    Phyplus Microelectronics Limited confidential and proprietary.
    All rights reserved.
    IMPORTANT: All rights of this software belong to Phyplus Microelectronics
    Limited ("Phyplus"). Your use of this Software is limited to those
    specific rights granted under  the terms of the business contract, the
    confidential agreement, the non-disclosure agreement and any other forms
    of agreements as a customer or a partner of Phyplus. You may not use this
    Software unless you agree to abide by the terms of these agreements.
    You acknowledge that the Software may not be modified, copied,
    distributed or disclosed unless embedded on a Phyplus Bluetooth Low Energy
    (BLE) integrated circuit, either as a product or is integrated into your
    products.  Other than for the aforementioned purposes, you may not use,
    reproduce, copy, prepare derivative works of, modify, distribute, perform,
    display or sell this Software and/or its documentation for any purposes.
    YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
    PROVIDED AS IS WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
    INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
    NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
    PHYPLUS OR ITS SUBSIDIARIES BE LIABLE OR OBLIGATED UNDER CONTRACT,
    NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
    LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
    INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
    OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
    OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
    (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
#include "rom_sym_def.h"
#include "types.h"
#include "ll_sleep.h"
#include "bus_dev.h"
#include "string.h"
#include "pwrmgr.h"
#include "error.h"
#include "gpio.h"
#include "log.h"
#include "clock.h"
#include "jump_function.h"
#include "flash.h"
#if(CFG_SLEEP_MODE == PWR_MODE_NO_SLEEP)
    static uint8_t mPwrMode = PWR_MODE_NO_SLEEP;
    #elif(CFG_SLEEP_MODE == PWR_MODE_SLEEP)
    static uint8_t mPwrMode = PWR_MODE_SLEEP;
    #elif(CFG_SLEEP_MODE == PWR_MODE_PWROFF_NO_SLEEP)
    static uint8_t mPwrMode = PWR_MODE_PWROFF_NO_SLEEP;
    #error "CFG_SLEEP_MODE define incorrect"
//#define CFG_FLASH_ENABLE_DEEP_SLEEP
#ifdef CFG_FLASH_ENABLE_DEEP_SLEEP
    #warning "CONFIG FLASH ENABLE DEEP SLEEP !!!"
//#define CFG_SRAM_RETENTION_LOW_CURRENT_LDO_ENABLE
#ifdef CFG_SRAM_RETENTION_LOW_CURRENT_LDO_ENABLE
    #warning "ENABLE LOW CURRENT LDO FOR SRAM RETENTION !!!"
typedef struct _pwrmgr_Context_t
    MODULE_e     moudle_id;
    bool         lock;
    pwrmgr_Hdl_t sleep_handler;
    pwrmgr_Hdl_t wakeup_handler;
} pwrmgr_Ctx_t;
static pwrmgr_Ctx_t mCtx[HAL_PWRMGR_TASK_MAX_NUM];
static uint32_t sramRet_config;
static uint32_t s_config_swClk0 = DEF_CLKG_CONFIG_0;
uint32_t s_config_swClk1 = DEF_CLKG_CONFIG_1;
uint32_t s_gpio_wakeup_src_group1,s_gpio_wakeup_src_group2;
    osal_idle_task will be call
__ATTR_SECTION_SRAM__ void osal_idle_task (void)
    AP_WDT_FEED;
		extern int app_get_low_power_state(void);
		if(app_get_low_power_state()){
			osal_pwrmgr_powerconserve0();
		}else{
			void hal_clock_time_run(void);
			hal_clock_time_run();
			extern void tal_framework_loop(void);
			tal_framework_loop();
int hal_pwrmgr_init(void)
    memset(&mCtx, 0, sizeof(mCtx));
    switch(mPwrMode)
    case PWR_MODE_NO_SLEEP:
    case PWR_MODE_PWROFF_NO_SLEEP:
        disableSleep();
    case PWR_MODE_SLEEP:
        enableSleep();
        if wdt enable, set osal idle task to feed wdt before powerconserve
    if(AP_WDT_ENABLE_STATE)
        JUMP_FUNCTION(OSAL_POWER_CONSERVE)=(uint32_t)&osal_idle_task;
    return PPlus_SUCCESS;
int hal_pwrmgr_clk_gate_config(MODULE_e module)
    if (module < MOD_CP_CPU)
        s_config_swClk0 |= BIT(module);
    else if (module < MOD_PCLK_CACHE)
        s_config_swClk1 |= BIT(module - MOD_CP_CPU);
bool hal_pwrmgr_is_lock(MODULE_e mod)
    int i;
    int ret = FALSE;
    if(mPwrMode == PWR_MODE_NO_SLEEP || mPwrMode == PWR_MODE_PWROFF_NO_SLEEP )
        return TRUE;
    HAL_ENTER_CRITICAL_SECTION();
    for(i = 0; i< HAL_PWRMGR_TASK_MAX_NUM; i++)
        if(mCtx[i].moudle_id == MOD_NONE)
        if(mCtx[i].moudle_id == mod)
            if(mCtx[i].lock == TRUE)
                ret = TRUE;
    HAL_EXIT_CRITICAL_SECTION();
int hal_pwrmgr_lock(MODULE_e mod)
    int i;
    int ret = PPlus_ERR_NOT_REGISTED;
        disableSleep();
            mCtx[i].lock = TRUE;
            disableSleep();
            //LOG("LOCK\n");
            ret = PPlus_SUCCESS;
int hal_pwrmgr_unlock(MODULE_e mod)
    int i, cnt = 0;
        disableSleep();
            mCtx[i].lock = FALSE;
        if(mCtx[i].lock)
            cnt ++;
    if(cnt == 0)
        enableSleep();
        disableSleep();
    //LOG("sleep mode:%d\n", isSleepAllow());
int hal_pwrmgr_register(MODULE_e mod, pwrmgr_Hdl_t sleepHandle, pwrmgr_Hdl_t wakeupHandle)
    int i;
    pwrmgr_Ctx_t* pctx = NULL;
            return PPlus_ERR_INVALID_STATE;
            pctx = &mCtx[i];
    if(pctx == NULL)
        return PPlus_ERR_NO_MEM;
    pctx->lock = FALSE;
    pctx->moudle_id = mod;
    pctx->sleep_handler = sleepHandle;
    pctx->wakeup_handler = wakeupHandle;
int hal_pwrmgr_unregister(MODULE_e mod)
    int i;
            pctx = &mCtx[i];
            return PPlus_ERR_NOT_REGISTED;
    if(pctx == NULL)
    memcpy(pctx, pctx+1, sizeof(pwrmgr_Ctx_t)*(HAL_PWRMGR_TASK_MAX_NUM-i-1));
int __attribute__((used)) hal_pwrmgr_wakeup_process(void)
    int i;
    extern void spif_release_deep_sleep(void);
    spif_release_deep_sleep();
    WaitRTCCount(8);
    AP_PCR->SW_CLK  = s_config_swClk0;
    AP_PCR->SW_CLK1 = s_config_swClk1|0x01;//force set M0 CPU
    s_gpio_wakeup_src_group1 = AP_AON->GPIO_WAKEUP_SRC[0];
    s_gpio_wakeup_src_group2 = AP_AON->GPIO_WAKEUP_SRC[1];
    //restore BB TIMER IRQ_PRIO
    NVIC_SetPriority((IRQn_Type)BB_IRQn,    IRQ_PRIO_REALTIME);
    NVIC_SetPriority((IRQn_Type)TIM1_IRQn,  IRQ_PRIO_HIGH);     //ll_EVT
    NVIC_SetPriority((IRQn_Type)TIM2_IRQn,  IRQ_PRIO_HIGH);     //OSAL_TICK
    NVIC_SetPriority((IRQn_Type)TIM4_IRQn,  IRQ_PRIO_HIGH);     //LL_EXA_ADV
        if(mCtx[i].wakeup_handler)
            mCtx[i].wakeup_handler();
int __attribute__((used)) hal_pwrmgr_sleep_process(void)
    int i;
    //20181013 ZQ :
    hal_pwrmgr_RAM_retention_set();
    //LOG("Sleep\n");
            //return PPlus_ERR_NOT_REGISTED;
            //found last module
        if(mCtx[i].sleep_handler)
            mCtx[i].sleep_handler();
    extern void spif_set_deep_sleep(void);
    spif_set_deep_sleep();
    @fn          hal_pwrmgr_RAM_retention
    @brief       This function process for enable retention sram
    input parameters
    @param       uint32_t sram: sram bit map
    output parameters
    @param       None.
    @return      refer error.h.
int hal_pwrmgr_RAM_retention(uint32_t sram)
    if(sram & 0xffffffe0)
        sramRet_config = 0x00;
        return PPlus_ERR_INVALID_PARAM;
    sramRet_config = sram;
int hal_pwrmgr_RAM_retention_clr(void)
    subWriteReg(0x4000f01c,21,17,0);
int hal_pwrmgr_RAM_retention_set(void)
    subWriteReg(0x4000f01c,21,17,sramRet_config);
int hal_pwrmgr_LowCurrentLdo_enable(void)
    uint32_t retention_flag;
    hal_flash_read(0x1100181c,(uint8_t*)&retention_flag,4);
    if(retention_flag == 0xffffffff)
        subWriteReg(0x4000f014,26,26, 1);
    return PPlus_ERR_FORBIDDEN;
int hal_pwrmgr_LowCurrentLdo_disable(void)
    subWriteReg(0x4000f014,26,26, 0);
extern void gpio_wakeup_set(gpio_pin_e pin, gpio_polarity_e type);
extern void gpio_pull_set(gpio_pin_e pin, gpio_pupd_e type);
void hal_pwrmgr_poweroff(pwroff_cfg_t* pcfg, uint8_t wakeup_pin_num)
    subWriteReg(0x4000f01c,6,6,0x00);   //disable software control
    //(void)(wakeup_pin_num);
    for(uint8_t i = 0; i < wakeup_pin_num; i++ )
        if(pcfg[i].type==POL_FALLING)
            gpio_pull_set(pcfg[i].pin,GPIO_PULL_UP_S);
            gpio_pull_set(pcfg[i].pin,GPIO_PULL_DOWN);
        gpio_wakeup_set(pcfg[i].pin, pcfg[i].type);
        config reset casue as RSTC_OFF_MODE
        reset path walkaround dwc
    AP_AON->SLEEP_R[0] = 2;
    write_reg(0x4000f000,0x5a5aa5a5);
    while(1);
__ATTR_SECTION_SRAM__ void hal_pwrmgr_enter_sleep_rtc_reset(uint32_t sleepRtcTick)
    config_RTC(sleepRtcTick);
    // clear sram retention
    hal_pwrmgr_RAM_retention_clr();
        config reset casue as RSTC_WARM_NDWC
    AP_AON->SLEEP_R[0]=4;
    enter_sleep_off_mode(SYSTEM_SLEEP_MODE);
    while(1) {};
#define STANDBY_WAIT_MS(a)  WaitRTCCount((a)<<5) // 32us * 32  around 1ms
__attribute__((section("_section_standby_code_"))) pwroff_cfg_t s_pwroff_cfg[WAKEUP_PIN_MAX];
__attribute__((section("_section_standby_code_"))) __attribute__((used)) uint8 pwroff_register_number=0;
__attribute__((section("_section_standby_code_"))) void wakeupProcess_standby(void)
    subWriteReg(0x4000f014,29,27,0x07);
    STANDBY_WAIT_MS(5);
    STANDBY_WAIT_MS(15);
    uint32_t volatile cnt=0;
    uint8_t volatile find_flag=0;
    uint8 pin_n=0;
    extern bool gpio_read(gpio_pin_e pin);
    for(pin_n=0; pin_n<pwroff_register_number; pin_n++)
        if((s_pwroff_cfg[pin_n].pin == P2) || (s_pwroff_cfg[pin_n].pin == P3))
            hal_gpio_pin2pin3_control(s_pwroff_cfg[pin_n].pin,1);
        if(gpio_read(s_pwroff_cfg[pin_n].pin)==s_pwroff_cfg[pin_n].type)
            find_flag=1;
    while(1)
        if(gpio_read(s_pwroff_cfg[pin_n].pin)==s_pwroff_cfg[pin_n].type&&find_flag==1)
            cnt++;
            STANDBY_WAIT_MS(32);
            if(cnt>(s_pwroff_cfg[pin_n].on_time>>5))
                write_reg(0x4000f030, 0x01);
            hal_pwrmgr_enter_standby(&s_pwroff_cfg[0],pwroff_register_number);
    set_sleep_flag(0);
    AP_AON->SLEEP_R[0] = 4;
    AP_PCR->SW_RESET1 = 0;
    while(1);
__attribute__((section("_section_standby_code_"))) void hal_pwrmgr_enter_standby(pwroff_cfg_t* pcfg,uint8_t wakeup_pin_num)
    uint8_t i = 0;
    if(wakeup_pin_num>WAKEUP_PIN_MAX)
        wakeup_pin_num=WAKEUP_PIN_MAX;
    for(i = 0; i < wakeup_pin_num; i++)
        osal_memcpy(&s_pwroff_cfg[i],&(pcfg[i]),sizeof(pwroff_cfg_t));
        pwroff_register_number++;
    JUMP_FUNCTION(WAKEUP_PROCESS)=   (uint32_t)&wakeupProcess_standby;
    WaitRTCCount(50);
    subWriteReg(0x4000f014,29,27,0);
    set_sleep_flag(1);
    subWriteReg(0x4000f01c,21,17,RET_SRAM0);
    while(1);
