====================[ Build | monitor | Debug-MinGW-IDF ]=======================
"D:\JetBrains\CLion 2021.3.4\bin\cmake\win\bin\cmake.exe" --build E:\HWS\Tuya-Plantsio-Ivy\cmake-build-debug-mingw-idf --target monitor
[0/1] cmd.exe /C "cd /D E:\HWS\Tuya-Plantsio-Ivy\esp-idf\components\esptool_py && "D:\JetBrains\CLion 2021.3.4\bin\cmake\win\bin\cmake.exe" -D IDF_PATH="E:/HWS/Tuya-Plantsio-Ivy/esp-idf" -D IDF_MONITOR="E:/HWS/Tuya-Plantsio-Ivy/esp-idf/tools/idf_monitor.py" -D ELF_FILE="Tuya-Plants-Ivy.elf" -D WORKING_DIRECTORY="E:/HWS/Tuya-Plantsio-Ivy/cmake-build-debug-mingw-idf" -P run_idf_monitor.cmake"
E:\HWS\Tuya-Plantsio-Ivy\esp-idf\tools\idf_monitor.py:325: DeprecationWarning: distutils Version classes are deprecated. Use packaging.version instead.
  if StrictVersion(serial.VERSION) < StrictVersion('3.3.0'):
--- idf_monitor on COM4 921600 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
[I][fat_interface.cpp:88] init_sd_fatfs(): SD card ready
[I][system.cpp:28] mem_print(): start | free: 261732 bytes | used: 61324 bytes | free block: 113804 bytes
[I][system.cpp:31] mem_print(): start | free: 4093420 bytes | used: 50608 bytes | free block: 4093396 bytes
[I][system.cpp:28] mem_print(): system init | free: 261704 bytes | used: 61344 bytes | free block: 113804 bytes
[I][system.cpp:31] mem_print(): system init | free: 4092812 bytes | used: 51196 bytes | free block: 4092788 bytes
I (1667) I2S: DMA Malloc info, datalen=blocksize=100, dma_buf_count=2
I (1667) I2S: PLL_D2: Req RATE: 10000, real rate: 626.000, BITS: 16, CLKM: 133, BCK: 60, MCLK: 133.333, SCLK: 20032.000000, diva: 64, divb: 21
[D][app_main.cpp:82] system_init(): debug wake up source: 0
[I][app_main.cpp:39] init_event_loop(): event loop initialized
[I][app_main.cpp:122] bootstrap(): bootstrapping...
[I][app_main.cpp:125] bootstrap(): Prop loaded
[D][LanguageDriver.cpp:132] get_root_filepath(): debug-language root file path: /language/1.1.5 exist!
[I][Font.cpp:51] Font(): successfully loaded font at /language/1.1.5/zh/mi_ex_font_120.bin
[I][Font.cpp:51] Font(): successfully loaded font at /language/1.1.5/zh/mi_light_font_14.bin
[I][Font.cpp:51] Font(): successfully loaded font at /language/1.1.5/zh/mi_light_font_16.bin
[I][Font.cpp:51] Font(): successfully loaded font at /language/1.1.5/zh/mi_light_font_24.bin
[I][Font.cpp:51] Font(): successfully loaded font at /language/1.1.5/zh/mi_light_font_30.bin
[I][Font.cpp:51] Font(): successfully loaded font at /language/1.1.5/zh/mi_light_font_36.bin
[I][Font.cpp:51] Font(): successfully loaded font at /language/1.1.5/zh/mi_light_font_109.bin
[I][LanguageDriver.cpp:64] load_user_language(): language 0 successfully loaded
[I][TextDriver.cpp:44] load_text(): loaded text for zh
[I][Boot.cpp:26] normal_system_pre_setup(): Normal System Init
[I][TouchButton.h:46] TouchButton(): touch pad initialized
[I][Ear.cpp:81] update_sensitivity(): ear thresh set to 2095 | 440
[I][Boot.cpp:33] normal_system_pre_setup(): Prop applied
[W][system.cpp:171] detect_i2c_device(): I2C device at 0x70 successfully detected!
[D][SparkFun_SHTC3.cpp:185] checkID(): request numBytesRx: 3
[I][HumTempSensor.cpp:25] HumTempSensor(): TH sensor dev 1 found
[I][IvyBody.cpp:336] boot(): Body booting...
[I][IvyBody.cpp:338] boot(): Belly initialized
[I][IvyBody.cpp:344] boot(): IO Expander started
[I][Sense.cpp:32] Sense(): Sense initializing...
[I][Sense.cpp:35] Sense(): Sense initialized
[I][IvyBody.cpp:356] boot(): Body booted
[I][Boot.cpp:39] normal_system_pre_setup(): Body inited
[I][CW2015.cpp:50] begin(): CW2015 init successful
[I][LED.cpp:25] LED(): LEDC initialized
[E][esp32-hal-cpu.c:125] removeApbChangeCallback(): not found func=4019C090 arg=3FFBFB44
[I][system.cpp:28] mem_print(): anim | free: 224572 bytes | used: 98396 bytes | free block: 113804 bytes
[I][system.cpp:31] mem_print(): anim | free: 3565732 bytes | used: 575872 bytes | free block: 3179584 bytes
[I][system.cpp:28] mem_print(): engine | free: 224572 bytes | used: 98396 bytes | free block: 113804 bytes
[I][system.cpp:31] mem_print(): engine | free: 3565732 bytes | used: 575872 bytes | free block: 3179584 bytes
[I][LvglDriver.cpp:84] LvglDriver(): lv init successful
[I][system.cpp:28] mem_print(): lvgl | free: 224572 bytes | used: 98396 bytes | free block: 113804 bytes
[I][system.cpp:31] mem_print(): lvgl | free: 3407592 bytes | used: 733664 bytes | free block: 3179584 bytes
[D][TouchButton.h:92] set_disable_t(): tp-4 disable for 2000 ms
[D][TouchButton.h:92] set_disable_t(): tp-1 disable for 2000 ms
[D][TouchButton.h:92] set_disable_t(): tp-0 disable for 2000 ms
[D][TouchButton.h:92] set_disable_t(): tp-9 disable for 2000 ms
[D][TouchButton.h:92] set_disable_t(): tp-8 disable for 2000 ms
I (5275) wifi:wifi driver task: 3ffbd6d4, prio:23, stack:6656, core=0
I (5311) wifi:wifi firmware version: ee7163f-dirty
I (5311) wifi:config NVS flash: enabled
I (5311) wifi:config nano formating: disabled
I (5312) wifi:Init data frame dynamic rx buffer num: 32
I (5312) wifi:Init management frame dynamic rx buffer num: 32
I (5313) wifi:Init management short buffer num: 32
I (5314) wifi:Init static tx buffer num: 32
I (5315) wifi:Init tx cache buffer num: 32
I (5315) wifi:Init static rx buffer size: 1600
I (5316) wifi:Init static rx buffer num: 10
I (5316) wifi:Init dynamic rx buffer num: 32
I (5317) wifi_init: rx ba win: 16
I (5317) wifi_init: tcpip mbox: 32
I (5317) wifi_init: udp mbox: 10
I (5317) wifi_init: tcp mbox: 6
I (5318) wifi_init: tcp tx win: 5744
I (5318) wifi_init: tcp rx win: 5744
I (5319) wifi_init: tcp mss: 1436
I (5319) wifi_init: WiFi/LWIP prefer SPIRAM
I (5320) phy_init: phy_version 4660,0162888,Dec 23 2020
W (5321) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
I (5510) wifi:mode : sta (e0:5a:1b:14:1c:28)
[I][NetInterface.cpp:116] net_event_handler(): WIFI STA Started
[I][system.cpp:28] mem_print(): prov | free: 79436 bytes | used: 243260 bytes | free block: 48728 bytes
[I][system.cpp:31] mem_print(): prov | free: 3331500 bytes | used: 808896 bytes | free block: 3179584 bytes
[E][system.cpp:473] nvs_get_string(): nvs get value length err: 0x1102 4354
[D][IOT.cpp:508] get_credentials(): nvs uuid =  authkey =
[D][IOT.cpp:509] get_credentials(): sd uuid = uuid79070d5eb1fb4a73 authkey = DG7oDRjexi6nbFSJiQP4z4QEswNqOu8H
E (5528) pin: tuya_pin_register is weaked...
[TOS_DBG]tuya_esp_flash_init ok, addr:0x7d0000, size:0x28000
[01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ...
[01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:sys_timer Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:cmmod Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2
[01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[01-01 18:12:15 TUYA E][log_seq.c:871] logseq empty
[01-01 18:12:15 TUYA I][uni_thread.c:220] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[01-01 18:12:15 TUYA D][uni_thread.c:247] Thread:wk_th-0 Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA N][device_interface.cpp:135] < TUYA IOT SDK V:2.3.2 BS:40.00_PT:2.2_LAN:3.4_CAD:1.0.4_CD:1.0.0 >
< BUILD AT:2022_09_29_11_36_59 BY ci_manage FOR ty_iot_sdk_custom AT esp32-series >
IOT DEFS < WIFI_GW:1 DEBUG:1 KV_FILE:0 SHUTDOWN_MODE:0 LITTLE_END:1 TLS_MODE:4 ENABLE_CLOUD_OPERATION:0 OPERATING_SYSTEM:98 ENABLE_SYS_RPC:0 RELIABLE_TRANSFER:0 ENABLE_LAN_ENCRYPTION:1 ENABLE_LAN_LINKAGE:0 ENABLE_LAN_DEV:0 >
[01-01 18:12:15 TUYA N][device_interface.cpp:136] Tuya-Plants-Ivy:1.1.5
[01-01 18:12:15 TUYA N][device_interface.cpp:137] firmware compiled at Apr 18 2023 15:45:03
[01-01 18:12:15 TUYA N][uni_log.c:197] SetLogManageAttr 2
[01-01 18:12:15 TUYA N][simple_flash.c:459] key_addr: 0x24000   block_sz 4096
[01-01 18:12:15 TUYA E][simple_flash.c:479] key data is not matched magic(0x3a2d3e45),crc32(0xe2d8782c)
[01-01 18:12:15 TUYA E][simple_flash.c:493] flash is encrypted or empty
[01-01 18:12:15 TUYA E][simple_flash_app.c:306] create_flash_hand_and_init err 10
[01-01 18:12:15 TUYA E][tuya_ws_db.c:454] db init fails -1
[01-01 18:12:15 TUYA E][tuya_iot_com_api.c:454] db init fails -1
[01-01 18:12:15 TUYA E][IOT.cpp:389] ret:-1
[01-01 18:12:15 TUYA E][simple_flash.c:601] key data is not matched magic(0x3a2d3e45),crc32(0xe2d8782c)
[01-01 18:12:15 TUYA N][simple_flash.c:548] get key:
0x86 0x85 0x96 0x3a 0xbf 0x93 0x8 0xd 0x34 0x57 0x47 0xc9 0xd2 0x5a 0x47 0x26
[01-01 18:12:16 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[01-01 18:12:16 TUYA N][tuya_iot_wifi_api.c:276] wifi soc init. pid:8n3q0y4cwov8ifxt firmwarekey:8n3q0y4cwov8ifxt ver:1.1.5
[01-01 18:12:16 TUYA N][tuya_devos_entry.c:1752] Last reset reason: 0
[TOS_DBG]....read wifi mac:e0:5a:1b:14:1c:28
[01-01 18:12:16 TUYA N][tuya_devos_entry.c:1116] serial_no:e05a1b141c28
I (7064) wifi:set country: cc=CN  schan=1 nchan=13 policy=1
[01-01 18:12:16 TUYA N][tuya_devos_entry.c:1147] gw_cntl.gw_wsm.stat:0
[01-01 18:12:16 TUYA N][tuya_devos_netcfg.c:1353] gw_cntl->gw_wsm.nc_tp:0
[01-01 18:12:16 TUYA N][tuya_devos_netcfg.c:1354] gw_cntl->gw_wsm.md:0
[01-01 18:12:16 TUYA N][tuya_devos_netcfg.c:1368] wifi config method not fit
[01-01 18:12:16 TUYA E][tuya_devos_entry.c:1763] ret:-2
[01-01 18:12:17 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_ai -6
[01-01 18:12:17 TUYA E][ws_db_gw.c:636] gw_ai read fail:-6
[D][NetInterface.h:76] set_prov_status(): xxxxxxxxxxxxxx set to 1
[D][LvglDriver.cpp:123] load(): debug-load-ui now loading 37, current ui 11
[D][LvglDriver.cpp:156] load(): debug-router loading 37, current:37
[I][device_interface.cpp:433] tuya_iot_bt_init(): tuya_iot_bt_init
I (8076) BTDM_INIT: BT controller compile version [ecc3fcf]
device id key : 16
b9 d8 6a af 11 61 5f 35 1c e8 db 77 01 38 51 d5
[TOS_DBG]new wf_mode:2, old wf_mode:0
tuya_adapter_ble_start
I (8179) phy_init: phy_version 4660,0162888,Dec 23 2020
[TOS_DBG]new wf_mode:1, old wf_mode:2
I (11227) wifi:ic_enable_sniffer
[01-01 18:12:20 TUYA N][device_interface.cpp:311] wf_nw_status_cb, wifi_status:1
[D][Fps.cpp:58] output(): system fps: 6.241950
[D][Fps.cpp:58] output(): anim fps: 17.710899
[I][system.cpp:28] mem_print(): get_percent | free: 32792 bytes | used: 289772 bytes | free block: 27796 bytes
[I][system.cpp:31] mem_print(): get_percent | free: 3299688 bytes | used: 839600 bytes | free block: 3179584 bytes
[D][Fps.cpp:58] output(): critical fps: 49.210896
[01-01 18:12:28 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): pre-body fps: 96.621574
[D][Fps.cpp:58] output(): system fps: 10.005944
[01-01 18:12:32 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:12:34 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:12:35 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:12:36 TUYA N][bt_netcfg.c:856] Dev Rev BT Package
[01-01 18:12:36 TUYA E][bt_netcfg.c:586] ty_ble_rx_proc version not compatibility!
[01-01 18:12:37 TUYA N][bt_netcfg.c:856] Dev Rev BT Package
[01-01 18:12:37 TUYA W][bt_netcfg.c:568] ble data package is pendding.
service_rand is : 0xc2, 0xbc, 0x92, 0x88, 0xb3, 0x40, 0x5b, 0xbe, 0x5f, 0x68, 0x6f, 0x30, 0xe0, 0xb1, 0x7f, 0x33,
ble service rand 3 16
c2 bc 92 88 b3 40 5b be 5f 68 6f 30 e0 b1 7f 33
ble service rand 2 16
ble decryped key 16
05 73 d4 07 bf 8e f0 43 75 a2 53 70 1e c5 3b 59
ble service rand 1 16
[01-01 18:12:37 TUYA N][bt_netcfg.c:864] default resp generated.
[01-01 18:12:37 TUYA N][bt_netcfg.c:1187] ble_send_data_to_app send_data->len:129
[01-01 18:12:38 TUYA N][bt_netcfg.c:856] Dev Rev BT Package
[01-01 18:12:38 TUYA W][bt_netcfg.c:568] ble data package is pendding.
ble dev rand 1 6
89 f5 5d 3b ee 3d
before key2 gen 22
05 73 d4 07 bf 8e f0 43 75 a2 53 70 1e c5 3b 59 89 f5 5d 3b ee 3d
ble decryped key 16
f2 42 11 c2 69 1c 79 79 48 20 b0 54 23 b4 03 d1
[01-01 18:12:38 TUYA N][bt_netcfg.c:298] ble set connect status:3
[01-01 18:12:38 TUYA N][bt_netcfg.c:337] PAIR_REQ ok-0
[01-01 18:12:38 TUYA N][bt_netcfg.c:864] default resp generated.
ble dev rand 1 6
89 f5 5d 3b ee 3d
before key2 gen 22
[01-01 18:12:38 TUYA N][bt_netcfg.c:1187] ble_send_data_to_app send_data->len:33
[01-01 18:12:39 TUYA N][bt_netcfg.c:856] Dev Rev BT Package
[01-01 18:12:39 TUYA W][bt_netcfg.c:568] ble data package is pendding.
ble dev rand 1 6
89 f5 5d 3b ee 3d
before key2 gen 22
ble decryped key 16
I (29719) wifi:ic_disable_sniffer
[01-01 18:12:39 TUYA E][wifi_netcfg_frame_transporter.c:431] timer is not run,wait
tuya_adapter_ble_deinit
esp_bt_controller_mem_release
[D][NetInterface.h:76] set_prov_status(): xxxxxxxxxxxxxx set to 2
[01-01 18:12:40 TUYA N][tuya_devos_netcfg.c:347] stop smt cfg mthd:0, ret:0
[TOS_DBG]new wf_mode:2, old wf_mode:2
I (30795) wifi:flush txq
I (30795) wifi:stop sw txq
I (30797) wifi:lmac stop hw txq
I (30798) phy_init: phy_version 4660,0162888,Dec 23 2020
I (30807) wifi:mode : sta (e0:5a:1b:14:1c:28)
[01-01 18:12:40 TUYA N][device_interface.cpp:311] wf_nw_status_cb, wifi_status:5
[I][NetInterface.cpp:225] net_status_change_handler(): STAT_STA_DISCONNECT
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC      : 0x4017f9ed  PS      : 0x00060130  A0      : 0x80163fb4  A1      : 0x3fffd900
A2      : 0x16701670  A3      : 0x00000006  A4      : 0x00000000  A5      : 0x00000000
A6      : 0x3ffc4204  A7      : 0x00000000  A8      : 0x801776f0  A9      : 0x3fffd8e0
A10     : 0x00000064  A11     : 0x00000000  A12     : 0x00000000  A13     : 0x3f82d9a0
A14     : 0x00000026  A15     : 0xaecb6d14  SAR     : 0x00000008  EXCCAUSE: 0x0000001c
EXCVADDR: 0x16701674  LBEG    : 0x4000c349  LEND    : 0x4000c36b  LCOUNT  : 0xffffffff
0x4017f9ed: GetThrdSta at ??:?
ELF file SHA256: dd013023cb0d959a
Backtrace: 0x4017f9ea:0x3fffd900 0x40163fb1:0x3fffd920 0x4017f801:0x3fffd940
0x4017f9ea: GetThrdSta at ??:?
0x40163fb1: ble_netcfg_task at /home/share/samba/wifi_sdk/TY_ESP32_SDK/tuya_sdk/tuya_btcfg/src/bt_netcfg.c:1419
0x4017f801: __WrapRunFunc at uni_thread.c:?
Rebooting...
€€ € €€€ €   € €€€€€ €€     €         €  €    €      €    €   €  €  € €€  € €€  €   €€ € €€ €    €€ €   € € €€€€€€€€€€ € €€€€€€€€€€  €€€€ €€ €€€€ € €€€€ €  €   €€€€€€€ €€ €    €€    €   € € €€ €€€  €€€€  €€ €€ €€ €€€€€€  €  €€ €€ €€  €€€€  €€ €€ € €€€€ € €€  € € €€€€ €€  €€ €€€ €€ €€ €€ € €      €   € €€ €€€  €€€€€ €€ €    €€€ €€€ €€€  € € € €€€€€€€€€  €  € €€ €    €     € € €€€€  €  € €€ €    €     €   €€€€  €  € €€ €    €     € € €€ €  €€€  €  € €€ €    €     €  €€  €€€€  €  € €€ €    €     € €€€ €€€€  €  € €€ €    €    €€  € €€€€€€€  €€€ € €   €€  €€ € €   € € €€€€€€ €€€€€    €€ €€ €€ € €  €€  €  €€€€€€ €  € €    €€    €  €  €    €     €  €€€€ € €€ €  € €€  €  €€€€€€ €  € €    €€    €  €  €    €  € € €  €€€€ € €€ € €     €€  €  €€€€€€ €  € €    €€    €  €  €          €  €€€€ € €€ €  €    €   €€  €  €€€€€€ €  € €    € €     €€          €  €€€€ € €€ € €  €  €€€  €  € €€  €  €€€€€€ €  € €    € €          €      €  €€€€ € €€ € €  €   €   €€  € €€ € €€ €€  €€ €     € €         €€€   € € €€  € €€ €€€€  €€ €     €€€€€  €   € €  €     € €    €€ €  €€ €€€€€ €    €€€ €€€ €€€ €  € € €€€ €€ €  € €€€ €  €€ €€ €€ €€€     €€€   €  €€€€  €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €     € €   € € €€ €€  €€ €€€€€ €     €€€€€€€€ €€  €   €  € €€ €  €€ €€ €€  € €€ €€€  €    €€€ €€€ €    €€€ € €€€ €€€ €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €     € €   € € €€ €€  €€ €€€€€ €   € €€ €€€  €    €€€ €€€ €  €€€€€€€  €€€ € €     € €€€ €€ € €€      €€€€  € €  €€ €€€€€      €€€€€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €  €€€ € €   € € €€ €€  €€ €€€€€ €    €€€ €€  €€€ €€€ €  € €€ €€€ €€ €€€ €€€ € €€€ €€ €€€€ €  € €   € €€ €€ € €€€€ €  € €€€ €  € €€ €€   €€€€€€€€€€  €€€ €€€ € €€   €    €€€ € €€€€  €€€ €€ €   €€€€€€€  €€€ € € €€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €        € €   € € €€€€€€€€€ € €€€ €  € €€ €    €€  €€€€  € € €€€€€  €€€€ € € €€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €      € € €   € € €€€€€€€€€ € €€€ €  € €€ €   € € € € €€€ €€€ €€ € €€€ €€€€€ €€  € €€ €€  €€€€  €€€€€€ € €€€ €€€€€ €€ € €€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €  €  € €   € € €€€€€€€€€ € €€€ €  € €€ €    €€  €€€€ €€€€€ €€ € €€   €€€ €€€€€€€ € €            €€€€€€€€ €€ €€€€  €€ €€€ € €€ €€€ €€€€ €  € €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €  €€ € €   € € €€€€€€€€€ € €€€ €  € €€ €   € € € €   €€€€ €  €€ €€ €€€€€ €€ €             €    €€ €  €€€€  € €€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   €    € €   € € €€€€€€€€€ € €€€ €  € €€ €   € €€€€€€€€ €€ €€ €€€€ €   €€€ €€€€€€€€ € €           € € €  €  €              €    €  €€€  € €  €€  €  €  € €€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   €   € €   € € €€€€€€€€€ € €€€ €  € €€ €   €€ €  €  €    €€ €€ €€€€ €  € €€  €€ €   €€€  €  €       €  €  €  €       €  € €  €    €€  €€€ €  € € €  €  € €€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €€€  € € €   € € €€€€€€€€€ € €€€ €  € €€ €   €€ €€ €€ €€€€€ €  €  €  € €                      €€ €  €    € €  €€€     €€€ € €  €  €€   € €€ €€  €   €     €€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   €   € €   € € €€€€€€€€€ € €€€ €  € €€ €   € €€ €€€ €  € €€€ €€ €€€ €  € € € €  € € €€€€€ €   €€ € €€ €€  €€ €   €€€€€ €€ €€ €€  € €€€ €     € €       €  €€      €€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €€€ €  € €   € € €€€€€€€€€ € €€€ €  € €€ €   € € € €  € € €€€€€  €€€€ € € €€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   € €€€ €  € €   € € €€ €€  €€ €€€€€ €   € €€ €€€  €  € €€  €€€ €€€ €  €€€€€€ €€€€€€€€  €€ €   €€€€ €€ € €€  € €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   €  €    € €    €€€€ €€ € €€€€€ €€ €€€ €€ €€ €   €  € €€€ €€ €€€ €€€ € €€€ €€ €€€ €€ €€€ € €     €€€ €€€ €  € € €€€ €€ €€ €€€ €  € €€€€ €    €€€€  €    €€ € €€€ €€€€€€ €€€ €  € € €€ €€€€€€ €€ € €€€ €€€€€ €€ € €€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   €  €    € €    €€€€ €€ € €€€€€ €€ €€€ €€ €€ €   € € €€  €    €  €€ €  €  €€       €€€€ € €€                €     €     €€ €€ €€  €€ €  €     €  €€€ €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   €  €  € € €    €€€€ €€ € €€€€€ €€ €€€ €€ €€ €   € € €€  €    €  €  € € €         €€€€ € €€          €  € €€€      € €€   €€ €€ €€  €€ €  €     €  €€€ €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   € €€    € €    €€€€ €€ € €€€€€ €€ €€€ €€ €€ €   € € €€  €    €  €  €€  € €        €€€€ € €€           € €         € €   €   €€ €€ €€  €€ €  €     €  €€€ €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   € €€   € €    €€€€ €€ € €€€€€ €€ €€€ €€ €€ €   € € €€  €    €  €  €  €  €€€€ € €   €€€€ € €€                 €    €     €€ €€ €€  €€ €  €     €  €€€ €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   €    € € €    €€€€ €€ € €€€€€ €€ €€€ €€ €€ €   € € €€  €    €  €€ €  €€ €  €     €€€€ € €€        €  €€ €  €€€      € €       €€ €€ €€  €€ €  €     €  €€€ €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   € €  €  € €    €€€€ €€ € €€€€€ €€ €€€ €€ €€ €   € € €€  €    €  €€€ €   €  €      €€€€ € €€          €  € €€€ €     € €   €   €€ €€ €€  €€ €  €     €€€ €  €  €€€ €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €   € €  €€ € €    €€€€ €€ € €€€€€ €€ €€€ €€ €€ €   € € €€  €    €  €€€ € € €  €€€      €€€€ € €€        €    €€ €  €     € €  €  €    €€ €€ €€  €€ €  €     €€€ €  €  €€€ €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €€€    € € €    €€€€ €€ € €€€€€ €€ €€€ €€ €€ €   € € €€   €     €  €  €   €      €€€€ € €€           € € €  €     €    €€   €€ €€ €€  €€ €  €   €  €  €€€ €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €€€ €    € €   € € €€€€€€€€€ € €€€ €  € €€ €    €€  €€€€  € € €€€€€  € € €€€ €  € €€  €€€€€ €€€ €  €  € €€€€  €€€ €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €€€ €  €€€ € €   € € €€ €€  €€ €€€€€ €   € €  €  €€ €€ €€€ €   €€€€€€€ €€  €€€  €   €    € €€ €€ €  €€€  €  €€ € € €€€€ €  € €€€ € €€  € €€ €€€  €  €€€€€€ €€€€€€€€  €€ €   €€€€€   €€€€ €€ € €  € € €€ €€€€€€ €€ € €€€€€  €€€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €€€  €   € €   € € €€€€€€€€€ € €€€ €  € €€ €   € €€ €€€ €  € €€€ €€ €€€ €  € €€ € €€€€ €  €€€€€ €€€€ €  €  €€€ €€   €€  €€€ €  € € €€€€€€€ € €€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   €   € €   € € €€€€€€€€€ € €€€ €  € €€ €   € €€ €€€ €  € €€€ €€ €€€ €  € €€ € €€€€ €  €€€€€ €€€€ €  €  €€€ €€  € € €€ €€  € € €€€€€€€ € €€ €€€€  €€€€€€  € €€ €€€€  €€ €     €€€€€  €   € €  €€€  € €  € €   € € €€ €€  €€ €€€€€ €     €€€€ €€ €€€ €  € €€€ €€ €€€ €   €€€€€€€ €€  €€€  €  €     €€ €  €€€  €  € €€ €€ €€€€ €  € €€€ € €€  €€€€€€ €€€€€€€€  €€ €    €€€€  €    €€€ €€ €€€ € €€ €€ €€€€ €  € €€€ € €€  € € €€ €€€€€€ €€ € €€€ €€€€€ €€€ €€€ €€€€  €€€€€€  € I (1580) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
[I][system.cpp:28] mem_print(): start | free: 261176 bytes | used: 61848 bytes | free block: 113804 bytes
[I][system.cpp:28] mem_print(): system init | free: 261148 bytes | used: 61868 bytes | free block: 113804 bytes
I (1686) I2S: DMA Malloc info, datalen=blocksize=100, dma_buf_count=2
I (1686) I2S: PLL_D2: Req RATE: 10000, real rate: 626.000, BITS: 16, CLKM: 133, BCK: 60, MCLK: 133.333, SCLK: 20032.000000, diva: 64, divb: 21
[I][system.cpp:28] mem_print(): anim | free: 224016 bytes | used: 98920 bytes | free block: 113804 bytes
[I][system.cpp:28] mem_print(): engine | free: 224016 bytes | used: 98920 bytes | free block: 113804 bytes
[I][system.cpp:28] mem_print(): lvgl | free: 224016 bytes | used: 98920 bytes | free block: 113804 bytes
I (5293) wifi:wifi driver task: 3ffd1700, prio:23, stack:6656, core=0
I (5308) wifi:wifi firmware version: ee7163f-dirty
I (5308) wifi:config NVS flash: enabled
I (5308) wifi:config nano formating: disabled
I (5308) wifi:Init data frame dynamic rx buffer num: 32
I (5309) wifi:Init management frame dynamic rx buffer num: 32
I (5309) wifi:Init management short buffer num: 32
I (5311) wifi:Init static tx buffer num: 32
I (5312) wifi:Init tx cache buffer num: 32
I (5312) wifi:Init static rx buffer size: 1600
I (5312) wifi:Init static rx buffer num: 10
I (5313) wifi:Init dynamic rx buffer num: 32
I (5313) wifi_init: rx ba win: 16
I (5313) wifi_init: tcpip mbox: 32
I (5314) wifi_init: udp mbox: 10
I (5314) wifi_init: tcp mbox: 6
I (5315) wifi_init: tcp tx win: 5744
I (5315) wifi_init: tcp rx win: 5744
I (5316) wifi_init: tcp mss: 1436
I (5316) wifi_init: WiFi/LWIP prefer SPIRAM
I (5317) phy_init: phy_version 4660,0162888,Dec 23 2020
I (5398) wifi:mode : sta (e0:5a:1b:14:1c:28)
[I][system.cpp:28] mem_print(): prov | free: 78880 bytes | used: 243784 bytes | free block: 48728 bytes
[I][system.cpp:31] mem_print(): prov | free: 3332124 bytes | used: 808300 bytes | free block: 3179584 bytes
[D][IOT.cpp:508] get_credentials(): nvs uuid = uuid79070d5eb1fb4a73 authkey = DG7oDRjexi6nbFSJiQP4z4QEswNqOu8H
E (5411) pin: tuya_pin_register is weaked...
[01-01 18:12:15 TUYA N][tuya_iot_wifi_api.c:276] wifi soc init. pid:8n3q0y4cwov8ifxt firmwarekey:8n3q0y4cwov8ifxt ver:1.1.5
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1752] Last reset reason: 4
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1116] serial_no:e05a1b141c28
I (5801) wifi:set country: cc=CN  schan=1 nchan=13 policy=1
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1147] gw_cntl.gw_wsm.stat:0
[01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1353] gw_cntl->gw_wsm.nc_tp:1
[01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1354] gw_cntl->gw_wsm.md:0
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1206] gw_cntl.gw_if.abi:0 input:0
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1207] gw_cntl.gw_if.product_key:8n3q0y4cwov8ifxt, input:8n3q0y4cwov8ifxt
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1208] gw_cntl.gw_if.tp:0, input:0
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1210] gw_cntl.gw_if.firmware_key:8n3q0y4cwov8ifxt, input:8n3q0y4cwov8ifxt
I (6037) BTDM_INIT: BT controller compile version [ecc3fcf]
device id key : 16
I (6141) phy_init: phy_version 4660,0162888,Dec 23 2020
[01-01 18:12:17 TUYA N][bt_netcfg.c:856] Dev Rev BT Package
[01-01 18:12:17 TUYA E][bt_netcfg.c:586] ty_ble_rx_proc version not compatibility!
[01-01 18:12:17 TUYA W][bt_netcfg.c:568] ble data package is pendding.
service_rand is : 0x2d, 0x7b, 0x64, 0x7, 0xc5, 0xd0, 0xfa, 0xac, 0x6a, 0xf7, 0xef, 0x3b, 0xec, 0xaa, 0xdf, 0xbc,
2d 7b 64 07 c5 d0 fa ac 6a f7 ef 3b ec aa df bc
ble decryped key 16
47 13 e4 95 7a 6e d2 98 2e 47 86 5a c2 0d 07 c4
[01-01 18:12:17 TUYA N][bt_netcfg.c:864] default resp generated.
[01-01 18:12:17 TUYA N][bt_netcfg.c:1187] ble_send_data_to_app send_data->len:129
[01-01 18:12:18 TUYA N][bt_netcfg.c:856] Dev Rev BT Package
[01-01 18:12:18 TUYA W][bt_netcfg.c:568] ble data package is pendding.
I (9186) wifi:ic_enable_sniffer
[01-01 18:12:18 TUYA N][device_interface.cpp:311] wf_nw_status_cb, wifi_status:1
ble dev rand 1 6
74 1d 39 4e c4 19
before key2 gen 22
47 13 e4 95 7a 6e d2 98 2e 47 86 5a c2 0d 07 c4 74 1d 39 4e c4 19
ble decryped key 16
dc 22 a0 a7 1c 89 77 23 3d 54 ac 3a ad 51 37 36
[01-01 18:12:18 TUYA N][bt_netcfg.c:298] ble set connect status:3
[01-01 18:12:18 TUYA N][bt_netcfg.c:337] PAIR_REQ ok-0
[01-01 18:12:18 TUYA N][bt_netcfg.c:864] default resp generated.
ble dev rand 1 6
74 1d 39 4e c4 19
before key2 gen 22
[01-01 18:12:18 TUYA N][bt_netcfg.c:1187] ble_send_data_to_app send_data->len:33
[01-01 18:12:20 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): system fps: 6.361197
[01-01 18:12:21 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:12:23 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): anim fps: 17.850006
[I][system.cpp:28] mem_print(): get_percent | free: 32240 bytes | used: 290292 bytes | free block: 27796 bytes
[I][system.cpp:31] mem_print(): get_percent | free: 3299188 bytes | used: 839980 bytes | free block: 3179584 bytes
[01-01 18:12:26 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): critical fps: 49.996666
[D][Fps.cpp:58] output(): pre-body fps: 99.473648
[01-01 18:12:30 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): system fps: 10.006935
[01-01 18:12:31 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:12:38 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:12:39 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): anim fps: 24.388618
[I][system.cpp:31] mem_print(): get_percent | free: 3298760 bytes | used: 840384 bytes | free block: 3179584 bytes
[01-01 18:12:42 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): critical fps: 50.000000
[D][Fps.cpp:58] output(): pre-body fps: 100.033325
[01-01 18:12:46 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:12:49 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:12:54 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): anim fps: 24.396748
[01-01 18:12:56 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): pre-body fps: 100.073288
[01-01 18:12:59 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:07 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:08 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): anim fps: 24.399975
[01-01 18:13:11 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:12 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): pre-body fps: 100.066620
[01-01 18:13:15 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:19 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): system fps: 10.004953
[01-01 18:13:23 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:26 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:29 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): pre-body fps: 100.053329
[01-01 18:13:31 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:33 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:36 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:40 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): anim fps: 24.401596
[D][Fps.cpp:58] output(): critical fps: 50.003330
[01-01 18:13:44 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): pre-body fps: 100.019997
[01-01 18:13:49 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:52 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:53 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:13:56 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): pre-body fps: 100.046654
[01-01 18:13:59 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:00 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:03 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:06 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:10 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): anim fps: 24.393494
[01-01 18:14:13 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:14 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:17 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:18 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:22 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:25 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:26 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:26 TUYA N][bt_netcfg.c:856] Dev Rev BT Package
[01-01 18:14:26 TUYA W][bt_netcfg.c:568] ble data package is pendding.
[01-01 18:14:27 TUYA N][bt_netcfg.c:856] Dev Rev BT Package
ble dev rand 1 6
74 1d 39 4e c4 19
before key2 gen 22
ble decryped key 16
[01-01 18:14:28 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:29 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:36 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): anim fps: 24.391869
[I][system.cpp:31] mem_print(): get_percent | free: 3301196 bytes | used: 838084 bytes | free block: 3179584 bytes
[01-01 18:14:43 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): pre-body fps: 100.013321
[01-01 18:14:47 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:54 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:14:59 TUYA E][wf_nw_cfg.c:619] channel err:36
[D][Fps.cpp:58] output(): pre-body fps: 100.026649
[01-01 18:15:01 TUYA E][wf_nw_cfg.c:619] channel err:36
[01-01 18:15:05 TUYA E][wf_nw_cfg.c:619] channel err:36
