DRAM:  ********Hello RTOS********
version : RTOS UP
open-version : RTOS 3.3.6
build data : Jul  7 2
RTOS # Mount procfs finished.
Spi Nor ID:0xEF 0x60 0x17 0x00 0x00 0x00 0x00 0x00
Spi is locked. lock address[0 => 0x80000]
Spi Nor Flash Info:
Name:"W25Q64FW" Size:8MB Block:64KB
******** usb_init in **********
usb v3.05 2019-10-22 09:32
XHCI: 64 bytes context size, 32-bit DMA
usbus0: 5.0Gbps Super Speed USB v3.0
******** usb_init ok**********
Vendor Watchdog Timer: 0.01 initialized. default_margin=60 sec (nodeamon= 0)
wtdg init ok. ver=Mar 29 2022, 01:09:21.
system will config syslink gpio mux.
PDT_ENXUN_DOORBELL
uhub0: <vendor 0x0000 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
received boot int,len:4,msg:pir
hisyslink sucess!
level: 3, bp_level_max: 7
==== online_flag=1, cmos_yuv_flag=0, sensor=gc2053, chip=gk7202v300, board=demo board====
==== g_quick_start_flag=1 ====
sysconfig init success!
osal_proc_mkdir - parent is NULL! proc=0x408c1efc
system will config syslink sdio mux.
<6>Vendor Media Memory Zone Manager
sdhci1: LOSCFG_PLATFORM_GK7202V300 selected
sdhci1-slot1: 50MHz HS 1bit VDD: 3.3V 3.0V VCCQ: 3.3V DRV: BACD DMA non-remoload sys.ko OK!
load region.ko OK!
load vgs.ko OK!
load isp.ko OK !
load vi.ko OK !
load vpss.ko OK!
load vo.ko OK!
load rc.ko OK!
load venc.ko OK!
load chnl.ko OK!
load vedu.ko OK!
load h264e.ko OK!
load h265e.ko OK!
vable
sdhci1-slot1: Re-tuning count 0 secs, mode 1
[ERROR] sdio_get_func:121: no sdio found!
load jpege.ko OK!
load ive.ko OK!
load aio.ko ....OK!
load ai.ko ....OK!
load ao.ko ....OK!
load aenc.ko ....OK!
load adec.ko ....OK!
load mipi_rx driver successful!
load acodec.ko ....OK!
Mount jffs on nor.
mmc: Probing bus
Mount jffs on nor finished.
enLogLevel= 2, enLogOn=0
lsadc init ok. ver=Mar 29 2022, 01:09:21.
initlializing pwm...
pwm_motor_pulse_interval = 100000
uhub0: 1 port with 1 removable, self powered
mmc: SDIO probe: OK (OCR: 0x10ff8000)
mmc: Current OCR: 0x00300000
mmc: Probing cards
[mmc|WARN] bad CIS address: 0x200, error 0
mmc: Vendor 0x0296 product 0x5347
mmc: Card at relative address 0x0001 added:
mmc:  quirks: 0x0
mmc:  bus: 1bit, 50MHz (high speed timing)
mmc:  Fun0: vendor_id 0x0296, device_id 0x5347, max_block_size 2048 bytes.
mmc: setting transfer rate to 50.000MHz (high speed timing)
mmc: setting bus width to 1 bits high speed timing
[mmc|WARN] bad CIS address: 0x211, error 0
[mmc|WARN] ignore the CISTPL_NULL tuple.
sdio: SDIO card vendor=0x296,device=0x5347
/dev/sdio0-Fun1: vendor_id 0x0296, device_id 0x5347, class WLAN, max_block_size 2048 bytes, 50.0MHz/1bit.
semMCreate, opt = 9
GC2053_SENSOR_1080P_30FPS_LINEAR_MODE
AudioDet Sens: 3
----------------soundDetectInit: sensitivity[98]
rtc init ok. ver=May 31 2021, 18:04:46.
umass0: <Generic Flash Card ReaderWriter, class 0/0, rev 2.00/1.00, addr 1> on usbus0
umass0:  SCSI over Bulk-Only; quirks = 0x4001
umass_geometry sc->info.sectorsize=512
disk_init : register /dev/sda ok!
DiskAddPart : register /dev/sdap0 ok!
level = 4
los_set_dev_log_on, g_log_level = 6, g_log_enable = 1
[09-27 15:39:26.444 INFO-]:tuyaSetLogLevel[70]:level = 4
[09-27 15:39:26.450 DEBUG-]:setAoVolume[128]:ps32VolumeDb=1, level=8
[09-27 15:39:26.530 DEBUG-]:avcodecPlayAudioFile[276]:/tmp/VOICE/di.wav, file_type=2, audioType = 102 ext:.wav..
[09-27 15:39:26.534 DEBUG-]:avcodecPlayAudioFile[305]:start /tmp/VOICE/di.wav, file_type=0, audioType = 100..
<09-27 15:39:26.6114> _cache_snapshot, clock_gettime  end time:1403 ms
[09-27 15:39:26.650 DEBUG-]:getThumbnailJpegData[329]:0xff, 0xd8, 0xff, 0xd9
[09-27 15:39:26.840 DEBUG-]:is_need_generate_image[304]:flag = 0
point:[/mnt/mmc01]
[09-27 15:39:26.842 WARN-]:eye_burn_uid[557]:get directory stat error, /mnt/mmc01/eyeconf
[09-27 15:39:26.851 DEBUG-]:checkFSRWTest[190]:init success
[09-27 15:39:26.857 INFO-]:ptzCtrlInit[183]:ptz_init isSupportPTZ:0
[09-27 15:39:26.863 DEBUG-]:HI_LED_RunSetEnalbe[29]:enable = 1
[09-27 15:39:26.869 DEBUG-]:PDT_INIT_SERVICE_GetInitStateMode[793]:deviceBindFlag = 1, powerOnType=0, longalive = 0
power on type: 0 battery status: 0 battery: 0, usb:0
PIR:0,REMOTE:1,KEY:2,USB:3,RTC WAKEUP:4,ELECTRY:5,LONGALIVE:6,NORMAL:7,DROPLINE:8,RING KEY:9,WIFI KEY:10
[09-27 15:39:26.894 INFO-]:PDT_INIT_SERVICE_Start[926]:state initmode: 1 arg: 3
[09-27 15:39:26.904 DEBUG-]:PDT_STATEMNG_ActivateHFSM[180]:init state: Wakeup
lib record 20190629
MountLocalPartitions......
stat /dev/sda................. ok
umass_geometry stry mount t=vfat dev=/dev/sda mp=/mnt/mmc01/0...[09-27 15:39:26.920 DEBUG-]:PDT_STATEMNG_BASE_StateEnter[29]: PDT_STATEMNG_BASE_StateEnter
[09-27 15:39:26.933 DEBUG-]:PDT_STATEMNG_WAKEUP_StateEnter[364]:enOnlic->info.sectorsize=512
neType = 3
[09-27 15:39:26.942 DEBUG-]:PDT_WIFI_CONNET[86]: start ...
...ok
[09-27 15:39:26.948 DEBUG-]:PDT_STATEMNG_CreateAliveTimer[256]:local_create_root, root_path = /mnt/mmc01/0
u32StandyTimeMs = 20000
[09-27 15:39:26.956 DEBUG-]:HI_PDT_WIFI_Init[486]:num of local partions: 1
 start ...
check /mnt/mmc01/0/DUMPLOG
[09-27 15:39:26.973 DEBUG-]:recInit[343]:[09-27 15:39:26.973 DEBUG-]:PDT_WIFI_InitHal[345]:-------------->init sd record, buffer is 1024KB
wifiStatus=1, resume=1
[09-27 15:39:26.985 DEBUG-]:PDT_INIT_SERVICE_MonitorTimerProc[673]:*libmyRecord.a, reversion: 1002
iReverse:0, ircut_cfg_reverse:0
[09-27 15:39:26.994 DEBUG-]:HI_HAL_WIFI_Init[97]:[09-27 15:39:26.997 DEBUG-]:doSdRecMode[417]:RecordThread, start ..
HI_HAL_WIFI_Init resume -- [1] !
doSdRecMode mode:0
[09-27 15:39:27.019 INFO-]:HI_HAL_WIFI_Init[99]:[09-27 15:39:27.019 DEBUG-]:creatSdRecordThead[313]:already Init
 [09-27 15:39:27.019 DEBUG-]:sdRecordTask[352]:0, IsStorageReady() = 1, recordMode=0
sd record init ok.
[09-27 15:39:27.035 INFO-]:los_start_get_cache_frame[467]: fifo data start call
[09-27 15:39:27.043 DEBUG-]:usrAppEntry[605]:0, IsStorageReady() = 1, p_devcfg_param->recordMode=0
[09-27 15:39:27.052 DEBUG-]:usrAppEntry[703]:--------------SONG TOOL INIT------------
[09-27 15:39:27.059 DEBUG-]:HI_HAL_WIFI_GetMacAddr[163]:macAddr = 703a2d370811
<09-27 15:39:27.0595> [start post fifo data], clock_gettime  end time:1851 ms
create the queue success [3]!
lib ctp. v20190625
fdUdp=256
CTP Server Started at  8001
[09-27 15:39:27.079 DEBUG-]:usrAppEntry[761]:[09-27 15:39:27.079 INFO-]:los_get_frame_thread[136]:-------b_dev_app_started, system_version = 9.0.14(3.2.20)
 first fifo data pts=997
chan=0, Len=  12183, pts=1004
vfbuffer_put_frame, ******* first pts = 1004
chan=1, Len=   5126, pts=1004
TUYA Start Init!![09-27 15:39:27.110 INFO-]:IPC_APP_set_watermark_onoff[274]:set watermark_on_off:1
[09-27 15:39:27.120 DEBUG-]:__tuya_app_write_INT[111]:write INT exc: /home/tuya.cfgs/tuya_watermark_onoff value:1
[09-27 15:39:27.134 INFO-]:IPC_APP_set_alarm_function_onoff[366]:set alarm_on_off:1
[09-27 15:39:27.139 DEBUG-]:__tuya_app_write_INT[111]:write INT exc: /home/tuya.cfgs/tuya_alarm_on_off value:1
[09-27 15:39:27.148 INFO-]:IPC_APP_Init_SDK[151]:SDK Version:<TUYA IPC SDK V:4.8.9 >
< TUYA IOT SDK V:4.1.1 BS:30.01_PT:2.2_LAN:3.3_CAD:1.0.1_CD:1.0.0 >
IPC DEFS < ENABLE_ECHO_SHOW:0 ENABLE_CHROMECAST:0 ENABLE_CLOUD_STORAGE:1 >'
< BUILD AT:2021_10_15_20_53_26 BY dongxk FOR liteos_wifi_wired_fs AT liteos-1-1-2 >
DisallowRecord, join thd_record
TUYA pid = ejveurwimrhw5tjf
uuid = exsm21b31c5619b157be
key = mkIUBGMllGrFMJLeLyEvuMs5bEwUNCKD
[09-27 15:39:27.193 DEBUG-]:IPC_APP_Init_SDK[192]:Init Value.storage_path /home/
[09-27 15:39:27.200 DEBUG-]:IPC_APP_Init_SDK[193]:Init Value.upgrade_file_path /tmp/firmware.bin
[09-27 15:39:27.209 DEBUG-]:IPC_APP_Init_SDK[194]:Init Value.sd_base_path /mnt/mmc01/0
[09-27 15:39:27.216 DEBUG-]:IPC_APP_Init_SDK[195]:Init Value.product_key ejveurwimrhw5tjf
[09-27 15:39:27.224 DEBUG-]:IPC_APP_Init_SDK[196]:Init Value.uuid exsm21b31c5619b157be
[09-27 15:39:27.234 DEBUG-]:IPC_APP_Init_SDK[197]:Init Value.auth_key mkIUBGMllGrFMJLeLyEvuMs5bEwUNCKD
[09-27 15:39:27.241 DEBUG-]:IPC_APP_Init_SDK[198]:Init Value.p2p_id
[09-27 15:39:27.247 DEBUG-]:IPC_APP_Init_SDK[199]:Init Value.dev_sw_version 9.0.14
[09-27 15:39:27.254 DEBUG-]:IPC_APP_Init_SDK[200]:Init Value.max_p2p_user 2
Dbg:channel_enable:1 1 0
Dbg:fps:20
Dbg:gop:20
Dbg:bitrate:1024 kbps
Dbg:video_main_width:1920
Dbg:video_main_height:1080
Dbg:video_freq:90000
Dbg:video_codec:4
Dbg:audio_codec:106
Dbg:audio_sample:8000
Dbg:audio_databits:16
Dbg:audio_channel:0
Dbg:init ring buffer Channel:0 Enable:1
Dbg:video_bitrate 1024, video_fps 20
Dbg:init ring buffer success. channel:0
Dbg:init ring buffer Channel:1 Enable:1
Dbg:video_bitrate 512, video_fps 20
Dbg:init ring buffer success. channel:1
Dbg:init ring buffer Channel:2 Enable:0
Dbg:init ring buffer Channel:3 Enable:0
Dbg:init ring buffer Channel:4 Enable:0
Dbg:init ring buffer Channel:5 Enable:0
Dbg:init ring buffer Channel:6 Enable:0
Dbg:init ring buffer Channel:7 Enable:0
Dbg:init ring buffer Channel:8 Enable:0
Dbg:init ring buffer Channel:9 Enable:1
Dbg:AUDIO audio_sample 8000, audio_databits 16, audio_fps 25
Dbg:init ring buffer success. channel:9
Dbg:init ring buffer Channel:10 Enable:0
Dbg:init ring buffer Channel:11 Enable:0
Dbg:init ring buffer Channel:12 Enable:0
Dbg:init ring buffer Channel:13 Enable:0
Dbg:init ring buffer Channel:14 Enable:0
Dbg:init ring buffer Channel:15 Enable:0
[09-27 15:39:27.370 DEBUG-]:IPC_APP_Notify_LED_Sound_Status_CB[129]:curr event:0
static dns for h2.iot-dns.com
num 1: a20e0e92
num 2: 379f4d6
num 3: 12c32cf7
num 4: 378a63b
num 8: 3419a69b
num 9: 22d691ec
num 10: 239ba6d6
num 14: 3419a69b
num 15: 22d691ec
[01-01 18:12:15:0 TUYA Debug][tuya_iot_com_api.c:96] init fs. Path: /home/
[01-01 18:12:15:7 TUYA Info][kv_storge.c:43] Init Kvs With File:/home/
[01-01 18:12:15:13 TUYA Debug][simplekv.c:916] path:/home/
[01-01 18:12:15:19 TUYA Debug][simplekv.c:952] get encrypt_key[帏h橵4~蹻DV]
[01-01 18:12:15:27 TUYA Debug][simplekv.c:983] both file exist
[01-01 18:12:15:32 TUYA Debug][simplekv.c:280] size in: 0 and final: 28700 And mag_rec_max: 512
[01-01 18:12:15:41 TUYA Debug][simplekv.c:295] create data hd success
[01-01 18:12:15:47 TUYA Debug][simplekv.c:1026] read from normal file
[01-01 18:12:15:54 TUYA Debug][simplekv.c:736] curr db is V2. No need to upgrade
record thread terminated.
[09-27 15:39:27.455 DEBUG-]:check_record_status[270]:[01-01 18:12:15:64 TUYA Debug][simplekv.c:526] head check success
set_time_for_start_record
[01-01 18:12:15:75 TUYA Debug][simplekv.c:629] read and check head success
[01-01 18:12:15:90 TUYA Debug][simplekv.c:1041] read from normal file success
[01-01 18:12:15:92 TUYA Debug][uni_thread.c:161] Init Thread Del Mgr
[01-01 18:12:15:102 TUYA Debug][simplekv.c:1079] init from normal file success.
[01-01 18:12:15:105 TUYA Debug][sys_timer.c:63] system timer has been inited
[01-01 18:12:15:112 TUYA Debug][sys_timer.c:63] system timer has been inited
[01-01 18:12:15:121 TUYA Debug][uni_thread.c:220] Thread:sys_timer Exec Start. Set to Running Status
[01-01 18:12:15:128 TUYA Debug][sys_timer.c:63] system timer has been inited
[01-01 18:12:15:135 TUYA Debug][sys_timer.c:34] system timer process run.
[01-01 18:12:15:142 TUYA Debug][online_log_serv.c:340] read from uf. max:1 first:0 last:0
[01-01 18:12:15:150 TUYA Debug][uni_thread.c:220] Thread:cmmod Exec Start. Set to Running Status
[01-01 18:12:15:164 TUYA Debug][online_log_serv.c:581] log serv init success
[01-01 18:12:15:166 TUYA Debug][ty_work_queue.c:22] init work queue. stack size:2560 pro:3 num:2
[01-01 18:12:15:174 TUYA Debug][ty_work_queue.c:27] ty work queue create success
 tuya log switch:0, level:6, path:null
Set Country Code:CN
unm_set_dns_cache_priority ->2
unm_set_dns_region 1
unw_add_dns_cache [http://a.tuyacn.com/d.json]<->[717232600]
unw_add_dns_cache [https://a2.tuyacn.com/d.json]<->[717233956]
unw_add_dns_cache [m2.tuyacn.com]<->[717233933]
unw_add_dns_cache [baal.tuyacn.com]<->[717235052]
[09-27 15:39:27.615 DEBUG-]:los_notify_device_standby[123]:g_notify_standby = 1
[09-27 15:39:27.619 INFO-]:PDT_AliveTimerReStart[290]:u32MaxAliveMs = 20000[20000]
WIFI Set Mode 2
[09-27 15:39:27.629 DEBUG-]:IPC_APP_Notify_LED_Sound_Status_CB[129]:[09-27 15:39:27.629 DEBUG-]:getTimeZone[418]:curr event:3
getTimeZone fd 40, tz = 28800
Already in status 0
[09-27 15:39:27.643 DEBUG-]:tuya_device_set_sdk_rtc_time[332]:[09-27 15:39:27.645 DEBUG-]:__IPC_APP_Get_Net_Status_cb[109]:utc = 1664264367 [+08:00]
Net status change to:3Dbg:Init Stream_Storage SD:/mnt/mmc01/0
TUYA_APP_Init_Stream_Storage 2
read int exc: /home/tuya.cfgs/tuya_sd_record_mode
[09-27 15:39:27:11 TUYA Err][tuya_ipc_stream_storage.c:1498] storage not inited
[09-27 15:39:27.678 DEBUG-]:is_adjust_sys_time[286]:_tm->tm_year = 122, is_time_sync= 1
unw_gethostbyname m2.tuyacn.com, prio 2
[09-27 15:39:27.692 DEBUG-]:getTimeZone[418]:getTimeZone fd 40, tz = 28800
[09-27 15:39:27.696 DEBUG-]:tuya_device_set_sdk_rtc_time[332]:utc = 1664264367 [+08:00]
[09-27 15:39:27:48 TUYA Err][tuya_ipc_stream_storage.c:1575] stream storage is inited already 1
Err:Init Main Video Stream_Storage Fail. -1
[09-27 15:39:27.720 DEBUG-]:tuya_device_check_offline_record[365]:TUYA_APP_Init_Stream_Storage, ret = -1.
[09-27 15:39:27:72 TUYA Err][tuya_ipc_video_msg.c:686] init video msg success
[09-27 15:39:27.737 INFO-]:TUYA_APP_Enable_P2PTransfer[400]:Init P2P With Max Users:2[09-27 15:39:27.748 DEBUG-]:tuya_offline_record_func[348]:cur_clock = 2539, sleep_time = 3461
P2P API Version: 244.3.3.1
tuya p2p rtc sdk version: 0xf4030301, Oct 15 2021 11:43:39
tuya liteos uv
[09-27 15:39:27:213 TUYA Err][tuya_ipc_p2p.c:4762] p2p v3 init ok
tuya liteos uv
watcher add 262, nfds 1
mqtt p2p LISTEN session........
2681 INFO  src/tuya_rtc.c:5562: try listen
unw_gethostbyname a2.tuyacn.com, prio 2
[09-27 15:39:27:342 TUYA Err][smart_frame.c:1297] mqtt async send fail -916
[09-27 15:39:27:343 TUYA Err][tuya_iot_com_api.c:751] dp report async fail.ret:-916
read int exc: /home/tuya.cfgs/tuya_sd_record_on_off
[09-27 15:39:28.035 DEBUG-]:HI_HAL_WIFI_StartSTA[392]:success to start sta[09-27 15:39:28.038 DEBUG-]:HI_PDT_WIFI_Connect[545]:connectAttr->sync = 0, reconnetTimes = 2
[09-27 15:39:28.249 DEBUG-]:los_put_frame_cahce[448]:4 chan=0, mt=3, Len=  14688, pts=3004, isKeyFrame=1
[09-27 15:39:28.375 INFO-]:PDT_IVA_DetectResultProc[185]: human was detected !. curTime: 3166
 first smd frame detected after:2311 ms.
[09-27 15:39:28.385 DEBUG-]:eventStartRecord[174]:evn = 2, s = 20
[09-27 15:39:28.390 DEBUG-]:los_put_frame_cahce[448]:5 chan=1, mt=0, Len=  15399, pts=3138, isKeyFrame=1
isAlarm:1, 3187 - 855 -> 4000
[09-27 15:39:28.403 DEBUG-]:PDT_IVP_ProcThread[501]:VIP exit
[09-27 15:39:28.410 INFO-]:PDT_IVP_Stop[573]:Wait Ivp thread exit .
[09-27 15:39:28.415 INFO-]:PDT_IVP_Stop[575]:Ivp thread exit ok.
[09-27 15:39:28.424 DEBUG-]:PDT_IVABASE_StopDebugVenc[328]: Debug venc not enabled .!
[09-27 15:39:28.429 INFO-]:PDT_IVP_Stop[590]:Ivp has been stopped successfully.
[09-27 15:39:28.438 INFO-]:PDT_IVP_ProcThread[508]: PDT_IVP_Proc thread exit.
[09-27 15:39:29.039 DEBUG-]:PDT_WIFI_STAInit[381]:PDT_WIFI_STAInit
[09-27 15:39:29.041 DEBUG-]:PDT_WIFI_STAStart[365]:resume = 1, g_standbyMode = 1
[09-27 15:39:29.049 DEBUG-]:PDT_WIFI_STAConnect[407]:connetStatus = 1
[09-27 15:39:29.056 DEBUG-]:PDT_WIFI_HalEventCallback[91]:eventId = 0
[09-27 15:39:29.064 DEBUG-]:PDT_WIFI_AsyncConnectThrd[447]:PDT_WIFI_STAInit ret = 0
[09-27 15:39:29.071 DEBUG-]:PDT_WIFI_AsyncConnectThrd[462]:wifi connect thread exit
[09-27 15:39:29.086 DEBUG-]:PDT_STATEMNG_EventProc[240]:Get 273448960 EVENT from eventhub.
[09-27 15:39:29.090 DEBUG-]:PDT_STATEMNG_WAKEUP_StateMsgProc[488]:state:Wakeup handle message what(104c8000)
[09-27 15:39:29.100 DEBUG-]:PDT_STATEMNG_WAKEUP_StateMsgProc[492]:0, pstMsg->what=0x104c8000
[09-27 15:39:31.209 INFO-]:los_start_get_cache_frame[467]: fifo data start call
[09-27 15:39:31.212 INFO-]:los_wakeup_check_record[703]:online:0, pd mode:open, record_time:20
[09-27 15:39:31.221 DEBUG-]:los_wakeup_check_record[705]:online = 0, evt_type = 1
[09-27 15:39:31.229 DEBUG-]:los_wakeup_check_record[713]:g_bStartRecordPdMode = 1
isAlarm:1, 6027 - 855 -> 4000
[09-27 15:39:31.239 DEBUG-]:los_wakeup_check_record[718]:human_alarm = 1, isDetectFinish = 1
[09-27 15:39:31.252 INFO-]:tuyaSetLogLevel[70]:level = 4
hi_los_set_record_status recording = 1[20]
PIR HUMAN OFFLINE RECORD
[09-27 15:39:31.264 INFO-]:tuyaHumanDetect[659]:=====================> record start.
[09-27 15:39:31.272 INFO-]:los_get_cached_snapshot[582]:cache_snapshot get jpg size = 11085锛buffer len=11085
[09-27 15:39:30:623 TUYA Err][tuya_ipc_cloud_storage.c:1881] cloud storage not inited
read int exc: /home/tuya.cfgs/tuya_alarm_on_off
[09-27 15:39:31.295 INFO-]:IPC_APP_get_alarm_function_onoff[377]:curr alarm_on_off:1
[09-27 15:39:31.304 INFO-]:tuyaHumanDetect[680]:------>tuya_ipc_notify_with_event start push human msg.
[09-27 15:39:32.619 DEBUG-]:__IPC_APP_Get_Net_Status_cb[109]:Net status change to:6read int exc: /home/tuya.cfgs/tuya_sd_record_on_off
[09-27 15:39:33:36 TUYA Err][app_agent.c:2017] unsupport frame type:64
[09-27 15:39:47.790 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:39:52.990 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:39:52.995 INFO-]:hi_los_is_readby_standby[151]:device recording
unm_reset_dns_cache_priority ->0
fail to gethostbyname 0
[09-27 15:39:56:930 TUYA Err][mqtt_client.c:1149] resolve mqtt host Fail:m2.tuyacn.com erro:-100
[09-27 15:39:56:943 TUYA Err][httpc.c:404] No entry for host a2.tuyacn.com found
[09-27 15:39:56:958 TUYA Err][httpc.c:476] Socket creation for a2.tuyacn.com:443 failed
[09-27 15:39:56:963 TUYA Err][httpc.c:404] No entry for host a2.tuyacn.com found
unm_lower_dns_cache_priority ->2
[09-27 15:39:56:974 TUYA Err][http_inf.c:47] Open session failed: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6ce39db372c7f0061etkvh&et=1&t=1664264367&v=1.0&sign=e22f974559dc5254f64bfee31519ac60 (-2)
[09-27 15:39:56:993 TUYA Err][httpc.c:476] Socket creation for a2.tuyacn.com:443 failed
[09-27 15:39:57:1 TUYA Err][iot_httpc.c:907] Post Data Return Fail.-706
unm_lower_dns_cache_priority ->0
[09-27 15:39:57:169 TUYA Err][http_inf.c:47] Open session failed: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6ce39db372c7f0061etkvh&et=1&t=1664264370&v=3.0&sign=d80fa760f34050983f2741692b0b4f12 (-2)
[09-27 15:39:57.837 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:39:57.858 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:39:57:206 TUYA Err][iot_httpc.c:907] Post Data Return Fail.-706
[09-27 15:39:57:213 TUYA Err][tuya_ipc_notification.c:570] cloud_get_detect_storage_config fail, ret -706
[09-27 15:39:57:226 TUYA Err][tuya_ipc_notification.c:704] notification_content_upload_from_buffer init failed:-706
unw_gethostbyname a2.tuyacn.com, prio 0
match_region 1
use dynamic dns ip 717233956 for domain a2.tuyacn.com
unw_gethostbyname m2.tuyacn.com, prio 0
match_region 1
use dynamic dns ip 717233933 for domain m2.tuyacn.com
[09-27 15:40:03.060 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:03.065 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:40:07.870 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:07.875 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:40:12.980 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:12.985 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:40:17.890 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:17.895 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:40:19.107 DEBUG-]:PDT_SYSLINK_PowerInfo[448]:batStatu:1, usb:1, batCapacity:58
[09-27 15:40:23.003 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:23.008 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:40:27.810 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:27.815 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:40:33.020 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:33.025 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:40:37.830 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:37.835 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:40:43.044 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:43.054 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:40:47.860 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:47.865 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:40:52.970 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:52.975 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:40:58.082 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:40:58.087 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:41:00:291 TUYA Err][httpc.c:485] tcp connect failed a2.tuyacn.com:443 errno=110
[09-27 15:41:00:366 TUYA Err][http_inf.c:47] Open session failed: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6ce39db372c7f0061etkvh&et=1&t=1664264397&v=3.0&sign=dbe4151cdac1a96a41286c5760399fa1 (-7)
[09-27 15:41:00:383 TUYA Err][iot_httpc.c:907] Post Data Return Fail.-706
[09-27 15:41:00:400 TUYA Err][tuya_ipc_notification.c:570] cloud_get_detect_storage_config fail, ret -706
[09-27 15:41:00:409 TUYA Err][tuya_ipc_notification.c:704] notification_content_upload_from_buffer init failed:-706
[09-27 15:41:01:91 TUYA Err][mqtt_client.c:1175] mqtt socket connect fail. retry_cnt:0 op_ret:-703 errno:-24
[09-27 15:41:02.990 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:41:02.995 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:41:07.800 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:41:07.805 INFO-]:hi_los_is_readby_standby[151]:device recording
clear all dynamic dns
fail to gethostbyname 110
[09-27 15:41:09:941 TUYA Err][httpc.c:404] No entry for host a2.tuyacn.com found
[09-27 15:41:09:948 TUYA Err][httpc.c:476] Socket creation for a2.tuyacn.com:443 failed
[09-27 15:41:09:963 TUYA Err][http_inf.c:47] Open session failed: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6ce39db372c7f0061etkvh&et=1&t=1664264460&v=3.0&sign=acd7c2304f2b66a1670fb4a483d1ff92 (-2)
[09-27 15:41:09:986 TUYA Err][iot_httpc.c:907] Post Data Return Fail.-706
[09-27 15:41:09:993 TUYA Err][tuya_ipc_notification.c:570] cloud_get_detect_storage_config fail, ret -706
[09-27 15:41:10:2 TUYA Err][tuya_ipc_notification.c:704] notification_content_upload_from_buffer init failed:-706
[09-27 15:41:10.672 INFO-]:los_start_get_cache_frame[467]: fifo data start call
[09-27 15:41:13.030 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:41:13.035 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:41:17.840 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:41:17.845 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:41:19.110 DEBUG-]:PDT_SYSLINK_PowerInfo[448]:batStatu:1, usb:1, batCapacity:58
[09-27 15:41:19:930 TUYA Err][mqtt_client.c:1149] resolve mqtt host Fail:m2.tuyacn.com erro:-24
match_region 1
use tuya dns service to get ip for domain m2.tuyacn.com
unw_gethostbyname h2.iot-dns.com, prio 0
match_region 1
use static dns ip -1576137070 for domain h2.iot-dns.com
[09-27 15:41:23.050 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:41:23.055 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:41:27.860 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
[09-27 15:41:27.865 INFO-]:hi_los_is_readby_standby[151]:device recording
[09-27 15:41:30:22 TUYA Err][tuya_ipc_cloud_storage.c:1952] cloud storage not inited
[09-27 15:41:30:24 TUYA Err][tuya_ipc_cloud_storage.c:2066] cloud storage not inited
[09-27 15:41:30.691 INFO-]:tuyaHumanDetect[694]:=====================> record stop, retVal = 3
hi_los_set_record_status recording = 0[20]
[09-27 15:41:32.970 DEBUG-]:PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc[128]:standy timeout timer run ...
tuya_get_standby_mask, g_TuyaStandbyMask = [0]
[09-27 15:41:32:319 TUYA Err][tuya_ipc_p2p.c:5207] input param error
is_tuya_can_standby, user = 0
[2022-09-27 15:41:32] [PDT_STATEMNG_WakeupCheckStandbyTimeOutTimerProc] standy now.
[09-27 15:41:32.996 DEBUG-]:PDT_STATEMNG_WAKEUP_StateMsgProc[488]:state:Wakeup handle message what(104c1002)
[09-27 15:41:33.006 DEBUG-]:PDT_STATEMNG_BASE_StateMsgProc[46]: will process message what(104c1002)
[09-27 15:41:33.010 DEBUG-]:PDT_STATEMNG_EventProc[240]:Get 273444864 EVENT from eventhub.
MSG_INNER_STATEMNG_STANDBY [0x104c1002]
PDT_STATEMNG_WAKEUP_StateExit
[09-27 15:41:33.032 DEBUG-]:PDT_STATEMNG_STANDBY_StateEnter[80]:PDT_STATEMNG_STANDBY_StateEnter ..
[09-27 15:41:33.042 DEBUG-]:PDT_STATEMNG_STANDBY_StateMsgProc[114]: will process message what(104c7000)
00, p2p offline
point:[/mnt/mmc01/0]
[09-27 15:41:33.056 DEBUG-]:PDT_WIFI_Standby[692]:Standby directly.
[09-27 15:41:33.062 DEBUG-]:PDT_SYSLINK_Soc2Wifi_StopKeepalvie[165]:HI_PDT_SOC_TO_WIFI_STOP_KEEPALIVE
[09-27 15:41:33.070 INFO-]:PDT_WIFI_Standby[658]:read int exc: /home/tuya.cfgs/tuya_sd_record_on_off
soc is sleeping
base64_encode devid:6oactqGhnhjO52uWqZqJkL9WZcD867TxL0acf9ByZYc=, b64EnLen = 44
devid:time:random -->> 6oactqGhnhjO52uWqZqJkL9WZcD867TxL0acf9ByZYc=:1664264493:G5cvfa2lqm02yDUK5z1wsvSXCfqJSSsi
        "type": 1,
        "method":       1,
        "authorization":        "time=1664264493,random=G5cvfa2lqm02yDUK5z1wsvSXCfqJSSsi",
        "signature":    "W8RcexUHvdlQ8gkrWsUwlS5NerRtWRNXS60UBm+LsMY="
}[167]
[09-27 15:41:34.120 DEBUG-]:HI_PDT_SYSTEM_SetKeepaliveAuth[561]:isAuth:1, AuthType:3
[09-27 15:41:34.122 DEBUG-]:HAL_WIFI_SetNetPattern[44]:not open NetPattern
[09-27 15:41:34.128 WARN-]:HI_HAL_WIFI_STAStandby[155]:HAL_WIFI_SetNetPattern failed
[09-27 15:41:34.137 DEBUG-]:HAL_WIFI_SetKeepAlive[78]:not open keepAlive
[09-27 15:41:34.143 WARN-]:HI_HAL_WIFI_STAStandby[161]:HAL_WIFI_SetKeepAlive failed
[09-27 15:41:34.152 FATAL-]:AJ_LOG_FileClose[370]:close log file
no support upload log
HI_PDT_SOC_TO_WIFI_SYSTEM_STANDBY
received deinit camera msg from mcu ...
[09-27 15:41:33:742 TUYA Err][tuya_ipc_p2p.c:5207] input param error
send soc standby ready msg to mcu.
