* @file tuya_sdk_callback.c
* @brief Common process - adapter the flash api
* @date 2021-10-22
#include "tuya_tools.h"
#include "tkl_gpio.h"
#include "tkl_uart.h"
#include "tkl_system.h"
#include "tkl_memory.h"
#include "tkl_network_manager.h"
#include "tal_gpio.h"
#include "tal_uart.h"
#include "tal_flash.h"
#include "tal_nv_flash.h"
#include "tal_sw_timer.h"
#include "tal_zcl_group.h"
#include "tal_zcl_scene.h"
#include "tal_time_sync.h"
#include "tal_heartbeat.h"
#include "tal_data_send.h"
#include "tal_network_mgr.h"
#include "tal_zcl_identify.h"
#include "tal_data_receive.h"
#include "tal_attribute_rw.h"
#include "tal_firmware_cfg.h"
#include "tal_reset_factory.h"
#include "tal_zll_commissioning.h"
#include "tal_endpoint_register.h"
#include "app_common.h"
#include "app_config.h"
#include "tlPrintf.h"
#include "tuya_sdk_callback.h"
#include "app_battery.h"
#include "app_sensor.h"
#include "app_led.h"
#define DEVICE_TYPE_LP		1	//0:router 1:低功耗
//mfg test flag---这里我们没用到
BOOL_T  mf_test_doing_flag = FALSE;
BOOL_T  sys_init_finish_flag = FALSE;
TIMER_ID etimer_key_scan;
TIMER_ID etimer_blink_sw;
TIMER_ID etimer_join_start_delay;
TIMER_ID etimer_clr_rst_cnt_delay;
TIMER_ID etimer_save_data_delay;
TIMER_ID etimer_mf_blink;
TIMER_ID etimer_power_on_sync;
TIMER_ID etimer_join_end_sync;
extern TIMER_ID etimer_connect_sync;
TAL_ZG_NWK_STATUS_E g_connect_status = TAL_ZG_NWK_IDLE;
#ifdef ENABLE_TAL_LOG
const char *g_net_st_str_test[] = {
    "TAL_ZG_NWK_IDLE",            ///< inner using
    "TAL_ZG_NWK_POWER_ON_LEAVE",  ///< power on and device is not joined network
    "TAL_ZG_NWK_POWER_ON_ONLINE", ///< power on and device is already joined network
    "TAL_ZG_NWK_JOIN_START",      ///< start joining network
    "TAL_ZG_NWK_JOIN_TIMEOUT",    ///< network joining timeout
    "TAL_ZG_NWK_JOIN_OK",         ///< network joined success
    "TAL_ZG_NWK_LOST",            ///< network lost, lost parent
    "TAL_ZG_NWK_REJOIN_OK",       ///< network rejoin ok
    "TAL_ZG_NWK_REMOTE_LEAVE",    ///< remove device by remote device
    "TAL_ZG_NWK_LOCAL_LEAVE",     ///< remove device by local
    "TAL_ZG_NWK_MF_TEST_LEAVE",   ///< remove device by PC test tools
    "TAL_ZG_NWK_ZLL_JOINED",      ///< network joined zll network
    "TAL_ZG_NWK_ZLL_LEAVE",       ///< remove device Zll Reset To Factory New
#ifndef GET_ARRAY_LEN
#define GET_ARRAY_LEN(x) (sizeof(x) / sizeof(x[0]))
#define PRIVATE_ATTR_LIST \
	{0x0000, ATTR_INT32S_ATTRIBUTE_TYPE, 4, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp101 x轴加速度 */\
	{0x0001, ATTR_INT32S_ATTRIBUTE_TYPE, 4, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp102 y轴加速度*/\
	{0x0002, ATTR_INT32S_ATTRIBUTE_TYPE, 4, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp103 z轴加速度 */\
	{0x0003, ATTR_INT32S_ATTRIBUTE_TYPE, 4, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp104 x轴加速度阈值 */\
	{0x0004, ATTR_INT32S_ATTRIBUTE_TYPE, 4, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp105 y轴加速度阈值 */\
	{0x0005, ATTR_INT32S_ATTRIBUTE_TYPE, 4, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp106 z轴加速度阈值 */\
	{0x0006, ATTR_INT8U_ATTRIBUTE_TYPE,  1, ATTR_MASK_READABLE, 0, (UINT8_T*)0x32 }, 	/* dp107 加速度阈值补偿 */\
	{0x0007, ATTR_INT32S_ATTRIBUTE_TYPE, 4, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp108 噪声阈值 */\
	{0x0008, ATTR_INT16S_ATTRIBUTE_TYPE, 2, ATTR_MASK_READABLE, 0, (UINT8_T*)0x18 }, 	/* dp109 当前温度 */\
	{0x0009, ATTR_INT16S_ATTRIBUTE_TYPE, 2, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp110 温度补偿 */\
	{0x000a, ATTR_ENUM8_ATTRIBUTE_TYPE,  1, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp111 传感器状态 */\
	{0x000b, ATTR_INT16S_ATTRIBUTE_TYPE, 2, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp112 角度上报阈值 */\
	{0x000c, ATTR_INT16S_ATTRIBUTE_TYPE, 2, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp113 x角度值 */\
	{0x000d, ATTR_ENUM8_ATTRIBUTE_TYPE,  1, ATTR_MASK_READABLE, 0, (UINT8_T*)0x01 }, 	/* dp114 工作模式 */\
	{0x000e, ATTR_INT8U_ATTRIBUTE_TYPE,  1, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp115 电量 */\
	{0x000f, ATTR_INT16S_ATTRIBUTE_TYPE, 2, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp116 y角度值 */\
	{0x0010, ATTR_INT16S_ATTRIBUTE_TYPE, 2, ATTR_MASK_READABLE, 0, (UINT8_T*)0x00 }, 	/* dp117 z角度值 */\
    {0xFFFD, ATTR_INT16U_ATTRIBUTE_TYPE, 2, ATTR_MASK_READABLE, 0, (UINT8_T *)0x0001},
// application attribute
const TAL_ATTR_T g_private_attr_list[] = {
	PRIVATE_ATTR_LIST};
#define DEF_CLUSTER_PRIVATE_CLUSTER_ID(a) \
    { CLUSTER_PRIVATE_TUYA_CLUSTER_ID, (TAL_ATTR_T *)&((a)[0]), GET_ARRAY_LEN((a)) },
// server cluster
const TAL_CLUSTER_T app_server_cluster_list[] = {
   	DEF_CLUSTER_PRIVATE_CLUSTER_ID(g_private_attr_list)
#define SERVER_CLUSTER_NUM GET_ARRAY_LEN(app_server_cluster_list)
TAL_ENDPOINT_T dev_endpoint_desc[] = {
    {1, ZHA_PROFILE_ID, ZG_DEVICE_ID_SMART_PLUG, SERVER_CLUSTER_NUM, (TAL_CLUSTER_T *)&app_server_cluster_list[0], 0, NULL},
STATIC VOID_T __power_on_event(void)  //(TIMER_ID timer_id, VOID_T *arg)
    TAL_PR_DEBUG("into __power_on_event");
    dev_power_on_indicate();
    //app_gpio_preheat_init();
STATIC VOID_T __network_info_print(VOID_T)
    TKL_NWK_BASIC_INFO_T nwk_info;
    tkl_zg_nwk_base_info_get(&nwk_info);
    TAL_PR_DEBUG("power_on_online, pan-id=0x%x ch=%d addr=%x tx_power=%d", \
                    nwk_info.panid, \
                    nwk_info.radio_channel, \
                    nwk_info.nwk_addr, 
                    nwk_info.radio_power);
VOID_T __tuya_pre_sleep_cb(VOID_T)
    TAL_PR_DEBUG("pre_sleep_cb!!!\r\n");
VOID_T __tuya_post_sleep_cb(VOID_T)
    TAL_PR_DEBUG("post_sleep_cb!!!\r\n");
/** 开启配网
 * @note join start delay timer hander, join now 
 * @param[in]  nones
 * @param[out] none
STATIC VOID_T __app_network_join_start_delay_cb(TIMER_ID timer_id, VOID_T *arg)
    tal_zg_join_start(ZIGBEE_JOIN_MAX_TIMEOUT);
 * @brief zigbee node init
 * @return VOID_T 
STATIC VOID_T __app_router_node_init(VOID_T)
    TAL_ZG_NODE_CFG_T node_config = {
        .node_type = ZG_ROUTER,
        .tx_power = 11,
        .scan_interval = 0,
        .scan_duration = ZG_SCAN_DURATION_3,
    tal_zg_node_config(&node_config);
 * @brief register router or sleep device
STATIC VOID_T __app_sleep_device_node_init(VOID_T)
 	// sleep end device node init
         .node_type = ZG_SLEEPY_END_DEVICE,
         .tx_power = 11, //10,
         .scan_interval = 100,
         .config.sleep_ed_cfg.poll_config.forever_flag = 0,
         .config.sleep_ed_cfg.poll_config.fast_swicth_parent = 0,
         .config.sleep_ed_cfg.poll_config.interval_ms = 250,
         .config.sleep_ed_cfg.poll_config.max_failed_times = 10,
         .config.sleep_ed_cfg.poll_config.duration_after_data_ms = 1000,
         .config.sleep_ed_cfg.poll_config.duration_after_join_ms = 60000,
         .config.sleep_ed_cfg.poll_config.duration_after_rejoin_ms = 15000,
         .config.sleep_ed_cfg.rejoin_config.power_on_active = 1,
         .config.sleep_ed_cfg.rejoin_config.send_data_active = 1,
         .config.sleep_ed_cfg.rejoin_config.attempts = 3,
         .config.sleep_ed_cfg.rejoin_config.interval = 3000,
    //config zigbee node
 * @brief Generally used for peripheral initialization
#if (ENABLE_TAL_LOG == 1)
    tal_log_create_manage_and_init(TAL_LOG_LEVEL_DEBUG, 128, Tl_printf);
	tal_mf_test_disable_beacon_test();
    TAL_PR_DEBUG("/*********first init, reason[%d]*********/", tal_system_get_reset_reason(NULL));
 * @brief Generally used for register zigbee device
    //initialize firmware infomation
    TAL_PR_DEBUG("Application version:%d", APP_FIRMWARE_VER);
    //register zigbee endpoint
    tal_zg_endpoint_register(dev_endpoint_desc, GET_ARRAY_LEN(dev_endpoint_desc));
    TAL_PR_DEBUG("identify init ret:%d", tal_zg_identify_init());
    //zigbee node configuration
#if DEVICE_TYPE_LP	== 0
    __app_router_node_init();
	__app_sleep_device_node_init();
    //zigbee joining network configuration
    TAL_ZG_JOIN_CFG_T join_config = {
        .auto_join_power_on_flag = FALSE,//defalut power on start join or not
        .auto_join_remote_leave_flag = TRUE,//default start join or not when receivew remote leave request
        .join_timeout = ZIGBEE_JOIN_MAX_TIMEOUT,//join timeout times 120s
    tal_zg_join_config(&join_config);
    //tal_time_sync_period_set(60 * 1000);
	//disable beacon test
	//tal_mf_test_disable_beacon_test();
    //disable network recovery
	tal_zg_nwk_recovery_disable(TRUE);
    TUYA_SLEEP_CB_T  sleep_cb = {
        .pre_sleep_cb = __tuya_pre_sleep_cb,
        .post_wakeup_cb = __tuya_post_sleep_cb,
    tal_cpu_sleep_callback_register(&sleep_cb);
    TAL_PR_DEBUG("/*********1.0.0 second init*********/");
 * @brief Generally used for initialization before manufacturing test
    TAL_PR_DEBUG("/*********third init*********/");
    OPERATE_RET ret;
	//creat software timer
    tal_sw_timer_create(app_button_scan_cb, NULL, &etimer_key_scan);
    tal_sw_timer_create(__app_network_join_start_delay_cb, NULL, &etimer_join_start_delay);
	app_led_init();
    app_button_init();
    ret = lis2dw12_init();
    if (ret != OPRT_OK)
        TAL_PR_DEBUG("sensor init ERROR");
		TAL_PR_DEBUG("sensor init Successful...");
 * @brief Generally used for initialization after manufacturing test
    UINT8_T version;
    tal_zg_read_attribute(TUYA_PRIMARY_ENDPOINT,
                          CLUSTER_BASIC_CLUSTER_ID,
                          ATTR_APPLICATION_VERSION_ATTRIBUTE_ID,
                          (VOID_T *)&version,
                          sizeof(version));
	__tuya_battery_init();
	dev_dpid_init();
	// tal_heartbeat_period_set(30*000);
    // tal_heartbeat_type_set(HEARTBEAT_APP_VERSION);
	sys_init_finish_flag = TRUE;
	__power_on_event();
    TAL_PR_DEBUG("/*********last init %d*********/", version);
 * @brief user-defined callback interface in main loop.do not block!!!
 * @brief heartbeat report callback
 * NOTE: you can rewrite this API in application layer
 * @param[in]   status: heartbeat report status
VOID_T tal_heartbeat_report_callback(TAL_HEARTBEAT_TYPE_E type)
    TAL_PR_DEBUG("heartbeat: %d", type);
 * @brief general message receive callback
 * @param msg 
 * @return TAL_MSG_RET_E 
TAL_MSG_RET_E tal_zcl_general_msg_recv_callback(TAL_ZCL_MSG_T *msg)
    //TAL_PR_DEBUG("app gen msg cb: cluster 0x%02x, cmd %d", msg->cluster, msg->command);
    return ZCL_MSG_RET_SUCCESS;
 * @brief specific message receive callback
 * @param msg 
TAL_MSG_RET_E tal_zcl_specific_msg_recv_callback(TAL_ZCL_MSG_T *msg)
    TAL_PR_DEBUG("app spec msg cb: cluster 0x%02x, cmd 0x%02x", msg->cluster, msg->command);
    ZIGBEE_CMD_T app_cmd_type = ZIGBEE_CMD_SINGLE;
    if (msg->mode == ZG_UNICAST_MODE)
        TAL_PR_DEBUG("receive single message");
        app_cmd_type = ZIGBEE_CMD_GROUP;
        TAL_PR_DEBUG("receive group message");
    switch (msg->cluster)
    case CLUSTER_PRIVATE_TUYA_CLUSTER_ID:
    	g_connect_status = TAL_ZG_NWK_JOIN_OK;
    	TAL_PR_DEBUG("==========recv private cluster=========");
		custom_obj_t custom_data = {0};
		custom_data.seq = msg->payload[0]*256 + msg->payload[1];
		custom_data.dpid = msg->payload[2];
		custom_data.type = msg->payload[3];
		custom_data.len = msg->payload[4]*256 + msg->payload[5];
		for(int i = custom_data.len - 1; i >= 0 ; i--)
			custom_data.value |= (msg->payload[6+i]<<(8*(custom_data.len - i - 1)));
		TAL_PR_DEBUG("seq_num = %d", custom_data.seq);
		TAL_PR_DEBUG("dpid    = %d", custom_data.dpid);
		TAL_PR_DEBUG("type    = %d", custom_data.type);
		TAL_PR_DEBUG("len     = %d", custom_data.len);
		TAL_PR_DEBUG("value   = %d", custom_data.value);
		TAL_PR_DEBUG("recv: %02x %02x %02x %02x %02x %02x %02x %02x %02x %02x", \
				msg->payload[0], msg->payload[1], msg->payload[2], msg->payload[3], msg->payload[4], msg->payload[5], \
				msg->payload[6], msg->payload[7], msg->payload[8], msg->payload[9]);
		switch(msg->command)
			case 0x04:
				dev_dpid_msg_rsp(QOS_1, 0, &(msg->payload[0]), msg->length);
				sensor_private_handler(&custom_data);
	case CLUSTER_GREEN_POWER_CLUSTER_ID:
    	TAL_PR_DEBUG("==========recv unknow cluster[%04x]=========", msg->cluster);
 * @brief add group callback
 * @param[in]   ep_id:    endpoint id
 * @param[in]   group_id: group id
 * @return  VOID_T
VOID_T tal_zg_add_group_callback(UINT8_T ep_id, UINT16_T group_id)
    TAL_PR_DEBUG("ep id: %d,group id: %d", ep_id, group_id);
 * @brief view group callback
 * @return  VOID_T
VOID_T tal_zg_view_group_callback(UINT8_T ep_id, UINT16_T group_id)
 * @brief remove group callback
 * @return  VOID_T
VOID_T tal_zg_remove_group_callback(UINT8_T ep_id, UINT16_T group_id)
 * @brief zigbee network network change callback(user can rewrite this API)
 * @param[in]   status: network status
 * @return VOID_T
VOID_T tal_zg_nwk_status_changed_callback(TAL_ZG_NWK_STATUS_E status)
	g_connect_status = status;
    switch (status)
    case TAL_ZG_NWK_POWER_ON_LEAVE:
        TAL_PR_DEBUG("power_on_leave---");
    case TAL_ZG_NWK_POWER_ON_ONLINE:
        TAL_PR_DEBUG("power_on_online---");
		tal_sw_timer_start(etimer_connect_sync, 3000, TAL_TIMER_CYCLE);
		__network_info_print();
		app_battery_start();
    case TAL_ZG_NWK_JOIN_START:
        TAL_PR_DEBUG("nwk_join_start---");
		dev_start_join_indicate(TRUE);
    case TAL_ZG_NWK_JOIN_OK:
        TAL_PR_DEBUG("nwk_join_ok---");
     	dev_join_success_indicate();
    case TAL_ZG_NWK_REJOIN_OK:
        TAL_PR_DEBUG("nwk_rejoin_ok---");
    case TAL_ZG_NWK_JOIN_TIMEOUT:
        TAL_PR_DEBUG("nwk_join_timeout---");
		dev_start_join_indicate(FALSE);
    case TAL_ZG_NWK_LOST:
        TAL_PR_DEBUG("nwk_lost---");
    case TAL_ZG_NWK_REMOTE_LEAVE:
        TAL_PR_DEBUG("nwk_remote_leave---");
    case TAL_ZG_NWK_LOCAL_LEAVE:
        TAL_PR_DEBUG("nwk_local_leave---");
    case TAL_ZG_NWK_MF_TEST_LEAVE:
        TAL_PR_DEBUG("nwk_mf_test_leave---");
VOID_T tal_beacon_mf_test_callback(VOID_T)
    TAL_PR_DEBUG("enter beacon test\n");
 * @brief reset factory default callback
 * @param[in]   type: reset factory type
 * @return  VOID_T
VOID_T tal_zg_reset_factory_default_callback(TAL_RESET_TYPE_T type)
    TAL_PR_DEBUG("receive reset to factory default cmd %d", type);
VOID_T tal_zll_target_commissioning_complete_callback(TAL_ZLL_TARGET_STATUS_E status)
    TAL_PR_DEBUG("zll target status %d",status);
VOID_T tal_time_sync_complete_callback(BOOL_T status, UINT_T time_sec)
#include "tkl_platform_types.h"
BOOL_T app_print_get_cfg(UINT8_T *print_type, UINT8_T *disable_irq, GPIO_PORT_PIN_T *gpio)
    gpio->port = PORT_C;
    gpio->pin = PIN_2;
    *print_type = 0;
    *disable_irq = 1;
#ifdef UART_PRINTF_MODE
    return 1;
