[root@vdpids /data/tfcard]$ ./tuya_sample umount /mnt/ ret=0 mount /dev/mmcblk0 ok mode = 0 --mode = 0 ---mode = 0 Dbg:SDK Version:< TUYA IOT SDK V:5.3.29 BS:40.00_PT:2.2_LAN:3.4_CAD:1.0.4_CD:1.0.0 > < BUILD AT:2022_11_28_18_27_09 BY ci_manage FOR ty_ipc_wr_wl_linux_sdk AT arm-anykav500-linux-gnueabi > IOT DEFS < WIFI_GW:1 DEBUG:1 KV_FILE:1 SHUTDOWN_MODE:1 LITTLE_END:1 TLS_MODE:4 ENABLE_CLOUD_OPERATION:1 OPERATING_SYSTEM:100 ENABLE_SYS_RPC:0 RELIABLE_TRANSFER:0 ENABLE_LAN_ENCRYPTION:1 ENABLE_LAN_LINKAGE:0 ENABLE_LAN_DEV:0 > Dbg:channel_enable:1 1 0 Dbg:fps:25 Dbg:gop:30 Dbg:bitrate:1536 kbps Dbg:video_main_width:640 Dbg:video_main_height:360 Dbg:video_freq:90000 Dbg:video_codec:2 Dbg:audio_codec:106 Dbg:audio_sample:16000 Dbg:audio_databits:16 Dbg:audio_channel:0 Dbg:tuya_ipc_sdk_mqtt_online_proc thread start success [01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /data/config/ [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/data/config/ [01-01 18:12:15 TUYA D][simplekv.c:945] path:/data/config/ [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£¢US¾򽸹kRꡝ [01-01 18:12:15 TUYA D][simplekv.c:1012] both file exist [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512 [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success [01-01 18:12:15 TUYA D][simplekv.c:1055] read from normal file [01-01 18:12:15 TUYA D][simplekv.c:765] curr db is V2. No need to upgrade [01-01 18:12:15 TUYA D][simplekv.c:555] head check success [01-01 18:12:15 TUYA D][simplekv.c:658] read and check head success [01-01 18:12:15 TUYA D][simplekv.c:1075] read from normal file success [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success. [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ... [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1 [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2 [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat [01-01 18:12:15 TUYA D][log_seq.c:894] read m:4 f:0 l:3 [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3 Dbg:init ring buffer Channel:0 Enable:1 Dbg:video_bitrate 1536, video_fps 25 Dbg:init ring buffer success. channel:0 Dbg:init ring buffer Channel:1 Enable:1 Dbg:video_bitrate 512, video_fps 25 Dbg:init ring buffer success. channel:1 Dbg:init ring buffer Channel:2 Enable:0 Dbg:init ring buffer Channel:3 Enable:0 Dbg:init ring buffer Channel:4 Enable:0 Dbg:init ring buffer Channel:5 Enable:0 Dbg:init ring buffer Channel:6 Enable:0 Dbg:init ring buffer Channel:7 Enable:0 Dbg:init ring buffer Channel:8 Enable:0 Dbg:init ring buffer Channel:9 Enable:1 Dbg:audio_sample 16000, audio_databits 16, audio_fps 25 Dbg:init ring buffer success. channel:9 Dbg:init ring buffer Channel:10 Enable:0 Dbg:init ring buffer Channel:11 Enable:0 Dbg:init ring buffer Channel:12 Enable:0 Dbg:init ring buffer Channel:13 Enable:0 Dbg:init ring buffer Channel:14 Enable:0 Dbg:init ring buffer Channel:15 Enable:0 pRunInfo->net_info.connect_mode = 0 [01-01 18:12:15 TUYA E][tuya_ipc_sdk_init.c:309] WIFI_INIT_AUTO is not support Err:start sdk is error Dbg:ipc sdk start fail,please check run parameter ret=-4
