# Automatically-generated file. Do not edit!
-include ../makefile.init
RM := rm -rf
# All of the sources participating in the build are defined here
-include sources.mk
-include subdir.mk
-include vendor.mk
-include objects.mk
-include app.mk
-include components.mk
-include include.mk
-include libs.mk
-include ../makefile.defs
# Add inputs and outputs from these tool invocations to the build variables
LST += \
boot-.lst \
FLASH_IMAGE += \
SIZEDUMMY += \
sizedummy \
# All Target
all: tuyaos_zg_g_sensor.elf secondary-outputs
# Tool invocations
tuyaos_zg_g_sensor.elf: $(OBJS) $(USER_OBJS)
	-@echo 'Building target: $@'
	-@echo 'Invoking: TC32 C Linker'
	../../../tools/tc32/tc32/bin/tc32-elf-ld --gc-sections -L../../../libs/tuya_lib/sleep_device -L../../../libs/vendor_lib -T ../../../libs/vendor_lib/boot.link -o"tuyaos_zg_g_sensor.elf" $(OBJS) $(USER_OBJS) $(LIBS)
	-@echo 'Finished building target: $@'
	-@echo ' '
	$(MAKE) --no-print-directory post-build
boot-.lst: tuyaos_zg_g_sensor.elf
	-@echo 'Create Flash image (binary format)'
	../../../tools/tc32/tc32/bin/tc32-elf-objcopy tuyaos_zg_g_sensor.elf
	-@echo 'Finished building: $@'
	-@echo ' '
sizedummy: tuyaos_zg_g_sensor.elf
	-@echo 'Invoking: Print Size'
	../../../tools/tc32/tc32/bin/tc32-elf-size -t tuyaos_zg_g_sensor.elf
	-@echo ' '
# Other Targets
clean:
	-$(RM) $(FLASH_IMAGE)$(ELFS)$(OBJS)$(LST)$(SIZEDUMMY) tuyaos_zg_g_sensor.elf
	-@echo ' '
post-build:
	-@echo ' '
secondary-outputs: $(LST) $(FLASH_IMAGE) $(SIZEDUMMY)
.PHONY: all clean dependents
.SECONDARY: post-build
-include ../makefile.targets
