 * @file app_main.c
 * @brief app_main module is used to
 * @date 2022-04-14
#include "ty_sys.h"
#include "tuya_app_config.h"
#include "ty_app_starts_up_intf.h"
#include "ty_app_mf_test.h"
#include "tkl_thread.h"
#define EXAMPLES_ENABLE 1
#if defined(EXAMPLES_ENABLE) && (EXAMPLES_ENABLE)
#include "examples_main.h"
STATIC TKL_THREAD_HANDLE ty_app_thread = NULL;
 * @brief  application entrance
 * @return
void app_main(void)
    // base utilities init, such as log system, etc.
    tuya_base_utilities_init();
#if defined(ENABLE_FIRMWARE_DEBUG) && (ENABLE_FIRMWARE_DEBUG)
    tal_log_set_manage_attr(TAL_LOG_LEVEL_DEBUG);
#if defined(ENABLE_LWIP) && (ENABLE_LWIP)
    TUYA_LwIP_Init();
    // 应用消息队列初始化
    TUYA_CALL_ERR_LOG(ty_app_msg_queue_init());
    // SDK 初始化前的预备工作，注册SDK事件等
    TUYA_CALL_ERR_LOG(ty_app_pre_sdk_init());
    tuyaos_wifi_sdk_init();
    // 模组产测（mf test） 通知注册
#if defined(ENABLE_MF_TEST_STATUS) && (ENABLE_MF_TEST_STATUS)
    TUYA_CALL_ERR_LOG(ty_sys_mf_status_cb_reg(ty_app_mf_test_status_cb));
    // 模组产测时获取应用配置参数(oem 参数) 回调注册
#if defined(ENABLE_GET_MF_TEST_USER_PARAM) && (ENABLE_GET_MF_TEST_USER_PARAM)
    mf_user_param_cb_set(ty_app_mf_test_user_param_cb);
    // KV flash 数据存储模块初始化
    tuya_iot_kv_flash_init(NULL);
    // 搭配涂鸦上位机进行成品产测
#if defined(ENABLE_PRODUCT_TEST_MF) && (ENABLE_PRODUCT_TEST_MF)
    TUYA_CALL_ERR_LOG(ty_sys_mf_product_test_reg(ty_app_product_test_mf_cb));
    // 成品产测扫描指定wifi
#if defined(ENABLE_PRODUCT_TEST_SCAN_WIFI) && (ENABLE_PRODUCT_TEST_SCAN_WIFI)
    TY_WIFI_TEST_SCAN_INFO_T wifi_scan_info;
    memset((TY_WIFI_TEST_SCAN_INFO_T *)&wifi_scan_info, 0x00, SIZEOF(TY_WIFI_TEST_SCAN_INFO_T));
    TUYA_CALL_ERR_LOG(ty_app_get_product_test_scan_wifi(&wifi_scan_info));
    TUYA_CALL_ERR_LOG(ty_sys_product_test_scan_wifi_reg(&wifi_scan_info));
#if defined(ENABLE_TY_FIRMWARE_OEM) && (ENABLE_TY_FIRMWARE_OEM)
    tuya_iot_oem_set(TRUE);
    //工厂测试
    TUYA_CALL_ERR_LOG(ty_sys_factory_test());
    //进入成品产测, 则不执行设备激活配网流程
    if(TRUE ==  ty_sys_is_enter_product_test()) {
        TAL_PR_NOTICE("factory product test");
        TUYA_CALL_ERR_LOG(ty_app_component_init());
    //注册联网单品设备重要回调
    TY_WIFI_PROD_CB_S  cb_list = {0};
    memset((UCHAR_T *)&cb_list, 0x00, SIZEOF(TY_WIFI_PROD_CB_S));
    cb_list.wf_nw_stat_cb   = ty_app_wf_nw_stat_cb;
    cb_list.gw_status_cb    = ty_app_gw_status_changed_cb;
    cb_list.gw_reset_cb     = ty_app_gw_reset_cb;
    cb_list.dev_obj_dp_cb   = ty_app_obj_dp_handle;
    cb_list.dev_raw_dp_cb   = ty_app_raw_dp_handle;
    cb_list.dev_dp_query_cb = ty_app_dp_query_handle;
#if defined(ENABLE_TY_INFORM_OTA_REQ) && (ENABLE_TY_INFORM_OTA_REQ)
    cb_list.pre_gw_mcu_ug_cb = ty_app_upgrade_pre_cb;
#if defined(ENABLE_TY_MCU_OTA) && (ENABLE_TY_MCU_OTA)
    cb_list.mcu_ug_cb = ty_app_mcu_upgrade_cb;
    TUYA_CALL_ERR_LOG(ty_sys_iot_dev_cbs_reg(&cb_list));
#if defined(ENABLE_TY_PROD_INIT_NORMAL_PROCESS) && (ENABLE_TY_PROD_INIT_NORMAL_PROCESS)
    //product starts up
#if defined(ENABLE_TY_SOC_DEV) && (ENABLE_TY_SOC_DEV)
    TY_WIFI_SOC_PROD_CFG_S  soc_prod_info;
    memset((TY_WIFI_SOC_PROD_CFG_S *)&soc_prod_info, 0x00, SIZEOF(TY_WIFI_SOC_PROD_CFG_S));
    TUYA_CALL_ERR_LOG(ty_app_get_soc_product_cfg(&soc_prod_info));
    TUYA_CALL_ERR_LOG(ty_sys_wifi_soc_init(&soc_prod_info));
    TY_WIFI_MCU_PROD_CFG_S mcu_prod_info;
    memset((TY_WIFI_MCU_PROD_CFG_S *)&mcu_prod_info, 0x00, SIZEOF(TY_WIFI_MCU_PROD_CFG_S));
    TUYA_CALL_ERR_LOG(ty_app_get_mcu_product_cfg(&mcu_prod_info));
    TUYA_CALL_ERR_LOG(ty_sys_wifi_mcu_init(&mcu_prod_info));
static void tuya_app_thread(void *arg)
#if !(defined(EXAMPLES_ENABLE) && (EXAMPLES_ENABLE))
    app_main();
    examples_main();
    tkl_thread_release(ty_app_thread);
void tuya_app_main(void)
    tkl_thread_create(&ty_app_thread, "tuya_app_main", 4096, 4, tuya_app_thread, NULL);
