<?xml version="1.0" encoding="UTF-8"?>
Base Device Behavior XML PICS
ZigBee Document 16-02800-000
July 6th, 2016
Copyright (c) ZigBee Alliance, Inc. (1996-2016).  All rights reserved.
508 Second Street, Suite 206 Davis, CA 95616 - USA
http://www.zigbee.org
Permission is granted to members of the ZigBee Alliance to reproduce this document
for their own use or the use of other ZigBee Alliance members only, provided this
notice is included.  All other rights reserved.  Duplication for sale, or for
commercial or for-profit use is strictly prohibited without the prior written consent
of the ZigBee Alliance.
Accepted by
This document has not been accepted for release by the ZigBee Alliance Board of
Directors
Abstract
This document contains the XML PICS for the Base Device Behavior according to the generic
XML PICS schema: 16-03902-003-Generic-PICS-XML-Schema.xsd
Notice of use and disclosure
Copyright © ZigBee Alliance, Inc. (1996-2016). All rights Reserved. This information
within this document is the property of the ZigBee Alliance and its use and
disclosure are restricted.
Elements of ZigBee Alliance specifications may be subject to third party intellectual
property rights, including without limitation, patent, copyright or trademark rights
(such a third party may or may not be a member of ZigBee). ZigBee is not responsible
and shall not be held responsible in any manner for identifying or failing to identify
any or all such third party intellectual property rights.
No right to use any ZigBee name, logo or trademark is conferred herein.  Use of any
ZigBee name, logo or trademark requires membership in the ZigBee Alliance and
compliance with the ZigBee Logo and Trademark Policy and related ZigBee policies.
This document and the information contained herein are provided on an “AS IS” basis
and ZigBee DISCLAIMS ALL WARRANTIES EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO
(A) ANY WARRANTY THAT THE USE OF THE INFORMATION HEREIN WILL NOT INFRINGE ANY RIGHTS
OF THIRD PARTIES (INCLUDING WITHOUT LIMITATION ANY INTELLECTUAL PROPERTY RIGHTS
INCLUDING PATENT, COPYRIGHT OR TRADEMARK RIGHTS) OR (B) ANY IMPLIED WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE OR NONINFRINGEMENT. IN NO
EVENT WILL ZIGBEE BE LIABLE FOR ANY LOSS OF PROFITS, LOSS OF BUSINESS, LOSS OF USE OF
DATA, INTERRUPTION OF BUSINESS, OR FOR ANY OTHER DIRECT, INDIRECT, SPECIAL OR
EXEMPLARY, INCIDENTIAL, PUNITIVE OR CONSEQUENTIAL DAMAGES OF ANY KIND, IN CONTRACT OR
IN TORT, IN CONNECTION WITH THIS DOCUMENT OR THE INFORMATION CONTAINED HEREIN, EVEN
IF ADVISED OF THE POSSIBILITY OF SUCH LOSS OR DAMAGE. All Company, brand and product
names may be trademarks that are the sole property of their respective owners.  
The above notice and this paragraph must be included on all copies of this document
that are made.
PICS Completion Notes
In each PICS <support></support> item use:
  "true"  if the feature is supported, OR
  "false" if the feature is NOT supported
By default all items are not supported (false)
In each PIXIT the <specification></specification> item specify as described
<generalPICS xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="file://./16-03902-003-Generic-PICS-XML-Schema.xsd">
  <pixit label="Internal attributes">
    <pixitItem>
      <itemNumber>IA1</itemNumber>
      <feature>bdbCommissioningGroupID: What is the list of groups the node is able to use for finding and binding?</feature>
      <reference>5.3.1</reference>
      <status>M</status>
      <specification>0xffff</specification>
    </pixitItem>
    <pixitItem>
      <itemNumber>IA2</itemNumber>
      <feature>bdbJoinUsesInstallCodeKey: Does the Trust Center policy require all nodes to join using an install code?</feature>
      <reference>5.3.6</reference>
      <status cond="ZLT1">M</status>
      <specification>True, False</specification>
    </pixitItem>
    <pixitItem>
      <itemNumber>IA3</itemNumber>
      <feature>bdbPrimaryChannelSet: What is the primary channel set?</feature>
      <reference>5.3.10</reference>
      <status>M</status>
      <specification>0x07FFF800</specification>
    </pixitItem>
    <pixitItem>
      <itemNumber>IA4</itemNumber>
      <feature>bdbScanDuration: What is the scan duration?</feature>
      <reference>5.3.11</reference>
      <status>M</status>
      <specification>0x04</specification>
    </pixitItem>
    <pixitItem>
      <itemNumber>IA5</itemNumber>
      <feature>bdbSecondaryChannelSet: What is the secondary channel set?</feature>
      <reference>5.3.12</reference>
      <status>M</status>
    </pixitItem>
    <pixitItem>
      <itemNumber>IA6</itemNumber>
      <feature>bdbTCLinkKeyExchangeAttemptsMax: What is the maximum number of attempts a node will try to exchange its Trust Center link key?</feature>
      <reference>5.3.14</reference>
      <status cond="ZLT2">M</status>
      <status cond="ZLT3">M</status>
      <specification>0x03</specification>
    </pixitItem>
    <pixitItem>
      <itemNumber>IA7</itemNumber>
      <feature>bdbTCLinkKeyExchangeMethod: What is the Trust Center link key exchange method?</feature>
      <reference>5.3.15</reference>
      <specification>0x00</specification>
    </pixitItem>
    <pixitItem>
      <itemNumber>IA8</itemNumber>
      <feature>bdbTrustCenterNodeJoinTimeout: What is the Trust Center node join timeout?</feature>
      <reference>5.3.16</reference>
      <specification>8-bit integer</specification>
    </pixitItem>
    <pixitItem>
      <itemNumber>IA9</itemNumber>
      <feature>bdbTrustCenterRequireKeyExchange: Does the Trust Center’s policy require a node to exchange its initial link key with a new link key generated by the Trust Center?</feature>
      <reference>5.3.17</reference>
    </pixitItem>
  </pixit>
  <pixit label="Commissioning combinations">
    <pixitItem>
      <itemNumber>CC1</itemNumber>
      <feature>Can the product be stimulated to invoke touchlink commissioning only?</feature>
      <status>O</status>
      <specification>Yes/No</specification>
    </pixitItem>
    <pixitItem>
      <itemNumber>CC2</itemNumber>
      <feature>Can the product be stimulated to invoke network formation only?</feature>
      <status>O</status>
    </pixitItem>
    <pixitItem>
      <itemNumber>CC3</itemNumber>
      <feature>Can the product be stimulated to invoke network steering only?</feature>
      <status>O</status>
      <specification>Yes</specification>
    </pixitItem>
    <pixitItem>
      <itemNumber>CC4</itemNumber>
      <feature>Can the product be stimulated to invoke finding &amp; binding only?</feature>
      <status>O</status>
    </pixitItem>
    <pixitItem>
      <itemNumber>CC5</itemNumber>
      <feature>Can the product be stimulated to invoke touchlink commissioning followed by network steering?</feature>
      <status>O</status>
    </pixitItem>
    <pixitItem>
      <itemNumber>CC6</itemNumber>
      <feature>Can the product be stimulated to invoke network formation followed by network steering?</feature>
      <status>O</status>
    </pixitItem>
    <pixitItem>
      <itemNumber>CC7</itemNumber>
      <feature>Can the product be stimulated to invoke network steering followed by network formation?</feature>
      <status>O</status>
    </pixitItem>
    <pixitItem>
      <itemNumber>CC8</itemNumber>
      <feature>Can the product be stimulated to reset before network formation?</feature>
      <status>O</status>
    </pixitItem>
    <pixitItem>
      <itemNumber>CC9</itemNumber>
      <feature>Can the product be stimulated to automatically form a network upon startup when factory new?</feature>
      <status>O</status>
    </pixitItem>
  </pixit>
  <pixit label="Miscellaneous">
    <pixitItem>
      <itemNumber>M1</itemNumber>
      <feature>Can the node disable network steering via local application trigger?</feature>
      <status>O</status>
    </pixitItem>
    <pixitItem>
      <itemNumber>M2</itemNumber>
      <feature>Can the node store more than one NWK outgoing frame counters?</feature>
      <status>O</status>
    </pixitItem>
    <pixitItem>
      <itemNumber>M3.1</itemNumber>
      <feature>If supported, give the identifier of a cluster that has at least one writable attribute.</feature>
      <status>O</status>
      <specification>Cluster ID or N/A</specification>
    </pixitItem>
    <pixitItem>
      <itemNumber>M3.2</itemNumber>
      <feature>Give the attribute identifier of a writable attribute.</feature>
      <status cond="M3.1">M</status>
      <specification>Attribute ID</specification>
    </pixitItem>
  </pixit>
  <pics label="[ZLT] ZigBee logical device types">
    <picsItem>
      <itemNumber>ZLT1</itemNumber>
      <feature>Is the logical device type specified as a ZigBee coordinator?</feature>
      <reference>[R1]/2.5.4.5.1</reference>
      <status>O.1</status>
      <support>false</support>
    </picsItem>
    <picsItem>
      <itemNumber>ZLT1.1</itemNumber>
      <feature>Does the node encompass the role of the Trust Center?</feature>
      <reference>6.1</reference>
      <status cond="ZLT2">X</status>
      <status cond="ZLT3">X</status>
    </picsItem>
    <picsItem>
      <itemNumber>ZLT1.2</itemNumber>
      <feature>Does the node form a centralized security network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>ZLT1.3</itemNumber>
      <feature>Does the node NOT attempt to join another network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>ZLT2</itemNumber>
      <feature>Is the logical device type specified as a ZigBee router?</feature>
      <reference>[R1]/2.5.4.5.2</reference>
      <support>true</support>
    </picsItem>
    <picsItem>
      <itemNumber>ZLT2.1</itemNumber>
      <feature>Can the router node join another network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>ZLT2.2</itemNumber>
      <feature>Does the node form a distributed network?</feature>
      <status cond="ZLT1">X</status>
      <status cond="ZLT2">O</status>
    </picsItem>
    <picsItem>
      <itemNumber>ZLT3</itemNumber>
      <feature>Is the logical device type specified as a ZigBee end device?</feature>
      <reference>[R1]/2.5.4.5.5</reference>
    </picsItem>
    <picsItem>
      <itemNumber>ZLT3.1</itemNumber>
      <feature>Can the end device node join another network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>ZLT3.2</itemNumber>
      <feature>Is the end device sleepy?</feature>
      <reference>-</reference>
      <status cond="ZLT3">O</status>
    </picsItem>
    <picsItem>
      <itemNumber>ZLT4</itemNumber>
      <feature>Can the node switch between ZLT1 and ZLT2 types under application control.</feature>
    </picsItem>
    <note ref="O.1">A node SHALL support one of ZLT1 or ZLT2 or ZLT3 or (ZLT1 and ZLT2, switchable under application control).</note>
  </pics>
  <pics label="[NSM] Network security models">
    <picsItem>
      <itemNumber>NSM1</itemNumber>
      <feature>Can the node join a centralized security network?</feature>
      <reference>6.2</reference>
    </picsItem>
    <picsItem>
      <itemNumber>NSM2</itemNumber>
      <feature>Can the node join a distributed security network?</feature>
    </picsItem>
  </pics>
  <pics label="[LK] Link keys">
    <picsItem>
      <itemNumber>LK1</itemNumber>
      <feature>Does the node contain the default global Trust Center link key?</feature>
      <reference>6.3</reference>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>LK2</itemNumber>
      <feature>Does the node contain the distributed security global link key?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>LK3</itemNumber>
      <feature>Does the node contain an install code derived preconfigured link key?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>LK4</itemNumber>
      <feature>Does the node contain the touchlink preconfigured link key?</feature>
      <status cond="GRC5">M</status>
    </picsItem>
  </pics>
  <pics label="[UIC] Use of install codes">
    <picsItem>
      <itemNumber>UIC1</itemNumber>
      <feature>Does the node support install codes?</feature>
      <reference>6.4</reference>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>UIC2</itemNumber>
      <feature>Will the node not be available via retail channels and be professionally installed?</feature>
      <status>O.2</status>
    </picsItem>
    <picsItem>
      <itemNumber>UIC3</itemNumber>
      <feature>Will the node be available via retail channels?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>UIC4</itemNumber>
      <feature>Is the node configured to only require the use of install codes on joining?</feature>
      <status cond="UIC2">O</status>
      <status cond="UIC3">X</status>
    </picsItem>
    <picsItem>
      <itemNumber>UIC5</itemNumber>
      <feature>Does the node have a user configuration mechanism?</feature>
      <status cond="UIC3">O.3</status>
    </picsItem>
    <picsItem>
      <itemNumber>UIC6</itemNumber>
      <feature>Does the node not have a user configuration mechanism?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>UIC7</itemNumber>
      <feature>Does the node default to requiring potential networks to use of install codes on joining?</feature>
      <status cond="UIC5">O</status>
      <status cond="UIC6">X</status>
    </picsItem>
    <picsItem>
      <itemNumber>UIC8</itemNumber>
      <feature>Can the node be switched into a mode whereby all networks are considered for joining?</feature>
      <status cond="UIC5">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>UIC9</itemNumber>
      <feature>Can the node join all types of networks?</feature>
      <status cond="UIC6">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>UIC10</itemNumber>
      <feature>Does the Trust Center require the use of install codes for all joining nodes?</feature>
      <status cond="ZLT1">O</status>
    </picsItem>
    <note ref="O.2">One of the items marked O.2 SHALL be supported.</note>
    <note ref="O.3">One of the items marked O.3 SHALL be supported.</note>
  </pics>
  <pics label="[GRC] Commissioning">
    <picsItem>
      <itemNumber>GRC1</itemNumber>
      <feature>Does the node support network steering?</feature>
      <reference>6.5</reference>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>GRC2.1</itemNumber>
      <feature>Is the device implemented as having a simple device class (see [R4])?</feature>
      <status>O.4</status>
    </picsItem>
    <picsItem>
      <itemNumber>GRC2.2</itemNumber>
      <feature>Is the device implemented as having a dynamic device class (see [R4])?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>GRC2.3</itemNumber>
      <feature>Is the device implemented as having a node device class (see [R4])?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>GRC4</itemNumber>
      <feature>Does the device support finding &amp; binding as either an initiator or a target?</feature>
      <status cond="GRC2.1">M</status>
      <status cond="GRC2.2">O</status>
      <status cond="GRC2.3">O</status>
    </picsItem>
    <picsItem>
      <itemNumber>GRC5</itemNumber>
      <feature>Does the device support touchlink commissioning as either an initiator or a target or both?</feature>
      <status>O</status>
    </picsItem>
    <picsItem>
      <itemNumber>GRC5.1</itemNumber>
      <feature>Does the device support touchlink commissioning as an initiator?</feature>
      <status cond="GRC5">O.5</status>
    </picsItem>
    <picsItem>
      <itemNumber>GRC5.2</itemNumber>
      <feature>Does the device support touchlink commissioning as a target?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>GRC6</itemNumber>
      <feature>If touchlink commissioning as an initiator is attempted and is successful does the device not attempt any further commissioning operations?</feature>
      <status cond="GRC5.1">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>GRC7</itemNumber>
      <feature>If network steering is attempted does the node follow the correct steering procedure dependent on whether the node is joined to a network or not?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>GRC8</itemNumber>
      <feature>Does the node only form a network if the node is not yet joined to a network?</feature>
      <status cond="ZLT1.2">M</status>
      <status cond="ZLT2.2">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>GRC9</itemNumber>
      <feature>Can the node form a centralized network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>GRC10</itemNumber>
      <feature>Can the node form a distributed network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>GRC11</itemNumber>
      <feature>Does the node skip network formation?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>GRC12</itemNumber>
      <feature>Does the node attempt finding &amp; binding only if it is joined to a network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>GRC13</itemNumber>
      <feature>Does the node instigate finding &amp; binding on one or more endpoints implemented on the node?</feature>
      <status cond="GRC4">O</status>
    </picsItem>
    <picsItem>
      <itemNumber>GRC14</itemNumber>
      <feature>Does the node attempt finding &amp; binding as an initiator endpoint if the endpoint supports a type 1 client or type 2 server cluster?</feature>
      <status cond="GRC4">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>GRC15</itemNumber>
      <feature>Does the node attempt finding &amp; binding as a target endpoint if the endpoint supports a type 1 server or type 2 client cluster?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>GRC16</itemNumber>
      <feature>Is the node capable of binding to a group during finding &amp; binding?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>GRC17</itemNumber>
      <feature>Is the device able to transmit groupcast messages?</feature>
      <status>O</status>
    </picsItem>
    <note ref="O.4">One of the items marked O.4 SHALL be supported.</note>
    <note ref="O.5">One of the items marked O.5 SHALL be supported.</note>
  </pics>
  <pics label="[MRD] Minimum requirements for all devices">
    <picsItem>
      <itemNumber>MRD1</itemNumber>
      <feature>Can the node process the ZDO Active_EP_req command and respond with the ZDO Active_EP_rsp command?</feature>
      <reference>6.6</reference>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD1.1</itemNumber>
      <feature>Can the node process the ZDO Node_Desc_req command and respond with the ZDO Node_Desc_rsp command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD2</itemNumber>
      <feature>Can the node process the ZDO Simple_Desc_req command and respond with the ZDO Simple_Desc_rsp command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD3</itemNumber>
      <feature>Can the node process the ZDO IEEE_Addr_req command and respond with the ZDO IEEE_Addr_rsp command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD4</itemNumber>
      <feature>Can the node process the ZDO NWK_Addr_req command and respond with the ZDO NWK_Addr_rsp command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD5</itemNumber>
      <feature>Can the node process the ZDO Match_Desc_req command and respond with the ZDO Match_Desc_rsp command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD6</itemNumber>
      <feature>Can the node process the ZDO Mgmt_Bind_req command and respond with the ZDO Mgmt_Bind_rsp command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD7</itemNumber>
      <feature>Can the node process the ZDO Mgmt_Lqi_req command and respond with the ZDO Mgmt_Lqi_rsp command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD8</itemNumber>
      <feature>Can the node process the ZDO Bind_req command and respond with the ZDO Bind_rsp command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD9</itemNumber>
      <feature>Can the node process the ZDO Unbind_req command and respond with the ZDO Unbind_rsp command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD10</itemNumber>
      <feature>Can the node process the ZDO Mgmt_Leave_req command and respond with the ZDO Mgmt_Leave_rsp command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD11</itemNumber>
      <feature>Can the node process at least one identify cluster, identify query response command after broadcasting an identify cluster, identify query command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD12</itemNumber>
      <feature>Can the node process more than one identify cluster, identify query response command after broadcasting an identify cluster, identify query command?</feature>
      <status>O</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD13</itemNumber>
      <feature>Does the node implement a binding table whose number of entries is ≥ the sum of cluster instances supported on each device?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD14</itemNumber>
      <feature>Regardless of the commissioning mechanism, is the binding table consistent such that its contents can be retrieved using the ZDO Mgmt_Bind_req command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD15</itemNumber>
      <feature>Does the node have a default reporting configuration for every implemented attribute that is specified as mandatory and reportable?</feature>
      <status cond="DRC1">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD16</itemNumber>
      <feature>Does the node have a cluster which is the target of an operational transaction?</feature>
      <status>O</status>
    </picsItem>
    <picsItem>
      <itemNumber>MRD17</itemNumber>
      <feature>Does the node support group addressing and at least 8 memberships in the group table?</feature>
      <status cond="MRD16">M</status>
    </picsItem>
  </pics>
  <pics label="[DRC] Default reporting configuration">
    <picsItem>
      <itemNumber>DRC1</itemNumber>
      <feature>Does the node have at least one attribute that is specified as reportable?</feature>
      <reference>6.7</reference>
      <status>O</status>
    </picsItem>
    <picsItem>
      <itemNumber>DRC2</itemNumber>
      <feature>Does the node have a default reporting configuration for every attribute that is specified as reportable?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>DRC3</itemNumber>
      <feature>Does the node automatically send reports to a node that binds with a cluster containing an attribute that is specified as reportable?</feature>
      <status cond="DRC2">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>DRC4</itemNumber>
      <feature>If any default reporting configuration is overwritten, is the updated reporting configuration used instead?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>DRC5</itemNumber>
      <feature>If the maximum reporting interval of an attribute is greater than 0x0000, is a report generated when the time that has elapse since the previous report of the same attribute is equal to the maximum reporting interval for that attribute?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>DRC6</itemNumber>
      <feature>If the maximum reporting interval of an attribute is equal to 0x0000, is a report generated when the attribute value changes?</feature>
    </picsItem>
  </pics>
  <pics label="[MDP] MAC data polling">
    <picsItem>
      <itemNumber>MDP1</itemNumber>
      <feature>Is the MAC data polling rate dynamic based on the operating state of the node?</feature>
      <reference>6.8</reference>
      <status cond="ZLT3">R</status>
    </picsItem>
    <picsItem>
      <itemNumber>MDP2</itemNumber>
      <feature>Does the node have at least a fast and a slow MAC data polling rate?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>MDP3</itemNumber>
      <feature>Does the device poll more frequently than once per 7.5 seconds?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>MDP4</itemNumber>
      <feature>While waiting for an active response message, does the node poll at its fast rate?</feature>
      <status cond="MDP2">R</status>
    </picsItem>
    <picsItem>
      <itemNumber>MDP5</itemNumber>
      <feature>Is the fast poll rate at least once every 3 seconds?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>MDP6</itemNumber>
      <feature>While not actively waiting for messages, does the node poll at its slow rate?</feature>
      <status cond="MDP2">O</status>
    </picsItem>
    <picsItem>
      <itemNumber>MDP7</itemNumber>
      <feature>Does the node poll at its fast rate during commissioning?</feature>
    </picsItem>
  </pics>
  <pics label="[ZPD] ZigBee persistent data">
    <picsItem>
      <itemNumber>ZPD1</itemNumber>
      <feature>Does the node preserve the value of the bdbNodeIsOnANetwork attribute across resets?</feature>
      <reference>6.9</reference>
      <status>M</status>
    </picsItem>
  </pics>
  <pics label="[INP] Initialization procedure">
    <picsItem>
      <itemNumber>INP1</itemNumber>
      <feature>Does the node support the initialization procedure?</feature>
      <reference>7.1</reference>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>INP2</itemNumber>
      <feature>Does the node restore its persistent ZigBee data?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>INP3</itemNumber>
      <feature>If the node is a ZigBee End Device and was previously on a network, does it attempt to rejoin the network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>INP4</itemNumber>
      <feature>On successful rejoining, does the node broadcast a device_annce ZDO command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>INP5</itemNumber>
      <feature>If the node is a ZigBee Router and supports touchlink but was not previously on a network, does it switch to a touchlink primary channel?</feature>
      <status cond="(ZLT2 AND GRC5)">M</status>
    </picsItem>
  </pics>
  <pics label="[COM] Commissioning">
    <picsItem>
      <itemNumber>COM1</itemNumber>
      <feature>Does the implementation provide a mechanism to invoke network steering?</feature>
      <reference>8</reference>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>COM2</itemNumber>
      <feature>Does the implementation provide a mechanism to invoke finding &amp; binding?</feature>
    </picsItem>
  </pics>
  <pics label="[TLC] Top level commissioning procedure">
    <picsItem>
      <itemNumber>TLC1</itemNumber>
      <feature>If touchlink commissioning is requested, does the node follow the touchlink for initiator procedure?</feature>
      <reference>8.1</reference>
    </picsItem>
    <picsItem>
      <itemNumber>TLC2</itemNumber>
      <feature>If network steering is requested when bdbNodeIsOnANetwork is equal to TRUE, does the node follow the network steering for a node on a network procedure?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>TLC3</itemNumber>
      <feature>If network steering is requested when bdbNodeIsOnANetwork is equal to FALSE, does the node follow the network steering for a node not on a network procedure?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>TLC4</itemNumber>
      <feature>If network formation is requested when bdbNodeIsOnANetwork is equal to FALSE, does the node follow the network formation procedure?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLC5</itemNumber>
      <feature>If network formation is requested when bdbNodeIsOnANetwork is equal to TRUE, does the node follow the network formation procedure?</feature>
      <status>X</status>
    </picsItem>
    <picsItem>
      <itemNumber>TLC6</itemNumber>
      <feature>If finding &amp; binding is requested when bdbNodeIsOnANetwork is equal to TRUE, does the node follow the finding &amp; binding procedure according to cluster class?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLC7</itemNumber>
      <feature>If finding &amp; binding is requested when bdbNodeIsOnANetwork is equal to FALSE, does the node follow the finding &amp; binding procedure according to cluster class?</feature>
      <status>X</status>
    </picsItem>
  </pics>
  <pics label="[NSO] Network steering procedure for a node on a network">
    <picsItem>
      <itemNumber>NSO1</itemNumber>
      <feature>Is the network steering for a node on a network procedure supported?</feature>
      <reference>8.2</reference>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>NSO2</itemNumber>
      <feature>Does the node first broadcast the Mgmt_Permit_Joining_req ZDO command?</feature>
      <status>M</status>
    </picsItem>
    <picsItem>
      <itemNumber>NSO3</itemNumber>
      <feature>If the node is a ZigBee Coordinator or a ZigBee Router, does the node activate its permit joining flag for ≥ bdbcMinCommissioningTime?</feature>
      <status cond="(ZLT1 OR ZLT2)">M</status>
    </picsItem>
  </pics>
  <pics label="[NSN] Network steering procedure for a node not on a network">
    <picsItem>
      <itemNumber>NSN1</itemNumber>
      <feature>Is the network steering for a node not on a network procedure supported?</feature>
      <reference>8.3</reference>
    </picsItem>
    <picsItem>
      <itemNumber>NSN2</itemNumber>
      <feature>Does the node attempt to discover networks over a set of channels?</feature>
      <status cond="NSN1">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>NSN3</itemNumber>
      <feature>If suitable networks were found, does the node attempt to join one of them using MAC association?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>NSN4</itemNumber>
      <feature>If the join was not successful and there are more suitable networks to join, does the node attempt to join another network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>NSN5</itemNumber>
      <feature>If the join was successful, does the node wait apsSecurityTimeOutPeriod milliseconds to receive the network key?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>NSN6</itemNumber>
      <feature>If the network key is not received within apsSecurityTimeOutPeriod milliseconds, the network key is received but could not be decrypted or the authentication fails does the node reset its network parameters?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>NSN7</itemNumber>
      <feature>Does the node broadcast a Device_annce ZDO command?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>NSN9</itemNumber>
      <feature>If the TC link key exchange is not successful, does the node reset its network parameters and remove itself from the network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>NSN10</itemNumber>
      <feature>If the TC link key exchange is successful, does the node broadcast the Mgmt_Permit_Joining_req ZDO command?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>NSN11</itemNumber>
      <feature>Does the node activate its permit joining flag if new nodes can join this node?</feature>
    </picsItem>
  </pics>
  <pics label="[NFP] Network formation procedure">
    <picsItem>
      <itemNumber>NFP1</itemNumber>
      <feature>Is the network formation procedure supported?</feature>
      <reference>8.4</reference>
    </picsItem>
    <picsItem>
      <itemNumber>NFP2</itemNumber>
      <feature>Does the node attempt to form a network over a set of channels?</feature>
      <status cond="NFP1">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>NFP3</itemNumber>
      <feature>If formation is successful and the node is a ZigBee Coordinator, does it initiate its Trust Center functionality?</feature>
      <status cond="(NFP1 AND ZLT1)">M</status>
    </picsItem>
  </pics>
  <pics label="[FBT] Finding &amp; binding procedure for a target endpoint">
    <picsItem>
      <itemNumber>FBT1</itemNumber>
      <feature>Is the finding &amp; binding for a target endpoint procedure supported?</feature>
      <reference>8.5</reference>
      <status cond="GRC15">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>FBT2</itemNumber>
      <feature>Does the target identify itself for at least bdbMinCommissioningTime seconds?</feature>
      <status cond="FBT1">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>FBT3</itemNumber>
      <feature>Does the target respond to Identify cluster Identify Query commands?</feature>
    </picsItem>
  </pics>
  <pics label="[FBI] Finding &amp; binding procedure for an initiator endpoint">
    <picsItem>
      <itemNumber>FBI1</itemNumber>
      <feature>Is the finding &amp; binding for an initiator endpoint procedure supported?</feature>
      <reference>8.6</reference>
      <status cond="GRC14">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>FBI2</itemNumber>
      <feature>Is the Identify cluster Identify Query command broadcast supported?</feature>
      <status cond="FBI1">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>FBI3</itemNumber>
      <feature>Is the simple descriptor of each respondent obtained with the Simple_Desc_req ZDO command?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>FBI4</itemNumber>
      <feature>Does the initiator create a binding table entry for each matching cluster to the respondent?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>FBI5</itemNumber>
      <feature>If a group binding is requested, does the initiator add the respondent to an appropriate group?</feature>
      <status cond="(FBI1 AND GRC16)">M</status>
    </picsItem>
  </pics>
  <pics label="[TLI] Touchlink procedure for an initiator">
    <picsItem>
      <itemNumber>TLI1</itemNumber>
      <feature>Is the touchlink for an initiator procedure supported?</feature>
      <reference>8.7</reference>
    </picsItem>
    <picsItem>
      <itemNumber>TLI2</itemNumber>
      <feature>Does the initiator broadcast 5 scan request inter-PAN command frames on the first primary touchlink channel and then once for each remaining primary channel?</feature>
      <status cond="TLI1">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>TLI3</itemNumber>
      <feature>Does the initiator broadcast a scan request inter-PAN command frames on each secondary touchlink channel when using touchlink for formation or joining?</feature>
      <status cond="TLI1">O</status>
    </picsItem>
    <picsItem>
      <itemNumber>TLI4</itemNumber>
      <feature>If the initiator is not on a network, does it ignore any scan request command frames from other factory new initiators?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLI5</itemNumber>
      <feature>If the initiator is not on a network, does it switch into a target mode if any scan request command frames are received from other non-factory new initiators?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLI6</itemNumber>
      <feature>If a target is found, does the initiator transmit a device information request inter-PAN command frame to the selected target?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLI7</itemNumber>
      <feature>If a target is found, does the initiator transmit one or more identify request inter-PAN command frame to the selected target?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLI8</itemNumber>
      <feature>If a scan request command frame is received from a target on the same network as the initiator with the network update identifier field lower than nwkUpdateId, does the initiator transmit a network update request inter-PAN command frame to the selected target and then terminate the touchlink procedure?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLI9</itemNumber>
      <feature>If a target is found on a different network to the initiator and the initiator is on a centralized network, does it terminate the touchlink procedure?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLI10</itemNumber>
      <feature>If the initiator is not on a network and the target is a ZigBee Router, does the initiator transmit a network start request inter-PAN command frame to the selected target?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLI11</itemNumber>
      <feature>If the initiator is on a network and the target is a ZigBee Router, does the initiator transmit a network join router request inter-PAN command frame to the selected target?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLI12</itemNumber>
      <feature>If the initiator is on a network and the target is a ZigBee End Device, does the node transmit a network join end device request inter-PAN command frame to the selected target?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLI13</itemNumber>
      <feature>If the initiator is an end device and a network start request inter-PAN command frame was sent to the selected target, does the node rejoin the network?</feature>
      <status cond="(ZLT3 AND TLI1)">M</status>
    </picsItem>
  </pics>
  <pics label="[TLT] Touchlink procedure for an target">
    <picsItem>
      <itemNumber>TLT1</itemNumber>
      <feature>Is the touchlink for a target procedure supported?</feature>
      <reference>8.8</reference>
      <status cond="GRC5.2">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>TLT2</itemNumber>
      <feature>Does the target discard any touchlink commissioning command other than a scan request command and terminate the procedure?</feature>
      <status cond="TLT1">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>TLT3</itemNumber>
      <feature>Does the target discard scan request command frames with an RSSI lower than a product specific threshold and terminate the procedure?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLT4</itemNumber>
      <feature>Does the target respond to a scan request command frame with a scan response command frame?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLT5</itemNumber>
      <feature>Does the target respond to a device information request command frame with a device information response command frame?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLT6</itemNumber>
      <feature>Does the target identify itself on receipt of a identify request command frame?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLT7</itemNumber>
      <feature>If the target receives a network start request command frame, is a ZigBee Router and decides to start a network, does it perform a network discovery?</feature>
      <status cond="(TLT1 AND ZLT2)">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>TLT8</itemNumber>
      <feature>If the target receives a network join router request command frame, is a ZigBee Router and decides to join the network of the initiator, does it respond with a network join router response command frame?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLT9</itemNumber>
      <feature>If the target receives a network join end device request command frame, is a ZigBee End Device and decides to join the network of the initiator, does it respond with a network join end device response command frame?</feature>
      <status cond="(TLT1 AND ZLT3)">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>TLT10</itemNumber>
      <feature>If target is already part of a network, does it leave its current network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLT11</itemNumber>
      <feature>If requested by the initiator, does the target start a new network and respond with a network start response command frame?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TLT12</itemNumber>
      <feature>After starting a new network, does the target direct join the initiator to its new network?</feature>
    </picsItem>
  </pics>
  <pics label="[RBC] Reset via the basic cluster">
    <picsItem>
      <itemNumber>RBC2</itemNumber>
      <feature>Does the initiator transmit a reset to factory defaults command frame to a target?</feature>
      <reference>9.1</reference>
      <status>O</status>
    </picsItem>
    <picsItem>
      <itemNumber>RBC3</itemNumber>
      <feature>On receipt of a reset to factory defaults command frame, does the target reset all attributes of all clusters to their default values?</feature>
      <status>O</status>
    </picsItem>
    <picsItem>
      <itemNumber>RBC4</itemNumber>
      <feature>On receipt of a reset to factory defaults command frame, does the target not reset its network parameters?</feature>
      <status>M</status>
    </picsItem>
  </pics>
  <pics label="[RTL] Reset via the touchlink commissioning cluster">
    <picsItem>
      <itemNumber>RTL2</itemNumber>
      <feature>Does the initiator transmit a reset to factory new command frame to a target?</feature>
      <reference>9.2</reference>
    </picsItem>
    <picsItem>
      <itemNumber>RTL3</itemNumber>
      <feature>On receipt of a reset to factory new command frame and if the target is on a distributed security network, does it leave the network?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>RTL4</itemNumber>
      <feature>On receipt of a reset to factory new command frame and if the target is on a centralized security network, does it ignore the command?</feature>
      <status cond="GRC5">O</status>
    </picsItem>
    <picsItem>
      <itemNumber>RTL5</itemNumber>
      <feature>Does the initiator use an extended channel scan during a reset via the touchlink commissioning cluster?</feature>
    </picsItem>
  </pics>
  <pics label="[RNL] Reset via network leave command">
    <picsItem>
      <itemNumber>RNL1</itemNumber>
      <feature>Does a node transmit a leave NWK command frame to another node to trigger the other node to leave?</feature>
      <reference>9.4</reference>
      <status>O</status>
    </picsItem>
    <picsItem>
      <itemNumber>RNL2</itemNumber>
      <feature>On receipt of a leave NWK command frame with the request bit set to 1, does the node leave the network?</feature>
      <status>M</status>
    </picsItem>
  </pics>
  <pics label="[RLZ] Reset via the Mgmt_Leave_req ZDO command">
    <picsItem>
      <itemNumber>RLZ1</itemNumber>
      <feature>Does a node transmit an Mgmt_Leave_req ZDO command frame to another node?</feature>
      <reference>9.5</reference>
      <status>O</status>
    </picsItem>
    <picsItem>
      <itemNumber>RLZ2</itemNumber>
      <feature>On receipt of an Mgmt_Leave_req ZDO command frame, does the node leave the network?</feature>
      <status>M</status>
    </picsItem>
  </pics>
  <pics label="[RLA] Reset via local action">
    <picsItem>
      <itemNumber>RLA1</itemNumber>
      <feature>Does the node provide a local reset mechanism?</feature>
      <reference>9.6</reference>
      <status>O</status>
    </picsItem>
    <picsItem>
      <itemNumber>RLA2</itemNumber>
      <feature>On activation of the local reset mechanism, does the node reset itself?</feature>
      <status cond="RLA1">M</status>
    </picsItem>
  </pics>
  <pics label="[RLK] Receiving a new Trust Center link key">
    <picsItem>
      <itemNumber>RLK0</itemNumber>
      <feature>Does the node exchange its link key during network steering on a centralized security network?</feature>
      <reference>10.2.5</reference>
    </picsItem>
    <picsItem>
      <itemNumber>RLK1a</itemNumber>
      <feature>Does the node execute the appropriate steps defined by the alternative link key exchange mechanism?</feature>
      <reference>10.2.5, step 1</reference>
      <status cond="(RLK0 AND (IA7!=0x00))">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>RLK1b</itemNumber>
      <feature>If the alternative mechanism is successful, does the node terminate the node link key exchange procedure?</feature>
      <status cond="RLK1a">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>RLK3</itemNumber>
      <feature>If the APS Request Key method is used or the alternative mechanism is not successful, does the node transmit the Node_Desc_req ZDO command to the Trust Center?</feature>
      <reference>10.2.5, step 3</reference>
      <status cond="(RLK0 AND (IA7==0x00))">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>RLK4a</itemNumber>
      <feature>If a Node_Desc_rsp ZDO command is not received within bdbcTCLinkKey-ExchangeTimeout seconds does the node retry up to the maximum attempts permitted?</feature>
      <reference>10.2.5, step 4</reference>
      <status cond="RLK3">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>RLK4b</itemNumber>
      <feature>If a Node_Desc_rsp ZDO command is not received after the maximum number of attempts permitted, does it terminate the node link key exchange procedure?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>RLK5</itemNumber>
      <feature>If a Node_Desc_rsp ZDO command is received and the server mask of the node descriptor indicates a core stack of r20 or earlier, does the node terminate the node link key exchange procedure?</feature>
      <reference>10.2.5, step 5</reference>
    </picsItem>
    <picsItem>
      <itemNumber>RLK7</itemNumber>
      <feature>If a Node_Desc_rsp ZDO command is received and the server mask of the node descriptor indicates a core stack of r21 or later, does the node request a new link key using the Request Key APS command frame to the Trust Center, encrypted with its initial link key?</feature>
      <reference>10.2.5, step 7</reference>
    </picsItem>
    <picsItem>
      <itemNumber>RLK8a</itemNumber>
      <feature>If a Transport Key APS command is not received within bdbcTCLinkKey-ExchangeTimeout seconds does the node retry up to the maximum attempts permitted?</feature>
      <reference>10.2.5, step 8</reference>
      <status cond="RLK7">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>RLK8b</itemNumber>
      <feature>If a Transport Key APS command is not received after the maximum number of attempts permitted, does it terminate the node link key exchange procedure?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>RLK9</itemNumber>
      <feature>If a Transport Key APS command frame is received from the Trust Center, containing a new link key, does the node update its Trust Center link key with the new key?</feature>
      <reference>10.2.5, step 9</reference>
    </picsItem>
    <picsItem>
      <itemNumber>RLK11</itemNumber>
      <feature>Does the node verify the new key using the Verify Key APS command frame to the Trust Center?</feature>
      <reference>10.2.5, step 11</reference>
    </picsItem>
    <picsItem>
      <itemNumber>RLK12a</itemNumber>
      <feature>If a Confirm Key APS command is not received within bdbcTCLinkKey-ExchangeTimeout seconds does the node retry up to the maximum attempts permitted?</feature>
      <reference>10.2.5, step 12</reference>
      <status cond="RLK11">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>RLK12b</itemNumber>
      <feature>If a Confirm Key APS command is not received after the maximum number of attempts permitted, does it terminate the node link key exchange procedure?</feature>
    </picsItem>
  </pics>
  <pics label="[AIC] Adding an install code">
    <picsItem>
      <itemNumber>AIC0</itemNumber>
      <feature>Does the Trust Center allow the input of an install code?</feature>
      <reference>10.3.1</reference>
    </picsItem>
    <picsItem>
      <itemNumber>AIC2</itemNumber>
      <feature>On receipt of an installation code, does the Trust Center create an entry in its node/link key mapping table (apsDeviceKeyPairSet) with the installation code derived key?</feature>
      <reference>10.3.1, step 2</reference>
      <status cond="(AIC0 AND (IA2==True))">M</status>
    </picsItem>
  </pics>
  <pics label="[ANN] Adding a new node into the network">
    <picsItem>
      <itemNumber>ANN1</itemNumber>
      <feature>On receipt of an Update Device APS command frame, does the Trust Center follow the procedure for adding a new node into the network?</feature>
      <reference>10.3.2</reference>
    </picsItem>
    <picsItem>
      <itemNumber>ANN2</itemNumber>
      <feature>If an install code is required and the new node is not in apsDeviceKeyPairSet, does the Trust Center terminate the Trust Center link key exchange procedure?</feature>
      <status cond="(ANN1 AND (IA2==True))">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>ANN3</itemNumber>
      <feature>If an install code is not required and the new node is not in apsDeviceKey-PairSet, does the Trust Center create an entry in its apsDeviceKeyPairSet for the joining node?</feature>
      <status cond="(ANN1 AND (IA2==False))">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>ANN4</itemNumber>
      <feature>Does the Trust Center send the network key to the joining node using a Transport Key APS command frame, encrypted with the entry in apsDeviceKeyPairSet corresponding to the joining node?</feature>
      <status cond="ANN1">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>ANN5</itemNumber>
      <feature>If a Request Key APS command frame is not received and the Trust Center requires the new node to exchange its link key, does it request the new node leaves the network?</feature>
      <status cond="(IA9==TRUE)">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>ANN6</itemNumber>
      <feature>On receipt of a Request Key APS command frame from the joining node, encrypted with its initial link key, does the Trust Center generate a new link key and transport it to the joining node using a Transport Key APS command frame?</feature>
      <status cond="ANN5">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>ANN7</itemNumber>
      <feature>If a Verify Key APS command frame is not received by the Trust Center from the joining node, does it request the new node leaves the network?</feature>
      <status cond="ANN6">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>ANN8</itemNumber>
      <feature>Does the Trust Center receive a Verify Key APS command frame from the joining node, update the entry in apsDeviceKeyPairSet corresponding to the joining node with the new key and respond with a Confirm Key APS command frame?</feature>
      <status cond="ANN7">M</status>
    </picsItem>
  </pics>
  <pics label="[BKN] Behavior when a known node joins">
    <picsItem>
      <itemNumber>BKN1</itemNumber>
      <feature>Does the Trust Center allow a known node to join but in a fresh state?</feature>
      <reference>10.3.3</reference>
    </picsItem>
    <picsItem>
      <itemNumber>BKN2</itemNumber>
      <feature>Does the Trust Center store the original install code derived link key for devices that have joined?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>BKN3</itemNumber>
      <feature>Does the Trust Center overwrite the link key for a joining node with the original install code derived link key?</feature>
      <status cond="((IA2==TRUE) AND BKN2)">M</status>
    </picsItem>
    <picsItem>
      <itemNumber>BKN4</itemNumber>
      <feature>Does the Trust Center overwrite the link key for a joining node with the default global Trust Center link key?</feature>
      <status cond="(IA2==FALSE)">M</status>
    </picsItem>
  </pics>
  <pics label="[TCP] Trust center policies">
    <picsItem>
      <itemNumber>TCP1.1</itemNumber>
      <feature>Does the Trust Center allow any nodes to join (Trust Center policy useWhiteList)?</feature>
      <reference>[ZIGBEE] Table 4.33</reference>
      <status cond="ZLT1.1">O.7</status>
    </picsItem>
    <picsItem>
      <itemNumber>TCP1.2</itemNumber>
      <feature>Does the Trust Center allow only known nodes to join (Trust Center policy useWhiteList)?</feature>
    </picsItem>
    <picsItem>
      <itemNumber>TCP2.1</itemNumber>
      <feature>Does the Trust Center allow a node on the network that transmits a ZDO Mgmt_Permit_Join with a significance set to 1 to affect the Trust Center policy (Trust Center policy allowRemoteTc-PolicyChange)?</feature>
      <status cond="ZLT1.1">O.8</status>
    </picsItem>
    <picsItem>
      <itemNumber>TCP2.2</itemNumber>
      <feature>Does the Trust Center forbid a node on the network that transmits a ZDO Mgmt_Permit_Join with a significance set to 1 to affect the Trust Center policy (Trust Center policy allowRemoteTc-PolicyChange)?</feature>
    </picsItem>
    <note ref="O.7">One or both of the items marked O.7 SHALL be supported.</note>
    <note ref="O.8">One or both of the items marked O.8 SHALL be supported.</note>
  </pics>
</generalPICS>
