[0;37m[4190] [DBG] [main.c:177]: SDK Version:< TUYA IOT SDK V:5.3.28 BS:40.00_PT:2.2_LAN:3.4_CAD:1.0.4_CD:1.0.0 >
< BUILD AT:2022_11_28_13_43_28 BY ci_manage FOR ty_ipc_wr_wl_linux_sdk AT arm-anykav500-linux-uclibcgnueabi-gcc-4.9.4 >
IOT DEFS < WIFI_GW:1 DEBUG:1 KV_FILE:1 SHUTDOWN_MODE:1 LITTLE_END:1 TLS_MODE:4 ENABLE_CLOUD_OPERATION:1 OPERATING_SYSTEM:100 ENABLE_SYS_RPC:0 RELIABLE_TRANSFER:0 ENABLE_LAN_ENCRYPTION:1 ENABLE_LAN_LINKAGE:0 ENABLE_LAN_DEV:0 >
[0m
[0;37m[4190] [DBG] [tuya_app_media.c:23]: channel_enable:1 1 0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:24]: fps:20[0m
[0;37m[4190] [DBG] [tuya_app_media.c:25]: gop:20[0m
[0;37m[4190] [DBG] [tuya_app_media.c:26]: bitrate:512 kbps[0m
[0;37m[4190] [DBG] [tuya_app_media.c:27]: video_main_width:1920[0m
[0;37m[4190] [DBG] [tuya_app_media.c:28]: video_main_height:1080[0m
[0;37m[4190] [DBG] [tuya_app_media.c:29]: video_freq:90000[0m
[0;37m[4190] [DBG] [tuya_app_media.c:30]: video_codec:2[0m
[0;37m[4190] [DBG] [tuya_app_media.c:32]: audio_codec:101[0m
[0;37m[4190] [DBG] [tuya_app_media.c:33]: audio_sample:8000[0m
[0;37m[4190] [DBG] [tuya_app_media.c:34]: audio_databits:16[0m
[0;37m[4190] [DBG] [tuya_app_media.c:35]: audio_channel:0[0m
[01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/tuya/ 
[01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/tuya/
[01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/tuya/
[01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£—¢US¾ñüùykRéâ]
[01-01 18:12:15 TUYA D][simplekv.c:999] normal file exist. bak file not exist
[01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512
[01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success
[01-01 18:12:15 TUYA D][simplekv.c:1055] read from normal file
[01-01 18:12:15 TUYA D][simplekv.c:765] curr db is V2. No need to upgrade
[01-01 18:12:15 TUYA D][simplekv.c:555] head check success
[01-01 18:12:15 TUYA D][simplekv.c:658] read and check head success
[01-01 18:12:15 TUYA D][simplekv.c:1075] read from normal file success
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success.
[01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ...
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2
[01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[01-01 18:12:15 TUYA D][log_seq.c:894] read m:0 f:0 l:0
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[01-01 18:12:15 TUYA N][uni_log.c:197] SetLogManageAttr 4
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:0 Enable:1[0m
[0;37m[4190] [DBG] [tuya_app_media.c:353]: video_bitrate 512, video_fps 20[0m
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:536] Init Ring Buffer. ch0st0tr0 bitrate:512 fps:20
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:568] Ring buffer malloc 655360 bytes for ch0st0tr0, max frame size 98304
[0;37m[4190] [DBG] [main.c:65]: tuya_ipc_sdk_mqtt_online_proc thread start success
[0m
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA I][tuya_ring_buffer.c:588] Init Ring Buffer success: ch0st0tr0 size:655360 nodes:200
[0;37m[4190] [DBG] [tuya_app_media.c:361]: init ring buffer success. channel:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:1 Enable:1[0m
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:536] Init Ring Buffer. ch0st0tr1 bitrate:512 fps:20
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:568] Ring buffer malloc 655360 bytes for ch0st0tr1, max frame size 98304
[01-01 18:12:15 TUYA I][tuya_ring_buffer.c:588] Init Ring Buffer success: ch0st0tr1 size:655360 nodes:200
[0;37m[4190] [DBG] [tuya_app_media.c:361]: init ring buffer success. channel:1[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:2 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:3 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:4 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:5 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:6 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:7 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:8 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:9 Enable:1[0m
[0;37m[4190] [DBG] [tuya_app_media.c:344]: audio_sample 8000, audio_databits 16, audio_fps 25[0m
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:536] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:568] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936
[01-01 18:12:15 TUYA I][tuya_ring_buffer.c:588] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250
[0;37m[4190] [DBG] [tuya_app_media.c:361]: init ring buffer success. channel:9[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:10 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:11 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:12 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:13 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:14 Enable:0[0m
[0;37m[4190] [DBG] [tuya_app_media.c:335]: init ring buffer Channel:15 Enable:0[0m
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:224
[01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success!
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1758] Last reset reason: 255
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:6 tls_ca_cnt
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:tls_ca_cnt find value.Len:16
[01-01 18:12:15 TUYA D][tuya_tls.c:319] tls_ca_cnt:1 and parse:1
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:5 tls_ca0
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:tls_ca0 find value.Len:2688
[01-01 18:12:15 TUYA D][tuya_tls.c:349] Parse DER tls_ca0:2002 success
WIFI Get MAC DC-29-19-4E-61-36
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1122] serial_no:dc29194e6136
Set Country Code:(null) 
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:160
[01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1153] gw_cntl.gw_wsm.stat:2
[01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1345] gw_cntl->gw_wsm.nc_tp:6
[01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1346] gw_cntl->gw_wsm.md:0
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:2 gw_di
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_di find value.Len:416
[01-01 18:12:15 TUYA D][ws_db_gw.c:515] gw_di read success
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:7 is_stride
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:is_stride find value.Len:16
[01-01 18:12:15 TUYA D][tuya_devos_entry.c:770] stride from flash: 0.
[01-01 18:12:15 TUYA D][tuya_devos_entry.c:798] ver no change.
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1212] gw_cntl.gw_if.abi:0 input:0
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1213] gw_cntl.gw_if.product_key:psdw3wvk8ks763ih, input:psdw3wvk8ks763ih
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1214] gw_cntl.gw_if.tp:0, input:0
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:9 gw_ai
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:544
[01-01 18:12:15 TUYA D][ws_db_gw.c:640] gw_ai read success
[01-01 18:12:15 TUYA D][uni_network.c:417] set_dns_region:3
[01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [http://a.tuyaus.com/d.json]<->[52.38.120.251]
[01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [https://a2.tuyaus.com/d.json]<->[100.21.15.118]
[01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [m2.tuyaus.com:1883]<->[54.188.109.168]
[01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [m2.tuyaus.com:8883]<->[54.188.109.168]
[01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [baal.tuyaus.com]<->[44.239.29.247]
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:000004yf9q isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:8 000004yf9q
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:000004yf9q find value.Len:368
[01-01 18:12:15 TUYA D][ws_db_gw.c:699] schema 000004yf9q read success
[01-01 18:12:15 TUYA D][tuya_devos_utils.c:872] create dev_cntl Success 
[01-01 18:12:15 TUYA D][tuya_devos_entry.c:1780] enter success_proc
[01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60
[01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8
[01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12
[01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1064] nc_tp:6, md:0
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:lpc_task,stackDepth:3072,totalstackDepth:17920,priority:3
[01-01 18:12:15 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:2
WIFI Set Mode 2
[01-01 18:12:15 TUYA D][tuya_iot_wired_wifi_api.c:608] register wifi network monitor. interval:1
[01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:803] ssid:tuya
[01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:804] passwd:tuya
[01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:805] token:
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:lpc_task Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][app_agent.c:1358] Setup TCP Server On Port:6668
[0;37m[4190] [DBG] [main.c:170]: tuya ipc sdk start is complete
[0m
can't read live audio file /mnt/tuya/demo/audio.raw
[0;37m[4190] [DBG] [tuya_app_media.c:195]: start live video using /mnt/tuya/demo/video.264[0m
[0;37m[4190] [DBG] [tuya_app_sysctl.c:116]: Net status change to:3[0m
[01-01 18:12:15 TUYA I][mqc_app.c:387] mqc app start ...
[01-01 18:12:15 TUYA D][mqc_app.c:459] MQTT Protocol URL:m2.tuyaus.com:8883 Port:8883
[01-01 18:12:15 TUYA D][mqc_app.c:473] TLS disable
[01-01 18:12:15 TUYA D][mqc_app.c:308] TLS Mode:4
[01-01 18:12:15 TUYA D][mqtt_client.c:291] subcribe_topic:smart/device/in/eb510a0dc949229902doie, client_id:eb510a0dc949229902doie, user_name:eb510a0dc949229902doie, passwd:5523c7caf44a447c
[01-01 18:12:15 TUYA D][mqtt_client.c:322] domain<0> m2.tuyaus.com:8883 HAVE PORT
[01-01 18:12:15 TUYA D][mqtt_client.c:325] PARSE m2.tuyaus.com:8883
[01-01 18:12:15 TUYA D][mqtt_client.c:353] wakeup_domain_tbl<0> m2.tuyaus.com:1883 HAVE PORT
[01-01 18:12:15 TUYA D][mqtt_client.c:356] PARSE m2.tuyaus.com:1883
[01-01 18:12:15 TUYA D][mqc_app.c:520] mqtt send topic:smart/device/out/eb510a0dc949229902doie
[01-01 18:12:15 TUYA D][mqc_app.c:522] mqtt-media send topic:d/m/o/eb510a0dc949229902doie
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:22016,priority:4
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:64 cnt:13
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:22 cnt:14
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:55 cnt:15
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[01-01 18:12:15 TUYA D][tuya_svc_timer_task.c:146] no timer
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:13 cnt:16
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:15 cnt:17
[01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:826] upgrade active success
[01-01 18:12:15 TUYA D][svc_online_log.c:217] mqtt log topic init log/realtime/eb510a0dc949229902doie
[01-01 18:12:15 TUYA D][svc_online_log.c:219] mqtt log topic init log/runstat/eb510a0dc949229902doie
[01-01 18:12:15 TUYA D][svc_online_log.c:317] svc online log active success
[01-01 07:00:00 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:2
[01-01 07:00:00 TUYA D][uni_thread.c:250] Thread:mq_cntl_task Exec Start. Set to Running Stat
[01-01 07:00:00 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[01-01 07:00:00 TUYA D][simplekv.c:1251] find key:4 p2p_pwd
[01-01 07:00:00 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[01-01 07:00:00 TUYA D][tuya_ipc_p2p_common.c:550] get p2p passwd = ade4a7f6
ioctl error
[01-01 07:00:00 TUYA E][tuya_ring_buffer.c:849] data over size:193943>98304
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:1 size:193943 pts:33333 ts:0[0m
[01-01 07:00:00 TUYA E][tuya_devos_netcfg.c:330] all netcfg stop fail:-1
[01-01 07:00:00 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:-1
[01-01 07:00:00 TUYA I][mqc_app.c:387] mqc app start ...
[01-01 07:00:00 TUYA D][mqc_app.c:144] mq_pro:15 cnt:18
[01-01 07:00:00 TUYA D][tuya_svc_upgrade.c:826] upgrade active success
[01-01 07:00:00 TUYA E][svc_online_log_mqtt.c:22] ret:-4
[01-01 07:00:00 TUYA E][svc_online_log.c:315] ret:-4
[01-01 07:00:00 TUYA E][tuya_svc_online_log.c:27] ret:-4
[01-01 07:00:00 TUYA E][tuya_devos_entry.c:612] tuya_svc_online_log_active fail:-4
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1479 pts:66666 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:4374 pts:99999 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:4466 pts:133332 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:49267 pts:166665 ts:0[0m
ioctl error
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:3438 pts:199998 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:22271 pts:233331 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:185 pts:266664 ts:0[0m
ioctl error
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:16747 pts:299997 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:9491 pts:333330 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1067 pts:366663 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:13956 pts:399996 ts:0[0m
ioctl error
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:9976 pts:433329 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:13157 pts:466662 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1540 pts:499995 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1291 pts:533328 ts:0[0m
ioctl error
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:3335 pts:566661 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1637 pts:599994 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:365 pts:633327 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1169 pts:666660 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:3485 pts:699993 ts:0[0m
ioctl error
ioctl error
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:433 pts:733326 ts:0[0m
[01-01 07:00:01 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[0;37m[4190] [DBG] [tuya_app_sysctl.c:116]: Net status change to:6[0m
[01-01 07:00:01 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1617 pts:766659 ts:0[0m
ioctl error
[01-01 07:00:01 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:0  -->>
[0;37m[4190] [DBG] [tuya_app_sysctl.c:116]: Net status change to:5[0m
[01-01 07:00:01 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:0  <<--
WIFI[0] Get IP:192.168.1.85
[01-01 07:00:01 TUYA D][tuya_iot_wired_wifi_api.c:504] wifi ip: 192.168.1.85, inet_addr(wifi_ip.ip): 0xc0a80155, mq_ip:0x0.
[01-01 07:00:01 TUYA D][tuya_iot_wired_wifi_api.c:590] wired wifi netstat changed to:wired  -->>
[01-01 07:00:01 TUYA D][tuya_iot_wired_wifi_api.c:592] wired wifi netstat changed to:wifi  <<--
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:5472 pts:799992 ts:0[0m
[01-01 07:00:01 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyaus.com, prio 2
[01-01 07:00:01 TUYA D][uni_network.c:353] use dynamic dns ip:54.188.109.168 for domain:m2.tuyaus.com
[01-01 07:00:01 TUYA D][mqtt_client.c:1406] select mqtt host:m2.tuyaus.com
[01-01 07:00:01 TUYA N][mqtt_client.c:1427] mqtt get serve ip success
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1575 pts:833325 ts:0[0m
[01-01 07:00:01 TUYA D][mqtt_client.c:932] serverIP 918318504 port:8883
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:827 pts:866658 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:2558 pts:899991 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:5910 pts:933324 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:987 pts:966657 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:2653 pts:999990 ts:0[0m
[01-01 07:00:01 TUYA D][mqtt_client.c:957] mqtt over TLS is enabled. Host:m2.tuyaus.com Port:8883
[01-01 07:00:01 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[01-01 07:00:01 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect m2.tuyaus.com:8883  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[01-01 07:00:01 TUYA D][tuya_tls.c:1379] load tuya cert.
[01-01 07:00:01 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[01-01 07:00:01 TUYA D][tuya_iot_com_api.c:259] tuya public url
[01-01 07:00:01 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:5764 pts:1033323 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1610 pts:1066656 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:785 pts:1099989 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:4661 pts:1133322 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1213 pts:1166655 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1230 pts:1199988 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:4412 pts:1233321 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:1846 pts:1266654 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:969 pts:1299987 ts:0[0m
[0;31m[4190] [ERR] [tuya_app_media.c:380]: Put Frame Fail.-2  type:0 size:2511 pts:1333320 ts:0[0m
[01-01 07:00:02 TUYA D][tuya_tls.c:1539] handshake finish for m2.tuyaus.com. set send/recv to user set
[01-01 07:00:02 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect m2.tuyaus.com:8883  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[01-01 07:00:02 TUYA N][mqtt_client.c:1465] mqtt create success, begin to connect
[01-01 07:00:02 TUYA D][mqc_app.c:308] TLS Mode:4
ioctl error
[01-01 07:00:02 TUYA D][mqtt_client.c:1347] cnt 1
[01-01 07:00:02 TUYA D][mqtt_client.c:1047] mqtt subscribe success
[01-01 07:00:02 TUYA D][mqc_app.c:732] mqtt connect success
[01-01 07:00:02 TUYA D][tuya_ipc_moto_mqtt.c:69] book topic start
[01-01 07:00:02 TUYA D][mqtt_client.c:1918] subscribe new topic /av/d/eb510a0dc949229902doie ret:1 
[01-01 07:00:02 TUYA D][tuya_ipc_moto_mqtt.c:73] book topic done
[0;37m[4190] [DBG] [tuya_app_sysctl.c:116]: Net status change to:11[0m
curr event:4 
[0;37m[4190] [DBG] [tuya_app_sysctl.c:128]: mqtt is online
[0m
mqtt subscribe ack 5
90 03 00 02 00 
[0;37m[4190] [DBG] [main.c:70]: tuya_ipc_sdk_mqtt_online_proc is start run
[0m
[01-01 07:00:03 TUYA D][tuya_ipc_sdk_info.c:116] no service time now, force sync
[01-01 07:00:03 TUYA D][iot_httpc.c:1161] Post Data: {"devId":"eb510a0dc949229902doie","lastFetchTime":"0","t":3}
[01-01 07:00:03 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.timer.count&devId=eb510a0dc949229902doie&et=1&t=3&v=4.2&sign=943146c39a589c21da8b08218d03e5c2
[01-01 07:00:03 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443  -->>
[01-01 07:00:03 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 2
[01-01 07:00:03 TUYA D][uni_network.c:353] use dynamic dns ip:100.21.15.118 for domain:a2.tuyaus.com
[01-01 07:00:03 TUYA D][httpc.c:477] ----got ipaddr:100,21,15,118
[01-01 07:00:03 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:7  -->>
[0;37m[4190] [DBG] [tuya_app_sysctl.c:116]: Net status change to:7[0m
curr event:4 
[0m
[01-01 07:00:03 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:7  <<--
ioctl error
[01-01 07:00:03 TUYA D][tuya_iot_wired_wifi_api.c:504] wifi ip: 192.168.1.85, inet_addr(wifi_ip.ip): 0xc0a80155, mq_ip:0xc0a80155.
[01-01 07:00:03 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[01-01 07:00:03 TUYA D][simplekv.c:1251] find key:11 em_sys_env
[01-01 07:00:03 TUYA D][simplekv.c:1280] key:em_sys_env find value.Len:32
[01-01 07:00:03 TUYA D][svc_online_log.c:173] load env success arm-anykav500-linux
[01-01 07:00:03 TUYA D][svc_online_log.c:176] env arm-anykav500-linux same. need not to update
[01-01 07:00:03 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443  --<< ,r:0
[01-01 07:00:03 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[01-01 07:00:03 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyaus.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[01-01 07:00:03 TUYA D][tuya_tls.c:1379] load tuya cert.
[01-01 07:00:03 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[01-01 07:00:03 TUYA D][tuya_iot_com_api.c:259] tuya public url
[01-01 07:00:03 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[01-01 07:00:04 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyaus.com. set send/recv to user set
[01-01 07:00:04 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyaus.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
ioctl error
[01-01 07:00:04 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"devId":"eb510a0dc949229902doie","code":"200","count":0,"lastFetchTime":0},"t":1676264493,"success":true}
[02-13 12:01:33 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[02-13 12:01:33 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[02-13 12:01:33 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1676264493 25200
[02-13 12:01:33 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1676264493 25200
[0;37m[4190] [DBG] [tuya_app_p2p.c:393]: Init P2P With Max Users:5[0m
[02-13 12:01:33 TUYA D][tuya_ipc_webrtc.c:1531] begin___
[02-13 12:01:33 TUYA D][tuya_ipc_webrtc.c:1538] --audio-:8000,format:101
[02-13 12:01:33 TUYA D][tuya_ipc_webrtc.c:1539] end___ audiocbk_hdl(0x182c8)
[02-13 12:01:33 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:5081] gw actived
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:5090] p2p max_client_num[5]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:5091] p2p init media info:
[02-13 12:01:33 TUYA D][tuya_ipc_webrtc.c:1523] webrtc playback start_id 5
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4784] video codec[18] fps[20] gop[20]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4785] height[1080] width[1920] bitrate[512]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4785] height[720] width[1280] bitrate[512]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4796] video codec[18] fps[20] gop[20]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4797] height[1080] width[1920] bitrate[512]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4797] height[720] width[1280] bitrate[512]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4796] video codec[0] fps[0] gop[0]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4797] height[0] width[0] bitrate[0]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4799] videoNum[2] audio codec[129] sample[0]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4800] databits[1] channel[0]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:5117] need speaker audio codec[133] sample[0] databits[1] channel[0] defLiveMode[0]
[02-13 12:01:33 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[02-13 12:01:33 TUYA D][simplekv.c:1251] find key:4 p2p_pwd
[02-13 12:01:33 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[02-13 12:01:33 TUYA D][tuya_ipc_p2p_common.c:264] get p2p passwd = ade4a7f6
[02-13 12:01:33 TUYA D][tuya_ipc_p2p_common.c:400] check p2p auth update or not
[02-13 12:01:33 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[02-13 12:01:33 TUYA D][simplekv.c:1251] find key:10 p2p_auth_info
[02-13 12:01:33 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[02-13 12:01:33 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[02-13 12:01:33 TUYA D][simplekv.c:1251] find key:12 p2p_type
[02-13 12:01:33 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[02-13 12:01:33 TUYA D][tuya_ipc_p2p_common.c:471] no need update p2p_auth_info from service
[02-13 12:01:33 TUYA D][tuya_ipc_p2p_common.c:120] load str:{"p2pId":"","type":4}
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:5173] p2p did[] apiLicense[] initString[]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:5176] support p2p type = 4
P2P API Version: 244.3.4.7
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4977] no encrypt
tuya liteos uv
[02-13 12:01:33 TUYA D][smart_frame.c:2112] Start To Sync Dev:eb510a0dc949229902doie, dp_rept_chan:1
[02-13 12:01:33 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:5.
[02-13 12:01:33 TUYA D][smart_frame.c:2517] Nothing To Pack
[02-13 12:01:33 TUYA D][smart_frame.c:2164] Sync Finish
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:5034] _mqtt_p2p_listen_sessions create
[02-13 12:01:33 TUYA E][tuya_ipc_p2p.c:5185] p2p v3 init ok
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:5225] speaker task create success
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:5268] __p2p_session_detech create
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:5285] __p2p_video_send_proc create ok
[02-13 12:01:33 TUYA D][tuya_ipc_upnp.c:432] tuya_ipc_upnp_init start
[02-13 12:01:33 TUYA I][uni_thread.c:228] thread_create name:ipc_upnp,stackDepth:65536,totalstackDepth:87552,priority:2
[02-13 12:01:33 TUYA D][tuya_ipc_upnp.c:449] tuya_ipc_upnp_init success
[02-13 12:01:33 TUYA E][tuya_ipc_streamer.c:1451] tstream init start
[02-13 12:01:33 TUYA D][tuya_ipc_packager.c:62] get packager instance
[02-13 12:01:33 TUYA D][tuya_ipc_packager.c:72] get packager instance done
[02-13 12:01:33 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[02-13 12:01:33 TUYA D][simplekv.c:1251] find key:13 cloud_enc_key
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4117] Begin to Listen mqtt p2p client connects In Thread
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4130] mqtt p2p LISTEN session........
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:4655] Begin to session detech
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:3764] into p2p video send
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:3776] video send proc alive [0]
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:3546] New Thread To proc, init source
[02-13 12:01:33 TUYA D][tuya_ipc_p2p.c:3565] session cmd recv proc alive [0] num[0]
[02-13 12:01:33 TUYA D][uni_thread.c:250] Thread:ipc_upnp Exec Start. Set to Running Stat
[02-13 12:01:33 TUYA D][iot_httpc.c:1161] Post Data: {"version":"1.0","t":1676264493}
[02-13 12:01:33 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.upnp.config.get&devId=eb510a0dc949229902doie&et=1&t=1676264493&v=1.0&sign=425708f45ded696ca80b80b31f0d80a7
[02-13 12:01:33 TUYA D][httpc.c:813] Connect: a2.tuyaus.com Port: 443  -->>
[02-13 12:01:33 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyaus.com, prio 2
[02-13 12:01:33 TUYA D][uni_network.c:353] use dynamic dns ip:100.21.15.118 for domain:a2.tuyaus.com
[02-13 12:01:33 TUYA D][httpc.c:477] ----got ipaddr:100,21,15,118
[02-13 12:01:33 TUYA D][simplekv.c:1280] key:cloud_enc_key find value.Len:32
[02-13 12:01:33 TUYA I][uni_thread.c:228] thread_create name:streamer,stackDepth:8192,totalstackDepth:95744,priority:3
[02-13 12:01:33 TUYA E][tuya_ipc_streamer.c:1519] tstream init done
[02-13 12:01:33 TUYA D][tuya_ipc_streamer.c:1406] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":2,\"sampleRate\":90000,\"profileId\":\"\",\"width\":1920,\"height\":1080},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":1280,\"height\":720}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]
[02-13 12:01:33 TUYA D][iot_httpc.c:1161] Post Data: {"skill":"{\"sdk_version\":\"5.3.28\",\"cloudGW\":1,\"webrtc\":115,\"p2p\":99,\"video_num\":2,\"videos\":[{\"streamType\":2,\"codecType\":2,\"sampleRate\":90000,\"profileId\":\"\",\"width\":1920,\"height\":1080},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":1280,\"height\":720}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]}","t":1676264493}
[02-13 12:01:33 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyaus.com/d.json?a=tuya.device.skill.update&devId=eb510a0dc949229902doie&et=1&t=1676264493&v=1.0&sign=fea43640d33d497a427a55aca5803ee0
[02-13 12:01:33 TUYA D][uni_thread.c:250] Thread:streamer Exec Start. Set to Running Stat
[02-13 12:01:33 TUYA D][tuya_ipc_streamer.c:1236] ThreadStreaming thread start
[02-13 12:01:33 TUYA D][tuya_ipc_moto_mqtt.c:59] topic already booked!
[signal_handle, 37] get signal(2) thread(4190) name(tuya_fw)
[02-13 12:01:33 TUYA D][httpc.c:815] Connect: a2.tuyaus.com Port: 443  --<< ,r:0
[02-13 12:01:33 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[02-13 12:01:33 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyaus.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[02-13 12:01:33 TUYA D][tuya_tls.c:1379] load tuya cert.
[02-13 12:01:33 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[02-13 12:01:33 TUYA D][tuya_iot_com_api.c:259] tuya public url
