System startup 1st App start. -------------------------- STOPWATCH[0-4]: 0 50 ms 1 312 ms 2 386 ms 3 0 ms 4 0 ms -------------------------- [main]-1084: pdm r 0x1e8 g 0x100 b 0x1c9 [Quickstart_StartMedia]-777: VB[1920 1080] size:2592000 count:1 [Quickstart_StartMedia]-784: VB[2304 1296] size:1658880 count:1 [Quickstart_StartMedia]-791: VB[800 448] size:537600 count:3 [Quickstart_StartMedia]-798: VB[640 360] size:345600 count:3 [audio_adp_codec_set_input_vol]-227: Acodec set input vol(30) [QUICKSTART_COMM_VI_SetMipiAttr]-1821: ============= MipiDev 0, SetMipiAttr enWDRMode: 0 linear mode Root Name: /dev/mtdblock3 Rootfs Type: squashfs [Func]:os02h10_write_register [Line]:189 [Info]:I2C_WRITE error! mount /dev/mtdblock3 as squashfs rootfs [Jan 19 2024 15:11:03]===os02h10 sensor linear init success!===== [QuickStart_Service_Thread]-1010: media init(isp-->venc) take time: 171 ms [QuickStart_Service_Thread]-1025: get isp running status true [RCS]: /etc/init.d/S00devs [RCS]: /etc/init.d/S01udev [RCS]: /etc/init.d/S02moutfs mount param fs dir. param fs mounted. mount app fs. app fs mounted. Load /lib/modules/4.9.37/kernel/drivers/mmc/host/sdhci-xmedia.ko Load /lib/modules/4.9.37/kernel/drivers/rtc/rtc-xmedia.ko [RCS]: /etc/init.d/S80network Auto login as root ... login[121]: root login on 'ttyS000' Welcome to Linux. None of nfsroot found in cmdline. /system/root # start MMC\n find dir /mnt/flash/mmc! /dev/mmcblk0 update start! update_file=/mnt/flash/mmc/IPW-G5A2D0A1-TY-HANHUI_1300B_V1.0.2-240612_CN_EN_upgrade.bin update_file_md5=83d0f899cc770334d93caf21d8bdf4ef check file md5sum ok check device_md5 ok file_version=V1.0.2 device_version=V1.0.2 check version ok same checksum, exit! 2: Warning: Mosquitto should not be run as root/administrator. [19700101-00:00:02.868 D 183] my_main.c 818: main, runTime 2.605 [19700101-00:00:03.063 D 182] main.c 455: main, runTime 2.949 [19700101-00:00:03.112 D 182] media_gk72010300.c 52: quickstart_debug init start 3.112 [19700101-00:00:03.113 D 182] quickstart_rootfs.c 155: BOARDID_1315B AUDIO_CTRL:56 AUDIO_CTRL_ENABLE:0 ICR_CAMERA_POS:35 ICR_CAMERA_NEG:36 IR=[70] [19700101-00:00:03.190 D 182] media_gk72010300.c 89: quickstart_debug init shbuf 3.190 [19700101-00:00:03.223 D 182] quickstart_rootfs.c 1704: pdm r 0x1e8 g 0x100 b 0x1c9 [19700101-00:00:03.485 D 182] quickstart_rootfs.c 1652: media init(isp-->venc) take time: 130 ms [19700101-00:00:03.534 D 182] audio_rootfs.c 573: AO SetVqeVolume deviD:0 Chn:0 VolDb:0 [19700101-00:00:03.534 D 182] audio_rootfs.c 579: AI SetVqeVolume deviD:0 Chn:0 VolDb:0 [19700101-00:00:03.534 D 182] audio_rootfs.c 1354: audio start EncType:20 BitWidth:16bit SampleRate:8000 PtNumPerFrm:320 [19700101-00:00:03.568 D 182] quickstart_rootfs.c 1610: isp data load 1ms isp api load 33ms [19700101-00:00:03.596 D 182] media_gk72010300.c 95: quickstart_debug start mpp 3.596 [19700101-00:00:03.596 D 182] stream_reader.c 1824: video stream_reader_proc create success! [19700101-00:00:03.596 D 182] stream_reader.c 1891: audio stream_reader_proc create success! [19700101-00:00:03.597 D 182] stream_reader.c 1928: audio stream_writer_proc create success! [19700101-00:00:03.597 D 182] media_gk72010300.c 114: quickstart_debug rw stream 3.597 [19700101-00:00:03.597 D 182] media_gk72010300.c 39: start hkaov_main tmp/sdk_app_is_ok cb [19700101-00:00:03.597 D 182] md.c 292: MDInit VpssGrp=0 VpssChn=2 Width:640 Height:360 [19700101-00:00:03.625 D 183] my_main.c 823: main, runTime 3.625 [19700101-00:00:03.627 D 183] hank_dev_json.c 707: g_DomeInfo.motor_hlocat[46 1] [19700101-08:00:03.628 I 183] hank_parameter.c 459: set env zone(28 TZ=GMT-08:00) success [19700101-08:00:03.628 I 183] my_main.c 754: generate version:1.0.2 suc. [19700101-08:00:03.629 I 183] my_main.c 793: generate factory_version:V1.0.2-Tuya_240612 suc. [ERR][1970/01/01/08:00:03:629][:57]device /mnt/flash/dev_param.cfg not exist /dev/null /dev/console /dev/console :::osd_set 3928 [1] [19700101-00:00:03.634 D 229] region.c 2679: ^_^ osd time width=2304 height=1296 fsize=56 size=0 :::quickstart_set_isp_daynightstate_func 1859 day[1] [19700101-00:00:03.639 D 226] quickstart_rootfs.c 1831: open white light [19700101-00:00:03.677 I 226] hank_parameter.c 408: [hk_parameter_set_int] DayNightMode=1 [ERR][1970/01/01/08:00:03:629][:513]json parse failed. ===param_set_default=== [DBG][1970/01/01/08:00:03:682][:435]now read param from backflash :::param_set_default:::945::qc11c9618107370f3fbe [20] 50 sizeof(devinfo.uuid_temp=[17] mac[d8:11:31:cc:d1:4c]word_mode_switch[0] [WRN][1970/01/01/08:00:03:683][:683]now write param to flash [19700101-08:00:03.688 D 183] my_param.c 167: soc versioninfo: IPW-G5A2D0A1-TY-HANHUI V1.0.2-Tuya_240612 [19700101-08:00:03.689 D 183] my_param.c 211: pirParamflag: 1 now clear platform p2p server cache! [/home/faerica/work/HK/gk_hank_lpc_project/gklinux_lowpower/mcu/hisyslink/rk_link/hichannel_main.c][sample_wlan_init_up][l:186],net device up success wifi send: ab 0d a0 01 02 01 08 00 05 00 02 01 0a [/home/faerica/work/HK/gk_hank_lpc_project/gklinux_lowpower/mcu/hisyslink/rk_link/hichannel_main.c][sample_cleanup][l:138],sample_cleanup enter [19700101-00:00:03.723 D 182] media_gk72010300.c 158: quickstart_debug init over 3.723 [19700101-00:00:03.736 D 182] main.c 460: main, runTime 3.736 [19700101-08:00:03.736 I 182] hank_parameter.c 459: set env zone(28 TZ=GMT-08:00) success set saturation type:1 value:150 get csc saturation:50 get csc contrast:52 [DBG][1970/01/01/08:00:03:747][:565]hisyslink recv:cmd[0xa0] len[17] xor[0x2a] wifi recv: ab 11 a0 00 00 00 00 04 00 00 00 00 12 24 06 04 2a [DBG][1970/01/01/08:00:03:748][:591]device get wifi time second 4 [DBG][1970/01/01/08:00:03:748][:606]wifi versioninfo 12 24 06 04 V12.240604 [DBG][1970/01/01/08:00:03:748][:1373]now soc start create heart task [DBG][1970/01/01/08:00:03:748][:613]=== power! [0 0]=== [DBG][1970/01/01/08:00:03:748][:528]index:0 [19700101-08:00:03.748 D 241] media_mqtt.c 420: quickstart_debug mqtt connected 3.748 [DBG][1970/01/01/08:00:03:836][:903]setmac[d8:11:31:cc:d1:4c] wifi send: ab 0a d1 d8 11 31 cc d1 4c d9 [DBG][1970/01/01/08:00:03:839][:290]uart attribute config:[/dev/ttyAMA1][9600] [19700101-08:00:03.840 D 239] md.c 689: enable=1 sensitivity=50 thr=220 :::InitShBuf 84 sdk_app MAJOR[0] size=512000 :::InitShBuf 91 sdk_app MAJOR[1] size=204800 :::InitShBuf 98 sdk_app MJPEG[2] size=204800 InitShBuf 105 sdk_app AUDIOOUT[4] size=65536 sdk_app AUDIOIN[5] size=16384[19700101-08:00:03.845 D 183] hk_stream.c 179: Create thread of hank_audio_thread success! [19700101-08:00:03.845 D 183] hk_playvoice.c 475: hank_set_audio_play_enable 1 [19700101-08:00:03.845 D 183] hk_stream.c 185: start hk_huiyun_stream_init end, video size:524288 audioout format:0 [DBG][1970/01/01/08:00:03:845][:1149]------ platform module init done ------ [19700101-08:00:03.847 D 183] motor_TMI8152.c 1305: [motor_module_create_TMI8152] Start Create handle=0xb6f6ca60 [19700101-08:00:03.847 D 183] motor_TMI8152.c 1322: [motor_module_create_TMI8152] OK [19700101-08:00:03.847 D 183] motor_TMI8152.c 166: [TMI8152_init] TMI8152 handle=0xb6f6ca60 OK :::mcu_send_data_buffer 2136 cmd=[a0 0 9 0] :::mcu_send_data_buffer 2187 [0] uart send >>> ab 0d a0 01 02 01 08 00 05 00 02 01 0a [19700101-08:00:03.858 D 255] hank_dev_json.c 147: get Json Object name=Tuya type=64 [19700101-08:00:03.859 I 255] hank_dev_json.c 297: parse obj cloud_plat:Tuya chip:GK720XXXXX CompanyVid: finished!!! [19700101-08:00:03.859 I 255] platform_common.c 75: parse cloud_info success. [19700101-08:00:03.859 I 255] hank_parameter.c 408: [hk_parameter_set_int] DayNightMode=1 [19700101-08:00:03.863 I 257] hal_sdcard.c 87: mnt_fsname :mmcblk0 [19700101-08:00:03.863 I 257] hal_sdcard.c 88: mnt_dir :/mnt/flash/mmc [19700101-08:00:03.863 I 257] hal_sdcard.c 89: mnt_type :vfat [19700101-08:00:03.863 I 257] hal_sdcard.c 90: mnt_opt :rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro [19700101-08:00:03.864 I 257] hal_sdcard.c 91: mnt_freq :0 [19700101-08:00:03.864 I 257] hal_sdcard.c 92: mnt_passno :0 [19700101-08:00:03.864 I 257] hal_sdcard.c 106: sd state report state:3 [19700101-08:00:03.864 D 257] hal_sdcard.c 121: dev mount success! [19700101-08:00:03.871 I 261] tuya_led_1315B.c 59: start init redled gpio [DBG][1970/01/01/08:00:03:880][:107]platform push eventId 0x905 [1] [DBG][1970/01/01/08:00:03:916][:529]log recv a msg: (0x108) [DBG][1970/01/01/08:00:03:917][:2100]oem TyPid= [DBG][1970/01/01/08:00:03:917][:2106]TyPid=glgx6l1rkenztvdh [DBG][1970/01/01/08:00:03:917][:2112]Tyid=qc11c9618107370f3fbe Tykey=7ywGtZ3sfxCpPfhYT9pB86cU9kZdBl4U [DBG][1970/01/01/08:00:03:917][:2167]tuya pid[glgx6l1rkenztvdh] uuid[qc11c9618107370f3fbe] authkey[7ywGtZ3sfxCpPfhYT9pB86cU9kZdBl4U] enable[1] [19700101-08:00:03.918 D 241] media_mqtt.c 265: msg_value: 0 :::daynight_mode_convert_dayNightContrl 3079 0 [DBG][1970/01/01/08:00:03:959][:528]index:1 [DBG][1970/01/01/08:00:03:959][:254]===========sample_wlan_init_ip============ [DBG][1970/01/01/08:00:03:959][:260]wlan ip[0.0.0.0] netmask[0.0.0.0] gw[0.0.0.0] boardcast[0.0.0.255] [ERR][1970/01/01/08:00:03:959][:264]ip addr is empty! [DBG][1970/01/01/08:00:03:961][:427]hal recv a msg: (0x905) [DBG][1970/01/01/08:00:03:961][:263]msgvalue: 0 :::lightsns_enter_nightmode_switch_mode:::299::curmode[0]:: [19700101-08:00:03.978 I 261] tuya_led_1315B.c 64: start init blueled gpio uart recv <<< ab 13 a0 00 01 34 47 0e 24 06 12 10 38 16 21 24 04 30 5b [DBG][1970/01/01/08:00:04:045][:1600]mcu handle cmd : 0xa0 :::mcu_check_cmd_resend 2126 [a0 a0] :::camera_mcu_startupinfo 1540 uwkup_reason[0] mcu_version[21 24 04 30][ 71 14 ][1 52] [last[0] [DBG][1970/01/01/08:00:04:045][:1473]0check_battery->lowper_flags[0] check_battery->check_count[0] check_val[52] [DBG][2024/06/12/10:38:16:000][:1572]currentTime:4 mcuTime:1718159896 zonetime:0 [DBG][2024/06/12/10:38:16:000][:1582]chargestatus[1] batteryvalue[52] lastbattery[0] :::camera_mcu_startupinfo 1583 wakeu[0] [DBG][2024/06/12/10:38:16:000][:101]mcu push mcu_eventId 0x10b [1] [DBG][2024/06/12/10:38:16:000][:1461]mcu_Heart_pthread start create heart task log_file_open : 244 : log file[/mnt/flash/mmc/devicelog/20240612_103816.txt] [DBG][2024/06/12/10:38:16:021][:851]platform recv a msg: (0x10b) [DBG][2024/06/12/10:38:16:060][:205]now push battery[52] charge[1] ts[1718159896]! [DBG][2024/06/12/10:38:16:060][:152]:::word_commond_set_flag:::152:::sd_flag 0 1: [20240612-10:38:16.115 I 261] tuya_led_1315B.c 73: start init Alarm gpio [20240612-10:38:16.130 I 261] tuya_led_1315B.c 208: INDICATORLED GPIO CMD:xmmm 0x112C0040 0x0 > /dev/null REDLED GPIO:40 ENABLE_LEVEL:1 [20240612-10:38:16.130 I 261] tuya_led_1315B.c 209: INDICATORLED GPIO CMD:xmmm 0x112C005C 0x0 > /dev/null BLUELED GPIO:57 ENABLE_LEVEL:1 [20240612-10:38:16.134 D 183] motor_TMI8152.c 156: init BOARDID_1315B gpio over! tuya_ipc_platform_uart_init begin tuya_ipc_platform_uart_init end uart recv <<< ab 08 a7 01 34 47 0e 78 [DBG][2024/06/12/10:38:16:170][:1600]mcu handle cmd : 0xa7 :::mcu_check_cmd_resend 2123 not mcu buffer data send[0 a7] [DBG][2024/06/12/10:38:16:170][:1473]0check_battery->lowper_flags[0] check_battery->check_count[0] check_val[52] [DBG][2024/06/12/10:38:16:170][:101]mcu push mcu_eventId 0x10b [1] [MSG][2024/06/12/10:38:16:170][:1516]batteryvalue[52] charge[1] [20240612-10:38:16.256 I 183] motor_TMI8152.c 216: sync userPosition userStepX:207 userStepY:90 [20240612-10:38:16.256 D 183] motor_TMI8152.c 260: set x:207 y:90 motor_dir:1 user_dir:6 [20240612-10:38:16.256 I 183] hank_parameter.c 408: [hk_parameter_set_int] userStepX=207 [20240612-10:38:16.258 I 183] hank_parameter.c 408: [hk_parameter_set_int] userStepY=90 [01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/flash/p2pCache/ [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/flash/p2pCache/ [01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/flash/p2pCache/ [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[ḉhV4~뚜FDV] [01-01 18:12:15 TUYA D][simplekv.c:989] both file not exist /mnt/flash/p2pCache/tuya_user.db [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512 [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success [01-01 18:12:15 TUYA D][simplekv.c:1083] init NEW normal file [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 3536627844 [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success [01-01 18:12:15 TUYA D][smart_frame.c:3473] dp filtered, dev no act [DBG][2024/06/12/10:38:16:370][:851]platform recv a msg: (0x10b) [DBG][2024/06/12/10:38:16:370][:205]now push battery[52] charge[1] ts[1718159896]! [01-01 18:12:15 TUYA D][smart_frame.c:3473] dp filtered, dev no act [20240612-10:38:16.460 D 229] region.c 2679: ^_^ osd time width=800 height=448 fsize=20 size=0 [20240612-10:38:16.473 D 229] region.c 2679: ^_^ osd time width=800 height=448 fsize=20 size=0 [01-01 18:12:15 TUYA D][tuya_ipc_webrtc.c:1531] begin___ [01-01 18:12:15 TUYA D][tuya_ipc_webrtc.c:1538] --audio-:8000,format:105 [01-01 18:12:15 TUYA D][tuya_ipc_webrtc.c:1539] end___ audiocbk_hdl(0x44fd4) [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success. [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ... [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2 [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success [01-01 18:12:15 TUYA E][log_seq.c:871] logseq empty [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6 [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6 [01-01 18:12:15 TUYA D][tuya_bt_sdk.c:92] ty bt cmmod regist ok:1 [01-01 18:12:15 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon. dev id key: 16 d4 1d 8c d9 8f 00 b2 04 e9 80 09 98 ec f8 42 7e [01-01 18:12:15 TUYA I][bt_ext_porting.c:352] [TUYA-BTUART]tuya ext bt port init [01-01 18:12:15 TUYA N][tuya_ble_api.c:650] ble sdk re_inited [01-01 18:12:15 TUYA D][tuya_ble_active.c:523] bt active init [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:141] ty bt sdk init success finish [20240612-10:38:16.504 D 183] motor_TMI8152.c 134: IRCUT ANTI_CLOCKWISE OVER! [20240612-10:38:16.504 D 183] motor_TMI8152.c 942: [TMI8152_ctrl] TMI8152 handle=0xb6f6ca60 type=13 OK [DBG][2024/06/12/10:38:16:504][:525]params->stpowermode.function_switch=0 [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6 :::wifi_factory_task_process 382 not factory [20240612-10:38:16.540 D 308] my_main.c 634: connect cb :::mw_DoubleLight_Func 3108 isp_start_test [20240612-10:38:16.600 D 228] quickstart_rootfs.c 202: [pwm_ctrl] num:1, duty 16000 :0 [20240612-10:38:16.600 D 228] gk_isp_os02h10.c 3908: [mw_DoubleLight_Func]--[3908] dualMode full color, day state, close wled and rled ===== :::mw_img_irmode_set_daynight 2966 [2] [20240612-10:38:16.600 D 228] quickstart_rootfs.c 1831: open white light [20240612-10:38:16.601 I 228] hank_parameter.c 408: [hk_parameter_set_int] DayNightMode=1 :::mw_imgs_set_icr_switch 2698 mode =[1] [DBG][2024/06/12/10:38:16:625][:427]hal recv a msg: (0x93c) [DBG][2024/06/12/10:38:16:625][:281]::::curmode[0 0]:: [20240612-10:38:16.625 D 256] motor_TMI8152.c 942: [TMI8152_ctrl] TMI8152 handle=0xb6f6ca60 type=12 OK [DBG][2024/06/12/10:38:16:630][:647]WIFI Get MAC 24-C6-1C-00-00-00 [DBG][2024/06/12/10:38:16:630][:869]Set Country Code:(null) [01-01 18:12:15 TUYA E][tuya_devos_entry.c:1769] ret:-2 [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_di -6 [01-01 18:12:15 TUYA E][ws_db_gw.c:494] gw_di read fail:-6 [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_ai -6 [01-01 18:12:15 TUYA E][ws_db_gw.c:636] gw_ai read fail:-6 [01-01 18:12:15 TUYA E][tuya_ipc_hardware_info.c:172] NO sensor info. Please check if you need. uuid: 20 71 63 31 31 63 39 36 31 38 31 30 37 33 37 30 66 33 66 62 65 dev_id_tmp: 16 68 c0 41 30 91 81 20 10 07 0c 70 0f 0c f2 ce ff dev_id_tmp2: 20 71 63 31 31 63 39 36 31 38 31 30 37 33 37 30 66 33 66 62 65 [DBG][2024/06/12/10:38:16:757][:647]WIFI Get MAC 00-00-00-00-00-00 Exec Cmd:ifconfig wlan0 up dev id key: 16 36 8e c0 64 f5 84 3b d0 ba da 26 0a 89 a9 bc e8 [20240612-10:38:16.758 D 312] hk_stream.c 312: stream[2] change buffer and send loss video data [20240612-10:38:16.766 D 311] hk_stream.c 312: stream[0] change buffer and send loss video data [20240612-10:38:16.766 D 311] hk_stream.c 312: stream[1] change buffer and send loss video data [DBG][2024/06/12/10:38:16:784][:1694]regStatus ==== 0! [DBG][2024/06/12/10:38:16:785][:107]platform push eventId 0x932 [1] [DBG][2024/06/12/10:38:16:788][:1981]wait mqtt online: 4.834 [DBG][2024/06/12/10:38:16:806][:1331]create sleep thread [DBG][2024/06/12/10:38:16:808][:705]WIFI Set Mode 3 [DBG][2024/06/12/10:38:16:809][:846]Start AP SSID:SmartLife-0000 [DBG][2024/06/12/10:38:16:809][:848]cfg->ip:192.168.175.1 mask=255.255.255.0 gw=192.168.175.1 curr event:1 [20240612-10:38:16.824 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:16.824 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:16.834 D 256] motor_TMI8152.c 128: IRCUT CLOCKWISE OVER! [DBG][2024/06/12/10:38:16:897][:427]hal recv a msg: (0x932) [DBG][2024/06/12/10:38:16:897][:205]msgvalue: 2 [20240612-10:38:16.904 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:16.904 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:16.947 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:16.951 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.077 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.077 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.094 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.094 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [DBG][2024/06/12/10:38:17:114][:1372]wait gs_tuyaDevinfo.regStatus... [DBG][2024/06/12/10:38:17:114][:1380]first start qrcode... [DBG][2024/06/12/10:38:17:114][:833]platform_start_qrdecode Create qrcodes_work thrd=3060256124 Success! [DBG][2024/06/12/10:38:17:115][:107]platform push eventId 0x91a [4] [20240612-10:38:17.119 D 308] my_main.c 621: media recv a msg: (0x91a) [20240612-10:38:17.119 D 308] my_main.c 496: voice_speak_process int_param:20 [20240612-10:38:17.120 D 308] hk_playvoice.c 305: hank_Play_AudioFile pri 2, file /mnt/flash/Server/resource/audio/en/3.g711u, repeat 1, duration -1, block 1 [20240612-10:38:17.120 D 308] hk_playvoice.c 152: hank_Play_AudioFile_now begin /mnt/flash/Server/resource/audio/en/3.g711u [20240612-10:38:17.171 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.172 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [DBG][2024/06/12/10:38:17:175][:759]create qrcode thread and send EVENTID_PLAT_QRCODE_START event [DBG][2024/06/12/10:38:17:175][:107]platform push eventId 0x91c [0] [20240612-10:38:17.177 D 241] media_mqtt.c 303: media_video_start_qrcode int_param:0 [20240612-10:38:17.177 D 241] media_gk72010300.c 301: [GK72010300_qrcode_yraw_data] GK72010300 handle=0xb6e7bf80 [20240612-10:38:17.177 D 241] quickstart_rootfs.c 2144: [qr_vpss_depthSetting] vpssChn=1 u32Depth=1 [20240612-10:38:17.180 E 316] hk_stream.c 574: scan qrFileName /tmp/qrcode.yuv not exsit! [MSG][2024/06/12/10:38:17:180][:772]get yuv picture failed! [20240612-10:38:17.180 D 317] quickstart_rootfs.c 2054: HI_MPI_ISP_GetExposureAttr sucees ! :::qr_mode_isp_open 2071 [1 0] [20240612-10:38:17.230 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.230 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.336 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.336 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.361 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.374 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.394 D 225] stream_reader.c 1309: audio swtich ON AUDIO_CTRL:56 [20240612-10:38:17.430 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.447 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.483 D 238] sample_aisdk.c 788: xmedia_ivp_set_ctrl_attr set threshold=0.700000 [20240612-10:38:17.501 D 238] sample_aisdk.c 1163: ivp_smd_start success,ivp_handle=0 [20240612-10:38:17.505 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.505 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.517 D 227] gk_isp_os02h10.c 1818: HI_MPI_VPSS_GetGrpNRSParam return ret = 0xa0078003 [20240612-10:38:17.517 D 227] gk_isp_os02h10.c 1922: set 3dnr param failed. 0xa0078003 [20240612-10:38:17.570 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.573 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [Func]:MPI_ISP_SetExposureAttr [Line]:38 [Info]:ISP[1] Mem NOT Init 0! [20240612-10:38:17.636 E 228] gk_isp_os02h10.c 2185: [mw_img_set_ae_daynight] Set auto exposure attribute pipe1 failed!! [Func]:ISP_CheckMemInit [Line]:124 [Info]:ISP[1] Mem NOT Init 0! [20240612-10:38:17.640 E 228] mw_isp_interface.c 1755: [ISP_Set_DN_Gamma] HI_MPI_ISP_SetGammaAttr pipe1 failed [20240612-10:38:17.642 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.642 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.711 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [DBG][2024/06/12/10:38:17:717][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [20240612-10:38:17.725 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.779 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.779 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.854 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.854 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.917 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.920 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:17.980 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:17.997 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:18.064 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:18.064 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:18.123 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:18.134 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:18.185 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [20240612-10:38:18.189 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:18.204 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:18.258 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:18.262 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:18.329 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:18.335 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:18.404 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:18.404 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:18.463 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:18.466 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:18.534 I 311] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:38:18.544 I 311] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:38:18.602 D 311] hk_stream.c 430: quickstart_debug stream[0] get Iframe over 6.648 [20240612-10:38:18.615 D 311] hk_stream.c 430: quickstart_debug stream[1] get Iframe over 6.661 [DBG][2024/06/12/10:38:18:824][:107]platform push eventId 0x92d [0] [DBG][2024/06/12/10:38:18:824][<__IPC_APP_Get_Net_Status_cb>:1576]Net status change to:2 [DBG][2024/06/12/10:38:18:824][<__IPC_APP_Get_Net_Status_cb>:1576]Net status change to:5 [DBG][2024/06/12/10:38:18:826][:1967]mcu recv a msg: (0x92d) [DBG][2024/06/12/10:38:18:827][:868]devIdInfo SmartLife_370f3fbe datalen 18 [DBG][2024/06/12/10:38:18:827][:891]soc send MCU_CMD_WIFI_APNAME(0xd7) cmd to wifi wifi send: ab 16 d7 53 6d 61 72 74 4c 69 66 65 5f 33 37 30 66 33 66 62 65 4a [DBG][2024/06/12/10:38:18:880][:601]WIFI[0] Get IP: [01-01 18:12:17 TUYA E][mqtt_client.c:807] hand null. dev id key: 16 da 44 db 3b d0 da 70 b1 68 af 23 51 62 f6 7e d4 [DBG][2024/06/12/10:38:19:074][:1433]start mcu MCU_CMD_HEARTBEAT ... [DBG][2024/06/12/10:38:19:074][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [20240612-10:38:19.201 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:19:201][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:19:384][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] [DBG][2024/06/12/10:38:19:504][:528]index:1 [DBG][2024/06/12/10:38:19:504][:254]===========sample_wlan_init_ip============ [DBG][2024/06/12/10:38:19:504][:260]wlan ip[192.168.175.1] netmask[255.255.255.0] gw[192.168.175.1] boardcast[192.168.175.255] :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [20240612-10:38:19.559 D 328] motor_TMI8152.c 1215: [TMI8152_selfcheck] TMI8152 handle=0xb6f6ca60 OK [20240612-10:38:19.560 D 328] motor_TMI8152.c 1065: hspeed:8 vspeed:8 [20240612-10:38:19.560 D 328] motor_TMI8152.c 1066: sinfo h factor:1 microstep:4 speed:18 [20240612-10:38:19.560 D 328] motor_TMI8152.c 1067: sinfo v factor:1 microstep:4 speed:18 [DBG][2024/06/12/10:38:19:626][:742]QRString Size:0! [20240612-10:38:19.628 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [MSG][2024/06/12/10:38:19:736][:369]===net device set ip success! wifistatus[1]=== [DBG][2024/06/12/10:38:20:214][:1372]wait gs_tuyaDevinfo.regStatus... [20240612-10:38:20.664 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:20:664][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:20:725][:1294]send wifi heartbeat---wifihbcnt[1][8][52] [DBG][2024/06/12/10:38:20:979][:742]QRString Size:0! [20240612-10:38:21.006 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [20240612-10:38:22.035 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:22:036][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:22:300][:742]QRString Size:0! [20240612-10:38:22.303 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [20240612-10:38:22.406 D 308] hk_playvoice.c 250: hank_Play_AudioFile_now /mnt/flash/Server/resource/audio/en/3.g711u end [20240612-10:38:22.406 D 308] hk_playvoice.c 251: total_data_len 42086, play_time 5205, audio_time 5260 [20240612-10:38:23.305 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:23:305][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:23:314][:1372]wait gs_tuyaDevinfo.regStatus... [DBG][2024/06/12/10:38:23:574][:742]QRString Size:0! [20240612-10:38:23.576 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:23:734][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:38:23:834][:601]WIFI[1] Get IP:192.168.175.1 gethostbyname_r error: Try again [01-01 18:12:22 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:12:22 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:12:22 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:12:22 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:12:22 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [01-01 18:12:22 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:38:23:947][:735]WIFI Get Mode 3 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [20240612-10:38:24.586 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:24:586][:782]qrcode yuv info [800*448][358400] [20240612-10:38:24.654 I 328] motor_TMI8152.c 1085: goto motor motorMaxPan over, cur_step=450 [DBG][2024/06/12/10:38:24:841][:742]QRString Size:0! [20240612-10:38:24.878 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:24:957][:735]WIFI Get Mode 3 [01-01 18:12:23 TUYA E][tuya_devos_activate.c:527] network unavailable [20240612-10:38:25.886 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:25:886][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:26:175][:742]QRString Size:0! [20240612-10:38:26.177 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:26:414][:1372]wait gs_tuyaDevinfo.regStatus... [DBG][2024/06/12/10:38:26:744][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [20240612-10:38:27.188 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:27:188][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:27:467][:742]QRString Size:0! [20240612-10:38:27.470 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [20240612-10:38:28.034 D 225] stream_reader.c 1319: audio swtich OFF AUDIO_CTRL:56 [20240612-10:38:28.481 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:28:481][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:28:722][:742]QRString Size:0! [20240612-10:38:28.768 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:28:834][:601]WIFI[1] Get IP:192.168.175.1 [DBG][2024/06/12/10:38:29:084][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [DBG][2024/06/12/10:38:29:414][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] [DBG][2024/06/12/10:38:29:514][:1372]wait gs_tuyaDevinfo.regStatus... :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:38:29:755][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [20240612-10:38:29.758 I 328] motor_TMI8152.c 1098: goto motorMaxPan 0 over, cur_step=450 [20240612-10:38:29.775 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:29:775][:782]qrcode yuv info [800*448][358400] gethostbyname_r error: Try again [01-01 18:12:28 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:12:28 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:12:28 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:12:28 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:12:28 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:38:29:974][:735]WIFI Get Mode 3 [01-01 18:12:28 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:38:30:111][:742]QRString Size:0! [20240612-10:38:30.112 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:12:29 TUYA E][tuya_devos_activate.c:527] network unavailable [20240612-10:38:31.117 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:31:117][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:31:462][:742]QRString Size:0! [20240612-10:38:31.488 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [20240612-10:38:31.798 I 328] motor_TMI8152.c 1111: goto motor motorMaxTilt over, cur_step=180 [20240612-10:38:32.497 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:32:497][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:32:614][:1372]wait gs_tuyaDevinfo.regStatus... [DBG][2024/06/12/10:38:32:767][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:38:32:902][:742]QRString Size:0! [20240612-10:38:32.933 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [20240612-10:38:33.834 I 328] motor_TMI8152.c 1124: goto motorTilt 0 over, cur_step=180 [DBG][2024/06/12/10:38:33:844][:601]WIFI[1] Get IP:192.168.175.1 [20240612-10:38:33.955 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:33:956][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:34:293][:742]QRString Size:0! [20240612-10:38:34.328 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [20240612-10:38:34.345 D 328] motor_TMI8152.c 1251: Yaxis_angel=58 Yaxis_circle=2 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [20240612-10:38:34.855 D 328] motor_TMI8152.c 1251: Yaxis_angel=117 Yaxis_circle=2 [20240612-10:38:35.337 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:35:337][:782]qrcode yuv info [800*448][358400] [20240612-10:38:35.366 D 328] motor_TMI8152.c 1251: Yaxis_angel=176 Yaxis_circle=2 [DBG][2024/06/12/10:38:35:662][:742]QRString Size:0! [20240612-10:38:35.685 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:35:716][:1372]wait gs_tuyaDevinfo.regStatus... [DBG][2024/06/12/10:38:35:774][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [20240612-10:38:35.874 D 328] motor_TMI8152.c 1251: Yaxis_angel=207 Yaxis_circle=2 [20240612-10:38:35.874 I 328] motor_TMI8152.c 1254: goto motor user hlocat=207 over gethostbyname_r error: Try again [01-01 18:12:34 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:12:34 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:12:34 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:12:34 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:12:34 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:38:35:996][:735]WIFI Get Mode 3 [01-01 18:12:34 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:38:35:996][:834]Get wifi station status 6 [20240612-10:38:36.384 D 328] motor_TMI8152.c 1268: Xaxis_angel=58 Xaxis_circle=2 [20240612-10:38:36.697 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:36:697][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:36:854][:735]WIFI Get Mode 3 [20240612-10:38:36.895 D 328] motor_TMI8152.c 1268: Xaxis_angel=90 Xaxis_circle=2 [20240612-10:38:36.895 I 328] motor_TMI8152.c 1271: goto motor user vlocat=90 over [20240612-10:38:36.895 D 328] motor_TMI8152.c 260: set x:207 y:90 motor_dir:1 user_dir:6 [DBG][2024/06/12/10:38:37:001][:742]QRString Size:0! [20240612-10:38:37.003 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:12:35 TUYA E][tuya_devos_activate.c:527] network unavailable [20240612-10:38:38.006 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:38:006][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:38:242][:742]QRString Size:0! [20240612-10:38:38.264 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:38:784][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:38:38:814][:1372]wait gs_tuyaDevinfo.regStatus... [DBG][2024/06/12/10:38:38:844][:601]WIFI[1] Get IP:192.168.175.1 [DBG][2024/06/12/10:38:39:094][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [20240612-10:38:39.277 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:39:277][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:39:344][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] [DBG][2024/06/12/10:38:39:519][:742]QRString Size:0! [20240612-10:38:39.522 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [20240612-10:38:40.527 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:40:530][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:40:809][:742]QRString Size:0! [20240612-10:38:40.811 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:41:794][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [20240612-10:38:41.816 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:41:816][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:41:914][:1372]wait gs_tuyaDevinfo.regStatus... gethostbyname_r error: Try again [01-01 18:12:40 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:12:40 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:12:40 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:12:40 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:12:40 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:38:42:034][:735]WIFI Get Mode 3 [01-01 18:12:40 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:38:42:104][:742]QRString Size:0! [20240612-10:38:42.106 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:12:41 TUYA E][tuya_devos_activate.c:527] network unavailable [20240612-10:38:43.118 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:43:119][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:43:369][:742]QRString Size:0! [20240612-10:38:43.371 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:43:854][:601]WIFI[1] Get IP:192.168.175.1 [20240612-10:38:44.375 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:44:375][:782]qrcode yuv info [800*448][358400] :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:38:44:645][:742]QRString Size:0! [20240612-10:38:44.647 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:44:806][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:38:45:014][:1372]wait gs_tuyaDevinfo.regStatus... [20240612-10:38:45.655 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:45:656][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:45:864][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:38:45:950][:742]QRString Size:0! [20240612-10:38:45.953 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [20240612-10:38:46.684 D 312] hk_stream.c 516: Send StreamID:2 EncodeType:1 CachedCount:0 SendCount:750 [20240612-10:38:46.956 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:46:956][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:47:217][:742]QRString Size:0! [20240612-10:38:47.237 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:47:814][:1294]send wifi heartbeat---wifihbcnt[0][8][52] gethostbyname_r error: Try again [01-01 18:12:46 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:12:46 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:12:46 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:12:46 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:12:46 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [01-01 18:12:46 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:38:48:119][:1372]wait gs_tuyaDevinfo.regStatus... [20240612-10:38:48.246 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:48:246][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:48:506][:742]QRString Size:0! [20240612-10:38:48.508 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:48:854][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:38:48:854][:601]WIFI[1] Get IP:192.168.175.1 [01-01 18:12:47 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:38:49:075][:834]Get wifi station status 6 [DBG][2024/06/12/10:38:49:104][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [DBG][2024/06/12/10:38:49:374][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] [20240612-10:38:49.516 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:49:517][:782]qrcode yuv info [800*448][358400] [20240612-10:38:49.520 D 311] hk_stream.c 468: Send StreamID:0 EncodeType:6 CachedCount:0 SendCount:450 [20240612-10:38:49.534 D 311] hk_stream.c 477: Send StreamID:1 EncodeType:7 CachedCount:1 SendCount:450 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:38:49:785][:742]QRString Size:0! [20240612-10:38:49.788 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [20240612-10:38:50.796 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:50:796][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:50:824][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:38:51:058][:742]QRString Size:0! [20240612-10:38:51.060 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:51:214][:1372]wait gs_tuyaDevinfo.regStatus... [20240612-10:38:52.066 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:52:066][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:52:347][:742]QRString Size:0! [20240612-10:38:52.350 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [20240612-10:38:53.356 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:53:357][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:53:627][:742]QRString Size:0! [20240612-10:38:53.637 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:53:835][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:38:53:864][:601]WIFI[1] Get IP:192.168.175.1 gethostbyname_r error: Try again [01-01 18:12:52 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:12:52 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:12:52 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:12:52 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:12:52 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:38:54:098][:735]WIFI Get Mode 3 [01-01 18:12:52 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:38:54:317][:1372]wait gs_tuyaDevinfo.regStatus... :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [20240612-10:38:54.648 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:54:648][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:54:951][:742]QRString Size:0! [20240612-10:38:54.953 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:54:956][:735]WIFI Get Mode 3 [01-01 18:12:53 TUYA E][tuya_devos_activate.c:527] network unavailable [20240612-10:38:55.957 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:55:958][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:56:241][:742]QRString Size:0! [20240612-10:38:56.265 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:12:55 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=40&v=1.0&sign=5e4d46ce16e380d79403317a5bb2d35c:80 errno=101 [01-01 18:12:55 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=40&v=1.0&sign=5e4d46ce16e380d79403317a5bb2d35c (-7) [01-01 18:12:55 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [DBG][2024/06/12/10:38:56:846][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:12:55 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=40&v=1.0&sign=5e4d46ce16e380d79403317a5bb2d35c:80 errno=101 [01-01 18:12:55 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=40&v=1.0&sign=5e4d46ce16e380d79403317a5bb2d35c (-7) [01-01 18:12:55 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [20240612-10:38:57.281 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:57:281][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:57:414][:1372]wait gs_tuyaDevinfo.regStatus... [01-01 18:12:56 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=41&v=1.0&sign=f23eefff5e09146487afc2319e84695b:80 errno=101 [01-01 18:12:56 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=41&v=1.0&sign=f23eefff5e09146487afc2319e84695b (-7) [01-01 18:12:56 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [DBG][2024/06/12/10:38:57:552][:742]QRString Size:0! [20240612-10:38:57.572 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:12:56 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=41&v=1.0&sign=f23eefff5e09146487afc2319e84695b:80 errno=101 [01-01 18:12:56 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=41&v=1.0&sign=f23eefff5e09146487afc2319e84695b (-7) [01-01 18:12:56 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:12:57 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=42&v=1.0&sign=72291e01283b031bbdba60e3ddabf36f:80 errno=101 [01-01 18:12:57 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=42&v=1.0&sign=72291e01283b031bbdba60e3ddabf36f (-7) [01-01 18:12:57 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [20240612-10:38:58.576 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:58:576][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:58:828][:742]QRString Size:0! [20240612-10:38:58.829 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:58:864][:601]WIFI[1] Get IP:192.168.175.1 [01-01 18:12:57 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=42&v=1.0&sign=72291e01283b031bbdba60e3ddabf36f:80 errno=101 [01-01 18:12:57 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=42&v=1.0&sign=72291e01283b031bbdba60e3ddabf36f (-7) [01-01 18:12:57 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [DBG][2024/06/12/10:38:59:114][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [DBG][2024/06/12/10:38:59:404][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] [01-01 18:12:58 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=43&v=1.0&sign=1c15ed2a8557005a393d07a91fcb2267:80 errno=101 [01-01 18:12:58 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=43&v=1.0&sign=1c15ed2a8557005a393d07a91fcb2267 (-7) [01-01 18:12:58 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [20240612-10:38:59.837 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:38:59:837][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:38:59:854][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:12:58 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=43&v=1.0&sign=1c15ed2a8557005a393d07a91fcb2267:80 errno=101 [01-01 18:12:58 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=43&v=1.0&sign=1c15ed2a8557005a393d07a91fcb2267 (-7) [01-01 18:12:58 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [DBG][2024/06/12/10:39:00:129][:742]QRString Size:0! [20240612-10:39:00.131 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 gethostbyname_r error: Try again [01-01 18:12:58 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:12:58 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:12:58 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:12:58 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:12:58 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:39:00:134][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:39:00:135][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:39:00:135][:735]WIFI Get Mode 3 [01-01 18:12:58 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:39:00:514][:1372]wait gs_tuyaDevinfo.regStatus... [01-01 18:12:59 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=44&v=1.0&sign=aea91c21b032b8113046145b7b28513f:80 errno=101 [01-01 18:12:59 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=44&v=1.0&sign=aea91c21b032b8113046145b7b28513f (-7) [01-01 18:12:59 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:12:59 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=44&v=1.0&sign=aea91c21b032b8113046145b7b28513f:80 errno=101 [01-01 18:12:59 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=44&v=1.0&sign=aea91c21b032b8113046145b7b28513f (-7) [01-01 18:12:59 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [20240612-10:39:01.137 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:01:138][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:01:388][:742]QRString Size:0! [20240612-10:39:01.390 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:00 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=45&v=1.0&sign=6901a5633aed3b2a9c4c97c541e45273:80 errno=101 [01-01 18:13:00 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=45&v=1.0&sign=6901a5633aed3b2a9c4c97c541e45273 (-7) [01-01 18:13:00 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:00 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=45&v=1.0&sign=6901a5633aed3b2a9c4c97c541e45273:80 errno=101 [01-01 18:13:00 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=45&v=1.0&sign=6901a5633aed3b2a9c4c97c541e45273 (-7) [01-01 18:13:00 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [20240612-10:39:02.397 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:02:397][:782]qrcode yuv info [800*448][358400] [01-01 18:13:01 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=46&v=1.0&sign=701322374db27cbd7ba6ef59529258fd:80 errno=101 [01-01 18:13:01 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=46&v=1.0&sign=701322374db27cbd7ba6ef59529258fd (-7) [01-01 18:13:01 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [DBG][2024/06/12/10:39:02:652][:742]QRString Size:0! [20240612-10:39:02.677 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:02:864][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:13:01 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=46&v=1.0&sign=701322374db27cbd7ba6ef59529258fd:80 errno=101 [01-01 18:13:01 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=46&v=1.0&sign=701322374db27cbd7ba6ef59529258fd (-7) [01-01 18:13:01 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [DBG][2024/06/12/10:39:03:614][:1372]wait gs_tuyaDevinfo.regStatus... [01-01 18:13:02 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=47&v=1.0&sign=e26344afe806f81be4674e963ed4409e:80 errno=101 [01-01 18:13:02 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=47&v=1.0&sign=e26344afe806f81be4674e963ed4409e (-7) [01-01 18:13:02 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [20240612-10:39:03.689 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:03:689][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:03:874][:601]WIFI[1] Get IP:192.168.175.1 [DBG][2024/06/12/10:39:03:914][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:39:04:006][:742]QRString Size:0! [20240612-10:39:04.008 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:02 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=47&v=1.0&sign=e26344afe806f81be4674e963ed4409e:80 errno=101 [01-01 18:13:02 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=47&v=1.0&sign=e26344afe806f81be4674e963ed4409e (-7) [01-01 18:13:02 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [01-01 18:13:03 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=48&v=1.0&sign=914c47d87e74896d0b2294e915671238:80 errno=101 [01-01 18:13:03 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=48&v=1.0&sign=914c47d87e74896d0b2294e915671238 (-7) [01-01 18:13:03 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [20240612-10:39:05.017 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:05:017][:782]qrcode yuv info [800*448][358400] [01-01 18:13:03 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=48&v=1.0&sign=914c47d87e74896d0b2294e915671238:80 errno=101 [01-01 18:13:03 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=48&v=1.0&sign=914c47d87e74896d0b2294e915671238 (-7) [01-01 18:13:03 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [DBG][2024/06/12/10:39:05:278][:742]QRString Size:0! [20240612-10:39:05.280 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:04 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=49&v=1.0&sign=ed5c1dcb7f6a81ccd9a79da6d84cc936:80 errno=101 [01-01 18:13:04 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=49&v=1.0&sign=ed5c1dcb7f6a81ccd9a79da6d84cc936 (-7) [01-01 18:13:04 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [DBG][2024/06/12/10:39:05:874][:1294]send wifi heartbeat---wifihbcnt[0][8][52] gethostbyname_r error: Try again [01-01 18:13:04 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:13:04 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:13:04 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:13:04 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:13:04 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:39:06:167][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:39:06:168][:735]WIFI Get Mode 3 [01-01 18:13:04 TUYA E][tuya_devos_activate.c:527] network unavailable [01-01 18:13:04 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.password.update&devId=&et=1&t=49&v=1.0&sign=ed5c1dcb7f6a81ccd9a79da6d84cc936:80 errno=101 [01-01 18:13:04 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.password.update&devId=&et=1&t=49&v=1.0&sign=ed5c1dcb7f6a81ccd9a79da6d84cc936 (-7) [01-01 18:13:04 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [DBG][2024/06/12/10:39:06:219][:735]WIFI Get Mode 3 [20240612-10:39:06.288 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:06:288][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:06:538][:742]QRString Size:0! [20240612-10:39:06.540 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:06:714][:1372]wait gs_tuyaDevinfo.regStatus... [01-01 18:13:05 TUYA E][tuya_ipc_p2p_common.c:257] p2p passwd update failed [01-01 18:13:05 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=50&v=2.0&sign=630701b2f368ab2cc1d7e6ee46ab2f04:80 errno=101 [01-01 18:13:05 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=50&v=2.0&sign=630701b2f368ab2cc1d7e6ee46ab2f04 (-7) [01-01 18:13:05 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:05 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [01-01 18:13:05 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:39:07:174][:834]Get wifi station status 6 [20240612-10:39:07.547 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:07:547][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:07:827][:742]QRString Size:0! [20240612-10:39:07.829 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:06 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=51&v=2.0&sign=594aa0f5e5bd02ccdb14f6fd4e51dde5:80 errno=101 [01-01 18:13:06 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=51&v=2.0&sign=594aa0f5e5bd02ccdb14f6fd4e51dde5 (-7) [01-01 18:13:06 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:06 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [20240612-10:39:08.835 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:08:836][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:08:884][:601]WIFI[1] Get IP:192.168.175.1 [DBG][2024/06/12/10:39:08:884][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:13:07 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=52&v=2.0&sign=5c361b2fab85186c1aebf1006fe1de0b:80 errno=101 [01-01 18:13:07 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=52&v=2.0&sign=5c361b2fab85186c1aebf1006fe1de0b (-7) [01-01 18:13:07 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:07 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:09:091][:742]QRString Size:0! [20240612-10:39:09.114 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:09:127][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [DBG][2024/06/12/10:39:09:334][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:39:09:814][:1372]wait gs_tuyaDevinfo.regStatus... [DBG][2024/06/12/10:39:09:934][:735]WIFI Get Mode 3 [01-01 18:13:08 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=53&v=2.0&sign=38c0a28d2e15ba834f3d494f133da4f2:80 errno=101 [01-01 18:13:08 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=53&v=2.0&sign=38c0a28d2e15ba834f3d494f133da4f2 (-7) [01-01 18:13:08 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:08 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [20240612-10:39:10.128 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:10:128][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:10:370][:742]QRString Size:0! [20240612-10:39:10.390 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:09 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=54&v=2.0&sign=714dc09f9066122f9cd01c9d87fac6b7:80 errno=101 [01-01 18:13:09 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=54&v=2.0&sign=714dc09f9066122f9cd01c9d87fac6b7 (-7) [01-01 18:13:09 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:09 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [01-01 18:13:09 TUYA E][tuya_ipc_p2p_common.c:463] get p2p auth retry cnt[5] [20240612-10:39:11.399 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:11:399][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:11:641][:742]QRString Size:0! [20240612-10:39:11.643 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:11:894][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:13:10 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=55&v=2.0&sign=e5e150ef56b2a7e9d4dfdb7d7659fe0e:80 errno=101 [01-01 18:13:10 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=55&v=2.0&sign=e5e150ef56b2a7e9d4dfdb7d7659fe0e (-7) [01-01 18:13:10 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:10 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed gethostbyname_r error: Try again [01-01 18:13:10 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:13:10 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:13:10 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:13:10 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:13:10 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:39:12:195][:735]WIFI Get Mode 3 [01-01 18:13:10 TUYA E][tuya_devos_activate.c:527] network unavailable [20240612-10:39:12.647 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:12:647][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:12:914][:1372]wait gs_tuyaDevinfo.regStatus... [DBG][2024/06/12/10:39:12:931][:742]QRString Size:0! [DBG][2024/06/12/10:39:12:934][:735]WIFI Get Mode 3 [20240612-10:39:12.957 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:11 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=56&v=2.0&sign=43e4ad0c3a7b5f96677a8fa4c939fda1:80 errno=101 [01-01 18:13:11 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=56&v=2.0&sign=43e4ad0c3a7b5f96677a8fa4c939fda1 (-7) [01-01 18:13:11 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:11 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [01-01 18:13:11 TUYA E][log_seq.c:152] ret:-1029 [DBG][2024/06/12/10:39:13:894][:601]WIFI[1] Get IP:192.168.175.1 [20240612-10:39:13.967 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:13:967][:782]qrcode yuv info [800*448][358400] [01-01 18:13:12 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=57&v=2.0&sign=5fc105d779d03bb986031c23bbabf117:80 errno=101 [01-01 18:13:12 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=57&v=2.0&sign=5fc105d779d03bb986031c23bbabf117 (-7) [01-01 18:13:12 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:12 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:14:193][:742]QRString Size:0! [20240612-10:39:14.234 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:39:14:904][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:13:13 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=58&v=2.0&sign=aed0877c3d8365fb0dec1cf9659a822e:80 errno=101 [01-01 18:13:13 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=58&v=2.0&sign=aed0877c3d8365fb0dec1cf9659a822e (-7) [01-01 18:13:13 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:13 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [20240612-10:39:15.247 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:15:247][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:15:508][:742]QRString Size:0! [20240612-10:39:15.510 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:16:009][:1372]wait gs_tuyaDevinfo.regStatus... [01-01 18:13:14 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=59&v=2.0&sign=b8ff100cab9a41fac12e594b91f57505:80 errno=101 [01-01 18:13:14 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=59&v=2.0&sign=b8ff100cab9a41fac12e594b91f57505 (-7) [01-01 18:13:14 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:14 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [01-01 18:13:14 TUYA E][tuya_ipc_p2p_common.c:463] get p2p auth retry cnt[10] [20240612-10:39:16.536 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:16:536][:782]qrcode yuv info [800*448][358400] [20240612-10:39:16.692 D 312] hk_stream.c 516: Send StreamID:2 EncodeType:1 CachedCount:0 SendCount:1500 [DBG][2024/06/12/10:39:16:838][:742]QRString Size:0! [20240612-10:39:16.841 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:15 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=60&v=2.0&sign=ea1769997aaf34af04b86c1a1060ca6d:80 errno=101 [01-01 18:13:15 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=60&v=2.0&sign=ea1769997aaf34af04b86c1a1060ca6d (-7) [01-01 18:13:15 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:15 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [20240612-10:39:17.847 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:17:847][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:17:914][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:13:16 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=61&v=2.0&sign=b41af091a59310197c6ada01f21d00c7:80 errno=101 [01-01 18:13:16 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=61&v=2.0&sign=b41af091a59310197c6ada01f21d00c7 (-7) [01-01 18:13:16 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:16 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:18:148][:742]QRString Size:0! [20240612-10:39:18.150 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 gethostbyname_r error: Try again [01-01 18:13:16 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:13:16 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:13:16 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:13:16 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:13:16 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:39:18:215][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:39:18:216][:735]WIFI Get Mode 3 [01-01 18:13:16 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:39:18:904][:601]WIFI[1] Get IP:192.168.175.1 [01-01 18:13:17 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=62&v=2.0&sign=ebb1cbb7f2f9962057c9f98c0397801d:80 errno=101 [01-01 18:13:17 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=62&v=2.0&sign=ebb1cbb7f2f9962057c9f98c0397801d (-7) [01-01 18:13:17 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:17 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:19:045][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:39:19:104][:1372]wait gs_tuyaDevinfo.regStatus... [DBG][2024/06/12/10:39:19:105][:107]platform push eventId 0x91a [4] [20240612-10:39:19.113 D 308] my_main.c 621: media recv a msg: (0x91a) [20240612-10:39:19.113 D 308] my_main.c 496: voice_speak_process int_param:20 [20240612-10:39:19.114 D 308] hk_playvoice.c 305: hank_Play_AudioFile pri 2, file /mnt/flash/Server/resource/audio/en/3.g711u, repeat 1, duration -1, block 1 [20240612-10:39:19.114 D 308] hk_playvoice.c 152: hank_Play_AudioFile_now begin /mnt/flash/Server/resource/audio/en/3.g711u [DBG][2024/06/12/10:39:19:134][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [20240612-10:39:19.157 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:19:157][:782]qrcode yuv info [800*448][358400] [20240612-10:39:19.204 D 225] stream_reader.c 1309: audio swtich ON AUDIO_CTRL:56 [01-01 18:13:17 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:39:19:364][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] [DBG][2024/06/12/10:39:19:429][:742]QRString Size:0! [20240612-10:39:19.431 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [01-01 18:13:18 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=63&v=2.0&sign=987cbda31100cb95a27e10e1f47e8d46:80 errno=101 [01-01 18:13:18 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=63&v=2.0&sign=987cbda31100cb95a27e10e1f47e8d46 (-7) [01-01 18:13:18 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:18 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [20240612-10:39:20.438 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:20:438][:782]qrcode yuv info [800*448][358400] [20240612-10:39:20.522 D 311] hk_stream.c 468: Send StreamID:0 EncodeType:6 CachedCount:2 SendCount:900 [20240612-10:39:20.522 D 311] hk_stream.c 477: Send StreamID:1 EncodeType:7 CachedCount:0 SendCount:900 [DBG][2024/06/12/10:39:20:713][:742]QRString Size:0! [20240612-10:39:20.721 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:20:924][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:13:19 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=64&v=2.0&sign=8b72a5740c871f6f0f5e7f7ebfa5fb95:80 errno=101 [01-01 18:13:19 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=64&v=2.0&sign=8b72a5740c871f6f0f5e7f7ebfa5fb95 (-7) [01-01 18:13:19 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:19 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [01-01 18:13:19 TUYA E][tuya_ipc_p2p_common.c:463] get p2p auth retry cnt[15] [20240612-10:39:21.728 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:21:728][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:22:013][:742]QRString Size:0! [20240612-10:39:22.047 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:20 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=65&v=2.0&sign=aa2e325e6d45bc014ccc162225decda9:80 errno=101 [01-01 18:13:20 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=65&v=2.0&sign=aa2e325e6d45bc014ccc162225decda9 (-7) [01-01 18:13:20 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:20 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:22:195][:1372]wait gs_tuyaDevinfo.regStatus... [20240612-10:39:23.057 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:23:058][:782]qrcode yuv info [800*448][358400] [01-01 18:13:21 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=66&v=2.0&sign=0b9d1e3e2f6d03de4ecac72886218ae9:80 errno=101 [01-01 18:13:21 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=66&v=2.0&sign=0b9d1e3e2f6d03de4ecac72886218ae9 (-7) [01-01 18:13:21 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:21 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:23:316][:742]QRString Size:0! [20240612-10:39:23.319 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:23:904][:601]WIFI[1] Get IP:192.168.175.1 [DBG][2024/06/12/10:39:23:934][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:13:22 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=67&v=2.0&sign=efcfd38937f465b79c34f8453005aeb1:80 errno=101 [01-01 18:13:22 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=67&v=2.0&sign=efcfd38937f465b79c34f8453005aeb1 (-7) [01-01 18:13:22 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:22 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed gethostbyname_r error: Try again [01-01 18:13:22 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:13:22 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:13:22 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:13:22 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:13:22 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:39:24:246][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:39:24:247][:735]WIFI Get Mode 3 [01-01 18:13:22 TUYA E][tuya_devos_activate.c:527] network unavailable [20240612-10:39:24.327 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:24:327][:782]qrcode yuv info [800*448][358400] [20240612-10:39:24.405 D 308] hk_playvoice.c 250: hank_Play_AudioFile_now /mnt/flash/Server/resource/audio/en/3.g711u end [20240612-10:39:24.405 D 308] hk_playvoice.c 251: total_data_len 42086, play_time 5208, audio_time 5260 [DBG][2024/06/12/10:39:24:581][:742]QRString Size:0! [20240612-10:39:24.583 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [01-01 18:13:23 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=68&v=2.0&sign=6c0bd0616a42fde0e95a92242e00dde9:80 errno=101 [01-01 18:13:23 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=68&v=2.0&sign=6c0bd0616a42fde0e95a92242e00dde9 (-7) [01-01 18:13:23 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:23 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:25:105][:735]WIFI Get Mode 3 [01-01 18:13:23 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:39:25:255][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:25:294][:1372]wait gs_tuyaDevinfo.regStatus... [20240612-10:39:25.616 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:25:617][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:25:936][:742]QRString Size:0! [20240612-10:39:25.938 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:24 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=69&v=2.0&sign=92d26d5ab303d4c1da91ce81435cbb79:80 errno=101 [01-01 18:13:24 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=69&v=2.0&sign=92d26d5ab303d4c1da91ce81435cbb79 (-7) [01-01 18:13:24 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:24 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [01-01 18:13:24 TUYA E][tuya_ipc_p2p_common.c:463] get p2p auth retry cnt[20] [DBG][2024/06/12/10:39:26:944][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [20240612-10:39:26.946 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:26:946][:782]qrcode yuv info [800*448][358400] [01-01 18:13:25 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=70&v=2.0&sign=6772836d48ae46432a42c1c348f8175b:80 errno=101 [01-01 18:13:25 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=70&v=2.0&sign=6772836d48ae46432a42c1c348f8175b (-7) [01-01 18:13:25 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:25 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:27:215][:742]QRString Size:0! [20240612-10:39:27.219 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:26 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=71&v=2.0&sign=a61410af226d57a37539196d235afd5d:80 errno=101 [01-01 18:13:26 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=71&v=2.0&sign=a61410af226d57a37539196d235afd5d (-7) [01-01 18:13:26 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:26 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [20240612-10:39:28.226 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:28:226][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:28:394][:1372]wait gs_tuyaDevinfo.regStatus... [DBG][2024/06/12/10:39:28:494][:742]QRString Size:0! [20240612-10:39:28.501 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:28:904][:601]WIFI[1] Get IP:192.168.175.1 [DBG][2024/06/12/10:39:29:144][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [01-01 18:13:27 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=72&v=2.0&sign=41976f34c0ef0f09103c5257b27ba45c:80 errno=101 [01-01 18:13:27 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=72&v=2.0&sign=41976f34c0ef0f09103c5257b27ba45c (-7) [01-01 18:13:27 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:27 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:29:395][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] [20240612-10:39:29.509 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:29:509][:782]qrcode yuv info [800*448][358400] :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:39:29:733][:565]hisyslink recv:cmd[0x86] len[5] xor[0x29] wifi recv: ab 05 86 01 29 [DBG][2024/06/12/10:39:29:733][:707]wifistatus[1] success! [DBG][2024/06/12/10:39:29:733][:101]mcu push mcu_eventId 0x17 [0] [DBG][2024/06/12/10:39:29:739][:851]platform recv a msg: (0x17) [DBG][2024/06/12/10:39:29:739][:566]soc recv wifi response netconfif success[0]! [DBG][2024/06/12/10:39:29:739][:406]tyapstat 1 :::platform_ap_netconfig_success 572 start platform_fillnetstat =0 [DBG][2024/06/12/10:39:29:775][:742]QRString Size:0! [20240612-10:39:29.800 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:29:954][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [20240612-10:39:30.044 D 225] stream_reader.c 1319: audio swtich OFF AUDIO_CTRL:56 [01-01 18:13:28 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=73&v=2.0&sign=0096abfaa5137f3763296a18e7610f51:80 errno=101 [01-01 18:13:28 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=73&v=2.0&sign=0096abfaa5137f3763296a18e7610f51 (-7) [01-01 18:13:28 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:28 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed gethostbyname_r error: Try again [01-01 18:13:28 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:13:28 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:13:28 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:13:28 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:13:28 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:39:30:275][:735]WIFI Get Mode 3 [01-01 18:13:28 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:39:30:275][:735]WIFI Get Mode 3 [20240612-10:39:30.808 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:30:811][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:31:102][:742]QRString Size:0! [20240612-10:39:31.125 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:29 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=74&v=2.0&sign=e6247d86d5e2750d56a4b647126980f7:80 errno=101 [01-01 18:13:29 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=74&v=2.0&sign=e6247d86d5e2750d56a4b647126980f7 (-7) [01-01 18:13:29 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:29 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [01-01 18:13:29 TUYA E][tuya_ipc_p2p_common.c:463] get p2p auth retry cnt[25] [DBG][2024/06/12/10:39:31:165][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:39:31:494][:1372]wait gs_tuyaDevinfo.regStatus... [20240612-10:39:32.136 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:32:136][:782]qrcode yuv info [800*448][358400] [01-01 18:13:30 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=75&v=2.0&sign=10445736f83adf11a16cd57be8ea0c39:80 errno=101 [01-01 18:13:30 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=75&v=2.0&sign=10445736f83adf11a16cd57be8ea0c39 (-7) [01-01 18:13:30 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:30 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:32:391][:742]QRString Size:0! [20240612-10:39:32.414 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:32:966][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:13:31 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=76&v=2.0&sign=3f2fe2dd743e66bd0851d924968f13bb:80 errno=101 [01-01 18:13:31 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=76&v=2.0&sign=3f2fe2dd743e66bd0851d924968f13bb (-7) [01-01 18:13:31 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:31 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [20240612-10:39:33.432 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:33:432][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:33:672][:742]QRString Size:0! [20240612-10:39:33.708 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:33:914][:601]WIFI[1] Get IP:192.168.175.1 [01-01 18:13:32 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=77&v=2.0&sign=6da3aee79873212aa6514830532d827e:80 errno=101 [01-01 18:13:32 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=77&v=2.0&sign=6da3aee79873212aa6514830532d827e (-7) [01-01 18:13:32 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:32 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:34:594][:1372]wait gs_tuyaDevinfo.regStatus... :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [20240612-10:39:34.716 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:34:716][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:35:012][:742]QRString Size:0! [20240612-10:39:35.035 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:33 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=78&v=2.0&sign=f5b5da05b2dd4a596323de93fc19671a:80 errno=101 [01-01 18:13:33 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=78&v=2.0&sign=f5b5da05b2dd4a596323de93fc19671a (-7) [01-01 18:13:33 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:33 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:35:974][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [20240612-10:39:36.052 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:36:052][:782]qrcode yuv info [800*448][358400] [01-01 18:13:34 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=79&v=2.0&sign=100b662b2a42b128e629802fa39e7830:80 errno=101 [01-01 18:13:34 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=79&v=2.0&sign=100b662b2a42b128e629802fa39e7830 (-7) [01-01 18:13:34 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:34 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [01-01 18:13:34 TUYA E][tuya_ipc_p2p_common.c:463] get p2p auth retry cnt[30] gethostbyname_r error: Try again [01-01 18:13:34 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:13:34 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:13:34 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:13:34 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:13:34 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:39:36:294][:735]WIFI Get Mode 3 [01-01 18:13:34 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:39:36:295][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:39:36:301][:742]QRString Size:0! [20240612-10:39:36.303 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:35 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=80&v=2.0&sign=bffdc4e14bdea60f5c6f033bac0f08fe:80 errno=101 [01-01 18:13:35 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=80&v=2.0&sign=bffdc4e14bdea60f5c6f033bac0f08fe (-7) [01-01 18:13:35 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:35 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [20240612-10:39:37.306 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:37:306][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:37:541][:742]QRString Size:0! [20240612-10:39:37.543 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:37:694][:1372]wait gs_tuyaDevinfo.regStatus... [01-01 18:13:36 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=81&v=2.0&sign=cd60c85d0842f20fb2cd35ab0754ffdb:80 errno=101 [01-01 18:13:36 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=81&v=2.0&sign=cd60c85d0842f20fb2cd35ab0754ffdb (-7) [01-01 18:13:36 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:36 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [20240612-10:39:38.565 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:38:565][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:38:831][:742]QRString Size:0! [20240612-10:39:38.867 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:38:924][:601]WIFI[1] Get IP:192.168.175.1 [DBG][2024/06/12/10:39:38:984][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:39:39:154][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [01-01 18:13:37 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=82&v=2.0&sign=5dbc7355910b4b84f7acf15b7bcbf8e3:80 errno=101 [01-01 18:13:37 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=82&v=2.0&sign=5dbc7355910b4b84f7acf15b7bcbf8e3 (-7) [01-01 18:13:37 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:37 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:39:524][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [20240612-10:39:39.878 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:39:878][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:39:974][:735]WIFI Get Mode 3 [DBG][2024/06/12/10:39:40:179][:742]QRString Size:0! [20240612-10:39:40.208 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:38 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=83&v=2.0&sign=4860f01a090220bc23d9d1a1da1569c4:80 errno=101 [01-01 18:13:38 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=83&v=2.0&sign=4860f01a090220bc23d9d1a1da1569c4 (-7) [01-01 18:13:38 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:38 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:40:794][:1372]wait gs_tuyaDevinfo.regStatus... [20240612-10:39:41.217 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:41:217][:782]qrcode yuv info [800*448][358400] [01-01 18:13:39 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=84&v=2.0&sign=176e5b9f226d9cc37d5bcd5e0cfbddec:80 errno=101 [01-01 18:13:39 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=84&v=2.0&sign=176e5b9f226d9cc37d5bcd5e0cfbddec (-7) [01-01 18:13:39 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:39 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [01-01 18:13:39 TUYA E][tuya_ipc_p2p_common.c:463] get p2p auth retry cnt[35] [DBG][2024/06/12/10:39:41:460][:742]QRString Size:0! [20240612-10:39:41.462 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:41:942][:862]Stop AP [DBG][2024/06/12/10:39:41:995][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:13:40 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=85&v=2.0&sign=d9d3bf45a9965cae3f5cf1c54c665604:80 errno=101 [01-01 18:13:40 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=85&v=2.0&sign=d9d3bf45a9965cae3f5cf1c54c665604 (-7) [01-01 18:13:40 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:40 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed gethostbyname_r error: Try again [01-01 18:13:41 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:13:41 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:13:41 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:13:41 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:13:41 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [01-01 18:13:41 TUYA E][tuya_devos_activate.c:527] network unavailable [DBG][2024/06/12/10:39:42:320][<__IPC_APP_Get_Net_Status_cb>:1576]Net status change to:3 [DBG][2024/06/12/10:39:42:357][:601]WIFI[0] Get IP:192.168.175.1 [01-01 18:13:41 TUYA E][mqtt_client.c:807] hand null. [01-01 18:13:41 TUYA E][log_seq.c:152] ret:-1029 [DBG][2024/06/12/10:39:42:358][:735]WIFI Get Mode 3 [01-01 18:13:41 TUYA E][wifi_netcfg_frame_transporter.c:431] timer is not run,wait [DBG][2024/06/12/10:39:42:358][:862]Stop AP Exec Cmd:ifconfig wlan0 up [DBG][2024/06/12/10:39:42:383][:705]WIFI Set Mode 2 [DBG][2024/06/12/10:39:42:383][:63]wifi connect, ssid[HKTEST11] passwd[11112222] [DBG][2024/06/12/10:39:42:385][:80]ssid=HKTEST11 passwd=11112222 gs_tuyaConfigWifi=0 curr event:3 [DBG][2024/06/12/10:39:42:385][:107]platform push eventId 0x91a [4] [20240612-10:39:42.388 D 308] my_main.c 621: media recv a msg: (0x91a) [20240612-10:39:42.388 D 308] my_main.c 496: voice_speak_process int_param:3 [DBG][2024/06/12/10:39:42:389][:93]ty_wifi_stainfo ssid=HKTEST11 passwd=11112222 [DBG][2024/06/12/10:39:42:389][:107]platform push eventId 0x91f [104] curr event:2 [DBG][2024/06/12/10:39:42:390][:107]platform push eventId 0x932 [1] [DBG][2024/06/12/10:39:42:391][:107]platform push eventId 0x91a [4] [DBG][2024/06/12/10:39:42:391][:124]......wifi config success now return...... [DBG][2024/06/12/10:39:42:391][<__IPC_APP_Get_Net_Status_cb>:1576]Net status change to:6 [DBG][2024/06/12/10:39:42:404][:1967]mcu recv a msg: (0x91f) [DBG][2024/06/12/10:39:42:404][:925]soc send MCU_CMD_STA_CONNECT(0xd2) cmd to wifi [104] wifi send: ab 6c d2 48 4b 54 45 53 54 31 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 31 31 31 31 32 32 32 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00 03 [DBG][2024/06/12/10:39:42:406][:427]hal recv a msg: (0x932) [DBG][2024/06/12/10:39:42:406][:205]msgvalue: 1 [20240612-10:39:42.407 D 308] my_main.c 621: media recv a msg: (0x91a) [20240612-10:39:42.407 D 308] my_main.c 496: voice_speak_process int_param:10 [DBG][2024/06/12/10:39:42:421][:528]index:1 [DBG][2024/06/12/10:39:42:422][:254]===========sample_wlan_init_ip============ [DBG][2024/06/12/10:39:42:422][:260]wlan ip[0.0.0.0] netmask[0.0.0.0] gw[0.0.0.0] boardcast[0.0.0.255] [ERR][2024/06/12/10:39:42:422][:264]ip addr is empty! [DBG][2024/06/12/10:39:42:440][:601]WIFI[0] Get IP:192.168.175.1 [01-01 18:13:41 TUYA E][mqtt_client.c:807] hand null. [DBG][2024/06/12/10:39:42:441][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:39:42:441][:834]Get wifi station status 6 dev id key: 16 36 8e c0 64 f5 84 3b d0 ba da 26 0a 89 a9 bc e8 [20240612-10:39:42.466 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:42:466][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:42:709][:742]QRString Size:0! [20240612-10:39:42.711 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:42:984][:834]Get wifi station status 6 [01-01 18:13:41 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=86&v=2.0&sign=28b09b0659e270a4e07ef5ec1fd73fee:80 errno=101 [01-01 18:13:41 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=86&v=2.0&sign=28b09b0659e270a4e07ef5ec1fd73fee (-7) [01-01 18:13:41 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:41 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:43:285][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:39:43:285][:834]Get wifi station status 6 [20240612-10:39:43.718 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:43:719][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:43:894][:1372]wait gs_tuyaDevinfo.regStatus... [DBG][2024/06/12/10:39:43:968][:601]WIFI[0] Get IP:192.168.175.1 [DBG][2024/06/12/10:39:43:977][:742]QRString Size:0! [20240612-10:39:43.980 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:42 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=87&v=2.0&sign=3e5f0f983a439a22709c2cca55759a4d:80 errno=101 [01-01 18:13:42 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=87&v=2.0&sign=3e5f0f983a439a22709c2cca55759a4d (-7) [01-01 18:13:42 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:42 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [20240612-10:39:44.987 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:44:988][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:45:004][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:39:45:242][:742]QRString Size:0! [20240612-10:39:45.263 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [01-01 18:13:43 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=88&v=2.0&sign=176e32e8ea04df06bc1ea572c975997b:80 errno=101 [01-01 18:13:43 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=88&v=2.0&sign=176e32e8ea04df06bc1ea572c975997b (-7) [01-01 18:13:43 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:43 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [20240612-10:39:46.267 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:46:267][:782]qrcode yuv info [800*448][358400] [01-01 18:13:45 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=90&v=2.0&sign=5b7bd5b685d9862d7a4168181bc6af72:80 errno=101 [01-01 18:13:45 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=90&v=2.0&sign=5b7bd5b685d9862d7a4168181bc6af72 (-7) [01-01 18:13:45 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:45 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [01-01 18:13:45 TUYA E][tuya_ipc_p2p_common.c:463] get p2p auth retry cnt[40] [DBG][2024/06/12/10:39:46:521][:742]QRString Size:0! [DBG][2024/06/12/10:39:46:546][:528]index:1 [DBG][2024/06/12/10:39:46:547][:254]===========sample_wlan_init_ip============ [DBG][2024/06/12/10:39:46:547][:260]wlan ip[192.168.3.97] netmask[255.255.255.0] gw[192.168.3.1] boardcast[192.168.3.255] [20240612-10:39:46.555 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [20240612-10:39:46.694 D 312] hk_stream.c 516: Send StreamID:2 EncodeType:1 CachedCount:0 SendCount:2250 [MSG][2024/06/12/10:39:46:748][:369]===net device set ip success! wifistatus[1]=== [DBG][2024/06/12/10:39:46:748][:565]hisyslink recv:cmd[0x82] len[5] xor[0x2c] wifi recv: ab 05 82 00 2c [DBG][2024/06/12/10:39:46:749][:444]wifistatus[1] success! [DBG][2024/06/12/10:39:46:749][:101]mcu push mcu_eventId 0xc [0] [DBG][2024/06/12/10:39:46:749][:101]mcu push mcu_eventId 0x921 [0] [DBG][2024/06/12/10:39:46:752][:427]hal recv a msg: (0x921) [DBG][2024/06/12/10:39:46:753][:851]platform recv a msg: (0xc) [DBG][2024/06/12/10:39:46:753][:545]soc recv wifi response netconfif success[0] [0]! [MSG][2024/06/12/10:39:46:753][:553]---netconfig success!!!--- [WRN][2024/06/12/10:39:46:753][:683]now write param to flash [20240612-10:39:46.754 D 241] media_mqtt.c 327: media_video_set_device_onlineevent int_param:0 [DBG][2024/06/12/10:39:46:758][:156]gs_tynetstat 1 [DBG][2024/06/12/10:39:47:004][:1372]wait gs_tuyaDevinfo.regStatus... [01-01 18:13:46 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=91&v=2.0&sign=13a384b6e1cccaa8904c0e43cc2f3dc7:80 errno=101 [01-01 18:13:46 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=91&v=2.0&sign=13a384b6e1cccaa8904c0e43cc2f3dc7 (-7) [01-01 18:13:46 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:46 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [20240612-10:39:47.568 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:47:568][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:47:826][:742]QRString Size:0! [20240612-10:39:47.829 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:48:014][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [01-01 18:13:47 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=92&v=2.0&sign=a6b9c8169aed016096f777587e213892:80 errno=101 [01-01 18:13:47 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=92&v=2.0&sign=a6b9c8169aed016096f777587e213892 (-7) [01-01 18:13:47 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:47 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed gethostbyname_r error: Try again [01-01 18:13:47 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:13:47 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:13:47 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:13:47 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v2/url_config (-15) [01-01 18:13:47 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 gethostbyname_r error: Try again [01-01 18:13:47 TUYA E][uni_network.c:360] fail to gethostbyname 2 [01-01 18:13:47 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5 [01-01 18:13:47 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed [01-01 18:13:47 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15) [01-01 18:13:47 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050 [DBG][2024/06/12/10:39:48:345][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:48:346][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:39:48:346][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:48:346][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:48:347][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:39:48:347][:834]Get wifi station status 6 [20240612-10:39:48.835 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:48:836][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:48:970][:601]WIFI[0] Get IP:192.168.3.97 [DBG][2024/06/12/10:39:49:004][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:49:121][:742]QRString Size:0! [20240612-10:39:49.123 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:49:164][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [01-01 18:13:48 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=93&v=2.0&sign=e56f723666b6ecf81c0376c7959eb65a:80 errno=101 [01-01 18:13:48 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=93&v=2.0&sign=e56f723666b6ecf81c0376c7959eb65a (-7) [01-01 18:13:48 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:48 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:49:355][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:39:50:114][:1372]wait gs_tuyaDevinfo.regStatus... [20240612-10:39:50.125 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:50:126][:782]qrcode yuv info [800*448][358400] [01-01 18:13:49 TUYA E][httpc.c:551] tcp connect failed ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=94&v=2.0&sign=0f37b9f89ec3245e86e4c338fab4b572:80 errno=101 [01-01 18:13:49 TUYA E][http_inf.c:51] Open session failed: ?a=tuya.device.ipc.p2p.config.get&devId=&et=1&t=94&v=2.0&sign=0f37b9f89ec3245e86e4c338fab4b572 (-7) [01-01 18:13:49 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-2050 [01-01 18:13:49 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [DBG][2024/06/12/10:39:50:443][:742]QRString Size:0! [20240612-10:39:50.461 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:50:572][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:39:50:572][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:50:894][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:51:024][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [20240612-10:39:51.467 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [DBG][2024/06/12/10:39:51:467][:782]qrcode yuv info [800*448][358400] [20240612-10:39:51.504 D 311] hk_stream.c 468: Send StreamID:0 EncodeType:6 CachedCount:0 SendCount:1350 [20240612-10:39:51.504 D 311] hk_stream.c 477: Send StreamID:1 EncodeType:7 CachedCount:0 SendCount:1350 [DBG][2024/06/12/10:39:51:935][:742]QRString Size:0! [20240612-10:39:51.937 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 [06-12 20:52:11 TUYA E][iot_httpc.c:1187] Post Data Return Fail.-4352 [06-12 20:52:11 TUYA E][tuya_ipc_p2p_common.c:374] get p2p auth failed [06-12 20:52:11 TUYA E][tuya_ipc_p2p_common.c:463] get p2p auth retry cnt[45] tuya_ipc_qrcode_active_cb short url is {"shortUrl":"https://m.smart321.com/AYk8NOXR4C"} [DBG][2024/06/12/10:39:52:288][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:39:52:288][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:52:322][<__IPC_APP_Get_Net_Status_cb>:1576]Net status change to:1 [DBG][2024/06/12/10:39:52:323][<__IPC_APP_Get_Net_Status_cb>:1576]Net status change to:3 [06-12 10:39:56 TUYA E][tuya_devos_netcfg.c:330] all netcfg stop fail:-1 dev id key: 16 bd 85 59 cc cf 3f 24 c4 a5 82 c6 3b 69 31 fb 21 [DBG][2024/06/12/10:39:52:585][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:52:829][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:39:52:829][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:52:829][<__IPC_APP_Get_Net_Status_cb>:1576]Net status change to:11 [DBG][2024/06/12/10:39:52:829][<__IPC_APP_Get_Net_Status_cb>:1632]STAT_MQTT_ONLINE! mqtt is online! curr event:4 [20240612-10:39:52.830 I 304] hank_parameter.c 408: [hk_parameter_set_int] bindState=1 [WRN][2024/06/12/10:39:52:832][:683]now write param to flash [DBG][2024/06/12/10:39:52:864][:107]platform push eventId 0x91a [4] [20240612-10:39:52.866 D 308] my_main.c 621: media recv a msg: (0x91a) [20240612-10:39:52.866 D 308] my_main.c 496: voice_speak_process int_param:2 [20240612-10:39:52.867 D 308] hk_playvoice.c 305: hank_Play_AudioFile pri 2, file /mnt/flash/Server/resource/audio/en/10.g711u, repeat 1, duration -1, block 1 [20240612-10:39:52.867 D 308] hk_playvoice.c 152: hank_Play_AudioFile_now begin /mnt/flash/Server/resource/audio/en/10.g711u Dbg:Get Server Time [DBG][2024/06/12/10:39:52:905][:149]Get Server Time Success: 1718159996 28800 0 1718159992 [DBG][2024/06/12/10:39:56:000][:107]platform push eventId 0x903 [0] Init tuya_ipc_ss_init [DBG][2024/06/12/10:39:56:001][:1505]sleep status,pushvideo[-1] clientnum[-1] waitcount[1] record[0] mqtt subscribe ack 5 90 03 00 02 00 [06-12 10:39:56 TUYA E][tuya_ipc_cloud_storage.c:383] iot_wd_common_read fails md5_encrypt_key -6 [06-12 10:39:56 TUYA E][tuya_ipc_cloud_storage.c:468] read key_key file failed. [06-12 10:39:56 TUYA E][tuya_ipc_cloud_storage.c:960] iot_wd_common_read fails storage_restriction -6 [DBG][2024/06/12/10:39:56:006][:107]platform push eventId 0x936 [0] [DBG][2024/06/12/10:39:56:006][:205]now push battery[52] charge[1] ts[1718159996]! [DBG][2024/06/12/10:39:56:015][:2306]over init tuya sdk dev running time: 100.967 [DBG][2024/06/12/10:39:56:020][:1967]mcu recv a msg: (0x903) [DBG][2024/06/12/10:39:56:021][:479]soc get current system timeinfo 124-5-12 10:39:56 [DBG][2024/06/12/10:39:56:021][:487]timezoneinfo:[28800 8.00 ] [8 0] [DBG][2024/06/12/10:39:56:021][:512]soc set mcu rtc timeinfo 24-06-12 10:39:56 :::mcu_send_data_buffer 2136 cmd=[ab 0 6 0] :::mcu_send_data_buffer 2187 [0] [DBG][2024/06/12/10:39:56:021][:532]set wifi rtc time[1718159996] wifi send: ab 08 ab 66 69 0a 7c 71 [DBG][2024/06/12/10:39:56:024][:1967]mcu recv a msg: (0x936) wifi send: ab 05 e1 00 4f [DBG][2024/06/12/10:39:56:025][:840]get tuya sleep keepactive info success [DBG][2024/06/12/10:39:56:028][:181]sd status 1 [20240612-10:39:56.035 D 387] kernel_manage.c 161: Got dev_name : mmcblk0 [20240612-10:39:56.042 D 316] hk_stream.c 618: get yuv width:800 heigth:448 size:358400 uart send >>> ab 0a ab 24 06 12 10 39 56 45 [20240612-10:39:56.223 D 225] stream_reader.c 1309: audio swtich ON AUDIO_CTRL:56 uart recv <<< ab 05 ab 00 05 [06-12 10:39:57 TUYA E][cloud_operation.c:511] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED [06-12 10:39:57 TUYA E][tuya_ipc_cloud_storage.c:1713] check cloud storage count failed, op_ret = -1 uart send >>> ab 0a ab 24 06 12 10 39 56 45 P2P API Version: 244.3.4.107 101699 (null) INFO:1653264: tuya p2p rtc sdk version: 0xf403046b, Nov 7 2023 17:44:56 tuya liteos uv uart send >>> ab 0a ab 24 06 12 10 39 56 45 uart send >>> ab 0a ab 24 06 12 10 39 56 45 uart send >>> ab 0a ab 24 06 12 10 39 56 45 :::mcu_send_data_execute_thread 2218 mcu send[ab]fail [06-12 10:39:58 TUYA E][tuya_ipc_p2p.c:5201] p2p v3 init ok :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:39:56:042][:782]qrcode yuv info [800*448][358400] [DBG][2024/06/12/10:39:57:829][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:57:830][:168]curr light_on_off:1 [06-12 10:39:58 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:101 not find [DBG][2024/06/12/10:39:57:830][:207]curr flip_on_off:0 [06-12 10:39:58 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:103 not find [DBG][2024/06/12/10:39:57:831][:337]curr s_nightvision_mode:2 [06-12 10:39:58 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:124 not find [DBG][2024/06/12/10:39:57:831][:371]curr alarm_on_off:1 [DBG][2024/06/12/10:39:57:831][:1600]mcu handle cmd : 0xab [DBG][2024/06/12/10:39:57:831][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:39:57:832][:400]curr device volume:8 [06-12 10:39:58 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:160 not find [DBG][2024/06/12/10:39:57:833][:451]curr alarm_sensitivity:1 [DBG][2024/06/12/10:39:57:838][:634]curr sd_status:1 [20240612-10:39:57.839 D 300] kernel_manage.c 161: Got dev_name : mmcblk0 [DBG][2024/06/12/10:39:57:911][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:39:57:911][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:57:914][<__IPC_APP_Get_Net_Status_cb>:1576]Net status change to:7 [DBG][2024/06/12/10:39:57:914][<__IPC_APP_Get_Net_Status_cb>:1588]cloud is online [DBG][2024/06/12/10:39:57:928][:169]sd capacity: total: 7784448 KB, used 4944 KB, free 7779504 KB [DBG][2024/06/12/10:39:57:948][:659]curr sd total:7784448 used:4944 empty:7779504 [DBG][2024/06/12/10:39:57:949][:205]now push battery[52] charge[1] ts[1718159997]! [DBG][2024/06/12/10:39:57:950][:1002]get filter_enable 1 [DBG][2024/06/12/10:39:57:950][:1630]curr s_pirsw_sensity:2 [DBG][2024/06/12/10:39:58:005][:834]Get wifi station status 6 [06-12 10:39:59 TUYA E][tuya_ipc_streamer.c:1457] tstream init start [06-12 10:39:59 TUYA E][tuya_ipc_encrypt.c:192] read local cloud encrypt key fails ..-6 [DBG][2024/06/12/10:39:58:575][:205]now push battery[52] charge[1] ts[1718159998]! :::mcu_check_cmd_resend 2123 not mcu buffer data send[0 ab] 103541 (null) INFO:1653264: try listen uart recv <<< ab 05 ab 00 05 [DBG][2024/06/12/10:39:58:704][:1600]mcu handle cmd : 0xab :::mcu_check_cmd_resend 2123 not mcu buffer data send[0 ab] [06-12 10:40:00 TUYA E][tuya_ipc_streamer.c:1525] tstream init done [DBG][2024/06/12/10:39:59:140][:742]QRString Size:0! [DBG][2024/06/12/10:39:59:509][:601]WIFI[0] Get IP:192.168.3.97 [DBG][2024/06/12/10:39:59:544][:601]WIFI[0] Get IP:192.168.3.97 [20240612-10:39:59.546 D 316] my_platform.c 766: already bind device,exit now [DBG][2024/06/12/10:39:59:546][:107]platform push eventId 0x91d [0] [DBG][2024/06/12/10:39:59:578][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:39:59:578][:834]Get wifi station status 6 [DBG][2024/06/12/10:39:59:588][:813]device configure over, exit now [20240612-10:39:59.650 D 308] hk_playvoice.c 250: hank_Play_AudioFile_now /mnt/flash/Server/resource/audio/en/10.g711u end [20240612-10:39:59.650 D 308] hk_playvoice.c 251: total_data_len 29169, play_time 3614, audio_time 3646 [06-12 10:40:00 TUYA E][svc_online_log_db.c:25] ret:-6 [DBG][2024/06/12/10:39:59:985][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:00:084][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:00:084][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:00:133][:107]platform push eventId 0x913 [0] [DBG][2024/06/12/10:40:00:135][:1967]mcu recv a msg: (0x913) [DBG][2024/06/12/10:40:00:135][:974]soc send MCU_CMD_GET_WIFI_RSSI(0xde) cmd to wifi wifi send: ab 04 de 71 [DBG][2024/06/12/10:40:00:146][:565]hisyslink recv:cmd[0xde] len[8] xor[0x6c] wifi recv: ab 08 de ee ff ff ff 6c [DBG][2024/06/12/10:40:00:146][:886]rssi[-18] [20240612-10:40:00.267 D 241] media_mqtt.c 315: media_video_stop_qrcode int_param:0 [20240612-10:40:00.279 D 241] media_gk72010300.c 301: [GK72010300_qrcode_yraw_data] GK72010300 handle=0xb6e7bf80 105290 (null) INFO:1653264: process signaling offer 105291 (null) INFO:1653264: process signaling candidate 105291 (null) INFO:1653264: process signaling candidate 105291 (null) INFO:1653264: process signaling candidate 105291 (null) INFO:1653264: process signaling candidate 105292 (null) WARN:1653264: channel 4 first write 105298 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 105305 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:01 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 105306 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 34, nfds 1 watcher add 36, nfds 2 105324 (null) INFO:1661204: ice 1 state change: CANDIDATE -> CHECK connect ret -1 watcher add 38, nfds 3 105351 (null) INFO:1653264: process signaling candidate 105362 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 38, nfds 2 watcher add 38, nfds 3 105420 (null) INFO:1715148: tcp 38 state change: CONNECT -> REQUEST 105473 (null) INFO:1661204: ice 1 state change: CHECK -> CONNECTED 105473 (null) INFO:1653264: rtc session 00010001 on ice status: 1, cost: 183 105473 (null) INFO:1653264: rtc 00010001 transport update 1: 1 -1 0, 100 0 0 105476 (null) INFO:1653264: rtc session 00010001 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 105476 (null) INFO:1653264: rtc session 00010001 state change: DTLS_SRTP_KEY_NEGO -> STREAM 105476 (null) INFO:1653264: add new rtc session 00010001, session id 6c71d5d0f96892389aay5r17181600015a3pcEhJ, connect session , status 0 105476 (null) INFO:1653264: listen result 00010001 105476 (null) WARN:1653264: channel 4 first send 105492 (null) INFO:1653264: rtc 00010001 transport update 2: 2 -1 0, 100 0 0 105492 (null) INFO:1653264: rtc 00010001 on ice data, cost: 202 105492 (null) WARN:1653264: channel 0 get first data [06-12 10:40:01 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:01 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 105512 (null) INFO:1653264: rtc session 00010001 close 105513 (null) INFO:1653264: rtc session 00010001 close over [06-12 10:40:01 TUYA E][tuya_ipc_p2p.c:4206] Close session[65537] [06-12 10:40:01 TUYA E][tuya_ipc_p2p.c:4209] resend p2p passwd to service 105557 (null) INFO:1653264: process control close 105558 (null) INFO:1653264: rtc session 00010001 ready to close 105558 (null) INFO:1653264: rtc 00010001 closed by remote or local, local:1 remote:0 105558 (null) INFO:1653264: rtc session 00010001 state change: STREAM -> FAILED 105571 (null) INFO:1653264: destroy rtc session 00010001 watcher remove 34, nfds 2 watcher remove 36, nfds 1 watcher remove 38, nfds 0 105682 (null) INFO:1653264: process signaling disconnect 105682 (null) INFO:1653264: can not find rtc session [20240612-10:40:00.758 D 317] quickstart_rootfs.c 2096: request yuv thread exit!!! [20240612-10:40:00.758 D 317] quickstart_rootfs.c 2063: HI_MPI_ISP_GetExposureAttr sucees ! :::qr_mode_isp_open 2071 [0 0] [20240612-10:40:00.785 D 241] quickstart_rootfs.c 2144: [qr_vpss_depthSetting] vpssChn=1 u32Depth=0 105800 (null) INFO:1653264: process signaling offer 105802 (null) WARN:1653264: channel 4 first write 105806 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 105807 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:01 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 105807 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 36, nfds 1 watcher add 38, nfds 2 105816 (null) INFO:1661204: ice 2 state change: CANDIDATE -> CHECK connect ret -1 watcher add 40, nfds 3 105830 (null) INFO:1653264: process signaling candidate 105830 (null) INFO:1653264: process signaling candidate 105831 (null) INFO:1653264: process signaling candidate 105834 (null) INFO:1653264: try listen error = 0 watcher remove 40, nfds 2 watcher add 40, nfds 3 105886 (null) INFO:1715148: tcp 40 state change: CONNECT -> REQUEST 105886 (null) INFO:1653264: process signaling candidate 105979 (null) INFO:1715148: tcp 40 state change: REQUEST -> ACK 105987 (null) INFO:1653264: process signaling candidate 105989 (null) INFO:1653264: process signaling candidate 106078 (null) INFO:1661204: ice 2 state change: CHECK -> CONNECTED 106079 (null) INFO:1653264: rtc session 00010002 on ice status: 1, cost: 279 106079 (null) INFO:1653264: rtc 00010002 transport update 1: 1 -1 0, 100 0 0 106079 (null) INFO:1653264: rtc session 00010002 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 106079 (null) INFO:1653264: rtc session 00010002 state change: DTLS_SRTP_KEY_NEGO -> STREAM 106079 (null) INFO:1653264: add new rtc session 00010002, session id 6c71d5d0f96892389aay5r1718160001vUBnQG23, connect session , status 0 106079 (null) INFO:1653264: listen result 00010002 106080 (null) WARN:1653264: channel 4 first send [DBG][2024/06/12/10:40:01:140][:809]Get Conn AP RSSI:100 twifirssi: -18 106095 (null) INFO:1653264: got repeated offer, drop [DBG][2024/06/12/10:40:01:145][:834]Get wifi station status 6 106100 (null) INFO:1653264: rtc 00010002 transport update 2: 2 -1 0, 100 0 0 106101 (null) INFO:1653264: rtc 00010002 on ice data, cost: 301 106101 (null) WARN:1653264: channel 0 get first data 106101 (null) INFO:1653264: process control retransmit_signaling 106102 (null) INFO:1653264: process signaling candidate 106102 (null) INFO:1653264: can not find rtc session 106102 (null) INFO:1653264: process signaling candidate 106102 (null) INFO:1653264: can not find rtc session 106102 (null) INFO:1653264: process signaling candidate 106102 (null) INFO:1653264: can not find rtc session 106110 (null) INFO:1653264: process signaling candidate 106110 (null) INFO:1653264: can not find rtc session 106110 (null) INFO:1653264: process signaling candidate 106110 (null) INFO:1653264: can not find rtc session [DBG][2024/06/12/10:40:01:161][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:01:161][:834]Get wifi station status 6 106117 (null) INFO:1653264: process signaling candidate 106117 (null) INFO:1653264: can not find rtc session 106117 (null) INFO:1653264: process signaling disconnect 106118 (null) INFO:1653264: can not find rtc session 106119 (null) INFO:1653264: got repeated offer, drop [06-12 10:40:01 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:01 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 106120 (null) INFO:1653264: rtc session 00010002 close 106120 (null) INFO:1653264: rtc session 00010002 close over [06-12 10:40:01 TUYA E][tuya_ipc_p2p.c:4206] Close session[65538] 106120 (null) INFO:1653264: try listen 106136 (null) INFO:1653264: process control retransmit_signaling 106137 (null) INFO:1653264: process control close 106137 (null) INFO:1653264: rtc session 00010002 ready to close 106137 (null) INFO:1653264: process signaling candidate 106137 (null) INFO:1653264: process signaling candidate 106137 (null) INFO:1653264: rtc 00010002 closed by remote or local, local:1 remote:0 106137 (null) INFO:1653264: rtc session 00010002 state change: STREAM -> FAILED [DBG][2024/06/12/10:40:01:188][:834]Get wifi station status 6 106160 (null) INFO:1653264: destroy rtc session 00010002 watcher remove 36, nfds 2 watcher remove 38, nfds 1 watcher remove 40, nfds 0 106169 (null) INFO:1653264: process signaling candidate 106169 (null) INFO:1653264: can not find rtc session 106169 (null) INFO:1653264: process signaling candidate 106169 (null) INFO:1653264: can not find rtc session 106169 (null) INFO:1653264: process signaling candidate 106169 (null) INFO:1653264: can not find rtc session 106169 (null) INFO:1653264: process signaling candidate 106169 (null) INFO:1653264: can not find rtc session 106440 (null) INFO:1653264: process signaling disconnect 106440 (null) INFO:1653264: can not find rtc session [DBG][2024/06/12/10:40:01:497][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:01:500][:834]Get wifi station status 6 106471 (null) INFO:1653264: process signaling disconnect 106471 (null) INFO:1653264: can not find rtc session 106560 (null) INFO:1653264: process signaling offer 106565 (null) WARN:1653264: channel 4 first write 106567 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 106567 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:02 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 106567 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 34, nfds 1 watcher add 36, nfds 2 106578 (null) INFO:1653264: got repeated offer, drop 106579 (null) INFO:1661204: ice 3 state change: CANDIDATE -> CHECK connect ret -1 watcher add 38, nfds 3 [DBG][2024/06/12/10:40:01:628][:1294]send wifi heartbeat---wifihbcnt[0][8][52] 106590 (null) INFO:1653264: process signaling candidate 106591 (null) INFO:1653264: process signaling candidate 106592 (null) INFO:1653264: process signaling candidate 106592 (null) INFO:1653264: process signaling candidate 106593 (null) INFO:1653264: process control retransmit_signaling [DBG][2024/06/12/10:40:01:644][:834]Get wifi station status 6 106602 (null) INFO:1653264: process signaling candidate 106602 (null) INFO:1653264: process signaling candidate 106631 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:01:691][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:01:691][:834]Get wifi station status 6 error = 0 watcher remove 38, nfds 2 watcher add 38, nfds 3 106647 (null) INFO:1715148: tcp 38 state change: CONNECT -> REQUEST 106648 (null) INFO:1653264: process signaling candidate 106648 (null) INFO:1653264: process signaling candidate 106649 (null) INFO:1653264: process signaling candidate 106660 (null) INFO:1653264: process signaling candidate 106690 (null) INFO:1653264: process signaling candidate 106710 (null) INFO:1661204: ice 3 state change: CHECK -> CONNECTED 106710 (null) INFO:1653264: rtc session 00010003 on ice status: 1, cost: 149 106710 (null) INFO:1653264: rtc 00010003 transport update 1: 1 -1 0, 100 0 0 106713 (null) INFO:1653264: rtc session 00010003 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 106714 (null) INFO:1653264: rtc session 00010003 state change: DTLS_SRTP_KEY_NEGO -> STREAM 106714 (null) INFO:1653264: add new rtc session 00010003, session id 6c71d5d0f96892389aay5r1718160002dJkVqQWL, connect session , status 0 106714 (null) INFO:1653264: listen result 00010003 106714 (null) WARN:1653264: channel 4 first send 106717 (null) INFO:1653264: rtc 00010003 transport update 2: 2 -1 0, 100 0 0 106717 (null) INFO:1653264: rtc 00010003 on ice data, cost: 156 106717 (null) WARN:1653264: channel 0 get first data [06-12 10:40:02 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:02 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 106732 (null) INFO:1653264: rtc session 00010003 close 106732 (null) INFO:1653264: rtc session 00010003 close over [06-12 10:40:02 TUYA E][tuya_ipc_p2p.c:4206] Close session[65539] 106732 (null) INFO:1653264: try listen [DBG][2024/06/12/10:40:01:781][:834]Get wifi station status 6 106734 (null) INFO:1653264: process control close 106734 (null) INFO:1653264: rtc session 00010003 ready to close 106740 (null) INFO:1653264: rtc 00010003 closed by remote or local, local:1 remote:0 106740 (null) INFO:1653264: rtc session 00010003 state change: STREAM -> FAILED 106752 (null) INFO:1653264: destroy rtc session 00010003 watcher remove 34, nfds 2 watcher remove 36, nfds 1 watcher remove 38, nfds 0 106870 (null) INFO:1653264: process signaling disconnect 106870 (null) INFO:1653264: can not find rtc session 106900 (null) INFO:1653264: process signaling disconnect 106900 (null) INFO:1653264: can not find rtc session 106960 (null) INFO:1653264: process signaling offer 106962 (null) WARN:1653264: channel 4 first write 106976 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 106977 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:02 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 107030 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 41, nfds 1 watcher add 38, nfds 2 107049 (null) INFO:1661204: ice 4 state change: CANDIDATE -> CHECK connect ret -1 watcher add 39, nfds 3 107060 (null) INFO:1653264: process signaling candidate 107061 (null) INFO:1653264: process signaling candidate 107061 (null) INFO:1653264: process signaling candidate 107061 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:02:111][:601]WIFI[0] Get IP:192.168.3.97 107074 (null) INFO:1653264: got repeated offer, drop 107081 (null) INFO:1653264: process signaling candidate 107081 (null) INFO:1653264: process signaling candidate 107081 (null) INFO:1653264: process control retransmit_signaling [DBG][2024/06/12/10:40:02:135][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:02:135][:834]Get wifi station status 6 107095 (null) INFO:1653264: process signaling candidate 107098 (null) INFO:1653264: process signaling candidate 107099 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:02:188][:834]Get wifi station status 6 107147 (null) INFO:1653264: process signaling candidate 107161 (null) INFO:1653264: process signaling candidate 107162 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 39, nfds 2 watcher add 39, nfds 3 [DBG][2024/06/12/10:40:02:267][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] 107221 (null) INFO:1715148: tcp 39 state change: CONNECT -> REQUEST 107266 (null) INFO:1661204: ice 4 state change: CHECK -> CONNECTED 107266 (null) INFO:1653264: rtc session 00010004 on ice status: 1, cost: 305 107266 (null) INFO:1653264: rtc 00010004 transport update 1: 1 -1 0, 100 0 0 107268 (null) INFO:1653264: rtc session 00010004 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 107268 (null) INFO:1653264: rtc session 00010004 state change: DTLS_SRTP_KEY_NEGO -> STREAM 107268 (null) INFO:1653264: add new rtc session 00010004, session id 6c71d5d0f96892389aay5r1718160002qxmz7dwY, connect session , status 0 107269 (null) INFO:1653264: listen result 00010004 107269 (null) WARN:1653264: channel 4 first send 107282 (null) INFO:1653264: rtc 00010004 transport update 2: 2 -1 0, 100 0 0 107283 (null) INFO:1653264: rtc 00010004 on ice data, cost: 322 107283 (null) WARN:1653264: channel 0 get first data [06-12 10:40:03 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:03 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 107301 (null) INFO:1653264: rtc session 00010004 close 107301 (null) INFO:1653264: rtc session 00010004 close over [06-12 10:40:03 TUYA E][tuya_ipc_p2p.c:4206] Close session[65540] 107302 (null) INFO:1653264: try listen 107304 (null) INFO:1653264: process control close 107305 (null) INFO:1653264: rtc session 00010004 ready to close 107305 (null) INFO:1653264: rtc 00010004 closed by remote or local, local:1 remote:0 107305 (null) INFO:1653264: rtc session 00010004 state change: STREAM -> FAILED 107323 (null) INFO:1653264: destroy rtc session 00010004 watcher remove 41, nfds 2 watcher remove 38, nfds 1 watcher remove 39, nfds 0 107380 (null) INFO:1653264: process signaling disconnect 107380 (null) INFO:1653264: can not find rtc session 107410 (null) INFO:1653264: process signaling disconnect 107410 (null) INFO:1653264: can not find rtc session [DBG][2024/06/12/10:40:02:508][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] 107470 (null) INFO:1653264: process signaling offer 107472 (null) WARN:1653264: channel 4 first write 107474 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 107474 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:03 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 107474 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 36, nfds 1 watcher add 38, nfds 2 107483 (null) INFO:1661204: ice 5 state change: CANDIDATE -> CHECK connect ret -1 watcher add 39, nfds 3 107490 (null) INFO:1653264: process signaling candidate 107490 (null) INFO:1653264: process signaling candidate 107490 (null) INFO:1653264: process signaling candidate 107525 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:02:588][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:02:588][:834]Get wifi station status 6 107542 (null) INFO:1653264: got repeated offer, drop 107550 (null) INFO:1653264: process control retransmit_signaling error = 0 watcher remove 39, nfds 2 watcher add 39, nfds 3 107578 (null) INFO:1715148: tcp 39 state change: CONNECT -> REQUEST 107581 (null) INFO:1653264: process signaling candidate 107584 (null) INFO:1653264: process signaling candidate 107584 (null) INFO:1653264: process signaling candidate 107585 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:02:636][:834]Get wifi station status 6 107589 (null) INFO:1653264: process signaling candidate 107603 (null) INFO:1653264: process signaling candidate 107604 (null) INFO:1653264: process signaling candidate 107604 (null) INFO:1653264: process signaling candidate 107680 (null) INFO:1661204: ice 5 state change: CHECK -> CONNECTED 107680 (null) INFO:1653264: rtc session 00010005 on ice status: 1, cost: 210 107680 (null) INFO:1653264: rtc 00010005 transport update 1: 1 -1 0, 100 0 0 107682 (null) INFO:1653264: rtc session 00010005 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 107683 (null) INFO:1653264: rtc session 00010005 state change: DTLS_SRTP_KEY_NEGO -> STREAM 107683 (null) INFO:1653264: add new rtc session 00010005, session id 6c71d5d0f96892389aay5r1718160003m9uvuQkB, connect session , status 0 107683 (null) INFO:1653264: listen result 00010005 107683 (null) WARN:1653264: channel 4 first send 107713 (null) INFO:1653264: rtc 00010005 transport update 2: 2 -1 0, 100 0 0 107714 (null) INFO:1653264: rtc 00010005 on ice data, cost: 244 107714 (null) WARN:1653264: channel 0 get first data [06-12 10:40:03 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:03 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 107720 (null) INFO:1653264: rtc session 00010005 close 107720 (null) INFO:1653264: rtc session 00010005 close over [06-12 10:40:03 TUYA E][tuya_ipc_p2p.c:4206] Close session[65541] 107720 (null) INFO:1653264: try listen 107725 (null) INFO:1715148: tcp 39 state change: REQUEST -> ACK 107726 (null) INFO:1653264: process control close 107726 (null) INFO:1653264: rtc session 00010005 ready to close 107740 (null) INFO:1653264: rtc 00010005 closed by remote or local, local:1 remote:0 107740 (null) INFO:1653264: rtc session 00010005 state change: STREAM -> FAILED 107748 (null) INFO:1653264: destroy rtc session 00010005 watcher remove 36, nfds 2 watcher remove 38, nfds 1 watcher remove 39, nfds 0 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 107790 (null) INFO:1653264: process signaling disconnect 107790 (null) INFO:1653264: can not find rtc session [DBG][2024/06/12/10:40:02:863][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:02:864][:834]Get wifi station status 6 107820 (null) INFO:1653264: process signaling disconnect 107820 (null) INFO:1653264: can not find rtc session 107882 (null) INFO:1653264: process signaling offer 107884 (null) WARN:1653264: channel 4 first write 107887 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 107888 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:03 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 107888 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 36, nfds 1 watcher add 38, nfds 2 107901 (null) INFO:1661204: ice 6 state change: CANDIDATE -> CHECK connect ret -1 watcher add 39, nfds 3 107910 (null) INFO:1653264: process signaling candidate 107910 (null) INFO:1653264: process signaling candidate 107911 (null) INFO:1653264: process signaling candidate 107911 (null) INFO:1653264: process signaling candidate 107928 (null) INFO:1653264: got repeated offer, drop 107940 (null) INFO:1653264: process control retransmit_signaling 107946 (null) INFO:1653264: process signaling candidate 107953 (null) INFO:1653264: process signaling candidate 107954 (null) INFO:1653264: process signaling candidate 107954 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 39, nfds 2 watcher add 39, nfds 3 [DBG][2024/06/12/10:40:03:028][:834]Get wifi station status 6 107995 (null) INFO:1715148: tcp 39 state change: CONNECT -> REQUEST 108000 (null) INFO:1653264: process signaling candidate 108000 (null) INFO:1653264: process signaling candidate 108001 (null) INFO:1653264: process signaling candidate 108002 (null) INFO:1653264: process signaling candidate 108103 (null) INFO:1661204: ice 6 state change: CHECK -> CONNECTED 108103 (null) INFO:1653264: rtc session 00010006 on ice status: 1, cost: 220 108103 (null) INFO:1653264: rtc 00010006 transport update 1: 1 -1 0, 100 0 0 108105 (null) INFO:1653264: rtc session 00010006 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 108105 (null) INFO:1653264: rtc session 00010006 state change: DTLS_SRTP_KEY_NEGO -> STREAM 108105 (null) INFO:1653264: add new rtc session 00010006, session id 6c71d5d0f96892389aay5r1718160003BwzSbKLl, connect session , status 0 108105 (null) INFO:1653264: listen result 00010006 108105 (null) WARN:1653264: channel 4 first send 108116 (null) INFO:1653264: rtc 00010006 transport update 2: 2 -1 0, 100 0 0 108116 (null) INFO:1653264: rtc 00010006 on ice data, cost: 233 108117 (null) WARN:1653264: channel 0 get first data [06-12 10:40:04 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:04 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 108126 (null) INFO:1653264: rtc session 00010006 close 108126 (null) INFO:1653264: rtc session 00010006 close over [06-12 10:40:04 TUYA E][tuya_ipc_p2p.c:4206] Close session[65542] 108129 (null) INFO:1653264: try listen 108129 (null) INFO:1653264: process control close 108130 (null) INFO:1653264: rtc session 00010006 ready to close 108140 (null) INFO:1653264: rtc 00010006 closed by remote or local, local:1 remote:0 108140 (null) INFO:1653264: rtc session 00010006 state change: STREAM -> FAILED 108145 (null) INFO:1653264: destroy rtc session 00010006 watcher remove 36, nfds 2 watcher remove 38, nfds 1 watcher remove 39, nfds 0 [DBG][2024/06/12/10:40:03:452][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:03:452][:735]WIFI Get Mode 2 108470 (null) INFO:1653264: process signaling disconnect 108471 (null) INFO:1653264: can not find rtc session 108500 (null) INFO:1653264: process signaling disconnect 108500 (null) INFO:1653264: can not find rtc session 108590 (null) INFO:1653264: process signaling offer 108592 (null) WARN:1653264: channel 4 first write 108599 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 108599 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:04 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 108602 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 34, nfds 1 watcher add 36, nfds 2 108621 (null) INFO:1661204: ice 7 state change: CANDIDATE -> CHECK connect ret -1 watcher add 38, nfds 3 108631 (null) INFO:1653264: process signaling candidate 108631 (null) INFO:1653264: process signaling candidate 108631 (null) INFO:1653264: process signaling candidate 108646 (null) INFO:1653264: got repeated offer, drop 108650 (null) INFO:1653264: process control retransmit_signaling 108650 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:03:699][:834]Get wifi station status 6 108661 (null) INFO:1653264: process signaling candidate 108661 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 38, nfds 2 watcher add 38, nfds 3 108700 (null) INFO:1715148: tcp 38 state change: CONNECT -> REQUEST 108700 (null) INFO:1653264: process signaling candidate 108701 (null) INFO:1653264: process signaling candidate 108713 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:03:784][:735]WIFI Get Mode 2 108737 (null) INFO:1653264: process signaling candidate 108737 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:03:785][:834]Get wifi station status 6 108755 (null) INFO:1661204: ice 7 state change: CHECK -> CONNECTED 108755 (null) INFO:1653264: rtc session 00010007 on ice status: 1, cost: 165 108755 (null) INFO:1653264: rtc 00010007 transport update 1: 1 -1 0, 100 0 0 108758 (null) INFO:1653264: rtc session 00010007 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 108758 (null) INFO:1653264: rtc session 00010007 state change: DTLS_SRTP_KEY_NEGO -> STREAM 108758 (null) INFO:1653264: add new rtc session 00010007, session id 6c71d5d0f96892389aay5r1718160004tEuF8wxK, connect session , status 0 108758 (null) INFO:1653264: listen result 00010007 108758 (null) WARN:1653264: channel 4 first send 108759 (null) INFO:1653264: process signaling candidate 108775 (null) INFO:1653264: rtc 00010007 transport update 2: 2 -1 0, 100 0 0 108776 (null) INFO:1653264: rtc 00010007 on ice data, cost: 186 108776 (null) WARN:1653264: channel 0 get first data [06-12 10:40:04 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:04 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 108790 (null) INFO:1653264: rtc session 00010007 close 108790 (null) INFO:1653264: rtc session 00010007 close over [06-12 10:40:04 TUYA E][tuya_ipc_p2p.c:4206] Close session[65543] 108790 (null) INFO:1653264: try listen 108791 (null) INFO:1653264: process control close 108791 (null) INFO:1653264: rtc session 00010007 ready to close 108798 (null) INFO:1653264: rtc 00010007 closed by remote or local, local:1 remote:0 108798 (null) INFO:1653264: rtc session 00010007 state change: STREAM -> FAILED 108807 (null) INFO:1653264: destroy rtc session 00010007 watcher remove 34, nfds 2 watcher remove 36, nfds 1 watcher remove 38, nfds 0 109100 (null) INFO:1653264: process signaling disconnect 109100 (null) INFO:1653264: can not find rtc session 109132 (null) INFO:1653264: process signaling disconnect 109132 (null) INFO:1653264: can not find rtc session 109251 (null) INFO:1653264: process signaling offer 109252 (null) WARN:1653264: channel 4 first write 109261 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 109261 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:05 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 109262 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 34, nfds 1 watcher add 36, nfds 2 109281 (null) INFO:1661204: ice 8 state change: CANDIDATE -> CHECK connect ret -1 watcher add 38, nfds 3 109291 (null) INFO:1653264: process signaling candidate 109291 (null) INFO:1653264: process signaling candidate 109292 (null) INFO:1653264: process signaling candidate 109301 (null) INFO:1653264: got repeated offer, drop 109311 (null) INFO:1653264: process control retransmit_signaling 109320 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:04:370][:834]Get wifi station status 6 109324 (null) INFO:1653264: process signaling candidate 109324 (null) INFO:1653264: process signaling candidate 109325 (null) INFO:1653264: process signaling candidate 109325 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 38, nfds 2 watcher add 38, nfds 3 109338 (null) INFO:1715148: tcp 38 state change: CONNECT -> REQUEST 109343 (null) INFO:1653264: process signaling candidate 109355 (null) INFO:1653264: process signaling candidate 109357 (null) INFO:1653264: process signaling candidate 109368 (null) INFO:1653264: process signaling candidate 109462 (null) INFO:1661204: ice 8 state change: CHECK -> CONNECTED 109462 (null) INFO:1653264: rtc session 00010008 on ice status: 1, cost: 211 109462 (null) INFO:1653264: rtc 00010008 transport update 1: 1 -1 0, 100 0 0 109466 (null) INFO:1653264: rtc session 00010008 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 109466 (null) INFO:1653264: rtc session 00010008 state change: DTLS_SRTP_KEY_NEGO -> STREAM 109466 (null) INFO:1653264: add new rtc session 00010008, session id 6c71d5d0f96892389aay5r1718160005zVqXx7lX, connect session , status 0 109466 (null) INFO:1653264: listen result 00010008 109466 (null) WARN:1653264: channel 4 first send 109472 (null) INFO:1653264: rtc 00010008 transport update 2: 2 -1 0, 100 0 0 109472 (null) INFO:1653264: rtc 00010008 on ice data, cost: 221 109472 (null) WARN:1653264: channel 0 get first data [06-12 10:40:05 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:05 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 109480 (null) INFO:1653264: rtc session 00010008 close 109480 (null) INFO:1653264: rtc session 00010008 close over [06-12 10:40:05 TUYA E][tuya_ipc_p2p.c:4206] Close session[65544] 109480 (null) INFO:1653264: try listen 109481 (null) INFO:1653264: process control close 109481 (null) INFO:1653264: rtc session 00010008 ready to close 109492 (null) INFO:1653264: rtc 00010008 closed by remote or local, local:1 remote:0 109492 (null) INFO:1653264: rtc session 00010008 state change: STREAM -> FAILED 109497 (null) INFO:1653264: destroy rtc session 00010008 watcher remove 34, nfds 2 watcher remove 36, nfds 1 watcher remove 38, nfds 0 [DBG][2024/06/12/10:40:04:638][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:40:04:700][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:04:700][:834]Get wifi station status 6 109720 (null) INFO:1653264: process signaling disconnect 109720 (null) INFO:1653264: can not find rtc session 109781 (null) INFO:1653264: process signaling disconnect 109781 (null) INFO:1653264: can not find rtc session 109870 (null) INFO:1653264: process signaling offer 109872 (null) INFO:1653264: process signaling candidate 109873 (null) INFO:1653264: process signaling candidate 109873 (null) INFO:1653264: process signaling candidate 109874 (null) WARN:1653264: channel 4 first write 109879 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 109879 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:05 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 109890 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 34, nfds 1 watcher add 36, nfds 2 109892 (null) INFO:1661204: ice 9 state change: CANDIDATE -> CHECK connect ret -1 watcher add 38, nfds 3 109900 (null) INFO:1653264: process signaling candidate 109923 (null) INFO:1653264: process signaling candidate 109926 (null) INFO:1653264: got repeated offer, drop [DBG][2024/06/12/10:40:04:975][:834]Get wifi station status 6 error = 0 watcher remove 38, nfds 2 watcher add 38, nfds 3 109947 (null) INFO:1715148: tcp 38 state change: CONNECT -> REQUEST [DBG][2024/06/12/10:40:05:011][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:05:011][:834]Get wifi station status 6 109964 (null) INFO:1653264: process control retransmit_signaling 109969 (null) INFO:1653264: process signaling candidate 109969 (null) INFO:1653264: process signaling candidate 109970 (null) INFO:1653264: process signaling candidate 109970 (null) INFO:1653264: process signaling candidate 109971 (null) INFO:1653264: process signaling candidate 109981 (null) INFO:1653264: process signaling candidate 110058 (null) INFO:1661204: ice 9 state change: CHECK -> CONNECTED 110058 (null) INFO:1653264: rtc session 00010009 on ice status: 1, cost: 188 110058 (null) INFO:1653264: rtc 00010009 transport update 1: 1 -1 0, 100 0 0 110063 (null) INFO:1653264: rtc session 00010009 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 110063 (null) INFO:1653264: rtc session 00010009 state change: DTLS_SRTP_KEY_NEGO -> STREAM 110063 (null) INFO:1653264: add new rtc session 00010009, session id 6c71d5d0f96892389aay5r1718160005GOsW6zF9, connect session , status 0 110064 (null) INFO:1653264: listen result 00010009 110064 (null) WARN:1653264: channel 4 first send 110064 (null) INFO:1653264: process signaling candidate 110070 (null) INFO:1653264: rtc 00010009 transport update 2: 2 -1 0, 100 0 0 110070 (null) INFO:1653264: rtc 00010009 on ice data, cost: 200 110070 (null) WARN:1653264: channel 0 get first data 110074 (null) INFO:1715148: tcp 38 state change: REQUEST -> ACK [06-12 10:40:06 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:06 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 110083 (null) INFO:1653264: rtc session 00010009 close 110083 (null) INFO:1653264: rtc session 00010009 close over [06-12 10:40:06 TUYA E][tuya_ipc_p2p.c:4206] Close session[65545] 110084 (null) INFO:1653264: try listen 110086 (null) INFO:1653264: process control close 110086 (null) INFO:1653264: rtc session 00010009 ready to close 110086 (null) INFO:1653264: rtc 00010009 closed by remote or local, local:1 remote:0 110086 (null) INFO:1653264: rtc session 00010009 state change: STREAM -> FAILED 110094 (null) INFO:1653264: destroy rtc session 00010009 watcher remove 34, nfds 2 watcher remove 36, nfds 1 watcher remove 38, nfds 0 110202 (null) INFO:1653264: process signaling disconnect 110203 (null) INFO:1653264: can not find rtc session 110230 (null) INFO:1653264: process signaling disconnect 110230 (null) INFO:1653264: can not find rtc session 110350 (null) INFO:1653264: process signaling offer 110351 (null) INFO:1653264: process signaling candidate 110351 (null) INFO:1653264: process signaling candidate 110351 (null) INFO:1653264: process signaling candidate 110352 (null) WARN:1653264: channel 4 first write 110359 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 110359 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:06 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 110362 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 36, nfds 1 watcher add 38, nfds 2 110366 (null) INFO:1661204: ice 10 state change: CANDIDATE -> CHECK [DBG][2024/06/12/10:40:05:416][:834]Get wifi station status 6 110369 (null) INFO:1653264: got repeated offer, drop connect ret -1 watcher add 40, nfds 3 110391 (null) INFO:1653264: process signaling candidate 110392 (null) INFO:1653264: process control retransmit_signaling 110399 (null) INFO:1653264: process signaling candidate 110399 (null) INFO:1653264: [DBG][2024/06/12/10:40:05:455][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:05:455][:834]Get wifi station status 6 process signaling candidate error = 0 watcher remove 40, nfds 2 watcher add 40, nfds 3 110443 (null) INFO:1715148: tcp 40 state change: CONNECT -> REQUEST [DBG][2024/06/12/10:40:05:618][:834]Get wifi station status 6 110595 (null) INFO:1661204: ice 10 state change: CHECK -> CONNECTED 110595 (null) INFO:1653264: rtc session 0001000a on ice status: 1, cost: 245 110595 (null) INFO:1653264: rtc 0001000a transport update 1: 1 -1 0, 100 0 0 110598 (null) INFO:1715148: tcp 40 state change: REQUEST -> ACK 110599 (null) INFO:1653264: rtc session 0001000a state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 110599 (null) INFO:1653264: rtc session 0001000a state change: DTLS_SRTP_KEY_NEGO -> STREAM 110599 (null) INFO:1653264: add new rtc session 0001000a, session id 6c71d5d0f96892389aay5r1718160006x0Oobpl7, connect session , status 0 110599 (null) INFO:1653264: listen result 0001000a 110607 (null) WARN:1653264: channel 4 first send 110612 (null) INFO:1653264: rtc 0001000a transport update 2: 2 -1 0, 100 0 0 110612 (null) INFO:1653264: rtc 0001000a on ice data, cost: 262 110612 (null) WARN:1653264: channel 0 get first data [06-12 10:40:06 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:06 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 110620 (null) INFO:1653264: rtc session 0001000a close 110620 (null) INFO:1653264: rtc session 0001000a close over [06-12 10:40:06 TUYA E][tuya_ipc_p2p.c:4206] Close session[65546] 110620 (null) INFO:1653264: try listen 110621 (null) INFO:1653264: process control close 110621 (null) INFO:1653264: rtc session 0001000a ready to close 110631 (null) INFO:1653264: rtc 0001000a closed by remote or local, local:1 remote:0 110631 (null) INFO:1653264: rtc session 0001000a state change: STREAM -> FAILED 110638 (null) INFO:1653264: destroy rtc session 0001000a watcher remove 36, nfds 2 watcher remove 38, nfds 1 watcher remove 40, nfds 0 110800 (null) INFO:1653264: process signaling disconnect 110800 (null) INFO:1653264: can not find rtc session 110920 (null) INFO:1653264: process signaling offer 110922 (null) WARN:1653264: channel 4 first write 110924 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 110925 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:06 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 110925 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 38, nfds 1 watcher add 39, nfds 2 110933 (null) INFO:1661204: ice 11 state change: CANDIDATE -> CHECK connect ret -1 watcher add 40, nfds 3 110940 (null) INFO:1653264: process signaling candidate 110941 (null) INFO:1653264: process signaling candidate 110941 (null) INFO:1653264: process signaling candidate 110951 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:06:035][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:06:035][:834]Get wifi station status 6 error = 0 watcher remove 40, nfds 2 watcher add 40, nfds 3 110989 (null) INFO:1715148: tcp 40 state change: CONNECT -> REQUEST 110990 (null) INFO:1653264: process signaling candidate 111012 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:06:070][:834]Get wifi station status 6 111053 (null) INFO:1715148: tcp 40 state change: REQUEST -> ACK 111089 (null) INFO:1661204: ice 11 state change: CHECK -> CONNECTED 111094 (null) INFO:1653264: rtc session 0001000b on ice status: 1, cost: 174 111094 (null) INFO:1653264: rtc 0001000b transport update 1: 1 -1 0, 100 0 0 111102 (null) INFO:1653264: rtc session 0001000b state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 111102 (null) INFO:1653264: rtc session 0001000b state change: DTLS_SRTP_KEY_NEGO -> STREAM 111102 (null) INFO:1653264: add new rtc session 0001000b, session id 6c71d5d0f96892389aay5r1718160006uXQiN6Y6, connect session , status 0 111104 (null) INFO:1653264: listen result 0001000b 111105 (null) WARN:1653264: channel 4 first send 111105 (null) INFO:1653264: rtc 0001000b transport update 2: 2 -1 0, 100 0 0 111105 (null) INFO:1653264: rtc 0001000b on ice data, cost: 185 111105 (null) WARN:1653264: channel 0 get first data [06-12 10:40:07 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:07 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 111120 (null) INFO:1653264: rtc session 0001000b close 111120 (null) INFO:1653264: rtc session 0001000b close over [06-12 10:40:07 TUYA E][tuya_ipc_p2p.c:4206] Close session[65547] 111120 (null) INFO:1653264: try listen 111125 (null) INFO:1653264: process control close 111125 (null) INFO:1653264: rtc session 0001000b ready to close 111132 (null) INFO:1653264: rtc 0001000b closed by remote or local, local:1 remote:0 111132 (null) INFO:1653264: rtc session 0001000b state change: STREAM -> FAILED 111135 (null) INFO:1653264: destroy rtc session 0001000b watcher remove 38, nfds 2 watcher remove 39, nfds 1 watcher remove 40, nfds 0 [DBG][2024/06/12/10:40:06:220][:1505]sleep status,pushvideo[-1] clientnum[-1] waitcount[21] record[0] 111270 (null) INFO:1653264: process signaling disconnect 111270 (null) INFO:1653264: can not find rtc session 111420 (null) INFO:1653264: process signaling offer 111422 (null) WARN:1653264: channel 4 first write 111426 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 111426 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:07 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 111426 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 38, nfds 1 watcher add 39, nfds 2 111443 (null) INFO:1661204: ice 12 state change: CANDIDATE -> CHECK connect ret -1 watcher add 40, nfds 3 111450 (null) INFO:1653264: process signaling candidate 111450 (null) INFO:1653264: process signaling candidate 111451 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:06:516][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:06:516][:834]Get wifi station status 6 111470 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 40, nfds 2 watcher add 40, nfds 3 111517 (null) INFO:1715148: tcp 40 state change: CONNECT -> REQUEST [DBG][2024/06/12/10:40:06:590][:834]Get wifi station status 6 111564 (null) INFO:1653264: process signaling candidate 111565 (null) INFO:1653264: process signaling candidate 111713 (null) INFO:1661204: ice 12 state change: CHECK -> CONNECTED 111714 (null) INFO:1653264: rtc session 0001000c on ice status: 1, cost: 294 111714 (null) INFO:1653264: rtc 0001000c transport update 1: 1 -1 0, 100 0 0 111716 (null) INFO:1653264: rtc session 0001000c state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 111717 (null) INFO:1653264: rtc session 0001000c state change: DTLS_SRTP_KEY_NEGO -> STREAM 111717 (null) INFO:1653264: add new rtc session 0001000c, session id 6c71d5d0f96892389aay5r171816000709JA0pMl, connect session , status 0 111718 (null) INFO:1653264: listen result 0001000c 111719 (null) WARN:1653264: channel 4 first send 111724 (null) INFO:1653264: rtc 0001000c transport update 2: 2 -1 0, 100 0 0 111724 (null) INFO:1653264: rtc 0001000c on ice data, cost: 304 111724 (null) WARN:1653264: channel 0 get first data [06-12 10:40:07 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:07 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 111730 (null) INFO:1653264: rtc session 0001000c close 111730 (null) INFO:1653264: rtc session 0001000c close over [06-12 10:40:07 TUYA E][tuya_ipc_p2p.c:4206] Close session[65548] 111730 (null) INFO:1653264: try listen 111732 (null) INFO:1653264: process control close 111732 (null) INFO:1653264: rtc session 0001000c ready to close 111740 (null) INFO:1653264: rtc 0001000c closed by remote or local, local:1 remote:0 111740 (null) INFO:1653264: rtc session 0001000c state change: STREAM -> FAILED 111744 (null) INFO:1653264: destroy rtc session 0001000c watcher remove 38, nfds 2 watcher remove 39, nfds 1 watcher remove 40, nfds 0 111820 (null) INFO:1653264: process signaling disconnect 111821 (null) INFO:1653264: can not find rtc session [DBG][2024/06/12/10:40:06:882][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:06:883][:834]Get wifi station status 6 111941 (null) INFO:1653264: process signaling offer 111942 (null) INFO:1653264: process signaling candidate 111943 (null) INFO:1653264: process signaling candidate 111943 (null) INFO:1653264: process signaling candidate 111946 (null) WARN:1653264: channel 4 first write 111951 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 111951 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:07 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 111952 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 38, nfds 1 watcher add 39, nfds 2 111967 (null) INFO:1661204: ice 13 state change: CANDIDATE -> CHECK connect ret -1 watcher add 40, nfds 3 111991 (null) INFO:1653264: process signaling candidate 111992 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:07:041][:834]Get wifi station status 6 112007 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:07:077][:601]WIFI[0] Get IP:192.168.3.97 [20240612-10:40:07.087 D 225] stream_reader.c 1319: audio swtich OFF AUDIO_CTRL:56 error = 0 watcher remove 40, nfds 2 watcher add 40, nfds 3 112057 (null) INFO:1715148: tcp 40 state change: CONNECT -> REQUEST 112127 (null) INFO:1661204: ice 13 state change: CHECK -> CONNECTED 112127 (null) INFO:1653264: rtc session 0001000d on ice status: 1, cost: 185 112127 (null) INFO:1653264: rtc 0001000d transport update 1: 1 -1 0, 100 0 0 112129 (null) INFO:1653264: rtc session 0001000d state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 112129 (null) INFO:1653264: rtc session 0001000d state change: DTLS_SRTP_KEY_NEGO -> STREAM 112129 (null) INFO:1653264: add new rtc session 0001000d, session id 6c71d5d0f96892389aay5r1718160007TbifHVy8, connect session , status 0 112129 (null) INFO:1653264: listen result 0001000d 112129 (null) WARN:1653264: channel 4 first send 112173 (null) INFO:1715148: tcp 40 state change: REQUEST -> ACK 112229 (null) INFO:1715148: tcp 40 state change: ACK -> STREAM 112229 (null) INFO:1653264: rtc session 0001000d on tcp status: 1, cost: 287 112229 (null) INFO:1653264: rtc 0001000d transport update 2: 1 -1 1, 100 0 10 112279 (null) INFO:1653264: rtc 0001000d transport update 3: 1 -1 2, 100 0 100 112279 (null) INFO:1653264: rtc 0001000d on tcp data, cost: 337 112279 (null) WARN:1653264: channel 4 get first data 112280 (null) INFO:1653264: rtc 0001000d got signaling from cmd 112280 (null) INFO:1653264: got repeated offer, drop 112281 (null) INFO:1653264: rtc 0001000d got signaling from cmd 112281 (null) INFO:1653264: rtc 0001000d got signaling from cmd 112281 (null) INFO:1653264: rtc 0001000d got signaling from cmd 112281 (null) INFO:1653264: rtc 0001000d got signaling from cmd 112284 (null) INFO:1653264: rtc 0001000d got signaling from cmd 112300 (null) INFO:1653264: process control retransmit_signaling 112301 (null) INFO:1653264: process signaling candidate 112301 (null) INFO:1653264: process signaling candidate 112301 (null) INFO:1653264: process signaling candidate 112302 (null) INFO:1653264: process signaling candidate 112302 (null) INFO:1653264: process signaling candidate 112310 (null) INFO:1653264: rtc 0001000d got signaling from cmd 112310 (null) WARN:1653264: channel 0 get first data 112311 (null) INFO:1653264: process signaling candidate [06-12 10:40:08 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:08 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 112320 (null) INFO:1653264: rtc session 0001000d close 112320 (null) INFO:1653264: rtc session 0001000d close over [06-12 10:40:08 TUYA E][tuya_ipc_p2p.c:4206] Close session[65549] 112321 (null) INFO:1653264: try listen 112335 (null) INFO:1653264: process control close 112335 (null) INFO:1653264: rtc session 0001000d ready to close 112351 (null) INFO:1653264: rtc 0001000d closed by remote or local, local:1 remote:0 112351 (null) INFO:1653264: rtc session 0001000d state change: STREAM -> FAILED 112359 (null) INFO:1653264: destroy rtc session 0001000d watcher remove 38, nfds 2 watcher remove 39, nfds 1 watcher remove 40, nfds 0 [DBG][2024/06/12/10:40:07:422][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:07:422][:834]Get wifi station status 6 112410 (null) INFO:1653264: process signaling disconnect 112410 (null) INFO:1653264: can not find rtc session 112500 (null) INFO:1653264: process signaling offer 112502 (null) WARN:1653264: channel 4 first write 112504 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 112504 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:08 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 112505 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 38, nfds 1 watcher add 39, nfds 2 112515 (null) INFO:1661204: ice 14 state change: CANDIDATE -> CHECK connect ret -1 watcher add 40, nfds 3 112538 (null) INFO:1653264: process signaling candidate 112539 (null) INFO:1653264: process signaling candidate 112539 (null) INFO:1653264: process signaling candidate 112551 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 40, nfds 2 watcher add 40, nfds 3 112574 (null) INFO:1715148: tcp 40 state change: CONNECT -> REQUEST [DBG][2024/06/12/10:40:07:648][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:40:07:652][:834]Get wifi station status 6 112620 (null) INFO:1653264: process signaling candidate 112630 (null) INFO:1653264: process signaling candidate 112654 (null) INFO:1715148: tcp 40 state change: REQUEST -> ACK 112710 (null) WARN:1653264: channel 0 get first data 112710 (null) INFO:1661204: ice 14 state change: CHECK -> CONNECTED 112710 (null) INFO:1653264: rtc session 0001000e on ice status: 1, cost: 210 112710 (null) INFO:1653264: rtc 0001000e transport update 1: 1 -1 0, 100 0 0 112713 (null) INFO:1653264: rtc session 0001000e state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 112715 (null) INFO:1653264: rtc session 0001000e state change: DTLS_SRTP_KEY_NEGO -> STREAM 112715 (null) INFO:1653264: add new rtc session 0001000e, session id 6c71d5d0f96892389aay5r1718160008waGwjS7y, connect session , status 0 112717 (null) INFO:1653264: listen result 0001000e [06-12 10:40:08 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:08 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 112718 (null) INFO:1653264: rtc session 0001000e close 112718 (null) INFO:1653264: rtc session 0001000e close over [06-12 10:40:08 TUYA E][tuya_ipc_p2p.c:4206] Close session[65550] 112718 (null) INFO:1653264: try listen [DBG][2024/06/12/10:40:07:766][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:07:766][:834]Get wifi station status 6 112719 (null) WARN:1653264: channel 4 first send 112719 (null) INFO:1653264: process control close 112719 (null) INFO:1653264: rtc session 0001000e ready to close 112719 (null) INFO:1653264: rtc 0001000e closed by remote or local, local:1 remote:0 112719 (null) INFO:1653264: rtc session 0001000e state change: STREAM -> FAILED 112723 (null) INFO:1653264: destroy rtc session 0001000e watcher remove 38, nfds 2 watcher remove 39, nfds 1 watcher remove 40, nfds 0 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 112940 (null) INFO:1653264: process signaling disconnect 112940 (null) INFO:1653264: can not find rtc session [20240612-10:40:08.048 D 387] kernel_manage.c 161: Got dev_name : mmcblk0 [DBG][2024/06/12/10:40:08:158][:169]sd capacity: total: 7784448 KB, used 4952 KB, free 7779496 KB 113120 (null) INFO:1653264: process signaling offer 113121 (null) INFO:1653264: process signaling candidate 113121 (null) INFO:1653264: can not find rtc session 113121 (null) INFO:1653264: process signaling candidate 113121 (null) INFO:1653264: process signaling candidate 113121 (null) INFO:1653264: process signaling candidate 113121 (null) INFO:1653264: process signaling candidate 113122 (null) INFO:1653264: process signaling candidate 113122 (null) INFO:1653264: can not find rtc session 113122 (null) INFO:1653264: process signaling candidate 113122 (null) INFO:1653264: can not find rtc session 113122 (null) INFO:1653264: process signaling candidate 113122 (null) INFO:1653264: can not find rtc session 113122 (null) INFO:1653264: process signaling candidate 113122 (null) INFO:1653264: can not find rtc session 113122 (null) INFO:1653264: process signaling candidate 113122 (null) INFO:1653264: can not find rtc session 113122 (null) INFO:1653264: process signaling disconnect 113122 (null) INFO:1653264: can not find rtc session 113123 (null) WARN:1653264: channel 4 first write 113125 (null) INFO:1653264: got repeated offer, drop 113128 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 113136 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:09 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 113137 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 34, nfds 1 113137 (null) INFO:1653264: got repeated offer, drop 113158 (null) INFO:1653264: got repeated offer, drop [DBG][2024/06/12/10:40:08:216][:834]Get wifi station status 6 113175 (null) INFO:1653264: got repeated offer, drop watcher add 36, nfds 2 113176 (null) INFO:1661204: ice 15 state change: CANDIDATE -> CHECK 113185 (null) INFO:1653264: got repeated offer, drop connect ret -1 watcher add 38, nfds 3 113199 (null) INFO:1653264: process control retransmit_signaling 113199 (null) INFO:1653264: process signaling candidate 113199 (null) INFO:1653264: can not find rtc session 113200 (null) INFO:1653264: process signaling candidate 113200 (null) INFO:1653264: can not find rtc session 113200 (null) INFO:1653264: process signaling candidate 113200 (null) INFO:1653264: can not find rtc session 113200 (null) INFO:1653264: process signaling candidate 113200 (null) INFO:1653264: can not find rtc session 113200 (null) INFO:1653264: process signaling candidate 113200 (null) INFO:1653264: can not find rtc session 113203 (null) INFO:1653264: process signaling candidate 113203 (null) INFO:1653264: can not find rtc session 113203 (null) INFO:1653264: process signaling disconnect 113203 (null) INFO:1653264: can not find rtc session 113203 (null) INFO:1653264: process control retransmit_signaling 113203 (null) INFO:1653264: process signaling candidate 113203 (null) INFO:1653264: can not find rtc session 113203 (null) INFO:1653264: process signaling candidate 113203 (null) INFO:1653264: can not find rtc session 113203 (null) INFO:1653264: process signaling candidate 113203 (null) INFO:1653264: can not find rtc session 113203 (null) INFO:1653264: process signaling candidate 113204 (null) INFO:1653264: can not find rtc session 113205 (null) INFO:1653264: process signaling candidate 113206 (null) INFO:1653264: can not find rtc session 113206 (null) INFO:1653264: process signaling candidate 113206 (null) INFO:1653264: can not find rtc session 113206 (null) INFO:1653264: process signaling candidate 113206 (null) INFO:1653264: process signaling disconnect 113206 (null) INFO:1653264: can not find rtc session 113206 (null) INFO:1653264: process control retransmit_signaling 113206 (null) INFO:1653264: process signaling candidate 113206 (null) INFO:1653264: can not find rtc session 113206 (null) INFO:1653264: process signaling candidate 113206 (null) INFO:1653264: can not find rtc session 113206 (null) INFO:1653264: process signaling candidate 113542 (null) INFO:1653264: can not find rtc session 113542 (null) INFO:1653264: process signaling candidate 113542 (null) INFO:1653264: can not find rtc session 113542 (null) INFO:1653264: process signaling candidate 113542 (null) INFO:1653264: can not find rtc session 113542 (null) INFO:1653264: process signaling candidate 113542 (null) INFO:1653264: can not find rtc session 113542 (null) INFO:1653264: process signaling disconnect 113542 (null) INFO:1653264: can not find rtc session 113543 (null) INFO:1653264: process control retransmit_signaling 113543 (null) INFO:1653264: process signaling candidate 113543 (null) INFO:1653264: process signaling candidate 113543 (null) INFO:1653264: can not find rtc session 113543 (null) INFO:1653264: process signaling candidate 113543 (null) INFO:1653264: can not find rtc session 113543 (null) INFO:1653264: process signaling candidate 113543 (null) INFO:1653264: can not find rtc session 113543 (null) INFO:1653264: process signaling candidate 113543 (null) INFO:1653264: can not find rtc session 113543 (null) INFO:1653264: process signaling candidate 113543 (null) INFO:1653264: can not find rtc session 113543 (null) INFO:1653264: process signaling candidate 113543 (null) INFO:1653264: can not find rtc session 113544 (null) INFO:1653264: process signaling disconnect 113544 (null) INFO:1653264: can not find rtc session 113544 (null) INFO:1653264: process control retransmit_signaling 113547 (null) INFO:1653264: process signaling candidate 113549 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:08:598][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:08:598][:834]Get wifi station status 6 113550 (null) INFO:1653264: process signaling candidate 113550 (null) INFO:1653264: process signaling candidate 113551 (null) INFO:1653264: process signaling candidate 113551 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 38, nfds 2 watcher add 38, nfds 3 113577 (null) INFO:1715148: tcp 38 state change: CONNECT -> REQUEST 113600 (null) INFO:1661204: ice 15 state change: CHECK -> CONNECTED 113601 (null) INFO:1653264: rtc session 0001000f on ice status: 1, cost: 481 113601 (null) INFO:1653264: rtc 0001000f transport update 1: 1 -1 0, 100 0 0 113603 (null) INFO:1653264: rtc session 0001000f state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 113603 (null) INFO:1653264: rtc session 0001000f state change: DTLS_SRTP_KEY_NEGO -> STREAM 113603 (null) INFO:1653264: add new rtc session 0001000f, session id 6c71d5d0f96892389aay5r1718160009ZKvIDxSq, connect session , status 0 113603 (null) INFO:1653264: listen result 0001000f 113603 (null) WARN:1653264: channel 4 first send 113618 (null) INFO:1653264: rtc 0001000f transport update 2: 2 -1 0, 100 0 0 113619 (null) INFO:1653264: rtc 0001000f on ice data, cost: 499 113619 (null) WARN:1653264: channel 0 get first data [06-12 10:40:09 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:09 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 113620 (null) INFO:1653264: rtc session 0001000f close 113620 (null) INFO:1653264: rtc session 0001000f close over [06-12 10:40:09 TUYA E][tuya_ipc_p2p.c:4206] Close session[65551] 113621 (null) INFO:1653264: try listen 113624 (null) INFO:1653264: process control close 113624 (null) INFO:1653264: rtc session 0001000f ready to close 113624 (null) INFO:1653264: rtc 0001000f closed by remote or local, local:1 remote:0 113624 (null) INFO:1653264: rtc session 0001000f state change: STREAM -> FAILED 113638 (null) INFO:1653264: destroy rtc session 0001000f watcher remove 34, nfds 2 watcher remove 36, nfds 1 watcher remove 38, nfds 0 113680 (null) INFO:1653264: process signaling disconnect 113680 (null) INFO:1653264: can not find rtc session [DBG][2024/06/12/10:40:08:759][:834]Get wifi station status 6 113740 (null) INFO:1653264: process signaling disconnect 113740 (null) INFO:1653264: can not find rtc session 113830 (null) INFO:1653264: process signaling offer 113831 (null) INFO:1653264: process signaling candidate 113831 (null) INFO:1653264: process signaling candidate 113831 (null) INFO:1653264: process signaling candidate 113832 (null) WARN:1653264: channel 4 first write 113847 (null) INFO:1653264: got repeated offer, drop 113850 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 113851 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:09 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 113851 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 34, nfds 1 watcher add 36, nfds 2 113875 (null) INFO:1661204: ice 16 state change: CANDIDATE -> CHECK connect ret -1 watcher add 38, nfds 3 113890 (null) INFO:1653264: process signaling candidate 113891 (null) INFO:1653264: process control retransmit_signaling 113895 (null) INFO:1653264: process signaling candidate 113895 (null) INFO:1653264: process signaling candidate 113896 (null) INFO:1653264: process signaling candidate 113896 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:08:951][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:08:951][:834]Get wifi station status 6 113929 (null) INFO:1653264: process signaling candidate 113933 (null) INFO:1653264: process signaling candidate 113934 (null) INFO:1653264: process signaling candidate 113934 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 38, nfds 2 watcher add 38, nfds 3 113941 (null) INFO:1715148: tcp 38 state change: CONNECT -> REQUEST 113959 (null) INFO:1661204: ice 16 state change: CHECK -> CONNECTED 113959 (null) INFO:1653264: rtc session 00010010 on ice status: 1, cost: 129 113959 (null) INFO:1653264: rtc 00010010 transport update 1: 1 -1 0, 100 0 0 113968 (null) INFO:1653264: rtc session 00010010 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 113968 (null) INFO:1653264: rtc session 00010010 state change: DTLS_SRTP_KEY_NEGO -> STREAM 113968 (null) INFO:1653264: add new rtc session 00010010, session id 6c71d5d0f96892389aay5r17181600091jnRc0iF, connect session , status 0 113968 (null) INFO:1653264: listen result 00010010 113968 (null) WARN:1653264: channel 4 first send 114016 (null) INFO:1653264: rtc 00010010 transport update 2: 2 -1 0, 100 0 0 114016 (null) INFO:1653264: rtc 00010010 on ice data, cost: 186 114016 (null) WARN:1653264: channel 0 get first data [06-12 10:40:10 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:10 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 114020 (null) INFO:1653264: rtc session 00010010 close 114020 (null) INFO:1653264: rtc session 00010010 close over [06-12 10:40:10 TUYA E][tuya_ipc_p2p.c:4206] Close session[65552] 114021 (null) INFO:1653264: try listen 114025 (null) INFO:1653264: process control close 114025 (null) INFO:1653264: rtc session 00010010 ready to close 114030 (null) INFO:1653264: rtc 00010010 closed by remote or local, local:1 remote:0 114030 (null) INFO:1653264: rtc session 00010010 state change: STREAM -> FAILED 114038 (null) INFO:1653264: destroy rtc session 00010010 watcher remove 34, nfds 2 watcher remove 36, nfds 1 watcher remove 38, nfds 0 114080 (null) INFO:1653264: process signaling disconnect 114080 (null) INFO:1653264: can not find rtc session [DBG][2024/06/12/10:40:09:172][:834]Get wifi station status 6 114140 (null) INFO:1653264: process signaling disconnect 114140 (null) INFO:1653264: can not find rtc session 114170 (null) INFO:1653264: process signaling offer 114171 (null) INFO:1653264: process signaling candidate 114171 (null) INFO:1653264: process signaling candidate 114171 (null) INFO:1653264: process signaling candidate 114177 (null) WARN:1653264: channel 4 first write 114181 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 114189 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:10 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 114190 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 36, nfds 1 watcher add 38, nfds 2 114197 (null) INFO:1661204: ice 17 state change: CANDIDATE -> CHECK connect ret -1 watcher add 39, nfds 3 114218 (null) INFO:1653264: got repeated offer, drop 114221 (null) INFO:1653264: process signaling candidate 114222 (null) INFO:1653264: process control retransmit_signaling 114234 (null) INFO:1653264: process signaling candidate 114234 (null) INFO:1653264: process signaling candidate 114237 (null) INFO:1653264: process signaling candidate 114237 (null) INFO:1653264: process signaling candidate 114237 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:09:286][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:09:286][:834]Get wifi station status 6 114270 (null) INFO:1661204: ice 17 state change: CHECK -> CONNECTED 114270 (null) INFO:1653264: rtc session 00010011 on ice status: 1, cost: 99 114270 (null) INFO:1653264: rtc 00010011 transport update 1: 1 -1 0, 100 0 0 114275 (null) INFO:1653264: rtc session 00010011 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 114276 (null) INFO:1653264: rtc session 00010011 state change: DTLS_SRTP_KEY_NEGO -> STREAM 114276 (null) INFO:1653264: add new rtc session 00010011, session id 6c71d5d0f96892389aay5r1718160010zo2mT3Ym, connect session , status 0 114276 (null) INFO:1653264: listen result 00010011 114276 (null) WARN:1653264: channel 4 first send 114276 (null) INFO:1653264: process signaling candidate 114277 (null) INFO:1653264: process signaling candidate 114286 (null) INFO:1653264: rtc 00010011 transport update 2: 2 -1 0, 100 0 0 114286 (null) INFO:1653264: rtc 00010011 on ice data, cost: 115 114287 (null) WARN:1653264: channel 0 get first data error = 0 watcher remove 39, nfds 2 watcher add 39, nfds 3 114624 (null) INFO:1715148: tcp 39 state change: CONNECT -> REQUEST 114625 (null) INFO:1653264: process signaling candidate [06-12 10:40:10 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:10 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 114630 (null) INFO:1653264: rtc session 00010011 close 114630 (null) INFO:1653264: rtc session 00010011 close over [06-12 10:40:10 TUYA E][tuya_ipc_p2p.c:4206] Close session[65553] 114631 (null) INFO:1653264: try listen 114631 (null) INFO:1653264: process control close 114632 (null) INFO:1653264: rtc session 00010011 ready to close 114640 (null) INFO:1653264: rtc 00010011 closed by remote or local, local:1 remote:0 114640 (null) INFO:1653264: rtc session 00010011 state change: STREAM -> FAILED 114644 (null) INFO:1653264: destroy rtc session 00010011 watcher remove 36, nfds 2 watcher remove 38, nfds 1 watcher remove 39, nfds 0 114680 (null) INFO:1653264: process signaling disconnect 114681 (null) INFO:1653264: can not find rtc session [DBG][2024/06/12/10:40:09:734][:834]Get wifi station status 6 114740 (null) INFO:1653264: process signaling disconnect 114740 (null) INFO:1653264: can not find rtc session 114830 (null) INFO:1653264: process signaling offer 114832 (null) WARN:1653264: channel 4 first write 114839 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 114839 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:10 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 114839 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 34, nfds 1 watcher add 38, nfds 2 114849 (null) INFO:1661204: ice 18 state change: CANDIDATE -> CHECK connect ret -1 watcher add 39, nfds 3 114860 (null) INFO:1653264: process signaling candidate 114864 (null) INFO:1653264: process signaling candidate 114864 (null) INFO:1653264: process signaling candidate 114871 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 39, nfds 2 watcher add 39, nfds 3 114894 (null) INFO:1653264: got repeated offer, drop 114909 (null) INFO:1715148: tcp 39 state change: CONNECT -> REQUEST 114920 (null) INFO:1653264: process control retransmit_signaling [DBG][2024/06/12/10:40:09:974][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:09:974][:834]Get wifi station status 6 114927 (null) INFO:1653264: process signaling candidate 114927 (null) INFO:1653264: process signaling candidate 114928 (null) INFO:1653264: process signaling candidate 114928 (null) INFO:1653264: process signaling candidate 114928 (null) INFO:1653264: process signaling candidate 114967 (null) INFO:1653264: process signaling candidate 114978 (null) INFO:1653264: process signaling candidate 114978 (null) INFO:1653264: process signaling candidate 114986 (null) WARN:1653264: channel 0 get first data 114987 (null) INFO:1661204: ice 18 state change: CHECK -> CONNECTED 114987 (null) INFO:1653264: rtc session 00010012 on ice status: 1, cost: 157 114987 (null) INFO:1653264: rtc 00010012 transport update 1: 1 -1 0, 100 0 0 114988 (null) INFO:1715148: tcp 39 state change: REQUEST -> ACK 114988 (null) INFO:1653264: rtc session 00010012 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 114988 (null) INFO:1653264: rtc session 00010012 state change: DTLS_SRTP_KEY_NEGO -> STREAM 114988 (null) INFO:1653264: add new rtc session 00010012, session id 6c71d5d0f96892389aay5r1718160010HfITjnDp, connect session , status 0 114992 (null) INFO:1653264: listen result 00010012 [06-12 10:40:11 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:11 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 114992 (null) INFO:1653264: rtc session 00010012 close 114992 (null) INFO:1653264: rtc session 00010012 close over [06-12 10:40:11 TUYA E][tuya_ipc_p2p.c:4206] Close session[65554] 114993 (null) INFO:1653264: try listen 115002 (null) WARN:1653264: channel 4 first send 115002 (null) INFO:1653264: process control close 115002 (null) INFO:1653264: rtc session 00010012 ready to close 115003 (null) INFO:1653264: rtc 00010012 closed by remote or local, local:1 remote:0 115003 (null) INFO:1653264: rtc session 00010012 state change: STREAM -> FAILED 115008 (null) INFO:1653264: destroy rtc session 00010012 watcher remove 34, nfds 2 watcher remove 38, nfds 1 watcher remove 39, nfds 0 [DBG][2024/06/12/10:40:10:107][:834]Get wifi station status 6 115060 (null) INFO:1653264: process signaling disconnect 115060 (null) INFO:1653264: can not find rtc session 115090 (null) INFO:1653264: process signaling disconnect 115090 (null) INFO:1653264: can not find rtc session 115150 (null) INFO:1653264: process signaling offer 115157 (null) WARN:1653264: channel 4 first write 115163 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 115164 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:11 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 115164 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 36, nfds 1 watcher add 38, nfds 2 115178 (null) INFO:1661204: ice 19 state change: CANDIDATE -> CHECK connect ret -1 watcher add 39, nfds 3 115193 (null) INFO:1653264: got repeated offer, drop 115200 (null) INFO:1653264: process signaling candidate 115202 (null) INFO:1653264: process signaling candidate 115202 (null) INFO:1653264: process signaling candidate 115202 (null) INFO:1653264: process signaling candidate 115203 (null) INFO:1653264: process control retransmit_signaling 115209 (null) INFO:1653264: process signaling candidate 115209 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:10:301][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:10:302][:834]Get wifi station status 6 error = 0 watcher remove 39, nfds 2 watcher add 39, nfds 3 115257 (null) INFO:1715148: tcp 39 state change: CONNECT -> REQUEST 115258 (null) INFO:1653264: process signaling candidate 115258 (null) INFO:1653264: process signaling candidate 115258 (null) INFO:1653264: process signaling candidate 115270 (null) INFO:1653264: process signaling candidate 115270 (null) INFO:1653264: process signaling candidate 115282 (null) INFO:1653264: process signaling candidate 115309 (null) INFO:1661204: ice 19 state change: CHECK -> CONNECTED 115310 (null) INFO:1653264: rtc session 00010013 on ice status: 1, cost: 159 115310 (null) INFO:1653264: rtc 00010013 transport update 1: 1 -1 0, 100 0 0 115314 (null) INFO:1653264: rtc session 00010013 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 115314 (null) INFO:1653264: rtc session 00010013 state change: DTLS_SRTP_KEY_NEGO -> STREAM 115314 (null) INFO:1653264: add new rtc session 00010013, session id 6c71d5d0f96892389aay5r17181600114z4ZfL2r, connect session , status 0 115314 (null) INFO:1653264: listen result 00010013 115315 (null) WARN:1653264: channel 4 first send 115339 (null) INFO:1653264: rtc 00010013 transport update 2: 2 -1 0, 100 0 0 115339 (null) INFO:1653264: rtc 00010013 on ice data, cost: 188 115339 (null) WARN:1653264: channel 0 get first data 115348 (null) INFO:1715148: tcp 39 state change: REQUEST -> ACK [06-12 10:40:11 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:11 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 115350 (null) INFO:1653264: rtc session 00010013 close 115350 (null) INFO:1653264: rtc session 00010013 close over [06-12 10:40:11 TUYA E][tuya_ipc_p2p.c:4206] Close session[65555] 115350 (null) INFO:1653264: try listen 115351 (null) INFO:1653264: process control close 115351 (null) INFO:1653264: rtc session 00010013 ready to close 115360 (null) INFO:1653264: rtc 00010013 closed by remote or local, local:1 remote:0 115360 (null) INFO:1653264: rtc session 00010013 state change: STREAM -> FAILED 115367 (null) INFO:1653264: destroy rtc session 00010013 watcher remove 36, nfds 2 watcher remove 38, nfds 1 watcher remove 39, nfds 0 [DBG][2024/06/12/10:40:10:447][:834]Get wifi station status 6 115420 (null) INFO:1653264: process signaling disconnect 115420 (null) INFO:1653264: can not find rtc session 115510 (null) INFO:1653264: process signaling offer 115512 (null) WARN:1653264: channel 4 first write 115516 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 115516 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:11 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 115516 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 38, nfds 1 watcher add 39, nfds 2 115524 (null) INFO:1661204: ice 20 state change: CANDIDATE -> CHECK connect ret -1 watcher add 40, nfds 3 115550 (null) INFO:1653264: process signaling candidate 115554 (null) INFO:1653264: process signaling candidate 115554 (null) INFO:1653264: process signaling candidate 115571 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:10:641][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:10:641][:834]Get wifi station status 6 error = 0 watcher remove 40, nfds 2 watcher add 40, nfds 3 115599 (null) INFO:1715148: tcp 40 state change: CONNECT -> REQUEST [DBG][2024/06/12/10:40:10:660][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [06-12 10:40:11 TUYA E][tuya_svc_upgrade.c:436] result null [DBG][2024/06/12/10:40:10:716][:834]Get wifi station status 6 115669 (null) INFO:1653264: process signaling candidate 115680 (null) INFO:1653264: process signaling candidate 115693 (null) INFO:1715148: tcp 40 state change: REQUEST -> ACK 115740 (null) WARN:1653264: channel 0 get first data 115741 (null) INFO:1661204: ice 20 state change: CHECK -> CONNECTED 115741 (null) INFO:1653264: rtc session 00010014 on ice status: 1, cost: 231 115741 (null) INFO:1653264: rtc 00010014 transport update 1: 1 -1 0, 100 0 0 115741 (null) INFO:1653264: rtc session 00010014 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 115741 (null) INFO:1653264: rtc session 00010014 state change: DTLS_SRTP_KEY_NEGO -> STREAM 115741 (null) INFO:1653264: add new rtc session 00010014, session id 6c71d5d0f96892389aay5r1718160011JF3oDioX, connect session , status 0 115742 (null) INFO:1653264: listen result 00010014 [06-12 10:40:11 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:11 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 115742 (null) INFO:1653264: rtc session 00010014 close 115742 (null) INFO:1653264: rtc session 00010014 close over [06-12 10:40:11 TUYA E][tuya_ipc_p2p.c:4206] Close session[65556] 115742 (null) INFO:1653264: try listen 115743 (null) WARN:1653264: channel 4 first send 115743 (null) INFO:1653264: process control close 115743 (null) INFO:1653264: rtc session 00010014 ready to close 115750 (null) INFO:1653264: rtc 00010014 closed by remote or local, local:1 remote:0 115750 (null) INFO:1653264: rtc session 00010014 state change: STREAM -> FAILED 115754 (null) INFO:1653264: destroy rtc session 00010014 watcher remove 38, nfds 2 watcher remove 39, nfds 1 watcher remove 40, nfds 0 115873 (null) INFO:1653264: got repeated offer, drop 115900 (null) INFO:1653264: process signaling disconnect 115900 (null) INFO:1653264: can not find rtc session 115900 (null) INFO:1653264: process control retransmit_signaling 115900 (null) INFO:1653264: process signaling candidate 115900 (null) INFO:1653264: can not find rtc session 115900 (null) INFO:1653264: process signaling candidate 115900 (null) INFO:1653264: can not find rtc session 115900 (null) INFO:1653264: process signaling candidate 115900 (null) INFO:1653264: can not find rtc session 115900 (null) INFO:1653264: process signaling candidate 115900 (null) INFO:1653264: can not find rtc session 115901 (null) INFO:1653264: process signaling candidate 115901 (null) INFO:1653264: can not find rtc session 115901 (null) INFO:1653264: process signaling candidate 115901 (null) INFO:1653264: can not find rtc session 116050 (null) INFO:1653264: process signaling disconnect 116050 (null) INFO:1653264: can not find rtc session 116080 (null) INFO:1653264: process signaling disconnect 116080 (null) INFO:1653264: can not find rtc session 116174 (null) INFO:1653264: process signaling offer 116176 (null) WARN:1653264: channel 4 first write 116177 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 116178 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:12 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 116178 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 34, nfds 1 watcher add 38, nfds 2 116188 (null) INFO:1661204: ice 21 state change: CANDIDATE -> CHECK connect ret -1 watcher add 39, nfds 3 116200 (null) INFO:1653264: process signaling candidate 116201 (null) INFO:1653264: process signaling candidate 116201 (null) INFO:1653264: process signaling candidate 116231 (null) INFO:1653264: process signaling candidate 116242 (null) INFO:1653264: got repeated offer, drop [DBG][2024/06/12/10:40:11:291][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:11:291][:834]Get wifi station status 6 116244 (null) INFO:1653264: process control retransmit_signaling error = 0 watcher remove 39, nfds 2 watcher add 39, nfds 3 116274 (null) INFO:1715148: tcp 39 state change: CONNECT -> REQUEST 116278 (null) INFO:1653264: process signaling candidate 116278 (null) INFO:1653264: process signaling candidate 116286 (null) INFO:1653264: process signaling candidate 116286 (null) INFO:1653264: process signaling candidate 116286 (null) INFO:1653264: process signaling candidate 116306 (null) INFO:1653264: process signaling candidate 116325 (null) INFO:1661204: ice 21 state change: CHECK -> CONNECTED 116325 (null) INFO:1653264: rtc session 00010015 on ice status: 1, cost: 151 116325 (null) INFO:1653264: rtc 00010015 transport update 1: 1 -1 0, 100 0 0 [DBG][2024/06/12/10:40:11:376][:834]Get wifi station status 6 116340 (null) INFO:1653264: rtc session 00010015 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 116340 (null) INFO:1653264: rtc session 00010015 state change: DTLS_SRTP_KEY_NEGO -> STREAM 116340 (null) INFO:1653264: add new rtc session 00010015, session id 6c71d5d0f96892389aay5r1718160012Sd2zOQCS, connect session , status 0 116340 (null) INFO:1653264: listen result 00010015 116340 (null) WARN:1653264: channel 4 first send 116340 (null) INFO:1653264: process signaling candidate 116342 (null) INFO:1653264: rtc 00010015 transport update 2: 2 -1 0, 100 0 0 116342 (null) INFO:1653264: rtc 00010015 on ice data, cost: 168 116343 (null) WARN:1653264: channel 0 get first data 116343 (null) INFO:1715148: tcp 39 state change: REQUEST -> ACK [06-12 10:40:12 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:12 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 116360 (null) INFO:1653264: rtc session 00010015 close 116360 (null) INFO:1653264: rtc session 00010015 close over [06-12 10:40:12 TUYA E][tuya_ipc_p2p.c:4206] Close session[65557] 116360 (null) INFO:1653264: try listen 116363 (null) INFO:1653264: process control close 116363 (null) INFO:1653264: rtc session 00010015 ready to close 116370 (null) INFO:1653264: rtc 00010015 closed by remote or local, local:1 remote:0 116370 (null) INFO:1653264: rtc session 00010015 state change: STREAM -> FAILED 116373 (null) INFO:1653264: destroy rtc session 00010015 watcher remove 34, nfds 2 watcher remove 38, nfds 1 watcher remove 39, nfds 0 116391 (null) INFO:1653264: process signaling candidate 116392 (null) INFO:1653264: can not find rtc session 116510 (null) INFO:1653264: process signaling disconnect 116510 (null) INFO:1653264: can not find rtc session 116540 (null) INFO:1653264: process signaling disconnect 116540 (null) INFO:1653264: can not find rtc session [DBG][2024/06/12/10:40:11:598][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:11:598][:834]Get wifi station status 6 116603 (null) INFO:1653264: process signaling offer 116605 (null) WARN:1653264: channel 4 first write 116615 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 116615 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:12 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 116615 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 36, nfds 1 watcher add 38, nfds 2 116623 (null) INFO:1661204: ice 22 state change: CANDIDATE -> CHECK connect ret -1 watcher add 39, nfds 3 116640 (null) INFO:1653264: process signaling candidate 116641 (null) INFO:1653264: process signaling candidate 116641 (null) INFO:1653264: process signaling candidate 116641 (null) INFO:1653264: process signaling candidate 116656 (null) INFO:1653264: got repeated offer, drop [DBG][2024/06/12/10:40:11:718][:834]Get wifi station status 6 116699 (null) INFO:1653264: process control retransmit_signaling 116703 (null) INFO:1653264: process signaling candidate 116703 (null) INFO:1653264: process signaling candidate 116703 (null) INFO:1653264: process signaling candidate 116704 (null) INFO:1653264: process signaling candidate 116704 (null) INFO:1653264: process signaling candidate 116704 (null) INFO:1653264: process signaling candidate 116704 (null) INFO:1653264: process signaling candidate 116704 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 39, nfds 2 watcher add 39, nfds 3 116714 (null) INFO:1715148: tcp 39 state change: CONNECT -> REQUEST 116821 (null) INFO:1661204: ice 22 state change: CHECK -> CONNECTED 116821 (null) INFO:1653264: rtc session 00010016 on ice status: 1, cost: 218 116821 (null) INFO:1653264: rtc 00010016 transport update 1: 1 -1 0, 100 0 0 116824 (null) INFO:1653264: rtc session 00010016 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 116824 (null) INFO:1653264: rtc session 00010016 state change: DTLS_SRTP_KEY_NEGO -> STREAM 116824 (null) INFO:1653264: add new rtc session 00010016, session id 6c71d5d0f96892389aay5r1718160012Bmol59Vl, connect session , status 0 116824 (null) INFO:1653264: listen result 00010016 116824 (null) WARN:1653264: channel 4 first send 116875 (null) INFO:1653264: rtc 00010016 transport update 2: 2 -1 0, 100 0 0 116876 (null) INFO:1653264: rtc 00010016 on ice data, cost: 273 116876 (null) WARN:1653264: channel 0 get first data [06-12 10:40:12 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:12 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 116884 (null) INFO:1653264: rtc session 00010016 close 116884 (null) INFO:1653264: rtc session 00010016 close over [06-12 10:40:12 TUYA E][tuya_ipc_p2p.c:4206] Close session[65558] 116884 (null) INFO:1653264: try listen [DBG][2024/06/12/10:40:11:933][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:11:933][:834]Get wifi station status 6 116888 (null) INFO:1715148: tcp 39 state change: REQUEST -> ACK 116889 (null) INFO:1653264: process control close 116889 (null) INFO:1653264: rtc session 00010016 ready to close 116900 (null) INFO:1653264: rtc 00010016 closed by remote or local, local:1 remote:0 116900 (null) INFO:1653264: rtc session 00010016 state change: STREAM -> FAILED 116906 (null) INFO:1653264: destroy rtc session 00010016 watcher remove 36, nfds 2 watcher remove 38, nfds 1 watcher remove 39, nfds 0 [DBG][2024/06/12/10:40:12:047][:601]WIFI[0] Get IP:192.168.3.97 117000 (null) INFO:1653264: process signaling disconnect 117000 (null) INFO:1653264: can not find rtc session 117060 (null) INFO:1653264: process signaling disconnect 117060 (null) INFO:1653264: can not find rtc session 117150 (null) INFO:1653264: process signaling offer 117155 (null) WARN:1653264: channel 4 first write 117165 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 117165 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:13 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 117165 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 36, nfds 1 watcher add 38, nfds 2 117168 (null) INFO:1661204: ice 23 state change: CANDIDATE -> CHECK connect ret -1 watcher add 39, nfds 3 117180 (null) INFO:1653264: process signaling candidate 117181 (null) INFO:1653264: process signaling candidate 117181 (null) INFO:1653264: process signaling candidate 117206 (null) INFO:1653264: process signaling candidate 117209 (null) INFO:1653264: got repeated offer, drop [DBG][2024/06/12/10:40:12:259][:834]Get wifi station status 6 117216 (null) INFO:1653264: process control retransmit_signaling 117224 (null) INFO:1653264: process signaling candidate 117225 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:12:278][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] 117231 (null) INFO:1653264: process signaling candidate 117232 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 39, nfds 2 watcher add 39, nfds 3 117261 (null) INFO:1715148: tcp 39 state change: CONNECT -> REQUEST [DBG][2024/06/12/10:40:12:316][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:12:316][:834]Get wifi station status 6 117270 (null) INFO:1653264: process signaling candidate 117273 (null) INFO:1653264: process signaling candidate 117274 (null) INFO:1653264: process signaling candidate 117274 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:12:542][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] 117531 (null) INFO:1715148: tcp 39 state change: REQUEST -> ACK 117545 (null) INFO:1661204: ice 23 state change: CHECK -> CONNECTED 117545 (null) INFO:1653264: rtc session 00010017 on ice status: 1, cost: 394 117545 (null) INFO:1653264: rtc 00010017 transport update 1: 1 -1 0, 100 0 0 117546 (null) INFO:1653264: rtc session 00010017 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 117546 (null) INFO:1653264: rtc session 00010017 state change: DTLS_SRTP_KEY_NEGO -> STREAM 117546 (null) INFO:1653264: add new rtc session 00010017, session id 6c71d5d0f96892389aay5r1718160013j4412L6F, connect session , status 0 117548 (null) INFO:1653264: listen result 00010017 117548 (null) WARN:1653264: channel 4 first send 117549 (null) INFO:1653264: rtc 00010017 transport update 2: 2 -1 0, 100 0 0 117549 (null) INFO:1653264: rtc 00010017 on ice data, cost: 398 117549 (null) WARN:1653264: channel 0 get first data [06-12 10:40:13 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:13 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 117563 (null) INFO:1653264: rtc session 00010017 close 117563 (null) INFO:1653264: rtc session 00010017 close over [06-12 10:40:13 TUYA E][tuya_ipc_p2p.c:4206] Close session[65559] 117564 (null) INFO:1653264: try listen 117566 (null) INFO:1653264: process control close 117566 (null) INFO:1653264: rtc session 00010017 ready to close 117570 (null) INFO:1653264: rtc 00010017 closed by remote or local, local:1 remote:0 117570 (null) INFO:1653264: rtc session 00010017 state change: STREAM -> FAILED 117575 (null) INFO:1653264: destroy rtc session 00010017 watcher remove 36, nfds 2 watcher remove 38, nfds 1 watcher remove 39, nfds 0 117701 (null) INFO:1653264: process signaling disconnect 117701 (null) INFO:1653264: can not find rtc session 117732 (null) INFO:1653264: process signaling disconnect 117732 (null) INFO:1653264: can not find rtc session :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 117820 (null) INFO:1653264: process signaling offer 117825 (null) WARN:1653264: channel 4 first write 117827 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 117827 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:13 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 117827 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 36, nfds 1 watcher add 38, nfds 2 117837 (null) INFO:1661204: ice 24 state change: CANDIDATE -> CHECK connect ret -1 watcher add 39, nfds 3 117846 (null) INFO:1653264: got repeated offer, drop [DBG][2024/06/12/10:40:12:894][:834]Get wifi station status 6 117852 (null) INFO:1653264: process signaling candidate 117853 (null) INFO:1653264: process signaling candidate 117853 (null) INFO:1653264: process signaling candidate 117853 (null) INFO:1653264: process signaling candidate 117854 (null) INFO:1653264: process control retransmit_signaling 117866 (null) INFO:1653264: process signaling candidate 117866 (null) INFO:1653264: process signaling candidate 117867 (null) INFO:1653264: process signaling candidate 117897 (null) INFO:1653264: process signaling candidate 117898 (null) INFO:1653264: process signaling candidate 117898 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 39, nfds 2 watcher add 39, nfds 3 117910 (null) INFO:1715148: tcp 39 state change: CONNECT -> REQUEST [DBG][2024/06/12/10:40:12:971][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:12:971][:834]Get wifi station status 6 117930 (null) INFO:1653264: process signaling candidate 117930 (null) INFO:1653264: process signaling candidate 118005 (null) INFO:1715148: tcp 39 state change: REQUEST -> ACK 118121 (null) INFO:1661204: ice 24 state change: CHECK -> CONNECTED 118122 (null) INFO:1653264: rtc session 00010018 on ice status: 1, cost: 302 118122 (null) INFO:1653264: rtc 00010018 transport update 1: 1 -1 0, 100 0 0 118125 (null) INFO:1653264: rtc session 00010018 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 118125 (null) INFO:1653264: rtc session 00010018 state change: DTLS_SRTP_KEY_NEGO -> STREAM 118125 (null) INFO:1653264: add new rtc session 00010018, session id 6c71d5d0f96892389aay5r1718160013UyqD64TX, connect session , status 0 118126 (null) INFO:1653264: listen result 00010018 118126 (null) WARN:1653264: channel 4 first send 118129 (null) INFO:1653264: rtc 00010018 transport update 2: 2 -1 0, 100 0 0 118129 (null) INFO:1653264: rtc 00010018 on ice data, cost: 309 118129 (null) WARN:1653264: channel 0 get first data [06-12 10:40:14 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:14 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 118140 (null) INFO:1653264: rtc session 00010018 close 118140 (null) INFO:1653264: rtc session 00010018 close over [06-12 10:40:14 TUYA E][tuya_ipc_p2p.c:4206] Close session[65560] 118140 (null) INFO:1653264: try listen 118153 (null) INFO:1715148: tcp 39 state change: ACK -> STREAM 118153 (null) INFO:1653264: rtc session 00010018 on tcp status: 1, cost: 333 118153 (null) INFO:1653264: rtc 00010018 transport update 3: 2 -1 1, 100 0 0 118153 (null) INFO:1653264: process control close 118153 (null) INFO:1653264: rtc session 00010018 ready to close 118160 (null) INFO:1653264: rtc 00010018 closed by remote or local, local:1 remote:0 118160 (null) INFO:1653264: rtc session 00010018 state change: STREAM -> FAILED 118163 (null) INFO:1653264: destroy rtc session 00010018 watcher remove 36, nfds 2 watcher remove 38, nfds 1 watcher remove 39, nfds 0 118200 (null) INFO:1653264: process signaling disconnect 118200 (null) INFO:1653264: can not find rtc session 118230 (null) INFO:1653264: process signaling disconnect 118230 (null) INFO:1653264: can not find rtc session 118350 (null) INFO:1653264: process signaling offer 118351 (null) INFO:1653264: process signaling candidate 118351 (null) INFO:1653264: process signaling candidate 118352 (null) INFO:1653264: process signaling candidate 118353 (null) WARN:1653264: channel 4 first write 118358 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 118358 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:14 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 118358 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 36, nfds 1 watcher add 38, nfds 2 118368 (null) INFO:1661204: ice 25 state change: CANDIDATE -> CHECK connect ret -1 watcher add 39, nfds 3 [DBG][2024/06/12/10:40:13:424][:834]Get wifi station status 6 118377 (null) INFO:1653264: got repeated offer, drop 118380 (null) INFO:1653264: process signaling candidate 118381 (null) INFO:1653264: process control retransmit_signaling 118394 (null) INFO:1653264: process signaling candidate 118396 (null) INFO:1653264: process signaling candidate 118396 (null) INFO:1653264: process signaling candidate 118417 (null) INFO:1653264: process signaling candidate 118421 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:13:495][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:13:495][:834]Get wifi station status 6 118449 (null) INFO:1653264: process signaling candidate 118449 (null) INFO:1653264: process signaling candidate 118457 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 39, nfds 2 watcher add 39, nfds 3 118458 (null) INFO:1715148: tcp 39 state change: CONNECT -> REQUEST [DBG][2024/06/12/10:40:13:668][:1294]send wifi heartbeat---wifihbcnt[0][8][52] 118642 (null) WARN:1653264: channel 0 get first data 118668 (null) INFO:1661204: ice 25 state change: System startup 1st App start. -------------------------- STOPWATCH[0-4]: 0 50 ms 1 312 ms 2 386 ms 3 0 ms 4 0 ms -------------------------- [main]-1084: pdm r 0x1e8 g 0x100 b 0x1c9 [Quickstart_StartMedia]-777: VB[1920 1080] size:2592000 count:1 [Quickstart_StartMedia]-784: VB[2304 1296] size:1658880 count:1 [Quickstart_StartMedia]-791: VB[800 448] size:537600 count:3 [Quickstart_StartMedia]-798: VB[640 360] size:345600 count:3 [audio_adp_codec_set_input_vol]-227: Acodec set input vol(30) [QUICKSTART_COMM_VI_SetMipiAttr]-1821: ============= MipiDev 0, SetMipiAttr enWDRMode: 0 linear mode Root Name: /dev/mtdblock3 Rootfs Type: squashfs [Func]:os02h10_write_register [Line]:189 [Info]:I2C_WRITE error! mount /dev/mtdblock3 as squashfs rootfs [Jan 19 2024 15:11:03]===os02h10 sensor linear init success!===== [QuickStart_Service_Thread]-1010: media init(isp-->venc) take time: 171 ms [QuickStart_Service_Thread]-1025: get isp running status true [RCS]: /etc/init.d/S00devs [RCS]: /etc/init.d/S01udev [RCS]: /etc/init.d/S02moutfs mount param fs dir. param fs mounted. mount app fs. app fs mounted. Load /lib/modules/4.9.37/kernel/drivers/mmc/host/sdhci-xmedia.ko Load /lib/modules/4.9.37/kernel/drivers/rtc/rtc-xmedia.ko [RCS]: /etc/init.d/S80network Auto login as root ... login[121]: root login on 'ttyS000' Welcome to Linux. None of nfsroot found in cmdline. /system/root # start MMC\n find dir /mnt/flash/mmc! /dev/mmcblk0 update start! update_file=/mnt/flash/mmc/IPW-G5A2D0A1-TY-HANHUI_1300B_V1.0.2-240612_CN_EN_upgrade.bin update_file_md5=83d0f899cc770334d93caf21d8bdf4ef check file md5sum ok check device_md5 ok file_version=V1.0.2 device_version=V1.0.2 check version ok same checksum, exit! 2: Warning: Mosquitto should not be run as root/administrator. [19700101-00:00:03.096 D 183] my_main.c 818: main, runTime 2.811 [19700101-00:00:03.325 D 182] main.c 455: main, runTime 3.207 [19700101-00:00:03.375 D 182] media_gk72010300.c 52: quickstart_debug init start 3.375 [19700101-00:00:03.375 D 182] quickstart_rootfs.c 155: BOARDID_1315B AUDIO_CTRL:56 AUDIO_CTRL_ENABLE:0 ICR_CAMERA_POS:35 ICR_CAMERA_NEG:36 IR=[70] [19700101-00:00:03.448 D 182] media_gk72010300.c 89: quickstart_debug init shbuf 3.448 [19700101-00:00:03.479 D 182] quickstart_rootfs.c 1704: pdm r 0x1e8 g 0x100 b 0x1c9 [19700101-00:00:03.742 D 182] quickstart_rootfs.c 1652: media init(isp-->venc) take time: 137 ms [19700101-00:00:03.796 D 182] audio_rootfs.c 573: AO SetVqeVolume deviD:0 Chn:0 VolDb:0 [19700101-00:00:03.796 D 182] audio_rootfs.c 579: AI SetVqeVolume deviD:0 Chn:0 VolDb:0 [19700101-00:00:03.796 D 182] audio_rootfs.c 1354: audio start EncType:20 BitWidth:16bit SampleRate:8000 PtNumPerFrm:320 [19700101-00:00:03.829 D 182] quickstart_rootfs.c 1610: isp data load 1ms isp api load 32ms [19700101-00:00:03.858 D 182] media_gk72010300.c 95: quickstart_debug start mpp 3.858 [19700101-00:00:03.858 D 182] stream_reader.c 1824: video stream_reader_proc create success! [19700101-00:00:03.859 D 182] stream_reader.c 1891: audio stream_reader_proc create success! [19700101-00:00:03.859 D 182] stream_reader.c 1928: audio stream_writer_proc create success! [19700101-00:00:03.859 D 182] media_gk72010300.c 114: quickstart_debug rw stream 3.859 [19700101-00:00:03.859 D 182] media_gk72010300.c 39: start hkaov_main tmp/sdk_app_is_ok cb [19700101-00:00:03.860 D 182] md.c 292: MDInit VpssGrp=0 VpssChn=2 Width:640 Height:360 [19700101-00:00:03.887 D 183] my_main.c 823: main, runTime 3.887 [19700101-00:00:03.889 D 183] hank_dev_json.c 707: g_DomeInfo.motor_hlocat[46 1] /dev/null /dev/console /dev/console [19700101-08:00:03.893 I 183] hank_parameter.c 459: set env zone(28 TZ=GMT-08:00) success [19700101-08:00:03.893 I 183] my_main.c 754: generate version:1.0.2 suc. [19700101-08:00:03.894 I 183] my_main.c 793: generate factory_version:V1.0.2-Tuya_240612 suc. param_flash_read size[65536] :::osd_set 3928 [1] [19700101-00:00:03.896 D 229] region.c 2679: ^_^ osd time width=2304 height=1296 fsize=56 size=0 :::quickstart_set_isp_daynightstate_func 1859 day[1] [19700101-00:00:03.901 D 226] quickstart_rootfs.c 1831: open white light [19700101-00:00:03.939 I 226] hank_parameter.c 408: [hk_parameter_set_int] DayNightMode=1 [19700101-08:00:03.953 D 183] my_param.c 167: soc versioninfo: IPW-G5A2D0A1-TY-HANHUI V1.0.2-Tuya_240612 [19700101-08:00:03.954 D 183] my_param.c 211: pirParamflag: 1 now clear platform p2p server cache! [/home/faerica/work/HK/gk_hank_lpc_project/gklinux_lowpower/mcu/hisyslink/rk_link/hichannel_main.c][sample_wlan_init_up][l:186],net device up success wifi send: ab 0d a0 01 02 01 08 00 05 00 02 01 0a [/home/faerica/work/HK/gk_hank_lpc_project/gklinux_lowpower/mcu/hisyslink/rk_link/hichannel_main.c][sample_cleanup][l:138],sample_cleanup enter [19700101-00:00:03.981 D 182] media_gk72010300.c 158: quickstart_debug init over 3.981 [DBG][1970/01/01/08:00:04:001][:565]hisyslink recv:cmd[0xa0] len[17] xor[0xba] wifi recv: ab 11 a0 04 66 69 0a a1 00 00 34 00 12 24 06 04 ba [DBG][1970/01/01/08:00:04:001][:591]device get wifi time second 1718160033 [DBG][2024/06/12/10:40:33:000][:597]wifi set rtc[1718160033] tz[8.000000] [DBG][2024/06/12/10:40:33:000][:606]wifi versioninfo 12 24 06 04 V12.240604 [DBG][2024/06/12/10:40:33:000][:1373]now soc start create heart task [DBG][2024/06/12/10:40:33:000][:613]=== power! [0 52]=== [DBG][2024/06/12/10:40:33:000][:528]index:0 [20240612-02:40:33.002 D 182] main.c 460: main, runTime 4.4 [20240612-10:40:33.002 I 182] hank_parameter.c 459: set env zone(28 TZ=GMT-08:00) success [20240612-10:40:33.005 D 243] media_mqtt.c 420: quickstart_debug mqtt connected 4.7 set saturation type:1 value:150 get csc saturation:50 get csc contrast:52 [20240612-10:40:33.098 D 240] md.c 689: enable=1 sensitivity=50 thr=220 [DBG][2024/06/12/10:40:33:106][:290]uart attribute config:[/dev/ttyAMA1][9600] :::InitShBuf 84 sdk_app MAJOR[0] size=512000 :::InitShBuf 91 sdk_app MAJOR[1] size=204800 :::InitShBuf 98 sdk_app MJPEG[2] size=204800 InitShBuf 105 sdk_app AUDIOOUT[4] size=65536 sdk_app AUDIOIN[5] size=16384[20240612-10:40:33.109 D 183] hk_stream.c 179: Create thread of hank_audio_thread success! [20240612-10:40:33.109 D 183] hk_playvoice.c 475: hank_set_audio_play_enable 1 [20240612-10:40:33.109 D 183] hk_stream.c 185: start hk_huiyun_stream_init end, video size:524288 audioout format:0 [DBG][2024/06/12/10:40:33:109][:1149]------ platform module init done ------ [DBG][2024/06/12/10:40:33:114][:903]setmac[d8:11:31:cc:d1:4c] wifi send: ab 0a d1 d8 11 31 cc d1 4c d9 [20240612-10:40:33.115 D 183] motor_TMI8152.c 1305: [motor_module_create_TMI8152] Start Create handle=0xb6f81c30 [20240612-10:40:33.115 D 183] motor_TMI8152.c 1322: [motor_module_create_TMI8152] OK [20240612-10:40:33.115 D 183] motor_TMI8152.c 166: [TMI8152_init] TMI8152 handle=0xb6f81c30 OK :::mcu_send_data_buffer 2136 cmd=[a0 0 9 0] :::mcu_send_data_buffer 2187 [0] uart send >>> ab 0d a0 01 02 01 08 00 05 00 02 01 0a [20240612-10:40:33.118 D 254] hank_dev_json.c 147: get Json Object name=Tuya type=64 [20240612-10:40:33.119 I 254] hank_dev_json.c 297: parse obj cloud_plat:Tuya chip:GK720XXXXX CompanyVid: finished!!! [20240612-10:40:33.119 I 254] platform_common.c 75: parse cloud_info success. [20240612-10:40:33.119 I 254] hank_parameter.c 408: [hk_parameter_set_int] DayNightMode=1 [DBG][2024/06/12/10:40:33:121][:107]platform push eventId 0x905 [1] [DBG][2024/06/12/10:40:33:122][:2100]oem TyPid= [DBG][2024/06/12/10:40:33:122][:2106]TyPid=glgx6l1rkenztvdh [20240612-10:40:33.130 D 243] media_mqtt.c 265: msg_value: 0 :::daynight_mode_convert_dayNightContrl 3079 0 [20240612-10:40:33.134 I 257] hal_sdcard.c 87: mnt_fsname :mmcblk0 [20240612-10:40:33.134 I 257] hal_sdcard.c 88: mnt_dir :/mnt/flash/mmc [20240612-10:40:33.134 I 257] hal_sdcard.c 89: mnt_type :vfat [20240612-10:40:33.134 I 257] hal_sdcard.c 90: mnt_opt :rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro [20240612-10:40:33.134 I 257] hal_sdcard.c 91: mnt_freq :0 [20240612-10:40:33.134 I 257] hal_sdcard.c 92: mnt_passno :0 [20240612-10:40:33.134 I 257] hal_sdcard.c 106: sd state report state:3 [20240612-10:40:33.135 D 257] hal_sdcard.c 121: dev mount success! [20240612-10:40:33.135 I 259] tuya_led_1315B.c 59: start init redled gpio [DBG][2024/06/12/10:40:33:122][:2112]Tyid=qc11c9618107370f3fbe Tykey=7ywGtZ3sfxCpPfhYT9pB86cU9kZdBl4U [DBG][2024/06/12/10:40:33:152][:2167]tuya pid[glgx6l1rkenztvdh] uuid[qc11c9618107370f3fbe] authkey[7ywGtZ3sfxCpPfhYT9pB86cU9kZdBl4U] enable[1] [DBG][2024/06/12/10:40:33:213][:529]log recv a msg: (0x108) log_file_open : 244 : log file[/mnt/flash/mmc/devicelog/20240612_104033.txt] [20240612-10:40:33.237 I 259] tuya_led_1315B.c 64: start init blueled gpio [20240612-10:40:33.247 I 259] tuya_led_1315B.c 73: start init Alarm gpio [20240612-10:40:33.258 I 259] tuya_led_1315B.c 208: INDICATORLED GPIO CMD:xmmm 0x112C0040 0x0 > /dev/null REDLED GPIO:40 ENABLE_LEVEL:1 [20240612-10:40:33.258 I 259] tuya_led_1315B.c 209: INDICATORLED GPIO CMD:xmmm 0x112C005C 0x0 > /dev/null BLUELED GPIO:57 ENABLE_LEVEL:1 [DBG][2024/06/12/10:40:33:270][:528]index:1 [DBG][2024/06/12/10:40:33:318][:254]===========sample_wlan_init_ip============ [DBG][2024/06/12/10:40:33:318][:260]wlan ip[192.168.3.97] netmask[255.255.255.0] gw[192.168.3.1] boardcast[192.168.3.255] uart recv <<< ab 13 a0 01 01 34 47 0e 24 06 12 10 40 31 21 24 04 30 05 [DBG][2024/06/12/10:40:33:321][:1600]mcu handle cmd : 0xa0 :::mcu_check_cmd_resend 2126 [a0 a0] :::camera_mcu_startupinfo 1540 uwkup_reason[1] mcu_version[21 24 04 30][ 71 14 ][1 52] [last[0] [DBG][2024/06/12/10:40:33:321][:1473]0check_battery->lowper_flags[0] check_battery->check_count[0] check_val[52] [DBG][2024/06/12/10:40:33:321][:1572]currentTime:1718160033 mcuTime:0 zonetime:0 [DBG][2024/06/12/10:40:33:321][:1582]chargestatus[1] batteryvalue[52] lastbattery[0] :::camera_mcu_startupinfo 1583 wakeu[1] [DBG][2024/06/12/10:40:33:321][:101]mcu push mcu_eventId 0x10b [1] [DBG][2024/06/12/10:40:33:321][:1461]mcu_Heart_pthread start create heart task [DBG][2024/06/12/10:40:33:321][:152]:::word_commond_set_flag:::152:::sd_flag 0 1: [DBG][2024/06/12/10:40:33:347][:851]platform recv a msg: (0x10b) [DBG][2024/06/12/10:40:33:348][:205]now push battery[52] charge[1] ts[1718160033]! [20240612-10:40:33.455 D 183] motor_TMI8152.c 156: init BOARDID_1315B gpio over! [MSG][2024/06/12/10:40:33:558][:369]===net device set ip success! wifistatus[1]=== [20240612-10:40:33.595 I 183] motor_TMI8152.c 216: sync userPosition userStepX:207 userStepY:90 [20240612-10:40:33.595 D 183] motor_TMI8152.c 260: set x:207 y:90 motor_dir:1 user_dir:6 [20240612-10:40:33.595 I 183] hank_parameter.c 408: [hk_parameter_set_int] userStepX=207 [20240612-10:40:33.597 I 183] hank_parameter.c 408: [hk_parameter_set_int] userStepY=90 [20240612-10:40:33.670 D 229] region.c 2679: ^_^ osd time width=800 height=448 fsize=20 size=0 tuya_ipc_platform_uart_init begin tuya_ipc_platform_uart_init end [20240612-10:40:33.724 D 229] region.c 2679: ^_^ osd time width=800 height=448 fsize=20 size=0 [01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/flash/p2pCache/ [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/flash/p2pCache/ [01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/flash/p2pCache/ [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[ḉhV4~뚜FDV] [01-01 18:12:15 TUYA D][simplekv.c:1012] both file exist [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512 [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success [01-01 18:12:15 TUYA D][simplekv.c:1055] read from normal file [01-01 18:12:15 TUYA D][simplekv.c:765] curr db is V2. No need to upgrade [20240612-10:40:33.903 D 183] motor_TMI8152.c 134: IRCUT ANTI_CLOCKWISE OVER! [20240612-10:40:33.903 D 183] motor_TMI8152.c 942: [TMI8152_ctrl] TMI8152 handle=0xb6f81c30 type=13 OK [DBG][2024/06/12/10:40:33:903][:525]params->stpowermode.function_switch=0 :::mw_DoubleLight_Func 3108 isp_start_test [20240612-10:40:33.909 D 228] quickstart_rootfs.c 202: [pwm_ctrl] num:1, duty 16000 :0 [20240612-10:40:33.909 D 228] gk_isp_os02h10.c 3908: [mw_DoubleLight_Func]--[3908] dualMode full color, day state, close wled and rled ===== :::mw_img_irmode_set_daynight 2966 [2] [20240612-10:40:33.909 D 228] quickstart_rootfs.c 1831: open white light [20240612-10:40:33.911 I 228] hank_parameter.c 408: [hk_parameter_set_int] DayNightMode=1 :::mw_imgs_set_icr_switch 2698 mode =[1] [01-01 18:12:15 TUYA D][simplekv.c:555] head check success [01-01 18:12:15 TUYA D][simplekv.c:658] read and check head success [01-01 18:12:15 TUYA D][simplekv.c:1075] read from normal file success :::wifi_factory_task_process 382 not factory [DBG][2024/06/12/10:40:33:971][:427]hal recv a msg: (0x93c) [DBG][2024/06/12/10:40:33:971][:281]::::curmode[0 0]:: [20240612-10:40:33.971 D 256] motor_TMI8152.c 942: [TMI8152_ctrl] TMI8152 handle=0xb6f81c30 type=12 OK [20240612-10:40:33.978 D 325] my_main.c 634: connect cb [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success. [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ... [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2 [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success [01-01 18:12:15 TUYA E][log_seq.c:871] logseq empty [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3 [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:256 [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0 [01-01 18:12:15 TUYA D][tuya_bt_sdk.c:92] ty bt cmmod regist ok:1 uuid: 20 71 63 31 31 63 39 36 31 38 31 30 37 33 37 30 66 33 66 62 65 devid_tmp: 16 68 c0 41 30 91 81 20 10 07 0c 70 0f 0c f2 ce ff devid_tmp2: 20 71 63 31 31 63 39 36 31 38 31 30 37 33 37 30 66 33 66 62 65 [01-01 18:12:15 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon. dev id key: 16 d4 1d 8c d9 8f 00 b2 04 e9 80 09 98 ec f8 42 7e [01-01 18:12:15 TUYA I][bt_ext_porting.c:352] [TUYA-BTUART]tuya ext bt port init [01-01 18:12:15 TUYA N][tuya_ble_api.c:650] ble sdk re_inited [01-01 18:12:15 TUYA D][tuya_ble_active.c:523] bt active init [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:141] ty bt sdk init success finish [DBG][2024/06/12/10:40:34:003][:647]WIFI Get MAC 24-C6-1C-00-00-00 [DBG][2024/06/12/10:40:34:003][:869]Set Country Code:(null) [01-01 18:12:15 TUYA E][tuya_ipc_hardware_info.c:172] NO sensor info. Please check if you need. uuid: 20 71 63 31 31 63 39 36 31 38 31 30 37 33 37 30 66 33 66 62 65 dev_id_tmp: 16 68 c0 41 30 91 81 20 10 07 0c 70 0f 0c f2 ce ff dev_id_tmp2: 20 71 63 31 31 63 39 36 31 38 31 30 37 33 37 30 66 33 66 62 65 Exec Cmd:ifconfig wlan0 up P2P API Version: 244.3.4.107 5061 (null) INFO:1653264: tuya p2p rtc sdk version: 0xf403046b, Nov 7 2023 17:44:56 tuya liteos uv dev id key: 16 36 8e c0 64 f5 84 3b d0 ba da 26 0a 89 a9 bc e8 [DBG][2024/06/12/10:40:34:082][:705]WIFI Set Mode 2 [DBG][2024/06/12/10:40:34:082][:63]wifi connect, ssid[HKTEST11] passwd[11112222] [DBG][2024/06/12/10:40:34:082][:80]ssid=HKTEST11 passwd=11112222 gs_tuyaConfigWifi=0 [DBG][2024/06/12/10:40:34:082][:129]IPC Dev is banded! [DBG][2024/06/12/10:40:34:082][<__IPC_APP_Get_Net_Status_cb>:1576]Net status change to:3 [01-01 08:00:00 TUYA E][tuya_devos_netcfg.c:330] all netcfg stop fail:-1 dev id key: 16 bd 85 59 cc cf 3f 24 c4 a5 82 c6 3b 69 31 fb 21 [20240612-10:40:34.083 D 335] hk_stream.c 312: stream[2] change buffer and send loss video data [20240612-10:40:34.088 D 334] hk_stream.c 312: stream[0] change buffer and send loss video data [20240612-10:40:34.088 D 334] hk_stream.c 312: stream[1] change buffer and send loss video data [DBG][2024/06/12/10:40:34:131][:1694]regStatus ==== 2! [DBG][2024/06/12/10:40:34:131][:1981]wait mqtt online: 5.133 [20240612-10:40:34.134 I 334] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:40:34.134 I 334] hk_stream.c 423: stream[1] need Iframe,read again! [DBG][2024/06/12/10:40:34:135][:1331]create sleep thread [DBG][2024/06/12/10:40:34:135][:1505]sleep status,pushvideo[-1] clientnum[-1] waitcount[1] record[0] [20240612-10:40:34.178 D 256] motor_TMI8152.c 128: IRCUT CLOCKWISE OVER! [20240612-10:40:34.197 I 334] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:40:34.201 I 334] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:40:34.328 I 334] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:40:34.328 I 334] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:40:34.350 I 334] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:40:34.350 I 334] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:40:34.428 I 334] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:40:34.428 I 334] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:40:34.478 I 334] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:40:34.480 I 334] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:40:34.543 I 334] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:40:34.545 I 334] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:40:34.612 I 334] hk_stream.c 423: stream[0] ne [20240612-10:40:35.675 I 334] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:40:35.676 I 334] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:40:35.715 I 334] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:40:35.715 I 334] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:40:35.782 I 334] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:40:35.788 I 334] hk_stream.c 423: stream[1] need Iframe,read again! [20240612-10:40:35.853 I 334] hk_stream.c 423: stream[0] need Iframe,read again! [20240612-10:40:35.858 I 334] hk_stream.c 423: stream[1] need Iframe,read again! [DBG][2024/06/12/10:40:35:904][:834]Get wifi station status 6 [20240612-10:40:35.922 D 334] hk_stream.c 430: quickstart_debug stream[0] get Iframe over 6.923 [20240612-10:40:35.938 D 334] hk_stream.c 430: quickstart_debug stream[1] get Iframe over 6.940 [DBG][2024/06/12/10:40:35:990][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:36:004][<__IPC_APP_Get_Net_Status_cb>:1576]Net status change to:11 [DBG][2024/06/12/10:40:36:004][<__IPC_APP_Get_Net_Status_cb>:1632]STAT_MQTT_ONLINE! mqtt is online! curr event:4 [DBG][2024/06/12/10:40:36:005][:840]get tuya sleep keepactive info success Dbg:Get Server Time [DBG][2024/06/12/10:40:36:090][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:36:090][<__IPC_APP_Get_Net_Status_cb>:1576]Net status change to:7 [DBG][2024/06/12/10:40:36:090][<__IPC_APP_Get_Net_Status_cb>:1588]cloud is online [DBG][2024/06/12/10:40:36:108][:107]platform push eventId 0x936 [0] [DBG][2024/06/12/10:40:36:109][:205]now push battery[52] charge[1] ts[1718160036]! [DBG][2024/06/12/10:40:36:112][:1967]mcu recv a msg: (0x936) wifi send: ab 05 e1 00 4f [DBG][2024/06/12/10:40:36:113][:2306]over init tuya sdk dev running time: 7.115 [DBG][2024/06/12/10:40:36:121][:601]WIFI[0] Get IP:192.168.3.97 [DBG][2024/06/12/10:40:36:267][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:36:279][:735]WIFI Get Mode 2 7290 (null) INFO:1653264: process signaling offer 7291 (null) INFO:1653264: process signaling candidate 7291 (null) INFO:1653264: process signaling candidate 7291 (null) INFO:1653264: process signaling candidate 7291 (null) INFO:1653264: process signaling candidate 7291 (null) INFO:1653264: process signaling candidate 7292 (null) INFO:1653264: process signaling candidate 7293 (null) WARN:1653264: channel 4 first write 7300 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 7301 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [01-01 08:00:02 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 7301 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 36, nfds 1 7313 (null) INFO:1653264: got repeated offer, drop [DBG][2024/06/12/10:40:36:313][:834]Get wifi station status 6 watcher add 37, nfds 2 7321 (null) INFO:1661204: ice 1 state change: CANDIDATE -> CHECK [DBG][2024/06/12/10:40:36:341][:834]Get wifi station status 6 connect ret -1 watcher add 34, nfds 3 7357 (null) INFO:1653264: process control retransmit_signaling 7358 (null) INFO:1653264: process signaling candidate 7359 (null) INFO:1653264: process signaling candidate 7360 (null) INFO:1653264: process signaling candidate 7360 (null) INFO:1653264: process signaling candidate 7361 (null) INFO:1653264: process signaling candidate 7361 (null) INFO:1653264: process signaling candidate [DBG][2024/06/12/10:40:36:398][:1433]start mcu MCU_CMD_HEARTBEAT ... [DBG][2024/06/12/10:40:36:398][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] error = 0 watcher remove 34, nfds 2 watcher add 34, nfds 3 7440 (null) INFO:1715148: tcp 34 state change: CONNECT -> REQUEST 7448 (null) INFO:1661204: ice 1 state change: CHECK -> CONNECTED 7449 (null) INFO:1653264: rtc session 00010001 on ice status: 1, cost: 159 7449 (null) INFO:1653264: rtc 00010001 transport update 1: 1 -1 0, 100 0 0 7465 (null) INFO:1653264: rtc session 00010001 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 7465 (null) INFO:1653264: rtc session 00010001 state change: DTLS_SRTP_KEY_NEGO -> STREAM 7465 (null) INFO:1653264: add new rtc session 00010001, session id 6c71d5d0f96892389aay5r17181600253mnJp1xW, connect session , status 0 7466 (null) INFO:1653264: listen result 00010001 7466 (null) WARN:1653264: channel 4 first send 7467 (null) INFO:1653264: rtc 00010001 transport update 2: 2 -1 0, 100 0 0 7467 (null) INFO:1653264: rtc 00010001 on ice data, cost: 177 7467 (null) WARN:1653264: channel 0 get first data [06-12 10:40:37 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:37 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 7480 (null) INFO:1653264: rtc session 00010001 close 7480 (null) INFO:1653264: rtc session 00010001 close over [06-12 10:40:37 TUYA E][tuya_ipc_p2p.c:4206] Close session[65537] [06-12 10:40:37 TUYA E][tuya_ipc_p2p.c:4209] resend p2p passwd to service 7493 (null) INFO:1653264: process control close 7493 (null) INFO:1653264: rtc session 00010001 ready to close 7500 (null) INFO:1653264: rtc 00010001 closed by remote or local, local:1 remote:0 7500 (null) INFO:1653264: rtc session 00010001 state change: STREAM -> FAILED 7506 (null) INFO:1653264: destroy rtc session 00010001 watcher remove 36, nfds 2 watcher remove 37, nfds 1 watcher remove 34, nfds 0 [DBG][2024/06/12/10:40:36:600][:149]Get Server Time Success: 1718160037 28800 0 1718160036 [DBG][2024/06/12/10:40:37:000][:107]platform push eventId 0x903 [0] [DBG][2024/06/12/10:40:37:001][:1967]mcu recv a msg: (0x903) [DBG][2024/06/12/10:40:37:002][:479]soc get current system timeinfo 124-5-12 10:40:37 [DBG][2024/06/12/10:40:37:002][:487]timezoneinfo:[28800 8.00 ] [8 0] [DBG][2024/06/12/10:40:37:002][:512]soc set mcu rtc timeinfo 24-06-12 10:40:37 :::mcu_send_data_buffer 2136 cmd=[ab 0 6 1] :::mcu_send_data_buffer 2187 [0] [DBG][2024/06/12/10:40:37:002][:532]set wifi rtc time[1718160037] wifi send: ab 08 ab 66 69 0a a5 a8 Init tuya_ipc_ss_init [06-12 10:40:37 TUYA E][tuya_ipc_cloud_storage.c:383] iot_wd_common_read fails md5_encrypt_key -6 [06-12 10:40:37 TUYA E][tuya_ipc_cloud_storage.c:468] read key_key file failed. [DBG][2024/06/12/10:40:37:014][:168]curr light_on_off:1 [06-12 10:40:37 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:101 not find [DBG][2024/06/12/10:40:37:014][:207]curr flip_on_off:0 [06-12 10:40:37 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:103 not find [DBG][2024/06/12/10:40:37:014][:337]curr s_nightvision_mode:2 [06-12 10:40:37 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:124 not find [DBG][2024/06/12/10:40:37:014][:371]curr alarm_on_off:1 [DBG][2024/06/12/10:40:37:015][:400]curr device volume:8 [06-12 10:40:37 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:160 not find [DBG][2024/06/12/10:40:37:015][:451]curr alarm_sensitivity:1 [DBG][2024/06/12/10:40:37:015][:634]curr sd_status:1 [20240612-10:40:37.016 D 320] kernel_manage.c 161: Got dev_name : mmcblk0 [DBG][2024/06/12/10:40:37:018][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] [DBG][2024/06/12/10:40:37:073][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:37:134][:834]Get wifi station status 6 7770 (null) INFO:1653264: process signaling disconnect 7770 (null) INFO:1653264: can not find rtc session uart send >>> ab 0a ab 24 06 12 10 40 37 5d [DBG][2024/06/12/10:40:37:277][:834]Get wifi station status 6 [06-12 10:40:37 TUYA E][cloud_operation.c:511] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED [06-12 10:40:37 TUYA E][tuya_ipc_cloud_storage.c:1713] check cloud storage count failed, op_ret = -1 7891 (null) INFO:1653264: try listen 7923 (null) INFO:1653264: process signaling offer 7928 (null) WARN:1653264: channel 4 first write [DBG][2024/06/12/10:40:37:332][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:37:343][:834]Get wifi station status 6 7949 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 7950 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:37 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 7950 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 34, nfds 1 watcher add 35, nfds 2 7959 (null) INFO:1661204: ice 2 state change: CANDIDATE -> CHECK connect ret -1 watcher add 36, nfds 3 7972 (null) INFO:1653264: process signaling candidate 7973 (null) INFO:1653264: process signaling candidate 7973 (null) INFO:1653264: process signaling candidate 7973 (null) INFO:1653264: process signaling candidate 7974 (null) INFO:1653264: process signaling candidate 7974 (null) INFO:1653264: process signaling candidate :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:40:37:409][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:37:409][:735]WIFI Get Mode 2 uart recv <<< ab 05 ab 00 05 [DBG][2024/06/12/10:40:37:417][:1600]mcu handle cmd : 0xab :::mcu_check_cmd_resend 2126 [ab ab] error = 0 watcher remove 36, nfds 2 watcher add 36, nfds 3 8031 (null) INFO:1715148: tcp 36 state change: CONNECT -> REQUEST 8171 (null) INFO:1661204: ice 2 state change: CHECK -> CONNECTED 8171 (null) INFO:1653264: rtc session 00010002 on ice status: 1, cost: 247 8171 (null) INFO:1653264: rtc 00010002 transport update 1: 1 -1 0, 100 0 0 8172 (null) INFO:1653264: rtc session 00010002 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 8172 (null) INFO:1653264: rtc session 00010002 state change: DTLS_SRTP_KEY_NEGO -> STREAM 8172 (null) INFO:1653264: add new rtc session 00010002, session id 6c71d5d0f96892389aay5r1718160037dDteyTOZ, connect session , status 0 8172 (null) INFO:1653264: listen result 00010002 8172 (null) WARN:1653264: channel 4 first send 8178 (null) INFO:1653264: rtc 00010002 transport update 2: 2 -1 0, 100 0 0 8178 (null) INFO:1653264: rtc 00010002 on ice data, cost: 254 8178 (null) WARN:1653264: channel 0 get first data [06-12 10:40:37 TUYA E][tuya_ipc_p2p.c:3724] auth failed [06-12 10:40:37 TUYA E][tuya_ipc_p2p.c:4204] check userinfo error 8190 (null) INFO:1653264: rtc session 00010002 close 8190 (null) INFO:1653264: rtc session 00010002 close over [06-12 10:40:37 TUYA E][tuya_ipc_p2p.c:4206] Close session[65538] 8191 (null) INFO:1653264: try listen 8191 (null) INFO:1653264: process control close 8191 (null) INFO:1653264: rtc session 00010002 ready to close [DBG][2024/06/12/10:40:37:592][:834]Get wifi station status 6 8203 (null) INFO:1653264: rtc 00010002 closed by remote or local, local:1 remote:0 8203 (null) INFO:1653264: rtc session 00010002 state change: STREAM -> FAILED 8212 (null) INFO:1653264: destroy rtc session 00010002 watcher remove 34, nfds 2 watcher remove 35, nfds 1 watcher remove 36, nfds 0 8500 (null) INFO:1653264: process signaling disconnect 8500 (null) INFO:1653264: can not find rtc session 8710 (null) INFO:1653264: process signaling offer 8717 (null) INFO:1653264: process signaling candidate 8718 (null) WARN:1653264: channel 4 first write [DBG][2024/06/12/10:40:38:130][:834]Get wifi station status 6 8734 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) 8747 (null) INFO:1659828: system has ipv4(yes), has ipv6(no) [06-12 10:40:38 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited 8748 (null) INFO:1708972: upnp alloc local failed, ret = -1 watcher add 34, nfds 1 [DBG][2024/06/12/10:40:38:155][:735]WIFI Get Mode 2 watcher add 35, nfds 2 8775 (null) INFO:1661204: ice 3 state change: CANDIDATE -> CHECK connect ret -1 watcher add 36, nfds 3 8789 (null) INFO:1653264: process signaling candidate 8790 (null) INFO:1653264: process signaling candidate 8790 (null) INFO:1653264: process signaling candidate 8791 (null) INFO:1653264: process signaling candidate 8791 (null) INFO:1653264: process signaling candidate error = 0 watcher remove 36, nfds 2 watcher add 36, nfds 3 8808 (null) INFO:1715148: tcp 36 state change: CONNECT -> REQUEST 8846 (null) INFO:1715148: tcp 36 state change: REQUEST -> ACK 8912 (null) INFO:1661204: ice 3 state change: CHECK -> CONNECTED 8913 (null) INFO:1653264: rtc session 00010003 on ice status: 1, cost: 202 8913 (null) INFO:1653264: rtc 00010003 transport update 1: 1 -1 0, 100 0 0 8919 (null) INFO:1653264: rtc session 00010003 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 8919 (null) INFO:1653264: rtc session 00010003 state change: DTLS_SRTP_KEY_NEGO -> STREAM 8919 (null) INFO:1653264: add new rtc session 00010003, session id 6c71d5d0f96892389aay5r1718160038H2RhbZga, connect session , status 0 8919 (null) INFO:1653264: listen result 00010003 8925 (null) WARN:1653264: channel 4 first send 8959 (null) INFO:1653264: rtc 00010003 transport update 2: 2 -1 0, 100 0 0 8960 (null) INFO:1653264: rtc 00010003 on ice data, cost: 249 8960 (null) WARN:1653264: channel 0 get first data 8970 (null) INFO:1653264: try listen 8972 (null) INFO:1715148: tcp 36 state change: ACK -> STREAM 8972 (null) INFO:1653264: rtc session 00010003 on tcp status: 1, cost: 261 8972 (null) INFO:1653264: rtc 00010003 transport update 3: 2 -1 1, 100 0 0 9011 (null) WARN:1653264: channel 0 first write 9012 (null) WARN:1653264: channel 0 first send [DBG][2024/06/12/10:40:38:409][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:38:452][:1294]send wifi heartbeat---wifihbcnt[1][8][52] [DBG][2024/06/12/10:40:38:599][<__TUYA_APP_p2p_event_cb>:463]p2p rev event cb=[4] [DBG][2024/06/12/10:40:38:599][<__TUYA_APP_p2p_event_cb>:739]set clarity:0 [DBG][2024/06/12/10:40:38:600][<__TUYA_APP_p2p_event_cb>:742]set clarity:0 OK [DBG][2024/06/12/10:40:38:600][:242]save param to mem! [DBG][2024/06/12/10:40:38:652][:181]sd status 1 [20240612-10:40:38.655 D 356] kernel_manage.c 161: Got dev_name : mmcblk0 [DBG][2024/06/12/10:40:38:747][:659]curr sd total:7784448 used:4964 empty:7779484 [DBG][2024/06/12/10:40:38:748][:205]now push battery[52] charge[1] ts[1718160038]! [DBG][2024/06/12/10:40:38:748][:1002]get filter_enable 1 [DBG][2024/06/12/10:40:38:749][:1630]curr s_pirsw_sensity:2 [DBG][2024/06/12/10:40:38:758][:169]sd capacity: total: 7784448 KB, used 4964 KB, free 7779484 KB [DBG][2024/06/12/10:40:38:872][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:38:917][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:39:108][<__TUYA_APP_p2p_event_cb>:463]p2p rev event cb=[0] [DBG][2024/06/12/10:40:39:108][<__TUYA_APP_p2p_event_cb>:474]chn[0] video start [DBG][2024/06/12/10:40:39:108][:107]platform push eventId 0x925 [1] [DBG][2024/06/12/10:40:39:142][:107]platform push eventId 0x925 [1] [DBG][2024/06/12/10:40:39:148][:851]platform recv a msg: (0x925) 9760 (null) WARN:1653264: channel 1 first write 9770 (null) WARN:1653264: channel 1 first send [DBG][2024/06/12/10:40:39:201][:851]platform recv a msg: (0x925) [DBG][2024/06/12/10:40:39:246][<__TUYA_APP_p2p_event_cb>:463]p2p rev event cb=[2] [DBG][2024/06/12/10:40:39:246][<__TUYA_APP_p2p_event_cb>:498]chn[0] audio start 9863 (null) WARN:1653264: channel 2 first write 9864 (null) WARN:1653264: channel 2 first send 9926 (null) WARN:1653264: channel 1 get first data 10432 (null) WARN:1653264: channel 2 get first data [20240612-10:40:39.901 D 243] quickstart_rootfs.c 311: VENC_RequestIDR stream:0 VencChn:0 [DBG][2024/06/12/10:40:40:309][:601]WIFI[0] Get IP:192.168.3.97 [DBG][2024/06/12/10:40:40:327][:834]Get wifi station status 6 [20240612-10:40:40.417 D 225] stream_reader.c 1319: audio swtich OFF AUDIO_CTRL:56 [20240612-10:40:40.499 D 243] quickstart_rootfs.c 311: VENC_RequestIDR stream:1 VencChn:1 [DBG][2024/06/12/10:40:40:820][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:41:458][:1294]send wifi heartbeat---wifihbcnt[0][8][52] :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:40:43:327][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:43:439][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:44:454][:601]WIFI[0] Get IP:192.168.3.97 [DBG][2024/06/12/10:40:44:467][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:40:44:757][:1505]sleep status,pushvideo[1] clientnum[1] waitcount[0] record[0] [DBG][2024/06/12/10:40:45:347][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:46:457][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:46:809][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [DBG][2024/06/12/10:40:47:338][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:40:47:458][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [0 b4] [DBG][2024/06/12/10:40:47:477][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:40:48:378][:834]Get wifi station status 6 [20240612-10:40:48.867 D 356] kernel_manage.c 161: Got dev_name : mmcblk0 [DBG][2024/06/12/10:40:48:977][:169]sd capacity: total: 7784448 KB, used 4968 KB, free 7779480 KB [DBG][2024/06/12/10:40:49:460][:601]WIFI[0] Get IP:192.168.3.97 [DBG][2024/06/12/10:40:49:497][:834]Get wifi station status 6 [06-12 10:40:50 TUYA E][tuya_svc_upgrade.c:436] result null [DBG][2024/06/12/10:40:50:490][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:40:51:399][:735]WIFI Get Mode 2 :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:40:52:478][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:53:498][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:40:54:466][:601]WIFI[0] Get IP:192.168.3.97 [DBG][2024/06/12/10:40:54:957][:1505]sleep status,pushvideo[1] clientnum[1] waitcount[0] record[0] [DBG][2024/06/12/10:40:55:408][:834]Get wifi station status 6 [DBG][2024/06/12/10:40:56:408][:735]WIFI Get Mode 2 [DBG][2024/06/12/10:40:56:507][:1294]send wifi heartbeat---wifihbcnt[0][8][52] [DBG][2024/06/12/10:40:56:817][:1439]send mcu heartbeat-sleep(10)--[1] :::mcu_send_data_buffer 2136 cmd=[b4 0 1 0] :::mcu_send_data_buffer 2187 [0] [DBG][2024/06/12/10:40:57:093][:1600]mcu handle cmd : 0xb4 :::mcu_check_cmd_resend 2126 [b4 b4] :::main 898pfacinfo->stpowermode.mode_sleep_sta=0 [DBG][2024/06/12/10:40:58:417][:834]Get wifi station status 6 Connection closed.
