[2023/2/15 16:53:28] ----TuyaCloudInit [2023/2/15 16:53:28] para.version = 1.3.4 [2023/2/15 16:53:28] para.DbPath = /data/cloud [2023/2/15 16:53:28] gTuyaCloudInitConfig->DbPath = /data/cloud/ [2023/2/15 16:53:28] TUYA_Init [2023/2/15 16:53:28] mode = 0 [2023/2/15 16:53:28] --mode = 1 [2023/2/15 16:53:28] ---mode = 1 [2023/2/15 16:53:28] Dbg:SDK Version:< TUYA IOT SDK V:5.3.33 BS:40.00_PT:2.2_LAN:3.4_CAD:1.0.4_CD:1.0.0 > [2023/2/15 16:53:28] < BUILD AT:2023_02_14_11_50_44 BY ci_manage FOR ty_ipc_wr_wl_linux_sdk AT arm-anykav500-linux-gnueabi > [2023/2/15 16:53:28] IOT DEFS < WIFI_GW:1 DEBUG:1 KV_FILE:1 SHUTDOWN_MODE:1 LITTLE_END:1 TLS_MODE:4 ENABLE_CLOUD_OPERATION:1 OPERATING_SYSTEM:100 ENABLE_SYS_RPC:0 RELIABLE_TRANSFER:0 ENABLE_LAN_ENCRYPTION:1 ENABLE_LAN_LINKAGE:0 ENABLE_LAN_DEV:0 > [2023/2/15 16:53:28] [2023/2/15 16:53:28] [2023/2/15 16:53:28] ---tuya_ipc_app_start [2023/2/15 16:53:28] Dbg:channel_enable:1 1 0 [2023/2/15 16:53:28] Dbg:fps:25 [2023/2/15 16:53:28] Dbg:gop:30 [2023/2/15 16:53:28] Dbg:bitrate:1536 kbps [2023/2/15 16:53:28] Dbg:video_main_width:640 [2023/2/15 16:53:28] Dbg:video_main_height:280 [2023/2/15 16:53:28] Dbg:video_freq:90000 [2023/2/15 16:53:28] Dbg:video_codec:2 [2023/2/15 16:53:28] Dbg:audio_codec:106 [2023/2/15 16:53:28] Dbg:audio_sample:8000 [2023/2/15 16:53:28] Dbg:audio_databits:16 [2023/2/15 16:53:28] Dbg:audio_channel:0 [2023/2/15 16:53:28] ---tuya_ipc_init_sdk [2023/2/15 16:53:28] Dbg:tuya_ipc_sdk_mqtt_online_proc thread start success [2023/2/15 16:53:28] [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /data/cloud [2023/2/15 16:53:28] [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/data/cloud [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:945] path:/data/cloud [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[¡ê¡éUS??kR? [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:1012] both file exist [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:1055] read from normal file [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:765] curr db is V2. No need to upgrade [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:555] head check success [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:658] read and check head success [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:155] key tls_ca0 is invaild, don't crc check [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:155] key tls_ca_cnt is invaild, don't crc check [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:1075] read from normal file success [2023/2/15 16:53:28] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success. [2023/2/15 16:53:28] [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ... [2023/2/15 16:53:28] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success [2023/2/15 16:53:28] [01-01 18:12:15 TUYA E][log_seq.c:863] open err [2023/2/15 16:53:28] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat [2023/2/15 16:53:28] ---pRunInfo->debug_info.log_level = 4 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA N][uni_log.c:197] SetLogManageAttr 4 [2023/2/15 16:53:28] ---TUYA_APP_Init_Ring_Buffer [2023/2/15 16:53:28] Dbg:init ring buffer Channel:0 Enable:1 [2023/2/15 16:53:28] Dbg:video_bitrate 1536, video_fps 25 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:536] Init Ring Buffer. ch0st0tr0 bitrate:1536 fps:25 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:568] Ring buffer malloc 1966080 bytes for ch0st0tr0, max frame size 294912 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:588] Init Ring Buffer success: ch0st0tr0 size:1966080 nodes:250 [2023/2/15 16:53:28] Dbg:init ring buffer success. channel:0 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:1 Enable:1 [2023/2/15 16:53:28] Dbg:video_bitrate 512, video_fps 25 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:536] Init Ring Buffer. ch0st0tr1 bitrate:512 fps:25 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:568] Ring buffer malloc 655360 bytes for ch0st0tr1, max frame size 98304 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:588] Init Ring Buffer success: ch0st0tr1 size:655360 nodes:250 [2023/2/15 16:53:28] Dbg:init ring buffer success. channel:1 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:2 Enable:0 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:3 Enable:0 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:4 Enable:0 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:5 Enable:0 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:6 Enable:0 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:7 Enable:0 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:8 Enable:0 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:9 Enable:1 [2023/2/15 16:53:28] Dbg:audio_sample 8000, audio_databits 16, audio_fps 25 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:536] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:568] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936 [2023/2/15 16:53:28] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:588] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250 [2023/2/15 16:53:28] Dbg:init ring buffer success. channel:9 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:10 Enable:0 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:11 Enable:0 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:12 Enable:0 [2023/2/15 16:53:28] Dbg:init ring buffer Channel:13 Enable:0 [2023/2/15 16:53:29] Dbg:init ring buffer Channel:14 Enable:0 [2023/2/15 16:53:29] Dbg:init ring buffer Channel:15 Enable:0 [2023/2/15 16:53:29] pRunInfo->net_info.connect_mode = 1 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:224 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success! [2023/2/15 16:53:29] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1758] Last reset reason: 255 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:224 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db [2023/2/15 16:53:29] ifconfig: wlan0: error fetching interface information: Device not found [2023/2/15 16:53:29] WIFI Get MAC 64-59-82-BE-70-FE [2023/2/15 16:53:29] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1122] serial_no:645982be70fe [2023/2/15 16:53:29] Set Country Code:(null) [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success [2023/2/15 16:53:29] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1153] gw_cntl.gw_wsm.stat:1 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:3 wf_start_md [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:wf_start_md find value.Len:16 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:648] <__gw_upd_nc_type> bcustom_mode:0, old_wf_start_mode: 0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1345] gw_cntl->gw_wsm.nc_tp:2 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1346] gw_cntl->gw_wsm.md:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:2 gw_di [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_di find value.Len:416 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][ws_db_gw.c:515] gw_di read success [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:10 is_stride [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:is_stride find value.Len:16 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:770] stride from flash: 0. [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:777] no actived, no upgrade:1 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1212] gw_cntl.gw_if.abi:0 input:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1213] gw_cntl.gw_if.product_key:nfkr4o148myon57c, input:nfkr4o148myon57c [2023/2/15 16:53:29] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1214] gw_cntl.gw_if.tp:0, input:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:12 gw_ai [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:544 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][ws_db_gw.c:640] gw_ai read success [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][uni_network.c:417] set_dns_region:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216] [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36] [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[42.192.30.165] [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:8883]<->[42.192.30.165] [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [baal.tuyacn.com:443]<->[42.192.35.108] [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1780] enter success_proc [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat [2023/2/15 16:53:29] ifconfig: wlan0: error fetching interface information: Device not found [2023/2/15 16:53:29] WIFI Get MAC 00-00-00-00-00-00 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1064] nc_tp:2, md:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_iot_wifi_api.c:415] register wifi network monitor. interval:1 [2023/2/15 16:53:29] Dbg:tuya ipc sdk start is complete [2023/2/15 16:53:29] [2023/2/15 16:53:29] @@@@@@@@@@@@@@@@ TUYA_APP_Init_Stream_Storage [2023/2/15 16:53:29] Dbg:Init Stream_Storage SD:/mnt/ [2023/2/15 16:53:29] Init tuya_ipc_ss_init [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1976] Init stream_storage.base_path:/mnt/ v:2 a:106, max event per day 500 skills 0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:2117] stream storage task init success [2023/2/15 16:53:29] [01-01 18:12:15 TUYA E][tuya_ipc_stream_storage.c:2188] the ss mgr not inited [2023/2/15 16:53:29] Dbg:local storage init result is 0 [2023/2/15 16:53:29] [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init [2023/2/15 16:53:29] [2023/2/15 16:53:29] [2023/2/15 16:53:29] Web_Init222222 23 [2023/2/15 16:53:29] [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:1 [2023/2/15 16:53:29] Exec Cmd:ifconfig wlan0 up [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1547] SD task begin___ [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1561] report sd status 0 -> 1 [2023/2/15 16:53:29] [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][smart_frame.c:3473] dp filtered, dev no act [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][uni_fs.c:35] mkdir_all:/mnt/DCIM [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:776] stream storage seize 1275648 bytes memory for media data, slice duration 10 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1532] stream storage with SD init success [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1890] write_mode set 0 -> 1 [2023/2/15 16:53:29] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1282] stream_storage thread start [2023/2/15 16:53:29] ifconfig: SIOCGIFFLAGS: No such device [2023/2/15 16:53:29] Exec Cmd:ifconfig wlan0 down [2023/2/15 16:53:29] ifconfig: SIOCGIFFLAGS: No such device [2023/2/15 16:53:29] Exec Cmd:ifconfig wlan0 up [2023/2/15 16:53:29] ifconfig: SIOCGIFFLAGS: No such device [2023/2/15 16:53:29] WIFI Set Mode 3 [2023/2/15 16:53:29] IDS_Wifi_StartApMode ssid =SmartLife-0000,password = [2023/2/15 16:53:29] ---Start AP SSID:SmartLife-0000,PASSWORD: [2023/2/15 16:53:29] [01-01 18:12:16 TUYA D][ap_netcfg.c:797] start ap success:SmartLife-0000 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10002 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10100 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA E][log_seq.c:152] ret:-1027 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA E][log_seq.c:152] ret:-1027 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA D][ap_netcfg.c:902] ap cfg start:65538 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:18432,priority:5 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10002 ret:0 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10100 ret:0 [2023/2/15 16:53:29] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:udp_ap_v3 Exec Start. Set to Running Stat [2023/2/15 16:53:29] [Lua] ########## lua start [2023/2/15 16:53:29] IDS_Wifi_DoStartAp:ssid = SmartLife-0000,password = 12345678 [2023/2/15 16:53:29] Wifi_AP_Init:ssid = SmartLife-0000,psk = 12345678 [2023/2/15 16:53:29] system sed -ri 's/ssid=.*/ssid=SmartLife-0000/' /data/cloud/hostapd.conf ok ! [2023/2/15 16:53:29] system sed -ri 's/wpa_passphrase=.*/wpa_passphrase=12345678/' /data/cloud/hostapd.conf ok ! [2023/2/15 16:53:30] killall: wpa_supplicant: no process killed [2023/2/15 16:53:30] killall: udhcpc: no process killed [2023/2/15 16:53:30] killall: udhcpd: no process killed [2023/2/15 16:53:30] [01-01 18:12:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:30] [01-01 18:12:16 TUYA D][tuya_iot_wifi_api.c:381] wifi netstat changed to:2 -->> [2023/2/15 16:53:30] Dbg:Net status change to:2 [2023/2/15 16:53:30] [01-01 18:12:16 TUYA D][tuya_iot_wifi_api.c:384] wifi netstat changed to:2 <<-- [2023/2/15 16:53:30] killall: hostapd: no process killed [2023/2/15 16:53:30] ifconfig: SIOCGIFFLAGS: No such device [2023/2/15 16:53:30] rmmod: can't unload module 'rtl8188ftv': No such file or directory [2023/2/15 16:53:30] rmmod: can't unload module 'ak_hcd': No such file or directory [2023/2/15 16:53:30] [01-01 18:12:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:31] [01-01 18:12:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:31] Fail to get key mask bitmap. [2023/2/15 16:53:31] Fail to get tr keyboard back ground bitmap. [2023/2/15 16:53:31] Fail to get span keyboard back ground bitmap. [2023/2/15 16:53:31] [01-01 18:12:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:31] softkeyboard/softkeywindow.c:441 IME_LANGUAGE_UNKNOWN 2 [2023/2/15 16:53:31] [2023/2/15 16:53:31] [2023/2/15 16:53:31] Web_Init 4 [2023/2/15 16:53:31] [2023/2/15 16:53:32] [01-01 18:12:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:32] [01-01 18:12:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:32] load img welcome.png [2023/2/15 16:53:33] [01-01 18:12:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:33] [Lua] wificfg.MODE.get() = 1 [2023/2/15 16:53:33] [2023/2/15 16:53:33] uart_write:[fe 04 04 08 ] [2023/2/15 16:53:33] [uart Send head[1]:0xfe, len[2]:4, cmd[3]:0x4, chksum[4]:0x8] [2023/2/15 16:53:33] [2023/2/15 16:53:33] uart_write:[fe 05 05 10 1a ] [2023/2/15 16:53:33] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x10, chksum[5]:0x1a] [2023/2/15 16:53:33] [2023/2/15 16:53:33] uart_write:[fe 05 05 01 0b ] [2023/2/15 16:53:33] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x1, chksum[5]:0xb] [2023/2/15 16:53:33] [2023/2/15 16:53:33] uart_write:[fe 05 05 02 0c ] [2023/2/15 16:53:33] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x2, chksum[5]:0xc] [2023/2/15 16:53:33] OnNewFileChange true true false [2023/2/15 16:53:33] [2023/2/15 16:53:33] uart_write:[fe 05 05 13 1d ] [2023/2/15 16:53:33] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x13, chksum[5]:0x1d] [2023/2/15 16:53:33] [2023/2/15 16:53:33] uart_write:[fe 05 00 01 06 ] [2023/2/15 16:53:33] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x0, data[4]:0x1, chksum[5]:0x6] [2023/2/15 16:53:33] [2023/2/15 16:53:33] uart_write:[fe 08 06 02 02 02 02 16 ] [2023/2/15 16:53:33] [uart Send head[1]:0xfe, len[2]:8, cmd[3]:0x6, data[4]:0x2, data[5]:0x2, data[6]:0x2, data[7]:0x2, chksum[8]:0x16] [2023/2/15 16:53:33] [Lua] @@@@@@@@@@ welcome open [2023/2/15 16:53:33] uart.OnRcv 254.0 7.0 4.0 23.0 17.0 [2023/2/15 16:53:33] TotalLen = 7 [2023/2/15 16:53:33] cmd:data = 4.0 table: 0x1928298 [2023/2/15 16:53:33] -----cmd:data = 4.0 table: 0x1928298 [2023/2/15 16:53:33] [Lua] mcu ver: 20230109 [2023/2/15 16:53:33] [01-01 18:12:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:34] [01-01 18:12:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:34] [01-01 18:12:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:34] [01-01 18:12:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:35] [01-01 18:12:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:35] [01-01 18:12:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:36] [01-01 18:12:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:36] Configuration file: /data/cloud/hostapd.conf [2023/2/15 16:53:36] rfkill: Cannot open RFKILL control device [2023/2/15 16:53:36] Using interface wlan0 with hwaddr c8:02:8f:d5:ab:12 and ssid "SmartLife-0000" [2023/2/15 16:53:36] [01-01 18:12:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:36] random: Only 15/20 bytes of strong random data available [2023/2/15 16:53:36] random: Not enough entropy pool available for secure operations [2023/2/15 16:53:36] WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects [2023/2/15 16:53:37] [01-01 18:12:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:37] wlan0: interface state UNINITIALIZED->ENABLED [2023/2/15 16:53:37] wlan0: AP-ENABLED [2023/2/15 16:53:37] system wifi_install.sh rtl8188 ap ok ! [2023/2/15 16:53:37] [01-01 18:12:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:38] [01-01 18:12:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:38] [01-01 18:12:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:39] [01-01 18:12:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:39] [01-01 18:12:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:39] [01-01 18:12:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:40] [01-01 18:12:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:40] [01-01 18:12:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:41] [01-01 18:12:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:41] [01-01 18:12:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:42] [Lua] [lua] page.Open desk/desk [2023/2/15 16:53:42] [01-01 18:12:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:42] [2023/2/15 16:53:42] uart_write:[fe 05 05 13 1d ] [2023/2/15 16:53:42] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x13, chksum[5]:0x1d] [2023/2/15 16:53:42] [Lua] GetUnReadCnt 25 4 [2023/2/15 16:53:42] [2023/2/15 16:53:42] uart_write:[fe 05 03 01 09 ] [2023/2/15 16:53:42] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x3, data[4]:0x1, chksum[5]:0x9] [2023/2/15 16:53:42] [2023/2/15 16:53:42] uart_write:[fe 08 35 02 02 02 02 45 ] [2023/2/15 16:53:42] [uart Send head[1]:0xfe, len[2]:8, cmd[3]:0x35, data[4]:0x2, data[5]:0x2, data[6]:0x2, data[7]:0x2, chksum[8]:0x45] [2023/2/15 16:53:42] Cloud_SetTimeZone [2023/2/15 16:53:42] [2023/2/15 16:53:42] uart_write:[fe 05 66 01 6c ] [2023/2/15 16:53:42] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x66, data[4]:0x1, chksum[5]:0x6c] [2023/2/15 16:53:42] [2023/2/15 16:53:42] uart_write:[fe 06 67 00 00 6d ] [2023/2/15 16:53:42] [uart Send head[1]:0xfe, len[2]:6, cmd[3]:0x67, data[4]:0x0, data[5]:0x0, chksum[6]:0x6d] [2023/2/15 16:53:42] [2023/2/15 16:53:42] uart_write:[fe 06 36 01 00 3d ] [2023/2/15 16:53:42] [uart Send head[1]:0xfe, len[2]:6, cmd[3]:0x36, data[4]:0x1, data[5]:0x0, chksum[6]:0x3d] [2023/2/15 16:53:42] [2023/2/15 16:53:42] uart_write:[fe 06 37 01 00 3e ] [2023/2/15 16:53:42] [uart Send head[1]:0xfe, len[2]:6, cmd[3]:0x37, data[4]:0x1, data[5]:0x0, chksum[6]:0x3e] [2023/2/15 16:53:42] [01-01 18:12:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:43] CurPage.name desk/desk [2023/2/15 16:53:43] [01-01 18:12:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:43] [01-01 18:12:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:44] [01-01 18:12:30 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 16:53:44] [01-01 18:12:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:44] [01-01 18:12:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:44] [01-01 18:12:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:45] [01-01 18:12:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:45] [01-01 18:12:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:46] [01-01 18:12:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:46] [01-01 18:12:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:47] [01-01 18:12:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:47] [01-01 18:12:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:48] [01-01 18:12:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:48] [01-01 18:12:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:49] [01-01 18:12:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:49] [2023/2/15 16:53:49] vdpids login: [01-01 18:12:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:49] [01-01 18:12:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:50] roo[01-01 18:12:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:50] t [2023/2/15 16:53:50] Password: [01-01 18:12:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:51] [01-01 18:12:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:51] [01-01 18:12:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:52] [01-01 18:12:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:52] [2023/2/15 16:53:52] login[607]: root login on 'ttySAK0' [2023/2/15 16:53:52] welcome to file system [2023/2/15 16:53:52] [root@vdpids ~]$ [01-01 18:12:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:53] [01-01 18:12:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:53] [01-01 18:12:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:54] [01-01 18:12:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:54] [01-01 18:12:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:54] [01-01 18:12:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:55] [01-01 18:12:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:55] [01-01 18:12:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:56] [01-01 18:12:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:56] [01-01 18:12:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:57] ifconfig eth0 down [2023/2/15 16:53:57] [root@vdpids ~]$ [01-01 18:12:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:57] [01-01 18:12:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:58] [01-01 18:12:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:58] i[01-01 18:12:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:59] fco[01-01 18:12:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:59] n[01-01 18:12:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:53:59] f[01-01 18:12:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:00] ig [2023/2/15 16:54:00] lo Link encap:Local Loopback [2023/2/15 16:54:00] inet addr:127.0.0.1 Mask:255.0.0.0 [2023/2/15 16:54:00] UP LOOPBACK RUNNING MTU:65536 Metric:1 [2023/2/15 16:54:00] RX packets:0 errors:0 dropped:0 overruns:0 frame:0 [2023/2/15 16:54:00] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 [2023/2/15 16:54:00] collisions:0 txqueuelen:1 [2023/2/15 16:54:00] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) [2023/2/15 16:54:00] [2023/2/15 16:54:00] wlan0 Link encap:Ethernet HWaddr C8:02:8F:D5:AB:12 [2023/2/15 16:54:00] inet addr:192.168.176.1 Bcast:192.168.176.255 Mask:255.255.255.0 [2023/2/15 16:54:00] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 [2023/2/15 16:54:00] RX packets:0 errors:0 dropped:0 overruns:0 frame:0 [2023/2/15 16:54:00] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 [2023/2/15 16:54:00] collisions:0 txqueuelen:1000 [2023/2/15 16:54:00] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) [2023/2/15 16:54:00] [2023/2/15 16:54:00] [root@vdpids ~]$ [01-01 18:12:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:00] [01-01 18:12:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:01] [01-01 18:12:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:01] [01-01 18:12:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:02] [01-01 18:12:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:02] [01-01 18:12:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:03] [01-01 18:12:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:03] [01-01 18:12:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:04] [01-01 18:12:50 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 16:54:04] [01-01 18:12:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:04] [01-01 18:12:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:04] [01-01 18:12:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:05] [01-01 18:12:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:05] [01-01 18:12:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:06] [01-01 18:12:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:06] [01-01 18:12:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:07] [01-01 18:12:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:07] [01-01 18:12:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:08] [01-01 18:12:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:08] [01-01 18:12:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:09] [01-01 18:12:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:09] [01-01 18:12:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:09] [01-01 18:12:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:10] [01-01 18:12:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:10] [01-01 18:12:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:11] [01-01 18:12:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:11] [01-01 18:12:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:12] [01-01 18:12:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:12] [01-01 18:12:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:13] [01-01 18:13:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:13] [01-01 18:13:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:14] [01-01 18:13:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:14] [01-01 18:13:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:14] [01-01 18:13:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:15] [01-01 18:13:02 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:15] [01-01 18:13:02 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:16] [01-01 18:13:03 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:16] [01-01 18:13:03 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:17] [01-01 18:13:04 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:17] [01-01 18:13:04 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:18] [01-01 18:13:05 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:18] [01-01 18:13:05 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:19] [01-01 18:13:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:19] [01-01 18:13:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:19] [01-01 18:13:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:20] [01-01 18:13:07 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:20] [01-01 18:13:07 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:21] [01-01 18:13:08 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:21] [01-01 18:13:08 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:22] [01-01 18:13:09 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:22] [01-01 18:13:09 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:23] [01-01 18:13:10 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:24] [01-01 18:13:10 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:24] [01-01 18:13:10 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 16:54:24] [01-01 18:13:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:24] [01-01 18:13:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:25] [01-01 18:13:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:25] [01-01 18:13:12 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:26] [01-01 18:13:12 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:26] [01-01 18:13:13 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:27] [01-01 18:13:13 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:27] [01-01 18:13:14 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:28] [01-01 18:13:14 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:28] [01-01 18:13:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:29] [01-01 18:13:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:29] [01-01 18:13:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:29] [01-01 18:13:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:30] [01-01 18:13:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:30] [01-01 18:13:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:31] [01-01 18:13:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:31] [01-01 18:13:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:32] [01-01 18:13:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:32] [01-01 18:13:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:33] [01-01 18:13:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:33] [01-01 18:13:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:34] [01-01 18:13:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:34] [01-01 18:13:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:34] i[01-01 18:13:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:35] f[01-01 18:13:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:35] [01-01 18:13:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:36] co[01-01 18:13:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:36] nfi[01-01 18:13:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:37] g[01-01 18:13:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:37] [2023/2/15 16:54:37] lo Link encap:Local Loopback [2023/2/15 16:54:37] inet addr:127.0.0.1 Mask:255.0.0.0 [2023/2/15 16:54:37] UP LOOPBACK RUNNING MTU:65536 Metric:1 [2023/2/15 16:54:37] RX packets:0 errors:0 dropped:0 overruns:0 frame:0 [2023/2/15 16:54:37] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 [2023/2/15 16:54:37] collisions:0 txqueuelen:1 [2023/2/15 16:54:37] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) [2023/2/15 16:54:37] [2023/2/15 16:54:37] wlan0 Link encap:Ethernet HWaddr C8:02:8F:D5:AB:12 [2023/2/15 16:54:37] inet addr:192.168.176.1 Bcast:192.168.176.255 Mask:255.255.255.0 [2023/2/15 16:54:37] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 [2023/2/15 16:54:37] RX packets:0 errors:0 dropped:0 overruns:0 frame:0 [2023/2/15 16:54:37] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 [2023/2/15 16:54:37] collisions:0 txqueuelen:1000 [2023/2/15 16:54:37] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) [2023/2/15 16:54:37] [2023/2/15 16:54:37] [root@vdpids ~]$ [01-01 18:13:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:38] [01-01 18:13:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:38] [01-01 18:13:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:39] [01-01 18:13:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:39] [01-01 18:13:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:39] [01-01 18:13:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:40] [01-01 18:13:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:40] [01-01 18:13:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:41] [01-01 18:13:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:41] [01-01 18:13:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:42] [01-01 18:13:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:42] systimeout.c 83: Time Out[sysinfo]! [2023/2/15 16:54:42] [Lua] [lua] page.Open timeout/timeout [2023/2/15 16:54:42] desk page.OnPause [2023/2/15 16:54:42] Year,Month,Day,Hour: 2000 1 18 1 [2023/2/15 16:54:42] Autidelfile...open [2023/2/15 16:54:42] [01-01 18:13:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:43] [01-01 18:13:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:43] [01-01 18:13:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:44] [01-01 18:13:30 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 16:54:44] [01-01 18:13:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:44] [01-01 18:13:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:44] [01-01 18:13:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:45] [01-01 18:13:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:45] [01-01 18:13:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:46] [01-01 18:13:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:46] [01-01 18:13:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:47] [01-01 18:13:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:47] [01-01 18:13:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:48] [01-01 18:13:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:48] [01-01 18:13:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:49] [01-01 18:13:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:49] [01-01 18:13:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:49] [01-01 18:13:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:50] [01-01 18:13:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:50] [01-01 18:13:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:51] [01-01 18:13:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:51] [01-01 18:13:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:52] [01-01 18:13:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:52] [01-01 18:13:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:53] [01-01 18:13:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:53] [01-01 18:13:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:54] [01-01 18:13:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:54] [01-01 18:13:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:54] [01-01 18:13:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:55] [01-01 18:13:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:55] [01-01 18:13:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:56] [01-01 18:13:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:56] [01-01 18:13:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:57] [01-01 18:13:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:57] [01-01 18:13:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:58] [01-01 18:13:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:58] [01-01 18:13:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:59] [01-01 18:13:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:59] [01-01 18:13:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:54:59] [01-01 18:13:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:00] [01-01 18:13:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:00] [01-01 18:13:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:01] [01-01 18:13:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:01] [01-01 18:13:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:02] [01-01 18:13:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:02] [01-01 18:13:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:03] [01-01 18:13:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:03] [01-01 18:13:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:04] [01-01 18:13:50 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 16:55:04] [01-01 18:13:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:04] [01-01 18:13:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:04] [01-01 18:13:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:05] [01-01 18:13:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:05] [01-01 18:13:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:06] [01-01 18:13:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:06] [01-01 18:13:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:07] [01-01 18:13:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:07] [01-01 18:13:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:08] [01-01 18:13:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:08] [01-01 18:13:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:09] [01-01 18:13:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:09] [01-01 18:13:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:09] [01-01 18:13:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:10] [01-01 18:13:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:10] [01-01 18:13:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:11] [01-01 18:13:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:11] [01-01 18:13:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:12] [01-01 18:13:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:12] [01-01 18:13:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:13] [01-01 18:13:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:13] [01-01 18:14:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:14] [01-01 18:14:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:14] [01-01 18:14:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:14] [01-01 18:14:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:15] [01-01 18:14:02 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:15] [01-01 18:14:02 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:16] [01-01 18:14:03 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:16] [01-01 18:14:03 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:17] [01-01 18:14:04 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:17] [01-01 18:14:04 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:18] [01-01 18:14:05 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:18] [01-01 18:14:05 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:19] [01-01 18:14:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:19] [01-01 18:14:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:19] [01-01 18:14:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:20] [01-01 18:14:07 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:20] [01-01 18:14:07 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:21] [01-01 18:14:08 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:21] [01-01 18:14:08 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:22] [01-01 18:14:09 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:22] [01-01 18:14:09 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:23] [01-01 18:14:10 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:23] [01-01 18:14:10 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:24] [01-01 18:14:10 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 16:55:24] [01-01 18:14:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:24] [01-01 18:14:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:24] [01-01 18:14:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:25] [01-01 18:14:12 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:25] [01-01 18:14:12 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:26] [01-01 18:14:13 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:26] [01-01 18:14:13 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:27] [01-01 18:14:14 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:28] [01-01 18:14:14 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:28] [01-01 18:14:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:29] [01-01 18:14:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:29] [01-01 18:14:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:29] [01-01 18:14:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:30] [01-01 18:14:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:30] [01-01 18:14:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:31] [01-01 18:14:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:31] [01-01 18:14:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:32] [01-01 18:14:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:32] [01-01 18:14:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:33] [01-01 18:14:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:33] [01-01 18:14:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:34] [01-01 18:14:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:34] [01-01 18:14:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:34] [01-01 18:14:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:35] [01-01 18:14:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:35] [01-01 18:14:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:36] [01-01 18:14:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:36] [01-01 18:14:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:37] [01-01 18:14:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:37] [01-01 18:14:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:38] [01-01 18:14:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:38] [01-01 18:14:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:39] [01-01 18:14:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:39] [01-01 18:14:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:39] [01-01 18:14:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:40] [01-01 18:14:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:40] [01-01 18:14:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:41] [01-01 18:14:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:41] [01-01 18:14:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:42] [01-01 18:14:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:42] [01-01 18:14:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:43] [01-01 18:14:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:43] [01-01 18:14:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:44] [01-01 18:14:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:44] [01-01 18:14:30 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 16:55:44] [01-01 18:14:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:44] [01-01 18:14:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:45] [01-01 18:14:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:45] [01-01 18:14:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:46] [01-01 18:14:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:46] [01-01 18:14:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:47] [01-01 18:14:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:47] [01-01 18:14:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:48] [01-01 18:14:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:48] [01-01 18:14:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:49] [01-01 18:14:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:49] [01-01 18:14:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:49] [01-01 18:14:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:50] [01-01 18:14:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:50] [01-01 18:14:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:50] [2023/2/15 16:55:51] [root@vdpids ~]$ [01-01 18:14:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:51] [01-01 18:14:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:52] [01-01 18:14:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:52] [01-01 18:14:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:53] [01-01 18:14:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:53] [01-01 18:14:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:54] [01-01 18:14:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:54] [01-01 18:14:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:54] [01-01 18:14:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:55] [01-01 18:14:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:55] [01-01 18:14:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:56] [01-01 18:14:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:56] [01-01 18:14:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:57] c[01-01 18:14:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:57] d /[01-01 18:14:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:58] da[01-01 18:14:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:58] [root@vdpids ~]$ cd /data/[01-01 18:14:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:59] [01-01 18:14:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:59] [01-01 18:14:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:55:59] c[01-01 18:14:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:00] [root@vdpids ~]$ cd /data/cloud/[01-01 18:14:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:00] [01-01 18:14:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:00] [2023/2/15 16:56:01] [root@vdpids /data/cloud]$ [01-01 18:14:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:01] [01-01 18:14:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:02] [01-01 18:14:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:02] [01-01 18:14:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:03] [01-01 18:14:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:03] c[01-01 18:14:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:04] d [01-01 18:14:50 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 16:56:04] [01-01 18:14:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:04] /[01-01 18:14:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:04] d[01-01 18:14:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:05] [root@vdpids /data/cloud]$ cd /data/[01-01 18:14:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:05] [01-01 18:14:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:06] [root@vdpids /data/cloud]$ cd /data/tfcard/[01-01 18:14:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 16:56:06] [01-01 18:14:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2
