1315951 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1315960 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:27:44 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:27:44 D] heartcnt = 45 getmapheart = 0 getmapflag = -1 app_msg=0x2c [2022-12-23 09:27:46 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:27:46 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 1318841 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: [2022-12-23 09:27:46 D] heartcnt = 46 getmapheart = 0 getmapflag = -1 process signaling candidate 1318884 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: [2022-12-23 09:27:46 D] hoslam end type = 44 app_msg=0x2b can not find rtc session [2022-12-23 09:27:46 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:27:46 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:27:46 D] hoslam end type = 43 [2022-12-23 09:27:46 I] app_debug = 0 [2022-12-23 09:27:48 D] heartcnt = 47 getmapheart = 0 getmapflag = -1 1321504 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1321519 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [daemon] memory_monitor: tcp/udp use 316 KB app_msg=0x2c [2022-12-23 09:27:50 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:27:50 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:27:50 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:27:50 D] heartcnt = 48 getmapheart = 0 getmapflag = -1 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:27:50 D] hoslam type = 43 [2022-12-23 09:27:50 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:27:50 D] hoslam end type = 43 1324293 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1324304 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:27:52 D] heartcnt = 49 getmapheart = 0 getmapflag = -1 app_msg=0x2c [2022-12-23 09:27:54 D] MSG_ROOMS_GET_WORKING_ROOMS 1326795 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: v4 rooms, count=0 process signaling candidate 1326821 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session ack_msg=0x2c,-1, ret=0 [2022-12-23 09:27:54 D] hoslam type = 44 app_msg=0x2b [2022-12-23 09:27:54 D] heartcnt = 50 getmapheart = 0 getmapflag = -1 [2022-12-23 09:27:54 D] hoslam end type = 44 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:27:54 D] hoslam type = 43 [2022-12-23 09:27:54 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:27:54 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:27:54 D] hoslam end type = 43 [2022-12-23 09:27:56 D] heartcnt = 51 getmapheart = 0 getmapflag = -1 [2022-12-23 09:27:56 I] app_debug = 0 1330242 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1330259 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling app_msg=0x2c [2022-12-23 09:27:58 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:27:58 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:27:58 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:27:58 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:27:58 D] heartcnt = 52 getmapheart = 0 getmapflag = -1 [2022-12-23 09:27:58 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:27:58 D] hoslam end type = 43 [daemon] memory_monitor: tcp/udp use 316 KB 1332602 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1332634 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:28:00 D] heartcnt = 53 getmapheart = 0 getmapflag = -1 [daemon] daemon is running app_msg=0x2c [2022-12-23 09:28:02 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:02 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 app_msg=0x2b [2022-12-23 09:28:02 D] hoslam end type = 44 [2022-12-23 09:28:02 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:02 D] heartcnt = 54 getmapheart = 0 getmapflag = -1 [2022-12-23 09:28:02 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:02 D] hoslam end type = 43 1335862 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1335905 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:28:04 D] heartcnt = 55 getmapheart = 0 getmapflag = -1 app_msg=0x2c [2022-12-23 09:28:06 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:28:06 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 1338989 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: [2022-12-23 09:28:06 D] hoslam type = 44 process signaling candidate ack_msg=0x2c,-1, ret=0 1339026 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:28:06 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:28:06 D] hoslam type = 43 [2022-12-23 09:28:06 D] heartcnt = 56 getmapheart = 0 getmapflag = -1 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:06 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:06 D] hoslam end type = 43 [2022-12-23 09:28:06 I] app_debug = 0 [daemon] memory_monitor: demo_rplidar use (6280, 5294, 5084) KB [2022-12-23 09:28:08 D] heartcnt = 57 getmapheart = 0 getmapflag = -1 1342781 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1342817 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session app_msg=0x2c [2022-12-23 09:28:10 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:10 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:28:10 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:28:10 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:10 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:10 D] heartcnt = 58 getmapheart = 0 getmapflag = -1 [2022-12-23 09:28:10 D] hoslam end type = 43 [2022-12-23 09:28:12 D] heartcnt = 59 getmapheart = 0 getmapflag = -1 1346051 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1346099 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [daemon] memory_monitor: wifi_app_server use (4096, 3128, 2908) KB app_msg=0x2c [2022-12-23 09:28:14 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:14 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:28:14 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:28:14 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:14 D] heartcnt = 60 getmapheart = 0 getmapflag = -1 [2022-12-23 09:28:14 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:14 D] hoslam end type = 43 1348821 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1348848 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:28:16 D] heartcnt = 1 getmapheart = 0 getmapflag = -1 [2022-12-23 09:28:17 I] app_debug = 0 app_msg=0x2c [2022-12-23 09:28:18 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:18 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:28:18 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:28:18 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:28:18 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:18 D] heartcnt = 2 getmapheart = 0 getmapflag = -1 [2022-12-23 09:28:18 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:18 D] hoslam end type = 43 [2022-12-23 09:28:20 D] heartcnt = 3 getmapheart = 0 getmapflag = -1 app_msg=0x2c [2022-12-23 09:28:22 I] Get Conn AP RSSI:98[2022-12-23 09:28:22 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:22 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:28:22 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:28:22 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:22 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:22 D] heartcnt = 4 getmapheart = 0 getmapflag = -1 [2022-12-23 09:28:22 D] hoslam end type = 43 [daemon] memory_monitor: tcp/udp use 308 KB [2022-12-23 09:28:24 D] heartcnt = 5 getmapheart = 0 getmapflag = -1 1357780 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1358727 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1358959 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) app_msg=0x2c [2022-12-23 09:28:26 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:26 D] hoslam type = 44 1359153 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: ack_msg=0x2c,-1, ret=0 system has ipv4(yes), has ipv6(no) [2022-12-23 09:28:26 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:28:26 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:26 D] heartcnt = 6 getmapheart = 0 getmapflag = -1 watcher add 15, nfds 2 [2022-12-23 09:28:26 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:27 D] hoslam end type = 43 [2022-12-23 09:28:27 I] app_debug = 0 watcher add 16, nfds 3 1359809 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_ice.c:1664: ice 60 state change: CANDIDATE -> CHECK connect ret -1 watcher add 17, nfds 4 error = 0 watcher remove 17, nfds 3 watcher add 17, nfds 4 1360498 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 17 state change: CONNECT -> REQUEST 1361289 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 17 state change: REQUEST -> ACK [2022-12-23 09:28:28 D] heartcnt = 7 getmapheart = 0 getmapflag = -1 1361490 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate app_msg=0x2c [2022-12-23 09:28:30 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:30 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:28:30 D] hoslam end type = 44 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:30 D] hoslam type = 43 [2022-12-23 09:28:30 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:30 D] heartcnt = 8 getmapheart = 0 getmapflag = -1 [2022-12-23 09:28:30 D] hoslam end type = 43 [daemon] memory_monitor: demo_rplidar use (6280, 5310, 5084) KB 1365358 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [2022-12-23 09:28:31 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:28:33 D] heartcnt = 9 getmapheart = 0 getmapflag = -1 app_msg=0x2c [2022-12-23 09:28:34 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:34 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:28:34 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:28:34 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:34 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:35 D] hoslam end type = 43 [2022-12-23 09:28:35 D] heartcnt = 10 getmapheart = 0 getmapflag = -1 [ 1368.323832] BSS Changed use_cts_prot[1] [ 1368.328638] BSS_CHANGED_HT: Untreated!! [ 1368.333394] NL80211_IFTYPE_STATION!! [ 1368.337349] [I] ssv6200_bss_info_changed(): leave 1369260 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp.c:243: tcp handshake timeout 1369291 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:910: rtc session 0001003c on tcp status: -1, cost: 11319 1369312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1254: rtc 0001003c transport update 1: 0 -1 -1, 0 0 0 [2022-12-23 09:28:37 D] heartcnt = 11 getmapheart = 0 getmapflag = -1 1369635 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: [2022-12-23 09:28:37 I] app_debug = 0 process signaling candidate app_msg=0x2c [2022-12-23 09:28:38 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:38 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 1371350 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:724: [2022-12-23 09:28:38 D] hoslam end type = 44 tcp wait handshake complete timeout app_msg=0x2b 1371392 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 17 state change: ACK -> FAILED ack_msg=0x2b,-1, ret=0 watcher remove 17, nfds 3 [2022-12-23 09:28:38 D] hoslam type = 43 [2022-12-23 09:28:39 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:39 D] heartcnt = 12 getmapheart = 0 getmapflag = -1 [2022-12-23 09:28:39 D] heartcnt = 12 getmapheart = 0 getmapflag = -1 hoslam end type = 43 [ 1371.636516] BSS Changed use_cts_prot[0] [ 1371.641369] BSS_CHANGED_HT: Untreated!! [ 1371.645637] NL80211_IFTYPE_STATION!! [ 1371.649564] [I] ssv6200_bss_info_changed(): leave [daemon] memory_monitor: wifi_app_server use (4096, 3147, 2908) KB 1373165 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1876: rtc session 0001003c connect timeout 1373190 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 0001003c state change: P2P_CONNECT -> FAILED [2022-12-23 09:28:41 D] heartcnt = 13 getmapheart = 0 getmapflag = -1 1374303 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 0001003c watcher remove 15, nfds 2 watcher remove 16, nfds 1 1374622 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1374661 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session app_msg=0x2c [2022-12-23 09:28:42 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:42 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:28:42 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:28:43 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:43 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:43 D] heartcnt = 14 getma[2022-12-23 09:28:43 D] heartcnt = 14 getmapheart = 0 getmapflag = -1 1376780 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1376794 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:28:45 D] heartcnt = 15 getmapheart = 0 getmapflag = -1 app_msg=0x2c [2022-12-23 09:28:45 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:28:46 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:46 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:28:46 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:28:47 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:47 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:47 D] hoslam end type = 43 [2022-12-23 09:28:47 D] heartcnt = 16 getmapheart = 0 getmapflag = -1 [2022-12-23 09:28:47 I] app_debug = 0 1379800 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1379867 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling [2022-12-23 09:28:49 D] heartcnt = 17 getmapheart = 0 getmapflag = -1 [daemon] memory_monitor: tcp/udp use 316 KB 1382479 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1382496 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session app_msg=0x2c [2022-12-23 09:28:50 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:50 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:28:50 D] hoslam end type = 44 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:51 D] hoslam type = 43 [2022-12-23 09:28:51 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:51 D] hoslam end type = 43 [2022-12-23 09:28:51 D] heartcnt = 18 getmapheart = 0 getmapflag = -1 [2022-12-23 09:28:53 D] heartcnt = 19 getmapheart = 0 getmapflag = -1 1385744 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1385763 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session app_msg=0x2c [2022-12-23 09:28:54 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:28:54 D] hoslam type = 44 app_msg=0x2b [2022-12-23 09:28:55 D] hoslam end type = 44 [2022-12-23 09:28:55 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:55 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:55 D] hoslam end type = 43 [2022-12-23 09:28:55 D] heartcnt = 20 getmapheart = 0 getmapflag = -1 1388903 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1388914 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:28:57 D] heartcnt = 21 getmapheart = 0 getmapflag = -1 [2022-12-23 09:28:57 I] app_debug = 0 [daemon] memory_monitor: demo_rplidar use (6280, 5306, 5084) KB app_msg=0x2c [2022-12-23 09:28:57 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:28:58 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:28:59 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:28:59 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:28:59 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:28:59 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:28:59 D] hoslam end type = 43 [2022-12-23 09:28:59 D] heartcnt = 22 getmapheart = 0 getmapflag = -1 1392222 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1392268 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [daemon] daemon is running [2022-12-23 09:29:01 D] heartcnt = 23 getmapheart = 0 getmapflag = -1 app_msg=0x2c [2022-12-23 09:29:02 D] MSG_ROOMS_GET_WORKING_ROOMS 1395469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: v4 rooms, count=0 process signaling candidate 1395511 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:29:03 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:03 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:29:03 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:03 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:03 D] hoslam end type = 43 [2022-12-23 09:29:03 D] heartcnt = 24 getmapheart = 0 getmapflag = -1 [daemon] memory_monitor: wifi_app_server use (4096, 3140, 2908) KB [2022-12-23 09:29:05 D] heartcnt = 25 getmapheart = 0 getmapflag = -1 1398347 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1398421 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling app_msg=0x2c [2022-12-23 09:29:06 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:07 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:07 D] hoslam end type = 44 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:07 D] hoslam type = 43 [2022-12-23 09:29:07 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:07 D] hoslam end type = 43 [2022-12-23 09:29:07 D] heartcnt = 26 getmapheart = 0 getmapflag = -1 [2022-12-23 09:29:07 I] app_debug = 0 1401181 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1401215 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:29:09 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:29:09 D] heartcnt = 27 getmapheart = 0 getmapflag = -1 app_msg=0x2c [2022-12-23 09:29:11 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:11 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 app_msg=0x2b [2022-12-23 09:29:11 D] hoslam end type = 44 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:11 D] hoslam type = 43 [2022-12-23 09:29:11 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:11 D] hoslam end type = 43 [2022-12-23 09:29:11 D] heartcnt = 28 getmapheart = 0 getmapflag = -1 1404289 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1404344 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:29:13 D] heartcnt = 29 getmapheart = 0 getmapflag = -1 [daemon] memory_monitor: tcp/udp use 316 KB 1407069 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1407107 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session app_msg=0x2c [2022-12-23 09:29:15 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:15 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:15 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:29:15 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:15 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:15 D] hoslam end type = 43 [2022-12-23 09:29:15 D] heartcnt = 30 getmapheart = 0 getmapflag = -1 [2022-12-23 09:29:17 D] heartcnt = 31 getmapheart = 0 getmapflag = -1 [2022-12-23 09:29:17 I] app_debug = 0 1410441 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1410482 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session app_msg=0x2c [2022-12-23 09:29:19 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:19 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:19 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:29:19 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:19 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:19 D] hoslam end type = 43 [2022-12-23 09:29:19 D] heartcnt = 32 getmapheart = 0 getmapflag = -1 1413919 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1413966 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:29:21 D] heartcnt = 33 getmapheart = 0 getmapflag = -1 [daemon] memory_monitor: demo_rplidar use (6280, 5310, 5084) KB app_msg=0x2c [2022-12-23 09:29:21 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:29:23 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:23 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:23 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:29:23 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:23 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:23 D] hoslam end type = 43 [2022-12-23 09:29:23 D] heartcnt = 34 getmapheart = 0 getmapflag = -1 1417631 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1417637 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:29:25 D] heartcnt = 35 getmapheart = 0 getmapflag = -1 app_msg=0x2c [2022-12-23 09:29:27 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:27 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:27 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:29:27 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:27 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:27 D] hoslam end type = 43 [2022-12-23 09:29:27 I] app_debug = 0 [2022-12-23 09:29:27 D] heartcnt = 36 getmapheart = 0 getmapflag = -1 [daemon] memory_monitor: wifi_app_server use (4096, 3145, 2908) KB 1421249 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1421885 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1422034 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1422141 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) [2022-12-23 09:29:29 D] heartcnt = 37 getmapheart = 0 getmapflag = -1 watcher add 15, nfds 2 watcher add 16, nfds 3 1422638 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_ice.c:1664: ice 61 state change: CANDIDATE -> CHECK connect ret -1 watcher add 17, nfds 4 error = 0 watcher remove 17, nfds 3 watcher add 17, nfds 4 1423249 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 17 state change: CONNECT -> REQUEST app_msg=0x2c [2022-12-23 09:29:31 D] MSG_ROOMS_GET_WORKING_ROOMS 1423671 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 17 state change: REQUEST -> ACK v4 rooms, count=0 [2022-12-23 09:29:31 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:31 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:29:31 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:31 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:31 D] hoslam end type = 43 [2022-12-23 09:29:31 D] heartcnt = 38 getmapheart = 0 getmapflag = -1 1424623 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [2022-12-23 09:29:33 D] heartcnt = 39 getmapheart = 0 getmapflag = -1 app_msg=0x2c [2022-12-23 09:29:34 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:29:35 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:35 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 1427830 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [2022-12-23 09:29:35 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:29:35 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:35 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:35 D] hoslam end type = 43 [2022-12-23 09:29:35 D] heartcnt = 40 getmapheart = 0 getmapflag = -1 [2022-12-23 09:29:37 I] app_debug = 0 [2022-12-23 09:29:37 D] heartcnt = 41 getmapheart = 0 getmapflag = -1 [daemon] memory_monitor: tcp/udp use 308 KB app_msg=0x2c [2022-12-23 09:29:39 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 1431824 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: [2022-12-23 09:29:39 D] hoslam type = 44 process signaling candidate ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:39 D] hoslam end type = 44 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:39 D] hoslam type = 43 [2022-12-23 09:29:39 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:39 D] hoslam end type = 43 1432265 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp.c:243: tcp handshake timeout 1432308 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:910: rtc session 0001003d on tcp status: -1, cost: 10905 1432346 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1254: [2022-12-23 09:29:39 D] heartcnt = 42 getmapheart = 0 getmapflag = -1 rtc 0001003d transport update 1: 0 -1 -1, 0 0 0 1433712 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:724: tcp wait handshake complete timeout 1433748 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 17 state change: ACK -> FAILED watcher remove 17, nfds 3 [2022-12-23 09:29:41 D] heartcnt = 43 getmapheart = 0 getmapflag = -1 1435529 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate app_msg=0x2c [2022-12-23 09:29:43 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:43 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:43 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:29:43 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:43 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:43 D] hoslam end type = 43 [2022-12-23 09:29:43 D] heartcnt = 44 getmapheart = 0 getmapflag = -1 1436582 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1876: rtc session 0001003d connect timeout 1436613 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 0001003d state change: P2P_CONNECT -> FAILED 1437860 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 0001003d watcher remove 15, nfds 2 watcher remove 16, nfds 1 [2022-12-23 09:29:45 D] heartcnt = 45 getmapheart = 0 getmapflag = -1 [daemon] memory_monitor: demo_rplidar use (6280, 5308, 5084) KB 1439409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1439421 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session app_msg=0x2c [2022-12-23 09:29:47 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:47 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:47 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:29:47 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:47 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:47 D] hoslam end type = 43 [2022-12-23 09:29:47 I] app_debug = 0 [2022-12-23 09:29:47 D] heartcnt = 46 getmapheart = 0 getmapflag = -1 [2022-12-23 09:29:49 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:29:50 D] heartcnt = 47 getmapheart = 0 getmapflag = -1 1443438 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1443484 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling app_msg=0x2c [2022-12-23 09:29:51 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:51 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:51 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:29:51 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:51 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:51 D] hoslam end type = 43 [2022-12-23 09:29:52 D] heartcnt = 48 getmapheart = 0 getmapflag = -1 [daemon] memory_monitor: wifi_app_server use (4096, 3121, 2908) KB [2022-12-23 09:29:54 D] heartcnt = 49 getmapheart = 0 getmapflag = -1 1446669 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1446698 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session app_msg=0x2c [2022-12-23 09:29:55 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:55 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:55 D] hoslam end type = 44 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:55 D] hoslam type = 43 [2022-12-23 09:29:55 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:55 D] hoslam end type = 43 [2022-12-23 09:29:56 D] heartcnt = 50 getmapheart = 0 getmapflag = -1 1449234 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1449278 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:29:57 I] app_debug = 0 [2022-12-23 09:29:58 D] heartcnt = 51 getmapheart = 0 getmapflag = -1 1451448 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1451471 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session app_msg=0x2c [2022-12-23 09:29:59 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:29:59 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:29:59 D] hoslam end type = 44 app_msg=0x2b [2022-12-23 09:29:59 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:29:59 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:29:59 D] hoslam end type = 43 [2022-12-23 09:30:00 D] heartcnt = 52 getmapheart = 0 getmapflag = -1 [daemon] daemon is running 1454585 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [2022-12-23 09:30:00 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:30:02 D] heartcnt = 53 getmapheart = 0 getmapflag = -1 1454597 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [daemon] memory_monitor: tcp/udp use 316 KB app_msg=0x2c [2022-12-23 09:30:03 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 [2022-12-23 09:30:03 D] hoslam type = 44 ack_msg=0x2c,-1, ret=0 app_msg=0x2b [2022-12-23 09:30:03 D] hoslam end type = 44 [2022-12-23 09:30:03 D] hoslam type = 43 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:03 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:03 D] hoslam end type = 43 [2022-12-23 09:30:04 D] heartcnt = 54 getmapheart = 0 getmapflag = -1 1457707 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1457738 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session # # [2022-12-23 09:30:06 D] heartcnt = 55 getmapheart = 0 getmapflag = -1 # # # # # # # # app_msg=0x2c [2022-12-23 09:30:07 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:30:07 D] hoslam type = 44 app_msg=0x2b [2022-12-23 09:30:07 D] hoslam end type = 44 ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:07 D] hoslam type = 43 [2022-12-23 09:30:07 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:07 D] hoslam end type = 43 [2022-12-23 09:30:08 I] app_debug = 0 1460628 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1460681 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: [2022-12-23 09:30:08 D] heartcnt = 56 getmapheart = 0 getmapflag = -1 can not find rtc session [2022-12-23 09:30:09 D] hoslam type = 9 [2022-12-23 09:30:09 D] robot_app_handle_sys_msg_wakeup [2022-12-23 09:30:09 D] robot_app_handle_sys_msg_wakeup [2022-12-23 09:30:10 D] heartcnt = 57 getmapheart = 0 getmapflag = -1 app_msg=0x2c [2022-12-23 09:30:11 D] MSG_ROOMS_GET_WORKING_ROOMS v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b [2022-12-23 09:30:12 D] heartcnt = 58 getmapheart = 0 getmapflag = -1 ack_msg=0x2b,-1, ret=0 [ 1465.147622] cpufreq: set policy PERFORMANCE 1465167 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1465169 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1465173 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1465176 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) watcher add 16, nfds 2 watcher add 15, nfds 3 1465187 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_ice.c:1664: ice 62 state change: CANDIDATE -> CHECK connect ret -1 watcher add 17, nfds 4 [2022-12-23 09:30:12 D] WIFI Get ip->ip:192.168.50.233error = 0 watcher remove 17, nfds 3 watcher add 17, nfds 4 1465223 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 17 state change: CONNECT -> REQUEST 1465260 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465263 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 17 state change: REQUEST -> ACK /root/etc/init.d/S00voice: line 33: can't create /sys/class/gpio/gpio147/direction: nonexistent directory /root/etc/init.d/S00voice: line 33: can't create /sys/class/gpio/gpio147/value: nonexistent directory 1465343 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [2022-12-23 09:30:12 D] [exit_sleep:245] SLEEP_DEEP_WIFI_ON--->exit_sleep [2022-12-23 09:30:12 D] exit powersave: 0 [2022-12-23 09:30:12 D] hoslam end type = 9 [2022-12-23 09:30:12 D] hoslam type = 3 app_msg=0x9 [2022-12-23 09:30:12 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:12 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:12 I] pro_version: V2 ,state:1 battery:67 area:0 time:0 errno:0 fan:0 water:1 con_clean:1 y_type_mop:0 dnd_mode:0 obstacles_cross:1 cliff_detect:1 edge_brush_life:11576 roll_brush_life:17576 filter_life:8576 mop_life:18000 ota state:3 clean_time_total 99,clean_area_total:84, clean_count_total:34,arrived_state:0,unit_set:0 mop_presure:0,mop_clean_mode:0,mop_state :0,dust_collection_num:0,dust_collection_switch:126 [2022-12-23 09:30:12 D] last_data_robot_sta work_mode:0 [2022-12-23 09:30:12 D] pInfo->robot_reposition_state = 0,last_robot_reposition_state = 0 [2022-12-23 09:30:12 D] ********robot_sta->robot_state:0 [2022-12-23 09:30:12 D] m_cur_scene:0,dp_state: 0 [2022-12-23 09:30:12 D] m_cur_scene:0 [2022-12-23 09:30:12 D] work_mode = 0, WORK_MODE_SMART [2022-12-23 09:30:12 I] stm report st:WORK_MODE_SMART <-> standby 0 0 [2022-12-23 09:30:12 D] #### 1 dev_report_dp_json_async return 0 [2022-12-23 09:30:12 D] ---record robot_sta string remember=standby,last=standby,now=standby [12-23 09:30:13 TUYA Err][smart_frame.c:493] devid:(null) dparr[6]:42 not find [12-23 09:30:13 TUYA Err][smart_frame.c:493] devid:(null) dparr[7]:29 not find [12-23 09:30:13 TUYA Err][smart_frame.c:493] devid:(null) dparr[8]:30 not find [12-23 09:30:13 TUYA Err][smart_frame.c:493] devid:(null) dparr[9]:31 not find [12-23 09:30:13 TUYA Err][smart_frame.c:493] devid:(null) dparr[10]:45 not find [12-23 09:30:13 TUYA Err][smart_frame.c:493] devid:(null) dparr[12]:40 not find [12-23 09:30:13 TUYA Err][smart_frame.c:493] devid:(null) dparr[13]:37 not find [12-23 09:30:13 TUYA Err][smart_frame.c:493] devid:(null) dparr[14]:38 not find [2022-12-23 09:30:12 D] #### 2 dev_report_dp_json_async return 0 [2022-12-23 09:30:12 D] #### 3 dev_report_dp_json_async return 0 [2022-12-23 09:30:12 D] edge_brush_life:11576, roll_brush_life:17576, filter_life:8576, mop_life:18000 [2022-12-23 09:30:12 D] #### iot_report_consumable_statis, dev_report_dp_json_async return: 0 [2022-12-23 09:30:12 D] hoslam end type = 3 [2022-12-23 09:30:12 D] hoslam type = 3 [2022-12-23 09:30:12 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:12 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:12 D] hoslam end type = 3 [2022-12-23 09:30:12 D] hoslam type = 44 [2022-12-23 09:30:12 D] hoslam end type = 44 [2022-12-23 09:30:12 D] hoslam type = 3 [2022-12-23 09:30:12 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:12 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:12 D] hoslam end type = 3 [2022-12-23 09:30:12 D] hoslam type = 43 [2022-12-23 09:30:12 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:12 D] hoslam end type = 43 1465404 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [2022-12-23 09:30:12 D] hoslam type = 3 [2022-12-23 09:30:12 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:12 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:12 D] hoslam end type = 3 1465452 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465520 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465537 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1465538 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1465565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465588 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465609 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465631 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465633 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465652 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1465654 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1465677 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465677 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465698 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465700 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465722 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465724 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1465729 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 0001003e close: 0,1 1465729 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 0001003e state change: P2P_CONNECT -> FAILED 1465734 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 0001003e [2022-12-23 09:30:13 D] WIFI Get ip->ip:192.168.50.233watcher remove 16, nfds 3 watcher remove 15, nfds 2 watcher remove 17, nfds 1 1465751 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1465754 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1465757 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1465757 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) watcher add 15, nfds 2 watcher add 14, nfds 3 1465764 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_ice.c:1664: ice 63 state change: CANDIDATE -> CHECK connect ret -1 watcher add 16, nfds 4 1465785 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465785 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465809 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1465810 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate error = 0 watcher remove 16, nfds 3 watcher add 16, nfds 4 1465811 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 16 state change: CONNECT -> REQUEST 1465857 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [daemon] memory_monitor: tcp/udp use 328 KB 1466143 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466143 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1466149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466151 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466151 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466150 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1466152 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466152 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466181 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1466191 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1466191 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466191 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466191 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466191 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466191 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466196 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1466200 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1466202 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1466202 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466202 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466208 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466211 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466211 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466539 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1466539 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [daemon] memory_monitor: demo_rplidar use (6280, 5318, 5084) KB 1466369 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:13 D] hoslam type = 3 [2022-12-23 09:30:14 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:14 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:14 D] hoslam end type = 3 1466543 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466543 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466543 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466543 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466543 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1466543 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466543 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466545 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1466547 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466547 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466547 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466547 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1466547 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1466554 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466554 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466554 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466555 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466555 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466888 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1466888 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466888 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466889 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466889 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466889 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466889 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1466889 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466889 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466889 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466889 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [daemon] memory_monitor: wifi_app_server use (4108, 3140, 2920) KB 1466583 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:14 D] heartcnt = 59 getmapheart = 0 getmapflag = -1 1466892 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466893 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1466894 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1466895 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1466896 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466896 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466896 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466896 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467226 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467227 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1467227 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467227 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1466908 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1467230 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467230 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1467231 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467231 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467231 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1467231 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467231 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467231 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467231 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467232 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467232 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1467232 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1467234 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467236 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467236 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467236 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467566 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467566 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1467566 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467566 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467566 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [2022-12-23 09:30:14 D] hoslam type = 3 [2022-12-23 09:30:15 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:15 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:15 D] hoslam end type = 3 1467255 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1467569 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467569 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467569 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1467569 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467569 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467569 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467569 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467570 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467570 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1467570 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1467570 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671757893wEAOLE4C 1467570 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1467572 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1467574 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467905 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1467905 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467905 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1467905 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467905 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1467905 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467906 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1467906 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467906 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1467906 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1467906 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467906 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1467906 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467906 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1467906 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467906 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1467907 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467907 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1467907 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1467907 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468236 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1468236 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468236 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468236 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468236 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468236 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: [2022-12-23 09:30:15 D] MSG_ROOMS_GET_WORKING_ROOMS app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:15 D] hoslam type = 44 [2022-12-23 09:30:15 D] hoslam end type = 44 [2022-12-23 09:30:15 D] hoslam type = 43 [2022-12-23 09:30:15 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:15 D] hoslam end type = 43 process signaling candidate 1468239 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468239 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468239 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468239 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468239 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468239 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1468239 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468240 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1468240 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671757898jP6owr0Y 1468240 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1467916 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1468244 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468244 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468574 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468574 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468574 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468574 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1468575 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:30:15 D] hoslam type = 3 [2022-12-23 09:30:16 D] recv packet : cmd = 6,length = 72 1468245 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:16 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:16 D] hoslam end type = 3 1468577 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1468910 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) [2022-12-23 09:30:16 D] hoslam end type = 3 1468914 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1468915 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 00010040 close: 0,1 1468915 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 00010040 state change: P2P_CONNECT -> FAILED 1468922 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 00010040 1468924 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1468928 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1468934 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1468933 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1468937 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1468937 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 00010041 close: 0,1 1468937 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 00010041 state change: P2P_CONNECT -> FAILED 1468954 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 00010041 1468961 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1468962 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1468968 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1468970 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1468970 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 00010042 close: 0,1 1468970 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1468970 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 00010042 state change: P2P_CONNECT -> FAILED 1468984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 00010042 1468990 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1468993 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1468997 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1469329 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 00010043 close: 0,1 1469329 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 00010043 state change: P2P_CONNECT -> FAILED 1468995 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1469334 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1469335 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 00010043 1469339 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 0001003f close: 0,1 1469339 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 0001003f state change: P2P_CONNECT -> FAILED 1469348 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 0001003f watcher remove 15, nfds 3 watcher remove 14, nfds 2 watcher remove 16, nfds 1 1469366 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1469366 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469366 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1469366 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469366 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1469366 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469366 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1469371 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1469373 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469373 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1469373 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469373 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1469373 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1469373 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1469375 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1469706 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469707 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [2022-12-23 09:30:17 D] hoslam type = 3 [2022-12-23 09:30:17 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:17 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:17 D] hoslam end type = 3 1469381 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1469710 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469710 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469711 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469711 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1469711 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469711 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469711 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469714 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469714 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469714 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1469714 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469714 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469715 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469716 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469716 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1469716 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1469716 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1469717 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1470045 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470047 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470047 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470047 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470047 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470047 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1470047 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470048 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1470049 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470049 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470049 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470049 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470049 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1470050 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470050 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470051 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470051 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470051 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470051 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1470052 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1470060 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1470386 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470386 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470387 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470388 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470388 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470388 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1470388 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470388 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470388 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470388 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470388 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470389 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1470389 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: 1470389 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop process signaling candidate 1470390 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470390 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470390 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470390 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470394 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1470394 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1470727 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470727 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470727 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470411 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:18 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:30:18 D] hoslam type = 3 [2022-12-23 09:30:18 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:18 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:18 D] hoslam end type = 3 [2022-12-23 09:30:18 D] hoslam end type = 3 1470731 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470732 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470732 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1470732 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470732 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470732 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470732 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470732 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470732 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1470733 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1470732 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470734 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1470734 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_li[0m process signaling candidate 1470734 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471065 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect [2022-12-23 09:30:18 D] heartcnt = 1 getmapheart = 0 getmapflag = -1 1470747 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1471066 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1471069 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471069 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471069 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471069 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471070 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471070 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1471071 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1471071 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471071 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471071 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471071 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471071 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471072 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1471072 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471072 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471072 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471403 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1471403 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1471084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1471406 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671757929jWyFE5UC 1471406 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1471408 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471408 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471408 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471409 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471410 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471741 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:30:19 D] hoslam type = 3 [2022-12-23 09:30:19 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:19 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:19 D] hoslam end type = 3 1471410 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1471745 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471745 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471745 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471745 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471745 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1471745 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471745 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471745 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471745 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471745 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471745 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1471746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1471746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1471746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1472074 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl16717579346Pxf2Yph 1472074 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472075 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [12-23 09:30:19 TUYA Err][mqc_app.c:728] MQ Not Find 63, Handler cnt:17, ret:0 1471752 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1472080 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472080 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472081 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472081 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: 1472081 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:19 I] Get Conn AP RSSI:98[2022-12-23 09:30:19 D] MSG_ROOMS_GET_WORKING_ROOMS app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:19 D] hoslam type = 44 [2022-12-23 09:30:19 D] hoslam end type = 44 [2022-12-23 09:30:19 D] hoslam type = 43 [2022-12-23 09:30:19 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:19 D] hoslam end type = 43 can not find rtc session 1472416 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472416 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472416 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472416 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472416 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1472417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1472746 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671757939UZdfpwFL 1472746 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1472746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472746 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:30:20 D] hoslam type = 3 [2022-12-23 09:30:20 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:20 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:20 D] hoslam end type = 3 1472430 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1472751 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472751 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472752 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472752 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472752 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472752 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472752 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1472752 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472752 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472752 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1472752 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1472753 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473084 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473085 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473085 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473085 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473085 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473085 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1473085 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473085 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1473085 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671757944TRqVq3NY 1473085 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: [2022-12-23 09:30:20 D] heartcnt = 2 getmapheart = 0 getmapflag = -1 create session failed 1473417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473417 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: 1472753 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop process signaling candidate 1473421 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473421 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473421 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473421 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1473421 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473421 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473421 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473422 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473423 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473423 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473423 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473423 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: [2022-12-23 09:30:21 D] hoslam type = 3 can not find rtc session 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473756 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: [2022-12-23 09:30:21 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:21 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:21 D] hoslam end type = 3 1473431 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop can not find rtc session 1473760 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1473761 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1473761 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1473761 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1473762 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671757950nkpiNk7H 1473762 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1474094 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1473773 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1474094 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474097 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474097 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474097 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474098 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474098 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474098 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474098 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474098 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474098 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1474098 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474098 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474098 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474098 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474098 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474099 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474099 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474099 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474099 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1474432 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session spi:1619,flag:2 1474100 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1474433 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1474436 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671757955kpALvQmd 1474437 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1474439 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474439 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474440 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [2022-12-23 09:30:22 D] hoslam type = 3 [2022-12-23 09:30:22 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:22 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:22 D] hoslam end type = 3 1474772 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474772 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474772 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474772 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474772 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474773 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474773 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474773 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1474773 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: 1474446 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop process signaling candidate 1474775 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474775 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474775 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474775 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474775 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474775 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474775 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474775 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1474775 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1474778 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1475108 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475108 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475108 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475109 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475109 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475109 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475109 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475109 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475109 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475109 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475109 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1475109 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475109 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1475109 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl16717579605IaKCJ45 1474779 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1475110 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1475115 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475115 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475115 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475115 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475115 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475447 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:30:22 D] heartcnt = 3 getmapheart = 0 getmapflag = -1 1475448 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475448 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475448 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475448 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475448 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1475448 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475448 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475448 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475779 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475780 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475780 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475780 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475780 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475780 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475780 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475780 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1475780 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475780 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1475780 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671757965smJjjN9u 1475780 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed [2022-12-23 09:30:23 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:30:23 D] hoslam type = 3 [2022-12-23 09:30:23 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:23 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:23 D] hoslam end type = 3 1475121 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1475785 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475785 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475785 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475785 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475785 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1475785 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475785 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476118 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1475786 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1476118 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476120 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476120 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1476120 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476120 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476120 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476120 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476120 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476120 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476121 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476121 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476121 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476121 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476121 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1476122 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476122 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476122 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476122 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476451 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476451 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476451 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476451 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476451 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476451 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476451 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1476451 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476451 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer [2022-12-23 09:30:23 D] MSG_ROOMS_GET_WORKING_ROOMS 1476131 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 [2022-12-23 09:30:24 D] hoslam type = 44 [2022-12-23 09:30:24 D] hoslam end type = 44 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:24 D] hoslam type = 43 [2022-12-23 09:30:24 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:24 D] hoslam end type = 43 1476457 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671757984SsjlVS0C 1476457 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1476459 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476459 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476459 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476459 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476459 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_liia_service_rtc.c:5466: can not find rtc session 1476459 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476789 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476789 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476789 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476789 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1476789 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476789 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476789 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476789 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476789 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1476790 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: [2022-12-23 09:30:24 D] hoslam type = 3 [2022-12-23 09:30:24 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:24 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:24 D] hoslam end type = 3 [daemon] memory_monitor: tcp/udp use 280 KB [12-23 09:30:24 TUYA Err][mqc_app.c:728] MQ Not Find 63, Handler cnt:17, ret:0 can not find rtc session 1477124 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477124 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477124 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477124 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477124 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1477124 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477124 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1477124 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl167175798901FaQjIz 1477125 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1476460 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1477130 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477130 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477130 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477130 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477132 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477132 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477132 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477132 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477132 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477461 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477461 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1477461 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477461 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477461 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477461 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [daemon] memory_monitor: demo_rplidar use (6280, 5309, 5084) KB 1477138 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:25 D] heartcnt = 4 getmapheart = 0 getmapflag = -1 1477463 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477463 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477465 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477465 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477465 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477465 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477465 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1477465 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477465 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477465 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477465 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477466 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477466 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477798 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477799 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477799 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477799 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477799 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1477799 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477799 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1477799 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671757995JJy5aQXy 1477799 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1477467 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:25 D] hoslam type = 3 [2022-12-23 09:30:25 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:25 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:25 D] hoslam end type = 3 1477804 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477804 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477805 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477806 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477806 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477806 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477807 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477807 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477807 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1477807 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478137 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1478137 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478137 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478137 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478137 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1477810 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1478139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1478140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478141 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478141 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478141 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478141 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: 1478142 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop can not find rtc session 1478473 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478473 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478473 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1478473 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478473 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1478473 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758000U7qbzaBh 1478473 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1478474 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478802 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478802 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478802 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478803 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478803 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478803 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478803 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478803 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478803 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478803 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1478803 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478803 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478803 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [2022-12-23 09:30:26 D] hoslam type = 3 [2022-12-23 09:30:26 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:26 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:26 D] hoslam end type = 3 1478479 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1478806 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478806 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478806 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478806 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1478806 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478806 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479135 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479135 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1479135 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479135 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1479136 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758005Z7JC8TAT 1479136 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1479136 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479136 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479136 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479136 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479136 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479136 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479136 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479136 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1478806 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1479140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1479140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479468 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479468 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479468 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479468 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479468 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479468 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479468 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479468 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479468 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1479469 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: [2022-12-23 09:30:27 D] heartcnt = 5 getmapheart = 0 getmapflag = -1 [2022-12-23 09:30:27 D] hoslam type = 3 [2022-12-23 09:30:27 D] recv packet : cmd = 6,length = 72 1479142 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop can not find rtc session 1479804 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1479804 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758010lF0zmPML 1479804 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1479804 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479804 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479804 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479804 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479804 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479804 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479804 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate [2022-12-23 09:30:27 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:27 D] hoslam end type = 3 1479804 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479806 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479808 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479808 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1479808 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479808 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1479808 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1479808 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480139 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480140 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1479811 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1480141 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758015298jQCHj 1480474 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed [2022-12-23 09:30:27 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:30:28 D] MSG_ROOMS_GET_WORKING_ROOMS app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:28 D] hoslam type = 44 [2022-12-23 09:30:28 D] hoslam end type = 44 [2022-12-23 09:30:28 D] hoslam type = 43 [2022-12-23 09:30:28 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:28 D] hoslam end type = 43 1480477 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480477 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480477 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480477 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480477 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480477 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480478 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480478 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480478 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480478 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480478 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1480478 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480478 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480478 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480478 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480478 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480478 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480810 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480810 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480810 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480810 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: [2022-12-23 09:30:28 D] hoslam type = 3 [2022-12-23 09:30:28 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:28 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:28 D] hoslam end type = 3 [2022-12-23 09:30:28 D] hoslam end type = 3 can not find rtc session 1480812 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1480812 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758866bhP0lqHc 1480812 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1480479 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1480816 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480816 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480816 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480816 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480816 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480816 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480816 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480816 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480817 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1480817 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480817 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481149 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481150 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481150 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481150 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481150 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481150 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481150 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481481 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1481482 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481482 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1481482 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl16717588712k1pnLsu 1481482 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1481482 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481482 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481482 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481482 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1480820 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1481482 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481486 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481486 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481486 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481486 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481486 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481486 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1481486 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481486 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481486 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481814 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481814 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481815 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481815 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481815 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1481815 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1481815 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:30:29 D] hoslam type = 3 1481487 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:29 D] heartcnt = 6 getmapheart = 0 getmapflag = -1 [2022-12-23 09:30:29 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:29 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:29 D] hoslam end type = 3 1481819 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1481823 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1481823 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1481823 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 00010044 close: 0,1 1481823 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 00010044 state change: P2P_CONNECT -> FAILED 1481827 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1481833 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 00010044 1481834 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1481836 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1481839 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1481840 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1481840 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 00010045 close: 0,1 1481840 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 00010045 state change: P2P_CONNECT -> FAILED 1481846 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1482174 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 00010045 1482177 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1482178 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1482182 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1482185 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1482185 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 00010046 close: 0,1 1482185 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 00010046 state change: P2P_CONNECT -> FAILED 1482194 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1482191 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 00010046 1482198 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1482201 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1482203 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1482205 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1482205 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 00010047 close: 0,1 1482205 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 00010047 state change: P2P_CONNECT -> FAILED 1482212 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 00010047 1482217 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeatep/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1482220 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1482220 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 00010048 close: 0,1 1482220 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 00010048 state change: P2P_CONNECT -> FAILED 1482222 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:30 D] hoslam type = 3 [2022-12-23 09:30:30 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:30 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:30 D] hoslam end type = 3 1482561 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 00010048 1482562 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1482562 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1482565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1482565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1482565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1482565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1482565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1482565 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1482566 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1482568 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1482569 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482569 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482569 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482569 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482901 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482902 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1482902 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482902 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482902 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482902 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482902 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482902 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1482902 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482902 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482902 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482903 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482903 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482903 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1482572 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1482907 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1482908 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482909 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482909 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482909 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482909 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483240 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1483240 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483240 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483241 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483241 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483241 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483241 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1483241 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483241 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483241 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483241 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483241 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1482910 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1483246 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1483247 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1483248 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1483250 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483252 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483253 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483253 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483253 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483584 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1483584 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483584 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483584 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483584 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483584 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483584 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1483584 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: [2022-12-23 09:30:31 D] hoslam type = 3 [2022-12-23 09:30:31 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:31 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:31 D] hoslam end type = 3 1483270 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1483587 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop process signaling candidate 1483588 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483588 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483588 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483589 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483589 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1483589 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1483590 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483591 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483591 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483591 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483922 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483922 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1483922 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483922 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483922 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483923 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483923 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483923 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1483923 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483923 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483923 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483923 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483923 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483923 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect [2022-12-23 09:30:31 D] heartcnt = 7 getmapheart = 0 getmapflag = -1 1483596 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1483926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1483927 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483927 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483927 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483927 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484255 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484255 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1484255 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484255 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484256 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484256 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484256 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1483925 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1484258 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1484258 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484258 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484258 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484258 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484258 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484258 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1484259 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1484259 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758902yp9errbF 1484259 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1484263 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484263 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484263 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484593 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484593 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484593 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484593 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484593 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484264 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:32 D] MSG_ROOMS_GET_WORKING_ROOMS app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:32 D] hoslam type = 3 [2022-12-23 09:30:32 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:32 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:32 D] hoslam end type = 3 [2022-12-23 09:30:32 D] hoslam type = 44 [2022-12-23 09:30:32 D] hoslam end type = 44 [2022-12-23 09:30:32 D] hoslam type = 43 [2022-12-23 09:30:32 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:32 D] hoslam end type = 43 1484597 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484597 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484598 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1484598 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484598 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484598 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484598 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484598 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484598 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484598 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484598 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484598 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1484926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484926 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484927 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484927 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1484927 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484598 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1484930 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1484930 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758907EE704Dv9 1484930 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1484933 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1484933 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485264 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485264 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485264 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485264 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485265 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485265 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485265 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485265 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1484935 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1485268 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1485268 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485269 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485269 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485269 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485270 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485270 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485270 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485270 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485270 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485270 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485272 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1485272 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485602 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485603 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485603 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485603 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485603 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485603 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485603 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485272 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:32 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:30:33 D] hoslam type = 3 [2022-12-23 09:30:33 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:33 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:33 D] hoslam end type = 3 1485607 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485607 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485607 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1485607 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485607 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1485607 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758912daedaTXQ 1485607 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1485609 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485609 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485609 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485609 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485941 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485941 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485941 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485941 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485941 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485941 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485941 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1485941 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485941 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1485942 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: [2022-12-23 09:30:33 D] heartcnt = 8 getmapheart = 0 getmapflag = -1 process signaling candidate 1486274 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486274 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486274 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486274 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486274 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486274 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486274 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486274 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1486274 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486275 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1486275 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758917seP7Xxhp 1486275 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: 1485611 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop create session failed 1486279 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486279 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486280 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486280 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486280 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486280 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486280 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486612 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486281 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:34 D] hoslam type = 3 [2022-12-23 09:30:34 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:34 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:34 D] hoslam end type = 3 1486613 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486617 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486617 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486945 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486945 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486945 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486945 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486945 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486945 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486945 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1486945 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486946 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1486946 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758922EwlxEbxC 1486946 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1486619 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1486950 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486950 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486951 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486951 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486951 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486951 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486951 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1486951 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486951 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487283 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487284 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1487284 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487284 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487284 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487284 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487284 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487284 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487284 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487284 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1486951 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1487287 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487287 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487287 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1487287 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487287 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487287 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487287 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487287 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487287 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1487616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487616 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1487617 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl16717589281bxmkLHD 1487617 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1487290 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [daemon] memory_monitor: tcp/udp use 164 KB [2022-12-23 09:30:35 D] hoslam type = 3 [2022-12-23 09:30:35 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:35 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:35 D] hoslam end type = 3 1487623 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487623 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487623 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487623 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487623 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487623 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487623 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487623 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487623 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487623 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487954 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1487954 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487955 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1487624 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [daemon] memory_monitor: demo_rplidar use (6280, 5321, 5084) KB 1487962 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1487962 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488293 INFO /root/r_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488293 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1488293 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488293 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1488293 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758933qCzETlhL 1488294 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1487964 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1488296 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: [daemon] memory_monitor: wifi_app_server use (4892, 3947, 3704) KB [2022-12-23 09:30:35 D] heartcnt = 9 getmapheart = 0 getmapflag = -1 got repeated offer, drop 1488298 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488299 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488299 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488299 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488300 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488300 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488300 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488300 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488300 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488300 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488300 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1488631 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488631 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488631 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_se[ 1488.711771] BSS_CHANGED_HT: Untreated!! rvice_rtc.c:5393: process signaling candidate 1488631 [ 1488.719574] NL80211_IFTYPE_STATION!! INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux[ 1488.728661] [I] ssv6200_bss_info_changed(): leave _sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488631 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488631 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488307 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:36 D] MSG_ROOMS_GET_WORKING_ROOMS app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:36 D] hoslam type = 3 [2022-12-23 09:30:36 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:36 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:36 D] hoslam end type = 3 [2022-12-23 09:30:36 D] hoslam type = 44 [2022-12-23 09:30:36 D] hoslam end type = 44 [2022-12-23 09:30:36 D] hoslam type = 43 [2022-12-23 09:30:36 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:36 D] hoslam end type = 43 1488634 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488634 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488634 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488634 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488634 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1488634 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488634 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488634 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488634 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488634 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488976 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488976 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488976 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488976 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488976 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488976 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1488976 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488637 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1488979 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1488979 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758938FeEwJjoq 1488979 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1488981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1488981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489309 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1489309 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489309 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1488985 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1489309 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489311 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489311 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489311 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489312 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489642 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489642 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489642 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1489642 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489642 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1489642 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758943QYjN21mD 1489642 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed spi:1531,flag:2 1489313 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:37 D] hoslam type = 3 [2022-12-23 09:30:37 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:37 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:37 D] hoslam end type = 3 1489649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489650 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1489980 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489980 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489980 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489980 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489980 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489980 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489652 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1489982 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489982 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489982 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489982 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489983 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1489983 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489983 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489983 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489983 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489983 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489983 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489983 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1489983 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1489983 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490313 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490313 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1490313 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490313 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1490313 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758948BN24RlkU 1490313 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1489984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:37 D] heartcnt = 10 getmapheart = 0 getmapflag = -1 1490315 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490315 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490315 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490315 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490315 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490315 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490315 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490318 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490318 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490318 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490318 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1490318 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490318 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490646 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490646 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490646 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490646 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490646 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490646 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490646 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490646 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490646 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1490646 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490646 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490322 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:37 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:30:38 D] hoslam type = 3 [2022-12-23 09:30:38 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:38 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:38 D] hoslam end type = 3 1490648 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490648 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490649 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490978 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:30:38 I] app_debug = 0 1490650 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1490978 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1490981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490981 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1490981 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758953fC3xBIiK 1490981 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1490984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490985 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1490985 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491317 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491318 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1490987 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1491321 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491321 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491321 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491321 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1491321 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491650 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1491650 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758958MxnrUbkn 1491650 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1491650 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491650 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491650 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491650 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491651 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491651 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491651 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491651 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491651 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491651 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491651 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1491651 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491651 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491651 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491651 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: [2022-12-23 09:30:39 D] hoslam type = 3 [2022-12-23 09:30:39 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:39 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:39 I] pro_version: V2 ,state:1 battery:66 area:0 time:0 errno:0 fan:0 water:1 con_clean:1 y_type_mop:0 dnd_mode:0 obstacles_cross:1 cliff_detect:1 edge_brush_life:11576 roll_brush_life:17576 filter_life:8576 mop_life:18000 ota state:3 clean_time_total 99,clean_area_total:84, clean_count_total:34,arrived_state:0,unit_set:0 mop_presure:0,mop_clean_mode:0,mop_state :0,dust_collection_num:0,dust_collection_switch:128 1491322 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop can not find rtc session 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491984 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491985 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491985 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491985 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1491985 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1491985 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1491985 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492315 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer [2022-12-23 09:30:39 D] last_data_robot_sta work_mode:0 1491989 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:39 D] pInfo->robot_reposition_state = 0,last_robot_reposition_state = 0 [2022-12-23 09:30:39 D] ********robot_sta->robot_state:0 [2022-12-23 09:30:39 D] ---record robot_sta string remember=standby,last=standby,now=standby [12-23 09:30:40 TUYA Err][smart_frame.c:493] devid:(null) dparr[6]:42 not find [12-23 09:30:40 TUYA Err][smart_frame.c:493] devid:(null) dparr[7]:29 not find [12-23 09:30:40 TUYA Err][smart_frame.c:493] devid:(null) dparr[8]:30 not find [12-23 09:30:40 TUYA Err][smart_frame.c:493] devid:(null) dparr[9]:31 not find [12-23 09:30:40 TUYA Err][smart_frame.c:493] devid:(null) dparr[10]:45 not find [12-23 09:30:40 TUYA Err][smart_frame.c:493] devid:(null) dparr[12]:40 not find [12-23 09:30:40 TUYA Err][smart_frame.c:493] devid:(null) dparr[13]:37 not find [12-23 09:30:40 TUYA Err][smart_frame.c:493] devid:(null) dparr[14]:38 not find [2022-12-23 09:30:39 D] heartcnt = 11 getmapheart = 0 getmapflag = -1 1492319 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758964Crq5RAUS 1492319 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1492322 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492322 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492322 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492322 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492322 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492322 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492324 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1492323 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:30:39 D] #### 2 dev_report_dp_json_async return 0 app_msg=0x2c 1492337 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:40 D] hoslam end type = 3 [2022-12-23 09:30:40 D] hoslam type = 3 [2022-12-23 09:30:40 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:40 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:40 D] hoslam end type = 3 [2022-12-23 09:30:40 D] hoslam end type = 3 v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 1492657 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492658 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: [2022-12-23 09:30:40 D] hoslam type = 44 [2022-12-23 09:30:40 D] hoslam end type = 44 [2022-12-23 09:30:40 D] hoslam type = 43 [2022-12-23 09:30:40 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:40 D] hoslam end type = 43 1492660 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop process signaling candidate 1492992 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492992 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492992 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492992 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492992 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492992 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492992 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492992 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1492992 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492993 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1492993 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl16717589694QeIPCI4 1492993 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1492666 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1492995 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492995 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492995 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492995 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492995 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492995 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492995 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1492995 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1493325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493325 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493326 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493326 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493326 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493326 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493326 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1493326 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493326 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493326 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493326 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1492997 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1493331 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493331 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493663 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493663 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493663 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493663 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493663 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1493663 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493664 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1493664 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758974CVJVfbB5 1493664 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed [2022-12-23 09:30:41 D] hoslam type = 3 [2022-12-23 09:30:41 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:41 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:41 D] hoslam end type = 3 1493332 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1493668 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493668 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493668 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493668 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493668 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493668 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493669 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493669 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493669 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1493669 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494001 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1494001 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494002 IN_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494002 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494003 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494334 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494334 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494334 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1494334 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1493669 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:41 D] heartcnt = 12 getmapheart = 0 getmapflag = -1 1494336 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1494337 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758979ufpJ9efC 1494337 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1494341 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494341 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494341 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494341 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494341 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494341 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494342 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494342 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494342 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494342 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494342 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1494342 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494342 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494347 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:42 D] hoslam type = 3 [2022-12-23 09:30:42 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:42 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:42 D] hoslam end type = 3 1494674 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494674 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494674 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/ba[ 1494.960605] BSS_CHANGED_HT: Untreated!! se_ice/src/tuya_media_service_rtc.c:5393: process signaling [ 1494.966231] NL80211_IFTYPE_STATION!! candidate 1494675 INFO /root/workspace_temp/Embe[ 1494.975340] [I] ssv6200_bss_info_changed(): leave dSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1494675 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495018 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1495018 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495018 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1495018 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758984BQC7blHE 1495018 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1495018 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495018 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495019 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495350 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495350 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1495351 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1494677 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1495354 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1495683 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758990rek7rYey 1495683 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1495358 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:42 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:30:43 D] hoslam type = 3 [2022-12-23 09:30:43 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:43 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:43 D] hoslam end type = 3 1495686 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1495687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496016 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496016 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496016 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496016 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496016 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496016 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1496017 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496017 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496017 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496017 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496017 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1495688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1496017 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496021 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496021 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496021 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496021 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496021 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1496021 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496021 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1496021 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671758995O0wQWVMN 1496354 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496355 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496023 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop [2022-12-23 09:30:43 D] heartcnt = 13 getmapheart = 0 getmapflag = -1 1496359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1496687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496687 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1496688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1496688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1496688 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer [2022-12-23 09:30:44 D] hoslam type = 3 [2022-12-23 09:30:44 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:44 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:44 D] hoslam end type = 3 1496359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:44 D] hoslam end type = 3 [2022-12-23 09:30:44 D] hoslam type = 44 [2022-12-23 09:30:44 D] hoslam end type = 44 [2022-12-23 09:30:44 D] hoslam type = 43 [2022-12-23 09:30:44 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:44 D] hoslam end type = 43 1496695 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl167175900038Afr932 1497026 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1497026 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497028 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497028 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497028 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497028 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497028 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497028 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497028 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1497029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497358 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497358 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497358 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1497358 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497359 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1496697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1497363 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl16717590062KNXN93z 1497363 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1497364 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497696 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497697 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1497698 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497698 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [2022-12-23 09:30:45 D] hoslam type = 3 [2022-12-23 09:30:45 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:45 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:45 D] hoslam end type = 3 1497698 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1497699 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498029 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1498030 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498030 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498030 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498030 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498030 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498030 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498030 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498030 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498030 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498030 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498031 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1498031 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498031 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1498031 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4046: incoming connection refused: 5/5, sessionid: 6c0d2d58fcb34fc800hptl1671759011wmQLfwsp 1498031 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5458: create session failed 1498032 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498033 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498033 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498033 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498033 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498362 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498362 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498363 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498363 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498363 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498363 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1498363 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498363 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498363 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498363 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498363 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498364 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498364 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498364 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498364 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1498364 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session 1498364 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1498364 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5466: can not find rtc session [daemon] memory_monitor: tcp/udp use 164 KB [2022-12-23 09:30:45 D] heartcnt = 14 getmapheart = 0 getmapflag = -1 1498367 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1498370 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1498701 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1498701 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 00010049 close: 0,1 1498701 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 00010049 state change: P2P_CONNECT -> FAILED [daemon] memory_monitor: demo_rplidar use (6280, 5321, 5084) KB [2022-12-23 09:30:46 D] hoslam type = 3 [2022-12-23 09:30:46 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:46 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:46 D] hoslam end type = 3 1498711 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 00010049 1498715 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1498720 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1498722 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1498722 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 0001004a close: 0,1 1498722 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 0001004a state change: P2P_CONNECT -> FAILED 1498728 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 0001004a 1498733 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1498737 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1498738 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1498740 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 0001004b close: 0,1 1498740 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 0001004b state change: P2P_CONNECT -> FAILED [daemon] memory_monitor: wifi_app_server use (4892, 3947, 3704) KB 1498744 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 0001004b 1498746 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1498748 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1498748 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1498750 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 0001004c close: 0,1 1498750 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 0001004c state change: P2P_CONNECT -> FAILED 1498754 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 0001004c 1499086 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1499091 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1499091 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1499091 ERROR /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1870: rtc session 0001004d close: 0,1 1499091 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 0001004d state change: P2P_CONNECT -> FAILED 1499097 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 0001004d # # # # # # # # # # # # # # # # # # # # [2022-12-23 09:30:47 D] hoslam type = 3 [2022-12-23 09:30:47 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:47 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:47 D] hoslam end type = 3 [2022-12-23 09:30:47 D] heartcnt = 15 getmapheart = 0 getmapflag = -1 [2022-12-23 09:30:48 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:30:48 D] hoslam type = 3 [2022-12-23 09:30:48 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:48 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:48 D] hoslam end type = 3 [2022-12-23 09:30:48 D] MSG_ROOMS_GET_WORKING_ROOMS app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:48 D] hoslam type = 44 [2022-12-23 09:30:48 D] hoslam end type = 44 [2022-12-23 09:30:48 D] hoslam type = 43 [2022-12-23 09:30:48 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:48 D] hoslam end type = 43 [2022-12-23 09:30:48 I] app_debug = 0 [2022-12-23 09:30:49 D] hoslam type = 3 [2022-12-23 09:30:49 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:49 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:49 D] hoslam end type = 3 [2022-12-23 09:30:49 D] heartcnt = 16 getmapheart = 0 getmapflag = -1 [2022-12-23 09:30:50 D] hoslam type = 3 [2022-12-23 09:30:50 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:50 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:50 D] hoslam end type = 3 [2022-12-23 09:30:51 D] hoslam type = 3 [2022-12-23 09:30:51 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:51 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:51 D] hoslam end type = 3 [2022-12-23 09:30:51 D] heartcnt = 17 getmapheart = 0 getmapflag = -1 [2022-12-23 09:30:52 D] hoslam type = 3 [2022-12-23 09:30:52 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:52 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:52 D] hoslam end type = 3 [2022-12-23 09:30:52 D] MSG_ROOMS_GET_WORKING_ROOMS app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:52 D] hoslam type = 44 [2022-12-23 09:30:52 D] hoslam end type = 44 [2022-12-23 09:30:52 D] hoslam type = 43 [2022-12-23 09:30:52 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:52 D] hoslam end type = 43 spi:1530,flag:2 [2022-12-23 09:30:52 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:30:53 D] hoslam type = 3 [2022-12-23 09:30:53 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:53 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:53 D] hoslam end type = 3 [2022-12-23 09:30:53 I] Get Conn AP RSSI:98[2022-12-23 09:30:53 D] heartcnt = 18 getmapheart = 0 getmapflag = -1 1506402 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling offer 1506405 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 6 first write 1506408 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) 1506408 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_misc.c:112: system has ipv4(yes), has ipv6(no) watcher add 15, nfds 2 watcher add 14, nfds 3 1506415 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_ice.c:1664: ice 78 state change: CANDIDATE -> CHECK connect ret -1 watcher add 16, nfds 4 1506437 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1506459 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate error = 0 watcher remove 16, nfds 3 watcher add 16, nfds 4 1506463 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 16 state change: CONNECT -> REQUEST 1506502 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1506518 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 16 state change: REQUEST -> ACK 1506542 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1506567 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_tcp_socket.c:783: tcp 16 state change: ACK -> STREAM 1506568 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:910: rtc session 0001004e on tcp status: 1, cost: 165 1506568 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1254: rtc 0001004e transport update 1: 0 -1 1, 0 0 100 1506568 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 0001004e state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO 1506568 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 0001004e state change: DTLS_SRTP_KEY_NEGO -> STREAM 1506568 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3589: add new rtc session 0001004e, session id 6c0d2d58fcb34fc800hptl1671759054kHEjoTNZ, connect session , status 0 1506568 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7212: listen result 0001004e 1506568 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3435: channel 6 first send [2022-12-23 09:30:54 D] hoslam type = 3 [2022-12-23 09:30:54 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:54 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:54 D] hoslam end type = 3 1506572 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1506601 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_ice.c:1664: ice 78 state change: CHECK -> CONNECTED 1506601 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:866: rtc session 0001004e on ice status: 1, cost: 198 1506601 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1254: rtc 0001004e transport update 2: 1 -1 1, 100 0 10 1506607 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1254: rtc 0001004e transport update 3: 2 -1 1, 100 0 0 1506607 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:887: rtc 0001004e on ice data, cost: 204 1506607 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3461: channel 0 get first data 1506626 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1254: rtc 0001004e transport update 4: 2 -1 2, 100 0 0 1506627 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:930: rtc 0001004e on tcp data, cost: 224 1506627 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3461: channel 6 get first data 1506628 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2268: rtc 0001004e got signaling from cmd 1506628 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7329: got repeated offer, drop 1506628 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control retransmit_signaling 1506629 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2268: rtc 0001004e got signaling from cmd 1506958 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2268: rtc 0001004e got signaling from cmd 1506959 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2268: rtc 0001004e got signaling from cmd 1506959 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2268: rtc 0001004e got signaling from cmd 1506959 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2268: rtc 0001004e got signaling from cmd 1506963 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7194: try listen 1506963 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1506964 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1506964 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1506964 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate 1506964 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling candidate p2p sweeper rev event cb=[203] __get_sweeper_handle session_id = 0 g_sweeper_ctrl[0].used = 1 g_sweeper_ctrl[1].used = 0 g_sweeper_ctrl[2].used = 0 g_sweeper_ctrl[3].used = 0 g_sweeper_ctrl[4].used = 0 g_sweeper_ctrl[5].used = 0 TRANS_ALBUM_QUERY ipc_sweeper_robot session_id [0] g_support_file = [63] 0 = [1] 1 = [1] 2 = [1] 3 = [1] 4 = [1] 5 = [1] query result count [6] file name:[map.bin] file name:[cleanPath.bin] file name:[navPath.bin] file name:[map.bin.stream] file name:[cleanPath.bin.stream] file name:[navPath.bin.stream] 1507041 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 0 first write 1507050 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3435: channel 0 first send p2p sweeper rev event cb=[204] __get_sweeper_handle session_id = 0 g_sweeper_ctrl[0].used = 1 g_sweeper_ctrl[1].used = 0 g_sweeper_ctrl[2].used = 0 g_sweeper_ctrl[3].used = 0 g_sweeper_ctrl[4].used = 0 g_sweeper_ctrl[5].used = 0 __get_sweeper_handle session_id = 0 g_sweeper_ctrl[0].used = 1 g_sweeper_ctrl[1].used = 0 g_sweeper_ctrl[2].used = 0 g_sweeper_ctrl[3].used = 0 g_sweeper_ctrl[4].used = 0 g_sweeper_ctrl[5].used = 0 session[0] start download download i = 0 download i = 0 download i = 0 download i = 1 download i = 1 download i = 1 session_id 0 transmode 2 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 0 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 1 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 2 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [3], read file :[/tmp/map.bin] send map filetype = 3 1507144 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3442: channel 5 first write SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [4], read file :[/tmp/cleanPath.bin] [12-23 09:30:55 TUYA Err][tuya_ipc_sweeper_demo.c:219] File Open Failed:/tmp/cleanPath.bin __get_sweeper_file_bufferr -1 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [5], read file :[/tmp/navPath.bin] [12-23 09:30:55 TUYA Err][tuya_ipc_sweeper_demo.c:219] File Open Failed:/tmp/navPath.bin __get_sweeper_file_bufferr -1 1507154 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3435: channel 5 first send 1507306 WARN /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:3461: channel 5 get first data [2022-12-23 09:30:55 D] hoslam type = 3 [2022-12-23 09:30:55 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:55 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:55 D] hoslam end type = 3 [2022-12-23 09:30:55 I] SOC Rev DP Obj Cmd t1:1 t2:0 CNT:1 [2022-12-23 09:30:55 I] idx:0 dpid:16 type:3 ts:1671759056 [2022-12-23 09:30:55 I] enum value:2[2022-12-23 09:30:55 I] ** rev msg: 16 app_msg=0x10 [2022-12-23 09:30:55 D] hoslam type = 17 [2022-12-23 09:30:55 I] s_vwall_arg.num = 0 [2022-12-23 09:30:55 I] s_fb_arg.num = 0 [2022-12-23 09:30:55 D] stm add virtualwall:0 forbidden:0,flag:1 [2022-12-23 09:30:55 D] hoslam end type = 17 [2022-12-23 09:30:55 I] inmap getmap [2022-12-23 09:30:55 D] heartcnt = 19 getmapheart = 1 getmapflag = 2 [2022-12-23 09:30:56 D] hoslam type = 3 [2022-12-23 09:30:56 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:56 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:56 I] pro_version: V2 ,state:1 battery:66 area:0 time:0 errno:0 fan:0 water:1 con_clean:1 y_type_mop:0 dnd_mode:0 obstacles_cross:1 cliff_detect:1 edge_brush_life:11576 roll_brush_life:17576 filter_life:8576 mop_life:18000 ota state:3 clean_time_total 99,clean_area_total:84, clean_count_total:34,arrived_state:0,unit_set:0 mop_presure:0,mop_clean_mode:0,mop_state :0,dust_collection_num:0,dust_collection_switch:128 [2022-12-23 09:30:56 D] last_data_robot_sta work_mode:0 [2022-12-23 09:30:56 D] pInfo->robot_reposition_state = 0,last_robot_reposition_state = 0 [2022-12-23 09:30:56 D] ********robot_sta->robot_state:0 [2022-12-23 09:30:56 D] m_cur_scene:0,dp_state: 0 [2022-12-23 09:30:56 D] m_cur_scene:0 [2022-12-23 09:30:56 D] work_mode = 0, WORK_MODE_SMART [2022-12-23 09:30:56 I] stm report st:WORK_MODE_SMART <-> standby 0 0 [2022-12-23 09:30:56 D] #### 1 dev_report_dp_json_async return 0 [2022-12-23 09:30:56 D] ---record robot_sta string remember=standby,last=standby,now=standby [12-23 09:30:56 TUYA Err][smart_frame.c:493] devid:(null) dparr[6]:42 not find [12-23 09:30:56 TUYA Err][smart_frame.c:493] devid:(null) dparr[7]:29 not find [12-23 09:30:56 TUYA Err][smart_frame.c:493] devid:(null) dparr[8]:30 not find [12-23 09:30:56 TUYA Err][smart_frame.c:493] devid:(null) dparr[9]:31 not find [12-23 09:30:56 TUYA Err][smart_frame.c:493] devid:(null) dparr[10]:45 not find [12-23 09:30:56 TUYA Err][smart_frame.c:493] devid:(null) dparr[12]:40 not find [12-23 09:30:56 TUYA Err][smart_frame.c:493] devid:(null) dparr[13]:37 not find [12-23 09:30:56 TUYA Err][smart_frame.c:493] devid:(null) dparr[14]:38 not find [2022-12-23 09:30:56 D] #### 2 dev_report_dp_json_async return 0 [2022-12-23 09:30:56 D] #### 3 dev_report_dp_json_async return 0 [2022-12-23 09:30:56 D] edge_brush_life:11576, roll_brush_life:17576, filter_life:8576, mop_life:18000 [2022-12-23 09:30:56 D] #### iot_report_consumable_statis, dev_report_dp_json_async return: 0 [2022-12-23 09:30:56 D] hoslam end type = 3 [2022-12-23 09:30:56 D] MSG_ROOMS_GET_WORKING_ROOMS app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:30:56 D] hoslam type = 44 [2022-12-23 09:30:56 D] hoslam end type = 44 [2022-12-23 09:30:56 D] hoslam type = 43 [2022-12-23 09:30:56 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:56 D] hoslam end type = 43 [daemon] memory_monitor: tcp/udp use 20 KB [daemon] memory_monitor: demo_rplidar use (6280, 5321, 5084) KB [daemon] memory_monitor: wifi_app_server use (4896, 3951, 3708) KB [2022-12-23 09:30:56 D] map_v2--->2bit [2022-12-23 09:30:56 D] power_on_rooms:0 [2022-12-23 09:30:56 I] map_is_editable_flag = 0 [2022-12-23 09:30:56 D] send_map->flag =1 [2022-12-23 09:30:56 D] map_v2--->2bit app_msg=0x2b ack_msg=0x2b,-1, ret=0 app_msg=0x2d [2022-12-23 09:30:56 D] hoslam type = 43 [2022-12-23 09:30:56 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:30:56 D] hoslam end type = 43 v4 rooms, count=0 ack_msg=0x2d,-1, ret=0 [2022-12-23 09:30:56 D] hoslam type = 45 [2022-12-23 09:30:56 I] rooms_count no charge [2022-12-23 09:30:56 D] hoslam end type = 45 [2022-12-23 09:30:56 D] w = 145, h = 198 [2022-12-23 09:30:56 D] colorCnt 1= 0 [2022-12-23 09:30:56 D] colorCnt2= 0 [2022-12-23 09:30:56 D] send_map->len_before_lz4 = 28712 [2022-12-23 09:30:56 I] p_rspec_arg->num = 0 [2022-12-23 09:30:56 D] send_rooms_size=2 [2022-12-23 09:30:56 I] map->w=145,map->h=198 [2022-12-23 09:30:56 I] map->ox = 73.000000,map->oy = 92.000000 [2022-12-23 09:30:56 D] mapox=73.000000,mapoy=106.000000 [2022-12-23 09:30:56 D] send_map->head=4 [2022-12-23 09:30:56 D] send_map->flag=1 [2022-12-23 09:30:56 D] send_map_size=28710 [2022-12-23 09:30:56 D] origin map len = 28712, LZ4 compressed len = 2003 [2022-12-23 09:30:56 D] ** tuya_iot_upload_map, size = 2027, cur getmapflag = 2 [2022-12-23 09:30:56 D] upload map size 2027 , used time - 1 ms [2022-12-23 09:30:56 I] (p_arg->num = 0) [2022-12-23 09:30:56 D] send forbin zone [2022-12-23 09:30:56 D] end zone [2022-12-23 09:30:56 D] send wall [2022-12-23 09:30:56 D] end wall [2022-12-23 09:30:56 I] get select room inf = 0 [2022-12-23 09:30:56 I] report all data to app [2022-12-23 09:30:56 I] *** upload_first_wirtual_wall_info to app *** [2022-12-23 09:30:56 I] ### cur_pose 0.000000, 0.000000 ### [2022-12-23 09:30:56 D] send_path->path[path->path_point_count].x = 0,send_path->path[path->path_point_count].y = 0 [2022-12-23 09:30:56 D] ### current point 0, 0 ### [2022-12-23 09:30:56 D] send_path->head = 4 [2022-12-23 09:30:56 D] send_path->num = 2 ,upload_cur_pose_flag:0 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 0 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 1 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 2 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [3], read file :[/tmp/map.bin] send map filetype = 3 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [4], read file :[/tmp/cleanPath.bin] [12-23 09:30:57 TUYA Err][tuya_ipc_sweeper_demo.c:219] File Open Failed:/tmp/cleanPath.bin __get_sweeper_file_bufferr -1 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [5], read file :[/tmp/navPath.bin] [12-23 09:30:57 TUYA Err][tuya_ipc_sweeper_demo.c:219] File Open Failed:/tmp/navPath.bin __get_sweeper_file_bufferr -1 [2022-12-23 09:30:57 D] hoslam type = 3 [2022-12-23 09:30:57 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:57 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:57 D] hoslam end type = 3 [2022-12-23 09:30:57 D] heartcnt = 20 getmapheart = 1 getmapflag = 2 [2022-12-23 09:30:57 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:30:58 D] hoslam type = 3 [2022-12-23 09:30:58 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:58 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:58 D] hoslam end type = 3 [2022-12-23 09:30:58 I] app_debug = 0 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 0 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 1 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 2 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [3], read file :[/tmp/map.bin] send map filetype = 3 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [4], read file :[/tmp/cleanPath.bin] [12-23 09:30:59 TUYA Err][tuya_ipc_sweeper_demo.c:219] File Open Failed:/tmp/cleanPath.bin __get_sweeper_file_bufferr -1 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [5], read file :[/tmp/navPath.bin] [12-23 09:30:59 TUYA Err][tuya_ipc_sweeper_demo.c:219] File Open Failed:/tmp/navPath.bin __get_sweeper_file_bufferr -1 [2022-12-23 09:30:59 D] hoslam type = 3 [2022-12-23 09:30:59 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:30:59 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:30:59 D] hoslam end type = 3 [2022-12-23 09:30:59 D] heartcnt = 21 getmapheart = 1 getmapflag = 2 [2022-12-23 09:31:00 D] hoslam type = 3 [2022-12-23 09:31:00 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:31:00 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:31:00 D] hoslam end type = 3 [2022-12-23 09:31:00 D] MSG_ROOMS_GET_WORKING_ROOMS app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:31:00 D] hoslam type = 44 [2022-12-23 09:31:00 D] hoslam end type = 44 [2022-12-23 09:31:00 D] hoslam type = 43 [2022-12-23 09:31:00 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:31:00 D] hoslam end type = 43 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 0 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 1 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 2 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [3], read file :[/tmp/map.bin] send map filetype = 3 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [4], read file :[/tmp/cleanPath.bin] [12-23 09:31:01 TUYA Err][tuya_ipc_sweeper_demo.c:219] File Open Failed:/tmp/cleanPath.bin __get_sweeper_file_bufferr -1 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [5], read file :[/tmp/navPath.bin] [12-23 09:31:01 TUYA Err][tuya_ipc_sweeper_demo.c:219] File Open Failed:/tmp/navPath.bin __get_sweeper_file_bufferr -1 [daemon] daemon is running [2022-12-23 09:31:01 D] hoslam type = 3 [2022-12-23 09:31:01 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:31:01 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:31:01 D] hoslam end type = 3 [2022-12-23 09:31:01 D] heartcnt = 22 getmapheart = 1 getmapflag = 2 [2022-12-23 09:31:02 D] hoslam type = 3 [2022-12-23 09:31:02 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:31:02 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:31:02 D] hoslam end type = 3 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 0 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 1 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 type 2 not needed SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [3], read file :[/tmp/map.bin] send map filetype = 3 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [4], read file :[/tmp/cleanPath.bin] [12-23 09:31:03 TUYA Err][tuya_ipc_sweeper_demo.c:219] File Open Failed:/tmp/cleanPath.bin __get_sweeper_file_bufferr -1 SWEEPER_CTRL = 64 index = 0 ,pSweeper = 0x1bf678,pSweeper->session_id = 0 file type [5], read file :[/tmp/navPath.bin] [12-23 09:31:03 TUYA Err][tuya_ipc_sweeper_demo.c:219] File Open Failed:/tmp/navPath.bin __get_sweeper_file_bufferr -1 [2022-12-23 09:31:03 D] WIFI Get ip->ip:192.168.50.233[2022-12-23 09:31:03 D] hoslam type = 3 [2022-12-23 09:31:03 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:31:03 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:31:03 D] hoslam end type = 3 1516037 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5393: process signaling disconnect 1516042 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:1973: rtc 0001004e closed by remote or local, local:0 remote:1 1516043 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:2118: rtc session 0001004e state change: STREAM -> FAILED [12-23 09:31:04 TUYA Err][tuya_ipc_p2p.c:3574] session[65614] was close by client ret[-13] [12-23 09:31:04 TUYA Err][tuya_ipc_p2p.c:3685] session[65614] read cmd failed [-1] 1516046 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7367: rtc session 0001004e close 1516046 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:7371: rtc session 0001004e close over ipc_sweeper_robot downlaod cancle p2p sweeper rev event cb=[205] session[0] download cancel __get_sweeper_handle session_id = 0 g_sweeper_ctrl[0].used = 1 g_sweeper_ctrl[1].used = 0 g_sweeper_ctrl[2].used = 0 g_sweeper_ctrl[3].used = 0 g_sweeper_ctrl[4].used = 0 g_sweeper_ctrl[5].used = 0 [12-23 09:31:04 TUYA Err][tuya_ipc_p2p.c:2511] speaker not start [12-23 09:31:04 TUYA Err][tuya_ipc_p2p.c:3535] session[65614] is try to releasing 1516047 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:5822: process control close 1516047 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:6174: rtc session 0001004e failed ready to close 1516047 INFO /root/workspace_temp/EmbedSDKs/ty_ipc_wr_wl_linux_sdk/ty_ipc_wr_wl_linux_sdk/sdk/base_ice/src/tuya_media_service_rtc.c:4202: destroy rtc session 0001004e watcher remove 15, nfds 3 watcher remove 14, nfds 2 watcher remove 16, nfds 1 [2022-12-23 09:31:03 D] heartcnt = 23 getmapheart = 1 getmapflag = 2 [2022-12-23 09:31:04 D] hoslam type = 3 [2022-12-23 09:31:04 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:31:04 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:31:04 D] hoslam end type = 3 [2022-12-23 09:31:04 D] MSG_ROOMS_GET_WORKING_ROOMS app_msg=0x2c v4 rooms, count=0 ack_msg=0x2c,-1, ret=0 app_msg=0x2b ack_msg=0x2b,-1, ret=0 [2022-12-23 09:31:04 D] hoslam type = 44 [2022-12-23 09:31:04 D] hoslam end type = 44 [2022-12-23 09:31:04 D] hoslam type = 43 [2022-12-23 09:31:04 D] wifi_app_msg_dp_send_set_is_editable = -1 [2022-12-23 09:31:04 D] hoslam end type = 43 session_id 0 tuya_ipc_sweeper_send_finish_2_app [12-23 09:31:05 TUYA Err][tuya_ipc_p2p.c:6365] client [0] download type[1] not start [12-23 09:31:05 TUYA Err][tuya_ipc_album_sweeper.c:128] download data failed -1, exit task [2022-12-23 09:31:05 D] hoslam type = 3 [2022-12-23 09:31:05 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:31:05 D] GET_WORKING_ROOMS_FLAG = 0 [2022-12-23 09:31:05 D] hoslam end type = 3 [2022-12-23 09:31:05 D] heartcnt = 24 getmapheart = 1 getmapflag = 2 [2022-12-23 09:31:06 D] hoslam type = 3 [2022-12-23 09:31:06 D] recv packet : cmd = 6,length = 72 [2022-12-23 09:31:06 D] GET_
