                         DRAM:  ********Hello RTOS********
version : RTOS UP
open-version : RTOS 3.3.6
build data : Jul  7 2
RTOS # Mount procfs finished.
Spi Nor ID:0xEF 0x60 0x17 0x00 0x00 0x00 0x00 0x00
Spi is locked. lock address[0 => 0x80000]
Spi Nor Flash Info:
Name:"W25Q64FW" Size:8MB Block:64KB
******** usb_init in **********
usb v3.05 2019-10-22 09:32
XHCI: 64 bytes context size, 32-bit DMA
usbus0: 5.0Gbps Super Speed USB v3.0
******** usb_init ok**********
Vendor Watchdog Timer: 0.01 initialized. default_margin=60 sec (nodeamon= 0)
wtdg init ok. ver=Mar 29 2022, 01:09:21.
system will config syslink gpio mux.
PDT_ENXUN_DOORBELL
uhub0: <vendor 0x0000 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
received boot int,len:4,msg:pir
hisyslink sucess!
level: 3, bp_level_max: 7
==== online_flag=1, cmos_yuv_flag=0, sensor=gc2053, chip=gk7202v300, board=demo board====
==== g_quick_start_flag=1 ====
sysconfig init success!
osal_proc_mkdir - parent is NULL! proc=0x408c1efc
system will config syslink sdio mux.
<6>Vendor Media Memory Zone Manager
sdhci1: LOSCFG_PLATFORM_GK7202V300 selected
sdhci1-slot1: 50MHz HS 1bit VDD: 3.3V 3.0V VCCQ: 3.3V DRV: BACD DMA non-remoload sys.ko OK!
load region.ko OK!
load vgs.ko OK!
load isp.ko OK !
load vi.ko OK !
load vpss.ko OK!
load vo.ko OK!
load rc.ko OK!
load venc.ko OK!
load chnl.ko OK!
load vedu.ko OK!
load h264e.ko OK!
vableh265e.ko OK!
sdhci1-slot1: Re-tuning count 0 secs, mode 1
[ERROR] sdio_get_func:121: no sdio found!
load jpege.ko OK!
load ive.ko OK!
load aio.ko ....OK!
load ai.ko ....OK!
load ao.ko ....OK!
load aenc.ko ....OK!
load adec.ko ....OK!
load mipi_rx driver successful!
load acodec.ko ....OK!
Mount jffs on nor.
mmc: Probing bus
Mount jffs on nor finished.
enLogLevel= 2, enLogOn=0
lsadc init ok. ver=Mar 29 2022, 01:09:21.
initlializing pwm...
pwm_motor_pulse_interval = 100000
uhub0: 1 port with 1 removable, self powered
mmc: SDIO probe: OK (OCR: 0x10ff8000)
mmc: Current OCR: 0x00300000
mmc: Probing cards
[mmc|WARN] bad CIS address: 0x200, error 0
mmc: Vendor 0x0296 product 0x5347
mmc: Card at relative address 0x0001 added:
mmc:  quirks: 0x0
mmc:  bus: 1bit, 50MHz (high speed timing)
mmc:  Fun0: vendor_id 0x0296, device_id 0x5347, max_block_size 2048 bytes.
mmc: setting transfer rate to 50.000MHz (high speed timing)
mmc: setting bus width to 1 bits high speed timing
[mmc|WARN] bad CIS address: 0x211, error 0
[mmc|WARN] ignore the CISTPL_NULL tuple.
sdio: SDIO card vendor=0x296,device=0x5347
/dev/sdio0-Fun1: vendor_id 0x0296, device_id 0x5347, class WLAN, max_block_size 2048 bytes, 50.0MHz/1bit.
semMCreate, opt = 9
GC2053_SENSOR_1080P_30FPS_LINEAR_MODE
AudioDet Sens: 3
----------------soundDetectInit: sensitivity[98]
rtc init ok. ver=May 31 2021, 18:04:46.
umass0: <Generic Flash Card ReaderWriter, class 0/0, rev 2.00/1.00, addr 1> on usbus0
umass0:  SCSI over Bulk-Only; quirks = 0x4001
umass_geometry sc->info.sectorsize=512
disk_init : register /dev/sda ok!
DiskAddPart : register /dev/sdap0 ok!
level = 4
los_set_dev_log_on, g_log_level = 6, g_log_enable = 1
[09-27 17:07:54.443 INFO-]:tuyaSetLogLevel[70]:level = 4
[09-27 17:07:54.449 DEBUG-]:setAoVolume[128]:ps32VolumeDb=1, level=8
[09-27 17:07:54.530 DEBUG-]:avcodecPlayAudioFile[276]:/tmp/VOICE/di.wav, file_type=2, audioType = 102 ext:.wav..
[09-27 17:07:54.534 DEBUG-]:avcodecPlayAudioFile[305]:start /tmp/VOICE/di.wav, file_type=0, audioType = 100..
<09-27 17:07:54.8198> _cache_snapshot, clock_gettime  end time:1421 ms
[09-27 17:07:54.841 DEBUG-]:getThumbnailJpegData[329]:0xff, 0xd8, 0xff, 0xd9
[09-27 17:07:54.843 DEBUG-]:is_need_generate_image[304]:flag = 0
point:[/mnt/mmc01]
[09-27 17:07:54.850 WARN-]:eye_burn_uid[557]:get directory stat error, /mnt/mmc01/eyeconf
[09-27 17:07:54.859 DEBUG-]:checkFSRWTest[190]:init success
[09-27 17:07:54.865 INFO-]:ptzCtrlInit[183]:ptz_init isSupportPTZ:0
[09-27 17:07:54.872 DEBUG-]:HI_LED_RunSetEnalbe[29]:enable = 1
[09-27 17:07:54.877 DEBUG-]:PDT_INIT_SERVICE_GetInitStateMode[793]:deviceBindFlag = 1, powerOnType=0, longalive = 0
power on type: 0 battery status: 0 battery: 0, usb:0
PIR:0,REMOTE:1,KEY:2,USB:3,RTC WAKEUP:4,ELECTRY:5,LONGALIVE:6,NORMAL:7,DROPLINE:8,RING KEY:9,WIFI KEY:10
[09-27 17:07:54.902 INFO-]:PDT_INIT_SERVICE_Start[926]:state initmode: 1 arg: 3
[09-27 17:07:54.911 DEBUG-]:PDT_STATEMNG_ActivateHFSM[180]:init state: Wakeup
lib record 20190629
[09-27 17:07:54.922 DEBUG-]:PDT_STATEMNG_BASE_StateEnter[29]:MountLocalPartitions......
stat /dev/sda................. ok
try mount t=vfat dev=/dev/sda mp=/mnt/mmc01/0...[09-27 17:07:54.936 DEBUG-]:PDT_STATEMNG_WAKEUP_StateEnter[364]:...ok
[09-27 17:07:54.939 DEBUG-]:PDT_WIFI_CONNET[86]:enOnlineType = 3
local_create_root, root_path = /mnt/mmc01/0
 start ...
num of local partions: 1
[09-27 17:07:54.962 DEBUG-]:PDT_STATEMNG_CreateAliveTimer[256]:check /mnt/mmc01/0/DUMPLOG
[09-27 17:07:54.964 DEBUG-]:HI_PDT_WIFI_Init[486]:u32StandyTimeMs = 20000
[09-27 17:07:54.972 DEBUG-]:recInit[343]: start ...
-------------->init sd record, buffer is 1024KB
[09-27 17:07:54.988 DEBUG-]:PDT_WIFI_InitHal[345]:*libmyRecord.a, reversion: 1002
wifiStatus=1, resume=1
[09-27 17:07:54.996 DEBUG-]:doSdRecMode[417]:[09-27 17:07:54.996 DEBUG-]:PDT_INIT_SERVICE_MonitorTimerProc[673]:RecordThread, start ..
doSdRecMode mode:0
iReverse:0, ircut_cfg_reverse:0
[09-27 17:07:55.008 DEBUG-]:HI_HAL_WIFI_Init[97]:HI_HAL_WIFI_Init resume -- [1] !
[09-27 17:07:55.019 DEBUG-]:creatSdRecordThead[313]:[09-27 17:07:55.019 DEBUG-]:sdRecordTask[352]:0, IsStorageReady() = 1, recordMode=0
sd record init ok.
[09-27 17:07:55.031 INFO-]:HI_HAL_WIFI_Init[99]:already Init
 [09-27 17:07:55.041 INFO-]:los_start_get_cache_frame[467]: fifo data start call
[09-27 17:07:55.050 DEBUG-]:usrAppEntry[605]:0, IsStorageReady() = 1, p_devcfg_param->recordMode=0
[09-27 17:07:55.059 DEBUG-]:usrAppEntry[703]:--------------SONG TOOL INIT------------
[09-27 17:07:55.067 DEBUG-]:HI_HAL_WIFI_GetMacAddr[163]:macAddr = 703a2d3635b1
<09-27 17:07:55.0716> [start post fifo data], clock_gettime  end time:1672 ms
create the queue success [3]!
lib ctp. v20190625
fdUdp=256
CTP Server Started at  8001
[09-27 17:07:55.086 DEBUG-]:usrAppEntry[761]:[09-27 17:07:55.087 INFO-]:los_get_frame_thread[136]:-------b_dev_app_started, system_version = 9.0.14(3.2.20)
 first fifo data pts=997
chan=0, Len=  15134, pts=1004
vfbuffer_put_frame, ******* first pts = 1004
chan=1, Len=   6942, pts=1004
TUYA Start Init!![09-27 17:07:55.117 INFO-]:IPC_APP_set_watermark_onoff[274]:set watermark_on_off:1
[09-27 17:07:55.126 DEBUG-]:__tuya_app_write_INT[111]:write INT exc: /home/tuya.cfgs/tuya_watermark_onoff value:1
[09-27 17:07:55.136 INFO-]:IPC_APP_set_alarm_function_onoff[366]:set alarm_on_off:1
[09-27 17:07:55.145 DEBUG-]:__tuya_app_write_INT[111]:write INT exc: /home/tuya.cfgs/tuya_alarm_on_off value:1
[09-27 17:07:55.155 INFO-]:IPC_APP_Init_SDK[151]:SDK Version:<TUYA IPC SDK V:4.8.9 >
< TUYA IOT SDK V:4.1.1 BS:30.01_PT:2.2_LAN:3.3_CAD:1.0.1_CD:1.0.0 >
IPC DEFS < ENABLE_ECHO_SHOW:0 ENABLE_CHROMECAST:0 ENABLE_CLOUD_STORAGE:1 >'
< BUILD AT:2021_10_15_20_53_26 BY dongxk FOR liteos_wifi_wired_fs AT liteos-1-1-2 >
TUYA pid = ejveurwimrhw5tjf
uuid = exsm23dcd7c6e1809ed0
key = 2YxdssXDZgfvE7tm8yT7g25joCpK51Ja
DisallowRecord, join thd_record
[09-27 17:07:55.196 DEBUG-]:IPC_APP_Init_SDK[192]:Init Value.storage_path /home/
[09-27 17:07:55.203 DEBUG-]:IPC_APP_Init_SDK[193]:Init Value.upgrade_file_path /tmp/firmware.bin
[09-27 17:07:55.214 DEBUG-]:IPC_APP_Init_SDK[194]:Init Value.sd_base_path /mnt/mmc01/0
[09-27 17:07:55.219 DEBUG-]:IPC_APP_Init_SDK[195]:Init Value.product_key ejveurwimrhw5tjf
[09-27 17:07:55.227 DEBUG-]:IPC_APP_Init_SDK[196]:Init Value.uuid exsm23dcd7c6e1809ed0
[09-27 17:07:55.234 DEBUG-]:IPC_APP_Init_SDK[197]:Init Value.auth_key 2YxdssXDZgfvE7tm8yT7g25joCpK51Ja
[09-27 17:07:55.244 DEBUG-]:IPC_APP_Init_SDK[198]:Init Value.p2p_id
[09-27 17:07:55.250 DEBUG-]:IPC_APP_Init_SDK[199]:Init Value.dev_sw_version 9.0.14
[09-27 17:07:55.257 DEBUG-]:IPC_APP_Init_SDK[200]:Init Value.max_p2p_user 2
Dbg:channel_enable:1 1 0
Dbg:fps:10
Dbg:gop:20
Dbg:bitrate:1024 kbps
Dbg:video_main_width:1920
Dbg:video_main_height:1080
Dbg:video_freq:90000
Dbg:video_codec:4
Dbg:audio_codec:106
Dbg:audio_sample:8000
Dbg:audio_databits:16
Dbg:audio_channel:0
Dbg:init ring buffer Channel:0 Enable:1
Dbg:video_bitrate 1024, video_fps 10
Dbg:init ring buffer success. channel:0
Dbg:init ring buffer Channel:1 Enable:1
Dbg:video_bitrate 512, video_fps 10
Dbg:init ring buffer success. channel:1
Dbg:init ring buffer Channel:2 Enable:0
Dbg:init ring buffer Channel:3 Enable:0
Dbg:init ring buffer Channel:4 Enable:0
Dbg:init ring buffer Channel:5 Enable:0
Dbg:init ring buffer Channel:6 Enable:0
Dbg:init ring buffer Channel:7 Enable:0
Dbg:init ring buffer Channel:8 Enable:0
Dbg:init ring buffer Channel:9 Enable:1
Dbg:AUDIO audio_sample 8000, audio_databits 16, audio_fps 25
Dbg:init ring buffer success. channel:9
Dbg:init ring buffer Channel:10 Enable:0
Dbg:init ring buffer Channel:11 Enable:0
Dbg:init ring buffer Channel:12 Enable:0
Dbg:init ring buffer Channel:13 Enable:0
Dbg:init ring buffer Channel:14 Enable:0
Dbg:init ring buffer Channel:15 Enable:0
[09-27 17:07:55.372 DEBUG-]:IPC_APP_Notify_LED_Sound_Status_CB[129]:curr event:0
static dns for h2.iot-dns.com
num 1: a20e0e92
num 2: 379f4d6
num 3: 12c32cf7
num 4: 378a63b
num 8: 3419a69b
num 9: 22d691ec
num 10: 239ba6d6
num 14: 3419a69b
num 15: 22d691ec
[01-01 18:12:15:0 TUYA Debug][tuya_iot_com_api.c:96] init fs. Path: /home/
[01-01 18:12:15:7 TUYA Info][kv_storge.c:43] Init Kvs With File:/home/
[01-01 18:12:15:13 TUYA Debug][simplekv.c:916] path:/home/
[01-01 18:12:15:20 TUYA Debug][simplekv.c:952] get encrypt_key[帏h橵4~蹻DV]
[01-01 18:12:15:26 TUYA Debug][simplekv.c:983] both file exist
[01-01 18:12:15:32 TUYA Debug][simplekv.c:280] size in: 0 and final: 28700 And mag_rec_max: 512
[01-01 18:12:15:40 TUYA Debug][simplekv.c:295] create data hd success
[01-01 18:12:15:46 TUYA Debug][simplekv.c:1026] read from normal file
[01-01 18:12:15:53 TUYA Debug][simplekv.c:736] curr db is V2. No need to upgrade
record thread terminated.
[09-27 17:07:55.458 DEBUG-]:check_record_status[270]:[01-01 18:12:15:65 TUYA Debug][simplekv.c:526] head check success
[09-27 17:07:55.461 INFO-]:PDT_IVA_DetectResultProc[185]:set_time_for_start_record
 human was detected !. curTime: 2061
[01-01 18:12:15:85 TUYA Debug][simplekv.c:629] read and check head success
 first smd frame detected after:1408 ms.
[01-01 18:12:15:99 TUYA Debug][simplekv.c:1041] read from normal file success
[09-27 17:07:55.501 DEBUG-]:eventStartRecord[174]:[01-01 18:12:15:106 TUYA Debug][uni_thread.c:161] Init Thread Del Mgr
evn = 2, s = 20
[01-01 18:12:15:118 TUYA Debug][simplekv.c:1079] init from normal file success.
isAlarm:1, 2114 - 653 -> 4000
[09-27 17:07:55.523 DEBUG-]:PDT_IVP_ProcThread[501]:VIP exit
[09-27 17:07:55.530 INFO-]:PDT_IVP_Stop[573]:Wait Ivp thread exit .
[09-27 17:07:55.535 INFO-]:PDT_IVP_Stop[575]:Ivp thread exit ok.
[01-01 18:12:15:144 TUYA Debug][uni_thread.c:220] Thread:sys_timer Exec Start. Set to Running Status
[09-27 17:07:55.551 DEBUG-]:PDT_IVABASE_StopDebugVenc[328]: Debug venc not enabled .!
[09-27 17:07:55.558 INFO-]:PDT_IVP_Stop[590]:Ivp has been stopped successfully.
[09-27 17:07:55.566 INFO-]:PDT_IVP_ProcThread[508]: PDT_IVP_Proc thread exit.
[01-01 18:12:15:174 TUYA Debug][sys_timer.c:63] system timer has been inited
[01-01 18:12:15:187 TUYA Debug][sys_timer.c:34] system timer process run.
[01-01 18:12:15:194 TUYA Debug][sys_timer.c:63] system timer has been inited
[01-01 18:12:15:201 TUYA Debug][sys_timer.c:63] system timer has been inited
[01-01 18:12:15:209 TUYA Debug][online_log_serv.c:340] read from uf. max:1 first:0 last:0
[01-01 18:12:15:218 TUYA Debug][uni_thread.c:220] Thread:cmmod Exec Start. Set to Running Status
[01-01 18:12:15:224 TUYA Debug][online_log_serv.c:581] log serv init success
[01-01 18:12:15:231 TUYA Debug][ty_work_queue.c:22] init work queue. stack size:2560 pro:3 num:2
[01-01 18:12:15:240 TUYA Debug][ty_work_queue.c:27] ty work queue create success
 tuya log switch:0, level:6, path:null
Set Country Code:CN
unm_set_dns_cache_priority ->0
unm_set_dns_region 1
unw_add_dns_cache [http://a.tuyacn.com/d.json]<->[717232600]
unw_add_dns_cache [https://a2.tuyacn.com/d.json]<->[717233956]
unw_add_dns_cache [m2.tuyacn.com]<->[717234005]
unw_add_dns_cache [baal.tuyacn.com]<->[717235052]
[09-27 17:07:55.679 DEBUG-]:los_notify_device_standby[123]:g_notify_standby = 1
WIFI Set Mode 2
[09-27 17:07:55.686 DEBUG-]:IPC_APP_Notify_LED_Sound_Status_CB[129]:[09-27 17:07:55.686 INFO-]:PDT_AliveTimerReStart[290]:curr event:3
u32MaxAliveMs = 20000[20000]
Already in status 0
[09-27 17:07:55.701 DEBUG-]:getTimeZone[418]:[09-27 17:07:55.703 DEBUG-]:__IPC_APP_Get_Net_Status_cb[109]:getTimeZone fd 41, tz = 28800
Net status change to:3[09-27 17:07:55.717 DEBUG-]:tuya_device_set_sdk_rtc_time[332]:utc = 1664269675 [+08:00]
Dbg:Init Stream_Storage SD:/mnt/mmc01/0
TUYA_APP_Init_Stream_Storage 2
unw_gethostbyname m2.tuyacn.com, prio 0
read int exc: /home/tuya.cfgs/tuya_sd_record_mode
match_region 1
[09-27 17:07:55:16 TUYA Err][tuya_ipc_stream_storage.c:1498] storage not inited
use dynamic dns ip 717234005 for domain m2.tuyacn.com
[09-27 17:07:55.753 DEBUG-]:is_adjust_sys_time[286]:_tm->tm_year = 122, is_time_sync= 1
[09-27 17:07:55.761 DEBUG-]:getTimeZone[418]:getTimeZone fd 42, tz = 28800
[09-27 17:07:55.767 DEBUG-]:tuya_device_set_sdk_rtc_time[332]:utc = 1664269675 [+08:00]
[09-27 17:07:55:54 TUYA Err][tuya_ipc_stream_storage.c:1575] stream storage is inited already 1
Err:Init Main Video Stream_Storage Fail. -1
[09-27 17:07:55.791 DEBUG-]:tuya_device_check_offline_record[365]:TUYA_APP_Init_Stream_Storage, ret = -1.
[09-27 17:07:55:77 TUYA Err][tuya_ipc_video_msg.c:686] init video msg success
[09-27 17:07:55.808 INFO-]:TUYA_APP_Enable_P2PTransfer[400]:Init P2P With Max Users:2[09-27 17:07:55.810 DEBUG-]:tuya_offline_record_func[348]:cur_clock = 2411, sleep_time = 3589
P2P API Version: 244.3.3.1
tuya p2p rtc sdk version: 0xf4030301, Oct 15 2021 11:43:39
tuya liteos uv
[09-27 17:07:55:208 TUYA Err][tuya_ipc_p2p.c:4762] p2p v3 init ok
tuya liteos uv
watcher add 263, nfds 1
mqtt p2p LISTEN session........
2551 INFO  src/tuya_rtc.c:5562: try listen
unw_gethostbyname a2.tuyacn.com, prio 0
match_region 1
use dynamic dns ip 717233956 for domain a2.tuyacn.com
[09-27 17:07:56.040 DEBUG-]:HI_HAL_WIFI_StartSTA[392]:success to start sta[09-27 17:07:56.041 DEBUG-]:HI_PDT_WIFI_Connect[545]:connectAttr->sync = 0, reconnetTimes = 2
[09-27 17:07:56.439 DEBUG-]:los_put_frame_cahce[448]:4 chan=0, mt=3, Len=  17095, pts=3004, isKeyFrame=1
[09-27 17:07:56.506 DEBUG-]:los_put_frame_cahce[448]:5 chan=1, mt=0, Len=  10674, pts=3071, isKeyFrame=1
[09-27 17:07:57.050 DEBUG-]:PDT_WIFI_STAInit[381]:PDT_WIFI_STAInit
[09-27 17:07:57.051 DEBUG-]:PDT_WIFI_STAStart[365]:resume = 1, g_standbyMode = 1
[09-27 17:07:57.060 DEBUG-]:PDT_WIFI_STAConnect[407]:connetStatus = 1
[09-27 17:07:57.067 DEBUG-]:PDT_WIFI_HalEventCallback[91]:eventId = 0
[09-27 17:07:57.074 DEBUG-]:PDT_WIFI_AsyncConnectThrd[447]:PDT_WIFI_STAInit ret = 0
[09-27 17:07:57.082 DEBUG-]:PDT_WIFI_AsyncConnectThrd[462]:wifi connect thread exit
[09-27 17:07:57.094 DEBUG-]:PDT_STATEMNG_EventProc[240]:Get 273448960 EVENT from eventhub.
[09-27 17:07:57.098 DEBUG-]:PDT_STATEMNG_WAKEUP_StateMsgProc[488]:state:Wakeup handle message what(104c8000)
[09-27 17:07:57.108 DEBUG-]:PDT_STATEMNG_WAKEUP_StateMsgProc[492]:0, pstMsg->what=0x104c8000
[09-27 17:07:59.400 INFO-]:los_start_get_cache_frame[467]: fifo data start call
[09-27 17:07:59.402 INFO-]:los_wakeup_check_record[703]:online:0, pd mode:open, record_time:20
[09-27 17:07:59.412 DEBUG-]:los_wakeup_check_record[705]:online = 0, evt_type = 1
[09-27 17:07:59.419 DEBUG-]:los_wakeup_check_record[713]:g_bStartRecordPdMode = 1
isAlarm:1, 6027 - 653 -> 4000
[09-27 17:07:59.429 DEBUG-]:los_wakeup_check_record[718]:human_alarm = 1, isDetectFinish = 1
[09-27 17:07:59.442 INFO-]:tuyaSetLogLevel[70]:level = 4
hi_los_set_record_status recording = 1[20]
PIR HUMAN OFFLINE RECORD
[09-27 17:07:59.454 INFO-]:tuyaHumanDetect[659]:=====================> record start.
[09-27 17:07:58:738 TUYA Err][tuya_ipc_stream_storage.c:1703] the ss mgr not inited
[09-27 17:07:59.471 INFO-]:los_get_cached_snapshot[582]:cache_snapshot get jpg size = 15561锛buffer len=15561
[09-27 17:07:58:756 TUYA Err][tuya_ipc_cloud_storage.c:1881] cloud storage not inited
read int exc: /home/tuya.cfgs/tuya_alarm_on_off
[09-27 17:07:59.494 INFO-]:IPC_APP_get_alarm_function_onoff[377]:curr alarm_on_off:1
[09-27 17:07:59.502 INFO-]:tuyaHumanDetect[680]:------>tuya_ipc_notify_with_event start push human msg.
match_region 1
[09-27 17:08:06.166 DEBUG-]:PDT_SYSLINK_PowerInfo[448]:batStatu:1, usb:1, batCapacity:49
[09-27 17:08:15.840 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:08:21.040 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:08:21.045 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:08:25.850 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:08:25.855 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:08:31.060 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:08:31.065 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:08:35.871 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:08:35.877 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:08:40.980 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:08:40.985 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:08:46.091 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:08:46.096 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:08:50.000 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:08:51.005 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:08:56.110 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:08:56.115 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:08:58:247 TUYA Err][mqtt_client.c:1175] mqtt socket connect fail. retry_cnt:0 op_ret:-703 errno:-24
[09-27 17:08:58.976 DEBUG-]:__IPC_APP_Get_Net_Status_cb[109]:Net status change to:6[09-27 17:08:58:259 TUYA Err][smart_frame.c:1297] mqtt async send fail -916
[09-27 17:08:58:265 TUYA Err][tuya_iot_com_api.c:751] dp report async fail.ret:-916
read int exc: /home/tuya.cfgs/tuya_sd_record_on_off
[09-27 17:08:58:446 TUYA Err][httpc.c:485] tcp connect failed a2.tuyacn.com:443 errno=110
unm_lower_dns_cache_priority ->2
[09-27 17:08:58:502 TUYA Err][http_inf.c:47] Open session failed: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c3397649a01b47a98fcff&et=1&t=1664269675&v=1.0&sign=fe28a9e8a5c8c21b5b11d596a4bc5f2d (-7)
[09-27 17:08:58:521 TUYA Err][iot_httpc.c:907] Post Data Return Fail.-706
unm_lower_dns_cache_priority ->0
clear all dynamic dns
match_region 1
use tuya dns service to get ip for domain m2.tuyacn.com
unw_gethostbyname h2.iot-dns.com, prio 0
match_region 1
use static dns ip -1576137070 for domain h2.iot-dns.com
[09-27 17:09:01.020 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:09:01.025 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:09:01:846 TUYA Err][httpc.c:485] tcp connect failed a2.tuyacn.com:443 errno=110
[09-27 17:09:01:855 TUYA Err][http_inf.c:47] Open session failed: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c3397649a01b47a98fcff&et=1&t=1664269678&v=3.0&sign=1fb1d2d03a11a9ee6710244ef0e3d4a9 (-7)
[09-27 17:09:01:872 TUYA Err][iot_httpc.c:907] Post Data Return Fail.-706
[09-27 17:09:01:880 TUYA Err][tuya_ipc_notification.c:570] cloud_get_detect_storage_config fail, ret -706
[09-27 17:09:01:889 TUYA Err][tuya_ipc_notification.c:704] notification_content_upload_from_buffer init failed:-706
unw_gethostbyname a2.tuyacn.com, prio 2
[09-27 17:09:05.930 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:09:05.935 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:09:06.170 DEBUG-]:PDT_SYSLINK_PowerInfo[448]:batStatu:1, usb:1, batCapacity:49
[09-27 17:09:11.040 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:09:11.045 INFO-]:hi_los_is_readby_standby[151]:device recording
unm_reset_dns_cache_priority ->0
fail to gethostbyname 110
[09-27 17:09:11:56 TUYA Err][httpc.c:404] No entry for host a2.tuyacn.com found
[09-27 17:09:11:63 TUYA Err][httpc.c:476] Socket creation for a2.tuyacn.com:443 failed
[09-27 17:09:11:73 TUYA Err][http_inf.c:47] Open session failed: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c3397649a01b47a98fcff&et=1&t=1664269741&v=3.0&sign=92eeb0af10a64980791f32c0fed0b2a0 (-2)
[09-27 17:09:11:93 TUYA Err][iot_httpc.c:907] Post Data Return Fail.-706
[09-27 17:09:11:100 TUYA Err][tuya_ipc_notification.c:570] cloud_get_detect_storage_config fail, ret -706
[09-27 17:09:11:109 TUYA Err][tuya_ipc_notification.c:704] notification_content_upload_from_buffer init failed:-706
[09-27 17:09:15.850 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:09:15.855 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:09:21.060 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:09:21.065 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:09:21:56 TUYA Err][httpc.c:404] No entry for host a2.tuyacn.com found
[09-27 17:09:21:63 TUYA Err][httpc.c:476] Socket creation for a2.tuyacn.com:443 failed
[09-27 17:09:21:73 TUYA Err][http_inf.c:47] Open session failed: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c3397649a01b47a98fcff&et=1&t=1664269751&v=3.0&sign=16b295dcee55ffddc614cd7c25a8b19b (-2)
[09-27 17:09:21:93 TUYA Err][iot_httpc.c:907] Post Data Return Fail.-706
[09-27 17:09:21:100 TUYA Err][tuya_ipc_notification.c:570] cloud_get_detect_storage_config fail, ret -706
[09-27 17:09:21:109 TUYA Err][tuya_ipc_notification.c:704] notification_content_upload_from_buffer init failed:-706
[09-27 17:09:21.844 INFO-]:los_start_get_cache_frame[467]: fifo data start call
[09-27 17:09:23:866 TUYA Err][app_agent.c:2017] unsupport frame type:64
[09-27 17:09:25.871 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:09:25.877 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:09:30.980 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:09:30.985 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:09:36.091 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:09:36.096 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:09:41.000 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 17:09:41.005 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 17:09:41:129 TUYA Err][tuya_ipc_stream_storage.c:1693] No event on going now
[09-27 17:09:41:130 TUYA Err][tuya_ipc_cloud_storage.c:1952] cloud storage not inited
[09-27 17:09:41:138 TUYA Err][tuya_ipc_cloud_storage.c:2066] cloud storage not inited
[09-27 17:09:41.871 INFO-]:tuyaHumanDetect[694]:=====================> record stop, retVal = 3
hi_los_set_record_status recording = 0[20]
[09-27 17:09:46.110 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
tuya_get_standby_mask, g_TuyaStandbyMask = [0]
[09-27 17:09:45:395 TUYA Err][tuya_ipc_p2p.c:5207] input param error
is_tuya_can_standby, user = 0
[2022-09-27 17:09:46] [PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc] standy now.
[09-27 17:09:46.137 DEBUG-]:PDT_STATEMNG_WAKEUP_StateMsgProc[488]:state:Wakeup handle message what(104c1002)
[09-27 17:09:46.147 DEBUG-]:PDT_STATEMNG_BASE_StateMsgProc[46]: will process message what(104c1002)
[09-27 17:09:46.150 DEBUG-]:PDT_STATEMNG_EventProc[240]:Get 273444864 EVENT from eventhub.
MSG_INNER_STATEMNG_STANDBY [0x104c1002]
PDT_STATEMNG_WAKEUP_StateExit
[09-27 17:09:46.173 DEBUG-]:PDT_STATEMNG_STANDBY_StateEnter[80]:PDT_STATEMNG_STANDBY_StateEnter ..
[09-27 17:09:46.182 DEBUG-]:PDT_STATEMNG_STANDBY_StateMsgProc[114]: will process message what(104c7000)
00, p2p offline
point:[/mnt/mmc01/0]
[09-27 17:09:46.196 DEBUG-]:PDT_WIFI_Standby[692]:Standby directly.
[09-27 17:09:46.202 DEBUG-]:PDT_SYSLINK_Soc2Wifi_StopKeepalvie[165]:HI_PDT_SOC_TO_WIFI_STOP_KEEPALIVE
[09-27 17:09:46.210 INFO-]:PDT_WIFI_Standby[658]:soc is sleeping
base64_encode devid:x7WQQQ0sEdgs51lJn/UOHZWLVoGGLjCoNRDYp5+uqWM=, b64EnLen = 44
devid:time:random -->> x7WQQQ0sEdgs51lJn/UOHZWLVoGGLjCoNRDYp5+uqWM=:1664269786:kiUMZkkWOnjPhP2qIwZUV9caFXHqWu2S
        "type": 1,
        "method":       1,
        "authorization":        "time=1664269786,random=kiUMZkkWOnjPhP2qIwZUV9caFXHqWu2S",
        "signature":    "QUBcZplW8ln1MwsrcI0bDcQCaF1nFKXdSjEfS5GQeyM="
}[167]
[09-27 17:09:47.240 DEBUG-]:HI_PDT_SYSTEM_SetKeepaliveAuth[561]:isAuth:1, AuthType:3
[09-27 17:09:47.242 DEBUG-]:HAL_WIFI_SetNetPattern[44]:not open NetPattern
[09-27 17:09:47.249 WARN-]:HI_HAL_WIFI_STAStandby[155]:HAL_WIFI_SetNetPattern failed
[09-27 17:09:47.257 DEBUG-]:HAL_WIFI_SetKeepAlive[78]:not open keepAlive
[09-27 17:09:47.264 WARN-]:HI_HAL_WIFI_STAStandby[161]:HAL_WIFI_SetKeepAlive failed
[09-27 17:09:47.272 FATAL-]:AJ_LOG_FileClose[370]:close log file
no support upload log
HI_PDT_SOC_TO_WIFI_SYSTEM_STANDBY
received deinit camera msg from mcu ...
[09-27 17:09:46:798 TUYA Err][tuya_ipc_p2p.c:5207] input param error
send soc standby ready msg to mcu.
