    Phyplus Microelectronics Limited confidential and proprietary.
    All rights reserved.
    IMPORTANT: All rights of this software belong to Phyplus Microelectronics
    Limited ("Phyplus"). Your use of this Software is limited to those
    specific rights granted under  the terms of the business contract, the
    confidential agreement, the non-disclosure agreement and any other forms
    of agreements as a customer or a partner of Phyplus. You may not use this
    Software unless you agree to abide by the terms of these agreements.
    You acknowledge that the Software may not be modified, copied,
    distributed or disclosed unless embedded on a Phyplus Bluetooth Low Energy
    (BLE) integrated circuit, either as a product or is integrated into your
    products.  Other than for the aforementioned purposes, you may not use,
    reproduce, copy, prepare derivative works of, modify, distribute, perform,
    display or sell this Software and/or its documentation for any purposes.
    YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
    PROVIDED AS IS WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
    INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
    NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
    PHYPLUS OR ITS SUBSIDIARIES BE LIABLE OR OBLIGATED UNDER CONTRACT,
    NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
    LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
    INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
    OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
    OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
    (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
    Filename:       phy_plus_phy.h
    Revised:
    Revision:
    Description:    This file contains the phyplus phy sample application
                  definitions and prototypes.
#ifndef PHYPLUSPHY_H
#define PHYPLUSPHY_H
extern "C"
    INCLUDES
    CONSTANTS
// PHY PLUS PHY Task Events
#define PPP_PERIODIC_TX_EVT         0x0001
#define PPP_PERIODIC_RX_EVT         0x0002
#define PPP_TX_DONE_EVT             0x0004
#define PPP_RX_DONE_EVT             0x0008
#define PPP_RX_DATA_PROCESS_EVT     0x0020
#define PPP_TY_BEACON_EVT           0x0040
#define PPP_TY_AUTHORIZE_EVT        0x0080
#define PPP_RTC_TEST_EVT            0x0100
#define PPP_5MS											0x0400
#define PPP_SLEEP_WAKE_UP						0x0800
    MACROS
    FUNCTIONS
    Task Initialization for the PHYPLUS PHY Application
extern void PhyPlusPhy_Init( unsigned char task_id );
    Task Event Processor for the PHYPLUS PHY Application
extern unsigned short PhyPlusPhy_ProcessEvent( unsigned char task_id, unsigned short events );
extern void phy_tx_buf_updata(unsigned char* txPayload,unsigned char dlen);
#endif /* PHYPLUSPHY_H */
