/ # tuya_app 1 drm: Found plane_id: 58 connector_id: 62 crtc_id: 60 drm: 480x800 (217mm X 136mm) pixel format AR24 DRM subsystem and buffer mapped successfully LOG_INFO :*** update_engine: Version V1.0.1 ***. LOG_INFO :Current device is not MTD LOG_INFO :Current device is not MTD Successfully initialized wpa_supplicant udhcpc: started, v1.27.2 udhcpc: sending discover 2022-10-19 15:23:06:977:setting_network.c:_RK_wifi_state_callback:615:_RK_wifi_state_callback state:4 2022-10-19 15:23:06:989:setting_network.c:_RK_wifi_state_callback:639:wifi_cur_name = Smatek 2022-10-19 15:23:07:124:main.c:setting_netword:189:设备已绑定! [01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /userdata/tuya_db_files [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/userdata/tuya_db_files [01-01 18:12:15 TUYA D][simplekv.c:945] path:/userdata/tuya_db_files [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[���US����ykR��] [01-01 18:12:15 TUYA D][simplekv.c:1012] both file exist [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512 [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success [01-01 18:12:15 TUYA D][simplekv.c:1055] read from normal file [01-01 18:12:15 TUYA D][simplekv.c:765] curr db is V2. No need to upgrade [01-01 18:12:15 TUYA D][simplekv.c:555] head check success [01-01 18:12:15 TUYA D][simplekv.c:658] read and check head success [01-01 18:12:15 TUYA D][simplekv.c:1075] read from normal file success [01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:sys_timer Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2360] [ty_rcd] udb_mng inited. [01-01 18:12:15 TUYA D][rcd_file.c:2377] [ty_rcd] db_enc_file_nm:/userdata/tuya_db_files/rcdDb/tyRcdEncKey.rdb rcd encrypt key 16 1b e1 4a c3 f0 2e ba cd 41 3e ae 04 c2 8e 8e 68 [01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:gw_pool_fast0,stackDepth:8192,totalstackDepth:12288,priority:4 [01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:gw_pool_fast0 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][thread_pool.c:154] get thread id:0x30c [01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:gw_pool_nor0,stackDepth:8192,totalstackDepth:20480,priority:3 [01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:gw_pool_nor0 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][thread_pool.c:154] get thread id:0x30d [01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:gw_pool_nor1,stackDepth:8192,totalstackDepth:28672,priority:3 [01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:gw_pool_nor1 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][thread_pool.c:154] get thread id:0x30e [01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:gw_pool_tmp0,stackDepth:8192,totalstackDepth:36864,priority:2 [01-01 18:12:15 TUYA D][thread_pool_temp.c:271] create temp 0 in 0x7f94001420 [01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:gw_pool_tmp0 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:gw_pool_tmp1,stackDepth:8192,totalstackDepth:45056,priority:2 [01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:gw_pool_tmp1 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][thread_pool_temp.c:271] create temp 1 in 0x7f940013f0 [01-01 18:12:15 TUYA D][thread_pool.c:393] thread type:1 idx:0 md:1 name:thr_pool_idle [01-01 18:12:15 TUYA D][thread_pool.c:431] get thread 1 thr_pool_idle ret:0x7fa1193618 [01-01 18:12:15 TUYA D][thread_pool_temp.c:354] not cycle thread [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ... [01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:cmmod,stackDepth:4096,totalstackDepth:49152,priority:4 [01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:cmmod Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2 [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success [01-01 18:12:15 TUYA D][log_seq.c:894] read m:0 f:0 l:0 [01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:54272,priority:3 [01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:wk_th-0 Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][user_iot_intf.c:337] tuya_iot_init success [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:192 [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0 [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:789] tuya svc upgrade init success! [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:2 gw_di [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_di find value.Len:352 [01-01 18:12:15 TUYA D][ws_db_gw.c:507] gw_di read success [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:000004brzg isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:10 000004brzg [01-01 18:12:15 TUYA D][simplekv.c:1280] key:000004brzg find value.Len:720 [01-01 18:12:15 TUYA D][ws_db_gw.c:691] schema 000004brzg read success [01-01 18:12:15 TUYA D][subdev_sto_rcd.c:995] schema value is ok [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_alarm_flag isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:192 [01-01 18:12:15 TUYA D][thread_pool.c:393] thread type:2 idx:0 md:1 name:async_task [01-01 18:12:15 TUYA D][thread_pool.c:431] get thread 2 async_task ret:0x7fa1193788 [01-01 18:12:15 TUYA D][thread_pool.c:393] thread type:2 idx:1 md:2 name:reli_http [01-01 18:12:15 TUYA D][thread_pool.c:431] get thread 2 reli_http ret:0x7fa1193788 [01-01 18:12:15 TUYA D][rcd_file.c:2450] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA E][rcd_file.c:707] [ty_rcd] fread error 3072 3392 [01-01 18:12:15 TUYA E][rcd_file.c:744] [ty_rcd] check metadata failed. [01-01 18:12:15 TUYA E][rcd_file.c:2497] [ty_rcd] __read_data_and_check error:-10109 [01-01 18:12:15 TUYA N][rcd_file.c:2477] [ty_rcd] restore from bak file [01-01 18:12:15 TUYA E][rcd_file.c:1080] [ty_rcd] open back file fails /userdata/tuya_db_files/rcdDb/gw_cm_kv.rdb_bak [01-01 18:12:15 TUYA N][rcd_file.c:2480] [ty_rcd] __rcd_db_restore error:-1001 [01-01 18:12:15 TUYA D][rcd_file.c:2512] [ty_rcd] init NEW normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2450] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA E][rcd_file.c:707] [ty_rcd] fread error 3072 3392 [01-01 18:12:15 TUYA E][rcd_file.c:744] [ty_rcd] check metadata failed. [01-01 18:12:15 TUYA E][rcd_file.c:2497] [ty_rcd] __read_data_and_check error:-10109 [01-01 18:12:15 TUYA N][rcd_file.c:2477] [ty_rcd] restore from bak file [01-01 18:12:15 TUYA E][rcd_file.c:1080] [ty_rcd] open back file fails /userdata/tuya_db_files/rcdDb/gw_cm_kv_s.rdb_bak [01-01 18:12:15 TUYA N][rcd_file.c:2480] [ty_rcd] __rcd_db_restore error:-1001 [01-01 18:12:15 TUYA D][rcd_file.c:2512] [ty_rcd] init NEW normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][crash_dump.c:376] init_dump_info rm: missing operand Try 'rm --help' for more information. set stack dump len: 8192 [01-01 18:12:15 TUYA D][tuya_zigbee_api.c:241] ++++++++>{ "storage_path": "/userdata", "cache_path": "/tmp", "dev_name": "/dev/ttyS0", "cts": 1, "thread_mode": 1, "sw_ver": "1.0.8" } [01-01 18:12:15 TUYA D][tuya_zigbee_api.c:263] zigbee is detected, port: /dev/ttyS0, cts: 1 cfg_str:{"platform":"GENERIC","mode_id":"SDK","product_key":"NOT USE","wifi_interface":"NOT USE","wan_interface":"NOT USE","net_led":"NOT USE","status_led":"NOT USE","reset_key":"NOT USE","is_sync_systime":false,"is_hardward":false,"storage_dir":"/userdata","log_dir":"/userdata","backup_dir":"/userdata","bin_dir":"/userdata","tmp_dir":"/tmp","serial_port":"/dev/ttyS0","is_cts":true}. [01-01 18:12:15 TUYA D][tuya_strategy_code.c:37] register code: enum cnt:1 [01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:img_sevice_http,stackDepth:10240,totalstackDepth:64512,priority:2 [01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:img_sevice_http Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][rcd_file.c:2460] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2505] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:52 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2460] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2505] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:52 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2460] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2505] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:60 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2460] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2505] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:6 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2460] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2505] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:1 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:38 cnt:3 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:2 cnt:4 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:903 cnt:5 [01-01 18:12:15 TUYA D][svc_img.c:976] id name path is:/userdata/tuya_db_files/ctrl_dev_img/ [01-01 18:12:15 TUYA D][svc_img.c:991] id name list path is:/userdata/tuya_db_files/ctrl_dev_img/ [01-01 18:12:15 TUYA D][thread_pool.c:393] thread type:2 idx:0 md:3 name:ctrl_center [01-01 18:12:15 TUYA D][thread_pool.c:431] get thread 2 ctrl_center ret:0x7fa1193850 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:287] start load config [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: axw2wati6x8wwqrh not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: axw2wati6x8wwqrh category: wg2 dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 6y1cduj4ealrfndo category: bzyd dp_num: 4 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: zach3mptpjpojys6 not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: zach3mptpjpojys6 category: ylcg dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: fboep9j6grtxyga9 category: dd dp_num: 7 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: jogzi8noyhgcahcq category: tdq dp_num: 6 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: dc6v3yjsjhajgb7f not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: dc6v3yjsjhajgb7f category: wfcon dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: l9rksbbbisynlnvq category: tdq dp_num: 8 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: pbx8cm1kvgn0fv2d category: dd dp_num: 7 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: mjffeakbzlnfxpzt not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: mjffeakbzlnfxpzt category: wnykq dp_num: 0 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 1vso02tkynsvpinp category: wg2 dp_num: 23 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: oniuxtrf5xu85d69 not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: oniuxtrf5xu85d69 category: wnykq dp_num: 0 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: 1svzszztogaibjxa not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 1svzszztogaibjxa category: dgnzk dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: qhfvhlm1k0ws0gul category: dj dp_num: 7 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: seuwp5kki3tvz3wl category: tdq dp_num: 6 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: w906qkrrhd3otiwd category: cz dp_num: 10 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: mh9px7cq category: wxkg dp_num: 5 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: j0zozzoarutv0nu1 category: cz dp_num: 9 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: jyupj3fw category: kg dp_num: 14 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: 7zjewx91 not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 7zjewx91 category: wg2 dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 1aso8gn0szwvjjue category: clkg dp_num: 6 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: jcamvbr95hdno5ub category: pir dp_num: 2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: oqe2ba267qac12ng category: wk dp_num: 11 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: ha7agddwqq6ahbiz category: tdq dp_num: 10 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: wpxcg1ahziux5tzh category: mcs dp_num: 2 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: 0000008vhd not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 0000008vhd category: infrared_ac dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: grpvptbrpkissnd8 category: cz dp_num: 10 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 98afxsvjfbobhjw4 category: tdq dp_num: 6 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: a33rw7ou category: mcs dp_num: 2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 2ekuz3dz category: wk dp_num: 13 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 97cp1wty56mww1o0 category: pc dp_num: 9 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: ajadcojk category: kg dp_num: 7 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: hfq0xqhjsqmfqkw4 category: wnykq dp_num: 2 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: nkkl7uzv not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: nkkl7uzv category: zjq dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 9yyaalraupjaredl category: dd dp_num: 9 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: yrmpfrig5ndywijq not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: yrmpfrig5ndywijq category: wnykq dp_num: 0 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: 000000dfug not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 000000dfug category: infrared_ac dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: manu90xvog2uqakl category: dlq dp_num: 15 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: mq2mrjjqlkorvgfe category: kg dp_num: 14 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 2mqosesmkrvlvl0w category: pir dp_num: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: qwpfjxryaj7pr9rw category: wsdcg dp_num: 15 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: lmjfyvtsig6v5npw not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: lmjfyvtsig6v5npw category: wnykq dp_num: 0 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 9nauypjb2kvujrut category: dj dp_num: 16 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 0ln8tfei1iulgo2k category: kg dp_num: 14 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 9cwtq6di0cz7bikc category: kg dp_num: 4 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: 2ywpwkvsgqujwlgs not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 2ywpwkvsgqujwlgs category: dgnzk dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: jqo111f6ahvas3tr category: tdq dp_num: 6 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:822] not process type: Raw [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: dgudhgjmxdznjm6d category: sp dp_num: 18 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: gw173aldekvpzalg category: wk dp_num: 5 [01-01 18:12:15 TUYA W][tuya_ctrl_center.c:1897] pid: qzktzhehinzsz2je not dp [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: qzktzhehinzsz2je category: infrared_ac dp_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 4fjiwweb category: wxkg dp_num: 4 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: pj3gdjgpeqao7xk4 category: wg2 dp_num: 4 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1926] add pid: 8nd1vkcuwbektfod category: clkg dp_num: 5 [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:53,udb->rcd_valid_cnt:52 [01-01 18:12:15 TUYA E][rcd_file.c:2887] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA E][tuya_ctrl_storage.c:109] call tuya_rcd_entry_read_next(first, TY_PROD_STD_FILE_NAME, &p_data, &data_len) return -10100 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: fboep9j6grtxyga9 switch_dp: 20 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: pbx8cm1kvgn0fv2d switch_dp: 20 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: j0zozzoarutv0nu1 switch_dp: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: 1aso8gn0szwvjjue switch_dp: 102 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: ha7agddwqq6ahbiz switch_dp: 3 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: 97cp1wty56mww1o0 switch_dp: 2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: 9yyaalraupjaredl switch_dp: 20 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: jqo111f6ahvas3tr switch_dp: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: 9nauypjb2kvujrut switch_dp: 20 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: 6y1cduj4ealrfndo switch_dp: 104 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: jogzi8noyhgcahcq switch_dp: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: dc6v3yjsjhajgb7f switch_dp: 104 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: qhfvhlm1k0ws0gul switch_dp: 20 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: seuwp5kki3tvz3wl switch_dp: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: jyupj3fw switch_dp: 6 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: 98afxsvjfbobhjw4 switch_dp: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: ajadcojk switch_dp: 3 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: manu90xvog2uqakl switch_dp: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: mq2mrjjqlkorvgfe switch_dp: 6 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: 0ln8tfei1iulgo2k switch_dp: 4 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2055] pid: 9cwtq6di0cz7bikc switch_dp: 1 [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:53,udb->rcd_valid_cnt:52 [01-01 18:12:15 TUYA E][rcd_file.c:2937] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA E][tuya_ctrl_storage.c:341] call tuya_rcd_entry_read_next_with_key(first, TY_CTRL_PRODUCT_FILE_NAME, &p_key, &p_data, &data_len) return -10100 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebd0ad496c403f1af3i9an name: Zigbee Contact Sensor pid: a33rw7ou comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: a4c1384c59b8c6ff icon_path: dev_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : a33rw7ou associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb257c7e0da82bf6fdgo2g name: Zigbee LAN Gateway pid: axw2wati6x8wwqrh comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 0 node: icon_path: dev_num: 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : axw2wati6x8wwqrh associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 1, dp_name : Switch 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 2, dp_name : Switch 2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 3, dp_name : Switch 3 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb0f65ca9465be8edcoyot name: ZigBee 3 Gang Switch pid: ajadcojk comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: 9035eafffe583c5a icon_path: dev_num: 2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : ajadcojk associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebf673a55509854f89o4ms name: Switch of scene pid: mh9px7cq comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: a4c138389b2e90c3 icon_path: dev_num: 3 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : mh9px7cq associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebe5c0ea9264da5aedqyqx name: 4'' Smart panel-EU pid: 2ywpwkvsgqujwlgs comm: ebe5c0ea9264da5aedqyqx pv: 2.2 sub: 0 node: 05e0 icon_path: dev_num: 4 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 2ywpwkvsgqujwlgs associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebabc77077c75fec391svt name: Zigbee Smart Thermostat pid: 2ekuz3dz comm: eb99a9cc76209358a4crkr pv: 2.2 sub: 1 node: a4c1388ce8e59bc8 icon_path: dev_num: 5 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 2ekuz3dz associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebe2744515d20294b1yhgw name: Zigbee Repeater pid: nkkl7uzv comm: eb99a9cc76209358a4crkr pv: 2.2 sub: 1 node: b4e3f9fffe3e0834 icon_path: dev_num: 6 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : nkkl7uzv associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb99a9cc76209358a4crkr name: Gateway pid: 7zjewx91 comm: eb99a9cc76209358a4crkr pv: 2.2 sub: 0 node: icon_path: dev_num: 7 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 7zjewx91 associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb67a0efcb59444d01ydgn name: 智能插座 pid: grpvptbrpkissnd8 comm: eb67a0efcb59444d01ydgn pv: 2.2 sub: 0 node: icon_path: dev_num: 8 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : grpvptbrpkissnd8 associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebe7f7541d3a5e34dcplwr name: RGB strip pid: pbx8cm1kvgn0fv2d comm: ebe7f7541d3a5e34dcplwr pv: 2.2 sub: 0 node: icon_path: dev_num: 9 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : pbx8cm1kvgn0fv2d associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb62263aaf2f73ef03xira name: 智能彩灯 pid: qhfvhlm1k0ws0gul comm: eb62263aaf2f73ef03xira pv: 2.2 sub: 0 node: icon_path: dev_num: 10 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : qhfvhlm1k0ws0gul associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebb800d543876b9d83jiah name: Alarm Security System pid: dc6v3yjsjhajgb7f comm: ebb800d543876b9d83jiah pv: 2.2 sub: 0 node: icon_path: dev_num: 11 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : dc6v3yjsjhajgb7f associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 1, dp_name : Switch 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 2, dp_name : Switch 2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 3, dp_name : Switch 3 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 4, dp_name : Switch 4 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 5, dp_name : Switch 5 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 6, dp_name : Switch 6 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 16, dp_name : Backlight Switch [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebc78c65e28bc1347ac761 name: 4X4 Switch+Socket pid: 0ln8tfei1iulgo2k comm: ebc78c65e28bc1347ac761 pv: 2.2 sub: 0 node: icon_path: dev_num: 12 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 0ln8tfei1iulgo2k associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb3b1fefe57125bb72nrzb name: Curtain switch pid: 1aso8gn0szwvjjue comm: eb3b1fefe57125bb72nrzb pv: 2.2 sub: 0 node: icon_path: dev_num: 13 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 1aso8gn0szwvjjue associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb9e43a7db146d1286luio name: 空调 pid: 0000008vhd comm: eb87649dc6a4ae7fef87xr pv: 2.2 sub: 1 node: f919e9057b0bfb2b icon_path: dev_num: 14 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 0000008vhd associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb87649dc6a4ae7fef87xr name: 智能红外遥控器 pid: mjffeakbzlnfxpzt comm: eb87649dc6a4ae7fef87xr pv: 2.2 sub: 0 node: icon_path: dev_num: 15 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : mjffeakbzlnfxpzt associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 2, dp_name : 彩灯 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb76889250a9917161wng9 name: Smart Color Ambiance Light pid: 6y1cduj4ealrfndo comm: eb76889250a9917161wng9 pv: 2.2 sub: 0 node: icon_path: dev_num: 16 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 6y1cduj4ealrfndo associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebff3d1dac6c9c54ebu58o name: 门铃按钮 pid: 2mqosesmkrvlvl0w comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: 0995C0FF icon_path: dev_num: 17 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 2mqosesmkrvlvl0w associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb3edad403134c4f6czxy4 name: 人体传感器 pid: jcamvbr95hdno5ub comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: AD2250FF icon_path: dev_num: 18 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : jcamvbr95hdno5ub associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebd959f9cc5a9857b2zsoo name: 遥控器 pid: zach3mptpjpojys6 comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: 5ECA80FF icon_path: dev_num: 19 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : zach3mptpjpojys6 associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb92c47fe161c74b89dk25 name: 门磁 pid: wpxcg1ahziux5tzh comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: 83DF08FF icon_path: dev_num: 20 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : wpxcg1ahziux5tzh associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebf8fee6f4298432a5eqvk name: 智能网关 pid: 1vso02tkynsvpinp comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 0 node: icon_path: dev_num: 21 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 1vso02tkynsvpinp associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb8607e2c51bffc942fczo name: 红外射频遥控器 3 pid: lmjfyvtsig6v5npw comm: eb8607e2c51bffc942fczo pv: 2.2 sub: 0 node: icon_path: dev_num: 22 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : lmjfyvtsig6v5npw associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebf911148e218a63b67uf3 name: Air pid: 000000dfug comm: ebd88c655bdd4b39adihqe pv: 2.2 sub: 1 node: f919e9057b0bfb2b icon_path: dev_num: 23 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 000000dfug associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebd88c655bdd4b39adihqe name: 智能红外遥控器 pid: oniuxtrf5xu85d69 comm: ebd88c655bdd4b39adihqe pv: 2.2 sub: 0 node: icon_path: dev_num: 24 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : oniuxtrf5xu85d69 associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb46ca57fbaaa5a173n9zv name: 红外射频遥控器 2 pid: lmjfyvtsig6v5npw comm: eb46ca57fbaaa5a173n9zv pv: 2.2 sub: 0 node: icon_path: dev_num: 25 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : lmjfyvtsig6v5npw associate 2 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb92b0479e015fbbaavltv name: 智能红外遥控器 pid: hfq0xqhjsqmfqkw4 comm: eb92b0479e015fbbaavltv pv: 2.2 sub: 0 node: icon_path: dev_num: 26 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : hfq0xqhjsqmfqkw4 associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 1, dp_name : Switch 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 2, dp_name : Switch 2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebaf2b250cb41e058ekxqm name: Smart Dual Socket 2 pid: 97cp1wty56mww1o0 comm: ebaf2b250cb41e058ekxqm pv: 2.2 sub: 0 node: icon_path: dev_num: 27 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 97cp1wty56mww1o0 associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 1, dp_name : Switch 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 2, dp_name : Switch 2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb09bad8e75f6222acaglz name: Intelligent Switcher 2CH pid: l9rksbbbisynlnvq comm: eb09bad8e75f6222acaglz pv: 2.2 sub: 0 node: icon_path: dev_num: 28 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : l9rksbbbisynlnvq associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb9c17916f715a30e0a7mz name: Intelligent Switcher 2 pid: 98afxsvjfbobhjw4 comm: eb9c17916f715a30e0a7mz pv: 2.2 sub: 0 node: icon_path: dev_num: 29 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 98afxsvjfbobhjw4 associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: vdevo166201192349972 name: 幻彩2期-oem-vdevo pid: fboep9j6grtxyga9 comm: vdevo166201192349972 pv: 2.0 sub: 0 node: icon_path: dev_num: 30 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : fboep9j6grtxyga9 associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 1, dp_name : 开关1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 2, dp_name : 开关2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb62f037dd6640bfa41gut name: Smart Dual Socket pid: 97cp1wty56mww1o0 comm: eb62f037dd6640bfa41gut pv: 2.2 sub: 0 node: icon_path: dev_num: 31 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 97cp1wty56mww1o0 associate 2 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb4576f5222b16dccaaazi name: WIFI lamp tape 2 pid: 9yyaalraupjaredl comm: eb4576f5222b16dccaaazi pv: 2.2 sub: 0 node: icon_path: dev_num: 32 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 9yyaalraupjaredl associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebb063750d514d878079mw name: 计量微断开关(1P+N) pid: manu90xvog2uqakl comm: ebb063750d514d878079mw pv: 2.2 sub: 0 node: icon_path: dev_num: 33 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : manu90xvog2uqakl associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eba407ffd4d23748c3rlsw name: Intelligent Switcher pid: 98afxsvjfbobhjw4 comm: eba407ffd4d23748c3rlsw pv: 2.2 sub: 0 node: icon_path: dev_num: 34 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 98afxsvjfbobhjw4 associate 2 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb0058bee16ce0c70aq9nj name: Temp pid: gw173aldekvpzalg comm: eb0058bee16ce0c70aq9nj pv: 2.2 sub: 0 node: icon_path: dev_num: 35 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : gw173aldekvpzalg associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb68d8dbe4707224e8sxd8 name: Wifi Plug pid: j0zozzoarutv0nu1 comm: eb68d8dbe4707224e8sxd8 pv: 2.2 sub: 0 node: icon_path: dev_num: 36 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : j0zozzoarutv0nu1 associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebe3006b0f14083917oh1d name: 空调温控器 2 pid: oqe2ba267qac12ng comm: ebe3006b0f14083917oh1d pv: 2.2 sub: 0 node: icon_path: dev_num: 37 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : oqe2ba267qac12ng associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: vdevo166098193021398 name: Smart Switch Module-vdevo pid: seuwp5kki3tvz3wl comm: vdevo166098193021398 pv: 2.0 sub: 0 node: icon_path: dev_num: 38 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : seuwp5kki3tvz3wl associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb3cfb587e6d81417eac8e name: Smart Switch pid: jogzi8noyhgcahcq comm: eb3cfb587e6d81417eac8e pv: 2.2 sub: 0 node: icon_path: dev_num: 39 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : jogzi8noyhgcahcq associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebb4f72bc0eb72ac62dhlo name: WIFI lamp tape pid: 9yyaalraupjaredl comm: ebb4f72bc0eb72ac62dhlo pv: 2.2 sub: 0 node: icon_path: dev_num: 40 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 9yyaalraupjaredl associate 2 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebc90e9813ffde4148tcvg name: WI-FI Temperature & Humidity Sensor pid: qwpfjxryaj7pr9rw comm: ebc90e9813ffde4148tcvg pv: 2.2 sub: 0 node: icon_path: dev_num: 41 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : qwpfjxryaj7pr9rw associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb631bd9b6590e001blfgs name: mini通断器 pid: jqo111f6ahvas3tr comm: eb631bd9b6590e001blfgs pv: 2.2 sub: 0 node: icon_path: dev_num: 42 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : jqo111f6ahvas3tr associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eba528413f6980a463pn4p name: Smart Bulb(BP5758D 35/10) pid: 9nauypjb2kvujrut comm: eba528413f6980a463pn4p pv: 2.2 sub: 0 node: icon_path: dev_num: 43 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 9nauypjb2kvujrut associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 1, dp_name : 开关 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 2, dp_name : 开关 2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 3, dp_name : 开关 3 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 4, dp_name : 开关 4 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 5, dp_name : 开关 5 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 6, dp_name : 开关 6 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 16, dp_name : 背光开关 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: vdevo166004655924109 name: Six Gang Switch-vdevo pid: mq2mrjjqlkorvgfe comm: vdevo166004655924109 pv: 2.0 sub: 0 node: icon_path: dev_num: 44 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : mq2mrjjqlkorvgfe associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb21cdbd5e05e8e428gaca name: 空调温控器 pid: oqe2ba267qac12ng comm: eb21cdbd5e05e8e428gaca pv: 2.2 sub: 0 node: icon_path: dev_num: 45 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : oqe2ba267qac12ng associate 2 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb71d993c258066917jpks name: IPC pid: dgudhgjmxdznjm6d comm: eb71d993c258066917jpks pv: 2.2 sub: 0 node: icon_path: dev_num: 46 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : dgudhgjmxdznjm6d associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebba64b6ac327cdeddq8z2 name: Curtain Switch pid: 8nd1vkcuwbektfod comm: ebba64b6ac327cdeddq8z2 pv: 2.2 sub: 0 node: icon_path: dev_num: 47 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 8nd1vkcuwbektfod associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 1, dp_name : 开关1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 2, dp_name : 开关2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 3, dp_name : 开关3 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 44, dp_name : 点动开关 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb2372042e64f76e79f3jk name: Smart 3-Gang Switch pid: ha7agddwqq6ahbiz comm: eb2372042e64f76e79f3jk pv: 2.2 sub: 0 node: icon_path: dev_num: 48 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : ha7agddwqq6ahbiz associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebb3fad96f393b588eomxh name: IR remote pid: lmjfyvtsig6v5npw comm: ebb3fad96f393b588eomxh pv: 2.2 sub: 0 node: icon_path: dev_num: 49 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : lmjfyvtsig6v5npw associate 3 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb1552c6f83a6b59edmyes name: P6EL 2 pid: 1svzszztogaibjxa comm: eb1552c6f83a6b59edmyes pv: 2.2 sub: 0 node: icon_path: dev_num: 50 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 1svzszztogaibjxa associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 1, dp_name : Switch 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 2, dp_name : Switch 2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 3, dp_name : Switch 3 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 4, dp_name : Switch 4 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 5, dp_name : Switch 5 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 6, dp_name : Switch 6 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 16, dp_name : Backlight Switch [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb0a212b4b26ce96c62aei name: Six Gang Switch 2 pid: jyupj3fw comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: a4c13822298c9cc4 icon_path: dev_num: 51 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : jyupj3fw associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebd1ebe54febaa9c022vqf name: Soquete Inteligente pid: w906qkrrhd3otiwd comm: ebd1ebe54febaa9c022vqf pv: 2.2 sub: 0 node: icon_path: dev_num: 52 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : w906qkrrhd3otiwd associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eba3fc32248cc469a3y5qe name: P6EL pid: 1svzszztogaibjxa comm: eba3fc32248cc469a3y5qe pv: 2.2 sub: 0 node: icon_path: dev_num: 53 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 1svzszztogaibjxa associate 2 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb0469f56ed95d7791ogla name: Smart Knob pid: 4fjiwweb comm: ebe5c0ea9264da5aedqyqx pv: 2.2 sub: 1 node: dc8e95fffeaa86e1 icon_path: dev_num: 54 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 4fjiwweb associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 1, dp_name : 开关 1 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 2, dp_name : 开关 2 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 3, dp_name : 开关 3 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 4, dp_name : 开关 4 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 5, dp_name : 开关 5 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 6, dp_name : 开关 6 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:267] init dev dp name info, dp_id : 16, dp_name : 背光开关 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: ebae3eac4f123fe22bbx5k name: Six Gang Switch pid: jyupj3fw comm: eb827d57cf10b04d2fxtij pv: 2.2 sub: 1 node: a4c138e103ae9725 icon_path: dev_num: 55 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : jyupj3fw associate 2 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eba19ee51b778585c0jcy3 name: Smart Wireless Switch K10W pid: 9cwtq6di0cz7bikc comm: eba19ee51b778585c0jcy3 pv: 2.2 sub: 0 node: icon_path: dev_num: 56 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : 9cwtq6di0cz7bikc associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb827d57cf10b04d2fxtij name: Mini 多模网关 pid: pj3gdjgpeqao7xk4 comm: eb827d57cf10b04d2fxtij pv: 2.2 sub: 0 node: 0908 icon_path: dev_num: 57 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : pj3gdjgpeqao7xk4 associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb079c4f40c6c21e6ffpd0 name: 空调 pid: qzktzhehinzsz2je comm: eb44125a98339e4a81t9za pv: 2.2 sub: 1 node: 11d64749afef4019 icon_path: dev_num: 58 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : qzktzhehinzsz2je associate 1 sub dev [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:277] add devId: eb44125a98339e4a81t9za name: 智能红外遥控器 pid: yrmpfrig5ndywijq comm: eb44125a98339e4a81t9za pv: 2.2 sub: 0 node: icon_path: dev_num: 59 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:2207] cur pid : yrmpfrig5ndywijq associate 1 sub dev [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:61,udb->rcd_valid_cnt:60 [01-01 18:12:15 TUYA E][rcd_file.c:2887] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA E][tuya_ctrl_storage.c:249] call tuya_rcd_entry_read_next(first, TY_CTRL_DEV_FILE_NAME, &p_data, &data_len) return -10100 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1827] add room id: 76643014 name: Living Room dev_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1827] add room id: 76643015 name: Master Bedroom dev_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1827] add room id: 76643016 name: Second Bedroom dev_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1827] add room id: 76643017 name: Dining Room dev_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1827] add room id: 76643018 name: Kitchen dev_num: 0 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:1827] add room id: 76643019 name: Study Room dev_num: 0 [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:7,udb->rcd_valid_cnt:6 [01-01 18:12:15 TUYA E][rcd_file.c:2887] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA E][tuya_ctrl_storage.c:295] call tuya_rcd_entry_read_next(first, TY_CTRL_ROOM_FILE_NAME, &p_data, &data_len) return -10100 [01-01 18:12:15 TUYA D][tuya_ctrl_storage.c:387] get sensor rule: { "deviceType": 1, "categoryList": ["sos", "sj", "mcs", "rqbj", "pir", "wsdcg"] } [01-01 18:12:15 TUYA E][rcd_file.c:1598] [ty_rcd] not FOUND entry.num_tmp:2,udb->rcd_valid_cnt:1 [01-01 18:12:15 TUYA E][rcd_file.c:2887] [ty_rcd] not FOUND record. [01-01 18:12:15 TUYA E][tuya_ctrl_storage.c:377] call tuya_rcd_entry_read_next(first, TY_CTRL_SENSOR_RULE_NAME, &p_data, &data_len) return -10100 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:59] init dev rule success [01-01 18:12:15 TUYA D][thread_pool.c:393] thread type:2 idx:1 md:4 name:tuya_ctrl_resend [01-01 18:12:15 TUYA D][thread_pool.c:431] get thread 2 tuya_ctrl_resend ret:0x7fa1193818 [01-01 18:12:15 TUYA D][tuya_ctrl_center.c:184] ctrl center init success [01-01 18:12:15 TUYA D][tuya_ctrl_center_api.c:797] dev_ability user set shortcut:0, media:0 [01-01 18:12:15 TUYA D][tuya_ctrl_center_api.c:836] dev_ability set success shortcut:2, media:1, dp_type: standard, category is kg,cz,dj,cl,kt,lyj,wk,pir,mcs,sj,wsdcg,rqbj,sos,dgnbj,xfj,pc,xxj,jsq,rs,tgkg,kj [01-01 18:12:15 TUYA D][tuya_iot_scene_init.c:20] tuya scence init [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:401 cnt:6 [01-01 18:12:15 TUYA D][svc_img.c:976] id name path is:/userdata/tuya_db_files/scene_img/ [01-01 18:12:15 TUYA D][svc_img.c:991] id name list path is:/userdata/tuya_db_files/scene_img/ [01-01 18:12:15 TUYA D][tuya_iot_scene_data.c:63] tuya_scene_rcd_data_init [01-01 18:12:15 TUYA D][rcd_file.c:2460] [ty_rcd] both file exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:2505] [ty_rcd] read from normal file success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:6 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2450] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA E][rcd_file.c:707] [ty_rcd] fread error 3072 3392 [01-01 18:12:15 TUYA E][rcd_file.c:744] [ty_rcd] check metadata failed. [01-01 18:12:15 TUYA E][rcd_file.c:2497] [ty_rcd] __read_data_and_check error:-10109 [01-01 18:12:15 TUYA N][rcd_file.c:2477] [ty_rcd] restore from bak file [01-01 18:12:15 TUYA E][rcd_file.c:1080] [ty_rcd] open back file fails /userdata/tuya_db_files/rcdDb/scene_data.rdb_bak [01-01 18:12:15 TUYA N][rcd_file.c:2480] [ty_rcd] __rcd_db_restore error:-1001 [01-01 18:12:15 TUYA D][rcd_file.c:2512] [ty_rcd] init NEW normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][tuya_iot_scene_sto.c:207] read all scene num:6 [01-01 18:12:15 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails Zd4uIIpB5OhLmN9a -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:98] scene name:Morning Mode, item num:1. [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [01-01 18:12:15 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails I6X5n3ssZ42CJ4JK -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:98] scene name:Holiday Mode, item num:1. [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [01-01 18:12:15 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails MNfDt2BAjdoAQWcW -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:98] scene name:Dinner Mode, item num:1. [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [01-01 18:12:15 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails bkmaaDxZcQ99DpLA -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:98] scene name:Night Mode, item num:1. [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [01-01 18:12:15 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails HRBsEBxG8o08HSwy -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:98] scene name:Back Home Mode, item num:3. [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [01-01 18:12:15 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails XTkz3wDAMpWflBn9 -6 [01-01 18:12:15 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:98] scene name:Left Home Mode, item num:1. [01-01 18:12:15 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [01-01 18:12:15 TUYA D][tuya_iot_scene_sto.c:142] read all scene data num:0 [01-01 18:12:15 TUYA D][tuya_iot_scene_init.c:27] tuya scence init success [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: all_info_sync [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: dev_shortcut_report [01-01 18:12:15 TUYA D][tuya_gw_z3_user.c:161] z3 user dev num: 2 [01-01 18:12:15 TUYA D][tuya_gw_z3_user.c:180] index[1], manufacture name: TUYATEC-nPGIPl5D, model id: TS0001 [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: dev_online_update [01-01 18:12:15 TUYA D][tuya_base_event.c:28] subscribe: dev_dp_name_update [01-01 18:12:15 TUYA D][tuya_gw_z3_user.c:180] index[2], manufacture name: TUYATEC-1xAC7DHQ, model id: TZ3000 [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1743] Last reset reason: 255 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:192 [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0 [01-01 18:12:15 TUYA D][tuya_tls.c:372] tls register constant 6ce871309d48c48f XFT83ZB1amWW83hDEg19M7lKxuf1YmG8 UvhspcVqKpqBDpnJXVn9xlBvxJzs93rlE4DTV [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:8 tls_ca_cnt [01-01 18:12:15 TUYA D][simplekv.c:1280] key:tls_ca_cnt find value.Len:16 [01-01 18:12:15 TUYA D][tuya_tls.c:319] tls_ca_cnt:2 and parse:2 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:7 tls_ca0 [01-01 18:12:15 TUYA D][simplekv.c:1280] key:tls_ca0 find value.Len:2688 [01-01 18:12:15 TUYA D][tuya_tls.c:349] Parse DER tls_ca0:2002 success [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca1 isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:6 tls_ca1 [01-01 18:12:15 TUYA D][simplekv.c:1280] key:tls_ca1 find value.Len:1376 [01-01 18:12:15 TUYA D][tuya_tls.c:349] Parse DER tls_ca1:1028 success [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1116] serial_no:null [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:80 [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1147] gw_cntl.gw_wsm.stat:2 [01-01 18:12:15 TUYA D][uni_network.c:403] set_dns_cache_priority:0 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:2 gw_di [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_di find value.Len:352 [01-01 18:12:15 TUYA D][ws_db_gw.c:507] gw_di read success [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1207] gw_cntl.gw_if.abi:1 input:1 [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1208] gw_cntl.gw_if.product_key:1svzszztogaibjxa, input:1svzszztogaibjxa [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1209] gw_cntl.gw_if.tp:0, input:0 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:11 gw_ai [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:592 [01-01 18:12:15 TUYA D][ws_db_gw.c:632] gw_ai read success [01-01 18:12:15 TUYA D][uni_network.c:417] set_dns_region:3 [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [http://a.tuyaus.com/d.json]<->[35.166.143.146] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [https://a2.tuyaus.com/d.json]<->[44.230.212.240] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [m2.tuyaus.com:1883]<->[54.212.163.173] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [m2.tuyaus.com:8883]<->[54.212.163.173] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [baal.tuyaus.com]<->[44.239.29.247] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1322] attach count changed [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:000004brzg isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:10 000004brzg [01-01 18:12:15 TUYA D][simplekv.c:1280] key:000004brzg find value.Len:720 [01-01 18:12:15 TUYA D][ws_db_gw.c:691] schema 000004brzg read success [01-01 18:12:15 TUYA D][tuya_devos_utils.c:872] create dev_cntl Success [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1765] enter success_proc [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600 [01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:66048,priority:5 [01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:health_monitor Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_alarm_flag isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:192 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_alarm_flag isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [01-01 18:12:15 TUYA D][home_security_inner_api.c:33] wd_common_read fails gw_alarm_flag -6 [01-01 18:12:15 TUYA D][subdev_mgr.c:37] gw_subdev_init [01-01 18:12:15 TUYA D][thread_pool.c:393] thread type:2 idx:0 md:5 name:subdev_mod [01-01 18:12:15 TUYA D][thread_pool.c:431] get thread 2 subdev_mod ret:0x7fa1193700 [01-01 18:12:15 TUYA D][subdev_core.c:106] subdev_core_init [01-01 18:12:15 TUYA I][subdev_hb_ol.c:198] subdev_hb_ol_init [01-01 18:12:15 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [01-01 18:12:15 TUYA E][gw_kv_db.c:115] rcd_entry_kv_read fails lp_off_dev -6 [01-01 18:12:15 TUYA D][subdev_hb_ol.c:1562] gw_kv_db_read lp_off_dev, maybe not exist [01-01 18:12:15 TUYA D][subdev_upgrade.c:171] subdev_upgrade_init [01-01 18:12:15 TUYA D][subdev_bind.c:1442] Begin Load Devices [01-01 18:12:15 TUYA D][rcd_file.c:2450] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA E][rcd_file.c:707] [ty_rcd] fread error 3072 3392 [01-01 18:12:15 TUYA E][rcd_file.c:744] [ty_rcd] check metadata failed. [01-01 18:12:15 TUYA E][rcd_file.c:2497] [ty_rcd] __read_data_and_check error:-10109 [01-01 18:12:15 TUYA N][rcd_file.c:2477] [ty_rcd] restore from bak file [01-01 18:12:15 TUYA E][rcd_file.c:1080] [ty_rcd] open back file fails /userdata/tuya_db_files/rcdDb/sub_dev_ddi_s.rdb_bak [01-01 18:12:15 TUYA N][rcd_file.c:2480] [ty_rcd] __rcd_db_restore error:-1001 [01-01 18:12:15 TUYA D][rcd_file.c:2512] [ty_rcd] init NEW normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2450] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA E][rcd_file.c:707] [ty_rcd] fread error 3072 3392 [01-01 18:12:15 TUYA E][rcd_file.c:744] [ty_rcd] check metadata failed. [01-01 18:12:15 TUYA E][rcd_file.c:2497] [ty_rcd] __read_data_and_check error:-10109 [01-01 18:12:15 TUYA N][rcd_file.c:2477] [ty_rcd] restore from bak file [01-01 18:12:15 TUYA E][rcd_file.c:1080] [ty_rcd] open back file fails /userdata/tuya_db_files/rcdDb/sub_dev_schm.rdb_bak [01-01 18:12:15 TUYA N][rcd_file.c:2480] [ty_rcd] __rcd_db_restore error:-1001 [01-01 18:12:15 TUYA D][rcd_file.c:2512] [ty_rcd] init NEW normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][rcd_file.c:2450] [ty_rcd] normal file exist. bak file not exist [01-01 18:12:15 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA E][rcd_file.c:707] [ty_rcd] fread error 3072 3392 [01-01 18:12:15 TUYA E][rcd_file.c:744] [ty_rcd] check metadata failed. [01-01 18:12:15 TUYA E][rcd_file.c:2497] [ty_rcd] __read_data_and_check error:-10109 [01-01 18:12:15 TUYA N][rcd_file.c:2477] [ty_rcd] restore from bak file [01-01 18:12:15 TUYA E][rcd_file.c:1080] [ty_rcd] open back file fails /userdata/tuya_db_files/rcdDb/s_dev_schm_ver.rdb_bak [01-01 18:12:15 TUYA N][rcd_file.c:2480] [ty_rcd] __rcd_db_restore error:-1001 [01-01 18:12:15 TUYA D][rcd_file.c:2512] [ty_rcd] init NEW normal file [01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0 [01-01 18:12:15 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:ddi- isFuzzy:1 skipCnt:1 [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15 TUYA D][subdev_sto_rcd.c:147] ddi fuzzy read -6. maybe not exist [01-01 18:12:15 TUYA D][subdev_sto_rcd.c:224] old plain db not exist [01-01 18:12:15 TUYA D][subdev_sto_rcd.c:592] num is 0 [01-01 18:12:15 TUYA D][subdev_bind.c:1446] Load Devices Finish [01-01 18:12:15 TUYA D][gw_engr_init.c:554] gw_engineer_init_pre [01-01 18:12:15 TUYA D][util_engr.c:290] config_path:/userdata/tuya_db_files,fs_storge_path:/userdata/tuya_db_files [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:7 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:8 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:9 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:10 [01-01 18:12:15 TUYA D][tuya_iot_base_api.c:270] register wired network monitor. interval:1 [01-01 18:12:15:314 TUYA D][tuya_iot_sdk_user_api.c:203] ncp(3) get version, register ok [01-01 18:12:15:314 TUYA N][sdk_adpt_internal_api.c:141] register attach upgrade, tp: 3 [01-01 18:12:15:314 TUYA D][app_agent.c:336] TUYA Mode [01-01 18:12:15:314 TUYA D][tuya_zigbee_api.c:122] serial port: /dev/ttyS0, cts: 1 [01-01 18:12:15:314 TUYA I][uni_thread.c:220] thread_create name:ty_zigbee_task,stackDepth:16384,totalstackDepth:82432,priority:5 [01-01 18:12:15:314 TUYA I][uni_thread.c:220] thread_create name:lpc_task,stackDepth:2048,totalstackDepth:84480,priority:3 [01-01 18:12:15:314 TUYA D][uni_thread.c:247] Thread:ty_zigbee_task Exec Start. Set to Running Stat [01-01 18:12:15:314 TUYA D][tuya_devos_netlink.c:343] gw_wsm stat:2 [01-01 18:12:15:314 TUYA I][tuya_iot_sdk_user_api.c:91] gw status changed to 3 [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:72] ===== zigbee host path print ===== [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:73] bin_dir: /userdata/ [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:74] storage_dir: /userdata/ [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:75] tmp_dir: /tmp/ [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:77] ===== zigbee host storage file path print ===== [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:78] zigbee_dev_flag_ini_file: /userdata/devflag.ini [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:79] zigbee_devices_txt_file: /userdata/devices.txt [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:80] zigbee_devices1_txt_file: /userdata/devices1.txt [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:81] zigbee_iaszone_txt_file: /userdata/iaszone.txt [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:82] NcpUpgrade_backup_ota_file: /userdata/NcpUpgrade_backup.ota [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:83] NcpUpgrade_backup65_ota_file: /userdata/NcpUpgrade_backup65.ota [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:84] coo_upgrating_file: /userdata/coo_upgrating [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:85] coo_upgdate65_file: /userdata/coo_upgdate65 [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:87] ===== zigbee host tmp file path print ===== [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:88] zigbee_ota_dir: /tmp/ota-files [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:89] zigbee_ncp_ug_file: /tmp/ota-files/NcpUpgrade.ota [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:90] zigbee_dev_ug_file: /tmp/ota-files/ZigbeeDevUpgrade.ota [01-01 18:12:15:315 TUYA D][tuya_z3_host_storage.c:91] zigbee_ncp_ver_file: /tmp//ncp_ver65_1_0_10_flag 2022-10-19 15:23:07:441:user_init.c:__gw_active_stat_cb:146:p6el:SOC TUYA-Cloud Status:3 Success: _Z3MsgSendToInit. 2022-10-19 15:23:07:441:login.c:login_success:88: login_success:88 Success: _MsgRecvformInit. =====devFileInit===== [01-01 18:12:15:315 TUYA D][uni_thread.c:247] Thread:lpc_task Exec Start. Set to Running Stat [01-01 18:12:15:316 TUYA D][app_agent.c:866] Setup TCP Server On Port:6668 [01-01 18:12:15:316 TUYA D][uni_thread.c:247] Thread:delay_queue Exec Start. Set to Running Stat [01-01 18:12:15:316 TUYA I][uni_thread.c:220] thread_create name:lan_nsvr,stackDepth:4096,totalstackDepth:96768,priority:4 [01-01 18:12:15:316 TUYA D][uni_thread.c:247] Thread:lan_nsvr Exec Start. Set to Running Stat [01-01 18:12:15:316 TUYA I][uni_thread.c:220] thread_create name:delay_queue,stackDepth:8192,totalstackDepth:92672,priority:3 [01-01 18:12:15:316 TUYA D][lan_dev_base.c:448] __try_load_lan_cluster_seqno [01-01 18:12:15:316 TUYA D][simplekv.c:1211] read key:lan_cls_seq isFuzzy:0 skipCnt:0 [01-01 18:12:15:316 TUYA D][simplekv.c:1251] find key:3 lan_cls_seq [01-01 18:12:15:316 TUYA D][simplekv.c:1280] key:lan_cls_seq find value.Len:32 fileFlag is 0 [01-01 18:12:15:316 TUYA D][simplekv.c:1211] read key:lan_cls_seq isFuzzy:0 skipCnt:0 [01-01 18:12:15:317 TUYA D][simplekv.c:1251] find key:3 lan_cls_seq [01-01 18:12:15:317 TUYA D][tuya_z3_api_tmp.c:7697] argc1 = 3 [01-01 18:12:15:317 TUYA D][simplekv.c:1280] key:lan_cls_seq find value.Len:32 [01-01 18:12:15:317 TUYA D][tuya_z3_api_tmp.c:7699] argv[0] = ./build/exe/Z3GatewayHost [01-01 18:12:15:317 TUYA D][tuya_z3_api_tmp.c:7700] argv[1] = -p [01-01 18:12:15:317 TUYA D][tuya_z3_api_tmp.c:7701] argv[2] = /dev/ttyS0 [01-01 18:12:15:317 TUYA D][simplekv.c:374] write key:lan_cls_seq And Value Len:32 [01-01 18:12:15:317 TUYA D][simplekv.c:397] 3 key same AND size old 436 >= new 32 [01-01 18:12:15:317 TUYA D][simplekv.c:430] find 3 available space [01-01 18:12:15:317 TUYA I][uni_thread.c:220] thread_create name:slow_queue,stackDepth:8192,totalstackDepth:104960,priority:2 [01-01 18:12:15:317 TUYA D][af-main-host.c:936] Reset info: 11 (SOFTWARE) [01-01 18:12:15:317 TUYA D][tuya_z3.c:28633] SUCCESS:tuya_z3_sce_init. [01-01 18:12:15:317 TUYA E][tuya_iot_ext_api.c:164] /userdata/engineer_dev_flag.ini is not exist [01-01 18:12:15:317 TUYA D][uni_thread.c:247] Thread:slow_queue Exec Start. Set to Running Stat [01-01 18:12:15:317 TUYA D][simplekv.c:474] reuse available space 29448 === ASH started === ty_uart_init begin uartMutexInit suceess[01-01 18:12:15:317 TUYA D][simplekv.c:203] update crc 2892983674 ty_uart_recv start ty_uart_recv end ty_uart_init end ,status:0. [01-01 18:12:15:319 TUYA D][lan_net_svr.c:131] begint to execute __lan_task_cb [01-01 18:12:15:333 TUYA D][simplekv.c:359] write head to normal file success [01-01 18:12:15:334 TUYA D][simplekv.c:520] write success [01-01 18:12:15:334 TUYA D][thread_pool.c:393] thread type:2 idx:1 md:6 name:lan_cls_m [01-01 18:12:15:334 TUYA D][thread_pool.c:431] get thread 2 lan_cls_m ret:0x7f8fffe7f8 [01-01 18:12:15:334 TUYA D][simplekv.c:1211] read key:lgw_nkey isFuzzy:0 skipCnt:0 [01-01 18:12:15:334 TUYA D][simplekv.c:1251] find key:5 lgw_nkey [01-01 18:12:15:334 TUYA D][simplekv.c:1280] key:lgw_nkey find value.Len:144 [01-01 18:12:15:334 TUYA D][base_rpc_com.c:339] rpc handler create success [01-01 18:12:15:334 TUYA D][simplekv.c:1211] read key:uz3-devices isFuzzy:0 skipCnt:0 [01-01 18:12:15:334 TUYA D][simplekv.c:1251] find key:4 uz3-devices [01-01 18:12:15:334 TUYA D][simplekv.c:1280] key:uz3-devices find value.Len:16 [01-01 18:12:15:334 TUYA D][tuya_z3.c:28644] SUCCESS:tuya_z3_NetDataInit. [01-01 18:12:15:334 TUYA D][thread_pool.c:393] thread type:2 idx:0 md:7 name:tuya_packet_trans [01-01 18:12:15:335 TUYA D][thread_pool.c:431] get thread 2 tuya_packet_trans ret:0x7fa1193728 [01-01 18:12:15:335 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0 [01-01 18:12:15:335 TUYA D][simplekv.c:1251] find key:11 gw_ai [01-01 18:12:15:335 TUYA D][tuya_z3_packet.c:314] tuya svc packet init success! [01-01 18:12:15:335 TUYA D][tuya_z3.c:28655] SUCCESS:tuya_z3_packet_init. [01-01 18:12:15:335 TUYA D][tuya_gw_z3_user.c:118] z3 user dev loading... [01-01 18:12:15:335 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:592 [01-01 18:12:15:335 TUYA D][simplekv.c:1211] read key:uz3-devices isFuzzy:0 skipCnt:0 [01-01 18:12:15:335 TUYA D][simplekv.c:1251] find key:4 uz3-devices [01-01 18:12:15:335 TUYA D][simplekv.c:1280] key:uz3-devices find value.Len:16 [01-01 18:12:15:335 TUYA D][tuya_gw_z3_user.c:129] z3_dev_db: [] [01-01 18:12:15:335 TUYA D][tuya_z3.c:28678] tuya_z3_init status: 0, isUg=0 [01-01 18:12:15:335 TUYA D][lan_rpc.c:267] read localkey success [01-01 18:12:15:336 TUYA I][uni_thread.c:220] thread_create name:lan_rpc,stackDepth:4096,totalstackDepth:109056,priority:4 [01-01 18:12:15:336 TUYA I][uni_thread.c:220] thread_create name:ty_z3_msg,stackDepth:8192,totalstackDepth:117248,priority:5 [01-01 18:12:15:336 TUYA D][lan_cluster_master_core.c:1321] cluster change status from 0 to 0 [01-01 18:12:15:336 TUYA N][lan_cluster_master_core.c:1333] cluster change status cb new out st 0 master [] ip[0] [01-01 18:12:15:336 TUYA D][lan_cluster_master_core.c:1380] __init_cls_node_list inited[0] [01-01 18:12:15:336 TUYA N][lan_rpc.c:233] lan rpc node is empty [01-01 18:12:15:336 TUYA I][uni_thread.c:220] thread_create name:lan_msg_send,stackDepth:4096,totalstackDepth:121344,priority:4 [01-01 18:12:15:336 TUYA D][uni_thread.c:247] Thread:lan_msg_send Exec Start. Set to Running Stat [01-01 18:12:15:336 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0 [01-01 18:12:15:336 TUYA D][simplekv.c:1251] find key:11 gw_ai [01-01 18:12:15:336 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:592 [01-01 18:12:15:336 TUYA D][uni_thread.c:247] Thread:lan_rpc Exec Start. Set to Running Stat [01-01 18:12:15:336 TUYA D][uni_thread.c:247] Thread:ty_z3_msg Exec Start. Set to Running Stat [01-01 18:12:15:337 TUYA D][lan_dev_base.c:436] read localkey success [01-01 18:12:15:337 TUYA D][lan_rpc.c:274] lan_rpc_session_key_set key: 64 63 31 66 [01-01 18:12:15:337 TUYA E][lan_msg_reliable_trans_master.c:744] param is NULL [01-01 18:12:15:337 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_SUBSCRIBE [01-01 18:12:15:337 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_PUBLISH [01-01 18:12:15:337 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_PUSH [01-01 18:12:15:337 TUYA D][lan_pub_sub_mq.c:508] lan_pub_sub_mq_init OK [01-01 18:12:15:337 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_SYNC_DP_RPT_REQ [01-01 18:12:15:337 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_SYNC_DP_RPT [01-01 18:12:15:337 TUYA D][thread_pool.c:393] thread type:2 idx:1 md:8 name:lan_dp_rpt_ch [01-01 18:12:15:337 TUYA D][thread_pool.c:431] get thread 2 lan_dp_rpt_ch ret:0x7f8fffe7e8 [01-01 18:12:15:337 TUYA D][thread_pool.c:393] thread type:2 idx:0 md:9 name:lan_node_rpt [01-01 18:12:15:337 TUYA D][thread_pool.c:431] get thread 2 lan_node_rpt ret:0x7f8fffe878 [01-01 18:12:15:337 TUYA D][thread_pool.c:393] thread type:2 idx:1 md:10 name:lan_ka_m [01-01 18:12:15:337 TUYA D][thread_pool.c:431] get thread 2 lan_ka_m ret:0x7f8fffe878 [01-01 18:12:15:337 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_PUSH [01-01 18:12:15:337 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_SUBSCRIBE [01-01 18:12:15:337 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_PUBLISH [01-01 18:12:15:337 TUYA D][lan_pub_sub_mq_center.c:514] lan_pub_sub_mq_center_init OK [01-01 18:12:15:337 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_SYNC_DP_RPT_REQ [01-01 18:12:15:337 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_SYNC_DP_RPT [01-01 18:12:15:337 TUYA D][thread_pool.c:393] thread type:2 idx:0 md:11 name:lan_dp_rpt_sy [01-01 18:12:15:337 TUYA D][thread_pool.c:431] get thread 2 lan_dp_rpt_sy ret:0x7f8fffe840 [01-01 18:12:15:338 TUYA D][scene_linkage_storage.c:380] scene_linkage_storage_init [01-01 18:12:15:338 TUYA D][rcd_file.c:2460] [ty_rcd] both file exist [01-01 18:12:15:338 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15:338 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15:338 TUYA D][rcd_file.c:2505] [ty_rcd] read from normal file success [01-01 18:12:15:338 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:2 [01-01 18:12:15:338 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15:338 TUYA D][scene_linkage_storage.c:251] get meta From db 0 0 0. [01-01 18:12:15:338 TUYA D][rcd_file.c:2460] [ty_rcd] both file exist [01-01 18:12:15:338 TUYA D][rcd_file.c:2490] [ty_rcd] read from normal file [01-01 18:12:15:338 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success [01-01 18:12:15:338 TUYA D][rcd_file.c:2505] [ty_rcd] read from normal file success [01-01 18:12:15:339 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:2 [01-01 18:12:15:339 TUYA D][rcd_file.c:2608] [ty_rcd] init from normal file success. [01-01 18:12:15:339 TUYA D][scene_linkage_storage.c:251] get meta From db 0 0 0. [01-01 18:12:15:339 TUYA D][simplekv.c:1211] read key:scene_unit isFuzzy:0 skipCnt:0 [01-01 18:12:15:339 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15:339 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15:339 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [01-01 18:12:15:339 TUYA D][simplekv.c:1211] read key:scn_lnk_ttl_cnt isFuzzy:0 skipCnt:0 [01-01 18:12:15:339 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15:339 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15:339 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [01-01 18:12:15:339 TUYA D][simplekv.c:1211] read key:lanlnk_ttl_cnt isFuzzy:0 skipCnt:0 [01-01 18:12:15:339 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15:339 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15:339 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [01-01 18:12:15:339 TUYA D][scene_linkage_rule_exe.c:362] set vid eb1552c6f83a6b59edmyes [01-01 18:12:15:339 TUYA D][thread_pool.c:393] thread type:2 idx:1 md:12 name:lkg_rule_exe [01-01 18:12:15:339 TUYA D][thread_pool.c:431] get thread 2 lkg_rule_exe ret:0x7f8fffe850 [01-01 18:12:15:339 TUYA D][thread_pool.c:393] thread type:2 idx:0 md:13 name:lkg_rule_up [01-01 18:12:15:339 TUYA D][thread_pool.c:431] get thread 2 lkg_rule_up ret:0x7f8fffe848 [01-01 18:12:15:339 TUYA D][scene_linkage_rule_sync.c:280] scene_linkage_rule_sync_init [01-01 18:12:15:339 TUYA D][scene_linkage_scene_name.c:345] remove all name [01-01 18:12:15:339 TUYA D][scene_linkage_scene_name.c:350] name list is empty [01-01 18:12:15:339 TUYA D][scene_linkage_rule_exe.c:893] scene_linkage_rule_delete_all, rule_type[0] [01-01 18:12:15:339 TUYA D][scene_linkage_rule_sync.c:464] read __get_real_count_from_nvram rule_type:0 real_cnt:0 [01-01 18:12:15:339 TUYA D][scene_linkage_rule_sync.c:467] No rules. [01-01 18:12:15:339 TUYA D][scene_linkage_rule_exe.c:893] scene_linkage_rule_delete_all, rule_type[1] [01-01 18:12:15:340 TUYA D][scene_linkage_rule_sync.c:464] read __get_real_count_from_nvram rule_type:1 real_cnt:0 [01-01 18:12:15:340 TUYA D][scene_linkage_rule_sync.c:467] No rules. [01-01 18:12:15:340 TUYA D][scene_linkage_rule_sync.c:1268] scene_linkage_update_from_server linkage_type:0 delaymS:18000 [01-01 18:12:15:340 TUYA D][mqc_app.c:144] mq_pro:49 cnt:11 [01-01 18:12:15:340 TUYA D][mqc_app.c:144] mq_pro:403 cnt:12 [01-01 18:12:15:340 TUYA D][thread_pool.c:393] thread type:2 idx:1 md:14 name:sce_lnk_log_upload [01-01 18:12:15:340 TUYA D][thread_pool.c:431] get thread 2 sce_lnk_log_upload ret:0x7f8fffe860 [01-01 18:12:15:340 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_DP_REPORT [01-01 18:12:15:340 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_DP_REPORT [01-01 18:12:15:340 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_LINKAGE [01-01 18:12:15:340 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_LINKAGE [01-01 18:12:15:340 TUYA I][mqc_app.c:387] mqc app start ... [01-01 18:12:15:340 TUYA D][mqc_app.c:459] MQTT Protocol URL:m2.tuyaus.com:8883 Port:8883 [01-01 18:12:15:340 TUYA D][mqc_app.c:473] TLS disable [01-01 18:12:15:340 TUYA D][mqc_app.c:308] TLS Mode:4 [01-01 18:12:15:340 TUYA D][scene_linkage_rule_exe.c:836] __rule_delete_all, rule_type[0] [01-01 18:12:15:340 TUYA D][scene_linkage_rule_exe.c:839] no record now [01-01 18:12:15:340 TUYA I][scene_linkage_scene_name.c:499] scene_linkage_name_id_update_notify [01-01 18:12:15:340 TUYA D][scene_linkage_rule_exe.c:836] __rule_delete_all, rule_type[1] [01-01 18:12:15:340 TUYA D][scene_linkage_rule_exe.c:839] no record now [01-01 18:12:15:340 TUYA I][scene_linkage_scene_name.c:499] scene_linkage_name_id_update_notify [01-01 18:12:15:340 TUYA D][mqtt_client.c:291] subcribe_topic:smart/device/in/eb1552c6f83a6b59edmyes, client_id:eb1552c6f83a6b59edmyes, user_name:eb1552c6f83a6b59edmyes, passwd:ec68e9a4dc001cfc [01-01 18:12:15:340 TUYA D][mqtt_client.c:322] domain<0> m2.tuyaus.com:8883 HAVE PORT [01-01 18:12:15:341 TUYA D][mqtt_client.c:325] PARSE m2.tuyaus.com:8883 [01-01 18:12:15:341 TUYA D][mqtt_client.c:353] wakeup_domain_tbl<0> m2.tuyaus.com:1883 HAVE PORT [01-01 18:12:15:341 TUYA D][mqtt_client.c:356] PARSE m2.tuyaus.com:1883 [01-01 18:12:15:341 TUYA D][mqc_app.c:520] mqtt send topic:smart/device/out/eb1552c6f83a6b59edmyes [01-01 18:12:15:341 TUYA D][mqc_app.c:522] mqtt-media send topic:d/m/o/eb1552c6f83a6b59edmyes [01-01 18:12:15:341 TUYA I][uni_thread.c:220] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:125440,priority:4 [01-01 18:12:15:341 TUYA D][mqc_app.c:144] mq_pro:64 cnt:13 [01-01 18:12:15:341 TUYA D][mqc_app.c:144] mq_pro:22 cnt:14 [01-01 18:12:15:341 TUYA D][mqc_app.c:144] mq_pro:55 cnt:15 [01-01 18:12:15:341 TUYA D][uni_thread.c:247] Thread:mq_cntl_task Exec Start. Set to Running Stat [01-01 18:12:15:341 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0 [01-01 18:12:15:341 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15:342 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15:342 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [01-01 18:12:15:342 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyaus.com, prio 0 [01-01 18:12:15:342 TUYA D][uni_network.c:181] use dynamic dns ip 54.212.163.173 for domain m2.tuyaus.com [01-01 18:12:15:342 TUYA D][mqtt_client.c:1400] select mqtt host:m2.tuyaus.com [01-01 18:12:15:342 TUYA N][mqtt_client.c:1421] mqtt get serve ip success [01-01 18:12:15:342 TUYA D][tuya_svc_timer_task.c:146] no timer [01-01 18:12:15:342 TUYA D][mqc_app.c:144] mq_pro:13 cnt:16 [01-01 18:12:15:342 TUYA D][mqc_app.c:144] mq_pro:15 cnt:17 [01-01 18:12:15:342 TUYA D][mqtt_client.c:931] serverIP 919905197 port:8883 [01-01 18:12:15:342 TUYA E][mqtt_client.c:1436] mqtt connect fail. retry_cnt:0 ret:-2310 errno:-18 [01-01 18:12:15:343 TUYA D][tuya_svc_upgrade.c:819] upgrade active success [01-01 18:12:15:343 TUYA D][svc_online_log.c:217] mqtt log topic init log/realtime/eb1552c6f83a6b59edmyes [01-01 18:12:15:343 TUYA D][svc_online_log.c:219] mqtt log topic init log/runstat/eb1552c6f83a6b59edmyes [01-01 18:12:15:343 TUYA D][svc_online_log.c:317] svc online log active success [01-01 08:00:00:343 TUYA E][app_agent.c:487] refused [01-01 08:00:00:343 TUYA D][gw_mgr.c:548] set client num 32 [01-01 08:00:00:343 TUYA D][group_scene_serve.c:2723] start group scene serve [01-01 08:00:00:343 TUYA D][group_scene_serve.c:654] =====__group_scene_save_init===== [01-01 08:00:00:343 TUYA D][group_scene_serve.c:692] group scene flag file: /userdata/tuya_db_files/grp_sce_flag_file. [01-01 08:00:00:343 TUYA D][group_scene_serve.c:693] group scene file: /userdata/tuya_db_files/grp_sce_save_file. [01-01 08:00:00:344 TUYA D][group_scene_serve.c:694] group scene back file: /userdata/tuya_db_files/grp_sce_save_bak_file. [01-01 08:00:00:344 TUYA D][simplekv.c:1211] read key:grp_sce_list isFuzzy:0 skipCnt:0 [01-01 08:00:00:344 TUYA D][simplekv.c:1247] no key find [01-01 08:00:00:344 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 08:00:00:344 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [01-01 08:00:00:344 TUYA E][group_scene_serve.c:630] read grp_sce_list err. -6 [01-01 08:00:00:344 TUYA D][group_scene_serve.c:722] No old group scene flag file. [01-01 08:00:00:344 TUYA D][uni_thread.c:247] Thread:grp_sce Exec Start. Set to Running Stat [01-01 08:00:00:345 TUYA I][uni_thread.c:220] thread_create name:grp_sce,stackDepth:2048,totalstackDepth:127488,priority:3 [01-01 08:00:00:345 TUYA D][group_scene_serve.c:2749] end group scene serve [01-01 08:00:00:345 TUYA D][mqc_app.c:144] mq_pro:204 cnt:18 [01-01 08:00:00:345 TUYA D][mqc_app.c:144] mq_pro:206 cnt:19 [01-01 08:00:00:345 TUYA D][mqc_app.c:144] mq_pro:202 cnt:20 [01-01 08:00:00:345 TUYA D][scene_linkage.c:50] the scene linkage is inited [01-01 08:00:00:345 TUYA D][home_security.c:2408] Init home security start, Ver:1.0.1. [01-01 08:00:00:345 TUYA D][thread_pool.c:393] thread type:2 idx:0 md:15 name:home_sec [01-01 08:00:00:345 TUYA D][thread_pool.c:431] get thread 2 home_sec ret:0x7f8fffe7f0 [01-01 08:00:00:345 TUYA D][simplekv.c:1211] read key:home_secu isFuzzy:0 skipCnt:0 [01-01 08:00:00:346 TUYA D][simplekv.c:1247] no key find [01-01 08:00:00:346 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 08:00:00:346 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [01-01 08:00:00:346 TUYA E][tuya_ws_db.c:326] kvs_read fails home_secu -6 [01-01 08:00:00:346 TUYA W][ws_db_home_security.c:61] home_secu read null. [01-01 08:00:00:346 TUYA E][home_security.c:2453] wd_gw_home_security_if_read error,ret:-6. [01-01 08:00:00:346 TUYA D][home_security.c:2460] security_mode:0, enable_def_time:60. [01-01 08:00:00:346 TUYA D][simplekv.c:1211] read key:delay_time_list isFuzzy:0 skipCnt:0 [01-01 08:00:00:346 TUYA D][simplekv.c:1251] find key:13 delay_time_list [01-01 08:00:00:346 TUYA D][simplekv.c:1280] key:delay_time_list find value.Len:48 [01-01 08:00:00:346 TUYA D][home_security.c:2464] delay_json_str:{"1":{"enable":0},"2":{"enable":30}}. [01-01 08:00:00:346 TUYA E][home_security.c:1017] mode_delay_json is error.. [01-01 08:00:00:347 TUYA E][home_security.c:1039] Enable def time:60. [01-01 08:00:00:347 TUYA W][home_security.c:2481] gw_home_security_if_cb is null. [01-01 08:00:00:347 TUYA D][simplekv.c:1211] read key:ignore_list isFuzzy:0 skipCnt:0 [01-01 08:00:00:347 TUYA D][simplekv.c:1247] no key find [01-01 08:00:00:347 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 08:00:00:347 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [01-01 08:00:00:347 TUYA E][home_security.c:862] read ignore_list err. -6 [01-01 08:00:00:347 TUYA D][lan_pub_sub_mq.c:636] add_sub_service [LAN_SECURITY] [01-01 08:00:00:347 TUYA D][lan_pub_sub_mq.c:672] add_publish_service [LAN_SECURITY] [01-01 08:00:00:347 TUYA D][lan_pub_sub_mq_api.c:120] add topic:[LAN_SECURITY] [01-01 08:00:00:348 TUYA D][lan_security_pub_sub.c:232] lan_security_pub_sub_init OK [01-01 08:00:00:348 TUYA D][mqc_app.c:144] mq_pro:701 cnt:21 [01-01 08:00:00:348 TUYA D][home_security.c:2511] Init home security end. [01-01 08:00:00:348 TUYA D][subdev_mgr.c:87] gw_subdev_active [01-01 08:00:00:348 TUYA D][mqc_app.c:144] mq_pro:8 cnt:22 [01-01 08:00:00:348 TUYA D][mqc_app.c:144] mq_pro:102 cnt:23 [01-01 08:00:00:348 TUYA D][mqc_app.c:144] mq_pro:200 cnt:24 [01-01 08:00:00:348 TUYA D][mqc_app.c:144] mq_pro:33 cnt:25 [01-01 08:00:00:348 TUYA D][mqc_app.c:144] mq_pro:28 cnt:26 [01-01 08:00:00:348 TUYA D][subdev_upgrade.c:186] subdev_upgrade_active [01-01 08:00:00:349 TUYA I][uni_thread.c:220] thread_create name:lpc_con,stackDepth:4096,totalstackDepth:131584,priority:4 [01-01 08:00:00:349 TUYA D][thread_pool.c:393] thread type:2 idx:1 md:16 name:lan_pro_c [01-01 08:00:00:349 TUYA D][thread_pool.c:431] get thread 2 lan_pro_c ret:0x7f8fffe7b0 [01-01 08:00:00:349 TUYA D][uni_thread.c:247] Thread:lpc_con Exec Start. Set to Running Stat [01-01 08:00:00:349 TUYA D][thread_pool.c:393] thread type:2 idx:0 md:17 name:ty_lan_dev [01-01 08:00:00:349 TUYA D][thread_pool.c:431] get thread 2 ty_lan_dev ret:0x7f8fffe7e0 [01-01 08:00:00:349 TUYA D][simplekv.c:1211] read key:lan_nd_attr isFuzzy:0 skipCnt:0 [01-01 08:00:00:350 TUYA D][simplekv.c:1251] find key:14 lan_nd_attr [01-01 08:00:00:350 TUYA D][simplekv.c:1280] key:lan_nd_attr find value.Len:16 [01-01 08:00:00:350 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_DEV_LIST_QR [01-01 08:00:00:350 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_DEV_LIST_QR [01-01 08:00:00:350 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_DEV_LIST_QR_RSP [01-01 08:00:00:350 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_DEV_LIST_QR_RSP [01-01 08:00:00:350 TUYA D][lan_pub_sub_mq.c:636] add_sub_service [LAN_DEV_LIST_SYNC] [01-01 08:00:00:351 TUYA D][lan_pub_sub_mq.c:672] add_publish_service [LAN_DEV_LIST_SYNC] [01-01 08:00:00:351 TUYA D][lan_pub_sub_mq_api.c:120] add topic:[LAN_DEV_LIST_SYNC] [01-01 08:00:00:351 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_DP_QUERY [01-01 08:00:00:351 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_DP_QUERY [01-01 08:00:00:351 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_DP_QUERY_RSP [01-01 08:00:00:351 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_DP_QUERY_RSP [01-01 08:00:00:351 TUYA D][lan_pub_sub_mq.c:636] add_sub_service [LAN_DP_UP] [01-01 08:00:00:352 TUYA D][lan_pub_sub_mq.c:672] add_publish_service [LAN_DP_UP] [01-01 08:00:00:352 TUYA D][lan_pub_sub_mq_api.c:120] add topic:[LAN_DP_UP] [01-01 08:00:00:352 TUYA D][lan_simple_mq.c:378] lan_simple_mq_add_send_service: LAN_CNTL_SEND [01-01 08:00:00:352 TUYA D][lan_simple_mq.c:314] lan_simple_mq_add_recv_service: LAN_CNTL_SEND [01-01 08:00:00:352 TUYA E][gw_mgr.c:460] Macro GW_MAJOR_SDK_INFO or GW_MINOR_SDK_INFO is not defined [01-01 08:00:00:352 TUYA I][gw_mgr.c:530] Dont't Upload Sdk Version [01-01 08:00:00:352 TUYA D][tuya_lan_dp_up.c:165] watch dev:,eb44125a98339e4a81t9za,eba19ee51b778585c0jcy3,eb827d57cf10b04d2fxtij,eba3fc32248cc469a3y5qe,ebd1ebe54febaa9c022vqf,ebb3fad96f393b588eomxh,eb2372042e64f76e79f3jk,ebba64b6ac327cdeddq8z2,eb71d993c258066917jpks,eb21cdbd5e05e8e428gaca,vdevo166004655924109,eba528413f6980a463pn4p,eb631bd9b6590e001blfgs,ebc90e9813ffde4148tcvg,ebb4f72bc0eb72ac62dhlo,eb3cfb587e6d81417eac8e,vdevo166098193021398,ebe3006b0f14083917oh1d,eb68d8dbe4707224e8sxd8,eb0058bee16ce0c70aq9nj,eba407ffd4d23748c3rlsw,ebb063750d514d878079mw,eb4576f5222b16dccaaazi,eb62f037dd6640bfa41gut,vdevo166201192349972,eb9c17916f715a30e0a7mz,eb09bad8e75f6222acaglz,ebaf2b250cb41e058ekxqm,eb92b0479e015fbbaavltv,eb46ca57fbaaa5a173n9zv,ebd88c655bdd4b39adihqe,eb8607e2c51bffc942fczo,ebf8fee6f4298432a5eqvk,eb76889250a9917161wng9,eb87649dc6a4ae7fef87xr,eb3b1fefe57125bb72nrzb,ebc78c65e28bc1347ac761,ebb800d543876b9d83jiah,eb62263aaf2f73ef03xira,ebe7f7541d3a5e34dcplwr,eb67a0efcb59444d01ydgn,eb99a9cc76209358a4crkr, [01-01 08:00:00:353 TUYA D][lan_pub_sub_mq.c:765] topic sub_param_set [LAN_DP_UP] 2022-10-19 15:23:07:525:main.c:home_main_fresh:122:home_main_fresh 2022-10-19 15:23:07:525:login.c:get_login_status:16:get_login_status : 2 2022-10-19 15:23:07:525:setting_display.c:write_backlight:240:write_backlight num = 150 2022-10-19 15:23:07:527:scenes_control.c:read_scenes:286: read_scenes count=6 2022-10-19 15:23:07:527:scenes_control.c:read_scenes:298: for = scene[i].id = Zd4uIIpB5OhLmN9a 2022-10-19 15:23:07:527:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Morning Mode i= 0 id= Zd4uIIpB5OhLmN9a 2022-10-19 15:23:07:527:scenes_control.c:read_scenes:298: for = scene[i].id = I6X5n3ssZ42CJ4JK 2022-10-19 15:23:07:527:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Holiday Mode i= 1 id= I6X5n3ssZ42CJ4JK 2022-10-19 15:23:07:528:scenes_control.c:read_scenes:298: for = scene[i].id = MNfDt2BAjdoAQWcW 2022-10-19 15:23:07:528:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Dinner Mode i= 2 id= MNfDt2BAjdoAQWcW 2022-10-19 15:23:07:528:scenes_control.c:read_scenes:298: for = scene[i].id = bkmaaDxZcQ99DpLA 2022-10-19 15:23:07:528:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Night Mode i= 3 id= bkmaaDxZcQ99DpLA 2022-10-19 15:23:07:529:scenes_control.c:read_scenes:298: for = scene[i].id = HRBsEBxG8o08HSwy 2022-10-19 15:23:07:529:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Back Home Mode i= 4 id= HRBsEBxG8o08HSwy 2022-10-19 15:23:07:529:scenes_control.c:read_scenes:298: for = scene[i].id = XTkz3wDAMpWflBn9 2022-10-19 15:23:07:529:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Left Home Mode i= 5 id= XTkz3wDAMpWflBn9 2022-10-19 15:23:07:532:main_page_shortcut.c:Tab1_Btn_Var_Show:251:Tab1_Btn_Var_Show:251 2022-10-19 15:23:07:532:main_page_shortcut.c:Tab1_Btn_Var_Show:275:Tab1_Btn_Var_Show:275 2022-10-19 15:23:07:532:main_page_shortcut.c:Tab1_Btn_Var_Show:295:295 :0 0 2022-10-19 15:23:07:532:main_page_shortcut.c:Tab1_Btn_Var_Show:426:shortcut_device_scene[1].on =0, ret2=0 [01-01 08:00:00:408 TUYA D][tuya_ctrl_center_api.c:370] tuya_get_room_info_list success, cnt is 6 [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: eb257c7e0da82bf6fdgo2g name : Zigbee LAN Gateway should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf673a55509854f89o4ms name : Switch of scene should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: ebe5c0ea9264da5aedqyqx name : 4'' Smart panel-EU should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: ebe2744515d20294b1yhgw name : Zigbee Repeater should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: eb99a9cc76209358a4crkr name : Gateway should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: eb9e43a7db146d1286luio name : 空调 should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: eb87649dc6a4ae7fef87xr name : 智能红外遥控器 should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: ebd959f9cc5a9857b2zsoo name : 遥控器 should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf8fee6f4298432a5eqvk name : 智能网关 should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: eb8607e2c51bffc942fczo name : 红外射频遥控器 3 should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf911148e218a63b67uf3 name : Air should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: ebd88c655bdd4b39adihqe name : 智能红外遥控器 should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: eb46ca57fbaaa5a173n9zv name : 红外射频遥控器 2 should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: eb92b0479e015fbbaavltv name : 智能红外遥控器 should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: eb09bad8e75f6222acaglz name : Intelligent Switcher 2CH should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: eb71d993c258066917jpks name : IPC should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: ebba64b6ac327cdeddq8z2 name : Curtain Switch should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: ebb3fad96f393b588eomxh name : IR remote should not show on screen [01-01 08:00:00:409 TUYA W][tuya_ctrl_center_api.c:185] dev: eb1552c6f83a6b59edmyes name : P6EL 2 should not show on screen [01-01 08:00:00:410 TUYA W][tuya_ctrl_center_api.c:185] dev: eba3fc32248cc469a3y5qe name : P6EL should not show on screen [01-01 08:00:00:410 TUYA W][tuya_ctrl_center_api.c:185] dev: eb0469f56ed95d7791ogla name : Smart Knob should not show on screen [01-01 08:00:00:410 TUYA W][tuya_ctrl_center_api.c:185] dev: eb827d57cf10b04d2fxtij name : Mini 多模网关 should not show on screen [01-01 08:00:00:410 TUYA W][tuya_ctrl_center_api.c:185] dev: eb079c4f40c6c21e6ffpd0 name : 空调 should not show on screen [01-01 08:00:00:410 TUYA W][tuya_ctrl_center_api.c:185] dev: eb44125a98339e4a81t9za name : 智能红外遥控器 should not show on screen [01-01 08:00:00:410 TUYA D][tuya_ctrl_center_api.c:213] tuya_get_dev_brief_info_list success, dev cnt is 36 2022-10-19 15:23:07:535:dev_control.c:get_brief_devices:611:tuya_get_dev_brief_info_list dev_count 36 2022-10-19 15:23:07:535:core_dev_data.c:dev_filter:178:dev_filter:mcs 2022-10-19 15:23:07:535:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:07:535:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = ZigBee 3 Gang Switch, dev_list[i].category = kg 2022-10-19 15:23:07:536:dev_control_cont.c:show_all_devices:263:dev_list->name = ZigBee 3 Gang Switch ,online_stat = 0 [01-01 08:00:00:411 TUYA D][strategy_code_enum.c:67] get enum error: [01-01 08:00:00:411 TUYA E][strategy_code_enum.c:117] strategyValue is {"relay_status":"{\"0\":\"power_off\",\"1\":\"power_on\",\"2\":\"last\",\"memory\":\"last\",\"off\":\"power_off\",\"on\":\"power_on\"}"}, src_tp:3, dst_tp:3 [01-01 08:00:00:411 TUYA E][tuya_ctrl_center_api.c:83] strategy convert error: -8 [01-01 08:00:00:411 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d364c0 [01-01 08:00:00:411 TUYA D][tuya_base_event.c:28] subscribe: dp-eb0f65ca9465be8edcoyot 2022-10-19 15:23:07:537:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 7 2022-10-19 15:23:07:537:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 3 [01-01 08:00:00:411 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d364c0 [01-01 08:00:00:412 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb0f65ca9465be8edcoyot 2022-10-19 15:23:07:537:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb0f65ca9465be8edcoyot 2022-10-19 15:23:07:537:core_dev_data.c:dev_filter:178:dev_filter:wk 2022-10-19 15:23:07:537:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Zigbee Smart Thermostat , dev_list[i].category = wk 2022-10-19 15:23:07:538:dev_control_cont.c:show_all_devices:263:dev_list->name = Zigbee Smart Thermostat ,online_stat = 0 [01-01 08:00:00:413 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d366f0 [01-01 08:00:00:413 TUYA D][tuya_base_event.c:28] subscribe: dp-ebabc77077c75fec391svt 2022-10-19 15:23:07:538:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 13 2022-10-19 15:23:07:538:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 0 [01-01 08:00:00:413 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d366f0 [01-01 08:00:00:413 TUYA D][tuya_base_event.c:31] unsubscribe: dp-ebabc77077c75fec391svt 2022-10-19 15:23:07:538:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = ebabc77077c75fec391svt 2022-10-19 15:23:07:539:core_dev_data.c:dev_filter:178:dev_filter:cz 2022-10-19 15:23:07:539:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = 智能插座, dev_list[i].category = cz 2022-10-19 15:23:07:539:dev_control_cont.c:show_all_devices:263:dev_list->name = 智能插座 ,online_stat = 0 [01-01 08:00:00:414 TUYA D][strategy_code_enum.c:67] get enum error: [01-01 08:00:00:414 TUYA E][strategy_code_enum.c:117] strategyValue is {"relay_status":"{\"0\":\"power_off\",\"1\":\"power_on\",\"2\":\"last\",\"memory\":\"last\",\"off\":\"power_off\",\"on\":\"power_on\"}"}, src_tp:3, dst_tp:3 [01-01 08:00:00:414 TUYA E][tuya_ctrl_center_api.c:83] strategy convert error: -8 [01-01 08:00:00:414 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d366f0 [01-01 08:00:00:414 TUYA D][tuya_base_event.c:28] subscribe: dp-eb67a0efcb59444d01ydgn 2022-10-19 15:23:07:540:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 10 2022-10-19 15:23:07:540:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [01-01 08:00:00:415 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d366f0 [01-01 08:00:00:415 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb67a0efcb59444d01ydgn 2022-10-19 15:23:07:540:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb67a0efcb59444d01ydgn 2022-10-19 15:23:07:540:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 2022-10-19 15:23:07:540:dev_control_cz.c:cz_ctl_shortcut_open:236:p6el:cz_ctl_shortcut_open dev_id = eb67a0efcb59444d01ydgn [01-01 08:00:00:415 TUYA D][strategy_code_enum.c:67] get enum error: [01-01 08:00:00:415 TUYA E][strategy_code_enum.c:117] strategyValue is {"relay_status":"{\"0\":\"power_off\",\"1\":\"power_on\",\"2\":\"last\",\"memory\":\"last\",\"off\":\"power_off\",\"on\":\"power_on\"}"}, src_tp:3, dst_tp:3 [01-01 08:00:00:415 TUYA E][tuya_ctrl_center_api.c:83] strategy convert error: -8 [01-01 08:00:00:415 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d366f0 [01-01 08:00:00:415 TUYA D][tuya_base_event.c:28] subscribe: dp-eb67a0efcb59444d01ydgn 2022-10-19 15:23:07:541:dev_control_cz.c:cz_ctl_shortcut_open:245:p6el:cz_ctl_shortcut_open dev_info = 315844400 2022-10-19 15:23:07:541:dev_control_cont.c:tab2_device_cb:693:sw off.. 2022-10-19 15:23:07:541:core_dev_data.c:dev_filter:178:dev_filter:dd 2022-10-19 15:23:07:541:core_dev_data.c:dev_filter:178:dev_filter:dj 2022-10-19 15:23:07:541:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = 智能彩灯, dev_list[i].category = dj 2022-10-19 15:23:07:541:dev_control_cont.c:show_all_devices:263:dev_list->name = 智能彩灯 ,online_stat = 0 [01-01 08:00:00:416 TUYA D][dpcode_strategy.c:55] str: len:0 [01-01 08:00:00:416 TUYA D][dpcode_strategy.c:58] strlen:0 is wrong [01-01 08:00:00:416 TUYA W][tuya_std_dp_light_transform.c:197] light scene mode : is not found [01-01 08:00:00:416 TUYA W][tuya_home_ctrl_light_dp.c:188] light_dp_generate_scene_mode is not found [01-01 08:00:00:417 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d377b0 [01-01 08:00:00:417 TUYA D][tuya_base_event.c:28] subscribe: dp-eb62263aaf2f73ef03xira 2022-10-19 15:23:07:542:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 7 2022-10-19 15:23:07:542:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [01-01 08:00:00:417 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d377b0 [01-01 08:00:00:417 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb62263aaf2f73ef03xira 2022-10-19 15:23:07:542:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb62263aaf2f73ef03xira 2022-10-19 15:23:07:542:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 [01-01 08:00:00:417 TUYA D][dpcode_strategy.c:55] str: len:0 [01-01 08:00:00:417 TUYA D][dpcode_strategy.c:58] strlen:0 is wrong [01-01 08:00:00:417 TUYA W][tuya_std_dp_light_transform.c:197] light scene mode : is not found [01-01 08:00:00:417 TUYA W][tuya_home_ctrl_light_dp.c:188] light_dp_generate_scene_mode is not found [01-01 08:00:00:417 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d377b0 [01-01 08:00:00:417 TUYA D][tuya_base_event.c:28] subscribe: dp-eb62263aaf2f73ef03xira 2022-10-19 15:23:07:543:dev_control_light.c:light_ctl_open:99:light_ctl_open = 315848624 2022-10-19 15:23:07:543:dev_control_cont.c:tab2_device_cb:693:sw off.. 2022-10-19 15:23:07:543:core_dev_data.c:dev_filter:178:dev_filter:wfcon 2022-10-19 15:23:07:543:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:07:543:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = 4X4 Switch+Socket, dev_list[i].category = kg 2022-10-19 15:23:07:544:dev_control_cont.c:show_all_devices:263:dev_list->name = 4X4 Switch+Socket ,online_stat = 0 [01-01 08:00:00:419 TUYA D][strategy_code_enum.c:67] get enum error: [01-01 08:00:00:419 TUYA E][strategy_code_enum.c:117] strategyValue is {"relay_status":"{\"0\":\"power_off\",\"1\":\"power_on\",\"2\":\"last\",\"memory\":\"last\",\"off\":\"power_off\",\"on\":\"power_on\"}"}, src_tp:3, dst_tp:3 [01-01 08:00:00:419 TUYA E][tuya_ctrl_center_api.c:83] strategy convert error: -8 [01-01 08:00:00:419 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d37a90 [01-01 08:00:00:419 TUYA D][tuya_base_event.c:28] subscribe: dp-ebc78c65e28bc1347ac761 2022-10-19 15:23:07:544:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 14 2022-10-19 15:23:07:544:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 7 [01-01 08:00:00:419 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d37a90 [01-01 08:00:00:419 TUYA D][tuya_base_event.c:31] unsubscribe: dp-ebc78c65e28bc1347ac761 2022-10-19 15:23:07:545:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = ebc78c65e28bc1347ac761 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:clkg 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:bzyd 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:pir 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:pir 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:mcs 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:pc 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:dd 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:pc 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:dd 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:dlq 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:07:545:core_dev_data.c:dev_filter:178:dev_filter:wk 2022-10-19 15:23:07:545:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Temp, dev_list[i].category = wk 2022-10-19 15:23:07:546:dev_control_cont.c:show_all_devices:263:dev_list->name = Temp ,online_stat = 0 [01-01 08:00:00:421 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d37a90 2022-10-19 15:23:07:546:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 5 [01-01 08:00:00:421 TUYA D][tuya_base_event.c:28] subscribe: dp-eb0058bee16ce0c70aq9nj 2022-10-19 15:23:07:546:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 0 [01-01 08:00:00:421 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d37a90 [01-01 08:00:00:421 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb0058bee16ce0c70aq9nj 2022-10-19 15:23:07:547:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb0058bee16ce0c70aq9nj 2022-10-19 15:23:07:547:core_dev_data.c:dev_filter:178:dev_filter:cz 2022-10-19 15:23:07:547:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Wifi Plug, dev_list[i].category = cz 2022-10-19 15:23:07:547:dev_control_cont.c:show_all_devices:263:dev_list->name = Wifi Plug ,online_stat = 0 [01-01 08:00:00:422 TUYA D][strategy_code_enum.c:67] get enum error: [01-01 08:00:00:422 TUYA E][strategy_code_enum.c:117] strategyValue is {"relay_status":"{\"0\":\"power_off\",\"1\":\"power_on\",\"2\":\"last\",\"memory\":\"last\",\"off\":\"power_off\",\"on\":\"power_on\"}"}, src_tp:3, dst_tp:3 [01-01 08:00:00:422 TUYA E][tuya_ctrl_center_api.c:83] strategy convert error: -8 [01-01 08:00:00:422 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d37a90 [01-01 08:00:00:422 TUYA D][tuya_base_event.c:28] subscribe: dp-eb68d8dbe4707224e8sxd8 2022-10-19 15:23:07:548:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 9 2022-10-19 15:23:07:548:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [01-01 08:00:00:423 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d37a90 [01-01 08:00:00:423 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb68d8dbe4707224e8sxd8 2022-10-19 15:23:07:548:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb68d8dbe4707224e8sxd8 2022-10-19 15:23:07:548:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 2022-10-19 15:23:07:548:dev_control_cz.c:cz_ctl_shortcut_open:236:p6el:cz_ctl_shortcut_open dev_id = eb68d8dbe4707224e8sxd8 [01-01 08:00:00:423 TUYA D][strategy_code_enum.c:67] get enum error: [01-01 08:00:00:423 TUYA E][strategy_code_enum.c:117] strategyValue is {"relay_status":"{\"0\":\"power_off\",\"1\":\"power_on\",\"2\":\"last\",\"memory\":\"last\",\"off\":\"power_off\",\"on\":\"power_on\"}"}, src_tp:3, dst_tp:3 [01-01 08:00:00:423 TUYA E][tuya_ctrl_center_api.c:83] strategy convert error: -8 [01-01 08:00:00:423 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d37a90 [01-01 08:00:00:423 TUYA D][tuya_base_event.c:28] subscribe: dp-eb68d8dbe4707224e8sxd8 2022-10-19 15:23:07:549:dev_control_cz.c:cz_ctl_shortcut_open:245:p6el:cz_ctl_shortcut_open dev_info = 315852400 2022-10-19 15:23:07:549:dev_control_cont.c:tab2_device_cb:693:sw off.. 2022-10-19 15:23:07:549:core_dev_data.c:dev_filter:178:dev_filter:wk 2022-10-19 15:23:07:549:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = 空调温控器 2, dev_list[i].category = wk 2022-10-19 15:23:07:549:dev_control_cont.c:show_all_devices:263:dev_list->name = 空调温控器 2 ,online_stat = 0 [01-01 08:00:00:425 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d38ed0 [01-01 08:00:00:425 TUYA D][tuya_base_event.c:28] subscribe: dp-ebe3006b0f14083917oh1d 2022-10-19 15:23:07:550:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 11 2022-10-19 15:23:07:550:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 0 [01-01 08:00:00:425 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d38ed0 [01-01 08:00:00:425 TUYA D][tuya_base_event.c:31] unsubscribe: dp-ebe3006b0f14083917oh1d 2022-10-19 15:23:07:550:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = ebe3006b0f14083917oh1d 2022-10-19 15:23:07:550:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:07:550:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:07:550:core_dev_data.c:dev_filter:178:dev_filter:dd 2022-10-19 15:23:07:550:core_dev_data.c:dev_filter:178:dev_filter:wsdcg 2022-10-19 15:23:07:550:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:07:551:core_dev_data.c:dev_filter:178:dev_filter:dj 2022-10-19 15:23:07:551:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Smart Bulb(BP5758D 35/10), dev_list[i].category = dj 2022-10-19 15:23:07:551:dev_control_cont.c:show_all_devices:263:dev_list->name = Smart Bulb(BP5758D 35/10) ,online_stat = 0 [01-01 08:00:00:426 TUYA D][dpcode_strategy.c:55] str: len:0 [01-01 08:00:00:426 TUYA D][dpcode_strategy.c:58] strlen:0 is wrong [01-01 08:00:00:426 TUYA W][tuya_std_dp_light_transform.c:197] light scene mode : is not found [01-01 08:00:00:426 TUYA W][tuya_home_ctrl_light_dp.c:188] light_dp_generate_scene_mode is not found [01-01 08:00:00:426 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d38ed0 [01-01 08:00:00:426 TUYA D][tuya_base_event.c:28] subscribe: dp-eba528413f6980a463pn4p 2022-10-19 15:23:07:552:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 16 2022-10-19 15:23:07:552:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [01-01 08:00:00:427 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d38ed0 [01-01 08:00:00:427 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eba528413f6980a463pn4p 2022-10-19 15:23:07:552:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eba528413f6980a463pn4p 2022-10-19 15:23:07:552:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 [01-01 08:00:00:427 TUYA D][dpcode_strategy.c:55] str: len:0 [01-01 08:00:00:427 TUYA D][dpcode_strategy.c:58] strlen:0 is wrong [01-01 08:00:00:427 TUYA W][tuya_std_dp_light_transform.c:197] light scene mode : is not found [01-01 08:00:00:427 TUYA W][tuya_home_ctrl_light_dp.c:188] light_dp_generate_scene_mode is not found [01-01 08:00:00:427 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d38ed0 [01-01 08:00:00:427 TUYA D][tuya_base_event.c:28] subscribe: dp-eba528413f6980a463pn4p 2022-10-19 15:23:07:553:dev_control_light.c:light_ctl_open:99:light_ctl_open = 315854544 2022-10-19 15:23:07:553:dev_control_cont.c:tab2_device_cb:693:sw off.. 2022-10-19 15:23:07:553:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:07:553:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Six Gang Switch-vdevo, dev_list[i].category = kg 2022-10-19 15:23:07:553:dev_control_cont.c:show_all_devices:263:dev_list->name = Six Gang Switch-vdevo ,online_stat = 0 [01-01 08:00:00:428 TUYA D][strategy_code_enum.c:67] get enum error: [01-01 08:00:00:428 TUYA E][strategy_code_enum.c:117] strategyValue is {"relay_status":"{\"0\":\"power_off\",\"1\":\"power_on\",\"2\":\"last\",\"memory\":\"last\",\"off\":\"power_off\",\"on\":\"power_on\"}"}, src_tp:3, dst_tp:3 [01-01 08:00:00:428 TUYA E][tuya_ctrl_center_api.c:83] strategy convert error: -8 [01-01 08:00:00:429 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d38a70 [01-01 08:00:00:429 TUYA D][tuya_base_event.c:28] subscribe: dp-vdevo166004655924109 2022-10-19 15:23:07:554:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 14 2022-10-19 15:23:07:554:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 7 [01-01 08:00:00:429 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d38a70 [01-01 08:00:00:429 TUYA D][tuya_base_event.c:31] unsubscribe: dp-vdevo166004655924109 2022-10-19 15:23:07:554:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = vdevo166004655924109 2022-10-19 15:23:07:554:core_dev_data.c:dev_filter:178:dev_filter:wk 2022-10-19 15:23:07:555:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = 空调温控器, dev_list[i].category = wk 2022-10-19 15:23:07:555:dev_control_cont.c:show_all_devices:263:dev_list->name = 空调温控器 ,online_stat = 0 [01-01 08:00:00:430 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3a950 2022-10-19 15:23:07:556:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 11 [01-01 08:00:00:430 TUYA D][tuya_base_event.c:28] subscribe: dp-eb21cdbd5e05e8e428gaca 2022-10-19 15:23:07:556:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 0 [01-01 08:00:00:430 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d3a950 [01-01 08:00:00:430 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb21cdbd5e05e8e428gaca 2022-10-19 15:23:07:556:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb21cdbd5e05e8e428gaca 2022-10-19 15:23:07:556:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:07:556:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:07:556:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Six Gang Switch 2, dev_list[i].category = kg 2022-10-19 15:23:07:556:dev_control_cont.c:show_all_devices:263:dev_list->name = Six Gang Switch 2 ,online_stat = 0 [01-01 08:00:00:432 TUYA D][strategy_code_enum.c:67] get enum error: [01-01 08:00:00:432 TUYA E][strategy_code_enum.c:117] strategyValue is {"relay_status":"{\"0\":\"power_off\",\"1\":\"power_on\",\"2\":\"last\",\"memory\":\"last\",\"off\":\"power_off\",\"on\":\"power_on\"}"}, src_tp:3, dst_tp:3 [01-01 08:00:00:432 TUYA E][tuya_ctrl_center_api.c:83] strategy convert error: -8 [01-01 08:00:00:432 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3a950 [01-01 08:00:00:432 TUYA D][tuya_base_event.c:28] subscribe: dp-eb0a212b4b26ce96c62aei 2022-10-19 15:23:07:557:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 14 2022-10-19 15:23:07:557:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 7 [01-01 08:00:00:432 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d3a950 [01-01 08:00:00:432 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb0a212b4b26ce96c62aei 2022-10-19 15:23:07:557:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb0a212b4b26ce96c62aei 2022-10-19 15:23:07:558:core_dev_data.c:dev_filter:178:dev_filter:cz 2022-10-19 15:23:07:558:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Soquete Inteligente, dev_list[i].category = cz 2022-10-19 15:23:07:558:dev_control_cont.c:show_all_devices:263:dev_list->name = Soquete Inteligente ,online_stat = 0 [01-01 08:00:00:433 TUYA D][strategy_code_enum.c:67] get enum error: [01-01 08:00:00:433 TUYA E][strategy_code_enum.c:117] strategyValue is {"relay_status":"{\"0\":\"power_off\",\"1\":\"power_on\",\"2\":\"last\",\"memory\":\"last\",\"off\":\"power_off\",\"on\":\"power_on\"}"}, src_tp:3, dst_tp:3 [01-01 08:00:00:433 TUYA E][tuya_ctrl_center_api.c:83] strategy convert error: -8 [01-01 08:00:00:433 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3a950 [01-01 08:00:00:433 TUYA D][tuya_base_event.c:28] subscribe: dp-ebd1ebe54febaa9c022vqf 2022-10-19 15:23:07:559:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 10 2022-10-19 15:23:07:559:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [01-01 08:00:00:434 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d3a950 [01-01 08:00:00:434 TUYA D][tuya_base_event.c:31] unsubscribe: dp-ebd1ebe54febaa9c022vqf 2022-10-19 15:23:07:559:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = ebd1ebe54febaa9c022vqf 2022-10-19 15:23:07:559:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 2022-10-19 15:23:07:559:dev_control_cz.c:cz_ctl_shortcut_open:236:p6el:cz_ctl_shortcut_open dev_id = ebd1ebe54febaa9c022vqf [01-01 08:00:00:434 TUYA D][strategy_code_enum.c:67] get enum error: [01-01 08:00:00:434 TUYA E][strategy_code_enum.c:117] strategyValue is {"relay_status":"{\"0\":\"power_off\",\"1\":\"power_on\",\"2\":\"last\",\"memory\":\"last\",\"off\":\"power_off\",\"on\":\"power_on\"}"}, src_tp:3, dst_tp:3 [01-01 08:00:00:434 TUYA E][tuya_ctrl_center_api.c:83] strategy convert error: -8 [01-01 08:00:00:434 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3a950 [01-01 08:00:00:434 TUYA D][tuya_base_event.c:28] subscribe: dp-ebd1ebe54febaa9c022vqf 2022-10-19 15:23:07:560:dev_control_cz.c:cz_ctl_shortcut_open:245:p6el:cz_ctl_shortcut_open dev_info = 315859376 2022-10-19 15:23:07:560:dev_control_cont.c:tab2_device_cb:693:sw off.. 2022-10-19 15:23:07:560:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:07:560:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Six Gang Switch, dev_list[i].category = kg 2022-10-19 15:23:07:560:dev_control_cont.c:show_all_devices:263:dev_list->name = Six Gang Switch ,online_stat = 0 [01-01 08:00:00:436 TUYA D][strategy_code_enum.c:67] get enum error: [01-01 08:00:00:436 TUYA E][strategy_code_enum.c:117] strategyValue is {"relay_status":"{\"0\":\"power_off\",\"1\":\"power_on\",\"2\":\"last\",\"memory\":\"last\",\"off\":\"power_off\",\"on\":\"power_on\"}"}, src_tp:3, dst_tp:3 [01-01 08:00:00:436 TUYA E][tuya_ctrl_center_api.c:83] strategy convert error: -8 [01-01 08:00:00:436 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3b0e0 [01-01 08:00:00:436 TUYA D][tuya_base_event.c:28] subscribe: dp-ebae3eac4f123fe22bbx5k 2022-10-19 15:23:07:561:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 14 2022-10-19 15:23:07:561:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 7 [01-01 08:00:00:436 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d3b0e0 [01-01 08:00:00:436 TUYA D][tuya_base_event.c:31] unsubscribe: dp-ebae3eac4f123fe22bbx5k 2022-10-19 15:23:07:561:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = ebae3eac4f123fe22bbx5k 2022-10-19 15:23:07:562:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:07:562:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Smart Wireless Switch K10W, dev_list[i].category = kg 2022-10-19 15:23:07:562:dev_control_cont.c:show_all_devices:263:dev_list->name = Smart Wireless Switch K10W ,online_stat = 0 [01-01 08:00:00:437 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3b0e0 [01-01 08:00:00:437 TUYA D][tuya_base_event.c:28] subscribe: dp-eba19ee51b778585c0jcy3 2022-10-19 15:23:07:563:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 4 2022-10-19 15:23:07:563:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [01-01 08:00:00:437 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d3b0e0 [01-01 08:00:00:438 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eba19ee51b778585c0jcy3 2022-10-19 15:23:07:563:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eba19ee51b778585c0jcy3 2022-10-19 15:23:07:563:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 [01-01 08:00:00:438 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3b0e0 [01-01 08:00:00:438 TUYA D][tuya_base_event.c:28] subscribe: dp-eba19ee51b778585c0jcy3 2022-10-19 15:23:07:563:dev_control_kg.c:kg_ctl_open:70:eba19ee51b778585c0jcy3 2022-10-19 15:23:07:563:dev_control_kg.c:kg_get_shortcut:105:---------------kg_get_shortcut:0 2022-10-19 15:23:07:563:dev_control_cont.c:tab2_device_cb:693:sw off.. 2022-10-19 15:23:07:564:dev_control.c:no_device_view:405:no_device_view view in 2022-10-19 15:23:07:574:dev_control.c:no_device_view:405:no_device_view view in 2022-10-19 15:23:07:576:dev_control.c:no_device_view:405:no_device_view view in 2022-10-19 15:23:07:577:dev_control.c:no_device_view:405:no_device_view view in 2022-10-19 15:23:07:578:dev_control.c:no_device_view:405:no_device_view view in 2022-10-19 15:23:07:580:dev_control.c:no_device_view:405:no_device_view view in [01-01 08:00:00:455 TUYA W][tuya_ctrl_center_api.c:185] dev: eb257c7e0da82bf6fdgo2g name : Zigbee LAN Gateway should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf673a55509854f89o4ms name : Switch of scene should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: ebe5c0ea9264da5aedqyqx name : 4'' Smart panel-EU should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: ebe2744515d20294b1yhgw name : Zigbee Repeater should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb99a9cc76209358a4crkr name : Gateway should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb9e43a7db146d1286luio name : 空调 should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb87649dc6a4ae7fef87xr name : 智能红外遥控器 should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: ebd959f9cc5a9857b2zsoo name : 遥控器 should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf8fee6f4298432a5eqvk name : 智能网关 should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb8607e2c51bffc942fczo name : 红外射频遥控器 3 should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf911148e218a63b67uf3 name : Air should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: ebd88c655bdd4b39adihqe name : 智能红外遥控器 should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb46ca57fbaaa5a173n9zv name : 红外射频遥控器 2 should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb92b0479e015fbbaavltv name : 智能红外遥控器 should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb09bad8e75f6222acaglz name : Intelligent Switcher 2CH should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb71d993c258066917jpks name : IPC should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: ebba64b6ac327cdeddq8z2 name : Curtain Switch should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: ebb3fad96f393b588eomxh name : IR remote should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb1552c6f83a6b59edmyes name : P6EL 2 should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eba3fc32248cc469a3y5qe name : P6EL should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb0469f56ed95d7791ogla name : Smart Knob should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb827d57cf10b04d2fxtij name : Mini 多模网关 should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb079c4f40c6c21e6ffpd0 name : 空调 should not show on screen [01-01 08:00:00:456 TUYA W][tuya_ctrl_center_api.c:185] dev: eb44125a98339e4a81t9za name : 智能红外遥控器 should not show on screen [01-01 08:00:00:456 TUYA D][tuya_ctrl_center_api.c:213] tuya_get_dev_brief_info_list success, dev cnt is 36 2022-10-19 15:23:07:582:pull_down_sensor.c:get_brief_sensor_devices:337:tuya_get_dev_brief_info_list dev_count 36 2022-10-19 15:23:07:582:core_dev_data.c:sensor_filter:256:dev_filter:mcs 2022-10-19 15:23:07:582:pull_down_sensor.c:get_brief_sensor_devices:345:dev_list[i].online_stat 0 dev_list[i].name = Zigbee Contact Sensor, dev_list[i].category = mcs 2022-10-19 15:23:07:582:pull_down_sensor.c:open_all_sensor_dev:270:open_all_sensor_dev:mcs 2022-10-19 15:23:07:582:test_home_ctrl_door_sensor.c:test_door_sensor_dp:84:report dev_id=0x12d32950, ebd0ad496c403f1af3i9an [01-01 08:00:00:457 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d30710 [01-01 08:00:00:457 TUYA D][tuya_base_event.c:28] subscribe: dp-ebd0ad496c403f1af3i9an 2022-10-19 15:23:07:582:pull_down_sensor.c:open_all_sensor_dev:313:smatek open_all_sensor_dev dev_info:0x12d30710, dev_list->id:ebd0ad496c403f1af3i9an 2022-10-19 15:23:07:582:core_dev_data.c:sensor_filter:256:dev_filter:kg 2022-10-19 15:23:07:582:core_dev_data.c:sensor_filter:256:dev_filter:wk 2022-10-19 15:23:07:583:core_dev_data.c:sensor_filter:256:dev_filter:cz 2022-10-19 15:23:07:583:core_dev_data.c:sensor_filter:256:dev_filter:dd 2022-10-19 15:23:07:583:core_dev_data.c:sensor_filter:256:dev_filter:dj 2022-10-19 15:23:07:583:core_dev_data.c:sensor_filter:256:dev_filter:wfcon 2022-10-19 15:23:07:583:core_dev_data.c:sensor_filter:256:dev_filter:kg 2022-10-19 15:23:07:583:core_dev_data.c:sensor_filter:256:dev_filter:clkg 2022-10-19 15:23:07:583:core_dev_data.c:sensor_filter:256:dev_filter:bzyd 2022-10-19 15:23:07:583:core_dev_data.c:sensor_filter:256:dev_filter:pir 2022-10-19 15:23:07:583:pull_down_sensor.c:get_brief_sensor_devices:345:dev_list[i].online_stat 0 dev_list[i].name = 门铃按钮, dev_list[i].category = pir 2022-10-19 15:23:07:583:pull_down_sensor.c:open_all_sensor_dev:270:open_all_sensor_dev:pir 2022-10-19 15:23:07:583:test_home_ctrl_pir_sensor.c:test_pir_sensor_dp:98:test_pir_sensor_dp dev_id:ebff3d1dac6c9c54ebu58o [01-01 08:00:00:458 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d38b20 [01-01 08:00:00:458 TUYA D][tuya_base_event.c:28] subscribe: dp-ebff3d1dac6c9c54ebu58o 2022-10-19 15:23:07:583:pull_down_sensor.c:open_all_sensor_dev:313:smatek open_all_sensor_dev dev_info:0x12d38b20, dev_list->id:ebff3d1dac6c9c54ebu58o 2022-10-19 15:23:07:583:core_dev_data.c:sensor_filter:256:dev_filter:pir 2022-10-19 15:23:07:583:pull_down_sensor.c:get_brief_sensor_devices:345:dev_list[i].online_stat 0 dev_list[i].name = 人体传感器, dev_list[i].category = pir 2022-10-19 15:23:07:583:pull_down_sensor.c:open_all_sensor_dev:270:open_all_sensor_dev:pir 2022-10-19 15:23:07:583:test_home_ctrl_pir_sensor.c:test_pir_sensor_dp:98:test_pir_sensor_dp dev_id:eb3edad403134c4f6czxy4 [01-01 08:00:00:458 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d36440 2022-10-19 15:23:07:584:pull_down_sensor.c:open_all_sensor_dev:313:smatek open_all_sensor_dev dev_info:0x12d36440, dev_list->id:eb3edad403134c4f6czxy4 [01-01 08:00:00:458 TUYA D][tuya_base_event.c:28] subscribe: dp-eb3edad403134c4f6czxy4 2022-10-19 15:23:07:584:core_dev_data.c:sensor_filter:256:dev_filter:mcs 2022-10-19 15:23:07:584:pull_down_sensor.c:get_brief_sensor_devices:345:dev_list[i].online_stat 0 dev_list[i].name = 门磁, dev_list[i].category = mcs 2022-10-19 15:23:07:584:pull_down_sensor.c:open_all_sensor_dev:270:open_all_sensor_dev:mcs 2022-10-19 15:23:07:584:test_home_ctrl_door_sensor.c:test_door_sensor_dp:84:report dev_id=0x12d334a8, eb92c47fe161c74b89dk25 [01-01 08:00:00:459 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3bdf0 2022-10-19 15:23:07:584:pull_down_sensor.c:open_all_sensor_dev:313:smatek open_all_sensor_dev dev_info:0x12d3bdf0, dev_list->id:eb92c47fe161c74b89dk25 [01-01 08:00:00:459 TUYA D][tuya_base_event.c:28] subscribe: dp-eb92c47fe161c74b89dk25 2022-10-19 15:23:07:584:core_dev_data.c:sensor_filter:256:dev_filter:pc 2022-10-19 15:23:07:584:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:07:584:core_dev_data.c:sensor_filter:256:dev_filter:dd 2022-10-19 15:23:07:584:core_dev_data.c:sensor_filter:256:dev_filter:pc 2022-10-19 15:23:07:584:core_dev_data.c:sensor_filter:256:dev_filter:dd 2022-10-19 15:23:07:585:core_dev_data.c:sensor_filter:256:dev_filter:dlq 2022-10-19 15:23:07:585:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:07:585:core_dev_data.c:sensor_filter:256:dev_filter:wk 2022-10-19 15:23:07:585:core_dev_data.c:sensor_filter:256:dev_filter:cz 2022-10-19 15:23:07:585:core_dev_data.c:sensor_filter:256:dev_filter:wk 2022-10-19 15:23:07:585:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:07:585:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:07:585:core_dev_data.c:sensor_filter:256:dev_filter:dd 2022-10-19 15:23:07:585:core_dev_data.c:sensor_filter:256:dev_filter:wsdcg 2022-10-19 15:23:07:585:pull_down_sensor.c:get_brief_sensor_devices:345:dev_list[i].online_stat 0 dev_list[i].name = WI-FI Temperature & Humidity Sensor, dev_list[i].category = wsdcg 2022-10-19 15:23:07:585:pull_down_sensor.c:open_all_sensor_dev:270:open_all_sensor_dev:wsdcg [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3c190 [01-01 08:00:00:460 TUYA D][test_home_ctrl_thtb_sensor.c:91] dev_id:ebc90e9813ffde4148tcvg, support 15 dps: [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:temp_unit_convert, mode:0, type:3 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_common_show.c:39] enum:, support total 2 enums: [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_common_show.c:42] c [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_common_show.c:42] f [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:maxtemp_set, mode:0, type:1 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_common_show.c:33] int min:-200, max:600, step:1, scale:1, value:0 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:minitemp_set, mode:0, type:1 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_common_show.c:33] int min:-200, max:600, step:1, scale:1, value:0 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:maxhum_set, mode:0, type:1 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_common_show.c:33] int min:0, max:100, step:1, scale:0, value:0 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:minihum_set, mode:0, type:1 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_common_show.c:33] int min:0, max:100, step:1, scale:0, value:0 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:temp_periodic_report, mode:0, type:1 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_common_show.c:33] int min:1, max:120, step:1, scale:0, value:0 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:hum_periodic_report, mode:0, type:1 [01-01 08:00:00:460 TUYA D][tuya_home_ctrl_common_show.c:33] int min:1, max:120, step:1, scale:0, value:0 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:temp_sensitivity, mode:0, type:1 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:33] int min:3, max:20, step:1, scale:1, value:0 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:hum_sensitivity, mode:0, type:1 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:33] int min:3, max:20, step:1, scale:0, value:0 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:va_temperature, mode:2, type:1 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:33] int min:-200, max:600, step:1, scale:1, value:0 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:va_humidity, mode:2, type:1 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:33] int min:0, max:100, step:1, scale:0, value:0 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:battery_state, mode:2, type:3 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:39] enum:, support total 3 enums: [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:42] low [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:42] middle [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:42] high [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:battery_percentage, mode:2, type:1 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:33] int min:0, max:100, step:1, scale:0, value:0 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:temp_alarm, mode:2, type:3 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:39] enum:, support total 3 enums: [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:42] loweralarm [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:42] upperalarm [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:42] cancel [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:hum_alarm, mode:2, type:3 [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:39] enum:, support total 3 enums: [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:42] loweralarm [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:42] upperalarm [01-01 08:00:00:461 TUYA D][tuya_home_ctrl_common_show.c:42] cancel [01-01 08:00:00:461 TUYA D][tuya_base_event.c:28] subscribe: dp-ebc90e9813ffde4148tcvg 2022-10-19 15:23:07:587:pull_down_sensor.c:open_all_sensor_dev:313:smatek open_all_sensor_dev dev_info:0x12d3c190, dev_list->id:ebc90e9813ffde4148tcvg 2022-10-19 15:23:07:587:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:07:587:core_dev_data.c:sensor_filter:256:dev_filter:dj 2022-10-19 15:23:07:587:core_dev_data.c:sensor_filter:256:dev_filter:kg 2022-10-19 15:23:07:587:core_dev_data.c:sensor_filter:256:dev_filter:wk 2022-10-19 15:23:07:587:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:07:587:core_dev_data.c:sensor_filter:256:dev_filter:kg 2022-10-19 15:23:07:587:core_dev_data.c:sensor_filter:256:dev_filter:cz 2022-10-19 15:23:07:587:core_dev_data.c:sensor_filter:256:dev_filter:kg 2022-10-19 15:23:07:587:core_dev_data.c:sensor_filter:256:dev_filter:kg udhcpc: sending discover [01-01 08:00:01:317 TUYA D][tuya_iot_base_api.c:249] wired netstat changed to:1 -->> [01-01 08:00:01:318 TUYA D][tuya_iot_sdk_api.c:65] base net stat:1 [01-01 08:00:01:318 TUYA D][sdk_adpt_internal_api.c:33] base nw stat: 1, ret:0 [01-01 08:00:01:318 TUYA D][tuya_iot_base_api.c:256] wired netstat changed to:1 <<-- [01-01 08:00:01:336 TUYA D][tuya_z3.c:28678] tuya_z3_init status: 1, isUg=0 [01-01 08:00:01:343 TUYA N][mqtt_client.c:1622] mqtt close [01-01 08:00:01:343 TUYA N][mqtt_client.c:782] close mqtt -->> [01-01 08:00:01:343 TUYA N][mqtt_client.c:828] close mqtt <<-- [01-01 08:00:01:343 TUYA D][mqtt_client.c:1638] mqtt fail_cnt:1, sleeptime:6386 ms [01-01 08:00:01:358 TUYA D][lan_pub_sub_mq.c:311] try to check sub topic [01-01 08:00:01:358 TUYA D][lan_pub_sub_mq.c:314] cur st is:0. not check udhcpc: sending select for 192.168.3.106 udhcpc: lease of 192.168.3.106 obtained, lease time 5678 deleting routers adding dns 114.114.114.114 adding dns 119.29.29.29 [01-01 08:00:02:350 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a5780 94038640 [01-01 08:00:02:350 TUYA D][thread_pool_temp.c:607] temp run 0x5a5780 94038640 [01-01 08:00:02:350 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a69a0 94029010 [01-01 08:00:02:350 TUYA D][thread_pool_temp.c:607] temp run 0x5a69a0 94029010 [01-01 08:00:02:350 TUYA D][thread_pool_temp.c:197] run temp 0x5a5780 94038640 in thread 94001420 BEGIN [01-01 08:00:02:350 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:02:350 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:02:350 TUYA D][thread_pool_temp.c:214] num:2 to exe [01-01 08:00:02:351 TUYA D][thread_pool_temp.c:197] run temp 0x5a69a0 94029010 in thread 94001420 BEGIN [01-01 08:00:02:351 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:02:351 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:02:351 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [01-01 08:00:02:351 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 ASH connected [01-01 08:00:02:423 TUYA D][af-main-host.c:1765] ezsp ver: 0x7 stack type :0x2 stack ver:[0x6500] [01-01 08:00:02:429 TUYA D][af-main-common.c:1223] stack ver. [6.5.0 [01-01 08:00:02:429 TUYA D][af-main-common.c:1233] 0x1a866a8 build 188] [01-01 08:00:02:429 TUYA D][af-main-host.c:564] NcpUpgrade_backup_ota_file:/userdata/NcpUpgrade_backup.ota. [01-01 08:00:02:429 TUYA D][af-main-host.c:565] coo_upgrating_file:/userdata/coo_upgrating. [01-01 08:00:02:429 TUYA D][af-main-host.c:616] NcpUpgrade_backup65_ota_file:/userdata/NcpUpgrade_backup65.ota. [01-01 08:00:02:429 TUYA D][af-main-host.c:617] coo_upgdate65_file:/userdata/coo_upgdate65. [01-01 08:00:02:436 TUYA D][tuya_z3.c:28678] tuya_z3_init status: 1, isUg=0 [01-01 08:00:02:443 TUYA D][af-main-host.c:705] Ezsp Config: get ncp info status:0: manufacturer ID:0x 2 version:0x1005. [01-01 08:00:02:447 TUYA D][af-main-host.c:1090] Ezsp Config: set config panid conflict. to 0x 5: Success set [01-01 08:00:02:452 TUYA D][af-main-host.c:718] Ezsp Config: get ezsp config application zdo flags value:0x0. [01-01 08:00:02:456 TUYA D][af-main-host.c:1090] Ezsp Config: set config application zdo flags. to 0x 2: Success set [01-01 08:00:02:461 TUYA D][af-main-host.c:1090] Ezsp Config: set EZSP_CONFIG_SEND_MULTICASTS_TO_SLEEPY_ADDRESS to 0x 1: Success set [01-01 08:00:02:466 TUYA D][af-main-host.c:1090] Ezsp Config: set security level to 0x 5: Success set [01-01 08:00:02:474 TUYA D][af-main-host.c:1090] Ezsp Config: set address table size to 0x 2: Success set [01-01 08:00:02:483 TUYA D][af-main-host.c:1090] Ezsp Config: set TC addr cache to 0x 2: Success set [01-01 08:00:02:487 TUYA D][af-main-host.c:1090] Ezsp Config: set stack profile to 0x 2: Success set [01-01 08:00:02:492 TUYA D][af-main-host.c:1090] Ezsp Config: set MAC indirect TX timeout to 0x1e00: Success set [01-01 08:00:02:496 TUYA D][af-main-host.c:1090] Ezsp Config: set max hops to 0x1e: Success set [01-01 08:00:02:501 TUYA D][af-main-host.c:1090] Ezsp Config: set tx power mode to 0x8000: Success set [01-01 08:00:02:509 TUYA D][af-main-host.c:1090] Ezsp Config: set supported networks to 0x 1: Success set [01-01 08:00:02:514 TUYA D][af-main-host.c:1117] Ezsp Policy: set binding modify to "allow for valid endpoints & clusters only": Success set [01-01 08:00:02:518 TUYA D][af-main-host.c:1117] Ezsp Policy: set message content in msgSent to "return": Success set [01-01 08:00:02:528 TUYA D][af-main-host.c:1140] Ezsp Value : set maximum incoming transfer size to [01-01 08:00:02:528 TUYA D][af-main-host.c:1149] 0x 52: [01-01 08:00:02:532 TUYA D][af-main-host.c:1140] Ezsp Value : set maximum outgoing transfer size to [01-01 08:00:02:532 TUYA D][af-main-host.c:1149] 0x 52: [01-01 08:00:02:541 TUYA D][ncp-configuration.c:26] Ezsp Config: get aps packet number to 100: [01-01 08:00:02:549 TUYA D][af-main-host.c:1090] Ezsp Config: set binding table size to 0x10: Success set [01-01 08:00:02:558 TUYA D][af-main-host.c:1090] Ezsp Config: set key table size to 0x a: Success set [01-01 08:00:02:566 TUYA D][af-main-host.c:1090] Ezsp Config: set max end device children to 0x20: Success set [01-01 08:00:02:586 TUYA D][af-main-host.c:1090] Ezsp Config: set route table size to 0x78: Success set [01-01 08:00:02:611 TUYA D][af-main-host.c:350] NCP supports maxing out packet buffers [01-01 08:00:02:611 TUYA D][af-main-host.c:364] Ezsp Config: set packet buffers to 250 [01-01 08:00:02:620 TUYA D][af-main-host.c:1090] Ezsp Config: set end device poll timeout to 0x 8: Success set [01-01 08:00:02:624 TUYA D][af-main-host.c:1090] Ezsp Config: set zll group addresses to 0x 0: Success set [01-01 08:00:02:629 TUYA D][af-main-host.c:1090] Ezsp Config: set zll rssi threshold to 0xff80: Success set [01-01 08:00:02:634 TUYA D][af-main-host.c:1090] Ezsp Config: set transient key timeout to 0xb4: Success set [01-01 08:00:02:654 TUYA D][af-main-host.c:1223] Ezsp Endpoint 1 added, profile 0x104, in clusters: 8, out clusters 20 [01-01 08:00:02:660 TUYA D][af-main-host.c:1223] Ezsp Endpoint 242 added, profile 0xa1e0, in clusters: 1, out clusters 1 [01-01 08:00:02:687 TUYA D][af-main-host.c:374] Ezsp Config: get packet buffer number to 250: [01-01 08:00:02:692 TUYA D][af-main-host.c:376] Ezsp Config: get aps buffer number to 100. [01-01 08:00:02:696 TUYA D][af-main-host.c:378] Ezsp Config: get broadcast table size to 250. [01-01 08:00:02:701 TUYA D][af-main-host.c:380] Ezsp Config: get source route table size to 0xc8. [01-01 08:00:02:705 TUYA D][af-main-host.c:382] Ezsp Config: get route table size to 0x78. [01-01 08:00:02:710 TUYA D][af-main-host.c:384] Ezsp Config: get neighbor table size to 0x1a. [01-01 08:00:02:715 TUYA D][af-main-host.c:386] Ezsp get config indirect transmission timeout: 30000. [01-01 08:00:02:719 TUYA D][af-main-host.c:388] Ezsp Config: get panid conflict report threshold value:5. [01-01 08:00:02:724 TUYA D][af-main-host.c:390] Ezsp Config: get ezsp config application zdo flags value:0x2. [01-01 08:00:02:729 TUYA D][af-main-host.c:446] creat flag file: echo 1 > /tmp//ncp_ver65_1_0_5_flag. [01-01 08:00:02:729 TUYA D][af-main-host.c:448] ncp start success. [01-01 08:00:02:749 TUYA D][device-table.c:919] read /userdata/devices.txt. [01-01 08:00:02:749 TUYA D][device-table.c:956] DevTable cur num:1, max num:1000. [01-01 08:00:02:750 TUYA D][green-power-server.c:6080] ====== Green Power Server Init ====== [01-01 08:00:02:754 TUYA D][trust-center-nwk-key-update-periodic.c:69] Next NWK key update in 2 0x1a84a08 [01-01 08:00:02:754 TUYA D][callback-stub.c:2310] [emberAfPluginOnOffClusterServerPostInitCallback:2310]. [01-01 08:00:02:754 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:02:754 TUYA D][tuya_z3.c:28009] Time is not synchronized Found 0 files [01-01 08:00:02:754 TUYA D][gateway-support.c:268] Registered EZSP FD 29 [01-01 08:00:02:754 TUYA D][z3_slabs.c:949] SUCCESS: writing zcl ver [01-01 08:00:02:754 TUYA D][z3_slabs.c:962] SUCCESS: writing power source [01-01 08:00:02:754 TUYA D][z3_slabs.c:977] SUCCESS: writing server cluster revision, clusterid: 0x0000 [01-01 08:00:02:754 TUYA D][z3_slabs.c:977] SUCCESS: writing server cluster revision, clusterid: 0x0003 [01-01 08:00:02:754 TUYA D][z3_slabs.c:977] SUCCESS: writing server cluster revision, clusterid: 0x0006 [01-01 08:00:02:754 TUYA D][z3_slabs.c:977] SUCCESS: writing server cluster revision, clusterid: 0x0008 [01-01 08:00:02:755 TUYA D][z3_slabs.c:977] SUCCESS: writing server cluster revision, clusterid: 0x000a [01-01 08:00:02:755 TUYA D][z3_slabs.c:993] SUCCESS: writing client cluster revision, clusterid: 0x0000 [01-01 08:00:02:755 TUYA D][z3_slabs.c:993] SUCCESS: writing client cluster revision, clusterid: 0x0003 [01-01 08:00:02:755 TUYA D][z3_slabs.c:993] SUCCESS: writing client cluster revision, clusterid: 0x0006 [01-01 08:00:02:755 TUYA D][z3_slabs.c:993] SUCCESS: writing client cluster revision, clusterid: 0x0008 WRITE ERR: ep 01 clus 0001 attr FFFD not supported [01-01 08:00:02:755 TUYA D][z3_slabs.c:990] ERR: writing client cluster revision, clusterid: 0x0001 [01-01 08:00:02:755 TUYA D][z3_slabs.c:993] SUCCESS: writing client cluster revision, clusterid: 0x0004 [01-01 08:00:02:755 TUYA D][z3_slabs.c:993] SUCCESS: writing client cluster revision, clusterid: 0x0005 WRITE ERR: ep 01 clus 0102 attr FFFD not supported [01-01 08:00:02:755 TUYA D][z3_slabs.c:990] ERR: writing client cluster revision, clusterid: 0x0102 [01-01 08:00:02:755 TUYA D][z3_slabs.c:993] SUCCESS: writing client cluster revision, clusterid: 0x0300 [01-01 08:00:02:755 TUYA D][z3_slabs.c:993] SUCCESS: writing client cluster revision, clusterid: 0x0402 [01-01 08:00:02:755 TUYA D][z3_slabs.c:993] SUCCESS: writing client cluster revision, clusterid: 0x0405 [01-01 08:00:02:755 TUYA D][z3_slabs.c:993] SUCCESS: writing client cluster revision, clusterid: 0x0406 [01-01 08:00:02:755 TUYA D][z3_slabs.c:993] SUCCESS: writing client cluster revision, clusterid: 0x0500 WRITE ERR: ep 01 clus 0502 attr FFFD not supported [01-01 08:00:02:755 TUYA D][z3_slabs.c:990] ERR: writing client cluster revision, clusterid: 0x0502 [01-01 08:00:02:755 TUYA D][z3_slabs.c:1010] SUCCESS: writing gps commissioning exit mode [01-01 08:00:02:755 TUYA D][z3_slabs.c:1027] SUCCESS: writing gps commissioning window [01-01 08:00:02:760 TUYA D][af-main-common.c:1034] 0x1a865a80x1a86598UP 0x 0 [01-01 08:00:02:764 TUYA D][callback-stub.c:3125] [emberAfRegistrationStartCallback:3125]. [01-01 08:00:02:774 TUYA D][device-table.c:550] 144 2 [01-01 08:00:02:789 TUYA D][ota-client.c:940] Bootload state: 0x1a82938 [01-01 08:00:02:789 TUYA D][ota-client.c:487] Delaying 74 seconds before starting OTA client [01-01 08:00:02:789 TUYA D][green-power-server.c:6089] Green Power Server Stack Status Callback status = 0x90 [01-01 08:00:02:789 TUYA D][callback-stub.c:932] GreenPower [emberAfGreenPowerServerUpdateInvolveTCCallback] len:932 staus:0x90 [01-01 08:00:02:789 TUYA D][callback-stub.c:3377] status = 144. [01-01 08:00:02:789 TUYA D][tuya_z3_api_tmp.c:5127] Waring: task status change: status:144. [01-01 08:00:02:809 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1011. [01-01 08:00:02:809 TUYA D][tuya_z3.c:25811] Coo ver is: 1.0.5. [01-01 08:00:02:814 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1006. [01-01 08:00:02:834 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1006. [01-01 08:00:03:320 TUYA D][lpc_db_manager.c:113] add dev:6c5005ca9f24c2b540xvlo, ip:117.2.168.192, overtime:57, active:2 [01-01 08:00:03:320 TUYA D][lan_cluster_master_core.c:1307] node [6c5005ca9f24c2b540xvlo]report. st[0] [01-01 08:00:03:320 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c5005ca9f24c2b540xvlo st:0 [01-01 08:00:03:320 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c5005ca9f24c2b540xvlo [01-01 08:00:03:320 TUYA D][lpc_db_manager.c:113] add dev:6c6c5515b325780527hx9l, ip:143.2.168.192, overtime:57, active:2 [01-01 08:00:03:321 TUYA D][lan_msg_seqno.c:153] __init is False [01-01 08:00:03:321 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:03:321 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6c5005ca9f24c2b540xvlo pos:0 [01-01 08:00:03:321 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c5005ca9f24c2b540xvlo st:0 [01-01 08:00:03:321 TUYA D][lan_dp_report_sync_master.c:329] node 6c5005ca9f24c2b540xvlo not found omit [01-01 08:00:03:321 TUYA I][lan_cluster_master_core.c:1022] node [6c5005ca9f24c2b540xvlo] ip[c0a80275] [5000] [103]join. hash map len=1 [01-01 08:00:03:321 TUYA D][lpc_db_manager.c:113] add dev:6c4ca30af981d36459nk3o, ip:142.2.168.192, overtime:57, active:2 [01-01 08:00:03:321 TUYA D][lpc_db_manager.c:113] add dev:6c0094b881e56546a7d52s, ip:121.2.168.192, overtime:57, active:2 [01-01 08:00:03:321 TUYA D][lan_cluster_master_core.c:1307] node [6c0094b881e56546a7d52s]report. st[0] [01-01 08:00:03:321 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c0094b881e56546a7d52s st:0 [01-01 08:00:03:321 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c0094b881e56546a7d52s [01-01 08:00:03:322 TUYA D][lan_msg_seqno.c:162] id not exist:6c0094b881e56546a7d52s [01-01 08:00:03:322 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:03:322 TUYA D][lpc_db_manager.c:113] add dev:6c6a927c9fe1cf0c9aui5u, ip:112.2.168.192, overtime:57, active:2 [01-01 08:00:03:322 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6c0094b881e56546a7d52s pos:1 [01-01 08:00:03:322 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c0094b881e56546a7d52s st:0 [01-01 08:00:03:322 TUYA D][lan_dp_report_sync_master.c:329] node 6c0094b881e56546a7d52s not found omit [01-01 08:00:03:322 TUYA I][lan_cluster_master_core.c:1022] node [6c0094b881e56546a7d52s] ip[c0a80279] [5000] [184]join. hash map len=2 [01-01 08:00:03:322 TUYA D][lan_cluster_master_core.c:1307] node [6c6a927c9fe1cf0c9aui5u]report. st[0] [01-01 08:00:03:322 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c6a927c9fe1cf0c9aui5u st:0 [01-01 08:00:03:322 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c6a927c9fe1cf0c9aui5u [01-01 08:00:03:322 TUYA D][lpc_db_manager.c:113] add dev:6c13b32e91fd726b8425ei, ip:9.3.168.192, overtime:57, active:2 [01-01 08:00:03:322 TUYA D][lan_msg_seqno.c:162] id not exist:6c6a927c9fe1cf0c9aui5u [01-01 08:00:03:322 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:03:322 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6c6a927c9fe1cf0c9aui5u pos:2 [01-01 08:00:03:322 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c6a927c9fe1cf0c9aui5u st:0 [01-01 08:00:03:323 TUYA D][lan_dp_report_sync_master.c:329] node 6c6a927c9fe1cf0c9aui5u not found omit [01-01 08:00:03:323 TUYA I][lan_cluster_master_core.c:1022] node [6c6a927c9fe1cf0c9aui5u] ip[c0a80270] [5000] [230]join. hash map len=3 [01-01 08:00:03:323 TUYA D][lan_cluster_master_core.c:1307] node [6c13b32e91fd726b8425ei]report. st[0] [01-01 08:00:03:323 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c13b32e91fd726b8425ei st:0 [01-01 08:00:03:323 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c13b32e91fd726b8425ei [01-01 08:00:03:323 TUYA D][lan_msg_seqno.c:162] id not exist:6c13b32e91fd726b8425ei [01-01 08:00:03:323 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:03:323 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6c13b32e91fd726b8425ei pos:3 [01-01 08:00:03:323 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c13b32e91fd726b8425ei st:0 [01-01 08:00:03:323 TUYA D][lan_dp_report_sync_master.c:329] node 6c13b32e91fd726b8425ei not found omit [01-01 08:00:03:323 TUYA D][lpc_db_manager.c:113] add dev:6c68477bf37381b524340j, ip:164.2.168.192, overtime:57, active:2 [01-01 08:00:03:323 TUYA I][lan_cluster_master_core.c:1022] node [6c13b32e91fd726b8425ei] ip[c0a80309] [8000] [2]join. hash map len=4 [01-01 08:00:03:323 TUYA D][lan_cluster_master_core.c:1307] node [6c68477bf37381b524340j]report. st[0] [01-01 08:00:03:323 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c68477bf37381b524340j st:0 [01-01 08:00:03:323 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c68477bf37381b524340j [01-01 08:00:03:323 TUYA D][lan_msg_seqno.c:162] id not exist:6c68477bf37381b524340j [01-01 08:00:03:323 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:03:323 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6c68477bf37381b524340j pos:4 [01-01 08:00:03:323 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c68477bf37381b524340j st:0 [01-01 08:00:03:323 TUYA D][lan_dp_report_sync_master.c:329] node 6c68477bf37381b524340j not found omit [01-01 08:00:03:323 TUYA D][lpc_db_manager.c:113] add dev:6c969031d409e86a781tlx, ip:157.2.168.192, overtime:57, active:2 [01-01 08:00:03:324 TUYA I][lan_cluster_master_core.c:1022] node [6c68477bf37381b524340j] ip[c0a802a4] [5000] [88]join. hash map len=5 [01-01 08:00:03:324 TUYA D][lan_cluster_master_core.c:1307] node [6c969031d409e86a781tlx]report. st[0] [01-01 08:00:03:324 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c969031d409e86a781tlx st:0 [01-01 08:00:03:324 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c969031d409e86a781tlx [01-01 08:00:03:324 TUYA D][lan_msg_seqno.c:162] id not exist:6c969031d409e86a781tlx [01-01 08:00:03:324 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:03:324 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6c969031d409e86a781tlx pos:5 [01-01 08:00:03:324 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c969031d409e86a781tlx st:0 [01-01 08:00:03:324 TUYA D][lan_dp_report_sync_master.c:329] node 6c969031d409e86a781tlx not found omit [01-01 08:00:03:324 TUYA I][lan_cluster_master_core.c:1022] node [6c969031d409e86a781tlx] ip[c0a8029d] [5000] [6]join. hash map len=6 [01-01 08:00:03:324 TUYA D][lpc_db_manager.c:113] add dev:6c79c0b9048783677fr8zk, ip:145.2.168.192, overtime:57, active:2 [01-01 08:00:03:324 TUYA D][lan_cluster_master_core.c:1307] node [6c79c0b9048783677fr8zk]report. st[0] [01-01 08:00:03:324 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c79c0b9048783677fr8zk st:0 [01-01 08:00:03:324 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c79c0b9048783677fr8zk [01-01 08:00:03:324 TUYA D][lan_msg_seqno.c:162] id not exist:6c79c0b9048783677fr8zk [01-01 08:00:03:324 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:03:325 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6c79c0b9048783677fr8zk pos:6 [01-01 08:00:03:325 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c79c0b9048783677fr8zk st:0 [01-01 08:00:03:325 TUYA D][lan_dp_report_sync_master.c:329] node 6c79c0b9048783677fr8zk not found omit [01-01 08:00:03:325 TUYA I][lan_cluster_master_core.c:1022] node [6c79c0b9048783677fr8zk] ip[c0a80291] [5000] [9]join. hash map len=7 [01-01 08:00:03:353 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a5780 94038640 [01-01 08:00:03:353 TUYA D][thread_pool_temp.c:607] temp run 0x5a5780 94038640 [01-01 08:00:03:353 TUYA D][thread_pool_temp.c:197] run temp 0x5a5780 94038640 in thread 94001420 BEGIN [01-01 08:00:03:353 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:03:353 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:03:353 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [01-01 08:00:03:353 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [01-01 08:00:03:493 TUYA D][lpc_db_manager.c:113] add dev:6cc9a0a0f9425c382btujz, ip:151.2.168.192, overtime:57, active:2 [01-01 08:00:03:493 TUYA D][lan_cluster_master_core.c:1307] node [6cc9a0a0f9425c382btujz]report. st[0] [01-01 08:00:03:493 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6cc9a0a0f9425c382btujz st:0 [01-01 08:00:03:493 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6cc9a0a0f9425c382btujz [01-01 08:00:03:493 TUYA D][lan_msg_seqno.c:162] id not exist:6cc9a0a0f9425c382btujz [01-01 08:00:03:493 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:03:493 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6cc9a0a0f9425c382btujz pos:7 [01-01 08:00:03:493 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6cc9a0a0f9425c382btujz st:0 [01-01 08:00:03:493 TUYA D][lan_dp_report_sync_master.c:329] node 6cc9a0a0f9425c382btujz not found omit [01-01 08:00:03:493 TUYA I][lan_cluster_master_core.c:1022] node [6cc9a0a0f9425c382btujz] ip[c0a80297] [5000] [5]join. hash map len=8 [01-01 08:00:03:537 TUYA D][tuya_z3.c:28678] tuya_z3_init status: 2, isUg=0 [01-01 08:00:03:537 TUYA I][tuya_z3.c:28721] tuya msg init end: 2. [01-01 08:00:03:537 TUYA I][uni_thread.c:220] thread_create name:heartbeat,stackDepth:2048,totalstackDepth:133632,priority:3 [01-01 08:00:03:537 TUYA D][tuya_iot_sdk_user_api.c:283] tuya user srv start [01-01 08:00:03:537 TUYA I][uni_thread.c:220] thread_create name:ncp_ver_upload,stackDepth:1024,totalstackDepth:134656,priority:4 [01-01 08:00:03:537 TUYA D][uni_thread.c:247] Thread:ncp_ver_upload Exec Start. Set to Running Stat [01-01 08:00:03:537 TUYA D][tuya_z3.c:28761] tuya_z3_init status: 2, isUg=0 [01-01 08:00:03:537 TUYA D][tuya_z3.c:28848] Zigbee COO ver is: 1.0.5. [01-01 08:00:03:537 TUYA D][tuya_z3.c:29262] COO cur version 1.0.5. [01-01 08:00:03:537 TUYA D][tuya_z3.c:29263] COO valid version 1.0.9. [01-01 08:00:03:537 TUYA D][tuya_z3.c:29283] cur_ver[0]:1,valid_ver[0]:1. [01-01 08:00:03:537 TUYA D][tuya_z3.c:29283] cur_ver[1]:0,valid_ver[1]:0. [01-01 08:00:03:537 TUYA D][tuya_z3.c:29283] cur_ver[2]:5,valid_ver[2]:9. [01-01 08:00:03:538 TUYA E][tuya_z3.c:29285] COO version is less than valid ver:1.0.9 [01-01 08:00:03:538 TUYA E][tuya_z3.c:29338] ncp ver invalid. [01-01 08:00:03:538 TUYA D][tuya_iot_sdk_user_api.c:147] ncp tp: 3, version: 1.0.5 [01-01 08:00:03:538 TUYA D][uni_thread.c:247] Thread:heartbeat Exec Start. Set to Running Stat [01-01 08:00:03:538 TUYA D][subdev_hb_ol.c:891] start hb process... [01-01 08:00:03:538 TUYA D][uni_thread.c:307] Del Thrd:ncp_ver_upload [01-01 08:00:03:543 TUYA D][tuya_z3_api_tmp.c:7274] centralizedNetwork = 1. [01-01 08:00:03:543 TUYA D][tuya_z3_api_tmp.c:7275] panId = 0x2345. [01-01 08:00:03:543 TUYA D][tuya_z3_api_tmp.c:7276] radioTxPower = 6. [01-01 08:00:03:543 TUYA D][tuya_z3_api_tmp.c:7277] channel = 0xb. [01-01 08:00:03:543 TUYA D][tuya_z3_api_tmp.c:7278] isAuto = true. [01-01 08:00:03:543 TUYA D][tuya_z3_api_tmp.c:7279] cca_grade = 2. [01-01 08:00:03:566 TUYA D][tuya_z3_api_tmp.c:5492] Success, leaving net work. [01-01 08:00:03:637 TUYA D][tuya_z3.c:28776] tuya_z3_init status2: 2. [01-01 08:00:03:638 TUYA D][tuya_z3.c:28761] tuya_z3_init status: 3, isUg=0 [01-01 08:00:03:759 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:03:759 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:03:759 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:03:759 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:04:238 TUYA D][uni_thread.c:265] Thread:ncp_ver_upload Exec Finish. Set to Del Stat [01-01 08:00:04:238 TUYA D][uni_thread.c:125] del list not empty...deleting [01-01 08:00:04:238 TUYA D][uni_thread.c:132] Final Free Thread:ncp_ver_upload, is_self:1 [01-01 08:00:04:238 TUYA D][uni_thread.c:138] delay to delete thread self [01-01 08:00:04:238 TUYA D][uni_thread.c:149] finally delete thread self [01-01 08:00:04:309 TUYA D][lpc_db_manager.c:113] add dev:6ca44bf75a687b0aecgwuy, ip:156.2.168.192, overtime:58, active:2 [01-01 08:00:04:309 TUYA D][lan_cluster_master_core.c:1307] node [6ca44bf75a687b0aecgwuy]report. st[0] [01-01 08:00:04:309 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6ca44bf75a687b0aecgwuy st:0 [01-01 08:00:04:309 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6ca44bf75a687b0aecgwuy [01-01 08:00:04:309 TUYA D][lan_msg_seqno.c:162] id not exist:6ca44bf75a687b0aecgwuy [01-01 08:00:04:309 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:04:309 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6ca44bf75a687b0aecgwuy pos:8 [01-01 08:00:04:309 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6ca44bf75a687b0aecgwuy st:0 [01-01 08:00:04:309 TUYA D][lan_dp_report_sync_master.c:329] node 6ca44bf75a687b0aecgwuy not found omit [01-01 08:00:04:310 TUYA I][lan_cluster_master_core.c:1022] node [6ca44bf75a687b0aecgwuy] ip[c0a8029c] [5000] [20]join. hash map len=9 [01-01 08:00:04:355 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a5780 94038640 [01-01 08:00:04:355 TUYA D][thread_pool_temp.c:607] temp run 0x5a5780 94038640 [01-01 08:00:04:355 TUYA D][thread_pool_temp.c:197] run temp 0x5a5780 94038640 in thread 94001420 BEGIN [01-01 08:00:04:355 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:04:355 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:04:355 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [01-01 08:00:04:355 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [01-01 08:00:04:429 TUYA D][lpc_db_manager.c:113] add dev:eb6ecb092720943cd7nfla, ip:84.2.168.192, overtime:58, active:2 [01-01 08:00:04:429 TUYA D][lan_cluster_master_core.c:1307] node [eb6ecb092720943cd7nfla]report. st[0] [01-01 08:00:04:429 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node eb6ecb092720943cd7nfla st:0 [01-01 08:00:04:429 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:eb6ecb092720943cd7nfla [01-01 08:00:04:429 TUYA D][lan_msg_seqno.c:162] id not exist:eb6ecb092720943cd7nfla [01-01 08:00:04:429 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:04:429 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:eb6ecb092720943cd7nfla pos:9 [01-01 08:00:04:429 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node eb6ecb092720943cd7nfla st:0 [01-01 08:00:04:429 TUYA D][lan_dp_report_sync_master.c:329] node eb6ecb092720943cd7nfla not found omit [01-01 08:00:04:429 TUYA I][lan_cluster_master_core.c:1022] node [eb6ecb092720943cd7nfla] ip[c0a80254] [5000] [6]join. hash map len=10 [01-01 08:00:04:488 TUYA D][af-main-common.c:1072] 0x1a865a80x1a86598DOWN [01-01 08:00:04:507 TUYA D][callback-stub.c:3097] [emberAfRegistrationAbortCallback:3097]. [01-01 08:00:04:511 TUYA D][concentrator-support.c:271] Clearing source route table. [01-01 08:00:04:516 TUYA D][device-table.c:550] 145 0 [01-01 08:00:04:520 TUYA D][device-table.c:554] DeviceTable: Clear State [01-01 08:00:04:520 TUYA D][device-table.c:559] Will clear dev table. [01-01 08:00:04:521 TUYA D][device-table.c:774] wirite /userdata/devices1.txt. fileFlag is 0 part:1,bit:0,fileFlag is 1 [01-01 08:00:04:521 TUYA D][callback-stub.c:1836] [emberAfPluginDeviceTableClearedCallback:1836]. [01-01 08:00:04:521 TUYA D][green-power-server.c:6089] Green Power Server Stack Status Callback status = 0x91 [01-01 08:00:04:530 TUYA D][callback-stub.c:932] GreenPower [emberAfGreenPowerServerUpdateInvolveTCCallback] len:932 staus:0x91 [01-01 08:00:04:607 TUYA D][callback-stub.c:3377] status = 145. [01-01 08:00:04:607 TUYA D][tuya_z3_api_tmp.c:5127] Waring: task status change: status:145. [01-01 08:00:04:675 TUYA N][z3_slabs.c:147] nodeEuiStr = 04cd15fffefda080. [01-01 08:00:04:675 TUYA N][z3_slabs.c:148] nodeId = 0xfffe. [01-01 08:00:04:675 TUYA N][z3_slabs.c:149] panId = 0x2a8c. [01-01 08:00:04:675 TUYA N][z3_slabs.c:150] channel = 0x19. [01-01 08:00:04:675 TUYA N][z3_slabs.c:151] ver = 1.0.5. [01-01 08:00:04:675 TUYA N][z3_slabs.c:152] netStatus = 0x00. [01-01 08:00:04:675 TUYA N][z3_slabs.c:153] extendedPanId: fe4e160b00b16c36 [01-01 08:00:04:675 TUYA N][z3_slabs.c:154] manufacturerId: 0x0002 [01-01 08:00:04:675 TUYA N][z3_slabs.c:160] netWorkKey: e4 c8 68 fd 45 24 33 b7 73 67 3b e3 09 de c8 54 [01-01 08:00:04:680 TUYA D][z3_slabs.c:170] Get Tx radio power error. [01-01 08:00:04:680 TUYA D][z3_custom_frame.c:104] set ncp CCA mask to 0xE6 [01-01 08:00:04:685 TUYA D][z3_custom_frame.c:109] ezspCustomFrame error. [01-01 08:00:04:685 TUYA D][tuya_z3_api_tmp.c:5520] Success, joining net work. [01-01 08:00:04:762 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:04:762 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:04:762 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:04:762 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:05:21 TUYA D][lpc_db_manager.c:113] add dev:6c22f40a1acb1885b59qaq, ip:229.3.168.192, overtime:58, active:2 [01-01 08:00:05:21 TUYA D][lan_cluster_master_core.c:1307] node [6c22f40a1acb1885b59qaq]report. st[0] [01-01 08:00:05:21 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c22f40a1acb1885b59qaq st:0 [01-01 08:00:05:21 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c22f40a1acb1885b59qaq [01-01 08:00:05:21 TUYA D][lan_msg_seqno.c:162] id not exist:6c22f40a1acb1885b59qaq [01-01 08:00:05:21 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:05:21 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6c22f40a1acb1885b59qaq pos:10 [01-01 08:00:05:21 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c22f40a1acb1885b59qaq st:0 [01-01 08:00:05:21 TUYA D][lan_dp_report_sync_master.c:329] node 6c22f40a1acb1885b59qaq not found omit [01-01 08:00:05:21 TUYA I][lan_cluster_master_core.c:1022] node [6c22f40a1acb1885b59qaq] ip[c0a803e5] [8000] [1]join. hash map len=11 [01-01 08:00:05:317 TUYA D][lpc_db_manager.c:113] add dev:eb1552c6f83a6b59edmyes, ip:106.3.168.192, overtime:59, active:2 [01-01 08:00:05:337 TUYA I][lan_cluster_master_core.c:790] __timer_proc_master_wait. send_cnt[0] [01-01 08:00:05:337 TUYA D][lan_cluster_master_confirm.c:231] Create UDP Socket To Broadcast master confirm [01-01 08:00:05:357 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a5780 94038640 [01-01 08:00:05:357 TUYA D][thread_pool_temp.c:607] temp run 0x5a5780 94038640 [01-01 08:00:05:357 TUYA D][thread_pool_temp.c:197] run temp 0x5a5780 94038640 in thread 94001420 BEGIN [01-01 08:00:05:358 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:05:358 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:05:358 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [01-01 08:00:05:358 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [01-01 08:00:05:780 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:05:780 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:05:780 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:05:780 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:06:358 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a5780 94038640 [01-01 08:00:06:359 TUYA D][thread_pool_temp.c:607] temp run 0x5a5780 94038640 [01-01 08:00:06:359 TUYA D][thread_pool_temp.c:197] run temp 0x5a5780 94038640 in thread 94001420 BEGIN [01-01 08:00:06:359 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:06:359 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:06:359 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [01-01 08:00:06:359 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [01-01 08:00:06:783 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:06:783 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:06:783 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:06:783 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:07:105 TUYA D][callback-stub.c:2196] RealRandomNum:0x59db. [01-01 08:00:07:200 TUYA D][network-creator-security.c:254] 0x1a7ffe8: 0x1a80058: 0x0 [01-01 08:00:07:220 TUYA D][network-creator.c:328] 0x1a80ec0: Form. Channel: 25. Status: 0x0 [01-01 08:00:07:220 TUYA D][callback-stub.c:2182] [emberAfPluginNetworkCreatorCompleteCallback:2182]. [01-01 08:00:07:220 TUYA D][network-creator.c:484] 0x1a80ec0: Stop. Status: 0x0. State: 0x0 [01-01 08:00:07:240 TUYA D][af-main-common.c:1034] 0x1a865a80x1a86598UP 0x 0 [01-01 08:00:07:245 TUYA D][callback-stub.c:3125] [emberAfRegistrationStartCallback:3125]. [01-01 08:00:07:254 TUYA D][device-table.c:550] 144 2 [01-01 08:00:07:269 TUYA D][green-power-server.c:6089] Green Power Server Stack Status Callback status = 0x90 [01-01 08:00:07:269 TUYA D][callback-stub.c:932] GreenPower [emberAfGreenPowerServerUpdateInvolveTCCallback] len:932 staus:0x90 [01-01 08:00:07:269 TUYA D][callback-stub.c:3377] status = 144. [01-01 08:00:07:269 TUYA D][tuya_z3_api_tmp.c:5127] Waring: task status change: status:144. [01-01 08:00:07:279 TUYA D][tuya_z3_api_tmp.c:5532] Success, joined net work. [01-01 08:00:07:322 TUYA N][z3_slabs.c:147] nodeEuiStr = 04cd15fffefda080. [01-01 08:00:07:322 TUYA N][z3_slabs.c:148] nodeId = 0x0000. [01-01 08:00:07:322 TUYA N][z3_slabs.c:149] panId = 0x59db. [01-01 08:00:07:322 TUYA N][z3_slabs.c:150] channel = 0x19. [01-01 08:00:07:322 TUYA N][z3_slabs.c:151] ver = 1.0.5. [01-01 08:00:07:322 TUYA N][z3_slabs.c:152] netStatus = 0x02. [01-01 08:00:07:322 TUYA N][z3_slabs.c:153] extendedPanId: 7fbaddda5c2e2693 [01-01 08:00:07:322 TUYA N][z3_slabs.c:154] manufacturerId: 0x0002 [01-01 08:00:07:322 TUYA N][z3_slabs.c:160] netWorkKey: 7f 28 8e 31 66 fb c2 82 88 80 c2 e2 81 3d 08 59 [01-01 08:00:07:327 TUYA D][z3_slabs.c:166] Get radion info: page [0] chan [25] pwr [13]. [01-01 08:00:07:327 TUYA D][tuya_z3_api_tmp.c:5558] Will save network info. [01-01 08:00:07:327 TUYA D][trust_center_swap_out_callbacks.c:1432] Storing node information and security data. [01-01 08:00:07:327 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1003. [01-01 08:00:07:327 TUYA D][tuya_z3.c:27085] nodeEuiStr = 04cd15fffefda080. [01-01 08:00:07:327 TUYA D][tuya_z3.c:27086] nodeId = 0x0000. [01-01 08:00:07:327 TUYA D][tuya_z3.c:27087] panId = 0x59db. [01-01 08:00:07:327 TUYA D][tuya_z3.c:27088] channel = 0x19. [01-01 08:00:07:327 TUYA D][tuya_z3.c:27089] ver = 1.0.5. [01-01 08:00:07:327 TUYA D][tuya_z3.c:27090] netStatus = 0x03. [01-01 08:00:07:327 TUYA D][tuya_z3.c:27091] manufacturerID = 0x0002. [01-01 08:00:07:327 TUYA D][tuya_z3.c:27092] netWorkKey: 7f 28 8e 31 66 fb c2 82 88 80 c2 e2 81 3d 08 59 [01-01 08:00:07:341 TUYA D][simplekv.c:1211] read key:lgw_nkey isFuzzy:0 skipCnt:0 [01-01 08:00:07:341 TUYA D][simplekv.c:1251] find key:5 lgw_nkey [01-01 08:00:07:341 TUYA D][simplekv.c:1280] key:lgw_nkey find value.Len:144 [01-01 08:00:07:341 TUYA D][simplekv.c:374] write key:lgw_nkey And Value Len:144 [01-01 08:00:07:341 TUYA D][simplekv.c:397] 5 key same AND size old 212 >= new 144 [01-01 08:00:07:341 TUYA D][simplekv.c:430] find 5 available space [01-01 08:00:07:341 TUYA D][simplekv.c:474] reuse available space 29968 [01-01 08:00:07:341 TUYA D][simplekv.c:203] update crc 4220174323 [01-01 08:00:07:357 TUYA D][simplekv.c:359] write head to normal file success [01-01 08:00:07:357 TUYA D][simplekv.c:520] write success [01-01 08:00:07:357 TUYA D][tuya_z3.c:28822] tuya_z3_init end: 9. [01-01 08:00:07:357 TUYA D][tuya_encrypt.c:734] now sync_normal_time:+3593s time:+4807s [01-01 08:00:07:357 TUYA D][rex_lock_encrypt.c:923] now sync_normal_time:+3593s time:+4502s [01-01 08:00:07:357 TUYA D][tuya_reliable_fingerprint.c:429] now sync_normal_time:+3593s uni_time_get_posix:+4502s [01-01 08:00:07:357 TUYA D][thread_pool.c:393] thread type:2 idx:1 md:18 name:trd_dev_del [01-01 08:00:07:357 TUYA D][thread_pool.c:431] get thread 2 trd_dev_del ret:0x7fa11937d8 [01-01 08:00:07:357 TUYA D][tuya_z3.c:27570] country code:, region:AZ. [01-01 08:00:07:357 TUYA D][heart_work_queue.c:22] init heart work queue. stack size:2560 pro:3 num:1 [01-01 08:00:07:357 TUYA I][uni_thread.c:220] thread_create name:wk_th-0,stackDepth:2560,totalstackDepth:137216,priority:3 [01-01 08:00:07:357 TUYA D][heart_work_queue.c:27] heart work queue create success [01-01 08:00:07:358 TUYA D][uni_thread.c:247] Thread:wk_th-0 Exec Start. Set to Running Stat [01-01 08:00:07:359 TUYA D][trust_center_swap_out_callbacks.c:403] networkFC: 0x69001 [01-01 08:00:07:359 TUYA D][trust_center_swap_out_callbacks.c:1439] Placing data in file [01-01 08:00:07:359 TUYA D][trust_center_swap_out_callbacks.c:1442] Error:tuya_saveTcBackupToFile. [01-01 08:00:07:360 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a5780 94038640 [01-01 08:00:07:360 TUYA D][thread_pool_temp.c:607] temp run 0x5a5780 94038640 [01-01 08:00:07:361 TUYA D][thread_pool_temp.c:197] run temp 0x5a5780 94038640 in thread 94001420 BEGIN [01-01 08:00:07:361 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:07:361 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a69a0 94029010 [01-01 08:00:07:361 TUYA D][thread_pool_temp.c:607] temp run 0x5a69a0 94029010 [01-01 08:00:07:361 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:07:361 TUYA D][thread_pool_temp.c:214] num:2 to exe [01-01 08:00:07:361 TUYA D][thread_pool_temp.c:197] run temp 0x5a69a0 94029010 in thread 94001420 BEGIN [01-01 08:00:07:361 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:07:361 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:07:361 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [01-01 08:00:07:361 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [01-01 08:00:07:383 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle. READ_ATTR: clus 0000 OTA READ: ep:01 cid:0000 attid:0001 msk:40 mfcode:0000 READ: clus 0000, attr 0001 failed 86 [01-01 08:00:07:416 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle. [01-01 08:00:07:416 TUYA D][callback-stub.c:3008] emberAfDeviceTableGetEui64FromNodeId. [01-01 08:00:07:591 TUYA D][callback-stub.c:3012] emberAfDeviceTableGetEui64FromNodeId. [01-01 08:00:07:591 TUYA D][callback-stub.c:3019] Waring: Don't find device tabls in ReadAttributesResponse. [01-01 08:00:07:601 TUYA D][callback-stub.c:1331] Waring: Don't find device tabls, data don't handle. [01-01 08:00:07:601 TUYA D][callback-stub.c:2766] NodeId:0x0, LastHopRssi:0, LastHopLqi:255. [01-01 08:00:07:601 TUYA D][device-table-discovery.c:1295] ZDOMessageReceived node id:0x0000 ,cluster:0x8001 [01-01 08:00:07:601 TUYA D][device-table-discovery.c:1343] IEEE_ADDRESS_RESPONSE [01-01 08:00:07:601 TUYA D][device-table-discovery.c:1345] Ieee source node 0x0000 [01-01 08:00:07:601 TUYA D][device-table-discovery.c:994] NewDeviceJoinHandler, node: 0x0000, eui64:04cd15fffefda080 [01-01 08:00:07:602 TUYA D][device-table-discovery.c:1027] Net is closed. [01-01 08:00:07:602 TUYA D][ias-zone-client.c:624] Incoming ZDO, Cluster: 0x8001 [01-01 08:00:07:612 TUYA D][af-main-common.c:931] Nodeid:0x0000, clusterId:0x0001, SUCCESS: tx 0. [01-01 08:00:07:612 TUYA D][callback-stub.c:1331] Waring: Don't find device tabls, data don't handle. [01-01 08:00:07:729 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyaus.com, prio 0 [01-01 08:00:07:729 TUYA D][uni_network.c:188] use dns service to get ip for domain m2.tuyaus.com [01-01 08:00:07:730 TUYA D][iot_httpc.c:1715] dns_query:https://h2.iot-dns.com/v1/dns_query [{"domain":"m2.tuyaus.com"}] [01-01 08:00:07:730 TUYA D][tuya_tls.c:372] tls register constant 6ce871309d48c48f XFT83ZB1amWW83hDEg19M7lKxuf1YmG8 UvhspcVqKpqBDpnJXVn9xlBvxJzs93rlE4DTV [01-01 08:00:07:730 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443 -->> [01-01 08:00:07:730 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0 [01-01 08:00:07:730 TUYA D][uni_network.c:167] use static dns ip 34.214.145.236 for domain h2.iot-dns.com [01-01 08:00:07:730 TUYA D][httpc.c:477] ----got ipaddr:34,214,145,236 [01-01 08:00:08:301 TUYA D][lpc_db_manager.c:113] add dev:6c214989a443b2dd90a4or, ip:158.2.168.192, overtime:62, active:2 [01-01 08:00:08:301 TUYA D][lan_cluster_master_core.c:1307] node [6c214989a443b2dd90a4or]report. st[0] [01-01 08:00:08:301 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c214989a443b2dd90a4or st:0 [01-01 08:00:08:301 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c214989a443b2dd90a4or [01-01 08:00:08:301 TUYA D][lan_msg_seqno.c:162] id not exist:6c214989a443b2dd90a4or [01-01 08:00:08:301 TUYA I][lan_msg_reliable_trans_master.c:461] send seq:1 recv seq:0 [01-01 08:00:08:301 TUYA D][lan_msg_reliable_trans_master.c:650] lan_msg_add_peer_node id:6c214989a443b2dd90a4or pos:11 [01-01 08:00:08:301 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c214989a443b2dd90a4or st:0 [01-01 08:00:08:302 TUYA D][lan_dp_report_sync_master.c:329] node 6c214989a443b2dd90a4or not found omit [01-01 08:00:08:302 TUYA I][lan_cluster_master_core.c:1022] node [6c214989a443b2dd90a4or] ip[c0a8029e] [5000] [9]join. hash map len=12 [01-01 08:00:08:362 TUYA D][tuya_z3_api_tmp.c:7290] uTimeVal = 0. [01-01 08:00:08:362 TUYA D][tuya_z3_api_tmp.c:7293] join diable. [01-01 08:00:08:362 TUYA D][z3_slabs.c:1040] tuya config net status: 0. [01-01 08:00:08:362 TUYA D][green-power-server.c:3323] ====== emberAfGreenPowerClusterGpSinkCommissioningModeCallback ====== [01-01 08:00:08:362 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a5780 94038640 [01-01 08:00:08:362 TUYA D][thread_pool_temp.c:607] temp run 0x5a5780 94038640 [01-01 08:00:08:362 TUYA D][thread_pool_temp.c:197] run temp 0x5a5780 94038640 in thread 94001420 BEGIN [01-01 08:00:08:362 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:08:362 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:08:362 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [01-01 08:00:08:362 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [01-01 08:00:08:375 TUYA D][green-power-server.c:3444] SinkCommissioningModeCallbacksend returned 0 [01-01 08:00:08:380 TUYA D][af-main-common.c:698] pJoin for 0 sec: 0x0 [01-01 08:00:08:385 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443 --<< ,r:0 [01-01 08:00:08:385 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:08:385 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect h2.iot-dns.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:08:385 TUYA D][tuya_tls.c:1360] load tuya cert. [01-01 08:00:08:385 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [01-01 08:00:08:385 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [01-01 08:00:08:385 TUYA D][tuya_iot_com_api.c:271] tuya iot dns [01-01 08:00:08:385 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [01-01 08:00:08:388 TUYA D][callback-stub.c:2766] NodeId:0x0, LastHopRssi:0, LastHopLqi:255. [01-01 08:00:08:388 TUYA D][callback-stub.c:2614] Revice Green Power cmd [01-01 08:00:08:388 TUYA D][tuya_z3_api_tmp.c:5010] Command recevice is green power [01-01 08:00:08:388 TUYA D][tuya_z3_api_tmp.c:5012] greenpower cmd:0x02, not ZCL_GP_NOTIFICATION_COMMAND_ID [01-01 08:00:08:388 TUYA D][green-power-client.c:98] Exit comm for sink 0 [01-01 08:00:08:394 TUYA D][af-main-common.c:931] Nodeid:0x0000, clusterId:0x0021, SUCCESS: tx 0. [01-01 08:00:08:394 TUYA D][callback-stub.c:1331] Waring: Don't find device tabls, data don't handle. [01-01 08:00:08:458 TUYA D][tuya_z3.c:13549] g_tyz3Globals.permit:0. [01-01 08:00:08:640 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle. READ_ATTR: clus 0000 OTA READ: ep:01 cid:0000 attid:0001 msk:40 mfcode:0000 READ: clus 0000, attr 0001 failed 86 [01-01 08:00:08:673 TUYA D][callback-stub.c:2646] NodeId is 0x0000, Don't handle. [01-01 08:00:08:673 TUYA D][callback-stub.c:3008] emberAfDeviceTableGetEui64FromNodeId. [01-01 08:00:08:843 TUYA D][callback-stub.c:3012] emberAfDeviceTableGetEui64FromNodeId. [01-01 08:00:08:843 TUYA D][callback-stub.c:3019] Waring: Don't find device tabls in ReadAttributesResponse. [01-01 08:00:08:854 TUYA D][callback-stub.c:1331] Waring: Don't find device tabls, data don't handle. [01-01 08:00:08:854 TUYA D][callback-stub.c:2766] NodeId:0x0, LastHopRssi:0, LastHopLqi:255. [01-01 08:00:08:854 TUYA D][device-table-discovery.c:1295] ZDOMessageReceived node id:0x0000 ,cluster:0x8001 [01-01 08:00:08:854 TUYA D][device-table-discovery.c:1343] IEEE_ADDRESS_RESPONSE [01-01 08:00:08:854 TUYA D][device-table-discovery.c:1345] Ieee source node 0x0000 [01-01 08:00:08:854 TUYA D][device-table-discovery.c:994] NewDeviceJoinHandler, node: 0x0000, eui64:04cd15fffefda080 [01-01 08:00:08:854 TUYA D][device-table-discovery.c:1027] Net is closed. [01-01 08:00:08:854 TUYA D][ias-zone-client.c:624] Incoming ZDO, Cluster: 0x8001 [01-01 08:00:08:865 TUYA D][af-main-common.c:931] Nodeid:0x0000, clusterId:0x0001, SUCCESS: tx 0. [01-01 08:00:08:865 TUYA D][callback-stub.c:1331] Waring: Don't find device tabls, data don't handle. [01-01 08:00:08:888 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:08:889 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:08:889 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:08:889 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:08:889 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:08:889 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:08:889 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:08:889 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:09:311 TUYA D][af-main-common.c:931] Nodeid:0xfffc, clusterId:0x0036, SUCCESS: tx 0. [01-01 08:00:09:364 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a5780 94038640 [01-01 08:00:09:365 TUYA D][thread_pool_temp.c:607] temp run 0x5a5780 94038640 [01-01 08:00:09:365 TUYA D][thread_pool_temp.c:197] run temp 0x5a5780 94038640 in thread 94001420 BEGIN [01-01 08:00:09:365 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:09:365 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:09:365 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [01-01 08:00:09:365 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [01-01 08:00:09:466 TUYA D][tuya_z3.c:29127] Not have WAN internet, so don't post channel [01-01 08:00:09:848 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:09:848 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:09:848 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:09:848 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:10:347 TUYA I][lan_cluster_master_core.c:790] __timer_proc_master_wait. send_cnt[1] [01-01 08:00:10:367 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a5780 94038640 [01-01 08:00:10:367 TUYA D][thread_pool_temp.c:607] temp run 0x5a5780 94038640 [01-01 08:00:10:367 TUYA D][thread_pool_temp.c:197] run temp 0x5a5780 94038640 in thread 94001420 BEGIN [01-01 08:00:10:367 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:10:367 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:10:367 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [01-01 08:00:10:367 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [01-01 08:00:10:422 TUYA D][tuya_tls.c:1520] handshake finish for h2.iot-dns.com. set send/recv to user set [01-01 08:00:10:422 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect h2.iot-dns.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:10:833 TUYA D][iot_httpc.c:678] return chunked:0 [01-01 08:00:10:833 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [01-01 08:00:10:833 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [01-01 08:00:10:833 TUYA D][uni_network.c:100] get ip 54.188.99.4 [01-01 08:00:10:833 TUYA D][uni_network.c:197] dns service get ip 54.188.99.4 for domain m2.tuyaus.com [01-01 08:00:10:833 TUYA D][uni_network.c:268] cache dns [m2.tuyaus.com]<->[54.188.99.4] [01-01 08:00:10:833 TUYA D][mqtt_client.c:1400] select mqtt host:m2.tuyaus.com [01-01 08:00:10:833 TUYA N][mqtt_client.c:1421] mqtt get serve ip success [01-01 08:00:10:833 TUYA D][mqtt_client.c:931] serverIP 918315780 port:8883 [01-01 08:00:10:850 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:10:850 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:10:850 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:10:850 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:11:58 TUYA D][mqtt_client.c:956] mqtt over TLS is enabled. Host:m2.tuyaus.com Port:8883 [01-01 08:00:11:58 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:11:58 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect m2.tuyaus.com:8883 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:11:58 TUYA D][tuya_tls.c:1360] load tuya cert. [01-01 08:00:11:58 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [01-01 08:00:11:59 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [01-01 08:00:11:59 TUYA D][tuya_iot_com_api.c:247] tuya public url [01-01 08:00:11:59 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [01-01 08:00:11:369 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a5780 94038640 [01-01 08:00:11:369 TUYA D][thread_pool_temp.c:607] temp run 0x5a5780 94038640 [01-01 08:00:11:369 TUYA D][thread_pool_temp.c:197] run temp 0x5a5780 94038640 in thread 94001420 BEGIN [01-01 08:00:11:370 TUYA D][thread_pool_temp.c:200] thread 94001420 END [01-01 08:00:11:370 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [01-01 08:00:11:370 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [01-01 08:00:11:370 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [01-01 08:00:11:685 TUYA D][tuya_tls.c:1520] handshake finish for m2.tuyaus.com. set send/recv to user set [01-01 08:00:11:685 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect m2.tuyaus.com:8883 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:11:686 TUYA N][mqtt_client.c:1459] mqtt create success, begin to connect [01-01 08:00:11:686 TUYA D][mqc_app.c:308] TLS Mode:4 [01-01 08:00:11:853 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:11:853 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:11:853 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:11:853 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:11:900 TUYA D][mqtt_client.c:1341] cnt 1 [01-01 08:00:12:115 TUYA D][mqtt_client.c:1046] mqtt subscribe success [01-01 08:00:12:115 TUYA D][mqc_app.c:728] mqtt connect success [01-01 08:00:12:115 TUYA D][tuya_ctrl_mqc.c:570] mqtt connect [01-01 08:00:12:116 TUYA D][tuya_ctrl_mqc.c:403] unsubscribe topic cnt:32 [01-01 08:00:12:116 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[0]:smart/mb/in/eb257c7e0da82bf6fdgo2g. [01-01 08:00:12:116 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[1]:smart/mb/in/eb99a9cc76209358a4crkr. [01-01 08:00:12:116 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[2]:smart/mb/in/eb67a0efcb59444d01ydgn. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[3]:smart/mb/in/ebe7f7541d3a5e34dcplwr. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[4]:smart/mb/in/eb62263aaf2f73ef03xira. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[5]:smart/mb/in/ebb800d543876b9d83jiah. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[6]:smart/mb/in/ebc78c65e28bc1347ac761. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[7]:smart/mb/in/eb3b1fefe57125bb72nrzb. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[8]:smart/mb/in/eb76889250a9917161wng9. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[9]:smart/mb/in/ebf8fee6f4298432a5eqvk. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[10]:smart/mb/in/ebaf2b250cb41e058ekxqm. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[11]:smart/mb/in/eb9c17916f715a30e0a7mz. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[12]:smart/mb/in/vdevo166201192349972. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[13]:smart/mb/in/eb62f037dd6640bfa41gut. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[14]:smart/mb/in/eb4576f5222b16dccaaazi. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[15]:smart/mb/in/ebb063750d514d878079mw. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[16]:smart/mb/in/eba407ffd4d23748c3rlsw. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[17]:smart/mb/in/eb0058bee16ce0c70aq9nj. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[18]:smart/mb/in/eb68d8dbe4707224e8sxd8. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[19]:smart/mb/in/ebe3006b0f14083917oh1d. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[20]:smart/mb/in/vdevo166098193021398. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[21]:smart/mb/in/eb3cfb587e6d81417eac8e. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[22]:smart/mb/in/ebb4f72bc0eb72ac62dhlo. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[23]:smart/mb/in/ebc90e9813ffde4148tcvg. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[24]:smart/mb/in/eb631bd9b6590e001blfgs. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[25]:smart/mb/in/eba528413f6980a463pn4p. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[26]:smart/mb/in/vdevo166004655924109. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[27]:smart/mb/in/eb21cdbd5e05e8e428gaca. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[28]:smart/mb/in/eb2372042e64f76e79f3jk. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[29]:smart/mb/in/ebd1ebe54febaa9c022vqf. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[30]:smart/mb/in/eb827d57cf10b04d2fxtij. [01-01 08:00:12:117 TUYA D][tuya_ctrl_mqc.c:416] unsubscribe topic[31]:smart/mb/in/eba19ee51b778585c0jcy3. [01-01 08:00:12:117 TUYA D][tuya_ctrl_center.c:2135] sync delay: 100 ms [01-01 08:00:12:118 TUYA D][tuya_ctrl_center.c:2308] dev ability is {"devId":"eb1552c6f83a6b59edmyes","value":"{\"device_list_show_rules\":\"{\\\"supportQuickSwitch\\\":true,\\\"supportDpType\\\":\\\"standard\\\",\\\"supportCategoryList\\\":[\\\"kg\\\",\\\"cz\\\",\\\"dj\\\",\\\"cl\\\",\\\"kt\\\",\\\"lyj\\\",\\\"wk\\\",\\\"pir\\\",\\\"mcs\\\",\\\"sj\\\",\\\"wsdcg\\\",\\\"rqbj\\\",\\\"sos\\\",\\\"dgnbj\\\",\\\"xfj\\\",\\\"pc\\\",\\\"xxj\\\",\\\"jsq\\\",\\\"rs\\\",\\\"tgkg\\\",\\\"kj\\\"]}\",\"scene_switch_support\":false,\"mesh_subscriber_support\":true}"} [01-01 08:00:12:118 TUYA D][iot_httpc.c:929] Post Data: {"devId":"eb1552c6f83a6b59edmyes","value":"{\"device_list_show_rules\":\"{\\\"supportQuickSwitch\\\":true,\\\"supportDpType\\\":\\\"standard\\\",\\\"supportCategoryList\\\":[\\\"kg\\\",\\\"cz\\\",\\\"dj\\\",\\\"cl\\\",\\\"kt\\\",\\\"lyj\\\",\\\"wk\\\",\\\"pir\\\",\\\"mcs\\\",\\\"sj\\\",\\\"wsdcg\\\",\\\"rqbj\\\",\\\"sos\\\",\\\"dgnbj\\\",\\\"xfj\\\",\\\"pc\\\",\\\"xxj\\\",\\\"jsq\\\",\\\"rs\\\",\\\"tgkg\\\",\\\"kj\\\"]}\",\"scene_switch_support\":false,\"mesh_subscriber_support\":true}","t":12} [01-01 08:00:12:118 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.screen.device.ability.report&devId=eb1552c6f83a6b59edmyes&et=1&t=12&v=1.0&sign=db3b2e26a31ffc438c9cd12dfaa8ac7f [01-01 08:00:12:118 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [01-01 08:00:12:118 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [01-01 08:00:12:118 TUYA D][uni_network.c:188] use dns service to get ip for domain a2.tuyaus.com [01-01 08:00:12:118 TUYA D][iot_httpc.c:1715] dns_query:https://h2.iot-dns.com/v1/dns_query [{"domain":"a2.tuyaus.com"}] [01-01 08:00:12:118 TUYA D][tuya_tls.c:372] tls register constant 6ce871309d48c48f XFT83ZB1amWW83hDEg19M7lKxuf1YmG8 UvhspcVqKpqBDpnJXVn9xlBvxJzs93rlE4DTV [01-01 08:00:12:118 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443 -->> [01-01 08:00:12:118 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0 [01-01 08:00:12:118 TUYA D][uni_network.c:167] use static dns ip 35.155.166.214 for domain h2.iot-dns.com [01-01 08:00:12:118 TUYA D][httpc.c:477] ----got ipaddr:35,155,166,214 [01-01 08:00:12:219 TUYA D][tuya_ctrl_center.c:212] start dev sync [01-01 08:00:12:219 TUYA D][iot_httpc.c:929] Post Data: {"t":12} [01-01 08:00:12:220 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.screen.standard.config.all&devId=eb1552c6f83a6b59edmyes&et=1&t=12&v=1.0&sign=d2e78cd3505453e3e5f995269bcc26c7 [01-01 08:00:12:220 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [01-01 08:00:12:220 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [01-01 08:00:12:220 TUYA D][uni_network.c:188] use dns service to get ip for domain a2.tuyaus.com [01-01 08:00:12:220 TUYA D][iot_httpc.c:1715] dns_query:https://h2.iot-dns.com/v1/dns_query [{"domain":"a2.tuyaus.com"}] [01-01 08:00:12:220 TUYA D][tuya_tls.c:372] tls register constant 6ce871309d48c48f XFT83ZB1amWW83hDEg19M7lKxuf1YmG8 UvhspcVqKpqBDpnJXVn9xlBvxJzs93rlE4DTV [01-01 08:00:12:220 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443 -->> [01-01 08:00:12:220 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0 [01-01 08:00:12:220 TUYA D][uni_network.c:167] use static dns ip 52.25.166.155 for domain h2.iot-dns.com [01-01 08:00:12:220 TUYA D][httpc.c:477] ----got ipaddr:52,25,166,155 [01-01 08:00:12:341 TUYA D][tuya_iot_base_api.c:249] wired netstat changed to:2 -->> [01-01 08:00:12:341 TUYA D][tuya_iot_sdk_api.c:65] base net stat:2 [01-01 08:00:12:341 TUYA D][tuya_zigbee_mgr.c:617] base net stat:2 [01-01 08:00:12:341 TUYA D][tuya_zigbee_mgr.c:589] network status is:1 old_nw_stat:0 [01-01 08:00:12:341 TUYA D][sdk_adpt_internal_api.c:33] base nw stat: 2, ret:0 [01-01 08:00:12:341 TUYA D][tuya_iot_base_api.c:256] wired netstat changed to:2 <<-- [01-01 08:00:12:353 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443 --<< ,r:0 [01-01 08:00:12:353 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:12:353 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect h2.iot-dns.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:12:353 TUYA D][tuya_tls.c:1360] load tuya cert. [01-01 08:00:12:353 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [01-01 08:00:12:353 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [01-01 08:00:12:353 TUYA D][tuya_iot_com_api.c:271] tuya iot dns [01-01 08:00:12:354 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [01-01 08:00:12:432 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443 --<< ,r:0 [01-01 08:00:12:432 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:12:432 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect h2.iot-dns.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:12:432 TUYA D][tuya_tls.c:1360] load tuya cert. [01-01 08:00:12:432 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [01-01 08:00:12:432 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [01-01 08:00:12:432 TUYA D][tuya_iot_com_api.c:271] tuya iot dns [01-01 08:00:12:432 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [01-01 08:00:12:472 TUYA D][iot_httpc.c:929] Post Data: {"metas":"{\"zigChannel\":25,\"zigBleSubEnable\":true}","t":12} [01-01 08:00:12:473 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.meta.save&devId=eb1552c6f83a6b59edmyes&et=1&t=12&v=1.0&sign=a3bb5ddbca1766c8f5436f7a2b958520 [01-01 08:00:12:473 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [01-01 08:00:12:473 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [01-01 08:00:12:473 TUYA D][uni_network.c:188] use dns service to get ip for domain a2.tuyaus.com [01-01 08:00:12:473 TUYA D][iot_httpc.c:1715] dns_query:https://h2.iot-dns.com/v1/dns_query [{"domain":"a2.tuyaus.com"}] [01-01 08:00:12:473 TUYA D][tuya_tls.c:372] tls register constant 6ce871309d48c48f XFT83ZB1amWW83hDEg19M7lKxuf1YmG8 UvhspcVqKpqBDpnJXVn9xlBvxJzs93rlE4DTV [01-01 08:00:12:473 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443 -->> [01-01 08:00:12:473 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0 [01-01 08:00:12:473 TUYA D][uni_network.c:167] use static dns ip 34.214.145.236 for domain h2.iot-dns.com [01-01 08:00:12:473 TUYA D][httpc.c:477] ----got ipaddr:34,214,145,236 [01-01 08:00:12:562 TUYA D][tuya_tls.c:1520] handshake finish for h2.iot-dns.com. set send/recv to user set [01-01 08:00:12:562 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect h2.iot-dns.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:12:694 TUYA D][tuya_tls.c:1520] handshake finish for h2.iot-dns.com. set send/recv to user set [01-01 08:00:12:694 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect h2.iot-dns.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:12:694 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443 --<< ,r:0 [01-01 08:00:12:694 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:12:695 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect h2.iot-dns.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:12:695 TUYA D][tuya_tls.c:1360] load tuya cert. [01-01 08:00:12:695 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [01-01 08:00:12:695 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [01-01 08:00:12:695 TUYA D][tuya_iot_com_api.c:271] tuya iot dns [01-01 08:00:12:695 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [01-01 08:00:12:856 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:12:856 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:12:856 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:12:856 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:12:995 TUYA D][iot_httpc.c:678] return chunked:0 [01-01 08:00:12:995 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [01-01 08:00:12:996 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [01-01 08:00:12:996 TUYA D][uni_network.c:100] get ip 44.231.176.168 [01-01 08:00:12:996 TUYA D][uni_network.c:197] dns service get ip 44.231.176.168 for domain a2.tuyaus.com [01-01 08:00:12:996 TUYA D][uni_network.c:268] cache dns [a2.tuyaus.com]<->[44.231.176.168] [01-01 08:00:12:996 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [01-01 08:00:13:147 TUYA D][iot_httpc.c:678] return chunked:0 [01-01 08:00:13:147 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [01-01 08:00:13:148 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [01-01 08:00:13:148 TUYA D][uni_network.c:100] get ip 44.231.176.168 [01-01 08:00:13:148 TUYA D][uni_network.c:197] dns service get ip 44.231.176.168 for domain a2.tuyaus.com [01-01 08:00:13:148 TUYA D][uni_network.c:268] cache dns [a2.tuyaus.com]<->[44.231.176.168] [01-01 08:00:13:148 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [01-01 08:00:13:209 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [01-01 08:00:13:209 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:13:209 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:13:209 TUYA D][tuya_tls.c:1360] load tuya cert. [01-01 08:00:13:209 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [01-01 08:00:13:209 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [01-01 08:00:13:209 TUYA D][tuya_iot_com_api.c:259] tuya public url [01-01 08:00:13:210 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [01-01 08:00:13:343 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [01-01 08:00:13:343 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:13:343 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:13:343 TUYA D][tuya_tls.c:1360] load tuya cert. [01-01 08:00:13:343 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [01-01 08:00:13:343 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [01-01 08:00:13:343 TUYA D][tuya_iot_com_api.c:259] tuya public url [01-01 08:00:13:343 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [01-01 08:00:13:515 TUYA D][tuya_tls.c:1520] handshake finish for h2.iot-dns.com. set send/recv to user set [01-01 08:00:13:515 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect h2.iot-dns.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:13:864 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:13:864 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:13:864 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [01-01 08:00:13:864 TUYA D][tuya_z3.c:28009] Time is not synchronized [01-01 08:00:13:925 TUYA D][iot_httpc.c:678] return chunked:0 [01-01 08:00:13:925 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [01-01 08:00:13:925 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [01-01 08:00:13:926 TUYA D][uni_network.c:100] get ip 44.231.176.168 [01-01 08:00:13:926 TUYA D][uni_network.c:197] dns service get ip 44.231.176.168 for domain a2.tuyaus.com [01-01 08:00:13:926 TUYA D][uni_network.c:268] cache dns [a2.tuyaus.com]<->[44.231.176.168] [01-01 08:00:13:926 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [01-01 08:00:13:999 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [01-01 08:00:13:999 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:14:105 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [01-01 08:00:14:105 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:14:105 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:14:105 TUYA D][tuya_tls.c:1360] load tuya cert. [01-01 08:00:14:105 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [01-01 08:00:14:105 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [01-01 08:00:14:105 TUYA D][tuya_iot_com_api.c:259] tuya public url [01-01 08:00:14:105 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [01-01 08:00:14:122 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [01-01 08:00:14:122 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:14:492 TUYA D][iot_httpc.c:596] Decode Rev:{"t":1666164201,"success":true} [10-19 15:23:21:0 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:21:1 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:21:1 TUYA D][tuya_iot_scene_event.c:77] mqtt connect [10-19 15:23:21:1 TUYA D][scene_linkage_rule_sync.c:1268] scene_linkage_update_from_server linkage_type:0 delaymS:10000 [10-19 15:23:21:1 TUYA D][scene_linkage_lan_master.c:328] lan_scene_linkage_on_mqtt_online 1 [10-19 15:23:21:1 TUYA D][lan_dev_base_master.c:389] lan_scene_linkage_on_mqtt_online 1 [10-19 15:23:21:1 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x572cdc 0 [10-19 15:23:21:1 TUYA D][thread_pool_temp.c:607] temp run 0x572cdc 0 [10-19 15:23:21:1 TUYA I][subdev_inner_api.c:276] gw_subdev_on_mq_con connected [10-19 15:23:21:1 TUYA I][subdev_bind.c:1587] sync dev list delay_ms: 3000 [10-19 15:23:21:1 TUYA D][thread_pool_temp.c:709] temp run add delay 0x7f8400f370 0x58bbd8 0 6 [10-19 15:23:21:1 TUYA D][thread_pool_temp.c:709] temp run add delay 0x7f8400f370 0x58c634 0 11 [10-19 15:23:21:1 TUYA W][home_security.c:2401] Home security have init.. [10-19 15:23:21:1 TUYA D][mqc_app.c:875] Send MQTT Msg.P:23 N:8569 Q:0 Data:{"reqType":"netMode","data":{"netMode":"wired"}} [10-19 15:23:21:2 TUYA D][gw_http_report_meta.c:161] gw_http_report_meta lanIp {\"lanIp\":\"192.168.3.106\"} [10-19 15:23:21:2 TUYA D][gw_reli_http_report.c:287] gw_reli_http_report_data 0x5db8ac 0x7f580102f0 [10-19 15:23:21:2 TUYA D][gw_http_report_meta.c:161] gw_http_report_meta wifiChannel {\"wifiChannel\":11} [10-19 15:23:21:2 TUYA D][gw_reli_http_report.c:287] gw_reli_http_report_data 0x5db8ac 0x7f58010380 [10-19 15:23:21:2 TUYA D][thread_pool_temp.c:696] temp run add 0x7f58001710 0x5e4770 580019b0 [10-19 15:23:21:2 TUYA D][thread_pool_temp.c:607] temp run 0x5e4770 580019b0 [10-19 15:23:21:2 TUYA D][user_iot_intf.c:89] online stat: 1 [10-19 15:23:21:2 TUYA D][thread_pool_temp.c:197] run temp 0x5e4770 580019b0 in thread 940013f0 BEGIN [10-19 15:23:21:2 TUYA D][thread_pool_temp.c:197] run temp 0x572cdc 0 in thread 94001420 BEGIN [10-19 15:23:21:3 TUYA D][iot_httpc.c:929] Post Data: {"devId":"eb1552c6f83a6b59edmyes","t":1666164201} [10-19 15:23:21:3 TUYA I][gw_info_report.c:306] post_data:{"value":{"compiler":"ci_manage@tuya.com","compile_time":1639221219,"gw_sdk_name":"ty_integrated_sdk","gw_sdk_ver":"3.0.0","gw_baseline":[{"local_linkage":[{"support":true},{"version":"3.1.2-beta.7"}]},{"lan_linkage":[{"support":true},{"version":"3.1.2-beta.7"}]},{"voice_scene":[{"support":false},{"version":null}]},{"engi_mode":[{"support":true},{"version":null}]},{"fault_transfer":[{"support":false},{"version":null}]},{"security":[{"support":true},{"version":null}]},{"pull_local_logs":[{"support":false},{"version":null}]}]},"type":1} [10-19 15:23:21:3 TUYA D][iot_httpc.c:929] Post Data: {"value":{"compiler":"ci_manage@tuya.com","compile_time":1639221219,"gw_sdk_name":"ty_integrated_sdk","gw_sdk_ver":"3.0.0","gw_baseline":[{"local_linkage":[{"support":true},{"version":"3.1.2-beta.7"}]},{"lan_linkage":[{"support":true},{"version":"3.1.2-beta.7"}]},{"voice_scene":[{"support":false},{"version":null}]},{"engi_mode":[{"support":true},{"version":null}]},{"fault_transfer":[{"support":false},{"version":null}]},{"security":[{"support":true},{"version":null}]},{"pull_local_logs":[{"support":false},{"version":null}]}]},"type":1,"t":1666164201} [10-19 15:23:21:3 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.properties.report&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164201&v=1.0&sign=4354a2cf9f63b524bcc96443381a3204 [10-19 15:23:21:3 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:21:3 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:21:3 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:21:3 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:21:4 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.cache.mark.publish&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164201&v=1.0&sign=5cc4dc84cb6a5f64a25e171d30ac7236 [10-19 15:23:21:4 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:21:4 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:21:4 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:21:4 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:21:16 TUYA D][tuya_z3_api_tmp.c:6064] Packet free num: 236. [10-19 15:23:21:239 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:21:239 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:21:239 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:21:239 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:21:239 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:21:240 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:21:240 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:21:240 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:21:240 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:21:240 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:21:240 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:21:240 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:21:241 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:21:241 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:21:241 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:21:241 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:21:349 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:21:349 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:21:356 TUYA D][iot_httpc.c:438] chunk_num.2 [10-19 15:23:21:381 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [10-19 15:23:21:381 TUYA D][tuya_z3.c:28037] Update z3 time. [10-19 15:23:21:391 TUYA D][tuya_z3_api_tmp.c:7382] uni_time = 719479401. [10-19 15:23:21:391 TUYA D][tuya_z3_api_tmp.c:7383] local_time = 719508201. [10-19 15:23:21:90 TUYA D][tuya_z3.c:26108] rev msg, type: 0x1007. [10-19 15:23:21:91 TUYA D][tuya_z3.c:28037] Update z3 time. [10-19 15:23:21:92 TUYA D][tuya_z3_api_tmp.c:7382] uni_time = 719479401. [10-19 15:23:21:92 TUYA D][tuya_z3_api_tmp.c:7383] local_time = 719508201. [10-19 15:23:21:229 TUYA D][iot_httpc.c:438] chunk_num.3 [10-19 15:23:21:328 TUYA D][iot_httpc.c:596] Decode Rev:{"result":true,"t":1666164202,"success":true} [10-19 15:23:22:1 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:22:1 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:22:1 TUYA D][tuya_z3.c:29140] Post gateway channel success data:{"metas":"{\"zigChannel\":25,\"zigBleSubEnable\":true}"} [10-19 15:23:22:11 TUYA D][smart_frame.c:2042] Start To Sync Dev:eb1552c6f83a6b59edmyes, dp_rept_chan:1 [10-19 15:23:22:11 TUYA D][smart_frame.c:2359] Pack local dp, reset_flow_ctl:1,dpnum:11. [10-19 15:23:22:11 TUYA D][smart_frame.c:2447] Nothing To Pack [10-19 15:23:22:11 TUYA D][smart_frame.c:2094] Sync Finish [10-19 15:23:22:11 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0 [10-19 15:23:22:11 TUYA D][simplekv.c:1251] find key:12 em_sys_env [10-19 15:23:22:12 TUYA D][simplekv.c:1280] key:em_sys_env find value.Len:32 [10-19 15:23:22:12 TUYA D][svc_online_log.c:173] load env success em_sys_env [10-19 15:23:22:12 TUYA D][svc_online_log.c:176] env em_sys_env same. need not to update [10-19 15:23:22:12 TUYA D][simplekv.c:1211] read key:000004brzg_ver isFuzzy:0 skipCnt:0 [10-19 15:23:22:12 TUYA D][simplekv.c:1247] no key find [10-19 15:23:22:12 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [10-19 15:23:22:12 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [10-19 15:23:22:12 TUYA D][tuya_svc_schema_upgrade.c:223] schema[000004brzg] not updated since activated [10-19 15:23:22:12 TUYA D][iot_httpc.c:929] Post Data: {"versions":"[{\"otaChannel\":0,\"protocolVer\":\"2.2\",\"devAttribute\":6,\"sdkFullVer\":\"TuyaOS2.3.5_ty_integrated_sdk_3.0.0_linux_rockchip_release_0.0.8\",\"baselineVer\":\"40.00\",\"softVer\":\"1.2.5\",\"cadVer\":\"1.0.4\",\"cdVer\":\"1.0.0\"},{\"otaChannel\":3,\"softVer\":\"1.0.5\"}]","t":1666164202} [10-19 15:23:22:12 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.versions.update&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164202&v=4.1&sign=52e4b30dc376824525da269abaf2a13b [10-19 15:23:22:12 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:22:12 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:22:12 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:22:13 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:22:36 TUYA D][iot_httpc.c:438] chunk_num.4 [10-19 15:23:22:56 TUYA D][iot_httpc.c:438] chunk_num.5 [10-19 15:23:22:109 TUYA D][iot_httpc.c:438] chunk_num.6 [10-19 15:23:22:125 TUYA D][iot_httpc.c:438] chunk_num.7 [10-19 15:23:22:143 TUYA I][lan_cluster_master_core.c:790] __timer_proc_master_wait. send_cnt[2] [10-19 15:23:22:194 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:22:194 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:22:194 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:22:194 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:22:194 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:22:194 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:22:194 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:22:194 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:22:245 TUYA D][iot_httpc.c:457] total_len:213519 [10-19 15:23:22:257 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:22:257 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:22:285 TUYA D][gw_async_task.c:231] gw_http_report_async 0x57f6d0 (nil) [10-19 15:23:22:286 TUYA D][tuya_iot_scene_sync.c:212] __tmm_scene_sync_cb [10-19 15:23:22:286 TUYA D][iot_httpc.c:929] Post Data: {"t":1666164202} [10-19 15:23:22:286 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.screen.linkage.rule.all&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164202&v=1.0&sign=e294349be0304f03bf7ee9bb3993a290 [10-19 15:23:22:286 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:22:286 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:22:286 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:22:286 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:22:306 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:22:307 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:22:489 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:22:489 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:22:489 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:22:489 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:22:489 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:22:489 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:22:489 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:22:489 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:22:674 TUYA D][iot_httpc.c:596] Decode Rev:{"result":[{"communicateTypes":["cable","zigbee"],"functionSchemaList":[],"productId":"axw2wati6x8wwqrh","statusSchemaList":[],"category":"wg2"},{"communicateTypes":["wifi","bluetooth"],"functionSchemaList":[{"mainDpCode":"switch_led","relationDpIdMaps":{"switch_led":2},"valueRange":"{}","mainDpType":"Boolean","strategyCode":"default","standardType":"Boolean","strategyValue":"{\"switch_led\":\"$\"}","standardCode":"switch_led"},{"mainDpCode":"volume_set","relationDpIdMaps":{"volume_set":5},"valueRange":"{\"unit\":\"\",\"min\":5,\"max\":100,\"scale\":0,\"step\":1}","mainDpType":"Integer","strategyCode":"default","standardType":"Integer","strategyValue":"{\"volume_set\":\"$\"}","standardCode":"volume_set"},{"mainDpCode":"snooze","relationDpIdMaps":{"snooze":7},"valueRange":"{}","mainDpType":"Boolean","strategyCode":"default","standardType":"Boolean","strategyValue":"{\"snooze\":\"$\"}","standardCode":"snooze"},{"mainDpCode":"colour_data","relationDpIdMa [10-19 15:23:22:705 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:22:705 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:22:706 TUYA D][tuya_ctrl_center.c:2018] get standard pid cnt: 52 [10-19 15:23:22:706 TUYA D][tuya_ctrl_center.c:1890] pid: axw2wati6x8wwqrh standard.config already exist [10-19 15:23:22:706 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:axw2wati6x8wwqrh,p_rcd_info:0x7f94015100 [10-19 15:23:22:706 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:56,p_rcd_info->crc32:1173220458,len:160 key:axw2wati6x8wwqrh. [10-19 15:23:22:706 TUYA D][tuya_ctrl_center.c:1890] pid: 6y1cduj4ealrfndo standard.config already exist [10-19 15:23:22:707 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:6y1cduj4ealrfndo,p_rcd_info:0x7f94015134 [10-19 15:23:22:708 TUYA D][iot_httpc.c:596] Decode Rev:{"result":true,"t":1666164202,"success":true} [10-19 15:23:22:708 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:57,p_rcd_info->crc32:1172617518,len:2480 key:6y1cduj4ealrfndo. [10-19 15:23:22:708 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:22:709 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:22:709 TUYA D][thread_pool_temp.c:200] thread 94001420 END [10-19 15:23:22:709 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:22:709 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [10-19 15:23:22:709 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:1 [10-19 15:23:22:709 TUYA D][tuya_ctrl_center.c:1890] pid: zach3mptpjpojys6 standard.config already exist [10-19 15:23:22:709 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:zach3mptpjpojys6,p_rcd_info:0x7f94015168 [10-19 15:23:22:709 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:58,p_rcd_info->crc32:3388075565,len:160 key:zach3mptpjpojys6. [10-19 15:23:22:709 TUYA D][tuya_ctrl_center.c:1890] pid: fboep9j6grtxyga9 standard.config already exist [10-19 15:23:22:711 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:fboep9j6grtxyga9,p_rcd_info:0x7f9401519c [10-19 15:23:22:712 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:59,p_rcd_info->crc32:837758816,len:3888 key:fboep9j6grtxyga9. [10-19 15:23:22:713 TUYA D][tuya_ctrl_center.c:1890] pid: jogzi8noyhgcahcq standard.config already exist [10-19 15:23:22:714 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:jogzi8noyhgcahcq,p_rcd_info:0x7f940151d0 [10-19 15:23:22:715 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:60,p_rcd_info->crc32:914460421,len:4000 key:jogzi8noyhgcahcq. [10-19 15:23:22:716 TUYA D][tuya_ctrl_center.c:1890] pid: dc6v3yjsjhajgb7f standard.config already exist [10-19 15:23:22:716 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:dc6v3yjsjhajgb7f,p_rcd_info:0x7f94015204 [10-19 15:23:22:716 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:61,p_rcd_info->crc32:2472654437,len:144 key:dc6v3yjsjhajgb7f. [10-19 15:23:22:716 TUYA D][tuya_ctrl_center.c:1890] pid: l9rksbbbisynlnvq standard.config already exist [10-19 15:23:22:718 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:l9rksbbbisynlnvq,p_rcd_info:0x7f94015238 [10-19 15:23:22:720 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:62,p_rcd_info->crc32:471924257,len:5216 key:l9rksbbbisynlnvq. [10-19 15:23:22:720 TUYA D][tuya_ctrl_center.c:1890] pid: pbx8cm1kvgn0fv2d standard.config already exist [10-19 15:23:22:722 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:pbx8cm1kvgn0fv2d,p_rcd_info:0x7f9401526c [10-19 15:23:22:723 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"cacheDevs":[]},"protocol":102,"s":1695745,"t":1666164202} [10-19 15:23:22:723 TUYA D][subdev_mq.c:94] Rev Device Wakeup Cmd [10-19 15:23:22:724 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:63,p_rcd_info->crc32:1097170635,len:4576 key:pbx8cm1kvgn0fv2d. [10-19 15:23:22:724 TUYA D][tuya_ctrl_center.c:1890] pid: mjffeakbzlnfxpzt standard.config already exist [10-19 15:23:22:724 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:mjffeakbzlnfxpzt,p_rcd_info:0x7f940152a0 [10-19 15:23:22:725 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:64,p_rcd_info->crc32:3540395499,len:176 key:mjffeakbzlnfxpzt. [10-19 15:23:22:725 TUYA D][tuya_ctrl_center.c:1890] pid: 1vso02tkynsvpinp standard.config already exist [10-19 15:23:22:728 TUYA D][iot_httpc.c:596] Decode Rev:{"t":1666164202,"success":true} [10-19 15:23:22:728 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:22:729 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:22:731 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:1vso02tkynsvpinp,p_rcd_info:0x7f940152d4 [10-19 15:23:22:734 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:65,p_rcd_info->crc32:3310694089,len:13264 key:1vso02tkynsvpinp. [10-19 15:23:22:734 TUYA D][tuya_ctrl_center.c:1890] pid: oniuxtrf5xu85d69 standard.config already exist [10-19 15:23:22:735 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:oniuxtrf5xu85d69,p_rcd_info:0x7f94015308 [10-19 15:23:22:735 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:66,p_rcd_info->crc32:1928958530,len:176 key:oniuxtrf5xu85d69. [10-19 15:23:22:735 TUYA D][tuya_ctrl_center.c:1890] pid: 1svzszztogaibjxa standard.config already exist [10-19 15:23:22:735 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:1svzszztogaibjxa,p_rcd_info:0x7f9401533c [10-19 15:23:22:735 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:67,p_rcd_info->crc32:20072584,len:176 key:1svzszztogaibjxa. [10-19 15:23:22:736 TUYA D][tuya_ctrl_center.c:1890] pid: qhfvhlm1k0ws0gul standard.config already exist [10-19 15:23:22:739 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:qhfvhlm1k0ws0gul,p_rcd_info:0x7f94015370 [10-19 15:23:22:741 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:68,p_rcd_info->crc32:3723419288,len:7648 key:qhfvhlm1k0ws0gul. [10-19 15:23:22:741 TUYA D][tuya_ctrl_center.c:1890] pid: seuwp5kki3tvz3wl standard.config already exist [10-19 15:23:22:743 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:seuwp5kki3tvz3wl,p_rcd_info:0x7f940153a4 [10-19 15:23:22:744 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:69,p_rcd_info->crc32:1982680045,len:4000 key:seuwp5kki3tvz3wl. [10-19 15:23:22:745 TUYA D][tuya_ctrl_center.c:1890] pid: w906qkrrhd3otiwd standard.config already exist [10-19 15:23:22:747 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:w906qkrrhd3otiwd,p_rcd_info:0x7f940153d8 [10-19 15:23:22:748 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:70,p_rcd_info->crc32:1037553508,len:5216 key:w906qkrrhd3otiwd. [10-19 15:23:22:749 TUYA D][tuya_ctrl_center.c:1890] pid: mh9px7cq standard.config already exist [10-19 15:23:22:750 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:mh9px7cq,p_rcd_info:0x7f9401540c [10-19 15:23:22:751 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:71,p_rcd_info->crc32:3367144087,len:2224 key:mh9px7cq. [10-19 15:23:22:751 TUYA D][tuya_ctrl_center.c:1890] pid: j0zozzoarutv0nu1 standard.config already exist [10-19 15:23:22:753 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:j0zozzoarutv0nu1,p_rcd_info:0x7f94015440 [10-19 15:23:22:754 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:72,p_rcd_info->crc32:4196404862,len:4688 key:j0zozzoarutv0nu1. [10-19 15:23:22:755 TUYA D][tuya_ctrl_center.c:1890] pid: jyupj3fw standard.config already exist [10-19 15:23:22:759 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:jyupj3fw,p_rcd_info:0x7f94015474 [10-19 15:23:22:761 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:73,p_rcd_info->crc32:4097052671,len:8896 key:jyupj3fw. [10-19 15:23:22:761 TUYA D][tuya_ctrl_center.c:1890] pid: 7zjewx91 standard.config already exist [10-19 15:23:22:762 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:7zjewx91,p_rcd_info:0x7f940154a8 [10-19 15:23:22:762 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:74,p_rcd_info->crc32:3453049796,len:144 key:7zjewx91. [10-19 15:23:22:762 TUYA D][tuya_ctrl_center.c:1890] pid: 1aso8gn0szwvjjue standard.config already exist [10-19 15:23:22:764 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:1aso8gn0szwvjjue,p_rcd_info:0x7f940154dc [10-19 15:23:22:765 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:75,p_rcd_info->crc32:2204226531,len:3984 key:1aso8gn0szwvjjue. [10-19 15:23:22:765 TUYA D][tuya_ctrl_center.c:1890] pid: jcamvbr95hdno5ub standard.config already exist [10-19 15:23:22:766 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:jcamvbr95hdno5ub,p_rcd_info:0x7f94015510 [10-19 15:23:22:766 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:76,p_rcd_info->crc32:3509625805,len:736 key:jcamvbr95hdno5ub. [10-19 15:23:22:767 TUYA D][tuya_ctrl_center.c:1890] pid: oqe2ba267qac12ng standard.config already exist [10-19 15:23:22:769 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:oqe2ba267qac12ng,p_rcd_info:0x7f94015544 [10-19 15:23:22:771 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:77,p_rcd_info->crc32:2646765449,len:5888 key:oqe2ba267qac12ng. [10-19 15:23:22:771 TUYA D][tuya_ctrl_center.c:1890] pid: ha7agddwqq6ahbiz standard.config already exist [10-19 15:23:22:774 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ha7agddwqq6ahbiz,p_rcd_info:0x7f94015578 [10-19 15:23:22:776 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:78,p_rcd_info->crc32:4051525223,len:6432 key:ha7agddwqq6ahbiz. [10-19 15:23:22:777 TUYA D][tuya_ctrl_center.c:1890] pid: wpxcg1ahziux5tzh standard.config already exist [10-19 15:23:22:777 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:wpxcg1ahziux5tzh,p_rcd_info:0x7f940155ac [10-19 15:23:22:777 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:79,p_rcd_info->crc32:85103180,len:768 key:wpxcg1ahziux5tzh. [10-19 15:23:22:778 TUYA D][tuya_ctrl_center.c:1890] pid: 0000008vhd standard.config already exist [10-19 15:23:22:778 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:0000008vhd,p_rcd_info:0x7f940155e0 [10-19 15:23:22:778 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:80,p_rcd_info->crc32:681496183,len:160 key:0000008vhd. [10-19 15:23:22:778 TUYA D][tuya_ctrl_center.c:1890] pid: grpvptbrpkissnd8 standard.config already exist [10-19 15:23:22:781 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:grpvptbrpkissnd8,p_rcd_info:0x7f94015614 [10-19 15:23:22:782 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:81,p_rcd_info->crc32:4286450097,len:5216 key:grpvptbrpkissnd8. [10-19 15:23:22:783 TUYA D][tuya_ctrl_center.c:1890] pid: 98afxsvjfbobhjw4 standard.config already exist [10-19 15:23:22:784 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:98afxsvjfbobhjw4,p_rcd_info:0x7f94015648 [10-19 15:23:22:786 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:82,p_rcd_info->crc32:1062413227,len:4000 key:98afxsvjfbobhjw4. [10-19 15:23:22:786 TUYA D][tuya_ctrl_center.c:1890] pid: a33rw7ou standard.config already exist [10-19 15:23:22:786 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:a33rw7ou,p_rcd_info:0x7f9401567c [10-19 15:23:22:787 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:83,p_rcd_info->crc32:738727984,len:800 key:a33rw7ou. [10-19 15:23:22:787 TUYA D][tuya_ctrl_center.c:1890] pid: 2ekuz3dz standard.config already exist [10-19 15:23:22:790 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:2ekuz3dz,p_rcd_info:0x7f940156b0 [10-19 15:23:22:792 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:84,p_rcd_info->crc32:3788443761,len:7200 key:2ekuz3dz. [10-19 15:23:22:793 TUYA D][tuya_ctrl_center.c:1890] pid: 97cp1wty56mww1o0 standard.config already exist [10-19 15:23:22:795 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:97cp1wty56mww1o0,p_rcd_info:0x7f940156e4 [10-19 15:23:22:797 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:85,p_rcd_info->crc32:2959722770,len:5728 key:97cp1wty56mww1o0. [10-19 15:23:22:798 TUYA D][tuya_ctrl_center.c:1890] pid: ajadcojk standard.config already exist [10-19 15:23:22:800 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ajadcojk,p_rcd_info:0x7f94015718 [10-19 15:23:22:801 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:86,p_rcd_info->crc32:620308568,len:4656 key:ajadcojk. [10-19 15:23:22:802 TUYA D][tuya_ctrl_center.c:1890] pid: hfq0xqhjsqmfqkw4 standard.config already exist [10-19 15:23:22:802 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:hfq0xqhjsqmfqkw4,p_rcd_info:0x7f9401574c [10-19 15:23:22:802 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:87,p_rcd_info->crc32:189919851,len:864 key:hfq0xqhjsqmfqkw4. [10-19 15:23:22:803 TUYA D][tuya_ctrl_center.c:1890] pid: nkkl7uzv standard.config already exist [10-19 15:23:22:803 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:nkkl7uzv,p_rcd_info:0x7f94015780 [10-19 15:23:22:803 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:88,p_rcd_info->crc32:2662624286,len:144 key:nkkl7uzv. [10-19 15:23:22:804 TUYA D][tuya_ctrl_center.c:1890] pid: 9yyaalraupjaredl standard.config already exist [10-19 15:23:22:806 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:9yyaalraupjaredl,p_rcd_info:0x7f940157b4 [10-19 15:23:22:809 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:89,p_rcd_info->crc32:597578810,len:7520 key:9yyaalraupjaredl. [10-19 15:23:22:809 TUYA D][tuya_ctrl_center.c:1890] pid: yrmpfrig5ndywijq standard.config already exist [10-19 15:23:22:809 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:yrmpfrig5ndywijq,p_rcd_info:0x7f940157e8 [10-19 15:23:22:809 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:90,p_rcd_info->crc32:2627475721,len:176 key:yrmpfrig5ndywijq. [10-19 15:23:22:810 TUYA D][tuya_ctrl_center.c:1890] pid: 000000dfug standard.config already exist [10-19 15:23:22:810 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:000000dfug,p_rcd_info:0x7f9401581c [10-19 15:23:22:810 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:91,p_rcd_info->crc32:4000911611,len:160 key:000000dfug. [10-19 15:23:22:810 TUYA D][tuya_ctrl_center.c:1890] pid: manu90xvog2uqakl standard.config already exist [10-19 15:23:22:813 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:manu90xvog2uqakl,p_rcd_info:0x7f94015850 [10-19 15:23:22:815 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:92,p_rcd_info->crc32:1394890728,len:6320 key:manu90xvog2uqakl. [10-19 15:23:22:815 TUYA D][tuya_ctrl_center.c:1890] pid: mq2mrjjqlkorvgfe standard.config already exist [10-19 15:23:22:819 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:mq2mrjjqlkorvgfe,p_rcd_info:0x7f94015884 [10-19 15:23:22:821 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:93,p_rcd_info->crc32:3212420828,len:8912 key:mq2mrjjqlkorvgfe. [10-19 15:23:22:822 TUYA D][tuya_ctrl_center.c:1890] pid: 2mqosesmkrvlvl0w standard.config already exist [10-19 15:23:22:822 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:2mqosesmkrvlvl0w,p_rcd_info:0x7f940158b8 [10-19 15:23:22:823 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:94,p_rcd_info->crc32:4185065136,len:416 key:2mqosesmkrvlvl0w. [10-19 15:23:22:823 TUYA D][tuya_ctrl_center.c:1890] pid: qwpfjxryaj7pr9rw standard.config already exist [10-19 15:23:22:826 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:qwpfjxryaj7pr9rw,p_rcd_info:0x7f940158ec [10-19 15:23:22:829 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:95,p_rcd_info->crc32:1608907565,len:8416 key:qwpfjxryaj7pr9rw. [10-19 15:23:22:829 TUYA D][tuya_ctrl_center.c:1890] pid: lmjfyvtsig6v5npw standard.config already exist [10-19 15:23:22:829 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:lmjfyvtsig6v5npw,p_rcd_info:0x7f94015920 [10-19 15:23:22:830 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:96,p_rcd_info->crc32:3269866653,len:176 key:lmjfyvtsig6v5npw. [10-19 15:23:22:830 TUYA D][tuya_ctrl_center.c:1890] pid: 9nauypjb2kvujrut standard.config already exist [10-19 15:23:22:834 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:9nauypjb2kvujrut,p_rcd_info:0x7f94015954 [10-19 15:23:22:839 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:97,p_rcd_info->crc32:1681664555,len:9792 key:9nauypjb2kvujrut. [10-19 15:23:22:840 TUYA D][tuya_ctrl_center.c:1890] pid: 0ln8tfei1iulgo2k standard.config already exist [10-19 15:23:22:844 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:0ln8tfei1iulgo2k,p_rcd_info:0x7f94015988 [10-19 15:23:22:847 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:98,p_rcd_info->crc32:1327071782,len:8912 key:0ln8tfei1iulgo2k. [10-19 15:23:22:848 TUYA D][tuya_ctrl_center.c:1890] pid: 9cwtq6di0cz7bikc standard.config already exist [10-19 15:23:22:849 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:9cwtq6di0cz7bikc,p_rcd_info:0x7f940159bc [10-19 15:23:22:850 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:99,p_rcd_info->crc32:1452580751,len:2464 key:9cwtq6di0cz7bikc. [10-19 15:23:22:850 TUYA D][tuya_ctrl_center.c:1890] pid: 2ywpwkvsgqujwlgs standard.config already exist [10-19 15:23:22:850 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:2ywpwkvsgqujwlgs,p_rcd_info:0x7f940159f0 [10-19 15:23:22:851 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:100,p_rcd_info->crc32:4234167548,len:192 key:2ywpwkvsgqujwlgs. [10-19 15:23:22:851 TUYA D][tuya_ctrl_center.c:1890] pid: jqo111f6ahvas3tr standard.config already exist [10-19 15:23:22:853 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:jqo111f6ahvas3tr,p_rcd_info:0x7f94015a24 [10-19 15:23:22:854 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:101,p_rcd_info->crc32:1396012225,len:4000 key:jqo111f6ahvas3tr. [10-19 15:23:22:854 TUYA D][tuya_ctrl_center.c:1890] pid: dgudhgjmxdznjm6d standard.config already exist [10-19 15:23:22:859 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:dgudhgjmxdznjm6d,p_rcd_info:0x7f94015a58 [10-19 15:23:22:861 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:102,p_rcd_info->crc32:2447286865,len:9696 key:dgudhgjmxdznjm6d. [10-19 15:23:22:862 TUYA D][tuya_ctrl_center.c:1890] pid: gw173aldekvpzalg standard.config already exist [10-19 15:23:22:863 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:gw173aldekvpzalg,p_rcd_info:0x7f94015a8c [10-19 15:23:22:864 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:103,p_rcd_info->crc32:3241470714,len:3024 key:gw173aldekvpzalg. [10-19 15:23:22:865 TUYA D][tuya_ctrl_center.c:1890] pid: qzktzhehinzsz2je standard.config already exist [10-19 15:23:22:865 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:qzktzhehinzsz2je,p_rcd_info:0x7f94015ac0 [10-19 15:23:22:865 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:104,p_rcd_info->crc32:776027656,len:160 key:qzktzhehinzsz2je. [10-19 15:23:22:865 TUYA D][tuya_ctrl_center.c:1890] pid: 4fjiwweb standard.config already exist [10-19 15:23:22:866 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:4fjiwweb,p_rcd_info:0x7f94015af4 [10-19 15:23:22:867 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:105,p_rcd_info->crc32:2406545818,len:1872 key:4fjiwweb. [10-19 15:23:22:867 TUYA D][tuya_ctrl_center.c:1890] pid: pj3gdjgpeqao7xk4 standard.config already exist [10-19 15:23:22:869 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:pj3gdjgpeqao7xk4,p_rcd_info:0x7f94015b28 [10-19 15:23:22:869 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:106,p_rcd_info->crc32:324557105,len:2576 key:pj3gdjgpeqao7xk4. [10-19 15:23:22:870 TUYA D][tuya_ctrl_center.c:1890] pid: 8nd1vkcuwbektfod standard.config already exist [10-19 15:23:22:871 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:8nd1vkcuwbektfod,p_rcd_info:0x7f94015b5c [10-19 15:23:22:872 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:107,p_rcd_info->crc32:4164941045,len:3328 key:8nd1vkcuwbektfod. [10-19 15:23:22:889 TUYA D][iot_httpc.c:929] Post Data: {"pids":["axw2wati6x8wwqrh","6y1cduj4ealrfndo","zach3mptpjpojys6","fboep9j6grtxyga9","jogzi8noyhgcahcq","dc6v3yjsjhajgb7f","l9rksbbbisynlnvq","pbx8cm1kvgn0fv2d","mjffeakbzlnfxpzt","1vso02tkynsvpinp","oniuxtrf5xu85d69","1svzszztogaibjxa","qhfvhlm1k0ws0gul","seuwp5kki3tvz3wl","w906qkrrhd3otiwd","mh9px7cq","j0zozzoarutv0nu1","jyupj3fw","7zjewx91","1aso8gn0szwvjjue","jcamvbr95hdno5ub","oqe2ba267qac12ng","ha7agddwqq6ahbiz","wpxcg1ahziux5tzh","0000008vhd","grpvptbrpkissnd8","98afxsvjfbobhjw4","a33rw7ou","2ekuz3dz","97cp1wty56mww1o0","ajadcojk","hfq0xqhjsqmfqkw4","nkkl7uzv","9yyaalraupjaredl","yrmpfrig5ndywijq","000000dfug","manu90xvog2uqakl","mq2mrjjqlkorvgfe","2mqosesmkrvlvl0w","qwpfjxryaj7pr9rw","lmjfyvtsig6v5npw","9nauypjb2kvujrut","0ln8tfei1iulgo2k","9cwtq6di0cz7bikc","2ywpwkvsgqujwlgs","jqo111f6ahvas3tr","dgudhgjmxdznjm6d","gw173aldekvpzalg","qzktzhehinzsz2je","4fjiwweb","pj3gdjgpeqao7xk4","8nd1vkcuwbektfod"],"t":1666164202} [10-19 15:23:22:889 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.linux.product.get&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164202&v=1.0&sign=40f4b4ae04fd6b599339bc17caad9b17 [10-19 15:23:22:889 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:22:889 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:22:889 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:22:889 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:22:987 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:22:987 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:23:80 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:23:80 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:23:80 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:23:80 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:23:81 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:23:81 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:23:81 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:23:81 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:23:247 TUYA D][tuya_gw_z3_user.c:536] z3 user dev notify [10-19 15:23:23:247 TUYA D][user_z3.c:237] dev notify [10-19 15:23:23:247 TUYA D][gw_http_report_meta.c:161] gw_http_report_meta z3Lqi {\"z3Lqi\":true} [10-19 15:23:23:247 TUYA D][gw_reli_http_report.c:287] gw_reli_http_report_data 0x5db8ac 0x7f94018580 [10-19 15:23:23:279 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:23:279 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:23:425 TUYA D][iot_httpc.c:596] Decode Rev:{"t":1666164203,"success":true} [10-19 15:23:23:425 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:23:425 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:23:426 TUYA D][tuya_ws_db.c:303] write buf:{"abi":1,"id":"eb1552c6f83a6b59edmyes","swv":"1.2.5","bv":"40.00","pv":"2.2","lpv":"3.3","pk":"1svzszztogaibjxa","firmk":null,"cadv":"1.0.4","cdv":"1.0.0","dev_swv":"1.2.5","s_id":"000004brzg","dtp":0,"sync":0,"attr_num":1,"mst_tp_0":3,"mst_ver_0":"1.0.5","mst_tp_1":0,"mst_ver_1":null,"mst_tp_2":0,"mst_ver_2":null,"mst_tp_3":0,"mst_ver_3":null } [10-19 15:23:23:426 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0 [10-19 15:23:23:426 TUYA D][simplekv.c:1251] find key:2 gw_di [10-19 15:23:23:426 TUYA D][simplekv.c:1280] key:gw_di find value.Len:352 [10-19 15:23:23:426 TUYA D][ws_db_gw.c:426] gw_di write success [10-19 15:23:23:426 TUYA D][iot_httpc.c:929] Post Data: {"subId":null,"t":1666164203} [10-19 15:23:23:426 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.upgrade.silent.get&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164203&v=4.4&sign=bc3448c8ffd0d9a7a33c2f80a1615fe9 [10-19 15:23:23:426 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:23:426 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:23:426 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:23:426 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:23:615 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:23:615 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:23:615 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:23:615 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:23:615 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:23:615 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:23:615 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:23:615 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:23:729 TUYA D][thread_pool_temp.c:200] thread 940013f0 END [10-19 15:23:23:729 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:23:729 TUYA D][thread_pool_temp.c:143] put thread 0x7f58001710 [10-19 15:23:23:729 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [10-19 15:23:23:760 TUYA D][iot_httpc.c:457] total_len:9295 [10-19 15:23:23:779 TUYA D][iot_httpc.c:596] Decode Rev:{"result":[{"matchType":1,"offGwSync":false,"outOfWork":0,"ownerId":"77850135","offGwSyncSuccess":false,"id":"Zd4uIIpB5OhLmN9a","runtimeEnv":"prod","newLocalScene":false,"coverIcon":"https://imagesd.tuyaus.com/smart/rule/glyphicons/curtain.png","commonField":"","background":"","name":"Morning Mode","actions":[{"offGwSync":false,"actionExecutor":"dpIssue","orderNum":1,"enabled":true,"executorProperty":{"1":"open"},"attribute":0,"id":"f1AkaG9bS8sVJLPmjKbh","ruleId":"Zd4uIIpB5OhLmN9a","actionStrategy":"edge","extraProperty":{},"entityId":"eb3b1fefe57125bb72nrzb","devDelMark":false,"status":true}],"gmtModified":1664264744373,"code":"","scenarioRule":true,"orderWeight":1,"needCleanGidSid":false,"enabled":true,"uid":"az1658925946144h4BjH","ruleType":3,"isLogicRule":false,"attribute":4,"boundForPanel":false,"isAlarmIssue":false,"stickyOnTop":true,"boundForWiFiPanel":false,"needValidOutOfWork":false,"gmtCreate":1664264744350,"iotAutoAlarm":false,"localLinkage [10-19 15:23:23:780 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:23:780 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:23:780 TUYA D][tuya_iot_scene_sync.c:174] scene num:6 [10-19 15:23:23:780 TUYA D][tuya_iot_scene_sync.c:188] scene: Morning Mode change, del old first [10-19 15:23:23:781 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [10-19 15:23:23:781 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [10-19 15:23:23:781 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails Zd4uIIpB5OhLmN9a -6 [10-19 15:23:23:781 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [10-19 15:23:23:781 TUYA D][tuya_iot_scene_parse.c:98] scene name:Morning Mode, item num:1. [10-19 15:23:23:781 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [10-19 15:23:23:782 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:Zd4uIIpB5OhLmN9a,p_rcd_info:0x7f9404b9b0 [10-19 15:23:23:782 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:18,p_rcd_info->crc32:3660693531,len:1248 key:Zd4uIIpB5OhLmN9a. [10-19 15:23:23:782 TUYA D][tuya_iot_scene_sto.c:36] rcd write Zd4uIIpB5OhLmN9a success [10-19 15:23:23:782 TUYA D][tuya_iot_scene_sync.c:188] scene: Holiday Mode change, del old first [10-19 15:23:23:782 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [10-19 15:23:23:782 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [10-19 15:23:23:782 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails I6X5n3ssZ42CJ4JK -6 [10-19 15:23:23:783 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [10-19 15:23:23:783 TUYA D][tuya_iot_scene_parse.c:98] scene name:Holiday Mode, item num:1. [10-19 15:23:23:783 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [10-19 15:23:23:783 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:I6X5n3ssZ42CJ4JK,p_rcd_info:0x7f9404b9e4 [10-19 15:23:23:784 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:19,p_rcd_info->crc32:3330553267,len:1248 key:I6X5n3ssZ42CJ4JK. [10-19 15:23:23:784 TUYA D][tuya_iot_scene_sto.c:36] rcd write I6X5n3ssZ42CJ4JK success [10-19 15:23:23:784 TUYA D][tuya_iot_scene_sync.c:188] scene: Dinner Mode change, del old first [10-19 15:23:23:784 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [10-19 15:23:23:784 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [10-19 15:23:23:784 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails MNfDt2BAjdoAQWcW -6 [10-19 15:23:23:784 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [10-19 15:23:23:784 TUYA D][tuya_iot_scene_parse.c:98] scene name:Dinner Mode, item num:1. [10-19 15:23:23:785 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [10-19 15:23:23:785 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:MNfDt2BAjdoAQWcW,p_rcd_info:0x7f9404ba18 [10-19 15:23:23:786 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:20,p_rcd_info->crc32:2732626457,len:1248 key:MNfDt2BAjdoAQWcW. [10-19 15:23:23:786 TUYA D][tuya_iot_scene_sto.c:36] rcd write MNfDt2BAjdoAQWcW success [10-19 15:23:23:786 TUYA D][tuya_iot_scene_sync.c:188] scene: Night Mode change, del old first [10-19 15:23:23:786 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [10-19 15:23:23:786 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [10-19 15:23:23:786 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails bkmaaDxZcQ99DpLA -6 [10-19 15:23:23:786 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [10-19 15:23:23:786 TUYA D][tuya_iot_scene_parse.c:98] scene name:Night Mode, item num:1. [10-19 15:23:23:786 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [10-19 15:23:23:787 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:bkmaaDxZcQ99DpLA,p_rcd_info:0x7f9404ba4c [10-19 15:23:23:788 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:21,p_rcd_info->crc32:172598991,len:1248 key:bkmaaDxZcQ99DpLA. [10-19 15:23:23:788 TUYA D][tuya_iot_scene_sto.c:36] rcd write bkmaaDxZcQ99DpLA success [10-19 15:23:23:788 TUYA D][tuya_iot_scene_sync.c:188] scene: Back Home Mode change, del old first [10-19 15:23:23:788 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [10-19 15:23:23:788 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [10-19 15:23:23:788 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails HRBsEBxG8o08HSwy -6 [10-19 15:23:23:788 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [10-19 15:23:23:788 TUYA D][tuya_iot_scene_parse.c:98] scene name:Back Home Mode, item num:3. [10-19 15:23:23:789 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [10-19 15:23:23:790 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:HRBsEBxG8o08HSwy,p_rcd_info:0x7f9404ba80 [10-19 15:23:23:790 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:22,p_rcd_info->crc32:1443374571,len:1936 key:HRBsEBxG8o08HSwy. [10-19 15:23:23:791 TUYA D][tuya_iot_scene_sto.c:36] rcd write HRBsEBxG8o08HSwy success [10-19 15:23:23:791 TUYA D][tuya_iot_scene_sync.c:188] scene: Left Home Mode change, del old first [10-19 15:23:23:791 TUYA E][rcd_file.c:1383] [ty_rcd] not FOUND rcd_info from hashmap. [10-19 15:23:23:791 TUYA E][rcd_file.c:1448] __read_kv_raw fail. -6 [10-19 15:23:23:791 TUYA E][tuya_iot_scene_sto.c:51] rcd_entry_kv_read fails XTkz3wDAMpWflBn9 -6 [10-19 15:23:23:791 TUYA E][tuya_iot_scene_sto.c:126] call __common_rcd_read(SCENE_DATA_RCD_FILE, id, &json_buf) return -17 [10-19 15:23:23:791 TUYA D][tuya_iot_scene_parse.c:98] scene name:Left Home Mode, item num:1. [10-19 15:23:23:791 TUYA D][tuya_iot_scene_parse.c:183] scene->lan_status:1. [10-19 15:23:23:792 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:XTkz3wDAMpWflBn9,p_rcd_info:0x7f9404bab4 [10-19 15:23:23:793 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:23,p_rcd_info->crc32:2544256560,len:1264 key:XTkz3wDAMpWflBn9. [10-19 15:23:23:793 TUYA D][tuya_iot_scene_sto.c:36] rcd write XTkz3wDAMpWflBn9 success [10-19 15:23:23:793 TUYA D][tuya_iot_scene_sync.c:198] storage scene sync begin. [10-19 15:23:23:793 TUYA D][tuya_iot_scene_sync.c:223] scene sync type: 3 [10-19 15:23:23:794 TUYA N][svc_img.c:688] id name url frist one build list:scene_img 2022-10-19 15:23:24:130:tuya_home_control_sync.c:tuya_home_control_all_info_sync_event:113: tuya_home_control_all_info_sync_event type:3 [10-19 15:23:23:794 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/scene_img/ [10-19 15:23:23:794 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/scene_img/ [10-19 15:23:23:795 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/scene_img/ [10-19 15:23:23:795 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/scene_img/ [10-19 15:23:23:795 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/scene_img/ [10-19 15:23:23:795 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/scene_img/ [10-19 15:23:23:795 TUYA D][svc_file.c:434] p_name file:. [10-19 15:23:23:795 TUYA D][svc_file.c:434] p_name file:.. [10-19 15:23:23:795 TUYA E][svc_file.c:438] tuya_hal_dir_read err:/userdata/tuya_db_files/scene_img/ [10-19 15:23:23:795 TUYA E][svc_img.c:713] tuya_dir_file_delete_for_url err:-1 [10-19 15:23:23:795 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/rule/glyphicons/curtain.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:23:795 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:23:796 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:23:796 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:23:796 TUYA D][uni_network.c:188] use dns service to get ip for domain imagesd.tuyaus.com [10-19 15:23:23:796 TUYA D][iot_httpc.c:1715] dns_query:https://h2.iot-dns.com/v1/dns_query [{"domain":"imagesd.tuyaus.com"}] [10-19 15:23:23:796 TUYA D][tuya_tls.c:372] tls register constant 6ce871309d48c48f XFT83ZB1amWW83hDEg19M7lKxuf1YmG8 UvhspcVqKpqBDpnJXVn9xlBvxJzs93rlE4DTV [10-19 15:23:23:796 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443 -->> [10-19 15:23:23:796 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0 [10-19 15:23:23:796 TUYA D][uni_network.c:167] use static dns ip 52.25.166.155 for domain h2.iot-dns.com [10-19 15:23:23:796 TUYA D][httpc.c:477] ----got ipaddr:52,25,166,155 [10-19 15:23:23:820 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:23:820 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 2022-10-19 15:23:24:294:scenes_control.c:read_scenes:286: read_scenes count=6 2022-10-19 15:23:24:294:scenes_control.c:read_scenes:298: for = scene[i].id = Zd4uIIpB5OhLmN9a 2022-10-19 15:23:24:294:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Morning Mode i= 0 id= Zd4uIIpB5OhLmN9a 2022-10-19 15:23:24:294:scenes_control.c:read_scenes:298: for = scene[i].id = I6X5n3ssZ42CJ4JK 2022-10-19 15:23:24:294:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Holiday Mode i= 1 id= I6X5n3ssZ42CJ4JK 2022-10-19 15:23:24:295:scenes_control.c:read_scenes:298: for = scene[i].id = MNfDt2BAjdoAQWcW 2022-10-19 15:23:24:295:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Dinner Mode i= 2 id= MNfDt2BAjdoAQWcW 2022-10-19 15:23:24:295:scenes_control.c:read_scenes:298: for = scene[i].id = bkmaaDxZcQ99DpLA 2022-10-19 15:23:24:295:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Night Mode i= 3 id= bkmaaDxZcQ99DpLA 2022-10-19 15:23:24:296:scenes_control.c:read_scenes:298: for = scene[i].id = HRBsEBxG8o08HSwy 2022-10-19 15:23:24:296:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Back Home Mode i= 4 id= HRBsEBxG8o08HSwy 2022-10-19 15:23:24:296:scenes_control.c:read_scenes:298: for = scene[i].id = XTkz3wDAMpWflBn9 2022-10-19 15:23:24:296:scenes_control.c:tab3_scenes_create:217: tab3_scenes_create name = Left Home Mode i= 5 id= XTkz3wDAMpWflBn9 [10-19 15:23:24:5 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443 --<< ,r:0 [10-19 15:23:24:5 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:24:5 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect h2.iot-dns.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:24:5 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:24:6 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:24:6 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:24:6 TUYA D][tuya_iot_com_api.c:271] tuya iot dns [10-19 15:23:24:6 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:24:10 TUYA D][mqc_app.c:1480] custom async cb op_ret: 0 [10-19 15:23:24:10 TUYA D][mqc_app.c:1533] pub finish:0 [10-19 15:23:24:10 TUYA D][log_seq.c:793] upolad: mqtt | 3.0.0 | 01-01 00:00:01 | erc:0 | [20:-2310] [10-19 15:23:24:222 TUYA D][mqc_app.c:1480] custom async cb op_ret: 0 [10-19 15:23:24:223 TUYA D][mqc_app.c:1533] pub finish:0 [10-19 15:23:24:254 TUYA D][gw_async_task.c:231] gw_http_report_async 0x57f6d0 (nil) [10-19 15:23:24:366 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:24:367 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:24:752 TUYA D][iot_httpc.c:596] Decode Rev:{"t":1666164204,"success":true} [10-19 15:23:24:753 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:24:753 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:24:753 TUYA E][tuya_svc_upgrade.c:433] result null [10-19 15:23:24:753 TUYA D][tuya_svc_upgrade.c:508] silent get firmware fail [10-19 15:23:24:753 TUYA D][tuya_svc_upgrade.c:204] next detect timer: 21600s [10-19 15:23:24:753 TUYA N][tuya_svc_timer_task.c:776] Update Timer from cloud [10-19 15:23:24:753 TUYA D][iot_httpc.c:929] Post Data: {"devId":"eb1552c6f83a6b59edmyes","lastFetchTime":"0","t":1666164204} [10-19 15:23:24:753 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.timer.count&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164204&v=4.0&sign=dbb7410d5c1c0efe5b7e4ed1fb22f1c1 [10-19 15:23:24:753 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:24:753 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:24:753 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:24:754 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:24:790 TUYA D][tuya_tls.c:1520] handshake finish for h2.iot-dns.com. set send/recv to user set [10-19 15:23:24:791 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect h2.iot-dns.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:24:800 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{"axw2wati6x8wwqrh":{"shortcut":{"quickOpDps":[],"faultDps":[],"displayDps":[],"displayMsgs":{}}},"gw173aldekvpzalg":{"shortcut":{"quickOpDps":[],"faultDps":[],"displayDps":[],"displayMsgs":{}}},"fboep9j6grtxyga9":{"shortcut":{"quickOpDps":[],"faultDps":[],"displayDps":[20],"switchDp":20,"displayMsgs":{}}},"l9rksbbbisynlnvq":{"shortcut":{"quickOpDps":[1,2],"faultDps":[],"displayDps":[1,2],"displayMsgs":{}}},"pbx8cm1kvgn0fv2d":{"shortcut":{"quickOpDps":[],"faultDps":[],"displayDps":[20,26],"switchDp":20,"displayMsgs":{}}},"mjffeakbzlnfxpzt":{"shortcut":{"quickOpDps":[],"faultDps":[],"displayDps":[],"displayMsgs":{}}},"1vso02tkynsvpinp":{"shortcut":{"quickOpDps":[],"faultDps":[],"displayDps":[],"displayMsgs":{}}},"1svzszztogaibjxa":{"shortcut":{"quickOpDps":[],"faultDps":[],"displayDps":[],"displayMsgs":{}}},"mh9px7cq":{"shortcut":{"quickOpDps":[],"faultDps":[],"displayDps":[],"displayMsgs":{}}},"dgudhgjmxdznjm6d":{"shortcut":{"quickOpDps":[], [10-19 15:23:24:801 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:24:801 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:24:801 TUYA D][tuya_ctrl_center.c:2110] get product cnt: 52 [10-19 15:23:24:802 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:axw2wati6x8wwqrh,p_rcd_info:0x7f94019120 [10-19 15:23:24:802 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:56,p_rcd_info->crc32:4293232989,len:112 key:axw2wati6x8wwqrh. [10-19 15:23:24:802 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:gw173aldekvpzalg,p_rcd_info:0x7f94019154 [10-19 15:23:24:802 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:57,p_rcd_info->crc32:4293232989,len:112 key:gw173aldekvpzalg. [10-19 15:23:24:803 TUYA D][tuya_ctrl_center.c:2055] pid: fboep9j6grtxyga9 switch_dp: 20 [10-19 15:23:24:803 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:fboep9j6grtxyga9,p_rcd_info:0x7f94019188 [10-19 15:23:24:803 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:58,p_rcd_info->crc32:3848699763,len:128 key:fboep9j6grtxyga9. [10-19 15:23:24:803 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:l9rksbbbisynlnvq,p_rcd_info:0x7f940191bc [10-19 15:23:24:803 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:59,p_rcd_info->crc32:1993128249,len:112 key:l9rksbbbisynlnvq. [10-19 15:23:24:804 TUYA D][tuya_ctrl_center.c:2055] pid: pbx8cm1kvgn0fv2d switch_dp: 20 [10-19 15:23:24:804 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:pbx8cm1kvgn0fv2d,p_rcd_info:0x7f940191f0 [10-19 15:23:24:804 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:60,p_rcd_info->crc32:3203251148,len:128 key:pbx8cm1kvgn0fv2d. [10-19 15:23:24:804 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:mjffeakbzlnfxpzt,p_rcd_info:0x7f94019224 [10-19 15:23:24:804 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:61,p_rcd_info->crc32:4293232989,len:112 key:mjffeakbzlnfxpzt. [10-19 15:23:24:805 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:1vso02tkynsvpinp,p_rcd_info:0x7f94019258 [10-19 15:23:24:805 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:62,p_rcd_info->crc32:4293232989,len:112 key:1vso02tkynsvpinp. [10-19 15:23:24:805 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:1svzszztogaibjxa,p_rcd_info:0x7f9401928c [10-19 15:23:24:805 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:63,p_rcd_info->crc32:4293232989,len:112 key:1svzszztogaibjxa. [10-19 15:23:24:806 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:mh9px7cq,p_rcd_info:0x7f940192c0 [10-19 15:23:24:806 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:64,p_rcd_info->crc32:4293232989,len:112 key:mh9px7cq. [10-19 15:23:24:806 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:dgudhgjmxdznjm6d,p_rcd_info:0x7f940192f4 [10-19 15:23:24:806 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:65,p_rcd_info->crc32:4293232989,len:112 key:dgudhgjmxdznjm6d. [10-19 15:23:24:807 TUYA D][tuya_ctrl_center.c:2055] pid: j0zozzoarutv0nu1 switch_dp: 1 [10-19 15:23:24:807 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:j0zozzoarutv0nu1,p_rcd_info:0x7f94019328 [10-19 15:23:24:807 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:66,p_rcd_info->crc32:1786686285,len:128 key:j0zozzoarutv0nu1. [10-19 15:23:24:807 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:7zjewx91,p_rcd_info:0x7f9401935c [10-19 15:23:24:807 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:67,p_rcd_info->crc32:4293232989,len:112 key:7zjewx91. [10-19 15:23:24:808 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:qzktzhehinzsz2je,p_rcd_info:0x7f94019390 [10-19 15:23:24:808 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:68,p_rcd_info->crc32:4293232989,len:112 key:qzktzhehinzsz2je. [10-19 15:23:24:808 TUYA D][tuya_ctrl_center.c:2055] pid: 1aso8gn0szwvjjue switch_dp: 102 [10-19 15:23:24:808 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:1aso8gn0szwvjjue,p_rcd_info:0x7f940193c4 [10-19 15:23:24:809 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:69,p_rcd_info->crc32:3090699162,len:144 key:1aso8gn0szwvjjue. [10-19 15:23:24:809 TUYA D][tuya_ctrl_center.c:2055] pid: ha7agddwqq6ahbiz switch_dp: 3 [10-19 15:23:24:809 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ha7agddwqq6ahbiz,p_rcd_info:0x7f940193f8 [10-19 15:23:24:809 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:70,p_rcd_info->crc32:1256203158,len:144 key:ha7agddwqq6ahbiz. [10-19 15:23:24:809 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:0000008vhd,p_rcd_info:0x7f9401942c [10-19 15:23:24:810 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:71,p_rcd_info->crc32:4293232989,len:112 key:0000008vhd. [10-19 15:23:24:810 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:a33rw7ou,p_rcd_info:0x7f94019460 [10-19 15:23:24:810 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:72,p_rcd_info->crc32:4293232989,len:112 key:a33rw7ou. [10-19 15:23:24:811 TUYA D][tuya_ctrl_center.c:2055] pid: 97cp1wty56mww1o0 switch_dp: 2 [10-19 15:23:24:811 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:97cp1wty56mww1o0,p_rcd_info:0x7f94019494 [10-19 15:23:24:811 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:73,p_rcd_info->crc32:2280076132,len:128 key:97cp1wty56mww1o0. [10-19 15:23:24:811 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:nkkl7uzv,p_rcd_info:0x7f940194c8 [10-19 15:23:24:812 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:74,p_rcd_info->crc32:4293232989,len:112 key:nkkl7uzv. [10-19 15:23:24:812 TUYA D][tuya_ctrl_center.c:2055] pid: 9yyaalraupjaredl switch_dp: 20 [10-19 15:23:24:812 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:9yyaalraupjaredl,p_rcd_info:0x7f940194fc [10-19 15:23:24:812 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:75,p_rcd_info->crc32:3475033586,len:144 key:9yyaalraupjaredl. [10-19 15:23:24:813 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:000000dfug,p_rcd_info:0x7f94019530 [10-19 15:23:24:813 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:76,p_rcd_info->crc32:4293232989,len:112 key:000000dfug. [10-19 15:23:24:813 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:8nd1vkcuwbektfod,p_rcd_info:0x7f94019564 [10-19 15:23:24:813 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:77,p_rcd_info->crc32:479188809,len:128 key:8nd1vkcuwbektfod. [10-19 15:23:24:814 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:2mqosesmkrvlvl0w,p_rcd_info:0x7f94019598 [10-19 15:23:24:814 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:78,p_rcd_info->crc32:4293232989,len:112 key:2mqosesmkrvlvl0w. [10-19 15:23:24:814 TUYA D][tuya_ctrl_center.c:2055] pid: jqo111f6ahvas3tr switch_dp: 1 [10-19 15:23:24:815 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:jqo111f6ahvas3tr,p_rcd_info:0x7f940195cc [10-19 15:23:24:815 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:79,p_rcd_info->crc32:1441943630,len:128 key:jqo111f6ahvas3tr. [10-19 15:23:24:815 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:lmjfyvtsig6v5npw,p_rcd_info:0x7f94019600 [10-19 15:23:24:816 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:80,p_rcd_info->crc32:4293232989,len:112 key:lmjfyvtsig6v5npw. [10-19 15:23:24:816 TUYA D][tuya_ctrl_center.c:2055] pid: 9nauypjb2kvujrut switch_dp: 20 [10-19 15:23:24:816 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:9nauypjb2kvujrut,p_rcd_info:0x7f94019634 [10-19 15:23:24:817 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:81,p_rcd_info->crc32:1448521615,len:144 key:9nauypjb2kvujrut. [10-19 15:23:24:817 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:4fjiwweb,p_rcd_info:0x7f94019668 [10-19 15:23:24:817 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:82,p_rcd_info->crc32:4293232989,len:112 key:4fjiwweb. [10-19 15:23:24:818 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:pj3gdjgpeqao7xk4,p_rcd_info:0x7f9401969c [10-19 15:23:24:818 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:83,p_rcd_info->crc32:4293232989,len:112 key:pj3gdjgpeqao7xk4. [10-19 15:23:24:818 TUYA D][tuya_ctrl_center.c:2055] pid: 6y1cduj4ealrfndo switch_dp: 104 [10-19 15:23:24:818 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:6y1cduj4ealrfndo,p_rcd_info:0x7f940196d0 [10-19 15:23:24:818 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:84,p_rcd_info->crc32:3305474599,len:128 key:6y1cduj4ealrfndo. [10-19 15:23:24:819 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:zach3mptpjpojys6,p_rcd_info:0x7f94019704 [10-19 15:23:24:819 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:85,p_rcd_info->crc32:4293232989,len:112 key:zach3mptpjpojys6. [10-19 15:23:24:819 TUYA D][tuya_ctrl_center.c:2055] pid: jogzi8noyhgcahcq switch_dp: 1 [10-19 15:23:24:819 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:jogzi8noyhgcahcq,p_rcd_info:0x7f94019738 [10-19 15:23:24:820 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:86,p_rcd_info->crc32:1786686285,len:128 key:jogzi8noyhgcahcq. [10-19 15:23:24:820 TUYA D][tuya_ctrl_center.c:2055] pid: dc6v3yjsjhajgb7f switch_dp: 104 [10-19 15:23:24:820 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:dc6v3yjsjhajgb7f,p_rcd_info:0x7f9401976c [10-19 15:23:24:820 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:87,p_rcd_info->crc32:271869457,len:128 key:dc6v3yjsjhajgb7f. [10-19 15:23:24:821 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:oniuxtrf5xu85d69,p_rcd_info:0x7f940197a0 [10-19 15:23:24:821 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:88,p_rcd_info->crc32:4293232989,len:112 key:oniuxtrf5xu85d69. [10-19 15:23:24:821 TUYA D][tuya_ctrl_center.c:2055] pid: qhfvhlm1k0ws0gul switch_dp: 20 [10-19 15:23:24:821 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:qhfvhlm1k0ws0gul,p_rcd_info:0x7f940197d4 [10-19 15:23:24:821 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:89,p_rcd_info->crc32:3203251148,len:128 key:qhfvhlm1k0ws0gul. [10-19 15:23:24:822 TUYA D][tuya_ctrl_center.c:2055] pid: seuwp5kki3tvz3wl switch_dp: 1 [10-19 15:23:24:822 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:seuwp5kki3tvz3wl,p_rcd_info:0x7f94019808 [10-19 15:23:24:822 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:90,p_rcd_info->crc32:1441943630,len:128 key:seuwp5kki3tvz3wl. [10-19 15:23:24:822 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:w906qkrrhd3otiwd,p_rcd_info:0x7f9401983c [10-19 15:23:24:823 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:91,p_rcd_info->crc32:4293232989,len:112 key:w906qkrrhd3otiwd. [10-19 15:23:24:823 TUYA D][tuya_ctrl_center.c:2055] pid: jyupj3fw switch_dp: 6 [10-19 15:23:24:823 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:jyupj3fw,p_rcd_info:0x7f94019870 [10-19 15:23:24:823 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:92,p_rcd_info->crc32:651869455,len:144 key:jyupj3fw. [10-19 15:23:24:824 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:jcamvbr95hdno5ub,p_rcd_info:0x7f940198a4 [10-19 15:23:24:824 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:93,p_rcd_info->crc32:4293232989,len:112 key:jcamvbr95hdno5ub. [10-19 15:23:24:824 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:oqe2ba267qac12ng,p_rcd_info:0x7f940198d8 [10-19 15:23:24:824 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:94,p_rcd_info->crc32:4293232989,len:112 key:oqe2ba267qac12ng. [10-19 15:23:24:825 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:wpxcg1ahziux5tzh,p_rcd_info:0x7f9401990c [10-19 15:23:24:825 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:95,p_rcd_info->crc32:4293232989,len:112 key:wpxcg1ahziux5tzh. [10-19 15:23:24:825 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:grpvptbrpkissnd8,p_rcd_info:0x7f94019940 [10-19 15:23:24:825 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:96,p_rcd_info->crc32:4293232989,len:112 key:grpvptbrpkissnd8. [10-19 15:23:24:826 TUYA D][tuya_ctrl_center.c:2055] pid: 98afxsvjfbobhjw4 switch_dp: 1 [10-19 15:23:24:826 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:98afxsvjfbobhjw4,p_rcd_info:0x7f94019974 [10-19 15:23:24:826 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:97,p_rcd_info->crc32:2715957910,len:128 key:98afxsvjfbobhjw4. [10-19 15:23:24:826 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:2ekuz3dz,p_rcd_info:0x7f940199a8 [10-19 15:23:24:826 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:98,p_rcd_info->crc32:4293232989,len:112 key:2ekuz3dz. [10-19 15:23:24:827 TUYA D][tuya_ctrl_center.c:2055] pid: ajadcojk switch_dp: 3 [10-19 15:23:24:827 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ajadcojk,p_rcd_info:0x7f940199dc [10-19 15:23:24:827 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:99,p_rcd_info->crc32:2777702534,len:128 key:ajadcojk. [10-19 15:23:24:827 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:hfq0xqhjsqmfqkw4,p_rcd_info:0x7f94019a10 [10-19 15:23:24:828 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:100,p_rcd_info->crc32:1527325384,len:112 key:hfq0xqhjsqmfqkw4. [10-19 15:23:24:828 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:yrmpfrig5ndywijq,p_rcd_info:0x7f94019a44 [10-19 15:23:24:828 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:101,p_rcd_info->crc32:4293232989,len:112 key:yrmpfrig5ndywijq. [10-19 15:23:24:828 TUYA D][tuya_ctrl_center.c:2055] pid: manu90xvog2uqakl switch_dp: 1 [10-19 15:23:24:829 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:manu90xvog2uqakl,p_rcd_info:0x7f94019a78 [10-19 15:23:24:829 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:102,p_rcd_info->crc32:1786686285,len:128 key:manu90xvog2uqakl. [10-19 15:23:24:829 TUYA D][tuya_ctrl_center.c:2055] pid: mq2mrjjqlkorvgfe switch_dp: 6 [10-19 15:23:24:829 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:mq2mrjjqlkorvgfe,p_rcd_info:0x7f94019aac [10-19 15:23:24:830 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:103,p_rcd_info->crc32:651869455,len:144 key:mq2mrjjqlkorvgfe. [10-19 15:23:24:830 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:qwpfjxryaj7pr9rw,p_rcd_info:0x7f94019ae0 [10-19 15:23:24:830 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:104,p_rcd_info->crc32:4293232989,len:112 key:qwpfjxryaj7pr9rw. [10-19 15:23:24:830 TUYA D][tuya_ctrl_center.c:2055] pid: 0ln8tfei1iulgo2k switch_dp: 4 [10-19 15:23:24:831 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:0ln8tfei1iulgo2k,p_rcd_info:0x7f94019b14 [10-19 15:23:24:831 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:105,p_rcd_info->crc32:3814711538,len:144 key:0ln8tfei1iulgo2k. [10-19 15:23:24:831 TUYA D][tuya_ctrl_center.c:2055] pid: 9cwtq6di0cz7bikc switch_dp: 1 [10-19 15:23:24:831 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:9cwtq6di0cz7bikc,p_rcd_info:0x7f94019b48 [10-19 15:23:24:832 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:106,p_rcd_info->crc32:1786686285,len:128 key:9cwtq6di0cz7bikc. [10-19 15:23:24:832 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:2ywpwkvsgqujwlgs,p_rcd_info:0x7f94019b7c [10-19 15:23:24:832 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:107,p_rcd_info->crc32:4293232989,len:112 key:2ywpwkvsgqujwlgs. [10-19 15:23:24:833 TUYA D][iot_httpc.c:929] Post Data: {"t":1666164204} [10-19 15:23:24:833 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.screen.device.type.config&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164204&v=1.0&sign=5a6c8cd9b392ab836a3d0ff089b15d55 [10-19 15:23:24:833 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:24:833 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:24:833 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:24:833 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:24:942 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:24:942 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:24:942 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:24:942 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:24:942 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:24:942 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:24:942 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:24:943 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:25:14 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:25:14 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:25:14 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:25:14 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:25:14 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:25:15 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:25:15 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:25:15 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:25:199 TUYA D][iot_httpc.c:678] return chunked:0 [10-19 15:23:25:199 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:25:199 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:25:199 TUYA D][uni_network.c:100] get ip 54.192.76.26 [10-19 15:23:25:200 TUYA D][uni_network.c:197] dns service get ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:25:200 TUYA D][uni_network.c:268] cache dns [imagesd.tuyaus.com]<->[54.192.76.26] [10-19 15:23:25:200 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:25:389 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:25:389 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:25:389 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:25:389 TUYA D][http_manager.c:135] http_send done [10-19 15:23:25:389 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:25:688 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:25:688 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:25:747 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:25:747 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:25:874 TUYA D][rcd_file.c:548] [ty_rcd]__flush_timer_cb start [10-19 15:23:25:875 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94001430 0x576444 94014b20 [10-19 15:23:25:875 TUYA D][thread_pool_temp.c:607] temp run 0x576444 94014b20 [10-19 15:23:25:875 TUYA D][thread_pool_temp.c:197] run temp 0x576444 94014b20 in thread 94001420 BEGIN [10-19 15:23:25:875 TUYA D][rcd_file.c:533] [ty_rcd] __rcd_db_flush start. [10-19 15:23:25:966 TUYA D][rcd_file.c:538] [ty_rcd] __rcd_db_flush end. [10-19 15:23:25:966 TUYA D][thread_pool_temp.c:200] thread 94001420 END [10-19 15:23:25:966 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:25:966 TUYA D][thread_pool_temp.c:143] put thread 0x7f94001430 [10-19 15:23:25:966 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [10-19 15:23:26:59 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{"devId":"eb1552c6f83a6b59edmyes","count":0,"lastFetchTime":0},"t":1666164206,"success":true} [10-19 15:23:26:60 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:26:60 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:26:60 TUYA D][tuya_svc_timer_task.c:435] time eq skip:0 [10-19 15:23:26:60 TUYA D][iot_httpc.c:929] Post Data: {"data":"255","t":1666164206} [10-19 15:23:26:60 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=atop.online.debug.log&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164206&sign=c69ed250a7485af24a40dc3bd5419cb1 [10-19 15:23:26:60 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:26:60 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:26:60 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:26:60 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:26:129 TUYA D][iot_httpc.c:596] Decode Rev:{"result":[{"deviceType":1,"categoryList":["sos","sj","mcs","rqbj","pir","wsdcg"]}],"t":1666164206,"success":true} [10-19 15:23:26:130 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:26:130 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:26:130 TUYA D][tuya_ctrl_storage.c:74] rcd: ctrl_sensor_rule delete tuya_sensor_rule success [10-19 15:23:26:131 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:4,p_rcd_info->crc32:1609444614,len:96 key:tuya_sensor_rule. [10-19 15:23:26:131 TUYA D][iot_httpc.c:929] Post Data: {"t":1666164206} [10-19 15:23:26:131 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.screen.home.device.all&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164206&v=1.0&sign=0547d78b062da553e7484dff1db87d56 [10-19 15:23:26:131 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:26:131 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:26:131 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:26:131 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:26:190 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:26:190 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:26:190 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:26:190 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:26:190 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:26:190 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/curtain.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:26:190 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:26:190 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:26:190 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:26:190 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:26:190 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:26:249 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:26:249 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:26:249 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:26:249 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:26:249 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:26:249 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:26:249 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:26:249 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:26:325 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:26:325 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:26:325 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:26:325 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:26:325 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:26:325 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:26:325 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:26:325 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:26:389 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:26:389 TUYA D][http_manager.c:94] create http session done, session id: 88010640 [10-19 15:23:26:389 TUYA D][http_manager.c:119] http_send: 88010640 [10-19 15:23:26:389 TUYA D][http_manager.c:135] http_send done [10-19 15:23:26:389 TUYA D][http_manager.c:146] http_receive: 88010640 [10-19 15:23:26:588 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:26:588 TUYA D][http_manager.c:196] http_receive: done 88010640 [10-19 15:23:26:588 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:26:588 TUYA D][http_manager.c:12] http_session_destory: 88010640 [10-19 15:23:26:588 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:26:588 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/curtain.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:26:588 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:26:588 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:26:588 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:26:588 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:26:589 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:26:783 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:26:783 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:26:783 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:26:783 TUYA D][http_manager.c:135] http_send done [10-19 15:23:26:783 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:26:798 TUYA D][rcd_file.c:548] [ty_rcd]__flush_timer_cb start [10-19 15:23:26:798 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94001430 0x576444 9404ae20 [10-19 15:23:26:799 TUYA D][thread_pool_temp.c:607] temp run 0x576444 9404ae20 [10-19 15:23:26:799 TUYA D][thread_pool_temp.c:197] run temp 0x576444 9404ae20 in thread 94001420 BEGIN [10-19 15:23:26:799 TUYA D][rcd_file.c:533] [ty_rcd] __rcd_db_flush start. [10-19 15:23:26:811 TUYA D][rcd_file.c:538] [ty_rcd] __rcd_db_flush end. [10-19 15:23:26:811 TUYA D][thread_pool_temp.c:200] thread 94001420 END [10-19 15:23:26:811 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:26:811 TUYA D][thread_pool_temp.c:143] put thread 0x7f94001430 [10-19 15:23:26:811 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [10-19 15:23:26:963 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:26:963 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:26:963 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:26:963 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:26:963 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:26:963 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/curtain.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:26:963 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:26:963 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:26:963 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:26:963 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:26:963 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:27:13 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:27:13 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:27:92 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:27:92 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:27:144 TUYA I][lan_cluster_master_core.c:790] __timer_proc_master_wait. send_cnt[3] [10-19 15:23:27:144 TUYA D][lan_cluster_master_core.c:1321] cluster change status from 0 to 1 [10-19 15:23:27:144 TUYA N][lan_cluster_master_core.c:1333] cluster change status cb new out st 1 master [eb1552c6f83a6b59edmyes] ip[0] [10-19 15:23:27:144 TUYA D][lan_pub_sub_mq.c:243] sub all topic at local [10-19 15:23:27:144 TUYA D][lan_pub_sub_mq_center.c:144] add topic[LAN_DP_UP] suber[local] [10-19 15:23:27:144 TUYA D][lan_pub_sub_mq_center.c:144] add topic[LAN_DEV_LIST_SYNC] suber[local] [10-19 15:23:27:144 TUYA D][lan_pub_sub_mq_center.c:144] add topic[LAN_SECURITY] suber[local] [10-19 15:23:27:144 TUYA I][uni_thread.c:220] thread_create name:lan_key_exch,stackDepth:4096,totalstackDepth:141312,priority:4 [10-19 15:23:27:145 TUYA D][scene_linkage_lan_master.c:350] __cluster_state_change -> 1 [10-19 15:23:27:145 TUYA D][uni_thread.c:247] Thread:lan_key_exch Exec Start. Set to Running Stat [10-19 15:23:27:145 TUYA D][scene_linkage_rule_sync.c:1268] scene_linkage_update_from_server linkage_type:1 delaymS:60000 [10-19 15:23:27:151 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:27:151 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:27:151 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:27:151 TUYA D][http_manager.c:135] http_send done [10-19 15:23:27:151 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:27:285 TUYA D][thread_pool_temp.c:413] check delay task num=2 [10-19 15:23:27:285 TUYA D][thread_pool_temp.c:607] temp run 0x58bbd8 0 [10-19 15:23:27:285 TUYA D][thread_pool_temp.c:449] check delay task wait 5000 [10-19 15:23:27:285 TUYA D][thread_pool_temp.c:197] run temp 0x58bbd8 0 in thread 94001420 BEGIN [10-19 15:23:27:286 TUYA D][iot_httpc.c:929] Post Data: {"typeAttribute":8,"t":1666164207} [10-19 15:23:27:286 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.local.group.relation.get&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164207&v=1.0&sign=919e5abc195f1f41f3c5b4c7d0f3478a [10-19 15:23:27:286 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:27:286 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:27:286 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:27:286 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:27:338 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:27:338 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:27:338 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:27:338 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:27:338 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:27:338 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/curtain.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:27:338 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:27:338 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:27:338 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:27:338 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:27:338 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:27:377 TUYA D][iot_httpc.c:596] Decode Rev:{"result":true,"t":1666164207,"success":true} [10-19 15:23:27:377 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:27:378 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:27:378 TUYA D][tuya_devos_entry.c:406] put rst log finish [10-19 15:23:27:378 TUYA D][iot_httpc.c:929] Post Data: {"type":"[\"timezone\",\"rateRule\"]","t":1666164207} [10-19 15:23:27:378 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.dynamic.config.get&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164207&v=2.0&sign=e9903861ff82002f4c18178e474ec00f [10-19 15:23:27:378 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:27:378 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:27:378 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:27:378 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:27:477 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:27:477 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:27:477 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:27:477 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:27:477 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:27:477 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:27:478 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:27:478 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:27:519 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:27:519 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:27:519 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:27:519 TUYA D][http_manager.c:135] http_send done [10-19 15:23:27:519 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:27:572 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:27:572 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:27:572 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:27:572 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:27:572 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:27:572 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:27:572 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:27:572 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:27:712 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:27:712 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:27:712 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:27:712 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:27:712 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:27:712 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/curtain.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:27:712 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/rule/glyphicons/holiday.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:27:712 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:27:712 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:27:712 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:27:712 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:27:713 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:27:783 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:27:783 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:27:837 TUYA D][rcd_file.c:548] [ty_rcd]__flush_timer_cb start [10-19 15:23:27:837 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94001430 0x576444 94018730 [10-19 15:23:27:837 TUYA D][thread_pool_temp.c:607] temp run 0x576444 94018730 [10-19 15:23:27:837 TUYA D][thread_pool_temp.c:197] run temp 0x576444 94018730 in thread 940013f0 BEGIN [10-19 15:23:27:837 TUYA D][rcd_file.c:533] [ty_rcd] __rcd_db_flush start. [10-19 15:23:27:848 TUYA D][rcd_file.c:538] [ty_rcd] __rcd_db_flush end. [10-19 15:23:27:848 TUYA D][thread_pool_temp.c:200] thread 940013f0 END [10-19 15:23:27:848 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:27:848 TUYA D][thread_pool_temp.c:143] put thread 0x7f94001430 [10-19 15:23:27:848 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:1 [10-19 15:23:27:916 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:27:916 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:27:916 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:27:916 TUYA D][http_manager.c:135] http_send done [10-19 15:23:27:916 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:28:8 TUYA D][iot_httpc.c:438] chunk_num.2 [10-19 15:23:28:101 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:28:101 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:28:101 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:28:101 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:28:101 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:28:101 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/holiday.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:28:101 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:28:101 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:28:101 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:28:101 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:28:101 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:28:198 TUYA D][iot_httpc.c:438] chunk_num.3 [10-19 15:23:28:208 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{"timezone":{"validTime":1800,"time":1666164208,"config":{}}},"t":1666164208,"success":true} [10-19 15:23:28:209 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:28:209 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:28:209 TUYA D][iot_httpc.c:3274] dynamic cfg post data:{"type":"[\"timezone\",\"rateRule\"]","t":1666164207}, ret:0. [10-19 15:23:28:209 TUYA D][tuya_devos_utils.c:205] set dp rate_rule:{"timezone":{"validTime":1800,"time":1666164208,"config":{}}}. [10-19 15:23:28:209 TUYA D][tuya_devos_utils.c:94] reset dp rate rule finish. [10-19 15:23:28:209 TUYA D][iot_httpc.c:2346] NO ackId [10-19 15:23:28:217 TUYA D][iot_httpc.c:438] chunk_num.4 [10-19 15:23:28:281 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:28:281 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:28:281 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:28:281 TUYA D][http_manager.c:135] http_send done [10-19 15:23:28:281 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:28:287 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:28:287 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:28:388 TUYA D][iot_httpc.c:457] total_len:103055 [10-19 15:23:28:465 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:28:465 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:28:465 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:28:465 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:28:465 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:28:465 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/holiday.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:28:465 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:28:465 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:28:465 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:28:465 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:28:465 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:28:595 TUYA D][iot_httpc.c:596] Decode Rev:{"result":[{"virtual":false,"lon":"113.8554","ownerId":"77850135","uuid":"a4c1384c59b8c6ff","mac":"a4c1384c59b8c6ff","accessType":0,"otaInfo":{"supportAuto":true,"otaUpgradeModes":[0],"otaModuleMap":{"zigbee":{"upgradeStatus":0,"cdv":"","verSw":"1.0.6"}}},"iconUrl":"https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/162615470435b99f0456c.png","communication":{"communicationNode":"eb257c7e0da82bf6fdgo2g","communicationModes":[{"pv":"","type":0},{"pv":"2.2","type":1}],"connectionStatus":0},"lat":"22.5904","runtimeEnv":"prod","devKey":"","devId":"ebd0ad496c403f1af3i9an","productId":"a33rw7ou","ip":"","activeTime":1666083500,"cloudOnline":false,"baseAttribute":0,"devAttribute":2048,"dataPointInfo":{"dpMaxTime":1666083500623,"dpName":{},"dps":{"1":false,"2":100},"dpsTime":{"1":1666083500623,"2":1666083500623}},"name":"Zigbee Contact Sensor","timezoneId":"Asia/Shanghai","deviceTopo":{"parentDevId":"eb257c7e0da82bf6fdgo2g","nodeId":"a4c1384c59b8c6ff" [10-19 15:23:28:612 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:28:612 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:28:612 TUYA D][tuya_ctrl_center.c:1422] get dev_cnt: 60 [10-19 15:23:28:613 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:613 TUYA D][tuya_ctrl_center.c:1337] update devId: ebd0ad496c403f1af3i9an name: Zigbee Contact Sensor pid: a33rw7ou comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: a4c1384c59b8c6ff dev_num: 60 [10-19 15:23:28:613 TUYA W][tuya_ctrl_storage.c:143] dev:ebd0ad496c403f1af3i9an, dp name is null [10-19 15:23:28:613 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebd0ad496c403f1af3i9an,p_rcd_info:0x7f9401d7e0 [10-19 15:23:28:614 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:80,p_rcd_info->crc32:3918558865,len:1232 key:ebd0ad496c403f1af3i9an. [10-19 15:23:28:614 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:614 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:614 TUYA D][tuya_ctrl_center.c:1337] update devId: eb257c7e0da82bf6fdgo2g name: Zigbee LAN Gateway pid: axw2wati6x8wwqrh comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:614 TUYA W][tuya_ctrl_storage.c:143] dev:eb257c7e0da82bf6fdgo2g, dp name is null [10-19 15:23:28:614 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb257c7e0da82bf6fdgo2g,p_rcd_info:0x7f9401d814 [10-19 15:23:28:615 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:81,p_rcd_info->crc32:1686685308,len:1232 key:eb257c7e0da82bf6fdgo2g. [10-19 15:23:28:615 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:615 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: Switch 1 [10-19 15:23:28:615 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: Switch 2 [10-19 15:23:28:615 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: Switch 3 [10-19 15:23:28:616 TUYA D][tuya_ctrl_center.c:1337] update devId: eb0f65ca9465be8edcoyot name: ZigBee 3 Gang Switch pid: ajadcojk comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: 9035eafffe583c5a dev_num: 60 [10-19 15:23:28:616 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb0f65ca9465be8edcoyot, serialize dp_names = {"1":"Switch 1","2":"Switch 2","3":"Switch 3"} [10-19 15:23:28:616 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb0f65ca9465be8edcoyot,p_rcd_info:0x7f9401d848 [10-19 15:23:28:616 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:82,p_rcd_info->crc32:1593605643,len:1232 key:eb0f65ca9465be8edcoyot. [10-19 15:23:28:617 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:617 TUYA D][tuya_ctrl_center.c:1337] update devId: ebf673a55509854f89o4ms name: Switch of scene pid: mh9px7cq comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: a4c138389b2e90c3 dev_num: 60 [10-19 15:23:28:617 TUYA W][tuya_ctrl_storage.c:143] dev:ebf673a55509854f89o4ms, dp name is null [10-19 15:23:28:617 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebf673a55509854f89o4ms,p_rcd_info:0x7f9401d87c [10-19 15:23:28:618 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:83,p_rcd_info->crc32:3826706150,len:1232 key:ebf673a55509854f89o4ms. [10-19 15:23:28:618 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:618 TUYA D][tuya_ctrl_center.c:1337] update devId: ebe5c0ea9264da5aedqyqx name: 4'' Smart panel-EU pid: 2ywpwkvsgqujwlgs comm: ebe5c0ea9264da5aedqyqx pv: 2.2 sub: 0 node: 05e0 dev_num: 60 [10-19 15:23:28:618 TUYA W][tuya_ctrl_storage.c:143] dev:ebe5c0ea9264da5aedqyqx, dp name is null [10-19 15:23:28:619 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebe5c0ea9264da5aedqyqx,p_rcd_info:0x7f9401d8b0 [10-19 15:23:28:619 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:84,p_rcd_info->crc32:1342546565,len:1232 key:ebe5c0ea9264da5aedqyqx. [10-19 15:23:28:619 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:620 TUYA D][tuya_ctrl_center.c:1337] update devId: ebabc77077c75fec391svt name: Zigbee Smart Thermostat pid: 2ekuz3dz comm: eb99a9cc76209358a4crkr pv: 2.2 sub: 1 node: a4c1388ce8e59bc8 dev_num: 60 [10-19 15:23:28:620 TUYA W][tuya_ctrl_storage.c:143] dev:ebabc77077c75fec391svt, dp name is null [10-19 15:23:28:620 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebabc77077c75fec391svt,p_rcd_info:0x7f9401d8e4 [10-19 15:23:28:620 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:85,p_rcd_info->crc32:1342355211,len:1232 key:ebabc77077c75fec391svt. [10-19 15:23:28:621 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:621 TUYA D][tuya_ctrl_center.c:1337] update devId: ebe2744515d20294b1yhgw name: Zigbee Repeater pid: nkkl7uzv comm: eb99a9cc76209358a4crkr pv: 2.2 sub: 1 node: b4e3f9fffe3e0834 dev_num: 60 [10-19 15:23:28:621 TUYA W][tuya_ctrl_storage.c:143] dev:ebe2744515d20294b1yhgw, dp name is null [10-19 15:23:28:621 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebe2744515d20294b1yhgw,p_rcd_info:0x7f9401d918 [10-19 15:23:28:622 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:86,p_rcd_info->crc32:190962717,len:1232 key:ebe2744515d20294b1yhgw. [10-19 15:23:28:622 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:622 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:622 TUYA D][tuya_ctrl_center.c:1337] update devId: eb99a9cc76209358a4crkr name: Gateway pid: 7zjewx91 comm: eb99a9cc76209358a4crkr pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:622 TUYA W][tuya_ctrl_storage.c:143] dev:eb99a9cc76209358a4crkr, dp name is null [10-19 15:23:28:623 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb99a9cc76209358a4crkr,p_rcd_info:0x7f9401d94c [10-19 15:23:28:623 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:87,p_rcd_info->crc32:674601886,len:1216 key:eb99a9cc76209358a4crkr. [10-19 15:23:28:624 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:624 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:624 TUYA D][tuya_ctrl_center.c:1337] update devId: eb67a0efcb59444d01ydgn name: 智能插座 pid: grpvptbrpkissnd8 comm: eb67a0efcb59444d01ydgn pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:624 TUYA W][tuya_ctrl_storage.c:143] dev:eb67a0efcb59444d01ydgn, dp name is null [10-19 15:23:28:624 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb67a0efcb59444d01ydgn,p_rcd_info:0x7f9401d980 [10-19 15:23:28:625 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:88,p_rcd_info->crc32:4149765423,len:1232 key:eb67a0efcb59444d01ydgn. [10-19 15:23:28:625 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:625 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:625 TUYA D][tuya_ctrl_center.c:1337] update devId: ebe7f7541d3a5e34dcplwr name: RGB strip pid: pbx8cm1kvgn0fv2d comm: ebe7f7541d3a5e34dcplwr pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:625 TUYA W][tuya_ctrl_storage.c:143] dev:ebe7f7541d3a5e34dcplwr, dp name is null [10-19 15:23:28:625 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebe7f7541d3a5e34dcplwr,p_rcd_info:0x7f9401d9b4 [10-19 15:23:28:626 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:89,p_rcd_info->crc32:2691424295,len:1216 key:ebe7f7541d3a5e34dcplwr. [10-19 15:23:28:626 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:626 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:626 TUYA D][tuya_ctrl_center.c:1337] update devId: eb62263aaf2f73ef03xira name: 智能彩灯 pid: qhfvhlm1k0ws0gul comm: eb62263aaf2f73ef03xira pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:626 TUYA W][tuya_ctrl_storage.c:143] dev:eb62263aaf2f73ef03xira, dp name is null [10-19 15:23:28:627 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb62263aaf2f73ef03xira,p_rcd_info:0x7f9401d9e8 [10-19 15:23:28:627 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:90,p_rcd_info->crc32:4039949835,len:1232 key:eb62263aaf2f73ef03xira. [10-19 15:23:28:628 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:628 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:628 TUYA D][tuya_ctrl_center.c:1337] update devId: ebb800d543876b9d83jiah name: Alarm Security System pid: dc6v3yjsjhajgb7f comm: ebb800d543876b9d83jiah pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:628 TUYA W][tuya_ctrl_storage.c:143] dev:ebb800d543876b9d83jiah, dp name is null [10-19 15:23:28:628 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebb800d543876b9d83jiah,p_rcd_info:0x7f9401da1c [10-19 15:23:28:629 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:91,p_rcd_info->crc32:2742674593,len:1232 key:ebb800d543876b9d83jiah. [10-19 15:23:28:629 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:629 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:629 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: Switch 1 [10-19 15:23:28:629 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: Switch 2 [10-19 15:23:28:629 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: Switch 3 [10-19 15:23:28:629 TUYA D][tuya_ctrl_center.c:1202] dp: 4 name: Switch 4 [10-19 15:23:28:629 TUYA D][tuya_ctrl_center.c:1202] dp: 5 name: Switch 5 [10-19 15:23:28:629 TUYA D][tuya_ctrl_center.c:1202] dp: 16 name: Backlight Switch [10-19 15:23:28:629 TUYA D][tuya_ctrl_center.c:1202] dp: 6 name: Switch 6 [10-19 15:23:28:630 TUYA D][tuya_ctrl_center.c:1202] dp: 19 name: Delay-off Schedule [10-19 15:23:28:630 TUYA E][tuya_ctrl_center.c:1205] id: 19 not find [10-19 15:23:28:630 TUYA D][tuya_ctrl_center.c:1337] update devId: ebc78c65e28bc1347ac761 name: 4X4 Switch+Socket pid: 0ln8tfei1iulgo2k comm: ebc78c65e28bc1347ac761 pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:630 TUYA D][tuya_ctrl_storage.c:169] dev_id : ebc78c65e28bc1347ac761, serialize dp_names = {"1":"Switch 1","2":"Switch 2","3":"Switch 3","4":"Switch 4","5":"Switch 5","6":"Switch 6","16":"Backlight Switch"} [10-19 15:23:28:630 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebc78c65e28bc1347ac761,p_rcd_info:0x7f9401da50 [10-19 15:23:28:630 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:92,p_rcd_info->crc32:3723984107,len:1232 key:ebc78c65e28bc1347ac761. [10-19 15:23:28:631 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:631 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:631 TUYA D][tuya_ctrl_center.c:1337] update devId: eb3b1fefe57125bb72nrzb name: Curtain switch pid: 1aso8gn0szwvjjue comm: eb3b1fefe57125bb72nrzb pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:631 TUYA W][tuya_ctrl_storage.c:143] dev:eb3b1fefe57125bb72nrzb, dp name is null [10-19 15:23:28:631 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb3b1fefe57125bb72nrzb,p_rcd_info:0x7f9401da84 [10-19 15:23:28:632 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:93,p_rcd_info->crc32:4238522071,len:1232 key:eb3b1fefe57125bb72nrzb. [10-19 15:23:28:632 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:632 TUYA D][tuya_ctrl_center.c:1337] update devId: eb9e43a7db146d1286luio name: 空调 pid: 0000008vhd comm: eb87649dc6a4ae7fef87xr pv: 2.2 sub: 1 node: f919e9057b0bfb2b dev_num: 60 [10-19 15:23:28:632 TUYA W][tuya_ctrl_storage.c:143] dev:eb9e43a7db146d1286luio, dp name is null [10-19 15:23:28:633 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb9e43a7db146d1286luio,p_rcd_info:0x7f9401dab8 [10-19 15:23:28:633 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:94,p_rcd_info->crc32:2962929744,len:1200 key:eb9e43a7db146d1286luio. [10-19 15:23:28:634 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:634 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:634 TUYA D][tuya_ctrl_center.c:1337] update devId: eb87649dc6a4ae7fef87xr name: 智能红外遥控器 pid: mjffeakbzlnfxpzt comm: eb87649dc6a4ae7fef87xr pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:634 TUYA W][tuya_ctrl_storage.c:143] dev:eb87649dc6a4ae7fef87xr, dp name is null [10-19 15:23:28:634 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb87649dc6a4ae7fef87xr,p_rcd_info:0x7f9401daec [10-19 15:23:28:635 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:95,p_rcd_info->crc32:3002071898,len:1232 key:eb87649dc6a4ae7fef87xr. [10-19 15:23:28:635 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:635 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:635 TUYA D][tuya_ctrl_center.c:1202] dp: 110 name: 闹钟2 [10-19 15:23:28:635 TUYA E][tuya_ctrl_center.c:1205] id: 110 not find [10-19 15:23:28:635 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: 彩灯 [10-19 15:23:28:635 TUYA D][tuya_ctrl_center.c:1202] dp: 102 name: 炫彩 [10-19 15:23:28:635 TUYA E][tuya_ctrl_center.c:1205] id: 102 not find [10-19 15:23:28:635 TUYA D][tuya_ctrl_center.c:1202] dp: 104 name: 夜灯 [10-19 15:23:28:636 TUYA E][tuya_ctrl_center.c:1205] id: 104 not find [10-19 15:23:28:636 TUYA D][tuya_ctrl_center.c:1202] dp: 106 name: 伴睡 [10-19 15:23:28:636 TUYA E][tuya_ctrl_center.c:1205] id: 106 not find [10-19 15:23:28:636 TUYA D][tuya_ctrl_center.c:1202] dp: 108 name: 闹钟1 [10-19 15:23:28:636 TUYA E][tuya_ctrl_center.c:1205] id: 108 not find [10-19 15:23:28:636 TUYA D][tuya_ctrl_center.c:1337] update devId: eb76889250a9917161wng9 name: Smart Color Ambiance Light pid: 6y1cduj4ealrfndo comm: eb76889250a9917161wng9 pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:636 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb76889250a9917161wng9, serialize dp_names = {"2":"彩灯"} [10-19 15:23:28:636 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb76889250a9917161wng9,p_rcd_info:0x7f9401db20 [10-19 15:23:28:637 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:96,p_rcd_info->crc32:4052856240,len:1248 key:eb76889250a9917161wng9. [10-19 15:23:28:637 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:637 TUYA D][tuya_ctrl_center.c:1337] update devId: ebff3d1dac6c9c54ebu58o name: 门铃按钮 pid: 2mqosesmkrvlvl0w comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: 0995C0FF dev_num: 60 [10-19 15:23:28:637 TUYA W][tuya_ctrl_storage.c:143] dev:ebff3d1dac6c9c54ebu58o, dp name is null [10-19 15:23:28:637 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebff3d1dac6c9c54ebu58o,p_rcd_info:0x7f9401db54 [10-19 15:23:28:638 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:97,p_rcd_info->crc32:1962596506,len:1200 key:ebff3d1dac6c9c54ebu58o. [10-19 15:23:28:638 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:638 TUYA D][tuya_ctrl_center.c:1337] update devId: eb3edad403134c4f6czxy4 name: 人体传感器 pid: jcamvbr95hdno5ub comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: AD2250FF dev_num: 60 [10-19 15:23:28:639 TUYA W][tuya_ctrl_storage.c:143] dev:eb3edad403134c4f6czxy4, dp name is null [10-19 15:23:28:639 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb3edad403134c4f6czxy4,p_rcd_info:0x7f9401db88 [10-19 15:23:28:639 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:98,p_rcd_info->crc32:3496148860,len:1216 key:eb3edad403134c4f6czxy4. [10-19 15:23:28:640 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:640 TUYA D][tuya_ctrl_center.c:1337] update devId: ebd959f9cc5a9857b2zsoo name: 遥控器 pid: zach3mptpjpojys6 comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: 5ECA80FF dev_num: 60 [10-19 15:23:28:640 TUYA W][tuya_ctrl_storage.c:143] dev:ebd959f9cc5a9857b2zsoo, dp name is null [10-19 15:23:28:640 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebd959f9cc5a9857b2zsoo,p_rcd_info:0x7f9401dbbc [10-19 15:23:28:641 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:99,p_rcd_info->crc32:1510184285,len:1200 key:ebd959f9cc5a9857b2zsoo. [10-19 15:23:28:641 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:641 TUYA D][tuya_ctrl_center.c:1337] update devId: eb92c47fe161c74b89dk25 name: 门磁 pid: wpxcg1ahziux5tzh comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: 83DF08FF dev_num: 60 [10-19 15:23:28:641 TUYA W][tuya_ctrl_storage.c:143] dev:eb92c47fe161c74b89dk25, dp name is null [10-19 15:23:28:642 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb92c47fe161c74b89dk25,p_rcd_info:0x7f9401dbf0 [10-19 15:23:28:642 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:100,p_rcd_info->crc32:2772803983,len:1200 key:eb92c47fe161c74b89dk25. [10-19 15:23:28:642 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:642 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:643 TUYA E][tuya_ctrl_center.c:1124] dev: ebf8fee6f4298432a5eqvk not find dp: 0 [10-19 15:23:28:643 TUYA E][tuya_ctrl_center.c:1124] dev: ebf8fee6f4298432a5eqvk not find dp: 0 [10-19 15:23:28:643 TUYA E][tuya_ctrl_center.c:1124] dev: ebf8fee6f4298432a5eqvk not find dp: 0 [10-19 15:23:28:643 TUYA D][tuya_ctrl_center.c:1337] update devId: ebf8fee6f4298432a5eqvk name: 智能网关 pid: 1vso02tkynsvpinp comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:643 TUYA W][tuya_ctrl_storage.c:143] dev:ebf8fee6f4298432a5eqvk, dp name is null [10-19 15:23:28:643 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebf8fee6f4298432a5eqvk,p_rcd_info:0x7f9401dc24 [10-19 15:23:28:644 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:101,p_rcd_info->crc32:538497749,len:1232 key:ebf8fee6f4298432a5eqvk. [10-19 15:23:28:644 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:644 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:644 TUYA D][tuya_ctrl_center.c:1337] update devId: eb8607e2c51bffc942fczo name: 红外射频遥控器 3 pid: lmjfyvtsig6v5npw comm: eb8607e2c51bffc942fczo pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:644 TUYA W][tuya_ctrl_storage.c:143] dev:eb8607e2c51bffc942fczo, dp name is null [10-19 15:23:28:644 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb8607e2c51bffc942fczo,p_rcd_info:0x7f9401dc58 [10-19 15:23:28:645 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:102,p_rcd_info->crc32:4262366154,len:1232 key:eb8607e2c51bffc942fczo. [10-19 15:23:28:645 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:645 TUYA D][tuya_ctrl_center.c:1337] update devId: ebf911148e218a63b67uf3 name: Air pid: 000000dfug comm: ebd88c655bdd4b39adihqe pv: 2.2 sub: 1 node: f919e9057b0bfb2b dev_num: 60 [10-19 15:23:28:645 TUYA W][tuya_ctrl_storage.c:143] dev:ebf911148e218a63b67uf3, dp name is null [10-19 15:23:28:646 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebf911148e218a63b67uf3,p_rcd_info:0x7f9401dc8c [10-19 15:23:28:646 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:103,p_rcd_info->crc32:2783521018,len:1200 key:ebf911148e218a63b67uf3. [10-19 15:23:28:647 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:647 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:647 TUYA D][tuya_ctrl_center.c:1337] update devId: ebd88c655bdd4b39adihqe name: 智能红外遥控器 pid: oniuxtrf5xu85d69 comm: ebd88c655bdd4b39adihqe pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:647 TUYA W][tuya_ctrl_storage.c:143] dev:ebd88c655bdd4b39adihqe, dp name is null [10-19 15:23:28:647 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebd88c655bdd4b39adihqe,p_rcd_info:0x7f9401dcc0 [10-19 15:23:28:648 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:104,p_rcd_info->crc32:454147156,len:1232 key:ebd88c655bdd4b39adihqe. [10-19 15:23:28:648 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:648 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:648 TUYA D][tuya_ctrl_center.c:1337] update devId: eb46ca57fbaaa5a173n9zv name: 红外射频遥控器 2 pid: lmjfyvtsig6v5npw comm: eb46ca57fbaaa5a173n9zv pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:648 TUYA W][tuya_ctrl_storage.c:143] dev:eb46ca57fbaaa5a173n9zv, dp name is null [10-19 15:23:28:649 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb46ca57fbaaa5a173n9zv,p_rcd_info:0x7f9401dcf4 [10-19 15:23:28:649 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:105,p_rcd_info->crc32:4122684231,len:1232 key:eb46ca57fbaaa5a173n9zv. [10-19 15:23:28:650 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:650 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:650 TUYA D][tuya_ctrl_center.c:1337] update devId: eb92b0479e015fbbaavltv name: 智能红外遥控器 pid: hfq0xqhjsqmfqkw4 comm: eb92b0479e015fbbaavltv pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:650 TUYA W][tuya_ctrl_storage.c:143] dev:eb92b0479e015fbbaavltv, dp name is null [10-19 15:23:28:650 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb92b0479e015fbbaavltv,p_rcd_info:0x7f9401dd28 [10-19 15:23:28:651 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:106,p_rcd_info->crc32:3460245617,len:1232 key:eb92b0479e015fbbaavltv. [10-19 15:23:28:651 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:651 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:651 TUYA D][tuya_ctrl_center.c:1202] dp: 44 name: Switch inching [10-19 15:23:28:651 TUYA E][tuya_ctrl_center.c:1205] id: 44 not find [10-19 15:23:28:651 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: Switch 1 [10-19 15:23:28:651 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: Switch 2 [10-19 15:23:28:651 TUYA D][tuya_ctrl_center.c:1337] update devId: ebaf2b250cb41e058ekxqm name: Smart Dual Socket 2 pid: 97cp1wty56mww1o0 comm: ebaf2b250cb41e058ekxqm pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:651 TUYA D][tuya_ctrl_storage.c:169] dev_id : ebaf2b250cb41e058ekxqm, serialize dp_names = {"1":"Switch 1","2":"Switch 2"} [10-19 15:23:28:652 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebaf2b250cb41e058ekxqm,p_rcd_info:0x7f9401dd5c [10-19 15:23:28:652 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:107,p_rcd_info->crc32:4155397716,len:1232 key:ebaf2b250cb41e058ekxqm. [10-19 15:23:28:653 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:653 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:653 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: Switch 1 [10-19 15:23:28:653 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: Switch 2 [10-19 15:23:28:653 TUYA D][tuya_ctrl_center.c:1337] update devId: eb09bad8e75f6222acaglz name: Intelligent Switcher 2CH pid: l9rksbbbisynlnvq comm: eb09bad8e75f6222acaglz pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:653 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb09bad8e75f6222acaglz, serialize dp_names = {"1":"Switch 1","2":"Switch 2"} [10-19 15:23:28:653 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb09bad8e75f6222acaglz,p_rcd_info:0x7f9401dd90 [10-19 15:23:28:654 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:108,p_rcd_info->crc32:415818497,len:1232 key:eb09bad8e75f6222acaglz. [10-19 15:23:28:654 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:654 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:654 TUYA D][tuya_ctrl_center.c:1337] update devId: eb9c17916f715a30e0a7mz name: Intelligent Switcher 2 pid: 98afxsvjfbobhjw4 comm: eb9c17916f715a30e0a7mz pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:655 TUYA W][tuya_ctrl_storage.c:143] dev:eb9c17916f715a30e0a7mz, dp name is null [10-19 15:23:28:655 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb9c17916f715a30e0a7mz,p_rcd_info:0x7f9401ddc4 [10-19 15:23:28:655 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:28:655 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:28:655 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:28:655 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:109,p_rcd_info->crc32:127778021,len:1232 key:eb9c17916f715a30e0a7mz. [10-19 15:23:28:656 TUYA D][http_manager.c:135] http_send done [10-19 15:23:28:656 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:28:656 TUYA W][tuya_ctrl_center.c:1255] dev: vdevo166201192349972 is virtual [10-19 15:23:28:656 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:656 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:656 TUYA D][tuya_ctrl_center.c:1337] update devId: vdevo166201192349972 name: 幻彩2期-oem-vdevo pid: fboep9j6grtxyga9 comm: vdevo166201192349972 pv: 2.0 sub: 0 node: dev_num: 60 [10-19 15:23:28:656 TUYA W][tuya_ctrl_storage.c:143] dev:vdevo166201192349972, dp name is null [10-19 15:23:28:656 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:vdevo166201192349972,p_rcd_info:0x7f9401ddf8 [10-19 15:23:28:657 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:110,p_rcd_info->crc32:3390062447,len:1216 key:vdevo166201192349972. [10-19 15:23:28:657 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:657 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:658 TUYA D][tuya_ctrl_center.c:1202] dp: 44 name: 点动开关 [10-19 15:23:28:658 TUYA E][tuya_ctrl_center.c:1205] id: 44 not find [10-19 15:23:28:658 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: 开关1 [10-19 15:23:28:658 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: 开关2 [10-19 15:23:28:658 TUYA D][tuya_ctrl_center.c:1337] update devId: eb62f037dd6640bfa41gut name: Smart Dual Socket pid: 97cp1wty56mww1o0 comm: eb62f037dd6640bfa41gut pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:658 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb62f037dd6640bfa41gut, serialize dp_names = {"1":"开关1","2":"开关2"} [10-19 15:23:28:658 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb62f037dd6640bfa41gut,p_rcd_info:0x7f9401de2c [10-19 15:23:28:659 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:111,p_rcd_info->crc32:2395713849,len:1232 key:eb62f037dd6640bfa41gut. [10-19 15:23:28:659 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:659 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:659 TUYA D][tuya_ctrl_center.c:1337] update devId: eb4576f5222b16dccaaazi name: WIFI lamp tape 2 pid: 9yyaalraupjaredl comm: eb4576f5222b16dccaaazi pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:659 TUYA W][tuya_ctrl_storage.c:143] dev:eb4576f5222b16dccaaazi, dp name is null [10-19 15:23:28:660 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb4576f5222b16dccaaazi,p_rcd_info:0x7f9401de60 [10-19 15:23:28:660 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:112,p_rcd_info->crc32:1571539006,len:1232 key:eb4576f5222b16dccaaazi. [10-19 15:23:28:661 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:661 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:661 TUYA D][tuya_ctrl_center.c:1337] update devId: ebb063750d514d878079mw name: 计量微断开关(1P+N) pid: manu90xvog2uqakl comm: ebb063750d514d878079mw pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:661 TUYA W][tuya_ctrl_storage.c:143] dev:ebb063750d514d878079mw, dp name is null [10-19 15:23:28:661 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebb063750d514d878079mw,p_rcd_info:0x7f9401de94 [10-19 15:23:28:662 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:113,p_rcd_info->crc32:3921719118,len:1248 key:ebb063750d514d878079mw. [10-19 15:23:28:662 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:662 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:662 TUYA D][tuya_ctrl_center.c:1337] update devId: eba407ffd4d23748c3rlsw name: Intelligent Switcher pid: 98afxsvjfbobhjw4 comm: eba407ffd4d23748c3rlsw pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:662 TUYA W][tuya_ctrl_storage.c:143] dev:eba407ffd4d23748c3rlsw, dp name is null [10-19 15:23:28:663 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eba407ffd4d23748c3rlsw,p_rcd_info:0x7f9401dec8 [10-19 15:23:28:663 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:114,p_rcd_info->crc32:1135417004,len:1232 key:eba407ffd4d23748c3rlsw. [10-19 15:23:28:664 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:664 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:664 TUYA D][tuya_ctrl_center.c:1337] update devId: eb0058bee16ce0c70aq9nj name: Temp pid: gw173aldekvpzalg comm: eb0058bee16ce0c70aq9nj pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:664 TUYA W][tuya_ctrl_storage.c:143] dev:eb0058bee16ce0c70aq9nj, dp name is null [10-19 15:23:28:664 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb0058bee16ce0c70aq9nj,p_rcd_info:0x7f9401defc [10-19 15:23:28:665 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:115,p_rcd_info->crc32:3453095001,len:1216 key:eb0058bee16ce0c70aq9nj. [10-19 15:23:28:665 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:665 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:665 TUYA D][tuya_ctrl_center.c:1337] update devId: eb68d8dbe4707224e8sxd8 name: Wifi Plug pid: j0zozzoarutv0nu1 comm: eb68d8dbe4707224e8sxd8 pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:665 TUYA W][tuya_ctrl_storage.c:143] dev:eb68d8dbe4707224e8sxd8, dp name is null [10-19 15:23:28:666 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb68d8dbe4707224e8sxd8,p_rcd_info:0x7f9401df30 [10-19 15:23:28:666 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:116,p_rcd_info->crc32:3217080471,len:1216 key:eb68d8dbe4707224e8sxd8. [10-19 15:23:28:666 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:667 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:667 TUYA D][tuya_ctrl_center.c:1337] update devId: ebe3006b0f14083917oh1d name: 空调温控器 2 pid: oqe2ba267qac12ng comm: ebe3006b0f14083917oh1d pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:667 TUYA W][tuya_ctrl_storage.c:143] dev:ebe3006b0f14083917oh1d, dp name is null [10-19 15:23:28:667 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebe3006b0f14083917oh1d,p_rcd_info:0x7f9401df64 [10-19 15:23:28:667 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:117,p_rcd_info->crc32:2736764629,len:1232 key:ebe3006b0f14083917oh1d. [10-19 15:23:28:668 TUYA W][tuya_ctrl_center.c:1255] dev: vdevo166098193021398 is virtual [10-19 15:23:28:668 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:668 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:668 TUYA D][tuya_ctrl_center.c:1337] update devId: vdevo166098193021398 name: Smart Switch Module-vdevo pid: seuwp5kki3tvz3wl comm: vdevo166098193021398 pv: 2.0 sub: 0 node: dev_num: 60 [10-19 15:23:28:668 TUYA W][tuya_ctrl_storage.c:143] dev:vdevo166098193021398, dp name is null [10-19 15:23:28:668 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:vdevo166098193021398,p_rcd_info:0x7f9401df98 [10-19 15:23:28:669 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:118,p_rcd_info->crc32:2127628467,len:1232 key:vdevo166098193021398. [10-19 15:23:28:669 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:670 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:670 TUYA D][tuya_ctrl_center.c:1337] update devId: eb3cfb587e6d81417eac8e name: Smart Switch pid: jogzi8noyhgcahcq comm: eb3cfb587e6d81417eac8e pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:670 TUYA W][tuya_ctrl_storage.c:143] dev:eb3cfb587e6d81417eac8e, dp name is null [10-19 15:23:28:670 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb3cfb587e6d81417eac8e,p_rcd_info:0x7f9401dfcc [10-19 15:23:28:670 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:119,p_rcd_info->crc32:3342434179,len:1232 key:eb3cfb587e6d81417eac8e. [10-19 15:23:28:671 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:671 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:671 TUYA D][tuya_ctrl_center.c:1337] update devId: ebb4f72bc0eb72ac62dhlo name: WIFI lamp tape pid: 9yyaalraupjaredl comm: ebb4f72bc0eb72ac62dhlo pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:671 TUYA W][tuya_ctrl_storage.c:143] dev:ebb4f72bc0eb72ac62dhlo, dp name is null [10-19 15:23:28:671 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebb4f72bc0eb72ac62dhlo,p_rcd_info:0x7f9401e000 [10-19 15:23:28:672 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:120,p_rcd_info->crc32:2843588107,len:1232 key:ebb4f72bc0eb72ac62dhlo. [10-19 15:23:28:672 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:672 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:673 TUYA D][tuya_ctrl_center.c:1337] update devId: ebc90e9813ffde4148tcvg name: WI-FI Temperature & Humidity Sensor pid: qwpfjxryaj7pr9rw comm: ebc90e9813ffde4148tcvg pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:673 TUYA W][tuya_ctrl_storage.c:143] dev:ebc90e9813ffde4148tcvg, dp name is null [10-19 15:23:28:673 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebc90e9813ffde4148tcvg,p_rcd_info:0x7f9401e034 [10-19 15:23:28:673 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:121,p_rcd_info->crc32:4107917005,len:1248 key:ebc90e9813ffde4148tcvg. [10-19 15:23:28:674 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:674 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:674 TUYA D][tuya_ctrl_center.c:1337] update devId: eb631bd9b6590e001blfgs name: mini通断器 pid: jqo111f6ahvas3tr comm: eb631bd9b6590e001blfgs pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:674 TUYA W][tuya_ctrl_storage.c:143] dev:eb631bd9b6590e001blfgs, dp name is null [10-19 15:23:28:674 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb631bd9b6590e001blfgs,p_rcd_info:0x7f9401e068 [10-19 15:23:28:675 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:122,p_rcd_info->crc32:3649317846,len:1232 key:eb631bd9b6590e001blfgs. [10-19 15:23:28:676 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:676 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:676 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:28:676 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:28:676 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:28:676 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:28:676 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:28:676 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:28:676 TUYA D][tuya_ctrl_center.c:1337] update devId: eba528413f6980a463pn4p name: Smart Bulb(BP5758D 35/10) pid: 9nauypjb2kvujrut comm: eba528413f6980a463pn4p pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:676 TUYA W][tuya_ctrl_storage.c:143] dev:eba528413f6980a463pn4p, dp name is null [10-19 15:23:28:676 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eba528413f6980a463pn4p,p_rcd_info:0x7f9401e09c [10-19 15:23:28:677 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:123,p_rcd_info->crc32:2575894488,len:1248 key:eba528413f6980a463pn4p. [10-19 15:23:28:677 TUYA W][tuya_ctrl_center.c:1255] dev: vdevo166004655924109 is virtual [10-19 15:23:28:677 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:677 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:678 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: 开关 1 [10-19 15:23:28:678 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: 开关 2 [10-19 15:23:28:678 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: 开关 3 [10-19 15:23:28:678 TUYA D][tuya_ctrl_center.c:1202] dp: 4 name: 开关 4 [10-19 15:23:28:678 TUYA D][tuya_ctrl_center.c:1202] dp: 5 name: 开关 5 [10-19 15:23:28:678 TUYA D][tuya_ctrl_center.c:1202] dp: 16 name: 背光开关 [10-19 15:23:28:678 TUYA D][tuya_ctrl_center.c:1202] dp: 6 name: 开关 6 [10-19 15:23:28:678 TUYA D][tuya_ctrl_center.c:1202] dp: 19 name: 点动开关(延时关) [10-19 15:23:28:678 TUYA E][tuya_ctrl_center.c:1205] id: 19 not find [10-19 15:23:28:678 TUYA D][tuya_ctrl_center.c:1337] update devId: vdevo166004655924109 name: Six Gang Switch-vdevo pid: mq2mrjjqlkorvgfe comm: vdevo166004655924109 pv: 2.0 sub: 0 node: dev_num: 60 [10-19 15:23:28:678 TUYA D][tuya_ctrl_storage.c:169] dev_id : vdevo166004655924109, serialize dp_names = {"1":"开关 1","2":"开关 2","3":"开关 3","4":"开关 4","5":"开关 5","6":"开关 6","16":"背光开关"} [10-19 15:23:28:678 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:vdevo166004655924109,p_rcd_info:0x7f9401e0d0 [10-19 15:23:28:679 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:124,p_rcd_info->crc32:2337589784,len:1216 key:vdevo166004655924109. [10-19 15:23:28:679 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:679 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:679 TUYA D][tuya_ctrl_center.c:1337] update devId: eb21cdbd5e05e8e428gaca name: 空调温控器 pid: oqe2ba267qac12ng comm: eb21cdbd5e05e8e428gaca pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:679 TUYA W][tuya_ctrl_storage.c:143] dev:eb21cdbd5e05e8e428gaca, dp name is null [10-19 15:23:28:680 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb21cdbd5e05e8e428gaca,p_rcd_info:0x7f9401e104 [10-19 15:23:28:680 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:125,p_rcd_info->crc32:964738206,len:1232 key:eb21cdbd5e05e8e428gaca. [10-19 15:23:28:681 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:681 TUYA E][tuya_ctrl_center.c:1124] dev: eb71d993c258066917jpks not find dp: 0 [10-19 15:23:28:681 TUYA D][tuya_ctrl_center.c:1337] update devId: eb71d993c258066917jpks name: IPC pid: dgudhgjmxdznjm6d comm: eb71d993c258066917jpks pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:681 TUYA W][tuya_ctrl_storage.c:143] dev:eb71d993c258066917jpks, dp name is null [10-19 15:23:28:681 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb71d993c258066917jpks,p_rcd_info:0x7f9401e138 [10-19 15:23:28:682 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:126,p_rcd_info->crc32:591265408,len:1216 key:eb71d993c258066917jpks. [10-19 15:23:28:682 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:682 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:682 TUYA D][tuya_ctrl_center.c:1337] update devId: ebba64b6ac327cdeddq8z2 name: Curtain Switch pid: 8nd1vkcuwbektfod comm: ebba64b6ac327cdeddq8z2 pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:682 TUYA W][tuya_ctrl_storage.c:143] dev:ebba64b6ac327cdeddq8z2, dp name is null [10-19 15:23:28:683 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebba64b6ac327cdeddq8z2,p_rcd_info:0x7f9401e16c [10-19 15:23:28:683 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:127,p_rcd_info->crc32:3532552519,len:1232 key:ebba64b6ac327cdeddq8z2. [10-19 15:23:28:684 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:684 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:684 TUYA D][tuya_ctrl_center.c:1202] dp: 44 name: 点动开关 [10-19 15:23:28:684 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: 开关1 [10-19 15:23:28:684 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: 开关2 [10-19 15:23:28:684 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: 开关3 [10-19 15:23:28:684 TUYA D][tuya_ctrl_center.c:1337] update devId: eb2372042e64f76e79f3jk name: Smart 3-Gang Switch pid: ha7agddwqq6ahbiz comm: eb2372042e64f76e79f3jk pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:684 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb2372042e64f76e79f3jk, serialize dp_names = {"1":"开关1","2":"开关2","3":"开关3","44":"点动开关"} [10-19 15:23:28:684 TUYA N][rcd_file.c:1195] [ty_rcd] need merg records or expand records.rcd_max:128,rcd_cnt:128,rcd_valid_cnt:60 . [10-19 15:23:28:685 TUYA N][rcd_file.c:1235] [ty_rcd] may be need to merg records,op_ret:-10105 . [10-19 15:23:28:685 TUYA E][rcd_file.c:1335] write kv eb2372042e64f76e79f3jk fail!! [10-19 15:23:28:685 TUYA D][rcd_file.c:1948] [ty_rcd] Record merge procedure. [10-19 15:23:28:685 TUYA D][rcd_file.c:1965] rebuild [eb2372042e64f76e79f3jk] 6720 1232 [10-19 15:23:28:685 TUYA D][rcd_file.c:1970] move value key:eb2372042e64f76e79f3jk, 90224 to 6720 [10-19 15:23:28:685 TUYA D][rcd_file.c:1985] move rcd key:eb2372042e64f76e79f3jk, 68 to 0 [10-19 15:23:28:685 TUYA D][rcd_file.c:1965] rebuild [ebb3fad96f393b588eomxh] 7952 1232 [10-19 15:23:28:685 TUYA D][rcd_file.c:1970] move value key:ebb3fad96f393b588eomxh, 91456 to 7952 [10-19 15:23:28:685 TUYA D][rcd_file.c:1985] move rcd key:ebb3fad96f393b588eomxh, 69 to 1 [10-19 15:23:28:685 TUYA D][rcd_file.c:1965] rebuild [eb1552c6f83a6b59edmyes] 9184 1216 [10-19 15:23:28:685 TUYA D][rcd_file.c:1970] move value key:eb1552c6f83a6b59edmyes, 92688 to 9184 [10-19 15:23:28:685 TUYA D][rcd_file.c:1985] move rcd key:eb1552c6f83a6b59edmyes, 70 to 2 [10-19 15:23:28:685 TUYA D][rcd_file.c:1965] rebuild [eb0a212b4b26ce96c62aei] 10400 1232 [10-19 15:23:28:685 TUYA D][rcd_file.c:1970] move value key:eb0a212b4b26ce96c62aei, 93904 to 10400 [10-19 15:23:28:685 TUYA D][rcd_file.c:1985] move rcd key:eb0a212b4b26ce96c62aei, 71 to 3 [10-19 15:23:28:686 TUYA D][rcd_file.c:1965] rebuild [ebd1ebe54febaa9c022vqf] 11632 1232 [10-19 15:23:28:686 TUYA D][rcd_file.c:1970] move value key:ebd1ebe54febaa9c022vqf, 95136 to 11632 [10-19 15:23:28:686 TUYA D][rcd_file.c:1985] move rcd key:ebd1ebe54febaa9c022vqf, 72 to 4 [10-19 15:23:28:686 TUYA D][rcd_file.c:1965] rebuild [eba3fc32248cc469a3y5qe] 12864 1216 [10-19 15:23:28:686 TUYA D][rcd_file.c:1970] move value key:eba3fc32248cc469a3y5qe, 96368 to 12864 [10-19 15:23:28:686 TUYA D][rcd_file.c:1985] move rcd key:eba3fc32248cc469a3y5qe, 73 to 5 [10-19 15:23:28:686 TUYA D][rcd_file.c:1965] rebuild [eb0469f56ed95d7791ogla] 14080 1216 [10-19 15:23:28:686 TUYA D][rcd_file.c:1970] move value key:eb0469f56ed95d7791ogla, 97584 to 14080 [10-19 15:23:28:686 TUYA D][rcd_file.c:1985] move rcd key:eb0469f56ed95d7791ogla, 74 to 6 [10-19 15:23:28:686 TUYA D][rcd_file.c:1965] rebuild [ebae3eac4f123fe22bbx5k] 15296 1232 [10-19 15:23:28:686 TUYA D][rcd_file.c:1970] move value key:ebae3eac4f123fe22bbx5k, 98800 to 15296 [10-19 15:23:28:686 TUYA D][rcd_file.c:1985] move rcd key:ebae3eac4f123fe22bbx5k, 75 to 7 [10-19 15:23:28:686 TUYA D][rcd_file.c:1965] rebuild [eba19ee51b778585c0jcy3] 16528 1248 [10-19 15:23:28:686 TUYA D][rcd_file.c:1970] move value key:eba19ee51b778585c0jcy3, 100032 to 16528 [10-19 15:23:28:686 TUYA D][rcd_file.c:1985] move rcd key:eba19ee51b778585c0jcy3, 76 to 8 [10-19 15:23:28:686 TUYA D][rcd_file.c:1965] rebuild [eb827d57cf10b04d2fxtij] 17776 1232 [10-19 15:23:28:686 TUYA D][rcd_file.c:1970] move value key:eb827d57cf10b04d2fxtij, 101280 to 17776 [10-19 15:23:28:686 TUYA D][rcd_file.c:1985] move rcd key:eb827d57cf10b04d2fxtij, 77 to 9 [10-19 15:23:28:686 TUYA D][rcd_file.c:1965] rebuild [eb079c4f40c6c21e6ffpd0] 19008 1216 [10-19 15:23:28:686 TUYA D][rcd_file.c:1970] move value key:eb079c4f40c6c21e6ffpd0, 102512 to 19008 [10-19 15:23:28:687 TUYA D][rcd_file.c:1985] move rcd key:eb079c4f40c6c21e6ffpd0, 78 to 10 [10-19 15:23:28:687 TUYA D][rcd_file.c:1965] rebuild [eb44125a98339e4a81t9za] 20224 1232 [10-19 15:23:28:687 TUYA D][rcd_file.c:1970] move value key:eb44125a98339e4a81t9za, 103728 to 20224 [10-19 15:23:28:687 TUYA D][rcd_file.c:1985] move rcd key:eb44125a98339e4a81t9za, 79 to 11 [10-19 15:23:28:687 TUYA D][rcd_file.c:1965] rebuild [ebd0ad496c403f1af3i9an] 21456 1232 [10-19 15:23:28:687 TUYA D][rcd_file.c:1970] move value key:ebd0ad496c403f1af3i9an, 104960 to 21456 [10-19 15:23:28:687 TUYA D][rcd_file.c:1985] move rcd key:ebd0ad496c403f1af3i9an, 80 to 12 [10-19 15:23:28:687 TUYA D][rcd_file.c:1965] rebuild [eb257c7e0da82bf6fdgo2g] 22688 1232 [10-19 15:23:28:687 TUYA D][rcd_file.c:1970] move value key:eb257c7e0da82bf6fdgo2g, 106192 to 22688 [10-19 15:23:28:687 TUYA D][rcd_file.c:1985] move rcd key:eb257c7e0da82bf6fdgo2g, 81 to 13 [10-19 15:23:28:687 TUYA D][rcd_file.c:1965] rebuild [eb0f65ca9465be8edcoyot] 23920 1232 [10-19 15:23:28:687 TUYA D][rcd_file.c:1970] move value key:eb0f65ca9465be8edcoyot, 107424 to 23920 [10-19 15:23:28:687 TUYA D][rcd_file.c:1985] move rcd key:eb0f65ca9465be8edcoyot, 82 to 14 [10-19 15:23:28:687 TUYA D][rcd_file.c:1965] rebuild [ebf673a55509854f89o4ms] 25152 1232 [10-19 15:23:28:687 TUYA D][rcd_file.c:1970] move value key:ebf673a55509854f89o4ms, 108656 to 25152 [10-19 15:23:28:687 TUYA D][rcd_file.c:1985] move rcd key:ebf673a55509854f89o4ms, 83 to 15 [10-19 15:23:28:687 TUYA D][rcd_file.c:1965] rebuild [ebe5c0ea9264da5aedqyqx] 26384 1232 [10-19 15:23:28:687 TUYA D][rcd_file.c:1970] move value key:ebe5c0ea9264da5aedqyqx, 109888 to 26384 [10-19 15:23:28:687 TUYA D][rcd_file.c:1985] move rcd key:ebe5c0ea9264da5aedqyqx, 84 to 16 [10-19 15:23:28:688 TUYA D][rcd_file.c:1965] rebuild [ebabc77077c75fec391svt] 27616 1232 [10-19 15:23:28:688 TUYA D][rcd_file.c:1970] move value key:ebabc77077c75fec391svt, 111120 to 27616 [10-19 15:23:28:688 TUYA D][rcd_file.c:1985] move rcd key:ebabc77077c75fec391svt, 85 to 17 [10-19 15:23:28:688 TUYA D][rcd_file.c:1965] rebuild [ebe2744515d20294b1yhgw] 28848 1232 [10-19 15:23:28:688 TUYA D][rcd_file.c:1970] move value key:ebe2744515d20294b1yhgw, 112352 to 28848 [10-19 15:23:28:688 TUYA D][rcd_file.c:1985] move rcd key:ebe2744515d20294b1yhgw, 86 to 18 [10-19 15:23:28:688 TUYA D][rcd_file.c:1965] rebuild [eb99a9cc76209358a4crkr] 30080 1216 [10-19 15:23:28:688 TUYA D][rcd_file.c:1970] move value key:eb99a9cc76209358a4crkr, 113584 to 30080 [10-19 15:23:28:688 TUYA D][rcd_file.c:1985] move rcd key:eb99a9cc76209358a4crkr, 87 to 19 [10-19 15:23:28:688 TUYA D][rcd_file.c:1965] rebuild [eb67a0efcb59444d01ydgn] 31296 1232 [10-19 15:23:28:688 TUYA D][rcd_file.c:1970] move value key:eb67a0efcb59444d01ydgn, 114800 to 31296 [10-19 15:23:28:688 TUYA D][rcd_file.c:1985] move rcd key:eb67a0efcb59444d01ydgn, 88 to 20 [10-19 15:23:28:688 TUYA D][rcd_file.c:1965] rebuild [ebe7f7541d3a5e34dcplwr] 32528 1216 [10-19 15:23:28:688 TUYA D][rcd_file.c:1970] move value key:ebe7f7541d3a5e34dcplwr, 116032 to 32528 [10-19 15:23:28:688 TUYA D][rcd_file.c:1985] move rcd key:ebe7f7541d3a5e34dcplwr, 89 to 21 [10-19 15:23:28:688 TUYA D][rcd_file.c:1965] rebuild [eb62263aaf2f73ef03xira] 33744 1232 [10-19 15:23:28:688 TUYA D][rcd_file.c:1970] move value key:eb62263aaf2f73ef03xira, 117248 to 33744 [10-19 15:23:28:688 TUYA D][rcd_file.c:1985] move rcd key:eb62263aaf2f73ef03xira, 90 to 22 [10-19 15:23:28:688 TUYA D][rcd_file.c:1965] rebuild [ebb800d543876b9d83jiah] 34976 1232 [10-19 15:23:28:688 TUYA D][rcd_file.c:1970] move value key:ebb800d543876b9d83jiah, 118480 to 34976 [10-19 15:23:28:689 TUYA D][rcd_file.c:1985] move rcd key:ebb800d543876b9d83jiah, 91 to 23 [10-19 15:23:28:689 TUYA D][rcd_file.c:1965] rebuild [ebc78c65e28bc1347ac761] 36208 1232 [10-19 15:23:28:689 TUYA D][rcd_file.c:1970] move value key:ebc78c65e28bc1347ac761, 119712 to 36208 [10-19 15:23:28:689 TUYA D][rcd_file.c:1985] move rcd key:ebc78c65e28bc1347ac761, 92 to 24 [10-19 15:23:28:689 TUYA D][rcd_file.c:1965] rebuild [eb3b1fefe57125bb72nrzb] 37440 1232 [10-19 15:23:28:689 TUYA D][rcd_file.c:1970] move value key:eb3b1fefe57125bb72nrzb, 120944 to 37440 [10-19 15:23:28:689 TUYA D][rcd_file.c:1985] move rcd key:eb3b1fefe57125bb72nrzb, 93 to 25 [10-19 15:23:28:689 TUYA D][rcd_file.c:1965] rebuild [eb9e43a7db146d1286luio] 38672 1200 [10-19 15:23:28:689 TUYA D][rcd_file.c:1970] move value key:eb9e43a7db146d1286luio, 122176 to 38672 [10-19 15:23:28:689 TUYA D][rcd_file.c:1985] move rcd key:eb9e43a7db146d1286luio, 94 to 26 [10-19 15:23:28:689 TUYA D][rcd_file.c:1965] rebuild [eb87649dc6a4ae7fef87xr] 39872 1232 [10-19 15:23:28:689 TUYA D][rcd_file.c:1970] move value key:eb87649dc6a4ae7fef87xr, 123376 to 39872 [10-19 15:23:28:689 TUYA D][rcd_file.c:1985] move rcd key:eb87649dc6a4ae7fef87xr, 95 to 27 [10-19 15:23:28:689 TUYA D][rcd_file.c:1965] rebuild [eb76889250a9917161wng9] 41104 1248 [10-19 15:23:28:689 TUYA D][rcd_file.c:1970] move value key:eb76889250a9917161wng9, 124608 to 41104 [10-19 15:23:28:689 TUYA D][rcd_file.c:1985] move rcd key:eb76889250a9917161wng9, 96 to 28 [10-19 15:23:28:689 TUYA D][rcd_file.c:1965] rebuild [ebff3d1dac6c9c54ebu58o] 42352 1200 [10-19 15:23:28:689 TUYA D][rcd_file.c:1970] move value key:ebff3d1dac6c9c54ebu58o, 125856 to 42352 [10-19 15:23:28:689 TUYA D][rcd_file.c:1985] move rcd key:ebff3d1dac6c9c54ebu58o, 97 to 29 [10-19 15:23:28:690 TUYA D][rcd_file.c:1965] rebuild [eb3edad403134c4f6czxy4] 43552 1216 [10-19 15:23:28:690 TUYA D][rcd_file.c:1970] move value key:eb3edad403134c4f6czxy4, 127056 to 43552 [10-19 15:23:28:690 TUYA D][rcd_file.c:1985] move rcd key:eb3edad403134c4f6czxy4, 98 to 30 [10-19 15:23:28:690 TUYA D][rcd_file.c:1965] rebuild [ebd959f9cc5a9857b2zsoo] 44768 1200 [10-19 15:23:28:690 TUYA D][rcd_file.c:1970] move value key:ebd959f9cc5a9857b2zsoo, 128272 to 44768 [10-19 15:23:28:690 TUYA D][rcd_file.c:1985] move rcd key:ebd959f9cc5a9857b2zsoo, 99 to 31 [10-19 15:23:28:690 TUYA D][rcd_file.c:1965] rebuild [eb92c47fe161c74b89dk25] 45968 1200 [10-19 15:23:28:690 TUYA D][rcd_file.c:1970] move value key:eb92c47fe161c74b89dk25, 129472 to 45968 [10-19 15:23:28:690 TUYA D][rcd_file.c:1985] move rcd key:eb92c47fe161c74b89dk25, 100 to 32 [10-19 15:23:28:690 TUYA D][rcd_file.c:1965] rebuild [ebf8fee6f4298432a5eqvk] 47168 1232 [10-19 15:23:28:690 TUYA D][rcd_file.c:1970] move value key:ebf8fee6f4298432a5eqvk, 130672 to 47168 [10-19 15:23:28:690 TUYA D][rcd_file.c:1985] move rcd key:ebf8fee6f4298432a5eqvk, 101 to 33 [10-19 15:23:28:690 TUYA D][rcd_file.c:1965] rebuild [eb8607e2c51bffc942fczo] 48400 1232 [10-19 15:23:28:690 TUYA D][rcd_file.c:1970] move value key:eb8607e2c51bffc942fczo, 131904 to 48400 [10-19 15:23:28:690 TUYA D][rcd_file.c:1985] move rcd key:eb8607e2c51bffc942fczo, 102 to 34 [10-19 15:23:28:690 TUYA D][rcd_file.c:1965] rebuild [ebf911148e218a63b67uf3] 49632 1200 [10-19 15:23:28:690 TUYA D][rcd_file.c:1970] move value key:ebf911148e218a63b67uf3, 133136 to 49632 [10-19 15:23:28:690 TUYA D][rcd_file.c:1985] move rcd key:ebf911148e218a63b67uf3, 103 to 35 [10-19 15:23:28:690 TUYA D][rcd_file.c:1965] rebuild [ebd88c655bdd4b39adihqe] 50832 1232 [10-19 15:23:28:690 TUYA D][rcd_file.c:1970] move value key:ebd88c655bdd4b39adihqe, 134336 to 50832 [10-19 15:23:28:691 TUYA D][rcd_file.c:1985] move rcd key:ebd88c655bdd4b39adihqe, 104 to 36 [10-19 15:23:28:691 TUYA D][rcd_file.c:1965] rebuild [eb46ca57fbaaa5a173n9zv] 52064 1232 [10-19 15:23:28:691 TUYA D][rcd_file.c:1970] move value key:eb46ca57fbaaa5a173n9zv, 135568 to 52064 [10-19 15:23:28:691 TUYA D][rcd_file.c:1985] move rcd key:eb46ca57fbaaa5a173n9zv, 105 to 37 [10-19 15:23:28:691 TUYA D][rcd_file.c:1965] rebuild [eb92b0479e015fbbaavltv] 53296 1232 [10-19 15:23:28:691 TUYA D][rcd_file.c:1970] move value key:eb92b0479e015fbbaavltv, 136800 to 53296 [10-19 15:23:28:691 TUYA D][rcd_file.c:1985] move rcd key:eb92b0479e015fbbaavltv, 106 to 38 [10-19 15:23:28:691 TUYA D][rcd_file.c:1965] rebuild [ebaf2b250cb41e058ekxqm] 54528 1232 [10-19 15:23:28:691 TUYA D][rcd_file.c:1970] move value key:ebaf2b250cb41e058ekxqm, 138032 to 54528 [10-19 15:23:28:691 TUYA D][rcd_file.c:1985] move rcd key:ebaf2b250cb41e058ekxqm, 107 to 39 [10-19 15:23:28:691 TUYA D][rcd_file.c:1965] rebuild [eb09bad8e75f6222acaglz] 55760 1232 [10-19 15:23:28:691 TUYA D][rcd_file.c:1970] move value key:eb09bad8e75f6222acaglz, 139264 to 55760 [10-19 15:23:28:691 TUYA D][rcd_file.c:1985] move rcd key:eb09bad8e75f6222acaglz, 108 to 40 [10-19 15:23:28:691 TUYA D][rcd_file.c:1965] rebuild [eb9c17916f715a30e0a7mz] 56992 1232 [10-19 15:23:28:691 TUYA D][rcd_file.c:1970] move value key:eb9c17916f715a30e0a7mz, 140496 to 56992 [10-19 15:23:28:691 TUYA D][rcd_file.c:1985] move rcd key:eb9c17916f715a30e0a7mz, 109 to 41 [10-19 15:23:28:691 TUYA D][rcd_file.c:1965] rebuild [vdevo166201192349972] 58224 1216 [10-19 15:23:28:691 TUYA D][rcd_file.c:1970] move value key:vdevo166201192349972, 141728 to 58224 [10-19 15:23:28:691 TUYA D][rcd_file.c:1985] move rcd key:vdevo166201192349972, 110 to 42 [10-19 15:23:28:692 TUYA D][rcd_file.c:1965] rebuild [eb62f037dd6640bfa41gut] 59440 1232 [10-19 15:23:28:692 TUYA D][rcd_file.c:1970] move value key:eb62f037dd6640bfa41gut, 142944 to 59440 [10-19 15:23:28:692 TUYA D][rcd_file.c:1985] move rcd key:eb62f037dd6640bfa41gut, 111 to 43 [10-19 15:23:28:692 TUYA D][rcd_file.c:1965] rebuild [eb4576f5222b16dccaaazi] 60672 1232 [10-19 15:23:28:692 TUYA D][rcd_file.c:1970] move value key:eb4576f5222b16dccaaazi, 144176 to 60672 [10-19 15:23:28:692 TUYA D][rcd_file.c:1985] move rcd key:eb4576f5222b16dccaaazi, 112 to 44 [10-19 15:23:28:692 TUYA D][rcd_file.c:1965] rebuild [ebb063750d514d878079mw] 61904 1248 [10-19 15:23:28:692 TUYA D][rcd_file.c:1970] move value key:ebb063750d514d878079mw, 145408 to 61904 [10-19 15:23:28:692 TUYA D][rcd_file.c:1985] move rcd key:ebb063750d514d878079mw, 113 to 45 [10-19 15:23:28:692 TUYA D][rcd_file.c:1965] rebuild [eba407ffd4d23748c3rlsw] 63152 1232 [10-19 15:23:28:692 TUYA D][rcd_file.c:1970] move value key:eba407ffd4d23748c3rlsw, 146656 to 63152 [10-19 15:23:28:692 TUYA D][rcd_file.c:1985] move rcd key:eba407ffd4d23748c3rlsw, 114 to 46 [10-19 15:23:28:692 TUYA D][rcd_file.c:1965] rebuild [eb0058bee16ce0c70aq9nj] 64384 1216 [10-19 15:23:28:692 TUYA D][rcd_file.c:1970] move value key:eb0058bee16ce0c70aq9nj, 147888 to 64384 [10-19 15:23:28:692 TUYA D][rcd_file.c:1985] move rcd key:eb0058bee16ce0c70aq9nj, 115 to 47 [10-19 15:23:28:692 TUYA D][rcd_file.c:1965] rebuild [eb68d8dbe4707224e8sxd8] 65600 1216 [10-19 15:23:28:692 TUYA D][rcd_file.c:1970] move value key:eb68d8dbe4707224e8sxd8, 149104 to 65600 [10-19 15:23:28:692 TUYA D][rcd_file.c:1985] move rcd key:eb68d8dbe4707224e8sxd8, 116 to 48 [10-19 15:23:28:692 TUYA D][rcd_file.c:1965] rebuild [ebe3006b0f14083917oh1d] 66816 1232 [10-19 15:23:28:692 TUYA D][rcd_file.c:1970] move value key:ebe3006b0f14083917oh1d, 150320 to 66816 [10-19 15:23:28:693 TUYA D][rcd_file.c:1985] move rcd key:ebe3006b0f14083917oh1d, 117 to 49 [10-19 15:23:28:693 TUYA D][rcd_file.c:1965] rebuild [vdevo166098193021398] 68048 1232 [10-19 15:23:28:693 TUYA D][rcd_file.c:1970] move value key:vdevo166098193021398, 151552 to 68048 [10-19 15:23:28:693 TUYA D][rcd_file.c:1985] move rcd key:vdevo166098193021398, 118 to 50 [10-19 15:23:28:693 TUYA D][rcd_file.c:1965] rebuild [eb3cfb587e6d81417eac8e] 69280 1232 [10-19 15:23:28:693 TUYA D][rcd_file.c:1970] move value key:eb3cfb587e6d81417eac8e, 152784 to 69280 [10-19 15:23:28:693 TUYA D][rcd_file.c:1985] move rcd key:eb3cfb587e6d81417eac8e, 119 to 51 [10-19 15:23:28:693 TUYA D][rcd_file.c:1965] rebuild [ebb4f72bc0eb72ac62dhlo] 70512 1232 [10-19 15:23:28:693 TUYA D][rcd_file.c:1970] move value key:ebb4f72bc0eb72ac62dhlo, 154016 to 70512 [10-19 15:23:28:693 TUYA D][rcd_file.c:1985] move rcd key:ebb4f72bc0eb72ac62dhlo, 120 to 52 [10-19 15:23:28:693 TUYA D][rcd_file.c:1965] rebuild [ebc90e9813ffde4148tcvg] 71744 1248 [10-19 15:23:28:693 TUYA D][rcd_file.c:1970] move value key:ebc90e9813ffde4148tcvg, 155248 to 71744 [10-19 15:23:28:693 TUYA D][rcd_file.c:1985] move rcd key:ebc90e9813ffde4148tcvg, 121 to 53 [10-19 15:23:28:693 TUYA D][rcd_file.c:1965] rebuild [eb631bd9b6590e001blfgs] 72992 1232 [10-19 15:23:28:693 TUYA D][rcd_file.c:1970] move value key:eb631bd9b6590e001blfgs, 156496 to 72992 [10-19 15:23:28:693 TUYA D][rcd_file.c:1985] move rcd key:eb631bd9b6590e001blfgs, 122 to 54 [10-19 15:23:28:693 TUYA D][rcd_file.c:1965] rebuild [eba528413f6980a463pn4p] 74224 1248 [10-19 15:23:28:693 TUYA D][rcd_file.c:1970] move value key:eba528413f6980a463pn4p, 157728 to 74224 [10-19 15:23:28:693 TUYA D][rcd_file.c:1985] move rcd key:eba528413f6980a463pn4p, 123 to 55 [10-19 15:23:28:694 TUYA D][rcd_file.c:1965] rebuild [vdevo166004655924109] 75472 1216 [10-19 15:23:28:694 TUYA D][rcd_file.c:1970] move value key:vdevo166004655924109, 158976 to 75472 [10-19 15:23:28:694 TUYA D][rcd_file.c:1985] move rcd key:vdevo166004655924109, 124 to 56 [10-19 15:23:28:694 TUYA D][rcd_file.c:1965] rebuild [eb21cdbd5e05e8e428gaca] 76688 1232 [10-19 15:23:28:694 TUYA D][rcd_file.c:1970] move value key:eb21cdbd5e05e8e428gaca, 160192 to 76688 [10-19 15:23:28:694 TUYA D][rcd_file.c:1985] move rcd key:eb21cdbd5e05e8e428gaca, 125 to 57 [10-19 15:23:28:694 TUYA D][rcd_file.c:1965] rebuild [eb71d993c258066917jpks] 77920 1216 [10-19 15:23:28:694 TUYA D][rcd_file.c:1970] move value key:eb71d993c258066917jpks, 161424 to 77920 [10-19 15:23:28:694 TUYA D][rcd_file.c:1985] move rcd key:eb71d993c258066917jpks, 126 to 58 [10-19 15:23:28:694 TUYA D][rcd_file.c:1965] rebuild [ebba64b6ac327cdeddq8z2] 79136 1232 [10-19 15:23:28:694 TUYA D][rcd_file.c:1970] move value key:ebba64b6ac327cdeddq8z2, 162640 to 79136 [10-19 15:23:28:694 TUYA D][rcd_file.c:1985] move rcd key:ebba64b6ac327cdeddq8z2, 127 to 59 [10-19 15:23:28:694 TUYA D][rcd_file.c:1994] trancate fileLen:80368 cnt:60 [10-19 15:23:28:695 TUYA D][rcd_file.c:3043] ################Dump metadata start################ [10-19 15:23:28:695 TUYA D][rcd_file.c:3044] file path:/userdata/tuya_db_files/rcdDb/ctrl_dev.rdb [10-19 15:23:28:695 TUYA D][rcd_file.c:3045] bak file path:/userdata/tuya_db_files/rcdDb/ctrl_dev.rdb_bak [10-19 15:23:28:695 TUYA D][rcd_file.c:3046] rcd_valid_cnt:60 [10-19 15:23:28:695 TUYA D][rcd_file.c:3047] cur_valid_rcd_num:12 [10-19 15:23:28:695 TUYA D][rcd_file.c:3048] cur_valid_rcd_pos:11 [10-19 15:23:28:695 TUYA D][rcd_file.c:3049] cur_total_size:73648 [10-19 15:23:28:695 TUYA D][rcd_file.c:3050] cur_total_size_valid:73648 [10-19 15:23:28:695 TUYA D][rcd_file.c:3054] crc32:-1245603246 [10-19 15:23:28:695 TUYA D][rcd_file.c:3055] version:1 [10-19 15:23:28:695 TUYA D][rcd_file.c:3056] wr_count:683 [10-19 15:23:28:695 TUYA D][rcd_file.c:3057] magic:1437226410 [10-19 15:23:28:695 TUYA D][rcd_file.c:3058] metadata_size:0x1A40 [10-19 15:23:28:695 TUYA D][rcd_file.c:3059] rawdata_max:1048576 [10-19 15:23:28:695 TUYA D][rcd_file.c:3060] rcd_max:128 [10-19 15:23:28:695 TUYA D][rcd_file.c:3061] rcd_cnt:60 [10-19 15:23:28:695 TUYA D][rcd_file.c:3063] ################Dump metadata end################ [10-19 15:23:28:696 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb2372042e64f76e79f3jk,p_rcd_info:0x7f9401d3d0 [10-19 15:23:28:696 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:60,p_rcd_info->crc32:2539775411,len:1232 key:eb2372042e64f76e79f3jk. [10-19 15:23:28:697 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:697 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:697 TUYA D][tuya_ctrl_center.c:1337] update devId: ebb3fad96f393b588eomxh name: IR remote pid: lmjfyvtsig6v5npw comm: ebb3fad96f393b588eomxh pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:697 TUYA W][tuya_ctrl_storage.c:143] dev:ebb3fad96f393b588eomxh, dp name is null [10-19 15:23:28:697 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebb3fad96f393b588eomxh,p_rcd_info:0x7f9401d404 [10-19 15:23:28:698 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:61,p_rcd_info->crc32:3879080828,len:1232 key:ebb3fad96f393b588eomxh. [10-19 15:23:28:698 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:698 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:698 TUYA D][tuya_ctrl_center.c:1337] update devId: eb1552c6f83a6b59edmyes name: P6EL 2 pid: 1svzszztogaibjxa comm: eb1552c6f83a6b59edmyes pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:698 TUYA W][tuya_ctrl_storage.c:143] dev:eb1552c6f83a6b59edmyes, dp name is null [10-19 15:23:28:699 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb1552c6f83a6b59edmyes,p_rcd_info:0x7f9401d438 [10-19 15:23:28:699 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:62,p_rcd_info->crc32:214856666,len:1216 key:eb1552c6f83a6b59edmyes. [10-19 15:23:28:699 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:700 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: Switch 1 [10-19 15:23:28:700 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: Switch 2 [10-19 15:23:28:700 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: Switch 3 [10-19 15:23:28:700 TUYA D][tuya_ctrl_center.c:1202] dp: 4 name: Switch 4 [10-19 15:23:28:700 TUYA D][tuya_ctrl_center.c:1202] dp: 5 name: Switch 5 [10-19 15:23:28:700 TUYA D][tuya_ctrl_center.c:1202] dp: 16 name: Backlight Switch [10-19 15:23:28:700 TUYA D][tuya_ctrl_center.c:1202] dp: 6 name: Switch 6 [10-19 15:23:28:700 TUYA D][tuya_ctrl_center.c:1202] dp: 19 name: Delay-off Schedule [10-19 15:23:28:700 TUYA E][tuya_ctrl_center.c:1205] id: 19 not find [10-19 15:23:28:700 TUYA D][tuya_ctrl_center.c:1337] update devId: eb0a212b4b26ce96c62aei name: Six Gang Switch 2 pid: jyupj3fw comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: a4c13822298c9cc4 dev_num: 60 [10-19 15:23:28:700 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb0a212b4b26ce96c62aei, serialize dp_names = {"1":"Switch 1","2":"Switch 2","3":"Switch 3","4":"Switch 4","5":"Switch 5","6":"Switch 6","16":"Backlight Switch"} [10-19 15:23:28:700 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb0a212b4b26ce96c62aei,p_rcd_info:0x7f9401d46c [10-19 15:23:28:701 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:63,p_rcd_info->crc32:2101040561,len:1232 key:eb0a212b4b26ce96c62aei. [10-19 15:23:28:701 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:701 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:701 TUYA D][tuya_ctrl_center.c:1337] update devId: ebd1ebe54febaa9c022vqf name: Soquete Inteligente pid: w906qkrrhd3otiwd comm: ebd1ebe54febaa9c022vqf pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:701 TUYA W][tuya_ctrl_storage.c:143] dev:ebd1ebe54febaa9c022vqf, dp name is null [10-19 15:23:28:702 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebd1ebe54febaa9c022vqf,p_rcd_info:0x7f9401d4a0 [10-19 15:23:28:702 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:64,p_rcd_info->crc32:3684184018,len:1232 key:ebd1ebe54febaa9c022vqf. [10-19 15:23:28:703 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:703 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:703 TUYA D][tuya_ctrl_center.c:1337] update devId: eba3fc32248cc469a3y5qe name: P6EL pid: 1svzszztogaibjxa comm: eba3fc32248cc469a3y5qe pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:703 TUYA W][tuya_ctrl_storage.c:143] dev:eba3fc32248cc469a3y5qe, dp name is null [10-19 15:23:28:703 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eba3fc32248cc469a3y5qe,p_rcd_info:0x7f9401d4d4 [10-19 15:23:28:703 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:65,p_rcd_info->crc32:354349445,len:1216 key:eba3fc32248cc469a3y5qe. [10-19 15:23:28:704 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:704 TUYA D][tuya_ctrl_center.c:1337] update devId: eb0469f56ed95d7791ogla name: Smart Knob pid: 4fjiwweb comm: ebe5c0ea9264da5aedqyqx pv: 2.2 sub: 1 node: dc8e95fffeaa86e1 dev_num: 60 [10-19 15:23:28:704 TUYA W][tuya_ctrl_storage.c:143] dev:eb0469f56ed95d7791ogla, dp name is null [10-19 15:23:28:704 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb0469f56ed95d7791ogla,p_rcd_info:0x7f9401d508 [10-19 15:23:28:705 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:66,p_rcd_info->crc32:2013950804,len:1216 key:eb0469f56ed95d7791ogla. [10-19 15:23:28:705 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:705 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: 开关 1 [10-19 15:23:28:705 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: 开关 2 [10-19 15:23:28:705 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: 开关 3 [10-19 15:23:28:705 TUYA D][tuya_ctrl_center.c:1202] dp: 4 name: 开关 4 [10-19 15:23:28:705 TUYA D][tuya_ctrl_center.c:1202] dp: 5 name: 开关 5 [10-19 15:23:28:705 TUYA D][tuya_ctrl_center.c:1202] dp: 16 name: 背光开关 [10-19 15:23:28:706 TUYA D][tuya_ctrl_center.c:1202] dp: 6 name: 开关 6 [10-19 15:23:28:706 TUYA D][tuya_ctrl_center.c:1202] dp: 19 name: 点动开关(延时关) [10-19 15:23:28:706 TUYA E][tuya_ctrl_center.c:1205] id: 19 not find [10-19 15:23:28:706 TUYA D][tuya_ctrl_center.c:1337] update devId: ebae3eac4f123fe22bbx5k name: Six Gang Switch pid: jyupj3fw comm: eb827d57cf10b04d2fxtij pv: 2.2 sub: 1 node: a4c138e103ae9725 dev_num: 60 [10-19 15:23:28:706 TUYA D][tuya_ctrl_storage.c:169] dev_id : ebae3eac4f123fe22bbx5k, serialize dp_names = {"1":"开关 1","2":"开关 2","3":"开关 3","4":"开关 4","5":"开关 5","6":"开关 6","16":"背光开关"} [10-19 15:23:28:706 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebae3eac4f123fe22bbx5k,p_rcd_info:0x7f9401d53c [10-19 15:23:28:707 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:67,p_rcd_info->crc32:4037150089,len:1232 key:ebae3eac4f123fe22bbx5k. [10-19 15:23:28:707 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:707 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:707 TUYA D][tuya_ctrl_center.c:1337] update devId: eba19ee51b778585c0jcy3 name: Smart Wireless Switch K10W pid: 9cwtq6di0cz7bikc comm: eba19ee51b778585c0jcy3 pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:707 TUYA W][tuya_ctrl_storage.c:143] dev:eba19ee51b778585c0jcy3, dp name is null [10-19 15:23:28:708 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eba19ee51b778585c0jcy3,p_rcd_info:0x7f9401d570 [10-19 15:23:28:708 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:68,p_rcd_info->crc32:2981876833,len:1248 key:eba19ee51b778585c0jcy3. [10-19 15:23:28:708 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:708 TUYA D][tuya_ctrl_center.c:1337] update devId: eb827d57cf10b04d2fxtij name: Mini 多模网关 pid: pj3gdjgpeqao7xk4 comm: eb827d57cf10b04d2fxtij pv: 2.2 sub: 0 node: 0908 dev_num: 60 [10-19 15:23:28:709 TUYA W][tuya_ctrl_storage.c:143] dev:eb827d57cf10b04d2fxtij, dp name is null [10-19 15:23:28:709 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb827d57cf10b04d2fxtij,p_rcd_info:0x7f9401d5a4 [10-19 15:23:28:709 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:69,p_rcd_info->crc32:3872309292,len:1232 key:eb827d57cf10b04d2fxtij. [10-19 15:23:28:710 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:710 TUYA D][tuya_ctrl_center.c:1337] update devId: eb079c4f40c6c21e6ffpd0 name: 空调 pid: qzktzhehinzsz2je comm: eb44125a98339e4a81t9za pv: 2.2 sub: 1 node: 11d64749afef4019 dev_num: 60 [10-19 15:23:28:710 TUYA W][tuya_ctrl_storage.c:143] dev:eb079c4f40c6c21e6ffpd0, dp name is null [10-19 15:23:28:710 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb079c4f40c6c21e6ffpd0,p_rcd_info:0x7f9401d5d8 [10-19 15:23:28:711 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:70,p_rcd_info->crc32:1154159737,len:1216 key:eb079c4f40c6c21e6ffpd0. [10-19 15:23:28:711 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:28:711 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:28:711 TUYA D][tuya_ctrl_center.c:1337] update devId: eb44125a98339e4a81t9za name: 智能红外遥控器 pid: yrmpfrig5ndywijq comm: eb44125a98339e4a81t9za pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:28:711 TUYA W][tuya_ctrl_storage.c:143] dev:eb44125a98339e4a81t9za, dp name is null [10-19 15:23:28:712 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb44125a98339e4a81t9za,p_rcd_info:0x7f9401d60c [10-19 15:23:28:712 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:71,p_rcd_info->crc32:1956560021,len:1232 key:eb44125a98339e4a81t9za. [10-19 15:23:28:726 TUYA D][iot_httpc.c:929] Post Data: {"t":1666164208} [10-19 15:23:28:726 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.screen.device.all&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164208&v=2.0&sign=2566d7792768ab6069f727ca8d2b9522 [10-19 15:23:28:726 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:28:726 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:28:726 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:28:726 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:28:835 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:28:835 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:28:835 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:28:835 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:28:835 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:28:835 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/holiday.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:28:835 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:28:835 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:28:835 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:28:835 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:28:835 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:28:924 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:28:924 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:28:924 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:28:924 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:28:924 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:28:924 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:28:924 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:28:924 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:29:14 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:29:14 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:29:14 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:29:14 TUYA D][http_manager.c:135] http_send done [10-19 15:23:29:14 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:29:134 TUYA D][rcd_file.c:548] [ty_rcd]__flush_timer_cb start [10-19 15:23:29:134 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94001430 0x576444 94023d90 [10-19 15:23:29:134 TUYA D][thread_pool_temp.c:607] temp run 0x576444 94023d90 [10-19 15:23:29:134 TUYA D][thread_pool_temp.c:197] run temp 0x576444 94023d90 in thread 940013f0 BEGIN [10-19 15:23:29:134 TUYA D][rcd_file.c:533] [ty_rcd] __rcd_db_flush start. [10-19 15:23:29:139 TUYA D][rcd_file.c:538] [ty_rcd] __rcd_db_flush end. [10-19 15:23:29:139 TUYA D][thread_pool_temp.c:200] thread 940013f0 END [10-19 15:23:29:139 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:29:139 TUYA D][thread_pool_temp.c:143] put thread 0x7f94001430 [10-19 15:23:29:139 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:1 [10-19 15:23:29:221 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:29:221 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:29:221 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:29:221 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:29:221 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:29:222 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/holiday.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:29:222 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:29:222 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:29:222 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:29:222 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:29:222 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:29:258 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{},"t":1666164208,"success":true} [10-19 15:23:29:259 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:29:259 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:29:259 TUYA D][thread_pool_temp.c:200] thread 94001420 END [10-19 15:23:29:259 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:29:259 TUYA D][thread_pool_temp.c:143] put thread 0x7f8400f370 [10-19 15:23:29:259 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [10-19 15:23:29:449 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:29:449 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:29:449 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:29:449 TUYA D][http_manager.c:135] http_send done [10-19 15:23:29:449 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:29:638 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:29:638 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:29:638 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:29:638 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:29:638 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:29:638 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/holiday.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:29:638 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/rule/glyphicons/rest.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:29:638 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:29:638 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:29:638 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:29:638 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:29:638 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:29:738 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:29:738 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:29:840 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:29:840 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:29:840 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:29:840 TUYA D][http_manager.c:135] http_send done [10-19 15:23:29:840 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:30:64 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:30:64 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:30:64 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:30:64 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:30:64 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:30:64 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/rest.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:30:64 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:30:64 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:30:64 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:30:64 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:30:64 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:30:238 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:30:238 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:30:238 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:30:238 TUYA D][http_manager.c:135] http_send done [10-19 15:23:30:238 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:30:285 TUYA D][iot_httpc.c:596] Decode Rev:{"result":["eb0a212b4b26ce96c62aei","eb9c17916f715a30e0a7mz","ebc90e9813ffde4148tcvg","eb76889250a9917161wng9","ebb800d543876b9d83jiah","ebd0ad496c403f1af3i9an","eb4576f5222b16dccaaazi","eb68d8dbe4707224e8sxd8","ebd1ebe54febaa9c022vqf","eb67a0efcb59444d01ydgn","eb3edad403134c4f6czxy4","eb0f65ca9465be8edcoyot","ebe7f7541d3a5e34dcplwr","eba528413f6980a463pn4p","vdevo166201192349972","ebc78c65e28bc1347ac761","ebe3006b0f14083917oh1d","eb3cfb587e6d81417eac8e","ebb063750d514d878079mw","vdevo166004655924109","eb62263aaf2f73ef03xira","eb3b1fefe57125bb72nrzb","ebaf2b250cb41e058ekxqm","ebabc77077c75fec391svt","eb2372042e64f76e79f3jk","ebff3d1dac6c9c54ebu58o","eb631bd9b6590e001blfgs","vdevo166098193021398","ebae3eac4f123fe22bbx5k","ebb4f72bc0eb72ac62dhlo","eb92c47fe161c74b89dk25","eb62f037dd6640bfa41gut","eb21cdbd5e05e8e428gaca","eba19ee51b778585c0jcy3","eb0058bee16ce0c70aq9nj","eba407ffd4d23748c3rlsw"],"t":1666164210,"success":true} [10-19 15:23:30:286 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:30:286 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:30:286 TUYA D][tuya_ctrl_center.c:1502] get show dev_cnt: 36 [10-19 15:23:30:286 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb0a212b4b26ce96c62aei, serialize dp_names = {"1":"Switch 1","2":"Switch 2","3":"Switch 3","4":"Switch 4","5":"Switch 5","6":"Switch 6","16":"Backlight Switch"} [10-19 15:23:30:287 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb0a212b4b26ce96c62aei,p_rcd_info:0x7f9401e09c [10-19 15:23:30:287 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:72,p_rcd_info->crc32:2101040561,len:1232 key:eb0a212b4b26ce96c62aei. [10-19 15:23:30:287 TUYA D][tuya_ctrl_center.c:1525] dev id: eb0a212b4b26ce96c62aei name: Six Gang Switch 2 should show on screen [10-19 15:23:30:288 TUYA W][tuya_ctrl_storage.c:143] dev:eb9c17916f715a30e0a7mz, dp name is null [10-19 15:23:30:288 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb9c17916f715a30e0a7mz,p_rcd_info:0x7f9401dc24 [10-19 15:23:30:288 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:73,p_rcd_info->crc32:127778021,len:1232 key:eb9c17916f715a30e0a7mz. [10-19 15:23:30:289 TUYA D][tuya_ctrl_center.c:1525] dev id: eb9c17916f715a30e0a7mz name: Intelligent Switcher 2 should show on screen [10-19 15:23:30:289 TUYA W][tuya_ctrl_storage.c:143] dev:ebc90e9813ffde4148tcvg, dp name is null [10-19 15:23:30:289 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebc90e9813ffde4148tcvg,p_rcd_info:0x7f9401de94 [10-19 15:23:30:290 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:74,p_rcd_info->crc32:4107917005,len:1248 key:ebc90e9813ffde4148tcvg. [10-19 15:23:30:290 TUYA D][tuya_ctrl_center.c:1525] dev id: ebc90e9813ffde4148tcvg name: WI-FI Temperature & Humidity Sensor should show on screen [10-19 15:23:30:290 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb76889250a9917161wng9, serialize dp_names = {"2":"彩灯"} [10-19 15:23:30:290 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb76889250a9917161wng9,p_rcd_info:0x7f9401d980 [10-19 15:23:30:291 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:75,p_rcd_info->crc32:4052856240,len:1248 key:eb76889250a9917161wng9. [10-19 15:23:30:291 TUYA D][tuya_ctrl_center.c:1525] dev id: eb76889250a9917161wng9 name: Smart Color Ambiance Light should show on screen [10-19 15:23:30:291 TUYA W][tuya_ctrl_storage.c:143] dev:ebb800d543876b9d83jiah, dp name is null [10-19 15:23:30:292 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebb800d543876b9d83jiah,p_rcd_info:0x7f9401d87c [10-19 15:23:30:292 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:76,p_rcd_info->crc32:2742674593,len:1232 key:ebb800d543876b9d83jiah. [10-19 15:23:30:292 TUYA D][tuya_ctrl_center.c:1525] dev id: ebb800d543876b9d83jiah name: Alarm Security System should show on screen [10-19 15:23:30:292 TUYA W][tuya_ctrl_storage.c:143] dev:ebd0ad496c403f1af3i9an, dp name is null [10-19 15:23:30:293 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebd0ad496c403f1af3i9an,p_rcd_info:0x7f9401d640 [10-19 15:23:30:293 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:77,p_rcd_info->crc32:3918558865,len:1232 key:ebd0ad496c403f1af3i9an. [10-19 15:23:30:294 TUYA D][tuya_ctrl_center.c:1525] dev id: ebd0ad496c403f1af3i9an name: Zigbee Contact Sensor should show on screen [10-19 15:23:30:294 TUYA W][tuya_ctrl_storage.c:143] dev:eb4576f5222b16dccaaazi, dp name is null [10-19 15:23:30:294 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb4576f5222b16dccaaazi,p_rcd_info:0x7f9401dcc0 [10-19 15:23:30:294 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:78,p_rcd_info->crc32:1571539006,len:1232 key:eb4576f5222b16dccaaazi. [10-19 15:23:30:295 TUYA D][tuya_ctrl_center.c:1525] dev id: eb4576f5222b16dccaaazi name: WIFI lamp tape 2 should show on screen [10-19 15:23:30:295 TUYA W][tuya_ctrl_storage.c:143] dev:eb68d8dbe4707224e8sxd8, dp name is null [10-19 15:23:30:295 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb68d8dbe4707224e8sxd8,p_rcd_info:0x7f9401dd90 [10-19 15:23:30:296 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:79,p_rcd_info->crc32:3217080471,len:1216 key:eb68d8dbe4707224e8sxd8. [10-19 15:23:30:296 TUYA D][tuya_ctrl_center.c:1525] dev id: eb68d8dbe4707224e8sxd8 name: Wifi Plug should show on screen [10-19 15:23:30:296 TUYA W][tuya_ctrl_storage.c:143] dev:ebd1ebe54febaa9c022vqf, dp name is null [10-19 15:23:30:296 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebd1ebe54febaa9c022vqf,p_rcd_info:0x7f9401e0d0 [10-19 15:23:30:297 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:80,p_rcd_info->crc32:3684184018,len:1232 key:ebd1ebe54febaa9c022vqf. [10-19 15:23:30:297 TUYA D][tuya_ctrl_center.c:1525] dev id: ebd1ebe54febaa9c022vqf name: Soquete Inteligente should show on screen [10-19 15:23:30:297 TUYA W][tuya_ctrl_storage.c:143] dev:eb67a0efcb59444d01ydgn, dp name is null [10-19 15:23:30:298 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb67a0efcb59444d01ydgn,p_rcd_info:0x7f9401d7e0 [10-19 15:23:30:298 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:81,p_rcd_info->crc32:4149765423,len:1232 key:eb67a0efcb59444d01ydgn. [10-19 15:23:30:299 TUYA D][tuya_ctrl_center.c:1525] dev id: eb67a0efcb59444d01ydgn name: 智能插座 should show on screen [10-19 15:23:30:299 TUYA W][tuya_ctrl_storage.c:143] dev:eb3edad403134c4f6czxy4, dp name is null [10-19 15:23:30:299 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb3edad403134c4f6czxy4,p_rcd_info:0x7f9401d9e8 [10-19 15:23:30:300 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:82,p_rcd_info->crc32:3496148860,len:1216 key:eb3edad403134c4f6czxy4. [10-19 15:23:30:300 TUYA D][tuya_ctrl_center.c:1525] dev id: eb3edad403134c4f6czxy4 name: 人体传感器 should show on screen [10-19 15:23:30:300 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb0f65ca9465be8edcoyot, serialize dp_names = {"1":"Switch 1","2":"Switch 2","3":"Switch 3"} [10-19 15:23:30:300 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb0f65ca9465be8edcoyot,p_rcd_info:0x7f9401d6a8 [10-19 15:23:30:301 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:83,p_rcd_info->crc32:1593605643,len:1232 key:eb0f65ca9465be8edcoyot. [10-19 15:23:30:301 TUYA D][tuya_ctrl_center.c:1525] dev id: eb0f65ca9465be8edcoyot name: ZigBee 3 Gang Switch should show on screen [10-19 15:23:30:301 TUYA W][tuya_ctrl_storage.c:143] dev:ebe7f7541d3a5e34dcplwr, dp name is null [10-19 15:23:30:301 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebe7f7541d3a5e34dcplwr,p_rcd_info:0x7f9401d814 [10-19 15:23:30:302 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:84,p_rcd_info->crc32:2691424295,len:1216 key:ebe7f7541d3a5e34dcplwr. [10-19 15:23:30:302 TUYA D][tuya_ctrl_center.c:1525] dev id: ebe7f7541d3a5e34dcplwr name: RGB strip should show on screen [10-19 15:23:30:302 TUYA W][tuya_ctrl_storage.c:143] dev:eba528413f6980a463pn4p, dp name is null [10-19 15:23:30:303 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eba528413f6980a463pn4p,p_rcd_info:0x7f9401defc [10-19 15:23:30:303 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:85,p_rcd_info->crc32:2575894488,len:1248 key:eba528413f6980a463pn4p. [10-19 15:23:30:303 TUYA D][tuya_ctrl_center.c:1525] dev id: eba528413f6980a463pn4p name: Smart Bulb(BP5758D 35/10) should show on screen [10-19 15:23:30:304 TUYA W][tuya_ctrl_storage.c:143] dev:vdevo166201192349972, dp name is null [10-19 15:23:30:304 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:vdevo166201192349972,p_rcd_info:0x7f9401dc58 [10-19 15:23:30:304 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:86,p_rcd_info->crc32:3390062447,len:1216 key:vdevo166201192349972. [10-19 15:23:30:305 TUYA D][tuya_ctrl_center.c:1525] dev id: vdevo166201192349972 name: 幻彩2期-oem-vdevo should show on screen [10-19 15:23:30:305 TUYA D][tuya_ctrl_storage.c:169] dev_id : ebc78c65e28bc1347ac761, serialize dp_names = {"1":"Switch 1","2":"Switch 2","3":"Switch 3","4":"Switch 4","5":"Switch 5","6":"Switch 6","16":"Backlight Switch"} [10-19 15:23:30:305 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebc78c65e28bc1347ac761,p_rcd_info:0x7f9401d8b0 [10-19 15:23:30:305 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:87,p_rcd_info->crc32:3723984107,len:1232 key:ebc78c65e28bc1347ac761. [10-19 15:23:30:306 TUYA D][tuya_ctrl_center.c:1525] dev id: ebc78c65e28bc1347ac761 name: 4X4 Switch+Socket should show on screen [10-19 15:23:30:306 TUYA W][tuya_ctrl_storage.c:143] dev:ebe3006b0f14083917oh1d, dp name is null [10-19 15:23:30:306 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebe3006b0f14083917oh1d,p_rcd_info:0x7f9401ddc4 [10-19 15:23:30:307 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:88,p_rcd_info->crc32:2736764629,len:1232 key:ebe3006b0f14083917oh1d. [10-19 15:23:30:307 TUYA D][tuya_ctrl_center.c:1525] dev id: ebe3006b0f14083917oh1d name: 空调温控器 2 should show on screen [10-19 15:23:30:307 TUYA W][tuya_ctrl_storage.c:143] dev:eb3cfb587e6d81417eac8e, dp name is null [10-19 15:23:30:307 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb3cfb587e6d81417eac8e,p_rcd_info:0x7f9401de2c [10-19 15:23:30:308 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:89,p_rcd_info->crc32:3342434179,len:1232 key:eb3cfb587e6d81417eac8e. [10-19 15:23:30:308 TUYA D][tuya_ctrl_center.c:1525] dev id: eb3cfb587e6d81417eac8e name: Smart Switch should show on screen [10-19 15:23:30:308 TUYA W][tuya_ctrl_storage.c:143] dev:ebb063750d514d878079mw, dp name is null [10-19 15:23:30:309 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebb063750d514d878079mw,p_rcd_info:0x7f9401dcf4 [10-19 15:23:30:309 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:90,p_rcd_info->crc32:3921719118,len:1248 key:ebb063750d514d878079mw. [10-19 15:23:30:309 TUYA D][tuya_ctrl_center.c:1525] dev id: ebb063750d514d878079mw name: 计量微断开关(1P+N) should show on screen [10-19 15:23:30:310 TUYA D][tuya_ctrl_storage.c:169] dev_id : vdevo166004655924109, serialize dp_names = {"1":"开关 1","2":"开关 2","3":"开关 3","4":"开关 4","5":"开关 5","6":"开关 6","16":"背光开关"} [10-19 15:23:30:310 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:vdevo166004655924109,p_rcd_info:0x7f9401df30 [10-19 15:23:30:310 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:91,p_rcd_info->crc32:2337589784,len:1216 key:vdevo166004655924109. [10-19 15:23:30:311 TUYA D][tuya_ctrl_center.c:1525] dev id: vdevo166004655924109 name: Six Gang Switch-vdevo should show on screen [10-19 15:23:30:311 TUYA W][tuya_ctrl_storage.c:143] dev:eb62263aaf2f73ef03xira, dp name is null [10-19 15:23:30:311 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb62263aaf2f73ef03xira,p_rcd_info:0x7f9401d848 [10-19 15:23:30:312 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:92,p_rcd_info->crc32:4039949835,len:1232 key:eb62263aaf2f73ef03xira. [10-19 15:23:30:312 TUYA D][tuya_ctrl_center.c:1525] dev id: eb62263aaf2f73ef03xira name: 智能彩灯 should show on screen [10-19 15:23:30:312 TUYA W][tuya_ctrl_storage.c:143] dev:eb3b1fefe57125bb72nrzb, dp name is null [10-19 15:23:30:312 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb3b1fefe57125bb72nrzb,p_rcd_info:0x7f9401d8e4 [10-19 15:23:30:313 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:93,p_rcd_info->crc32:4238522071,len:1232 key:eb3b1fefe57125bb72nrzb. [10-19 15:23:30:313 TUYA D][tuya_ctrl_center.c:1525] dev id: eb3b1fefe57125bb72nrzb name: Curtain switch should show on screen [10-19 15:23:30:313 TUYA D][tuya_ctrl_storage.c:169] dev_id : ebaf2b250cb41e058ekxqm, serialize dp_names = {"1":"Switch 1","2":"Switch 2"} [10-19 15:23:30:314 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebaf2b250cb41e058ekxqm,p_rcd_info:0x7f9401dbbc [10-19 15:23:30:314 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:94,p_rcd_info->crc32:4155397716,len:1232 key:ebaf2b250cb41e058ekxqm. [10-19 15:23:30:314 TUYA D][tuya_ctrl_center.c:1525] dev id: ebaf2b250cb41e058ekxqm name: Smart Dual Socket 2 should show on screen [10-19 15:23:30:315 TUYA W][tuya_ctrl_storage.c:143] dev:ebabc77077c75fec391svt, dp name is null [10-19 15:23:30:315 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebabc77077c75fec391svt,p_rcd_info:0x7f9401d744 [10-19 15:23:30:315 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:95,p_rcd_info->crc32:1342355211,len:1232 key:ebabc77077c75fec391svt. [10-19 15:23:30:316 TUYA D][tuya_ctrl_center.c:1525] dev id: ebabc77077c75fec391svt name: Zigbee Smart Thermostat should show on screen [10-19 15:23:30:316 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb2372042e64f76e79f3jk, serialize dp_names = {"1":"开关1","2":"开关2","3":"开关3","44":"点动开关"} [10-19 15:23:30:316 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb2372042e64f76e79f3jk,p_rcd_info:0x7f9401e000 [10-19 15:23:30:317 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:96,p_rcd_info->crc32:2539775411,len:1232 key:eb2372042e64f76e79f3jk. [10-19 15:23:30:317 TUYA D][tuya_ctrl_center.c:1525] dev id: eb2372042e64f76e79f3jk name: Smart 3-Gang Switch should show on screen [10-19 15:23:30:317 TUYA W][tuya_ctrl_storage.c:143] dev:ebff3d1dac6c9c54ebu58o, dp name is null [10-19 15:23:30:317 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebff3d1dac6c9c54ebu58o,p_rcd_info:0x7f9401d9b4 [10-19 15:23:30:318 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:97,p_rcd_info->crc32:1962596506,len:1200 key:ebff3d1dac6c9c54ebu58o. [10-19 15:23:30:318 TUYA D][tuya_ctrl_center.c:1525] dev id: ebff3d1dac6c9c54ebu58o name: 门铃按钮 should show on screen [10-19 15:23:30:318 TUYA W][tuya_ctrl_storage.c:143] dev:eb631bd9b6590e001blfgs, dp name is null [10-19 15:23:30:319 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb631bd9b6590e001blfgs,p_rcd_info:0x7f9401dec8 [10-19 15:23:30:319 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:98,p_rcd_info->crc32:3649317846,len:1232 key:eb631bd9b6590e001blfgs. [10-19 15:23:30:320 TUYA D][tuya_ctrl_center.c:1525] dev id: eb631bd9b6590e001blfgs name: mini通断器 should show on screen [10-19 15:23:30:320 TUYA W][tuya_ctrl_storage.c:143] dev:vdevo166098193021398, dp name is null [10-19 15:23:30:320 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:vdevo166098193021398,p_rcd_info:0x7f9401ddf8 [10-19 15:23:30:321 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:99,p_rcd_info->crc32:2127628467,len:1232 key:vdevo166098193021398. [10-19 15:23:30:321 TUYA D][tuya_ctrl_center.c:1525] dev id: vdevo166098193021398 name: Smart Switch Module-vdevo should show on screen [10-19 15:23:30:321 TUYA D][tuya_ctrl_storage.c:169] dev_id : ebae3eac4f123fe22bbx5k, serialize dp_names = {"1":"开关 1","2":"开关 2","3":"开关 3","4":"开关 4","5":"开关 5","6":"开关 6","16":"背光开关"} [10-19 15:23:30:321 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebae3eac4f123fe22bbx5k,p_rcd_info:0x7f9401e16c [10-19 15:23:30:322 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:100,p_rcd_info->crc32:4037150089,len:1232 key:ebae3eac4f123fe22bbx5k. [10-19 15:23:30:322 TUYA D][tuya_ctrl_center.c:1525] dev id: ebae3eac4f123fe22bbx5k name: Six Gang Switch should show on screen [10-19 15:23:30:322 TUYA W][tuya_ctrl_storage.c:143] dev:ebb4f72bc0eb72ac62dhlo, dp name is null [10-19 15:23:30:323 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebb4f72bc0eb72ac62dhlo,p_rcd_info:0x7f9401de60 [10-19 15:23:30:323 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:101,p_rcd_info->crc32:2843588107,len:1232 key:ebb4f72bc0eb72ac62dhlo. [10-19 15:23:30:323 TUYA D][tuya_ctrl_center.c:1525] dev id: ebb4f72bc0eb72ac62dhlo name: WIFI lamp tape should show on screen [10-19 15:23:30:323 TUYA W][tuya_ctrl_storage.c:143] dev:eb92c47fe161c74b89dk25, dp name is null [10-19 15:23:30:324 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb92c47fe161c74b89dk25,p_rcd_info:0x7f9401da50 [10-19 15:23:30:324 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:102,p_rcd_info->crc32:2772803983,len:1200 key:eb92c47fe161c74b89dk25. [10-19 15:23:30:325 TUYA D][tuya_ctrl_center.c:1525] dev id: eb92c47fe161c74b89dk25 name: 门磁 should show on screen [10-19 15:23:30:325 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb62f037dd6640bfa41gut, serialize dp_names = {"1":"开关1","2":"开关2"} [10-19 15:23:30:325 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb62f037dd6640bfa41gut,p_rcd_info:0x7f9401dc8c [10-19 15:23:30:325 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:103,p_rcd_info->crc32:2395713849,len:1232 key:eb62f037dd6640bfa41gut. [10-19 15:23:30:326 TUYA D][tuya_ctrl_center.c:1525] dev id: eb62f037dd6640bfa41gut name: Smart Dual Socket should show on screen [10-19 15:23:30:326 TUYA W][tuya_ctrl_storage.c:143] dev:eb21cdbd5e05e8e428gaca, dp name is null [10-19 15:23:30:326 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb21cdbd5e05e8e428gaca,p_rcd_info:0x7f9401df64 [10-19 15:23:30:327 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:104,p_rcd_info->crc32:964738206,len:1232 key:eb21cdbd5e05e8e428gaca. [10-19 15:23:30:327 TUYA D][tuya_ctrl_center.c:1525] dev id: eb21cdbd5e05e8e428gaca name: 空调温控器 should show on screen [10-19 15:23:30:327 TUYA W][tuya_ctrl_storage.c:143] dev:eba19ee51b778585c0jcy3, dp name is null [10-19 15:23:30:328 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eba19ee51b778585c0jcy3,p_rcd_info:0x7f9401e1a0 [10-19 15:23:30:328 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:105,p_rcd_info->crc32:2981876833,len:1248 key:eba19ee51b778585c0jcy3. [10-19 15:23:30:328 TUYA D][tuya_ctrl_center.c:1525] dev id: eba19ee51b778585c0jcy3 name: Smart Wireless Switch K10W should show on screen [10-19 15:23:30:328 TUYA W][tuya_ctrl_storage.c:143] dev:eb0058bee16ce0c70aq9nj, dp name is null [10-19 15:23:30:329 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb0058bee16ce0c70aq9nj,p_rcd_info:0x7f9401dd5c [10-19 15:23:30:329 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:106,p_rcd_info->crc32:3453095001,len:1216 key:eb0058bee16ce0c70aq9nj. [10-19 15:23:30:330 TUYA D][tuya_ctrl_center.c:1525] dev id: eb0058bee16ce0c70aq9nj name: Temp should show on screen [10-19 15:23:30:330 TUYA W][tuya_ctrl_storage.c:143] dev:eba407ffd4d23748c3rlsw, dp name is null [10-19 15:23:30:330 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eba407ffd4d23748c3rlsw,p_rcd_info:0x7f9401dd28 [10-19 15:23:30:330 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:107,p_rcd_info->crc32:1135417004,len:1232 key:eba407ffd4d23748c3rlsw. [10-19 15:23:30:331 TUYA D][tuya_ctrl_center.c:1525] dev id: eba407ffd4d23748c3rlsw name: Intelligent Switcher should show on screen [10-19 15:23:30:331 TUYA D][tuya_ctrl_mqc.c:376] subscribe topic cnt:32 [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[0]:smart/mb/in/eb257c7e0da82bf6fdgo2g. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[1]:smart/mb/in/eb99a9cc76209358a4crkr. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[2]:smart/mb/in/eb67a0efcb59444d01ydgn. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[3]:smart/mb/in/ebe7f7541d3a5e34dcplwr. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[4]:smart/mb/in/eb62263aaf2f73ef03xira. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[5]:smart/mb/in/ebb800d543876b9d83jiah. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[6]:smart/mb/in/ebc78c65e28bc1347ac761. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[7]:smart/mb/in/eb3b1fefe57125bb72nrzb. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[8]:smart/mb/in/eb76889250a9917161wng9. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[9]:smart/mb/in/ebf8fee6f4298432a5eqvk. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[10]:smart/mb/in/ebaf2b250cb41e058ekxqm. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[11]:smart/mb/in/eb9c17916f715a30e0a7mz. [10-19 15:23:30:332 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[12]:smart/mb/in/vdevo166201192349972. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[13]:smart/mb/in/eb62f037dd6640bfa41gut. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[14]:smart/mb/in/eb4576f5222b16dccaaazi. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[15]:smart/mb/in/ebb063750d514d878079mw. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[16]:smart/mb/in/eba407ffd4d23748c3rlsw. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[17]:smart/mb/in/eb0058bee16ce0c70aq9nj. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[18]:smart/mb/in/eb68d8dbe4707224e8sxd8. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[19]:smart/mb/in/ebe3006b0f14083917oh1d. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[20]:smart/mb/in/vdevo166098193021398. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[21]:smart/mb/in/eb3cfb587e6d81417eac8e. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[22]:smart/mb/in/ebb4f72bc0eb72ac62dhlo. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[23]:smart/mb/in/ebc90e9813ffde4148tcvg. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[24]:smart/mb/in/eb631bd9b6590e001blfgs. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[25]:smart/mb/in/eba528413f6980a463pn4p. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[26]:smart/mb/in/vdevo166004655924109. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[27]:smart/mb/in/eb21cdbd5e05e8e428gaca. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[28]:smart/mb/in/eb2372042e64f76e79f3jk. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[29]:smart/mb/in/ebd1ebe54febaa9c022vqf. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[30]:smart/mb/in/eb827d57cf10b04d2fxtij. [10-19 15:23:30:333 TUYA D][tuya_ctrl_mqc.c:390] subscribe topic[31]:smart/mb/in/eba19ee51b778585c0jcy3. [10-19 15:23:30:333 TUYA D][iot_httpc.c:929] Post Data: {"t":1666164210} [10-19 15:23:30:333 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.screen.home.device.all&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164210&v=1.0&sign=77e94b0bffbd4847f562c15366104890 [10-19 15:23:30:333 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:30:333 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:30:334 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:30:334 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:30:420 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:30:420 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:30:420 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:30:420 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:30:420 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:30:420 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/rest.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:30:420 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:30:420 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:30:420 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:30:420 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:30:421 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:30:525 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:30:525 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:30:525 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:30:525 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:30:525 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:30:525 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:30:526 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:30:526 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:30:599 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:30:599 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:30:599 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:30:599 TUYA D][http_manager.c:135] http_send done [10-19 15:23:30:599 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:30:793 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:30:793 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:30:793 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:30:793 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:30:793 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:30:793 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/rest.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:30:793 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:30:793 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:30:793 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:30:793 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:30:793 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:30:964 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:30:964 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:30:964 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:30:964 TUYA D][http_manager.c:135] http_send done [10-19 15:23:30:964 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:31:18 TUYA D][subdev_upgrade_schema.c:530] start schema update subdev. [10-19 15:23:31:18 TUYA D][subdev_upgrade_schema.c:541] schema update dev get. [10-19 15:23:31:18 TUYA D][subdev_upgrade_schema.c:574] end schema update subdev:1. [10-19 15:23:31:157 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:31:157 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:31:157 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:31:157 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:31:157 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:31:157 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/rest.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:31:157 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:31:157 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:31:157 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:31:157 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:31:157 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:31:288 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:31:288 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:31:347 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:31:347 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:31:347 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:31:347 TUYA D][http_manager.c:135] http_send done [10-19 15:23:31:347 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:31:539 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:31:539 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:31:539 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:31:539 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:31:539 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:31:539 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/rest.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:31:539 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/rule/glyphicons/moon.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:31:539 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:31:539 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:31:539 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:31:539 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:31:539 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:31:721 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:31:721 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:31:721 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:31:721 TUYA D][http_manager.c:135] http_send done [10-19 15:23:31:721 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:31:907 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:31:907 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:31:907 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:31:907 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:31:907 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:31:907 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/moon.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:31:907 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:31:907 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:31:907 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:31:907 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:31:907 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:32:85 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:32:85 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:32:85 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:32:85 TUYA D][http_manager.c:135] http_send done [10-19 15:23:32:85 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:32:138 TUYA D][iot_httpc.c:438] chunk_num.2 [10-19 15:23:32:151 TUYA D][lan_cluster_master_core.c:1307] node [6c214989a443b2dd90a4or]report. st[1] [10-19 15:23:32:151 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c214989a443b2dd90a4or st:1 [10-19 15:23:32:151 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c214989a443b2dd90a4or [10-19 15:23:32:151 TUYA D][lan_msg_reliable_trans_master.c:636] id 6c214989a443b2dd90a4or already add [10-19 15:23:32:151 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c214989a443b2dd90a4or st:1 [10-19 15:23:32:151 TUYA D][lan_dp_report_sync_master.c:329] node 6c214989a443b2dd90a4or not found omit [10-19 15:23:32:151 TUYA I][lan_cluster_master_core.c:912] node [6c214989a443b2dd90a4or] joined [10-19 15:23:32:151 TUYA D][lan_cluster_master_core.c:1307] node [6c22f40a1acb1885b59qaq]report. st[1] [10-19 15:23:32:151 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c22f40a1acb1885b59qaq st:1 [10-19 15:23:32:151 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c22f40a1acb1885b59qaq [10-19 15:23:32:151 TUYA D][lan_msg_reliable_trans_master.c:636] id 6c22f40a1acb1885b59qaq already add [10-19 15:23:32:151 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c22f40a1acb1885b59qaq st:1 [10-19 15:23:32:151 TUYA D][lan_dp_report_sync_master.c:329] node 6c22f40a1acb1885b59qaq not found omit [10-19 15:23:32:151 TUYA I][lan_cluster_master_core.c:912] node [6c22f40a1acb1885b59qaq] joined [10-19 15:23:32:152 TUYA D][lan_cluster_master_core.c:1307] node [eb6ecb092720943cd7nfla]report. st[1] [10-19 15:23:32:152 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node eb6ecb092720943cd7nfla st:1 [10-19 15:23:32:152 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:eb6ecb092720943cd7nfla [10-19 15:23:32:152 TUYA D][lan_msg_reliable_trans_master.c:636] id eb6ecb092720943cd7nfla already add [10-19 15:23:32:152 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node eb6ecb092720943cd7nfla st:1 [10-19 15:23:32:152 TUYA D][lan_dp_report_sync_master.c:329] node eb6ecb092720943cd7nfla not found omit [10-19 15:23:32:152 TUYA I][lan_cluster_master_core.c:912] node [eb6ecb092720943cd7nfla] joined [10-19 15:23:32:152 TUYA D][lan_cluster_master_core.c:1307] node [6ca44bf75a687b0aecgwuy]report. st[1] [10-19 15:23:32:152 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6ca44bf75a687b0aecgwuy st:1 [10-19 15:23:32:152 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6ca44bf75a687b0aecgwuy [10-19 15:23:32:152 TUYA D][lan_msg_reliable_trans_master.c:636] id 6ca44bf75a687b0aecgwuy already add [10-19 15:23:32:152 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6ca44bf75a687b0aecgwuy st:1 [10-19 15:23:32:152 TUYA D][lan_dp_report_sync_master.c:329] node 6ca44bf75a687b0aecgwuy not found omit [10-19 15:23:32:152 TUYA I][lan_cluster_master_core.c:912] node [6ca44bf75a687b0aecgwuy] joined [10-19 15:23:32:152 TUYA D][lan_cluster_master_core.c:1307] node [6cc9a0a0f9425c382btujz]report. st[1] [10-19 15:23:32:152 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6cc9a0a0f9425c382btujz st:1 [10-19 15:23:32:152 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6cc9a0a0f9425c382btujz [10-19 15:23:32:152 TUYA D][lan_msg_reliable_trans_master.c:636] id 6cc9a0a0f9425c382btujz already add [10-19 15:23:32:152 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6cc9a0a0f9425c382btujz st:1 [10-19 15:23:32:152 TUYA D][lan_dp_report_sync_master.c:329] node 6cc9a0a0f9425c382btujz not found omit [10-19 15:23:32:152 TUYA I][lan_cluster_master_core.c:912] node [6cc9a0a0f9425c382btujz] joined [10-19 15:23:32:152 TUYA D][lan_cluster_master_core.c:1307] node [6c79c0b9048783677fr8zk]report. st[1] [10-19 15:23:32:152 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c79c0b9048783677fr8zk st:1 [10-19 15:23:32:152 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c79c0b9048783677fr8zk [10-19 15:23:32:152 TUYA D][lan_msg_reliable_trans_master.c:636] id 6c79c0b9048783677fr8zk already add [10-19 15:23:32:152 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c79c0b9048783677fr8zk st:1 [10-19 15:23:32:152 TUYA D][lan_dp_report_sync_master.c:329] node 6c79c0b9048783677fr8zk not found omit [10-19 15:23:32:152 TUYA I][lan_cluster_master_core.c:912] node [6c79c0b9048783677fr8zk] joined [10-19 15:23:32:152 TUYA D][lan_cluster_master_core.c:1307] node [6c969031d409e86a781tlx]report. st[1] [10-19 15:23:32:152 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c969031d409e86a781tlx st:1 [10-19 15:23:32:153 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c969031d409e86a781tlx [10-19 15:23:32:153 TUYA D][lan_msg_reliable_trans_master.c:636] id 6c969031d409e86a781tlx already add [10-19 15:23:32:153 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c969031d409e86a781tlx st:1 [10-19 15:23:32:153 TUYA D][lan_dp_report_sync_master.c:329] node 6c969031d409e86a781tlx not found omit [10-19 15:23:32:153 TUYA I][lan_cluster_master_core.c:912] node [6c969031d409e86a781tlx] joined [10-19 15:23:32:153 TUYA D][lan_cluster_master_core.c:1307] node [6c68477bf37381b524340j]report. st[1] [10-19 15:23:32:153 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c68477bf37381b524340j st:1 [10-19 15:23:32:153 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c68477bf37381b524340j [10-19 15:23:32:153 TUYA D][lan_msg_reliable_trans_master.c:636] id 6c68477bf37381b524340j already add [10-19 15:23:32:153 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c68477bf37381b524340j st:1 [10-19 15:23:32:153 TUYA D][lan_dp_report_sync_master.c:329] node 6c68477bf37381b524340j not found omit [10-19 15:23:32:153 TUYA I][lan_cluster_master_core.c:912] node [6c68477bf37381b524340j] joined [10-19 15:23:32:153 TUYA D][lan_cluster_master_core.c:1307] node [6c13b32e91fd726b8425ei]report. st[1] [10-19 15:23:32:153 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c13b32e91fd726b8425ei st:1 [10-19 15:23:32:153 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c13b32e91fd726b8425ei [10-19 15:23:32:153 TUYA D][lan_msg_reliable_trans_master.c:636] id 6c13b32e91fd726b8425ei already add [10-19 15:23:32:153 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c13b32e91fd726b8425ei st:1 [10-19 15:23:32:153 TUYA D][lan_dp_report_sync_master.c:329] node 6c13b32e91fd726b8425ei not found omit [10-19 15:23:32:153 TUYA I][lan_cluster_master_core.c:912] node [6c13b32e91fd726b8425ei] joined [10-19 15:23:32:153 TUYA D][lan_cluster_master_core.c:1307] node [6c6a927c9fe1cf0c9aui5u]report. st[1] [10-19 15:23:32:153 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c6a927c9fe1cf0c9aui5u st:1 [10-19 15:23:32:153 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c6a927c9fe1cf0c9aui5u [10-19 15:23:32:153 TUYA D][lan_msg_reliable_trans_master.c:636] id 6c6a927c9fe1cf0c9aui5u already add [10-19 15:23:32:153 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c6a927c9fe1cf0c9aui5u st:1 [10-19 15:23:32:153 TUYA D][lan_dp_report_sync_master.c:329] node 6c6a927c9fe1cf0c9aui5u not found omit [10-19 15:23:32:153 TUYA I][lan_cluster_master_core.c:912] node [6c6a927c9fe1cf0c9aui5u] joined [10-19 15:23:32:153 TUYA D][lan_cluster_master_core.c:1307] node [6c0094b881e56546a7d52s]report. st[1] [10-19 15:23:32:153 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c0094b881e56546a7d52s st:1 [10-19 15:23:32:153 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c0094b881e56546a7d52s [10-19 15:23:32:153 TUYA D][lan_msg_reliable_trans_master.c:636] id 6c0094b881e56546a7d52s already add [10-19 15:23:32:153 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c0094b881e56546a7d52s st:1 [10-19 15:23:32:154 TUYA D][lan_dp_report_sync_master.c:329] node 6c0094b881e56546a7d52s not found omit [10-19 15:23:32:154 TUYA I][lan_cluster_master_core.c:912] node [6c0094b881e56546a7d52s] joined [10-19 15:23:32:154 TUYA D][lan_cluster_master_core.c:1307] node [6c5005ca9f24c2b540xvlo]report. st[1] [10-19 15:23:32:154 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c5005ca9f24c2b540xvlo st:1 [10-19 15:23:32:154 TUYA I][lan_msg_reliable_trans_master.c:617] lan_msg_add_peer_node id:6c5005ca9f24c2b540xvlo [10-19 15:23:32:154 TUYA D][lan_msg_reliable_trans_master.c:636] id 6c5005ca9f24c2b540xvlo already add [10-19 15:23:32:154 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c5005ca9f24c2b540xvlo st:1 [10-19 15:23:32:154 TUYA D][lan_dp_report_sync_master.c:329] node 6c5005ca9f24c2b540xvlo not found omit [10-19 15:23:32:154 TUYA I][lan_cluster_master_core.c:912] node [6c5005ca9f24c2b540xvlo] joined [10-19 15:23:32:154 TUYA I][lan_cluster_master_core.c:1270] node report. total num[12] report num[12] [10-19 15:23:32:154 TUYA D][lan_cluster_node_info.c:122] __cluster_node_info_change_cb num = 12 6c5005ca9f24c2b540xvlo,6c0094b881e56546a7d52s,6c6a927c9fe1cf0c9aui5u,6c13b32e91fd726b8425ei,6c68477bf37381b524340j,6c969031d409e86a781tlx,6c79c0b9048783677fr8zk,6cc9a0a0f9425c382btujz,6ca44bf75a687b0aecgwuy,eb6ecb092720943cd7nfla,6c22f40a1acb1885b59qaq,6c214989a443b2dd90a4or,[10-19 15:23:32:154 TUYA D][lan_cluster_node_info.c:126] [10-19 15:23:32:154 TUYA D][lan_dev_base_master.c:460] node report num[12] [10-19 15:23:32:273 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:32:273 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:32:273 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:32:273 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:32:273 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:32:273 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/moon.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:32:273 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:32:273 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:32:273 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:32:273 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:32:273 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:32:292 TUYA D][thread_pool_temp.c:413] check delay task num=1 [10-19 15:23:32:292 TUYA D][thread_pool_temp.c:607] temp run 0x58c634 0 [10-19 15:23:32:293 TUYA D][thread_pool_temp.c:197] run temp 0x58c634 0 in thread 94001420 BEGIN [10-19 15:23:32:293 TUYA D][iot_httpc.c:929] Post Data: {"typeAttribute":0,"t":1666164212} [10-19 15:23:32:293 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.local.group.relation.get&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164212&v=1.0&sign=bb4f2d7effad769b77d432891a572284 [10-19 15:23:32:293 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:32:293 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:32:293 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:32:293 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:32:324 TUYA D][iot_httpc.c:438] chunk_num.3 [10-19 15:23:32:480 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:32:480 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:32:480 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:32:480 TUYA D][http_manager.c:135] http_send done [10-19 15:23:32:480 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:32:489 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:32:489 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:32:489 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:32:489 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:32:489 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:32:489 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:32:489 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:32:490 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:32:494 TUYA D][iot_httpc.c:438] chunk_num.4 [10-19 15:23:32:501 TUYA D][iot_httpc.c:457] total_len:103055 [10-19 15:23:32:671 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:32:671 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:32:671 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:32:671 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:32:671 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:32:671 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/moon.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:32:671 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:32:671 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:32:671 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:32:671 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:32:671 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:32:710 TUYA D][iot_httpc.c:596] Decode Rev:{"result":[{"virtual":false,"lon":"113.8554","ownerId":"77850135","uuid":"a4c1384c59b8c6ff","mac":"a4c1384c59b8c6ff","accessType":0,"otaInfo":{"supportAuto":true,"otaUpgradeModes":[0],"otaModuleMap":{"zigbee":{"upgradeStatus":0,"cdv":"","verSw":"1.0.6"}}},"iconUrl":"https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/162615470435b99f0456c.png","communication":{"communicationNode":"eb257c7e0da82bf6fdgo2g","communicationModes":[{"pv":"","type":0},{"pv":"2.2","type":1}],"connectionStatus":0},"lat":"22.5904","runtimeEnv":"prod","devKey":"","devId":"ebd0ad496c403f1af3i9an","productId":"a33rw7ou","ip":"","activeTime":1666083500,"cloudOnline":false,"baseAttribute":0,"devAttribute":2048,"dataPointInfo":{"dpMaxTime":1666083500623,"dpName":{},"dps":{"1":false,"2":100},"dpsTime":{"1":1666083500623,"2":1666083500623}},"name":"Zigbee Contact Sensor","timezoneId":"Asia/Shanghai","deviceTopo":{"parentDevId":"eb257c7e0da82bf6fdgo2g","nodeId":"a4c1384c59b8c6ff" [10-19 15:23:32:728 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:32:729 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:32:729 TUYA D][tuya_ctrl_center.c:1422] get dev_cnt: 60 [10-19 15:23:32:729 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:729 TUYA D][tuya_ctrl_center.c:1337] update devId: ebd0ad496c403f1af3i9an name: Zigbee Contact Sensor pid: a33rw7ou comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: a4c1384c59b8c6ff dev_num: 60 [10-19 15:23:32:729 TUYA W][tuya_ctrl_storage.c:143] dev:ebd0ad496c403f1af3i9an, dp name is null [10-19 15:23:32:729 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebd0ad496c403f1af3i9an,p_rcd_info:0x7f9401e374 [10-19 15:23:32:730 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:108,p_rcd_info->crc32:3918558865,len:1232 key:ebd0ad496c403f1af3i9an. [10-19 15:23:32:730 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:730 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:730 TUYA D][tuya_ctrl_center.c:1337] update devId: eb257c7e0da82bf6fdgo2g name: Zigbee LAN Gateway pid: axw2wati6x8wwqrh comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:731 TUYA W][tuya_ctrl_storage.c:143] dev:eb257c7e0da82bf6fdgo2g, dp name is null [10-19 15:23:32:731 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb257c7e0da82bf6fdgo2g,p_rcd_info:0x7f9401d674 [10-19 15:23:32:731 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:109,p_rcd_info->crc32:1686685308,len:1232 key:eb257c7e0da82bf6fdgo2g. [10-19 15:23:32:732 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:732 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: Switch 1 [10-19 15:23:32:732 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: Switch 2 [10-19 15:23:32:732 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: Switch 3 [10-19 15:23:32:732 TUYA D][tuya_ctrl_center.c:1337] update devId: eb0f65ca9465be8edcoyot name: ZigBee 3 Gang Switch pid: ajadcojk comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: 9035eafffe583c5a dev_num: 60 [10-19 15:23:32:732 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb0f65ca9465be8edcoyot, serialize dp_names = {"1":"Switch 1","2":"Switch 2","3":"Switch 3"} [10-19 15:23:32:732 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb0f65ca9465be8edcoyot,p_rcd_info:0x7f9401e4ac [10-19 15:23:32:733 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:110,p_rcd_info->crc32:1593605643,len:1232 key:eb0f65ca9465be8edcoyot. [10-19 15:23:32:733 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:733 TUYA D][tuya_ctrl_center.c:1337] update devId: ebf673a55509854f89o4ms name: Switch of scene pid: mh9px7cq comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: a4c138389b2e90c3 dev_num: 60 [10-19 15:23:32:733 TUYA W][tuya_ctrl_storage.c:143] dev:ebf673a55509854f89o4ms, dp name is null [10-19 15:23:32:734 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebf673a55509854f89o4ms,p_rcd_info:0x7f9401d6dc [10-19 15:23:32:734 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:111,p_rcd_info->crc32:3826706150,len:1232 key:ebf673a55509854f89o4ms. [10-19 15:23:32:735 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:735 TUYA D][tuya_ctrl_center.c:1337] update devId: ebe5c0ea9264da5aedqyqx name: 4'' Smart panel-EU pid: 2ywpwkvsgqujwlgs comm: ebe5c0ea9264da5aedqyqx pv: 2.2 sub: 0 node: 05e0 dev_num: 60 [10-19 15:23:32:735 TUYA W][tuya_ctrl_storage.c:143] dev:ebe5c0ea9264da5aedqyqx, dp name is null [10-19 15:23:32:735 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebe5c0ea9264da5aedqyqx,p_rcd_info:0x7f9401d710 [10-19 15:23:32:736 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:112,p_rcd_info->crc32:1342546565,len:1232 key:ebe5c0ea9264da5aedqyqx. [10-19 15:23:32:736 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:736 TUYA D][tuya_ctrl_center.c:1337] update devId: ebabc77077c75fec391svt name: Zigbee Smart Thermostat pid: 2ekuz3dz comm: eb99a9cc76209358a4crkr pv: 2.2 sub: 1 node: a4c1388ce8e59bc8 dev_num: 60 [10-19 15:23:32:736 TUYA W][tuya_ctrl_storage.c:143] dev:ebabc77077c75fec391svt, dp name is null [10-19 15:23:32:737 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebabc77077c75fec391svt,p_rcd_info:0x7f9401e71c [10-19 15:23:32:737 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:113,p_rcd_info->crc32:1342355211,len:1232 key:ebabc77077c75fec391svt. [10-19 15:23:32:738 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:738 TUYA D][tuya_ctrl_center.c:1337] update devId: ebe2744515d20294b1yhgw name: Zigbee Repeater pid: nkkl7uzv comm: eb99a9cc76209358a4crkr pv: 2.2 sub: 1 node: b4e3f9fffe3e0834 dev_num: 60 [10-19 15:23:32:738 TUYA W][tuya_ctrl_storage.c:143] dev:ebe2744515d20294b1yhgw, dp name is null [10-19 15:23:32:738 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebe2744515d20294b1yhgw,p_rcd_info:0x7f9401d778 [10-19 15:23:32:739 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:114,p_rcd_info->crc32:190962717,len:1232 key:ebe2744515d20294b1yhgw. [10-19 15:23:32:739 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:739 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:739 TUYA D][tuya_ctrl_center.c:1337] update devId: eb99a9cc76209358a4crkr name: Gateway pid: 7zjewx91 comm: eb99a9cc76209358a4crkr pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:739 TUYA W][tuya_ctrl_storage.c:143] dev:eb99a9cc76209358a4crkr, dp name is null [10-19 15:23:32:740 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb99a9cc76209358a4crkr,p_rcd_info:0x7f9401d7ac [10-19 15:23:32:740 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:115,p_rcd_info->crc32:674601886,len:1216 key:eb99a9cc76209358a4crkr. [10-19 15:23:32:741 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:741 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:741 TUYA D][tuya_ctrl_center.c:1337] update devId: eb67a0efcb59444d01ydgn name: 智能插座 pid: grpvptbrpkissnd8 comm: eb67a0efcb59444d01ydgn pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:741 TUYA W][tuya_ctrl_storage.c:143] dev:eb67a0efcb59444d01ydgn, dp name is null [10-19 15:23:32:741 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb67a0efcb59444d01ydgn,p_rcd_info:0x7f9401e444 [10-19 15:23:32:742 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:116,p_rcd_info->crc32:4149765423,len:1232 key:eb67a0efcb59444d01ydgn. [10-19 15:23:32:742 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:742 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:742 TUYA D][tuya_ctrl_center.c:1337] update devId: ebe7f7541d3a5e34dcplwr name: RGB strip pid: pbx8cm1kvgn0fv2d comm: ebe7f7541d3a5e34dcplwr pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:742 TUYA W][tuya_ctrl_storage.c:143] dev:ebe7f7541d3a5e34dcplwr, dp name is null [10-19 15:23:32:742 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebe7f7541d3a5e34dcplwr,p_rcd_info:0x7f9401e4e0 [10-19 15:23:32:743 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:117,p_rcd_info->crc32:2691424295,len:1216 key:ebe7f7541d3a5e34dcplwr. [10-19 15:23:32:743 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:743 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:744 TUYA D][tuya_ctrl_center.c:1337] update devId: eb62263aaf2f73ef03xira name: 智能彩灯 pid: qhfvhlm1k0ws0gul comm: eb62263aaf2f73ef03xira pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:744 TUYA W][tuya_ctrl_storage.c:143] dev:eb62263aaf2f73ef03xira, dp name is null [10-19 15:23:32:744 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb62263aaf2f73ef03xira,p_rcd_info:0x7f9401e680 [10-19 15:23:32:744 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:118,p_rcd_info->crc32:4039949835,len:1232 key:eb62263aaf2f73ef03xira. [10-19 15:23:32:745 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:745 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:745 TUYA D][tuya_ctrl_center.c:1337] update devId: ebb800d543876b9d83jiah name: Alarm Security System pid: dc6v3yjsjhajgb7f comm: ebb800d543876b9d83jiah pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:745 TUYA W][tuya_ctrl_storage.c:143] dev:ebb800d543876b9d83jiah, dp name is null [10-19 15:23:32:745 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebb800d543876b9d83jiah,p_rcd_info:0x7f9401e340 [10-19 15:23:32:746 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:119,p_rcd_info->crc32:2742674593,len:1232 key:ebb800d543876b9d83jiah. [10-19 15:23:32:746 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:746 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:747 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: Switch 1 [10-19 15:23:32:747 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: Switch 2 [10-19 15:23:32:747 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: Switch 3 [10-19 15:23:32:747 TUYA D][tuya_ctrl_center.c:1202] dp: 4 name: Switch 4 [10-19 15:23:32:747 TUYA D][tuya_ctrl_center.c:1202] dp: 5 name: Switch 5 [10-19 15:23:32:747 TUYA D][tuya_ctrl_center.c:1202] dp: 16 name: Backlight Switch [10-19 15:23:32:747 TUYA D][tuya_ctrl_center.c:1202] dp: 6 name: Switch 6 [10-19 15:23:32:747 TUYA D][tuya_ctrl_center.c:1202] dp: 19 name: Delay-off Schedule [10-19 15:23:32:747 TUYA E][tuya_ctrl_center.c:1205] id: 19 not find [10-19 15:23:32:747 TUYA D][tuya_ctrl_center.c:1337] update devId: ebc78c65e28bc1347ac761 name: 4X4 Switch+Socket pid: 0ln8tfei1iulgo2k comm: ebc78c65e28bc1347ac761 pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:747 TUYA D][tuya_ctrl_storage.c:169] dev_id : ebc78c65e28bc1347ac761, serialize dp_names = {"1":"Switch 1","2":"Switch 2","3":"Switch 3","4":"Switch 4","5":"Switch 5","6":"Switch 6","16":"Backlight Switch"} [10-19 15:23:32:747 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebc78c65e28bc1347ac761,p_rcd_info:0x7f9401e57c [10-19 15:23:32:748 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:120,p_rcd_info->crc32:3723984107,len:1232 key:ebc78c65e28bc1347ac761. [10-19 15:23:32:748 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:748 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:748 TUYA D][tuya_ctrl_center.c:1337] update devId: eb3b1fefe57125bb72nrzb name: Curtain switch pid: 1aso8gn0szwvjjue comm: eb3b1fefe57125bb72nrzb pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:748 TUYA W][tuya_ctrl_storage.c:143] dev:eb3b1fefe57125bb72nrzb, dp name is null [10-19 15:23:32:749 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb3b1fefe57125bb72nrzb,p_rcd_info:0x7f9401e6b4 [10-19 15:23:32:749 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:121,p_rcd_info->crc32:4238522071,len:1232 key:eb3b1fefe57125bb72nrzb. [10-19 15:23:32:750 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:750 TUYA D][tuya_ctrl_center.c:1337] update devId: eb9e43a7db146d1286luio name: 空调 pid: 0000008vhd comm: eb87649dc6a4ae7fef87xr pv: 2.2 sub: 1 node: f919e9057b0bfb2b dev_num: 60 [10-19 15:23:32:750 TUYA W][tuya_ctrl_storage.c:143] dev:eb9e43a7db146d1286luio, dp name is null [10-19 15:23:32:750 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb9e43a7db146d1286luio,p_rcd_info:0x7f9401d918 [10-19 15:23:32:751 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:122,p_rcd_info->crc32:2962929744,len:1200 key:eb9e43a7db146d1286luio. [10-19 15:23:32:751 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:751 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:751 TUYA D][tuya_ctrl_center.c:1337] update devId: eb87649dc6a4ae7fef87xr name: 智能红外遥控器 pid: mjffeakbzlnfxpzt comm: eb87649dc6a4ae7fef87xr pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:751 TUYA W][tuya_ctrl_storage.c:143] dev:eb87649dc6a4ae7fef87xr, dp name is null [10-19 15:23:32:752 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb87649dc6a4ae7fef87xr,p_rcd_info:0x7f9401d94c [10-19 15:23:32:752 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:123,p_rcd_info->crc32:3002071898,len:1232 key:eb87649dc6a4ae7fef87xr. [10-19 15:23:32:753 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:753 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:753 TUYA D][tuya_ctrl_center.c:1202] dp: 110 name: 闹钟2 [10-19 15:23:32:753 TUYA E][tuya_ctrl_center.c:1205] id: 110 not find [10-19 15:23:32:753 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: 彩灯 [10-19 15:23:32:753 TUYA D][tuya_ctrl_center.c:1202] dp: 102 name: 炫彩 [10-19 15:23:32:753 TUYA E][tuya_ctrl_center.c:1205] id: 102 not find [10-19 15:23:32:753 TUYA D][tuya_ctrl_center.c:1202] dp: 104 name: 夜灯 [10-19 15:23:32:753 TUYA E][tuya_ctrl_center.c:1205] id: 104 not find [10-19 15:23:32:753 TUYA D][tuya_ctrl_center.c:1202] dp: 106 name: 伴睡 [10-19 15:23:32:753 TUYA E][tuya_ctrl_center.c:1205] id: 106 not find [10-19 15:23:32:753 TUYA D][tuya_ctrl_center.c:1202] dp: 108 name: 闹钟1 [10-19 15:23:32:753 TUYA E][tuya_ctrl_center.c:1205] id: 108 not find [10-19 15:23:32:753 TUYA D][tuya_ctrl_center.c:1337] update devId: eb76889250a9917161wng9 name: Smart Color Ambiance Light pid: 6y1cduj4ealrfndo comm: eb76889250a9917161wng9 pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:753 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb76889250a9917161wng9, serialize dp_names = {"2":"彩灯"} [10-19 15:23:32:754 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb76889250a9917161wng9,p_rcd_info:0x7f9401e30c [10-19 15:23:32:754 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:124,p_rcd_info->crc32:4052856240,len:1248 key:eb76889250a9917161wng9. [10-19 15:23:32:755 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:755 TUYA D][tuya_ctrl_center.c:1337] update devId: ebff3d1dac6c9c54ebu58o name: 门铃按钮 pid: 2mqosesmkrvlvl0w comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: 0995C0FF dev_num: 60 [10-19 15:23:32:755 TUYA W][tuya_ctrl_storage.c:143] dev:ebff3d1dac6c9c54ebu58o, dp name is null [10-19 15:23:32:755 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebff3d1dac6c9c54ebu58o,p_rcd_info:0x7f9401e784 [10-19 15:23:32:756 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:125,p_rcd_info->crc32:1962596506,len:1200 key:ebff3d1dac6c9c54ebu58o. [10-19 15:23:32:756 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:756 TUYA D][tuya_ctrl_center.c:1337] update devId: eb3edad403134c4f6czxy4 name: 人体传感器 pid: jcamvbr95hdno5ub comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: AD2250FF dev_num: 60 [10-19 15:23:32:756 TUYA W][tuya_ctrl_storage.c:143] dev:eb3edad403134c4f6czxy4, dp name is null [10-19 15:23:32:757 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb3edad403134c4f6czxy4,p_rcd_info:0x7f9401e478 [10-19 15:23:32:757 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:126,p_rcd_info->crc32:3496148860,len:1216 key:eb3edad403134c4f6czxy4. [10-19 15:23:32:757 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:758 TUYA D][tuya_ctrl_center.c:1337] update devId: ebd959f9cc5a9857b2zsoo name: 遥控器 pid: zach3mptpjpojys6 comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: 5ECA80FF dev_num: 60 [10-19 15:23:32:758 TUYA W][tuya_ctrl_storage.c:143] dev:ebd959f9cc5a9857b2zsoo, dp name is null [10-19 15:23:32:758 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebd959f9cc5a9857b2zsoo,p_rcd_info:0x7f9401da1c [10-19 15:23:32:758 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:127,p_rcd_info->crc32:1510184285,len:1200 key:ebd959f9cc5a9857b2zsoo. [10-19 15:23:32:759 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:759 TUYA D][tuya_ctrl_center.c:1337] update devId: eb92c47fe161c74b89dk25 name: 门磁 pid: wpxcg1ahziux5tzh comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 1 node: 83DF08FF dev_num: 60 [10-19 15:23:32:759 TUYA W][tuya_ctrl_storage.c:143] dev:eb92c47fe161c74b89dk25, dp name is null [10-19 15:23:32:760 TUYA N][rcd_file.c:1195] [ty_rcd] need merg records or expand records.rcd_max:128,rcd_cnt:128,rcd_valid_cnt:60 . [10-19 15:23:32:760 TUYA N][rcd_file.c:1235] [ty_rcd] may be need to merg records,op_ret:-10105 . [10-19 15:23:32:760 TUYA E][rcd_file.c:1335] write kv eb92c47fe161c74b89dk25 fail!! [10-19 15:23:32:760 TUYA D][rcd_file.c:1948] [ty_rcd] Record merge procedure. [10-19 15:23:32:760 TUYA D][rcd_file.c:1965] rebuild [ebf8fee6f4298432a5eqvk] 6720 1232 [10-19 15:23:32:760 TUYA D][rcd_file.c:1970] move value key:ebf8fee6f4298432a5eqvk, 47168 to 6720 [10-19 15:23:32:760 TUYA D][rcd_file.c:1985] move rcd key:ebf8fee6f4298432a5eqvk, 33 to 0 [10-19 15:23:32:760 TUYA D][rcd_file.c:1965] rebuild [eb8607e2c51bffc942fczo] 7952 1232 [10-19 15:23:32:760 TUYA D][rcd_file.c:1970] move value key:eb8607e2c51bffc942fczo, 48400 to 7952 [10-19 15:23:32:760 TUYA D][rcd_file.c:1985] move rcd key:eb8607e2c51bffc942fczo, 34 to 1 [10-19 15:23:32:760 TUYA D][rcd_file.c:1965] rebuild [ebf911148e218a63b67uf3] 9184 1200 [10-19 15:23:32:760 TUYA D][rcd_file.c:1970] move value key:ebf911148e218a63b67uf3, 49632 to 9184 [10-19 15:23:32:760 TUYA D][rcd_file.c:1985] move rcd key:ebf911148e218a63b67uf3, 35 to 2 [10-19 15:23:32:760 TUYA D][rcd_file.c:1965] rebuild [ebd88c655bdd4b39adihqe] 10384 1232 [10-19 15:23:32:760 TUYA D][rcd_file.c:1970] move value key:ebd88c655bdd4b39adihqe, 50832 to 10384 [10-19 15:23:32:760 TUYA D][rcd_file.c:1985] move rcd key:ebd88c655bdd4b39adihqe, 36 to 3 [10-19 15:23:32:761 TUYA D][rcd_file.c:1965] rebuild [eb46ca57fbaaa5a173n9zv] 11616 1232 [10-19 15:23:32:761 TUYA D][rcd_file.c:1970] move value key:eb46ca57fbaaa5a173n9zv, 52064 to 11616 [10-19 15:23:32:761 TUYA D][rcd_file.c:1985] move rcd key:eb46ca57fbaaa5a173n9zv, 37 to 4 [10-19 15:23:32:761 TUYA D][rcd_file.c:1965] rebuild [eb92b0479e015fbbaavltv] 12848 1232 [10-19 15:23:32:761 TUYA D][rcd_file.c:1970] move value key:eb92b0479e015fbbaavltv, 53296 to 12848 [10-19 15:23:32:761 TUYA D][rcd_file.c:1985] move rcd key:eb92b0479e015fbbaavltv, 38 to 5 [10-19 15:23:32:761 TUYA D][rcd_file.c:1965] rebuild [eb09bad8e75f6222acaglz] 14080 1232 [10-19 15:23:32:761 TUYA D][rcd_file.c:1970] move value key:eb09bad8e75f6222acaglz, 55760 to 14080 [10-19 15:23:32:761 TUYA D][rcd_file.c:1985] move rcd key:eb09bad8e75f6222acaglz, 40 to 6 [10-19 15:23:32:761 TUYA D][rcd_file.c:1965] rebuild [eb71d993c258066917jpks] 15312 1216 [10-19 15:23:32:761 TUYA D][rcd_file.c:1970] move value key:eb71d993c258066917jpks, 77920 to 15312 [10-19 15:23:32:761 TUYA D][rcd_file.c:1985] move rcd key:eb71d993c258066917jpks, 58 to 7 [10-19 15:23:32:761 TUYA D][rcd_file.c:1965] rebuild [ebba64b6ac327cdeddq8z2] 16528 1232 [10-19 15:23:32:761 TUYA D][rcd_file.c:1970] move value key:ebba64b6ac327cdeddq8z2, 79136 to 16528 [10-19 15:23:32:761 TUYA D][rcd_file.c:1985] move rcd key:ebba64b6ac327cdeddq8z2, 59 to 8 [10-19 15:23:32:761 TUYA D][rcd_file.c:1965] rebuild [ebb3fad96f393b588eomxh] 17760 1232 [10-19 15:23:32:761 TUYA D][rcd_file.c:1970] move value key:ebb3fad96f393b588eomxh, 81600 to 17760 [10-19 15:23:32:761 TUYA D][rcd_file.c:1985] move rcd key:ebb3fad96f393b588eomxh, 61 to 9 [10-19 15:23:32:761 TUYA D][rcd_file.c:1965] rebuild [eb1552c6f83a6b59edmyes] 18992 1216 [10-19 15:23:32:761 TUYA D][rcd_file.c:1970] move value key:eb1552c6f83a6b59edmyes, 82832 to 18992 [10-19 15:23:32:762 TUYA D][rcd_file.c:1985] move rcd key:eb1552c6f83a6b59edmyes, 62 to 10 [10-19 15:23:32:762 TUYA D][rcd_file.c:1965] rebuild [eba3fc32248cc469a3y5qe] 20208 1216 [10-19 15:23:32:762 TUYA D][rcd_file.c:1970] move value key:eba3fc32248cc469a3y5qe, 86512 to 20208 [10-19 15:23:32:762 TUYA D][rcd_file.c:1985] move rcd key:eba3fc32248cc469a3y5qe, 65 to 11 [10-19 15:23:32:762 TUYA D][rcd_file.c:1965] rebuild [eb0469f56ed95d7791ogla] 21424 1216 [10-19 15:23:32:762 TUYA D][rcd_file.c:1970] move value key:eb0469f56ed95d7791ogla, 87728 to 21424 [10-19 15:23:32:762 TUYA D][rcd_file.c:1985] move rcd key:eb0469f56ed95d7791ogla, 66 to 12 [10-19 15:23:32:762 TUYA D][rcd_file.c:1965] rebuild [eb827d57cf10b04d2fxtij] 22640 1232 [10-19 15:23:32:762 TUYA D][rcd_file.c:1970] move value key:eb827d57cf10b04d2fxtij, 91424 to 22640 [10-19 15:23:32:762 TUYA D][rcd_file.c:1985] move rcd key:eb827d57cf10b04d2fxtij, 69 to 13 [10-19 15:23:32:762 TUYA D][rcd_file.c:1965] rebuild [eb079c4f40c6c21e6ffpd0] 23872 1216 [10-19 15:23:32:762 TUYA D][rcd_file.c:1970] move value key:eb079c4f40c6c21e6ffpd0, 92656 to 23872 [10-19 15:23:32:762 TUYA D][rcd_file.c:1985] move rcd key:eb079c4f40c6c21e6ffpd0, 70 to 14 [10-19 15:23:32:762 TUYA D][rcd_file.c:1965] rebuild [eb44125a98339e4a81t9za] 25088 1232 [10-19 15:23:32:762 TUYA D][rcd_file.c:1970] move value key:eb44125a98339e4a81t9za, 93872 to 25088 [10-19 15:23:32:762 TUYA D][rcd_file.c:1985] move rcd key:eb44125a98339e4a81t9za, 71 to 15 [10-19 15:23:32:762 TUYA D][rcd_file.c:1965] rebuild [eb0a212b4b26ce96c62aei] 26320 1232 [10-19 15:23:32:762 TUYA D][rcd_file.c:1970] move value key:eb0a212b4b26ce96c62aei, 95104 to 26320 [10-19 15:23:32:762 TUYA D][rcd_file.c:1985] move rcd key:eb0a212b4b26ce96c62aei, 72 to 16 [10-19 15:23:32:762 TUYA D][rcd_file.c:1965] rebuild [eb9c17916f715a30e0a7mz] 27552 1232 [10-19 15:23:32:763 TUYA D][rcd_file.c:1970] move value key:eb9c17916f715a30e0a7mz, 96336 to 27552 [10-19 15:23:32:763 TUYA D][rcd_file.c:1985] move rcd key:eb9c17916f715a30e0a7mz, 73 to 17 [10-19 15:23:32:763 TUYA D][rcd_file.c:1965] rebuild [ebc90e9813ffde4148tcvg] 28784 1248 [10-19 15:23:32:763 TUYA D][rcd_file.c:1970] move value key:ebc90e9813ffde4148tcvg, 97568 to 28784 [10-19 15:23:32:763 TUYA D][rcd_file.c:1985] move rcd key:ebc90e9813ffde4148tcvg, 74 to 18 [10-19 15:23:32:763 TUYA D][rcd_file.c:1965] rebuild [eb4576f5222b16dccaaazi] 30032 1232 [10-19 15:23:32:763 TUYA D][rcd_file.c:1970] move value key:eb4576f5222b16dccaaazi, 102528 to 30032 [10-19 15:23:32:763 TUYA D][rcd_file.c:1985] move rcd key:eb4576f5222b16dccaaazi, 78 to 19 [10-19 15:23:32:763 TUYA D][rcd_file.c:1965] rebuild [eb68d8dbe4707224e8sxd8] 31264 1216 [10-19 15:23:32:763 TUYA D][rcd_file.c:1970] move value key:eb68d8dbe4707224e8sxd8, 103760 to 31264 [10-19 15:23:32:763 TUYA D][rcd_file.c:1985] move rcd key:eb68d8dbe4707224e8sxd8, 79 to 20 [10-19 15:23:32:763 TUYA D][rcd_file.c:1965] rebuild [ebd1ebe54febaa9c022vqf] 32480 1232 [10-19 15:23:32:763 TUYA D][rcd_file.c:1970] move value key:ebd1ebe54febaa9c022vqf, 104976 to 32480 [10-19 15:23:32:763 TUYA D][rcd_file.c:1985] move rcd key:ebd1ebe54febaa9c022vqf, 80 to 21 [10-19 15:23:32:763 TUYA D][rcd_file.c:1965] rebuild [eba528413f6980a463pn4p] 33712 1248 [10-19 15:23:32:763 TUYA D][rcd_file.c:1970] move value key:eba528413f6980a463pn4p, 111104 to 33712 [10-19 15:23:32:763 TUYA D][rcd_file.c:1985] move rcd key:eba528413f6980a463pn4p, 85 to 22 [10-19 15:23:32:763 TUYA D][rcd_file.c:1965] rebuild [vdevo166201192349972] 34960 1216 [10-19 15:23:32:763 TUYA D][rcd_file.c:1970] move value key:vdevo166201192349972, 112352 to 34960 [10-19 15:23:32:763 TUYA D][rcd_file.c:1985] move rcd key:vdevo166201192349972, 86 to 23 [10-19 15:23:32:764 TUYA D][rcd_file.c:1965] rebuild [ebe3006b0f14083917oh1d] 36176 1232 [10-19 15:23:32:764 TUYA D][rcd_file.c:1970] move value key:ebe3006b0f14083917oh1d, 114800 to 36176 [10-19 15:23:32:764 TUYA D][rcd_file.c:1985] move rcd key:ebe3006b0f14083917oh1d, 88 to 24 [10-19 15:23:32:764 TUYA D][rcd_file.c:1965] rebuild [eb3cfb587e6d81417eac8e] 37408 1232 [10-19 15:23:32:764 TUYA D][rcd_file.c:1970] move value key:eb3cfb587e6d81417eac8e, 116032 to 37408 [10-19 15:23:32:764 TUYA D][rcd_file.c:1985] move rcd key:eb3cfb587e6d81417eac8e, 89 to 25 [10-19 15:23:32:764 TUYA D][rcd_file.c:1965] rebuild [ebb063750d514d878079mw] 38640 1248 [10-19 15:23:32:764 TUYA D][rcd_file.c:1970] move value key:ebb063750d514d878079mw, 117264 to 38640 [10-19 15:23:32:764 TUYA D][rcd_file.c:1985] move rcd key:ebb063750d514d878079mw, 90 to 26 [10-19 15:23:32:764 TUYA D][rcd_file.c:1965] rebuild [vdevo166004655924109] 39888 1216 [10-19 15:23:32:764 TUYA D][rcd_file.c:1970] move value key:vdevo166004655924109, 118512 to 39888 [10-19 15:23:32:764 TUYA D][rcd_file.c:1985] move rcd key:vdevo166004655924109, 91 to 27 [10-19 15:23:32:764 TUYA D][rcd_file.c:1965] rebuild [ebaf2b250cb41e058ekxqm] 41104 1232 [10-19 15:23:32:764 TUYA D][rcd_file.c:1970] move value key:ebaf2b250cb41e058ekxqm, 122192 to 41104 [10-19 15:23:32:764 TUYA D][rcd_file.c:1985] move rcd key:ebaf2b250cb41e058ekxqm, 94 to 28 [10-19 15:23:32:764 TUYA D][rcd_file.c:1965] rebuild [eb2372042e64f76e79f3jk] 42336 1232 [10-19 15:23:32:764 TUYA D][rcd_file.c:1970] move value key:eb2372042e64f76e79f3jk, 124656 to 42336 [10-19 15:23:32:764 TUYA D][rcd_file.c:1985] move rcd key:eb2372042e64f76e79f3jk, 96 to 29 [10-19 15:23:32:764 TUYA D][rcd_file.c:1965] rebuild [eb631bd9b6590e001blfgs] 43568 1232 [10-19 15:23:32:764 TUYA D][rcd_file.c:1970] move value key:eb631bd9b6590e001blfgs, 127088 to 43568 [10-19 15:23:32:764 TUYA D][rcd_file.c:1985] move rcd key:eb631bd9b6590e001blfgs, 98 to 30 [10-19 15:23:32:765 TUYA D][rcd_file.c:1965] rebuild [vdevo166098193021398] 44800 1232 [10-19 15:23:32:765 TUYA D][rcd_file.c:1970] move value key:vdevo166098193021398, 128320 to 44800 [10-19 15:23:32:765 TUYA D][rcd_file.c:1985] move rcd key:vdevo166098193021398, 99 to 31 [10-19 15:23:32:765 TUYA D][rcd_file.c:1965] rebuild [ebae3eac4f123fe22bbx5k] 46032 1232 [10-19 15:23:32:765 TUYA D][rcd_file.c:1970] move value key:ebae3eac4f123fe22bbx5k, 129552 to 46032 [10-19 15:23:32:765 TUYA D][rcd_file.c:1985] move rcd key:ebae3eac4f123fe22bbx5k, 100 to 32 [10-19 15:23:32:765 TUYA D][rcd_file.c:1965] rebuild [ebb4f72bc0eb72ac62dhlo] 47264 1232 [10-19 15:23:32:765 TUYA D][rcd_file.c:1970] move value key:ebb4f72bc0eb72ac62dhlo, 130784 to 47264 [10-19 15:23:32:765 TUYA D][rcd_file.c:1985] move rcd key:ebb4f72bc0eb72ac62dhlo, 101 to 33 [10-19 15:23:32:765 TUYA D][rcd_file.c:1965] rebuild [eb92c47fe161c74b89dk25] 48496 1200 [10-19 15:23:32:765 TUYA D][rcd_file.c:1970] move value key:eb92c47fe161c74b89dk25, 132016 to 48496 [10-19 15:23:32:765 TUYA D][rcd_file.c:1985] move rcd key:eb92c47fe161c74b89dk25, 102 to 34 [10-19 15:23:32:765 TUYA D][rcd_file.c:1965] rebuild [eb62f037dd6640bfa41gut] 49696 1232 [10-19 15:23:32:765 TUYA D][rcd_file.c:1970] move value key:eb62f037dd6640bfa41gut, 133216 to 49696 [10-19 15:23:32:765 TUYA D][rcd_file.c:1985] move rcd key:eb62f037dd6640bfa41gut, 103 to 35 [10-19 15:23:32:765 TUYA D][rcd_file.c:1965] rebuild [eb21cdbd5e05e8e428gaca] 50928 1232 [10-19 15:23:32:765 TUYA D][rcd_file.c:1970] move value key:eb21cdbd5e05e8e428gaca, 134448 to 50928 [10-19 15:23:32:765 TUYA D][rcd_file.c:1985] move rcd key:eb21cdbd5e05e8e428gaca, 104 to 36 [10-19 15:23:32:765 TUYA D][rcd_file.c:1965] rebuild [eba19ee51b778585c0jcy3] 52160 1248 [10-19 15:23:32:765 TUYA D][rcd_file.c:1970] move value key:eba19ee51b778585c0jcy3, 135680 to 52160 [10-19 15:23:32:766 TUYA D][rcd_file.c:1985] move rcd key:eba19ee51b778585c0jcy3, 105 to 37 [10-19 15:23:32:766 TUYA D][rcd_file.c:1965] rebuild [eb0058bee16ce0c70aq9nj] 53408 1216 [10-19 15:23:32:766 TUYA D][rcd_file.c:1970] move value key:eb0058bee16ce0c70aq9nj, 136928 to 53408 [10-19 15:23:32:766 TUYA D][rcd_file.c:1985] move rcd key:eb0058bee16ce0c70aq9nj, 106 to 38 [10-19 15:23:32:766 TUYA D][rcd_file.c:1965] rebuild [eba407ffd4d23748c3rlsw] 54624 1232 [10-19 15:23:32:766 TUYA D][rcd_file.c:1970] move value key:eba407ffd4d23748c3rlsw, 138144 to 54624 [10-19 15:23:32:766 TUYA D][rcd_file.c:1985] move rcd key:eba407ffd4d23748c3rlsw, 107 to 39 [10-19 15:23:32:766 TUYA D][rcd_file.c:1965] rebuild [ebd0ad496c403f1af3i9an] 55856 1232 [10-19 15:23:32:766 TUYA D][rcd_file.c:1970] move value key:ebd0ad496c403f1af3i9an, 139376 to 55856 [10-19 15:23:32:766 TUYA D][rcd_file.c:1985] move rcd key:ebd0ad496c403f1af3i9an, 108 to 40 [10-19 15:23:32:766 TUYA D][rcd_file.c:1965] rebuild [eb257c7e0da82bf6fdgo2g] 57088 1232 [10-19 15:23:32:766 TUYA D][rcd_file.c:1970] move value key:eb257c7e0da82bf6fdgo2g, 140608 to 57088 [10-19 15:23:32:766 TUYA D][rcd_file.c:1985] move rcd key:eb257c7e0da82bf6fdgo2g, 109 to 41 [10-19 15:23:32:766 TUYA D][rcd_file.c:1965] rebuild [eb0f65ca9465be8edcoyot] 58320 1232 [10-19 15:23:32:766 TUYA D][rcd_file.c:1970] move value key:eb0f65ca9465be8edcoyot, 141840 to 58320 [10-19 15:23:32:766 TUYA D][rcd_file.c:1985] move rcd key:eb0f65ca9465be8edcoyot, 110 to 42 [10-19 15:23:32:766 TUYA D][rcd_file.c:1965] rebuild [ebf673a55509854f89o4ms] 59552 1232 [10-19 15:23:32:766 TUYA D][rcd_file.c:1970] move value key:ebf673a55509854f89o4ms, 143072 to 59552 [10-19 15:23:32:766 TUYA D][rcd_file.c:1985] move rcd key:ebf673a55509854f89o4ms, 111 to 43 [10-19 15:23:32:766 TUYA D][rcd_file.c:1965] rebuild [ebe5c0ea9264da5aedqyqx] 60784 1232 [10-19 15:23:32:767 TUYA D][rcd_file.c:1970] move value key:ebe5c0ea9264da5aedqyqx, 144304 to 60784 [10-19 15:23:32:767 TUYA D][rcd_file.c:1985] move rcd key:ebe5c0ea9264da5aedqyqx, 112 to 44 [10-19 15:23:32:767 TUYA D][rcd_file.c:1965] rebuild [ebabc77077c75fec391svt] 62016 1232 [10-19 15:23:32:767 TUYA D][rcd_file.c:1970] move value key:ebabc77077c75fec391svt, 145536 to 62016 [10-19 15:23:32:767 TUYA D][rcd_file.c:1985] move rcd key:ebabc77077c75fec391svt, 113 to 45 [10-19 15:23:32:767 TUYA D][rcd_file.c:1965] rebuild [ebe2744515d20294b1yhgw] 63248 1232 [10-19 15:23:32:767 TUYA D][rcd_file.c:1970] move value key:ebe2744515d20294b1yhgw, 146768 to 63248 [10-19 15:23:32:767 TUYA D][rcd_file.c:1985] move rcd key:ebe2744515d20294b1yhgw, 114 to 46 [10-19 15:23:32:767 TUYA D][rcd_file.c:1965] rebuild [eb99a9cc76209358a4crkr] 64480 1216 [10-19 15:23:32:767 TUYA D][rcd_file.c:1970] move value key:eb99a9cc76209358a4crkr, 148000 to 64480 [10-19 15:23:32:767 TUYA D][rcd_file.c:1985] move rcd key:eb99a9cc76209358a4crkr, 115 to 47 [10-19 15:23:32:767 TUYA D][rcd_file.c:1965] rebuild [eb67a0efcb59444d01ydgn] 65696 1232 [10-19 15:23:32:767 TUYA D][rcd_file.c:1970] move value key:eb67a0efcb59444d01ydgn, 149216 to 65696 [10-19 15:23:32:767 TUYA D][rcd_file.c:1985] move rcd key:eb67a0efcb59444d01ydgn, 116 to 48 [10-19 15:23:32:767 TUYA D][rcd_file.c:1965] rebuild [ebe7f7541d3a5e34dcplwr] 66928 1216 [10-19 15:23:32:767 TUYA D][rcd_file.c:1970] move value key:ebe7f7541d3a5e34dcplwr, 150448 to 66928 [10-19 15:23:32:767 TUYA D][rcd_file.c:1985] move rcd key:ebe7f7541d3a5e34dcplwr, 117 to 49 [10-19 15:23:32:767 TUYA D][rcd_file.c:1965] rebuild [eb62263aaf2f73ef03xira] 68144 1232 [10-19 15:23:32:767 TUYA D][rcd_file.c:1970] move value key:eb62263aaf2f73ef03xira, 151664 to 68144 [10-19 15:23:32:768 TUYA D][rcd_file.c:1985] move rcd key:eb62263aaf2f73ef03xira, 118 to 50 [10-19 15:23:32:768 TUYA D][rcd_file.c:1965] rebuild [ebb800d543876b9d83jiah] 69376 1232 [10-19 15:23:32:768 TUYA D][rcd_file.c:1970] move value key:ebb800d543876b9d83jiah, 152896 to 69376 [10-19 15:23:32:768 TUYA D][rcd_file.c:1985] move rcd key:ebb800d543876b9d83jiah, 119 to 51 [10-19 15:23:32:768 TUYA D][rcd_file.c:1965] rebuild [ebc78c65e28bc1347ac761] 70608 1232 [10-19 15:23:32:768 TUYA D][rcd_file.c:1970] move value key:ebc78c65e28bc1347ac761, 154128 to 70608 [10-19 15:23:32:768 TUYA D][rcd_file.c:1985] move rcd key:ebc78c65e28bc1347ac761, 120 to 52 [10-19 15:23:32:768 TUYA D][rcd_file.c:1965] rebuild [eb3b1fefe57125bb72nrzb] 71840 1232 [10-19 15:23:32:768 TUYA D][rcd_file.c:1970] move value key:eb3b1fefe57125bb72nrzb, 155360 to 71840 [10-19 15:23:32:768 TUYA D][rcd_file.c:1985] move rcd key:eb3b1fefe57125bb72nrzb, 121 to 53 [10-19 15:23:32:768 TUYA D][rcd_file.c:1965] rebuild [eb9e43a7db146d1286luio] 73072 1200 [10-19 15:23:32:768 TUYA D][rcd_file.c:1970] move value key:eb9e43a7db146d1286luio, 156592 to 73072 [10-19 15:23:32:768 TUYA D][rcd_file.c:1985] move rcd key:eb9e43a7db146d1286luio, 122 to 54 [10-19 15:23:32:768 TUYA D][rcd_file.c:1965] rebuild [eb87649dc6a4ae7fef87xr] 74272 1232 [10-19 15:23:32:768 TUYA D][rcd_file.c:1970] move value key:eb87649dc6a4ae7fef87xr, 157792 to 74272 [10-19 15:23:32:768 TUYA D][rcd_file.c:1985] move rcd key:eb87649dc6a4ae7fef87xr, 123 to 55 [10-19 15:23:32:768 TUYA D][rcd_file.c:1965] rebuild [eb76889250a9917161wng9] 75504 1248 [10-19 15:23:32:768 TUYA D][rcd_file.c:1970] move value key:eb76889250a9917161wng9, 159024 to 75504 [10-19 15:23:32:768 TUYA D][rcd_file.c:1985] move rcd key:eb76889250a9917161wng9, 124 to 56 [10-19 15:23:32:768 TUYA D][rcd_file.c:1965] rebuild [ebff3d1dac6c9c54ebu58o] 76752 1200 [10-19 15:23:32:768 TUYA D][rcd_file.c:1970] move value key:ebff3d1dac6c9c54ebu58o, 160272 to 76752 [10-19 15:23:32:769 TUYA D][rcd_file.c:1985] move rcd key:ebff3d1dac6c9c54ebu58o, 125 to 57 [10-19 15:23:32:769 TUYA D][rcd_file.c:1965] rebuild [eb3edad403134c4f6czxy4] 77952 1216 [10-19 15:23:32:769 TUYA D][rcd_file.c:1970] move value key:eb3edad403134c4f6czxy4, 161472 to 77952 [10-19 15:23:32:769 TUYA D][rcd_file.c:1985] move rcd key:eb3edad403134c4f6czxy4, 126 to 58 [10-19 15:23:32:769 TUYA D][rcd_file.c:1965] rebuild [ebd959f9cc5a9857b2zsoo] 79168 1200 [10-19 15:23:32:769 TUYA D][rcd_file.c:1970] move value key:ebd959f9cc5a9857b2zsoo, 162688 to 79168 [10-19 15:23:32:769 TUYA D][rcd_file.c:1985] move rcd key:ebd959f9cc5a9857b2zsoo, 127 to 59 [10-19 15:23:32:769 TUYA D][rcd_file.c:1994] trancate fileLen:80368 cnt:60 [10-19 15:23:32:770 TUYA D][rcd_file.c:3043] ################Dump metadata start################ [10-19 15:23:32:770 TUYA D][rcd_file.c:3044] file path:/userdata/tuya_db_files/rcdDb/ctrl_dev.rdb [10-19 15:23:32:770 TUYA D][rcd_file.c:3045] bak file path:/userdata/tuya_db_files/rcdDb/ctrl_dev.rdb_bak [10-19 15:23:32:770 TUYA D][rcd_file.c:3046] rcd_valid_cnt:60 [10-19 15:23:32:770 TUYA D][rcd_file.c:3047] cur_valid_rcd_num:1 [10-19 15:23:32:770 TUYA D][rcd_file.c:3048] cur_valid_rcd_pos:0 [10-19 15:23:32:770 TUYA D][rcd_file.c:3049] cur_total_size:73648 [10-19 15:23:32:770 TUYA D][rcd_file.c:3050] cur_total_size_valid:73648 [10-19 15:23:32:770 TUYA D][rcd_file.c:3054] crc32:-332674175 [10-19 15:23:32:770 TUYA D][rcd_file.c:3055] version:1 [10-19 15:23:32:770 TUYA D][rcd_file.c:3056] wr_count:752 [10-19 15:23:32:770 TUYA D][rcd_file.c:3057] magic:1437226410 [10-19 15:23:32:770 TUYA D][rcd_file.c:3058] metadata_size:0x1A40 [10-19 15:23:32:770 TUYA D][rcd_file.c:3059] rawdata_max:1048576 [10-19 15:23:32:770 TUYA D][rcd_file.c:3060] rcd_max:128 [10-19 15:23:32:770 TUYA D][rcd_file.c:3061] rcd_cnt:60 [10-19 15:23:32:770 TUYA D][rcd_file.c:3063] ################Dump metadata end################ [10-19 15:23:32:771 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb92c47fe161c74b89dk25,p_rcd_info:0x7f9401dab8 [10-19 15:23:32:771 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:60,p_rcd_info->crc32:2772803983,len:1200 key:eb92c47fe161c74b89dk25. [10-19 15:23:32:771 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:772 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:772 TUYA E][tuya_ctrl_center.c:1124] dev: ebf8fee6f4298432a5eqvk not find dp: 0 [10-19 15:23:32:772 TUYA E][tuya_ctrl_center.c:1124] dev: ebf8fee6f4298432a5eqvk not find dp: 0 [10-19 15:23:32:772 TUYA E][tuya_ctrl_center.c:1124] dev: ebf8fee6f4298432a5eqvk not find dp: 0 [10-19 15:23:32:772 TUYA D][tuya_ctrl_center.c:1337] update devId: ebf8fee6f4298432a5eqvk name: 智能网关 pid: 1vso02tkynsvpinp comm: ebf8fee6f4298432a5eqvk pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:772 TUYA W][tuya_ctrl_storage.c:143] dev:ebf8fee6f4298432a5eqvk, dp name is null [10-19 15:23:32:772 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebf8fee6f4298432a5eqvk,p_rcd_info:0x7f9401d3d0 [10-19 15:23:32:773 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:61,p_rcd_info->crc32:538497749,len:1232 key:ebf8fee6f4298432a5eqvk. [10-19 15:23:32:773 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:773 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:773 TUYA D][tuya_ctrl_center.c:1337] update devId: eb8607e2c51bffc942fczo name: 红外射频遥控器 3 pid: lmjfyvtsig6v5npw comm: eb8607e2c51bffc942fczo pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:773 TUYA W][tuya_ctrl_storage.c:143] dev:eb8607e2c51bffc942fczo, dp name is null [10-19 15:23:32:774 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb8607e2c51bffc942fczo,p_rcd_info:0x7f9401d404 [10-19 15:23:32:774 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:62,p_rcd_info->crc32:4262366154,len:1232 key:eb8607e2c51bffc942fczo. [10-19 15:23:32:774 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:774 TUYA D][tuya_ctrl_center.c:1337] update devId: ebf911148e218a63b67uf3 name: Air pid: 000000dfug comm: ebd88c655bdd4b39adihqe pv: 2.2 sub: 1 node: f919e9057b0bfb2b dev_num: 60 [10-19 15:23:32:775 TUYA W][tuya_ctrl_storage.c:143] dev:ebf911148e218a63b67uf3, dp name is null [10-19 15:23:32:775 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebf911148e218a63b67uf3,p_rcd_info:0x7f9401d438 [10-19 15:23:32:775 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:63,p_rcd_info->crc32:2783521018,len:1200 key:ebf911148e218a63b67uf3. [10-19 15:23:32:776 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:776 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:776 TUYA D][tuya_ctrl_center.c:1337] update devId: ebd88c655bdd4b39adihqe name: 智能红外遥控器 pid: oniuxtrf5xu85d69 comm: ebd88c655bdd4b39adihqe pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:776 TUYA W][tuya_ctrl_storage.c:143] dev:ebd88c655bdd4b39adihqe, dp name is null [10-19 15:23:32:776 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebd88c655bdd4b39adihqe,p_rcd_info:0x7f9401d46c [10-19 15:23:32:777 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:64,p_rcd_info->crc32:454147156,len:1232 key:ebd88c655bdd4b39adihqe. [10-19 15:23:32:777 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:777 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:777 TUYA D][tuya_ctrl_center.c:1337] update devId: eb46ca57fbaaa5a173n9zv name: 红外射频遥控器 2 pid: lmjfyvtsig6v5npw comm: eb46ca57fbaaa5a173n9zv pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:777 TUYA W][tuya_ctrl_storage.c:143] dev:eb46ca57fbaaa5a173n9zv, dp name is null [10-19 15:23:32:778 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb46ca57fbaaa5a173n9zv,p_rcd_info:0x7f9401d4a0 [10-19 15:23:32:778 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:65,p_rcd_info->crc32:4122684231,len:1232 key:eb46ca57fbaaa5a173n9zv. [10-19 15:23:32:778 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:779 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:779 TUYA D][tuya_ctrl_center.c:1337] update devId: eb92b0479e015fbbaavltv name: 智能红外遥控器 pid: hfq0xqhjsqmfqkw4 comm: eb92b0479e015fbbaavltv pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:779 TUYA W][tuya_ctrl_storage.c:143] dev:eb92b0479e015fbbaavltv, dp name is null [10-19 15:23:32:779 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb92b0479e015fbbaavltv,p_rcd_info:0x7f9401d4d4 [10-19 15:23:32:780 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:66,p_rcd_info->crc32:3460245617,len:1232 key:eb92b0479e015fbbaavltv. [10-19 15:23:32:780 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:780 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:780 TUYA D][tuya_ctrl_center.c:1202] dp: 44 name: Switch inching [10-19 15:23:32:780 TUYA E][tuya_ctrl_center.c:1205] id: 44 not find [10-19 15:23:32:780 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: Switch 1 [10-19 15:23:32:780 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: Switch 2 [10-19 15:23:32:780 TUYA D][tuya_ctrl_center.c:1337] update devId: ebaf2b250cb41e058ekxqm name: Smart Dual Socket 2 pid: 97cp1wty56mww1o0 comm: ebaf2b250cb41e058ekxqm pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:780 TUYA D][tuya_ctrl_storage.c:169] dev_id : ebaf2b250cb41e058ekxqm, serialize dp_names = {"1":"Switch 1","2":"Switch 2"} [10-19 15:23:32:781 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebaf2b250cb41e058ekxqm,p_rcd_info:0x7f9401d980 [10-19 15:23:32:781 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:67,p_rcd_info->crc32:4155397716,len:1232 key:ebaf2b250cb41e058ekxqm. [10-19 15:23:32:782 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:782 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:782 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: Switch 1 [10-19 15:23:32:782 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: Switch 2 [10-19 15:23:32:782 TUYA D][tuya_ctrl_center.c:1337] update devId: eb09bad8e75f6222acaglz name: Intelligent Switcher 2CH pid: l9rksbbbisynlnvq comm: eb09bad8e75f6222acaglz pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:782 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb09bad8e75f6222acaglz, serialize dp_names = {"1":"Switch 1","2":"Switch 2"} [10-19 15:23:32:782 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb09bad8e75f6222acaglz,p_rcd_info:0x7f9401d508 [10-19 15:23:32:783 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:68,p_rcd_info->crc32:415818497,len:1232 key:eb09bad8e75f6222acaglz. [10-19 15:23:32:783 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:783 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:783 TUYA D][tuya_ctrl_center.c:1337] update devId: eb9c17916f715a30e0a7mz name: Intelligent Switcher 2 pid: 98afxsvjfbobhjw4 comm: eb9c17916f715a30e0a7mz pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:783 TUYA W][tuya_ctrl_storage.c:143] dev:eb9c17916f715a30e0a7mz, dp name is null [10-19 15:23:32:783 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb9c17916f715a30e0a7mz,p_rcd_info:0x7f9401d744 [10-19 15:23:32:784 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:69,p_rcd_info->crc32:127778021,len:1232 key:eb9c17916f715a30e0a7mz. [10-19 15:23:32:784 TUYA W][tuya_ctrl_center.c:1255] dev: vdevo166201192349972 is virtual [10-19 15:23:32:784 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:784 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:784 TUYA D][tuya_ctrl_center.c:1337] update devId: vdevo166201192349972 name: 幻彩2期-oem-vdevo pid: fboep9j6grtxyga9 comm: vdevo166201192349972 pv: 2.0 sub: 0 node: dev_num: 60 [10-19 15:23:32:785 TUYA W][tuya_ctrl_storage.c:143] dev:vdevo166201192349972, dp name is null [10-19 15:23:32:785 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:vdevo166201192349972,p_rcd_info:0x7f9401d87c [10-19 15:23:32:785 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:70,p_rcd_info->crc32:3390062447,len:1216 key:vdevo166201192349972. [10-19 15:23:32:786 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:786 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:786 TUYA D][tuya_ctrl_center.c:1202] dp: 44 name: 点动开关 [10-19 15:23:32:786 TUYA E][tuya_ctrl_center.c:1205] id: 44 not find [10-19 15:23:32:786 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: 开关1 [10-19 15:23:32:786 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: 开关2 [10-19 15:23:32:786 TUYA D][tuya_ctrl_center.c:1337] update devId: eb62f037dd6640bfa41gut name: Smart Dual Socket pid: 97cp1wty56mww1o0 comm: eb62f037dd6640bfa41gut pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:786 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb62f037dd6640bfa41gut, serialize dp_names = {"1":"开关1","2":"开关2"} [10-19 15:23:32:786 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb62f037dd6640bfa41gut,p_rcd_info:0x7f9401daec [10-19 15:23:32:787 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:71,p_rcd_info->crc32:2395713849,len:1232 key:eb62f037dd6640bfa41gut. [10-19 15:23:32:787 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:787 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:787 TUYA D][tuya_ctrl_center.c:1337] update devId: eb4576f5222b16dccaaazi name: WIFI lamp tape 2 pid: 9yyaalraupjaredl comm: eb4576f5222b16dccaaazi pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:788 TUYA W][tuya_ctrl_storage.c:143] dev:eb4576f5222b16dccaaazi, dp name is null [10-19 15:23:32:788 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb4576f5222b16dccaaazi,p_rcd_info:0x7f9401d7ac [10-19 15:23:32:788 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:72,p_rcd_info->crc32:1571539006,len:1232 key:eb4576f5222b16dccaaazi. [10-19 15:23:32:789 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:789 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:789 TUYA D][tuya_ctrl_center.c:1337] update devId: ebb063750d514d878079mw name: 计量微断开关(1P+N) pid: manu90xvog2uqakl comm: ebb063750d514d878079mw pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:789 TUYA W][tuya_ctrl_storage.c:143] dev:ebb063750d514d878079mw, dp name is null [10-19 15:23:32:790 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebb063750d514d878079mw,p_rcd_info:0x7f9401d918 [10-19 15:23:32:790 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:73,p_rcd_info->crc32:3921719118,len:1248 key:ebb063750d514d878079mw. [10-19 15:23:32:790 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:790 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:791 TUYA D][tuya_ctrl_center.c:1337] update devId: eba407ffd4d23748c3rlsw name: Intelligent Switcher pid: 98afxsvjfbobhjw4 comm: eba407ffd4d23748c3rlsw pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:791 TUYA W][tuya_ctrl_storage.c:143] dev:eba407ffd4d23748c3rlsw, dp name is null [10-19 15:23:32:791 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eba407ffd4d23748c3rlsw,p_rcd_info:0x7f9401dbbc [10-19 15:23:32:791 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:74,p_rcd_info->crc32:1135417004,len:1232 key:eba407ffd4d23748c3rlsw. [10-19 15:23:32:792 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:792 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:792 TUYA D][tuya_ctrl_center.c:1337] update devId: eb0058bee16ce0c70aq9nj name: Temp pid: gw173aldekvpzalg comm: eb0058bee16ce0c70aq9nj pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:792 TUYA W][tuya_ctrl_storage.c:143] dev:eb0058bee16ce0c70aq9nj, dp name is null [10-19 15:23:32:792 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb0058bee16ce0c70aq9nj,p_rcd_info:0x7f9401db88 [10-19 15:23:32:793 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:75,p_rcd_info->crc32:3453095001,len:1216 key:eb0058bee16ce0c70aq9nj. [10-19 15:23:32:793 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:793 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:793 TUYA D][tuya_ctrl_center.c:1337] update devId: eb68d8dbe4707224e8sxd8 name: Wifi Plug pid: j0zozzoarutv0nu1 comm: eb68d8dbe4707224e8sxd8 pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:793 TUYA W][tuya_ctrl_storage.c:143] dev:eb68d8dbe4707224e8sxd8, dp name is null [10-19 15:23:32:794 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb68d8dbe4707224e8sxd8,p_rcd_info:0x7f9401d7e0 [10-19 15:23:32:794 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:76,p_rcd_info->crc32:3217080471,len:1216 key:eb68d8dbe4707224e8sxd8. [10-19 15:23:32:795 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:795 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:795 TUYA D][tuya_ctrl_center.c:1337] update devId: ebe3006b0f14083917oh1d name: 空调温控器 2 pid: oqe2ba267qac12ng comm: ebe3006b0f14083917oh1d pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:795 TUYA W][tuya_ctrl_storage.c:143] dev:ebe3006b0f14083917oh1d, dp name is null [10-19 15:23:32:795 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebe3006b0f14083917oh1d,p_rcd_info:0x7f9401d8b0 [10-19 15:23:32:796 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:77,p_rcd_info->crc32:2736764629,len:1232 key:ebe3006b0f14083917oh1d. [10-19 15:23:32:796 TUYA W][tuya_ctrl_center.c:1255] dev: vdevo166098193021398 is virtual [10-19 15:23:32:796 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:796 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:796 TUYA D][tuya_ctrl_center.c:1337] update devId: vdevo166098193021398 name: Smart Switch Module-vdevo pid: seuwp5kki3tvz3wl comm: vdevo166098193021398 pv: 2.0 sub: 0 node: dev_num: 60 [10-19 15:23:32:796 TUYA W][tuya_ctrl_storage.c:143] dev:vdevo166098193021398, dp name is null [10-19 15:23:32:797 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:vdevo166098193021398,p_rcd_info:0x7f9401da1c [10-19 15:23:32:797 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:78,p_rcd_info->crc32:2127628467,len:1232 key:vdevo166098193021398. [10-19 15:23:32:798 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:798 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:798 TUYA D][tuya_ctrl_center.c:1337] update devId: eb3cfb587e6d81417eac8e name: Smart Switch pid: jogzi8noyhgcahcq comm: eb3cfb587e6d81417eac8e pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:798 TUYA W][tuya_ctrl_storage.c:143] dev:eb3cfb587e6d81417eac8e, dp name is null [10-19 15:23:32:798 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb3cfb587e6d81417eac8e,p_rcd_info:0x7f9401d8e4 [10-19 15:23:32:799 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:79,p_rcd_info->crc32:3342434179,len:1232 key:eb3cfb587e6d81417eac8e. [10-19 15:23:32:799 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:799 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:799 TUYA D][tuya_ctrl_center.c:1337] update devId: ebb4f72bc0eb72ac62dhlo name: WIFI lamp tape pid: 9yyaalraupjaredl comm: ebb4f72bc0eb72ac62dhlo pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:799 TUYA W][tuya_ctrl_storage.c:143] dev:ebb4f72bc0eb72ac62dhlo, dp name is null [10-19 15:23:32:800 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebb4f72bc0eb72ac62dhlo,p_rcd_info:0x7f9401da84 [10-19 15:23:32:800 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:80,p_rcd_info->crc32:2843588107,len:1232 key:ebb4f72bc0eb72ac62dhlo. [10-19 15:23:32:801 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:801 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:801 TUYA D][tuya_ctrl_center.c:1337] update devId: ebc90e9813ffde4148tcvg name: WI-FI Temperature & Humidity Sensor pid: qwpfjxryaj7pr9rw comm: ebc90e9813ffde4148tcvg pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:801 TUYA W][tuya_ctrl_storage.c:143] dev:ebc90e9813ffde4148tcvg, dp name is null [10-19 15:23:32:801 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebc90e9813ffde4148tcvg,p_rcd_info:0x7f9401d778 [10-19 15:23:32:802 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:81,p_rcd_info->crc32:4107917005,len:1248 key:ebc90e9813ffde4148tcvg. [10-19 15:23:32:802 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:802 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:802 TUYA D][tuya_ctrl_center.c:1337] update devId: eb631bd9b6590e001blfgs name: mini通断器 pid: jqo111f6ahvas3tr comm: eb631bd9b6590e001blfgs pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:802 TUYA W][tuya_ctrl_storage.c:143] dev:eb631bd9b6590e001blfgs, dp name is null [10-19 15:23:32:803 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb631bd9b6590e001blfgs,p_rcd_info:0x7f9401d9e8 [10-19 15:23:32:803 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:82,p_rcd_info->crc32:3649317846,len:1232 key:eb631bd9b6590e001blfgs. [10-19 15:23:32:804 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:804 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:804 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:32:804 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:32:804 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:32:804 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:32:804 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:32:804 TUYA E][tuya_ctrl_center.c:1124] dev: eba528413f6980a463pn4p not find dp: 0 [10-19 15:23:32:804 TUYA D][tuya_ctrl_center.c:1337] update devId: eba528413f6980a463pn4p name: Smart Bulb(BP5758D 35/10) pid: 9nauypjb2kvujrut comm: eba528413f6980a463pn4p pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:804 TUYA W][tuya_ctrl_storage.c:143] dev:eba528413f6980a463pn4p, dp name is null [10-19 15:23:32:805 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eba528413f6980a463pn4p,p_rcd_info:0x7f9401d848 [10-19 15:23:32:805 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:83,p_rcd_info->crc32:2575894488,len:1248 key:eba528413f6980a463pn4p. [10-19 15:23:32:805 TUYA W][tuya_ctrl_center.c:1255] dev: vdevo166004655924109 is virtual [10-19 15:23:32:806 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:806 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:806 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: 开关 1 [10-19 15:23:32:806 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: 开关 2 [10-19 15:23:32:806 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: 开关 3 [10-19 15:23:32:806 TUYA D][tuya_ctrl_center.c:1202] dp: 4 name: 开关 4 [10-19 15:23:32:806 TUYA D][tuya_ctrl_center.c:1202] dp: 5 name: 开关 5 [10-19 15:23:32:806 TUYA D][tuya_ctrl_center.c:1202] dp: 16 name: 背光开关 [10-19 15:23:32:806 TUYA D][tuya_ctrl_center.c:1202] dp: 6 name: 开关 6 [10-19 15:23:32:806 TUYA D][tuya_ctrl_center.c:1202] dp: 19 name: 点动开关(延时关) [10-19 15:23:32:806 TUYA E][tuya_ctrl_center.c:1205] id: 19 not find [10-19 15:23:32:806 TUYA D][tuya_ctrl_center.c:1337] update devId: vdevo166004655924109 name: Six Gang Switch-vdevo pid: mq2mrjjqlkorvgfe comm: vdevo166004655924109 pv: 2.0 sub: 0 node: dev_num: 60 [10-19 15:23:32:806 TUYA D][tuya_ctrl_storage.c:169] dev_id : vdevo166004655924109, serialize dp_names = {"1":"开关 1","2":"开关 2","3":"开关 3","4":"开关 4","5":"开关 5","6":"开关 6","16":"背光开关"} [10-19 15:23:32:806 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:vdevo166004655924109,p_rcd_info:0x7f9401d94c [10-19 15:23:32:807 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:84,p_rcd_info->crc32:2337589784,len:1216 key:vdevo166004655924109. [10-19 15:23:32:807 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:807 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:808 TUYA D][tuya_ctrl_center.c:1337] update devId: eb21cdbd5e05e8e428gaca name: 空调温控器 pid: oqe2ba267qac12ng comm: eb21cdbd5e05e8e428gaca pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:808 TUYA W][tuya_ctrl_storage.c:143] dev:eb21cdbd5e05e8e428gaca, dp name is null [10-19 15:23:32:808 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb21cdbd5e05e8e428gaca,p_rcd_info:0x7f9401db20 [10-19 15:23:32:808 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:85,p_rcd_info->crc32:964738206,len:1232 key:eb21cdbd5e05e8e428gaca. [10-19 15:23:32:809 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:809 TUYA E][tuya_ctrl_center.c:1124] dev: eb71d993c258066917jpks not find dp: 0 [10-19 15:23:32:809 TUYA D][tuya_ctrl_center.c:1337] update devId: eb71d993c258066917jpks name: IPC pid: dgudhgjmxdznjm6d comm: eb71d993c258066917jpks pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:809 TUYA W][tuya_ctrl_storage.c:143] dev:eb71d993c258066917jpks, dp name is null [10-19 15:23:32:810 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb71d993c258066917jpks,p_rcd_info:0x7f9401d53c [10-19 15:23:32:810 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:86,p_rcd_info->crc32:591265408,len:1216 key:eb71d993c258066917jpks. [10-19 15:23:32:811 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:811 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:811 TUYA D][tuya_ctrl_center.c:1337] update devId: ebba64b6ac327cdeddq8z2 name: Curtain Switch pid: 8nd1vkcuwbektfod comm: ebba64b6ac327cdeddq8z2 pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:811 TUYA W][tuya_ctrl_storage.c:143] dev:ebba64b6ac327cdeddq8z2, dp name is null [10-19 15:23:32:811 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebba64b6ac327cdeddq8z2,p_rcd_info:0x7f9401d570 [10-19 15:23:32:812 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:87,p_rcd_info->crc32:3532552519,len:1232 key:ebba64b6ac327cdeddq8z2. [10-19 15:23:32:812 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:812 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:812 TUYA D][tuya_ctrl_center.c:1202] dp: 44 name: 点动开关 [10-19 15:23:32:812 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: 开关1 [10-19 15:23:32:812 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: 开关2 [10-19 15:23:32:812 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: 开关3 [10-19 15:23:32:812 TUYA D][tuya_ctrl_center.c:1337] update devId: eb2372042e64f76e79f3jk name: Smart 3-Gang Switch pid: ha7agddwqq6ahbiz comm: eb2372042e64f76e79f3jk pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:812 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb2372042e64f76e79f3jk, serialize dp_names = {"1":"开关1","2":"开关2","3":"开关3","44":"点动开关"} [10-19 15:23:32:813 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb2372042e64f76e79f3jk,p_rcd_info:0x7f9401d9b4 [10-19 15:23:32:813 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:88,p_rcd_info->crc32:2539775411,len:1232 key:eb2372042e64f76e79f3jk. [10-19 15:23:32:814 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:814 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:814 TUYA D][tuya_ctrl_center.c:1337] update devId: ebb3fad96f393b588eomxh name: IR remote pid: lmjfyvtsig6v5npw comm: ebb3fad96f393b588eomxh pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:814 TUYA W][tuya_ctrl_storage.c:143] dev:ebb3fad96f393b588eomxh, dp name is null [10-19 15:23:32:814 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebb3fad96f393b588eomxh,p_rcd_info:0x7f9401d5a4 [10-19 15:23:32:815 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:89,p_rcd_info->crc32:3879080828,len:1232 key:ebb3fad96f393b588eomxh. [10-19 15:23:32:815 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:815 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:815 TUYA D][tuya_ctrl_center.c:1337] update devId: eb1552c6f83a6b59edmyes name: P6EL 2 pid: 1svzszztogaibjxa comm: eb1552c6f83a6b59edmyes pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:815 TUYA W][tuya_ctrl_storage.c:143] dev:eb1552c6f83a6b59edmyes, dp name is null [10-19 15:23:32:816 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb1552c6f83a6b59edmyes,p_rcd_info:0x7f9401d5d8 [10-19 15:23:32:816 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:90,p_rcd_info->crc32:214856666,len:1216 key:eb1552c6f83a6b59edmyes. [10-19 15:23:32:817 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:817 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: Switch 1 [10-19 15:23:32:817 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: Switch 2 [10-19 15:23:32:817 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: Switch 3 [10-19 15:23:32:817 TUYA D][tuya_ctrl_center.c:1202] dp: 4 name: Switch 4 [10-19 15:23:32:817 TUYA D][tuya_ctrl_center.c:1202] dp: 5 name: Switch 5 [10-19 15:23:32:817 TUYA D][tuya_ctrl_center.c:1202] dp: 16 name: Backlight Switch [10-19 15:23:32:817 TUYA D][tuya_ctrl_center.c:1202] dp: 6 name: Switch 6 [10-19 15:23:32:817 TUYA D][tuya_ctrl_center.c:1202] dp: 19 name: Delay-off Schedule [10-19 15:23:32:817 TUYA E][tuya_ctrl_center.c:1205] id: 19 not find [10-19 15:23:32:817 TUYA D][tuya_ctrl_center.c:1337] update devId: eb0a212b4b26ce96c62aei name: Six Gang Switch 2 pid: jyupj3fw comm: eb257c7e0da82bf6fdgo2g pv: 2.2 sub: 1 node: a4c13822298c9cc4 dev_num: 60 [10-19 15:23:32:817 TUYA D][tuya_ctrl_storage.c:169] dev_id : eb0a212b4b26ce96c62aei, serialize dp_names = {"1":"Switch 1","2":"Switch 2","3":"Switch 3","4":"Switch 4","5":"Switch 5","6":"Switch 6","16":"Backlight Switch"} [10-19 15:23:32:817 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb0a212b4b26ce96c62aei,p_rcd_info:0x7f9401d710 [10-19 15:23:32:818 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:91,p_rcd_info->crc32:2101040561,len:1232 key:eb0a212b4b26ce96c62aei. [10-19 15:23:32:819 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:819 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:819 TUYA D][tuya_ctrl_center.c:1337] update devId: ebd1ebe54febaa9c022vqf name: Soquete Inteligente pid: w906qkrrhd3otiwd comm: ebd1ebe54febaa9c022vqf pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:819 TUYA W][tuya_ctrl_storage.c:143] dev:ebd1ebe54febaa9c022vqf, dp name is null [10-19 15:23:32:819 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebd1ebe54febaa9c022vqf,p_rcd_info:0x7f9401d814 [10-19 15:23:32:820 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:92,p_rcd_info->crc32:3684184018,len:1232 key:ebd1ebe54febaa9c022vqf. [10-19 15:23:32:820 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:820 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:820 TUYA D][tuya_ctrl_center.c:1337] update devId: eba3fc32248cc469a3y5qe name: P6EL pid: 1svzszztogaibjxa comm: eba3fc32248cc469a3y5qe pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:820 TUYA W][tuya_ctrl_storage.c:143] dev:eba3fc32248cc469a3y5qe, dp name is null [10-19 15:23:32:820 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eba3fc32248cc469a3y5qe,p_rcd_info:0x7f9401d60c [10-19 15:23:32:821 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:93,p_rcd_info->crc32:354349445,len:1216 key:eba3fc32248cc469a3y5qe. [10-19 15:23:32:821 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:821 TUYA D][tuya_ctrl_center.c:1337] update devId: eb0469f56ed95d7791ogla name: Smart Knob pid: 4fjiwweb comm: ebe5c0ea9264da5aedqyqx pv: 2.2 sub: 1 node: dc8e95fffeaa86e1 dev_num: 60 [10-19 15:23:32:822 TUYA W][tuya_ctrl_storage.c:143] dev:eb0469f56ed95d7791ogla, dp name is null [10-19 15:23:32:822 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb0469f56ed95d7791ogla,p_rcd_info:0x7f9401d640 [10-19 15:23:32:822 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:94,p_rcd_info->crc32:2013950804,len:1216 key:eb0469f56ed95d7791ogla. [10-19 15:23:32:823 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:823 TUYA D][tuya_ctrl_center.c:1202] dp: 1 name: 开关 1 [10-19 15:23:32:823 TUYA D][tuya_ctrl_center.c:1202] dp: 2 name: 开关 2 [10-19 15:23:32:823 TUYA D][tuya_ctrl_center.c:1202] dp: 3 name: 开关 3 [10-19 15:23:32:823 TUYA D][tuya_ctrl_center.c:1202] dp: 4 name: 开关 4 [10-19 15:23:32:823 TUYA D][tuya_ctrl_center.c:1202] dp: 5 name: 开关 5 [10-19 15:23:32:823 TUYA D][tuya_ctrl_center.c:1202] dp: 16 name: 背光开关 [10-19 15:23:32:823 TUYA D][tuya_ctrl_center.c:1202] dp: 6 name: 开关 6 [10-19 15:23:32:823 TUYA D][tuya_ctrl_center.c:1202] dp: 19 name: 点动开关(延时关) [10-19 15:23:32:823 TUYA E][tuya_ctrl_center.c:1205] id: 19 not find [10-19 15:23:32:823 TUYA D][tuya_ctrl_center.c:1337] update devId: ebae3eac4f123fe22bbx5k name: Six Gang Switch pid: jyupj3fw comm: eb827d57cf10b04d2fxtij pv: 2.2 sub: 1 node: a4c138e103ae9725 dev_num: 60 [10-19 15:23:32:823 TUYA D][tuya_ctrl_storage.c:169] dev_id : ebae3eac4f123fe22bbx5k, serialize dp_names = {"1":"开关 1","2":"开关 2","3":"开关 3","4":"开关 4","5":"开关 5","6":"开关 6","16":"背光开关"} [10-19 15:23:32:824 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:ebae3eac4f123fe22bbx5k,p_rcd_info:0x7f9401da50 [10-19 15:23:32:824 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:95,p_rcd_info->crc32:4037150089,len:1232 key:ebae3eac4f123fe22bbx5k. [10-19 15:23:32:825 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:825 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:825 TUYA D][tuya_ctrl_center.c:1337] update devId: eba19ee51b778585c0jcy3 name: Smart Wireless Switch K10W pid: 9cwtq6di0cz7bikc comm: eba19ee51b778585c0jcy3 pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:825 TUYA W][tuya_ctrl_storage.c:143] dev:eba19ee51b778585c0jcy3, dp name is null [10-19 15:23:32:825 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eba19ee51b778585c0jcy3,p_rcd_info:0x7f9401db54 [10-19 15:23:32:826 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:96,p_rcd_info->crc32:2981876833,len:1248 key:eba19ee51b778585c0jcy3. [10-19 15:23:32:826 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:826 TUYA D][tuya_ctrl_center.c:1337] update devId: eb827d57cf10b04d2fxtij name: Mini 多模网关 pid: pj3gdjgpeqao7xk4 comm: eb827d57cf10b04d2fxtij pv: 2.2 sub: 0 node: 0908 dev_num: 60 [10-19 15:23:32:826 TUYA W][tuya_ctrl_storage.c:143] dev:eb827d57cf10b04d2fxtij, dp name is null [10-19 15:23:32:827 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb827d57cf10b04d2fxtij,p_rcd_info:0x7f9401d674 [10-19 15:23:32:827 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:97,p_rcd_info->crc32:3872309292,len:1232 key:eb827d57cf10b04d2fxtij. [10-19 15:23:32:828 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:828 TUYA D][tuya_ctrl_center.c:1337] update devId: eb079c4f40c6c21e6ffpd0 name: 空调 pid: qzktzhehinzsz2je comm: eb44125a98339e4a81t9za pv: 2.2 sub: 1 node: 11d64749afef4019 dev_num: 60 [10-19 15:23:32:828 TUYA W][tuya_ctrl_storage.c:143] dev:eb079c4f40c6c21e6ffpd0, dp name is null [10-19 15:23:32:828 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb079c4f40c6c21e6ffpd0,p_rcd_info:0x7f9401d6a8 [10-19 15:23:32:829 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:98,p_rcd_info->crc32:1154159737,len:1216 key:eb079c4f40c6c21e6ffpd0. [10-19 15:23:32:829 TUYA E][tuya_ctrl_center.c:745] p_skills is null! [10-19 15:23:32:829 TUYA E][tuya_ctrl_center.c:758] node_id is null! [10-19 15:23:32:829 TUYA D][tuya_ctrl_center.c:1337] update devId: eb44125a98339e4a81t9za name: 智能红外遥控器 pid: yrmpfrig5ndywijq comm: eb44125a98339e4a81t9za pv: 2.2 sub: 0 node: dev_num: 60 [10-19 15:23:32:829 TUYA W][tuya_ctrl_storage.c:143] dev:eb44125a98339e4a81t9za, dp name is null [10-19 15:23:32:830 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:eb44125a98339e4a81t9za,p_rcd_info:0x7f9401d6dc [10-19 15:23:32:830 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:99,p_rcd_info->crc32:1956560021,len:1232 key:eb44125a98339e4a81t9za. [10-19 15:23:32:836 TUYA D][tuya_ctrl_frame.c:674] recv id: vdevo166201192349972 tp:1 src:0 online stat: 1, old_st:0, new_st:0x2, old_online:0, new_online:1 [10-19 15:23:32:837 TUYA D][tuya_ctrl_frame.c:674] recv id: vdevo166098193021398 tp:1 src:0 online stat: 1, old_st:0, new_st:0x2, old_online:0, new_online:1 [10-19 15:23:32:837 TUYA D][tuya_ctrl_frame.c:674] recv id: ebc90e9813ffde4148tcvg tp:1 src:0 online stat: 1, old_st:0, new_st:0x2, old_online:0, new_online:1 [10-19 15:23:32:837 TUYA D][tuya_ctrl_frame.c:674] recv id: vdevo166004655924109 tp:1 src:0 online stat: 1, old_st:0, new_st:0x2, old_online:0, new_online:1 [10-19 15:23:32:837 TUYA D][tuya_ctrl_frame.c:674] recv id: eb1552c6f83a6b59edmyes tp:1 src:0 online stat: 1, old_st:0, new_st:0x2, old_online:0, new_online:1 [10-19 15:23:32:837 TUYA D][tuya_ctrl_frame.c:674] recv id: eba19ee51b778585c0jcy3 tp:1 src:0 online stat: 1, old_st:0, new_st:0x2, old_online:0, new_online:1 [10-19 15:23:32:837 TUYA D][tuya_home_ctrl_event.c:253] event oneline devid : vdevo166201192349972, online state : 1 [10-19 15:23:32:837 TUYA N][tuya_home_ctrl_event.c:267] hashmap_get err:-2, dev_id:vdevo166201192349972 [10-19 15:23:32:837 TUYA D][tuya_home_ctrl_event.c:253] event oneline devid : vdevo166098193021398, online state : 1 [10-19 15:23:32:837 TUYA N][tuya_home_ctrl_event.c:267] hashmap_get err:-2, dev_id:vdevo166098193021398 [10-19 15:23:32:837 TUYA D][tuya_home_ctrl_event.c:253] event oneline devid : ebc90e9813ffde4148tcvg, online state : 1 [10-19 15:23:32:837 TUYA D][tuya_home_ctrl_event.c:253] event oneline devid : vdevo166004655924109, online state : 1 [10-19 15:23:32:837 TUYA N][tuya_home_ctrl_event.c:267] hashmap_get err:-2, dev_id:vdevo166004655924109 [10-19 15:23:32:837 TUYA D][tuya_home_ctrl_event.c:253] event oneline devid : eb1552c6f83a6b59edmyes, online state : 1 [10-19 15:23:32:837 TUYA N][tuya_home_ctrl_event.c:267] hashmap_get err:-2, dev_id:eb1552c6f83a6b59edmyes [10-19 15:23:32:837 TUYA D][tuya_home_ctrl_event.c:253] event oneline devid : eba19ee51b778585c0jcy3, online state : 1 [10-19 15:23:32:847 TUYA D][iot_httpc.c:929] Post Data: {"t":1666164212} [10-19 15:23:32:847 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.screen.linux.get.mesh.data.list&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164212&v=1.0&sign=721be40a3e95de5e908592abaf9206c5 [10-19 15:23:32:847 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:32:847 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:32:847 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:32:847 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:32:859 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:32:859 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:32:859 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:32:859 TUYA D][http_manager.c:135] http_send done [10-19 15:23:32:859 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:33:39 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:33:39 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:33:39 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:33:39 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:33:39 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:33:39 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/moon.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:33:39 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:33:39 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:33:39 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:33:39 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:33:39 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:33:48 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:33:48 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:33:48 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:33:49 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:33:49 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:33:49 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:33:49 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:33:49 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:33:214 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:33:214 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:33:214 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:33:214 TUYA D][http_manager.c:135] http_send done [10-19 15:23:33:214 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:33:277 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:33:277 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:33:443 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:33:443 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:33:443 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:33:443 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:33:443 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:33:443 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/moon.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:33:443 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/rule/glyphicons/home.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:33:443 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:33:443 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:33:443 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:33:443 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:33:443 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:33:663 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:33:663 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:33:663 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:33:663 TUYA D][http_manager.c:135] http_send done [10-19 15:23:33:663 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:33:780 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{},"t":1666164214,"success":true} [10-19 15:23:34:1 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:34:1 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:34:1 TUYA I][group_scene_serve.c:2424] dev group relation: (null) [10-19 15:23:34:1 TUYA I][group_scene_serve.c:2340] zigbee group is null [10-19 15:23:34:1 TUYA D][thread_pool_temp.c:200] thread 94001420 END [10-19 15:23:34:1 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:34:1 TUYA D][thread_pool_temp.c:143] put thread 0x7f8400f370 [10-19 15:23:34:1 TUYA D][thread_pool_temp.c:151] temp thread total:2 used:0 [10-19 15:23:34:94 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:34:94 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:34:94 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:34:94 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:34:94 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:34:94 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/home.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:34:94 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:34:94 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:34:94 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:34:94 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:34:94 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:34:98 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:34:98 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:34:279 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:34:279 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:34:279 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:34:279 TUYA D][http_manager.c:135] http_send done [10-19 15:23:34:279 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:34:469 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:34:469 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:34:469 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:34:469 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:34:469 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:34:469 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/home.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:34:469 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:34:469 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:34:469 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:34:469 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:34:469 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:34:519 TUYA D][iot_httpc.c:596] Decode Rev:{"result":[{"protocolVer":"2.1","code":"tymesh1658926009","pv":"2.1","type":0,"ownerId":"77850135","meshId":"meebad4511200549211cv5","networkKey":"","uid":"az1658925946144h4BjH","meshKey":"","name":"tymesh1658926009","appKey":"","share":false,"localKey":"fe08b72a137ff1f7"},{"protocolVer":"2.1","code":"meebcf2cbad39e0ea3c7si","pv":"2.1","type":1,"ownerId":"77850135","meshId":"meebcf2cbad39e0ea3c7si","networkKey":"54B481E831E26D0F83C58294B421BF4A","uid":"az1658925946144h4BjH","meshKey":"AE59725E881F5B854E230CBC69553706","name":"54B481E831E26D0F83C58294B421BF4A","appKey":"AE59725E881F5B854E230CBC69553706","share":false,"localKey":"c8c75ad6794708a7"}],"t":1666164214,"success":true} [10-19 15:23:34:520 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:34:520 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:34:520 TUYA D][tuya_ctrl_mesh.c:192] subscribe topic: smart/mb/in/meebcf2cbad39e0ea3c7si [10-19 15:23:34:520 TUYA D][tuya_ctrl_utils.c:11] sync type: 2 2022-10-19 15:23:34:637:tuya_home_control_sync.c:tuya_home_control_all_info_sync_event:113: tuya_home_control_all_info_sync_event type:2 2022-10-19 15:23:34:637:tuya_home_control_sync.c:tuya_home_control_all_info_sync_event:131:TY_SYNC_TP_DEV not_refresh_dev:0 not_refresh_room:0 [10-19 15:23:34:521 TUYA D][iot_httpc.c:929] Post Data: {"t":1666164214} [10-19 15:23:34:521 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.screen.room.device.all&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164214&v=1.0&sign=4f5aa7b4938513d0b16271c8c987fe81 [10-19 15:23:34:521 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:34:521 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:34:521 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:34:521 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:34:652 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:34:652 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:34:652 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:34:652 TUYA D][http_manager.c:135] http_send done [10-19 15:23:34:652 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:34:710 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:34:710 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:34:710 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:34:710 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:34:710 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:34:710 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:34:710 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:34:711 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:34:851 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:34:851 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:34:851 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:34:851 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:34:851 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:34:851 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/home.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:34:851 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:34:851 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:34:851 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:34:851 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:34:851 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:35:40 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:35:40 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:35:40 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:35:40 TUYA D][http_manager.c:135] http_send done [10-19 15:23:35:40 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:35:256 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:35:256 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:35:256 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:35:256 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:35:256 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:35:256 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/home.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:35:256 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:35:256 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:35:256 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:35:256 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:35:256 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:35:431 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:35:431 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:35:431 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:35:431 TUYA D][http_manager.c:135] http_send done [10-19 15:23:35:431 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:35:437 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:35:437 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:35:617 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:35:617 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:35:617 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:35:617 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:35:617 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:35:617 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/home.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:35:617 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/rule/glyphicons/leaveHome.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:35:617 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:35:617 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:35:617 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:35:617 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:35:617 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:35:795 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:35:795 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:35:795 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:35:795 TUYA D][http_manager.c:135] http_send done [10-19 15:23:35:795 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:35:866 TUYA D][iot_httpc.c:596] Decode Rev:{"result":[{"groupIds":[],"name":"Living Room","devIds":[],"id":76643014},{"groupIds":[],"name":"Master Bedroom","devIds":[],"id":76643015},{"groupIds":[],"name":"Second Bedroom","devIds":[],"id":76643016},{"groupIds":[],"name":"Dining Room","devIds":[],"id":76643017},{"groupIds":[],"name":"Kitchen","devIds":[],"id":76643018},{"groupIds":[],"name":"Study Room","devIds":[],"id":76643019}],"t":1666164215,"success":true} [10-19 15:23:35:867 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:35:867 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:35:867 TUYA D][tuya_ctrl_center.c:1847] get room_cnt: 6 [10-19 15:23:35:867 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:76643014,p_rcd_info:0x7f94021c78 [10-19 15:23:35:867 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:24,p_rcd_info->crc32:774512900,len:80 key:76643014. [10-19 15:23:35:868 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:76643015,p_rcd_info:0x7f94021cac [10-19 15:23:35:868 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:25,p_rcd_info->crc32:3993243728,len:80 key:76643015. [10-19 15:23:35:868 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:76643016,p_rcd_info:0x7f94021ce0 [10-19 15:23:35:868 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:26,p_rcd_info->crc32:3669996523,len:80 key:76643016. [10-19 15:23:35:868 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:76643017,p_rcd_info:0x7f94021d14 [10-19 15:23:35:868 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:27,p_rcd_info->crc32:2806308396,len:80 key:76643017. [10-19 15:23:35:869 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:76643018,p_rcd_info:0x7f94021d48 [10-19 15:23:35:869 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:28,p_rcd_info->crc32:528619598,len:80 key:76643018. [10-19 15:23:35:869 TUYA D][rcd_file.c:1244] [ty_rcd] FOUND metadata from hashmap.key:76643019,p_rcd_info:0x7f94021d7c [10-19 15:23:35:869 TUYA D][rcd_file.c:1280] [ty_rcd] cnt:29,p_rcd_info->crc32:4175150169,len:80 key:76643019. [10-19 15:23:35:869 TUYA D][tuya_ctrl_utils.c:11] sync type: 1 2022-10-19 15:23:35:986:tuya_home_control_sync.c:tuya_home_control_all_info_sync_event:113: tuya_home_control_all_info_sync_event type:1 2022-10-19 15:23:35:986:tuya_home_control_sync.c:tuya_home_control_all_info_sync_event:119:TY_SYNC_TP_ROOM not_refresh_dev:1 not_refresh_room:0 [10-19 15:23:35:870 TUYA N][svc_img.c:830] url is repetition:https://imagesd.tuyaus.com/smart/ir/icon/9knfrm4eawao.png [10-19 15:23:35:870 TUYA N][svc_img.c:830] url is repetition:https://imagesd.tuyaus.com/smart/icon/ay1525749833414yotNt/60d6e9bf17212e96654c407646dd03d0.png [10-19 15:23:35:870 TUYA N][svc_img.c:830] url is repetition:https://imagesd.tuyaus.com/smart/icon/bay1600244221163vqEi/ef1c71f3915af31e087151ca4a99c263.jpg [10-19 15:23:35:870 TUYA N][svc_img.c:830] url is repetition:https://imagesd.tuyaus.com/smart/solution/160001/4772fad51dca8c64_cover.png [10-19 15:23:35:870 TUYA N][svc_img.c:830] url is repetition:https://imagesd.tuyaus.com/smart/program_category_icon/dd.png [10-19 15:23:35:870 TUYA N][svc_img.c:830] url is repetition:https://imagesd.tuyaus.com/smart/icon/ay1547209623516pqlXf/2c50c3721b8ca97593a99e93cebb4ed8.png [10-19 15:23:35:870 TUYA N][svc_img.c:830] url is repetition:https://imagesd.tuyaus.com/smart/icon/ay1525749833414yotNt/60d6e9bf17212e96654c407646dd03d0.png [10-19 15:23:35:870 TUYA N][svc_img.c:830] url is repetition:https://imagesd.tuyaus.com/smart/icon/ay1526524119318s73ao/33931b52deafe9738729f8eec5fbc7bc.png [10-19 15:23:35:870 TUYA N][svc_img.c:830] url is repetition:https://imagesd.tuyaus.com/smart/icon/ay1535193862006vs1if/1656401997c1ec05a32fb.png [10-19 15:23:35:870 TUYA D][tuya_lan_dp_up.c:165] watch dev:,eb44125a98339e4a81t9za,eba19ee51b778585c0jcy3,eb827d57cf10b04d2fxtij,eba3fc32248cc469a3y5qe,ebd1ebe54febaa9c022vqf,ebb3fad96f393b588eomxh,eb2372042e64f76e79f3jk,ebba64b6ac327cdeddq8z2,eb71d993c258066917jpks,eb21cdbd5e05e8e428gaca,vdevo166004655924109,eba528413f6980a463pn4p,eb631bd9b6590e001blfgs,ebc90e9813ffde4148tcvg,ebb4f72bc0eb72ac62dhlo,eb3cfb587e6d81417eac8e,vdevo166098193021398,ebe3006b0f14083917oh1d,eb68d8dbe4707224e8sxd8,eb0058bee16ce0c70aq9nj,eba407ffd4d23748c3rlsw,ebb063750d514d878079mw,eb4576f5222b16dccaaazi,eb62f037dd6640bfa41gut,vdevo166201192349972,eb9c17916f715a30e0a7mz,eb09bad8e75f6222acaglz,ebaf2b250cb41e058ekxqm,eb92b0479e015fbbaavltv,eb46ca57fbaaa5a173n9zv,ebd88c655bdd4b39adihqe,eb8607e2c51bffc942fczo,ebf8fee6f4298432a5eqvk,eb76889250a9917161wng9,eb87649dc6a4ae7fef87xr,eb3b1fefe57125bb72nrzb,ebc78c65e28bc1347ac761,ebb800d543876b9d83jiah,eb62263aaf2f73ef03xira,ebe7f7541d3a5e34dcplwr,eb67a0efcb59444d01ydgn,eb99a9cc76209358a4crkr, [10-19 15:23:35:870 TUYA D][lan_pub_sub_mq_center.c:144] add topic[LAN_DP_UP] suber[local] [10-19 15:23:35:871 TUYA D][lan_pub_sub_mq_center.c:153] sub before, update sub param [10-19 15:23:35:871 TUYA D][lan_pub_sub_mq.c:765] topic sub_param_set [LAN_DP_UP] [10-19 15:23:35:871 TUYA D][thread_pool_temp.c:696] temp run add 0x7f68000ce0 0x71d4b0 0 [10-19 15:23:35:871 TUYA D][thread_pool_temp.c:607] temp run 0x71d4b0 0 [10-19 15:23:35:871 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a69a0 94029010 [10-19 15:23:35:871 TUYA D][thread_pool_temp.c:607] temp run 0x5a69a0 94029010 [10-19 15:23:35:871 TUYA D][thread_pool_temp.c:197] run temp 0x71d4b0 0 in thread 94001420 BEGIN [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: eb257c7e0da82bf6fdgo2g name : Zigbee LAN Gateway should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf673a55509854f89o4ms name : Switch of scene should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: ebe5c0ea9264da5aedqyqx name : 4'' Smart panel-EU should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: ebe2744515d20294b1yhgw name : Zigbee Repeater should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: eb99a9cc76209358a4crkr name : Gateway should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: eb9e43a7db146d1286luio name : 空调 should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: eb87649dc6a4ae7fef87xr name : 智能红外遥控器 should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: ebd959f9cc5a9857b2zsoo name : 遥控器 should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf8fee6f4298432a5eqvk name : 智能网关 should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: eb8607e2c51bffc942fczo name : 红外射频遥控器 3 should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf911148e218a63b67uf3 name : Air should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: ebd88c655bdd4b39adihqe name : 智能红外遥控器 should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: eb46ca57fbaaa5a173n9zv name : 红外射频遥控器 2 should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: eb92b0479e015fbbaavltv name : 智能红外遥控器 should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: eb09bad8e75f6222acaglz name : Intelligent Switcher 2CH should not show on screen [10-19 15:23:35:871 TUYA W][tuya_ctrl_center_api.c:185] dev: eb71d993c258066917jpks name : IPC should not show on screen [10-19 15:23:35:872 TUYA W][tuya_ctrl_center_api.c:185] dev: ebba64b6ac327cdeddq8z2 name : Curtain Switch should not show on screen [10-19 15:23:35:872 TUYA W][tuya_ctrl_center_api.c:185] dev: ebb3fad96f393b588eomxh name : IR remote should not show on screen [10-19 15:23:35:872 TUYA W][tuya_ctrl_center_api.c:185] dev: eb1552c6f83a6b59edmyes name : P6EL 2 should not show on screen [10-19 15:23:35:872 TUYA W][tuya_ctrl_center_api.c:185] dev: eba3fc32248cc469a3y5qe name : P6EL should not show on screen [10-19 15:23:35:872 TUYA W][tuya_ctrl_center_api.c:185] dev: eb0469f56ed95d7791ogla name : Smart Knob should not show on screen [10-19 15:23:35:872 TUYA W][tuya_ctrl_center_api.c:185] dev: eb827d57cf10b04d2fxtij name : Mini 多模网关 should not show on screen [10-19 15:23:35:872 TUYA W][tuya_ctrl_center_api.c:185] dev: eb079c4f40c6c21e6ffpd0 name : 空调 should not show on screen [10-19 15:23:35:872 TUYA W][tuya_ctrl_center_api.c:185] dev: eb44125a98339e4a81t9za name : 智能红外遥控器 should not show on screen [10-19 15:23:35:872 TUYA D][tuya_ctrl_center_api.c:213] tuya_get_dev_brief_info_list success, dev cnt is 36 [10-19 15:23:35:872 TUYA D][iot_httpc.c:929] Post Data: {"queryDpHistoryParam":"[{\"devId\":\"ebd0ad496c403f1af3i9an\",\"dpId\":\"1\",\"limit\": 2, \"sortType\": \"DESC\"},{\"devId\":\"ebd0ad496c403f1af3i9an\",\"dpId\":\"2\",\"limit\": 2, \"sortType\": \"DESC\"},{\"devId\":\"ebff3d1dac6c9c54ebu58o\",\"dpId\":\"1\",\"limit\": 2, \"sortType\": \"DESC\"},{\"devId\":\"eb3edad403134c4f6czxy4\",\"dpId\":\"1\",\"limit\": 2, \"sortType\": \"DESC\"},{\"devId\":\"eb3edad403134c4f6czxy4\",\"dpId\":\"3\",\"limit\": 2, \"sortType\": \"DESC\"},{\"devId\":\"eb92c47fe161c74b89dk25\",\"dpId\":\"1\",\"limit\": 2, \"sortType\": \"DESC\"},{\"devId\":\"eb92c47fe161c74b89dk25\",\"dpId\":\"3\",\"limit\": 2, \"sortType\": \"DESC\"},{\"devId\":\"ebc90e9813ffde4148tcvg\",\"dpId\":\"9\",\"limit\": 2, \"sortType\": \"DESC\"},{\"devId\":\"ebc90e9813ffde4148tcvg\",\"dpId\":\"10\",\"limit\": 2, \"sortType\": \"DESC\"},{\"devId\":\"ebc90e9813ffde4148tcvg\",\"dpId\":\"11\",\"limit\": 2, \"sortType\": \"DESC\"},{\"devId\":\"ebc90e9813ffde4 [10-19 15:23:35:873 TUYA D][thread_pool_temp.c:197] run temp 0x5a69a0 94029010 in thread 940013f0 BEGIN [10-19 15:23:35:873 TUYA D][iot_httpc.c:929] Post Data: {"t":1666164215} [10-19 15:23:35:873 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.sub.list&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164215&v=2.0&sign=cb603251c11fe0a4924acfd23d53e4d9 [10-19 15:23:35:873 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:35:873 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:35:873 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:35:873 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:35:874 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.screen.dp.history.list.batch&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164215&v=1.0&sign=a6c5d092f2f5515a426c2790a806c1ca [10-19 15:23:35:874 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:35:874 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:35:874 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:35:874 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:35:874 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a5780 94038640 [10-19 15:23:35:874 TUYA D][thread_pool_temp.c:607] temp run 0x5a5780 94038640 [10-19 15:23:35:874 TUYA D][scene_linkage_rule_sync.c:1186] report_ability [10-19 15:23:35:874 TUYA D][thread_pool_temp.c:696] temp run add 0x7f8400da30 0x5cd028 0 [10-19 15:23:35:875 TUYA I][uni_thread.c:220] thread_create name:gw_pool_tmp2,stackDepth:8192,totalstackDepth:149504,priority:2 [10-19 15:23:35:875 TUYA D][uni_thread.c:247] Thread:gw_pool_tmp2 Exec Start. Set to Running Stat [10-19 15:23:35:875 TUYA D][thread_pool_temp.c:271] create temp 2 in 0x7f68000da0 [10-19 15:23:35:875 TUYA D][thread_pool_temp.c:129] temp thread expand:3 [10-19 15:23:35:875 TUYA D][thread_pool_temp.c:607] temp run 0x5cd028 0 [10-19 15:23:35:875 TUYA D][thread_pool_temp.c:197] run temp 0x5cd028 0 in thread 68000da0 BEGIN [10-19 15:23:35:875 TUYA D][gw_async_task.c:112] node 0x57f6d0 (nil) use thr 0 [10-19 15:23:35:875 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94001600 0x5dc158 600015d0 [10-19 15:23:35:875 TUYA I][scene_linkage_http_intf.c:223] post_data: {"gwId":"eb1552c6f83a6b59edmyes","abilityProperty":{"condType":[7,13],"actionType":["dpStep","deviceGroupDpIssue"],"unSupportActionType":["irIssue","irIssueVii"]}} [10-19 15:23:35:875 TUYA I][uni_thread.c:220] thread_create name:gw_pool_tmp3,stackDepth:8192,totalstackDepth:157696,priority:2 [10-19 15:23:35:875 TUYA D][thread_pool_temp.c:271] create temp 3 in 0x7f68004130 [10-19 15:23:35:875 TUYA D][thread_pool_temp.c:129] temp thread expand:4 [10-19 15:23:35:875 TUYA D][thread_pool_temp.c:607] temp run 0x5dc158 600015d0 [10-19 15:23:35:875 TUYA D][uni_thread.c:247] Thread:gw_pool_tmp3 Exec Start. Set to Running Stat [10-19 15:23:35:876 TUYA D][thread_pool_temp.c:197] run temp 0x5dc158 600015d0 in thread 68004130 BEGIN [10-19 15:23:35:876 TUYA D][gw_async_task.c:53] call cb 0x57f6d0 (nil), idx 0 [10-19 15:23:35:876 TUYA D][iot_httpc.c:929] Post Data: {"gwId":"eb1552c6f83a6b59edmyes","abilityProperty":{"condType":[7,13],"actionType":["dpStep","deviceGroupDpIssue"],"unSupportActionType":["irIssue","irIssueVii"]},"t":1666164215} [10-19 15:23:35:876 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.linkage.ability&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164215&v=1.0&sign=d1528768ddcd61c4efa15a77e98b5b91 [10-19 15:23:35:876 TUYA D][iot_httpc.c:929] Post Data: {"metas":"{\"lanIp\":\"192.168.3.106\"}","t":1666164215} [10-19 15:23:35:876 TUYA D][gw_async_task.c:112] node 0x57f6d0 (nil) use thr 1 [10-19 15:23:35:876 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:35:876 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.meta.save&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164215&v=1.0&sign=926fec0ace39c3b6ffb7cce6bc6a590d [10-19 15:23:35:876 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:35:876 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:35:876 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:35:876 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94001610 0x5dc158 60001630 [10-19 15:23:35:876 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:35:876 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:35:876 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:35:876 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:35:877 TUYA I][uni_thread.c:220] thread_create name:gw_pool_tmp4,stackDepth:8192,totalstackDepth:165888,priority:2 [10-19 15:23:35:877 TUYA D][uni_thread.c:247] Thread:gw_pool_tmp4 Exec Start. Set to Running Stat [10-19 15:23:35:877 TUYA D][thread_pool_temp.c:271] create temp 4 in 0x7f68000a90 [10-19 15:23:35:877 TUYA D][thread_pool_temp.c:129] temp thread expand:5 [10-19 15:23:35:877 TUYA D][thread_pool_temp.c:607] temp run 0x5dc158 60001630 [10-19 15:23:35:877 TUYA D][thread_pool_temp.c:197] run temp 0x5dc158 60001630 in thread 68000a90 BEGIN [10-19 15:23:35:877 TUYA D][gw_async_task.c:53] call cb 0x57f6d0 (nil), idx 1 [10-19 15:23:35:878 TUYA D][gw_async_task.c:93] no msg to rpt [10-19 15:23:35:878 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94034d10 0x5a69a0 94029010 [10-19 15:23:35:878 TUYA D][thread_pool_temp.c:607] temp run 0x5a69a0 94029010 [10-19 15:23:35:878 TUYA D][iot_httpc.c:929] Post Data: {"metas":"{\"wifiChannel\":11}","t":1666164215} [10-19 15:23:35:878 TUYA D][thread_pool_temp.c:696] temp run add 0x7f8400f590 0x5e7c98 0 [10-19 15:23:35:878 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.meta.save&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164215&v=1.0&sign=926fec0ace39c3b6ffb7cce6bc6a590d [10-19 15:23:35:878 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:35:878 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:35:878 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:35:878 TUYA I][uni_thread.c:220] thread_create name:gw_pool_tmp5,stackDepth:8192,totalstackDepth:174080,priority:2 [10-19 15:23:35:878 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:35:878 TUYA D][thread_pool_temp.c:271] create temp 5 in 0x7f68004020 [10-19 15:23:35:878 TUYA D][thread_pool_temp.c:129] temp thread expand:6 [10-19 15:23:35:878 TUYA D][thread_pool_temp.c:607] temp run 0x5e7c98 0 [10-19 15:23:35:879 TUYA D][tuya_lan_dev_list_core.c:342] lan_cluste st 1 [10-19 15:23:35:879 TUYA I][lpc_con_core.c:245] tuya_lan_pro_client_connet_del_all_peer_node [10-19 15:23:35:879 TUYA D][uni_thread.c:247] Thread:gw_pool_tmp5 Exec Start. Set to Running Stat [10-19 15:23:35:879 TUYA D][thread_pool_temp.c:197] run temp 0x5e7c98 0 in thread 68004020 BEGIN [10-19 15:23:35:879 TUYA D][tuya_lan_dev_localkey.c:518] add node 6c214989a443b2dd90a4or [10-19 15:23:35:879 TUYA D][tuya_lan_dev_localkey.c:518] add node 6c22f40a1acb1885b59qaq [10-19 15:23:35:879 TUYA D][tuya_lan_dev_localkey.c:518] add node eb6ecb092720943cd7nfla [10-19 15:23:35:879 TUYA D][tuya_lan_dev_localkey.c:518] add node 6ca44bf75a687b0aecgwuy [10-19 15:23:35:879 TUYA D][tuya_lan_dev_localkey.c:518] add node 6cc9a0a0f9425c382btujz [10-19 15:23:35:879 TUYA D][tuya_lan_dev_localkey.c:518] add node 6c79c0b9048783677fr8zk [10-19 15:23:35:879 TUYA D][iot_httpc.c:929] Post Data: {"devId":"eb1552c6f83a6b59edmyes","t":1666164215} [10-19 15:23:35:879 TUYA D][tuya_lan_dev_localkey.c:518] add node 6c969031d409e86a781tlx [10-19 15:23:35:879 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.h.s.boot.config.get&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164215&v=3.0&sign=0550b68c0aa393f45e6c46b2db375c51 [10-19 15:23:35:880 TUYA D][tuya_lan_dev_localkey.c:518] add node 6c68477bf37381b524340j [10-19 15:23:35:880 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:35:880 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:35:880 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:35:880 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:35:880 TUYA D][tuya_lan_dev_localkey.c:518] add node 6c13b32e91fd726b8425ei [10-19 15:23:35:880 TUYA D][tuya_lan_dev_localkey.c:518] add node 6c6a927c9fe1cf0c9aui5u [10-19 15:23:35:880 TUYA D][tuya_lan_dev_localkey.c:518] add node 6c0094b881e56546a7d52s [10-19 15:23:35:880 TUYA D][tuya_lan_dev_localkey.c:518] add node 6c4ca30af981d36459nk3o [10-19 15:23:35:880 TUYA D][tuya_lan_dev_localkey.c:518] add node 6c6c5515b325780527hx9l [10-19 15:23:35:880 TUYA D][tuya_lan_dev_localkey.c:518] add node 6c5005ca9f24c2b540xvlo [10-19 15:23:35:880 TUYA D][tuya_lan_dev_list_cache.c:207] dev list add cache eb1552c6f83a6b59edmyes [10-19 15:23:35:880 TUYA D][tuya_ctrl_lan_manage.c:117] dev:eb1552c6f83a6b59edmyes lan avail:1 [10-19 15:23:35:880 TUYA D][scene_linkage_rule_sync.c:1186] report_ability [10-19 15:23:35:880 TUYA D][thread_pool_temp.c:696] temp run add 0x7f8400da30 0x5cd028 0 [10-19 15:23:35:880 TUYA D][thread_pool_temp.c:607] temp run 0x5cd028 0 [10-19 15:23:35:881 TUYA D][tuya_ctrl_frame.c:581] recv id: eb1552c6f83a6b59edmyes tp:0 src:3 online stat: 1, old_st:0x2, new_st:0x3, old_online:1, new_online:1 [10-19 15:23:36:44 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:36:44 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:36:44 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:36:44 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:36:44 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:36:45 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/leaveHome.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:36:45 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:36:45 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:36:45 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:36:45 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:36:45 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:36:54 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:36:54 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:36:54 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:36:54 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:36:54 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:36:54 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:36:54 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:36:54 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:36:57 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:36:57 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:36:57 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:36:57 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:36:57 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:36:57 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:36:57 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:36:57 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:36:57 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:36:58 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:36:58 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:36:58 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:36:58 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:36:58 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:36:58 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:36:58 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:36:58 TUYA D][rcd_file.c:548] [ty_rcd]__flush_timer_cb start [10-19 15:23:36:58 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94001430 0x576444 9401cab0 [10-19 15:23:36:59 TUYA I][uni_thread.c:220] thread_create name:gw_pool_tmp6,stackDepth:8192,totalstackDepth:182272,priority:2 [10-19 15:23:36:59 TUYA D][uni_thread.c:247] Thread:gw_pool_tmp6 Exec Start. Set to Running Stat [10-19 15:23:36:59 TUYA D][thread_pool_temp.c:271] create temp 6 in 0x7f80002db0 [10-19 15:23:36:59 TUYA D][thread_pool_temp.c:129] temp thread expand:7 [10-19 15:23:36:59 TUYA D][thread_pool_temp.c:607] temp run 0x576444 9401cab0 [10-19 15:23:36:59 TUYA D][thread_pool_temp.c:197] run temp 0x576444 9401cab0 in thread 80002db0 BEGIN [10-19 15:23:36:59 TUYA D][rcd_file.c:533] [ty_rcd] __rcd_db_flush start. [10-19 15:23:36:61 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:36:62 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:36:64 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:36:64 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:36:64 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:36:64 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:36:64 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:36:64 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:36:64 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:36:64 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:36:64 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:36:64 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:36:66 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:36:67 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:36:67 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:36:69 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:36:73 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:36:73 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:36:73 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:36:73 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:36:73 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:36:73 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:36:73 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:36:73 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:36:125 TUYA D][rcd_file.c:538] [ty_rcd] __rcd_db_flush end. [10-19 15:23:36:125 TUYA D][thread_pool_temp.c:200] thread 80002db0 END [10-19 15:23:36:125 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:36:125 TUYA D][thread_pool_temp.c:143] put thread 0x7f94001430 [10-19 15:23:36:125 TUYA D][thread_pool_temp.c:151] temp thread total:7 used:6 [10-19 15:23:36:220 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:36:220 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:36:220 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:36:220 TUYA D][http_manager.c:135] http_send done [10-19 15:23:36:220 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:36:243 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:36:243 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:36:408 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:36:408 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:36:408 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:36:408 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:36:409 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:36:409 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/leaveHome.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:36:409 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:36:409 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:36:409 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:36:409 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:36:409 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:36:600 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:36:600 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:36:600 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:36:600 TUYA D][http_manager.c:135] http_send done [10-19 15:23:36:600 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:36:610 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{"nodes":[]},"t":1666164216,"success":true} [10-19 15:23:36:611 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:36:611 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:36:611 TUYA D][subdev_bind.c:1065] dev_num:0 [10-19 15:23:36:611 TUYA D][subdev_bind.c:1067] dev_list_bind:[]. [10-19 15:23:36:611 TUYA D][subdev_sigmesh.c:1174] dev_num:0 [10-19 15:23:36:611 TUYA D][thread_pool_temp.c:200] thread 940013f0 END [10-19 15:23:36:611 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:36:611 TUYA D][thread_pool_temp.c:214] num:3 to exe [10-19 15:23:36:611 TUYA D][thread_pool_temp.c:197] run temp 0x5a5780 94038640 in thread 940013f0 BEGIN [10-19 15:23:36:611 TUYA D][subdev_bind.c:455] sub device bind start [10-19 15:23:36:611 TUYA D][thread_pool_temp.c:200] thread 940013f0 END [10-19 15:23:36:611 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:36:611 TUYA D][thread_pool_temp.c:214] num:2 to exe [10-19 15:23:36:611 TUYA D][thread_pool_temp.c:197] run temp 0x5a69a0 94029010 in thread 940013f0 BEGIN [10-19 15:23:36:611 TUYA D][iot_httpc.c:929] Post Data: {"t":1666164216} [10-19 15:23:36:612 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.sub.list&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164216&v=2.0&sign=54590ec22fd6bc9f2edf04f64cc876f8 [10-19 15:23:36:612 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:36:612 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:36:612 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:36:612 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:36:783 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:36:783 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:36:783 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:36:783 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:36:783 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:36:783 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/leaveHome.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:36:783 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:36:783 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:36:783 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:36:783 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:36:783 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:36:822 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:36:822 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:36:822 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:36:822 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:36:823 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:36:823 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:36:823 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:36:823 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:36:881 TUYA D][thread_pool_temp.c:696] temp run add 0x7f8400f900 0x5f7ca0 0 [10-19 15:23:36:881 TUYA D][thread_pool_temp.c:607] temp run 0x5f7ca0 0 [10-19 15:23:36:881 TUYA D][thread_pool_temp.c:197] run temp 0x5f7ca0 0 in thread 80002db0 BEGIN [10-19 15:23:36:881 TUYA D][iot_httpc.c:929] Post Data: {"devIds":["6c5005ca9f24c2b540xvlo","6c6c5515b325780527hx9l","6c4ca30af981d36459nk3o","6c0094b881e56546a7d52s","6c6a927c9fe1cf0c9aui5u","6c13b32e91fd726b8425ei","6c68477bf37381b524340j","6c969031d409e86a781tlx","6c79c0b9048783677fr8zk","6cc9a0a0f9425c382btujz","6ca44bf75a687b0aecgwuy","eb6ecb092720943cd7nfla","6c22f40a1acb1885b59qaq","6c214989a443b2dd90a4or"],"t":1666164216} [10-19 15:23:36:881 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.lan.node.sync&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164216&v=2.0&sign=73e0f74b75d85d8fac5d6dcbf567efa5 [10-19 15:23:36:881 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:36:881 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:36:881 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:36:882 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:36:922 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:36:922 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:36:946 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:36:946 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:36:949 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:36:949 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:36:968 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:36:968 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:36:968 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:36:968 TUYA D][http_manager.c:135] http_send done [10-19 15:23:36:968 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:36:978 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:36:978 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:37:44 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:37:44 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:37:115 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:37:115 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:37:115 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:37:115 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:37:115 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:37:115 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:37:115 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:37:115 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:37:149 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:37:149 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:37:149 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:37:149 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:37:149 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:37:149 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/leaveHome.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:37:149 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:37:149 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:37:149 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:37:149 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:37:149 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:37:282 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:37:282 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:37:309 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{"abilityProperty":"{\"condType\":[7,13],\"actionType\":[\"dpStep\",\"deviceGroupDpIssue\"],\"unSupportActionType\":[\"irIssue\",\"irIssueVii\"]}","gwId":"eb1552c6f83a6b59edmyes"},"t":1666164217,"success":true} [10-19 15:23:37:309 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:37:309 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:37:309 TUYA D][thread_pool_temp.c:200] thread 68000da0 END [10-19 15:23:37:310 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:37:310 TUYA D][thread_pool_temp.c:214] num:2 to exe [10-19 15:23:37:310 TUYA D][thread_pool_temp.c:197] run temp 0x5cd028 0 in thread 68000da0 BEGIN [10-19 15:23:37:310 TUYA I][scene_linkage_http_intf.c:223] post_data: {"gwId":"eb1552c6f83a6b59edmyes","abilityProperty":{"condType":[7,13],"actionType":["dpStep","deviceGroupDpIssue"],"unSupportActionType":["irIssue","irIssueVii"]}} [10-19 15:23:37:310 TUYA D][iot_httpc.c:929] Post Data: {"gwId":"eb1552c6f83a6b59edmyes","abilityProperty":{"condType":[7,13],"actionType":["dpStep","deviceGroupDpIssue"],"unSupportActionType":["irIssue","irIssueVii"]},"t":1666164217} [10-19 15:23:37:310 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.linkage.ability&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164217&v=1.0&sign=ac834961b094ac47a6665426ffba0be7 [10-19 15:23:37:310 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:37:310 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:37:310 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:37:310 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:37:310 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:37:311 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:37:324 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:37:324 TUYA D][http_manager.c:94] create http session done, session id: 88000d90 [10-19 15:23:37:324 TUYA D][http_manager.c:119] http_send: 88000d90 [10-19 15:23:37:324 TUYA D][http_manager.c:135] http_send done [10-19 15:23:37:325 TUYA D][http_manager.c:146] http_receive: 88000d90 [10-19 15:23:37:347 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{"delayTimes":{"1":{"enable":0},"2":{"enable":30}}},"t":1666164217,"success":true} [10-19 15:23:37:348 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:37:348 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:37:348 TUYA D][home_security.c:1424] home security delay_time: {"1":{"enable":0},"2":{"enable":30}}, cmd_from = 0. [10-19 15:23:37:348 TUYA D][home_security.c:889] Save delay time list: {"1":{"enable":0},"2":{"enable":30}}. [10-19 15:23:37:348 TUYA D][simplekv.c:1211] read key:delay_time_list isFuzzy:0 skipCnt:0 [10-19 15:23:37:348 TUYA D][simplekv.c:1251] find key:13 delay_time_list [10-19 15:23:37:348 TUYA D][simplekv.c:1280] key:delay_time_list find value.Len:48 [10-19 15:23:37:348 TUYA D][home_security.c:788] isNeedPullTime:1. [10-19 15:23:37:348 TUYA D][thread_pool_temp.c:200] thread 68004020 END [10-19 15:23:37:348 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:37:348 TUYA D][thread_pool_temp.c:143] put thread 0x7f8400f590 [10-19 15:23:37:348 TUYA D][thread_pool_temp.c:151] temp thread total:7 used:6 [10-19 15:23:37:353 TUYA D][iot_httpc.c:596] Decode Rev:{"result":true,"t":1666164217,"success":true} [10-19 15:23:37:353 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:37:353 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:37:353 TUYA D][gw_http_report_meta.c:119] meta rpt {"metas":"{\"wifiChannel\":11}"} ret 0 cnt 0 [10-19 15:23:37:354 TUYA D][thread_pool_temp.c:200] thread 68000a90 END [10-19 15:23:37:354 TUYA D][gw_async_task.c:93] no msg to rpt [10-19 15:23:37:354 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:37:354 TUYA D][thread_pool_temp.c:143] put thread 0x7f94001610 [10-19 15:23:37:354 TUYA D][thread_pool_temp.c:151] temp thread total:7 used:5 [10-19 15:23:37:378 TUYA D][thread_pool_temp.c:696] temp run add 0x7f84004c00 0x560914 0 [10-19 15:23:37:378 TUYA D][thread_pool_temp.c:607] temp run 0x560914 0 [10-19 15:23:37:378 TUYA D][thread_pool_temp.c:197] run temp 0x560914 0 in thread 68000a90 BEGIN [10-19 15:23:37:378 TUYA D][lan_dev_base_master.c:556] node report node_num 12. [10-19 15:23:37:378 TUYA D][iot_httpc.c:929] Post Data: {"devIds": ["6c5005ca9f24c2b540xvlo","6c0094b881e56546a7d52s","6c6a927c9fe1cf0c9aui5u","6c13b32e91fd726b8425ei","6c68477bf37381b524340j","6c969031d409e86a781tlx","6c79c0b9048783677fr8zk","6cc9a0a0f9425c382btujz","6ca44bf75a687b0aecgwuy","eb6ecb092720943cd7nfla","6c22f40a1acb1885b59qaq","6c214989a443b2dd90a4or"],"t":1666164217} [10-19 15:23:37:379 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.lan.node.report&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164217&v=1.0&sign=269383fafe32aed01f4a45c8216c7345 [10-19 15:23:37:379 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:37:379 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:37:379 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:37:379 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:37:425 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{"nodes":[]},"t":1666164217,"success":true} [10-19 15:23:37:425 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:37:426 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:37:426 TUYA D][subdev_bind.c:1065] dev_num:0 [10-19 15:23:37:426 TUYA D][subdev_bind.c:1067] dev_list_bind:[]. [10-19 15:23:37:426 TUYA D][subdev_sigmesh.c:1174] dev_num:0 [10-19 15:23:37:426 TUYA D][thread_pool_temp.c:200] thread 940013f0 END [10-19 15:23:37:426 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:37:426 TUYA D][thread_pool_temp.c:143] put thread 0x7f94034d10 [10-19 15:23:37:426 TUYA D][thread_pool_temp.c:151] temp thread total:7 used:5 [10-19 15:23:37:507 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:37:507 TUYA D][http_manager.c:196] http_receive: done 88000d90 [10-19 15:23:37:507 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:37:507 TUYA D][http_manager.c:12] http_session_destory: 88000d90 [10-19 15:23:37:507 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:37:507 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/rule/glyphicons/leaveHome.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:37:507 TUYA E][svc_img.c:168] sucess cnt is 0 [10-19 15:23:37:507 TUYA E][svc_img.c:260] tuya_img_service_result_handle [10-19 15:23:37:507 TUYA E][tuya_iot_scene_img_sync.c:51] invalid param [10-19 15:23:37:507 TUYA N][svc_img.c:688] id name url frist one build list:ctrl_dev_img [10-19 15:23:37:508 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:508 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:508 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:508 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:508 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:508 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:508 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:508 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:508 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:509 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:510 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA E][svc_file.c:358] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:511 TUYA D][svc_file.c:434] p_name file:. [10-19 15:23:37:511 TUYA D][svc_file.c:434] p_name file:.. [10-19 15:23:37:511 TUYA E][svc_file.c:438] tuya_hal_dir_read err:/userdata/tuya_db_files/ctrl_dev_img/ [10-19 15:23:37:512 TUYA E][svc_img.c:713] tuya_dir_file_delete_for_url err:-1 [10-19 15:23:37:512 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/162615470435b99f0456c.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:37:512 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:37:512 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:37:512 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:37:512 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:37:512 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:37:517 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:37:517 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:37:517 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:37:517 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:37:517 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:37:517 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:37:517 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:37:517 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:37:593 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:37:593 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:37:593 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:37:593 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:37:593 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:37:593 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:37:593 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:37:593 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake 2022-10-19 15:23:37:715:dev_control.c:refresh_device_task:795:refresh_device_task in [10-19 15:23:37:600 TUYA D][tuya_ctrl_center_api.c:370] tuya_get_room_info_list success, cnt is 6 [10-19 15:23:37:600 TUYA W][tuya_ctrl_center_api.c:185] dev: eb257c7e0da82bf6fdgo2g name : Zigbee LAN Gateway should not show on screen [10-19 15:23:37:600 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf673a55509854f89o4ms name : Switch of scene should not show on screen [10-19 15:23:37:600 TUYA W][tuya_ctrl_center_api.c:185] dev: ebe5c0ea9264da5aedqyqx name : 4'' Smart panel-EU should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: ebe2744515d20294b1yhgw name : Zigbee Repeater should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb99a9cc76209358a4crkr name : Gateway should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb9e43a7db146d1286luio name : 空调 should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb87649dc6a4ae7fef87xr name : 智能红外遥控器 should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: ebd959f9cc5a9857b2zsoo name : 遥控器 should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf8fee6f4298432a5eqvk name : 智能网关 should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb8607e2c51bffc942fczo name : 红外射频遥控器 3 should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf911148e218a63b67uf3 name : Air should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: ebd88c655bdd4b39adihqe name : 智能红外遥控器 should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb46ca57fbaaa5a173n9zv name : 红外射频遥控器 2 should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb92b0479e015fbbaavltv name : 智能红外遥控器 should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb09bad8e75f6222acaglz name : Intelligent Switcher 2CH should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb71d993c258066917jpks name : IPC should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: ebba64b6ac327cdeddq8z2 name : Curtain Switch should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: ebb3fad96f393b588eomxh name : IR remote should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb1552c6f83a6b59edmyes name : P6EL 2 should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eba3fc32248cc469a3y5qe name : P6EL should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb0469f56ed95d7791ogla name : Smart Knob should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb827d57cf10b04d2fxtij name : Mini 多模网关 should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb079c4f40c6c21e6ffpd0 name : 空调 should not show on screen [10-19 15:23:37:601 TUYA W][tuya_ctrl_center_api.c:185] dev: eb44125a98339e4a81t9za name : 智能红外遥控器 should not show on screen [10-19 15:23:37:601 TUYA D][tuya_ctrl_center_api.c:213] tuya_get_dev_brief_info_list success, dev cnt is 36 2022-10-19 15:23:37:718:dev_control.c:get_brief_devices:611:tuya_get_dev_brief_info_list dev_count 36 2022-10-19 15:23:37:718:core_dev_data.c:dev_filter:178:dev_filter:mcs 2022-10-19 15:23:37:718:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:37:718:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = ZigBee 3 Gang Switch, dev_list[i].category = kg 2022-10-19 15:23:37:718:dev_control_cont.c:show_all_devices:263:dev_list->name = ZigBee 3 Gang Switch ,online_stat = 0 [10-19 15:23:37:603 TUYA D][strategy_code_enum.c:80] convert enum to: last [10-19 15:23:37:603 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d32770 [10-19 15:23:37:603 TUYA D][tuya_base_event.c:28] subscribe: dp-eb0f65ca9465be8edcoyot 2022-10-19 15:23:37:719:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 7 2022-10-19 15:23:37:719:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 3 [10-19 15:23:37:603 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d32770 [10-19 15:23:37:603 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb0f65ca9465be8edcoyot 2022-10-19 15:23:37:719:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb0f65ca9465be8edcoyot 2022-10-19 15:23:37:719:core_dev_data.c:dev_filter:178:dev_filter:wk 2022-10-19 15:23:37:720:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Zigbee Smart Thermostat , dev_list[i].category = wk 2022-10-19 15:23:37:720:dev_control_cont.c:show_all_devices:263:dev_list->name = Zigbee Smart Thermostat ,online_stat = 0 [10-19 15:23:37:604 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d32770 [10-19 15:23:37:604 TUYA D][tuya_base_event.c:28] subscribe: dp-ebabc77077c75fec391svt 2022-10-19 15:23:37:721:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 13 2022-10-19 15:23:37:721:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 0 [10-19 15:23:37:604 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d32770 [10-19 15:23:37:604 TUYA D][tuya_base_event.c:31] unsubscribe: dp-ebabc77077c75fec391svt 2022-10-19 15:23:37:721:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = ebabc77077c75fec391svt 2022-10-19 15:23:37:721:core_dev_data.c:dev_filter:178:dev_filter:cz 2022-10-19 15:23:37:721:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = 智能插座, dev_list[i].category = cz 2022-10-19 15:23:37:721:dev_control_cont.c:show_all_devices:263:dev_list->name = 智能插座 ,online_stat = 0 2022-10-19 15:23:37:722:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 10 2022-10-19 15:23:37:722:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [10-19 15:23:37:605 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d366f0 [10-19 15:23:37:606 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb67a0efcb59444d01ydgn 2022-10-19 15:23:37:722:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb67a0efcb59444d01ydgn 2022-10-19 15:23:37:722:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 2022-10-19 15:23:37:722:dev_control_cz.c:cz_ctl_shortcut_open:236:p6el:cz_ctl_shortcut_open dev_id = eb67a0efcb59444d01ydgn [10-19 15:23:37:606 TUYA D][strategy_code_enum.c:80] convert enum to: power_on [10-19 15:23:37:606 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d366f0 [10-19 15:23:37:606 TUYA D][tuya_base_event.c:28] subscribe: dp-eb67a0efcb59444d01ydgn 2022-10-19 15:23:37:723:dev_control_cz.c:cz_ctl_shortcut_open:245:p6el:cz_ctl_shortcut_open dev_info = 315844400 2022-10-19 15:23:37:723:dev_control_cont.c:tab2_device_cb:685:sw on.. 2022-10-19 15:23:37:725:core_dev_data.c:dev_filter:178:dev_filter:dd 2022-10-19 15:23:37:725:core_dev_data.c:dev_filter:178:dev_filter:dj 2022-10-19 15:23:37:725:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = 智能彩灯, dev_list[i].category = dj 2022-10-19 15:23:37:726:dev_control_cont.c:show_all_devices:263:dev_list->name = 智能彩灯 ,online_stat = 0 2022-10-19 15:23:37:726:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 7 2022-10-19 15:23:37:726:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [10-19 15:23:37:610 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d377b0 [10-19 15:23:37:610 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb62263aaf2f73ef03xira 2022-10-19 15:23:37:726:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb62263aaf2f73ef03xira 2022-10-19 15:23:37:726:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 [10-19 15:23:37:610 TUYA D][dpcode_strategy.c:55] str:000003e803e8 len:12 [10-19 15:23:37:610 TUYA D][dpcode_strategy.c:82] H S V:0x0 0x3e8 0x3e8 [10-19 15:23:37:610 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d377b0 [10-19 15:23:37:610 TUYA D][tuya_base_event.c:28] subscribe: dp-eb62263aaf2f73ef03xira 2022-10-19 15:23:37:727:dev_control_light.c:light_ctl_open:99:light_ctl_open = 315848624 2022-10-19 15:23:37:727:dev_control_cont.c:tab2_device_cb:685:sw on.. 2022-10-19 15:23:37:727:core_dev_data.c:dev_filter:178:dev_filter:wfcon 2022-10-19 15:23:37:727:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:37:727:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = 4X4 Switch+Socket, dev_list[i].category = kg 2022-10-19 15:23:37:728:dev_control_cont.c:show_all_devices:263:dev_list->name = 4X4 Switch+Socket ,online_stat = 0 [10-19 15:23:37:612 TUYA D][strategy_code_enum.c:80] convert enum to: last [10-19 15:23:37:612 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d36f40 [10-19 15:23:37:612 TUYA D][tuya_base_event.c:28] subscribe: dp-ebc78c65e28bc1347ac761 2022-10-19 15:23:37:728:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 14 2022-10-19 15:23:37:728:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 7 [10-19 15:23:37:612 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d36f40 [10-19 15:23:37:612 TUYA D][tuya_base_event.c:31] unsubscribe: dp-ebc78c65e28bc1347ac761 2022-10-19 15:23:37:728:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = ebc78c65e28bc1347ac761 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:clkg 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:bzyd 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:pir 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:pir 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:mcs 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:pc 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:dd 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:pc 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:dd 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:dlq 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:37:729:core_dev_data.c:dev_filter:178:dev_filter:wk 2022-10-19 15:23:37:729:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Temp, dev_list[i].category = wk 2022-10-19 15:23:37:730:dev_control_cont.c:show_all_devices:263:dev_list->name = Temp ,online_stat = 0 [10-19 15:23:37:614 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d36f40 [10-19 15:23:37:614 TUYA D][tuya_base_event.c:28] subscribe: dp-eb0058bee16ce0c70aq9nj 2022-10-19 15:23:37:730:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 5 2022-10-19 15:23:37:730:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 0 [10-19 15:23:37:614 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d36f40 [10-19 15:23:37:614 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb0058bee16ce0c70aq9nj 2022-10-19 15:23:37:730:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb0058bee16ce0c70aq9nj 2022-10-19 15:23:37:730:core_dev_data.c:dev_filter:178:dev_filter:cz 2022-10-19 15:23:37:730:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Wifi Plug, dev_list[i].category = cz 2022-10-19 15:23:37:731:dev_control_cont.c:show_all_devices:263:dev_list->name = Wifi Plug ,online_stat = 0 2022-10-19 15:23:37:731:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 9 2022-10-19 15:23:37:731:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [10-19 15:23:37:615 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d37a90 [10-19 15:23:37:615 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb68d8dbe4707224e8sxd8 2022-10-19 15:23:37:732:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb68d8dbe4707224e8sxd8 2022-10-19 15:23:37:732:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 2022-10-19 15:23:37:732:dev_control_cz.c:cz_ctl_shortcut_open:236:p6el:cz_ctl_shortcut_open dev_id = eb68d8dbe4707224e8sxd8 [10-19 15:23:37:616 TUYA D][strategy_code_enum.c:80] convert enum to: last [10-19 15:23:37:616 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d37a90 [10-19 15:23:37:616 TUYA D][tuya_base_event.c:28] subscribe: dp-eb68d8dbe4707224e8sxd8 2022-10-19 15:23:37:732:dev_control_cz.c:cz_ctl_shortcut_open:245:p6el:cz_ctl_shortcut_open dev_info = 315842048 2022-10-19 15:23:37:732:dev_control_cont.c:tab2_device_cb:693:sw off.. 2022-10-19 15:23:37:732:core_dev_data.c:dev_filter:178:dev_filter:wk 2022-10-19 15:23:37:732:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = 空调温控器 2, dev_list[i].category = wk 2022-10-19 15:23:37:733:dev_control_cont.c:show_all_devices:263:dev_list->name = 空调温控器 2 ,online_stat = 0 [10-19 15:23:37:617 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d36f00 [10-19 15:23:37:617 TUYA D][tuya_base_event.c:28] subscribe: dp-ebe3006b0f14083917oh1d 2022-10-19 15:23:37:734:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 11 2022-10-19 15:23:37:734:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 0 [10-19 15:23:37:617 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d36f00 [10-19 15:23:37:618 TUYA D][tuya_base_event.c:31] unsubscribe: dp-ebe3006b0f14083917oh1d 2022-10-19 15:23:37:734:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = ebe3006b0f14083917oh1d 2022-10-19 15:23:37:734:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:37:734:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:37:734:core_dev_data.c:dev_filter:178:dev_filter:dd 2022-10-19 15:23:37:734:core_dev_data.c:dev_filter:178:dev_filter:wsdcg 2022-10-19 15:23:37:734:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:37:734:core_dev_data.c:dev_filter:178:dev_filter:dj 2022-10-19 15:23:37:734:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Smart Bulb(BP5758D 35/10), dev_list[i].category = dj 2022-10-19 15:23:37:735:dev_control_cont.c:show_all_devices:263:dev_list->name = Smart Bulb(BP5758D 35/10) ,online_stat = 0 2022-10-19 15:23:37:735:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 16 2022-10-19 15:23:37:735:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [10-19 15:23:37:619 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d38ed0 [10-19 15:23:37:619 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eba528413f6980a463pn4p 2022-10-19 15:23:37:735:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eba528413f6980a463pn4p 2022-10-19 15:23:37:736:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 [10-19 15:23:37:619 TUYA D][dpcode_strategy.c:55] str:010b03e803e8 len:12 [10-19 15:23:37:619 TUYA D][dpcode_strategy.c:82] H S V:0x10b 0x3e8 0x3e8 [10-19 15:23:37:619 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d38ed0 [10-19 15:23:37:620 TUYA D][tuya_base_event.c:28] subscribe: dp-eba528413f6980a463pn4p 2022-10-19 15:23:37:736:dev_control_light.c:light_ctl_open:99:light_ctl_open = 315854544 2022-10-19 15:23:37:736:dev_control_cont.c:tab2_device_cb:685:sw on.. 2022-10-19 15:23:37:736:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:37:736:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 1 dev_list[i].name = Six Gang Switch-vdevo, dev_list[i].category = kg 2022-10-19 15:23:37:737:dev_control_cont.c:show_all_devices:263:dev_list->name = Six Gang Switch-vdevo ,online_stat = 1 [10-19 15:23:37:621 TUYA D][strategy_code_enum.c:80] convert enum to: power_off [10-19 15:23:37:621 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d32760 [10-19 15:23:37:621 TUYA D][tuya_base_event.c:28] subscribe: dp-vdevo166004655924109 2022-10-19 15:23:37:737:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 14 2022-10-19 15:23:37:737:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 7 [10-19 15:23:37:621 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d32760 [10-19 15:23:37:621 TUYA D][tuya_base_event.c:31] unsubscribe: dp-vdevo166004655924109 2022-10-19 15:23:37:738:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = vdevo166004655924109 2022-10-19 15:23:37:738:core_dev_data.c:dev_filter:178:dev_filter:wk 2022-10-19 15:23:37:738:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = 空调温控器, dev_list[i].category = wk 2022-10-19 15:23:37:738:dev_control_cont.c:show_all_devices:263:dev_list->name = 空调温控器 ,online_stat = 0 [10-19 15:23:37:622 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d32760 [10-19 15:23:37:622 TUYA D][tuya_base_event.c:28] subscribe: dp-eb21cdbd5e05e8e428gaca 2022-10-19 15:23:37:739:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 11 2022-10-19 15:23:37:739:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 0 [10-19 15:23:37:623 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d32760 [10-19 15:23:37:623 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb21cdbd5e05e8e428gaca 2022-10-19 15:23:37:739:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb21cdbd5e05e8e428gaca 2022-10-19 15:23:37:739:core_dev_data.c:dev_filter:178:dev_filter:tdq 2022-10-19 15:23:37:739:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:37:739:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Six Gang Switch 2, dev_list[i].category = kg 2022-10-19 15:23:37:740:dev_control_cont.c:show_all_devices:263:dev_list->name = Six Gang Switch 2 ,online_stat = 0 [10-19 15:23:37:624 TUYA D][strategy_code_enum.c:80] convert enum to: power_off [10-19 15:23:37:624 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d32760 [10-19 15:23:37:624 TUYA D][tuya_base_event.c:28] subscribe: dp-eb0a212b4b26ce96c62aei 2022-10-19 15:23:37:740:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 14 2022-10-19 15:23:37:740:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 7 [10-19 15:23:37:624 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d32760 [10-19 15:23:37:624 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eb0a212b4b26ce96c62aei 2022-10-19 15:23:37:741:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eb0a212b4b26ce96c62aei 2022-10-19 15:23:37:741:core_dev_data.c:dev_filter:178:dev_filter:cz 2022-10-19 15:23:37:741:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Soquete Inteligente, dev_list[i].category = cz 2022-10-19 15:23:37:741:dev_control_cont.c:show_all_devices:263:dev_list->name = Soquete Inteligente ,online_stat = 0 2022-10-19 15:23:37:741:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 10 2022-10-19 15:23:37:742:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [10-19 15:23:37:625 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d3a950 [10-19 15:23:37:625 TUYA D][tuya_base_event.c:31] unsubscribe: dp-ebd1ebe54febaa9c022vqf 2022-10-19 15:23:37:742:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = ebd1ebe54febaa9c022vqf 2022-10-19 15:23:37:742:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 2022-10-19 15:23:37:742:dev_control_cz.c:cz_ctl_shortcut_open:236:p6el:cz_ctl_shortcut_open dev_id = ebd1ebe54febaa9c022vqf [10-19 15:23:37:626 TUYA D][strategy_code_enum.c:80] convert enum to: last [10-19 15:23:37:626 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3a950 [10-19 15:23:37:626 TUYA D][tuya_base_event.c:28] subscribe: dp-ebd1ebe54febaa9c022vqf 2022-10-19 15:23:37:742:dev_control_cz.c:cz_ctl_shortcut_open:245:p6el:cz_ctl_shortcut_open dev_info = 315859376 2022-10-19 15:23:37:742:dev_control_cont.c:tab2_device_cb:685:sw on.. 2022-10-19 15:23:37:743:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:37:743:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 0 dev_list[i].name = Six Gang Switch, dev_list[i].category = kg 2022-10-19 15:23:37:743:dev_control_cont.c:show_all_devices:263:dev_list->name = Six Gang Switch ,online_stat = 0 [10-19 15:23:37:627 TUYA D][strategy_code_enum.c:80] convert enum to: power_off [10-19 15:23:37:627 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3b6b0 [10-19 15:23:37:627 TUYA D][tuya_base_event.c:28] subscribe: dp-ebae3eac4f123fe22bbx5k 2022-10-19 15:23:37:744:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 14 2022-10-19 15:23:37:744:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 7 [10-19 15:23:37:628 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d3b6b0 [10-19 15:23:37:628 TUYA D][tuya_base_event.c:31] unsubscribe: dp-ebae3eac4f123fe22bbx5k 2022-10-19 15:23:37:744:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = ebae3eac4f123fe22bbx5k 2022-10-19 15:23:37:744:core_dev_data.c:dev_filter:178:dev_filter:kg 2022-10-19 15:23:37:744:dev_control.c:get_brief_devices:622:p6el: dev_list[i].online_stat 1 dev_list[i].name = Smart Wireless Switch K10W, dev_list[i].category = kg 2022-10-19 15:23:37:745:dev_control_cont.c:show_all_devices:263:dev_list->name = Smart Wireless Switch K10W ,online_stat = 1 2022-10-19 15:23:37:745:core_dev_data.c:is_shortcut_device:114:is_shortcut_device dp_num = 4 2022-10-19 15:23:37:745:core_dev_data.c:is_shortcut_device:124:is_shortcut_device num = 1 [10-19 15:23:37:629 TUYA D][tuya_home_ctrl_dev.c:512] close dev, dev des is 0x12d3b0e0 [10-19 15:23:37:629 TUYA D][tuya_base_event.c:31] unsubscribe: dp-eba19ee51b778585c0jcy3 2022-10-19 15:23:37:745:dev_control_cont.c:show_all_devices:327: test---dev_info.dev.id = eba19ee51b778585c0jcy3 2022-10-19 15:23:37:745:dev_control_cont.c:tab2_device_cb:654:tab2_device_cb event 654 [10-19 15:23:37:629 TUYA D][tuya_home_ctrl_dev.c:477] open dev, new dev_des is 0x12d3b0e0 [10-19 15:23:37:629 TUYA D][tuya_base_event.c:28] subscribe: dp-eba19ee51b778585c0jcy3 2022-10-19 15:23:37:746:dev_control_kg.c:kg_ctl_open:70:eba19ee51b778585c0jcy3 2022-10-19 15:23:37:746:dev_control_kg.c:kg_get_shortcut:105:---------------kg_get_shortcut:0 2022-10-19 15:23:37:746:dev_control_cont.c:tab2_device_cb:693:sw off.. 2022-10-19 15:23:37:746:dev_control.c:no_device_view:405:no_device_view view in 2022-10-19 15:23:37:756:dev_control.c:no_device_view:405:no_device_view view in 2022-10-19 15:23:37:758:dev_control.c:no_device_view:405:no_device_view view in 2022-10-19 15:23:37:759:dev_control.c:no_device_view:405:no_device_view view in 2022-10-19 15:23:37:761:dev_control.c:no_device_view:405:no_device_view view in 2022-10-19 15:23:37:762:dev_control.c:no_device_view:405:no_device_view view in 2022-10-19 15:23:37:763:main_page_shortcut.c:Tab1_Btn_Var_Show:251:Tab1_Btn_Var_Show:251 2022-10-19 15:23:37:763:main_page_shortcut.c:Tab1_Btn_Var_Show:275:Tab1_Btn_Var_Show:275 2022-10-19 15:23:37:763:main_page_shortcut.c:Tab1_Btn_Var_Show:295:295 :0 0 2022-10-19 15:23:37:764:main_page_shortcut.c:Tab1_Btn_Var_Show:426:shortcut_device_scene[1].on =0, ret2=0 [10-19 15:23:37:647 TUYA W][tuya_ctrl_center_api.c:185] dev: eb257c7e0da82bf6fdgo2g name : Zigbee LAN Gateway should not show on screen [10-19 15:23:37:647 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf673a55509854f89o4ms name : Switch of scene should not show on screen [10-19 15:23:37:647 TUYA W][tuya_ctrl_center_api.c:185] dev: ebe5c0ea9264da5aedqyqx name : 4'' Smart panel-EU should not show on screen [10-19 15:23:37:647 TUYA W][tuya_ctrl_center_api.c:185] dev: ebe2744515d20294b1yhgw name : Zigbee Repeater should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb99a9cc76209358a4crkr name : Gateway should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb9e43a7db146d1286luio name : 空调 should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb87649dc6a4ae7fef87xr name : 智能红外遥控器 should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: ebd959f9cc5a9857b2zsoo name : 遥控器 should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf8fee6f4298432a5eqvk name : 智能网关 should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb8607e2c51bffc942fczo name : 红外射频遥控器 3 should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: ebf911148e218a63b67uf3 name : Air should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: ebd88c655bdd4b39adihqe name : 智能红外遥控器 should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb46ca57fbaaa5a173n9zv name : 红外射频遥控器 2 should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb92b0479e015fbbaavltv name : 智能红外遥控器 should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb09bad8e75f6222acaglz name : Intelligent Switcher 2CH should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb71d993c258066917jpks name : IPC should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: ebba64b6ac327cdeddq8z2 name : Curtain Switch should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: ebb3fad96f393b588eomxh name : IR remote should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb1552c6f83a6b59edmyes name : P6EL 2 should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eba3fc32248cc469a3y5qe name : P6EL should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb0469f56ed95d7791ogla name : Smart Knob should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb827d57cf10b04d2fxtij name : Mini 多模网关 should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb079c4f40c6c21e6ffpd0 name : 空调 should not show on screen [10-19 15:23:37:648 TUYA W][tuya_ctrl_center_api.c:185] dev: eb44125a98339e4a81t9za name : 智能红外遥控器 should not show on screen [10-19 15:23:37:648 TUYA D][tuya_ctrl_center_api.c:213] tuya_get_dev_brief_info_list success, dev cnt is 36 2022-10-19 15:23:37:765:pull_down_sensor.c:get_brief_sensor_devices:337:tuya_get_dev_brief_info_list dev_count 36 2022-10-19 15:23:37:765:core_dev_data.c:sensor_filter:256:dev_filter:mcs 2022-10-19 15:23:37:765:pull_down_sensor.c:get_brief_sensor_devices:345:dev_list[i].online_stat 0 dev_list[i].name = Zigbee Contact Sensor, dev_list[i].category = mcs 2022-10-19 15:23:37:765:pull_down_sensor.c:open_all_sensor_dev:270:open_all_sensor_dev:mcs 2022-10-19 15:23:37:765:test_home_ctrl_door_sensor.c:test_door_sensor_dp:84:report dev_id=0x12d3ce10, ebd0ad496c403f1af3i9an 2022-10-19 15:23:37:765:pull_down_sensor.c:open_all_sensor_dev:313:smatek open_all_sensor_dev dev_info:0x12d30710, dev_list->id:ebd0ad496c403f1af3i9an 2022-10-19 15:23:37:765:core_dev_data.c:sensor_filter:256:dev_filter:kg 2022-10-19 15:23:37:765:core_dev_data.c:sensor_filter:256:dev_filter:wk 2022-10-19 15:23:37:765:core_dev_data.c:sensor_filter:256:dev_filter:cz 2022-10-19 15:23:37:765:core_dev_data.c:sensor_filter:256:dev_filter:dd 2022-10-19 15:23:37:765:core_dev_data.c:sensor_filter:256:dev_filter:dj 2022-10-19 15:23:37:765:core_dev_data.c:sensor_filter:256:dev_filter:wfcon 2022-10-19 15:23:37:765:core_dev_data.c:sensor_filter:256:dev_filter:kg 2022-10-19 15:23:37:765:core_dev_data.c:sensor_filter:256:dev_filter:clkg 2022-10-19 15:23:37:766:core_dev_data.c:sensor_filter:256:dev_filter:bzyd 2022-10-19 15:23:37:766:core_dev_data.c:sensor_filter:256:dev_filter:pir 2022-10-19 15:23:37:766:pull_down_sensor.c:get_brief_sensor_devices:345:dev_list[i].online_stat 0 dev_list[i].name = 门铃按钮, dev_list[i].category = pir 2022-10-19 15:23:37:766:pull_down_sensor.c:open_all_sensor_dev:270:open_all_sensor_dev:pir 2022-10-19 15:23:37:766:test_home_ctrl_pir_sensor.c:test_pir_sensor_dp:98:test_pir_sensor_dp dev_id:ebff3d1dac6c9c54ebu58o 2022-10-19 15:23:37:766:pull_down_sensor.c:open_all_sensor_dev:313:smatek open_all_sensor_dev dev_info:0x12d38b20, dev_list->id:ebff3d1dac6c9c54ebu58o 2022-10-19 15:23:37:766:core_dev_data.c:sensor_filter:256:dev_filter:pir 2022-10-19 15:23:37:766:pull_down_sensor.c:get_brief_sensor_devices:345:dev_list[i].online_stat 0 dev_list[i].name = 人体传感器, dev_list[i].category = pir 2022-10-19 15:23:37:766:pull_down_sensor.c:open_all_sensor_dev:270:open_all_sensor_dev:pir 2022-10-19 15:23:37:766:test_home_ctrl_pir_sensor.c:test_pir_sensor_dp:98:test_pir_sensor_dp dev_id:eb3edad403134c4f6czxy4 2022-10-19 15:23:37:766:pull_down_sensor.c:open_all_sensor_dev:313:smatek open_all_sensor_dev dev_info:0x12d36440, dev_list->id:eb3edad403134c4f6czxy4 2022-10-19 15:23:37:766:core_dev_data.c:sensor_filter:256:dev_filter:mcs 2022-10-19 15:23:37:766:pull_down_sensor.c:get_brief_sensor_devices:345:dev_list[i].online_stat 0 dev_list[i].name = 门磁, dev_list[i].category = mcs 2022-10-19 15:23:37:766:pull_down_sensor.c:open_all_sensor_dev:270:open_all_sensor_dev:mcs 2022-10-19 15:23:37:766:test_home_ctrl_door_sensor.c:test_door_sensor_dp:84:report dev_id=0x12d3d968, eb92c47fe161c74b89dk25 2022-10-19 15:23:37:766:pull_down_sensor.c:open_all_sensor_dev:313:smatek open_all_sensor_dev dev_info:0x12d3bdf0, dev_list->id:eb92c47fe161c74b89dk25 2022-10-19 15:23:37:766:core_dev_data.c:sensor_filter:256:dev_filter:pc 2022-10-19 15:23:37:766:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:37:766:core_dev_data.c:sensor_filter:256:dev_filter:dd 2022-10-19 15:23:37:767:core_dev_data.c:sensor_filter:256:dev_filter:pc 2022-10-19 15:23:37:767:core_dev_data.c:sensor_filter:256:dev_filter:dd 2022-10-19 15:23:37:767:core_dev_data.c:sensor_filter:256:dev_filter:dlq 2022-10-19 15:23:37:767:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:37:767:core_dev_data.c:sensor_filter:256:dev_filter:wk 2022-10-19 15:23:37:767:core_dev_data.c:sensor_filter:256:dev_filter:cz 2022-10-19 15:23:37:767:core_dev_data.c:sensor_filter:256:dev_filter:wk 2022-10-19 15:23:37:767:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:37:767:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:37:767:core_dev_data.c:sensor_filter:256:dev_filter:dd 2022-10-19 15:23:37:767:core_dev_data.c:sensor_filter:256:dev_filter:wsdcg 2022-10-19 15:23:37:767:pull_down_sensor.c:get_brief_sensor_devices:345:dev_list[i].online_stat 1 dev_list[i].name = WI-FI Temperature & Humidity Sensor, dev_list[i].category = wsdcg 2022-10-19 15:23:37:767:pull_down_sensor.c:open_all_sensor_dev:270:open_all_sensor_dev:wsdcg [10-19 15:23:37:651 TUYA D][test_home_ctrl_thtb_sensor.c:91] dev_id:ebc90e9813ffde4148tcvg, support 15 dps: [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:temp_unit_convert, mode:0, type:3 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_common_show.c:39] enum:, support total 2 enums: [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_common_show.c:42] c [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_common_show.c:42] f [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:maxtemp_set, mode:0, type:1 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_common_show.c:33] int min:-200, max:600, step:1, scale:1, value:0 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:minitemp_set, mode:0, type:1 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_common_show.c:33] int min:-200, max:600, step:1, scale:1, value:0 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:maxhum_set, mode:0, type:1 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_common_show.c:33] int min:0, max:100, step:1, scale:0, value:0 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:minihum_set, mode:0, type:1 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_common_show.c:33] int min:0, max:100, step:1, scale:0, value:0 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:temp_periodic_report, mode:0, type:1 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_common_show.c:33] int min:1, max:120, step:1, scale:0, value:0 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:hum_periodic_report, mode:0, type:1 [10-19 15:23:37:651 TUYA D][tuya_home_ctrl_common_show.c:33] int min:1, max:120, step:1, scale:0, value:0 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:temp_sensitivity, mode:0, type:1 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:33] int min:3, max:20, step:1, scale:1, value:0 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:hum_sensitivity, mode:0, type:1 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:33] int min:3, max:20, step:1, scale:0, value:0 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:va_temperature, mode:2, type:1 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:33] int min:-200, max:600, step:1, scale:1, value:0 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:va_humidity, mode:2, type:1 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:33] int min:0, max:100, step:1, scale:0, value:0 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:battery_state, mode:2, type:3 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:39] enum:, support total 3 enums: [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:42] low [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:42] middle [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:42] high [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:battery_percentage, mode:2, type:1 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:33] int min:0, max:100, step:1, scale:0, value:0 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:temp_alarm, mode:2, type:3 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:39] enum:, support total 3 enums: [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:42] loweralarm [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:42] upperalarm [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:42] cancel [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_dev.c:846] dp_code:hum_alarm, mode:2, type:3 [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:39] enum:, support total 3 enums: [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:42] loweralarm [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:42] upperalarm [10-19 15:23:37:652 TUYA D][tuya_home_ctrl_common_show.c:42] cancel 2022-10-19 15:23:37:769:pull_down_sensor.c:open_all_sensor_dev:313:smatek open_all_sensor_dev dev_info:0x12d3c190, dev_list->id:ebc90e9813ffde4148tcvg 2022-10-19 15:23:37:769:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:37:769:core_dev_data.c:sensor_filter:256:dev_filter:dj 2022-10-19 15:23:37:769:core_dev_data.c:sensor_filter:256:dev_filter:kg 2022-10-19 15:23:37:769:core_dev_data.c:sensor_filter:256:dev_filter:wk 2022-10-19 15:23:37:769:core_dev_data.c:sensor_filter:256:dev_filter:tdq 2022-10-19 15:23:37:769:core_dev_data.c:sensor_filter:256:dev_filter:kg 2022-10-19 15:23:37:769:core_dev_data.c:sensor_filter:256:dev_filter:cz 2022-10-19 15:23:37:769:core_dev_data.c:sensor_filter:256:dev_filter:kg 2022-10-19 15:23:37:769:core_dev_data.c:sensor_filter:256:dev_filter:kg [10-19 15:23:37:664 TUYA D][iot_httpc.c:596] Decode Rev:{"result":true,"t":1666164217,"success":true} [10-19 15:23:37:664 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:37:665 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:37:665 TUYA D][gw_http_report_meta.c:119] meta rpt {"metas":"{\"lanIp\":\"192.168.3.106\"}"} ret 0 cnt 0 [10-19 15:23:37:665 TUYA D][thread_pool_temp.c:200] thread 68004130 END [10-19 15:23:37:665 TUYA D][gw_async_task.c:93] no msg to rpt [10-19 15:23:37:665 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:37:665 TUYA D][thread_pool_temp.c:143] put thread 0x7f94001600 [10-19 15:23:37:665 TUYA D][thread_pool_temp.c:151] temp thread total:7 used:4 [10-19 15:23:37:695 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{"fail":["6c5005ca9f24c2b540xvlo","eb6ecb092720943cd7nfla","6c0094b881e56546a7d52s","6ca44bf75a687b0aecgwuy","6c214989a443b2dd90a4or","6cc9a0a0f9425c382btujz","6c969031d409e86a781tlx","6c4ca30af981d36459nk3o","6c22f40a1acb1885b59qaq","6c6a927c9fe1cf0c9aui5u","6c68477bf37381b524340j","6c6c5515b325780527hx9l","6c79c0b9048783677fr8zk","6c13b32e91fd726b8425ei"],"nodes":[],"success":[]},"t":1666164217,"success":true} [10-19 15:23:37:695 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:37:695 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:37:695 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:37:695 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:37:695 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6c5005ca9f24c2b540xvlo is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node eb6ecb092720943cd7nfla is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6c0094b881e56546a7d52s is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6ca44bf75a687b0aecgwuy is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6c214989a443b2dd90a4or is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6cc9a0a0f9425c382btujz is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6c969031d409e86a781tlx is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6c4ca30af981d36459nk3o is not allow [10-19 15:23:37:696 TUYA D][http_manager.c:135] http_send done [10-19 15:23:37:696 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6c22f40a1acb1885b59qaq is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6c6a927c9fe1cf0c9aui5u is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6c68477bf37381b524340j is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6c6c5515b325780527hx9l is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6c79c0b9048783677fr8zk is not allow [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:344] node 6c13b32e91fd726b8425ei is not allow [10-19 15:23:37:696 TUYA D][simplekv.c:1211] read key:lan_nd_attr isFuzzy:0 skipCnt:0 [10-19 15:23:37:696 TUYA D][simplekv.c:1251] find key:14 lan_nd_attr [10-19 15:23:37:696 TUYA D][simplekv.c:1280] key:lan_nd_attr find value.Len:16 [10-19 15:23:37:696 TUYA D][tuya_lan_dev_localkey.c:89] __localkey_get_rsp [10-19 15:23:37:697 TUYA D][tuya_lan_dev_localkey.c:113] __localkey_get_rsp num=14 [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:568] local key get cb 14 [10-19 15:23:37:697 TUYA D][thread_pool_temp.c:200] thread 80002db0 END [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6c5005ca9f24c2b540xvlo is cannot get lk [10-19 15:23:37:697 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:37:697 TUYA D][thread_pool_temp.c:143] put thread 0x7f8400f900 [10-19 15:23:37:697 TUYA D][thread_pool_temp.c:151] temp thread total:7 used:3 [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6c6c5515b325780527hx9l is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6c4ca30af981d36459nk3o is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6c0094b881e56546a7d52s is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6c6a927c9fe1cf0c9aui5u is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6c13b32e91fd726b8425ei is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6c68477bf37381b524340j is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6c969031d409e86a781tlx is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6c79c0b9048783677fr8zk is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6cc9a0a0f9425c382btujz is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6ca44bf75a687b0aecgwuy is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id eb6ecb092720943cd7nfla is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6c22f40a1acb1885b59qaq is cannot get lk [10-19 15:23:37:697 TUYA D][tuya_lan_dev_list_core.c:537] id 6c214989a443b2dd90a4or is cannot get lk [10-19 15:23:37:799 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:37:799 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:37:881 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:37:881 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:37:881 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:37:881 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:37:881 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:37:881 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/162615470435b99f0456c.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:37:881 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:37:881 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:37:881 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:37:881 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:37:881 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:38:86 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:38:86 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:38:86 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:38:86 TUYA D][http_manager.c:135] http_send done [10-19 15:23:38:86 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:38:150 TUYA D][iot_httpc.c:596] Decode Rev:{"result":[{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":0,"dps":[],"success":true,"hasNext":false},{"total":89,"dps":[{"timeStamp":1666161586845,"devId":"ebc90e9813ffde4148tcvg","dpId":1,"rowkey":"cff4845egvct8414edff3189 [10-19 15:23:38:151 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:38:151 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:38:151 TUYA D][tuya_ctrl_dp_log.c:439] event sync type: 5 2022-10-19 15:23:38:268:tuya_home_control_sync.c:tuya_home_control_all_info_sync_event:113: tuya_home_control_all_info_sync_event type:5 [10-19 15:23:38:152 TUYA D][thread_pool_temp.c:200] thread 94001420 END [10-19 15:23:38:152 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:38:152 TUYA D][thread_pool_temp.c:143] put thread 0x7f68000ce0 [10-19 15:23:38:152 TUYA D][thread_pool_temp.c:151] temp thread total:7 used:2 [10-19 15:23:38:217 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{"success":["eb1552c6f83a6b59edmyes"],"fail":["6c5005ca9f24c2b540xvlo","eb6ecb092720943cd7nfla","6c22f40a1acb1885b59qaq","6c6a927c9fe1cf0c9aui5u","6c0094b881e56546a7d52s","6c68477bf37381b524340j","6c79c0b9048783677fr8zk","6c13b32e91fd726b8425ei","6ca44bf75a687b0aecgwuy","6c214989a443b2dd90a4or","6cc9a0a0f9425c382btujz","6c969031d409e86a781tlx"],"keyMap":{"eb1552c6f83a6b59edmyes":"dc1fe2dadc9737a5"}},"t":1666164218,"success":true} [10-19 15:23:38:217 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:38:217 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:38:217 TUYA D][simplekv.c:1340] delete key:cls_local_key isFuzzy:0 [10-19 15:23:38:218 TUYA D][simplekv.c:1346] cnt:17 delete bit arr len:1 [10-19 15:23:38:218 TUYA D][lan_cluster_master_core.c:1179] __on_node_ack num[13]. hash map len=12 [10-19 15:23:38:218 TUYA D][lan_cluster_master_core.c:1307] node [6c5005ca9f24c2b540xvlo]report. st[4] [10-19 15:23:38:218 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c5005ca9f24c2b540xvlo st:4 [10-19 15:23:38:218 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c5005ca9f24c2b540xvlo st:4 [10-19 15:23:38:218 TUYA D][lan_dp_report_sync_master.c:329] node 6c5005ca9f24c2b540xvlo not found omit [10-19 15:23:38:218 TUYA D][lan_cluster_master_core.c:1193] node [6c5005ca9f24c2b540xvlo] not allow join [10-19 15:23:38:218 TUYA D][lan_cluster_master_core.c:1307] node [eb6ecb092720943cd7nfla]report. st[4] [10-19 15:23:38:218 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node eb6ecb092720943cd7nfla st:4 [10-19 15:23:38:218 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node eb6ecb092720943cd7nfla st:4 [10-19 15:23:38:218 TUYA D][lan_dp_report_sync_master.c:329] node eb6ecb092720943cd7nfla not found omit [10-19 15:23:38:218 TUYA D][lan_cluster_master_core.c:1193] node [eb6ecb092720943cd7nfla] not allow join [10-19 15:23:38:218 TUYA D][lan_cluster_master_core.c:1307] node [6c22f40a1acb1885b59qaq]report. st[4] [10-19 15:23:38:218 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c22f40a1acb1885b59qaq st:4 [10-19 15:23:38:218 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c22f40a1acb1885b59qaq st:4 [10-19 15:23:38:218 TUYA D][lan_dp_report_sync_master.c:329] node 6c22f40a1acb1885b59qaq not found omit [10-19 15:23:38:218 TUYA D][lan_cluster_master_core.c:1193] node [6c22f40a1acb1885b59qaq] not allow join [10-19 15:23:38:218 TUYA D][lan_cluster_master_core.c:1307] node [6c6a927c9fe1cf0c9aui5u]report. st[4] [10-19 15:23:38:218 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c6a927c9fe1cf0c9aui5u st:4 [10-19 15:23:38:218 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c6a927c9fe1cf0c9aui5u st:4 [10-19 15:23:38:218 TUYA D][lan_dp_report_sync_master.c:329] node 6c6a927c9fe1cf0c9aui5u not found omit [10-19 15:23:38:218 TUYA D][lan_cluster_master_core.c:1193] node [6c6a927c9fe1cf0c9aui5u] not allow join [10-19 15:23:38:218 TUYA D][lan_cluster_master_core.c:1307] node [6c0094b881e56546a7d52s]report. st[4] [10-19 15:23:38:218 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c0094b881e56546a7d52s st:4 [10-19 15:23:38:218 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c0094b881e56546a7d52s st:4 [10-19 15:23:38:218 TUYA D][lan_dp_report_sync_master.c:329] node 6c0094b881e56546a7d52s not found omit [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1193] node [6c0094b881e56546a7d52s] not allow join [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1307] node [6c68477bf37381b524340j]report. st[4] [10-19 15:23:38:219 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c68477bf37381b524340j st:4 [10-19 15:23:38:219 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c68477bf37381b524340j st:4 [10-19 15:23:38:219 TUYA D][lan_dp_report_sync_master.c:329] node 6c68477bf37381b524340j not found omit [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1193] node [6c68477bf37381b524340j] not allow join [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1307] node [6c79c0b9048783677fr8zk]report. st[4] [10-19 15:23:38:219 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c79c0b9048783677fr8zk st:4 [10-19 15:23:38:219 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c79c0b9048783677fr8zk st:4 [10-19 15:23:38:219 TUYA D][lan_dp_report_sync_master.c:329] node 6c79c0b9048783677fr8zk not found omit [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1193] node [6c79c0b9048783677fr8zk] not allow join [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1307] node [6c13b32e91fd726b8425ei]report. st[4] [10-19 15:23:38:219 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c13b32e91fd726b8425ei st:4 [10-19 15:23:38:219 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c13b32e91fd726b8425ei st:4 [10-19 15:23:38:219 TUYA D][lan_dp_report_sync_master.c:329] node 6c13b32e91fd726b8425ei not found omit [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1193] node [6c13b32e91fd726b8425ei] not allow join [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1307] node [6ca44bf75a687b0aecgwuy]report. st[4] [10-19 15:23:38:219 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6ca44bf75a687b0aecgwuy st:4 [10-19 15:23:38:219 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6ca44bf75a687b0aecgwuy st:4 [10-19 15:23:38:219 TUYA D][lan_dp_report_sync_master.c:329] node 6ca44bf75a687b0aecgwuy not found omit [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1193] node [6ca44bf75a687b0aecgwuy] not allow join [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1307] node [6c214989a443b2dd90a4or]report. st[4] [10-19 15:23:38:219 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c214989a443b2dd90a4or st:4 [10-19 15:23:38:219 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c214989a443b2dd90a4or st:4 [10-19 15:23:38:219 TUYA D][lan_dp_report_sync_master.c:329] node 6c214989a443b2dd90a4or not found omit [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1193] node [6c214989a443b2dd90a4or] not allow join [10-19 15:23:38:219 TUYA D][lan_cluster_master_core.c:1307] node [6cc9a0a0f9425c382btujz]report. st[4] [10-19 15:23:38:219 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6cc9a0a0f9425c382btujz st:4 [10-19 15:23:38:219 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6cc9a0a0f9425c382btujz st:4 [10-19 15:23:38:220 TUYA D][lan_dp_report_sync_master.c:329] node 6cc9a0a0f9425c382btujz not found omit [10-19 15:23:38:220 TUYA D][lan_cluster_master_core.c:1193] node [6cc9a0a0f9425c382btujz] not allow join [10-19 15:23:38:220 TUYA D][lan_cluster_master_core.c:1307] node [6c969031d409e86a781tlx]report. st[4] [10-19 15:23:38:220 TUYA D][lan_dev_base_master.c:1081] __lan_node_change_single_cb node 6c969031d409e86a781tlx st:4 [10-19 15:23:38:220 TUYA D][lan_dp_report_sync_master.c:321] __lan_node_change_single_cb node 6c969031d409e86a781tlx st:4 [10-19 15:23:38:220 TUYA D][lan_dp_report_sync_master.c:329] node 6c969031d409e86a781tlx not found omit [10-19 15:23:38:220 TUYA D][lan_cluster_master_core.c:1193] node [6c969031d409e86a781tlx] not allow join [10-19 15:23:38:220 TUYA D][simplekv.c:1387] key:cls_local_key not find [10-19 15:23:38:220 TUYA D][simplekv.c:1211] read key:cls_key_cnt isFuzzy:0 skipCnt:0 [10-19 15:23:38:220 TUYA D][simplekv.c:1251] find key:15 cls_key_cnt [10-19 15:23:38:220 TUYA D][simplekv.c:1280] key:cls_key_cnt find value.Len:32 [10-19 15:23:38:220 TUYA D][simplekv.c:1211] read key:cls_lck_key_a isFuzzy:0 skipCnt:0 [10-19 15:23:38:220 TUYA D][simplekv.c:1251] find key:16 cls_lck_key_a [10-19 15:23:38:220 TUYA D][simplekv.c:1280] key:cls_lck_key_a find value.Len:48 [10-19 15:23:38:220 TUYA D][simplekv.c:1211] read key:cls_key_cnt isFuzzy:0 skipCnt:0 [10-19 15:23:38:220 TUYA D][simplekv.c:1251] find key:15 cls_key_cnt [10-19 15:23:38:220 TUYA D][simplekv.c:1280] key:cls_key_cnt find value.Len:32 [10-19 15:23:38:220 TUYA D][simplekv.c:1211] read key:cls_lck_key_a isFuzzy:0 skipCnt:0 [10-19 15:23:38:220 TUYA D][simplekv.c:1251] find key:16 cls_lck_key_a [10-19 15:23:38:220 TUYA D][simplekv.c:1280] key:cls_lck_key_a find value.Len:48 [10-19 15:23:38:220 TUYA D][simplekv.c:1211] read key:cls_key_cnt isFuzzy:0 skipCnt:0 [10-19 15:23:38:221 TUYA D][simplekv.c:1251] find key:15 cls_key_cnt [10-19 15:23:38:221 TUYA D][simplekv.c:1280] key:cls_key_cnt find value.Len:32 [10-19 15:23:38:221 TUYA D][simplekv.c:1211] read key:cls_lck_key_a isFuzzy:0 skipCnt:0 [10-19 15:23:38:221 TUYA D][simplekv.c:1251] find key:16 cls_lck_key_a [10-19 15:23:38:221 TUYA D][simplekv.c:1280] key:cls_lck_key_a find value.Len:48 [10-19 15:23:38:221 TUYA D][thread_pool_temp.c:200] thread 68000a90 END [10-19 15:23:38:221 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:38:221 TUYA D][thread_pool_temp.c:143] put thread 0x7f84004c00 [10-19 15:23:38:221 TUYA D][thread_pool_temp.c:151] temp thread total:7 used:1 [10-19 15:23:38:275 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:38:275 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:38:275 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:38:275 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:38:275 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:38:275 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/162615470435b99f0456c.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:38:275 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:38:275 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:38:275 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:38:275 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:38:275 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:38:348 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:38:348 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:38:458 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:38:458 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:38:458 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:38:458 TUYA D][http_manager.c:135] http_send done [10-19 15:23:38:458 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:38:644 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:38:644 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:38:644 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:38:644 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:38:644 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:38:644 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/162615470435b99f0456c.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:38:644 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:38:644 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:38:645 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:38:645 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:38:645 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:38:665 TUYA D][gw_async_task.c:231] gw_http_report_async 0x57f6d0 (nil) [10-19 15:23:38:665 TUYA D][gw_async_task.c:112] node 0x57f6d0 (nil) use thr 0 [10-19 15:23:38:665 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94001600 0x5dc158 600015d0 [10-19 15:23:38:665 TUYA D][thread_pool_temp.c:607] temp run 0x5dc158 600015d0 [10-19 15:23:38:665 TUYA D][thread_pool_temp.c:197] run temp 0x5dc158 600015d0 in thread 94001420 BEGIN [10-19 15:23:38:665 TUYA D][gw_async_task.c:53] call cb 0x57f6d0 (nil), idx 0 [10-19 15:23:38:665 TUYA D][iot_httpc.c:929] Post Data: {"metas":"{\"z3Lqi\":true}","t":1666164218} [10-19 15:23:38:666 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.meta.save&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164218&v=1.0&sign=1a807fbdc3f5efab18c831863671bba3 [10-19 15:23:38:666 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:38:666 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:38:666 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:38:666 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:38:767 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{"abilityProperty":"{\"condType\":[7,13],\"actionType\":[\"dpStep\",\"deviceGroupDpIssue\"],\"unSupportActionType\":[\"irIssue\",\"irIssueVii\"]}","gwId":"eb1552c6f83a6b59edmyes"},"t":1666164218,"success":true} [10-19 15:23:38:767 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:38:767 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:38:767 TUYA D][thread_pool_temp.c:200] thread 68000da0 END [10-19 15:23:38:767 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:38:767 TUYA D][thread_pool_temp.c:143] put thread 0x7f8400da30 [10-19 15:23:38:767 TUYA D][thread_pool_temp.c:151] temp thread total:7 used:1 [10-19 15:23:38:822 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:38:822 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:38:822 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:38:822 TUYA D][http_manager.c:135] http_send done [10-19 15:23:38:822 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:38:872 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:38:872 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:38:872 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:38:872 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:38:872 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:38:872 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:38:872 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:38:872 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:38:877 TUYA D][rcd_file.c:548] [ty_rcd]__flush_timer_cb start [10-19 15:23:38:877 TUYA D][thread_pool_temp.c:696] temp run add 0x7f94001430 0x576444 94020fb0 [10-19 15:23:38:877 TUYA D][thread_pool_temp.c:607] temp run 0x576444 94020fb0 [10-19 15:23:38:877 TUYA D][thread_pool_temp.c:197] run temp 0x576444 94020fb0 in thread 940013f0 BEGIN [10-19 15:23:38:878 TUYA D][rcd_file.c:533] [ty_rcd] __rcd_db_flush start. [10-19 15:23:38:883 TUYA D][rcd_file.c:538] [ty_rcd] __rcd_db_flush end. [10-19 15:23:38:883 TUYA D][thread_pool_temp.c:200] thread 940013f0 END [10-19 15:23:38:884 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:38:884 TUYA D][thread_pool_temp.c:143] put thread 0x7f94001430 [10-19 15:23:38:884 TUYA D][thread_pool_temp.c:151] temp thread total:7 used:1 [10-19 15:23:39:12 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:39:12 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:39:12 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:39:12 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:39:12 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:39:12 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/162615470435b99f0456c.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:39:12 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:39:12 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:39:12 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:39:12 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:39:12 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:39:211 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:39:211 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:39:211 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:39:211 TUYA D][http_manager.c:135] http_send done [10-19 15:23:39:211 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:39:408 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:39:408 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:39:408 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:39:408 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:39:408 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:39:408 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/162615470435b99f0456c.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:39:408 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/ee86ae8faf09f6aa8893dcbaa9b8622a.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:39:408 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:39:408 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:39:408 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:39:408 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:39:408 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:39:585 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:39:585 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:39:585 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:39:585 TUYA D][http_manager.c:135] http_send done [10-19 15:23:39:585 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:39:649 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:39:649 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:39:774 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:39:774 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:39:774 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:39:774 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:39:774 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:39:774 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/ee86ae8faf09f6aa8893dcbaa9b8622a.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:39:774 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:39:774 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:39:774 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:39:774 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:39:775 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:39:955 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:39:955 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:39:955 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:39:955 TUYA D][http_manager.c:135] http_send done [10-19 15:23:39:955 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:40:78 TUYA D][iot_httpc.c:596] Decode Rev:{"result":true,"t":1666164220,"success":true} [10-19 15:23:40:78 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:40:79 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:40:79 TUYA D][gw_http_report_meta.c:119] meta rpt {"metas":"{\"z3Lqi\":true}"} ret 0 cnt 0 [10-19 15:23:40:79 TUYA D][thread_pool_temp.c:200] thread 94001420 END [10-19 15:23:40:79 TUYA D][gw_async_task.c:93] no msg to rpt [10-19 15:23:40:79 TUYA N][uni_msg_queue.c:286] last_cb:0x581f94 [10-19 15:23:40:79 TUYA D][thread_pool_temp.c:143] put thread 0x7f94001600 [10-19 15:23:40:79 TUYA D][thread_pool_temp.c:151] temp thread total:7 used:0 [10-19 15:23:40:139 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:40:139 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:40:139 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:40:139 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:40:139 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:40:139 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/ee86ae8faf09f6aa8893dcbaa9b8622a.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:40:139 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:40:139 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:40:139 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:40:139 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:40:139 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:40:319 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:40:319 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:40:319 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:40:319 TUYA D][http_manager.c:135] http_send done [10-19 15:23:40:319 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:40:503 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:40:503 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:40:503 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:40:503 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:40:503 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:40:503 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/ee86ae8faf09f6aa8893dcbaa9b8622a.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:40:503 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:40:503 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:40:503 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:40:503 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:40:503 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:40:547 TUYA D][subdev_hb_ol.c:903] start heartbeat qeury process... [10-19 15:23:40:692 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:40:692 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:40:692 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:40:692 TUYA D][http_manager.c:135] http_send done [10-19 15:23:40:692 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:40:894 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:40:894 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:40:894 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:40:894 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:40:894 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:40:894 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/ee86ae8faf09f6aa8893dcbaa9b8622a.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:40:894 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:40:894 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:40:894 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:40:894 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:40:894 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:41:69 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:41:69 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:41:69 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:41:69 TUYA D][http_manager.c:135] http_send done [10-19 15:23:41:69 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:41:85 TUYA D][gw_reli_http_report.c:94] no msg to rpt [10-19 15:23:41:247 TUYA D][simplekv.c:1211] read key:000004brzg_ver isFuzzy:0 skipCnt:0 [10-19 15:23:41:247 TUYA D][simplekv.c:1247] no key find [10-19 15:23:41:247 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [10-19 15:23:41:247 TUYA D][simplekv.c:1328] __read_kv_with_decode fail. -3 [10-19 15:23:41:247 TUYA D][tuya_svc_upgrade_http.c:125] schema get:{"schemaId":"000004brzg","version":""} [10-19 15:23:41:247 TUYA D][iot_httpc.c:929] Post Data: {"schemaId":"000004brzg","version":"","t":1666164221} [10-19 15:23:41:247 TUYA D][iot_httpc.c:941] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.schema.newest.get&devId=eb1552c6f83a6b59edmyes&et=1&t=1666164221&v=1.0&sign=c4182d1291fbd3f8c04d0fc8ca05ba7e [10-19 15:23:41:248 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443 -->> [10-19 15:23:41:248 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 0 [10-19 15:23:41:248 TUYA D][uni_network.c:181] use dynamic dns ip 44.231.176.168 for domain a2.tuyaus.com [10-19 15:23:41:248 TUYA D][httpc.c:477] ----got ipaddr:44,231,176,168 [10-19 15:23:41:265 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:41:265 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:41:265 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:41:265 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:41:265 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:41:265 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/ee86ae8faf09f6aa8893dcbaa9b8622a.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:41:265 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/icon/ay1535193862006vs1if/e9a902f91a369853f950fb5d8337d991.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:41:265 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:41:265 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:41:265 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:41:266 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:41:266 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:41:432 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443 --<< ,r:0 [10-19 15:23:41:432 TUYA D][tuya_tls.c:1253] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [10-19 15:23:41:432 TUYA D][tuya_tls.c:1296] TUYA_TLS Begin Connect a2.tuyaus.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [10-19 15:23:41:432 TUYA D][tuya_tls.c:1360] load tuya cert. [10-19 15:23:41:432 TUYA D][tuya_tls.c:1365] parse crt <0> len <2002> ret <0> [10-19 15:23:41:432 TUYA D][tuya_tls.c:1365] parse crt <1> len <1028> ret <0> [10-19 15:23:41:432 TUYA D][tuya_iot_com_api.c:259] tuya public url [10-19 15:23:41:433 TUYA D][tuya_tls.c:1475] socket fd is set. set to inner send/recv to handshake [10-19 15:23:41:441 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:41:441 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:41:441 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:41:441 TUYA D][http_manager.c:135] http_send done [10-19 15:23:41:441 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:41:621 TUYA D][tuya_tls.c:1520] handshake finish for a2.tuyaus.com. set send/recv to user set [10-19 15:23:41:621 TUYA D][tuya_tls.c:1535] TUYA_TLS Success Connect a2.tuyaus.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [10-19 15:23:41:634 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:41:634 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:41:634 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:41:634 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:41:634 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:41:634 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1535193862006vs1if/e9a902f91a369853f950fb5d8337d991.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:41:634 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:41:634 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:41:634 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:41:634 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:41:634 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:41:813 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:41:813 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:41:813 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:41:813 TUYA D][http_manager.c:135] http_send done [10-19 15:23:41:813 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:41:998 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:41:998 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:41:998 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:41:998 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:41:998 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:41:998 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1535193862006vs1if/e9a902f91a369853f950fb5d8337d991.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:41:998 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:41:998 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:41:998 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:41:998 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:41:998 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:42:4 TUYA D][iot_httpc.c:596] Decode Rev:{"result":{"schema":"","schemaId":"000004brzg"},"t":1666164222,"success":true} [10-19 15:23:42:5 TUYA D][tuya_tls.c:1615] TUYA_TLS Disconnect ENTER [10-19 15:23:42:5 TUYA D][tuya_tls.c:1670] TUYA_TLS Disconnect Success [10-19 15:23:42:5 TUYA D][tuya_svc_upgrade_http.c:133] schema get result:{"schema":"","schemaId":"000004brzg"} [10-19 15:23:42:5 TUYA D][tuya_svc_schema_upgrade.c:130] schema[000004brzg] ver not update [10-19 15:23:42:202 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:42:202 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:42:202 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:42:202 TUYA D][http_manager.c:135] http_send done [10-19 15:23:42:202 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:42:389 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:42:389 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:42:389 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:42:389 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:42:389 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:42:389 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1535193862006vs1if/e9a902f91a369853f950fb5d8337d991.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:42:389 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:42:389 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:42:389 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:42:389 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:42:389 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:42:567 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:42:567 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:42:567 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:42:567 TUYA D][http_manager.c:135] http_send done [10-19 15:23:42:567 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:42:761 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:42:761 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:42:761 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:42:761 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:42:761 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:42:761 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1535193862006vs1if/e9a902f91a369853f950fb5d8337d991.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:42:761 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:42:761 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:42:761 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:42:761 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:42:761 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:42:997 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:42:997 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:42:997 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:42:997 TUYA D][http_manager.c:135] http_send done [10-19 15:23:42:997 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:43:192 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:43:192 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:43:192 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:43:192 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:43:192 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:43:192 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1535193862006vs1if/e9a902f91a369853f950fb5d8337d991.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:43:192 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/icon/ay15554925906369PM9S/4b5d40431044b1174d496977a083af4f.jpg?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:43:192 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:43:192 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:43:192 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:43:192 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:43:193 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:43:373 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:43:373 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:43:373 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:43:373 TUYA D][http_manager.c:135] http_send done [10-19 15:23:43:373 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:43:591 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:43:591 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:43:591 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:43:591 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:43:591 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:43:591 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/icon/ay15554925906369PM9S/4b5d40431044b1174d496977a083af4f.jpg?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:43:591 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:43:591 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:43:591 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:43:591 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:43:592 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:43:811 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:43:811 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:43:811 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:43:811 TUYA D][http_manager.c:135] http_send done [10-19 15:23:43:811 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:43:997 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:43:997 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:43:997 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:43:997 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:43:997 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:43:997 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/icon/ay15554925906369PM9S/4b5d40431044b1174d496977a083af4f.jpg?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:43:997 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:43:997 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:43:997 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:43:998 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:43:998 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:44:175 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:44:175 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:44:175 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:44:175 TUYA D][http_manager.c:135] http_send done [10-19 15:23:44:175 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:44:365 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:44:365 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:44:365 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:44:365 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:44:365 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:44:365 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/icon/ay15554925906369PM9S/4b5d40431044b1174d496977a083af4f.jpg?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:44:365 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:44:365 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:44:365 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:44:365 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:44:365 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:44:536 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:44:536 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:44:536 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:44:536 TUYA D][http_manager.c:135] http_send done [10-19 15:23:44:536 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:44:715 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:44:715 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:44:715 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:44:715 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:44:715 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:44:715 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/icon/ay15554925906369PM9S/4b5d40431044b1174d496977a083af4f.jpg?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:44:715 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:44:715 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:44:715 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:44:715 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:44:716 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:44:895 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:44:895 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:44:895 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:44:895 TUYA D][http_manager.c:135] http_send done [10-19 15:23:44:895 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:45:79 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:45:79 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:45:79 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:45:79 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:45:79 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:45:79 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/icon/ay15554925906369PM9S/4b5d40431044b1174d496977a083af4f.jpg?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:45:79 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/icon/ay1567078882587Wqg0Z/eeb7e37c9e2e8a10860b10ce7021adce.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:45:79 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:45:79 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:45:79 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:45:79 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:45:80 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:45:266 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:45:266 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:45:266 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:45:266 TUYA D][http_manager.c:135] http_send done [10-19 15:23:45:266 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:45:457 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:45:457 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:45:457 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:45:457 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:45:457 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:45:457 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1567078882587Wqg0Z/eeb7e37c9e2e8a10860b10ce7021adce.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:45:457 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:45:457 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:45:457 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:45:458 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:45:458 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:45:635 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:45:635 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:45:635 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:45:635 TUYA D][http_manager.c:135] http_send done [10-19 15:23:45:635 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:45:843 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:45:843 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:45:843 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:45:843 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:45:843 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:45:843 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1567078882587Wqg0Z/eeb7e37c9e2e8a10860b10ce7021adce.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:45:843 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:45:843 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:45:843 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:45:843 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:45:843 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:46:33 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:46:33 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:46:33 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:46:33 TUYA D][http_manager.c:135] http_send done [10-19 15:23:46:33 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:46:217 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:46:217 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:46:217 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:46:217 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:46:218 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:46:218 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1567078882587Wqg0Z/eeb7e37c9e2e8a10860b10ce7021adce.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:46:218 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:46:218 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:46:218 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:46:218 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:46:218 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:46:393 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:46:393 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:46:393 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:46:393 TUYA D][http_manager.c:135] http_send done [10-19 15:23:46:393 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:46:573 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:46:573 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:46:573 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:46:573 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:46:573 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:46:573 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1567078882587Wqg0Z/eeb7e37c9e2e8a10860b10ce7021adce.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:46:573 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:46:573 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:46:573 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:46:573 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:46:573 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:46:766 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:46:766 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:46:766 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:46:766 TUYA D][http_manager.c:135] http_send done [10-19 15:23:46:766 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:46:971 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:46:971 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:46:971 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:46:971 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:46:971 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:46:971 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1567078882587Wqg0Z/eeb7e37c9e2e8a10860b10ce7021adce.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:46:971 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/icon/ay1541560588798qVUG7/c1f66a1ba15a346965a37602b7c2c2b2.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:46:971 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:46:972 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:46:972 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:46:972 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:46:972 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:47:184 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:47:184 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:47:184 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:47:184 TUYA D][http_manager.c:135] http_send done [10-19 15:23:47:184 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:47:368 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:47:368 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:47:368 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:47:368 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:47:368 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:47:368 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1541560588798qVUG7/c1f66a1ba15a346965a37602b7c2c2b2.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:47:368 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:47:368 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:47:368 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:47:368 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:47:369 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:47:548 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:47:548 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:47:548 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:47:548 TUYA D][http_manager.c:135] http_send done [10-19 15:23:47:548 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:47:735 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:47:736 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:47:736 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:47:736 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:47:736 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:47:736 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1541560588798qVUG7/c1f66a1ba15a346965a37602b7c2c2b2.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:47:736 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:47:736 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:47:736 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:47:736 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:47:736 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:47:914 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:47:915 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:47:915 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:47:916 TUYA D][http_manager.c:135] http_send done [10-19 15:23:47:916 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:48:12 TUYA D][subdev_upgrade_schema.c:202] start schema get subdev. [10-19 15:23:48:12 TUYA D][subdev_upgrade_schema.c:237] end schema get subdev, eAction:1, is_got_new:0. [10-19 15:23:48:96 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:48:96 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:48:96 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:48:96 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:48:96 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:48:96 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1541560588798qVUG7/c1f66a1ba15a346965a37602b7c2c2b2.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:48:96 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:48:96 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:48:96 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:48:96 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:48:96 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:48:281 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:48:281 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:48:281 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:48:281 TUYA D][http_manager.c:135] http_send done [10-19 15:23:48:281 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:48:469 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:48:469 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:48:469 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:48:469 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:48:469 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:48:469 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1541560588798qVUG7/c1f66a1ba15a346965a37602b7c2c2b2.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:48:469 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:48:469 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:48:469 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:48:469 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:48:470 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:48:646 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:48:646 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:48:646 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:48:646 TUYA D][http_manager.c:135] http_send done [10-19 15:23:48:646 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:48:831 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:48:831 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:48:831 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:48:831 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:48:831 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:48:831 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1541560588798qVUG7/c1f66a1ba15a346965a37602b7c2c2b2.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:48:831 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/139a072cda7c4a75e20679ad9ecaefcb.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:48:831 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:48:831 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:48:831 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:48:831 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:48:831 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:49:12 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:49:12 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:49:12 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:49:12 TUYA D][http_manager.c:135] http_send done [10-19 15:23:49:12 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:49:214 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:49:214 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:49:214 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:49:214 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:49:214 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:49:215 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/139a072cda7c4a75e20679ad9ecaefcb.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:49:215 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:49:215 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:49:215 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:49:215 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:49:215 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:49:431 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:49:431 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:49:431 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:49:432 TUYA D][http_manager.c:135] http_send done [10-19 15:23:49:432 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:49:656 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:49:656 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:49:656 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:49:656 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:49:656 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:49:656 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/139a072cda7c4a75e20679ad9ecaefcb.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:49:656 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:49:656 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:49:656 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:49:656 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:49:656 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:49:854 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:49:854 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:49:854 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:49:854 TUYA D][http_manager.c:135] http_send done [10-19 15:23:49:854 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:50:42 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:50:42 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:50:42 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:50:42 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:50:42 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:50:42 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/139a072cda7c4a75e20679ad9ecaefcb.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:50:42 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:50:42 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:50:42 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:50:42 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:50:42 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:50:216 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:50:216 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:50:216 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:50:216 TUYA D][http_manager.c:135] http_send done [10-19 15:23:50:216 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:50:401 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:50:401 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:50:401 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:50:401 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:50:401 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:50:401 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/139a072cda7c4a75e20679ad9ecaefcb.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:50:401 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:50:401 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:50:401 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:50:401 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:50:401 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:50:590 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:50:590 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:50:590 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:50:590 TUYA D][http_manager.c:135] http_send done [10-19 15:23:50:590 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:50:774 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:50:775 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:50:775 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:50:775 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:50:775 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:50:775 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1562803410690AUgvL/139a072cda7c4a75e20679ad9ecaefcb.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:50:775 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/icon/ay1525749833414yotNt/e91248a4e9ad897236039c57ba9ad8a6.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:50:775 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:50:775 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:50:775 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:50:775 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:50:775 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:50:953 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:50:953 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:50:953 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:50:953 TUYA D][http_manager.c:135] http_send done [10-19 15:23:50:954 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:51:187 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:51:187 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:51:187 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:51:187 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:51:187 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:51:187 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 0, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1525749833414yotNt/e91248a4e9ad897236039c57ba9ad8a6.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:51:187 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:51:187 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:51:187 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:51:187 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:51:187 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:51:363 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:51:363 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:51:363 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:51:363 TUYA D][http_manager.c:135] http_send done [10-19 15:23:51:363 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:51:552 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:51:552 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:51:552 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:51:552 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:51:552 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:51:552 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 1, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1525749833414yotNt/e91248a4e9ad897236039c57ba9ad8a6.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:51:552 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:51:552 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:51:552 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:51:552 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:51:552 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:52:734 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:52:734 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:52:734 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:52:734 TUYA D][http_manager.c:135] http_send done [10-19 15:23:52:734 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:52:918 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:52:918 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:52:918 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:52:918 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:52:918 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:52:918 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 2, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1525749833414yotNt/e91248a4e9ad897236039c57ba9ad8a6.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:52:918 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:52:918 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:52:918 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:52:918 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:52:918 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:53:18 TUYA D][tuya_svc_schema_upgrade.c:170] next schema get slot 64094. [10-19 15:23:53:101 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:53:101 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:53:101 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:53:101 TUYA D][http_manager.c:135] http_send done [10-19 15:23:53:101 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:53:292 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:53:292 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:53:292 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:53:292 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:53:292 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:53:292 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 3, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1525749833414yotNt/e91248a4e9ad897236039c57ba9ad8a6.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:53:292 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:53:292 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:53:292 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:53:292 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:53:292 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 [10-19 15:23:53:470 TUYA D][httpc.c:815] Connect: imagesd.tuyaus.com Port: 80 --<< ,r:0 [10-19 15:23:53:470 TUYA D][http_manager.c:94] create http session done, session id: 88002c40 [10-19 15:23:53:470 TUYA D][http_manager.c:119] http_send: 88002c40 [10-19 15:23:53:470 TUYA D][http_manager.c:135] http_send done [10-19 15:23:53:470 TUYA D][http_manager.c:146] http_receive: 88002c40 [10-19 15:23:53:654 TUYA D][http_manager.c:158] http_receive: code 308 [10-19 15:23:53:654 TUYA D][http_manager.c:196] http_receive: done 88002c40 [10-19 15:23:53:654 TUYA E][svc_img_http.c:82] g_http_manager http_receive: code 308 [10-19 15:23:53:654 TUYA D][http_manager.c:12] http_session_destory: 88002c40 [10-19 15:23:53:654 TUYA D][http_manager.c:30] http_session_destory done: 0 [10-19 15:23:53:654 TUYA E][svc_img_http.c:219] get_http_manager_session exec error! ret = -1, retry_cnt = 4, url_buf = https://imagesd.tuyaus.com/smart/icon/ay1525749833414yotNt/e91248a4e9ad897236039c57ba9ad8a6.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:53:654 TUYA D][svc_img_http.c:202] url_buf----------:https://imagesd.tuyaus.com/smart/icon/ay1547110530245tcZgC/77971bbb812f5f43189be29347129d88.png?imageMogr2/format/png/thumbnail/42x42 [10-19 15:23:53:654 TUYA D][http_manager.c:38] create http session for url: imagesd.tuyaus.com/, 1 [10-19 15:23:53:654 TUYA D][httpc.c:813] Connect: imagesd.tuyaus.com Port: 80 -->> [10-19 15:23:53:654 TUYA D][uni_network.c:314] unw_gethostbyname imagesd.tuyaus.com, prio 0 [10-19 15:23:53:654 TUYA D][uni_network.c:181] use dynamic dns ip 54.192.76.26 for domain imagesd.tuyaus.com [10-19 15:23:53:654 TUYA D][httpc.c:477] ----got ipaddr:54,192,76,26 ^C / #
