1686 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:66 timestamp:126 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:650 type:0 pts:4511728 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:567039 data_size:650 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:67 timestamp:126 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3590 type:0 pts:4578392 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:567689 data_size:3590 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:68 timestamp:126 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2520 type:0 pts:4645063 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:571279 data_size:2520 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:69 timestamp:126 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4661 type:0 pts:4711728 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:573799 data_size:4661 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:70 timestamp:126 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1931 type:0 pts:4778394 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:578460 data_size:1931 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:71 timestamp:127 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2877 type:0 pts:4845061 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:580391 data_size:2877 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:72 timestamp:127 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1120 type:0 pts:4911724 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:583268 data_size:1120 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:73 timestamp:127 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4408 type:0 pts:4978396 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:584388 data_size:4408 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:74 timestamp:127 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:10587 type:0 pts:5045062 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:588796 data_size:10587 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:75 timestamp:127 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2219 type:0 pts:5111731 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:599383 data_size:2219 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:76 timestamp:127 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7887 type:0 pts:5178397 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:601602 data_size:7887 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:77 timestamp:128 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:12461 type:0 pts:5245060 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:609489 data_size:12461 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:78 timestamp:128 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5661 type:0 pts:5311726 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:621950 data_size:5661 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:79 timestamp:128 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:14515 type:0 pts:5378394 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:627611 data_size:14515 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:80 timestamp:128 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1706 type:0 pts:5445059 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:642126 data_size:1706 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:81 timestamp:129 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1985 type:0 pts:5511728 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:643832 data_size:1985 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:82 timestamp:129 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4423 type:0 pts:5578396 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:645817 data_size:4423 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:83 timestamp:129 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2363 type:0 pts:5645061 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:650240 data_size:2363 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:84 timestamp:129 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5637 type:0 pts:5711729 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:652603 data_size:5637 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:85 timestamp:130 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3324 type:0 pts:5778396 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:658240 data_size:3324 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:86 timestamp:130 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4758 type:0 pts:5845059 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:661564 data_size:4758 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:87 timestamp:130 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1425 type:0 pts:5911726 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:666322 data_size:1425 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:88 timestamp:130 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4041 type:0 pts:5978393 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:667747 data_size:4041 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:89 timestamp:130 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4749 type:0 pts:6045061 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:671788 data_size:4749 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:90 timestamp:130 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:48578 type:1 pts:6111727 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:676537 data_size:48578 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:91 timestamp:131 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1434 type:0 pts:6178396 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:725115 data_size:1434 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:92 timestamp:131 [01-01 00:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6181 type:0 pts:6245062 [01-01 00:00:00 ty N][b200][tuya_ble_svc.c:1294] ty bt sdk init success finish [01-01 00:00:00 ty N][b200][tuya_svc_devos.c:246] __devos_init_evt success [01-01 00:00:00 ty N][b200][tuya_svc_devos.c:75] already bind [01-01 00:00:00 ty E][b200][tuya_ipc_sdk_init.c:376] gw status changed to [3], but not notify [01-01 00:00:00 ty I][b200][mqc_app.c:526] mqc app start ... [01-01 00:00:00 ty D][b200][mqc_app.c:573] MQTT Protocol URL:m6.tuyacn.com:8886 Port:8883 [01-01 00:00:00 ty I][b200][tal_thread.c:185] thread_create name:mqtt_thread,stackDepth:9216,totalstackDepth:26112,priority:4 [01-01 00:00:00 ty D][b200][mqc_app.c:617] mqtt send topic:smart/device/out/6cee1be97d371185c4aj6a [01-01 00:00:00 ty D][b200][mqc_app.c:619] mqtt-media send topic:d/m/o/6cee1be97d371185c4aj6a [01-01 00:00:00 ty N][b200][tuya_svc_mqtt_client.c:175] [mqtts://m6.tuyacn.com:8886] mqtt state change 0 -> 1 [01-01 00:00:00 ty D][b200][mqc_app.c:109] mq_pro:64 cnt:9 [01-01 00:00:00 ty D][b200][mqc_app.c:109] mq_pro:19 cnt:10 [01-01 00:00:00 ty D][b200][mqc_app.c:109] mq_pro:22 cnt:11 [01-01 00:00:00 ty D][b200][mqc_app.c:109] mq_pro:55 cnt:12 [01-01 00:00:00 ty D][b200][simplekv.c:1133] read key:timer_full_key isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][b200][simplekv.c:1161] no key find [01-01 00:00:00 ty D][b200][simplekv.c:1203] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][b200][simplekv.c:1242] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty E][b200][tuya_svc_timer_task.c:1376] read timer_full_key failed [01-01 00:00:00 ty D][b200][simplekv.c:1133] read key:timer_arr isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][b200][simplekv.c:1161] no key find [01-01 00:00:00 ty D][b200][simplekv.c:1203] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][b200][simplekv.c:1242] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty D][b200][tuya_svc_timer_task.c:429] no timer [01-01 00:00:00 ty D][b200][tuya_svc_timer_task.c:1480] --- timer_cnt = 0 [01-01 00:00:00 ty D][b200][mqc_app.c:109] mq_pro:15 cnt:13 [01-01 00:00:00 ty D][b200][tuya_svc_upgrade.c:1396] upgrade active success [01-01 00:00:00 ty D][b200][tuya_svc_online_log.c:204] mqtt log topic init log/realtime/6cee1be97d371185c4aj6a [01-01 00:00:00 ty D][b200][tuya_svc_online_log.c:205] mqtt log topic init log/runstat/6cee1be97d371185c4aj6a [01-01 00:00:00 ty D][b200][tuya_svc_online_log.c:314] svc online log active success [01-01 00:00:00 ty D][b200][mqc_app.c:109] mq_pro:11 cnt:14 [01-01 00:00:00 ty D][b200][mqc_app.c:109] mq_pro:41 cnt:15 [01-01 00:00:00 ty D][b200][mqc_app.c:109] mq_pro:27 cnt:16 [01-01 08:00:00 ty D][b200][tuya_devos_log_upd.c:1168] not set cb, will not rept meta [01-01 08:00:00 ty D][b200][tuya_bt_link.c:233] __bt_run_event [01-01 08:00:00 ty D][b200][simplekv.c:1133] read key:wf_pt isFuzzy:0 skipCnt:0 [01-01 08:00:00 ty D][b200][simplekv.c:1161] no key find [01-01 08:00:00 ty D][b200][simplekv.c:1203] __read_kv_raw fail. -3 [01-01 08:00:00 ty D][b200][simplekv.c:1242] __read_kv_with_decode fail. -3 [01-01 08:00:00 ty D][b200][wf_protect.c:1617] wifi protect ap info init [01-01 08:00:00 ty D][b200][tuya_ble_svc.c:609] meta rpt for ble v2 crpt [01-01 08:00:00 ty D][b200][ty_meta_report.c:184] need_report 0 mode 0 [01-01 08:00:00 ty D][b200][ty_meta_report.c:184] need_report 0 mode 0 [01-01 08:00:00 ty D][b200][tuya_wifi_connect.c:319] __wifi_net_conn. [00:00:24:335] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:00 ty D][b200][tuya_wifi_connect.c:217] status:6,mode:2 [00:00:24:335] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:00 ty D][b200][tuya_wifi_connect.c:217] status:6,mode:2 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:726549 data_size:6181 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:93 timestamp:131 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1163 type:0 pts:6311728 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:732730 data_size:1163 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:94 timestamp:138 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2673 type:0 pts:6378398 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:733893 data_size:2673 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:95 timestamp:138 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1503 type:0 pts:6445060 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:736566 data_size:1503 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:96 timestamp:138 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2804 type:0 pts:6511728 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:738069 data_size:2804 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:97 timestamp:138 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2757 type:0 pts:6578394 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:740873 data_size:2757 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:98 timestamp:138 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6399 type:0 pts:6645059 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:743630 data_size:6399 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:99 timestamp:138 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2018 type:0 pts:6711729 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:750029 data_size:2018 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:100 timestamp:139 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2984 type:0 pts:6778396 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:752047 data_size:2984 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:101 timestamp:139 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:15130 type:0 pts:21178404 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:755031 data_size:15130 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:102 timestamp:139 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3205 type:0 pts:21245068 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:770161 data_size:3205 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:103 timestamp:139 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1160 type:0 pts:21311733 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:773366 data_size:1160 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:104 timestamp:139 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2792 type:0 pts:21378401 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:774526 data_size:2792 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:105 timestamp:140 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:20583 type:0 pts:21445072 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:777318 data_size:20583 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:106 timestamp:140 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:25548 type:0 pts:21511728 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:797901 data_size:25548 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:107 timestamp:140 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:16852 type:0 pts:21578395 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:823449 data_size:16852 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:108 timestamp:141 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:23992 type:0 pts:21645066 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:840301 data_size:23992 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:109 timestamp:141 [00:00:24:340] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:00 ty N][b200][tuya_wifi_status.c:167] cur stat:6 0x1c262c -->> [01-01 08:00:00 ty N][b200][tuya_wifi_status.c:169] wifi netstat changed to:6 -->> [01-01 08:00:00 ty N][b200][tuya_wifi_status.c:173] report wifi netstat[6] to callback -->> [00:00:24:340] [APX_TUYA] [tuya_sdk_status_change_callback, 81]:status changed: group[2] status[21] [01-01 08:00:00 ty D][b200][tuya_ble_svc.c:244] upd adv para, send conn_req beacon. [01-01 08:00:00 ty D][b200][tuya_ble_svc.c:115] adv_data 31 <0x516a99> 02 01 06 03 02 50 fd 17 16 50 fd 4b 0c 00 10 23 40 9e 97 08 36 07 1b 63 f1 28 d8 27 05 d6 62 [01-01 08:00:00 ty D][b200][tuya_ble_svc.c:115] rsp_data 31 <0x516ab9> 17 ff d0 07 00 00 04 a1 d4 5d 0e b2 91 4c fd 71 35 a4 6c 76 33 e7 5c 4b 06 09 54 55 59 41 5f [01-01 08:00:00 ty D][b200][tuya_ble_svc.c:1665] ble get conn stat:4 [00:00:24:341] [TKL_BT] [tkl_ble_gap_adv_stop, 246]:trace [00:00:24:342] [APX_BLE] [alp_hci_send_cmd, 144]:hci uart send cmd(69) ok. tkl_ble_gap_adv_rsp_data_set enter >>>>> adv data: {0x02, 0x01, 0x06, 0x03, 0x02, 0x50, 0xFD, 0x17, 0x16, 0x50, 0xFD, 0x4B, 0x0C, 0x00, 0x10, 0x23, 0x40, 0x9E, 0x97, 0x08, 0x36, 0x07, 0x1B, 0x63, 0xF1, 0x28, 0xD8, 0x27, 0x05, 0xD6, 0x62} scan rsp data: {0x17, 0xFF, 0xD0, 0x07, 0x00, 0x00, 0x04, 0xA1, 0xD4, 0x5D, 0x0E, 0xB2, 0x91, 0x4C, 0xFD, 0x71, 0x35, 0xA4, 0x6C, 0x76, 0x33, 0xE7, 0x5C, 0x4B, 0x06, 0x09, 0x54, 0x55, 0x59, 0x41, 0x5F} [00:00:24:342] [APX_BLE] [alp_hci_send_cmd, 144]:hci uart send cmd(65) ok. [00:00:24:342] [APX_BLE] [alp_hci_send_cmd, 144]:hci uart send cmd(66) ok. tkl_ble_gap_adv_start enter >>>>> adv param: .adv_type = 1 .direct_addr.type = 0 .direct_addr.addr = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00} .adv_interval_min = 30 .adv_interval_max = 60 .adv_channel_map = 7 [00:00:24:342] [APX_BLE] [alp_hci_send_cmd, 144]:hci uart send cmd(68) ok. [01-01 08:00:00 ty N][b200][tuya_ble_svc.c:1381] ble adv updated [01-01 08:00:00 ty D][f9e0][tal_thread.c:209] Thread:mqtt_thread Exec Start. Set to Running Stat 0xa2f9e0b0 [01-01 08:00:00 ty N][f9e0][tuya_svc_mqtt_client.c:1193] mqtt_thread paused [01-01 08:00:00 ty N][f9e0][tuya_svc_mqtt_client.c:656] mqtt close [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:21479 type:0 pts:21711735 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:864293 data_size:21479 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:110 timestamp:145 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4393 type:0 pts:21778401 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:885772 data_size:4393 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:111 timestamp:145 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:8474 type:0 pts:21845068 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:890165 data_size:8474 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:112 timestamp:146 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:15123 type:0 pts:21911728 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:898639 data_size:15123 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:113 timestamp:148 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:17097 type:0 pts:21978394 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:913762 data_size:17097 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:114 timestamp:149 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:20614 type:0 pts:22045067 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:930859 data_size:20614 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:115 timestamp:150 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:9509 type:0 pts:22111736 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:951473 data_size:9509 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:116 timestamp:150 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:14646 type:0 pts:22178401 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:960982 data_size:14646 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:117 timestamp:150 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5845 type:0 pts:22245068 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:975628 data_size:5845 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:118 timestamp:150 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:8974 type:0 pts:22311728 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:981473 data_size:8974 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:119 timestamp:150 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1614 type:0 pts:22378395 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:990447 data_size:1614 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:120 timestamp:151 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:53882 type:1 pts:22445067 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:992061 data_size:53882 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:121 timestamp:151 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2398 type:0 pts:22511735 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1045943 data_size:2398 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:122 timestamp:151 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1275 type:0 pts:22578403 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1048341 data_size:1275 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:123 timestamp:151 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2205 type:0 pts:22645069 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1049616 data_size:2205 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:124 timestamp:153 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5162 type:0 pts:22711727 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1051821 data_size:5162 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:125 timestamp:153 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3614 type:0 pts:22778394 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1056983 data_size:3614 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:126 timestamp:153 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7414 type:0 pts:22845068 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1060597 data_size:7414 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:127 timestamp:153 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:988 type:0 pts:22911734 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1068011 data_size:988 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:128 timestamp:154 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1852 type:0 pts:22978402 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1068999 data_size:1852 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:129 timestamp:154 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:693 type:0 pts:23045068 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1070851 data_size:693 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:130 timestamp:154 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1714 type:0 pts:23111728 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1071544 data_size:1714 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:131 timestamp:154 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:457 type:0 pts:23178395 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1073258 data_size:457 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:132 timestamp:154 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1322 type:0 pts:23245068 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1073715 data_size:1322 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:133 timestamp:154 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:352 type:0 pts:23311734 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1075037 data_size:352 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:134 timestamp:155 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:644 type:0 pts:23378399 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1075389 data_size:644 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:135 timestamp:155 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:534 type:0 pts:23445070 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1076033 data_size:534 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:136 timestamp:155 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1170 type:0 pts:23511728 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1076567 data_size:1170 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:137 timestamp:155 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1001 type:0 pts:23578394 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1077737 data_size:1001 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:138 timestamp:155 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2331 type:0 pts:23645068 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1078738 data_size:2331 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:139 timestamp:155 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1184 type:0 pts:23711734 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1081069 data_size:1184 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:140 timestamp:155 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2103 type:0 pts:23778399 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1082253 data_size:2103 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:141 timestamp:155 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1119 type:0 pts:23845068 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1084356 data_size:1119 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:142 timestamp:156 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1292 type:0 pts:23911728 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1085475 data_size:1292 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:143 timestamp:156 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:549 type:0 pts:23978394 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1086767 data_size:549 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:144 timestamp:156 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:958 type:0 pts:24045069 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1087316 data_size:958 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:145 timestamp:156 [01-01 08:00:00 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:472 type:0 pts:24111737 [00:00:25:230] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:25:340] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:680] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:680] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:680] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:680] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:680] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:33:681] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 ======================= will back.m_writeOffset: 0 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1088274 data_size:472 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:146 timestamp:156 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1195 type:0 pts:24178398 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1088746 data_size:1195 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:147 timestamp:9484 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:772 type:0 pts:24245062 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1089941 data_size:772 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:148 timestamp:9484 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1844 type:0 pts:24311736 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1090713 data_size:1844 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:149 timestamp:9485 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:962 type:0 pts:24378394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1092557 data_size:962 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:0 timestamp:9485 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:58846 type:1 pts:24445066 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1093519 data_size:58846 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:1 timestamp:9485 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1281 type:0 pts:24511735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1152365 data_size:1281 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:2 timestamp:9485 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2451 type:0 pts:24578400 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1153646 data_size:2451 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:3 timestamp:9486 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1502 type:0 pts:24645068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1156097 data_size:1502 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:4 timestamp:9486 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3001 type:0 pts:24711728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1157599 data_size:3001 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:5 timestamp:9486 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:10866 type:0 pts:24778395 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1160600 data_size:10866 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:6 timestamp:9486 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5446 type:0 pts:24845068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1171466 data_size:5446 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:7 timestamp:9486 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:9993 type:0 pts:24911736 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1176912 data_size:9993 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:8 timestamp:9487 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3576 type:0 pts:24978401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1186905 data_size:3576 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:9 timestamp:9487 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5258 type:0 pts:25045068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1190481 data_size:5258 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:10 timestamp:9487 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4838 type:0 pts:25111727 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1195739 data_size:4838 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:11 timestamp:9487 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:12811 type:0 pts:25178394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1200577 data_size:12811 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:12 timestamp:9487 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4956 type:0 pts:25245069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1213388 data_size:4956 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:13 timestamp:9487 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:10877 type:0 pts:25311735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1218344 data_size:10877 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:14 timestamp:9488 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:12776 type:0 pts:25378399 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1229221 data_size:12776 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:15 timestamp:9488 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5609 type:0 pts:25445068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1241997 data_size:5609 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:16 timestamp:9488 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1658 type:0 pts:25511728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1247606 data_size:1658 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:17 timestamp:9488 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2110 type:0 pts:25578394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1249264 data_size:2110 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:18 timestamp:9489 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:539 type:0 pts:25645069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1251374 data_size:539 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:19 timestamp:9489 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1578 type:0 pts:25711734 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1251913 data_size:1578 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:20 timestamp:9489 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3213 type:0 pts:25778401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1253491 data_size:3213 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:21 timestamp:9489 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:681 type:0 pts:25845068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1256704 data_size:681 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:22 timestamp:9489 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4792 type:0 pts:25911728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1257385 data_size:4792 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:23 timestamp:9489 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2450 type:0 pts:25978394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1262177 data_size:2450 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:24 timestamp:9489 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:901 type:0 pts:26045068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1264627 data_size:901 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:25 timestamp:9490 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:868 type:0 pts:26111735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1265528 data_size:868 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:26 timestamp:9490 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:293 type:0 pts:26178400 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1266396 data_size:293 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:27 timestamp:9490 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1869 type:0 pts:26245070 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1266689 data_size:1869 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:28 timestamp:9490 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:281 type:0 pts:26311728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1268558 data_size:281 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:29 timestamp:9490 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1412 type:0 pts:26378394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:1268839 data_size:1412 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:30 timestamp:9490 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:57270 type:1 pts:26445067 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:303] reach end,restart.ch0st0tr0 tail_offset:1270251 data_size:57270 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:31 timestamp:9491 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1677 type:0 pts:26511735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:57270 data_size:1677 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:32 timestamp:9491 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3370 type:0 pts:26578401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:58947 data_size:3370 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:33 timestamp:9491 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:274 type:0 pts:26645069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:62317 data_size:274 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:34 timestamp:9491 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:387 type:0 pts:26711729 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:62591 data_size:387 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:35 timestamp:9491 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:279 type:0 pts:26778394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:62978 data_size:279 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:36 timestamp:9499 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1989 type:0 pts:26845066 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:63257 data_size:1989 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:37 timestamp:9499 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1541 type:0 pts:26911734 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:65246 data_size:1541 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:38 timestamp:9500 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2821 type:0 pts:26978401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:66787 data_size:2821 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:39 timestamp:9500 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3727 type:0 pts:27045062 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:69608 data_size:3727 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:40 timestamp:9500 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2802 type:0 pts:27111728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:73335 data_size:2802 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:41 timestamp:9500 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1998 type:0 pts:27178394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:76137 data_size:1998 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:42 timestamp:9500 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2804 type:0 pts:27245067 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:78135 data_size:2804 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:43 timestamp:9500 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1238 type:0 pts:27311734 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:80939 data_size:1238 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:44 timestamp:9501 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2974 type:0 pts:27378400 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:82177 data_size:2974 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:45 timestamp:9501 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1542 type:0 pts:27445068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:85151 data_size:1542 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:46 timestamp:9501 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3473 type:0 pts:27511727 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:86693 data_size:3473 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:47 timestamp:9501 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2697 type:0 pts:27578394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:90166 data_size:2697 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:48 timestamp:9501 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3542 type:0 pts:27645068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:92863 data_size:3542 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:49 timestamp:9501 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4315 type:0 pts:27711736 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:96405 data_size:4315 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:50 timestamp:9501 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7248 type:0 pts:27778402 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:100720 data_size:7248 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:51 timestamp:9502 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2042 type:0 pts:27845070 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:107968 data_size:2042 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:52 timestamp:9502 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6512 type:0 pts:27911727 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:110010 data_size:6512 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:53 timestamp:9502 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6868 type:0 pts:27978394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:116522 data_size:6868 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:54 timestamp:9502 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4331 type:0 pts:28045067 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:123390 data_size:4331 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:55 timestamp:9503 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:805 type:0 pts:28111735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:127721 data_size:805 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:56 timestamp:9503 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2951 type:0 pts:28178401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:128526 data_size:2951 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:57 timestamp:9503 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5298 type:0 pts:28245069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:131477 data_size:5298 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:58 timestamp:9503 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:495 type:0 pts:28311728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:136775 data_size:495 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:59 timestamp:9503 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1483 type:0 pts:28378395 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:137270 data_size:1483 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:60 timestamp:9503 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:57699 type:1 pts:28445067 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:138753 data_size:57699 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:61 timestamp:9504 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:864 type:0 pts:28511734 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:196452 data_size:864 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:62 timestamp:9504 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3030 type:0 pts:28578401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:197316 data_size:3030 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:63 timestamp:9504 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1395 type:0 pts:28645070 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:200346 data_size:1395 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:64 timestamp:9504 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1842 type:0 pts:28711728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:201741 data_size:1842 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:65 timestamp:9504 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1384 type:0 pts:28778394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:203583 data_size:1384 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:66 timestamp:9505 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3351 type:0 pts:28845068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:204967 data_size:3351 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:67 timestamp:9505 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1728 type:0 pts:28911735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:208318 data_size:1728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:68 timestamp:9505 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2065 type:0 pts:28978401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:210046 data_size:2065 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:69 timestamp:9505 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:771 type:0 pts:29045068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:212111 data_size:771 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:70 timestamp:9505 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1281 type:0 pts:29111728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:212882 data_size:1281 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:71 timestamp:9505 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:354 type:0 pts:29178394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:214163 data_size:354 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:72 timestamp:9505 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:913 type:0 pts:29245066 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:214517 data_size:913 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:73 timestamp:9506 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3777 type:0 pts:29311735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:215430 data_size:3777 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:74 timestamp:9506 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1821 type:0 pts:29378400 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:219207 data_size:1821 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:75 timestamp:9506 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:328 type:0 pts:29445069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:221028 data_size:328 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:76 timestamp:9506 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1202 type:0 pts:29511727 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:221356 data_size:1202 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:77 timestamp:9506 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:806 type:0 pts:29578395 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:222558 data_size:806 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:78 timestamp:9506 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2404 type:0 pts:29645067 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:223364 data_size:2404 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:79 timestamp:9506 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1640 type:0 pts:29711734 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:225768 data_size:1640 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:80 timestamp:9507 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3132 type:0 pts:29778401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:227408 data_size:3132 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:81 timestamp:9507 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5733 type:0 pts:29845068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:230540 data_size:5733 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:82 timestamp:9507 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3948 type:0 pts:29911727 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:236273 data_size:3948 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:83 timestamp:9507 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7709 type:0 pts:29978395 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:240221 data_size:7709 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:84 timestamp:9507 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1405 type:0 pts:30045067 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:247930 data_size:1405 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:85 timestamp:9507 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2203 type:0 pts:30111735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:249335 data_size:2203 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:86 timestamp:9508 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:845 type:0 pts:30178400 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:251538 data_size:845 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:87 timestamp:9508 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4243 type:0 pts:30245069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:252383 data_size:4243 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:88 timestamp:9508 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5370 type:0 pts:30311728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:256626 data_size:5370 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:89 timestamp:9508 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2259 type:0 pts:30378394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:261996 data_size:2259 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:90 timestamp:9508 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:52846 type:1 pts:30445066 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:264255 data_size:52846 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:91 timestamp:9508 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1486 type:0 pts:30511735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:317101 data_size:1486 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:92 timestamp:9509 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4026 type:0 pts:30578401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:318587 data_size:4026 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:93 timestamp:9509 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1381 type:0 pts:30645068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:322613 data_size:1381 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:94 timestamp:9509 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3273 type:0 pts:30711727 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:323994 data_size:3273 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:95 timestamp:9509 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5842 type:0 pts:30778395 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:327267 data_size:5842 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:96 timestamp:9509 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1664 type:0 pts:30845068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:333109 data_size:1664 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:97 timestamp:9510 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2818 type:0 pts:30911736 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:334773 data_size:2818 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:98 timestamp:9510 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4308 type:0 pts:30978402 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:337591 data_size:4308 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:99 timestamp:9510 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5586 type:0 pts:31045069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:341899 data_size:5586 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:100 timestamp:9510 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3572 type:0 pts:31111728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:347485 data_size:3572 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:101 timestamp:9510 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4994 type:0 pts:31178395 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:351057 data_size:4994 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:102 timestamp:9510 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2679 type:0 pts:31245069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:356051 data_size:2679 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:103 timestamp:9510 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4205 type:0 pts:31311735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:358730 data_size:4205 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:104 timestamp:9511 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6852 type:0 pts:31378401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:362935 data_size:6852 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:105 timestamp:9511 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:11077 type:0 pts:31445068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:369787 data_size:11077 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:106 timestamp:9511 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5893 type:0 pts:31511728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:380864 data_size:5893 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:107 timestamp:9511 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:8849 type:0 pts:31578395 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:386757 data_size:8849 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:108 timestamp:9511 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4685 type:0 pts:31645067 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:395606 data_size:4685 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:109 timestamp:9513 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2930 type:0 pts:31711735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:400291 data_size:2930 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:110 timestamp:9513 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3000 type:0 pts:31778401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:403221 data_size:3000 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:111 timestamp:9513 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7060 type:0 pts:31845069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:406221 data_size:7060 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:112 timestamp:9516 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:821 type:0 pts:31911728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:413281 data_size:821 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:113 timestamp:9516 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2856 type:0 pts:31978394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:414102 data_size:2856 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:114 timestamp:9516 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1895 type:0 pts:32045068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:416958 data_size:1895 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:115 timestamp:9516 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7873 type:0 pts:32111735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:418853 data_size:7873 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:116 timestamp:9516 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7926 type:0 pts:32178401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:426726 data_size:7926 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:117 timestamp:9516 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:17847 type:0 pts:32245069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:434652 data_size:17847 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:118 timestamp:9517 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:15864 type:0 pts:32311727 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:452499 data_size:15864 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:119 timestamp:9517 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:14225 type:0 pts:32378395 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:468363 data_size:14225 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:120 timestamp:9517 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:44682 type:1 pts:32445068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:482588 data_size:44682 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:121 timestamp:9518 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2337 type:0 pts:32511736 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:527270 data_size:2337 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:122 timestamp:9518 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3742 type:0 pts:32578400 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:529607 data_size:3742 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:123 timestamp:9518 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6734 type:0 pts:32645069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:533349 data_size:6734 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:124 timestamp:9518 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:14062 type:0 pts:32711728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:540083 data_size:14062 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:125 timestamp:9519 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:8624 type:0 pts:32778395 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:554145 data_size:8624 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:126 timestamp:9519 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:13461 type:0 pts:32845068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:562769 data_size:13461 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:127 timestamp:9519 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:7836 type:0 pts:32911733 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:576230 data_size:7836 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:128 timestamp:9520 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:9421 type:0 pts:32978402 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:584066 data_size:9421 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:129 timestamp:9520 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:8369 type:0 pts:33045067 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:593487 data_size:8369 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:130 timestamp:9520 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6452 type:0 pts:33111728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:601856 data_size:6452 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:131 timestamp:9520 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5278 type:0 pts:33178394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:608308 data_size:5278 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:132 timestamp:9521 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3728 type:0 pts:33245068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:613586 data_size:3728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:133 timestamp:9521 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1476 type:0 pts:33311735 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:617314 data_size:1476 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:134 timestamp:9521 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2039 type:0 pts:33378400 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:618790 data_size:2039 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:135 timestamp:9521 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:4092 type:0 pts:33445069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:620829 data_size:4092 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:136 timestamp:9521 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1030 type:0 pts:33511728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:624921 data_size:1030 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:137 timestamp:9523 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1930 type:0 pts:33578395 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:625951 data_size:1930 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:138 timestamp:9523 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:813 type:0 pts:33645068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:627881 data_size:813 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:139 timestamp:9523 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3775 type:0 pts:33711734 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:628694 data_size:3775 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:140 timestamp:9563 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2563 type:0 pts:33778401 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:632469 data_size:2563 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:141 timestamp:9622 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2563 type:0 pts:33845069 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:635032 data_size:2563 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:142 timestamp:9682 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:993 type:0 pts:33911728 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:637595 data_size:993 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:143 timestamp:9762 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2282 type:0 pts:33978394 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:638588 data_size:2282 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:144 timestamp:9822 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:947 type:0 pts:34045068 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:640870 data_size:947 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:145 timestamp:9892 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2710 type:0 pts:34111736 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:641817 data_size:2710 [01-01 08:00:09 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:146 timestamp:9952 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1078 type:0 pts:34178401 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:644527 data_size:1078 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:147 timestamp:10032 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2661 type:0 pts:34245069 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:645605 data_size:2661 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:148 timestamp:10092 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5610 type:0 pts:34311728 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:648266 data_size:5610 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:149 timestamp:10152 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3387 type:0 pts:34378395 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:653876 data_size:3387 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:0 timestamp:10232 [00:00:34:430] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:34:430] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:54801 type:1 pts:34445068 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:657263 data_size:54801 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:1 timestamp:10292 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:753 type:0 pts:34511735 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:712064 data_size:753 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:2 timestamp:10352 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3216 type:0 pts:34578400 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:712817 data_size:3216 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:3 timestamp:10432 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:560 type:0 pts:34645068 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:716033 data_size:560 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:4 timestamp:10492 [00:00:34:690] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1246 type:0 pts:34711728 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:716593 data_size:1246 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:5 timestamp:10552 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:470 type:0 pts:34778395 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:717839 data_size:470 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:6 timestamp:10632 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5997 type:0 pts:34845067 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:718309 data_size:5997 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:7 timestamp:10692 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1200 type:0 pts:34911735 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:724306 data_size:1200 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:8 timestamp:10752 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:5567 type:0 pts:34978401 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:725506 data_size:5567 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:9 timestamp:10822 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1387 type:0 pts:35045068 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:731073 data_size:1387 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:10 timestamp:10882 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1781 type:0 pts:35111728 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:732460 data_size:1781 [01-01 08:00:10 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:11 timestamp:10962 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:988 type:0 pts:35178395 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:734241 data_size:988 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:12 timestamp:11022 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1869 type:0 pts:35245069 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:735229 data_size:1869 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:13 timestamp:11092 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:934 type:0 pts:35311735 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:737098 data_size:934 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:14 timestamp:11152 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2556 type:0 pts:35378401 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:738032 data_size:2556 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:15 timestamp:11222 [00:00:35:440] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:35:440] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1860 type:0 pts:35445069 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:740588 data_size:1860 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:16 timestamp:11282 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3233 type:0 pts:35511727 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:742448 data_size:3233 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:17 timestamp:11362 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:685 type:0 pts:35578394 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:745681 data_size:685 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:18 timestamp:11422 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1460 type:0 pts:35645068 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:746366 data_size:1460 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:19 timestamp:11492 [00:00:35:700] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:749 type:0 pts:35711734 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:747826 data_size:749 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:20 timestamp:11552 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2467 type:0 pts:35778401 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:748575 data_size:2467 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:21 timestamp:11632 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:822 type:0 pts:35845062 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:751042 data_size:822 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:22 timestamp:11692 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2154 type:0 pts:35911726 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:751864 data_size:2154 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:23 timestamp:11752 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1676 type:0 pts:35978394 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:754018 data_size:1676 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:24 timestamp:11832 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2456 type:0 pts:36045068 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:755694 data_size:2456 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:25 timestamp:11892 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:567 type:0 pts:36111736 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:758150 data_size:567 [01-01 08:00:11 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:26 timestamp:11952 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1404 type:0 pts:36178398 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:758717 data_size:1404 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:27 timestamp:12032 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:510 type:0 pts:36245068 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:760121 data_size:510 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:28 timestamp:12092 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1656 type:0 pts:36311727 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:760631 data_size:1656 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:29 timestamp:12152 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:220 type:0 pts:36378394 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:762287 data_size:220 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:30 timestamp:12232 [00:00:36:450] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:36:450] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:62624 type:1 pts:36445068 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:762507 data_size:62624 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:31 timestamp:12292 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:449 type:0 pts:36511735 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:825131 data_size:449 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:32 timestamp:12352 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2423 type:0 pts:36578401 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:825580 data_size:2423 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:33 timestamp:12432 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1108 type:0 pts:36645070 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:828003 data_size:1108 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:34 timestamp:12492 [00:00:36:710] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:356 type:0 pts:36711728 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:829111 data_size:356 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:35 timestamp:12552 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:410 type:0 pts:36778395 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:829467 data_size:410 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:36 timestamp:12632 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1127 type:0 pts:36845067 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:829877 data_size:1127 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:37 timestamp:12692 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:539 type:0 pts:36911735 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:831004 data_size:539 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:38 timestamp:12752 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1333 type:0 pts:36978402 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:831543 data_size:1333 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:39 timestamp:12822 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:552 type:0 pts:37045070 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:832876 data_size:552 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:40 timestamp:12882 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2066 type:0 pts:37111728 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:833428 data_size:2066 [01-01 08:00:12 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:41 timestamp:12962 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1023 type:0 pts:37178395 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:835494 data_size:1023 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:42 timestamp:13022 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:986 type:0 pts:37245068 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:836517 data_size:986 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:43 timestamp:13092 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:245 type:0 pts:37311736 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:837503 data_size:245 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:44 timestamp:13152 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:738 type:0 pts:37378400 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:837748 data_size:738 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:45 timestamp:13222 [00:00:37:460] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:37:460] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:323 type:0 pts:37445069 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:838486 data_size:323 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:46 timestamp:13282 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1307 type:0 pts:37511727 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:838809 data_size:1307 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:47 timestamp:13362 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:259 type:0 pts:37578394 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:840116 data_size:259 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:48 timestamp:13422 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:880 type:0 pts:37645067 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:840375 data_size:880 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:49 timestamp:13492 [00:00:37:720] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1281 type:0 pts:37711735 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:841255 data_size:1281 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:50 timestamp:13552 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2611 type:0 pts:37778401 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:842536 data_size:2611 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:51 timestamp:13622 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:734 type:0 pts:37845069 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:845147 data_size:734 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:52 timestamp:13682 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2664 type:0 pts:37911727 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:845881 data_size:2664 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:53 timestamp:13762 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:961 type:0 pts:37978395 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:848545 data_size:961 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:54 timestamp:13822 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2383 type:0 pts:38045068 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:849506 data_size:2383 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:55 timestamp:13892 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1873 type:0 pts:38111735 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:851889 data_size:1873 [01-01 08:00:13 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:56 timestamp:13952 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2926 type:0 pts:38178399 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:853762 data_size:2926 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:57 timestamp:14022 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:2381 type:0 pts:38245068 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:856688 data_size:2381 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:58 timestamp:14082 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3742 type:0 pts:38311728 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:859069 data_size:3742 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:59 timestamp:14162 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:3212 type:0 pts:38378394 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:862811 data_size:3212 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:60 timestamp:14222 [00:00:38:470] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [00:00:38:470] [TKL_WIFI] [tkl_wifi_station_get_status, 681]:g_sta_status = 6 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:61127 type:1 pts:38445068 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:866023 data_size:61127 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:61 timestamp:14292 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:1202 type:0 pts:38511735 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:927150 data_size:1202 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:62 timestamp:14352 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:921] append to ch0st0tr0 size:6025 type:0 pts:38578402 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:311] not reach end.ch0st0tr0 tail_offset:928352 data_size:6025 [01-01 08:00:14 ty T][ae00][tuya_ring_buffer.c:972] append done, ch0st0tr0 node index:63 timestamp:14422 ^Csignal 2 [00:00:38:631] [MAIN] [main, 184]:exit main # ^C
