[09:41:11.727]ÊÕ¡û¡ô [09:41:11.994]ÊÕ¡û¡ôÿ\0 [09:41:12.114]ÊÕ¡û¡ô V:BK7231N_1.0.1 REG:cpsr spsr r13 r14 SVC:000000D3 00401C1C 000033AC IRQ:000000d2 00000010 00401e0c fb730ef7 FIR:000000d1 00000010 00401ffc 9f367cfe SYS:000000df 0040192c 00000158 ST:00000000 J 0x10000 bk_misc_init_start_type 0 0 prvHeapInit-start addr:0x4117e0, size:124960 [Flash]id:0x1c7015 sctrl_sta_ps_init cset:0 0 0 0 [01-01 18:12:15 TUYA Info][lr:0xa2f0d] mqc app init ... [01-01 18:12:15 TUYA Info][lr:0xac03b] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [01-01 18:12:15 TUYA Info][lr:0xac03b] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4 [01-01 18:12:15 TUYA Debug][lr:0xa2ebb] mq_pro:5 cnt:1 [01-01 18:12:15 TUYA Debug][lr:0xa2ebb] mq_pro:31 cnt:2 [01-01 18:12:15 TUYA Debug][lr:0xabec7] Thread:sys_timer Exec Start. Set to Running Stat [01-01 18:12:15 TUYA Debug][lr:0x9cced] read m:0 f:0 l:0 [01-01 18:12:15 TUYA Debug][lr:0xab9ab] svc online log init success [01-01 18:12:15 TUYA Info][lr:0xac03b] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3 [01-01 18:12:15 TUYA Err][lr:0xc2285] kvs_read fails gw_bi -1 [01-01 18:12:15 TUYA Debug][lr:0x95823] gw base read finish:-18 [01-01 18:12:15 TUYA Debug][lr:0xa01e9] ty bt cmmod regist ok:1 [01-01 18:12:15 TUYA Debug][lr:0xa04e5] upd adv para, send conn_req beacon. [PLATFORM DEBUG]!!!!!!!!!!tuya_os_adapt_bt_port_init [01-01 18:12:1ble mac:1c-90-ff-50-d1-5f-50-d1-20 [01-01 18:2ice][lr:0xa02d3] ty bt 12:15 TUYA Notice][lr:0sdk init finish xvr_rexa02d3] ty bt sdk init g_init h4tl_init-1 okfinish [PLATFORM NOTIC ]bk_rst:0 tuya_rst:0 E]bk_rst:0 tuya_rst:0 hci_init ok !!!!!!init_type=0 rwble_hl_init ok rwble_init ok rwip_driver_init ok [ble_appm_send_gapm_reset_cmd] tx_pwr_idx:0 enter normal mode !!!!!!init_type=1 llm_init:312 [gapm_cmp_evt_handler] con0x2 0xb8 0x83 0xbd 0xf1 idx:0,operation:0x1,sta0x1c 0x85 0x60 0xa9 0x4tus:0x0 cmd->addr.addrc>addr.addr[5] :0 0x7b[5] :0 !!!!!!init_type !init_type=2 0x66 0x5f=2 [gapm_cmp_evt_handle _cmp_evt_handler] conir] conidx:0,operation:0xdx:0,operation:0x3,stat3,status:0x0 gapm_cmp_us:0x0 0x74 0xd 0x8e evt:GAPM_SET_DEV_CONFIG gapm_cmp_evt:wait GAPM_GEN_RAND_NB [gapm_cmp_evt_handler] conidx:0,operation:0x1a,status:0x0 gapm_cmp_evt:GAPM_GEN_RAND_NB [gapm_cmp_evt_handler] conidx:0,operation:0x1a,status:0x0 gapm_cmp_evt:GAPM_GEN_RAND_NB [gapm_cmp_evt_handler] conidx:0,operation:0x28,status:0x0 gapm_cmp_evt:BLE_STACK_OK [PLATFORM NOTICE]STACK INIT OK ble create new db ble_env->start_hdl = 0x10 [PLATFORM NOTICE]CREATE DB SUCCESS [PLATFORM DEBUG]!!!!!!!!!!tuya_os_adapt_bt_reset_adv [PLATFORM NOTICE]!!!!!!!!!!tuya_before_netcfg_cb [appm_create_advertising] [ble_appm_create_advertising] adv_state:1 [gapm_c[01-01 18:12:15 TUYA Erm8:12:15 TUYA Err][lr:0r][lr:0xbfc27] create_fxbfc27] create_flash_halash_hand_and_init err 6nd_and_init err 6 [01-01 18:12:15 TUYA Err]adv_actv_idx:0,tx_pwr:0[lr:0xc2317] db init fa [PLATFORM DEBUG]UNKNOils -1 [01-01 18:12:15Wrr][lr:0xa395d] db ini TUYA Err][lr:0xa395d] t fails -1 [gapm_cmp_evdon:0xa0,status:0x0 t_handler] conidx:0,operation:0xa0,status:0x0 [appm_adv_fsm_next] cur adv_state:1 adv_state:2 [ble_appm_set_adv_data]set data:02:01:06:03:02:01:a2:04:16:01:a2:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00 [appm_set_adv_data]ret:0 end adv_state:2 [PLATFORM DEBUG]UNKNOW EVENT:16 [gapm_cmp_evt_handler] conidx:0,operation:0xa9,status:0x0 [appm_adv_fsm_next] cur adv_state:2 [appm_set_scan_rsp_data] adv_state:3 [ble_appm_set_scan_rsp_data] end adv_state:3 [PLATFORM DEBUG]UNKNOW EVENT:16 [gapm_cmp_evt_handler] conidx:0,operation:0xaa,status:0x0 [appm_adv_fsm_next] cur adv_state:3 [appm_start_advertising_cmd] adv_state:6 [ble_appm_start_advertising] end adv_state:6 [PLATFORM DEBUG]UNKNOW EVENT:16 [gapm_cmp_evt_handler] conidx:0,operation:0xa4,status:0x0 [appm_adv_fsm_next] cur adv_state:6 adv_state:7 end adv_state:7 [PLATFORM DEBUG]UNKNOW EVENT:16 bandgap_calm_in_efuse=0x36 [load]bandgap_calm=0x36->0x16,vddig=4->5 [FUNC]rwnxl_init [bk]tx_txdesc_flush [FUNC]intc_init [FUNC]calibration_main gpio_level=0,txpwr_state=0 user define rfcali mode:0 get rfcali_mode:0 [09:41:12.849]ÊÕ¡û¡ôrate=54,channel=1,tssi_thred=0x7d,tssi_offset=0x4c3,index=39 fit n20 tab with dist:4 rate=54,channel=7,tssi_thred=0x7d,tssi_offset=0x4c3,index=38 fit n20 tab with dist:4 rate=54,channel=13,tssi_thred=0x7d,tssi_offset=0x4c3,index=42 fit n20 tab with dist:4 rate=11,channel=1,tssi_thred=0xd0,tssi_offset=0x4c3,index=20 rate=11,channel=7,tssi_thred=0xd0,tssi_offset=0x4c3,index=19 rate=11,channel=13,tssi_thred=0xd0,tssi_offset=0x4c3,index=21 txpwr table for ble ch0/19/39 inused 0x7 [09:41:12.959]ÊÕ¡û¡ôcalibration_main over temp in flash is:350 xtal in flash is:12 xtal_cali:12 --init_xtal = 12 [FUNC]ps_init [FUNC]func_init_extended OVER!!! start_type:0 Version: Initializing TCP/IP stack tcp_port:62642 app_init finished [01-01 18:12:15 TUYA Err][lr:0xc2285] kvs_read fails gw_wsm -1 [01-01 18:12:15 TUYA Err][lr:0x95b69] gw_wsm read fail:-18 [01-01 18:12:15 TUYA Err][lr:0xc2285] kvs_read fails gw_bi -1 [PLATFORM NOTICE]bk_rst:0 tuya_rst:0 [01-01 18:12:15 TUYA Err][lr:0xc2285] kvs_read fails gw_bi -1 [01-01 18:12:15 TUYA Err][lr:0x99ae7] base read fail:-6914 [01-01 18:12:15 TUYA Err][lr:0x9a42b] ERR_EXIT is Jumped! [01-01 18:12:15 TUYA Err][lr:0x58a57] tuya_iot_wf_soc_dev_init fail,fail_num:-6914 [01-01 18:12:15 TUYA Err][lr:0x57f81] ret:-6914 [09:41:13.962]ÊÕ¡û¡ôtemperature_type=2 do td cur_t:340--last:idx:13,t:350 -- new:idx:14,t:340 --0xc:00, shift_b:0, shift_g:0, X:-1 init_xtal:12, delta:-1, last_xtal:12 [09:41:21.103]ÊÕ¡û¡ô =========Reset Factory!!!!!!!!!!!!!!! ============>Reset Factory = -1 [09:41:24.943]ÊÕ¡û¡ô =========Reset Factory!!!!!!!!!!!!!!! ============>Reset Factory = -1 [09:41:28.043]ÊÕ¡û¡ô =========Reset Factory!!!!!!!!!!!!!!! ============>Reset Factory = -1
