 * @file tuya_app_main.c
 * @brief tuya_app_main module is used to
 * @date 2022-10-28
#include "tuya_iot_wifi_api.h"
#include "tuya_ws_db.h"
#include "gw_intf.h"
#include "tal_wifi.h"
#include "tal_uart.h"
#include "mf_test.h"
#if defined(ENABLE_LWIP) && (ENABLE_LWIP == 1)
#include "lwip_init.h"
#include "dp_process.h"
#include "app_key.h"
#include "app_led.h"
#include "tuya_uf_db.h"
#include "uni_log.h"
//#define PID "u9xxv0wjpl4ssfz7"
#define PID "jk6iyohq6tftkxfo"
#define USE_DEFAULT_AUTH
/* The registration code here does not work, you need to apply for a new one.
 * https://developer.tuya.com/cn/docs/iot/lisence-management?id=Kb4qlem97idl0
 //#define UUID "uuid2cbe12e89181b55d"
 //#define AUTHKEY "DY75JFUH1Wx5gRmf2xVFZY64EJBpaaJB"
#ifndef USER_SW_VER
#define USER_SW_VER "1.2.8"
/* network button, LED pin */
#define KEY_PIN TUYA_GPIO_NUM_3
#define LED_PIN TUYA_GPIO_NUM_2
/* app thread handle */
STATIC THREAD_HANDLE ty_app_thread = NULL;
OPERATE_RET op_ret = OPRT_OK;
INT_T i;
BYTE_T *out_value = NULL;
UINT_T len1 = 0;
* @brief firmware download content process callback
* @param[in] fw: firmware info
* @param[in] total_len: firmware total size
* @param[in] offset: offset of this download package
* @param[in] data && len: this download package
* @param[out] remain_len: the size left to process in next cb
* @param[in] pri_data: private data
* @return OPRT_OK: success  Other: fail
STATIC OPERATE_RET get_file_data_cb(IN CONST FW_UG_S *fw, IN CONST UINT_T total_len, IN CONST UINT_T offset,
                                     IN CONST BYTE_T *data, IN CONST UINT_T len, OUT UINT_T *remain_len, IN PVOID_T
pri_data)
    UINT_T i=0;
    TAL_PR_DEBUG("-------------start-------------------");
    TAL_PR_DEBUG("channel:%d", fw->tp);
    TAL_PR_DEBUG("remian len:%d", *remain_len);
    TAL_PR_DEBUG("totle len: %d, len:%d, offset:%d, data:", total_len, len, offset);
    // for (i=0; i<len; i++) {
    //     TAL_PR_DEBUG_RAW("0x%02x ", data[i]);
    TAL_PR_DEBUG("-------------end-------------------");
    op_ret = uf_db_user_param_write(data, (sizeof(data)));
    if(OPRT_OK != op_ret) {
        //TAL_PR_ERR("err<%d>, write fail", op_ret);
    //TAL_PR_NOTICE("uf db write data:");
    for (i=0; i<sizeof(data)/sizeof(data[0]); i++) {
        //TAL_PR_DEBUG_RAW("0x%02x ", data[i]);
    //TAL_PR_DEBUG_RAW("\r\n\r\n");
    //read data
    op_ret = uf_db_user_param_read(&out_value, &len1);
        //TAL_PR_ERR("err<%d>, read fail!", op_ret);
        //TAL_PR_DEBUG("read len %d", len1);
        for ( i = 0; i < len1; i++) {
            //TAL_PR_DEBUG("out_value[%d] = %d", i, out_value[i]);
* @brief firmware download finish result callback
* @param[in] download_result: 0 means download succes. other means fail
VOID_T upgrade_notify_cb(IN CONST FW_UG_S *fw, IN CONST INT_T download_result, IN PVOID_T pri_data)
    // 这里简单认为 MCU 固件下载完成就升级完成，实际开发中不能这么做
    if(fw->tp == GP_DEV_MCU) {
        GW_ATTACH_ATTR_T mcu_attach = {0};
        mcu_attach.tp = fw->tp;
        strncpy(mcu_attach.ver, fw->sw_ver, SW_VER_LEN);
        tuya_iot_dev_set_attach_attr(fw->tp, &mcu_attach); // 上报升级成功后的固件版本
 * @brief SOC device upgrade entry
 * @return OPRT_OK on success. Others on error, please refer to "tuya_error_code.h".
STATIC OPERATE_RET __soc_dev_rev_upgrade_info_cb(IN CONST FW_UG_S *fw)
    PR_DEBUG("SOC_Rev_Upgrade_Info3");
    TAL_PR_DEBUG("fw->tp:%d", fw->tp);
    TAL_PR_DEBUG("fw->fw_url:%s", fw->fw_url);
    TAL_PR_DEBUG("fw->fw_hmac:%s", fw->fw_hmac);
    TAL_PR_DEBUG("fw->sw_ver:%s", fw->sw_ver);
    TAL_PR_DEBUG("fw->file_size:%u", fw->file_size);
    return tuya_iot_upgrade_gw(fw, get_file_data_cb, upgrade_notify_cb, NULL);
    //return OPRT_OK;
STATIC OPERATE_RET __soc_pre_dev_rev_upgrade_info_cb(IN CONST FW_UG_S *fw)
    //return tuya_iot_upgrade_gw(fw, get_file_data_cb, upgrade_notify_cb, NULL);
 * @brief SOC device cloud state change callback
 * @param[in] status: current status
STATIC VOID_T __soc_dev_status_changed_cb(IN CONST GW_STATUS_E status)
    TAL_PR_DEBUG("SOC TUYA-Cloud Status:%d", status);
 * @brief SOC device DP query entry
 * @param[in] dp_qry: DP query list
STATIC VOID_T __soc_dev_dp_query_cb(IN CONST TY_DP_QUERY_S *dp_qry)
    UINT32_T index = 0;
    TAL_PR_DEBUG("SOC Rev DP Query Cmd");
    if (dp_qry->cid != NULL) {
        TAL_PR_ERR("soc not have cid.%s", dp_qry->cid);
    if (dp_qry->cnt == 0) {
        TAL_PR_DEBUG("soc rev all dp query");
        update_all_dp();
        TAL_PR_DEBUG("soc rev dp query cnt:%d", dp_qry->cnt);
        for (index = 0; index < dp_qry->cnt; index++) {
            TAL_PR_DEBUG("rev dp query:%d", dp_qry->dpid[index]);
            // UserTODO
 * @brief SOC device format command data delivery entry
 * @param[in] dp: obj dp info
STATIC VOID_T __soc_dev_obj_dp_cmd_cb(IN CONST TY_RECV_OBJ_DP_S *dp)
    UINT32_T index = 0;
    TAL_PR_DEBUG("SOC Rev DP Obj Cmd t1:%d t2:%d CNT:%u", dp->cmd_tp, dp->dtt_tp, dp->dps_cnt);
    if (dp->cid != NULL) {
        TAL_PR_ERR("soc not have cid.%s", dp->cid);
    for (index = 0; index < dp->dps_cnt; index++) {
        deal_dp_proc(&(dp->dps[index]));
 * @brief SOC device transparently transmits command data delivery entry
 * @param[in] dp: raw dp info
STATIC VOID_T __soc_dev_raw_dp_cmd_cb(IN CONST TY_RECV_RAW_DP_S *dp)
    TAL_PR_DEBUG("SOC Rev DP Raw Cmd t1:%d t2:%d dpid:%d len:%u", dp->cmd_tp, dp->dtt_tp, dp->dpid, dp->len);
 * @brief SOC device process restart request entry
 * @param[in] type: gateway reset type
STATIC VOID_T __soc_dev_restart_req_cb(GW_RESET_TYPE_E type)
    TAL_PR_DEBUG("SOC Rev Restart Req %d", type);
    if (GW_RESET_DATA_FACTORY != type) {
        // UserTODO Device process restart
        tal_system_reset();
 * @brief SOC external network status change callback
 * @param[in] stat: curr network status
STATIC VOID __soc_dev_net_status_cb(IN CONST GW_WIFI_NW_STAT_E stat)
    TAL_PR_DEBUG("network status:%d", stat);
 * @brief mf uart init
 * @param[in] baud: Baud rate
 * @param[in] bufsz: uart receive buffer size
VOID mf_uart_init_callback(UINT_T baud, UINT_T bufsz)
    TAL_UART_CFG_T cfg;
    memset(&cfg, 0, sizeof(TAL_UART_CFG_T));
    cfg.base_cfg.baudrate = baud;
    cfg.base_cfg.databits = TUYA_UART_DATA_LEN_8BIT;
    cfg.base_cfg.parity = TUYA_UART_PARITY_TYPE_NONE;
    cfg.base_cfg.stopbits = TUYA_UART_STOP_LEN_1BIT;
    cfg.rx_buffer_size = bufsz;
    tal_uart_init(TUYA_UART_NUM_0, &cfg);
 * @brief mf uart free
 * @param[in] none
VOID mf_uart_free_callback(VOID)
 * @brief mf uart send function
 * @param[in] data: send data
 * @param[in] len: send data length
VOID mf_uart_send_callback(IN BYTE_T *data, IN CONST UINT_T len)
    tal_uart_write(TUYA_UART_NUM_0, data, len);
 * @brief mf uart receive function
 * @param[in] buf: receive buffer
 * @param[in] len: receive buffer max length
 * @return receive data length
UINT_T mf_uart_recv_callback(OUT BYTE_T *buf, IN CONST UINT_T len)
    return tal_uart_read(TUYA_UART_NUM_0, buf, len);
 * @brief Product test callback function
 * @param[in] cmd: Command
 * @param[in] data: data
 * @param[out] ret_data: Resulting data
 * @param[out] ret_len: Resulting data length
OPERATE_RET mf_user_product_test_callback(USHORT_T cmd, UCHAR_T *data, UINT_T len, OUT UCHAR_T **ret_data, OUT USHORT_T *ret_len)
    /* USER todo */
 * @brief mf configure write callback functions
 * @param[in] none
VOID mf_user_callback(VOID)
    return ;
 * @brief Callback function before entering the production test
 * @param[in] none
VOID mf_user_enter_mf_callback(VOID)
    return ;
 * @brief SOC device initialization
 * @param[in] none
OPERATE_RET __soc_device_init(VOID_T)
#if (defined(UUID) && defined(AUTHKEY))
    ws_db_init_mf();
    /* Set authorization information
     * Note that if you use the default authorization information of the code, there may be problems of multiple users and conflicts,
     * so try to use all the authorizations purchased from the tuya iot platform.
     * Buying guide: https://developer.tuya.com/cn/docs/iot/lisence-management?id=Kb4qlem97idl0.
     * You can also apply for two authorization codes for free in the five-step hardware development stage of the Tuya IoT platform.
     * Authorization information can also be written through the production testing tool.
     * When the production testing function is started and the authorization is burned with the Tuya Cloud module tool,
     * please comment out this piece of code.
    TUYA_CALL_ERR_RETURN(tuya_iot_set_wf_gw_prod_info(&prod_info));
    // 产测初始化， 注册函数需要应用实现，其中串口驱动不需要应用提供
    MF_IMPORT_INTF_S intf = {0};
    intf.uart_init = mf_uart_init_callback;
    intf.uart_free = mf_uart_free_callback;
    intf.uart_send = mf_uart_send_callback;
    intf.uart_recv = mf_uart_recv_callback;
    intf.mf_user_product_test = mf_user_product_test_callback;
    intf.user_callback = mf_user_callback;
    intf.user_enter_mf_callback = mf_user_enter_mf_callback;
    TAL_PR_ERR("mf_init APP_BIN_NAME[%s] USER_SW_VER[%s]", APP_BIN_NAME, USER_SW_VER);
    TUYA_CALL_ERR_RETURN(mf_init(&intf, APP_BIN_NAME, USER_SW_VER, TRUE));
    /* Initialize TuyaOS product information */
    TY_IOT_CBS_S iot_cbs = {0};
    iot_cbs.gw_status_cb = __soc_dev_status_changed_cb;
    iot_cbs.gw_ug_cb = __soc_dev_rev_upgrade_info_cb;//通知应用设备开始升级
    iot_cbs.gw_reset_cb = __soc_dev_restart_req_cb;
    iot_cbs.dev_obj_dp_cb = __soc_dev_obj_dp_cmd_cb;
    iot_cbs.dev_raw_dp_cb = __soc_dev_raw_dp_cmd_cb;
    iot_cbs.dev_dp_query_cb = __soc_dev_dp_query_cb;
    iot_cbs.pre_gw_ug_cb = __soc_pre_dev_rev_upgrade_info_cb;//通知应用设备即将开始升级
    TUYA_CALL_ERR_RETURN(tuya_iot_wf_soc_dev_init(GWCM_OLD, WF_START_AP_FIRST, &iot_cbs, PID, USER_SW_VER));
    GW_ATTACH_ATTR_T attach_mcu = {0};
    attach_mcu.tp = DEV_NM_NOT_ATH_SNGL;
    strncpy(attach_mcu.ver, "1.0.4", SW_VER_LEN);
    // 注册 SOC 和 mcu 升级通道
    //TUYA_CALL_ERR_RETURN(tuya_iot_wf_mcu_dev_init(GWCM_LOW_POWER, WF_START_AP_FIRST, &iot_cbs, NULL, PID, USER_SW_VER, "1.0.2"));
    TUYA_CALL_ERR_RETURN(tuya_iot_wf_dev_init(GWCM_OLD, WF_START_AP_FIRST, &iot_cbs, NULL, PID, USER_SW_VER, DEV_NM_ATH_SNGL, &attach_mcu, 1));
    TUYA_CALL_ERR_RETURN(tuya_iot_reg_get_wf_nw_stat_cb(__soc_dev_net_status_cb));
    /* Network button, LED initialization */
    app_led_init(LED_PIN);
    app_key_init(KEY_PIN);
STATIC VOID_T user_main(VOID_T)
    /* Initialization, because DB initialization takes a long time,
     * which affects the startup efficiency of some devices,
     * so special processing is performed during initialization to delay initialization of DB
    TY_INIT_PARAMS_S init_param = {0};
    init_param.init_db = TRUE;
    strcpy(init_param.sys_env, TARGET_PLATFORM);
    TUYA_CALL_ERR_LOG(tuya_iot_init_params(NULL, &init_param));
    tal_log_set_manage_attr(TAL_LOG_LEVEL_DEBUG);
    /* Initialization device */
    TAL_PR_DEBUG("device_init in");
    TUYA_CALL_ERR_LOG(__soc_device_init());
* @brief  task thread
* @param[in] arg:Parameters when creating a task
STATIC VOID_T tuya_app_thread(VOID_T *arg)
    /* Initialization LWIP first!!! */
    TUYA_LwIP_Init();
    user_main();
    tal_thread_delete(ty_app_thread);
 * @brief user entry function
 * @param[in] none:
VOID_T tuya_app_main(VOID_T)
    THREAD_CFG_T thrd_param = {4096, 4, "tuya_app_main"};
    tal_thread_create_and_start(&ty_app_thread, NULL, NULL, tuya_app_thread, NULL, &thrd_param);
